[GRASS-CVS] hamish: grass6/gui/tcltk/gis.m description.html, 1.23,
1.24
grass at intevation.de
Thu Nov 15 02:58:27 EST 2007
Author: hamish
Update of /grassrepository/grass6/gui/tcltk/gis.m
In directory doto:/tmp/cvs-serv20519
Modified Files:
description.html
Log Message:
postscript -> PostScript pedancy
Index: description.html
RCS file: /grassrepository/grass6/gui/tcltk/gis.m/description.html,v
retrieving revision 1.23
retrieving revision 1.24
diff -u -d -r1.23 -r1.24
--- description.html 15 Nov 2007 07:56:46 -0000 1.23
+++ description.html 15 Nov 2007 07:58:25 -0000 1.24
@@ -184,14 +184,14 @@
<DT><img src="icons/gui-maptext.gif"> Add PostScript labels layer for vector
objects (from existing labels file)</DT>
-<DD>Add postscript text layer from a labels file for vector objects created
+<DD>Add PostScript text layer from a labels file for vector objects created
with the <em><a href="v.label.html">v.label</a></em> module (accessed from
button in options panel). A labels file can also be created with a text editor.
<i>See <a href="d.labels.html">d.labels</a>.</i>
</DD>
-<DT><img src="icons/gui-maplabels.gif"> Add postscript text layer</DT>
-<DD>Adds layer to display a line of postscript text. Options include: text
+<DT><img src="icons/gui-maplabels.gif"> Add PostScript text layer</DT>
+<DD>Adds layer to display a line of PostScript text. Options include: text
placement by coordinates (geographic or screen); text
alignment, font and line spacing; and text size, bolding, and color.
</DL>
@@ -379,7 +379,7 @@
<DT><img src="icons/file-print.gif"> Print map</DT>
<DD>Prints map on the UNIX <i>lpr</i> printer or PostScript device;
-saves visible map display (including postscript text and labels) to PDF
+saves visible map display (including PostScript text and labels) to PDF
or EPS file. Requires <tt>ghostscript</tt> for all output except EPS.</DD>
<DT><img src="icons/file-save.gif"> Export map display</DT>
