3.14.0beta1 Available
Greg Troxel gdt at lexort.com
Tue Jul 22 07:52:53 PDT 2025
Other than not documenting API withdrawals, this seems fine.
* API changes
I built this via pkgsrc, and here are the changes in installed files.
  - 3 withdrawn headers (not apparent in NEWS)
  - 6 new headers (inferrable as expected from NEWS)
  - minor version bump, but not major, in libgeos_c (ok)
=> Checking file-check results for geos-3.14.0beta1
ERROR: ************************************************************
ERROR: The following files are in the PLIST but not in /tmp/work/geography/geos/work/.destdir/usr/pkg:
ERROR:         /tmp/work/geography/geos/work/.destdir/usr/pkg/include/geos/algorithm/SimplePointInRing.h
ERROR:         /tmp/work/geography/geos/work/.destdir/usr/pkg/include/geos/precision/PrecisionReducerCoordinateOperation.h
ERROR:         /tmp/work/geography/geos/work/.destdir/usr/pkg/include/geos/unload.h
ERROR:         /tmp/work/geography/geos/work/.destdir/usr/pkg/lib/libgeos_c.so.1.19.2
ERROR: The following files are in /tmp/work/geography/geos/work/.destdir/usr/pkg but not in the PLIST:
ERROR:         /tmp/work/geography/geos/work/.destdir/usr/pkg/include/geos/algorithm/construct/ExactMaxInscribedCircle.h
ERROR:         /tmp/work/geography/geos/work/.destdir/usr/pkg/include/geos/coverage/CleanCoverage.h
ERROR:         /tmp/work/geography/geos/work/.destdir/usr/pkg/include/geos/coverage/CoverageCleaner.h
ERROR:         /tmp/work/geography/geos/work/.destdir/usr/pkg/include/geos/dissolve/DissolveEdgeGraph.h
ERROR:         /tmp/work/geography/geos/work/.destdir/usr/pkg/include/geos/dissolve/DissolveHalfEdge.h
ERROR:         /tmp/work/geography/geos/work/.destdir/usr/pkg/include/geos/dissolve/LineDissolver.h
ERROR:         /tmp/work/geography/geos/work/.destdir/usr/pkg/lib/libgeos_c.so.1.20.0
* odd linking issue
After building while 3.13.1 was installed, somehow pkgsrc decided that
the package needs to link against libgeos.so.3.13.1.  That's probably an
issue on our end, but I do not see this with other packages so there may
be something unusual going on.
* tests
After installing, I ran tests
  [snip]
  502/502 Test #502: xml-validate-TestRelatePP ..................................   Passed    0.00 sec
  100% tests passed, 0 tests failed out of 502
  Total Test time (real) =  13.94 sec
on NetBSD 10 amd64.
* postgis
With this, postgis's rc still builds.
Tests are no more troubled than with older geos.  (buggy postgis tests,
nothing real)
* qgis
With postgis built with this geos running, qgis loads features from a
postgis database.
