[GRASS-CVS] markus: grass6/lib/cairodriver read.c, NONE,
1.1.2.1 read_bmp.c, NONE, 1.1.2.1 read_ppm.c, NONE,
1.1.2.1 write_bmp.c, NONE, 1.1.2.1 write_ppm.c, NONE,
1.1.2.1 Draw_bitmap.c, 1.1.2.1, 1.1.2.2 Graph.c, 1.1.2.1,
1.1.2.2 Makefile, 1.1.2.1, 1.1.2.2 Raster.c, 1.1.2.1,
1.1.2.2 cairodriver.h, 1.1.2.1, 1.1.2.2 write.c, 1.1.2.1, 1.1.2.2
grass at intevation.de
Fri Nov 23 05:47:15 EST 2007
Author: markus
Update of /grassrepository/grass6/lib/cairodriver
In directory doto:/tmp/cvs-serv11882
Modified Files:
Tag: releasebranch_6_3
Draw_bitmap.c Graph.c Makefile Raster.c cairodriver.h write.c
Added Files:
read.c read_bmp.c read_ppm.c write_bmp.c write_ppm.c
Log Message:
various fixes merged from HEAD
--- NEW FILE: read.c ---
#include "cairodriver.h"
void read_image(void)
G_debug(1, "read_image");
if (!cairo || !surface)
return;
if (file_type == FTYPE_PPM)
G_debug(1, "Reading image from %s", file_name);
read_ppm();
else if (file_type == FTYPE_BMP)
read_bmp();
#if CAIRO_HAS_PNG_FUNCTIONS
else if (file_type == FTYPE_PNG)
cairo_surface_t *img_surf;
img_surf = cairo_image_surface_create_from_png(file_name);
if (!img_surf)
return;
cairo_save(cairo);
cairo_set_source_surface(cairo, img_surf, 0, 0);
cairo_paint(cairo);
cairo_restore(cairo);
cairo_surface_destroy(img_surf);
#endif
/* vector format files are written directly to file */
modified = 0;
--- NEW FILE: read_bmp.c ---
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <grass/gis.h>
static unsigned int get_2(const unsigned char **q)
const unsigned char *p = *q;
unsigned int n = (p[0] << 0) | (p[1] << 8);
*q += 2;
return n;
static unsigned int get_4(const unsigned char **q)
unsigned int n = (p[0] << 0) | (p[1] << 8) | (p[2] << 16) | (p[3] << 24);
*q += 4;
return n;
static int read_bmp_header(const unsigned char *p)
if (*p++ != 'B')
return 0;
if (*p++ != 'M')
return 0;
if (get_4(&p) != HEADER_SIZE + width * height * 4)
return 0;
get_4(&p);
if (get_4(&p) != HEADER_SIZE)
return 0;
if (get_4(&p) != 40)
return 0;
if (get_4(&p) != width)
return 0;
if (get_4(&p) != -height)
return 0;
get_2(&p);
if (get_2(&p) != 32)
return 0;
if (get_4(&p) != 0)
return 0;
if (get_4(&p) != width * height * 4)
return 0;
get_4(&p);
get_4(&p);
get_4(&p);
get_4(&p);
return 1;
void read_bmp(void)
char header[HEADER_SIZE];
FILE *input;
int x, y;
input = fopen(file_name, "rb");
if (!input)
G_fatal_error("cairo:: couldn't open input file %s", file_name);
if (fread(header, sizeof(header), 1, input) != 1)
G_fatal_error("cairo:: invalid input file %s", file_name);
if (!read_bmp_header(header))
G_fatal_error("cairo:: invalid BMP header for %s", file_name);
fread(grid, stride, height, input);
fclose(input);
--- NEW FILE: read_ppm.c ---
void read_ppm(void)
char *mask_name = G_store(file_name);
FILE *input, *mask;
int x, y;
int i_width, i_height, maxval;
if (!input)
G_fatal_error("cairo: couldn't open input file %s", file_name);
if (fscanf(input, "P6 %d %d %d", &i_width, &i_height, &maxval) != 3)
G_fatal_error("cairo: invalid input file %s", file_name);
fgetc(input);
if (i_width != width || i_height != height)
G_fatal_error(
"cairo: input file has incorrect dimensions: expected: %dx%d got: %dx%d",
width, height, i_width, i_height);
mask_name[strlen(mask_name) - 2] = 'g';
input = fopen(mask_name, "rb");
if (!input)
G_fatal_error("cairo: couldn't open input mask file %s", mask_name);
if (fscanf(input, "P5 %d %d %d", &i_width, &i_height, &maxval) != 3)
G_fatal_error("cairo: invalid input mask file %s", mask_name);
fgetc(input);
G_fatal_error(
"cairo: input mask file has incorrect dimensions: expected: %dx%d got: %dx%d",
G_free(mask_name);
for (y = 0; y < height; y++)
unsigned int *row = (unsigned int *) (grid + y * stride);
for (x = 0; x < width; x++)
int r = fgetc(input);
int g = fgetc(input);
int b = fgetc(input);
int a = fgetc(mask);
r = r * 255 / maxval;
g = g * 255 / maxval;
b = b * 255 / maxval;
a = a * 255 / maxval;
if (a > 0 && a < 0xFF)
r = r * a / 0xFF;
g = g * a / 0xFF;
b = b * a / 0xFF;
row[x] = (a << 24) | (r << 16) | (g << 8) | (b << 0);
fclose(input);
fclose(mask);
--- NEW FILE: write_bmp.c ---
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
static unsigned char *put_2(unsigned char *p, unsigned int n)
*p++ = n & 0xFF; n >>= 8;
*p++ = n & 0xFF;
return p;
static unsigned char *put_4(unsigned char *p, unsigned int n)
*p++ = n & 0xFF;
return p;
static void make_bmp_header(unsigned char *p)
*p++ = 'B';
*p++ = 'M';
p = put_4(p, HEADER_SIZE + width * height * 4);
p = put_4(p, 0);
p = put_4(p, HEADER_SIZE);
p = put_4(p, 40);
p = put_4(p, width);
p = put_4(p, -height);
p = put_2(p, 1);
p = put_2(p, 32);
p = put_4(p, 0);
p = put_4(p, width * height * 4);
p = put_4(p, 0);
p = put_4(p, 0);
p = put_4(p, 0);
p = put_4(p, 0);
void write_bmp(void)
FILE *output;
int x, y;
output = fopen(file_name, "wb");
if (!output)
G_fatal_error("cairo: couldn't open output file %s", file_name);
make_bmp_header(header);
fwrite(header, sizeof(header), 1, output);
fwrite(grid, stride, height, output);
fclose(output);
--- NEW FILE: write_ppm.c ---
void write_ppm(void)
FILE *output, *mask;
int x, y;
if (!output)
mask = fopen(mask_name, "wb");
if (!mask)
G_fatal_error("cairo: couldn't open mask file %s", mask_name);
G_free(mask_name);
fprintf(output, "P6\n%d %d\n255\n", width, height);
fprintf(mask, "P5\n%d %d\n255\n", width, height);
const unsigned int *row = (const unsigned int *) (grid + y * stride);
unsigned int c = row[x];
int a = (c >> 24) & 0xFF;
int r = (c >> 16) & 0xFF;
int g = (c >> 8) & 0xFF;
int b = (c >> 0) & 0xFF;
r = r * 0xFF / a;
g = g * 0xFF / a;
b = b * 0xFF / a;
fputc((unsigned char) r, output);
fputc((unsigned char) g, output);
fputc((unsigned char) b, output);
fputc((unsigned char) a, mask);
fclose(output);
fclose(mask);
Index: Draw_bitmap.c
RCS file: /grassrepository/grass6/lib/cairodriver/Draw_bitmap.c,v
retrieving revision 1.1.2.1
retrieving revision 1.1.2.2
diff -u -d -r1.1.2.1 -r1.1.2.2
--- Draw_bitmap.c 24 Oct 2007 00:20:57 -0000 1.1.2.1
+++ Draw_bitmap.c 23 Nov 2007 10:47:12 -0000 1.1.2.2
@@ -1,5 +1,30 @@
+static cairo_surface_t *fix_surface(cairo_surface_t *src)
+ int width = cairo_image_surface_get_width(src);
+ int height = cairo_image_surface_get_height(src);
+ int stride = cairo_image_surface_get_stride(src);
+ cairo_format_t format = cairo_image_surface_get_format(src);
+ unsigned char *data = cairo_image_surface_get_data(src);
+ cairo_surface_t *dst = cairo_image_surface_create(format, width, height);
+ int stride2 = cairo_image_surface_get_stride(dst);
+ unsigned char *data2 = cairo_image_surface_get_data(dst);
+ int i;
+ for (i = 0; i < height; i++)
+ void *p = data + i * stride;
+ void *q = data2 + i * stride2;
+ int n = stride < stride2 ? stride : stride2;
+ memcpy(q, p, n);
+ cairo_surface_destroy(src);
+ return dst;
void Cairo_draw_bitmap(int ncols, int nrows, int threshold, const unsigned char *buf)
cairo_surface_t *surf;
@@ -11,6 +36,8 @@
if (cairo_surface_status(surf) != CAIRO_STATUS_SUCCESS)
G_fatal_error("Cairo_draw_bitmap: Failed to create source");
+ surf = fix_surface(surf);
cairo_mask_surface(cairo, surf, cur_x, cur_y);
Index: Graph.c
RCS file: /grassrepository/grass6/lib/cairodriver/Graph.c,v
--- Graph.c 24 Oct 2007 00:20:57 -0000 1.1.2.1
+++ Graph.c 23 Nov 2007 10:47:12 -0000 1.1.2.2
@@ -2,13 +2,30 @@
#include <cairo-ps.h>
#include <cairo-pdf.h>
#include <cairo-svg.h>
+#include <cairo-xlib.h>
+#ifndef __MINGW32__
+#include <unistd.h>
+#include <fcntl.h>
+#include <sys/types.h>
+#include <sys/stat.h>
+#include <sys/mman.h>
+#endif
+#if CAIRO_HAS_XLIB_SURFACE
+#include <X11/X.h>
+#include <X11/Xlib.h>
+#include <X11/Xutil.h>
+#endif
/* globals */
char *file_name;
int file_type;
-int width, height;
+int width, height, stride;
+unsigned char *grid;
int modified;
int auto_write;
+int mapped;
/* background color */
double bgcolor_r, bgcolor_g, bgcolor_b, bgcolor_a;
@@ -17,76 +34,190 @@
cairo_surface_t *surface;
cairo_t *cairo;
-int Cairo_Graph_set(int argc, char **argv)
+static void init_cairo(void);
+static int ends_with(const char *string, const char *suffix);
+static void map_file(void);
+static int init_xlib(void)
- char *c;
+ Display *dpy;
+ Drawable win;
+ unsigned long xid;
+ XVisualInfo templ;
+ XVisualInfo *vinfo;
+ int count;
+ Window root;
+ unsigned int depth;
+ int si;
+ unsigned int ui;
+ Visual *visual;
+ char *p;
- G_gisinit("Cairo driver");
- G_debug(1, "Cairo_Graph_set");
+ p = getenv("GRASS_CAIRO_DRAWABLE");
+ if (!p || sscanf(p, "%li", &xid) != 1)
+ G_fatal_error("invalid Drawable XID: %s", p);
+ win = xid;
+ dpy = XOpenDisplay(NULL);
+ if (!dpy)
+ G_fatal_error("Unable to open display");
+ p = getenv("GRASS_CAIRO_VISUAL");
+ G_fatal_error("invalid Visual XID: %s", p);
+ templ.visualid = xid;
+ vinfo = XGetVisualInfo(dpy, VisualIDMask, &templ, &count);
+ if (!vinfo || !count)
+ G_fatal_error("Unable to obtain visual");
+ visual = vinfo[0].visual;
+ if (!XGetGeometry(dpy, win, &root, &si, &si, &width, &height, &ui, &depth))
+ G_fatal_error("Unable to query drawable");
+ surface = cairo_xlib_surface_create(dpy, win, visual, width, height);
+ if (cairo_surface_status(surface) != CAIRO_STATUS_SUCCESS)
+ G_fatal_error("Failed to initialize Xlib surface");
+ cairo = cairo_create(surface);
+ file_name = "<X11>";
+ file_type = FTYPE_X11;
+ screen_right = screen_left + width;
+ screen_bottom = screen_top + height;
+ return 0;
+#endif
+static int init_file(void)
+ int do_read = 0;
+ int do_map = 0;
+ char *p;
/* set image properties */
width = screen_right - screen_left;
height = screen_bottom - screen_top;
- /* TODO: find out why G_getenv doesn't work */
+ stride = width * 4;
/* get file name */
- c = getenv("GRASS_CAIROFILE");
- if (!c || strlen(c) == 0)
- c = DEFAULT_FILE_NAME;
+ p = getenv("GRASS_CAIROFILE");
+ if (!p || strlen(p) == 0)
+ p = DEFAULT_FILE_NAME;
- file_name = c;
- G_message("CAIRO: collecting to file: %s\n GRASS_WIDTH=%d, GRASS_HEIGHT=%d", file_name, width, height);
+ file_name = p;
/* get file type (from extension) */
- if (ends_with(c, ".png"))
+ if (file_type == FTYPE_X11)
+ ; /* skip */
+ else if (ends_with(file_name, ".ppm"))
+ file_type = FTYPE_PPM;
+ else if (ends_with(file_name, ".bmp"))
+ file_type = FTYPE_BMP;
+#if CAIRO_HAS_PNG_FUNCTIONS
+ else if (ends_with(file_name, ".png"))
file_type = FTYPE_PNG;
+#endif
#if CAIRO_HAS_PDF_SURFACE
- else if (ends_with(c, ".pdf"))
+ else if (ends_with(file_name, ".pdf"))
file_type = FTYPE_PDF;
#endif
#if CAIRO_HAS_PS_SURFACE
- else if (ends_with(c, ".ps"))
+ else if (ends_with(file_name, ".ps"))
file_type = FTYPE_PS;
#endif
#if CAIRO_HAS_SVG_SURFACE
- else if (ends_with(c, ".svg"))
+ else if (ends_with(file_name, ".svg"))
file_type = FTYPE_SVG;
#endif
else
- G_fatal_error("Unknown file extension: %s", c);
- G_debug(1, "File type: %s (%d)", c, file_type);
+ G_fatal_error("Unknown file extension: %s", p);
+ G_debug(1, "File type: %s (%d)", file_name, file_type);
- c = getenv("GRASS_AUTO_WRITE");
- auto_write = c && strcmp(c, "TRUE") == 0;
+ p = getenv("GRASS_CAIRO_MAPPED");
+ do_map = p && strcmp(p, "TRUE") == 0 && ends_with(file_name, ".bmp");
+ p = getenv("GRASS_CAIRO_READ");
+ do_read = p && strcmp(p, "TRUE") == 0;
+ if (do_read && access(file_name, 0) != 0)
+ do_read = 0;
+ G_message("cairo: collecting to file: %s,\n GRASS_WIDTH=%d, GRASS_HEIGHT=%d",
+ file_name, width, height);
+ if (do_read && do_map)
+ map_file();
+ if (!mapped)
+ grid = G_malloc(height * stride);
+ init_cairo();
+ if (!do_read)
+ Cairo_Erase();
+ modified = 1;
+ if (do_read && !mapped)
+ read_image();
+ if (do_map && !mapped)
+ write_image();
+ map_file();
+ return 0;
+int Cairo_Graph_set(int argc, char **argv)
+ char *p;
+ G_gisinit("Cairo driver");
+ G_debug(1, "Cairo_Graph_set");
/* get background color */
- c = getenv("GRASS_BACKGROUNDCOLOR");
- if (c && *c)
+ p = getenv("GRASS_BACKGROUNDCOLOR");
+ if (p && *p)
unsigned int red, green, blue;
- if (sscanf(c, "%02x%02x%02x", &red, &green, &blue) == 3)
+ if (sscanf(p, "%02x%02x%02x", &red, &green, &blue) == 3)
bgcolor_r = CAIROCOLOR(red);
bgcolor_g = CAIROCOLOR(green);
bgcolor_b = CAIROCOLOR(blue);
else
- G_fatal_error("Unknown background color: %s", c);
+ G_fatal_error("Unknown background color: %s", p);
else
bgcolor_r = bgcolor_g = bgcolor_b = 1.0;
/* get background transparency setting */
- c = getenv("GRASS_TRANSPARENT");
- if (c && strcmp(c, "TRUE") == 0)
+ p = getenv("GRASS_TRANSPARENT");
+ if (p && strcmp(p, "TRUE") == 0)
bgcolor_a = 0.0;
else
bgcolor_a = 1.0;
- init_cairo();
- return 0;
+ p = getenv("GRASS_AUTO_WRITE");
+ auto_write = p && strcmp(p, "TRUE") == 0;
+ if (p)
+ return init_xlib();
+#endif
+ return init_file();
void Cairo_Graph_close(void)
@@ -107,15 +238,17 @@
-void init_cairo(void)
G_debug(1, "init_cairo");
/* create cairo surface */
switch (file_type)
+ case FTYPE_PPM:
+ case FTYPE_BMP:
case FTYPE_PNG:
- surface = cairo_image_surface_create(CAIRO_FORMAT_ARGB32, width, height);
+ surface = (cairo_surface_t *) cairo_image_surface_create_for_data(grid, CAIRO_FORMAT_ARGB32, width, height, stride);
break;
case FTYPE_PDF:
@@ -141,15 +274,44 @@
G_fatal_error("Failed to initialize Cairo surface");
- Cairo_Erase();
/* Returns TRUE if string ends with suffix (case insensitive) */
-int ends_with(const char *string, const char *suffix)
if (strlen(string) < strlen(suffix))
return FALSE;
return G_strcasecmp(suffix, string + strlen(string) - strlen(suffix)) == 0;
+ size_t size = HEADER_SIZE + width * height * sizeof(unsigned int);
+ void *ptr;
+ int fd;
+ fd = open(file_name, O_RDWR);
+ if (fd < 0)
+ return;
+ ptr = mmap(NULL, size, PROT_READ|PROT_WRITE, MAP_SHARED, fd, (off_t ) 0);
+ if (ptr == MAP_FAILED)
+ return;
+ if (grid)
+ cairo_destroy(cairo);
+ cairo_surface_destroy(surface);
+ G_free(grid);
+ grid = (char *) ptr + HEADER_SIZE;
+ init_cairo();
+ close(fd);
+ mapped = 1;
+#endif
Index: Makefile
RCS file: /grassrepository/grass6/lib/cairodriver/Makefile,v
--- Makefile 24 Oct 2007 00:20:57 -0000 1.1.2.1
+++ Makefile 23 Nov 2007 10:47:12 -0000 1.1.2.2
@@ -29,7 +29,12 @@
Raster.o \
Respond.o \
Color.o \
- write.o
+ read.o \
+ read_bmp.o \
+ read_ppm.o \
+ write.o \
+ write_bmp.o \
+ write_ppm.o
include $(MODULE_TOPDIR)/include/Make/Lib.make
Index: Raster.c
RCS file: /grassrepository/grass6/lib/cairodriver/Raster.c,v
--- Raster.c 24 Oct 2007 00:20:57 -0000 1.1.2.1
+++ Raster.c 23 Nov 2007 10:47:12 -0000 1.1.2.2
@@ -18,19 +18,21 @@
/* TODO: are top and left swapped? */
- src_r = s[0][1];
- src_b = s[1][1];
src_l = s[0][0];
+ src_r = s[0][1];
src_t = s[1][0];
- dst_r = d[0][1];
- dst_b = d[1][1];
+ src_b = s[1][1];
+ src_w = src_r - src_l;
+ src_h = src_b - src_t;
dst_l = d[0][0];
+ dst_r = d[0][1];
dst_t = d[1][0];
+ dst_b = d[1][1];
- src_h = src_b - src_t + 1;
- src_w = src_r - src_l + 1;
- dst_h = dst_b - dst_t + 1;
- dst_w = dst_r - dst_l + 1;
+ dst_w = dst_r - dst_l;
+ dst_h = dst_b - dst_t;
G_debug(1, " src (TBLR): %d %d %d %d, dst (TBLR) %d %d %d %d",
src_t, src_b, src_l, src_r, dst_t, dst_b, dst_l, dst_r);
@@ -48,7 +50,7 @@
int n, int row,
const unsigned char *red, const unsigned char *grn, const unsigned char *blu, const unsigned char *nul)
- unsigned int *dst = (unsigned int *) src_data + row * (src_stride >> 2);
+ unsigned int *dst = (unsigned int *) (src_data + (row - src_t) * src_stride);
int i;
G_debug(3, "Cairo_scaled_raster: %d %d", n, row);
@@ -74,8 +76,9 @@
/* paint source surface onto dstination (scaled) */
cairo_save(cairo);
+ cairo_translate(cairo, dst_l, dst_t);
cairo_scale(cairo, (double) dst_w / (double) src_w, (double) dst_h / (double) src_h);
- cairo_set_source_surface(cairo, src_surf, dst_l, dst_t);
+ cairo_set_source_surface(cairo, src_surf, 0, 0);
cairo_paint(cairo);
Index: cairodriver.h
RCS file: /grassrepository/grass6/lib/cairodriver/cairodriver.h,v
--- cairodriver.h 24 Oct 2007 00:20:57 -0000 1.1.2.1
+++ cairodriver.h 23 Nov 2007 10:47:12 -0000 1.1.2.2
@@ -14,28 +14,35 @@
#define DEFAULT_FILE_NAME "map.png"
+#define HEADER_SIZE 54
/* Scale for converting colors from [0..255] to cairo's [0.0..1.0] */
#define COLORSCALE (1.0/255.0)
#define CAIROCOLOR(a) (((double)(a))*COLORSCALE)
/* File types */
#define FTYPE_UNKNOWN 0
-#define FTYPE_PNG 1
-#define FTYPE_PDF 2
-#define FTYPE_PS 3
-#define FTYPE_SVG 4
+#define FTYPE_PPM 1
+#define FTYPE_BMP 2
+#define FTYPE_PNG 3
+#define FTYPE_PDF 4
+#define FTYPE_PS 5
+#define FTYPE_SVG 6
+#define FTYPE_X11 7
extern cairo_surface_t *surface;
extern cairo_t *cairo;
extern char *file_name;
extern int file_type;
-extern int width, height;
+extern int width, height, stride;
+extern unsigned char *grid;
extern int clip_left, clip_right, clip_top, clip_bottom;
extern int auto_write;
extern double bgcolor_r, bgcolor_g, bgcolor_b, bgcolor_a;
extern int modified;
+extern int mapped;
extern const struct driver *Cairo_Driver(void);
@@ -60,11 +67,13 @@
extern void Cairo_Polyline_abs(const int*, const int*, int);
extern void Cairo_Respond(void);
-/* Graph.c */
-extern void init_cairo(void);
-extern int ends_with(const char*, const char*);
+/* read.c */
+extern void read_image(void);
+extern void read_ppm(void);
+extern void read_bmp(void);
/* write.c */
extern void write_image(void);
+extern void write_ppm(void);
+extern void write_bmp(void);
#endif /* __CAIRODRIVER_H__ */
Index: write.c
RCS file: /grassrepository/grass6/lib/cairodriver/write.c,v
--- write.c 24 Oct 2007 00:20:57 -0000 1.1.2.1
+++ write.c 23 Nov 2007 10:47:12 -0000 1.1.2.2
@@ -1,5 +1,10 @@
+#endif
G_debug(1, "write_image");
@@ -7,15 +12,37 @@
if (!modified)
return;
- if (cairo && surface)
+ if (mapped)
+ return;
+ if (!cairo || !surface)
+ return;
+ if (file_type == FTYPE_PPM)
- if (file_type == FTYPE_PNG)
- G_debug(1, "Writing image to %s", file_name);
- cairo_surface_write_to_png(surface, file_name);
- /* vector format files are written directly to file */
+ G_debug(1, "Writing image to %s", file_name);
+ write_ppm();
+ else if (file_type == FTYPE_BMP)
+ write_bmp();
+ else if (file_type == FTYPE_PNG)
+ cairo_surface_write_to_png(surface, file_name);
+#endif
+ else if (file_type == FTYPE_X11)
+ XFlush(cairo_xlib_surface_get_display(surface));
+#endif
+ /* vector format files are written directly to file */
modified = 0;
