[GRASS-CVS] markus: grass6/scripts/r.mask r.mask,1.8,1.8.2.1
grass at intevation.de
Sun Dec 2 11:49:44 EST 2007
Author: markus
Update of /grassrepository/grass6/scripts/r.mask
In directory doto:/tmp/cvs-serv15171
Modified Files:
Tag: releasebranch_6_3
r.mask
Log Message:
fixes + inverse MASK backported
Index: r.mask
RCS file: /grassrepository/grass6/scripts/r.mask/r.mask,v
retrieving revision 1.8
retrieving revision 1.8.2.1
diff -u -d -r1.8 -r1.8.2.1
--- r.mask 29 Mar 2007 09:21:05 -0000 1.8
+++ r.mask 2 Dec 2007 16:49:42 -0000 1.8.2.1
@@ -4,8 +4,9 @@
# MODULE: r.mask
# AUTHOR(S): Michael Barton, Arizona State University
+# Markus Neteler
# PURPOSE: Facilitates creation of raster MASK using r.reclass
-# COPYRIGHT: (C) 2005 by the GRASS Development Team
+# COPYRIGHT: (C) 2005, 2007 by the GRASS Development Team
# This program is free software under the GNU General Public
# License (>=v2). Read the file COPYING that comes with GRASS
@@ -32,6 +33,10 @@
#% answer: *
#%END
#%flag
+#% key: i
+#% description: Create inverse MASK from specified 'maskcats' list
+#%END
+#%flag
#% key: o
#% description: Overwrite existing MASK
#%END
@@ -50,6 +55,25 @@
exec g.parser "$0" "$@"
fi
+# temp file
+TMP="r_mask_$$"
+cleanup()
+ g.remove --q rast=$TMP
+# what to do in case of user break:
+exitprocedure()
+ g.message -e 'User break!'
+ cleanup
+ exit 1
+# shell check for user break (signal list: trap -l)
+trap "exitprocedure" 2 3 15
if [ "$GIS_FLAG_R" -eq 1 ]; then
if test -f `g.gisenv GISDBASE`/`g.gisenv LOCATION_NAME`/`g.gisenv MAPSET`/cell/MASK ; then
g.remove rast=MASK
@@ -59,14 +83,28 @@
fi
else
- g.message "MASK created. All subsequent raster operations"
- g.message "will be limited to MASK area"
- g.message "Removing or renaming raster file named MASK will"
- g.message "restore raster operations to normal"
if [ "$GIS_FLAG_O" -eq 1 ]; then
echo "$GIS_OPT_MASKCATS = 1" | r.reclass input=$GIS_OPT_INPUT output=MASK --o
else
+ # does map exist in CURRENT mapset?
+ eval `g.findfile element=cell file=MASK mapset=$MAPSET`
+ if [ "$file" ] ; then
+ g.message -e "MASK already found in current mapset. Delete first or overwrite"
+ exit 1
+ fi
fi
+ if [ "$GIS_FLAG_I" -eq 1 ]; then
+ g.rename --q rast=MASK,$TMP
+ r.mapcalc "MASK=if(isnull($TMP),1,null())"
+ g.message "Inverted MASK created. All subsequent raster operations"
+ else
+ g.message "MASK created. All subsequent raster operations"
+ fi
+ g.message "will be limited to MASK area"
+ g.message "Removing or renaming raster file named MASK will"
+ g.message "restore raster operations to normal"
fi
