[GRASS-CVS] carlos: grass6/locale/po grasslibs_zh.po, 1.21,
1.22 grassmods_zh.po, 1.35, 1.36
grass at intevation.de
Thu Nov 29 15:12:20 EST 2007
- Previous message: [GRASS-CVS] carlos: grass6/vector/v.in.ascii in.c,1.52,1.53
- Next message: [GRASS-CVS] carlos: grass6/locale/po grasslibs_ar.po, 1.14,
1.15 grasslibs_cs.po, 1.36, 1.37 grasslibs_de.po, 1.55, 1.56 grasslibs_el.po,
1.9, 1.10 grasslibs_es.po, 1.67, 1.68 grasslibs_fr.po, 1.31,
1.32 grasslibs_hi.po, 1.19, 1.20 grasslibs_it.po, 1.32, 1.33 grasslibs_ja.po,
1.29, 1.30 grasslibs_ko.po, 1.20, 1.21 grasslibs_lv.po, 1.18,
1.19 grasslibs_mr.po, 1.18, 1.19 grasslibs_pl.po, 1.21, 1.22 grasslibs_pt.po,
1.11, 1.12 grasslibs_pt_br.po, 1.27, 1.28 grasslibs_ru.po, 1.26,
1.27 grasslibs_sl.po, 1.22, 1.23 grasslibs_th.po, 1.1, 1.2 grasslibs_tr.po,
1.17, 1.18 grasslibs_vi.po, 1.22, 1.23 grassmods_ar.po, 1.26,
1.27 grassmods_cs.po, 1.51, 1.52 grassmods_de.po, 1.120,
1.121 grassmods_el.po, 1.9, 1.10 grassmods_es.po, 1.87, 1.88 grassmods_fr.po,
1.46, 1.47 grassmods_hi.po, 1.29, 1.30 grassmods_it.po, 1.42,
1.43 grassmods_ja.po, 1.40, 1.41 grassmods_ko.po, 1.28, 1.29 grassmods_lv.po,
1.28, 1.29 grassmods_mr.po, 1.28, 1.29 grassmods_pl.po, 1.31,
1.32 grassmods_pt.po, 1.7, 1.8 grassmods_pt_br.po, 1.44,
1.45 grassmods_ru.po, 1.36, 1.37 grassmods_sl.po, 1.
32, 1.33 grassmods_th.po, 1.1, 1.2 grassmods_tr.po, 1.28,
1.29 grassmods_vi.po, 1.34, 1.35 grasstcl_am.po, 1.4, 1.5 grasstcl_ar.po,
1.9, 1.10 grasstcl_cs.po, 1.18, 1.19 grasstcl_de.po, 1.26,
1.27 grasstcl_el.po, 1.9, 1.10 grasstcl_es.po, 1.61, 1.62 grasstcl_fr.po,
1.19, 1.20 grasstcl_hi.po, 1.15, 1.16 grasstcl_it.po, 1.21,
1.22 grasstcl_ja.po, 1.17, 1.18 grasstcl_ko.po, 1.9, 1.10 grasstcl_lv.po,
1.15, 1.16 grasstcl_mr.po, 1.10, 1.11 grasstcl_pl.po, 1.21,
1.22 grasstcl_pt.po, 1.12, 1.13 grasstcl_pt_br.po, 1.27, 1.28 grasstcl_ru.po,
1.15, 1.16 grasstcl_sl.po, 1.9, 1.10 grasstcl_th.po, 1.1, 1.2 grasstcl_tr.po,
1.16, 1.17 grasstcl_vi.po, 1.17, 1.18 grasstcl_zh.po, 1.9, 1.10
- Messages sorted by:
[ date ]
[ thread ]
[ subject ]
[ author ]
Author: carlos
Update of /grassrepository/grass6/locale/po
In directory doto:/tmp/cvs-serv729
Modified Files:
grasslibs_zh.po grassmods_zh.po
Log Message:
Su Yongheng translations and updated
Index: grasslibs_zh.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_zh.po,v
retrieving revision 1.21
retrieving revision 1.22
diff -u -d -r1.21 -r1.22
--- grasslibs_zh.po 21 Nov 2007 13:18:49 -0000 1.21
+++ grasslibs_zh.po 29 Nov 2007 20:12:17 -0000 1.22
@@ -7,10 +7,10 @@
msgstr ""
"Project-Id-Version: grasslibs_zh\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2007-10-26 21:10+0200\n"
-"PO-Revision-Date: 2006-02-09 14:37+0800\n"
-"Last-Translator: Zhang Jun <nilarcs at gmail.com>\n"
-"Language-Team: Simplified Chinese <translations at lists.osgeo.org>\n"
+"POT-Creation-Date: 2007-11-29 20:51+0100\n"
+"PO-Revision-Date: 2007-11-27 14:54+0800\n"
+"Last-Translator: Su Yongheng <night2008 at gmail.com>\n"
+"Language-Team: Simplified Chinese <translations at grass.itc.it>\n"
[...1575 lines suppressed...]
+#: ../lib/vector/Vlib/snap.c:370
msgid "Snapped vertices"
msgstr ""
-#: ../lib/vector/Vlib/snap.c:373
+#: ../lib/vector/Vlib/snap.c:371
msgid "New vertices"
msgstr ""
@@ -3651,6 +3703,10 @@
"Attempt to read line angle for the line which is not connected to the node: "
"node = [%d] line = [%d]"
msgstr ""
+#, fuzzy
+#~ msgid "Error opening raster map %s"
+#~ msgstr "å·²ææ
æ ¼å°å¾ %d"
#~ msgid "Output name '%s' is not valid vector name."
#~ msgstr "è¾åºçåç§°'%s'䏿¯ææçç¢éåç§°ã"
Index: grassmods_zh.po
RCS file: /grassrepository/grass6/locale/po/grassmods_zh.po,v
retrieving revision 1.35
retrieving revision 1.36
diff -u -d -r1.35 -r1.36
--- grassmods_zh.po 21 Nov 2007 13:18:52 -0000 1.35
+++ grassmods_zh.po 29 Nov 2007 20:12:17 -0000 1.36
@@ -7,10 +7,10 @@
msgstr ""
"Project-Id-Version: grassmods_zh\n"
-"PO-Revision-Date: 2006-02-15 14:45+0800\n"
+"POT-Creation-Date: 2007-11-29 20:52+0100\n"
+"PO-Revision-Date: 2007-11-03 22:51+0800\n"
"MIME-Version: 1.0\n"
[...4704 lines suppressed...]
#~ msgid "Zooming finished.\n"
#~ msgstr "缩æ¾å®ç§°ã\n"
+#, fuzzy
+#~ msgid "%s: unable to re-open %s"
+#~ msgstr "æ æ³æå¼<%s>"
+#, fuzzy
+#~ msgid ""
+#~ "No database connection for driver <%s> is defined. Try to run db.connect."
+#~ msgstr "æ°æ®åºè¿æ¥æªå®ä¹"
+#, fuzzy
+#~ msgid "Database connection not defined for layer %d "
+#, fuzzy
+#~ msgid "Can't open vector map <%s> in <%s>"
+#~ msgstr "æ æ³æå¼ç¢éæä»¶<%s>å¨<%s>ä¸"
[ date ]
[ thread ]
[ subject ]
[ author ]
