[GRASS-CVS] markus: grass6/doc howto_release.txt, 1.49,
1.49.2.1 infrastructure.txt, 1.9, 1.9.2.1
grass at intevation.de
Fri Nov 23 11:35:36 EST 2007
Author: markus
Update of /grassrepository/grass6/doc
In directory doto:/tmp/cvs-serv19255
Modified Files:
Tag: releasebranch_6_3
howto_release.txt infrastructure.txt
Log Message:
updated (merged from HEAD)
Index: howto_release.txt
RCS file: /grassrepository/grass6/doc/howto_release.txt,v
retrieving revision 1.49
retrieving revision 1.49.2.1
diff -u -d -r1.49 -r1.49.2.1
--- howto_release.txt 23 Jul 2007 12:06:21 -0000 1.49
+++ howto_release.txt 23 Nov 2007 16:35:33 -0000 1.49.2.1
@@ -17,8 +17,8 @@
1. Local work (basically at ITC-irst)
- check if
- doc/raster/r.example/
- doc/vector/v.example/
+ ( cd doc/raster/r.example/ ; make )
+ ( cd doc/vector/v.example/ ; make )
still compile; fix otherwise
- cleanup rubbish:
@@ -91,7 +91,7 @@
o Store the source tarball in (use scp -p FILES grass:):
http://grass.itc.it/grass/grass$MAJOR$MINOR/source/
along with associated files:
- scp grass-$VERSION.* AUTHORS COPYING ChangeLog_$VERSION.gz INSTALL REQUIREMENTS.html SUBMITTING SUBMITTING_TCLTK SUBMITTING_SCRIPTS neteler at grass.itc.it:www/grass$MAJOR$MINOR/source/
+ scp grass-$VERSION.* AUTHORS COPYING ChangeLog_$VERSION.gz INSTALL REQUIREMENTS.html SUBMITTING SUBMITTING_DOCS SUBMITTING_TCLTK SUBMITTING_SCRIPTS neteler at grass.itc.it:www/grass$MAJOR$MINOR/source/
o update web site to new version (HTML in Web-CVS)
- rss.xml (for news section)
@@ -176,9 +176,14 @@
1. update from CVS into clean directory
+yourcvsid=markus
+export CVSROOT=:ext:$yourcvsid at grasscvs:/grassrepository
+cvs -z3 checkout grass6
+mv grass6 grass6_tmp
2. create the branch:
-BRANCH="releasebranch_6_1"
+BRANCH="releasebranch_6_3"
cvs tag -b $BRANCH
3. checkout the branch into new directory:
@@ -186,7 +191,7 @@
yourcvsid=markus
cvs -z3 checkout -r $BRANCH grass6
+mv grass6 clean_$BRANCH
4. Take care that relevant HEAD changes are backported.
Index: infrastructure.txt
RCS file: /grassrepository/grass6/doc/infrastructure.txt,v
retrieving revision 1.9
retrieving revision 1.9.2.1
diff -u -d -r1.9 -r1.9.2.1
--- infrastructure.txt 11 Feb 2007 12:36:58 -0000 1.9
+++ infrastructure.txt 23 Nov 2007 16:35:34 -0000 1.9.2.1
@@ -3,23 +3,31 @@
written by M. Neteler, $Date$
+Related Wiki documents:
+* http://grass.gdf-hannover.de/wiki/GRASS_Migration_to_OSGeo
== GRASS Web server ==
Maintainer: M. Neteler
-* http://grass.itc.it
-* 3Ghz Dual Core Pentium, sponsored by ITC-irst, Trento, Italy
-* Apache Server with PHP
-* OS: RHEL4 with overnight security updates
+* http://grass.fbk.eu
+** 3Ghz Dual Core Pentium, sponsored by FBK-irst (formerly ITC-irst), Trento, Italy
+** Apache Server with PHP
+** OS: RHEL4 with overnight security updates
+* http://grass.osgeo.org
+** OSGeo infrastructure (http://wiki.osgeo.org/index.php/SAC)
+* http://www.grass-gis.org
+** Apache rewrite engine to http://grass.osgeo.org
* Web pages:
** hosted in the CVS server (developers can modify), downloaded to Web server
- via cronjob every three hours
+ via cronjob hourly
** written in simple PHP/HTML (just include() statement for menus)
** mirrored to selected tier-1 sites via rsync (hardcoded IPs to avoid
- that too many sites connect)
+ that too many sites connect at grass.fbk.eu)
** tier-1 sites are mirrored via rsync to tier-2 mirrors (no hardcoded IPs)
** RSS feed: rss.xml file stored in CVS-Web
+** TODO: To be migrated to OSGeo Drupal 12/2007
* Weekly snapshots (generated Saturday morning Italian time):
** Source code tarball of CVS HEAD
@@ -30,49 +38,53 @@
* GRASS user manual HTML:
** generated during compilation of weekly Linux binary snapshot
-* GRASS programmer's manual:
-** HTML: job manually run by M Neteler from time to time (not on grass.itc.it)
+* GRASS programmer's manual (http://mpa.fbk.eu/markus/grass63progman/):
+** HTML: cronjob run Saturday morning Italian time
** PDF: currently broken since PDFs aren't created for unknown reasons in cronjob
+** TODO: To be migrated to OSGeo server 12/2007
* i18N translation statistics:
** generated during compilation of Linux binary snapshot, stats of
(cd locale; make) are extracted into text file
** text file parsed by PHP page and shown as table
* GRASS 5 tutorial (generated Saturday morning Italian time):
** downloaded to Web server via cronjob
** built with docbook
* GRASS user map
** GDF is creating png output via mapserver
** fetched every three hours via cronjob from http://mapserver.gdf-hannover.de/tmp/
* GRASS-Mapserver demo
-** currently broken after grass.itc.it update
+** currently broken after grass.fbk.eu update
* Search engine
** htdig runs once a week
** searchgrass.inc contains selective entries (CVS-Web)
* FTP server
** no longer available due to security risk
-* Mailman mailing lists + Spam filtering
+* Mailman mailing lists + Spam filtering (at lists.osgeo.org since 11/2007)
** Mailman is doing the job, only registered users can post
-** each incoming email first passes 'bogofilter', then a set of handwritten
- procmail rules filter standard rubbish
-** 'bogofilter' is autotrained
-** the few spams which arrive through the bugtracker or into the open 'weblist'
- are manually added to /var/mail/bogofilter-train-as-spam folder
-** bogofilter learn script which reads /var/mail/bogofilter-train-as-spam and
- /var/mail/bogofilter-train-as-ham runs every night via cronjob
+** messages from unsubscribed people is auto-discarded without notification
+** the open "weblist" operates as:
+ User -> weblist at grass itc.it -> /etc/aliases ->
+ -> neteler.osgeo..gmail.com (for Spam filtering) -> FWD ->
+ -> grass-web at lists osgeo.org
* Backup of mailing lists (mbox files)
** manually done by MN and Intevation (into freegis.org FTP space)
+** nightly backup at OSGeo.org
* Web statistics
-** Webalizer (http://grass.itc.it/webalizer/) runs daily as cronjob
+** Webalizer (http://grass.fbk.eu/webalizer/) runs daily as cronjob
** Sitemeter: http://www.sitemeter.com/?a=stats&s=s24grassgis
Summary: The system should run almost autonomous.
@@ -81,34 +93,34 @@
Maintainer: Markus Neteler
Available lists:
-grass-abm Integration of GRASS with JAVA based agent based modeling (ABM)
-grass-announce GRASS announcements (moderated by M. Neteler)
-grass-commit Mailing list to distribute GRASS-CVS commits (limited posters)
-grass-dev GRASS GIS Development mailing list
-grass-qa GRASS Quality Assessment and monitoring list (limited posters)
-grass-psc GRASS-PSC (Project Steering Committee) list
-grassgui GRASSGUI mailing list
-grassuser GRASS user list
-nvizlist List to discuss GRASS/NVIZ visualization tools
-sqlgrass GRASS and SQL support
-statsgrass GRASS and statistical software
-translations Translation of GRASS (i18N)
-weblist GRASS website mailing list
-winGRASS winGRASS - Using GRASS on MS-Windows systems mailing list
+* at FBK-irst (http://grass.fbk.eu/mailman/admin/):
+ grass-commit-addons Mailing list to distribute GRASS Addons-SVN commits
+* at OSGeo.org (http://lists.osgeo.org/mailman/listinfo):
+ grass-abm Integration of GRASS with JAVA based agent based modeling (ABM)
+ grass-announce GRASS announcements
+ grass-commit Mailing list to distribute GRASS-CVS commits
+ grass-dev GRASS GIS Development mailing list
+ grass-es La lista de correo de GRASS GIS en español
+ grass-gui GRASSGUI mailing list
+ grass-psc GRASS-PSC: GRASS Project Steering Committee
+ grass-qa GRASS Quality Assessment and monitoring list
+ grass-stats GRASS and statistical software
+ grass-translations Translation of GRASS (i18N)
+ grass-user GRASS user list
+ grass-web GRASS website mailing list
+ grass-windows winGRASS - Using GRASS on MS-Windows systems mailing list
Notes:
-* The old user list at Baylor university, Texas, USA is still functional. The
- new grassuser list at ITC-irst is subscribed at Baylor to transport messages
- posted there to the new list.
* grass-announce:
- * posts to 'announce AT grass.osgeo.org'. The latter is moderated by M. Neteler
- * has monthly password reminder disabled to avoid leakage into publicly archived
- lists such as 'announce AT grass.osgeo.org'
+ * moderated by M. Neteler
+ * has monthly password reminder disabled to avoid leakage into publicly archived lists
* grass-qa is receiving posts from the GRASS Quality Control System at
Ecole Polytechnique de Montreal, Canada. Not open for other postings.
* grass-commit is receiving posts from the GRASS CVS server at intevation.de.
-* weblist is an open list (posting without subscription possible) with spam filter
+* weblist is an open list (posting without subscription possible) with (Google) spam filter
== GRASS Wiki ==
@@ -171,9 +183,11 @@
* http://web.soccerlab.polymtl.ca/grass-evolution/grass-browsers/grass-index-en.html
implemented and sponsored by Ecole Polytechnique de Montreal, Canada
-* Realtime analysis is sent to: http://grass.itc.it/mailman/listinfo/grass-qa
+* Realtime analysis is sent to: http://grass.fbk.eu/mailman/listinfo/grass-qa
Further notification/functionality test systems:
-* http://cia.navi.cx/stats/project/GRASS
+* http://cia.vc/stats/project/GRASS
+** posts into #grass IRC channel
+** posts into #osgeo-commits IRC channel
* http://www-pool.math.tu-berlin.de/~soeren/grass/GRASS_TestSuite/?C=M;O=D
