[GRASS-CVS] hamish: grass6/gui/tcltk/gis.m description.html, 1.22,
1.23
grass at intevation.de
Thu Nov 15 02:56:48 EST 2007
Author: hamish
Update of /grassrepository/grass6/gui/tcltk/gis.m
In directory doto:/tmp/cvs-serv20484
Modified Files:
description.html
Log Message:
minor fixes
Index: description.html
RCS file: /grassrepository/grass6/gui/tcltk/gis.m/description.html,v
retrieving revision 1.22
retrieving revision 1.23
diff -u -d -r1.22 -r1.23
--- description.html 15 Nov 2007 07:32:07 -0000 1.22
+++ description.html 15 Nov 2007 07:56:46 -0000 1.23
@@ -14,9 +14,9 @@
window which contains options panels for layers in the layer tree.
<br><br>
-<div align="center">
-<img src="gm_gismgr.jpg" alt="GIS Manager window" align="top" height="551" width="480">
-</div>
+<center>
+<img src="gm_gismgr.jpg" alt="GIS Manager window" height="551" width="480">
+</center>
<br>
<br>
@@ -65,9 +65,9 @@
the computational region extents.
<br><br>
-<img src="gm_mapdisp.jpg" alt="Map Display window" align="top" height="422" width="480">
-</div>
+<center>
+<img src="gm_mapdisp.jpg" alt="Map Display window" height="422" width="480">
+</center>
<br><br>
A separate console window shows all commands issued and all command
@@ -75,9 +75,9 @@
commands) can be run from the console (lower window).<br>
<br>
-<img src="gm_gronsole.png" alt="Output and command console window" align="top" height="231" width="480">
-</div>
+<center>
+<img src="gm_gronsole.png" alt="Output and command console window" height="231" width="480">
+</center>
<br>
@@ -342,7 +342,7 @@
computational region for other GIS processes.
<i>See <a href="g.region.html">g.region</a>.</i></DD>
-<DT><img src="icons/gui-zoom_back.gif"> Revert Zoom</DT>
+<DT><img src="icons/gui-zoom_back.gif"> Revert zoom</DT>
<DD>Returns to the previous zoom. Up to 5 levels of zoom back are maintained.
@@ -355,7 +355,7 @@
(does not change the resolution).
-<DT><img src="icons/gui-query.gif"> Query Tool (select a map first)</DT>
+<DT><img src="icons/gui-query.gif"> Query tool (select a map first)</DT>
<DD>Query selected raster (only the base map of a draped map will be
queried), RGB raster map (all three map channels will be queried), or
vector map using the mouse. A map must be selected before query.
@@ -371,7 +371,7 @@
measurement unit.
<i>See also <a href="d.measure.html">d.measure</a>.</i></DD>
-<DT><img src="icons/gui-profile.gif"> Profile Tool</DT>
+<DT><img src="icons/gui-profile.gif"> Profile tool</DT>
<DD>Interactively create profile of a raster map. Profile transect
is drawn with the mouse in map display. The profile may be of the
displayed map or a different map.<i>
@@ -416,9 +416,10 @@
<a href="gm_animate.html">gis.m: ANIMATION TOOL</a><br>
<a href="gm_georect.html">gis.m: GEORECTIFY TOOL</a><br>
<a href="gm_profile.html">gis.m: PROFILE TOOL</a><br>
-<BR></em>
+</em>
+<BR>
<a href="d.m.html"><em>d.m</em> GUI</a>: The old display manager GUI<BR>
-<a href="http://grass.gdf-hannover.de/wiki/WxPython-based_GUI_for_GRASS">wxPython GUI</a></em>:
+<a href="http://grass.gdf-hannover.de/wiki/WxPython-based_GUI_for_GRASS">wxPython GUI</a>:
The next genration GUI, currently under development<BR>
