[GRASS-CVS] carlos: grass6/locale/po grasslibs_ar.po, 1.14,
1.15 grasslibs_cs.po, 1.36, 1.37 grasslibs_de.po, 1.55, 1.56 grasslibs_el.po,
1.9, 1.10 grasslibs_es.po, 1.67, 1.68 grasslibs_fr.po, 1.31,
1.32 grasslibs_hi.po, 1.19, 1.20 grasslibs_it.po, 1.32, 1.33 grasslibs_ja.po,
1.29, 1.30 grasslibs_ko.po, 1.20, 1.21 grasslibs_lv.po, 1.18,
1.19 grasslibs_mr.po, 1.18, 1.19 grasslibs_pl.po, 1.21, 1.22 grasslibs_pt.po,
1.11, 1.12 grasslibs_pt_br.po, 1.27, 1.28 grasslibs_ru.po, 1.26,
1.27 grasslibs_sl.po, 1.22, 1.23 grasslibs_th.po, 1.1, 1.2 grasslibs_tr.po,
1.17, 1.18 grasslibs_vi.po, 1.22, 1.23 grassmods_ar.po, 1.26,
1.27 grassmods_cs.po, 1.51, 1.52 grassmods_de.po, 1.120,
1.121 grassmods_el.po, 1.9, 1.10 grassmods_es.po, 1.87, 1.88 grassmods_fr.po,
1.46, 1.47 grassmods_hi.po, 1.29, 1.30 grassmods_it.po, 1.42,
1.43 grassmods_ja.po, 1.40, 1.41 grassmods_ko.po, 1.28, 1.29 grassmods_lv.po,
1.28, 1.29 grassmods_mr.po, 1.28, 1.29 grassmods_pl.po, 1.31,
1.32 grassmods_pt.po, 1.7, 1.8 grassmods_pt_br.po, 1.44,
1.45 grassmods_ru.po, 1.36, 1.37 grassmods_sl.po, 1.
32, 1.33 grassmods_th.po, 1.1, 1.2 grassmods_tr.po, 1.28,
1.29 grassmods_vi.po, 1.34, 1.35 grasstcl_am.po, 1.4, 1.5 grasstcl_ar.po,
1.9, 1.10 grasstcl_cs.po, 1.18, 1.19 grasstcl_de.po, 1.26,
1.27 grasstcl_el.po, 1.9, 1.10 grasstcl_es.po, 1.61, 1.62 grasstcl_fr.po,
1.19, 1.20 grasstcl_hi.po, 1.15, 1.16 grasstcl_it.po, 1.21,
1.22 grasstcl_ja.po, 1.17, 1.18 grasstcl_ko.po, 1.9, 1.10 grasstcl_lv.po,
1.15, 1.16 grasstcl_mr.po, 1.10, 1.11 grasstcl_pl.po, 1.21,
1.22 grasstcl_pt.po, 1.12, 1.13 grasstcl_pt_br.po, 1.27, 1.28 grasstcl_ru.po,
1.15, 1.16 grasstcl_sl.po, 1.9, 1.10 grasstcl_th.po, 1.1, 1.2 grasstcl_tr.po,
1.16, 1.17 grasstcl_vi.po, 1.17, 1.18 grasstcl_zh.po, 1.9, 1.10
grass at intevation.de
Thu Nov 29 15:21:41 EST 2007
Author: carlos
Update of /grassrepository/grass6/locale/po
In directory doto:/tmp/cvs-serv792
Modified Files:
grasslibs_ar.po grasslibs_cs.po grasslibs_de.po
grasslibs_el.po grasslibs_es.po grasslibs_fr.po
grasslibs_hi.po grasslibs_it.po grasslibs_ja.po
grasslibs_ko.po grasslibs_lv.po grasslibs_mr.po
grasslibs_pl.po grasslibs_pt.po grasslibs_pt_br.po
grasslibs_ru.po grasslibs_sl.po grasslibs_th.po
grasslibs_tr.po grasslibs_vi.po grassmods_ar.po
grassmods_cs.po grassmods_de.po grassmods_el.po
grassmods_es.po grassmods_fr.po grassmods_hi.po
grassmods_it.po grassmods_ja.po grassmods_ko.po
grassmods_lv.po grassmods_mr.po grassmods_pl.po
grassmods_pt.po grassmods_pt_br.po grassmods_ru.po
grassmods_sl.po grassmods_th.po grassmods_tr.po
grassmods_vi.po grasstcl_am.po grasstcl_ar.po grasstcl_cs.po
grasstcl_de.po grasstcl_el.po grasstcl_es.po grasstcl_fr.po
grasstcl_hi.po grasstcl_it.po grasstcl_ja.po grasstcl_ko.po
grasstcl_lv.po grasstcl_mr.po grasstcl_pl.po grasstcl_pt.po
grasstcl_pt_br.po grasstcl_ru.po grasstcl_sl.po grasstcl_th.po
grasstcl_tr.po grasstcl_vi.po grasstcl_zh.po
Log Message:
Messages updated sync'ed
Index: grasslibs_ar.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_ar.po,v
retrieving revision 1.14
retrieving revision 1.15
diff -u -d -r1.14 -r1.15
--- grasslibs_ar.po 21 Nov 2007 13:18:49 -0000 1.14
+++ grasslibs_ar.po 29 Nov 2007 20:21:04 -0000 1.15
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grassmods_ar\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2007-10-26 21:10+0200\n"
+"POT-Creation-Date: 2007-11-29 20:51+0100\n"
"PO-Revision-Date: 2005-03-09 12:50+0100\n"
"Last-Translator: Dr. Alaa Masoud <alaamasoud at hotmail.com>\n"
"Language-Team: Arabic <translations at lists.osgeo.org>\n"
@@ -473,11 +473,11 @@
msgid "%s not set"
msgstr "%s ÙÙ
ÙØØ¯Ø¯"
-#: ../lib/gis/error.c:316
+#: ../lib/gis/error.c:315
msgid "WARNING: "
msgstr "ØªØØ°Ùر:"
-#: ../lib/gis/error.c:317
+#: ../lib/gis/error.c:316
msgid "ERROR: "
msgstr "خطÙÙÙÙØ£:"
@@ -1823,7 +1823,7 @@
msgid "Unable to change directory to %s"
msgstr " [%s] ØºÙØ± ÙØ§Ø¯Ø± عÙÙ Ø£ÙØ´Ø§Ø¡ Ù
Ù٠عÙÙØ§Ù Ø±Ø¦ÙØ³Ù Ù"
-#: ../lib/gis/system.c:87
+#: ../lib/gis/system.c:90
#, fuzzy
msgid "Can not create a new process!"
msgstr "ÙÙ
ÙØªÙ
Ø§ÙØ´Ø§Ø¡ عÙ
ÙÙØ© Ø¬Ø¯ÙØ¯Ø©"
@@ -2327,14 +2327,14 @@
msgstr ""
#: ../lib/gpde/N_arrays_io.c:55
-#, c-format
-msgid "Requested raster map <%s> not found"
-msgstr ""
+#, fuzzy, c-format
+msgid "Raster map <%s> not found"
+msgstr "ØºÙØ± Ù
ÙØ¬Ùد'%s' اÙÙÙÙØªÙر"
-#: ../lib/gpde/N_arrays_io.c:67 ../lib/gpde/N_arrays_io.c:190
+#: ../lib/gpde/N_arrays_io.c:67
#, fuzzy, c-format
-msgid "Error opening raster map %s"
-msgstr "ÙÙØ®Ø±Ø§Ø¦Ø· Ø§ÙØ±Ø§Ø³ØªØ±ÙØ© اÙÙ
ÙØ¬Ùدة %d\n"
+msgid "Unable to open raster map <%s>"
+msgstr " [%s] ØºÙØ± ÙØ§Ø¯Ø± عÙÙ Ø£ÙØ´Ø§Ø¡ Ù
#: ../lib/gpde/N_arrays_io.c:96
#, fuzzy, c-format
@@ -2355,6 +2355,11 @@
msgid "N_array_2d * array is empty"
msgstr ""
+#: ../lib/gpde/N_arrays_io.c:190
+#, fuzzy, c-format
+msgid "Unable to create raster map <%s>"
#: ../lib/gpde/N_arrays_io.c:199
#, c-format
msgid "Write 2d array to raster map <%s>"
@@ -2718,6 +2723,15 @@
msgid "ERROR - no response from graphics monitor <%s>.\n"
msgstr ""
+#: ../lib/rst/interp_float/input2d.c:49
+#, fuzzy, c-format
+msgid "Mask raster map <%s> not found"
+msgstr "ØºÙØ± Ù
+#: ../lib/rst/interp_float/input2d.c:72
+msgid "Bitmap mask created"
+msgstr ""
#: ../lib/rst/interp_float/segmen2d.c:123
msgid ""
"taking too long to find points for interpolation--please change the region "
@@ -2836,6 +2850,35 @@
msgid "Unable to open file %s"
msgstr "ÙÙ
ÙÙ
ÙÙ ÙØªØÙ %s ÙÙ %s"
+#: ../lib/vector/Vlib/array.c:84
+#, c-format
+msgid "%d errors in category string."
+msgstr ""
+#: ../lib/vector/Vlib/array.c:121 ../lib/vector/Vlib/array.c:229
+msgid "Mixed area and other type requested for vector array."
+msgstr ""
+#: ../lib/vector/Vlib/array.c:131 ../lib/vector/Vlib/array.c:151
+#: ../lib/vector/Vlib/array.c:261 ../lib/vector/Vlib/array.c:291
+msgid "Not enough space in vector array."
+msgstr ""
+#: ../lib/vector/Vlib/array.c:238 ../lib/vector/Vlib/net.c:170
+#: ../lib/vector/Vlib/net.c:302
+#, fuzzy
+msgid "Cannot get field info"
+msgstr "ÙÙ
ÙÙ
ÙÙ Ù
ØÙ Ø§ÙØ®Ø·"
+#: ../lib/vector/Vlib/array.c:244
+#, fuzzy
+msgid "Cannot open database"
+msgstr "ÙÙ
ÙØªÙ
ÙØªØ§Ø¨Ø© Ø±ÙØ§Ø¨Ø· ÙØ§Ø¹Ø¯Ø© Ø§ÙØ¨ÙØ§ÙØ§Øª"
+#: ../lib/vector/Vlib/array.c:253
+msgid "Could not select from table/column"
+msgstr ""
#: ../lib/vector/Vlib/build.c:27 ../lib/vector/Vlib/open.c:32
#: ../lib/vector/Vlib/write.c:36
msgid "Requested format is not compiled in this version"
@@ -3042,17 +3085,17 @@
msgid "Layer index out of range"
msgstr "دÙÙÙ Ø§ÙØ®Ùاص اÙÙ
Ø¶Ø§Ø¹ÙØ© اÙÙÙÙ
Ø© خارج اÙÙØ·Ø§Ù"
-#: ../lib/vector/Vlib/cindex.c:456
+#: ../lib/vector/Vlib/cindex.c:457
#, fuzzy, c-format
msgid "Unable to open cidx file <%s> for write"
msgstr "ÙÙ
ÙÙ
ÙÙ ÙØªØÙ %s ÙÙ %s"
-#: ../lib/vector/Vlib/cindex.c:464
+#: ../lib/vector/Vlib/cindex.c:465
#, fuzzy, c-format
msgid "Error writing out category index file <%s>"
msgstr "خطا ÙÙ ÙØªØ§Ø¨Ø© Ø§ÙØ¯ÙÙ٠اÙÙØ±Ø§ØºÙ\n"
-#: ../lib/vector/Vlib/cindex.c:507
+#: ../lib/vector/Vlib/cindex.c:508
#, fuzzy, c-format
msgid "Unable to open category index file for vector map <%s@%s>"
msgstr "'%s' ÙÙ
ÙÙ
ÙÙ ÙØªØ Ù
ÙÙ Ø§ÙØªØ§Ø±ÙØ® ÙÙÙÙÙØªÙر"
@@ -3266,11 +3309,6 @@
msgid "Arc field < 1"
msgstr ""
-#: ../lib/vector/Vlib/net.c:170 ../lib/vector/Vlib/net.c:302
-#, fuzzy
-msgid "Cannot get field info"
-msgstr "ÙÙ
ÙÙ
ÙÙ Ù
ØÙ Ø§ÙØ®Ø·"
#: ../lib/vector/Vlib/net.c:175 ../lib/vector/Vlib/net.c:306
#, fuzzy, c-format
msgid "Cannot open database <%s> by driver <%s>"
@@ -3418,37 +3456,37 @@
msgid "Cannot get feature geometry, FID [%ld]"
msgstr ""
-#: ../lib/vector/Vlib/snap.c:119 ../lib/vector/Vlib/snap.c:159
+#: ../lib/vector/Vlib/snap.c:117 ../lib/vector/Vlib/snap.c:157
#, fuzzy
msgid "Registering points"
msgstr ":تسجÙÙ Ø§ÙØ®Ø·ÙØ·"
-#: ../lib/vector/Vlib/snap.c:168
+#: ../lib/vector/Vlib/snap.c:166
msgid "All vertices"
msgstr ""
-#: ../lib/vector/Vlib/snap.c:169
+#: ../lib/vector/Vlib/snap.c:167
#, fuzzy
msgid "Registered points"
-#: ../lib/vector/Vlib/snap.c:214
+#: ../lib/vector/Vlib/snap.c:212
msgid "Nodes marked as anchor"
msgstr ""
-#: ../lib/vector/Vlib/snap.c:215
+#: ../lib/vector/Vlib/snap.c:213
msgid "Nodes marked to be snapped"
msgstr ""
-#: ../lib/vector/Vlib/snap.c:224 ../lib/vector/Vlib/snap.c:364
+#: ../lib/vector/Vlib/snap.c:222 ../lib/vector/Vlib/snap.c:362
msgid "Snaps"
msgstr ""
-#: ../lib/vector/Vlib/snap.c:372
+#: ../lib/vector/Vlib/snap.c:370
msgid "Snapped vertices"
msgstr ""
-#: ../lib/vector/Vlib/snap.c:373
+#: ../lib/vector/Vlib/snap.c:371
msgid "New vertices"
msgstr ""
@@ -3580,6 +3618,10 @@
"Attempt to read line angle for the line which is not connected to the node: "
"node = [%d] line = [%d]"
msgstr ""
+#, fuzzy
+#~ msgid "Error opening raster map %s"
+#~ msgstr "ÙÙØ®Ø±Ø§Ø¦Ø· Ø§ÙØ±Ø§Ø³ØªØ±ÙØ© اÙÙ
ÙØ¬Ùدة %d\n"
#~ msgid "Output name '%s' is not valid vector name."
#~ msgstr "ØºÙØ± ØµØ§ÙØ '%s' اسÙ
اÙÙ
Ù٠اÙÙÙÙØªÙر٠اÙÙ
خرج"
Index: grasslibs_cs.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_cs.po,v
retrieving revision 1.36
retrieving revision 1.37
diff -u -d -r1.36 -r1.37
--- grasslibs_cs.po 21 Nov 2007 13:18:49 -0000 1.36
+++ grasslibs_cs.po 29 Nov 2007 20:21:04 -0000 1.37
@@ -11,7 +11,7 @@
msgstr ""
"Project-Id-Version: grasslibs_cs\n"
"PO-Revision-Date: 2007-10-26 10:57+0200\n"
"Last-Translator: Martin Landa <landa.martin gmail.com>\n"
"Language-Team: Czech <translations at lists.osgeo.org>\n"
@@ -485,11 +485,11 @@
msgid "%s not set"
msgstr "%s není nastaveno"
msgid "WARNING: "
msgstr "UPOZORNÌNÍ: "
msgid "ERROR: "
msgstr "CHYBA: "
@@ -1856,7 +1856,7 @@
msgstr "Nelze zmìnit adresáø na %s"
msgstr "nelze vytvoøit nový proces"
@@ -2412,14 +2412,14 @@
"-- Math tool test skonèil úspì¹nì --"
-#, c-format
-msgstr "Po¾adovaná rastrová mapa <%s> nebyla nalezena"
+#, fuzzy, c-format
+msgstr "Vektorová mapa <%s> nebyla nalezena"
-#, c-format
-msgstr "Chyba pøi otevøení rastrové mapy %s"
+#, fuzzy, c-format
+msgstr "Nelze otevøít vektorovou mapu <%s>"
#, c-format
@@ -2438,6 +2438,11 @@
msgstr "N_array_2d * pole je prázdné"
+#, fuzzy, c-format
+msgstr "Nelze vytvoøit vektorovou mapu <%s>"
#, c-format
@@ -2808,6 +2813,15 @@
msgstr "CHYBA - ¾ádná odezva od grafického monitoru <%s>.\n"
+#, fuzzy, c-format
+msgstr "Po¾adovaná rastrová mapa <%s> nebyla nalezena"
+msgstr ""
msgid ""
@@ -2933,6 +2947,34 @@
msgstr "Nelze otevøít soubor %s"
+#, c-format
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr "Nelze získat informace o vrstvì"
+#, fuzzy
+msgstr "Nelze navázat spojení s databází %s"
+msgstr ""
@@ -3136,17 +3178,17 @@
msgstr "Index vrstev je mimo rozsah"
#, c-format
msgstr "Nelze otevøít soubor s indexem kategorií <%s> pro zápis"
#, c-format
msgstr "Chyba pøi zápisu souboru s indexem kategorií <%s>"
#, c-format
msgstr "Nelze otevøít soubor s indexem kategorií pro vektorovou mapu <%s@%s>"
@@ -3359,10 +3401,6 @@
msgstr "Arc vrtsva < 1"
-msgstr "Nelze získat informace o vrstvì"
#, c-format
@@ -3510,35 +3548,35 @@
msgstr "Nelze pøeèíst prvky geometrie, FID [%ld]"
msgstr "Registrace bodù"
msgstr "V¹echny opìrné body"
msgstr "Registrovaných bodù"
msgstr "Uzel oznaèen jako fixní"
msgstr "Uzel oznaèen jako pøipojený"
msgid "Snaps"
msgstr "Pøipojení"
msgstr "Pøipojených opìrných bodù"
msgstr "Nový opìrný bod"
@@ -3667,6 +3705,9 @@
msgstr ""
"Pokus o naètení úhlu linie pro linii, která není pøipojena k uzlu: \n"
"uzel = [%d] linie = [%d]"
+#~ msgstr "Chyba pøi otevøení rastrové mapy %s"
#~ msgstr "NÄÄzev vÄËstupu '%s' nenÄÂ platnÄËm nÄÄzvem vektorovÄÅ mapy."
Index: grasslibs_de.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_de.po,v
retrieving revision 1.55
retrieving revision 1.56
diff -u -d -r1.55 -r1.56
--- grasslibs_de.po 21 Nov 2007 13:18:49 -0000 1.55
+++ grasslibs_de.po 29 Nov 2007 20:21:04 -0000 1.56
@@ -9,7 +9,7 @@
msgstr ""
"Project-Id-Version: grasslibs_de\n"
"PO-Revision-Date: 2007-03-23 16:50+0100\n"
"Last-Translator: Stephan Holl <stephan.holl at intevation.de>\n"
"Language-Team: deutsch <translations at lists.osgeo.org>\n"
@@ -498,11 +498,11 @@
msgid "%s not set"
msgstr "%s nicht gesetzt"
msgid "WARNING: "
msgstr "WARNUNG: "
msgid "ERROR: "
msgstr "FEHLER: "
@@ -1895,7 +1895,7 @@
msgstr "Kann nicht zum Verzeichnis %s wechseln."
msgstr "Kann keinen neuen Prozess erzeugen!"
@@ -2458,14 +2458,14 @@
"-- Solver unit Tests erfolgreich beendet --"
-#, c-format
-msgstr "Angefragte Rasterkarte <%s> nicht gefunden."
+#, fuzzy, c-format
+msgstr "Eingabevektorkarte <%s> nicht gefunden."
-#, c-format
-msgstr "Fehler beim Öffnen der Rasterkarte %s"
+#, fuzzy, c-format
+msgstr "Kann nicht zum Verzeichnis %s wechseln."
#, c-format
@@ -2484,6 +2484,11 @@
msgstr "N_array_2d * Array ist leer"
+#, fuzzy, c-format
#, c-format
@@ -2874,6 +2879,15 @@
msgstr "Fehler - keine Antwort vom Graphikmonitor <%s>.\n"
+#, fuzzy, c-format
+msgstr "Angefragte Rasterkarte <%s> nicht gefunden."
+msgstr ""
msgid ""
@@ -3008,6 +3022,35 @@
msgstr "Kann Datei %s nicht öffnen."
+#, c-format
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "Kann die Layer-Informationen nicht abfragen."
+#, fuzzy
+msgstr "Kann Datenbank '%s' nicht öffnen."
+msgstr ""
@@ -3216,17 +3259,17 @@
msgstr "Matrix-Dimensionen liegen außerhalb der Spanne."
#, fuzzy, c-format
msgstr "Kann %s nicht zum Beschreiben öffnen."
#, fuzzy, c-format
msgstr "Fehler beim Schreiben des spatial index aufgetreten"
#, fuzzy, c-format
msgstr "Kann den Kategorieindex der Vektorkarte <%s> nicht öffnen."
@@ -3448,11 +3491,6 @@
msgstr ""
-#, fuzzy
-msgstr "Kann die Layer-Informationen nicht abfragen."
#, fuzzy, c-format
@@ -3603,37 +3641,37 @@
msgstr "Kann Objektgeometrie FID [%ld] nicht holen"
#, fuzzy
msgstr "Registriere Linien..."
msgstr ""
#, fuzzy
msgstr ""
msgstr ""
msgid "Snaps"
msgstr ""
msgstr ""
msgstr ""
@@ -3766,6 +3804,9 @@
msgstr ""
"Versuch, den Winkel einer Linie ,die nicht an den Knoten angebunden ist, zu "
"lesen: Knoten = [%d], Linie = [%d]"
+#~ msgstr "Fehler beim Öffnen der Rasterkarte %s"
#~ msgstr "Ergebniskarte '%s' ist kein gültiger Vektorkartenname."
Index: grasslibs_el.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_el.po,v
retrieving revision 1.9
retrieving revision 1.10
diff -u -d -r1.9 -r1.10
--- grasslibs_el.po 21 Nov 2007 13:18:49 -0000 1.9
+++ grasslibs_el.po 29 Nov 2007 20:21:04 -0000 1.10
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grasslibs_el\n"
"PO-Revision-Date: 2007-03-23 16:35+0100\n"
"Last-Translator: Carlos Davila <carluti at users.sourceforge.net>\n"
"Language-Team: Greek <translations at lists.osgeo.org>\n"
@@ -462,11 +462,11 @@
msgid "%s not set"
msgstr ""
msgid "WARNING: "
msgstr ""
msgid "ERROR: "
msgstr ""
@@ -1767,7 +1767,7 @@
msgstr ""
msgstr ""
@@ -2264,12 +2264,12 @@
#, c-format
msgstr ""
#, c-format
msgstr ""
@@ -2289,6 +2289,11 @@
msgstr ""
+#, c-format
+msgstr ""
#, c-format
@@ -2644,6 +2649,15 @@
msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
msgid ""
@@ -2761,6 +2775,33 @@
msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
@@ -2960,17 +3001,17 @@
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
@@ -3180,10 +3221,6 @@
msgstr ""
-msgstr ""
#, c-format
@@ -3324,35 +3361,35 @@
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgid "Snaps"
msgstr ""
msgstr ""
msgstr ""
Index: grasslibs_es.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_es.po,v
retrieving revision 1.67
retrieving revision 1.68
diff -u -d -r1.67 -r1.68
--- grasslibs_es.po 21 Nov 2007 13:18:49 -0000 1.67
+++ grasslibs_es.po 29 Nov 2007 20:21:04 -0000 1.68
@@ -14,10 +14,10 @@
msgstr ""
"Project-Id-Version: grasslibs_es\n"
-"PO-Revision-Date: 2007-10-19 12:32+0200\n"
+"PO-Revision-Date: 2007-11-29 09:26+0100\n"
-"Language-Team: Español <translations at lists.osgeo.org>\n"
+"Language-Team: Español <grass-translations at lists.osgeo.org>\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=ISO-8859-1\n"
"Content-Transfer-Encoding: 8bit\n"
@@ -504,11 +504,11 @@
msgid "%s not set"
msgstr "%s no inicializado"
msgid "WARNING: "
msgstr "ATENCIÓN: "
msgid "ERROR: "
msgstr "ERROR: "
@@ -1896,7 +1896,7 @@
msgstr "No se puede cambiar el directorio a %s"
msgstr "¡No se puede crear un proceso nuevo!"
@@ -2473,13 +2473,13 @@
#, c-format
-msgstr "No se encontró el mapa ráster <%s> solicitado"
+msgstr "No se encuentra el mapa ráster <%s>"
#, c-format
-msgstr "Error al abrir el mapa ráster %s"
+msgstr "No se puede abrir el mapa ráster <%s>"
#, c-format
@@ -2498,6 +2498,11 @@
msgstr "N_array_2d * la matriz está vacía"
+#, c-format
+msgstr "No se puede crear el mapa ráster <%s>"
#, c-format
@@ -2884,6 +2889,15 @@
msgstr "ERROR - el monitor de gráficos <%s> no reponde.\n"
+#, c-format
+msgstr "No se encuentra el mapa ráster de máscara <%s>"
+msgstr "Creada máscara de mapa de bits"
msgid ""
@@ -3016,6 +3030,33 @@
msgstr "No se puede abrir el archivo %s "
+#, c-format
+msgstr "%d errores en la cadena de categoría."
+msgstr "Área mixta y otro tipo solicitado para la matriz vectorial."
+msgstr "Espacio insuficiente en la matriz vectorial."
+msgstr "No se puede obtener información de la capa"
+msgstr "No se puede abrir la base de datos"
+msgstr "No se pudo seleccionar de la tabla/columna"
@@ -3209,9 +3250,8 @@
msgstr "Índice de capa no válido (índice >= número de capas)"
#: ../lib/vector/Vlib/cindex.c:110
-#, fuzzy
msgid "Invalid layer index (index < 0 or index >= number of layers)"
-msgstr "Índice de capa no válido (índice >= número de capas)"
+msgstr "Índice de capa no válido (índice < 0 o índice >= número de capas)"
#: ../lib/vector/Vlib/cindex.c:235
msgid "Layer or category index out of range"
@@ -3221,18 +3261,18 @@
msgstr "Índice de capa fuera del intervalo"
#, c-format
msgstr "No se puede abrir el archivo cidx <%s> para escritura"
#, c-format
msgstr "Error al escribir el archivo de índices de categoría <%s>"
#, c-format
msgstr ""
@@ -3462,10 +3502,6 @@
msgstr "Campo de arco < 1"
-msgstr "No se puede obtener información de la capa"
#, c-format
@@ -3589,9 +3625,9 @@
msgstr "No se puede crear el mapa vectorial <%s>"
#: ../lib/vector/Vlib/open.c:590
-#, fuzzy, c-format
+#, c-format
msgid "Unable to stat file <%s>"
-msgstr "No se puede abrir el archivo %s "
+msgstr "No se puede abrir el archivo <%s>"
#: ../lib/vector/Vlib/open.c:701
msgid "Size of 'coor' file differs from value saved in topology file"
@@ -3625,35 +3661,35 @@
msgstr "No se puede adquirir la geometría, FID [%ld]"
msgstr "Registrando puntos: "
msgstr "Todos los vértices"
msgstr "Nodos marcados como fijos"
msgstr "Nodos marcados para eliminar"
msgid "Snaps"
msgstr ""
msgstr "Vértices eliminados"
msgstr "Nuevos vértices"
@@ -3793,6 +3829,3 @@
msgstr ""
"Intento de leer el ángulo para la línea que no está conectada al nodo: nodo "
"= [%d] línea = [%d]"
-#~ msgid "The vector map <%s> already exists and will be overwritten"
-#~ msgstr "El mapa vectorial <%s> ya existe y será sobrescrito"
Index: grasslibs_fr.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_fr.po,v
retrieving revision 1.31
retrieving revision 1.32
diff -u -d -r1.31 -r1.32
--- grasslibs_fr.po 21 Nov 2007 13:18:49 -0000 1.31
+++ grasslibs_fr.po 29 Nov 2007 20:21:04 -0000 1.32
@@ -9,7 +9,7 @@
msgstr ""
"Project-Id-Version: grasslibs_fr\n"
"PO-Revision-Date: 2005-02-23 20:47-0500\n"
"Last-Translator: Eve\n"
"Language-Team: French <translations at lists.osgeo.org>\n"
@@ -495,11 +495,11 @@
msgid "%s not set"
msgstr "%s n'a pas de valeur"
msgid "WARNING: "
msgstr "ATTENTION: "
msgid "ERROR: "
msgstr "ERREUR:"
@@ -1916,7 +1916,7 @@
msgstr "impossible de changer de répertoire pour aller dans %s"
#, fuzzy
msgstr "impossible de créer un nouveau processus"
@@ -2441,14 +2441,14 @@
msgstr ""
-#, c-format
-msgstr ""
+#, fuzzy, c-format
+msgstr "Le vecteur d'entrée '%s' n'a pas été trouvé"
#, fuzzy, c-format
-msgstr "pour la couche raster existante %d"
+msgstr "impossible de changer de répertoire pour aller dans %s"
#, fuzzy, c-format
@@ -2469,6 +2469,11 @@
msgstr ""
+#, fuzzy, c-format
#, c-format
@@ -2837,6 +2842,15 @@
msgstr "ERREUR - le moniteur graphique <%s> ne répond pas.\n"
+#, fuzzy, c-format
+msgstr ""
msgid ""
@@ -2971,6 +2985,35 @@
msgstr "Impossible d'ouvrir le fichier %s dans %s"
+#, c-format
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "Impossible de récupérer les infos de la couche"
+#, fuzzy
+msgstr "Impossible d'ouvrir la base de données %s"
+msgstr ""
@@ -3177,17 +3220,17 @@
msgstr "Index de l'attribut double en dehors des limites"
#, fuzzy, c-format
msgstr "Impossible d'ouvrir %s en écriture"
#, fuzzy, c-format
msgstr "Erreur lors de l'écriture du fichier d'index spatial.\n"
#, fuzzy, c-format
msgstr "Impossible d'ouvrir le fichier d'historique pour le vecteur '%s'"
@@ -3408,11 +3451,6 @@
msgstr ""
-#, fuzzy
-msgstr "Impossible de récupérer les infos de la couche"
#, fuzzy, c-format
@@ -3566,37 +3604,37 @@
msgstr ""
#, fuzzy
msgstr "Enregistrement des lignes: "
msgstr ""
#, fuzzy
msgstr ""
msgstr ""
msgid "Snaps"
msgstr ""
msgstr ""
msgstr ""
@@ -3732,6 +3770,10 @@
msgstr ""
+#, fuzzy
+#~ msgstr "pour la couche raster existante %d"
#~ msgstr "Le nom de sortie '%s' n'est pas un nom de vecteur valide."
Index: grasslibs_hi.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_hi.po,v
retrieving revision 1.19
retrieving revision 1.20
diff -u -d -r1.19 -r1.20
--- grasslibs_hi.po 21 Nov 2007 13:18:49 -0000 1.19
+++ grasslibs_hi.po 29 Nov 2007 20:21:04 -0000 1.20
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grasslibs_hi\n"
"PO-Revision-Date: 2005-12-22 14:34+0100\n"
"Last-Translator: Markus Neteler <neteler at itc.it>\n"
"Language-Team: Hindi <translations at lists.osgeo.org>\n"
@@ -477,11 +477,11 @@
msgid "%s not set"
msgstr "नहà¥à¤ सà¥à¤"
msgid "WARNING: "
msgstr ""
#, fuzzy
msgid "ERROR: "
msgstr "तà¥à¤°à¥à¤à¤¿ "
@@ -1858,7 +1858,7 @@
msgstr "à¤à¥ लिà¤"
#, fuzzy
msgstr "नहà¥à¤ a!"
@@ -2361,13 +2361,13 @@
msgstr ""
-#, c-format
-msgstr ""
+#, fuzzy, c-format
+msgstr "नहà¥à¤"
#, fuzzy, c-format
msgstr "à¤à¥ लिà¤"
@@ -2389,6 +2389,11 @@
msgstr ""
+#, fuzzy, c-format
+msgstr "à¤à¥ लिà¤"
#, c-format
@@ -2753,6 +2758,15 @@
msgstr "तà¥à¤°à¥à¤à¤¿ n"
+#, fuzzy, c-format
+msgstr "नहà¥à¤"
+msgstr ""
#, fuzzy
msgid ""
@@ -2877,6 +2891,35 @@
msgstr "à¤à¤¾"
+#, c-format
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "à¤à¥ लिठn"
+#, fuzzy
+msgstr "लिà¤à¤ ."
+msgstr ""
#, fuzzy
@@ -3087,17 +3130,17 @@
msgstr "दà¥à¤à¥à¤¨à¤¾ à¤à¤¾"
#, fuzzy, c-format
msgstr "à¤à¥ लिà¤"
#, fuzzy, c-format
#, fuzzy, c-format
msgstr "à¤à¥ लिà¤"
@@ -3315,11 +3358,6 @@
msgstr ""
-#, fuzzy
-msgstr "à¤à¥ लिठn"
#, fuzzy, c-format
@@ -3467,35 +3505,35 @@
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgid "Snaps"
msgstr ""
msgstr ""
msgstr ""
@@ -3631,6 +3669,10 @@
msgstr ""
+#, fuzzy
+#~ msgstr "à¤à¥ लिà¤"
#, fuzzy
Index: grasslibs_it.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_it.po,v
retrieving revision 1.33
diff -u -d -r1.32 -r1.33
--- grasslibs_it.po 21 Nov 2007 13:18:49 -0000 1.32
+++ grasslibs_it.po 29 Nov 2007 20:21:04 -0000 1.33
@@ -11,7 +11,7 @@
msgstr ""
"Project-Id-Version: grasslibs_it\n"
"PO-Revision-Date: 2007-11-21 12:41+0100\n"
"Last-Translator: Tobias Vigl <vigltobias at icqmail.com>\n"
"Language-Team: Italian <translations at lists.osgeo.org>\n"
@@ -24,25 +24,30 @@
#: ../lib/db/dbmi_base/legal_dbname.c:24
#, fuzzy, c-format
[...1589 lines suppressed...]
#~ msgid "open mode = %d"
#~ msgstr "modalità di apertura = %d"
#~ msgid "Cell header %p"
#~ msgstr "Intestazione cella %p"
@@ -3920,10 +3942,12 @@
#, fuzzy
#~ msgid "Not able to open cellfile for [%s]"
#~ msgstr "Impossibile aprire il file %s in %s"
#~ msgid "Too many open raster maps"
#~ msgstr "Troppi file raster aperti"
#~ msgid "Too many open files"
#~ msgstr "Troppi file aperti"
#~ msgid "ERROR: GISBASE not set\n"
#~ msgstr "ERRORE: GISBASE non definito\n"
Index: grasslibs_ja.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_ja.po,v
retrieving revision 1.29
retrieving revision 1.30
diff -u -d -r1.29 -r1.30
--- grasslibs_ja.po 21 Nov 2007 13:18:49 -0000 1.29
+++ grasslibs_ja.po 29 Nov 2007 20:21:04 -0000 1.30
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grasslibs_ja\n"
"PO-Revision-Date: 2005-12-30 17:41+0100\n"
"Language-Team: Japanese <translations at lists.osgeo.org>\n"
@@ -465,11 +465,11 @@
msgid "%s not set"
msgstr ""
msgid "WARNING: "
msgstr ""
msgid "ERROR: "
msgstr ""
@@ -1815,7 +1815,7 @@
msgstr "����� ���� ���\n"
#, fuzzy
msgstr "�������: ����� �����������n"
@@ -2316,15 +2316,15 @@
msgstr ""
-#, c-format
-msgstr ""
#, fuzzy, c-format
msgstr "���"
+#, fuzzy, c-format
+msgstr "����� ���� ���\n"
#, fuzzy, c-format
msgid "Reading raster map <%s> into memory"
@@ -2343,6 +2343,11 @@
msgstr ""
+#, fuzzy, c-format
#, c-format
@@ -2709,6 +2714,15 @@
msgstr "��� - ����������<%s> � ����.\n"
+#, fuzzy, c-format
+msgstr "���"
+msgstr ""
msgid ""
@@ -2826,6 +2840,35 @@
msgstr "���"
+#, c-format
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "���"
+#, fuzzy
+msgstr "���"
+msgstr ""
@@ -3025,17 +3068,17 @@
msgstr ""
#, fuzzy, c-format
msgstr "���"
#, fuzzy, c-format
msgstr "���"
#, fuzzy, c-format
msgstr "���"
@@ -3246,11 +3289,6 @@
msgstr ""
-#, fuzzy
-msgstr "���"
#, fuzzy, c-format
@@ -3393,35 +3431,35 @@
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgid "Snaps"
msgstr ""
msgstr ""
msgstr ""
@@ -3552,6 +3590,10 @@
msgstr ""
+#, fuzzy
+#~ msgstr "���"
#, fuzzy
Index: grasslibs_ko.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_ko.po,v
retrieving revision 1.21
diff -u -d -r1.20 -r1.21
--- grasslibs_ko.po 21 Nov 2007 13:18:49 -0000 1.20
+++ grasslibs_ko.po 29 Nov 2007 20:21:04 -0000 1.21
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grasslibs_ko\n"
"PO-Revision-Date: 2005-12-22 14:49+0100\n"
"Last-Translator: Huidae Cho\n"
"Language-Team: Korean <translations at lists.osgeo.org>\n"
@@ -475,11 +475,11 @@
msgid "%s not set"
msgstr ""
msgid "WARNING: "
msgstr ""
msgid "ERROR: "
msgstr ""
@@ -1780,7 +1780,7 @@
msgstr ""
msgstr ""
@@ -2277,13 +2277,13 @@
#, c-format
msgstr ""
-#, c-format
-msgstr ""
+#, fuzzy, c-format
+msgstr "Datum %s í
ì´ë¸íì¼ì ì´ ì ììµëë¤"
#, c-format
@@ -2303,6 +2303,11 @@
msgstr ""
+#, fuzzy, c-format
+msgstr "Datum %s í
#, c-format
@@ -2658,6 +2663,15 @@
msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
msgid ""
@@ -2775,6 +2789,35 @@
msgstr "Datum %s í
+#, c-format
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "ììíì¼ì ì´ ì ììµëë¤"
+#, fuzzy
+msgstr ""
@@ -2974,17 +3017,17 @@
msgstr ""
#, fuzzy, c-format
msgstr "Datum %s í
#, fuzzy, c-format
#, fuzzy, c-format
@@ -3194,11 +3237,6 @@
msgstr ""
-#, fuzzy
-msgstr "ììíì¼ì ì´ ì ììµëë¤"
#, fuzzy, c-format
@@ -3341,35 +3379,35 @@
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgid "Snaps"
msgstr ""
msgstr ""
msgstr ""
Index: grasslibs_lv.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_lv.po,v
retrieving revision 1.18
diff -u -d -r1.18 -r1.19
--- grasslibs_lv.po 21 Nov 2007 13:18:49 -0000 1.18
+++ grasslibs_lv.po 29 Nov 2007 20:21:04 -0000 1.19
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grasslibs_lv\n"
"PO-Revision-Date: 2006-12-09 01:00+0200\n"
"Last-Translator: Maris Nartiss <maris.kde at gmail.com>\n"
"Language-Team: Latvian <translations at lists.osgeo.org>\n"
msgid "%s not set"
msgstr "%s nav norÄdÄ«ts"
msgid "WARNING: "
msgstr "BRĪDINÄJUMS:"
msgid "ERROR: "
msgstr "KĻŪDA:"
@@ -1872,7 +1872,7 @@
msgstr "neispÄjami mainÄ«t direktoriju uz %s"
msgstr "Nevar izveidot jaunu procesu!"
@@ -2393,14 +2393,14 @@
msgstr ""
-#, c-format
-msgstr ""
+#, fuzzy, c-format
+msgstr "Ieejas vektors '%s' nav atrasts"
#, fuzzy, c-format
-msgstr "eksistÄjoÅ¡Äm rastra kartÄm %d"
+msgstr "neispÄjami mainÄ«t direktoriju uz %s"
#, fuzzy, c-format
@@ -2421,6 +2421,11 @@
msgstr ""
+#, fuzzy, c-format
#, c-format
@@ -2788,6 +2793,15 @@
msgstr "KĻŪDA - nav atbildes no grafiskÄ monitora <%s>\n"
+#, fuzzy, c-format
+msgstr ""
msgid ""
@@ -2905,6 +2919,35 @@
msgstr "NeiespÄjami atvÄrt failu %s iekÅ¡ %s"
+#, c-format
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "Nevar iegÅ«t slÄÅa informÄciju"
+#, fuzzy
+msgstr "Nevar atvÄrt datubÄzi %s"
+msgstr ""
@@ -3111,17 +3154,17 @@
msgstr "Dubulto atribÅ«tu indekss Ärpus diapazona"
#, fuzzy, c-format
msgstr "NeiespÄjami atvÄrt %s priekÅ¡ rakstīšanas"
#, fuzzy, c-format
msgstr "Kļūdu rakstīšana Ärpus telpisko datu index faila.\n"
#, fuzzy, c-format
msgstr "Nevar atvÄrt vÄsturi vektoram '%s'"
@@ -3339,11 +3382,6 @@
msgstr ""
-#, fuzzy
-msgstr "Nevar iegÅ«t slÄÅa informÄciju"
#, fuzzy, c-format
@@ -3495,37 +3533,37 @@
msgstr ""
#, fuzzy
msgstr "SaglabÄjam/reÄ£istrÄjam lÄ«nijas"
msgstr ""
#, fuzzy
msgstr ""
msgstr ""
msgid "Snaps"
msgstr ""
msgstr ""
msgstr ""
@@ -3658,6 +3696,10 @@
msgstr ""
+#, fuzzy
+#~ msgstr "eksistÄjoÅ¡Äm rastra kartÄm %d"
#~ msgstr "Izejas vÄrds '%s' nav derÄ«gs vektora nosaukums."
Index: grasslibs_mr.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_mr.po,v
--- grasslibs_mr.po 26 Oct 2007 19:35:21 -0000 1.18
+++ grasslibs_mr.po 29 Nov 2007 20:21:04 -0000 1.19
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: Grass 6.0\n"
"PO-Revision-Date: 2005-06-02 18:00+0530\n"
"Last-Translator: Swapnil Hajare <dreamil at gmail.com>\n"
"Language-Team: Marathi <www.janabhaaratii.org.in>\n"
@@ -464,11 +464,11 @@
msgid "%s not set"
msgstr ""
msgid "WARNING: "
msgstr "ताà¤à¤¿à¤¦: "
msgid "ERROR: "
msgstr "तà¥à¤°à¥à¤à¥: "
@@ -1774,7 +1774,7 @@
msgstr ""
msgstr ""
@@ -2270,14 +2270,14 @@
msgstr ""
-#, c-format
-msgstr ""
+#, fuzzy, c-format
+msgstr "%s मिळालॠनाहà¥"
-#, c-format
-msgstr ""
+#, fuzzy, c-format
+msgstr "%s à¤à¤à¤¡à¤¤à¤¾ à¤à¤²à¥ नाहà¥"
#, fuzzy, c-format
@@ -2297,6 +2297,11 @@
msgstr ""
+#, fuzzy, c-format
#, c-format
@@ -2652,6 +2657,15 @@
msgstr ""
+#, fuzzy, c-format
+msgstr ""
msgid ""
@@ -2769,6 +2783,35 @@
+#, c-format
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "temp फाà¤à¤² à¤à¤à¤¡à¤¤à¤¾ à¤à¤²à¥ नाहà¥"
+#, fuzzy
+msgstr ""
@@ -2968,17 +3011,17 @@
msgstr ""
#, fuzzy, c-format
#, fuzzy, c-format
#, fuzzy, c-format
@@ -3188,11 +3231,6 @@
msgstr ""
-#, fuzzy
-msgstr "temp फाà¤à¤² à¤à¤à¤¡à¤¤à¤¾ à¤à¤²à¥ नाहà¥"
#, fuzzy, c-format
@@ -3336,35 +3374,35 @@
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgid "Snaps"
msgstr ""
msgstr ""
msgstr ""
Index: grasslibs_pl.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_pl.po,v
retrieving revision 1.22
diff -u -d -r1.21 -r1.22
--- grasslibs_pl.po 26 Oct 2007 19:35:21 -0000 1.21
+++ grasslibs_pl.po 29 Nov 2007 20:21:04 -0000 1.22
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grasslibs_pl\n"
"PO-Revision-Date: 2007-09-21 14:20+0100\n"
"Last-Translator: Monika Tylus <monikatylus_gmail.com>\n"
"Language-Team: Polska <translation at grass.itc.it>\n"
msgid "%s not set"
msgstr ""
msgid "WARNING: "
msgstr "UWAGA:"
msgid "ERROR: "
msgstr "B£¡D:"
@@ -1885,7 +1885,7 @@
msgstr "Nie mo¿na utworzyæ nag³ówka pliku dla [%s]"
msgstr ""
@@ -2418,14 +2418,14 @@
msgstr "nieznany typ interpolacji"
-#, c-format
-msgstr ""
+#, fuzzy, c-format
+msgstr "Nie mo¿na znale¼æ wektora ¼ród³owego '%s'"
#, fuzzy, c-format
-msgstr "dla istniej±cych map rastrowych %d"
+msgstr "Nie mo¿na otworzyæ %s"
#, fuzzy, c-format
@@ -2446,6 +2446,11 @@
msgstr ""
+#, fuzzy, c-format
+msgstr "Nie mo¿na utworzyæ nag³ówka pliku dla [%s]"
#, c-format
@@ -2816,6 +2821,15 @@
msgstr ""
+#, fuzzy, c-format
+msgstr ""
msgid ""
@@ -2938,6 +2952,34 @@
msgstr "W %s nie mo¿na otworzyæ pliku %s"
+#, c-format
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr "Brak informacji o polu"
+#, fuzzy
+msgstr "Nie mo¿na otworzyæ bazy danych %s"
+msgstr ""
@@ -3140,17 +3182,17 @@
msgstr "Nieprawid³owy rozmiar macierzy"
#, fuzzy, c-format
msgstr "Nie mo¿na otworzyæ %s do zapisu"
#, fuzzy, c-format
msgstr "b³±d podczas zapisu zerowego wiersza %d"
#, fuzzy, c-format
msgstr "Nie mo¿na otworzyæ pliku ¶ledzenia b³êdu '%s'"
@@ -3367,10 +3409,6 @@
msgstr ""
-msgstr "Brak informacji o polu"
#, fuzzy, c-format
@@ -3518,35 +3556,35 @@
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgid "Snaps"
msgstr ""
msgstr ""
msgstr ""
@@ -3677,6 +3715,10 @@
msgstr ""
+#, fuzzy
+#~ msgstr "dla istniej±cych map rastrowych %d"
#~ msgstr "Nazwa wyniku '%s' nie jest poprawn± nazw± wektora."
Index: grasslibs_pt.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_pt.po,v
retrieving revision 1.11
retrieving revision 1.12
diff -u -d -r1.11 -r1.12
--- grasslibs_pt.po 21 Nov 2007 13:18:49 -0000 1.11
+++ grasslibs_pt.po 29 Nov 2007 20:21:04 -0000 1.12
@@ -10,7 +10,7 @@
msgstr ""
"Project-Id-Version: grasslibs_pt\n"
"PO-Revision-Date: 2007-06-18 22:26-0300\n"
"Last-Translator: Paulo E. P. Marcondes <paulomarcondes at gmail dot com>\n"
"Language-Team: Portuguese <translations at lists.osgeo.org>\n"
@@ -483,11 +483,11 @@
msgid "%s not set"
msgstr "%s não inicializado"
msgid "WARNING: "
msgstr "ATENÇÃO: "
msgid "ERROR: "
msgstr "ERRO:"
@@ -1859,7 +1859,7 @@
msgstr "Impossível mudar de diretório para %s"
msgstr "não consegui criar novo processo!"
@@ -2370,14 +2370,14 @@
msgstr ""
-#, c-format
-msgstr "Mapa raster solicitado <%s> não encontrado"
+#, fuzzy, c-format
+msgstr "Vetor de entrada '%s' não encontrado"
-#, c-format
-msgstr "ERRO abrindo mapa raster %s"
+#, fuzzy, c-format
+msgstr "Impossível mudar de diretório para %s"
#, c-format
@@ -2396,6 +2396,11 @@
msgstr ""
+#, fuzzy, c-format
#, c-format
@@ -2759,6 +2764,15 @@
msgstr "ERRO - O monitor gráfico <%s> não está respondendo.\n"
+#, fuzzy, c-format
+msgstr "Mapa raster solicitado <%s> não encontrado"
+msgstr ""
msgid ""
@@ -2883,6 +2897,34 @@
msgstr "Impossível abrir arquivo %s"
+#, c-format
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr "Impossível obter informação do campo"
+#, fuzzy
+msgstr "não consegui abrir banco de dados %s"
+msgstr ""
@@ -3087,17 +3129,17 @@
msgstr "Dimensões da matriz além dos limites"
#, fuzzy, c-format
msgstr "não consegui abrir %s para escrita"
#, fuzzy, c-format
msgstr "Erro de escrita no arquivo de índices espaciais."
#, fuzzy, c-format
msgstr "Impossível abrir índice de categoria para mapa vetorial <%s>"
@@ -3312,10 +3354,6 @@
-msgstr "Impossível obter informação do campo"
#, c-format
@@ -3461,35 +3499,35 @@
msgstr "Impossível obter geometria do elemento, FID [%ld]"
msgstr "Registrando pontos"
msgstr "Todos os vértices"
msgstr "Pontos registrados"
msgstr ""
msgstr "Nós marcados para encaixar"
msgid "Snaps"
msgstr "Encaixe"
msgstr "Vértices encaixados"
msgstr "Novos vértices"
@@ -3617,6 +3655,9 @@
msgstr ""
+#~ msgstr "ERRO abrindo mapa raster %s"
#~ msgstr "Nome de arquivo de saída %s não é um nome de vetor válido."
Index: grasslibs_pt_br.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_pt_br.po,v
retrieving revision 1.27
retrieving revision 1.28
diff -u -d -r1.27 -r1.28
--- grasslibs_pt_br.po 21 Nov 2007 13:18:49 -0000 1.27
+++ grasslibs_pt_br.po 29 Nov 2007 20:21:04 -0000 1.28
@@ -10,7 +10,7 @@
msgstr ""
"Project-Id-Version: grasslibs_pt_br\n"
"PO-Revision-Date: 2007-05-20 10:44-0300\n"
"Last-Translator: Paulo E. P. Marcondes <paulomarcondes at gmail.com>\n"
"Language-Team: Brazilian Portuguese <translations at lists.osgeo.org>\n"
msgid "%s not set"
msgid "WARNING: "
msgstr "ATENÇÃO: "
msgid "ERROR: "
msgstr "ERRO:"
@@ -1864,7 +1864,7 @@
msgstr ""
-#, c-format
-msgstr ""
+#, fuzzy, c-format
-#, c-format
+#, fuzzy, c-format
#, c-format
@@ -2398,6 +2398,11 @@
msgstr ""
+#, fuzzy, c-format
#, c-format
@@ -2765,6 +2770,15 @@
+#, fuzzy, c-format
+msgstr ""
msgid ""
@@ -2889,6 +2903,35 @@
msgstr "não foi possível abrir o arquivo %s em %s"
+#, c-format
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "não consegui obter informações de camada"
+#, fuzzy
+msgstr ""
@@ -3093,17 +3136,17 @@
#, fuzzy, c-format
#, fuzzy, c-format
msgstr "Erro de escrita no arquivo de índices espaciais.\n"
#, fuzzy, c-format
msgstr "Não consegui abrir histórico para o vetor %s"
@@ -3320,11 +3363,6 @@
msgstr ""
-#, fuzzy
-msgstr "não consegui obter informações de camada"
#, fuzzy, c-format
@@ -3475,37 +3513,37 @@
msgstr ""
#, fuzzy
msgstr "Registrando linhas: "
msgstr ""
#, fuzzy
msgstr ""
msgstr ""
msgid "Snaps"
msgstr ""
msgstr ""
msgstr ""
@@ -3637,6 +3675,9 @@
msgstr ""
Index: grasslibs_ru.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_ru.po,v
retrieving revision 1.26
diff -u -d -r1.26 -r1.27
--- grasslibs_ru.po 21 Nov 2007 13:18:49 -0000 1.26
+++ grasslibs_ru.po 29 Nov 2007 20:21:04 -0000 1.27
@@ -6,7 +6,7 @@
msgstr ""
"Project-Id-Version: grasslibs_ru\n"
"PO-Revision-Date: 2006-07-07 11:52+0200\n"
"Language-Team: Russian <translations at lists.osgeo.org>\n"
@@ -481,12 +481,12 @@
msgid "%s not set"
msgstr "%s ÎÅ ÕÓÔÁÎÏ×ÌÅÎ"
#, fuzzy
msgid "WARNING: "
msgstr "ðòåäõðòåöäåîéå "
#, fuzzy
msgid "ERROR: "
msgstr "ïûéâëá "
@@ -1860,7 +1860,7 @@
msgstr " "
msgstr ""
@@ -2361,14 +2361,14 @@
msgstr ""
-#, c-format
-msgstr ""
+#, fuzzy, c-format
+msgstr "×ÅËÔÏÒ "
#, fuzzy, c-format
-msgstr "óÌÉÛËÏÍ ÍÎÏÇÏ ÒÁÓÔÒÏ×ÙÈ ÆÁÊÌÏ× ÏÔËÒÙÔÙ"
+msgstr " "
#, fuzzy, c-format
msgstr ""
+#, fuzzy, c-format
+msgstr " "
#, c-format
@@ -2751,6 +2756,15 @@
msgstr "ïûéâëá - ÇÒÁÆÉÞÅÓËÉÊ ÄÉÓÐÌÅÊ <%s> ÎÅ ÏÔ×ÅÞÁÅÔ.\n"
+#, fuzzy, c-format
+msgstr "×ÅËÔÏÒ "
+msgstr ""
#, fuzzy
msgid ""
@@ -2873,6 +2887,35 @@
msgstr "îÅ×ÏÚÍÏÖÎÏ ÏÔËÒÙÔØ ÆÁÊÌ %s × %s"
+#, c-format
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "îÅ ÍÏÇÕ ÏÔËÒÙÔØ ×ÒÅÍ. ÆÁÊÌ"
+#, fuzzy
+msgstr " "
+msgstr ""
#, fuzzy
@@ -3074,17 +3117,17 @@
msgstr ""
#, fuzzy, c-format
msgstr "îÅ×ÏÚÍÏÖÎÏ ÏÔËÒÙÔØ %s ÄÌÑ ÚÁÐÉÓÉ"
#, fuzzy, c-format
msgstr "ïÛÉÂËÁ ÚÁÐÉÓÉ × ÆÁÊÌ Ó ÐÌÁ×ÁÀÝÅÊ ÔÏÞËÏÊ ÄÌÑ ËÁÒÔÙ %s"
#, fuzzy, c-format
msgstr "×ÅËÔÏÒ "
@@ -3299,11 +3342,6 @@
msgstr ""
-#, fuzzy
-msgstr "îÅ ÍÏÇÕ ÏÔËÒÙÔØ ×ÒÅÍ. ÆÁÊÌ"
#, fuzzy, c-format
@@ -3448,35 +3486,35 @@
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgid "Snaps"
msgstr ""
msgstr ""
msgstr ""
@@ -3609,6 +3647,10 @@
msgstr ""
+#, fuzzy
+#~ msgstr "óÌÉÛËÏÍ ÍÎÏÇÏ ÒÁÓÔÒÏ×ÙÈ ÆÁÊÌÏ× ÏÔËÒÙÔÙ"
#, fuzzy
Index: grasslibs_sl.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_sl.po,v
retrieving revision 1.23
diff -u -d -r1.22 -r1.23
--- grasslibs_sl.po 21 Nov 2007 13:18:49 -0000 1.22
+++ grasslibs_sl.po 29 Nov 2007 20:21:04 -0000 1.23
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grasslibs_sl\n"
"PO-Revision-Date: 2005-04-26 09:38+0200\n"
"Last-Translator: Miha Staut <mihastaut at yahoo.co.uk>\n"
"Language-Team: Sloven¹èina <translations at lists.osgeo.org>\n"
@@ -486,11 +486,11 @@
msgid "%s not set"
msgstr "%s ni nastavljen"
msgid "WARNING: "
msgstr "OPOZORILO: "
msgid "ERROR: "
msgstr "NAPAKA: "
@@ -1891,7 +1891,7 @@
msgstr "ne morem spremeniti direktorija v %s"
#, fuzzy
msgstr "ne morem ustvariti novega procesa"
@@ -2405,14 +2405,14 @@
msgstr ""
-#, c-format
-msgstr ""
+#, fuzzy, c-format
+msgstr "Vneseni vektor '%s' ni bil najden"
#, fuzzy, c-format
-msgstr "za obstojeèe rastrske sloje %d\n"
+msgstr "ne morem spremeniti direktorija v %s"
#, fuzzy, c-format
@@ -2433,6 +2433,11 @@
msgstr ""
+#, fuzzy, c-format
#, c-format
@@ -2801,6 +2806,15 @@
msgstr "NAPAKA - grafièni monitor <%s> se ne odziva.\n"
+#, fuzzy, c-format
+msgstr ""
msgid ""
@@ -2919,6 +2933,35 @@
msgstr "Nezmo¾en odpreti datoteko %s v %s"
+#, c-format
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "Ne morem zbrisati linije"
+#, fuzzy
+msgstr "Ne morem zapisati povezav z bazo podatkov."
+msgstr ""
@@ -3125,17 +3168,17 @@
msgstr "Dvojni atributni indeks je izven razpona"
#, fuzzy, c-format
msgstr "Nezmo¾en odpreti %s za pisanje"
#, fuzzy, c-format
msgstr "Napaka pri pisanju datoteke sidx.\n"
#, fuzzy, c-format
msgstr "Ne morem odpreti datoteke z zgodovino za vektor '%s'"
@@ -3353,11 +3396,6 @@
msgstr ""
-#, fuzzy
-msgstr "Ne morem zbrisati linije"
#, fuzzy, c-format
@@ -3506,37 +3544,37 @@
msgstr ""
#, fuzzy
msgstr "Registriram linije: "
msgstr ""
#, fuzzy
msgstr ""
msgstr ""
msgid "Snaps"
msgstr ""
msgstr ""
msgstr ""
@@ -3668,6 +3706,10 @@
msgstr ""
+#, fuzzy
+#~ msgstr "za obstojeèe rastrske sloje %d\n"
#~ msgstr "Izhodno ime '%s' ni veljavno ime za vektor."
Index: grasslibs_th.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_th.po,v
diff -u -d -r1.1 -r1.2
--- grasslibs_th.po 15 Nov 2007 07:48:14 -0000 1.1
+++ grasslibs_th.po 29 Nov 2007 20:21:05 -0000 1.2
@@ -6,7 +6,7 @@
msgstr ""
"Project-Id-Version: grasstcl_th\n"
"PO-Revision-Date: 2007-11-12 02:10+0900\n"
"Last-Translator: Sarawut Ninsawat <sarawut.map at gmail.com>\n"
"Language-Team: Thai <grass-translations at lists.osgeo.org>\n"
@@ -15,327 +15,254 @@
"X-Generator: KBabel 1.11.4\n"
[...4214 lines suppressed...]
+#: ../lib/vector/diglib/plus_area.c:413
+#, c-format
+msgid "Attempt to delete area [%d] info from dead isle [%d]"
msgstr ""
-#: ../lib/gmath/la.c:1291
-msgid "Vector structure is not initialised"
+#: ../lib/vector/diglib/plus_area.c:741
+#, c-format
+msgid "Attempt to delete isle [%d] info from dead area [%d]"
msgstr ""
-#: ../lib/gmath/la.c:1413 ../lib/gmath/la.c:1421 ../lib/gmath/la.c:1426
-msgid "Input format error"
+#: ../lib/vector/diglib/plus_node.c:244
+#, c-format
+msgid ""
+"Attempt to read line angle for the line which is not connected to the node: "
+"node = [%d] line = [%d]"
msgstr ""
Index: grasslibs_tr.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_tr.po,v
retrieving revision 1.17
diff -u -d -r1.17 -r1.18
--- grasslibs_tr.po 21 Nov 2007 13:18:49 -0000 1.17
+++ grasslibs_tr.po 29 Nov 2007 20:21:05 -0000 1.18
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grasslibs_tr\n"
"PO-Revision-Date: 2006-04-18 06:17+0300\n"
"Last-Translator: oyy <yilmazy at istanbul.edu.tr>\n"
"Language-Team: Turkish <translations at lists.osgeo.org>\n"
@@ -481,11 +481,11 @@
msgid "%s not set"
msgstr "%s ayarlanmadı"
msgid "WARNING: "
msgstr "UYARI:"
msgid "ERROR: "
msgstr "HATA:"
@@ -1853,7 +1853,7 @@
msgstr "Dizin %s'e deÄiÅtirilemiyor"
msgstr "Yeni bir iÅlem oluÅturulamıyor!"
@@ -2363,14 +2363,14 @@
msgstr ""
-#, c-format
-msgstr ""
+#, fuzzy, c-format
+msgstr "'%s' girdi vektörü bulunamadı"
#, fuzzy, c-format
-msgstr "Ãok fazla açık raster dosya"
+msgstr "Dizin %s'e deÄiÅtirilemiyor"
#, fuzzy, c-format
@@ -2391,6 +2391,11 @@
msgstr ""
+#, fuzzy, c-format
#, c-format
msgstr "HATA - <%s> grafik ekranından yanıt yok.\n"
+#, fuzzy, c-format
+msgstr ""
msgid ""
@@ -2868,6 +2882,35 @@
msgstr "%s içindeki %s dosyası açılamadı"
+#, c-format
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "Katman bilgisi alınamıyor"
+#, fuzzy
+msgstr "%s veritabanı açılamıyor"
+msgstr ""
@@ -3069,17 +3112,17 @@
msgstr ""
#, fuzzy, c-format
msgstr "%s okuma için yazılamıyor"
#, fuzzy, c-format
msgstr "Mekansal indek dosyasını yazmada hata.\n"
#, fuzzy, c-format
msgstr "'%s' vektörünün geçmiŠdosyası açılamıyor"
@@ -3291,11 +3334,6 @@
msgstr ""
-#, fuzzy
-msgstr "Katman bilgisi alınamıyor"
#, fuzzy, c-format
@@ -3444,37 +3482,37 @@
msgstr ""
#, fuzzy
msgstr "çizgiler kaydediliyor: "
msgstr ""
#, fuzzy
msgstr ""
msgstr ""
msgid "Snaps"
msgstr ""
msgstr ""
msgstr ""
@@ -3605,6 +3643,10 @@
msgstr ""
+#, fuzzy
+#~ msgstr "Ãok fazla açık raster dosya"
#~ msgstr "'%s' çıktı adı geçerli vektör adı deÄil."
Index: grasslibs_vi.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_vi.po,v
--- grasslibs_vi.po 21 Nov 2007 13:18:49 -0000 1.22
+++ grasslibs_vi.po 29 Nov 2007 20:21:05 -0000 1.23
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grasslibs_vi\n"
"PO-Revision-Date: 2006-09-20 16:09+0200\n"
"Last-Translator: Bui Huu Manh <bhmanh73 at yahoo.com>\n"
"Language-Team: Vietnamese <translations at lists.osgeo.org>\n"
msgid "%s not set"
msgstr "%s không ÄÆ°á»£c thiết láºp"
msgid "WARNING: "
msgstr "CẢNH BÃO: "
msgid "ERROR: "
msgstr "Lá»I: "
@@ -1877,7 +1877,7 @@
msgstr "không thá» Äá»i thư mục Äến %s"
msgstr "Không thá» tạo má»t quá trình má»i"
@@ -2392,14 +2392,14 @@
msgstr ""
-#, c-format
-msgstr ""
+#, fuzzy, c-format
+msgstr "Không tìm thấy vector Äầu và o '%s'"
#, fuzzy, c-format
-msgstr "cho các bản Äá» raster hiá»n có %d"
+msgstr "không thá» Äá»i thư mục Äến %s"
#, fuzzy, c-format
@@ -2420,6 +2420,11 @@
msgstr ""
+#, fuzzy, c-format
#, c-format
@@ -2787,6 +2792,15 @@
msgstr "Lá»I - mà n hình Äá» há»a không phản ứng <%s>.\n"
+#, fuzzy, c-format
+msgstr ""
msgid ""
@@ -2912,6 +2926,35 @@
msgstr "Không thá» má» táºp tin %s trong %s"
+#, c-format
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "Không thá» lấy thông tin lá»p"
+#, fuzzy
+msgstr "Không thỠmỠCSDL"
+msgstr ""
@@ -3115,17 +3158,17 @@
msgstr ""
#, fuzzy, c-format
#, fuzzy, c-format
msgstr "Lá»i khi Äang ghi táºp tin chá» mục không gian.\n"
#, fuzzy, c-format
msgstr "Không thá» má» táºp tin lá»ch sá» cá»§a vector '%s'"
@@ -3341,11 +3384,6 @@
msgstr ""
-#, fuzzy
-msgstr "Không thá» lấy thông tin lá»p"
#, fuzzy, c-format
@@ -3496,37 +3534,37 @@
msgstr ""
#, fuzzy
msgstr "Äang ÄÄng ký các ÄÆ°á»ng:"
msgstr ""
#, fuzzy
msgstr ""
msgstr ""
msgid "Snaps"
msgstr ""
msgstr ""
msgstr ""
@@ -3657,6 +3695,10 @@
msgstr ""
+#, fuzzy
+#~ msgstr "cho các bản Äá» raster hiá»n có %d"
#~ msgstr "Tên bản Äá» Äầu ra '%s' không phải là tên vector hợp lá»"
Index: grassmods_ar.po
RCS file: /grassrepository/grass6/locale/po/grassmods_ar.po,v
--- grassmods_ar.po 21 Nov 2007 13:18:49 -0000 1.26
+++ grassmods_ar.po 29 Nov 2007 20:21:05 -0000 1.27
@@ -7,7 +7,7 @@
msgstr ""
+"POT-Creation-Date: 2007-11-29 20:52+0100\n"
@@ -158,8 +158,9 @@
msgstr "<%s> ÙÙ
ÙÙ
ÙÙ ÙØªØ"
[...4218 lines suppressed...]
#, fuzzy
-#~ msgid "Raster map [%s] does not exist"
-#~ msgstr "ØºÙØ± Ù
ÙØ¬Ùدة <%s> Ø§ÙØ®Ø±Ùطة Ø§ÙØ±Ø§Ø³ØªØ±ÙØ© "
-#, fuzzy
#~ msgid "Unable to open raster map [%s]"
#~ msgstr "اسÙ
Ø§ÙØ®Ø±Ùطة Ø§ÙØ±Ø§Ø³ØªØ±ÙØ© اÙÙ
خرجة"
@@ -27546,10 +27885,6 @@
#, fuzzy
#~ msgid "Database's name couldn't be read"
#~ msgstr "ÙÙ
ÙØªÙ
Ø§ÙØ¥ØªØµØ§Ù Ø¨ÙØ§Ø¹Ø¯Ø© Ø§ÙØ¨ÙØ§ÙØ§Øª\n"
-#, fuzzy
-#~ msgid "Cannot open vector points map <%s>"
-#~ msgstr "<%s>ÙÙ<%s>ÙÙ
ÙÙ
ÙÙ ÙØªØ اÙÙ
Ù٠اÙÙÙÙØªÙرÙ"
#, fuzzy
#~ msgid "Cannot create vector map <%s>"
Index: grassmods_cs.po
RCS file: /grassrepository/grass6/locale/po/grassmods_cs.po,v
retrieving revision 1.51
retrieving revision 1.52
diff -u -d -r1.51 -r1.52
--- grassmods_cs.po 27 Nov 2007 14:20:05 -0000 1.51
+++ grassmods_cs.po 29 Nov 2007 20:21:05 -0000 1.52
@@ -10,2758 +10,5195 @@
msgstr ""
"Project-Id-Version: grassmods_cs\n"
-"POT-Creation-Date: 2007-10-26 10:42+0200\n"
"PO-Revision-Date: 2007-11-27 15:19+0100\n"
"Last-Translator: Radim Bla¾ek <blazek at itc.it>\n"
"Content-Type: text/plain; charset=ISO-8859-2\n"
-"Content-Transfer-Encoding: 8bit"
[...48654 lines suppressed...]
#~ msgid "Total species representation is < 100"
#~ msgstr ""
#~ "CelkovÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂ
ÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂ
ÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÃÅ¡ÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃ
ÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄ
ÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂ "
#~ "zastoupenÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂ
ÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃ
ÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄ
ÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂ
ÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂ "
-#~ "druhÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃ
ÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÄÂĹÄÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃ
ÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÃÅ¡ÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂ
ÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÄÂĹÄÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂ
ÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂ je < 100"
+#~ "druhÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃ
+#~ "je < 100"
#~ msgid "Cannot select attributes for point #%d"
#~ msgstr "Nelze vybrat atributy pro bod #%d"
#~ msgid "Species <%s> not known. I'll use parameters for spruce instead"
#~ msgstr ""
-#~ "Druh <%s> nenÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂ
ÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄ
ÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃ
ÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂ
ÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂ "
+#~ "Druh <%s> "
+#~ "nenÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃ
ÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂ
ÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂ
ÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃ
#~ "znÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂ
ÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃ
ÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂm. "
-#~ "PouÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃ
ÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÄÂĹÄÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂ
ÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÄÂĹÄÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÃÅ¡ÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÄÂĹÄÄÂÃÂÄÂÃÂÄÂÃ
ÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÃÅ¡ÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÄÂĹÄÄÂÃÂÃÂÃÂÃÅ¡ÃÂÄÂĹÄÃšĹžiji parametry pro smrk."
+#~ "PouÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃ
ÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÃÅ¡ÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÄÂĹÄÄÂÃÂÃÂÃÂÃÅ¡ÃÂÄÂĹÄÃšĹžiji "
+#~ "parametry pro smrk."
Index: grassmods_de.po
RCS file: /grassrepository/grass6/locale/po/grassmods_de.po,v
retrieving revision 1.120
retrieving revision 1.121
diff -u -d -r1.120 -r1.121
--- grassmods_de.po 21 Nov 2007 13:18:49 -0000 1.120
+++ grassmods_de.po 29 Nov 2007 20:21:05 -0000 1.121
@@ -9,7 +9,7 @@
msgstr ""
"Project-Id-Version: grassmods_de\n"
"PO-Revision-Date: 2007-08-17 20:19+0200\n"
"Last-Translator: Robert Nuske <rnuske at gwdg.de>\n"
"Language-Team: Deutsch <translations at lists.osgeo.org>\n"
@@ -168,8 +168,9 @@
msgstr "Kann die Rasterkarte <%s> nicht öffnen."
[...4308 lines suppressed...]
@@ -28200,9 +28558,6 @@
#~ msgid "Unable to open [%s]"
#~ msgstr "Kann [%s] nicht öffnen."
-#~ msgstr "Rasterkarte [%s] existiert nicht."
#~ msgstr "Kann die Rasterkarte [%s] nicht öffnen."
@@ -28948,9 +29303,6 @@
#~ msgid "Cannot open raster map"
#~ msgstr "Kann Rasterkarte nicht öffnen!"
-#~ msgid "Unable to allocate memory for row buffer"
-#~ msgstr "Kann keinen Speicherplatz für Zeilen-Puffer belegen."
#~ msgid ""
#~ "Number of column used as z coordinate (first column is 1) for points "
Index: grassmods_el.po
RCS file: /grassrepository/grass6/locale/po/grassmods_el.po,v
--- grassmods_el.po 21 Nov 2007 13:18:50 -0000 1.9
+++ grassmods_el.po 29 Nov 2007 20:21:05 -0000 1.10
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grassmods_el\n"
@@ -146,8 +146,9 @@
msgstr ""
[...3853 lines suppressed...]
+msgstr ""
+#: ../vector/v.net.visibility/main.c:59
+msgid "One or more coordinates"
+msgstr ""
+#: ../vector/v.net.visibility/main.c:65
+msgid "Add points after computing the vis graph"
+msgstr ""
+#: ../vector/v.net.visibility/main.c:98
+#, c-format
+msgid "Unable to copy elements from vector map <%s>"
+msgstr ""
+#: ../vector/v.net.visibility/main.c:104
+msgid "Lat-long projection"
msgstr ""
#: ../visualization/nviz/src/nviz_init.c:56
Index: grassmods_es.po
RCS file: /grassrepository/grass6/locale/po/grassmods_es.po,v
retrieving revision 1.87
retrieving revision 1.88
diff -u -d -r1.87 -r1.88
--- grassmods_es.po 21 Nov 2007 13:18:50 -0000 1.87
+++ grassmods_es.po 29 Nov 2007 20:21:05 -0000 1.88
@@ -14,10 +14,10 @@
msgstr ""
"Project-Id-Version: grassmods_es\n"
-"PO-Revision-Date: 2007-10-26 21:29+0200\n"
+"PO-Revision-Date: 2007-11-29 20:45+0100\n"
[...7276 lines suppressed...]
+#, fuzzy
+#~ msgid "Raster map <%s not found"
+#~ msgstr "Mapa ráster <%s> no encontrado"
+#~ msgid "elevation file [%s] not found"
+#~ msgstr "archivo de elevación [%s] no encontrado"
+#~ msgid "min computed aspect %.4f max computed aspect %.4f"
+#~ msgstr ""
+#~ "orientación mínima procesada %.4f orientación máxima procesada %.4f"
+#~ msgid "min computed slope %.4f max computed slope %.4f"
+#~ msgstr "pendiente mínima procesada %.4f pendiente máxima procesada %.4f"
+#, fuzzy
+#~ msgid "Unavle to open database <%s> by driver <%s>"
+#~ msgstr "No se puede abrir la base de datos <%s> por el controlador <%s>"
+#~ msgid "Unable create table: %s"
+#~ msgstr "No se puede crear la tabla: %s"
Index: grassmods_fr.po
RCS file: /grassrepository/grass6/locale/po/grassmods_fr.po,v
retrieving revision 1.46
retrieving revision 1.47
diff -u -d -r1.46 -r1.47
--- grassmods_fr.po 21 Nov 2007 13:18:50 -0000 1.46
+++ grassmods_fr.po 29 Nov 2007 20:21:05 -0000 1.47
@@ -11,7 +11,7 @@
msgstr ""
"Project-Id-Version: grassmods_fr\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2007-10-26 21:10+0200\n"
"PO-Revision-Date: 2005-10-14 23:38-0500\n"
"Language-Team: Français <translations at lists.osgeo.org>\n"
@@ -181,8 +181,9 @@
# c-format
[...4417 lines suppressed...]
#~ msgstr "Impossible d'ouvrir la couche raster"
-#, fuzzy
-#~ msgstr "Impossible d'allouer de la mémoire pour les pointeurs de ligne"
#~ msgid ""
#~ "mode. If 0, z coordinate is not used."
@@ -30763,10 +31126,6 @@
#~ msgid " Residual mean average : %f\n"
#~ msgstr " Moyenne résiduelle : %f\n"
-#, fuzzy
-#~ msgid "Raster <%s> already exist."
-#~ msgstr "ERREUR: <%s> existe déjà\n"
#~ msgid "Vector map(s) -- source for composite"
#~ msgstr "Couche(s) vectorielles -- source pour la composite"
Index: grassmods_hi.po
RCS file: /grassrepository/grass6/locale/po/grassmods_hi.po,v
--- grassmods_hi.po 21 Nov 2007 13:18:50 -0000 1.29
+++ grassmods_hi.po 29 Nov 2007 20:21:05 -0000 1.30
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grassmods_hi\n"
"PO-Revision-Date: 2005-12-20 22:29+0100\n"
@@ -163,8 +163,9 @@
msgstr "à¤à¥ लिà¤."
[...4259 lines suppressed...]
#, fuzzy
-#~ msgstr "à¤à¥ लिà¤"
-#, fuzzy
#~ msgid ""
@@ -29511,10 +29830,6 @@
#, fuzzy
#~ msgid "Name of input map"
#~ msgstr "à¤à¤¾"
-#, fuzzy
-#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),c(ounts)"
-#~ msgstr "f a h"
#, fuzzy
#~ msgid "Write an Arc-Info line/polygon coverage in e00 format."
Index: grassmods_it.po
RCS file: /grassrepository/grass6/locale/po/grassmods_it.po,v
retrieving revision 1.42
retrieving revision 1.43
diff -u -d -r1.42 -r1.43
--- grassmods_it.po 21 Nov 2007 13:18:51 -0000 1.42
+++ grassmods_it.po 29 Nov 2007 20:21:05 -0000 1.43
@@ -11,7 +11,7 @@
msgstr ""
"Project-Id-Version: grassmods_it\n"
"PO-Revision-Date: 2006-11-03 19:42+0100\n"
"Last-Translator: Stefano Costa <steko at iosa.it>\n"
@@ -176,8 +176,9 @@
msgstr "impossibile aprire <%s>"
[...4172 lines suppressed...]
#, fuzzy
-#~ msgid "Cannot open file for <%s>"
-#~ msgstr "Non riesco ad impostare user/password"
-#, fuzzy
#~ msgid "%s: Unable to find raster map <%s>"
#~ msgstr "impossibile aprire <%s>"
@@ -28353,10 +28673,6 @@
#, fuzzy
#~ msgid "EPSG code of projection to be created"
#~ msgstr "Numero di passi attraverso il dataset"
-#, fuzzy
-#~ msgid "EPSG code <%s> does not exist"
-#~ msgstr "raster <%s> non trovato"
#~ msgid "must be even number of names"
#~ msgstr "deve essere un numero pari di nomi"
Index: grassmods_ja.po
RCS file: /grassrepository/grass6/locale/po/grassmods_ja.po,v
retrieving revision 1.40
retrieving revision 1.41
diff -u -d -r1.40 -r1.41
--- grassmods_ja.po 21 Nov 2007 13:18:51 -0000 1.40
+++ grassmods_ja.po 29 Nov 2007 20:21:05 -0000 1.41
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grassmods_ja\n"
"PO-Revision-Date: 2005-12-30 17:42+0100\n"
@@ -161,8 +161,9 @@
msgstr "åºåãããã¡ã¤ã«"
[...4252 lines suppressed...]
#, fuzzy
-#~ msgstr "���."
-#, fuzzy
#~ msgstr "å
¥åãããã¡ã¤ã«"
@@ -29213,10 +29532,6 @@
#, fuzzy
#~ msgid "%d byte%s per cell\n"
#~ msgstr "1ã»ã«ã®ãã¤ãæ°"
-#, fuzzy
-#~ msgstr "è¨æ¸¬åä½"
#, fuzzy
#~ msgid "page length (default: %d lines)"
Index: grassmods_ko.po
RCS file: /grassrepository/grass6/locale/po/grassmods_ko.po,v
diff -u -d -r1.28 -r1.29
--- grassmods_ko.po 21 Nov 2007 13:18:51 -0000 1.28
+++ grassmods_ko.po 29 Nov 2007 20:21:05 -0000 1.29
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grassmods_ko\n"
"PO-Revision-Date: 2005-08-09 22:53-0500\n"
@@ -147,8 +147,9 @@
msgstr "ì¶ë ¥í ëì¤í°ë§µ"
[...3999 lines suppressed...]
+#, fuzzy
+#~ msgid "Cannot describe table <%s>"
+#~ msgstr "ì¶ë ¥í ëì¤í°ë§µ"
+#, fuzzy
#~ msgid "Unable to open database %s by driver %s"
@@ -25468,10 +25657,6 @@
#, fuzzy
#~ msgid "Cannot open labels <%s>"
-#~ msgstr "ì¶ë ¥í ëì¤í°ë§µ"
-#, fuzzy
-#~ msgid "Cannot fetch data from table"
#, fuzzy
Index: grassmods_lv.po
RCS file: /grassrepository/grass6/locale/po/grassmods_lv.po,v
--- grassmods_lv.po 21 Nov 2007 13:18:51 -0000 1.28
+++ grassmods_lv.po 29 Nov 2007 20:21:05 -0000 1.29
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grassmods_lv\n"
"PO-Revision-Date: 2006-12-09 01:04+0200\n"
@@ -172,8 +172,9 @@
msgstr "neiespÄjami atvÄrt <%s>"
[...4212 lines suppressed...]
#~ msgstr "NeiespÄjami atvÄrt [%s]"
-#~ msgstr "rastra karte [%s] nav atrasta"
#, fuzzy
#~ msgstr "neiespÄjami atvÄrt <%s>"
@@ -27245,10 +27572,6 @@
#, fuzzy
#~ msgstr "DatubÄzes konekcija nav definÄta"
-#, fuzzy
-#~ msgstr "Izejas vektora punktu kartes nosaukums"
#, fuzzy
Index: grassmods_mr.po
RCS file: /grassrepository/grass6/locale/po/grassmods_mr.po,v
--- grassmods_mr.po 26 Oct 2007 19:35:23 -0000 1.28
+++ grassmods_mr.po 29 Nov 2007 20:21:05 -0000 1.29
@@ -6,7 +6,7 @@
msgstr ""
@@ -150,8 +150,9 @@
msgstr "'%s'. डà¥à¤°à¤¾à¤à¤µà¤° à¤à¤¾à¤²à¥ हà¥à¤¤ नाहà¥"
[...4050 lines suppressed...]
#, fuzzy
-#~ msgstr "डà¥à¤à¤¾à¤¬à¥à¤¸à¤à¥ यादॠदाà¤à¤µà¤¤à¤¾ यà¥à¤£à¤¾à¤° नाहà¥"
-#, fuzzy
#~ msgid "Cannot open file [%s]"
#~ msgstr "'%s'. डà¥à¤°à¤¾à¤à¤µà¤° à¤à¤¾à¤²à¥ हà¥à¤¤ नाहà¥"
@@ -26002,10 +26214,6 @@
#, fuzzy
#~ msgid "Cannot create output map [%s]"
-#~ msgstr "'%s'. डà¥à¤°à¤¾à¤à¤µà¤° à¤à¤¾à¤²à¥ हà¥à¤¤ नाहà¥"
-#, fuzzy
#, fuzzy
Index: grassmods_pl.po
RCS file: /grassrepository/grass6/locale/po/grassmods_pl.po,v
--- grassmods_pl.po 26 Oct 2007 19:35:23 -0000 1.31
+++ grassmods_pl.po 29 Nov 2007 20:21:05 -0000 1.32
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grassmodes_pl\n"
"PO-Revision-Date: 2007-09-19 21:58+0100\n"
@@ -166,8 +166,9 @@
msgstr "Nie mo¿na otworzyæ mapy rastrowej <%s>"
[...4204 lines suppressed...]
+#, fuzzy
+#~ msgid "%s given an illegal number of points [%d]"
+#~ msgstr ""
+#~ "\n"
+#~ "<%s> -- niew³a¶ciwa liczba pocz±tkowych klas"
+#, fuzzy
#~ msgstr "Bazy danych <%s> nie mo¿na otworzyæ sterownikiem <%s>"
@@ -27818,9 +28170,6 @@
#, fuzzy
#~ msgid "Can't read current window parameters"
#~ msgstr "wypisz parametry bie¿±cego po³±czenia i wyjd¼"
-#~ msgid "Can't open raster file %s"
-#~ msgstr "Nie mo¿na otworzyæ pliku rastrowego %s"
#~ msgid "[%s] file name not legal"
#~ msgstr "[%s] nazwa pliku jest niedozwolona"
Index: grassmods_pt.po
RCS file: /grassrepository/grass6/locale/po/grassmods_pt.po,v
retrieving revision 1.7
diff -u -d -r1.7 -r1.8
--- grassmods_pt.po 21 Nov 2007 13:18:51 -0000 1.7
+++ grassmods_pt.po 29 Nov 2007 20:21:06 -0000 1.8
@@ -10,7 +10,7 @@
msgstr ""
"Project-Id-Version: grassmods_pt\n"
"PO-Revision-Date: 2007-06-21 21:54-0300\n"
"Last-Translator: Daniel de Castro Victoria <daniel dot victoria at gmail dot "
"com>\n"
@@ -173,8 +173,9 @@
msgstr "Não consegui abrir mapa raster <%s>"
[...4310 lines suppressed...]
#~ msgstr "Não consegui abrir mapa raster [%s]."
-#, fuzzy
-#~ msgstr "Não consegui alocar memória para 'string'"
#~ msgid "Keep existing color table"
#~ msgstr "Manter a tabela de cores existente"
@@ -29834,10 +30197,6 @@
#~ msgstr " Erro médio : %f\n"
-#, fuzzy
-#~ msgstr "O vetor '%s' já existe."
#~ msgstr "Mapa vetorial -- fonte para composição"
Index: grassmods_pt_br.po
RCS file: /grassrepository/grass6/locale/po/grassmods_pt_br.po,v
retrieving revision 1.44
retrieving revision 1.45
diff -u -d -r1.44 -r1.45
--- grassmods_pt_br.po 21 Nov 2007 13:18:51 -0000 1.44
+++ grassmods_pt_br.po 29 Nov 2007 20:21:06 -0000 1.45
@@ -10,7 +10,7 @@
msgstr ""
"PO-Revision-Date: 2007-06-16 19:30-0300\n"
"Last-Translator: Daniel de Castro Victoria <daniel.victoria at gmail.com>\n"
@@ -172,8 +172,9 @@
[...4309 lines suppressed...]
-#, fuzzy
@@ -29912,10 +30274,6 @@
-#, fuzzy
Index: grassmods_ru.po
RCS file: /grassrepository/grass6/locale/po/grassmods_ru.po,v
retrieving revision 1.36
retrieving revision 1.37
diff -u -d -r1.36 -r1.37
--- grassmods_ru.po 21 Nov 2007 13:18:51 -0000 1.36
+++ grassmods_ru.po 29 Nov 2007 20:21:06 -0000 1.37
@@ -6,7 +6,7 @@
msgstr ""
"Project-Id-Version: grassmods_ru\n"
"PO-Revision-Date: 2006-07-07 11:53+0200\n"
@@ -155,8 +155,9 @@
msgstr " "
[...4200 lines suppressed...]
#, fuzzy
-#~ msgstr " "
-#, fuzzy
#~ msgstr " "
@@ -27701,10 +28060,6 @@
#, fuzzy
#~ msgid "'%s' has finished the transformation of the vectors.\n"
#~ msgstr " "
-#, fuzzy
-#~ msgstr "ïûéâëá "
#, fuzzy
Index: grassmods_sl.po
RCS file: /grassrepository/grass6/locale/po/grassmods_sl.po,v
--- grassmods_sl.po 21 Nov 2007 13:18:51 -0000 1.32
+++ grassmods_sl.po 29 Nov 2007 20:21:06 -0000 1.33
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grassmods_sl\n"
"PO-Revision-Date: 2005-06-10 11:15+0200\n"
@@ -172,8 +172,9 @@
msgstr "Ime izhodnega rastrskega sloja"
[...4232 lines suppressed...]
#, fuzzy
-#~ msgstr "Ne najdem vhodnega rastrskega sloja <%s>."
-#, fuzzy
#~ msgstr "Ime izhodnega rastrskega sloja"
@@ -27909,10 +28246,6 @@
#, fuzzy
#~ msgstr "Povezava z bazo podatkov ni definirana\n"
-#, fuzzy
-#~ msgstr "Ime izhodnega vektorskega toèkovnega sloja"
#, fuzzy
Index: grassmods_th.po
RCS file: /grassrepository/grass6/locale/po/grassmods_th.po,v
--- grassmods_th.po 15 Nov 2007 07:48:14 -0000 1.1
+++ grassmods_th.po 29 Nov 2007 20:21:06 -0000 1.2
@@ -6,7 +6,7 @@
msgstr ""
"Project-Id-Version: grassmods_th\n"
@@ -15,9612 +15,10180 @@
[...37563 lines suppressed...]
-msgid "raster3d, voxel, export"
+#: ../visualization/ximgview/main.c:252
+msgid "Unable to map image file"
msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:260
-msgid "Converts a 3D raster map layer into an ASCII text file"
+#: ../visualization/ximgview/main.c:273
+msgid "View BMP images from the PNG driver."
msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:323
-msgid "Error closing new ASCII file"
+#: ../visualization/ximgview/main.c:281
+msgid "Image file"
+msgstr ""
+#: ../visualization/ximgview/main.c:288
+msgid "Percentage of CPU time to use"
msgstr ""
Index: grassmods_tr.po
RCS file: /grassrepository/grass6/locale/po/grassmods_tr.po,v
--- grassmods_tr.po 21 Nov 2007 13:18:52 -0000 1.28
+++ grassmods_tr.po 29 Nov 2007 20:21:06 -0000 1.29
@@ -6,7 +6,7 @@
msgstr ""
"Project-Id-Version: grassmods_tr\n"
"PO-Revision-Date: 2006-04-17 06:58+0300\n"
@@ -168,8 +168,9 @@
msgstr "[%s] raster haritası açılamıyor."
[...4176 lines suppressed...]
#, fuzzy
-#~ msgstr " [%s] vektör haritası bulunamadı"
-#, fuzzy
#~ msgstr "'%s'.vektör haritası oluÅturulamıyor"
@@ -28045,10 +28354,6 @@
#~ msgid " Current Map New Map\n"
#~ msgstr " Geçerli Harita Yeni Harita\n"
-#, fuzzy
-#~ msgstr "HATA: <%s> zaten mevcut\n"
#, fuzzy
#~ msgid "No database updates."
Index: grassmods_vi.po
RCS file: /grassrepository/grass6/locale/po/grassmods_vi.po,v
retrieving revision 1.34
retrieving revision 1.35
diff -u -d -r1.34 -r1.35
--- grassmods_vi.po 21 Nov 2007 13:18:52 -0000 1.34
+++ grassmods_vi.po 29 Nov 2007 20:21:06 -0000 1.35
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grassmods_vi\n"
"PO-Revision-Date: 2006-09-20 09:40+0700\n"
@@ -169,8 +169,9 @@
msgstr "Không thá» má» bản Äá» raster <%s>"
#~ msgstr "Không thá» má» bản Äá» raster"
-#, fuzzy
-#~ msgstr "Thất bại trong viá»c cấp phát bá» nhá» cho các con trá» hà ng"
#~ msgid ""
@@ -29621,9 +29975,6 @@
#~ msgstr " Trung bình phần thừa : %f\n"
-#~ msgstr "Raster <%s> Äã có."
#~ msgstr "(Các) bản Äá» vector --nguá»n Äá» tá» hợp"
Index: grasstcl_am.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_am.po,v
diff -u -d -r1.4 -r1.5
--- grasstcl_am.po 21 Nov 2007 13:18:52 -0000 1.4
+++ grasstcl_am.po 29 Nov 2007 20:21:06 -0000 1.5
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grasstcl_am\n"
"PO-Revision-Date: 2007-06-07 18:17-0500\n"
"Last-Translator: Solomon Gizaw <solohavi at yahoo.com>\n"
"Language-Team: <translations at lists.osgeo.org>\n"
@@ -49,11 +49,14 @@
#: ../gui/tcltk/gis.m/barscale.tcl:184 ../gui/tcltk/gis.m/chart.tcl:184
#: ../gui/tcltk/gis.m/chart.tcl:188 ../gui/tcltk/gis.m/dtext.tcl:177
[...1558 lines suppressed...]
+#: ../gui/tcltk/gis.m/animate.tcl:1031
msgid "Animation Window"
msgstr ""
@@ -5902,6 +6064,15 @@
#: ../visualization/nviz/scripts/panel_animation.tcl:275
msgid "Test"
msgstr "á´áµáµ "
+#~ msgid " width"
+#~ msgstr "áµááµ :"
+#~ msgid "text color"
+#~ msgstr "áá½áá ááá "
+#~ msgid " text size"
+#~ msgstr "á¨á½áá ááááµ "
#~ msgid "GRASS"
#~ msgstr "áá«áµ "
Index: grasstcl_ar.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_ar.po,v
retrieving revision 1.9
retrieving revision 1.10
diff -u -d -r1.9 -r1.10
--- grasstcl_ar.po 21 Nov 2007 13:18:52 -0000 1.9
+++ grasstcl_ar.po 29 Nov 2007 20:21:06 -0000 1.10
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grasstcl_ar\n"
"PO-Revision-Date: 2007-03-16 21:31+0100\n"
"Last-Translator: Carlos Davila <carluti at users.sourceforge.net>\n"
"Language-Team: Arabic <translations at lists.osgeo.org>\n"
@@ -48,11 +48,14 @@
[...1503 lines suppressed...]
-#: ../gui/tcltk/gis.m/animate.tcl:513
+#: ../gui/tcltk/gis.m/animate.tcl:525
msgid "Maps for frame 4 (optional): "
msgstr ""
-#: ../gui/tcltk/gis.m/animate.tcl:551
+#: ../gui/tcltk/gis.m/animate.tcl:563
msgid "You must select maps to animate for frame 1"
msgstr ""
-#: ../gui/tcltk/gis.m/animate.tcl:552
+#: ../gui/tcltk/gis.m/animate.tcl:564
msgid "No maps selected"
msgstr ""
-#: ../gui/tcltk/gis.m/animate.tcl:1019
msgstr ""
Index: grasstcl_cs.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_cs.po,v
--- grasstcl_cs.po 27 Nov 2007 14:44:05 -0000 1.18
+++ grasstcl_cs.po 29 Nov 2007 20:21:06 -0000 1.19
@@ -7,16 +7,15 @@
msgstr ""
"Project-Id-Version: grasstcl_cs\n"
"PO-Revision-Date: 2007-11-27 15:42+0100\n"
"Last-Translator: honza <j.trochta at seznam.cz>\n"
"Language-Team: Czech <translations at lists.osgeo.org>\n"
"MIME-Version: 1.0\n"
[...4410 lines suppressed...]
#~ msgid ""
#~ "Error in regular expression:\n"
#~ "\"%s\""
#~ msgstr ""
#~ "Chyba v regulÄÄrnÄÂm vÄËrazu:\n"
#~ "\"%s\""
#~ msgid "list devices"
#~ msgstr "seznam zaÃÅ¡ÃÂÃÂÃÂzenÃÂÃÂ"
#~ msgid "Create WIND3 (default 3D window) from current 2D region"
-#~ msgstr "VytvoÃÅ¡ÃÂit WIND3 (vÃÂÃÂchozÃÂà3D window) z aktuÃÂÃÂlnÃÂÃÂho 2D regionu"
+#~ msgstr ""
+#~ "VytvoÃÅ¡ÃÂit WIND3 (vÃÂÃÂchozÃÂà3D window) z aktuÃÂÃÂlnÃÂÃÂho 2D regionu"
#~ msgid "Manage 3D region"
#~ msgstr "SprÃÂÃÂva 3D regionu"
#~ msgid "Break lines at intersections"
#~ msgstr "PÃÅ¡ÃÂeruÃÅ¡ÃÂit linie v pruseciku"
Index: grasstcl_de.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_de.po,v
--- grasstcl_de.po 21 Nov 2007 13:18:52 -0000 1.26
+++ grasstcl_de.po 29 Nov 2007 20:21:06 -0000 1.27
@@ -9,7 +9,7 @@
msgstr ""
"Project-Id-Version: grasstcl_de\n"
"PO-Revision-Date: 2007-02-23 09:12+0100\n"
"Last-Translator: Stephan Holl <stephan.holl at intevation.de>\n"
"Language-Team: deutsch <translations at lists.osgeo.org>\n"
@@ -51,11 +51,14 @@
[...1640 lines suppressed...]
msgstr "Testen"
+#, fuzzy
+#~ msgid " width"
+#~ msgstr "Breite:"
+#~ msgstr "Textfarbe"
+#~ msgstr " TextgröÃe"
+#~ msgid " justification"
+#~ msgstr " Ausrichtung"
+#~ msgid "query cat values "
+#~ msgstr "Kategoriewerte abfragen "
#~ msgid ""
#~ "WARNING: Please supply a\n"
Index: grasstcl_el.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_el.po,v
--- grasstcl_el.po 21 Nov 2007 13:18:52 -0000 1.9
+++ grasstcl_el.po 29 Nov 2007 20:21:06 -0000 1.10
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grasstcl_el\n"
"PO-Revision-Date: 2007-03-23 16:35+0100\n"
"Language-Team: Greek <translations at lists.osgeo.org>\n"
@@ -48,11 +48,14 @@
msgstr ""
msgstr ""
msgstr ""
msgstr ""
Index: grasstcl_es.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_es.po,v
retrieving revision 1.61
retrieving revision 1.62
diff -u -d -r1.61 -r1.62
--- grasstcl_es.po 23 Nov 2007 17:37:42 -0000 1.61
+++ grasstcl_es.po 29 Nov 2007 20:21:06 -0000 1.62
@@ -11,15 +11,15 @@
msgstr ""
"Project-Id-Version: grasstcl_es\n"
-"POT-Creation-Date: 2007-11-23 18:36+0100\n"
-"PO-Revision-Date: 2007-11-23 18:37+0100\n"
+"PO-Revision-Date: 2007-11-29 09:21+0100\n"
"Language-Team: Español <grass-translations at lists.osgeo.org>\n"
"Content-Type: text/plain; charset=UTF-8\n"
"Content-Transfer-Encoding: 8bit\n"
-"Plural-Forms: nplurals=2; plural=(n != 1);\n"
+"Plural-Forms: nplurals=2; plural=(n != 1);\n"
#: ../gui/tcltk/d.m/barscale.tcl:67 ../gui/tcltk/d.m/legend.tcl:106
msgid "Text color: "
@@ -98,7 +98,8 @@
#: ../gui/tcltk/d.m/barscale.tcl:118 ../gui/tcltk/d.m/legend.tcl:185
msgid "place with mouse (cannot save placement with group)"
-msgstr "colocar con el ratón (no se puede guardar en el emplazamiento en grupo) "
+msgstr ""
+"colocar con el ratón (no se puede guardar en el emplazamiento en grupo) "
#: ../gui/tcltk/d.m/chart.tcl:91 ../gui/tcltk/gis.m/chart.tcl:176
msgid "Vector map to chart:"
@@ -109,28 +110,27 @@
msgstr "Tipo de vector:"
#: ../gui/tcltk/d.m/chart.tcl:107 ../gui/tcltk/d.m/vector.tcl:227
-#: ../gui/tcltk/gis.m/chart.tcl:195 ../gui/tcltk/gis.m/vector.tcl:355
+#: ../gui/tcltk/gis.m/chart.tcl:195
msgid "points"
msgstr "puntos"
#: ../gui/tcltk/d.m/chart.tcl:108 ../gui/tcltk/d.m/vector.tcl:229
#: ../gui/tcltk/gis.m/chart.tcl:196 ../gui/tcltk/gis.m/legend.tcl:277
-#: ../gui/tcltk/gis.m/vector.tcl:357
msgid "lines"
msgstr "lÃneas"
#: ../gui/tcltk/d.m/chart.tcl:109 ../gui/tcltk/d.m/vector.tcl:231
-#: ../gui/tcltk/gis.m/chart.tcl:197 ../gui/tcltk/gis.m/vector.tcl:359
+#: ../gui/tcltk/gis.m/chart.tcl:197
msgid "boundaries"
msgstr "bordes"
#: ../gui/tcltk/d.m/chart.tcl:110 ../gui/tcltk/d.m/vector.tcl:233
-#: ../gui/tcltk/gis.m/chart.tcl:198 ../gui/tcltk/gis.m/vector.tcl:363
+#: ../gui/tcltk/gis.m/chart.tcl:198
msgid "centroids"
msgstr "centróides"
#: ../gui/tcltk/d.m/chart.tcl:111 ../gui/tcltk/d.m/vector.tcl:235
-#: ../gui/tcltk/gis.m/chart.tcl:199 ../gui/tcltk/gis.m/vector.tcl:361
+#: ../gui/tcltk/gis.m/chart.tcl:199
msgid "areas"
msgstr "áreas"
@@ -197,7 +197,8 @@
#: ../gui/tcltk/d.m/fttext.tcl:102
msgid " (leave blank to place with mouse; position will not save)"
-msgstr " (dejar en blanco para colocar con el ratón; la posición no se guardará)"
+msgstr ""
+" (dejar en blanco para colocar con el ratón; la posición no se guardará)"
#: ../gui/tcltk/d.m/fttext.tcl:108
msgid " coordinate type"
@@ -517,7 +518,8 @@
#: ../gui/tcltk/d.m/menu.tcl:138
msgid "ASCII vector or point file/old GRASS ASCII vector file"
-msgstr "Vector ASCII de archivo de puntos/antiguo archivo vectorial GRASS ASCII"
+msgstr ""
+"Vector ASCII de archivo de puntos/antiguo archivo vectorial GRASS ASCII"
#: ../gui/tcltk/d.m/menu.tcl:139
msgid "POV-Ray format"
@@ -731,11 +733,13 @@
#: ../gui/tcltk/d.m/menu.tcl:201
msgid "Create/edit projection information for current location"
-msgstr "Crear/editar la información de la proyección para la localización activa"
+msgstr ""
+"Crear/editar la información de la proyección para la localización activa"
#: ../gui/tcltk/d.m/menu.tcl:202
msgid "Show projection information and create projection files"
-msgstr "Mostrar información de la proyección y crear los archivos de proyección"
+msgstr ""
+"Mostrar información de la proyección y crear los archivos de proyección"
#: ../gui/tcltk/d.m/menu.tcl:204
msgid "Convert coordinates from one projection to another"
@@ -828,7 +832,8 @@
#: ../gui/tcltk/d.m/menu.tcl:232
msgid "Resample using regularized spline with tension method"
-msgstr "Volver a muestrear utilizando spline regularizada con el método de tensión"
+msgstr ""
+"Volver a muestrear utilizando spline regularizada con el método de tensión"
#: ../gui/tcltk/d.m/menu.tcl:235
msgid "Support file creation and maintenance"
@@ -1135,7 +1140,8 @@
#: ../gui/tcltk/d.m/menu.tcl:332
msgid "Generate random cells and vector points from raster map"
-msgstr "Generar celdas aleatorias y puntos vectoriales a partir de un mapa ráster"
+msgstr ""
+"Generar celdas aleatorias y puntos vectoriales a partir de un mapa ráster"
#: ../gui/tcltk/d.m/menu.tcl:334 ../gui/tcltk/gis.m/gmmenu.tcl:372
msgid "Generate surfaces"
@@ -1187,7 +1193,8 @@
#: ../gui/tcltk/d.m/menu.tcl:348
msgid "Inverse distance weighted interpolation from vector points"
-msgstr "Interpolación de distancia inversa ponderada a partir de puntos vectoriales"
+msgstr ""
+"Interpolación de distancia inversa ponderada a partir de puntos vectoriales"
#: ../gui/tcltk/d.m/menu.tcl:349
msgid "Regularized spline tension interpolation from vector points or contours"
@@ -1391,7 +1398,8 @@
#: ../gui/tcltk/d.m/menu.tcl:415
msgid "Generate Thiessen polygons around points (Voronoi diagram)"
-msgstr "Generar polÃgonos de Thiessen alrededor de puntos (diagrama de Voronoi)"
+msgstr ""
+"Generar polÃgonos de Thiessen alrededor de puntos (diagrama de Voronoi)"
#: ../gui/tcltk/d.m/menu.tcl:416
msgid "Connect points to create Delaunay triangles"
@@ -1499,7 +1507,8 @@
#: ../gui/tcltk/d.m/menu.tcl:451
msgid "Calculate statistics for raster map overlain by vector map"
-msgstr "Calcular estadÃsticas para mapas ráster cubiertos por mapas vectoriales"
+msgstr ""
+"Calcular estadÃsticas para mapas ráster cubiertos por mapas vectoriales"
#: ../gui/tcltk/d.m/menu.tcl:452 ../gui/tcltk/gis.m/gmmenu.tcl:512
msgid "Sample raster map at point locations"
@@ -1517,7 +1526,8 @@
#: ../gui/tcltk/d.m/menu.tcl:456
msgid "Transfer attribute data from queried vector map to points"
-msgstr "Transferir datos de atributo de las consultas del mapa vectorial a puntos"
+msgstr ""
+"Transferir datos de atributo de las consultas del mapa vectorial a puntos"
#: ../gui/tcltk/d.m/menu.tcl:460 ../gui/tcltk/gis.m/gmmenu.tcl:517
#: ../gui/tcltk/gis.m/gmmenu.tcl:587
@@ -1538,7 +1548,8 @@
#: ../gui/tcltk/d.m/menu.tcl:466
msgid "Calculate stats for raster map underlying vector objects"
-msgstr "Calcular estadÃsticas para objetos vectoriales superpuestos a un mapa ráster"
+msgstr ""
+"Calcular estadÃsticas para objetos vectoriales superpuestos a un mapa ráster"
#: ../gui/tcltk/d.m/menu.tcl:467
msgid "Indices of point counts in quadrats"
@@ -1569,19 +1580,22 @@
msgstr "Administrar colores de imágenes"
#: ../gui/tcltk/d.m/menu.tcl:478
-msgid "Color balance and enhance color tables of multiband imagery for rgb display"
+msgid ""
+"Color balance and enhance color tables of multiband imagery for rgb display"
msgstr ""
"Balance de color y mejora de tablas de color de imágenes multibanda para "
"visualización RGB"
#: ../gui/tcltk/d.m/menu.tcl:479
-msgid "Transform HIS (Hue/Intensity/Saturation) color image to RGB (Red/Green/Blue)"
+msgid ""
+"Transform HIS (Hue/Intensity/Saturation) color image to RGB (Red/Green/Blue)"
msgstr ""
"Transformar imagen de color HIS (tono/intensidad/saturación) a RGB (rojo/"
"verde/azul)"
#: ../gui/tcltk/d.m/menu.tcl:480
-msgid "Transform RGB (Red/Green/Blue) color image to HIS (Hue/Intensity/Saturation)"
+msgid ""
+"Transform RGB (Red/Green/Blue) color image to HIS (Hue/Intensity/Saturation)"
msgstr ""
"Transformar imágenes de color RGB (rojo/verde/azul) a HIS (tono/intensidad/"
"saturación)"
@@ -2028,7 +2042,7 @@
msgstr "tipo de vectorial"
#: ../gui/tcltk/d.m/thematic.tcl:150 ../gui/tcltk/d.m/vector.tcl:348
-#: ../gui/tcltk/gis.m/thematic.tcl:268 ../gui/tcltk/gis.m/vector.tcl:483
+#: ../gui/tcltk/gis.m/thematic.tcl:268
msgid " show attribute columns"
msgstr "mostrar columnas de atributos"
@@ -2057,7 +2071,7 @@
msgstr "Por mapa"
#: ../gui/tcltk/d.m/thematic.tcl:205 ../gui/tcltk/d.m/vector.tcl:245
-#: ../gui/tcltk/gis.m/thematic.tcl:320 ../gui/tcltk/gis.m/vector.tcl:373
+#: ../gui/tcltk/gis.m/thematic.tcl:320
msgid "icon"
msgstr "icono"
@@ -2241,19 +2255,19 @@
msgid "Display:"
msgstr "Visualizar:"
-#: ../gui/tcltk/d.m/vector.tcl:213 ../gui/tcltk/gis.m/vector.tcl:341
+#: ../gui/tcltk/d.m/vector.tcl:213
msgid "shapes"
msgstr "formas"
-#: ../gui/tcltk/d.m/vector.tcl:215 ../gui/tcltk/gis.m/vector.tcl:343
+#: ../gui/tcltk/d.m/vector.tcl:215
msgid "categories"
msgstr "categorÃas"
-#: ../gui/tcltk/d.m/vector.tcl:217 ../gui/tcltk/gis.m/vector.tcl:345
+#: ../gui/tcltk/d.m/vector.tcl:217
msgid "topology"
msgstr "topologÃa"
-#: ../gui/tcltk/d.m/vector.tcl:219 ../gui/tcltk/gis.m/vector.tcl:347
+#: ../gui/tcltk/d.m/vector.tcl:219
msgid "line directions"
msgstr "direcciones de lÃnea"
@@ -2261,7 +2275,7 @@
msgid " "
msgstr " "
-#: ../gui/tcltk/d.m/vector.tcl:237 ../gui/tcltk/gis.m/vector.tcl:365
+#: ../gui/tcltk/d.m/vector.tcl:237
msgid "faces"
msgstr "caras"
@@ -2270,8 +2284,7 @@
msgstr "Dibujar lÃneas:"
#: ../gui/tcltk/d.m/vector.tcl:262 ../gui/tcltk/d.m/vector.tcl:278
-#: ../gui/tcltk/d.m/vector.tcl:294 ../gui/tcltk/gis.m/vector.tcl:388
-#: ../gui/tcltk/gis.m/vector.tcl:404
+#: ../gui/tcltk/d.m/vector.tcl:294
msgid "color"
msgstr "color"
@@ -2283,7 +2296,7 @@
msgid " "
msgstr " "
-#: ../gui/tcltk/d.m/vector.tcl:282 ../gui/tcltk/gis.m/vector.tcl:408
+#: ../gui/tcltk/d.m/vector.tcl:282
msgid "random colors"
msgstr "Colores aleatorios"
@@ -2299,7 +2312,7 @@
msgid "label"
msgstr "Etiqueta"
-#: ../gui/tcltk/d.m/vector.tcl:297 ../gui/tcltk/gis.m/vector.tcl:377
+#: ../gui/tcltk/d.m/vector.tcl:297
msgid " size"
msgstr "tamaño"
@@ -2311,11 +2324,11 @@
msgid " align with pt"
msgstr " alinear con punto"
-#: ../gui/tcltk/d.m/vector.tcl:315 ../gui/tcltk/gis.m/vector.tcl:446
+#: ../gui/tcltk/d.m/vector.tcl:315
msgid " layer for labels"
msgstr " capa para etiquetas"
-#: ../gui/tcltk/d.m/vector.tcl:318 ../gui/tcltk/gis.m/vector.tcl:448
+#: ../gui/tcltk/d.m/vector.tcl:318
msgid " attribute col for labels"
msgstr "Columna de atributos para las etiquetas"
@@ -2405,7 +2418,7 @@
#: ../gui/tcltk/gis.m/labels.tcl:122 ../gui/tcltk/gis.m/legend.tcl:176
#: ../gui/tcltk/gis.m/rastarrows.tcl:151 ../gui/tcltk/gis.m/raster.tcl:172
#: ../gui/tcltk/gis.m/rastnums.tcl:150 ../gui/tcltk/gis.m/rgbhis.tcl:147
-#: ../gui/tcltk/gis.m/thematic.tcl:227 ../gui/tcltk/gis.m/vector.tcl:310
+#: ../gui/tcltk/gis.m/thematic.tcl:227
msgid " Transparent"
msgstr " Transparente"
@@ -2416,7 +2429,8 @@
#: ../gui/tcltk/gis.m/barscale.tcl:176
msgid "\t enter x,y of scale/arrow upper left corner"
-msgstr "\t introducir X, Y de la esquina superior izquierda de la escala/flecha"
+msgstr ""
+"\t introducir X, Y de la esquina superior izquierda de la escala/flecha"
#: ../gui/tcltk/gis.m/barscale.tcl:179
msgid " "
@@ -2472,7 +2486,8 @@
msgstr "gráfico para %s"
#: ../gui/tcltk/gis.m/chart.tcl:159
-msgid "Display pie and bar charts of attribute values at vector object locations"
+msgid ""
+"Display pie and bar charts of attribute values at vector object locations"
msgstr ""
"Mostrar gráficos de tarta o de barras de los valores de atributos en las "
"localizaciones de los objetos vectoriales"
@@ -2489,7 +2504,7 @@
-#: ../gui/tcltk/gis.m/chart.tcl:218 ../gui/tcltk/gis.m/vector.tcl:489
+#: ../gui/tcltk/gis.m/chart.tcl:218
msgid " show attribute data"
msgstr "mostrar atributos"
@@ -2555,7 +2570,8 @@
#: ../gui/tcltk/gis.m/frames.tcl:105
msgid "Divide map display into frames for displaying multiple maps"
-msgstr "Dividir visualización de mapa en marcos para visualizar múltiples mapas"
+msgstr ""
+"Dividir visualización de mapa en marcos para visualizar múltiples mapas"
#: ../gui/tcltk/gis.m/frames.tcl:116
msgid "remove all frames "
@@ -4133,7 +4149,8 @@
#: ../gui/tcltk/gis.m/legend.tcl:165
msgid "Display legend for raster map using cat values and labels"
-msgstr "Mostrar leyenda para mapa ráster usando valores de categorÃas y etiquetas"
+msgstr ""
+"Mostrar leyenda para mapa ráster usando valores de categorÃas y etiquetas"
#: ../gui/tcltk/gis.m/legend.tcl:182
msgid "Raster map: "
@@ -4521,7 +4538,8 @@
#: ../gui/tcltk/gis.m/maptool.tcl:199
msgid "Set current region (WIND file) to match display"
-msgstr "Establecer la región actual (archivo WIND) para ajustar a la visualización"
+msgstr ""
+"Establecer la región actual (archivo WIND) para ajustar a la visualización"
#: ../gui/tcltk/gis.m/maptool.tcl:247
msgid "Measure"
@@ -4662,7 +4680,8 @@
#: ../gui/tcltk/gis.m/rastarrows.tcl:134
msgid "Display arrows whose orientations are based on raster aspect map"
-msgstr "Mostrar flechas cuya orientación esté basada en mapa ráster de orientación"
+msgstr ""
+"Mostrar flechas cuya orientación esté basada en mapa ráster de orientación"
#: ../gui/tcltk/gis.m/rastarrows.tcl:140
msgid " (optionally, arrow lengths are based on slope or intensity map)"
@@ -4732,7 +4751,8 @@
#: ../gui/tcltk/gis.m/raster.tcl:214
msgid "\tdrape map for color in color relief map or data fusion"
-msgstr "\tmapa de cobertura para mapa de relieve color en color o fusión de datos"
+msgstr ""
+"\tmapa de cobertura para mapa de relieve color en color o fusión de datos"
#: ../gui/tcltk/gis.m/raster.tcl:219
msgid "\tdrape map: "
@@ -4817,7 +4837,8 @@
msgstr "Mapa ráster para el canal azul o de saturación"
#: ../gui/tcltk/gis.m/rgbhis.tcl:136
-msgid "Display 3 raster maps as Red/Green/Blue or Hue/Intensity/Saturation channels"
+msgid ""
+"Display 3 raster maps as Red/Green/Blue or Hue/Intensity/Saturation channels"
msgstr ""
"Mostrar 3 mapas ráster como canales Rojo/Verde/Azul o de Tonalidad/"
"Intensidad/Saturación"
@@ -5077,6 +5098,10 @@
msgid "Display vector maps"
msgstr "Visualizar mapas vectoriales"
+#: ../gui/tcltk/gis.m/vector.tcl:310
+msgid "Transparent"
+msgstr "Transparente"
#: ../gui/tcltk/gis.m/vector.tcl:319
msgid "vector map to display"
msgstr "vectorial a visualizar"
@@ -5089,17 +5114,69 @@
msgid "Display: "
msgstr "Visualizar: "
+#: ../gui/tcltk/gis.m/vector.tcl:341
+msgid "Shapes "
+msgstr "Formas "
+#: ../gui/tcltk/gis.m/vector.tcl:343
+msgid "Categories "
+msgstr "CategorÃas "
+#: ../gui/tcltk/gis.m/vector.tcl:345
+msgid "Topology "
+msgstr "TopologÃa "
+#: ../gui/tcltk/gis.m/vector.tcl:347
+msgid "Line directions "
+msgstr "Direcciones de lÃnea "
+#: ../gui/tcltk/gis.m/vector.tcl:355
+msgid "Points "
+msgstr "Puntos "
+#: ../gui/tcltk/gis.m/vector.tcl:357
+msgid "Lines "
+msgstr "LÃneas "
+#: ../gui/tcltk/gis.m/vector.tcl:359
+msgid "Boundaries "
+msgstr "Contornos "
+#: ../gui/tcltk/gis.m/vector.tcl:361
+msgid "Areas "
+msgstr "Ãreas "
+#: ../gui/tcltk/gis.m/vector.tcl:363
+msgid "Centroids "
+msgstr "Centroides "
+#: ../gui/tcltk/gis.m/vector.tcl:365
+msgid "Faces "
+msgstr "Caras "
#: ../gui/tcltk/gis.m/vector.tcl:372
msgid "Point symbols:"
msgstr "SÃmbolos de puntos:"
+#: ../gui/tcltk/gis.m/vector.tcl:373
+msgid "Icon"
+msgstr "Icono"
+#: ../gui/tcltk/gis.m/vector.tcl:377
+msgid " Size"
+msgstr " Tamaño"
#: ../gui/tcltk/gis.m/vector.tcl:379
msgid "Icon size"
msgstr "Tamaño de icono"
+#: ../gui/tcltk/gis.m/vector.tcl:388 ../gui/tcltk/gis.m/vector.tcl:404
+msgid "Color"
+msgstr "Color"
#: ../gui/tcltk/gis.m/vector.tcl:391
-msgid " width"
-msgstr " anchura"
+msgid " Width"
+msgstr " Anchura"
#: ../gui/tcltk/gis.m/vector.tcl:393
msgid "Line width"
@@ -5109,49 +5186,69 @@
msgid "(pixels) "
msgstr "(pÃxeles) "
+#: ../gui/tcltk/gis.m/vector.tcl:408
+msgid "Random colors "
+msgstr "Colores aleatorios "
#: ../gui/tcltk/gis.m/vector.tcl:420
-msgid "text color"
-msgstr "color de texto"
+msgid " Text color"
+msgstr " Color de texto"
#: ../gui/tcltk/gis.m/vector.tcl:423
-msgid " text size"
-msgstr "tamaño de texto"
+msgid " Text size"
+msgstr " Tamaño de texto"
#: ../gui/tcltk/gis.m/vector.tcl:433
-msgid "label part to align with vector point"
-msgstr "parte de la etiqueta para alinear con punto vectorial"
+msgid "Label part to align with vector point"
+msgstr "Parte de la etiqueta para alinear con punto vectorial"
#: ../gui/tcltk/gis.m/vector.tcl:437
-msgid " justification"
-msgstr " justificación"
+msgid " Justification"
+msgstr " Justificación"
+#: ../gui/tcltk/gis.m/vector.tcl:446
+msgid " Layer for labels"
+msgstr " Capa para etiquetas"
+#: ../gui/tcltk/gis.m/vector.tcl:448
+msgid " Attribute col for labels"
+msgstr " Columna de atributos para las etiquetas"
#: ../gui/tcltk/gis.m/vector.tcl:455
msgid "Query vectors for display: "
msgstr "Consultar vectoriales para visualizar: "
#: ../gui/tcltk/gis.m/vector.tcl:464
-msgid "query cat values "
-msgstr "consultar valores de categorÃa"
+msgid "Query cat values"
+msgstr "Valores de las categorÃas para la consulta"
#: ../gui/tcltk/gis.m/vector.tcl:475
-msgid "use SQL query"
-msgstr "usar consulta SQL"
+msgid "Use SQL query"
+msgstr "Usar consulta SQL"
+#: ../gui/tcltk/gis.m/vector.tcl:483
+msgid " Show attribute columns"
+msgstr " Mostrar columnas de atributos"
+#: ../gui/tcltk/gis.m/vector.tcl:489
+msgid " Show attribute data"
+msgstr " Mostrar atributos"
#: ../gui/tcltk/gis.m/vector.tcl:501
-msgid "save displayed objects to new vector file "
-msgstr "Guardar objetos visualizados en nuevo vectorial"
+msgid "Save displayed objects to new vector file "
+msgstr "Guardar objetos visualizados en nuevo vectorial "
#: ../gui/tcltk/gis.m/vector.tcl:503
-msgid "overwrite existing"
+msgid "Overwrite existing"
msgstr "Sobrescribir existente"
#: ../gui/tcltk/gis.m/vector.tcl:510
-msgid " new vector"
-msgstr " nuevo vectorial"
+msgid " New vector"
+msgstr " Nuevo vectorial"
#: ../gui/tcltk/gis.m/vector.tcl:514
-msgid "select existing vector for saving queried objects"
-msgstr "seleccionar vectorial existente para guardar objetos consultados"
+msgid "Select existing vector for saving queried objects"
+msgstr "Seleccionar vectorial existente para guardar objetos consultados"
#: ../gui/tcltk/gis.m/vector.tcl:525
msgid " or <"
@@ -5219,7 +5316,8 @@
#: ../gui/tcltk/gis.m/animate.tcl:479
msgid "Select maps to animate in one or more frames (1 frame required)"
-msgstr "Seleccionar mapas para animar en uno o más marcos (se requiere un marco)"
+msgstr ""
+"Seleccionar mapas para animar en uno o más marcos (se requiere un marco)"
#: ../gui/tcltk/gis.m/animate.tcl:492
msgid "Maps for frame 1 (required): "
@@ -5563,7 +5661,8 @@
#: ../lib/init/file_option.tcl:102
msgid "Path to georeferenced file (format must be readable by GDAL/OGR)"
-msgstr "Ruta a archivo georreferenciado (el formato debe ser legible por GDAL/OGR)"
+msgstr ""
+"Ruta a archivo georreferenciado (el formato debe ser legible por GDAL/OGR)"
#: ../lib/init/file_option.tcl:106
msgid "Browse to locate georeferenced file"
@@ -5618,8 +5717,10 @@
#: ../lib/init/gis_set.tcl:132
#, tcl-format
-msgid "Warning: location <%s> at GISDBASE <%s> is not a directory or does not exist."
-msgstr "AVISO: la localización <%s> en GISDBASE <%s> no es un directorio o no existe."
+msgid ""
+"Warning: location <%s> at GISDBASE <%s> is not a directory or does not exist."
+msgstr ""
+"AVISO: la localización <%s> en GISDBASE <%s> no es un directorio o no existe."
#: ../lib/init/gis_set.tcl:177
#, tcl-format
@@ -6042,4 +6143,3 @@
msgid "Test"
msgstr "Test"
Index: grasstcl_fr.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_fr.po,v
retrieving revision 1.19
retrieving revision 1.20
diff -u -d -r1.19 -r1.20
--- grasstcl_fr.po 26 Oct 2007 19:35:25 -0000 1.19
+++ grasstcl_fr.po 29 Nov 2007 20:21:06 -0000 1.20
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grasstcl_fr\n"
"PO-Revision-Date: 2007-08-08 22:40+0200\n"
"Last-Translator: BAIN <bain at toraval.fr>\n"
"Language-Team: french\n"
@@ -51,11 +51,14 @@
[...1598 lines suppressed...]
msgstr ""
@@ -6160,6 +6334,15 @@
#, fuzzy
msgid "Test"
msgstr "Texte"
+#~ msgstr "couleur de texte"
+#~ msgstr " taille de texte"
+#~ msgstr " justification"
#~ msgid ""
#~ "Could not open file for writing.\n"
Index: grasstcl_hi.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_hi.po,v
retrieving revision 1.15
retrieving revision 1.16
diff -u -d -r1.15 -r1.16
--- grasstcl_hi.po 21 Nov 2007 13:18:52 -0000 1.15
+++ grasstcl_hi.po 29 Nov 2007 20:21:06 -0000 1.16
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grasstcl_hi\n"
"PO-Revision-Date: 2006-09-19 22:49+0200\n"
"Last-Translator: Markus Neteler <neteler at itc.it>\n"
"Language-Team: Hindi <translations at lists.osgeo.org>\n"
@@ -48,11 +48,14 @@
msgstr ""
msgstr ""
msgstr ""
msgstr ""
Index: grasstcl_it.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_it.po,v
retrieving revision 1.21
retrieving revision 1.22
diff -u -d -r1.21 -r1.22
--- grasstcl_it.po 21 Nov 2007 13:18:52 -0000 1.21
+++ grasstcl_it.po 29 Nov 2007 20:21:06 -0000 1.22
@@ -9,7 +9,7 @@
msgstr ""
"Project-Id-Version: grasstcl_it\n"
"PO-Revision-Date: 2006-08-06 17:26+0200\n"
"Last-Translator: Luciano Montanaro <mikelima at cirulla.net>\n"
"Language-Team: Italian <translations at lists.osgeo.org>\n"
@@ -51,11 +51,14 @@
[...1688 lines suppressed...]
@@ -6788,9 +6976,6 @@
#~ msgid "Num. Levels:"
#~ msgstr "Num. Livelli:"
-#~ msgid "Interpolation"
-#~ msgstr "Interpolazione"
#~ msgid "linear"
#~ msgstr "lineare"
@@ -7202,9 +7387,6 @@
#~ msgid "Site"
#~ msgstr "Site"
-#~ msgid "Icons"
-#~ msgstr "Icone"
#~ msgid "Color Panel"
#~ msgstr "Pannello Colore"
Index: grasstcl_ja.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_ja.po,v
retrieving revision 1.18
--- grasstcl_ja.po 21 Nov 2007 13:18:52 -0000 1.17
+++ grasstcl_ja.po 29 Nov 2007 20:21:06 -0000 1.18
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grasstcl_ja\n"
"PO-Revision-Date: 2006-06-29 11:49+0200\n"
"Language-Team: Japanese <translations at lists.osgeo.org>\n"
@@ -52,11 +52,14 @@
[...1654 lines suppressed...]
#, fuzzy
-#~ msgid "Color"
-#~ msgstr "è²"
-#, fuzzy
#~ msgid "Display on surface(s):"
#~ msgstr "ã¬ã³ã:"
@@ -6764,10 +6920,6 @@
#, fuzzy
#~ msgid "Threshold Type"
#~ msgstr "ã¢ã¤ã³ã³"
-#, fuzzy
-#~ msgstr "è£é"
#, fuzzy
#~ msgid "Pipe to: None"
Index: grasstcl_ko.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_ko.po,v
--- grasstcl_ko.po 21 Nov 2007 13:18:52 -0000 1.9
+++ grasstcl_ko.po 29 Nov 2007 20:21:06 -0000 1.10
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grasstcl_ko\n"
"Language-Team: Korean <translations at lists.osgeo.org>\n"
@@ -47,11 +47,14 @@
msgstr ""
msgstr ""
msgstr ""
msgstr ""
Index: grasstcl_lv.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_lv.po,v
--- grasstcl_lv.po 21 Nov 2007 13:18:52 -0000 1.15
+++ grasstcl_lv.po 29 Nov 2007 20:21:06 -0000 1.16
@@ -6,7 +6,7 @@
msgstr ""
"Project-Id-Version: grasstcl_lv\n"
"PO-Revision-Date: 2006-12-09 01:00+0200\n"
"Last-Translator: Maris Nartiss <maris.kde at gmail.com>\n"
"Language-Team: Latvian <translations at lists.osgeo.org>\n"
@@ -49,11 +49,14 @@
[...1524 lines suppressed...]
msgstr ""
msgstr ""
msgstr ""
msgstr ""
Index: grasstcl_mr.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_mr.po,v
retrieving revision 1.11
diff -u -d -r1.10 -r1.11
--- grasstcl_mr.po 21 Nov 2007 13:18:52 -0000 1.10
+++ grasstcl_mr.po 29 Nov 2007 20:21:06 -0000 1.11
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grasstcl_mr\n"
"Language-Team: Marathi <translations at lists.osgeo.org>\n"
@@ -47,11 +47,14 @@
msgstr ""
msgstr ""
msgstr ""
msgstr ""
Index: grasstcl_pl.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_pl.po,v
--- grasstcl_pl.po 26 Oct 2007 19:35:25 -0000 1.21
+++ grasstcl_pl.po 29 Nov 2007 20:21:06 -0000 1.22
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grasstcl_pl\n"
"PO-Revision-Date: 2007-09-19 22:10+0100\n"
"Last-Translator: Monika Tylus <monikatylus_gmail.com>\n"
"Language-Team: Polska <translation at grass.itc.it>\n"
@@ -47,11 +47,14 @@
[...1648 lines suppressed...]
@@ -6517,9 +6708,6 @@
#~ msgid "Current:"
#~ msgstr "Bie¿±cy:"
-#~ msgid "Color"
-#~ msgstr "Kolor"
#~ msgid "Draw Current"
#~ msgstr "Przerysuj Bie¿±cy"
@@ -6552,9 +6740,6 @@
#~ msgid "Labels"
#~ msgstr "Etykiety"
-#~ msgid "Icons"
-#~ msgstr "Ikony"
#~ msgid "3d.view"
#~ msgstr "Widok 3d"
Index: grasstcl_pt.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_pt.po,v
retrieving revision 1.13
diff -u -d -r1.12 -r1.13
--- grasstcl_pt.po 21 Nov 2007 13:18:52 -0000 1.12
+++ grasstcl_pt.po 29 Nov 2007 20:21:06 -0000 1.13
@@ -9,7 +9,7 @@
msgstr ""
"Project-Id-Version: grasstcl_pt\n"
"PO-Revision-Date: 2007-06-18 20:35-0300\n"
"Last-Translator: Paulo E. P. Marcondes <paulomarcondes at gmail dot com>\n"
"Language-Team: Portuguese <translations at lists.osgeo.org>\n"
@@ -51,11 +51,14 @@
[...1625 lines suppressed...]
msgid "Test"
msgstr "Teste"
+#~ msgid " width"
+#~ msgstr "largura"
+#~ msgstr "Cor do Texto"
+#~ msgstr " tamanho do texto"
+#~ msgstr " justificar"
+#~ msgstr "Pesquisar valores de categoria"
#~ msgid ""
Index: grasstcl_pt_br.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_pt_br.po,v
retrieving revision 1.27
retrieving revision 1.28
diff -u -d -r1.27 -r1.28
--- grasstcl_pt_br.po 21 Nov 2007 13:18:52 -0000 1.27
+++ grasstcl_pt_br.po 29 Nov 2007 20:21:06 -0000 1.28
@@ -11,7 +11,7 @@
msgstr ""
"Project-Id-Version: grasstcl_pt_br\n"
"PO-Revision-Date: 2007-06-16 18:27-0300\n"
"Last-Translator: Paulo Eduardo Pasquini Marcondes <paulomarcondes at gmail."
"com>\n"
@@ -54,11 +54,14 @@
[...1624 lines suppressed...]
msgid "Test"
msgstr "Teste"
+#~ msgid " width"
#~ msgid ""
Index: grasstcl_ru.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_ru.po,v
--- grasstcl_ru.po 21 Nov 2007 13:18:53 -0000 1.15
+++ grasstcl_ru.po 29 Nov 2007 20:21:07 -0000 1.16
@@ -6,7 +6,7 @@
msgstr ""
"Project-Id-Version: grasstcl_ru\n"
"Language-Team: Russian <translations at lists.osgeo.org>\n"
@@ -47,11 +47,14 @@
[...1539 lines suppressed...]
msgstr ""
msgstr ""
#, fuzzy
msgstr "÷ÅËÔÏÒÎÁÑ ËÁÒÔÁ:"
msgstr ""
Index: grasstcl_sl.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_sl.po,v
--- grasstcl_sl.po 21 Nov 2007 13:18:53 -0000 1.9
+++ grasstcl_sl.po 29 Nov 2007 20:21:07 -0000 1.10
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grasstcl_sl\n"
"PO-Revision-Date: 007-03-16 21:31+0100\n"
"Language-Team: Sloven�na <translations at lists.osgeo.org>\n"
@@ -48,11 +48,14 @@
msgstr ""
msgstr ""
msgstr ""
msgstr ""
Index: grasstcl_th.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_th.po,v
diff -u -d -r1.1 -r1.2
--- grasstcl_th.po 15 Nov 2007 07:48:14 -0000 1.1
+++ grasstcl_th.po 29 Nov 2007 20:21:07 -0000 1.2
@@ -6,7 +6,7 @@
msgstr ""
"Project-Id-Version: grasstcl_th\n"
+"POT-Creation-Date: 2007-11-29 20:52+0100\n"
"PO-Revision-Date: 2007-11-12 02:10+0900\n"
"Last-Translator: Sarawut Ninsawat <sarawut.map at gmail.com>\n"
"Language-Team: Thai <grass-translations at lists.osgeo.org>\n"
@@ -50,11 +50,14 @@
[...1690 lines suppressed...]
-msgstr "สรà¹à¸²à¸ mapset à¹à¸«à¸¡à¹\n à¹à¸ location à¸à¸µà¹à¹à¸¥à¸·à¸à¸"
+msgstr ""
+"สรà¹à¸²à¸ mapset à¹à¸«à¸¡à¹\n"
+" à¹à¸ location à¸à¸µà¹à¹à¸¥à¸·à¸à¸"
#: ../lib/init/gis_set.tcl:366
msgid "Create new mapset"
@@ -5979,3 +6163,12 @@
msgid "Test"
msgstr "à¸à¸à¸ªà¸à¸"
+#, fuzzy
+#~ msgid " width"
+#~ msgstr "à¸à¸§à¹à¸²à¸"
+#~ msgstr "สีà¸à¹à¸à¸à¸§à¸²à¸¡"
+#~ msgstr "à¸à¸à¸²à¸à¸à¹à¸à¸à¸§à¸²à¸¡"
Index: grasstcl_tr.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_tr.po,v
retrieving revision 1.17
diff -u -d -r1.16 -r1.17
--- grasstcl_tr.po 21 Nov 2007 13:18:53 -0000 1.16
+++ grasstcl_tr.po 29 Nov 2007 20:21:07 -0000 1.17
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grasstcl_tr\n"
"PO-Revision-Date: 2006-06-20 16:04+0300\n"
"Last-Translator: Osman Yalçın YILMAZ\n"
"Language-Team: Turkish <translations at lists.osgeo.org>\n"
@@ -48,11 +48,14 @@
[...1653 lines suppressed...]
@@ -6495,9 +6681,6 @@
#~ msgid "Current:"
#~ msgstr "Güncel:"
-#~ msgid "Color"
-#~ msgstr "Renk"
#~ msgstr "Güncel olanı çiz."
@@ -6809,9 +6992,6 @@
#~ msgid "Labels"
#~ msgstr "Etiketler"
-#~ msgid "Icons"
-#~ msgstr "Simge"
#~ msgstr "Renk Paneli"
Index: grasstcl_vi.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_vi.po,v
diff -u -d -r1.17 -r1.18
--- grasstcl_vi.po 21 Nov 2007 13:18:53 -0000 1.17
+++ grasstcl_vi.po 29 Nov 2007 20:21:07 -0000 1.18
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grasstcl_vi\n"
"PO-Revision-Date: 2006-09-20 12:01+0200\n"
"Last-Translator: Bui Huu Manh <bhmanh73 at yahoo.com>\n"
"Language-Team: vietnamese <translations at lists.osgeo.org>\n"
@@ -50,11 +50,14 @@
[...1636 lines suppressed...]
msgstr "Chữ"
+#, fuzzy
+#~ msgid " width"
+#~ msgstr "chiá»u rá»ng:"
+#~ msgstr "mà u chữ"
+#~ msgstr "cỡ chữ"
+#~ msgstr " canh thẳng"
+#~ msgstr "truy vấn các giá trỠphạm trù "
#, fuzzy
#~ msgid "Select default font for GRASS displays"
Index: grasstcl_zh.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_zh.po,v
--- grasstcl_zh.po 21 Nov 2007 13:18:53 -0000 1.9
+++ grasstcl_zh.po 29 Nov 2007 20:21:07 -0000 1.10
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grasstcl_zh\n"
"Language-Team: Simplified Chinese <translations at lists.osgeo.org>\n"
@@ -50,11 +50,14 @@
msgstr ""
msgstr ""
msgstr ""
msgstr ""
