[GRASS-CVS] markus: grass6/doc/vector/v.example main.c, 1.8,
1.8.2.1
grass at intevation.de
Fri Nov 23 11:35:36 EST 2007
Author: markus
Update of /grassrepository/grass6/doc/vector/v.example
In directory doto:/tmp/cvs-serv19255/vector/v.example
Modified Files:
Tag: releasebranch_6_3
main.c
Log Message:
updated (merged from HEAD)
Index: main.c
RCS file: /grassrepository/grass6/doc/vector/v.example/main.c,v
retrieving revision 1.8
retrieving revision 1.8.2.1
diff -u -d -r1.8 -r1.8.2.1
--- main.c 15 Mar 2007 08:54:16 -0000 1.8
+++ main.c 23 Nov 2007 16:35:34 -0000 1.8.2.1
@@ -58,16 +58,16 @@
Vect_check_input_output_name(new->answer, old->answer, GV_FATAL_EXIT);
if ((mapset = G_find_vector2(old->answer, "")) == NULL)
- G_fatal_error(_("Could not find input %s"), old->answer);
+ G_fatal_error(_("Vector map <%s> not found"), old->answer);
Vect_set_open_level(2);
if (1 > Vect_open_old(&In, old->answer, mapset))
- G_fatal_error(_("Could not open input"));
+ G_fatal_error(_("Unable to open vector map <%s>"), old->answer);
if (0 > Vect_open_new(&Out, new->answer, WITHOUT_Z)) {
Vect_close(&In);
- G_fatal_error(_("Could not open output"));
+ G_fatal_error(_("Unable to create vector map <%s>"), new->answer);
Vect_copy_head_data(&In, &Out);
