[GRASS-SVN] r30859 - in grass/trunk/raster: r.in.mat r.out.mat
svn_grass at osgeo.org
Fri Apr 4 09:32:10 EDT 2008
Author: glynn
Date: 2008-04-04 09:32:10 -0400 (Fri, 04 Apr 2008)
New Revision: 30859
grass/trunk/raster/r.in.mat/main.c
grass/trunk/raster/r.out.mat/main.c
Use int instead of long to avoid issues on 64-bit systems
Modified: grass/trunk/raster/r.in.mat/main.c
--- grass/trunk/raster/r.in.mat/main.c 2008-04-04 09:08:19 UTC (rev 30858)
+++ grass/trunk/raster/r.in.mat/main.c 2008-04-04 13:32:10 UTC (rev 30859)
@@ -52,13 +52,13 @@
int machine_endianness, file_endianness, endian_mismatch; /* 0=little, 1=big */
int data_format; /* 0=double 1=float 2=32bit signed int 5=8bit unsigned int (ie text) */
int data_type; /* 0=numbers 1=text */
- long format_block; /* combo of endianness, 0, data_format, and type */
- static long realflag = 0; /* 0=only real values used */
+ int format_block; /* combo of endianness, 0, data_format, and type */
+ int realflag = 0; /* 0=only real values used */
/* should type be specifically uint32 ??? */
char array_name[65];
int name_len;
- long mrows, ncols; /* text/data/map array dimensions*/
+ int mrows, ncols; /* text/data/map array dimensions*/
int *pval_i; /* for misc use */
float *pval_f; /* for misc use */
@@ -141,7 +141,7 @@
have_n = have_s = have_e = have_w = 0;
/* Check Endian State of File */
- fread(&format_block, sizeof(long), 1, fp1);
+ fread(&format_block, sizeof(int), 1, fp1);
fseek(fp1, 0, SEEK_SET); /* frewind() */
file_endianness = format_block / 1000; /* 0=little, 1=big */
@@ -163,7 +163,7 @@
while (!feof(fp1)) {
/* scan for needed array variables */
if(feof(fp1))
break;
@@ -181,19 +181,19 @@
/* 4 byte number of rows & columns */
- fread(&mrows, sizeof(long), 1, fp1);
- fread(&ncols, sizeof(long), 1, fp1);
+ fread(&mrows, sizeof(int), 1, fp1);
+ fread(&ncols, sizeof(int), 1, fp1);
if(mrows < 1 || ncols < 1)
G_fatal_error(_("Array contains no data"));
/* 4 byte real/imag flag 0=real vals only */
- fread(&realflag, sizeof(long), 1, fp1);
+ fread(&realflag, sizeof(int), 1, fp1);
if(realflag != 0)
G_fatal_error(_("Array contains imaginary data"));
/* length of array_name+1 */
- fread(&name_len, sizeof(long), 1, fp1);
+ fread(&name_len, sizeof(int), 1, fp1);
if(name_len < 1)
G_fatal_error(_("Invalid array name"));
@@ -205,11 +205,11 @@
G_debug(3, "array name = [%s]", array_name);
- G_debug(3, " format block = [%04ld]", format_block);
+ G_debug(3, " format block = [%04d]", format_block);
G_debug(3, " data format = [%d]", data_format);
G_debug(3, " data type = [%d]", data_type);
- G_debug(3, " rows = [%ld]", mrows);
- G_debug(3, " cols = [%ld]", ncols);
+ G_debug(3, " rows = [%d]", mrows);
+ G_debug(3, " cols = [%d]", ncols);
if(strcmp(array_name, "map_name") == 0) {
have_name = 1;
@@ -333,7 +333,7 @@
- G_debug(3, "Read array '%s' [%ld,%ld] format=%d type=%d\n",
+ G_debug(3, "Read array '%s' [%d,%d] format=%d type=%d\n",
array_name, ncols, mrows, data_format, data_type);
} /* while !EOF */
Modified: grass/trunk/raster/r.out.mat/main.c
--- grass/trunk/raster/r.out.mat/main.c 2008-04-04 09:08:19 UTC (rev 30858)
+++ grass/trunk/raster/r.out.mat/main.c 2008-04-04 13:32:10 UTC (rev 30859)
@@ -27,15 +27,15 @@
int endianness; /* 0=little, 1=big */
- long realflag = 0; /* 0=only real values used */
char array_name[32]; /* variable names must start with a letter (case
sensitive) followed by letters, numbers, or
underscores. 31 chars max. */
int name_len;
int val_i; /* for misc use */
float val_f; /* for misc use */
@@ -129,19 +129,19 @@
/* 4 byte data format */
format_block = endianness*1000 + data_format*10 + data_type;
- fwrite(&format_block, sizeof(long), 1, fp1);
+ fwrite(&format_block, sizeof(int), 1, fp1);
/* fprintf(stderr, "name data format is [%04ld]\n", format_block); */
- fwrite(&mrows, sizeof(long), 1, fp1);
- fwrite(&ncols, sizeof(long), 1, fp1);
+ fwrite(&mrows, sizeof(int), 1, fp1);
+ fwrite(&ncols, sizeof(int), 1, fp1);
- fwrite(&realflag, sizeof(long), 1, fp1);
+ fwrite(&realflag, sizeof(int), 1, fp1);
name_len = strlen(array_name) + 1;
- fwrite(&name_len, sizeof(long), 1, fp1);
+ fwrite(&name_len, sizeof(int), 1, fp1);
/* array name */
fprintf(fp1, "%s%c", array_name, '\0');
@@ -162,18 +162,18 @@
/* array name */
@@ -234,19 +234,19 @@
/* fprintf(stderr, "bounds data format is [%04ld]\n", format_block); */
/* 4 byte number of rows , 4 byte number of colums */
/* 4 byte real/imag flag 0=only real */
/* array name */
@@ -292,20 +292,20 @@
format_block = (endianness*1000) + (data_format*10) + data_type;
- G_debug(3, "map data format is [%04ld]\n", format_block);
+ G_debug(3, "map data format is [%04d]\n", format_block);
/* 4 byte number of rows & columns*/
/* array name */
