[GRASS-CVS] markus: grass6/lib/gis getl.c,2.6,2.6.2.1
grass at intevation.de
Fri Nov 23 08:16:46 EST 2007
- Previous message: [GRASS-CVS] markus: grass6/lib/cairodriver read.c, NONE,
1.1.2.1 read_bmp.c, NONE, 1.1.2.1 read_ppm.c, NONE,
1.1.2.1 write_bmp.c, NONE, 1.1.2.1 write_ppm.c, NONE,
1.1.2.1 Draw_bitmap.c, 1.1.2.1, 1.1.2.2 Graph.c, 1.1.2.1,
1.1.2.2 Makefile, 1.1.2.1, 1.1.2.2 Raster.c, 1.1.2.1,
1.1.2.2 cairodriver.h, 1.1.2.1, 1.1.2.2 write.c, 1.1.2.1, 1.1.2.2
- Next message: [GRASS-CVS] moritz: grass6/scripts/d.vect.thematic d.vect.thematic,
1.56, 1.57
- Messages sorted by:
[ date ]
[ thread ]
[ subject ]
[ author ]
Author: markus
Update of /grassrepository/grass6/lib/gis
In directory doto:/tmp/cvs-serv15139
Modified Files:
Tag: releasebranch_6_3
getl.c
Log Message:
Include trailing NUL in buffer size
Use \r,\n instead of octal constants (merge from HEAD)
Index: getl.c
RCS file: /grassrepository/grass6/lib/gis/getl.c,v
retrieving revision 2.6
retrieving revision 2.6.2.1
diff -u -d -r2.6 -r2.6.2.1
--- getl.c 12 Nov 2006 04:05:02 -0000 2.6
+++ getl.c 23 Nov 2007 13:16:44 -0000 2.6.2.1
@@ -55,7 +55,7 @@
int c;
int ret = 1;
- while ( i < n ) {
+ while ( i < n - 1 ) {
c = fgetc(fd);
if ( c == EOF ) {
@@ -65,11 +65,11 @@
break;
- if ( c == '\012' ) break; /* UNIX */
+ if ( c == '\n' ) break; /* UNIX */
- if ( c == '\015' ) { /* DOS or MacOS9 */
+ if ( c == '\r' ) { /* DOS or MacOS9 */
if ( (c = fgetc(fd) ) != EOF ) {
- if ( c != '\012' ) { /* MacOS9 - we have to return the char to stream */
+ if ( c != '\n' ) { /* MacOS9 - we have to return the char to stream */
ungetc ( c, fd );
1.56, 1.57
[ date ]
[ thread ]
[ subject ]
[ author ]
