[GRASS-CVS] markus: grass6/gui/tcltk/gis.m vector.tcl, 1.35,
1.35.2.1
grass at intevation.de
Thu Nov 29 08:29:22 EST 2007
Author: markus
Update of /grassrepository/grass6/gui/tcltk/gis.m
In directory doto:/tmp/cvs-serv18875
Modified Files:
Tag: releasebranch_6_3
vector.tcl
Log Message:
Closes bug #317 and other enhancements (merge from HEAD)
Index: vector.tcl
RCS file: /grassrepository/grass6/gui/tcltk/gis.m/vector.tcl,v
retrieving revision 1.35
retrieving revision 1.35.2.1
diff -u -d -r1.35 -r1.35.2.1
--- vector.tcl 8 Sep 2007 03:55:07 -0000 1.35
+++ vector.tcl 29 Nov 2007 13:29:20 -0000 1.35.2.1
@@ -307,7 +307,7 @@
scale $row.b -from 1.0 -to 0.0 -showvalue 1 \
-orient horizontal -length 300 -resolution 0.01 -fg "#656565"\
-variable GmVector::opt($id,1,opacity)
- Label $row.c -text [G_msg " Transparent"]
+ Label $row.c -text [G_msg "Transparent"]
pack $row.a $row.b $row.c -side left
pack $row -side top -fill both -expand yes
@@ -338,13 +338,13 @@
# display
set row [ frame $frm.disp ]
Label $row.a -text [G_msg "Display: "]
- checkbutton $row.b -text [G_msg "shapes"] -variable GmVector::opt($id,1,display_shape) \
+ checkbutton $row.b -text [G_msg "Shapes "] -variable GmVector::opt($id,1,display_shape) \
-command "GmVector::legend $id"
- checkbutton $row.c -text [G_msg "categories"] -variable GmVector::opt($id,1,display_cat) \
+ checkbutton $row.c -text [G_msg "Categories "] -variable GmVector::opt($id,1,display_cat) \
- checkbutton $row.d -text [G_msg "topology"] -variable GmVector::opt($id,1,display_topo) \
+ checkbutton $row.d -text [G_msg "Topology "] -variable GmVector::opt($id,1,display_topo) \
- checkbutton $row.e -text [G_msg "line directions"] -variable GmVector::opt($id,1,display_dir) \
+ checkbutton $row.e -text [G_msg "Line directions "] -variable GmVector::opt($id,1,display_dir) \
pack $row.a $row.b $row.c $row.d $row.e -side left
@@ -352,17 +352,17 @@
# type
set row [ frame $frm.type ]
Label $row.a -text " "
- checkbutton $row.b -text [G_msg "points"] -variable GmVector::opt($id,1,type_point) \
+ checkbutton $row.b -text [G_msg "Points "] -variable GmVector::opt($id,1,type_point) \
- checkbutton $row.c -text [G_msg "lines"] -variable GmVector::opt($id,1,type_line) \
+ checkbutton $row.c -text [G_msg "Lines "] -variable GmVector::opt($id,1,type_line) \
- checkbutton $row.d -text [G_msg "boundaries"] -variable GmVector::opt($id,1,type_boundary) \
+ checkbutton $row.d -text [G_msg "Boundaries "] -variable GmVector::opt($id,1,type_boundary) \
- checkbutton $row.e -text [G_msg "areas"] -variable GmVector::opt($id,1,type_area) \
+ checkbutton $row.e -text [G_msg "Areas "] -variable GmVector::opt($id,1,type_area) \
- checkbutton $row.f -text [G_msg "centroids"] -variable GmVector::opt($id,1,type_centroid)\
+ checkbutton $row.f -text [G_msg "Centroids "] -variable GmVector::opt($id,1,type_centroid)\
- checkbutton $row.g -text [G_msg "faces"] -variable GmVector::opt($id,1,type_face) \
+ checkbutton $row.g -text [G_msg "Faces "] -variable GmVector::opt($id,1,type_face) \
pack $row.a $row.b $row.c $row.d $row.e $row.f $row.g -side left
@@ -370,11 +370,11 @@
# points
set row [ frame $frm.icon ]
Label $row.a -text [G_msg "Point symbols:"]
- Button $row.b -text [G_msg "icon"] \
+ Button $row.b -text [G_msg "Icon"] \
-command "GmVector::select_symbol $id"
Entry $row.c -width 15 -text "$opt($id,1,icon)" \
-textvariable GmVector::opt($id,1,icon)
- Label $row.d -text [G_msg " size"]
+ Label $row.d -text [G_msg " Size"]
SpinBox $row.e -range {1 50 1} -textvariable GmVector::opt($id,1,size) \
-width 2 -helptext [G_msg "Icon size"] -modifycmd "GmVector::legend $id"
@@ -385,10 +385,10 @@
Label $row.a -text [G_msg "Draw lines:"]
checkbutton $row.b -variable GmVector::opt($id,1,_use_color) \
- Label $row.c -text [G_msg "color"]
+ Label $row.c -text [G_msg "Color"]
SelectColor $row.d -type menubutton -variable GmVector::opt($id,1,color) \
- Label $row.e -text [G_msg " width"]
+ Label $row.e -text [G_msg " Width"]
SpinBox $row.f -range {0 50 1} -textvariable GmVector::opt($id,1,lwidth) \
-width 2 -helptext [G_msg "Line width"] \
@@ -401,11 +401,11 @@
Label $row.a -text [G_msg "Fill areas:"]
checkbutton $row.b -variable GmVector::opt($id,1,_use_fcolor) \
SelectColor $row.d -type menubutton -variable GmVector::opt($id,1,fcolor) \
Label $row.e -text " "
- checkbutton $row.f -text [G_msg "random colors"] -variable GmVector::opt($id,1,rdmcolor) \
+ checkbutton $row.f -text [G_msg "Random colors "] -variable GmVector::opt($id,1,rdmcolor) \
checkbutton $row.g -text [G_msg "GRASSRGB column colors"] -variable GmVector::opt($id,1,sqlcolor) \
@@ -417,10 +417,10 @@
Label $row.a -text [G_msg "Label vectors:"]
checkbutton $row.b -text [G_msg "label"] -variable GmVector::opt($id,1,display_attr) \
- Label $row.c -text [G_msg "text color"]
+ Label $row.c -text [G_msg " Text color"]
SelectColor $row.d -type menubutton -variable GmVector::opt($id,1,lcolor) \
- Label $row.e -text [G_msg " text size"]
+ Label $row.e -text [G_msg " Text size"]
SpinBox $row.f -range {1 50 1} -textvariable GmVector::opt($id,1,lsize) \
-width 2 -helptext [G_msg "text size"] \
@@ -430,11 +430,11 @@
# label alighment
set row [ frame $frm.label2 ]
- ComboBox $row.b -label [G_msg "label part to align with vector point"] \
+ ComboBox $row.b -label [G_msg "Label part to align with vector point"] \
-width 6 -textvariable GmVector::opt($id,1,xref) \
-values {"left" "center" "right"} \
- ComboBox $row.c -label [G_msg " justification"] \
+ ComboBox $row.c -label [G_msg " Justification"] \
-width 6 -textvariable GmVector::opt($id,1,yref) \
-values {"top" "center" "bottom"} \
@@ -443,9 +443,9 @@
# labels layer and attribute column
set row [ frame $frm.label3 ]
- LabelEntry $row.a -label [G_msg " layer for labels"] \
+ LabelEntry $row.a -label [G_msg " Layer for labels"] \
-textvariable GmVector::opt($id,1,lfield) -width 3
- LabelEntry $row.b -label [G_msg " attribute col for labels"] \
+ LabelEntry $row.b -label [G_msg " Attribute col for labels"] \
-textvariable GmVector::opt($id,1,attribute) -width 23
pack $row.a $row.b -side left
@@ -461,7 +461,7 @@
# query cat
set row [ frame $frm.query2 ]
- LabelEntry $row.b -label [G_msg "query cat values "] \
+ LabelEntry $row.b -label [G_msg "Query cat values"] \
-textvariable GmVector::opt($id,1,cat) \
-width 40
@@ -472,7 +472,7 @@
checkbutton $row.b -variable GmVector::opt($id,1,_use_where) \
- LabelEntry $row.c -label [G_msg "use SQL query"] \
+ LabelEntry $row.c -label [G_msg "Use SQL query"] \
-textvariable GmVector::opt($id,1,where) \
-width 40
@@ -480,13 +480,13 @@
#show columns and data
set row [ frame $frm.columns ]
- Label $row.a -text [G_msg " show attribute columns"]
+ Label $row.a -text [G_msg " Show attribute columns"]
Button $row.b -text [G_msg "columns"] \
-image [image create photo -file "$iconpath/db-columns.gif"] \
-command "GmVector::show_columns $id" \
-background $bgcolor -borderwidth 1\
-helptext [G_msg "Show columns"]
- Label $row.c -text [G_msg " show attribute data"]
+ Label $row.c -text [G_msg " Show attribute data"]
Button $row.d -text [G_msg "data"] \
-image [image create photo -file "$iconpath/db-values.gif"] \
-command "GmVector::show_data $id" \
@@ -498,20 +498,20 @@
# save query to new vector file
set row [ frame $frm.qsave ]
- checkbutton $row.b -text [G_msg "save displayed objects to new vector file "] \
+ checkbutton $row.b -text [G_msg "Save displayed objects to new vector file "] \
-variable GmVector::opt($id,1,qsave)
- checkbutton $row.c -text [G_msg "overwrite existing"] \
+ checkbutton $row.c -text [G_msg "Overwrite existing"] \
-variable GmVector::opt($id,1,qoverwrite)
# save query vector name
set row [ frame $frm.qname ]
- Label $row.a -text [G_msg " new vector"]
+ Label $row.a -text [G_msg " New vector"]
Button $row.b -image [image create photo -file "$iconpath/element-vector.gif"] \
-highlightthickness 0 -takefocus 0 -relief raised -borderwidth 1 \
-command "GmVector::select_qmap $id" \
- -helptext [G_msg "select existing vector for saving queried objects"]
+ -helptext [G_msg "Select existing vector for saving queried objects"]
Entry $row.c -width 40 -text "$opt($id,1,qmap)" \
-textvariable GmVector::opt($id,1,qmap)
