[GRASS-CVS] markus: grass6/db/db.login description.html,1.5,1.6
grass at intevation.de grass at intevation.de
Thu Nov 29 08:20:46 EST 2007
Author: markus
Update of /grassrepository/grass6/db/db.login
In directory doto:/tmp/cvs-serv18356
Modified Files:
	description.html
Log Message:
typos fixed
Index: description.html
RCS file: /grassrepository/grass6/db/db.login/description.html,v
retrieving revision 1.5
retrieving revision 1.6
diff -u -d -r1.5 -r1.6
--- description.html	29 Nov 2007 10:20:42 -0000	1.5
+++ description.html	29 Nov 2007 13:20:44 -0000	1.6
@@ -19,7 +19,7 @@
 <P>
 Example 2: Username and password specified (note that the command
-lins history will store the password in this way):
+lines history will store the password in this way):
 <div class="code"><pre>
 db.login user=bacava pass=secret
@@ -27,7 +27,7 @@
 <P>
 Example 3: Username and empty password specified (note that the command
 db.login user=bacava pass=""
