[GRASS-SVN] r30865 - grass/branches/releasebranch_6_3/scripts/v.report
Fri Apr 4 22:48:36 EDT 2008
Author: hamish
Date: 2008-04-04 22:48:35 -0400 (Fri, 04 Apr 2008)
New Revision: 30865
   grass/branches/releasebranch_6_3/scripts/v.report/v.report
don't quote var which could be empty. thanks for spotting this Maciek (merge from HEAD)
Modified: grass/branches/releasebranch_6_3/scripts/v.report/v.report
--- grass/branches/releasebranch_6_3/scripts/v.report/v.report	2008-04-05 02:46:16 UTC (rev 30864)
+++ grass/branches/releasebranch_6_3/scripts/v.report/v.report	2008-04-05 02:48:35 UTC (rev 30865)
@@ -150,7 +150,7 @@
       exit 1
    fi
    #fetch the requested attribute sorted by cat:
-   v.to.db -p map="$MAP" opt="$OPTION" col="$COLUMS" "$UNITSPARAM" \
+   v.to.db -p map="$MAP" opt="$OPTION" col="$COLUMS" $UNITSPARAM \
 	   layer="$LAYER" 2> /dev/null | grep -v '^cat' | grep -v '^-1' | grep -v '^0'\
 	   | sort -n -t'|' -k 1 | cut -d'|' -f2-4 > "$TMP2"
    #make pre-table
@@ -159,7 +159,7 @@
     v.category input="$MAP" layer="$LAYER" option=print | sort -n | uniq | \
         grep -v '^-1' | grep -v '^0' > "$TMP1"
     #make pre-table
 	   | sort -n -t'|' -k 1 > "$TMP3"
