[GRASS-SVN] r30860 - grass/trunk/gui/wxpython/vdigit
Fri Apr 4 10:56:27 EDT 2008
Author: martinl
Date: 2008-04-04 10:56:26 -0400 (Fri, 04 Apr 2008)
New Revision: 30860
   grass/trunk/gui/wxpython/vdigit/digit.h
   grass/trunk/gui/wxpython/vdigit/line.cpp
   grass/trunk/gui/wxpython/vdigit/undo.cpp
wxGUI (vdigit): Undo functionality updated (very basic prototype)
Modified: grass/trunk/gui/wxpython/vdigit/digit.h
--- grass/trunk/gui/wxpython/vdigit/digit.h	2008-04-04 13:32:10 UTC (rev 30859)
+++ grass/trunk/gui/wxpython/vdigit/digit.h	2008-04-04 14:56:26 UTC (rev 30860)
@@ -34,6 +34,7 @@
     int AddActionToChangeset(int, action_type, int);
     int ApplyChangeset(int, bool);
     void FreeChangeset(int);
+    int RemoveActionFromChangeset(int, action_type, int);
 public:
     Digit(DisplayDriver *);
Modified: grass/trunk/gui/wxpython/vdigit/line.cpp
--- grass/trunk/gui/wxpython/vdigit/line.cpp	2008-04-04 13:32:10 UTC (rev 30859)
+++ grass/trunk/gui/wxpython/vdigit/line.cpp	2008-04-04 14:56:26 UTC (rev 30860)
@@ -525,40 +525,94 @@
 int Digit::MergeLines()
-    int ret;
+    int ret, changeset, line;
     if (!display->mapInfo) {
 	return -1;
+    /* register changeset */
+    changeset = changesets.size();
+    for (int i = 0; i < display->selected->n_values; i++) {
+	AddActionToChangeset(changeset, DELETE, display->selected->value[i]);
     ret = Vedit_merge_lines(display->mapInfo, display->selected);
+    if (ret > 0) {
+	/* update changeset */
+	    line = display->selected->value[i];
+	    if (Vect_line_alive(display->mapInfo, line)) {
+		RemoveActionFromChangeset(changeset, DELETE, line);
+	for(int i = 0; i < Vect_get_num_updated_lines(display->mapInfo); i++) {
+	    line = Vect_get_updated_line(display->mapInfo, i);
+	    AddActionToChangeset(changeset, ADD, line);
+    else {
+	changesets.erase(changeset);
     return ret;
    \brief Breaks selected lines/boundaries
+   \todo undo
    \return number of modified lines
    \return -1 on error
 int Digit::BreakLines()
-    int ret;
 	return -1;
     ret = Vect_break_lines_list(display->mapInfo, display->selected,
 				GV_LINES, NULL, NULL);
+    if (ret > 0) {
+    else {
     return ret;
    \brief Snap selected lines/boundaries
+   \todo undo
    \param thresh threshold value for snapping
    \return 0 on success
@@ -585,15 +639,37 @@
 int Digit::ConnectLines(double thresh)
-    int ret;
+    int ret, changeset;
+    long int nlines_diff;
 	return -1;
+    if (display->selected->n_values != 2)
+	return 0;
+    nlines_diff = Vect_get_num_lines(display->mapInfo);
     ret = Vedit_connect_lines(display->mapInfo, display->selected,
 			      thresh);
+    if (ret == 1) {
+	nlines_diff = Vect_get_num_lines(display->mapInfo) - nlines_diff;
+	for(int i = Vect_get_num_lines(display->mapInfo); i > nlines_diff; i--) {
+	    AddActionToChangeset(changeset, ADD, i);
+    else {
     return ret;
@@ -602,6 +678,8 @@
    Modified vector map must be 3D.
+   \todo Undo
    \param x1,y1,x2,y2 line nodes for intersection
    \param start starting value
    \param step  step value for labeling
@@ -752,12 +830,34 @@
 int Digit::TypeConvLines()
+    int ret;
+    int npoints, nlines, ncentroids, nboundaries;
+    int changeset, nlines_diff;
 	return -1;
-    int npoints, nlines, ncentroids, nboundaries;
-    return Vedit_chtype_lines (display->mapInfo, display->selected,
+    ret = Vedit_chtype_lines (display->mapInfo, display->selected,
 			       &npoints, &ncentroids,
 			       &nlines, &nboundaries);
+    if(ret > 0) {
+    else {
+    return ret;
Modified: grass/trunk/gui/wxpython/vdigit/undo.cpp
--- grass/trunk/gui/wxpython/vdigit/undo.cpp	2008-04-04 13:32:10 UTC (rev 30859)
+++ grass/trunk/gui/wxpython/vdigit/undo.cpp	2008-04-04 14:56:26 UTC (rev 30860)
@@ -201,3 +201,30 @@
     return;
+   \brief Remove action from changeset
+   \param changeset changeset id
+   \param type action type (ADD, DELETE, REWRITE)
+   \param line line id
+   \return number of actions in changeset
+   \return -1 on error
+int Digit::RemoveActionFromChangeset(int changeset, Digit::action_type type, int line)
+    if (changesets.find(changeset) == changesets.end())
+	return -1;
+    std::vector<action_meta>& action = changesets[changeset];
+    for (std::vector<action_meta>::iterator i = action.begin(); i != action.end(); ++i) {
+	if ((*i).type == type && (*i).line == line) {
+	    G_debug (3, "Digit.RemoveActionFromChangeset(): changeset=%d, type=%d, line=%d",
+		     changeset, type, line);
+	    action.erase(i--);
+    return action.size();
