[GRASS-ABM] grass repast
Markus Neteler
neteler at osgeo.org
Sat Feb 20 04:25:46 EST 2010
On Sat, Feb 20, 2010 at 6:40 AM, Altaweel, Mark R. <maltaweel at anl.gov> wrote:
> There is now a plugin in Repast Simphony 1.2 that allows you to run grass modules and scripts within the Repast development environment. Anyway, this should allow you to send commands to run a grass module via repast. I am sure there are many ways to improve it, so if there are suggestions please let me know. The code can be found in the repast repository and there should be test code and some documentation about how to run things.
Mark,
thanks for the heads-up, I'll try it asap.
Best,
Markus
More information about the grass-abm
