[GRASS-SVN] r30858 - grass-addons/gipe/i.dn2potrad.l5
svn_grass at osgeo.org
Fri Apr 4 05:08:20 EDT 2008
Author: ychemin
Date: 2008-04-04 05:08:19 -0400 (Fri, 04 Apr 2008)
New Revision: 30858
grass-addons/gipe/i.dn2potrad.l5/main.c
updated code for i.dn2potrad.l5
Modified: grass-addons/gipe/i.dn2potrad.l5/main.c
--- grass-addons/gipe/i.dn2potrad.l5/main.c 2008-04-04 08:29:28 UTC (rev 30857)
+++ grass-addons/gipe/i.dn2potrad.l5/main.c 2008-04-04 09:08:19 UTC (rev 30858)
@@ -1,8 +1,8 @@
- * MODULE: i.dn2potrad.l7
+ * MODULE: i.dn2potrad.l5
* AUTHOR(S): Yann Chemin - ychemin at gmail.com
- * PURPOSE: Calculate ETpot radiative for Landsat7 from DN.
+ * PURPOSE: Calculate ETpot radiative for Landsat5 from DN.
* COPYRIGHT: (C) 2007-2008 by the GRASS Development Team
@@ -36,7 +36,8 @@
#define KEXO3 1551.0
#define KEXO4 1044.0
#define KEXO5 225.7
-#define KEXO6 82.07
+#define KEXO6 0.00
+#define KEXO7 82.07
#define PI 3.1415926
@@ -114,7 +115,7 @@
double roh_w, tsw;
- double histogram[100]={0.0};
+ int histogram[100];
/* Albedo correction coefficients****/
double a, b;
@@ -151,20 +152,13 @@
input2->answer = "1010.0";
output = G_define_standard_option(G_OPT_R_OUTPUT) ;
- output->key = _("output");
- output->type = TYPE_STRING;
- output->required = YES;
- output->gisprompt = _("new,cell,raster");
output->description= _("ETpot output layer name");
/* Define the different flags */
flag1 = G_define_flag() ;
flag1->key =_('a');
- flag1->description =_("Albedo dry run to calculate some water\
- to beach/sand/desert stretching,\
- a kind of simple atmospheric correction.\
- Will slow down the processing.");
+ flag1->description =_("Albedo dry run to calculate some water to beach/sand/desert stretching, a kind of simple atmospheric correction. Will slow down the processing.");
if (G_parser(argc, argv))
@@ -190,7 +184,7 @@
// printf("%i=>%f, %f, %f, %f\n",i,lmin[i],lmax[i],qcalmin[i],qcalmax[i]);
doy = date2doy(day,month,year);
-// printf("doy=%i\n",doy);
+ printf("doy=%i\n",doy);
if(year<2000){
temp = year - 1900;
@@ -224,7 +218,8 @@
kexo[2]=KEXO3;
kexo[3]=KEXO4;
kexo[4]=KEXO5;
- kexo[5]=KEXO6;
+ kexo[5]=KEXO6;//filling only
+ kexo[6]=KEXO7;
@@ -431,6 +426,9 @@
/*START ALBEDO HISTOGRAM STRETCH*/
/*This is correcting contrast for water/sand*/
/*A poor man's atmospheric correction...*/
+ for (i=0;i<100;i++){
+ histogram[i]=0;
for (row = 0; row < nrows; row++)
G_percent (row, nrows, 2);
@@ -478,10 +476,16 @@
// End of Convert DN 2 radiance 2 reflectance
// Process regular data
- d_albedo = bb_alb_landsat(dout[0],dout[1],dout[2],dout[3],dout[4],dout[7]);
- int temp;
- temp = (int) (d_albedo*100);
- histogram[temp]++;
+ d_albedo = bb_alb_landsat(dout[0],dout[1],dout[2],dout[3],dout[4],dout[6]);
+ if(G_is_d_null_value(&d_albedo)){
+ /*Do nothing*/
+ } else {
+ int temp;
+ temp = (int) (d_albedo*100);
+ if(temp>0){
+ histogram[temp]=histogram[temp]+1.0;
printf("Histogram of Albedo\n");
@@ -494,23 +498,22 @@
i_peak2=0;
i_peak3=0;
for(i=0;i<100;i++){
- printf("%d\t%d\n",i,histogram[i]);
/*Search for peaks of datasets (1)*/
- if(i<10){
+ if(i<=10){
if(histogram[i]>peak1){
peak1 = histogram[i];
i_peak1=i;
/*Search for peaks of datasets (2)*/
- if(i>=10&&i<40){
+ if(i>=10&&i<=30){
if(histogram[i]>peak2){
peak2 = histogram[i];
i_peak2=i;
/*Search for peaks of datasets (3)*/
- if(i>=40){
+ if(i>=30){
if(histogram[i]>peak3){
peak3 = histogram[i];
i_peak3=i;
@@ -523,12 +526,12 @@
int i_bottom1a, i_bottom1b;
int i_bottom2a, i_bottom2b;
int i_bottom3a, i_bottom3b;
- bottom1a=1000;
- bottom1b=1000;
- bottom2a=1000;
- bottom2b=1000;
- bottom3a=1000;
- bottom3b=1000;
+ bottom1a=100000;
+ bottom1b=100000;
+ bottom2a=100000;
+ bottom2b=100000;
+ bottom3a=100000;
+ bottom3b=100000;
i_bottom1a=100;
i_bottom1b=100;
i_bottom2a=100;
@@ -577,8 +580,11 @@
i_bottom3b = i;
- a=(0.36-0.05)/(i_bottom2b/100.0-i_bottom1a/100.0);
- b=0.05-a*(i_bottom1a/100.0);
+ printf("peak1 %d %d\n",peak1, i_peak1);
+ printf("bottom2b= %d %d\n",bottom2b, i_bottom2b);
+ a=(0.36-0.05)/(i_bottom2b/100.0-i_peak1/100.0);
+ b=0.05-a*(i_peak1/100.0);
+ printf("a= %f\tb= %f\n",a,b);
}//END OF FLAG1
/*START PROCESSING*/
@@ -642,7 +648,7 @@
// End of process regular data
// write output to file
- ((DCELL *) outrast[0])[col] = d_etpot;
+ ((DCELL *) outrast[0])[col] = d_solar;
// End of write output to file
if (G_put_raster_row (outfd[0], outrast[0], out_data_type) < 0)
