[GRASS-CVS] markus: grass6/lib/proj gcs.override.csv, NONE,
1.1.4.1 pcs.override.csv, NONE, 1.1.4.1 ellipsoid.csv, 1.3.4.2,
1.3.4.3 gcs.csv, 1.4.4.3, 1.4.4.4 gdal_datum.csv, 1.3.4.3,
1.3.4.4 pcs.csv, 1.4.4.3, 1.4.4.4 projop_wparm.csv, 1.3.4.2,
1.3.4.3 unit_of_measure.csv, 1.3.4.2, 1.3.4.3
grass at intevation.de
Tue Nov 20 16:30:48 EST 2007
Author: markus
Update of /grassrepository/grass6/lib/proj
In directory doto:/tmp/cvs-serv25757
Modified Files:
Tag: releasebranch_6_2
ellipsoid.csv gcs.csv gdal_datum.csv pcs.csv projop_wparm.csv
unit_of_measure.csv
Added Files:
gcs.override.csv pcs.override.csv
Log Message:
sync'ed to EPSG 6.13 (from GRASS 6.3.0RC2 = HEAD today)
--- NEW FILE: gcs.override.csv ---
"COORD_REF_SYS_CODE","COORD_REF_SYS_NAME","DATUM_CODE","DATUM_NAME","GREENWICH_DATUM","UOM_CODE","ELLIPSOID_CODE","PRIME_MERIDIAN_CODE","SHOW_CRS","DEPRECATED","COORD_OP_METHOD_CODE","DX","DY","DZ","RX","RY","RZ","DS"
# See http://bugzilla.remotesensing.org/show_bug.cgi?id=339
# Or http://www.linz.govt.nz/rcs/linz/pub/web/root/core/SurveySystem/GeodeticInfo/geodeticdatums/index.jsp
4272,NZGD49,6272,New Zealand Geodetic Datum 1949,6272,9122,7022,8901,1,0,9606,59.47,-5.04,187.44,0.47,-0.1,1.024,-4.5993
# Use the seven-parameter transformation from the BEV (1618) for MGI (bug 870)
4312,MGI,6312,Militar-Geographische Institut,6312,9108,7004,8901,1,0,9606,577.326,90.129,463.919,5.137,1.474,5.297,2.4232
# Bart van den Eijnden and Jan Hartmann suggest this datum shift value:
#4289,Amersfoort,6289,Amersfoort,6289,9122,7004,8901,1,0,9606,565.2369,50.0087,465.658,-0.406857330322398,0.350732676542563,-1.8703473836068,4.0812
# Per http://bugzilla.remotesensing.org/show_bug.cgi?id=1305
4218,Bogota 1975,6218,Bogota 1975,6218,9122,7022,8901,1,0,9603,307,304,-318,,,,
# Per http://bugzilla.remotesensing.org/show_bug.cgi?id=957
4149,CH1903,6149,CH1903,6149,9122,7004,8901,1,0,9603,674.374,15.056,405.346,,,,
# From Jan: http://bugzilla.remotesensing.org/show_bug.cgi?id=1336
4313,Belge 1972,6313,Reseau National Belge 1972,6313,9122,7022,8901,1,0,9606,106.868628,-52.297783,103.723893,-0.336570,0.456955,-1.842183,1.0000012747
--- NEW FILE: pcs.override.csv ---
"COORD_REF_SYS_CODE","COORD_REF_SYS_NAME","UOM_CODE","SOURCE_GEOGCRS_CODE","COORD_OP_CODE","COORD_OP_METHOD_CODE","SHOW_CRS","DEPRECATED","PARAMETER_CODE_1","PARAMETER_VALUE_1","PARAMETER_UOM_1","PARAMETER_CODE_2","PARAMETER_VALUE_2","PARAMETER_UOM_2","PARAMETER_CODE_3","PARAMETER_VALUE_3","PARAMETER_UOM_3","PARAMETER_CODE_4","PARAMETER_VALUE_4","PARAMETER_UOM_4","PARAMETER_CODE_5","PARAMETER_VALUE_5","PARAMETER_UOM_5","PARAMETER_CODE_6","PARAMETER_VALUE_6","PARAMETER_UOM_6","PARAMETER_CODE_7","PARAMETER_VALUE_7","PARAMETER_UOM_7"
# Adjust central meridian to be relative to prime meridian.
26591,"Monte Mario (Rome) / Italy zone 1",9001,4806,18121,9807,1,0,8801,0,9102,8802,-3.45233333333333,9102,8805,0.9996,9201,8806,1500000,9001,8807,0,9001,,,,,,
26592,"Monte Mario (Rome) / Italy zone 2",9001,4806,18122,9807,1,0,8801,0,9102,8802,2.54766666666666,9102,8805,0.9996,9201,8806,2520000,9001,8807,0,9001,,,,,,
Index: ellipsoid.csv
RCS file: /grassrepository/grass6/lib/proj/ellipsoid.csv,v
retrieving revision 1.3.4.2
retrieving revision 1.3.4.3
diff -u -d -r1.3.4.2 -r1.3.4.3
--- ellipsoid.csv 18 Oct 2006 07:32:07 -0000 1.3.4.2
+++ ellipsoid.csv 20 Nov 2007 21:30:46 -0000 1.3.4.3
@@ -1,5 +1,5 @@
ellipsoid_code,ellipsoid_name,semi_major_axis,uom_code,inv_flattening,semi_minor_axis,ellipsoid_shape,remarks,information_source,data_source,revision_date,change_id,deprecated
-7001,Airy 1830,6377563.396,9001,299.3249646,,1,Original definition is a=20923713 and b=20853810 feet of 1796. For the 1936 retriangulation OSGB defines the relationship of feet of 1796 to the International metre through log(1.48401603) exactly [=0.3048007491...]. 1/f is given to 7 decimal places.,Ordnance Survey of Great Britain.,EPSG,1995-06-02,98.321 98.34,0
+7001,Airy 1830,6377563.396,9001,299.3249646,,1,"Original definition is a=20923713, b=20853810 feet of 1796. 1/f is given to 7 decimal places. For the 1936 retriangulation OSGB defines the relationship of 10 feet of 1796 to the International metre through ([10^0.48401603]/10) exactly = 0.3048007491...",Ordnance Survey of Great Britain.,EPSG,2006-11-27,98.321 98.34 2006.932,0
7002,Airy Modified 1849,6377340.189,9001,299.3249646,,1,OSGB Airy 1830 figure (ellipsoid code 7001) rescaled by 0.999965 to best fit the scale of the 19th century primary triangulation of Ireland.,"""The Irish Grid - A Description of the Co-ordinate Reference System"" published by Ordnance Survey of Ireland, Dublin and Ordnance Survey of Northern Ireland, Belfast.",EPSG,2003-06-27,98.321 2002.622,0
7003,Australian National Spheroid,6378160,9001,298.25,,1,Based on the GRS 1967 figure but with 1/f taken to 2 decimal places exactly. The dimensions are also used as the GRS 1967 (SAD69) ellipsoid (see code 7050).,"""Australian Map Grid Technical Manual""; National Mapping Council of Australia Special Publication #7; 1972",EPSG,2002-09-19,2002.50,0
7004,Bessel 1841,6377397.155,9001,299.1528128,,1,"Original Bessel definition is a=3272077.14 and b=3261139.33 toise. This used a weighted mean of values from several authors but did not account for differences in the length of the various toise: the ""Bessel toise"" is therefore of uncertain length.",US Army Map Service Technical Manual; 1943.,EPSG,1999-04-22,98.321 98.34,0
@@ -48,3 +48,5 @@
7054,PZ-90,6378136,9001,298.257839303,,1,,"Geodeziya i Katografiya, 1993.",OGP,2006-02-03,,0
7055,Clarke 1880 (international foot),20926202,9002,,20854895,1,Clark'es 1880 definition in feet assumed for the purposes of metric conversion to be international foot. a = 6378306.370Â
metres. 1/f derived from a and b = 293.4663077Â
Used in Fiji.,"Department of Lands and Survey, Fiji.",OGP,2006-07-14,,0
7056,Everest 1830 (RSO 1969),6377295.664,9001,300.8017,,1,Adopted for 1969 metrication of peninsula Malaysia RSO grid. Uses Sears 1922 yard-metre ratio truncated to 6 significant figures applied to Everest 1830 original definition of a and 1/f but with a taken to be in British rather than Indian feet.,Defence Geographic Centre,OGP,2006-07-24,,0
+7057,International 1924 Authalic Sphere,6371228,9001,,6371228,0,Authalic sphere derived from International 1924 ellipsoid (code 7022).,OGP,OGP,2006-09-22,,0
+7058,Hughes 1980,6378273,9001,,6356889.449,1,Used in US DMSP SSM/I microwave sensor processing software. Semi-minor axis derived from eccentricity=0.081816153. Semi-major axis (a) sometimes given as 3443.992nm which OGP suspects is a derived approximation. OGP conversion assumes 1nm=1852m exactly.,US National Snow and Ice Data Center,OGP,2006-09-22,,0
Index: gcs.csv
RCS file: /grassrepository/grass6/lib/proj/gcs.csv,v
retrieving revision 1.4.4.3
retrieving revision 1.4.4.4
diff -u -d -r1.4.4.3 -r1.4.4.4
--- gcs.csv 18 Oct 2006 07:32:07 -0000 1.4.4.3
+++ gcs.csv 20 Nov 2007 21:30:46 -0000 1.4.4.4
@@ -39,6 +39,8 @@
4045,"Unknown datum based upon the Everest 1830 (1975 Definition) ellipsoid",6045,"Not specified (based on Everest 1830 (1975 Definition) ellipsoid)",6045,9122,7045,8901,0,0,,,,,,,,
4047,Unspecified datum based upon the GRS 1980 Authalic Sphere,6047,"Not specified (based on GRS 1980 Authalic Sphere)",6047,9122,7048,8901,0,0,,,,,,,,
4052,Unspecified datum based upon the Clarke 1866 Authalic Sphere,6052,"Not specified (based on Clarke 1866 Authalic Sphere)",6052,9122,7052,8901,0,0,,,,,,,,
+4053,Unspecified datum based upon the International 1924 Authalic Sphere,6053,"Not specified (based on International 1924 Authalic Sphere)",6053,9122,7057,8901,0,0,,,,,,,,
+4054,Unspecified datum based upon the Hughes 1980 ellipsoid,6054,"Not specified (based on Hughes 1980 ellipsoid)",6054,9122,7058,8901,0,0,,,,,,,,
4120,Greek,6120,Greek,6120,9122,7004,8901,1,0,,,,,,,,
4121,GGRS87,6121,Greek Geodetic Reference System 1987,6121,9122,7019,8901,1,0,9603,-199.87,74.79,246.62,,,,
4122,ATS77,6122,Average Terrestrial System 1977,6122,9122,7041,8901,1,0,,,,,,,,
@@ -68,7 +70,7 @@
4146,Kalianpur 1975,6146,Kalianpur 1975,6146,9122,7045,8901,1,0,9603,295,736,257,,,,
4147,Hanoi 1972,6147,Hanoi 1972,6147,9122,7024,8901,1,0,9603,-17.51,-108.32,-62.39,,,,
4148,Hartebeesthoek94,6148,Hartebeesthoek94,6148,9122,7030,8901,1,0,9603,0,0,0,,,,
-4149,CH1903,6149,CH1903,6149,9122,7004,8901,1,0,9603,674.374,15.056,405.346,,,,
+4149,CH1903,6149,CH1903,6149,9122,7004,8901,1,0,,,,,,,,
4150,"CH1903+",6150,"CH1903+",6150,9122,7004,8901,1,0,9603,674.374,15.056,405.346,,,,
4151,CHTRF95,6151,Swiss Terrestrial Reference Frame 1995,6151,9122,7019,8901,1,0,9603,0,0,0,,,,
4152,"NAD83(HARN)",6152,"NAD83 (High Accuracy Regional Network)",6152,9122,7019,8901,1,0,,,,,,,,
@@ -133,7 +135,7 @@
4214,Beijing 1954,6214,Beijing 1954,6214,9122,7024,8901,1,0,,,,,,,,
4215,Belge 1950,6215,Reseau National Belge 1950,6215,9122,7022,8901,1,0,,,,,,,,
4216,Bermuda 1957,6216,Bermuda 1957,6216,9122,7008,8901,1,0,9603,-73,213,296,,,,
-4218,Bogota 1975,6218,Bogota 1975,6218,9122,7022,8901,1,0,9603,307,304,-318,,,,
+4218,Bogota 1975,6218,Bogota 1975,6218,9122,7022,8901,1,0,,,,,,,,
4219,Bukit Rimpah,6219,Bukit Rimpah,6219,9122,7004,8901,1,0,9603,-384,664,-48,,,,
4220,Camacupa,6220,Camacupa,6220,9122,7012,8901,1,0,,,,,,,,
4221,Campo Inchauspe,6221,Campo Inchauspe,6221,9122,7022,8901,1,0,,,,,,,,
@@ -187,7 +189,7 @@
4269,NAD83,6269,North American Datum 1983,6269,9122,7019,8901,1,0,,,,,,,,
4270,Nahrwan 1967,6270,Nahrwan 1967,6270,9122,7012,8901,1,0,,,,,,,,
4271,Naparima 1972,6271,Naparima 1972,6271,9122,7022,8901,1,0,,,,,,,,
-4272,NZGD49,6272,New Zealand Geodetic Datum 1949,6272,9122,7022,8901,1,0,9606,59.47,-5.04,187.44,0.47,-0.1,1.024,-4.5993
+4272,NZGD49,6272,New Zealand Geodetic Datum 1949,6272,9122,7022,8901,1,0,,,,,,,,
4273,NGO 1948,6273,NGO 1948,6273,9122,7005,8901,1,0,9606,278.3,93,474.5,7.889,0.05,-6.61,6.21
4274,Datum 73,6274,Datum 73,6274,9122,7022,8901,1,0,,,,,,,,
4275,NTF,6275,Nouvelle Triangulation Francaise,6275,9122,7011,8901,1,0,9603,-168,-60,320,,,,
@@ -204,7 +206,7 @@
4286,Qatar 1948,6286,Qatar 1948,6286,9122,7020,8901,1,0,,,,,,,,
4287,Qornoq,6287,Qornoq,6287,9108,7022,8901,1,1,9603,164,138,-189,,,,
4288,Loma Quintana,6288,Loma Quintana,6288,9122,7022,8901,1,0,,,,,,,,
-4289,Amersfoort,6289,Amersfoort,6289,9122,7004,8901,1,0,9606,565.2369,50.0087,465.658,-0.406857330322398,0.350732676542563,-1.8703473836068,4.0812
+4289,Amersfoort,6289,Amersfoort,6289,9122,7004,8901,1,0,,,,,,,,
4291,SAD69,6291,South American Datum 1969,6291,9108,7036,8901,1,1,,,,,,,,
4292,Sapper Hill 1943,6292,Sapper Hill 1943,6292,9122,7022,8901,1,0,9603,-355,21,72,,,,
4293,Schwarzeck,6293,Schwarzeck,6293,9122,7046,8901,1,0,,,,,,,,
@@ -225,7 +227,7 @@
4309,Yacare,6309,Yacare,6309,9122,7022,8901,1,0,9603,-155,171,37,,,,
4310,Yoff,6310,Yoff,6310,9122,7011,8901,1,0,,,,,,,,
4311,Zanderij,6311,Zanderij,6311,9122,7022,8901,1,0,9603,-265,120,-358,,,,
-4312,MGI,6312,Militar-Geographische Institut,6312,9108,7004,8901,1,0,9606,577.326,90.129,463.919,5.137,1.474,5.297,2.4232
+4312,MGI,6312,Militar-Geographische Institut,6312,9122,7004,8901,1,0,,,,,,,,
4313,Belge 1972,6313,Reseau National Belge 1972,6313,9122,7022,8901,1,0,,,,,,,,
4314,DHDN,6314,Deutsches Hauptdreiecksnetz,6314,9122,7004,8901,1,0,,,,,,,,
4315,Conakry 1905,6315,Conakry 1905,6315,9122,7011,8901,1,0,9603,-23,259,-9,,,,
@@ -235,7 +237,7 @@
4319,KUDAMS,6319,Kuwait Utility,6319,9122,7019,8901,1,0,,,,,,,,
4322,WGS 72,6322,World Geodetic System 1972,6322,9122,7043,8901,1,0,,,,,,,,
4324,WGS 72BE,6324,WGS 72 Transit Broadcast Ephemeris,6324,9122,7043,8901,1,0,9606,0,0,1.9,0,0,0.814,-0.38
-4326,WGS 84,6326,World Geodetic System 1984,6326,9122,7030,8901,1,0,9603,,,,,,,
+4326,WGS 84,6326,World Geodetic System 1984,6326,9122,7030,8901,1,0,,,,,,,,
4600,Anguilla 1957,6600,Anguilla 1957,6600,9122,7012,8901,1,0,,,,,,,,
4601,Antigua 1943,6601,Antigua 1943,6601,9122,7012,8901,1,0,,,,,,,,
4602,Dominica 1945,6602,Dominica 1945,6602,9122,7012,8901,1,0,9603,725,685,536,,,,
@@ -365,7 +367,7 @@
4736,Deception Island,6736,Deception Island,6736,9122,7012,8901,1,0,9603,260,12,-147,,,,
4737,Korea 2000,6737,Geocentric datum of Korea,6737,9122,7019,8901,1,0,9603,0,0,0,,,,
4738,Hong Kong 1963,6738,Hong Kong 1963,6738,9122,7007,8901,1,0,,,,,,,,
-4739,"Hong Kong 1963(67)",6739,"Hong Kong 1963(67)",6739,9122,7022,8901,1,0,9603,-156,-271,-189,,,,
+4739,"Hong Kong 1963(67)",6739,"Hong Kong 1963(67)",6739,9122,7022,8901,1,0,9606,-156,-271,-189,,,,
4740,PZ-90,6740,Parametrop Zemp 1990,6740,9122,7054,8901,1,0,9607,0,0,1.5,0,0,-0.076,0
4741,FD54,6741,Faroe Datum 1954,6741,9122,7022,8901,1,0,,,,,,,,
4742,GDM2000,6742,Geodetic Datum of Malaysia 2000,6742,9122,7019,8901,1,0,,,,,,,,
@@ -383,6 +385,10 @@
4754,LGD2006,6754,Libyan Geodetic Datum 2006,6754,9122,7022,8901,1,0,9603,-208.4058,-109.8777,-2.5764,,,,
4755,DGN95,6755,Datum Geodesi Nasional 1995,6755,9122,7030,8901,1,0,9603,0,0,0,,,,
4756,VN-2000,6756,Vietnam 2000,6756,9122,7030,8901,1,0,,,,,,,,
+4757,SVY21,6757,SVY21,6757,9122,7030,8901,1,0,,,,,,,,
+4758,JAD2001,6758,Jamaica 2001,6758,9122,7030,8901,1,0,9603,0,0,0,,,,
+4759,"NAD83(NSRS2007)",6759,"NAD83 (National Spatial Reference System 2007)",6759,9122,7019,8901,1,0,9603,0,0,0,,,,
+4760,WGS 66,6760,World Geodetic System 1966,6760,9122,7025,8901,1,0,,,,,,,,
4801,"Bern 1898 (Bern)",6801,"CH1903 (Bern)",6149,9122,7004,8907,1,0,,,,,,,,
4802,"Bogota 1975 (Bogota)",6802,"Bogota 1975 (Bogota)",6218,9122,7022,8904,1,0,,,,,,,,
4803,"Lisbon (Lisbon)",6803,"Lisbon 1937 (Lisbon)",6207,9122,7022,8902,1,0,,,,,,,,
Index: gdal_datum.csv
RCS file: /grassrepository/grass6/lib/proj/gdal_datum.csv,v
retrieving revision 1.3.4.4
diff -u -d -r1.3.4.3 -r1.3.4.4
--- gdal_datum.csv 7 Mar 2007 08:15:23 -0000 1.3.4.3
+++ gdal_datum.csv 20 Nov 2007 21:30:46 -0000 1.3.4.4
@@ -1,9 +1,9 @@
"DATUM_CODE","DATUM_NAME","DATUM_TYPE","ORIGIN_DESCRIPTION","REALIZATION_EPOCH","ELLIPSOID_CODE","PRIME_MERIDIAN_CODE","AREA_OF_USE_CODE","DATUM_SCOPE","REMARKS","INFORMATION_SOURCE","DATA_SOURCE","REVISION_DATE","CHANGE_ID","DEPRECATED","ESRI_DATUM_NAME"
5100,Mean Sea Level,vertical,,,,,1262,Hydrography.,"msl has geographic and temporal components. Users are advised to not use this generic vertical datum but to define specific instances of msl based on knowledge of these components; for instance ""msl at xxx during 19yy"".",,EPSG,1996-04-12,,0,
5101,Ordnance Datum Newlyn,vertical,Mean Sea Level at Newlyn between 1915 and 1921.,,,,2792,"Topographic mapping, geodetic survey.",Orthometric heights.,Ordnance Survey of Great Britain,EPSG,2004-06-16,2004.10,0,
-5102,National Geodetic Vertical Datum 1929,vertical,26 tide gauges in the US and Canada.,1929,,,1323,"Topographic mapping, geodetic survey.",,,EPSG,1996-09-12,,0,
-5103,North American Vertical Datum 1988,vertical,"Father's Point, Rimouski, Quebec.",1988,,,1325,"Topographic mapping, geodetic survey.",,,EPSG,2006-01-16,2005.88,0,
-5104,Yellow Sea 1956,vertical,2 years tide readings at Qingdao.,1956,,,3228,"Topographic mapping, geodetic survey.",Superseded by Yellow Sea 1985 datum.,,EPSG,2002-06-22,2002.16,0,
+5102,National Geodetic Vertical Datum 1929,vertical,26 tide gauges in the US and Canada.,1929,,,1323,"Topographic mapping, geodetic survey.",Normal orthometric heights.,,EPSG,1996-09-12,,0,
+5103,North American Vertical Datum 1988,vertical,"Father's Point, Rimouski, Quebec.",1988,,,1325,"Topographic mapping, geodetic survey.",Helmert orthometric heights.,,EPSG,2006-01-16,2005.88,0,
+5104,Yellow Sea 1956,vertical,2 years tide readings at Qingdao.,1956,,,3228,"Topographic mapping, geodetic survey.",Replaced by Yellow Sea 1985 datum.,,EPSG,2002-06-22,2002.16,0,
5105,Baltic Sea,vertical,"Datum: average water level at Kronstadt 1833. Network adjusted in 1977.",1977,,,1284,"Topographic mapping, geodetic survey.",Uses Normal heights.,,EPSG,2005-05-27,2004.10 2005.18,0,
5106,Caspian Sea,vertical,Defined as -28.0m Baltic datum,,,,1291,Hydrography.,,,EPSG,1996-09-12,,0,
5107,Nivellement general de la France,vertical,Mean sea level at Marseille,,,,1326,"Topographic mapping, geodetic survey.",The CNIG states that NGF is a general term applying to all vertical network readjustments of France and recommends more specific terminology. See codes 5118-5120.,"Conseil National de l'Information Geographique groupe de travail ""Reseaux de Nivellement"" recommendations v5.1 April 1994.",EPSG,1996-09-12,,1,
@@ -19,15 +19,15 @@
5117,Rikets hojdsystem 1970,vertical,"Adjustment is referenced to mean high tide at Amsterdams Peil in 1684. To account for land level movements caused by isostatic rebound, heights are reduced to epoch 1970.0 using uplift values computed from repeated levelling observations.",1970,,,3313,"Topographic mapping, geodetic survey.",Uses Normal heights.,National Land Survey of Sweden,EPSG,2004-06-16,2002.48 2004.10,0,
5118,Nivellement General de la France - Lallemand,vertical,"Rivet number M.ac O-VIII on the Marseille tide gauge site, with the height fixed in 1897 at 1.661 metre above mean sea level between February 2nd 1885 and January 1st 1897.",,,,1326,"Geodetic survey, topographic mapping, engineering survey.",Orthometric heights.,"Conseil National de l'Information Geographique groupe de travail ""Reseaux de Nivellement"" recommendations v5.1 April 1994.",EPSG,1997-11-13,2001.47 2004.06,0,
5119,Nivellement General de la France - IGN69,vertical,"Rivet number M.ac O-VIII on the Marseille tide gauge site, with the height fixed in 1897 at 1.661 metre above mean sea level between February 2nd 1885 and January 1st 1897.",1969,,,1326,"Geodetic survey, topographic mapping, engineering survey.",Uses Normal heights.,"Conseil National de l'Information Geographique groupe de travail ""Reseaux de Nivellement"" recommendations v5.1 April 1994.",EPSG,1997-11-13,2001.47,0,
-5120,IGN78 Corsica,vertical,Marker MM3 situated on the tide gauge site of Ajaccio. Height is 3.640 metre above mean sea level.,1978,,,1327,"Geodetic survey, topographic mapping, engineering survey.","Uses Normal heights. Supersedes NGC (datum code 5189).","Conseil National de l'Information Geographique groupe de travail ""Reseaux de Nivellement"" recommendations v5.1 April 1994.",EPSG,2004-10-14,2001.47 2004.06 2004.564,0,
+5120,IGN78 Corsica,vertical,Marker MM3 situated on the tide gauge site of Ajaccio. Height is 3.640 metre above mean sea level.,1978,,,1327,"Geodetic survey, topographic mapping, engineering survey.","Uses Normal heights. Replaces NGC (datum code 5189).","Conseil National de l'Information Geographique groupe de travail ""Reseaux de Nivellement"" recommendations v5.1 April 1994.",EPSG,2004-10-14,2001.47 2004.06 2004.564,0,
5121,Maputo,vertical,Mean sea level at Maputo.,,,,3281,Topographic mapping.,,"Direcção Nacional de Geografia e Cadastral (DINAGECA).",EPSG,1998-04-16,,0,
5122,Japanese Standard Levelling Datum 1949,vertical,24.4140 metres above mean sea level Tokyo Bay.,1949,,,3263,"Topographic mapping, geodetic survey.",,"Ministry of Construction; Japan. http://vldb.gsi.go.jp/sokuchi/datum/tokyodatum.html",EPSG,2004-05-09,2002.08 2004.38,0,
-5123,PDO Height Datum 1993,vertical,,1993,,,3288,Oil industry mapping.,"Misclosure between Muscat and Salalah less than .5 meters with differences from of up to 5 meters from old Fahud Datum. The PHD93 adjustment was initially known as the Spine. Supersedes Fahud Vertical Datum (code 5124) from 1993.",Petroleum Development Oman,EPSG,1999-04-22,,0,
-5124,Fahud Height Datum,vertical,Single MSL determination at Mina Al Fahal.,,,,3288,Oil industry mapping.,"Based on reciprocal trigonometric heighting. Superseded by PHD93 Datum (code 5123) in 1993.",Petroleum Development Oman,EPSG,2004-04-07,2004.212,0,
+5123,PDO Height Datum 1993,vertical,,1993,,,3288,Oil industry mapping.,"Misclosure between Muscat and Salalah less than .5 meters with differences from of up to 5 meters from old Fahud Datum. The PHD93 adjustment was initially known as the Spine. Replaces Fahud Vertical Datum (code 5124) from 1993.",Petroleum Development Oman,EPSG,1999-04-22,,0,
+5124,Fahud Height Datum,vertical,Single MSL determination at Mina Al Fahal.,,,,3288,Oil industry mapping.,"Based on reciprocal trigonometric heighting. Replaced by PHD93 Datum (code 5123) in 1993.",Petroleum Development Oman,EPSG,2004-04-07,2004.212,0,
5125,Ha Tien 1960,vertical,,1960,,,1302,"Topographic mapping, geodetic survey.",In Vietnam replaced by Hon Dau in 1992.,,EPSG,1999-10-20,,0,
-5126,Hon Dau 1992,vertical,,1992,,,3328,"Topographic mapping, geodetic survey.",Supersedes Ha Tien in Vietnam.,,EPSG,1999-10-20,,0,
-5127,Landesnivellement 1902,vertical,"Origin at Repere Pierre du Niton (RPN) defined as 373.6 metres above msl. This value derived from msl at Marseille in 1897 through the French Lallemand network.",1902,,,1286,"Topographic mapping, cadastral survey.","Levelling observations not corrected for gravity field. For scientific purposes, superseded by LHHN95.","Bundesamt für Landestopographie",EPSG,2004-06-16,2004.10,0,
-5128,Landeshohennetz 1995,vertical,"Origin at Repere Pierre du Niton (RPN) defined as 373.6 metres above msl. This value derived from msl at Marseille in 1897 through the French Lallemand network.",1995,,,1286,Geodetic survey and scientific studies.,"Orthometric heights. For scientific purposes only, supersedes LN02.","Bundesamt für Landestopographie",EPSG,2004-06-16,2004.10,0,
+5126,Hon Dau 1992,vertical,,1992,,,3328,"Topographic mapping, geodetic survey.",Replaces Ha Tien in Vietnam.,,EPSG,1999-10-20,,0,
+5127,Landesnivellement 1902,vertical,"Origin at Repere Pierre du Niton (RPN) defined as 373.6 metres above msl. This value derived from msl at Marseille in 1897 through the French Lallemand network.",1902,,,1286,"Topographic mapping, cadastral survey.","Levelling observations not corrected for gravity field. For scientific purposes, replaced by LHHN95.","Bundesamt für Landestopographie",EPSG,2004-06-16,2004.10,0,
+5128,Landeshohennetz 1995,vertical,"Origin at Repere Pierre du Niton (RPN) defined as 373.6 metres above msl. This value derived from msl at Marseille in 1897 through the French Lallemand network.",1995,,,1286,Geodetic survey and scientific studies.,"Orthometric heights. For scientific purposes only, replaces LN02.","Bundesamt für Landestopographie",EPSG,2004-06-16,2004.10,0,
5129,European Vertical Reference Frame 2000,vertical,"Height at Normaal Amsterdams Peil (NAP) is zero, defined through height at UELN bench mark 13600 (52°22'53""N 4°54'34""E) of 0.71599m. Datum at NAP is mean high tide in 1684.",2000,,,1299,Geodesy.,Realised by geopotential numbers and Normal heights of the United European Levelling Network.,"European veritical data centre at Bundesamt für Kartographie und Geodäsie (BKG), Leipzig branch. http://crs.bkg.bund.de/evrs/",EPSG,2000-10-19,,0,
5130,Malin Head,vertical,Mean sea level between January 1960 and December 1969.,1970,,,1305,Topographic mapping,Orthometric heights.,Ordnance Survey of Ireland,EPSG,2001-11-06,,0,
5131,Belfast Lough,vertical,"Mean sea level between 1951 and 1956 at Clarendon Dock, Belfast.",1957,,,2530,"Large scale (1:1,250, 1:2,500 and 1:10,000) topographic mapping.","Orthometric heights. Malin Head (datum code 5130) used for 1:50,000 and smaller mapping.",Ordnance Survey of Northern Ireland,EPSG,2002-09-19,2002.62,0,
@@ -36,7 +36,7 @@
5134,Black Sea,vertical,,,,,1102,Hydrographic surveying and since break-up of Former Soviet Union also topographic mapping.,Black Sea datum is 0.4m below Baltic datum.,BP,EPSG,2002-02-12,,0,
5135,Hong Kong Principal Datum,vertical,"1.23m below the mean of 19 years (1965-83) observations of tide levels at North Point, Victoria Harbour.",1980,,,3334,"Geodetic survey, engineering survey, cadastre.",,"Survey and Mapping Office, Lands Department. Http://www.info.gov.hk/landsd/mapping/tindex.htm",EPSG,2002-06-22,,0,
5136,Hong Kong Chart Datum,vertical,"Approximates to Lowest Astronomic Tide level (LAT).",,,,3335,Hydrographic survey and charting.,"Chart datum is 0.15 metres below Hong Kong Principal Datum (code 5135) and 1.38m below MSL at Quarry Bay.","Survey and Mapping Office, Lands Department. Http://www.info.gov.hk/landsd/mapping/tindex.htm",EPSG,2002-06-22,,0,
-5137,Yellow Sea 1985,vertical,20 years tide readings at Qingdao.,1985,,,3228,"Topographic mapping, geodetic survey.",Supersedes Yellow Sea 1956 datum.,Guangdong Province Land Resource Information Centre,EPSG,2002-06-22,,0,
+5137,Yellow Sea 1985,vertical,20 years tide readings at Qingdao.,1985,,,3228,"Topographic mapping, geodetic survey.",Replaces Yellow Sea 1956 datum.,Guangdong Province Land Resource Information Centre,EPSG,2002-06-22,,0,
5138,"Ordnance Datum Newlyn (Orkney Isles)",vertical,Connected to Newlyn datum by triangulation from the British mainland.,,,,2793,"Topographic mapping, geodetic survey.",Considered as separate from Newlyn because the accuracy of the trigonometric connection across the Pentland Firth does not meet geodetic levelling specifications. Orthometric heights.,Ordnance Survey of Great Britain,EPSG,2004-06-16,2004.10,0,
5139,Fair Isle,vertical,,,,,2794,"Topographic mapping, geodetic survey.",Orthometric heights.,Ordnance Survey of Great Britain,EPSG,2002-09-19,,0,
5140,Lerwick,vertical,,,,,2795,"Topographic mapping, geodetic survey.",Orthometric heights.,Ordnance Survey of Great Britain,EPSG,2002-09-19,,0,
@@ -48,13 +48,13 @@
5146,Flannan Isles,vertical,,,,,2801,"Topographic mapping, geodetic survey.",Orthometric heights.,Ordnance Survey of Great Britain,EPSG,2006-01-16,2005.88,0,
5147,St. Marys,vertical,,,,,2802,"Topographic mapping, geodetic survey.",Orthometric heights.,Ordnance Survey of Great Britain,EPSG,2002-09-19,,0,
5148,Douglas,vertical,,,,,2803,"Topographic mapping, geodetic survey.",Orthometric heights.,Ordnance Survey of Great Britain,EPSG,2002-09-19,,0,
-5149,Fao,vertical,,,,,2806,"Topographic mapping, geodetic survey.","Established by Hunting Surveys for IPC. Superseded by Bandar Abbas (code 5150). At time of record creation NIOC data in Ahwaz area still usually referenced to Fao.","National Iranian Oil Company (NIOC).",EPSG,2002-09-19,,0,
-5150,Bandar Abbas,vertical,Average sea level at Bandar Abbass 1995-2001.,2001,,,3336,"Topographic mapping, geodetic survey.","Supersedes Fao (code 5149).",National Cartographic Centre of Iran,EPSG,2002-09-19,,0,
+5149,Fao,vertical,,,,,2806,"Topographic mapping, geodetic survey.","Established by Hunting Surveys for IPC. Replaced by Bandar Abbas (code 5150). At time of record creation NIOC data in Ahwaz area still usually referenced to Fao.","National Iranian Oil Company (NIOC).",EPSG,2002-09-19,,0,
+5150,Bandar Abbas,vertical,Average sea level at Bandar Abbass 1995-2001.,2001,,,3336,"Topographic mapping, geodetic survey.","Replaces Fao (code 5149).",National Cartographic Centre of Iran,EPSG,2002-09-19,,0,
5151,Nivellement General de Nouvelle Caledonie,vertical,"Rivet AB01 established by SHOM (Service Hydrographique de la Marine) in 1937 on the Quai des Volontaires in Noumea. Height i: 1.885 metre above mean sea level.",1969,,,2822,"Geodetic survey, topographic mapping, engineering survey.",Orthometric heights.,Service Topographique de la Nouvelle Caledonie.,EPSG,2004-03-15,2004.06,0,
-5152,Poolbeg,vertical,"Low water mark of the spring tide on the 8 April 1837 at Poolbeg Lighthouse, Dublin.",1837,,,1305,Topographic mapping before 1956 in Northern Ireland and 1970 in the Republic of Ireland.,"Superseded by Belfast Lough and Malin Head (datum codes 5130-31).","""The Irish Grid - A Description of the Co-ordinate Reference System"" published by Ordnance Survey of Ireland, Dublin and Ordnance Survey of Northern Ireland, Belfast.",EPSG,2003-06-27,,0,
+5152,Poolbeg,vertical,"Low water mark of the spring tide on the 8 April 1837 at Poolbeg Lighthouse, Dublin.",1837,,,1305,Topographic mapping before 1956 in Northern Ireland and 1970 in the Republic of Ireland.,"Replaced by Belfast Lough and Malin Head (datum codes 5130-31).","""The Irish Grid - A Description of the Co-ordinate Reference System"" published by Ordnance Survey of Ireland, Dublin and Ordnance Survey of Northern Ireland, Belfast.",EPSG,2003-06-27,,0,
5153,Nivellement General Guyanais 1977,vertical,,1977,,,3146,"Geodetic survey, topographic mapping, engineering survey.",Normal heights.,IGN Paris,EPSG,2003-06-27,,0,
-5154,Martinique 1987,vertical,,,,,3276,"Geodetic survey, topographic mapping, engineering survey.","Supersedes Martinique 1955 (datum code 5192).",IGN Paris,EPSG,2004-10-14,2004.561,0,
-5155,Guadeloupe 1988,vertical,,,,,2829,"Geodetic survey, topographic mapping, engineering survey.","Supersedes Guadeloupe 1951 (datum code 5193).",IGN Paris,EPSG,2004-10-14,2004.561,0,
+5154,Martinique 1987,vertical,,,,,3276,"Geodetic survey, topographic mapping, engineering survey.","Replaces Martinique 1955 (datum code 5192).",IGN Paris,EPSG,2004-10-14,2004.561,0,
+5155,Guadeloupe 1988,vertical,,,,,2829,"Geodetic survey, topographic mapping, engineering survey.","Replaces Guadeloupe 1951 (datum code 5193).",IGN Paris,EPSG,2004-10-14,2004.561,0,
5156,Reunion 1989,vertical,,,,,3337,"Geodetic survey, topographic mapping, engineering survey.",,IGN Paris,EPSG,2004-10-14,2004.561,0,
5157,Auckland,vertical,MSL at Auckland harbour 1909-1923.,1946,,,1500,"Geodetic survey, topographic mapping, engineering survey.",,"OSG Technical Report #10, February 2001.",EPSG,2004-03-09,,0,
5158,Bluff,vertical,MSL at Invercargill harbour over 8 years between 1918 and 1934.,1955,,,1501,"Geodetic survey, topographic mapping, engineering survey.",,"OSG Technical Report #10, February 2001.",EPSG,2004-03-09,,0,
@@ -80,19 +80,19 @@
5178,Cascais,vertical,Mean Sea Level at Cascais 1938.,1938,,,1294,"Geodetic survey, topographic mapping, engineering survey.",Orthometric heights.,"Eurogeographics, http://crs.bkg.bund.de/crs-eu/",EPSG,2004-03-09,,0,
5179,Constanta,vertical,Mean Sea Level at Constanta.,,,,3295,"Geodetic survey, topographic mapping, engineering survey.",Normal-orthometric heights.,"Eurogeographics, http://crs.bkg.bund.de/evrs/Relations.html",EPSG,2004-03-09,,0,
5180,Alicante,vertical,Mean Sea Level at Alicante between 1870 and 1882.,,,,2366,"Geodetic survey, topographic mapping, engineering survey.",Orthometric heights.,"Eurogeographics, http://crs.bkg.bund.de/crs-eu/",EPSG,2004-03-09,,0,
-5181,Deutches Haupthohennetz 1992,vertical,"Network adjusted in 1992. Geopotential number at reference point Wallenhorst defined as value from the UELN-73/86 adjustment. Datum at Normaal Amsterdams Peil (NAP) is mean high tide in 1684.",1992,,,3339,"Geodetic survey, topographic mapping, engineering survey.",Supersedes DHHN85 in West Germany and SNN76 in East Germany. Uses Normal heights.,"Bundesamt für Kartographie und Geodäsie (BKG), http://crs.bkg.bund.de/crs-eu/",EPSG,2004-03-09,,0,
-5182,Deutches Haupthohennetz 1985,vertical,"Network adjusted in 1985. Height of reference point Wallenhorst defined as value from 1928 adjustment. Datum at Normaal Amsterdams Peil (NAP) is mean high tide in 1684.",1985,,,2326,"Geodetic survey, topographic mapping, engineering survey.",Superseded by DHHN92. Uses Normal-orthometric heights.,"Eurogeographics, http://crs.bkg.bund.de/crs-eu/",EPSG,2004-03-09,,0,
-5183,SNN76,vertical,Network adjusted in 1976. Height at reference point Hoppegarten defined as 1957 value from the UPLN adjustment. Datum at Kronstadt is mean sea level of Baltic in 1833.,1976,,,1343,"Geodetic survey, topographic mapping, engineering survey.",Uses Normal heights. Superseded by DHHN92.,"Eurogeographics, http://crs.bkg.bund.de/crs-eu/",EPSG,2004-03-09,,0,
+5181,Deutches Haupthohennetz 1992,vertical,"Network adjusted in 1992. Geopotential number at reference point Wallenhorst defined as value from the UELN-73/86 adjustment. Datum at Normaal Amsterdams Peil (NAP) is mean high tide in 1684.",1992,,,3339,"Geodetic survey, topographic mapping, engineering survey.",Replaces DHHN85 in West Germany and SNN76 in East Germany. Uses Normal heights.,"Bundesamt für Kartographie und Geodäsie (BKG), http://crs.bkg.bund.de/crs-eu/",EPSG,2004-03-09,,0,
+5182,Deutches Haupthohennetz 1985,vertical,"Network adjusted in 1985. Height of reference point Wallenhorst defined as value from 1928 adjustment. Datum at Normaal Amsterdams Peil (NAP) is mean high tide in 1684.",1985,,,2326,"Geodetic survey, topographic mapping, engineering survey.",Replaced by DHHN92. Uses Normal-orthometric heights.,"Eurogeographics, http://crs.bkg.bund.de/crs-eu/",EPSG,2004-03-09,,0,
+5183,SNN76,vertical,Network adjusted in 1976. Height at reference point Hoppegarten defined as 1957 value from the UPLN adjustment. Datum at Kronstadt is mean sea level of Baltic in 1833.,1976,,,1343,"Geodetic survey, topographic mapping, engineering survey.",Uses Normal heights. Replaced by DHHN92.,"Eurogeographics, http://crs.bkg.bund.de/crs-eu/",EPSG,2004-03-09,,0,
5184,Baltic 1982,vertical,Network adjusted in 1982. Height at reference point Varna defined as 1958 value from the UPLN adjustment. Datum at Kronstadt is mean sea level of Baltic in 1833.,1982,,,3224,"Geodetic survey, topographic mapping, engineering survey.",Uses Normal heights.,"Eurogeographics, http://crs.bkg.bund.de/crs-eu/",EPSG,2004-03-09,,0,
5185,Baltic 1980,vertical,,,,,1119,"Geodetic survey, topographic mapping, engineering survey.",Uses Normal heights.,"Eurogeographics, http://crs.bkg.bund.de/crs-eu/",EPSG,2004-03-09,,0,
5186,Kuwait PWD,vertical,"Mean Low Low Water (MLLW) at Kuwait City.",,,,3267,Municipality and military purposes.,Approximately 1.03m below MSL.,Kuwait Oil Company.,EPSG,2004-06-16,,0,
5187,KOC Well Datum,vertical,,1937,,,3267,KOC exploration and field development subsurface work.,Approximately 3.22m above MSL.,Kuwait Oil Company.,EPSG,2004-06-16,,0,
5188,KOC Construction Datum,vertical,,1952,,,3267,KOC survey control and facilities engineering.,Approximately 1.52m below MSL. Created for the construction of the Mina al Ahmadi refinery.,Kuwait Oil Company.,EPSG,2004-06-16,,0,
-5189,Nivellement General de la Corse 1948,vertical,Mean sea level at Ajaccio between 1912 and 1937.,1948,,,1327,"Geodetic survey, topographic mapping, engineering survey.","Superseded by IGN78 Corsica (datum 5120).",IGN Paris,EPSG,2004-10-14,,0,
+5189,Nivellement General de la Corse 1948,vertical,Mean sea level at Ajaccio between 1912 and 1937.,1948,,,1327,"Geodetic survey, topographic mapping, engineering survey.","Replaced by IGN78 Corsica (datum 5120).",IGN Paris,EPSG,2004-10-14,,0,
5190,Danger 1950,vertical,Marker near tide gauge at port of Saint Pierre. Height is 1.26 metres above zero of tide gauge.,1950,,,3299,"Geodetic survey, topographic mapping, engineering survey.",,IGN Paris,EPSG,2004-10-14,,0,
5191,Mayotte 1950,vertical,Marker on Issoufali jetty at Dzaoudzi. Height is 2.18m above zero of tide gauge.,1950,,,3340,"Geodetic survey, topographic mapping, engineering survey.",,IGN Paris,EPSG,2004-10-14,,0,
-5192,Martinique 1955,vertical,Marker N.BC-2 situated at the port of Fort de France.,1955,,,3276,"Geodetic survey, topographic mapping, engineering survey.","Superseded by Martinique 1987 (datum code 5154).",IGN Paris,EPSG,2004-10-14,,0,
-5193,Guadeloupe 1951,vertical,At the port of Pointe-a-Pitre.,1955,,,2892,"Geodetic survey, topographic mapping, engineering survey.","Superseded by Guadeloupe 1988 (datum code 5155).",IGN Paris,EPSG,2004-10-14,,0,
+5192,Martinique 1955,vertical,Marker N.BC-2 situated at the port of Fort de France.,1955,,,3276,"Geodetic survey, topographic mapping, engineering survey.","Replaced by Martinique 1987 (datum code 5154).",IGN Paris,EPSG,2004-10-14,,0,
+5193,Guadeloupe 1951,vertical,At the port of Pointe-a-Pitre.,1955,,,2892,"Geodetic survey, topographic mapping, engineering survey.","Replaced by Guadeloupe 1988 (datum code 5155).",IGN Paris,EPSG,2004-10-14,,0,
5194,Lagos 1955,vertical,"Mean sea level at Lagos, 1912-1928.",1955,,,3287,"Geodetic survey, topographic mapping, engineering survey.",,"Ebong et al, AVN International, 1991.",EPSG,2004-10-14,,0,
5195,Nivellement General de Polynesie Francaise,vertical,,,,,3134,"Geodetic survey, topographic mapping, engineering survey.",The collection of heterogeneous levelling networks throughout the Society Islands of French Polynesia.,"Gouvernement de la Polynésie Française, Service de l'Urbanisme, Section topographie.",EPSG,2005-08-12,,0,
5196,IGN 1966,vertical,"Fundamental benchmark: RN501",1966,,,3124,"Geodetic survey, topographic mapping, engineering survey.",Included as part of NGPF - see datum code 5195.,"Gouvernement de la Polynésie Française, Service de l'Urbanisme, Section topographie.",EPSG,2005-08-12,,0,
@@ -103,6 +103,9 @@
5201,Tahaa SAU 2001,vertical,"Fundamental benchmark: RN16",2001,,,3138,"Geodetic survey, topographic mapping, engineering survey.",Included as part of NGPF - see datum code 5195.,"Gouvernement de la Polynésie Française, Service de l'Urbanisme, Section topographie.",EPSG,2005-08-12,,0,
5202,Bora Bora SAU 2001,vertical,"Fundamental benchmark: Vaitape quay SHOM benchmark B.",2001,,,3137,"Geodetic survey, topographic mapping, engineering survey.",Included as part of NGPF - see datum code 5195.,"Gouvernement de la Polynésie Française, Service de l'Urbanisme, Section topographie.",EPSG,2005-08-12,,0,
5203,EGM84 geoid,vertical,WGS 84 ellipsoid.,1984,,,1262,Geodesy.,,"US National Geospatial-Intelligence Agency (NGA); http://earth-info.nga.mil/GandG/",EPSG,2005-09-30,,0,
+5204,International Great Lakes Datum 1955,vertical,"Pointe-au-Père (Father's Point), Quebec",1955,,,3468,Hydrology.,Dynamic heights. Adopted in 1962. Replaced by IGLD 1985 in January 1992.,Coordinating Committee on Great Lakes Basic Hydraulic and Hydrologic Data,OGP,2006-11-11,,0,
+5205,International Great Lakes Datum 1985,vertical,"Rimouski, Quebec.",1985,,,3468,Hydrology.,Dynamic heights. Replaces IGLD 1955 from January 1992.,Coordinating Committee on Great Lakes Basic Hydraulic and Hydrologic Data,OGP,2006-11-11,,0,
+5206,Dansk Vertikal Reference 1990,vertical,"Benchmark at Ã
rhus cathedral referenced to mean sea level determined during 1990 at 10 tide gauges: Esbjerg, Fredericia, Frederikshavn, Gedser, Hirtshals, Hornbæk, Korsør, København, Slipshavn and Ã
rhus.",,,,3237,Topographic mapping and engineering survey,Normal Orthometric heights.,"Kort & Matrikelstyrelsen",OGP,2006-12-01,,0,
6001,"Not specified (based on Airy 1830 ellipsoid)",geodetic,,,7001,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,EPSG,EPSG,2000-05-03,96.08 2000.42,0,"D_Airy_1830"
6002,"Not specified (based on Airy Modified 1849 ellipsoid)",geodetic,,,7002,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,EPSG,EPSG,2000-05-03,96.08 2000.42,0,"D_Airy_Modified"
6003,"Not specified (based on Australian National Spheroid)",geodetic,,,7003,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,EPSG,EPSG,2000-05-03,96.08 2000.42,0,"D_Australian"
@@ -134,7 +137,7 @@
6032,"Not specified (based on OSU86F ellipsoid)",geodetic,,,7032,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,EPSG,EPSG,2000-05-03,96.08 2000.42,0,"D_OSU_86F"
6033,"Not specified (based on OSU91A ellipsoid)",geodetic,,,7033,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,EPSG,EPSG,2000-05-03,96.08 2000.42,0,"D_OSU_91A"
6034,"Not specified (based on Clarke 1880 ellipsoid)",geodetic,,,7034,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,EPSG,EPSG,2000-05-03,96.08 2000.42,0,"D_Clarke_1880"
-6035,"Not specified (based on Authalic Sphere)",geodetic,,,7035,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown. Deprecated and superseded by 6047.,EPSG,EPSG,2001-06-05,96.08 2000.42,1,"D_Sphere"
+6035,"Not specified (based on Authalic Sphere)",geodetic,,,7035,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown. Deprecated and replaced by 6047.,EPSG,EPSG,2001-06-05,96.08 2000.42,1,"D_Sphere"
6036,"Not specified (based on GRS 1967 ellipsoid)",geodetic,,,7036,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,EPSG,EPSG,2000-05-03,2000.42,0,"D_GRS_1967"
6041,"Not specified (based on Average Terrestrial System 1977 ellipsoid)",geodetic,,,7041,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,EPSG,EPSG,2000-05-03,2000.42,0,
6042,"Not specified (based on Everest (1830 Definition) ellipsoid)",geodetic,,,7042,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,EPSG,EPSG,2000-05-03,2000.42,0,"D_Everest_1830"
@@ -143,36 +146,38 @@
6045,"Not specified (based on Everest 1830 (1975 Definition) ellipsoid)",geodetic,,,7045,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,EPSG,EPSG,2000-05-03,2000.42,0,"D_Everest_Def_1975"
6047,"Not specified (based on GRS 1980 Authalic Sphere)",geodetic,,,7048,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,EPSG,EPSG,2004-04-27,2001.19 2003.33,0,
6052,"Not specified (based on Clarke 1866 Authalic Sphere)",geodetic,,,7052,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,EPSG,EPSG,2004-04-27,,0,"D_Sphere_Clarke_1866_Authalic"
-6120,Greek,geodetic,"Fundamental point: Athens Observatory; latitude 37 deg 58 min 20.132 sec N; longitude 23 deg 42 min 58.815 sec E of Greenwich",,7004,8901,1106,Topographic mapping.,"See geodetic datum alias 6404. Used as basis of topographic mapping based on Hatt projection. Superseded by GGRS87 (code 6121).","Topography Department; National Technical University of Athens",EPSG,2004-03-26,2004.183,0,"D_Greek"
-6121,Greek Geodetic Reference System 1987,geodetic,"Fundamental point: Dionysos; latitude 38 deg 04 min 33.8 sec N; longitude 23 deg 55 min 51.0 sec E of Greenwich; geoid height 7.0 m.",1987,7019,8901,1106,Topographic mapping.,"Superseded (old) Greek datum. Oil industry work based on ED50.","L. Portokalakis; Public Petroleum Corporation of Greece",EPSG,1997-06-16,,0,"D_GGRS_1987"
+6053,"Not specified (based on International 1924 Authalic Sphere)",geodetic,,,7057,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2006-09-22,,0,
+6054,"Not specified (based on Hughes 1980 ellipsoid)",geodetic,,,7058,8901,1263,Not a valid datum.,Included for coordinate reference systems where datum is unknown.,OGP,OGP,2006-09-22,,0,
+6120,Greek,geodetic,"Fundamental point: Athens Observatory; latitude 37 deg 58 min 20.132 sec N; longitude 23 deg 42 min 58.815 sec E of Greenwich",,7004,8901,1106,Topographic mapping.,"See geodetic datum alias 6404. Used as basis of topographic mapping based on Hatt projection. Replaced by GGRS87 (code 6121).","Topography Department; National Technical University of Athens",EPSG,2004-03-26,2004.183,0,"D_Greek"
+6121,Greek Geodetic Reference System 1987,geodetic,"Fundamental point: Dionysos; latitude 38 deg 04 min 33.8 sec N; longitude 23 deg 55 min 51.0 sec E of Greenwich; geoid height 7.0 m.",1987,7019,8901,1106,Topographic mapping.,"Replaced (old) Greek datum. Oil industry work based on ED50.","L. Portokalakis; Public Petroleum Corporation of Greece",EPSG,1997-06-16,,0,"D_GGRS_1987"
6122,Average Terrestrial System 1977,geodetic,,1977,7041,8901,1283,Topographic mapping.,"In use from 1979. To be phased out in late 1990's.",New Brunswick Geographic Information Corporation land and water information standards manual.,EPSG,1997-07-02,,0,"D_ATS_1977"
6123,"Kartastokoordinaattijarjestelma (1966)",geodetic,Adjustment with fundamental point SF31 based on ED50 transformed to best fit the older VVJ adjustment.,1966,7022,8901,1095,"Geodetic survey, cadastre, topographic mapping, engineering survey.",Adopted in 1970.,"National Land Survey of Finland;
http://www.maanmittauslaitos.fi",EPSG,2006-03-31,2006.27,0,"D_KKJ"
-6124,Rikets koordinatsystem 1990,geodetic,,1982,7004,8901,1225,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Supersedes RT38 adjustment (datum code 6308)",National Land Survey of Sweden,EPSG,1997-11-13,,0,"D_RT_1990"
+6124,Rikets koordinatsystem 1990,geodetic,,1982,7004,8901,1225,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaces RT38 adjustment (datum code 6308)",National Land Survey of Sweden,EPSG,1997-11-13,,0,"D_RT_1990"
6125,Samboja,geodetic,Original origin station P2 Exc now destroyed. Extensions recomputed using Toran station T9 as origin.,,7004,8901,1328,Topographic mapping.,,Total Indonesia.,EPSG,1997-11-13,,1,"D_Samboja"
6126,"Lithuania 1994 (ETRS89)",geodetic,Constrained to 4 ETRS89 points in Lithuania from the EUREF Baltic 1992 campaign..,1994,7019,8901,1145,"Topographic mapping, geodetic survey.",Densification of ETRS89 during the 1992 Baltic campaign.,HNIT-Baltic GeoInfoServisas,EPSG,1998-03-12,,0,"D_Lithuania_1994"
6127,Tete,geodetic,"Fundamental point: Tete.",,7008,8901,3281,Topographic mapping.,,"Mozambique Direcção Nacional de Geografia e Cadastral (DINAGECA).",EPSG,1998-04-16,,0,"D_Tete"
-6128,Madzansua,geodetic,"Fundamental point: Madzansua.",,7008,8901,1315,Topographic mapping.,"Superseded by transformation to Tete datum (datum code 6127).","Mozambique Direcção Nacional de Geografia e Cadastral (DINAGECA).",EPSG,1998-04-16,,0,"D_Madzansua"
-6129,Observatario,geodetic,"Fundamental point: Maputo observatory.",,7008,8901,1329,Topographic mapping.,"Superseded by transformation to Tete datum (datum code 6127).","Mozambique Direcção Nacional de Geografia e Cadastral (DINAGECA).",EPSG,1998-04-16,,0,"D_Observatario"
+6128,Madzansua,geodetic,"Fundamental point: Madzansua.",,7008,8901,1315,Topographic mapping.,"Replaced by transformation to Tete datum (datum code 6127).","Mozambique Direcção Nacional de Geografia e Cadastral (DINAGECA).",EPSG,1998-04-16,,0,"D_Madzansua"
+6129,Observatario,geodetic,"Fundamental point: Maputo observatory.",,7008,8901,1329,Topographic mapping.,"Replaced by transformation to Tete datum (datum code 6127).","Mozambique Direcção Nacional de Geografia e Cadastral (DINAGECA).",EPSG,1998-04-16,,0,"D_Observatario"
6130,"Moznet (ITRF94)",geodetic,ITRF94 at epoch 1996.9,,7030,8901,1167,Topographic mapping.,,"Mozambique Direcção Nacional de Geografia e Cadastral (DINAGECA).",EPSG,2006-08-18,2006.77,0,"D_Moznet"
6131,Indian 1960,geodetic,DMA extension over IndoChina of the Indian 1954 network adjusted to better fit local geoid.,,7015,8901,1302,Topographic mapping.,"Also known as Indian (DMA Reduced).",,EPSG,2003-12-31,2003.361,0,"D_Indian_1960"
6132,Final Datum 1958,geodetic,"Fundamental point: Maniyur. Latitude: 31 deg 23 min 59.19 sec N; Longitude: 48 deg 32 min 31.38 sec E (of Greenwich).",,7012,8901,1300,Oil industry mapping.,Network included in Nahrwan 1967 adjustment.,IOEPC records,EPSG,1998-11-11,,0,"D_FD_1958"
-6133,Estonia 1992,geodetic,Densification from 4 ETRS89 points.,1992,7019,8901,1090,"Topographic mapping, Geodetic survey.","Based on ETRS89 as established during the 1992 Baltic campaign. Superseded by Estonia 1997 adjustment (code 6180).","http://www.geo.ut.ee",EPSG,2005-09-06,2005.46,0,"D_Estonia_1992"
-6134,PDO Survey Datum 1993,geodetic,Adjustment best fitted to Fahud network.,1993,7012,8901,3288,Oil industry mapping.,"Supersedes Fahud datum (code 6232). Maximum differences to Fahud adjustment are 20 metres.",Petroleum Development Oman,EPSG,1999-04-22,,0,"D_PDO_1993"
+6133,Estonia 1992,geodetic,Densification from 4 ETRS89 points.,1992,7019,8901,1090,"Topographic mapping, Geodetic survey.","Based on ETRS89 as established during the 1992 Baltic campaign. Replaced by Estonia 1997 adjustment (code 6180).","http://www.geo.ut.ee",EPSG,2005-09-06,2005.46,0,"D_Estonia_1992"
+6134,PDO Survey Datum 1993,geodetic,Adjustment best fitted to Fahud network.,1993,7012,8901,3288,Oil industry mapping.,"Replaces Fahud datum (code 6232). Maximum differences to Fahud adjustment are 20 metres.",Petroleum Development Oman,EPSG,1999-04-22,,0,"D_PDO_1993"
6135,Old Hawaiian,geodetic,"Fundamental point: Oahu West Base Astro. Latitude: 21 deg 18 min 13.89 sec N; longitude 157 deg 50 min 55.79 sec W (of Greenwich)",,7008,8901,1334,Topographic mapping.,"Hawaiian Islands were never on NAD27 but rather on Old Hawaiian Datum. NADCON conversion program provides transformation from Old Hawaiian Datum to NAD83 (original 1986 realization) but making the transformation appear to user as if from NAD27.","http://www.ngs.noaa.gov/ (NADCON readme file).",EPSG,2005-09-05,2005.46,0,"D_Old_Hawaiian"
6136,St. Lawrence Island,geodetic,,,7008,8901,1332,Topographic mapping.,"Many Alaskan islands were never on NAD27 but rather on independent datums. NADCON conversion program provides transformation from St. Lawrence Island Datum to NAD83 (original 1986 realization) - making the transformation appear to user as if from NAD27.","http://www.ngs.noaa.gov/ (NADCON readme file)",EPSG,1999-05-24,,0,"D_St_Lawrence_Island"
6137,St. Paul Island,geodetic,"Fundamental point latitude: 57 deg 07 min 16.86 sec N; longitude: 170 deg 16 min 24.00 sec W (of Greenwich).",,7008,8901,1333,Topographic mapping.,"Many Alaskan islands were never on NAD27 but rather on independent datums. NADCON conversion program provides transformation from St. Paul Island Datum to NAD83 (original 1986 realization) - making the transformation appear to user as if from NAD27.","http://www.ngs.noaa.gov/ (NADCON readme file)",EPSG,1999-05-24,,0,"D_St_Paul_Island"
6138,St. George Island,geodetic,"Fundamental point latitude: 56 deg 36 min 11.31 sec N; longitude: 169 deg 32 min 36.00 sec W (of Greenwich).",,7008,8901,1331,Topographic mapping.,"Many Alaskan islands were never on NAD27 but rather on independent datums. NADCON conversion program provides transformation from St. George Island Datum to NAD83 (original 1986 realization) - making the transformation appear to user as if from NAD27.","http://www.ngs.noaa.gov/ (NADCON readme file)",EPSG,2003-12-31,2003.362,0,"D_St_George_Island"
6139,Puerto Rico,geodetic,"Fundamental point: Cardona Island Lighthouse. Latitude:17 deg 57 min 31.40 sec N; Longitude: 66 deg 38 min 07.53 sec W (of Greenwich).",1901,7008,8901,1335,Topographic mapping.,"NADCON conversion program provides transformation from Puerto Rico Datum to NAD83 (original 1986 realization) but making the transformation appear to user as if from NAD27.","Ordnance Survey of Great Britain and http://www.ngs.noaa.gov/ (NADCON readme file).",EPSG,2003-12-31,2003.362,0,"D_Puerto_Rico"
-6140,NAD83 Canadian Spatial Reference System,geodetic,,1998,7019,8901,2784,Geodetic survey.,,"Natural Resources of Canada, CSRS website. http://www.geod.nrcan.gc.ca",EPSG,2006-07-30,2005.88 2006.461,0,"D_North_American_1983_CSRS98"
+6140,NAD83 Canadian Spatial Reference System,geodetic,,1998,7019,8901,1061,Geodetic survey.,,"Natural Resources of Canada, CSRS website. http://www.geod.nrcan.gc.ca",EPSG,2007-05-29,2005.88 2006.461 2007.026,0,"D_North_American_1983_CSRS98"
6141,Israel,geodetic,"Fundamental point: Latitude: 31 deg 44 min 03.817 sec N; Longitude: 35 deg 12 min 16.261 sec E (of Greenwich).",,7019,8901,2603,Topographic mapping.,,Survey of Israel.,EPSG,2004-04-14,2002.34 2004.15,0,"D_Israel"
6142,Locodjo 1965,geodetic,"Fundamental point: T5 Banco. Latitude: 5 deg 18 min 50.5 sec N; Longitude: 4 deg 02 min 05.1 sec W (of Greenwich).",1965,7012,8901,1075,Topographic mapping.,,IGN Paris.,EPSG,1999-10-20,,0,"D_Locodjo_1965"
6143,Abidjan 1987,geodetic,"Fundamental point: Abidjan I. Latitude: 5 deg 18 min 51.01 sec N; Longitude: 4 deg 02 min 06.04 sec W (of Greenwich).",1987,7012,8901,1075,Topographic mapping.,,IGN Paris.,EPSG,1999-10-20,,0,"D_Abidjan_1987"
-6144,Kalianpur 1937,geodetic,"Fundamental point: Kalianpur. Latitude: 24 deg 07 min 11.260 sec N; Longitude: 77 deg 39 min 17.570 sec E (of Greenwich).",1937,7015,8901,1308,Topographic mapping.,Supersedes 1880 adjustment except for topographic mapping. Superseded in Bangladesh and Pakistan by 1962 metrication conversion and in India by 1975 metrication conversion.,"G. Bomford; ""The Re-adjustment of the Indian Triangulation""; Survey of India Professional Paper 28; 1939.",EPSG,1999-10-20,,0,"D_Kalianpur_1937"
+6144,Kalianpur 1937,geodetic,"Fundamental point: Kalianpur. Latitude: 24 deg 07 min 11.260 sec N; Longitude: 77 deg 39 min 17.570 sec E (of Greenwich).",1937,7015,8901,1308,Topographic mapping.,Replaces 1880 adjustment except for topographic mapping. Replaced in Bangladesh and Pakistan by 1962 metrication conversion and in India by 1975 metrication conversion.,"G. Bomford; ""The Re-adjustment of the Indian Triangulation""; Survey of India Professional Paper 28; 1939.",EPSG,1999-10-20,,0,"D_Kalianpur_1937"
6145,Kalianpur 1962,geodetic,"Fundamental point: Kalianpur. Latitude: 24 deg 07 min 11.260 sec N; Longitude: 77 deg 39 min 17.570 sec E (of Greenwich).",1962,7044,8901,3289,Topographic mapping.,"1937 adjustment rescaled by ratio metric conversions of Indian foot (1937) to Indian foot (1962).",,EPSG,1999-10-20,,0,"D_Kalianpur_1962"
6146,Kalianpur 1975,geodetic,"Fundamental point: Kalianpur. Latitude: 24 deg 07 min 11.260 sec N; Longitude: 77 deg 39 min 17.570 sec E (of Greenwich).",1975,7045,8901,3341,Topographic mapping.,"1937 adjustment rescaled by ratio metric conversions of Indian foot (1937) to Indian foot (1975).",,EPSG,1999-10-20,,0,"D_Kalianpur_1975"
6147,Hanoi 1972,geodetic,,1972,7024,8901,3328,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,PetroVietnam,EPSG,1999-10-20,,0,"D_Hanoi_1972"
-6148,Hartebeesthoek94,geodetic,Coincident with ITRF91 at epoch 1994.0 at Hartebeesthoek astronomical observatory near Pretoria.,1994,7030,8901,1215,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Supersedes Cape datum (code 6222).","Directorate of Surveys and Mapping; http://w3sli.wcape.gov.za/surveys/mapping/wgs84.htm",EPSG,2006-08-18,99.96 2006.77,0,"D_Hartebeesthoek_1994"
+6148,Hartebeesthoek94,geodetic,Coincident with ITRF91 at epoch 1994.0 at Hartebeesthoek astronomical observatory near Pretoria.,1994,7030,8901,1215,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaces Cape datum (code 6222).","Directorate of Surveys and Mapping; http://w3sli.wcape.gov.za/surveys/mapping/wgs84.htm",EPSG,2006-08-18,99.96 2006.77,0,"D_Hartebeesthoek_1994"
6149,CH1903,geodetic,"Fundamental point: Old Bern observatory. Latitude: 46 deg 57 min 08.660 sec N; Longitude: 7 deg 26 min 22.500 sec E (of Greenwich).",1903,7004,8901,1286,Topographic mapping.,,"Bundesamt für Landestopographie",EPSG,1999-10-20,,0,"D_CH1903"
6150,"CH1903+",geodetic,"Fundamental point: Zimmerwald observatory.",,7004,8901,1286,"Geodetic survey, topographic mapping.",,"Bundesamt für Landestopographie. Aufbau der Landesvermessung der Schweiz 'LV95' Teil 3: Terrestrische Bezugssysteme und Bezugsrahmen. L+T 1999.",EPSG,2001-11-06,2001.52,0,"D_CH1903+"
6151,Swiss Terrestrial Reference Frame 1995,geodetic,ETRF89 at epoch 1993.0,1995,7019,8901,1286,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"Bundesamt für Landestopographie. Aufbau der Landesvermessung der Schweiz 'LV95' Teil 3: Terrestrische Bezugssysteme und Bezugsrahmen. L+T 1999.",EPSG,2006-08-18,2006.77,0,"D_Swiss_TRF_1995"
@@ -184,38 +189,38 @@
6157,Mount Dillon,geodetic,"Fundamental point: Mount Dillon triangulation station. Latitude: 11 deg 15 min 07.843 sec N; Longitude: 60 deg 41 min 09.632 sec W (of Greenwich).",,7007,8901,1322,Topographic mapping.,,University of the West Indies Geodetic Services.,EPSG,2003-12-31,2003.361,0,"D_Mount_Dillon"
6158,Naparima 1955,geodetic,"Fundamental point: Naparima. Latitude: 10 deg 16 min 44.860 sec N; Longitude: 61 deg 27 min 34.620 sec W (of Greenwich).",1955,7022,8901,3143,Topographic mapping.,Naparima 1972 is an extension of the Naparima 1955 network of Trinidad to include Tobago.,Ordnance Survey International.,EPSG,2000-03-07,,0,"D_Naparima_1955"
6159,European Libyan Datum 1979,geodetic,Extension of ED50 over Libya.,1979,7022,8901,1143,Topographic mapping.,,Brown and Root,EPSG,2003-12-31,2003.362,0,"D_European_Libyan_1979"
-6160,Chos Malal 1914,geodetic,Chos Malal police station.,1914,7022,8901,1292,Oil industry mapping.,"Also known as Quini-Huao. Superseded by Campo Inchauspe (code 6221).",Various oil company records.,EPSG,2000-03-07,,0,"D_Chos_Malal_1914"
-6161,Pampa del Castillo,geodetic,,,7022,8901,1265,Oil industry mapping.,"Used in Comodoro Rivadavia area. Superseded by Campo Inchauspe (code 6221).",Various oil company records.,EPSG,2000-03-07,,0,"D_Pampa_del_Castillo"
+6160,Chos Malal 1914,geodetic,Chos Malal police station.,1914,7022,8901,1292,Oil industry mapping.,"Also known as Quini-Huao. Replaced by Campo Inchauspe (code 6221).",Various oil company records.,EPSG,2000-03-07,,0,"D_Chos_Malal_1914"
+6161,Pampa del Castillo,geodetic,,,7022,8901,1265,Oil industry mapping.,"Used in Comodoro Rivadavia area. Replaced by Campo Inchauspe (code 6221).",Various oil company records.,EPSG,2000-03-07,,0,"D_Pampa_del_Castillo"
6162,Korean Datum 1985,geodetic,"Fundamental point: Suwon; latitude 37 deg 16 min 31.9034 sec N; longitude 127 deg 03 min 05.1451 sec E of Greenwich.",1985,7004,8901,3266,Topographic mapping.,,"Clifford J. Mugnier; in Photogrammetric Engineering & Remote Sensing November 1999. http://www.asprs.org/",EPSG,2005-09-05,2001.28 2005.46,0,"D_Korean_Datum_1985"
6163,Yemen National Geodetic Network 1996,geodetic,"Sana'a IGN reference marker",1996,7030,8901,1257,Topographic mapping.,,IGN Paris,EPSG,2000-03-07,,0,"D_Yemen_NGN_1996"
6164,South Yemen,geodetic,,,7024,8901,1340,Topographic mapping.,,IGN Paris,EPSG,2000-03-07,,0,"D_South_Yemen"
6165,Bissau,geodetic,,,7022,8901,3258,Topographic mapping.,,"NIMA TR8350.2 ftp://164.214.2.65/pub/gig/tr8350.2/changes.pdf",EPSG,2005-09-05,2005.46,0,"D_Bissau"
6166,Korean Datum 1995,geodetic,,1995,7030,8901,3266,Topographic mapping.,,"NIMA TR8350.2 ftp://164.214.2.65/pub/gig/tr8350.2/changes.pdf",EPSG,2005-09-05,2005.46,0,"D_Korean_Datum_1995"
-6167,New Zealand Geodetic Datum 2000,geodetic,Based on ITRF96 at epoch 2000.0,2000,7019,8901,3285,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Supersedes New Zealand Geodetic Datum 1949 (code 6272) and Chatham Islands Datum 1979 (code 6673) from March 2000.","Land Information New Zealand. http://www.linz.govt.nz/rcs/linz/pub/web/root/core/SurveySystem/GeodeticInfo/GeodeticDatums/nzgd2000factsheet/index.jsp",EPSG,2004-03-26,2004.11,0,"D_NZGD_2000"
-6168,Accra,geodetic,"Fundamental point: GCS Station 547. Latitude: 5 deg 23 min 43.3 sec N; Longitude: 0 deg 11 min 52.3 sec W (of Greenwich).",,7029,8901,1104,Topographic mapping.,"Superseded in 1978 by Leigon datum (code 6250).",Ordnance Survey International,EPSG,2000-10-12,,0,"D_Accra"
+6167,New Zealand Geodetic Datum 2000,geodetic,Based on ITRF96 at epoch 2000.0,2000,7019,8901,3285,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaces New Zealand Geodetic Datum 1949 (code 6272) and Chatham Islands Datum 1979 (code 6673) from March 2000.","Land Information New Zealand. http://www.linz.govt.nz/rcs/linz/pub/web/root/core/SurveySystem/GeodeticInfo/GeodeticDatums/nzgd2000factsheet/index.jsp",EPSG,2004-03-26,2004.11,0,"D_NZGD_2000"
+6168,Accra,geodetic,"Fundamental point: GCS Station 547. Latitude: 5 deg 23 min 43.3 sec N; Longitude: 0 deg 11 min 52.3 sec W (of Greenwich).",,7029,8901,1104,Topographic mapping.,"Replaced in 1978 by Leigon datum (code 6250).",Ordnance Survey International,EPSG,2000-10-12,,0,"D_Accra"
6169,American Samoa 1962,geodetic,"Fundamental point: Betty 13 eccentric. Latitude: 14 deg 20 min 08.34 sec S; longitude: 170 deg 42 min 52.25 sec W",1962,7008,8901,3109,Topographic mapping.,,NIMA TR8350.2 revision of January 2000. Oil industry sources for origin description details.,EPSG,2005-05-21,2003.362 2005.23,0,"D_American_Samoa_1962"
-6170,Sistema de Referencia Geocentrico para America del Sur 1995,geodetic,ITRF94 at epoch 1995.42.,1995,7019,8901,3448,Geodetic survey.,Realised by a frame of 58 stations observed in 1995 and adjusted in the ITRF94. Superseded by SIRGAS 2000.,"NIMA TR8350.2 revision of January 2000. Also http://www1.ibge.gov.br/",EPSG,2006-08-18,2004.25 2005.46 2006.465 2006.77,0,"D_SIRGAS"
+6170,Sistema de Referencia Geocentrico para America del Sur 1995,geodetic,ITRF94 at epoch 1995.42.,1995,7019,8901,3448,Geodetic survey.,Realised by a frame of 58 stations observed in 1995 and adjusted in the ITRF94. Replaced by SIRGAS 2000.,"NIMA TR8350.2 revision of January 2000. Also http://www1.ibge.gov.br/",EPSG,2006-08-18,2004.25 2005.46 2006.465 2006.77,0,"D_SIRGAS"
6171,Reseau Geodesique Francais 1993,geodetic,Coincident with ETRS89 at epoch 1993.0,1993,7019,8901,1096,Geodetic survey.,,"http://www.ign.fr/ via TotalFinaElf",EPSG,2005-09-05,2001.51 2005.46,0,"D_RGF_1993"
6172,Posiciones Geodesicas Argentinas,geodetic,,1994,7019,8901,1033,"Topographic mapping, geodetic survey.","Una red geodésica de 127 puntos materializados
-en el terreno que definen el Sistema Geodésico Nacional. [A geodetic network of 127 points defining the National Geodetic System.] Superseded by POSGAR98 (code 6190).","http://www.igm.gov.ar/posgar.html",EPSG,2000-10-19,,1,"D_POSGAR"
+en el terreno que definen el Sistema Geodésico Nacional. [A geodetic network of 127 points defining the National Geodetic System.] Replaced by POSGAR98 (code 6190).","http://www.igm.gov.ar/posgar.html",EPSG,2000-10-19,,1,"D_POSGAR"
6173,IRENET95,geodetic,ETRS89 stations in Ireland,1995,7019,8901,1305,Geodetic survey.,Densification of ETRS89,Ordnance Survey of Ireland,EPSG,2004-04-07,2004.22,0,"D_IRENET95"
6174,Sierra Leone Colony 1924,geodetic,"Fundamental point: Kortright. Latitude: 8 deg 28 min 44.4 sec N; Longitude: 13 deg 13 min 03.81 sec W (of Greenwich).",1924,7029,8901,1342,"Topographic mapping, engineering survey.",,Ordnance Survey International.,EPSG,2001-06-05,,0,"D_Sierra_Leone_1924"
6175,Sierra Leone 1968,geodetic,"Fundamental point: SLX2 Astro. Latitude: 8 deg 27 min 17.567 sec N; Longitude: 12 deg 49 min 40.186 sec W (of Greenwich).",1968,7012,8901,3306,"Topographic mapping, engineering survey.",Extension and readjustment with additional observations of 1960 network. Coordinates of 1960 stations change by less than 3 metres.,Ordnance Survey International.,EPSG,2001-06-05,,0,"D_Sierra_Leone_1968"
6176,Australian Antarctic Datum 1998,geodetic,,1998,7019,8901,1278,Topographic mapping.,,Standards Australia,EPSG,2006-01-30,2006.08,0,"D_Australian_Antarctic_1998"
6178,"Pulkovo 1942/83",geodetic,"Fundamental point: Pulkovo observatory. Latitude: 59 deg 46 min 18.550 sec N; Longitude: 30 deg 19 min 42.090 sec E (of Greenwich).",1983,7024,8901,1343,"Geodetic survey, cadastre, topographic mapping, engineering survey.",International adjustment of Uniforrm Astro-Geodetic Network of countries of central and eastern Europe.,"Bundesamt für Kartographie und Geodäsie via EuroGeographics; http://crs.bkg.bund.de/crs-eu/",EPSG,2001-06-05,,0,"D_Pulkovo_1942_Adj_1983"
6179,"Pulkovo 1942/58",geodetic,"Fundamental point: Pulkovo observatory. Latitude: 59 deg 46 min 18.550 sec N; Longitude: 30 deg 19 min 42.090 sec E (of Greenwich).",1958,7024,8901,1192,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"Glowny Urzad Geodezji i Kartografii via EuroGeographics; http://crs.bkg.bund.de/crs-eu/",EPSG,2001-06-05,,0,"D_Pulkovo_1942_Adj_1958"
-6180,Estonia 1997,geodetic,Densification of ETRS89 during EUREF-ESTONIA97 campaign through transformation from ITRF96 at epoch 1997.56.,1997,7019,8901,1090,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Supersedes Estonia 1992 adjustment (code 6133).","Estonian National Land Board via EuroGeographics; http://crs.bkg.bund.de/crs-eu/",EPSG,2006-08-18,2006.77,0,"D_Estonia_1997"
+6180,Estonia 1997,geodetic,Densification of ETRS89 during EUREF-ESTONIA97 campaign through transformation from ITRF96 at epoch 1997.56.,1997,7019,8901,1090,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaces Estonia 1992 adjustment (code 6133).","Estonian National Land Board via EuroGeographics; http://crs.bkg.bund.de/crs-eu/",EPSG,2006-08-18,2006.77,0,"D_Estonia_1997"
6181,Luxembourg 1930,geodetic,"Fundamental point: northern station of Habay-la-Neuve baseline in Belgium. Latitude: 49 deg 43 min 24.408 sec N; longitude: 5 deg 38 min 22.470 sec E (of Greenwich)",1930,7022,8901,1146,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"Administration du Cadastre et de la Topographie via EuroGeographics; http://crs.bkg.bund.de/crs-eu/",EPSG,2001-06-05,,0,"D_Luxembourg_1930"
6182,Azores Occidental Islands 1939,geodetic,"Fundamental point: Observatario Meteorologico Flores.",1939,7022,8901,1344,Topographic mapping.,,"Instituto Geografico e Cadastral Lisbon via EuroGeographics; http://crs.bkg.bund.de/crs-eu/",EPSG,2005-12-30,2005.85,0,"D_Azores_Occidental_Islands_1939"
-6183,Azores Central Islands 1948,geodetic,"Fundamental point: Graciosa south west base. Latitude: 39 deg 03 min 54.934 sec N; longitude: 28 deg 02 min 23.882 sec W",1948,7022,8901,1301,Topographic mapping.,"Superseded by 1995 adjustment (datum code 6665).","Instituto Geografico e Cadastral Lisbon via EuroGeographics; http://crs.bkg.bund.de/crs-eu/ Oil industry sources for origin description details.",EPSG,2003-12-31,2002.25 2003.231 2003.362,0,"D_Azores_Central_Islands_1948"
-6184,Azores Oriental Islands 1940,geodetic,"Fundamental point: Forte de São Bras.",1940,7022,8901,1345,Topographic mapping.,"Superseded by 1995 adjustment (datum code 6664).","Instituto Geografico e Cadastral Lisbon via EuroGeographics; http://crs.bkg.bund.de/crs-eu/",EPSG,2003-08-14,2003.231,0,"D_Azores_Oriental_Islands_1940"
+6183,Azores Central Islands 1948,geodetic,"Fundamental point: Graciosa south west base. Latitude: 39 deg 03 min 54.934 sec N; longitude: 28 deg 02 min 23.882 sec W",1948,7022,8901,1301,Topographic mapping.,"Replaced by 1995 adjustment (datum code 6665).","Instituto Geografico e Cadastral Lisbon via EuroGeographics; http://crs.bkg.bund.de/crs-eu/ Oil industry sources for origin description details.",EPSG,2003-12-31,2002.25 2003.231 2003.362,0,"D_Azores_Central_Islands_1948"
+6184,Azores Oriental Islands 1940,geodetic,"Fundamental point: Forte de São Bras.",1940,7022,8901,1345,Topographic mapping.,"Replaced by 1995 adjustment (datum code 6664).","Instituto Geografico e Cadastral Lisbon via EuroGeographics; http://crs.bkg.bund.de/crs-eu/",EPSG,2003-08-14,2003.231,0,"D_Azores_Oriental_Islands_1940"
6185,Madeira 1936,geodetic,"Fundamental point: Madeira SE Base.",1936,7022,8901,1314,Topographic mapping.,,"Instituto Geografico e Cadastral Lisbon via EuroGeographics; http://crs.bkg.bund.de/crs-eu/",EPSG,2001-06-05,,1,"D_Madeira_1936"
-6188,OSNI 1952,geodetic,Position fixed to the coordinates from the 19th century Principle Triangulation of station Divis. Scale and orientation controlled by position of Principle Triangulation stations Knocklayd and Trostan.,1952,7001,8901,2530,Geodetic survey and topographic mapping.,"Superseded by Geodetic Datum of 1965 alias 1975 Mapping Adjustment or TM75 (datum code 6300).",Ordnance Survey of Northern Ireland.,EPSG,2001-11-06,,0,"D_OSNI_1952"
+6188,OSNI 1952,geodetic,Position fixed to the coordinates from the 19th century Principle Triangulation of station Divis. Scale and orientation controlled by position of Principle Triangulation stations Knocklayd and Trostan.,1952,7001,8901,2530,Geodetic survey and topographic mapping.,"Replaced by Geodetic Datum of 1965 alias 1975 Mapping Adjustment or TM75 (datum code 6300).",Ordnance Survey of Northern Ireland.,EPSG,2001-11-06,,0,"D_OSNI_1952"
6189,Red Geodesica Venezolana,geodetic,Realised by a frame of 67 stations observed in 1995 as a densification of the SIRGAS campaign and adjusted in the ITRF94.,2000,7019,8901,1251,Geodetic survey.,,Servicio Autonomo de Geografia y Cartografia Nacional.,EPSG,2001-06-11,,0,"D_REGVEN"
-6190,Posiciones Geodesicas Argentinas 1998,geodetic,"A geodetic network of 136 high accuracy surveyed points. Densification of SIRGAS 1995; ITRF94 at epoch 1995.42.",1998,7019,8901,1033,Geodetic survey.,"Technically, but at this record revision date not legally, supersedes the 1994 POSGAR adjustment (code 6694).","Instituto Geográfico Militar de la República Argentina, http://www.igm.gov.ar",EPSG,2005-09-12,2003.372 2005.46 2005.48 2006.77,0,"D_POSGAR_1998"
+6190,Posiciones Geodesicas Argentinas 1998,geodetic,"A geodetic network of 136 high accuracy surveyed points. Densification of SIRGAS 1995; ITRF94 at epoch 1995.42.",1998,7019,8901,1033,Geodetic survey.,"Technically, but at this record revision date not legally, replaces the 1994 POSGAR adjustment (code 6694).","Instituto Geográfico Militar de la República Argentina, http://www.igm.gov.ar",EPSG,2005-09-12,2003.372 2005.46 2005.48 2006.77,0,"D_POSGAR_1998"
6191,Albanian 1987,geodetic,,1987,7024,8901,1025,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"EuroGeographics; http://crs.bkg.bund.de/crs-eu/",EPSG,2001-11-06,,0,"D_Albanian_1987"
-6192,Douala 1948,geodetic,"South pillar of Douala base; 4deg 00min 40.64sec N, 9deg 42min 30.41sec E",1948,7022,8901,2555,Topographic mapping.,"Superseded by Manoca 1962 datum (code 6193).",TotalFinaElf,EPSG,2005-12-30,2005.83,0,"D_Douala_1948"
-6193,Manoca 1962,geodetic,"Reservoir centre at the Manoca tower (""tube Suel""), 3deg 51min 49.896sec N, 9deg 36min 49.347sec E.",1962,7011,8901,2555,Topographic mapping.,"The intent of the Bukavu 1953 conference was to adopt the Clarke 1880 (RGS) ellipsoid (code 7012) but in practice this datum has used the IGN version. Supersedes Douala 1948 (code 6192).",TotalFinaElf,EPSG,2002-01-18,,0,"D_Manoca_1962"
+6192,Douala 1948,geodetic,"South pillar of Douala base; 4deg 00min 40.64sec N, 9deg 42min 30.41sec E",1948,7022,8901,2555,Topographic mapping.,"Replaced by Manoca 1962 datum (code 6193).",TotalFinaElf,EPSG,2005-12-30,2005.83,0,"D_Douala_1948"
+6193,Manoca 1962,geodetic,"Reservoir centre at the Manoca tower (""tube Suel""), 3deg 51min 49.896sec N, 9deg 36min 49.347sec E.",1962,7011,8901,2555,Topographic mapping.,"The intent of the Bukavu 1953 conference was to adopt the Clarke 1880 (RGS) ellipsoid (code 7012) but in practice this datum has used the IGN version. Replaces Douala 1948 (code 6192).",TotalFinaElf,EPSG,2002-01-18,,0,"D_Manoca_1962"
6194,Qornoq 1927,geodetic,"Fundamental point: Station 7008. Latitude: 64 deg 31 min 06.27 sec N; Longitude: 51 deg 12 min 24.86 sec W (of Greenwich).",1927,7022,8901,3362,Topographic mapping.,,"Kort & Matrikelstyrelsen, Copenhagen. Origin coordinates from NIMA http://earth-info.nima.mil/",EPSG,2006-03-16,2003.362 2005.46 2006.22,0,"D_Qornoq_1927"
6195,Scoresbysund 1952,geodetic,,1952,7022,8901,2570,Topographic mapping.,,"Kort & Matrikelstyrelsen, Copenhagen.",EPSG,2002-01-18,,0,"D_Scoresbysund_1952"
6196,Ammassalik 1958,geodetic,,1958,7022,8901,2571,Topographic mapping.,,"Kort & Matrikelstyrelsen, Copenhagen.",EPSG,2002-01-18,,0,"D_Ammassalik_1958"
@@ -229,7 +234,7 @@
6204,Ain el Abd 1970,geodetic,"Fundamental point: Ain El Abd. Latitude: 28 deg 14 min 06.171 sec N; Longitude: 48 deg 16 min 20.906 sec E (of Greenwich).",1970,7022,8901,1272,Topographic mapping.,,,EPSG,2003-12-31,2003.361,0,"D_Ain_el_Abd_1970"
6205,Afgooye,geodetic,,,7024,8901,1214,Topographic mapping.,,,EPSG,1995-06-02,,0,"D_Afgooye"
6206,Agadez,geodetic,,,7011,8901,1177,Topographic mapping.,,,EPSG,1995-06-02,,0,"D_Agadez"
-6207,Lisbon 1937,geodetic,"Fundamental point: Castelo Sao Jorge; Lisbon. Latitude: 38 deg 42 min 43.631 sec N; Longitude: 9 deg 07 min 54.862 sec W (of Greenwich).",1937,7022,8901,1294,Topographic mapping.,"Supersedes Lisbon 1890 adjustment (which used Bessel 1841 ellipsoid).","Instituto Geografico e Cadastral; Lisbon",EPSG,1995-06-02,2001.551,0,"D_Lisbon"
+6207,Lisbon 1937,geodetic,"Fundamental point: Castelo Sao Jorge; Lisbon. Latitude: 38 deg 42 min 43.631 sec N; Longitude: 9 deg 07 min 54.862 sec W (of Greenwich).",1937,7022,8901,1294,Topographic mapping.,"Replaces Lisbon 1890 adjustment (which used Bessel 1841 ellipsoid).","Instituto Geografico e Cadastral; Lisbon",EPSG,1995-06-02,2001.551,0,"D_Lisbon"
6208,Aratu,geodetic,,,7022,8901,1274,Oil industry geodetic purposes.,,,EPSG,1995-06-02,,0,"D_Aratu"
6209,Arc 1950,geodetic,"Fundamental point: Buffelsfontein. Latitude: 33 deg 59 min 32.000 sec S; Longitude: 25 deg 30 min 44.622 sec E (of Greenwich).",1950,7013,8901,1276,"Topographic mapping, geodetic survey.",,,EPSG,1995-06-02,,0,"D_Arc_1950"
6210,Arc 1960,geodetic,"Fundamental point: Buffelsfontein. Latitude: 33 deg 59 min 32.000 sec S; Longitude: 25 deg 30 min 44.622 sec E (of Greenwich).",1960,7012,8901,1277,"Topographic mapping, geodetic survey.",,,EPSG,1995-06-02,,0,"D_Arc_1960"
@@ -239,9 +244,9 @@
6214,Beijing 1954,geodetic,,1954,7024,8901,1067,Topographic mapping.,,,EPSG,1995-06-02,,0,"D_Beijing_1954"
6215,Reseau National Belge 1950,geodetic,"Fundamental point: Lommel (tower). Latitude: 51 deg 13 min 47.334 sec N; Longitude: 5 deg 18 min 49.483 sec E (of Greenwich).",1950,7022,8901,1347,Topographic mapping.,,,EPSG,2003-12-18,2003.361,0,"D_Belge_1950"
6216,Bermuda 1957,geodetic,"Fundamental point: Fort George base. Latitude 32 deg 22 min 44.36 sec N; longitude 64 deg 40 min 58.11 sec W (of Greenwich).",1957,7008,8901,1047,Topographic mapping.,,Various oil industry sources.,EPSG,2003-12-31,2003.362,0,"D_Bermuda_1957"
-6218,Bogota 1975,geodetic,"Fundamental point: Bogota observatory. Latitude: 4 deg 35 min 56.570 sec N; Longitude: 74 deg 4 min 51.300 sec W (of Greenwich).",1975,7022,8901,3229,Topographic mapping.,"Supersedes 1951 adjustment. Superseded by MAGNA-SIRGAS (datum code 6685).","Instituto Geografico Agustin Caduzzi (IGAC) special publication no. 1, 4th edition (1975) ""Geodesia: Resultados Definitvos de Parte de las Redes Geodesicas Establecidas en el Pais"".",EPSG,2005-04-14,2000.20 2005.06,0,"D_Bogota"
+6218,Bogota 1975,geodetic,"Fundamental point: Bogota observatory. Latitude: 4 deg 35 min 56.570 sec N; Longitude: 74 deg 4 min 51.300 sec W (of Greenwich).",1975,7022,8901,3229,Topographic mapping.,"Replaces 1951 adjustment. Replaced by MAGNA-SIRGAS (datum code 6685).","Instituto Geografico Agustin Codazzi (IGAC) special publication no. 1, 4th edition (1975) ""Geodesia: Resultados Definitvos de Parte de las Redes Geodesicas Establecidas en el Pais"".",EPSG,2007-07-02,2000.20 2005.06 2007.060,0,"D_Bogota"
6219,Bukit Rimpah,geodetic,"2deg 00min 40.16sec S 105deg 51min 39.76sec E (of Greenwich).",,7004,8901,1287,Topographic mapping.,,,EPSG,1995-06-02,,0,"D_Bukit_Rimpah"
-6220,Camacupa,geodetic,"Fundamental point: Campo de Aviaçao. Latitude: 12 deg 01 min 19.070 sec South, Longitude = 17 deg 27 min 19.800 sec East of Greenwich",1948,7012,8901,1288,Coastal hydrography.,,"Clifford J. Mugnier, PE&RS journal, March 2001.",EPSG,2004-01-08,2003.361,0,"D_Camacupa"
+6220,Camacupa,geodetic,"Fundamental point: Campo de Aviaçao. Latitude: 12 deg 01 min 09.070 sec South, Longitude = 17 deg 27 min 19.800 sec East of Greenwich",1948,7012,8901,1288,Coastal hydrography.,,"Portuguese Hydrographic Institute and Clifford J. Mugnier, PE&RS journal, March 2001.",EPSG,2006-12-05,2003.361 2006.973,0,"D_Camacupa"
6221,Campo Inchauspe,geodetic,"Fundamental point: Campo Inchauspe. Latitude: 35 deg 58 min 16.56 sec S; Longitude: 62 deg 10 min 12.03 sec W (of Greenwich).",,7022,8901,1033,Topographic mapping.,,"NIMA http://earth-info.nima.mil/",EPSG,2005-09-05,2003.361 2005.46,0,"D_Campo_Inchauspe"
6222,Cape,geodetic,"Fundamental point: Buffelsfontein. Latitude: 33 deg 59 min 32.000 sec S; Longitude: 25 deg 30 min 44.622 sec E (of Greenwich).",,7013,8901,1290,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"Private Communication, Directorate of Surveys and Land Information, Cape Town.",EPSG,1996-10-18,96.25 99.69,0,"D_Cape"
6223,Carthage,geodetic,"Fundamental point: Carthage. Latitude: 40.9464506g = 36 deg 51 min 06.50 sec N; Longitude: 8.8724368g E of Paris = 10 deg 19 min 20.72 sec E of Greenwich.",1925,7011,8901,1236,Topographic mapping.,Fundamental point astronomic coordinates determined in 1878.,,EPSG,2004-01-15,2003.362 2003.05,0,"D_Carthage"
@@ -253,48 +258,48 @@
6229,Egypt 1907,geodetic,"Fundamental point: Station F1 (Venus). Latitude: 30 deg 01 min 42.86 sec N; Longitude: 31 deg 16 min 33.60 sec E (of Greenwich).",1907,7020,8901,1086,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,,EPSG,1995-06-02,,0,"D_Egypt_1907"
6230,European Datum 1950,geodetic,"Fundamental point: Potsdam (Helmert Tower). Latitude: 52 deg 22 min 51.4456 sec N; Longitude: 13 deg 3 min 58.9283 sec E (of Greenwich).",1950,7022,8901,1296,"Topographic mapping, geodetic survey.",,"EuroGeographics; http://crs.bkg.bund.de/crs-eu/",EPSG,2003-12-31,2003.361,0,"D_European_1950"
6231,European Datum 1987,geodetic,"Fundamental point: Potsdam (Helmert Tower). Latitude: 52 deg 22 min 51.4456 sec N; Longitude: 13 deg 3 min 58.9283 sec E (of Greenwich).",1987,7022,8901,1297,Scientific network.,,,EPSG,2003-12-31,2003.362,0,"D_European_1987"
-6232,Fahud,geodetic,"Fundamental point: Station NO68-024 Fahud. Latitude: 22 deg 17 min 31.182 sec N; Longitude: 56 deg 29 min 18.820 sec E (of Greenwich).",,7012,8901,3288,Oil industry mapping.,"Superseded by PSD93 (code 6134).",Petroleum Development Oman.,EPSG,1995-06-02,,0,"D_Fahud"
+6232,Fahud,geodetic,"Fundamental point: Station NO68-024 Fahud. Latitude: 22 deg 17 min 31.182 sec N; Longitude: 56 deg 29 min 18.820 sec E (of Greenwich).",,7012,8901,3288,Oil industry mapping.,"Replaced by PSD93 (code 6134).",Petroleum Development Oman.,EPSG,1995-06-02,,0,"D_Fahud"
6233,Gandajika 1970,geodetic,,1970,7022,8901,1152,Topographic mapping.,,,EPSG,1995-06-02,,1,"D_Gandajika_1970"
6234,Garoua,geodetic,,,7011,8901,1060,Topographic mapping.,"The intent of the Bukavu 1953 conference was to adopt the Clarke 1880 (RGS) ellipsoid (code 7012) but in practice this datum has used the IGN version.",,EPSG,1995-06-02,,1,"D_Garoua"
6235,Guyane Francaise,geodetic,,,7022,8901,1097,Topographic mapping.,,,EPSG,1995-06-02,,1,"D_Guyane_Francaise"
6236,Hu Tzu Shan,geodetic,"Fundamental point: Hu Tzu Shan. Latitude: 23 deg 58 min 32.34 sec N; Longitude: 120 deg 58 min 25.975 sec E (of Greenwich).",,7022,8901,3315,Topographic mapping.,,"NIMA http://earth-info.nima.mil/",EPSG,2005-12-30,2003.362 2005.46 2005.83,0,"D_Hu_Tzu_Shan"
6237,Hungarian Datum 1972,geodetic,"Fundamental point: Szolohegy. Latitude: 47 deg 17 min 32,6156 sec N; Longitude 19 deg 36 min 09.9865 sec E; geoid height 6.56m.",1972,7036,8901,1119,Topographic mapping.,,"http://lazarus.elte.hu/gb/geodez/geod3.htm",EPSG,1996-10-18,96.09,0,"D_Hungarian_1972"
-6238,Indonesian Datum 1974,geodetic,"Fundamental point: Padang. Latitude: 0 deg 56 min 38.414 sec S; Longitude: 100 deg 22 min 8.804 sec E (of Greenwich). Ellipsoidal height 3.190m, gravity-related height 14.0m above mean sea level.",1974,7021,8901,1122,Topographic mapping.,Superseded by DGN95.,Bakosurtanal 1979 paper by Jacob Rais.,EPSG,2006-08-25,2002.151 2006.81,0,"D_Indonesian_1974"
+6238,Indonesian Datum 1974,geodetic,"Fundamental point: Padang. Latitude: 0 deg 56 min 38.414 sec S; Longitude: 100 deg 22 min 8.804 sec E (of Greenwich). Ellipsoidal height 3.190m, gravity-related height 14.0m above mean sea level.",1974,7021,8901,1122,Topographic mapping.,Replaced by DGN95.,Bakosurtanal 1979 paper by Jacob Rais.,EPSG,2006-08-25,2002.151 2006.81,0,"D_Indonesian_1974"
6239,Indian 1954,geodetic,Extension of Kalianpur 1937 over Myanmar and Thailand.,1954,7015,8901,1304,Topographic mapping.,,,EPSG,2003-12-31,2003.361,0,"D_Indian_1954"
6240,Indian 1975,geodetic,"Fundamental point: Khau Sakaerang",1975,7015,8901,1231,Topographic mapping.,,,EPSG,1995-06-02,,0,"D_Indian_1975"
6241,Jamaica 1875,geodetic,"Fundamental point: Fort Charles Flagstaff. Latitude: 17 deg 55 min 55.800 sec N; Longitude: 76 deg 56 min 37.260 sec W (of Greenwich).",1875,7034,8901,3342,Topographic mapping.,,"Survey Department, Government of Jamaica, 1983.",EPSG,2004-09-12,2004.51,0,"D_Jamaica_1875"
6242,Jamaica 1969,geodetic,"Fundamental point: Fort Charles Flagstaff. Latitude: 17 deg 55 min 55.800 sec N; Longitude: 76 deg 56 min 37.260 sec W (of Greenwich).",1969,7008,8901,3342,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"Survey Department, Government of Jamaica, 1983.",EPSG,2004-09-12,2004.51,0,"D_Jamaica_1969"
-6243,Kalianpur 1880,geodetic,"Fundamental point: Kalianpur. Latitude: 24 deg 07 min 11.260 sec N; Longitude: 77 deg 39 min 17.570 sec E (of Greenwich).",1880,7042,8901,1307,Topographic mapping.,"Includes 1916 extension into Burma (Myanmar). Superseded by 1937 adjustment.","G. Bomford; ""The Re-adjustment of the Indian Triangulation""; Survey of India Professional Paper 28; 1939.",EPSG,2004-04-27,97.23 2004.27,0,"D_Kalianpur_1880"
+6243,Kalianpur 1880,geodetic,"Fundamental point: Kalianpur. Latitude: 24 deg 07 min 11.260 sec N; Longitude: 77 deg 39 min 17.570 sec E (of Greenwich).",1880,7042,8901,1307,Topographic mapping.,"Includes 1916 extension into Burma (Myanmar). Replaced by 1937 adjustment.","G. Bomford; ""The Re-adjustment of the Indian Triangulation""; Survey of India Professional Paper 28; 1939.",EPSG,2004-04-27,97.23 2004.27,0,"D_Kalianpur_1880"
6244,Kandawala,geodetic,,,7015,8901,3310,Topographic mapping.,,,EPSG,1995-06-02,,0,"D_Kandawala"
-6245,Kertau 1968,geodetic,"Fundamental point: Kertau. Latitude: 3 deg 27 min 50.710 sec N; Longitude: 102 deg 37 min 24.550 sec E (of Greenwich).",1968,7018,8901,1309,"Geodetic survey, cadastre.","Supersedes MRT48 and earlier adjustments. Adopts metric conversion of 39.370113 inches per metre. Not used for 1969 metrication of RSO grid - see Kertau (RSO) (code 6751).",Defence Geographic Centre.,EPSG,2006-07-31,2006.251,0,"D_Kertau"
+6245,Kertau 1968,geodetic,"Fundamental point: Kertau. Latitude: 3 deg 27 min 50.710 sec N; Longitude: 102 deg 37 min 24.550 sec E (of Greenwich).",1968,7018,8901,1309,"Geodetic survey, cadastre.","Replaces MRT48 and earlier adjustments. Adopts metric conversion of 39.370113 inches per metre. Not used for 1969 metrication of RSO grid - see Kertau (RSO) (code 6751).",Defence Geographic Centre.,EPSG,2006-07-31,2006.251,0,"D_Kertau"
6246,Kuwait Oil Company,geodetic,"Fundamental point: K28. Latitude: 29 deg 03 min 42.348 sec N; Longitude: 48 deg 08 min 42.558 sec E (of Greenwich).",1952,7012,8901,3267,Oil industry mapping.,,,EPSG,2004-06-16,2004.41,0,"D_Kuwait_Oil_Company"
6247,La Canoa,geodetic,"Fundamental point: La Canoa. Latitude: 8 deg 34 min 17.170 sec N; Longitude: 63 deg 51 min 34.880 sec W (of Greenwich).",,7022,8901,3327,"Geodetic survey, topographic mapping, engineering survey.",Origin also adopted for PSAD56.,,EPSG,1995-06-02,,0,"D_La_Canoa"
6248,Provisional South American Datum 1956,geodetic,"Fundamental point: La Canoa. Latitude: 8 deg 34 min 17.170 sec N; Longitude: 63 deg 51 min 34.880 sec W (of Greenwich).",1956,7022,8901,1348,Topographic mapping.,Same origin as La Canoa datum.,,EPSG,1995-06-02,,0,"D_Provisional_S_American_1956"
6249,Lake,geodetic,"Fundamental point: Maracaibo Cathedral. Latitude: 10 deg 38 min 34.678 sec N; Longitude: 71 deg 36 min 20.224 sec W (of Greenwich).",,7022,8901,1312,Oil industry mapping.,,,EPSG,1995-06-02,,0,"D_Lake"
-6250,Leigon,geodetic,"Fundamental point: GCS Station 121, Leigon. Latitude: 5 deg 38 min 52.27 sec N; Longitude: 0 deg 11 min 46.08 sec W (of Greenwich).",,7012,8901,1104,Topographic mapping.,"Superseded Accra datum (code 6168) from 1978. Coordinates at Leigon fundamental point defined as Accra datum values for that point.",Ordnance Survey International,EPSG,1995-06-02,,0,"D_Leigon"
+6250,Leigon,geodetic,"Fundamental point: GCS Station 121, Leigon. Latitude: 5 deg 38 min 52.27 sec N; Longitude: 0 deg 11 min 46.08 sec W (of Greenwich).",,7012,8901,1104,Topographic mapping.,"Replaced Accra datum (code 6168) from 1978. Coordinates at Leigon fundamental point defined as Accra datum values for that point.",Ordnance Survey International,EPSG,1995-06-02,,0,"D_Leigon"
6251,Liberia 1964,geodetic,"Fundamental point: Robertsfield. Latitude: 6 deg 13 min 53.02 sec N; Longitude: 10 deg 21 min 35.44 sec W (of Greenwich).",1964,7012,8901,3270,Topographic mapping.,,"NIMA http://earth-info.nima.mil/",EPSG,2005-09-05,2003.362 2005.46,0,"D_Liberia_1964"
6252,Lome,geodetic,,,7011,8901,1232,Topographic mapping.,,,EPSG,1995-06-02,,0,"D_Lome"
-6253,Luzon 1911,geodetic,"Fundamental point: Balacan. Latitude: 13 deg 33 min 41.000 sec N; Longitude: 121 deg 52 min 03.000 sec E (of Greenwich).",1911,7008,8901,1190,Topographic mapping.,"Superseded by Philippine Reference system of 1992 (datum code 6683).",Coast and Geodetic Survey,EPSG,2004-12-24,2004.73,0,"D_Luzon_1911"
+6253,Luzon 1911,geodetic,"Fundamental point: Balacan. Latitude: 13 deg 33 min 41.000 sec N; Longitude: 121 deg 52 min 03.000 sec E (of Greenwich).",1911,7008,8901,1190,Topographic mapping.,"Replaced by Philippine Reference system of 1992 (datum code 6683).",Coast and Geodetic Survey,EPSG,2004-12-24,2004.73,0,"D_Luzon_1911"
6254,Hito XVIII 1963,geodetic,Chile-Argentina boundary survey.,1963,7022,8901,1303,Geodetic survey.,Used in Tierra del Fuego.,Various oil company records.,EPSG,1995-06-02,,0,"D_Hito_XVIII_1963"
6255,Herat North,geodetic,"Fundamental point: Herat North. Latitude: 34 deg 23 min 09.08 sec N; Longitude: 64 deg 10 min 58.94 sec E (of Greenwich).",,7022,8901,1024,Topographic mapping.,,"NIMA http://earth-info.nima.mil/",EPSG,2005-09-05,2003.362 2005.46,0,"D_Herat_North"
6256,Mahe 1971,geodetic,"Fundamental point: Mahe",1971,7012,8901,1208,Topographic mapping.,,,EPSG,1995-06-02,,0,"D_Mahe_1971"
6257,Makassar,geodetic,"Fundamental point: station P1, Moncongloe. Latitude: 5 deg 08 min 41.42 sec S; long 119 deg 24 min 14.94 sec E of Greenwich.",,7004,8901,1316,Topographic mapping.,,"NIMA http://earth-info.nima.mil/",EPSG,2005-09-05,2003.361 2005.46,0,"D_Makassar"
6258,European Terrestrial Reference System 1989,geodetic,"Fixed to the stable part of the Eurasian continental
plate and consistent with ITRS at the epoch 1989.0.",1989,7019,8901,1298,Geodetic survey.,"The distinction in usage between ETRF89 and ETRS89 is confused: although in principle conceptually different in practice both are used for the realisation.",,EPSG,2003-08-14,97.11 97.55 99.111 2000.72 2003.26,0,"D_ETRS_1989"
-6259,Malongo 1987,geodetic,"Fundamental point: Station Y at Malongo base camp. Latitude: 5 deg 23 min 30.810 sec S; Longitude: 12 deg 12 min 01.590 sec E (of Greenwich).",1987,7022,8901,3180,Oil industry offshore exploration and production from 1987.,"Superseded Mhast (offshore) (code 6705) in 1987. Origin coordinates constrained to those of Mhast (offshore) but other station coordinates differ. References to ""Mhast"" since 1987 often should have stated ""Malongo 1987"".",Chevron Petroleum Technology.,EPSG,2006-01-06,2005.751,0,"D_Malongo_1987"
+6259,Malongo 1987,geodetic,"Fundamental point: Station Y at Malongo base camp. Latitude: 5 deg 23 min 30.810 sec S; Longitude: 12 deg 12 min 01.590 sec E (of Greenwich).",1987,7022,8901,3180,Oil industry offshore exploration and production from 1987.,"Replaced Mhast (offshore) (code 6705) in 1987. Origin coordinates constrained to those of Mhast (offshore) but other station coordinates differ. References to ""Mhast"" since 1987 often should have stated ""Malongo 1987"".",Chevron Petroleum Technology.,EPSG,2006-01-06,2005.751,0,"D_Malongo_1987"
6260,Manoca,geodetic,,,7012,8901,1060,Topographic mapping.,,,EPSG,1995-06-02,,1,"D_Manoca"
6261,Merchich,geodetic,"Fundamental point: Merchich. Latitude: 33 deg 26 min 59.672 sec N; Longitude: 7deg 33 min 27.295sec W (of Greenwich).",1922,7011,8901,3280,Topographic mapping.,,,EPSG,2003-12-31,2003.361,0,"D_Merchich"
6262,Massawa,geodetic,,,7004,8901,1089,Topographic mapping.,,,EPSG,1995-06-02,,0,"D_Massawa"
6263,Minna,geodetic,"Fundamental point: Minna base station L40. Latitude: 9 deg 38 min 08.87 sec N; Longitude: 6 deg 30 min 58.76 sec E (of Greenwich).",,7012,8901,1178,Topographic mapping.,,"NIMA http://earth-info.nima.mil/",EPSG,2005-09-05,2003.361 2005.46,0,"D_Minna"
6264,Mhast,geodetic,,,7022,8901,1318,Coastal hydrography.,,,EPSG,1995-06-02,,1,"D_Mhast"
-6265,Monte Mario,geodetic,"Fundamental point: Monte Mario. Latitude: 41 deg 55 min 25.51 sec N; Longitude: 12 deg 27 min 08.4 sec E (of Greenwich).",1940,7022,8901,3343,Topographic mapping.,"Superseded Genova datum, Bessel 1841 ellipsoid, from 1940.",,EPSG,2003-12-31,2003.36,0,"D_Monte_Mario"
+6265,Monte Mario,geodetic,"Fundamental point: Monte Mario. Latitude: 41 deg 55 min 25.51 sec N; Longitude: 12 deg 27 min 08.4 sec E (of Greenwich).",1940,7022,8901,3343,Topographic mapping.,"Replaced Genova datum, Bessel 1841 ellipsoid, from 1940.",,EPSG,2003-12-31,2003.36,0,"D_Monte_Mario"
6266,"M'poraloko",geodetic,,,7011,8901,1100,Topographic mapping.,,,EPSG,1995-06-02,,0,"D_Mporaloko"
-6267,North American Datum 1927,geodetic,"Fundamental point: Meade's Ranch. Latitude: 39 deg 13 min 26.686 sec N; Longitude: 98 deg 32 min 30.506 sec W (of Greenwich).",1927,7008,8901,1349,Topographic mapping.,"Superseded by North American Datum 1983 (NAD83)",,EPSG,1995-06-02,,0,"D_North_American_1927"
+6267,North American Datum 1927,geodetic,"Fundamental point: Meade's Ranch. Latitude: 39 deg 13 min 26.686 sec N; Longitude: 98 deg 32 min 30.506 sec W (of Greenwich).",1927,7008,8901,1349,Topographic mapping.,"Replaced by North American Datum 1983 (NAD83)",,EPSG,1995-06-02,,0,"D_North_American_1927"
6268,NAD Michigan,geodetic,"Fundamental point: Meade's Ranch. Latitude: 39 deg 13 min 26.686 sec N; Longitude: 98 deg 32 min 30.506 sec W (of Greenwich).",,7009,8901,1391,Topographic mapping.,,,EPSG,1995-06-02,,0,"D_North_American_Michigan"
6269,North American Datum 1983,geodetic,Origin at geocentre.,1986,7019,8901,1350,Topographic mapping.,"Although the 1986 adjustment included connections to Greenland and Mexico, it has not been adopted there.",,EPSG,2006-07-19,2006.464,0,"D_North_American_1983"
-6270,Nahrwan 1967,geodetic,"Fundamental point: Nahrwan south base. Latitude: 33 deg 19 min 10.87 sec N; Longitude: 44 deg 43 min 25.54 sec E (of Greenwich).",1967,7012,8901,1351,Topographic mapping.,"In Iraq, supersedes Nahrwan 1934.",,EPSG,2006-06-02,2006.34,0,"D_Nahrwan_1967"
+6270,Nahrwan 1967,geodetic,"Fundamental point: Nahrwan south base. Latitude: 33 deg 19 min 10.87 sec N; Longitude: 44 deg 43 min 25.54 sec E (of Greenwich).",1967,7012,8901,1351,Topographic mapping.,"In Iraq, replaces Nahrwan 1934.",,EPSG,2006-06-02,2006.34,0,"D_Nahrwan_1967"
6271,Naparima 1972,geodetic,"Fundamental point: Naparima. Latitude: 10 deg 16 min 44.860 sec N; Longitude: 61 deg 27 min 34.620 sec W (of Greenwich).",1972,7022,8901,1322,Topographic mapping.,Naparima 1972 is an extension of the Naparima 1955 network of Trinidad to include Tobago.,Ordnance Survey International.,EPSG,1995-06-02,,0,"D_Naparima_1972"
-6272,New Zealand Geodetic Datum 1949,geodetic,"Fundamental point: Papatahi. Latitude: 41 deg 19 min 8.900 sec S; Longitude: 175 deg 02 min 51.000 sec E (of Greenwich).",1949,7022,8901,3285,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Superseded by New Zealand Geodetic Datum 2000 (code 6167) from March 2000.","Land Information New Zealand. http://www.linz.govt.nz/rcs/linz/pub/web/root/core/SurveySystem/GeodeticInfo/GeodeticDatums/nzgd2000factsheet/index.jsp",EPSG,2004-03-26,2000.702 2004.11,0,"D_New_Zealand_1949"
+6272,New Zealand Geodetic Datum 1949,geodetic,"Fundamental point: Papatahi. Latitude: 41 deg 19 min 8.900 sec S; Longitude: 175 deg 02 min 51.000 sec E (of Greenwich).",1949,7022,8901,3285,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaced by New Zealand Geodetic Datum 2000 (code 6167) from March 2000.","Land Information New Zealand. http://www.linz.govt.nz/rcs/linz/pub/web/root/core/SurveySystem/GeodeticInfo/GeodeticDatums/nzgd2000factsheet/index.jsp",EPSG,2004-03-26,2000.702 2004.11,0,"D_New_Zealand_1949"
6273,NGO 1948,geodetic,"Fundamental point: Oslo observatory. Latitude: 59 deg 54 min 43.7 sec N; Longitude: 10 deg 43 min 22.5 sec E (of Greenwich).",1948,7005,8901,1352,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"EuroGeographics; http://crs.bkg.bund.de/crs-eu/",EPSG,2004-01-05,2003.362,0,"D_NGO_1948"
6274,Datum 73,geodetic,"Fundamental point: TF4, Melrica. Latitude: 39 deg 41 min 37.30 sec N; Longitude: 8 deg 07 min 53.31 sec W (of Greenwich).",1964,7022,8901,1294,Topographic mapping.,,"Instituto Geografico e Cadastral; Lisbon",EPSG,1995-06-02,,0,"D_Datum_73"
6275,Nouvelle Triangulation Francaise,geodetic,"Fundamental point: Pantheon. Latitude: 48 deg 50 min 46.522 sec N; Longitude: 2 deg 20 min 48.667 sec E (of Greenwich).",1895,7011,8901,1326,Topographic mapping.,,,EPSG,2004-01-07,2003.361,0,"D_NTF"
@@ -310,7 +315,7 @@
6285,Qatar 1974,geodetic,"Fundamental point: Station G3",1974,7022,8901,1346,Topographic mapping.,,,EPSG,2001-08-28,2001.27,0,"D_Qatar"
6286,Qatar 1948,geodetic,"Fundamental point: Sokey 0 M. Latitude: 25 deg 22 min 56.500 sec N; Longitude: 50 deg 45 min 41.000 sec E (of Greenwich).",1948,7020,8901,1346,Topographic mapping.,,,EPSG,1995-06-02,,0,"D_Qatar_1948"
6287,Qornoq,geodetic,,1927,7022,8901,1107,Topographic mapping.,,,EPSG,1995-06-02,,1,"D_Qornoq"
-6288,Loma Quintana,geodetic,"Fundamental point: Loma Quintana",,7022,8901,1313,Topographic mapping.,"Superseded by La Canoa (code 6247).",,EPSG,1995-06-02,,0,"D_Loma_Quintana"
+6288,Loma Quintana,geodetic,"Fundamental point: Loma Quintana",,7022,8901,1313,Topographic mapping.,"Replaced by La Canoa (code 6247).",,EPSG,1995-06-02,,0,"D_Loma_Quintana"
6289,Amersfoort,geodetic,"Fundamental point: Amersfoort. Latitude: 52 deg 09 min 22.178 sec N; Longitude: 5 deg 23 min 15.478 sec E (of Greenwich).",,7004,8901,1275,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"http://www.rdnap.nl/",EPSG,2005-09-29,2000.56 2003.361 2005.46,0,"D_Amersfoort"
6291,South American Datum 1969,geodetic,,1969,7036,8901,1358,Topographic mapping.,"SAD69 uses GRS67 ellipsoid with 1/f to exactly 2 decimal places. Precision of ellipsoid entry increased from 2 to 5 dp with change id 97.252. Error introduced if not using the truncated precision is 0 to 31mm.",,EPSG,1996-10-18,96.09 97.252,1,"D_South_American_1969"
6292,Sapper Hill 1943,geodetic,,1943,7022,8901,3247,Topographic mapping.,,,EPSG,1995-06-02,,0,"D_Sapper_Hill_1943"
@@ -320,26 +325,26 @@
6296,Sudan,geodetic,,,7011,8901,1361,Topographic mapping.,,,EPSG,1995-06-02,,1,"D_Sudan"
6297,Tananarive 1925,geodetic,"Fundamental point: Tananarive observatory. Latitude: 18 deg 55 min 02.10 sec S; Longitude: 47 deg 33 min 06.75 sec E (of Greenwich).",2025,7022,8901,3273,Topographic mapping.,,IGN Paris,EPSG,2003-12-31,2003.361,0,"D_Tananarive_1925"
6298,Timbalai 1948,geodetic,"Fundamental point: Station P85 at Timbalai. Latitude: 5 deg 17 min 3.548 sec N; Longitude: 115 deg 10 min 56.409 sec E (of Greenwich).",1948,7016,8901,1362,Topographic mapping.,"In 1968, the original adjustment was densified in Sarawak and extended to Sabah.",Defence Geographic Centre.,EPSG,2006-07-24,2006.252,0,"D_Timbalai_1948"
-6299,TM65,geodetic,Adjusted to best mean fit 12 stations of the OSNI 1952 primary adjustment.,1965,7002,8901,1305,Topographic mapping.,"Differences between OSNI 1952 and TM65 at these stations are RMS 0.25m east, 0.23m north, maximum vector 0.57m. TM65 superseded by and not to be confused with Geodetic Datum of 1965 alias 1975 Mapping Adjustment or TM75 (datum code 6300).","""The Irish Grid - A Description of the Co-ordinate Reference System"" published by Ordnance Survey of Ireland, Dublin and Ordnance Survey of Northern Ireland, Belfast.",EPSG,2003-06-27,2002.621,0,"D_TM65"
+6299,TM65,geodetic,Adjusted to best mean fit 12 stations of the OSNI 1952 primary adjustment.,1965,7002,8901,1305,Topographic mapping.,"Differences between OSNI 1952 and TM65 at these stations are RMS 0.25m east, 0.23m north, maximum vector 0.57m. TM65 replaced by and not to be confused with Geodetic Datum of 1965 alias 1975 Mapping Adjustment or TM75 (datum code 6300).","""The Irish Grid - A Description of the Co-ordinate Reference System"" published by Ordnance Survey of Ireland, Dublin and Ordnance Survey of Northern Ireland, Belfast.",EPSG,2003-06-27,2002.621,0,"D_TM65"
6300,Geodetic Datum of 1965,geodetic,Adjusted to best mean fit 9 stations of the OSNI 1952 primary adjustment in Northern Ireland plus the 1965 values of 3 stations in the Republic of Ireland.,1975,7002,8901,1305,"Geodetic survey, topographic mapping and engineering survey.","Differences from the 1965 adjustment (datum code 6299) are: average difference in Eastings 0.092m; average difference in Northings 0.108m; maximum vector difference 0.548m.","""The Irish Grid - A Description of the Co-ordinate Reference System"" published by Ordnance Survey of Ireland, Dublin and Ordnance Survey of Northern Ireland, Belfast.",EPSG,2003-06-27,2002.621,0,"D_TM75"
-6301,Tokyo,geodetic,"Fundamental point: Nikon-Keido-Genten. Latitude: 35 deg 39 min 17.5148 sec N; Longitude: 139 deg 44 min 40.5020 sec E (of Greenwich).",,7004,8901,1364,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Superseded by Japanese Geodetic Datum 2000 (code 6611).","Geographic Survey Institute; Japan; Bulletin 40 (March 1994). Also http://vldb.gsi.go.jp/sokuchi/datum/tokyodatum.html",EPSG,2002-06-22,98.46 2002.08,0,"D_Tokyo"
+6301,Tokyo,geodetic,"Fundamental point: Nikon-Keido-Genten. Latitude: 35 deg 39 min 17.5148 sec N; Longitude: 139 deg 44 min 40.5020 sec E (of Greenwich).",,7004,8901,1364,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaced by Japanese Geodetic Datum 2000 (code 6611).","Geographic Survey Institute; Japan; Bulletin 40 (March 1994). Also http://vldb.gsi.go.jp/sokuchi/datum/tokyodatum.html",EPSG,2002-06-22,98.46 2002.08,0,"D_Tokyo"
6302,Trinidad 1903,geodetic,"Station 00, Harbour Master's Flagstaff, Port of Spain.
Trinidad 1903 / Trinidad Grid coordinates (Clarke's links): 333604.30 E, 436366.91 N (Latitude: 10 deg 38 min 39.01 sec N, Longitude: 61 deg 30 min 38.00 sec W of Greenwich)",1903,7007,8901,1339,Topographic mapping.,,"""Land Surveyor's Handbook"", 1935, published under the direction of JW MacGillivray, Surveyor General, Land & Survey's Department, Trinidad & Tobago.",EPSG,2004-03-01,2003.362 2004.13,0,"D_Trinidad_1903"
6303,Trucial Coast 1948,geodetic,"Fundamental point: TC1. Latitude: 25 deg 23 min 50.190 sec N; Longitude: 55 deg 26 min 43.950 sec E (of Greenwich).",1948,7020,8901,1363,Oil industry mapping.,,,EPSG,1995-06-02,,0,"D_Trucial_Coast_1948"
-6304,Voirol 1875,geodetic,"Fundamental point: Voirol. Latitude: 36 deg 45 min 07.927 sec N; Longitude: 3 deg 02 min 49.435 sec E of Greenwich. Uses RGS (and old IGN) value of 2 deg 20 min 13.95 sec for Greenwich-Paris meridian difference.",1875,7011,8901,1365,Topographic mapping.,"Superseded by Voirol 1879 (code 6671).",IGN Paris,EPSG,2004-01-07,2003.361,0,"D_Voirol_1875"
+6304,Voirol 1875,geodetic,"Fundamental point: Voirol. Latitude: 36 deg 45 min 07.927 sec N; Longitude: 3 deg 02 min 49.435 sec E of Greenwich. Uses RGS (and old IGN) value of 2 deg 20 min 13.95 sec for Greenwich-Paris meridian difference.",1875,7011,8901,1365,Topographic mapping.,"Replaced by Voirol 1879 (code 6671).",IGN Paris,EPSG,2004-01-07,2003.361,0,"D_Voirol_1875"
6306,Bern 1938,geodetic,"Fundamental point: Old Bern observatory. Latitude: 46 deg 57 min 7.890 sec N; Longitude: 7 deg 26 min 22.335 sec E (of Greenwich).",1938,7004,8901,1286,Topographic mapping.,"This redetermination of the coordinates of fundamental point is used for scientific purposes and as the graticule overprinted on topographic maps constructed on the CH1903 / LV03 projected CS (code 21781).","""Die Projektionen der schweizerischen Plan- und Kartenwerke""; J. Bolliger 1967",EPSG,1995-06-02,,0,"D_Bern_1938"
6307,Nord Sahara 1959,geodetic,"Coordinates of primary network readjusted on ED50 datum and then transformed conformally to Clarke 1880 (RGS) ellipsoid.",1959,7012,8901,1365,Topographic mapping.,"Sometimes incorrectly referred to as Voirol Unifie 1960. Voirol Unifie 1960 is NOT a datum: it is two projected coordinate systems based on Nord Sahara 1959. See coordinate system codes 30791 and 30792.","""Le System Geodesique Nord-Sahara""; IGN Paris",EPSG,2006-01-16,99.62 2003.361 2005.88,0,"D_Nord_Sahara_1959"
-6308,Stockholm 1938,geodetic,"Fundamental point: Stockholm observatory",1938,7004,8901,3313,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Superseded by RT90 adjustment (datum code 6124)",,EPSG,1996-04-12,,0,"D_Stockholm_1938"
+6308,Stockholm 1938,geodetic,"Fundamental point: Stockholm observatory",1938,7004,8901,3313,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaced by RT90 adjustment (datum code 6124)",,EPSG,1996-04-12,,0,"D_Stockholm_1938"
6309,Yacare,geodetic,"Fundamental point: Yacare. Latitude: 30 deg 35 min 53.68 sec S; Longitude: 57 deg 25 min 01.30 sec W of Greenwich.",,7022,8901,1247,Topographic mapping.,,"NIMA http://earth-info.nima.mil/",EPSG,2005-09-05,2003.362 2005.46,0,"D_Yacare"
6310,Yoff,geodetic,"Fundamental point: Yoff. Latitude: 14 deg 44 min 41.62 sec N; Longitude: 17 deg 29 min 07.02 sec W of Greenwich.",,7011,8901,1207,Topographic mapping.,,,EPSG,2003-12-31,2003.362,0,"D_Yoff"
6311,Zanderij,geodetic,,,7022,8901,1222,Topographic mapping.,,,EPSG,1995-06-02,,0,"D_Zanderij"
-6312,Militar-Geographische Institut,geodetic,"Fundamental point: Hermannskogel. Latitude: 48 deg 16 min 15.29 sec N; Longitude: 16 deg 17 min 41.06 sec E (of Greenwich).",1901,7004,8901,1321,Topographic mapping.,"Croatia is planning to define a new modern datum to supersede HR1901 (info from EuroGeographics; http://crs.ifag.de/).","Bundesamt fur Eich- und Vermessungswesen; Wien",EPSG,1995-06-02,,0,"D_MGI"
+6312,Militar-Geographische Institut,geodetic,"Fundamental point: Hermannskogel. Latitude: 48 deg 16 min 15.29 sec N; Longitude: 16 deg 17 min 41.06 sec E (of Greenwich).",1901,7004,8901,1321,Topographic mapping.,"Croatia is planning to define a new modern datum to replace HR1901 (info from EuroGeographics; http://crs.ifag.de/).","Bundesamt fur Eich- und Vermessungswesen; Wien",EPSG,1995-06-02,,0,"D_MGI"
6313,Reseau National Belge 1972,geodetic,"Fundamental point: Uccle observatory. Latitude: 50 deg 47 min 57.704 sec N; Longitude: 4 deg 21 min 24.983 sec E (of Greenwich).",1972,7022,8901,1347,Topographic mapping.,,,EPSG,1995-06-02,,0,"D_Belge_1972"
6314,Deutsches Hauptdreiecksnetz,geodetic,"Fundamental point: Rauenberg. Latitude: 52 deg 27 min 12.021 sec N; Longitude: 13 deg 22 min 04.928 sec E (of Greenwich). This station was destroyed in 1910 and the station at Potsdam substituted as the fundamental point.",,7004,8901,2326,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"BKG via EuroGeographics. http://crs.bkg.bund.de",EPSG,2006-06-12,2001.511 2006.41,0,"D_Deutsches_Hauptdreiecksnetz"
6315,Conakry 1905,geodetic,"Fundamental point: Conakry. Latitude: 10.573766g N; Longitude: 17.833682g W (of Paris).",1905,7011,8901,3257,Topographic mapping.,,,EPSG,1995-06-02,,0,"D_Conakry_1905"
-6316,Dealul Piscului 1933,geodetic,"Fundamental point: latitude 44 deg 24 min 33.9606 sec N; longitude 26 deg 06 min 44.8772 sec E (of Greenwich).",1933,7022,8901,3295,Topographic mapping.,"Superseded by 1970 adjustment (datum code 6317)",Institute for Geodesy Photogrametry and Land Management,EPSG,1996-04-12,,0,"D_Dealul_Piscului_1933"
-6317,Dealul Piscului 1970,geodetic,"Fundamental point: latitude 44 deg 24 min 23.7709 sec N; longitude 26deg 06 min 44.1265 sec E (of Greenwich).",1970,7024,8901,1197,Topographic mapping.,"Supersedes 1933 adjustment (datum code 6316)",Institute for Geodesy Photogrametry and Land Management,EPSG,1996-04-12,,0,"D_Dealul_Piscului_1970"
-6318,National Geodetic Network,geodetic,,1993,7030,8901,3267,Geodetic survey.,Supersedes 1984 adjustment which used the WGS72 ellipsoid.,,EPSG,2004-06-16,2004.41,0,"D_NGN"
+6316,Dealul Piscului 1933,geodetic,"Fundamental point: latitude 44 deg 24 min 33.9606 sec N; longitude 26 deg 06 min 44.8772 sec E (of Greenwich).",1933,7022,8901,3295,Topographic mapping.,"Replaced by 1970 adjustment (datum code 6317)",Institute for Geodesy Photogrametry and Land Management,EPSG,1996-04-12,,0,"D_Dealul_Piscului_1933"
+6317,Dealul Piscului 1970,geodetic,"Fundamental point: latitude 44 deg 24 min 23.7709 sec N; longitude 26deg 06 min 44.1265 sec E (of Greenwich).",1970,7024,8901,1197,Topographic mapping.,"Replaces 1933 adjustment (datum code 6316)",Institute for Geodesy Photogrametry and Land Management,EPSG,1996-04-12,,0,"D_Dealul_Piscului_1970"
+6318,National Geodetic Network,geodetic,,1993,7030,8901,3267,Geodetic survey.,Replaces 1984 adjustment which used the WGS72 ellipsoid.,,EPSG,2004-06-16,2004.41,0,"D_NGN"
6319,Kuwait Utility,geodetic,,,7019,8901,1310,"Cadastre, engineering survey.",,,EPSG,1996-04-12,,0,"D_Kuwait_Utility"
6322,World Geodetic System 1972,geodetic,Developed from a worldwide distribution of terrestrial and geodetic satellite observations and defined through a set of station coordinates.,1972,7043,8901,1262,Satellite navigation.,Used by GPS before 1987. For Transit satellite positioning see also WGS 72BE.,"NIMA http://earth-info.nima.mil/",EPSG,2006-08-24,99.03 2003.362 2005.46 2006.82,0,"D_WGS_1972"
6324,WGS 72 Transit Broadcast Ephemeris,geodetic,,1972,7043,8901,1262,Satellite navigation.,Alleged datum for use with Transit broadcast ephemeris prior to 1989. Relationship to WGS 72 has changed over time.,,EPSG,2006-08-24,99.03 2006.82,0,"D_WGS_1972_BE"
@@ -356,25 +361,25 @@
6608,"North American Datum 1927 (1976)",geodetic,"Fundamental point: Meade's Ranch. Latitude: 39 deg 13 min 26.686 sec N; Longitude: 98 deg 32 min 30.506 sec W (of Greenwich).",1976,7008,8901,1367,"Geodetic survey, cadastre, topographic mapping, engineering survey.","NAD27(76) used in Ontario for all maps at scale 1/20 000 and larger; elsewhere in Canada for selected purposes.",Geodetic Survey of Canada.,EPSG,1999-05-12,,0,"D_NAD_1927_Definition_1976"
6609,"North American Datum 1927 (CGQ77)",geodetic,"Fundamental point: Meade's Ranch. Latitude: 39 deg 13 min 26.686 sec N; Longitude: 98 deg 32 min 30.506 sec W (of Greenwich).",1977,7008,8901,1368,"Geodetic survey, cadastre, topographic mapping, engineering survey.","NAD27 (CGQ77) used in Quebec for all maps at scale 1/20 000 and larger; generally for maps issued by the Quebec cartography office whose reference system is CGQ77.","Geodetic Service of Quebec. Contact alain.bernard at mrn.gouv.qc.ca",EPSG,1999-05-12,,0,"D_NAD_1927_CGQ77"
6610,Xian 1980,geodetic,,1980,7049,8901,3228,"Geodetic survey, topographic and engineering survey.",,BP,EPSG,2002-02-12,,0,"D_Xian_1980"
-6611,Hong Kong 1980,geodetic,"Fundamental point: Trig ""Zero"", 38.4 feet south along the transit circle of the Kowloon Observatory. Latitude 22deg 18min 12.82sec North, longitude 114deg 10min 18.75sec East.",1980,7022,8901,1118,"Geodetic survey, topgraphic and engineering survey, cadastre.","Supersedes Hong Kong 1963 and Hong Kong 1963(67).","Survey and Mapping Office, Lands Department. http://www.info.gov.hk/landsd/mapping/tindex.htm",EPSG,2006-02-06,2005.26,0,"D_Hong_Kong_1980"
-6612,Japanese Geodetic Datum 2000,geodetic,ITRF94 at epoch 1997.0,2000,7019,8901,1129,"Geodetic survey, topographic and engineering survey.","Instigated under amendment to the Japanese Surveying Law with effect from April 2002. Supersedes Tokyo datum (code 6301).","Japanese Survey Federation and Geographical Survey Institute http://www.gsi.go.jp/ENGLISH/RESEARCH/BULLETIN/vol-45/45abst1.htm",EPSG,2002-06-22,,0,"D_JGD_2000"
+6611,Hong Kong 1980,geodetic,"Fundamental point: Trig ""Zero"", 38.4 feet south along the transit circle of the Kowloon Observatory. Latitude 22deg 18min 12.82sec North, longitude 114deg 10min 18.75sec East.",1980,7022,8901,1118,"Geodetic survey, topgraphic and engineering survey, cadastre.","Replaces Hong Kong 1963 and Hong Kong 1963(67).","Survey and Mapping Office, Lands Department. http://www.info.gov.hk/landsd/mapping/tindex.htm",EPSG,2006-02-06,2005.26,0,"D_Hong_Kong_1980"
+6612,Japanese Geodetic Datum 2000,geodetic,ITRF94 at epoch 1997.0,2000,7019,8901,1129,"Geodetic survey, topographic and engineering survey.","Instigated under amendment to the Japanese Surveying Law with effect from April 2002. Replaces Tokyo datum (code 6301).","Japanese Survey Federation and Geographical Survey Institute http://www.gsi.go.jp/ENGLISH/RESEARCH/BULLETIN/vol-45/45abst1.htm",EPSG,2002-06-22,,0,"D_JGD_2000"
6613,Gunung Segara,geodetic,"Station P5 (Gunung Segara). Latitude 0deg 32min 12.83sec S, longitude 117deg 08min 48.47sec E (of Greenwich).",,7004,8901,1360,Topographic mapping.,,TotalFinaElf.,EPSG,2002-06-22,,0,"D_Gunung_Segara"
6614,Qatar National Datum 1995,geodetic,Defined by transformation from WGS 84 - see coordinate operation code 1840.,1995,7022,8901,1346,Topographic mapping.,,Qatar Centre for Geographic Information.,EPSG,2002-06-28,,0,"D_QND_1995"
-6615,Porto Santo 1936,geodetic,SE Base on Porto Santo island.,1936,7022,8901,1314,Topographic mapping.,"Superseded by 1995 adjustment (datum code 6663). For Selvagens see Selvagem Grande (code 6616).","Instituto Geografico e Cadastral Lisbon http://www.igeo.pt",EPSG,2003-08-14,2003.231 2003.232,0,"D_Porto_Santo_1936"
+6615,Porto Santo 1936,geodetic,SE Base on Porto Santo island.,1936,7022,8901,1314,Topographic mapping.,"Replaced by 1995 adjustment (datum code 6663). For Selvagens see Selvagem Grande (code 6616).","Instituto Geografico e Cadastral Lisbon http://www.igeo.pt",EPSG,2003-08-14,2003.231 2003.232,0,"D_Porto_Santo_1936"
6616,Selvagem Grande,geodetic,,,7022,8901,2779,Topographic mapping.,,"Instituto Geografico e Cadastral Lisbon http://www.igeo.pt",EPSG,2003-08-14,2003.232,0,
6618,South American Datum 1969,geodetic,"Fundamental point: Chua. Geodetic latitude: 19 deg 45 min 41.6527 sec S; geodetic longitude: 48 deg 06 min 04.0639 sec W (of Greenwich). (Astronomic coordinates: Latitude 19 deg 45 min 41.34 +/- 0.05 sec S; Longitude 48 deg 06 min 07.80 +/- 0.08 sec W).",1969,7050,8901,1358,Topographic mapping.,"SAD69 uses GRS 1967 ellipsoid but with 1/f to exactly 2 decimal places.",DMA 1974.,EPSG,2004-01-09,2003.362,0,"D_South_American_1969"
6619,SWEREF99,geodetic,Densification of ETRS89.,1982,7019,8901,1225,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"National Land Survey of Sweden http://www.lantmateriet.se",EPSG,2002-09-19,,0,"D_SWEREF99"
6620,Point 58,geodetic,"Fundamental point: Point 58. Latitude: 3 deg 58 min 37.040 sec N; Longitude: 12 deg 52 min 44.045 sec E (of Greenwich).",1969,7012,8901,2790,Geodetic survey,Used as the basis for computation of the 12th Parallel traverse conducted 1966-70 from Senegal to Chad and connecting to the Adindan triangulation in Sudan.,IGN Paris.,EPSG,2002-09-19,,0,"D_Point_58"
-6621,Fort Marigot,geodetic,,,7022,8901,2828,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Superseded by RRAF 1991 (datum code 6640).",IGN Paris.,EPSG,2002-11-29,,0,"D_Fort_Marigot"
-6622,Guadeloupe 1948,geodetic,,1948,7022,8901,2829,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Superseded by RRAF 1991 (datum code 6640).",IGN Paris.,EPSG,2004-10-14,2004.561,0,"D_Sainte_Anne"
-6623,Centre Spatial Guyanais 1967,geodetic,"Fundamental point: Kourou-Diane. Latitude: 5 deg 15 min 53.699 sec N; Longitude: 52 deg 48 min 09.149 sec W (of Greenwich).",1967,7022,8901,3105,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Superseded by RGFG95 (code 6624).",IGN Paris.,EPSG,2005-04-24,2004.562,0,"D_CSG_1967"
-6624,Reseau Geodesique Francais Guyane 1995,geodetic,ITRF93 at epoch 1995.0,1995,7019,8901,1097,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Supersedes CSG67 (datum code 6623).",IGN Paris.,EPSG,2002-11-29,,0,"D_RGFG_1995"
-6625,Martinique 1938,geodetic,"Fundamental point: Fort Desaix. Latitude: 14 deg 36 min 54.090 sec N; Longitude: 61 deg 04 min 04.030 sec W (of Greenwich).",1938,7022,8901,3276,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Superseded by RRAF 1991 (datum code 6640).",IGN Paris.,EPSG,2004-10-14,2004.561,0,"D_Fort_Desaix"
-6626,Reunion 1947,geodetic,"Fundamental point: Piton des Neiges (Borne). Latitude: 21 deg 05 min 13.119 sec S; Longitude: 55 deg 29 min 09.193 sec E (of Greenwich).",1947,7022,8901,3337,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Superseded by RGR92 (datum code 6627).",IGN Paris.,EPSG,2004-10-14,2004.561,0,"D_Reunion_1947"
-6627,Reseau Geodesique de la Reunion 1992,geodetic,ITRF91 at epoch 1993.0,1992,7019,8901,1196,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Supersedes Piton des Neiges (code 6626).",IGN Paris.,EPSG,2006-08-18,2006.77,0,"D_RGR_1992"
-6628,Tahiti 52,geodetic,"Fundamental point: Tahiti North Base. Latitude: 17 deg 38 min 10.0 sec S; Longitude: 149 deg 36 min 57.8 sec W (of Greenwich).",1952,7022,8901,2811,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Superseded by Tahiti 79 (datum code 6690) in Tahiti and Moorea 87 (code 6691) in Moorea.","Gouvernement de la Polynésie Française, Service de l'Urbanisme, Section topographie.",EPSG,2002-11-29,2005.38,0,"D_Tahiti_1952"
-6629,Tahaa 54,geodetic,"Fundamental point: Tahaa East Base. Latitude: 16 deg 33 min 20.97 sec S; Longitude: 151 deg 29 min 06.25 sec W (of Greenwich).",1954,7022,8901,2812,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Superseded by RGPF (datum code 6687).","Gouvernement de la Polynésie Française, Service de l'Urbanisme, Section topographie.",EPSG,2005-08-12,2005.38,0,"D_Tahaa_1954"
-6630,IGN72 Nuku Hiva,geodetic,"Fundamental point: Taiohae. Latitude: 8 deg 55 min 03.97 sec S; Longitude: 140 deg 05 min 36.24 sec W (of Greenwich).",1972,7022,8901,3129,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Superseded by RGPF (datum code 6687).","Gouvernement de la Polynésie Française, Service de l'Urbanisme, Section topographie.",EPSG,2005-08-12,2005.38,0,"D_IGN72_Nuku_Hiva"
+6621,Fort Marigot,geodetic,,,7022,8901,2828,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaced by RRAF 1991 (datum code 6640).",IGN Paris.,EPSG,2002-11-29,,0,"D_Fort_Marigot"
+6622,Guadeloupe 1948,geodetic,,1948,7022,8901,2829,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaced by RRAF 1991 (datum code 6640).",IGN Paris.,EPSG,2004-10-14,2004.561,0,"D_Sainte_Anne"
+6623,Centre Spatial Guyanais 1967,geodetic,"Fundamental point: Kourou-Diane. Latitude: 5 deg 15 min 53.699 sec N; Longitude: 52 deg 48 min 09.149 sec W (of Greenwich).",1967,7022,8901,3105,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaced by RGFG95 (code 6624).",IGN Paris.,EPSG,2005-04-24,2004.562,0,"D_CSG_1967"
+6624,Reseau Geodesique Francais Guyane 1995,geodetic,ITRF93 at epoch 1995.0,1995,7019,8901,1097,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaces CSG67 (datum code 6623).",IGN Paris.,EPSG,2002-11-29,,0,"D_RGFG_1995"
+6625,Martinique 1938,geodetic,"Fundamental point: Fort Desaix. Latitude: 14 deg 36 min 54.090 sec N; Longitude: 61 deg 04 min 04.030 sec W (of Greenwich).",1938,7022,8901,3276,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaced by RRAF 1991 (datum code 6640).",IGN Paris.,EPSG,2004-10-14,2004.561,0,"D_Fort_Desaix"
+6626,Reunion 1947,geodetic,"Fundamental point: Piton des Neiges (Borne). Latitude: 21 deg 05 min 13.119 sec S; Longitude: 55 deg 29 min 09.193 sec E (of Greenwich).",1947,7022,8901,3337,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaced by RGR92 (datum code 6627).",IGN Paris.,EPSG,2004-10-14,2004.561,0,"D_Reunion_1947"
+6627,Reseau Geodesique de la Reunion 1992,geodetic,ITRF91 at epoch 1993.0,1992,7019,8901,1196,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaces Piton des Neiges (code 6626).",IGN Paris.,EPSG,2006-08-18,2006.77,0,"D_RGR_1992"
+6628,Tahiti 52,geodetic,"Fundamental point: Tahiti North Base. Latitude: 17 deg 38 min 10.0 sec S; Longitude: 149 deg 36 min 57.8 sec W (of Greenwich).",1952,7022,8901,2811,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaced by Tahiti 79 (datum code 6690) in Tahiti and Moorea 87 (code 6691) in Moorea.","Gouvernement de la Polynésie Française, Service de l'Urbanisme, Section topographie.",EPSG,2002-11-29,2005.38,0,"D_Tahiti_1952"
+6629,Tahaa 54,geodetic,"Fundamental point: Tahaa East Base. Latitude: 16 deg 33 min 20.97 sec S; Longitude: 151 deg 29 min 06.25 sec W (of Greenwich).",1954,7022,8901,2812,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaced by RGPF (datum code 6687).","Gouvernement de la Polynésie Française, Service de l'Urbanisme, Section topographie.",EPSG,2005-08-12,2005.38,0,"D_Tahaa_1954"
+6630,IGN72 Nuku Hiva,geodetic,"Fundamental point: Taiohae. Latitude: 8 deg 55 min 03.97 sec S; Longitude: 140 deg 05 min 36.24 sec W (of Greenwich).",1972,7022,8901,3129,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaced by RGPF (datum code 6687).","Gouvernement de la Polynésie Française, Service de l'Urbanisme, Section topographie.",EPSG,2005-08-12,2005.38,0,"D_IGN72_Nuku_Hiva"
6631,K0 1949,geodetic,,1949,7022,8901,2816,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,IGN Paris.,EPSG,2002-11-29,,1,"D_K0_1949"
6632,Combani 1950,geodetic,,1950,7022,8901,3340,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,IGN Paris.,EPSG,2002-11-29,,0,"D_Combani_1950"
6633,IGN56 Lifou,geodetic,South end of the Goume base.,1956,7022,8901,2814,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"Service Topographique de la Nouvelle Caledonie, Direction des Infrastructures, de la Topografie et des Transports Terrestres. www.dittt.gouv.nc",EPSG,2006-07-21,2006.62,0,"D_IGN56_Lifou"
@@ -384,73 +389,73 @@
6637,Pointe Geologie Perroud 1950,geodetic,"Fundamental point: Astro station G.0 on Pointe Geologie. Latitude: 66 deg 39 min 30 sec S; Longitude: 140 deg 01 min 00 sec E (of Greenwich).",1950,7022,8901,2818,"Geodetic survey, topographic mapping.",,IGN Paris.,EPSG,2002-11-29,,0,"D_Pointe_Geologie_Perroud_1950"
6638,Saint Pierre et Miquelon 1950,geodetic,,1950,7008,8901,1220,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,IGN Paris.,EPSG,2006-02-03,2006.06,0,"D_Saint_Pierre_et_Miquelon_1950"
6639,MOP78,geodetic,,1978,7022,8901,2815,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,IGN Paris.,EPSG,2002-11-29,,0,"D_MOP78"
-6640,Reseau de Reference des Antilles Francaises 1991,geodetic,WGS 84 coordinates of a single station determined during the 1988 Tango mission.,1991,7030,8901,2824,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Supersedes Fort Marigot and Sainte Anne (datum codes 6621-22) in Guadeloupe and Fort Desaix (datum code 6625) in Martinique.",IGN Paris.,EPSG,2004-03-26,2004.20,0,"D_RRAF_1991"
+6640,Reseau de Reference des Antilles Francaises 1991,geodetic,WGS 84 coordinates of a single station determined during the 1988 Tango mission.,1991,7030,8901,2824,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaces Fort Marigot and Sainte Anne (datum codes 6621-22) in Guadeloupe and Fort Desaix (datum code 6625) in Martinique.",IGN Paris.,EPSG,2004-03-26,2004.20,0,"D_RRAF_1991"
6641,IGN53 Mare,geodetic,South-east end of the La Roche base.,1953,7022,8901,2819,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"Service Topographique de la Nouvelle Caledonie, Direction des Infrastructures, de la Topografie et des Transports Terrestres. www.dittt.gouv.nc",EPSG,2006-07-21,2006.62,0,"D_IGN53_Mare"
6642,ST84 Ile des Pins,geodetic,Pic Nga,1984,7022,8901,2820,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"Service Topographique de la Nouvelle Caledonie, Direction des Infrastructures, de la Topografie et des Transports Terrestres. www.dittt.gouv.nc",EPSG,2006-07-21,2006.62,0,"D_ST84_Ile_des_Pins"
6643,ST71 Belep,geodetic,,1971,7022,8901,2821,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,Service Topographique de la Nouvelle Caledonie.,EPSG,2002-11-29,,0,"D_ST71_Belep"
6644,NEA74 Noumea,geodetic,Noumea old signal station.,1974,7022,8901,2823,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"Service Topographique de la Nouvelle Caledonie, Direction des Infrastructures, de la Topografie et des Transports Terrestres. www.dittt.gouv.nc",EPSG,2006-07-21,2006.62,0,"D_NEA74_Noumea"
6645,Reseau Geodesique Nouvelle Caledonie 1991,geodetic,ITRF90 at epoch 1989.0,1989,7022,8901,1174,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,Service Topographique de la Nouvelle Caledonie.,EPSG,2002-11-29,,1,"D_RGNC_1991"
6646,Grand Comoros,geodetic,"Fundamental point: M'Tsaoueni. Latitude: 11 deg 28 min 32.200 sec S; Longitude: 43 deg 15 min 42.315 sec E (of Greenwich).",,7022,8901,2807,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,IGN Paris.,EPSG,2002-11-29,,0,"D_Grand_Comoros"
-6647,IERS Terrestrial Reference Frame 1988,geodetic,"Origin at geocentre, orientated to the BIH Terrestrial System at epoch 1984.0. Datum defined by a set of 3-dimensional Cartesian station coordinates (SCS).",1988,7019,8901,1262,Geodesy.,"Realisation of the IERS Terrestrial Reference System (ITRS) at epoch 1988.0. Superseded by ITRF89 (code 6648).","International Earth Rotation Service (IERS) Annual Report for 1988. Also IGN Paris http://lareg.ensg.ign.fr/ITRF",EPSG,2006-08-18,2006.77,0,
-6648,IERS Terrestrial Reference Frame 1989,geodetic,"Origin at geocentre, orientated to the BIH Terrestrial System at epoch 1984.0. Datum defined by a set of 3-dimensional Cartesian station coordinates (SCS).",1989,7019,8901,1262,Geodesy.,"Realisation of the IERS Terrestrial Reference System (ITRS) at epoch 1989.0. Supersedes ITRF88 (code 6647). Superseded by ITRF90 (code 6649).","International Earth Rotation Service (IERS) Technical Note No. 6. Also IGN Paris http://lareg.ensg.ign.fr/ITRF",EPSG,2006-08-18,2006.77,0,
-6649,IERS Terrestrial Reference Frame 1990,geodetic,"Origin at geocentre, orientated to the BIH Terrestrial System at epoch 1984.0. Datum defined by a set of 3-dimensional Cartesian station coordinates (SCS).",1990,7019,8901,1262,Geodesy.,"Realisation of the IERS Terrestrial Reference System (ITRS) at epoch 1990.0. Supersedes ITRF89 (code 6648). Superseded by ITRF91 (code 6650).","International Earth Rotation Service (IERS) Technical Note No. 9. Also IGN Paris http://lareg.ensg.ign.fr/ITRF",EPSG,2006-08-18,2006.77,0,
-6650,IERS Terrestrial Reference Frame 1991,geodetic,"Origin at geocentre, orientated to the BIH Terrestrial System at epoch 1984.0. Datum defined by a set of 3-dimensional Cartesian station coordinates (SCS).",1991,7019,8901,1262,Geodesy.,"Realisation of the IERS Terrestrial Reference System (ITRS) at epoch 1991.0. Supersedes ITRF90 (code 6649). Superseded by ITRF92 (code 6651).","International Earth Rotation Service (IERS) Technical Note No. 12. Also IGN Paris http://lareg.ensg.ign.fr/ITRF",EPSG,2006-08-18,2006.77,0,
-6651,IERS Terrestrial Reference Frame 1992,geodetic,"Origin at geocentre, orientated to the BIH Terrestrial System at epoch 1984.0. Datum defined by a set of 3-dimensional Cartesian station coordinates (SCS).",1992,7019,8901,1262,Geodesy.,"Realisation of the IERS Terrestrial Reference System (ITRS) at epoch 1992.0. Supersedes ITRF91 (code 6650). Superseded by ITRF93 (code 6652).","International Earth Rotation Service (IERS) Technical Note No. 15. Also IGN Paris http://lareg.ensg.ign.fr/ITRF",EPSG,2006-08-18,2006.77,0,
-6652,IERS Terrestrial Reference Frame 1993,geodetic,"Origin at geocentre, orientated to the BIH Terrestrial System at epoch 1984.0. Datum defined by a set of 3-dimensional Cartesian station coordinates (SCS).",1993,7019,8901,1262,Geodesy.,"Realisation of the IERS Terrestrial Reference System (ITRS) at epoch 1993.0. Supersedes ITRF92 (code 6651). Superseded by ITRF94 (code 6653).","International Earth Rotation Service (IERS) Technical Note No. 18. Also IGN Paris http://lareg.ensg.ign.fr/ITRF",EPSG,2006-08-18,2006.77,0,
-6653,IERS Terrestrial Reference Frame 1994,geodetic,"Origin at geocentre, orientated to the BIH Terrestrial System at epoch 1984.0. Datum defined by a set of 3-dimensional Cartesian station coordinates (SCS).",1994,7019,8901,1262,Geodesy.,"Realisation of the IERS Terrestrial Reference System (ITRS) at epoch 1994.0. Supersedes ITRF93 (code 6652). Superseded by ITRF96 (code 6654).","International Earth Rotation Service (IERS) Technical Note No. 20. Also IGN Paris http://lareg.ensg.ign.fr/ITRF",EPSG,2006-08-18,2006.77,0,
-6654,IERS Terrestrial Reference Frame 1996,geodetic,"Origin at geocentre, orientated to the BIH Terrestrial System at epoch 1984.0. Datum defined by a set of 3-dimensional Cartesian station coordinates (SCS).",1996,7019,8901,1262,Geodesy.,"Realisation of the IERS Terrestrial Reference System (ITRS) at epoch 1996.0. Supersedes ITRF94 (code 6653). Superseded by ITRF97 (code 6655).","International Earth Rotation Service (IERS) Technical Note No. 24. Also IGN Paris http://lareg.ensg.ign.fr/ITRF",EPSG,2006-08-18,2006.77,0,
-6655,IERS Terrestrial Reference Frame 1997,geodetic,"Origin at geocentre, orientated to the BIH Terrestrial System at epoch 1984.0. Datum defined by a set of 3-dimensional Cartesian station coordinates (SCS).",1997,7019,8901,1262,Geodesy.,"Realisation of the IERS Terrestrial Reference System (ITRS) at epoch 1997.0. Supersedes ITRF96 (code 6654). Superseded by ITRF2000 (code 6656).","International Earth Rotation Service (IERS) Technical Note No. 27. Also IGN Paris http://lareg.ensg.ign.fr/ITRF",EPSG,2006-08-18,2006.77,0,
-6656,IERS Terrestrial Reference Frame 2000,geodetic,"Origin at geocentre, orientated to the BIH Terrestrial System at epoch 1984.0. Datum defined by a set of 3-dimensional Cartesian station coordinates (SCS).",2000,7019,8901,1262,Geodesy.,"Realisation of the IERS Terrestrial Reference System (ITRS) at epoch 2000.0. Supersedes ITRF97 (code 6655).","IGN Paris http://lareg.ensg.ign.fr/ITRF",EPSG,2006-08-18,2006.77,0,
+6647,International Terrestrial Reference Frame 1988,geodetic,"Origin at geocentre, orientated to the BIH Terrestrial System at epoch 1984.0. Datum defined by a set of 3-dimensional Cartesian station coordinates (SCS).",1988,7019,8901,1262,Geodesy.,"Realisation of the IERS Terrestrial Reference System (ITRS) at epoch 1988.0. Replaced by ITRF89 (code 6648).","International Earth Rotation Service (IERS) Annual Report for 1988. Also IGN Paris http://lareg.ensg.ign.fr/ITRF",EPSG,2006-10-13,2006.77 2006.892,0,
+6648,International Terrestrial Reference Frame 1989,geodetic,"Origin at geocentre, orientated to the BIH Terrestrial System at epoch 1984.0. Datum defined by a set of 3-dimensional Cartesian station coordinates (SCS).",1989,7019,8901,1262,Geodesy.,"Realisation of the IERS Terrestrial Reference System (ITRS) at epoch 1989.0. Replaces ITRF88 (code 6647). Replaced by ITRF90 (code 6649).","International Earth Rotation Service (IERS) Technical Note No. 6. Also IGN Paris http://lareg.ensg.ign.fr/ITRF",EPSG,2006-10-13,2006.77 2006.892,0,
+6649,International Terrestrial Reference Frame 1990,geodetic,"Origin at geocentre, orientated to the BIH Terrestrial System at epoch 1984.0. Datum defined by a set of 3-dimensional Cartesian station coordinates (SCS).",1990,7019,8901,1262,Geodesy.,"Realisation of the IERS Terrestrial Reference System (ITRS) at epoch 1990.0. Replaces ITRF89 (code 6648). Replaced by ITRF91 (code 6650).","International Earth Rotation Service (IERS) Technical Note No. 9. Also IGN Paris http://lareg.ensg.ign.fr/ITRF",EPSG,2006-10-13,2006.77 2006.892,0,
+6650,International Terrestrial Reference Frame 1991,geodetic,"Origin at geocentre, orientated to the BIH Terrestrial System at epoch 1984.0. Datum defined by a set of 3-dimensional Cartesian station coordinates (SCS).",1991,7019,8901,1262,Geodesy.,"Realisation of the IERS Terrestrial Reference System (ITRS) at epoch 1991.0. Replaces ITRF90 (code 6649). Replaced by ITRF92 (code 6651).","International Earth Rotation Service (IERS) Technical Note No. 12. Also IGN Paris http://lareg.ensg.ign.fr/ITRF",EPSG,2006-10-13,2006.77 2006.892,0,
+6651,International Terrestrial Reference Frame 1992,geodetic,"Origin at geocentre, orientated to the BIH Terrestrial System at epoch 1984.0. Datum defined by a set of 3-dimensional Cartesian station coordinates (SCS).",1992,7019,8901,1262,Geodesy.,"Realisation of the IERS Terrestrial Reference System (ITRS) at epoch 1992.0. Replaces ITRF91 (code 6650). Replaced by ITRF93 (code 6652).","International Earth Rotation Service (IERS) Technical Note No. 15. Also IGN Paris http://lareg.ensg.ign.fr/ITRF",EPSG,2006-10-13,2006.77 2006.892,0,
+6652,International Terrestrial Reference Frame 1993,geodetic,"Origin at geocentre, orientated to the BIH Terrestrial System at epoch 1984.0. Datum defined by a set of 3-dimensional Cartesian station coordinates (SCS).",1993,7019,8901,1262,Geodesy.,"Realisation of the IERS Terrestrial Reference System (ITRS) at epoch 1993.0. Replaces ITRF92 (code 6651). Replaced by ITRF94 (code 6653).","International Earth Rotation Service (IERS) Technical Note No. 18. Also IGN Paris http://lareg.ensg.ign.fr/ITRF",EPSG,2006-10-13,2006.77 2006.892,0,
+6653,International Terrestrial Reference Frame 1994,geodetic,"Origin at geocentre, orientated to the BIH Terrestrial System at epoch 1984.0. Datum defined by a set of 3-dimensional Cartesian station coordinates (SCS).",1994,7019,8901,1262,Geodesy.,"Realisation of the IERS Terrestrial Reference System (ITRS) at epoch 1994.0. Replaces ITRF93 (code 6652). Replaced by ITRF96 (code 6654).","International Earth Rotation Service (IERS) Technical Note No. 20. Also IGN Paris http://lareg.ensg.ign.fr/ITRF",EPSG,2006-10-13,2006.77 2006.892,0,
+6654,International Terrestrial Reference Frame 1996,geodetic,"Origin at geocentre, orientated to the BIH Terrestrial System at epoch 1984.0. Datum defined by a set of 3-dimensional Cartesian station coordinates (SCS).",1996,7019,8901,1262,Geodesy.,"Realisation of the IERS Terrestrial Reference System (ITRS) at epoch 1996.0. Replaces ITRF94 (code 6653). Replaced by ITRF97 (code 6655).","International Earth Rotation Service (IERS) Technical Note No. 24. Also IGN Paris http://lareg.ensg.ign.fr/ITRF",EPSG,2006-10-13,2006.77 2006.892,0,
+6655,International Terrestrial Reference Frame 1997,geodetic,"Origin at geocentre, orientated to the BIH Terrestrial System at epoch 1984.0. Datum defined by a set of 3-dimensional Cartesian station coordinates (SCS).",1997,7019,8901,1262,Geodesy.,"Realisation of the IERS Terrestrial Reference System (ITRS) at epoch 1997.0. Replaces ITRF96 (code 6654). Replaced by ITRF2000 (code 6656).","International Earth Rotation Service (IERS) Technical Note No. 27. Also IGN Paris http://lareg.ensg.ign.fr/ITRF",EPSG,2006-10-13,2006.77 2006.892,0,
+6656,International Terrestrial Reference Frame 2000,geodetic,"Origin at geocentre, orientated to the BIH Terrestrial System at epoch 1984.0. Datum defined by a set of 3-dimensional Cartesian station coordinates (SCS).",2000,7019,8901,1262,Geodesy.,"Realisation of the IERS Terrestrial Reference System (ITRS) at epoch 2000.0. Replaces ITRF97 (code 6655). Replaced by ITRF2005 (code 6758).","IGN Paris http://lareg.ensg.ign.fr/ITRF",EPSG,2006-10-13,2006.77 2006.892,0,
6657,Reykjavik 1900,geodetic,"Fundamental point: Latitude: 64 deg 08 min 31.88 sec N; Longitude: 21 deg 55 min 51.15 sec W (of Greenwich).",1900,7051,8901,3262,Medium scale topographic mapping.,,"Landmaelingar Islands (National Survey of Iceland).",EPSG,2003-06-27,,0,"D_Reykjavik_1900"
6658,Hjorsey 1955,geodetic,"Fundamental point: Latitude: 64 deg 31 min 29.26 sec N; Longitude: 22 deg 22 min 05.84 sec W (of Greenwich).",1955,7022,8901,3262,"1/50,000 scale topographic mapping.",,"Landmaelingar Islands (National Survey of Iceland).",EPSG,2003-06-27,,0,"D_Hjorsey_1955"
6659,Islands Network 1993,geodetic,ITRF93 at epoch 1993.6.,1996,7019,8901,1120,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"Landmaelingar Islands (National Survey of Iceland).",EPSG,2006-08-18,2006.77,0,"D_Islands_Network_1993"
6660,Helle 1954,geodetic,,1954,7022,8901,2869,"Geodetic survey, topographic mapping..",,Statens kartverk.,EPSG,2003-06-27,,0,"D_Helle_1954"
6661,Latvia 1992,geodetic,Constrained to 4 ETRS89 points in Latvia from the EUREF Baltic 1992 campaign.,1992,7019,8901,1139,"Topographic mapping, geodetic survey.",Densification of ETRS89 during the 1992 Baltic campaign.,"Latvijas Republikas Valsts zemes dienests (State Land Service of the Republic of Latvia) via EuroGeographics. http://crs.bkg.bund.de/crs-eu/",EPSG,2003-06-27,,0,"D_Latvia_1992"
-6663,Porto Santo 1995,geodetic,SE Base on Porto Santo island. Origin and orientation constrained to those of the 1936 adjustment.,1995,7022,8901,1314,Topographic mapping.,"Classical and GPS observations. Supersedes 1936 adjustment (datum code 6615).
+6663,Porto Santo 1995,geodetic,SE Base on Porto Santo island. Origin and orientation constrained to those of the 1936 adjustment.,1995,7022,8901,1314,Topographic mapping.,"Classical and GPS observations. Replaces 1936 adjustment (datum code 6615).
For Selvagens see Selvagem Grande (datum code 6616).","Instituto Geografico e Cadastral Lisbon; http://www.igeo.pt/",EPSG,2005-09-06,2005.46,0,"D_Porto_Santo_1995"
-6664,Azores Oriental Islands 1995,geodetic,"Fundamental point: Forte de São Bras. Origin and orientation constrained to those of the 1940 adjustment.",1940,7022,8901,1345,Topographic mapping.,"Classical and GPS observations. Supersedes 1940 adjustment (datum code 6184).","Instituto Geografico e Cadastral Lisbon; http://www.igeo.pt/",EPSG,2005-09-06,2005.46,0,"D_Azores_Oriental_Islands_1995"
-6665,Azores Central Islands 1995,geodetic,"Fundamental point: Graciosa south west base. Origin and orientation constrained to those of the 1948 adjustment.",1948,7022,8901,1301,Topographic mapping.,"Classical and GPS observations. Supersedes 1948 adjustment (datum code 6183).","Instituto Geografico e Cadastral Lisbon; http://www.igeo.pt/",EPSG,2005-09-06,2005.46,0,"D_Azores_Central_Islands_1995"
-6666,Lisbon 1890,geodetic,"Fundamental point: Castelo Sao Jorge; Lisbon. Latitude: 38 deg 42 min 43.631 sec N; Longitude: 9 deg 07 min 54.862 sec W of Greenwich.",1937,7004,8901,1294,Topographic mapping.,"Superseded by Lisbon 1937 adjustment (which uses International 1924 ellipsoid).","Instituto Geografico e Cadastral Lisbon http://www.igeo.pt",EPSG,2003-12-18,2003.361,0,"D_Lisbon_1890"
+6664,Azores Oriental Islands 1995,geodetic,"Fundamental point: Forte de São Bras. Origin and orientation constrained to those of the 1940 adjustment.",1940,7022,8901,1345,Topographic mapping.,"Classical and GPS observations. Replaces 1940 adjustment (datum code 6184).","Instituto Geografico e Cadastral Lisbon; http://www.igeo.pt/",EPSG,2005-09-06,2005.46,0,"D_Azores_Oriental_Islands_1995"
+6665,Azores Central Islands 1995,geodetic,"Fundamental point: Graciosa south west base. Origin and orientation constrained to those of the 1948 adjustment.",1948,7022,8901,1301,Topographic mapping.,"Classical and GPS observations. Replaces 1948 adjustment (datum code 6183).","Instituto Geografico e Cadastral Lisbon; http://www.igeo.pt/",EPSG,2005-09-06,2005.46,0,"D_Azores_Central_Islands_1995"
+6666,Lisbon 1890,geodetic,"Fundamental point: Castelo Sao Jorge; Lisbon. Latitude: 38 deg 42 min 43.631 sec N; Longitude: 9 deg 07 min 54.862 sec W of Greenwich.",1937,7004,8901,1294,Topographic mapping.,"Replaced by Lisbon 1937 adjustment (which uses International 1924 ellipsoid).","Instituto Geografico e Cadastral Lisbon http://www.igeo.pt",EPSG,2003-12-18,2003.361,0,"D_Lisbon_1890"
6667,Iraq-Kuwait Boundary Datum 1992,geodetic,Four stations established between September and December 1991 determined by GPS and Doppler observations.,1992,7030,8901,2876,International boundary demarcation,,"United Nations Iraq-Kuwait Boundary Demarcation Commission, Final Report, May 1993.",EPSG,2003-09-01,,0,"D_Iraq_Kuwait_Boundary_1992"
-6668,European Datum 1979,geodetic,"Fundamental point: Potsdam (Helmert Tower). Latitude: 52 deg 22 min 51.4456 sec N; Longitude: 13 deg 3 min 58.9283 sec E (of Greenwich).",1979,7022,8901,1297,Scientific network.,Superseded by 1987 adjustment.,,EPSG,2003-12-31,,0,"D_European_1979"
+6668,European Datum 1979,geodetic,"Fundamental point: Potsdam (Helmert Tower). Latitude: 52 deg 22 min 51.4456 sec N; Longitude: 13 deg 3 min 58.9283 sec E (of Greenwich).",1979,7022,8901,1297,Scientific network.,Replaced by 1987 adjustment.,,EPSG,2003-12-31,,0,"D_European_1979"
6670,Istituto Geografico Militaire 1995,geodetic,Network of 1296 points observed 1992-1995 and adjusted in 1996 constrained to 9 ETRS89 points. Densification of ETRS89 in Italy.,1995,7030,8901,1127,Geodetic survey and scientific study.,,ENI,EPSG,2004-01-07,,0,"D_IGM_1995"
-6671,Voirol 1879,geodetic,"Fundamental point: Voirol. Latitude: 36 deg 45 min 08.199 sec N; Longitude: 3 deg 02 min 49.435 sec E of Greenwich. Uses RGS (and old IGN) value of 2 deg 20 min 13.95 sec for Greenwich-Paris meridian difference.",1879,7011,8901,1365,Topographic mapping.,"Supersedes Voirol 1875 (code 6304).",IGN Paris,EPSG,2004-01-07,,0,"D_Voirol_1879"
-6672,Chatham Islands Datum 1971,geodetic,,1971,7022,8901,2889,"Geodetic survey, topographic mapping, engineering survey.","Superseded by Chatham Islands Datum 1979 (code 6673).","Office of Surveyor General (OSG) Technical Report 14, June 2001.",EPSG,2004-02-17,,0,"D_Chatham_Island_1971"
-6673,Chatham Islands Datum 1979,geodetic,"Fundamental point: station Astro. Latitude: 43 deg 57 min 23.60 sec S; Longitude: 176 deg 34 min 28.65 sec W (of Greenwich).",1979,7022,8901,2889,"Geodetic survey, topographic mapping, engineering survey.","Supersedes Chatham Islands Datum 1971 (code 6672). Superseded by New Zealand Geodetic Datum 2000 (code 6167) from March 2000.","Office of Surveyor General (OSG) Technical Report 14, June 2001.",EPSG,2004-02-17,,0,"D_Chatham_Islands_1979"
-6674,Sistema de Referencia Geocentrico para America del Sur 2000,geodetic,ITRF2000 at epoch 2000.40.,2000,7019,8901,3418,Geodetic survey.,"Realised by a frame of 184 stations observed in 2000 and adjusted in the ITRF2000. Includes ties to tide gauges. Supersedes SIRGAS 1995 system for South America; expands SIRGAS to Mexico and Central America.","IBGE Brazil, http://www1.ibge.gov.br/",EPSG,2006-08-18,2005.46 2005.83 2006.465 2006.77,0,"D_SIRGAS_2000"
-6675,Guam 1963,geodetic,"Fundamental point: Tagcha. Latitude: 13 deg 22 min 38.49 sec N; Longitude: 144 deg 45 min 51.56 sec E (of Greenwich).",1963,7008,8901,3255,Topographic mapping.,"Superseded by NAD83(HARN)","US National Geospatial Intelligence Agency (NGA). http://earth-info.nga.mil/",EPSG,2005-09-06,2005.46,0,"D_Guam_1963"
-6676,Vientiane 1982,geodetic,"Fundamental point: Vientiane (Nongteng) Astro Pillar. Latitude: 18 deg 01 min 31.6301 sec N; Longitude: 102 deg 30 min 56.6999 sec E (of Greenwich).",1982,7024,8901,1138,Topographic mapping.,Superseded by Lao 1993.,National Geographic Department,EPSG,2004-04-27,,0,"D_Vientiane_1982"
-6677,Lao 1993,geodetic,"Fundamental point: Lao 1982 coordinates of Pakxa pillar. Latitude: 18 deg 23 min 57.0056 sec N; Longitude: 103 deg 38 min 41.8020 sec E (of Greenwich). Orientation parallel with WGS 84.",1993,7024,8901,1138,Topographic mapping.,Supersedes Vientiane 1982. Superseded by Lao 1997,National Geographic Department,EPSG,2004-04-27,,0,"D_Lao_1993"
-6678,Lao National Datum 1997,geodetic,"Fundamental point: Vientiane (Nongteng) Astro Pillar. Latitude: 18 deg 01 min 31.3480 sec N; Longitude: 102 deg 30 min 57.1376 sec E (of Greenwich).",1997,7024,8901,1138,"Cadastre, topographic mapping, engineering survey.",Supersedes Lao 1993.,National Geographic Department,EPSG,2004-04-27,,0,"D_Lao_National_Datum_1997"
-6679,Jouik 1961,geodetic,,1961,7012,8901,2967,Hydrographic charting.,"Superseded by Mauritania 1999 (datum code 6702).",Woodside,EPSG,2006-06-12,2006.44,0,"D_Jouik_1961"
-6680,Nouakchott 1965,geodetic,Nouakchott astronomical point.,1965,7012,8901,2968,Topographic survey.,"Triangulation limited to environs of Nouakchott. Extended in 1982 by satellite translocation from a single station ""Ruines"" to support Syledis chain for offshore operations. Superseded by Mauritania 1999 (datum code 6602).",IGN Paris and various industry sources.,EPSG,2006-06-12,2006.44,0,"D_Nouakchott_1965"
+6671,Voirol 1879,geodetic,"Fundamental point: Voirol. Latitude: 36 deg 45 min 08.199 sec N; Longitude: 3 deg 02 min 49.435 sec E of Greenwich. Uses RGS (and old IGN) value of 2 deg 20 min 13.95 sec for Greenwich-Paris meridian difference.",1879,7011,8901,1365,Topographic mapping.,"Replaces Voirol 1875 (code 6304).",IGN Paris,EPSG,2004-01-07,,0,"D_Voirol_1879"
+6672,Chatham Islands Datum 1971,geodetic,,1971,7022,8901,2889,"Geodetic survey, topographic mapping, engineering survey.","Replaced by Chatham Islands Datum 1979 (code 6673).","Office of Surveyor General (OSG) Technical Report 14, June 2001.",EPSG,2004-02-17,,0,"D_Chatham_Island_1971"
+6673,Chatham Islands Datum 1979,geodetic,"Fundamental point: station Astro. Latitude: 43 deg 57 min 23.60 sec S; Longitude: 176 deg 34 min 28.65 sec W (of Greenwich).",1979,7022,8901,2889,"Geodetic survey, topographic mapping, engineering survey.","Replaces Chatham Islands Datum 1971 (code 6672). Replaced by New Zealand Geodetic Datum 2000 (code 6167) from March 2000.","Office of Surveyor General (OSG) Technical Report 14, June 2001.",EPSG,2004-02-17,,0,"D_Chatham_Islands_1979"
+6674,Sistema de Referencia Geocentrico para America del Sur 2000,geodetic,ITRF2000 at epoch 2000.40.,2000,7019,8901,3418,Geodetic survey.,"Realised by a frame of 184 stations observed in 2000 and adjusted in the ITRF2000. Includes ties to tide gauges. Replaces SIRGAS 1995 system for South America; expands SIRGAS to Mexico and Central America.","IBGE Brazil, http://www1.ibge.gov.br/",EPSG,2006-08-18,2005.46 2005.83 2006.465 2006.77,0,"D_SIRGAS_2000"
+6675,Guam 1963,geodetic,"Fundamental point: Tagcha. Latitude: 13 deg 22 min 38.49 sec N; Longitude: 144 deg 45 min 51.56 sec E (of Greenwich).",1963,7008,8901,3255,Topographic mapping.,"Replaced by NAD83(HARN)","US National Geospatial Intelligence Agency (NGA). http://earth-info.nga.mil/",EPSG,2005-09-06,2005.46,0,"D_Guam_1963"
+6676,Vientiane 1982,geodetic,"Fundamental point: Vientiane (Nongteng) Astro Pillar. Latitude: 18 deg 01 min 31.6301 sec N; Longitude: 102 deg 30 min 56.6999 sec E (of Greenwich).",1982,7024,8901,1138,Topographic mapping.,Replaced by Lao 1993.,National Geographic Department,EPSG,2004-04-27,,0,"D_Vientiane_1982"
+6677,Lao 1993,geodetic,"Fundamental point: Lao 1982 coordinates of Pakxa pillar. Latitude: 18 deg 23 min 57.0056 sec N; Longitude: 103 deg 38 min 41.8020 sec E (of Greenwich). Orientation parallel with WGS 84.",1993,7024,8901,1138,Topographic mapping.,Replaces Vientiane 1982. Replaced by Lao 1997,National Geographic Department,EPSG,2004-04-27,,0,"D_Lao_1993"
+6678,Lao National Datum 1997,geodetic,"Fundamental point: Vientiane (Nongteng) Astro Pillar. Latitude: 18 deg 01 min 31.3480 sec N; Longitude: 102 deg 30 min 57.1376 sec E (of Greenwich).",1997,7024,8901,1138,"Cadastre, topographic mapping, engineering survey.",Replaces Lao 1993.,National Geographic Department,EPSG,2004-04-27,,0,"D_Lao_National_Datum_1997"
+6679,Jouik 1961,geodetic,,1961,7012,8901,2967,Hydrographic charting.,"Replaced by Mauritania 1999 (datum code 6702).",Woodside,EPSG,2006-06-12,2006.44,0,"D_Jouik_1961"
+6680,Nouakchott 1965,geodetic,Nouakchott astronomical point.,1965,7012,8901,2968,Topographic survey.,"Triangulation limited to environs of Nouakchott. Extended in 1982 by satellite translocation from a single station ""Ruines"" to support Syledis chain for offshore operations. Replaced by Mauritania 1999 (datum code 6602).",IGN Paris and various industry sources.,EPSG,2006-06-12,2006.44,0,"D_Nouakchott_1965"
6681,Mauritania 1999,geodetic,,1999,7012,8901,1157,"Minerals management, topographic mapping.","A network of 36 GPS stations tied to ITRF96, 8 of which are IGN astronomic points.",Woodside,EPSG,2004-10-14,,1,
6682,Gulshan 303,geodetic,"Gulshan garden, Dhaka.",1995,7015,8901,1041,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Network of more than 140 control points observed and adjusted in 1995 by Japan International Cooperation Agency (JICA).",Survey of Bangladesh via IGN Paris and Tullow Oil.,EPSG,2006-06-22,2006.47,0,"D_Gulshan_303"
-6683,Philippine Reference System 1992,geodetic,"Fundamental point: Balacan. Latitude: 13 deg 33 min 41.000 sec N; Longitude: 121 deg 52 min 03.000 sec E (of Greenwich), geoid-ellipsoid separation 0.34m.",1992,7008,8901,1190,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Supersedes Luzon 1911 datum (code 6253).","National Mapping and Resource Information Authority, Coast and Geodetic Survey Department.",EPSG,2004-12-24,,0,"D_Phillipine_Reference_System_1992"
+6683,Philippine Reference System 1992,geodetic,"Fundamental point: Balacan. Latitude: 13 deg 33 min 41.000 sec N; Longitude: 121 deg 52 min 03.000 sec E (of Greenwich), geoid-ellipsoid separation 0.34m.",1992,7008,8901,1190,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaces Luzon 1911 datum (code 6253).","National Mapping and Resource Information Authority, Coast and Geodetic Survey Department.",EPSG,2004-12-24,,0,"D_Phillipine_Reference_System_1992"
6684,Gan 1970,geodetic,,1970,7022,8901,3274,Topographic mapping.,"In some references incorrectly named ""Gandajika 1970"". See datum code 6685.",Various industry sources.,EPSG,2005-04-14,,0,"D_Gan_1970"
6685,Gandajika,geodetic,Gandajika base,1953,7022,8901,1259,Topographic mapping.,In some references incorrectly attributed to the Maldives. See datum code 6684.,Various industry sources.,EPSG,2005-04-14,,1,
-6686,Marco Geocentrico Nacional de Referencia,geodetic,"ITRF94 at epoch 1995.4. Bogota observatory coordinates: Latitude: 4 deg 35 min 46.3215 sec N; Longitude: 74 deg 04 min 39.0285 sec W (of Greenwich).",2004,7019,8901,3229,Geodetic survey.,"Densification of SIRGAS 1995 within Colombia. Supersedes Bogota 1975 (datum code 6218).","Instituto Geografico Agustin Caduzzi (IGAC) publication ""Aspectos prácticos de la adopción del Marco Geocéntrico Nacional de Referencia MAGNA-SIRGAS como datum oficial de Colombia"". http://www.igac.gov.co/MAGNAWEB/DocumentosMAGNA.htm",EPSG,2006-08-18,2006.77,0,"D_MAGNA"
-6687,Reseau Geodesique de la Polynesie Francaise,geodetic,"ITRF92 at epoch 1993.0. Densification by GPS of the Reference Network of French Polynesia, a coordinate set of 13 stations determined through DORIS observations.",1993,7019,8901,1098,Geodetic survey.,"Supersedes Tahaa 54 (datum code 6629), IGN 63 Hiva Oa (6689), IGN 72 Nuku Hiva (6630), Maupiti 83 (6692), MHEFO 55 (6688), Moorea 87 (6691) and Tahiti 79 (6690).","Gouvernement de la Polynésie Française, Service de l'Urbanisme, Section topographie. Also www.shom.fr, technical report 002/199.",EPSG,2006-08-18,2006.77,0,"D_Reseau_Geodesique_de_la_Polynesie_Francaise"
-6688,Fatu Iva 72,geodetic,"Fundamental point: Latitude: 9 deg 25 min 58.00 sec S; Longitude: 138 deg 55 min 06.25 sec W (of Greenwich).",1972,7022,8901,3133,Hydrographic and topographic survey.,"Recomputed by IGN in 1972 using origin and observations of 1953-1955 Mission Hydrographique des Establissements Francais d'Oceanie (MHEFO 55). Superseded by RGPF (datum code 6687).","Gouvernement de la Polynésie Française, Service de l'Urbanisme, Section topographie.",EPSG,2005-08-12,,0,"D_Fatu_Iva_1972"
-6689,IGN63 Hiva Oa,geodetic,"Fundamental point: Atuona. Latitude: 9 deg 48 min 27.20 sec S; Longitude: 139 deg 02 min 15.45 sec W (of Greenwich).",1963,7022,8901,3130,Hydrographic and topographic survey.,"Superseded by RGPF (datum code 6687).","Gouvernement de la Polynésie Française, Service de l'Urbanisme, Section topographie.",EPSG,2005-08-12,,0,"D_IGN63_Hiva_Oa"
-6690,Tahiti 79,geodetic,"Fundamental point: Tahiti North Base. Latitude: 17 deg 38 min 10.0 sec S; Longitude: 149 deg 36 min 57.8 sec W (of Greenwich).",1979,7022,8901,3124,Hydrographic and topographic survey.,"Supersedes Tahiti 52 (datum code 6628) in Tahiti. Superseded by RGPF (datum code 6687).","Gouvernement de la Polynésie Française, Service de l'Urbanisme, Section topographie.",EPSG,2005-08-12,,0,"D_Tahiti_1979"
-6691,Moorea 87,geodetic,Two stations on Tahiti whose coordinates from the Tahiti 1979 adjustment were held fixed.,1987,7022,8901,3125,Hydrographic and topographic survey.,"Supersedes Tahiti 52 (datum code 6628) in Moorea. Superseded by RGPF (datum code 6687).","Gouvernement de la Polynésie Française, Service de l'Urbanisme, Section topographie.",EPSG,2005-08-12,,0,"D_Moorea_1987"
-6692,Maupiti 83,geodetic,"Fundamental point: Pitiahe South Base. Latitude: 16 deg 28 min 28.942 sec S; Longitude: 152 deg 14 min 55.059 sec W (of Greenwich).",1983,7022,8901,3126,Hydrographic and topographic survey.,"Superseded by RGPF (datum code 6687).","Gouvernement de la Polynésie Française, Service de l'Urbanisme, Section topographie.",EPSG,2005-08-12,,0,"D_Maupiti_1983"
+6686,Marco Geocentrico Nacional de Referencia,geodetic,"ITRF94 at epoch 1995.4. Bogota observatory coordinates: Latitude: 4 deg 35 min 46.3215 sec N; Longitude: 74 deg 04 min 39.0285 sec W (of Greenwich).",2004,7019,8901,3229,Geodetic survey.,"Densification of SIRGAS 1995 within Colombia. Replaces Bogota 1975 (datum code 6218).","Instituto Geografico Agustin Codazzi (IGAC) publication ""Aspectos prácticos de la adopción del Marco Geocéntrico Nacional de Referencia MAGNA-SIRGAS como datum oficial de Colombia"". http://www.igac.gov.co/MAGNAWEB/DocumentosMAGNA.htm",EPSG,2007-07-02,2006.77 2007.060,0,"D_MAGNA"
+6687,Reseau Geodesique de la Polynesie Francaise,geodetic,"ITRF92 at epoch 1993.0. Densification by GPS of the Reference Network of French Polynesia, a coordinate set of 13 stations determined through DORIS observations.",1993,7019,8901,1098,Geodetic survey.,"Replaces Tahaa 54 (datum code 6629), IGN 63 Hiva Oa (6689), IGN 72 Nuku Hiva (6630), Maupiti 83 (6692), MHEFO 55 (6688), Moorea 87 (6691) and Tahiti 79 (6690).","Gouvernement de la Polynésie Française, Service de l'Urbanisme, Section topographie. Also www.shom.fr, technical report 002/199.",EPSG,2006-08-18,2006.77,0,"D_Reseau_Geodesique_de_la_Polynesie_Francaise"
+6688,Fatu Iva 72,geodetic,"Fundamental point: Latitude: 9 deg 25 min 58.00 sec S; Longitude: 138 deg 55 min 06.25 sec W (of Greenwich).",1972,7022,8901,3133,Hydrographic and topographic survey.,"Recomputed by IGN in 1972 using origin and observations of 1953-1955 Mission Hydrographique des Establissements Francais d'Oceanie (MHEFO 55). Replaced by RGPF (datum code 6687).","Gouvernement de la Polynésie Française, Service de l'Urbanisme, Section topographie.",EPSG,2005-08-12,,0,"D_Fatu_Iva_1972"
+6689,IGN63 Hiva Oa,geodetic,"Fundamental point: Atuona. Latitude: 9 deg 48 min 27.20 sec S; Longitude: 139 deg 02 min 15.45 sec W (of Greenwich).",1963,7022,8901,3130,Hydrographic and topographic survey.,"Replaced by RGPF (datum code 6687).","Gouvernement de la Polynésie Française, Service de l'Urbanisme, Section topographie.",EPSG,2005-08-12,,0,"D_IGN63_Hiva_Oa"
+6690,Tahiti 79,geodetic,"Fundamental point: Tahiti North Base. Latitude: 17 deg 38 min 10.0 sec S; Longitude: 149 deg 36 min 57.8 sec W (of Greenwich).",1979,7022,8901,3124,Hydrographic and topographic survey.,"Replaces Tahiti 52 (datum code 6628) in Tahiti. Replaced by RGPF (datum code 6687).","Gouvernement de la Polynésie Française, Service de l'Urbanisme, Section topographie.",EPSG,2005-08-12,,0,"D_Tahiti_1979"
+6691,Moorea 87,geodetic,Two stations on Tahiti whose coordinates from the Tahiti 1979 adjustment were held fixed.,1987,7022,8901,3125,Hydrographic and topographic survey.,"Replaces Tahiti 52 (datum code 6628) in Moorea. Replaced by RGPF (datum code 6687).","Gouvernement de la Polynésie Française, Service de l'Urbanisme, Section topographie.",EPSG,2005-08-12,,0,"D_Moorea_1987"
+6692,Maupiti 83,geodetic,"Fundamental point: Pitiahe South Base. Latitude: 16 deg 28 min 28.942 sec S; Longitude: 152 deg 14 min 55.059 sec W (of Greenwich).",1983,7022,8901,3126,Hydrographic and topographic survey.,"Replaced by RGPF (datum code 6687).","Gouvernement de la Polynésie Française, Service de l'Urbanisme, Section topographie.",EPSG,2005-08-12,,0,"D_Maupiti_1983"
6693,Nakhl-e Ghanem,geodetic,"Coordinates of two stations determined with respect to ITRF 2000 at epoch 2005.2: BMT1 latitude 27 deg 42 min 09.8417 sec N, longitude 52 deg 12 min 11.0362 sec E; Total1 latitude 27 deg 31 min 03.8896 sec N, longitude 52 deg 36 min 13.1312 sec E.",2005,7030,8901,2362,Engineering survey for onshore facilities for South Pars phase 11 and Pars LNG.,,Total,EPSG,2006-08-18,2006.77,0,"D_Nakhl-e_Ghanem"
6694,Posiciones Geodesicas Argentinas 1994,geodetic,"A geodetic network of 127 high accuracy surveyed points based on WGS 84 that define the National Geodetic System (Sistema Geodésico Nacional).",1994,7019,8901,1033,"Topographic mapping, geodetic survey.","Una red geodésica de 127 puntos materializados
en el terreno que definen el Sistema Geodésico Nacional.
-Technically, but at this record revision date not legally, superseded by POSGAR 98 (code 6190).","Instituto Geográfico Militar de la República Argentina, http://www.igm.gov.ar",EPSG,2005-09-12,,0,"D_POSGAR_1994"
-6695,Katanga 1955,geodetic,"Fundamental point: Tshinsenda A. Latitude: 12 deg 20 min 31.568 sec S; Longitude: 28 deg 01 min 02.971 sec E.",1955,7008,8901,3147,"Cadastre, topographic mapping, engineering survey.",Supersedes earlier adjustments.,"Clifford J. Mugnier, in Photogrammetric Engineering and Remote Sensing, June 2005.",EPSG,2005-09-30,,0,"D_Katanga_1955"
-6696,Kasai 1953,geodetic,"Two stations of the Katanga triangulation with ellipsoid change applied: Kabila, latitude 6 deg 58 min 34.023 sec S, longitude 23 deg 50 min 24.028 sec E; and Gandajika NW base, latitude 6 deg 45 min 01.057 sec S, longitude 23 deg 57 min 03.038 sec E.",1955,7012,8901,3148,"Cadastre, topographic mapping, engineering survey.",Superseded by IGC 1962 Arc of the 6th Parallel South.,Institute Geographique du Congo,EPSG,2005-09-30,,0,"D_Kasai_1955"
+Technically, but at this record revision date not legally, replaced by POSGAR 98 (code 6190).","Instituto Geográfico Militar de la República Argentina, http://www.igm.gov.ar",EPSG,2005-09-12,,0,"D_POSGAR_1994"
+6695,Katanga 1955,geodetic,"Fundamental point: Tshinsenda A. Latitude: 12 deg 20 min 31.568 sec S; Longitude: 28 deg 01 min 02.971 sec E.",1955,7008,8901,3147,"Cadastre, topographic mapping, engineering survey.",Replaces earlier adjustments.,"Clifford J. Mugnier, in Photogrammetric Engineering and Remote Sensing, June 2005.",EPSG,2005-09-30,,0,"D_Katanga_1955"
+6696,Kasai 1953,geodetic,"Two stations of the Katanga triangulation with ellipsoid change applied: Kabila, latitude 6 deg 58 min 34.023 sec S, longitude 23 deg 50 min 24.028 sec E; and Gandajika NW base, latitude 6 deg 45 min 01.057 sec S, longitude 23 deg 57 min 03.038 sec E.",1955,7012,8901,3148,"Cadastre, topographic mapping, engineering survey.",Replaced by IGC 1962 Arc of the 6th Parallel South.,Institute Geographique du Congo,EPSG,2005-09-30,,0,"D_Kasai_1955"
6697,IGC 1962 Arc of the 6th Parallel South,geodetic,"Coordinates of 3 stations determined with respect to Arc 1950: Mulungu 4deg 47min 39.2325sec S, 29deg 59min 37.5864sec E; Nyakawembe 4deg 14min 57.3618sec S, 29deg 42min 52.8032sec E; Kavula 4deg 35min 15.8634sec S, 29deg 41min 14.2693sec E.",1962,7012,8901,3149,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,Institute Geographique du Congo,EPSG,2006-08-25,2006.721,0,"D_IGC_1962_Arc_of_the_6th_Parallel_South"
6698,IGN 1962 Kerguelen,geodetic,K0 1949.,1949,7022,8901,2816,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,IGN Paris.,OGP,2005-11-23,,0,"D_Kerguelen_Island_1949"
6699,Le Pouce 1934,geodetic,"Fundamental point: Le Pouce. Latitude: 20 deg 11 min 42.25 sec S; Longitude: 57 deg 31 min 18.58 sec E.",1934,7012,8901,3209,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"Cartography Section, Ministry of Housing and Land.",OGP,2006-01-16,,0,
-6700,IGN Astro 1960,geodetic,Realised through a set of independent astronomically-positioned points.,1960,7012,8901,1157,Small scale topographic mapping.,"Observed during 1959-1960. Independent points not connected through a network. Relative accuracy estimated at 50-100m. Superseded by Mauritania 1999 (datum code 6702).","Ministry of Works and Transport, Topography and Cartography Directive.",OGP,2006-06-12,2006.44,0,
-6701,Institut Geographique du Congo Belge 1955,geodetic,"Fundamental point: Yella east base. Latitude: 6 deg 00 min 53.139 sec S; Longitude: 12 deg 58 min 29.287 sec E.",1955,7012,8901,3171,"Cadastre, topographic mapping, engineering survey.","Superseded by IGC 1962 Arc of the 6th Parallel South, except for oil industry activities.",Institut Geographique du Congo Belge.,OGP,2005-11-28,,0,"D_Institut_Geographique_du_Congo_Belge_1955"
+6700,IGN Astro 1960,geodetic,Realised through a set of independent astronomically-positioned points.,1960,7012,8901,1157,Small scale topographic mapping.,"Observed during 1959-1960. Independent points not connected through a network. Relative accuracy estimated at 50-100m. Replaced by Mauritania 1999 (datum code 6702).","Ministry of Works and Transport, Topography and Cartography Directive.",OGP,2006-06-12,2006.44,0,
+6701,Institut Geographique du Congo Belge 1955,geodetic,"Fundamental point: Yella east base. Latitude: 6 deg 00 min 53.139 sec S; Longitude: 12 deg 58 min 29.287 sec E.",1955,7012,8901,3171,"Cadastre, topographic mapping, engineering survey.","Replaced by IGC 1962 Arc of the 6th Parallel South, except for oil industry activities.",Institut Geographique du Congo Belge.,OGP,2005-11-28,,0,"D_Institut_Geographique_du_Congo_Belge_1955"
6702,Mauritania 1999,geodetic,ITRF96 at epoch 1997.0,1999,7019,8901,1157,Geodesy.,"A network of 36 GPS stations tied to ITRF96, 8 of which are IGN 1962 astronomic points.","Ministry of Works and Transport, Topography and Cartography Directive.",EPSG,2006-08-18,2006.77,0,"D_Mauritania_1999"
6703,Missao Hidrografico Angola y Sao Tome 1951,geodetic,Extension of Camacupa datum into Cabinda.,1951,7012,8901,1318,Coastal hydrography.,"A variation of this datum has been adopted by the oil industry but incorrectly using the International 1924 ellipsoid and not tied to the official Portuguese triangulation - see Mhast (onshore) and Mhast (offshore) (codes 6704 and 6705).",Various industry sources.,OGP,2006-01-03,,0,"D_Mhast_1951"
6704,"Mhast (onshore)",geodetic,Probably adopted a Mhast 1951 coordinate set but associated an incorrect ellipsoid with it.,,7022,8901,3179,"Oil industry exploration and production. From 1979, offshore use superseded by Mhast (offshore) (code 6705).","Adopted by oil industry with intention of being Mhast 1951 (code 6703) but incorrectly (for Mhast 1951) used the International 1924 ellipsoid. This datum differs by about 400 metres from the Portuguese Mhast 1951 and Camacupa datums.",ChevronTexaco.,OGP,2006-01-03,,0,"D_Mhast_Onshore"
-6705,"Mhast (offshore)",geodetic,"Fundamental point: Station Y at Malongo base camp. Latitude: 5 deg 23 min 30.810 sec S; Longitude: 12 deg 12 min 01.590 sec E (of Greenwich).",1979,7022,8901,3180,Oil industry offshore exploration and production between 1979 and 1987.,"Origin coordinates determined by Transit single point position using 32 passes and transformed from WGS72BE using transformation code 15790. Differs from Mhast (onshore) by approximately 10m. Superseded in 1987 by Malongo 1987 (code 6259).",ChevronTexaco.,OGP,2006-01-03,,0,"D_Mhast_Offshore"
+6705,"Mhast (offshore)",geodetic,"Fundamental point: Station Y at Malongo base camp. Latitude: 5 deg 23 min 30.810 sec S; Longitude: 12 deg 12 min 01.590 sec E (of Greenwich).",1979,7022,8901,3180,Oil industry offshore exploration and production between 1979 and 1987.,"Origin coordinates determined by Transit single point position using 32 passes and transformed from WGS72BE using transformation code 15790. Differs from Mhast (onshore) by approximately 10m. Replaced in 1987 by Malongo 1987 (code 6259).",ChevronTexaco.,OGP,2006-01-03,,0,"D_Mhast_Offshore"
6706,Egypt Gulf of Suez S-650 TL,geodetic,"Fundamental point: Station S-650 DMX. Adopted coordinates: latitude: 28 deg 19 min 02.1907 sec N; Longitude: 33 deg 06 min 36.6344 sec E (of Greenwich). The proper Egypt 1907 coordinates for S-650 differ from these by about 20m.",1980,7020,8901,2341,Oil industry offshore exploration and production in Gulf of Suez after 1980.,"A coherent set of stations bordering the Gulf of Suez coordinated by Transit translocation (""TL"") between 1980 and 1984. Based on incorrect Egypt 1907 values for origin station S-650. Differs from true Egypt 1907 by approximately 20m.",Various industry sources.,OGP,2006-01-11,,0,"D_Egypt_Gulf_of_Suez_S-650_TL"
6707,Tern Island 1961,geodetic,"Fundamental point: station FRIG on tern island, station B4 on Sorol Atoll.",1961,7022,8901,3181,Military and topographic mapping,"Two independent astronomic determinations considered to be consistent through adoption of common transformation to WGS 84 (see tfm code 15795).","DMA / NIMA / NGA TR8350.2 (original 1987 first edition and 3rd edition, Amendment 1, 3 January 2000).",OGP,2006-01-26,,0,"D_Tern_Island_1961"
6708,Cocos Islands 1965,geodetic,"Fundamental point: Anna 1.",1965,7003,8901,1069,Military and topographic mapping,,"DMA / NIMA / NGA TR8350.2 (3rd edition, Amendment 1, 3 January 2000).",OGP,2006-01-26,,0,
@@ -465,8 +470,8 @@
6717,Cape Canaveral,geodetic,"Fundamental point: Central 1950. Latitude: 28 deg 29 min 32.36555 sec N; longitude 80 deg 34 min 38.77362 sec W (of Greenwich)",1963,7008,8901,3206,US space and military operations.,,"US NGS and DMA / NIMA / NGA TR8350.2 (3rd edition, Amendment 1, 3 January 2000).",OGP,2006-09-28,2006.87,0,"D_Cape_Canaveral"
6718,Solomon 1968,geodetic,"Fundamental point: GUX 1.",1968,7022,8901,1213,"Military and topographic mapping, +/- 25 meters in each component",,"DMA / NIMA / NGA TR8350.2 (3rd edition, Amendment 1, 3 January 2000).",OGP,2006-01-26,,0,
6719,Easter Island 1967,geodetic,,1967,7022,8901,3188,"Military and topographic mapping, +/- 25 meters in each component",,"DMA / NIMA / NGA TR8350.2 (3rd edition, Amendment 1, 3 January 2000).",OGP,2006-01-26,,0,"D_Easter_Island_1967"
-6720,Fiji Geodetic Datum 1986,geodetic,NWL 9D coordinates of 6 stations on Vitu Levu and Vanua Levu.,1986,7043,8901,1094,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Supersedes Viti Levu 1912, Vanua Levu 1915 and Fiji 1956.","Survey Review 30,231 (January 1989).",OGP,2006-07-19,2006.50,0,"D_Fiji_1986"
-6721,Fiji 1956,geodetic,"Latitude origin was obtained astronomically at station Rasusuva = 17 deg 49 min 03.13 sec South, Longitude origin was obtained astronomically at station Suva = 178 deg 25 min 35.835 sec East.",1956,7022,8901,3398,Military and topographic mapping,For topographic mapping supersedes Viti Levu 1912 and Vanua Levu 1915. Superseded by Fiji Geodetic Datum 1986.,"SOPAC, www.sopac.org, and Clifford J. Mugnier in Photogrammetric Engineering and Remote Sensing, October 2000, www.asprs.org.",OGP,2006-07-19,2006.50,0,"D_Fiji_1956"
+6720,Fiji Geodetic Datum 1986,geodetic,NWL 9D coordinates of 6 stations on Vitu Levu and Vanua Levu.,1986,7043,8901,1094,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaces Viti Levu 1912, Vanua Levu 1915 and Fiji 1956.","Survey Review 30,231 (January 1989).",OGP,2006-07-19,2006.50,0,"D_Fiji_1986"
+6721,Fiji 1956,geodetic,"Latitude origin was obtained astronomically at station Rasusuva = 17 deg 49 min 03.13 sec South, Longitude origin was obtained astronomically at station Suva = 178 deg 25 min 35.835 sec East.",1956,7022,8901,3398,Military and topographic mapping,For topographic mapping replaces Viti Levu 1912 and Vanua Levu 1915. Replaced by Fiji Geodetic Datum 1986.,"SOPAC, www.sopac.org, and Clifford J. Mugnier in Photogrammetric Engineering and Remote Sensing, October 2000, www.asprs.org.",OGP,2006-07-19,2006.50,0,"D_Fiji_1956"
6722,South Georgia 1968,geodetic,"Fundamental point: ISTS 061.",1968,7022,8901,3187,Military and topographic mapping,,"DMA / NIMA / NGA TR8350.2 (3rd edition, Amendment 1, 3 January 2000).",OGP,2006-01-26,,0,
6723,Grand Cayman 1959,geodetic,"Fundamental point: GC1. Latitude: 19deg 17min 54.43sec North, longitude: 81deg 22min 37.17sec West.",1959,7008,8901,3185,Topographic mapping,,"Clifford J. Mugnier; in Photogrammetric Engineering & Remote Sensing November 1998. http://www.asprs.org/",OGP,2006-01-26,,0,"D_Grand_Cayman_1959"
6724,Diego Garcia 1969,geodetic,"Fundamental point: ISTS 073",1969,7022,8901,3189,Military and topographic mapping,,"DMA / NIMA / NGA TR8350.2 (3rd edition, Amendment 1, 3 January 2000).",OGP,2006-01-26,,0,
@@ -483,49 +488,54 @@
6735,Kusaie 1951,geodetic,,1951,7022,8901,3192,Military and topographic mapping,,"DMA / NIMA / NGA TR8350.2 (3rd edition, Amendment 1, 3 January 2000).",OGP,2006-01-26,,0,"D_Kusaie_1951"
6736,Deception Island,geodetic,,,7012,8901,3204,Military and scientific mapping,,"DMA / NIMA / NGA TR8350.2 (3rd edition, Amendment 1, 3 January 2000).",OGP,2006-01-26,,0,"D_Deception_Island"
6737,Geocentric datum of Korea,geodetic,ITRF2000 at epoch 2002.0,2002,7019,8901,1135,Geodetic survey.,,"Permanent Committee for GIS Infrastructure for Asia and the Pacific (PCGIAP), http://www.gsi.go.jp/PCGIAP",OGP,2006-08-18,2006.77,0,"D_Korea_2000"
-6738,Hong Kong 1963,geodetic,"Fundamental point: Trig ""Zero"", 38.4 feet south along the transit circle of the Kowloon Observatory. Latitude 22deg 18min 12.82sec North, longitude 114deg 10min 18.75sec East.",1963,7007,8901,1118,Topographic mapping and hydrographic charting.,"Superseded by Hong Kong 1963(67) for military purposes only in 1967. Superseded by Hong Kong 1980.","Survey and Mapping Office, Lands Department. http://www.info.gov.hk/landsd/",OGP,2006-02-03,,0,"D_Hong_Kong_1963"
-6739,"Hong Kong 1963(67)",geodetic,"Fundamental point: Trig ""Zero"", 38.4 feet south along the transit circle of the Kowloon Observatory. Latitude 22deg 18min 12.82sec North, longitude 114deg 10min 18.75sec East.",1967,7022,8901,1118,Military mapping and charting.,Supersedes Hong Kong 1963 for military purposes only in 1967. Superseded by Hong Kong 1980.,UK Hydrographic Office.,OGP,2006-02-03,,0,"D_Hong_Kong_1963_67"
+6738,Hong Kong 1963,geodetic,"Fundamental point: Trig ""Zero"", 38.4 feet south along the transit circle of the Kowloon Observatory. Latitude 22deg 18min 12.82sec North, longitude 114deg 10min 18.75sec East.",1963,7007,8901,1118,Topographic mapping and hydrographic charting.,"Replaced by Hong Kong 1963(67) for military purposes only in 1967. Replaced by Hong Kong 1980.","Survey and Mapping Office, Lands Department. http://www.info.gov.hk/landsd/",OGP,2006-02-03,,0,"D_Hong_Kong_1963"
+6739,"Hong Kong 1963(67)",geodetic,"Fundamental point: Trig ""Zero"", 38.4 feet south along the transit circle of the Kowloon Observatory. Latitude 22deg 18min 12.82sec North, longitude 114deg 10min 18.75sec East.",1967,7022,8901,1118,Military mapping and charting.,Replaces Hong Kong 1963 for military purposes only in 1967. Replaced by Hong Kong 1980.,UK Hydrographic Office.,OGP,2006-02-03,,0,"D_Hong_Kong_1963_67"
6740,Parametrop Zemp 1990,geodetic,Geocentre.,1990,7054,8901,1262,Geodetic survey.,Derived through satellite tracking techniques.,"Geodeziya i Katografiya, 1993.",OGP,2006-02-03,,0,"D_Parametrop_Zemp_1990"
-6741,Faroe Datum 1954,geodetic,Astronomical observations at 3 points.,1954,7022,8901,3248,"Geodetic survey, topographic mapping, engineering and cadastral survey.","Superseded by ED50 in late 1970's for all purposes other than cadastre. Superseded by fk89 for cadastre.","Kort & Matrikelstyrelsen (KMS), Copenhagen.",OGP,2006-08-04,2005.472,0,
-6742,Geodetic Datum of Malaysia 2000,geodetic,"ITRF2000, epoch 2000.0",2000,7019,8901,1151,"Geodetic survey, topographic mapping, engineering and cadastrral survey.",Supersedes all older Malaysian datums.,"GDM2000 Technical Manual; Department of Survey and Mapping Malaysia. www.jupem.gov.my",OGP,2006-03-16,,0,"D_GDM_2000"
+6741,Faroe Datum 1954,geodetic,Astronomical observations at 3 points.,1954,7022,8901,3248,"Geodetic survey, topographic mapping, engineering and cadastral survey.","Replaced by ED50 in late 1970's for all purposes other than cadastre. Replaced by fk89 for cadastre.","Kort & Matrikelstyrelsen (KMS), Copenhagen.",OGP,2006-08-04,2005.472,0,
+6742,Geodetic Datum of Malaysia 2000,geodetic,"ITRF2000, epoch 2000.0",2000,7019,8901,1151,"Geodetic survey, topographic mapping, engineering and cadastrral survey.",Replaces all older Malaysian datums.,"GDM2000 Technical Manual; Department of Survey and Mapping Malaysia. www.jupem.gov.my",OGP,2006-03-16,,0,"D_GDM_2000"
6743,"Karbala 1979 (Polservice)",geodetic,Karbala.,1979,7012,8901,1124,Geodetic survey.,National geodetic network established by Polservice consortium.,Various industry sources.,OGP,2006-06-02,,0,
-6744,Nahrwan 1934,geodetic,"Fundamental point: Nahrwan south base. Latitude: 33 deg 19 min 10.87 sec N; Longitude: 44 deg 43 min 25.54 sec E (of Greenwich).",1934,7012,8901,3390,Oil exploration and production.,"This adjustment later discovered to have a significant orientation error. In Iran superseded by FD58. In Iraq, superseded by Nahrwan 1967.",Various industry sources.,OGP,2006-06-02,,0,
+6744,Nahrwan 1934,geodetic,"Fundamental point: Nahrwan south base. Latitude: 33 deg 19 min 10.87 sec N; Longitude: 44 deg 43 min 25.54 sec E (of Greenwich).",1934,7012,8901,3390,Oil exploration and production.,"This adjustment later discovered to have a significant orientation error. In Iran replaced by FD58. In Iraq, replaced by Nahrwan 1967.",Various industry sources.,OGP,2006-06-02,,0,
6745,"Rauenberg Datum/83",geodetic,"Fundamental point: Rauenberg. Latitude: 52 deg 27 min 12.021 sec N; Longitude: 13 deg 22 min 04.928 sec E (of Greenwich). This station was destroyed in 1910 and the station at Potsdam substituted as the fundamental point.",1990,7004,8901,2545,"Geodetic survey, cadastre, topographic mapping, engineering survey.","RD/83 is the realisation of DHDN in Saxony. It is the resultant of applying a transformation derived at 106 points throughout former East Germany to Pulkovo 1942/83 points in Saxony.","BKG via EuroGeographics. http://crs.bkg.bund.de",OGP,2006-06-12,,0,
6746,"Potsdam Datum/83",geodetic,"Fundamental point: Rauenberg. Latitude: 52 deg 27 min 12.021 sec N; Longitude: 13 deg 22 min 04.928 sec E (of Greenwich). This station was destroyed in 1910 and the station at Potsdam substituted as the fundamental point.",1990,7004,8901,2544,"Geodetic survey, cadastre, topographic mapping, engineering survey.","PD/83 is the realisation of DHDN in Thuringen. It is the resultant of applying a transformation derived at 13 points on the border between East and West Germany to Pulkovo 1942/83 points in Thuringen.","BKG via EuroGeographics. http://crs.bkg.bund.de",OGP,2006-06-12,,0,
-6747,Greenland 1996,geodetic,ITRF94 at epoch 1996.62,1996,7019,8901,1107,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Supersedes Ammassalik 1958, Qornoq 1927 and Scoresbysund 1952.","Kort & Matrikelstyrelsen (KMS), Copenhagen.",OGP,2006-08-18,2006.77,0,
-6748,Vanua Levu 1915,geodetic,"Latitude origin was obtained astronomically at station Numuiloa = 16 deg 23 min 38.36 sec South, Longitude origin was obtained astronomically at station Suva = 178 deg 25 min 35.835 sec East.",1915,7055,8901,3401,"Geodetic survey, cadastre, topographic mapping, engineering survey.","For topographic mapping, superseded by Fiji 1956. For other purposes, superseded by Fiji 1986.","Clifford J. Mugnier in Photogrammetric Engineering and Remote Sensing, October 2000, www.asprs.org.",OGP,2006-07-19,,0,
+6747,Greenland 1996,geodetic,ITRF94 at epoch 1996.62,1996,7019,8901,1107,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaces Ammassalik 1958, Qornoq 1927 and Scoresbysund 1952.","Kort & Matrikelstyrelsen (KMS), Copenhagen.",OGP,2006-08-18,2006.77,0,
+6748,Vanua Levu 1915,geodetic,"Latitude origin was obtained astronomically at station Numuiloa = 16 deg 23 min 38.36 sec South, Longitude origin was obtained astronomically at station Suva = 178 deg 25 min 35.835 sec East.",1915,7055,8901,3401,"Geodetic survey, cadastre, topographic mapping, engineering survey.","For topographic mapping, replaced by Fiji 1956. For other purposes, replaced by Fiji 1986.","Clifford J. Mugnier in Photogrammetric Engineering and Remote Sensing, October 2000, www.asprs.org.",OGP,2006-07-19,,0,
6749,Reseau Geodesique de Nouvelle Caledonie 91-93,geodetic,ITRF90 at epoch 1989.0,1989,7019,8901,1174,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"Service Topographique de la Nouvelle Caledonie, Direction des Infrastructures, de la Topografie et des Transports Terrestres. www.dittt.gouv.nc",OGP,2006-08-18,2006.77,0,
6750,ST87 Ouvea,geodetic,Ouloup.,1987,7030,8901,2813,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"Service Topographique de la Nouvelle Caledonie, Direction des Infrastructures, de la Topografie et des Transports Terrestres. www.dittt.gouv.nc",OGP,2006-07-21,,0,
6751,"Kertau (RSO)",geodetic,,1969,7056,8901,1309,Metrication of RSO grid.,Adopts metric conversion of 0.914398 metres per yard exactly. This is a truncation of the Sears 1922 ratio.,Defence Geographic Centre.,OGP,2006-07-24,,0,
-6752,Viti Levu 1912,geodetic,"Latitude origin was obtained astronomically at station Monavatu = 17 deg 53 min 28.285 sec South, Longitude origin was obtained astronomically at station Suva = 178 deg 25 min 35.835 sec East.",1912,7055,8901,3195,"Geodetic survey, cadastre, topographic mapping, engineering survey.","For topographic mapping, superseded by Fiji 1956. For other purposes, superseded by Fiji 1986.","Clifford J. Mugnier in Photogrammetric Engineering and Remote Sensing, October 2000, www.asprs.org.",OGP,2006-07-30,,0,
-6753,fk89,geodetic,,1989,7022,8901,3248,Cadastre,Supersedes FD54 for cadastre.,"Kort & Matrikelstyrelsen (KMS), Copenhagen.",OGP,2006-08-04,,0,
-6754,Libyan Geodetic Datum 2006,geodetic,5 stations tied to ITRF2000 through 8 days of continuous observations in May 2006.,2006,7022,8901,1143,"Geodetic survey, topographic mapping, engineering survey.",Supersedes ELD79.,Survey Department of Libya.,OGP,2006-08-25,,0,
-6755,Datum Geodesi Nasional 1995,geodetic,ITRF91at epoch 1992.0.,1995,7030,8901,1122,"Geodetic survey, topographic mapping, engineering survey.",Supersedes ID74 and all older datums.,Bakosurtanal.,OGP,2006-08-25,,0,
-6756,Vietnam 2000,geodetic,"Point N00, located in the premises of the Land Administration Research Institute, Hoang Quoc Viet Street, Hanoi.",2000,7030,8901,1252,"Geodetic survey, topographic mapping, engineering survey.",Supersedes Hanoi 1972.,General Director of Land Administration.,OGP,2006-09-13,,0,
+6752,Viti Levu 1912,geodetic,"Latitude origin was obtained astronomically at station Monavatu = 17 deg 53 min 28.285 sec South, Longitude origin was obtained astronomically at station Suva = 178 deg 25 min 35.835 sec East.",1912,7055,8901,3195,"Geodetic survey, cadastre, topographic mapping, engineering survey.","For topographic mapping, replaced by Fiji 1956. For other purposes, replaced by Fiji 1986.","Clifford J. Mugnier in Photogrammetric Engineering and Remote Sensing, October 2000, www.asprs.org.",OGP,2006-07-30,,0,
+6753,fk89,geodetic,,1989,7022,8901,3248,Cadastre,Replaces FD54 for cadastre.,"Kort & Matrikelstyrelsen (KMS), Copenhagen.",OGP,2006-08-04,,0,
+6754,Libyan Geodetic Datum 2006,geodetic,5 stations tied to ITRF2000 through 8 days of continuous observations in May 2006.,2006,7022,8901,1143,"Geodetic survey, topographic mapping, engineering survey.",Replaces ELD79.,Survey Department of Libya.,OGP,2006-08-25,,0,
+6755,Datum Geodesi Nasional 1995,geodetic,ITRF91at epoch 1992.0.,1995,7030,8901,1122,"Geodetic survey, topographic mapping, engineering survey.",Replaces ID74 and all older datums.,Bakosurtanal.,OGP,2006-08-25,,0,
+6756,Vietnam 2000,geodetic,"Point N00, located in the premises of the Land Administration Research Institute, Hoang Quoc Viet Street, Hanoi.",2000,7030,8901,1252,"Geodetic survey, topographic mapping, engineering survey.",Replaces Hanoi 1972.,General Director of Land Administration.,OGP,2006-09-13,,0,
+6757,SVY21,geodetic,"Fundamental point: Base 7 at Pierce Resevoir. Latitude: 1 deg 22 min 02.9154 sec N; Longitude: 103 deg 49 min 31.9752 sec E (of Greenwich).",2004,7030,8901,1210,Cadastre.,Replaces Kertau 1968 for cadastral purposes from August 2004.,Singapore Land Authority,OGP,2006-10-13,,0,
+6758,Jamaica 2001,geodetic,Aligned to WGS 84.,2001,7030,8901,1128,"Geodetic survey, cadastre, topographic mapping, hydrographic charting, engineering survey.",,National Land Agency.,OGP,2007-01-19,,0,
+6759,"NAD83 (National Spatial Reference System 2007)",geodetic,"Coordinates of 486 national continually operating reference system (CORS) and 195 collaborative GPS (CGPS) sites constrained to their CORS96 values, ITRF2000 at epoch 2002.0.",2007,7019,8901,1511,Geodetic survey.,,"U.S. National Geodetic Survey, http://www.ngs.noaa.gov/",OGP,2007-03-13,,0,
+6760,World Geodetic System 1966,geodetic,Developed from a worldwide distribution of terrestrial and geodetic satellite observations and defined through a set of station coordinates.,1966,7025,8901,1262,Geodesy.,"A worldwide 5° à 5° mean free air gravity anomaly field provided the basic data for producing the WGS 66 gravimetric geoid. Replaced by WGS 72.","US DMA/NIMA/NGA",OGP,2007-03-25,,0,
6801,"CH1903 (Bern)",geodetic,"Fundamental point: Old Bern observatory. Latitude: 46 deg 57 min 08.660 sec N; Longitude: 0 deg E of Bern.",1903,7004,8907,1286,Topographic mapping.,,"Bundesamt für Landestopographie",EPSG,2003-12-18,2003.361,0,"D_Bern_1898"
6802,"Bogota 1975 (Bogota)",geodetic,"Fundamental point: Bogota observatory. Latitude: 4 deg 35 min 56.570 sec N; Longitude: 0 deg E of Bogota.",1975,7022,8904,3229,Topographic mapping.,,,EPSG,2003-12-18,2000.20 2003.361,0,"D_Bogota"
-6803,"Lisbon 1937 (Lisbon)",geodetic,"Fundamental point: Castelo Sao Jorge; Lisbon. Latitude: 38 deg 42 min 43.631 sec N; Longitude: 0",1937,7022,8902,1294,Topographic mapping.,"Supersedes Lisbon 1890 adjustment (which used Bessel 1841 ellipsoid).","Instituto Geografico e Cadastral; Lisbon",EPSG,1995-06-02,2001.551,0,"D_Lisbon"
+6803,"Lisbon 1937 (Lisbon)",geodetic,"Fundamental point: Castelo Sao Jorge; Lisbon. Latitude: 38 deg 42 min 43.631 sec N; Longitude: 0",1937,7022,8902,1294,Topographic mapping.,"Replaces Lisbon 1890 adjustment (which used Bessel 1841 ellipsoid).","Instituto Geografico e Cadastral; Lisbon",EPSG,1995-06-02,2001.551,0,"D_Lisbon"
6804,"Makassar (Jakarta)",geodetic,"Fundamental point: station P1, Moncongloe. Latitude 5 deg 08 min 41.42 sec S; longitude 12 deg 35 min 47.15 sec E of Jakarta.",,7004,8908,1316,Topographic mapping.,,EPSG,EPSG,2003-12-31,2003.361,0,"D_Makassar"
6805,"Militar-Geographische Institut (Ferro)",geodetic,"Fundamental point: Hermannskogel. Latitude: 48 deg 16 min 15.29 sec N; Longitude: 33 deg 57 min 41.06 sec E of Ferro.",1901,7004,8909,1321,Topographic mapping.,,"Bundesamt fur Eich- und Vermessungswesen; Wien",EPSG,1995-06-02,,0,"D_MGI"
-6806,"Monte Mario (Rome)",geodetic,"Fundamental point: Monte Mario. Latitude: 41 deg 55 min 25.51 sec N; Longitude: 0 deg 00 min 00.00 sec E (of Rome).",,7022,8906,3343,Topographic mapping.,"Superseded Genova datum, Bessel 1841 ellipsoid, from 1940.",,EPSG,2003-12-31,2003.36,0,"D_Monte_Mario"
+6806,"Monte Mario (Rome)",geodetic,"Fundamental point: Monte Mario. Latitude: 41 deg 55 min 25.51 sec N; Longitude: 0 deg 00 min 00.00 sec E (of Rome).",,7022,8906,3343,Topographic mapping.,"Replaced Genova datum, Bessel 1841 ellipsoid, from 1940.",,EPSG,2003-12-31,2003.36,0,"D_Monte_Mario"
6807,"Nouvelle Triangulation Francaise (Paris)",geodetic,"Fundamental point: Pantheon. Latitude: 54.273618g N; Longitude: 0.0106921g E (of Paris).",1895,7011,8903,1326,Topographic mapping.,,,EPSG,2004-01-07,2003.361,0,"D_NTF"
6808,"Padang 1884 (Jakarta)",geodetic,"Fundamental point: Padang",1884,7004,8908,1355,Topographic mapping.,,,EPSG,1995-06-02,,0,"D_Padang_1884"
6809,"Reseau National Belge 1950 (Brussels)",geodetic,"Fundamental point: Lommel (tower). Latitude: 51 deg 13 min 47.334 sec N; Longitude: 0 deg 56 min 44.773 sec E (of Brussels).",1950,7022,8910,1347,Topographic mapping.,,,EPSG,1995-06-02,,0,"D_Belge_1950"
6810,"Tananarive 1925 (Paris)",geodetic,"Fundamental point: Tananarive observatory. Latitude: 21.0191667g S; Longitude: 50.23849537g E (of Paris)",1925,7022,8903,3273,Topographic mapping.,,IGN Paris,EPSG,2003-12-31,2003.361,0,"D_Tananarive_1925"
6811,"Voirol 1875 (Paris)",geodetic,"Fundamental point: Voirol. Latitude: 40.83578 grads N; Longitude: 0.78873 grads E of Paris.",1875,7011,8903,1365,Topographic mapping.,,IGN Paris,EPSG,2004-01-07,2003.361,0,"D_Voirol_1875"
6813,"Batavia (Jakarta)",geodetic,"Fundamental point: Longitude at Batavia Astro. Station. Latitude: 6 deg 7 min 39.522 sec S; Longitude: 0 deg 00 min 00.0 sec E (of Jakarta). Latitude and azimuth at Genuk.",,7004,8908,1285,Topographic mapping.,,,EPSG,2003-12-31,2003.361,0,"D_Batavia"
-6814,"Stockholm 1938 (Stockholm)",geodetic,"Fundamental point: Stockholm observatory",1938,7004,8911,3313,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Superseded by RT90 adjustment (datum code 6124)",,EPSG,1996-04-12,,0,"D_Stockholm_1938"
+6814,"Stockholm 1938 (Stockholm)",geodetic,"Fundamental point: Stockholm observatory",1938,7004,8911,3313,"Geodetic survey, cadastre, topographic mapping, engineering survey.","Replaced by RT90 adjustment (datum code 6124)",,EPSG,1996-04-12,,0,"D_Stockholm_1938"
6815,"Greek (Athens)",geodetic,"Fundamental point: Athens Observatory; latitude 37 deg 58 min 20.132 sec N; longitude 0 deg E of Athens.",,7004,8912,1106,Topographic mapping.,See geodetic datum alias 6404. Used as basis of topographic mapping based on Hatt projection.,"Topography Department; National Technical University of Athens",EPSG,1997-06-16,,0,"D_Greek"
6816,"Carthage (Paris)",geodetic,"Fundamental point: Carthage. Latitude: 40.9464506g N; Longitude: 8.8724368g E (of Paris).",1925,7011,8903,1618,Topographic mapping.,Fundamental point astronomic coordinates determined in 1878.,,EPSG,2004-01-15,2003.362 2003.05,0,"D_Carthage"
6817,"NGO 1948 (Oslo)",geodetic,"Fundamental point: Oslo observatory. Latitude: 59 deg 54 min 43.7 sec N; Longitude: 0 deg 00 min 00.0 sec E (of Oslo).",1948,7005,8913,1352,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,,EPSG,2004-01-05,2003.362,0,"D_NGO_1948"
6818,"S-JTSK (Ferro)",geodetic,"Modification of Austrian MGI (Ferro) datum.",1920,7004,8909,1306,"Geodetic survey, cadastre, topographic mapping, engineering survey.",,"Research Institute for Geodesy Topography and Cartography (VUGTK); Prague.",EPSG,2001-08-28,2001.26,0,"D_S_JTSK"
6819,"Nord Sahara 1959 (Paris)",geodetic,"Coordinates of primary network readjusted on ED50 datum and then transformed conformally to Clarke 1880 (RGS) ellipsoid.",1959,7012,8903,1366,Topographic mapping.,,"""Le System Geodesique Nord-Sahara""; IGN Paris",EPSG,2000-06-23,,1,"D_Nord_Sahara_1959"
6820,"Gunung Segara (Jakarta)",geodetic,"Station P5 (Gunung Segara) 0deg 32min 12.83sec S 117deg 08min 48.47sec E of Greenwich (8deg 20min 20.68sec E of Jakarta).",,7004,8908,1360,Topographic mapping.,,,EPSG,2002-06-22,,0,"D_Gunung_Segara"
-6821,"Voirol 1879 (Paris)",geodetic,"Fundamental point: Voirol. Latitude: 40.835864 grads N; Longitude: 0.788735 grads E of Paris.",1879,7011,8903,1365,Topographic mapping.,"Supersedes Voirol 1875 (Paris) (code 6811).",IGN Paris,EPSG,2004-01-07,,0,"D_Voirol_1879"
+6821,"Voirol 1879 (Paris)",geodetic,"Fundamental point: Voirol. Latitude: 40.835864 grads N; Longitude: 0.788735 grads E of Paris.",1879,7011,8903,1365,Topographic mapping.,"Replaces Voirol 1875 (Paris) (code 6811).",IGN Paris,EPSG,2004-01-07,,0,"D_Voirol_1879"
+6896,International Terrestrial Reference Frame 2005,geodetic,"Origin at geocentre, originally orientated to the BIH Terrestrial System at epoch 1984.0 then adjusted to ensure zero net rotation to earth's overall tectonic motion. Defined by time series of Cartesian station coordinates and Earth Rotation parameters.",2005,7019,8901,1262,Geodesy.,"Realisation of the IERS Terrestrial Reference System (ITRS) at epoch 2005.0. Replaces ITRF2000 (code 6656).","IGN Paris http://itrf.ensg.ign.fr/itrs_itrf.php",OGP,2007-01-19,,0,
6901,"Ancienne Triangulation Francaise (Paris)",geodetic,,,7027,8903,1326,Topographic mapping.,,,EPSG,1995-06-02,,0,"D_ATF"
6902,"Nord de Guerre (Paris)",geodetic,,,7027,8903,1369,Topographic mapping.,,,EPSG,1995-06-02,,0,"D_Nord_de_Guerre"
6903,"Madrid 1870 (Madrid)",geodetic,"Fundamental point: Madrid observatory.",1870,7028,8905,2366,Topographic mapping.,,"Institut de Geomatica; Barcelona",EPSG,1998-11-11,,0,"D_Madrid_1870"
-6904,"Lisbon 1890 (Lisbon)",geodetic,"Fundamental point: Castelo Sao Jorge; Lisbon. Latitude: 38 deg 42 min 43.631 sec N; Longitude: 0 deg E of Lisbon.",1937,7004,8902,1294,Topographic mapping.,"Superseded by Lisbon 1937 adjustment (which uses International 1924 ellipsoid).","Instituto Geografico e Cadastral Lisbon http://www.igeo.pt",EPSG,2003-08-14,2003.232,0,"D_Lisbon_1890"
+6904,"Lisbon 1890 (Lisbon)",geodetic,"Fundamental point: Castelo Sao Jorge; Lisbon. Latitude: 38 deg 42 min 43.631 sec N; Longitude: 0 deg E of Lisbon.",1937,7004,8902,1294,Topographic mapping.,"Replaced by Lisbon 1937 adjustment (which uses International 1924 ellipsoid).","Instituto Geografico e Cadastral Lisbon http://www.igeo.pt",EPSG,2003-08-14,2003.232,0,"D_Lisbon_1890"
9300,Astra Minas,engineering,"Origin at 45 deg 59 min 54.79 sec S; 67 deg 34 min 38.94 sec W.",,,,1265,Oil industry mapping.,,,EPSG,2000-03-07,,0,
9301,Barcelona,engineering,"Centre of the gateway of San Cristobal chuch; Plaza Boyaca; Barcelona.",,,,1266,Oil industry mapping.,Coordinates variously given as 10deg 08min 06sec N 64deg 41min 17sec W and 10deg 08min 06sec N 64deg 41min 07.5sec W. It is not clear whether there should be two local datums.,"Ministry of Mines standards manual, 1974.",EPSG,2000-03-07,,0,
9302,Maturin,engineering,"Concrete post PR-1 in Plaza Bolivar; Maturin. 9deg 44min 55sec N 63deg 10min 40sec W.",,,,1320,Oil industry mapping.,,"Ministry of Mines standards manual, 1974.",EPSG,2000-06-10,,0,
Index: pcs.csv
RCS file: /grassrepository/grass6/lib/proj/pcs.csv,v
retrieving revision 1.4.4.3
retrieving revision 1.4.4.4
diff -u -d -r1.4.4.3 -r1.4.4.4
--- pcs.csv 23 Oct 2006 22:28:30 -0000 1.4.4.3
+++ pcs.csv 20 Nov 2007 21:30:46 -0000 1.4.4.4
@@ -1,219 +1,219 @@
"COORD_REF_SYS_CODE","COORD_REF_SYS_NAME","UOM_CODE","SOURCE_GEOGCRS_CODE","COORD_OP_CODE","COORD_OP_METHOD_CODE","SHOW_CRS","DEPRECATED","PARAMETER_CODE_1","PARAMETER_VALUE_1","PARAMETER_UOM_1","PARAMETER_CODE_2","PARAMETER_VALUE_2","PARAMETER_UOM_2","PARAMETER_CODE_3","PARAMETER_VALUE_3","PARAMETER_UOM_3","PARAMETER_CODE_4","PARAMETER_VALUE_4","PARAMETER_UOM_4","PARAMETER_CODE_5","PARAMETER_VALUE_5","PARAMETER_UOM_5","PARAMETER_CODE_6","PARAMETER_VALUE_6","PARAMETER_UOM_6","PARAMETER_CODE_7","PARAMETER_VALUE_7","PARAMETER_UOM_7"
-2000,"Anguilla 1957 / British West Indies Grid",9001,4600,19942,9807,1,0,8801,0,9102,8802,-62,9102,8805,0.9995,9201,8806,400000,9001,8807,0,9001,,,,,,
-2001,"Antigua 1943 / British West Indies Grid",9001,4601,19942,9807,1,0,8801,0,9102,8802,-62,9102,8805,0.9995,9201,8806,400000,9001,8807,0,9001,,,,,,
-2002,"Dominica 1945 / British West Indies Grid",9001,4602,19942,9807,1,0,8801,0,9102,8802,-62,9102,8805,0.9995,9201,8806,400000,9001,8807,0,9001,,,,,,
-2003,"Grenada 1953 / British West Indies Grid",9001,4603,19942,9807,1,0,8801,0,9102,8802,-62,9102,8805,0.9995,9201,8806,400000,9001,8807,0,9001,,,,,,
-2004,"Montserrat 1958 / British West Indies Grid",9001,4604,19942,9807,1,0,8801,0,9102,8802,-62,9102,8805,0.9995,9201,8806,400000,9001,8807,0,9001,,,,,,
-2005,"St. Kitts 1955 / British West Indies Grid",9001,4605,19942,9807,1,0,8801,0,9102,8802,-62,9102,8805,0.9995,9201,8806,400000,9001,8807,0,9001,,,,,,
-2006,"St. Lucia 1955 / British West Indies Grid",9001,4606,19942,9807,1,0,8801,0,9102,8802,-62,9102,8805,0.9995,9201,8806,400000,9001,8807,0,9001,,,,,,
-2007,"St. Vincent 45 / British West Indies Grid",9001,4607,19942,9807,1,0,8801,0,9102,8802,-62,9102,8805,0.9995,9201,8806,400000,9001,8807,0,9001,,,,,,
-2008,"NAD27(CGQ77) / SCoPQ zone 2",9001,4609,17700,9807,1,0,8801,0,9110,8802,-55.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
-2009,"NAD27(CGQ77) / SCoPQ zone 3",9001,4609,17703,9807,1,0,8801,0,9110,8802,-58.3,9110,8805,0.9999,9201,8806,304800,9001,8807,0,9001,,,,,,
[...4922 lines suppressed...]
+32743,"WGS 84 / UTM zone 43S",9001,4326,16143,9807,1,0,8806,500000,9001,8805,0.9996,9201,8802,75,9102,8801,0,9102,8807,10000000,9001,,,,,,
+32744,"WGS 84 / UTM zone 44S",9001,4326,16144,9807,1,0,8801,0,9102,8807,10000000,9001,8802,81,9102,8806,500000,9001,8805,0.9996,9201,,,,,,
+32745,"WGS 84 / UTM zone 45S",9001,4326,16145,9807,1,0,8801,0,9102,8806,500000,9001,8805,0.9996,9201,8802,87,9102,8807,10000000,9001,,,,,,
+32746,"WGS 84 / UTM zone 46S",9001,4326,16146,9807,1,0,8807,10000000,9001,8806,500000,9001,8805,0.9996,9201,8802,93,9102,8801,0,9102,,,,,,
+32747,"WGS 84 / UTM zone 47S",9001,4326,16147,9807,1,0,8802,99,9102,8801,0,9102,8805,0.9996,9201,8807,10000000,9001,8806,500000,9001,,,,,,
+32748,"WGS 84 / UTM zone 48S",9001,4326,16148,9807,1,0,8802,105,9102,8801,0,9102,8807,10000000,9001,8806,500000,9001,8805,0.9996,9201,,,,,,
+32749,"WGS 84 / UTM zone 49S",9001,4326,16149,9807,1,0,8807,10000000,9001,8806,500000,9001,8801,0,9102,8805,0.9996,9201,8802,111,9102,,,,,,
+32750,"WGS 84 / UTM zone 50S",9001,4326,16150,9807,1,0,8801,0,9102,8805,0.9996,9201,8802,117,9102,8806,500000,9001,8807,10000000,9001,,,,,,
+32751,"WGS 84 / UTM zone 51S",9001,4326,16151,9807,1,0,8805,0.9996,9201,8802,123,9102,8801,0,9102,8807,10000000,9001,8806,500000,9001,,,,,,
+32752,"WGS 84 / UTM zone 52S",9001,4326,16152,9807,1,0,8801,0,9102,8807,10000000,9001,8802,129,9102,8806,500000,9001,8805,0.9996,9201,,,,,,
+32753,"WGS 84 / UTM zone 53S",9001,4326,16153,9807,1,0,8805,0.9996,9201,8802,135,9102,8801,0,9102,8806,500000,9001,8807,10000000,9001,,,,,,
+32754,"WGS 84 / UTM zone 54S",9001,4326,16154,9807,1,0,8806,500000,9001,8805,0.9996,9201,8802,141,9102,8801,0,9102,8807,10000000,9001,,,,,,
+32755,"WGS 84 / UTM zone 55S",9001,4326,16155,9807,1,0,8802,147,9102,8801,0,9102,8805,0.9996,9201,8807,10000000,9001,8806,500000,9001,,,,,,
+32756,"WGS 84 / UTM zone 56S",9001,4326,16156,9807,1,0,8805,0.9996,9201,8802,153,9102,8801,0,9102,8807,10000000,9001,8806,500000,9001,,,,,,
+32757,"WGS 84 / UTM zone 57S",9001,4326,16157,9807,1,0,8807,10000000,9001,8806,500000,9001,8801,0,9102,8805,0.9996,9201,8802,159,9102,,,,,,
+32758,"WGS 84 / UTM zone 58S",9001,4326,16158,9807,1,0,8805,0.9996,9201,8802,165,9102,8801,0,9102,8806,500000,9001,8807,10000000,9001,,,,,,
+32759,"WGS 84 / UTM zone 59S",9001,4326,16159,9807,1,0,8807,10000000,9001,8806,500000,9001,8805,0.9996,9201,8802,171,9102,8801,0,9102,,,,,,
+32760,"WGS 84 / UTM zone 60S",9001,4326,16160,9807,1,0,8802,177,9102,8801,0,9102,8807,10000000,9001,8806,500000,9001,8805,0.9996,9201,,,,,,
+32761,"WGS 84 / UPS South",9001,4326,16161,9810,1,0,8801,-90,9102,8806,2000000,9001,8805,0.994,9201,8802,0,9102,8807,2000000,9001,,,,,,
+32766,"WGS 84 / TM 36 SE",9001,4326,16636,9807,1,0,8806,500000,9001,8802,36,9102,8801,0,9102,8807,10000000,9001,8805,0.9996,9201,,,,,,
Index: projop_wparm.csv
RCS file: /grassrepository/grass6/lib/proj/projop_wparm.csv,v
retrieving revision 1.3.4.2
retrieving revision 1.3.4.3
diff -u -d -r1.3.4.2 -r1.3.4.3
--- projop_wparm.csv 18 Oct 2006 07:32:07 -0000 1.3.4.2
+++ projop_wparm.csv 20 Nov 2007 21:30:46 -0000 1.3.4.3
@@ -97,6 +97,7 @@
11851,Maine CS2000 East zone,9807,8801,43.5,9110,8802,-67.523,9110,8805,0.99998,9201,8806,700000,9001,8807,0,9001,,,,,,
11852,Maine CS2000 Central zone,9807,8801,43,9110,8802,-69.073,9110,8805,0.99998,9201,8806,500000,9001,8807,0,9001,,,,,,
11853,Maine CS2000 West zone,9807,8801,42.5,9110,8802,-70.223,9110,8805,0.99998,9201,8806,300000,9001,8807,0,9001,,,,,,
+11854,Maine CS2000 Central zone,9807,8801,43.3,9110,8802,-69.073,9110,8805,0.99998,9201,8806,500000,9001,8807,0,9001,,,,,,
11900,Maryland CS27,9802,8821,37.5,9110,8822,-77,9110,8823,38.18,9110,8824,39.27,9110,8826,800000,9003,8827,0,9003,,,
11930,"SPCS83 Maryland zone (meters)",9802,8821,37.4,9110,8822,-77,9110,8823,39.27,9110,8824,38.18,9110,8826,400000,9001,8827,0,9001,,,
12001,Massachusetts CS27 Mainland zone,9802,8821,41,9110,8822,-71.3,9110,8823,41.43,9110,8824,42.41,9110,8826,600000,9003,8827,0,9003,,,
@@ -170,6 +171,8 @@
13402,Ohio CS27 South zone,9802,8821,38,9110,8822,-82.3,9110,8823,38.44,9110,8824,40.02,9110,8826,2000000,9003,8827,0,9003,,,
13431,"SPCS83 Ohio North zone (meters)",9802,8821,39.4,9110,8822,-82.3,9110,8823,41.42,9110,8824,40.26,9110,8826,600000,9001,8827,0,9001,,,
13432,"SPCS83 Ohio South zone (meters)",9802,8821,38,9110,8822,-82.3,9110,8823,40.02,9110,8824,38.44,9110,8826,600000,9001,8827,0,9001,,,
[...2040 lines suppressed...]
+19986,Europe Equal Area 2001,9820,8802,10,9102,8801,52,9102,8807,3210000,9001,8806,4321000,9001,,,,,,,,,
+19987,Iceland Lambert 1900,9826,8807,0,9001,8801,65,9110,8802,-19.011965,9110,8806,0,9001,8805,1,9201,,,,,,
+19988,Iceland Lambert 1955,9826,8802,-18,9102,8805,1,9201,8801,65,9102,8806,500000,9001,8807,500000,9001,,,,,,
+19989,Iceland Lambert 1993,9802,8823,64.15,9110,8826,500000,9001,8821,65,9110,8822,-19,9110,8824,65.45,9110,8827,500000,9001,,,
+19990,Latvian Transverse Mercator,9807,8807,-6000000,9001,8805,0.9996,9201,8802,24,9102,8801,0,9102,8806,500000,9001,,,,,,
+19991,Jan Mayen Grid,9807,8802,-8.3,9110,8806,50000,9001,8807,-7800000,9001,8801,0,9110,8805,1,9201,,,,,,
+19992,Antarctic Polar Stereographic,9829,8833,0,9102,8807,0,9001,8806,0,9001,8832,-71,9102,,,,,,,,,
19993,Australian Antarctic Polar Stereographic,9829,8806,6000000,9001,8807,6000000,9001,8832,-71,9102,8833,70,9102,,,,,,,,,
-19994,Australian Antarctic Lambert,9802,8821,-50,9110,8822,70,9110,8823,-68.3,9110,8824,-74.3,9110,8826,6000000,9001,8827,6000000,9001,,,
-19995,Jordan Transverse Mercator,9807,8801,0,9102,8802,37,9102,8805,0.9998,9201,8806,500000,9001,8807,-3000000,9001,,,,,,
-19996,Soldner Berlin,9806,8801,52.25071338,9110,8802,13.37379332,9110,8806,40000,9001,8807,10000,9001,,,,,,,,,
-19997,Kuwait Transverse Mercator,9807,8801,0,9102,8802,48,9102,8805,1,9201,8806,500000,9001,8807,0,9001,,,,,,
-19998,Guernsey Grid,9807,8801,49.3,9110,8802,-2.25,9110,8805,0.999997,9201,8806,47000,9001,8807,50000,9001,,,,,,
-19999,Jersey Transverse Mercator,9807,8801,49.225,9102,8802,-2.135,9102,8805,0.9999999,9201,8806,40000,9001,8807,70000,9001,,,,,,
+19994,Australian Antarctic Lambert,9802,8822,70,9110,8827,6000000,9001,8823,-68.3,9110,8821,-50,9110,8824,-74.3,9110,8826,6000000,9001,,,
+19995,Jordan Transverse Mercator,9807,8807,-3000000,9001,8802,37,9102,8806,500000,9001,8801,0,9102,8805,0.9998,9201,,,,,,
+19996,Soldner Berlin,9806,8806,40000,9001,8807,10000,9001,8802,13.37379332,9110,8801,52.25071338,9110,,,,,,,,,
+19997,Kuwait Transverse Mercator,9807,8805,1,9201,8801,0,9102,8806,500000,9001,8807,0,9001,8802,48,9102,,,,,,
+19998,Guernsey Grid,9807,8802,-2.25,9110,8806,47000,9001,8801,49.3,9110,8807,50000,9001,8805,0.999997,9201,,,,,,
+19999,Jersey Transverse Mercator,9807,8801,49.225,9102,8805,0.9999999,9201,8802,-2.135,9102,8807,70000,9001,8806,40000,9001,,,,,,
Index: unit_of_measure.csv
RCS file: /grassrepository/grass6/lib/proj/unit_of_measure.csv,v
--- unit_of_measure.csv 18 Oct 2006 07:32:07 -0000 1.3.4.2
+++ unit_of_measure.csv 20 Nov 2007 21:30:46 -0000 1.3.4.3
@@ -28,20 +28,20 @@
9070,British foot (1865),length,9001,0.9144025,3,Uses Clark's estimate of 1853-1865 British foot-metre ratio of 0.9144025 metres per yard. Used in 1962 and 1975 estimates of Indian foot.,"J.S.Clark; ""Remeasurement of the Old Length Standards""; Empire Survey Review no. 90; 1953.",EPSG,2000-05-07,97.233 99.99,0
9080,Indian foot,length,9001,12,39.370142,Indian Foot = 0.99999566 British feet (A.R.Clarke 1865). British yard (= 3 British feet) taken to be J.S.Clark's 1865 value of 0.9144025 metres.,"G. Bomford; ""The Re-adjustment of the Indian Triangulation""; Survey of India Professional Paper 28; 1939.",EPSG,2000-05-07,97.231 99.99,0
9081,Indian foot (1937),length,9001,0.30479841,1,Indian Foot = 0.99999566 British feet (A.R.Clarke 1865). British foot taken to be 1895 Benoit value of 12/39.370113m. Rounded to 8 decimal places as 0.30479841. Used from Bangladesh to Vietnam. Previously used in India and Pakistan but superseded.,"G. Bomford; ""The Re-adjustment of the Indian Triangulation""; Survey of India Professional Paper 28; 1939.",EPSG,2000-05-07,97.231 99.99,0
-9082,Indian foot (1962),length,9001,0.3047996,1,Indian Foot = 0.99999566 British feet (A.R.Clarke 1865). British yard (3 feet) taken to be J.S. Clark's 1865 value of 0.9144025m. Rounded to 8 significant figures with a small error as 1 Ind ft=0.3048996m. Used in Pakistan since metrication.,"G. Bomford; ""Geodesy""; 2nd edition 1962",EPSG,2000-05-07,97.231 99.99,0
-9083,Indian foot (1975),length,9001,0.3047995,1,Indian Foot = 0.99999566 British feet (A.R.Clarke 1865). British yard (3 feet) taken to be J.S. Clark's 1865 value of 0.9144025m. Rounded to 8 significant figures as 1 Ind ft=0.3048995m. Used in India since metrication.,"G. Bomford; ""Geodesy""; 3rd edition 1975",EPSG,2000-05-07,97.231 99.99,0
+9082,Indian foot (1962),length,9001,0.3047996,1,Indian Foot = 0.99999566 British feet (A.R.Clarke 1865). British yard (3 feet) taken to be J.S. Clark's 1865 value of 0.9144025m. Rounded to 7 significant figures with a small error as 1 Ind ft=0.3047996m. Used in Pakistan since metrication.,"G. Bomford; ""Geodesy""; 2nd edition 1962",EPSG,2007-01-25,97.231 99.99 2007.011,0
+9083,Indian foot (1975),length,9001,0.3047995,1,Indian Foot = 0.99999566 British feet (A.R.Clarke 1865). British yard (3 feet) taken to be J.S. Clark's 1865 value of 0.9144025m. Rounded to 7 significant figures as 1 Ind ft=0.3047995m. Used in India since metrication.,"G. Bomford; ""Geodesy""; 3rd edition 1975",EPSG,2007-01-25,97.231 99.99 2007.011,0
9084,Indian yard,length,9001,36,39.370142,Indian Foot = 0.99999566 British feet (A.R.Clarke 1865). British yard (= 3 British feet) taken to be J.S.Clark's 1865 value of 0.9144025 metres.,"G. Bomford; ""The Re-adjustment of the Indian Triangulation""; Survey of India Professional Paper 28; 1939.",EPSG,2000-05-07,97.231 99.99,0
9085,Indian yard (1937),length,9001,0.91439523,1,Indian Foot = 0.99999566 British feet (A.R.Clarke 1865). British foot taken to be 1895 Benoit value of 12/39.370113m. Rounded to 8 decimal places as 0.30479841. Used from Bangladesh to Vietnam. Previously used in India and Pakistan but superseded.,"G. Bomford; ""The Re-adjustment of the Indian Triangulation""; Survey of India Professional Paper 28; 1939.",EPSG,2000-05-07,97.231 99.99,0
-9086,Indian yard (1962),length,9001,0.9143988,1,Indian Foot = 0.99999566 British feet (A.R.Clarke 1865). British yard (3 feet) taken to be J.S. Clark's 1865 value of 0.9144025m. Rounded to 8 significant figures with a small error as 1 Ind ft=0.3048996m. Used in Pakistan since metrication.,"G. Bomford; ""Geodesy""; 2nd edition 1962",EPSG,2000-05-07,97.231 99.99,0
-9087,Indian yard (1975),length,9001,0.9143985,1,Indian Foot = 0.99999566 British feet (A.R.Clarke 1865). British yard (3 feet) taken to be J.S. Clark's 1865 value of 0.9144025m. Rounded to 8 significant figures as 1 Ind ft=0.3048995m. Used in India since metrication.,"G. Bomford; ""Geodesy""; 3rd edition 1975",EPSG,2000-05-07,97.231 99.99,0
+9086,Indian yard (1962),length,9001,0.9143988,1,Indian Foot = 0.99999566 British feet (A.R.Clarke 1865). British yard (3 feet) taken to be J.S. Clark's 1865 value of 0.9144025m. Rounded to 7 significant figures with a small error as 1 Ind ft=0.3047996m. Used in Pakistan since metrication.,"G. Bomford; ""Geodesy""; 2nd edition 1962",EPSG,2007-01-25,97.231 99.99 2007.011,0
+9087,Indian yard (1975),length,9001,0.9143985,1,Indian Foot = 0.99999566 British feet (A.R.Clarke 1865). British yard (3 feet) taken to be J.S. Clark's 1865 value of 0.9144025m. Rounded to 7 significant figures as 1 Ind ft=0.3047995m. Used in India since metrication.,"G. Bomford; ""Geodesy""; 3rd edition 1975",EPSG,2007-01-25,97.231 99.99 2007.011,0
9093,Statute mile,length,9001,1609.344,1,=5280 feet,EPSG,EPSG,2000-03-07,,0
9094,Gold Coast foot,length,9001,6378300,20926201,"Used in Ghana and some adjacent parts of British west Africa prior to metrication, except for the metrication of projection defining parameters when British foot (Sears 1922) used.",Ordnance Survey International,EPSG,2001-01-21,2000.86,0
-9095,British foot (1936),length,9001,0.3048007491,1,For the 1936 retriangulation OSGB defines the relationship of feet of 1796 to the International metre through log(1.48401603) exactly [=0.3048007491...]. Also used for metric conversions in Ireland.,"1. ""The Retriangulation of Great Britain"", Ordnance Survey of Great Britain.
-2. ""The Irish Grid - A Description of the Co-ordinate Reference System"" published by Ordnance Survey of Ireland, Dublin and Ordnance Survey of Northern Ireland, Belfast.",EPSG,2003-06-27,2002.621,0
+9095,British foot (1936),length,9001,0.3048007491,1,For the 1936 retriangulation OSGB defines the relationship of 10 feet of 1796 to the International metre through the logarithmic relationship (10^0.48401603 exactly). 1 ft = 0.3048007491Â
m. Also used for metric conversions in Ireland.,"1. ""The Retriangulation of Great Britain"", Ordnance Survey of Great Britain.
+2. ""The Irish Grid - A Description of the Co-ordinate Reference System"" published by Ordnance Survey of Ireland, Dublin and Ordnance Survey of Northern Ireland, Belfast.",EPSG,2006-11-27,2002.621 2006.932,0
9096,yard,length,9001,0.9144,1,=3 international feet.,OGP,OGP,2006-07-14,,0
9097,chain,length,9001,20.1168,1,=22 international yards or 66 international feet.,OGP,OGP,2006-07-14,,0
9098,link,length,9001,20.1168,100,=1/100 international chain.,OGP,OGP,2006-07-14,,0
-9099,British yard (Sears 1922 truncated),length,9001,0.914398,1,Uses Sear's 1922 British yard-metre ratio truncated to 6 significant figures. Used in metrication of Malaya RSO grid.,Defence Geographic Centre,OGP,2006-07-24,,0
+9099,British yard (Sears 1922 truncated),length,9001,0.914398,1,Uses Sear's 1922 British yard-metre ratio (UoM code 9040) truncated to 6 significant figures.,Defence Geographic Centre,OGP,2006-10-23,2006.901,0
9101,radian,angle,9101,1,1,SI standard unit.,ISO 1000:1992,EPSG,1995-06-02,,0
9102,degree,angle,9101,3.14159265358979,180,= pi/180 radians,,EPSG,2002-11-18,96.22 2002.86,0
9103,arc-minute,angle,9101,3.14159265358979,10800,1/60th degree = ((pi/180) / 60) radians,,EPSG,2002-11-18,96.22 2002.86,0
@@ -75,6 +75,6 @@
9209,Bin width 12.5 metres,length,9001,12.5,1,,EPSG,EPSG,2000-10-19,2000.59,0
9210,Bin width 6.25 metres,length,9001,6.25,1,,EPSG,EPSG,2000-10-19,2000.59,0
9211,Bin width 3.125 metres,length,9001,3.125,1,,EPSG,EPSG,2000-10-19,2000.59,0
-9300,British foot (Sears 1922 truncated),length,9001,0.304799333333333,1,Uses Sear's 1922 British yard-metre ratio truncated to 6 significant figures. Used in metrication of Malaya RSO grid.,Defence Geographic Centre,OGP,2006-07-24,,0
-9301,British chain (Sears 1922 truncated),length,9001,20.116756,1,Uses Sear's 1922 British yard-metre ratio truncated to 6 significant figures. Used in metrication of Malaya RSO grid.,Defence Geographic Centre,OGP,2006-07-24,,0
-9302,British link (Sears 1922 truncated),length,9001,0.20116756,1,Uses Sear's 1922 British yard-metre ratio truncated to 6 significant figures. Used in metrication of Malaya RSO grid.,Defence Geographic Centre,OGP,2006-07-24,,0
+9300,British foot (Sears 1922 truncated),length,9001,0.914398,3,"Uses Sear's 1922 British yard-metre ratio (UoM code 9040) truncated to 6 significant figures; this truncated ratio (0.914398, UoM code 9099) then converted to other imperial units. 3 ftSe(T) = 1 ydSe(T).",Defence Geographic Centre,OGP,2006-10-23,2006.901,0
+9301,British chain (Sears 1922 truncated),length,9001,20.116756,1,"Uses Sear's 1922 British yard-metre ratio (UoM code 9040) truncated to 6 significant figures; this truncated ratio (0.914398, UoM code 9099) then converted to other imperial units. 1 chSe(T) = 22 ydSe(T). Used in metrication of Malaya RSO grid.",Defence Geographic Centre,OGP,2006-10-23,2006.901,0
+9302,British link (Sears 1922 truncated),length,9001,20.116756,100,"Uses Sear's 1922 British yard-metre ratio (UoM code 9040) truncated to 6 significant figures; this truncated ratio (0.914398, UoM code 9099) then converted to other imperial units. 100 lkSe(T) = 1 chSe(T).",Defence Geographic Centre,OGP,2006-10-23,2006.901,0
