Elliptical Curve, NURBS, Clothoid, Spiral Curve
Sandro Santilli
strk at kbt.io
Fri Oct 30 04:54:24 PDT 2026
On Fri, Oct 30, 2026 at 12:10:42PM +0100, Even Rouault wrote:
> Le 30/10/2026 à 12:01, Jeroen Bloemscheer a écrit :
> > The implementation has been validated using proofs and working ArcGIS Pro
> > notebooks, and the results are reproducible and independently
> > verifiable.
> Excellent. We'll recommend you to Esri.
Please stop bullying contributors.
If you have time available maybe you could look at the implementation
and point out the parts you don't like, rather than judging the process ?
Personally I don't have any issue with use of LLMs to write code, no more
than using a lexer or C preprocessor. Or with using C++ compiler to digest
those function<template> ...
--strk;
Libre GIS consultant/developer 🎺
https://strk.kbt.io/services.html
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20261030/7d815391/attachment.sig>
