[GRASS-CVS] markus: grass6/db/db.login description.html, 1.4,
1.4.2.1
grass at intevation.de
Thu Nov 29 08:21:12 EST 2007
Author: markus
Update of /grassrepository/grass6/db/db.login
In directory doto:/tmp/cvs-serv18385
Modified Files:
Tag: releasebranch_6_3
description.html
Log Message:
extended; typos fixed
Index: description.html
RCS file: /grassrepository/grass6/db/db.login/description.html,v
retrieving revision 1.4
retrieving revision 1.4.2.1
diff -u -d -r1.4 -r1.4.2.1
--- description.html 16 Nov 2006 06:43:17 -0000 1.4
+++ description.html 29 Nov 2007 13:21:10 -0000 1.4.2.1
@@ -4,30 +4,34 @@
<h2>NOTE</h2>
-This is only related to SQL databases.
+This is only related to SQL database backends (PostgreSQL, MySQL etc).
+The passwords are stored in a hidden file in the user account ('home'
+directory) called <em>.grasslogin6</em>. Only the file owner
+can access this file.
<h2>EXAMPLES</h2>
-Example 1: Username and password specified:
+Example 1: Username specified, password will be invisibly queried interactively:
<div class="code"><pre>
-db.login user=bacava pass=secret
+db.login user=bacava
</pre></div>
<P>
-Example 2: Username and empty password specified:
+Example 2: Username and password specified (note that the command
+lines history will store the password in this way):
-db.login user=bacava pass=""
+db.login user=bacava pass=secret
</pre></div>
<P>
-Example 3: Username specified, password will be invisibly queried interactively:
+Example 3: Username and empty password specified (note that the command
+db.login user=bacava pass=""
</pre></div>
<h2>SEE ALSO</h2>
<em>
