[GRASS-CVS] markus: grass6/scripts/d.out.file d.out.file, 1.13,
1.13.2.1 description.html, 1.5, 1.5.2.1
grass at intevation.de
Thu Nov 29 08:24:59 EST 2007
Author: markus
Update of /grassrepository/grass6/scripts/d.out.file
In directory doto:/tmp/cvs-serv18618
Modified Files:
Tag: releasebranch_6_3
d.out.file description.html
Log Message:
sync'ed to HEAD for cairo
Index: d.out.file
RCS file: /grassrepository/grass6/scripts/d.out.file/d.out.file,v
retrieving revision 1.13
retrieving revision 1.13.2.1
diff -u -d -r1.13 -r1.13.2.1
--- d.out.file 16 May 2007 04:24:06 -0000 1.13
+++ d.out.file 29 Nov 2007 13:24:57 -0000 1.13.2.1
@@ -29,7 +29,7 @@
#%option
#% key: format
#% type: string
-#% options: png,ppm,tif,jpg,bmp,ps,eps
+#% options: png,ppm,tif,jpg,bmp,ps,eps,svg,pdf
#% answer: png
#% description: Graphics file format
#% required : yes
@@ -99,19 +99,24 @@
#% description: PostScript level (only limits functionality!)
#% guisection: PostScript
#% required : no
-#%end
+#% end
#%flag
-#%key: b
-#%description: Set background color to black (white default)
-#%end
+#% key: b
+#% description: Set background color to black (white default)
+#% end
#%flag
-#%key: t
-#%description: Set transparent background
+#% key: t
+#% description: Set transparent background
#% guisection: Images
-#%end
+#% end
#%flag
-#%key: r
-#%description: Set paper orientation to landscape (for PostScript output)
+#% key: c
+#% description: Use the Cario driver to render images
+#% guisection: Images
+#% end
+#%flag
+#% key: r
+#% description: Set paper orientation to landscape (for PostScript output)
#%end
@@ -151,6 +156,20 @@
exit 1
fi
+case "$GIS_OPT_FORMAT" in
+ pdf | svg)
+ if [ $GIS_FLAG_C -eq 0 ] ; then
+ g.message "Using the Cairo driver."
+ GIS_FLAG_C=1
+ fi
+esac
+if [ $GIS_FLAG_C -eq 1 ] && [ `d.mon -l | grep -c '^cairo'` -eq 0 ] ; then
+ g.message -e "Cairo driver not present in this build of GRASS."
+ exit 1
+fi
#### set variables
res="$GIS_OPT_RESOLUTION"
@@ -195,12 +214,19 @@
#set output file name and format
- png | ppm | ps | eps)
+ png | ppm | ps | eps | svg | pdf)
output="${GIS_OPT_OUTPUT}.${GIS_OPT_FORMAT}"
- tif | jpg | bmp)
+ tif | jpg)
output="`g.tempfile pid=$$`.ppm"
+ bmp)
+ if [ $GIS_FLAG_C -eq 1 ] ; then
+ output="${GIS_OPT_OUTPUT}.${GIS_OPT_FORMAT}"
+ else
+ output="`g.tempfile pid=$$`.ppm"
+ fi
esac
outname="${GIS_OPT_OUTPUT}.${GIS_OPT_FORMAT}"
@@ -215,9 +241,25 @@
if [ "$GIS_OPT_FORMAT" = "ps" ] || [ "$GIS_OPT_FORMAT" = "eps" ] ; then
- GRAPHICS_DRIVER=PS
- GRASS_PSFILE="$output"
- export GRASS_PSFILE
+ if [ $GIS_FLAG_R -eq 1 ] ; then
+ g.message -w "Cairo driver doesn't know how to do landscape mode"
+ fi
+ if [ "$GIS_OPT_FORMAT" = "eps" ] ; then
+ g.message -e "Cairo driver doesn't support EPS"
+ exit 1
+ fi
+ fi
+ GRAPHICS_DRIVER=PS
+ GRASS_PSFILE="$output"
+ export GRASS_PSFILE
+ else
+ GRAPHICS_DRIVER=cairo
+ GRASS_CAIROFILE="$output"
+ export GRASS_CAIROFILE
+ fi
if [ "$GIS_OPT_FORMAT" = "ps" ] ; then
GRASS_PAPER="$GIS_OPT_PAPER"
@@ -244,9 +286,15 @@
fi
else
- GRAPHICS_DRIVER=PNG
- GRASS_PNGFILE="$output"
- export GRASS_PNGFILE
+ GRAPHICS_DRIVER=PNG
+ GRASS_PNGFILE="$output"
+ export GRASS_PNGFILE
+ else
+ fi
#make sure that output is 24 bit color
GRASS_TRUECOLOR=TRUE
@@ -258,6 +306,7 @@
g.message "Saving display from Monitor: [$curr_mon] to <$outname>."
+# what does the Cairo/PS driver do?
if [ "$GIS_OPT_FORMAT" != "ps" ] ; then
g.message "Image size [$out_width x $out_height]"
else
@@ -278,15 +327,25 @@
d.mon select="$curr_mon"
g.message "Done."
exit
- tif | jpg | bmp)
+ tif | jpg)
# delay not needed if using GRASS_PNG_AUTO_WRITE ?
g.message "Waiting for file to write ..."
sleep 5
+ bmp)
+ g.message "Done."
+ exit
+ else
+ # delay not needed if using GRASS_PNG_AUTO_WRITE ?
+ g.message "Waiting for file to write ..."
+ sleep 5
+ fi
esac
@@ -310,6 +369,6 @@
\rm "$output"
-g.message "Done."
+g.message "Done."
exit $EXITCODE
Index: description.html
RCS file: /grassrepository/grass6/scripts/d.out.file/description.html,v
retrieving revision 1.5
retrieving revision 1.5.2.1
diff -u -d -r1.5 -r1.5.2.1
--- description.html 16 May 2007 05:32:53 -0000 1.5
+++ description.html 29 Nov 2007 13:24:57 -0000 1.5.2.1
@@ -73,10 +73,11 @@
<A HREF="d.out.png.html">d.out.png</A>,
<A HREF="d.save.html">d.save</A>,
<A HREF="ps.map.html">ps.map</A></EM><BR>
-<A HREF="pngdriver.html">GRASS PNG driver</A>,
-<A HREF="psdriver.html">GRASS PostScript driver</A>,
-<A HREF="htmlmapdriver.html">GRASS HTML-map driver</A>,
-<A HREF="xdriver.html">GRASS X driver</A><BR>
+<A HREF="cairodriver.html">Cairo driver</A>,
+<A HREF="pngdriver.html">PNG driver</A>,
+<A HREF="psdriver.html">PostScript driver</A>,
+<A HREF="htmlmapdriver.html">HTML-map driver</A>,
+<A HREF="xdriver.html">X driver</A><BR>
<A HREF="http://www.gdal.org">GDAL Homepage</a>
