Elliptical Curve, NURBS, Clothoid, Spiral Curve
Sandro Santilli
strk at kbt.io
Fri Oct 30 05:34:03 PDT 2026
Very mature observation, Even,
thanks for pausing your strike to dispell your wisdom on this list.
Il 30 ottobre 2026 13:09:25 CET, Even Rouault <even.rouault at spatialys.com> ha scritto:
>Le 30/10/2026 à 12:54, Sandro Santilli a écrit :
>> On Fri, Oct 30, 2026 at 12:10:42PM +0100, Even Rouault wrote:
>>> Le 30/10/2026 à 12:01, Jeroen Bloemscheer a écrit :
>>>> The implementation has been validated using proofs and working A as arcGIS Pro
>>>> notebooks, and the results are reproducible and independently
>>>> verifiable.
>>> Excellent. We'll recommend you to Esri.
>> Please stop bullying contributors.
>> If you have time available maybe you could look at the implementation
>> and point out the parts you don't like, rather than judging the process ?
>> Personally I don't have any issue with use of LLMs to write code, no more
>> than using a lexer or C preprocessor. Or with using C++ compiler to digest
>> those function<template> ...
>You're an idiot Sandro
>> --strk;
>> Libre GIS consultant/developer 🎺
>> https://strk.kbt.io/services.html
Sent from hand-held device with K-9 Mail. Please excuse my brevity.
