[GRASS-CVS] markus: grass6/lib/gis rename.c,2.4,2.4.2.1
grass at intevation.de
Thu Nov 29 08:30:08 EST 2007
Author: markus
Update of /grassrepository/grass6/lib/gis
In directory doto:/tmp/cvs-serv18961
Modified Files:
Tag: releasebranch_6_3
rename.c
Log Message:
add G_rename_file function for renaming files on file system (merge from HEAD)
Index: rename.c
RCS file: /grassrepository/grass6/lib/gis/rename.c,v
retrieving revision 2.4
retrieving revision 2.4.2.1
diff -u -d -r2.4 -r2.4.2.1
--- rename.c 14 Apr 2007 23:02:00 -0000 2.4
+++ rename.c 29 Nov 2007 13:30:06 -0000 2.4.2.1
@@ -19,6 +19,30 @@
+ **\fn int G_rename_file (char *oldname, char *newname)
+ **\brief Rename a file in the filesystem.
+ **The file or directory <b>oldname</b> is renamed to <b>newname</b>.<br>
+ ** \param[in] oldname
+ ** \param[in] newname
+ ** \return 0 if successful
+ ** \return -1 on error
+int G_rename_file ( const char *oldname, const char *newname )
+ #ifdef __MINGW32__
+ remove(oldname);
+ #endif
+ return rename(oldname, newname);
* \fn int G_rename (char *element, char *oldname, char *newname)
* \brief Rename a database file.
@@ -60,5 +84,5 @@
G__file_name (to, element, newname, mapset);
/* return result of rename */
- return rename(from, to) == 0 ? 1 : -1;
+ return G_rename_file(from, to) == 0 ? 1 : -1;
