3.14.0beta1 Available
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Jul 22 08:29:49 PDT 2025
Also fine here on Visual Studio.
Thanks,
-jeff
On 2025-07-22 11:52 a.m., Greg Troxel wrote:
> Other than not documenting API withdrawals, this seems fine.
> * API changes
> I built this via pkgsrc, and here are the changes in installed files.
> - 3 withdrawn headers (not apparent in NEWS)
> - 6 new headers (inferrable as expected from NEWS)
> - minor version bump, but not major, in libgeos_c (ok)
> => Checking file-check results for geos-3.14.0beta1
> ERROR: ************************************************************
> ERROR: The following files are in the PLIST but not in /tmp/work/geography/geos/work/.destdir/usr/pkg:
> ERROR: /tmp/work/geography/geos/work/.destdir/usr/pkg/include/geos/algorithm/SimplePointInRing.h
> ERROR: /tmp/work/geography/geos/work/.destdir/usr/pkg/include/geos/precision/PrecisionReducerCoordinateOperation.h
> ERROR: /tmp/work/geography/geos/work/.destdir/usr/pkg/include/geos/unload.h
> ERROR: /tmp/work/geography/geos/work/.destdir/usr/pkg/lib/libgeos_c.so.1.19.2
> ERROR: The following files are in /tmp/work/geography/geos/work/.destdir/usr/pkg but not in the PLIST:
> ERROR: /tmp/work/geography/geos/work/.destdir/usr/pkg/include/geos/algorithm/construct/ExactMaxInscribedCircle.h
> ERROR: /tmp/work/geography/geos/work/.destdir/usr/pkg/include/geos/coverage/CleanCoverage.h
> ERROR: /tmp/work/geography/geos/work/.destdir/usr/pkg/include/geos/coverage/CoverageCleaner.h
> ERROR: /tmp/work/geography/geos/work/.destdir/usr/pkg/include/geos/dissolve/DissolveEdgeGraph.h
> ERROR: /tmp/work/geography/geos/work/.destdir/usr/pkg/include/geos/dissolve/DissolveHalfEdge.h
> ERROR: /tmp/work/geography/geos/work/.destdir/usr/pkg/include/geos/dissolve/LineDissolver.h
> ERROR: /tmp/work/geography/geos/work/.destdir/usr/pkg/lib/libgeos_c.so.1.20.0
> * odd linking issue
> After building while 3.13.1 was installed, somehow pkgsrc decided that
> the package needs to link against libgeos.so.3.13.1. That's probably an
> issue on our end, but I do not see this with other packages so there may
> be something unusual going on.
> * tests
> After installing, I ran tests
> [snip]
> 502/502 Test #502: xml-validate-TestRelatePP .................................. Passed 0.00 sec
> 100% tests passed, 0 tests failed out of 502
> Total Test time (real) = 13.94 sec
> on NetBSD 10 amd64.
> * postgis
> With this, postgis's rc still builds.
> Tests are no more troubled than with older geos. (buggy postgis tests,
> nothing real)
> * qgis
> With postgis built with this geos running, qgis loads features from a
> postgis database.
Jeff McKenna
GatewayGeo: Developers of MS4W, & offering MapServer Consulting/Dev
co-founder of FOSS4G
http://gatewaygeo.com/
