Elliptical Curve, NURBS, Clothoid, Spiral Curve
Regina Obe lr at pcorp.us
Fri Oct 30 06:57:06 PDT 2026
Jeroen,
As you can see some of us have very strong feelings about AI generated code.  I’m going to handwave all that away for a minute.  My concern is more of scope creep.
It’s my understanding is that CGAL https://www.cgal.org/ already has all this functionality you speak of.
On PostGIS project we have started to incorporate NURBS but using sfcgal - https://sfcgal.gitlab.io/SFCGAL/  which leverages CGAL under the hood.
Is there a reason you decided to incorporate this into GEOS instead of just using CGAL which is more committed to this kind of support?
Thanks,
Regina
Sent: Friday, October 30, 2026 7:11 AM
To: Jeroen Bloemscheer <jeroen.bloemscheer at merkator.com>
Cc: geos-devel at lists.osgeo.org
Subject: Re: Elliptical Curve, NURBS, Clothoid, Spiral Curve
Le 30/10/2026 à 12:01, Jeroen Bloemscheer a écrit :
I think there are two separate discussions here: whether GEOS should have a policy around LLM-assisted development, and whether this particular contribution meets GEOS quality standards.
For the latter, the code is not being submitted on faith. The implementation has been validated using proofs and working ArcGIS Pro notebooks, and the results are reproducible and independently verifiable.
Excellent. We'll recommend you to Esri.
If there are concerns about the algorithm, implementation details, performance, or maintainability, I'm happy to discuss those. But I don't think "vibe coded" is an accurate characterization of the work.
Anything with Claude as author is by definition vibe coded
http://www.spatialys.com
LLMs contribute to global warming and brain rot.
Let's guillotine them! "Ah ! ça ira, ça ira, ça ira !"
Initiator of https://fuckaifoundation.org
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20261030/ff404bdb/attachment-0001.htm>
