[GRASS-CVS] hamish: grass6/vector/v.in.ogr description.html, 1.33,
1.34
grass at intevation.de
Tue Nov 20 20:51:26 EST 2007
- Previous message: [GRASS-CVS] markus: grass6/lib/proj gcs.override.csv, NONE,
1.1.4.1 pcs.override.csv, NONE, 1.1.4.1 ellipsoid.csv, 1.3.4.2,
1.3.4.3 gcs.csv, 1.4.4.3, 1.4.4.4 gdal_datum.csv, 1.3.4.3,
1.3.4.4 pcs.csv, 1.4.4.3, 1.4.4.4 projop_wparm.csv, 1.3.4.2,
1.3.4.3 unit_of_measure.csv, 1.3.4.2, 1.3.4.3
- Next message: [GRASS-CVS] hamish: grass6/raster/r.los description.html,1.5,1.6
- Messages sorted by:
[ date ]
[ thread ]
[ subject ]
[ author ]
Author: hamish
Update of /grassrepository/grass6/vector/v.in.ogr
In directory doto:/tmp/cvs-serv1737
Modified Files:
description.html
Log Message:
document shapefile.shp as dsn
Index: description.html
RCS file: /grassrepository/grass6/vector/v.in.ogr/description.html,v
retrieving revision 1.33
retrieving revision 1.34
diff -u -d -r1.33 -r1.34
--- description.html 5 Nov 2007 07:14:15 -0000 1.33
+++ description.html 21 Nov 2007 01:51:23 -0000 1.34
@@ -64,6 +64,11 @@
<ul>
<li><B>SHAPE files</B>
<div class="code"><pre>
+v.in.ogr dsn=/home/user/shape_data/test_shape.shp output=grass_map
+</pre></div>
+Alternate method:
+<div class="code"><pre>
v.in.ogr dsn=/home/user/shape_data layer=test_shape output=grass_map
</pre></div>
<BR>
[ date ]
[ thread ]
[ subject ]
[ author ]
