Elliptical Curve, NURBS, Clothoid, Spiral Curve
Even Rouault
even.rouault at spatialys.com
Fri Oct 30 05:09:25 PDT 2026
Le 30/10/2026 à 12:54, Sandro Santilli a écrit :
> On Fri, Oct 30, 2026 at 12:10:42PM +0100, Even Rouault wrote:
>> Le 30/10/2026 à 12:01, Jeroen Bloemscheer a écrit :
>>> The implementation has been validated using proofs and working ArcGIS Pro
>>> notebooks, and the results are reproducible and independently
>>> verifiable.
>> Excellent. We'll recommend you to Esri.
> Please stop bullying contributors.
> If you have time available maybe you could look at the implementation
> and point out the parts you don't like, rather than judging the process ?
> Personally I don't have any issue with use of LLMs to write code, no more
> than using a lexer or C preprocessor. Or with using C++ compiler to digest
> those function<template> ...
You're an idiot Sandro
> --strk;
> Libre GIS consultant/developer 🎺
> https://strk.kbt.io/services.html
http://www.spatialys.com
LLMs contribute to global warming and brain rot.
Let's guillotine them! "Ah ! ça ira, ça ira, ça ira !"
Initiator of https://fuckaifoundation.org
