[GRASS-CVS] carlos: grass6/raster/wildfire/r.spread main.c, 2.13,
2.14
grass at intevation.de
Fri Nov 23 10:49:10 EST 2007
Author: carlos
Update of /grassrepository/grass6/raster/wildfire/r.spread
In directory doto:/tmp/cvs-serv18355/raster/wildfire/r.spread
Modified Files:
main.c
Log Message:
Message standardization
Index: main.c
RCS file: /grassrepository/grass6/raster/wildfire/r.spread/main.c,v
retrieving revision 2.13
retrieving revision 2.14
diff -u -d -r2.13 -r2.14
--- main.c 20 Aug 2007 15:11:13 -0000 2.13
+++ main.c 23 Nov 2007 15:49:08 -0000 2.14
@@ -335,42 +335,42 @@
/* Check if input layers exists in data base */
if (G_find_cell2 (max_layer, "") == NULL) {
- sprintf(buf, "%s - not found", max_layer);
+ sprintf(buf, "Raster map <%s> not found", max_layer);
G_fatal_error (buf);
exit(EXIT_FAILURE);
if (G_find_cell2 (dir_layer, "") == NULL) {
- sprintf(buf, "%s - not found", dir_layer);
+ sprintf(buf, _("Raster map <%s> not found"), dir_layer);
exit(EXIT_FAILURE);
if (G_find_cell2 (base_layer, "") == NULL) {
- sprintf(buf, "%s - not found", base_layer);
+ sprintf(buf, _("Raster map <%s> not found"), base_layer);
exit(EXIT_FAILURE);
if (G_find_cell2 (start_layer, "") == NULL) {
- sprintf(buf, "%s - not found", start_layer);
+ sprintf(buf, _("Raster map <%s> not found"), start_layer);
exit(EXIT_FAILURE);
if (spotting) {
if (G_find_cell2 (spotdist_layer, "") == NULL) {
- sprintf(buf, "%s - not found", spotdist_layer);
+ sprintf(buf, _("Raster map <%s> not found"), spotdist_layer);
exit(EXIT_FAILURE);
if (G_find_cell2 (velocity_layer, "") == NULL) {
- sprintf(buf, "%s - not found", velocity_layer);
+ sprintf(buf, _("Raster map <%s> not found"), velocity_layer);
exit(EXIT_FAILURE);
if (G_find_cell2 (mois_layer, "") == NULL) {
- sprintf(buf, "%s - not found", mois_layer);
+ sprintf(buf, _("Raster map <%s> not found"), mois_layer);
exit(EXIT_FAILURE);
@@ -380,24 +380,24 @@
/* Check if specified output layer names ARE LEGAL or EXISTS */
if (G_legal_filename (out_layer) < 0) {
- sprintf(buf, "%s - illegal name", out_layer);
+ sprintf(buf, _("<%s> is an illegal file name"), out_layer);
exit(EXIT_FAILURE);
if (G_find_cell2 (out_layer, G_mapset())) {
- sprintf(buf, "%s - exits in Mapset <%s>, select another name", out_layer, G_mapset());
+ sprintf(buf, _("Raster map <%s> already exists in mapset <%s>, select another name"), out_layer, G_mapset());
exit(EXIT_FAILURE);
if (x_out) {
if (G_legal_filename (x_out_layer) < 0) {
- sprintf(buf, "%s - illegal name", x_out_layer);
+ sprintf(buf, _("<%s> is an illegal file name"), x_out_layer);
exit(EXIT_FAILURE);
if (G_find_cell2 (x_out_layer, G_mapset())) {
- sprintf(buf, "%s - exits in Mapset <%s>, select another name", x_out_layer, G_mapset());
+ sprintf(buf, _("Raster map <%s> already exists in mapset <%s>, select another name"), x_out_layer, G_mapset());
exit(EXIT_FAILURE);
@@ -405,12 +405,12 @@
if (y_out) {
if (G_legal_filename (y_out_layer) < 0) {
- sprintf(buf, "%s - illegal name", y_out_layer);
+ sprintf(buf, _("<%s> is an illegal file name"), y_out_layer);
exit(EXIT_FAILURE);
if (G_find_cell2 (y_out_layer, G_mapset())) {
- sprintf(buf, "%s - exits in Mapset <%s>, select another name", y_out_layer, G_mapset());
+ sprintf(buf, _("Raster map <%s> already exists in mapset <%s>, select another name"), y_out_layer, G_mapset());
exit(EXIT_FAILURE);
@@ -420,21 +420,21 @@
max_fd = G_open_cell_old(max_layer, G_find_cell2 (max_layer,""));
if (max_fd < 0) {
- sprintf (buf, "%s - can't open raster map", max_layer);
+ sprintf (buf, _("Unable to open raster map <%s>"), max_layer);
exit(EXIT_FAILURE);
dir_fd = G_open_cell_old(dir_layer, G_find_cell2 (dir_layer,""));
if (dir_fd < 0) {
- sprintf (buf, "%s - can't open raster map", dir_layer);
+ sprintf (buf, _("Unable to open raster map <%s>"), dir_layer);
exit(EXIT_FAILURE);
base_fd = G_open_cell_old(base_layer, G_find_cell2 (base_layer,""));
if (base_fd < 0) {
- sprintf (buf, "%s - can't open raster map", base_layer);
+ sprintf (buf, _("Unable to open raster map <%s>"), base_layer);
exit(EXIT_FAILURE);
@@ -442,19 +442,19 @@
if (spotting) {
spotdist_fd = G_open_cell_old(spotdist_layer, G_find_cell2 (spotdist_layer,""));
if (spotdist_fd < 0) {
- sprintf (buf, "%s - can't open raster map", spotdist_layer);
+ sprintf (buf, _("Unable to open raster map <%s>"), spotdist_layer);
exit(EXIT_FAILURE);
velocity_fd = G_open_cell_old(velocity_layer, G_find_cell2 (velocity_layer,""));
if (velocity_fd < 0) {
- sprintf (buf, "%s - can't open raster map", velocity_layer);
+ sprintf (buf, _("Unable to open raster map <%s>"), velocity_layer);
exit(EXIT_FAILURE);
mois_fd = G_open_cell_old(mois_layer, G_find_cell2 (mois_layer,""));
if (mois_fd < 0) {
- sprintf (buf, "%s - can't open raster map", mois_layer);
+ sprintf (buf, _("Unable to open raster map <%s>"), mois_layer);
exit(EXIT_FAILURE);
@@ -522,7 +522,7 @@
start_fd = G_open_cell_old(start_layer, G_find_cell2 (start_layer,""));
if (start_fd < 0) {
- sprintf (buf, "%s - can't open raster map", start_layer);
+ sprintf (buf, _("Unable to open raster map <%s>"), start_layer);
exit(EXIT_FAILURE);
@@ -534,7 +534,7 @@
heap = (struct costHa *) G_calloc (nrows*ncols + 1, sizeof(struct costHa));
heap_len = 0;
- G_message (_("Reading %s... "), start_layer);
+ G_message (_("Reading %s..."), start_layer);
#ifdef DEBUG
printf ("Collecting origins...");
#endif
