[GRASS-SVN] r30866 - grass/trunk/raster/r.in.mat
svn_grass at osgeo.org
Sat Apr 5 10:35:19 EDT 2008
Author: hamish
Date: 2008-04-05 10:35:18 -0400 (Sat, 05 Apr 2008)
New Revision: 30866
grass/trunk/raster/r.in.mat/main.c
undo damage done since last I visited this code (repair lost map name logic, add back diag messages, fid was used as %s, ...)
Modified: grass/trunk/raster/r.in.mat/main.c
--- grass/trunk/raster/r.in.mat/main.c 2008-04-05 02:48:35 UTC (rev 30865)
+++ grass/trunk/raster/r.in.mat/main.c 2008-04-05 14:35:18 UTC (rev 30866)
@@ -77,10 +77,7 @@
struct History history;
struct Option *inputfile, *outputfile;
- /* please, remove before GRASS 7 released */
- struct Flag *verbose;
+ struct Flag *verbose; /* remove for GRASS 7 */
struct GModule *module;
int cf;
@@ -106,7 +103,7 @@
outputfile = G_define_option() ;
outputfile->key = "output";
outputfile->type = TYPE_STRING;
- outputfile->required = YES;
+ outputfile->required = NO;
outputfile->gisprompt = "new,cell,raster" ;
outputfile->description= _("Name for the output raster map (override)");
@@ -120,6 +117,10 @@
exit(EXIT_FAILURE);
+ /* remove for GRASS 7 */
+ if(verbose->answer)
+ G_warning(_("The '-v' flag is superseded and will be removed "
+ "in future. Please use '--verbose' instead."));
/****** SETUP ****************************************************/
/* Check Endian State of Host Computer*/
@@ -158,7 +159,7 @@
/****** READ MAP ****************************************************/
- G_message(_("Reading MAT-File..."));
+ G_verbose_message(_("Reading MAT-File..."));
while (!feof(fp1)) {
@@ -314,7 +315,7 @@
} /* endif map_data */
else {
- G_warning(_("Skipping unknown array '%s'"), array_name);
+ G_important_message(_("Skipping unknown array '%s'"), array_name);
switch (data_format) {
/* 0=double 1=float 2=32bit signed int 5=8bit unsigned int(text) */
case 0:
@@ -345,8 +346,25 @@
/* set map name */
- strncpy(map_name, outfile, 61);
+ if(have_name) {
+ if(outfile) {
+ if( 0 != strcmp(outfile, map_name) )
+ G_message(_("Setting map name to <%s> which overrides <%s>"),
+ outfile, map_name);
+ strncpy(map_name, outfile, 61);
+ else {
+ if(outfile) {
+ G_verbose_message(_("Setting map name to <%s>"), outfile);
+ else {
+ G_message(_("No 'map_name' array found; using <MatFile>"));
+ strcpy(map_name, "MatFile");
G_strip(map_name); /* remove leading and trailing whitespace */
if(G_legal_filename(map_name) != 1)
G_fatal_error(_("<%s> is an illegal file name"), map_name);
@@ -373,20 +391,26 @@
if(buff) G_fatal_error(buff);
G_set_window(®ion);
- if(verbose->answer)
- G_warning(_("The '-v' flag is superseded and will be removed "
- "in future. Please use '--verbose' instead."));
+ G_verbose_message("\nMap <%s> bounds set to:", map_name);
+ G_verbose_message("northern edge=%f", region.north);
+ G_verbose_message("southern edge=%f", region.south);
+ G_verbose_message("eastern edge=%f", region.east);
+ G_verbose_message("western edge=%f", region.west);
+ G_verbose_message("nsres=%f", region.ns_res);
+ G_verbose_message("ewres=%f", region.ew_res);
+ G_verbose_message("rows=%d", region.rows);
+ G_verbose_message("cols=%d", region.cols);
+ G_verbose_message("");
/* prep memory */
- raster = G_allocate_raster_buf(map_type);
+ raster = G_allocate_raster_buf(map_type);
cf = G_open_raster_new(map_name, map_type);
if (cf < 0)
- G_fatal_error (_("Unable to create raster map <%s>"), outfile);
+ G_fatal_error(_("Unable to create raster map <%s>"), outfile);
/* write new raster map*/
- G_message(_("Writing new raster map..."));
+ G_verbose_message(_("Writing new raster map..."));
mrows = region.rows;
ncols = region.cols;
@@ -436,7 +460,7 @@
if( 1 != G_put_raster_row(cf, raster, map_type) ) {
G_close_cell(cf);
- G_fatal_error(_("Failed writing raster map <%s> row %d"), raster, row);
+ G_fatal_error(_("Writing raster map, row %d"), row);
G_percent(row, mrows, 5);
@@ -459,7 +483,9 @@
G_command_history(&history);
G_write_history(map_name, &history);
- return 0;
+ G_done_msg("");
+ exit(EXIT_SUCCESS);
