[GRASS-CVS] markus: grass6/db/db.login description.html, 1.2.6.1,
1.2.6.2
grass at intevation.de
Thu Nov 29 08:21:46 EST 2007
Author: markus
Update of /grassrepository/grass6/db/db.login
In directory doto:/tmp/cvs-serv18435
Modified Files:
Tag: releasebranch_6_2
description.html
Log Message:
typos fixed
Index: description.html
RCS file: /grassrepository/grass6/db/db.login/description.html,v
retrieving revision 1.2.6.1
retrieving revision 1.2.6.2
diff -u -d -r1.2.6.1 -r1.2.6.2
--- description.html 29 Nov 2007 10:21:17 -0000 1.2.6.1
+++ description.html 29 Nov 2007 13:21:43 -0000 1.2.6.2
@@ -19,7 +19,7 @@
<P>
Example 2: Username and password specified (note that the command
-lins history will store the password in this way):
+lines history will store the password in this way):
<div class="code"><pre>
db.login user=bacava pass=secret
@@ -27,7 +27,7 @@
<P>
Example 3: Username and empty password specified (note that the command
db.login user=bacava pass=""
