[GRASS-CVS] markus: grass6/scripts/d.vect.thematic d.vect.thematic,
1.55, 1.55.2.1
grass at intevation.de
Fri Nov 23 10:50:51 EST 2007
Author: markus
Update of /grassrepository/grass6/scripts/d.vect.thematic
In directory doto:/tmp/cvs-serv18412
Modified Files:
Tag: releasebranch_6_3
d.vect.thematic
Log Message:
fix for line type; use user chosen layer (merge from HEAD)
Index: d.vect.thematic
RCS file: /grassrepository/grass6/scripts/d.vect.thematic/d.vect.thematic,v
retrieving revision 1.55
retrieving revision 1.55.2.1
diff -u -d -r1.55 -r1.55.2.1
--- d.vect.thematic 9 May 2007 10:05:29 -0000 1.55
+++ d.vect.thematic 23 Nov 2007 15:50:49 -0000 1.55.2.1
@@ -240,7 +240,7 @@
MAX_LEG_ITEMS=18
# check column type
-COLTYPE="`v.info -c $GIS_OPT_MAP layer=1 2> /dev/null | grep -w $GIS_OPT_COLUMN | cut -d'|' -f1 | tr -s '[:upper:]' '[:lower:]'`"
+COLTYPE="`v.info -c $GIS_OPT_MAP layer=$GIS_OPT_LAYER 2> /dev/null | grep -w $GIS_OPT_COLUMN | cut -d'|' -f1 | tr -s '[:upper:]' '[:lower:]'`"
#COLTYPE=...
if [ -z "$COLTYPE" ] ; then
@@ -372,9 +372,17 @@
# Calculate statistics for thematic intervals
if [ -z "$GIS_OPT_WHERE" ] ; then
- v.univar -e -g map=$GIS_OPT_MAP type=point,centroid column=$GIS_OPT_COLUMN > "$TMP1"
+ if [ "$GIS_OPT_TYPE" = "line" ] ; then
+ v.univar -e -g map=$GIS_OPT_MAP type=line column=$GIS_OPT_COLUMN > "$TMP1"
+ else
+ v.univar -e -g map=$GIS_OPT_MAP type=point,centroid column=$GIS_OPT_COLUMN > "$TMP1"
+ fi
else
- v.univar -e -g map=$GIS_OPT_MAP type=point,centroid column=$GIS_OPT_COLUMN where="$GIS_OPT_WHERE" > "$TMP1"
+ v.univar -e -g map=$GIS_OPT_MAP type=line column=$GIS_OPT_COLUMN where="$GIS_OPT_WHERE" > "$TMP1"
+ else
+ v.univar -e -g map=$GIS_OPT_MAP type=point,centroid column=$GIS_OPT_COLUMN where="$GIS_OPT_WHERE" > "$TMP1"
+ fi
fi
min="`grep 'min=' $TMP1 | sed s/min=//`"
