[GRASS-CVS] markus: grass6/scripts/r.mask r.mask,1.10,1.11
grass at intevation.de
Sun Dec 2 11:47:13 EST 2007
Author: markus
Update of /grassrepository/grass6/scripts/r.mask
In directory doto:/tmp/cvs-serv15063
Modified Files:
r.mask
Log Message:
fix message position
Index: r.mask
RCS file: /grassrepository/grass6/scripts/r.mask/r.mask,v
retrieving revision 1.10
retrieving revision 1.11
diff -u -d -r1.10 -r1.11
--- r.mask 12 Nov 2007 17:51:14 -0000 1.10
+++ r.mask 2 Dec 2007 16:47:11 -0000 1.11
@@ -85,7 +85,6 @@
if [ "$GIS_FLAG_O" -eq 1 ]; then
echo "$GIS_OPT_MASKCATS = 1" | r.reclass input=$GIS_OPT_INPUT output=MASK --o
- g.message "MASK created. All subsequent raster operations"
else
# does map exist in CURRENT mapset?
eval `g.findfile element=cell file=MASK mapset=$MAPSET`
@@ -95,7 +94,6 @@
fi
fi
if [ "$GIS_FLAG_I" -eq 1 ]; then
@@ -103,6 +101,8 @@
r.mapcalc "MASK=if(isnull($TMP),1,null())"
g.remove --q rast=$TMP
g.message "Inverted MASK created. All subsequent raster operations"
+ else
+ g.message "MASK created. All subsequent raster operations"
fi
g.message "will be limited to MASK area"
g.message "Removing or renaming raster file named MASK will"
