[GRASS-CVS]
hamish: grass6/gui/tcltk/gis.m/docs gm_animate.html, 1.2,
1.3 gm_georect.html, 1.2, 1.3
grass at intevation.de
Thu Nov 15 03:11:35 EST 2007
Author: hamish
Update of /grassrepository/grass6/gui/tcltk/gis.m/docs
In directory doto:/tmp/cvs-serv20909
Modified Files:
gm_animate.html gm_georect.html
Log Message:
minor fixes
Index: gm_animate.html
RCS file: /grassrepository/grass6/gui/tcltk/gis.m/docs/gm_animate.html,v
retrieving revision 1.2
retrieving revision 1.3
diff -u -d -r1.2 -r1.3
--- gm_animate.html 15 Nov 2007 07:32:07 -0000 1.2
+++ gm_animate.html 15 Nov 2007 08:11:32 -0000 1.3
@@ -17,7 +17,7 @@
<h3>Using the Animation Tool</h3>
-The Animation Tool is started from the <i>file</i> menu or
+The Animation Tool is started from the <i>File</i> menu or
from the animation button (<img src="icons/module-xganim.gif" alt="icon">)
on the GIS Manager toolbar.
Index: gm_georect.html
RCS file: /grassrepository/grass6/gui/tcltk/gis.m/docs/gm_georect.html,v
--- gm_georect.html 15 Nov 2007 07:32:07 -0000 1.2
+++ gm_georect.html 15 Nov 2007 08:11:32 -0000 1.3
@@ -72,7 +72,7 @@
georectify, the location/mapset of the map to georectify, the
<i>image group</i> of the map to georectify, and a map to use for marking
GCPs.</p>
-<BR><BR>
+<BR>
<center>
<img src="gm_georectstart.jpg" alt="Georectify workflow menu" height="214" width="350">
</center>
@@ -108,17 +108,15 @@
marking GCPs, and a GCP manager window.
The GCP map display can be zoomed and panned like a normal map display.
<br>
-<br>
<center>
<img src="gm_georectdisp.jpg" alt="Georectifier Display window" height="439" width="500">
</center>
<br>
<br>
-</div>The GCP manager window holds the x/y coordinates and geographic
-coordinates of each
-GCP, and displays the <i>error</i> for each GCP (i.e., the distance
-that the actual GCP marked deviates from its expected placement using a
-transformation equation).
+The GCP manager window holds the x/y coordinates and geographic
+coordinates of each GCP, and displays the <i>error</i> for each
+GCP (i.e., the distance that the actual GCP marked deviates from
+its expected placement using a transformation equation).
<br>
<br>
<center>
@@ -199,6 +197,9 @@
<a href="i.points.html">i.points</a><br>
<a href="i.vpoints.html">i.vpoints</a><br>
<a href="i.rectify.html">i.rectify</a><br>
+<a href="g.proj.html">g.proj</a><br>
+<a href="g.setproj.html">g.setproj</a><br>
+<a href="m.proj.html">m.proj</a><br>
<a href="r.proj.html">r.proj</a><br>
<a href="v.proj.html">v.proj</a>
</em>
