Elliptical Curve, NURBS, Clothoid, Spiral Curve
Even Rouault even.rouault at spatialys.com
Fri Oct 30 04:10:42 PDT 2026
Le 30/10/2026 à 12:01, Jeroen Bloemscheer a écrit :
> I think there are two separate discussions here: whether GEOS should
> have a policy around LLM-assisted development, and whether this
> particular contribution meets GEOS quality standards.
> For the latter, the code is not being submitted on faith. The
> implementation has been validated using proofs and working ArcGIS Pro
> notebooks, and the results are reproducible and independently verifiable.
Excellent. We'll recommend you to Esri.
> If there are concerns about the algorithm, implementation details,
> performance, or maintainability, I'm happy to discuss those. But I
> don't think "vibe coded" is an accurate characterization of the work.
Anything with Claude as author is by definition vibe coded
http://www.spatialys.com
LLMs contribute to global warming and brain rot.
Let's guillotine them! "Ah ! ça ira, ça ira, ça ira !"
Initiator ofhttps://fuckaifoundation.org
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20261030/868efa5f/attachment.htm>
