[GRASS-SVN] r30898 - in grass/trunk/gui/wxpython: . gui_modules
svn_grass at osgeo.org
Mon Apr 7 16:07:19 EDT 2008
Author: martinl
Date: 2008-04-07 16:07:19 -0400 (Mon, 07 Apr 2008)
New Revision: 30898
grass/trunk/gui/wxpython/gui_modules/gdialogs.py
grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
grass/trunk/gui/wxpython/wxgui.py
wxGUI (gdialogs): LoadMapLayersDialog moved from wxgui_utils to gdialog module.
Simple map name filter implemented (matching ^[string]).
Modified: grass/trunk/gui/wxpython/gui_modules/gdialogs.py
--- grass/trunk/gui/wxpython/gui_modules/gdialogs.py 2008-04-07 14:10:12 UTC (rev 30897)
+++ grass/trunk/gui/wxpython/gui_modules/gdialogs.py 2008-04-07 20:07:19 UTC (rev 30898)
@@ -8,6 +8,7 @@
- SavedRegion
- DecorationDialog
- TextLayerDialog
+ - LoadMapLayersDialog
(C) 2008 by the GRASS Development Team
@@ -19,6 +20,7 @@
import sys
+import re
import wx
@@ -478,3 +480,201 @@
"""Get text properties"""
return (self.currText, self.currFont,
self.currClr, self.currRot)
+class LoadMapLayersDialog(wx.Dialog):
+ """Load selected map layers (raster, vector) into layer tree"""
+ def __init__(self, parent, title, style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
+ wx.Dialog.__init__(self, parent=parent, id=wx.ID_ANY, title=title, style=style)
+ self.parent = parent # GMFrame
+ # dialog body
+ self.bodySizer = self.__createDialogBody()
+ # update list of layer to be loaded
+ self.map_layers = [] # list of map layers (full list type/mapset)
+ self.LoadMapLayers(self.layerType.GetStringSelection()[:4],
+ self.mapset.GetStringSelection())
+ # buttons
+ btnCancel = wx.Button(self, wx.ID_CANCEL)
+ btnOk = wx.Button(self, wx.ID_OK, _("Load") )
+ btnOk.SetDefault()
+ # bindigs
+ #btnOk.Bind(wx.EVT_BUTTON, self.OnOK)
+ #btnCancel.Bind(wx.EVT_BUTTON, self.OnCancel)
+ # sizers & do layout
+ btnSizer = wx.StdDialogButtonSizer()
+ btnSizer.AddButton(btnCancel)
+ btnSizer.AddButton(btnOk)
+ btnSizer.Realize()
+ mainSizer = wx.BoxSizer(wx.VERTICAL)
+ mainSizer.Add(item=self.bodySizer, proportion=1,
+ flag=wx.EXPAND | wx.ALL, border=5)
+ mainSizer.Add(item=btnSizer, proportion=0,
+ flag=wx.EXPAND | wx.ALL | wx.ALIGN_CENTER, border=5)
+ self.SetSizer(mainSizer)
+ mainSizer.Fit(self)
+ # set dialog min size
+ self.SetMinSize(self.GetSize())
+ def __createDialogBody(self):
+ bodySizer = wx.GridBagSizer(vgap=3, hgap=3)
+ bodySizer.AddGrowableCol(1)
+ bodySizer.AddGrowableRow(3)
+ # layer type
+ bodySizer.Add(item=wx.StaticText(parent=self, label=_("Map layer type:")),
+ flag=wx.ALIGN_CENTER_VERTICAL,
+ pos=(0,0))
+ self.layerType = wx.Choice(parent=self, id=wx.ID_ANY,
+ choices=['raster', 'vector'], size=(100,-1))
+ self.layerType.SetSelection(0)
+ bodySizer.Add(item=self.layerType,
+ pos=(0,1))
+ # mapset filter
+ bodySizer.Add(item=wx.StaticText(parent=self, label=_("Mapset:")),
+ pos=(1,0))
+ self.mapset = wx.ComboBox(parent=self, id=wx.ID_ANY,
+ style=wx.CB_SIMPLE | wx.CB_READONLY,
+ choices=UserSettings.Get(group='general', key='mapsetPath', subkey='value', internal=True),
+ size=(250,-1))
+ self.mapset.SetStringSelection(grassenv.GetGRASSVariable("MAPSET"))
+ bodySizer.Add(item=self.mapset,
+ pos=(1,1))
+ # map name filter
+ bodySizer.Add(item=wx.StaticText(parent=self, label=_("Filter:")),
+ pos=(2,0))
+ self.filter = wx.TextCtrl(parent=self, id=wx.ID_ANY,
+ value="",
+ size=(250,-1))
+ bodySizer.Add(item=self.filter,
+ flag=wx.EXPAND,
+ pos=(2,1))
+ # layer list
+ bodySizer.Add(item=wx.StaticText(parent=self, label=_("List of maps:")),
+ flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_TOP,
+ pos=(3,0))
+ self.layers = wx.CheckListBox(parent=self, id=wx.ID_ANY,
+ size=(250, 100),
+ choices=[])
+ bodySizer.Add(item=self.layers,
+ flag=wx.EXPAND,
+ pos=(3,1))
+ # bindings
+ self.layerType.Bind(wx.EVT_CHOICE, self.OnChangeParams)
+ self.mapset.Bind(wx.EVT_COMBOBOX, self.OnChangeParams)
+ self.layers.Bind(wx.EVT_RIGHT_DOWN, self.OnMenu)
+ self.filter.Bind(wx.EVT_TEXT, self.OnFilter)
+ return bodySizer
+ def LoadMapLayers(self, type, mapset):
+ """Load list of map layers
+ @param type layer type ('raster' or 'vector')
+ @param mapset mapset name
+ list = gcmd.Command(['g.mlist',
+ 'type=%s' % type,
+ 'mapset=%s' % mapset])
+ for map in list.ReadStdOutput():
+ self.map_layers.append(map)
+ self.layers.Set(self.map_layers)
+ # check all items by default
+ for item in range(self.layers.GetCount()):
+ self.layers.Check(item)
+ def OnChangeParams(self, event):
+ """Filter parameters changed by user"""
+ event.Skip()
+ def OnMenu(self, event):
+ """Table description area, context menu"""
+ if not hasattr(self, "popupID1"):
+ self.popupDataID1 = wx.NewId()
+ self.popupDataID2 = wx.NewId()
+ self.Bind(wx.EVT_MENU, self.OnSelectAll, id=self.popupDataID1)
+ self.Bind(wx.EVT_MENU, self.OnDeselectAll, id=self.popupDataID2)
+ # generate popup-menu
+ menu = wx.Menu()
+ menu.Append(self.popupDataID1, _("Select all"))
+ menu.Append(self.popupDataID2, _("Deselect all"))
+ self.PopupMenu(menu)
+ menu.Destroy()
+ def OnSelectAll(self, event):
+ """Select all map layer from list"""
+ self.layers.Check(item, True)
+ def OnDeselectAll(self, event):
+ self.layers.Check(item, False)
+ def OnFilter(self, event):
+ """Apply filter for map names"""
+ if len(event.GetString()) == 0:
+ return
+ list = []
+ for layer in self.map_layers:
+ if re.compile('^' + event.GetString()).search(layer):
+ list.append(layer)
+ self.layers.Set(list)
+ event.Skip()
+ def GetMapLayers(self):
+ """Return list of checked map layers"""
+ layerNames = []
+ for indx in self.layers.GetSelections():
+ # layers.append(self.layers.GetStringSelec(indx))
+ pass
+ # return fully qualified map names
+ mapset = self.mapset.GetStringSelection()
+ if not self.layers.IsChecked(item):
+ continue
+ layerNames.append(self.layers.GetString(item) + '@' + mapset)
+ return layerNames
+ def GetLayerType(self):
+ """Get selected layer type"""
+ return self.layerType.GetStringSelection()
Modified: grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-04-07 14:10:12 UTC (rev 30897)
+++ grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-04-07 20:07:19 UTC (rev 30898)
@@ -5,7 +5,6 @@
* AbstractLayer
* Layer
* LayerTree
- * LoadMapLayersDialog
PURPOSE: Utility classes for GRASS wxPython GUI. Main functions include tree control
for GIS map layer management, command console, and command parsing.
@@ -1096,173 +1095,3 @@
item = self.GetNextSibling(item)
return None
-class LoadMapLayersDialog(wx.Dialog):
- """Load selected map layers (raster, vector) into layer tree"""
- def __init__(self, parent, title, style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
- wx.Dialog.__init__(self, parent=parent, id=wx.ID_ANY, title=title, style=style)
- self.parent = parent # GMFrame
- # dialog body
- self.bodySizer = self.__createDialogBody()
- # update list of layer to be loaded
- self.LoadMapLayers(self.layerType.GetStringSelection()[:4],
- self.mapset.GetStringSelection())
- # buttons
- btnCancel = wx.Button(self, wx.ID_CANCEL)
- btnOk = wx.Button(self, wx.ID_OK, _("Load") )
- btnOk.SetDefault()
- # bindigs
- #btnOk.Bind(wx.EVT_BUTTON, self.OnOK)
- #btnCancel.Bind(wx.EVT_BUTTON, self.OnCancel)
- # sizers & do layout
- btnSizer = wx.StdDialogButtonSizer()
- btnSizer.AddButton(btnCancel)
- btnSizer.AddButton(btnOk)
- btnSizer.Realize()
- mainSizer = wx.BoxSizer(wx.VERTICAL)
- mainSizer.Add(item=self.bodySizer, proportion=1,
- flag=wx.EXPAND | wx.ALL, border=5)
- mainSizer.Add(item=btnSizer, proportion=0,
- flag=wx.EXPAND | wx.ALL | wx.ALIGN_CENTER, border=5)
- self.SetSizer(mainSizer)
- mainSizer.Fit(self)
- # set dialog min size
- self.SetMinSize(self.GetSize())
- def __createDialogBody(self):
- bodySizer = wx.GridBagSizer(vgap=3, hgap=3)
- bodySizer.AddGrowableCol(1)
- bodySizer.AddGrowableRow(2)
- # layer type
- bodySizer.Add(item=wx.StaticText(parent=self, label=_("Map layer type:")),
- flag=wx.ALIGN_CENTER_VERTICAL,
- pos=(0,0))
- self.layerType = wx.Choice(parent=self, id=wx.ID_ANY,
- choices=['raster', 'vector'], size=(200,-1))
- self.layerType.SetSelection(0)
- bodySizer.Add(item=self.layerType,
- pos=(0,1))
- # mapset filter
- bodySizer.Add(item=wx.StaticText(parent=self, label=_("Mapset:")),
- pos=(1,0))
- self.mapset = wx.ComboBox(parent=self, id=wx.ID_ANY,
- style=wx.CB_SIMPLE | wx.CB_READONLY,
- choices=UserSettings.Get(group='general', key='mapsetPath', subkey='value', internal=True),
- size=(200,-1))
- self.mapset.SetStringSelection(grassenv.GetGRASSVariable("MAPSET"))
- bodySizer.Add(item=self.mapset,
- pos=(1,1))
- # layer list
- bodySizer.Add(item=wx.StaticText(parent=self, label=_("List of maps:")),
- flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_TOP,
- pos=(2,0))
- self.layers = wx.CheckListBox(parent=self, id=wx.ID_ANY,
- size=(250, 100),
- choices=[])
- bodySizer.Add(item=self.layers,
- flag=wx.EXPAND,
- pos=(2,1))
- # bindings
- self.layerType.Bind(wx.EVT_CHOICE, self.OnChangeParams)
- self.mapset.Bind(wx.EVT_COMBOBOX, self.OnChangeParams)
- self.layers.Bind(wx.EVT_RIGHT_DOWN, self.OnMenu)
- return bodySizer
- def LoadMapLayers(self, type, mapset):
- """Load list of map layers
- @param type layer type ('raster' or 'vector')
- @param mapset mapset name
- list = gcmd.Command(['g.mlist',
- 'type=%s' % type,
- 'mapset=%s' % mapset])
- maps = []
- for map in list.ReadStdOutput():
- maps.append(map)
- self.layers.Set(maps)
- # check all items by default
- for item in range(self.layers.GetCount()):
- self.layers.Check(item)
- def OnChangeParams(self, event):
- """Filter parameters changed by user"""
- event.Skip()
- def OnMenu(self, event):
- """Table description area, context menu"""
- if not hasattr(self, "popupID1"):
- self.popupDataID1 = wx.NewId()
- self.popupDataID2 = wx.NewId()
- self.Bind(wx.EVT_MENU, self.OnSelectAll, id=self.popupDataID1)
- self.Bind(wx.EVT_MENU, self.OnDeselectAll, id=self.popupDataID2)
- # generate popup-menu
- menu = wx.Menu()
- menu.Append(self.popupDataID1, _("Select all"))
- menu.Append(self.popupDataID2, _("Deselect all"))
- self.PopupMenu(menu)
- menu.Destroy()
- def OnSelectAll(self, event):
- """Select all map layer from list"""
- self.layers.Check(item, True)
- def OnDeselectAll(self, event):
- self.layers.Check(item, False)
- def GetMapLayers(self):
- """Return list of checked map layers"""
- layerNames = []
- for indx in self.layers.GetSelections():
- # layers.append(self.layers.GetStringSelec(indx))
- pass
- # return fully qualified map names
- mapset = self.mapset.GetStringSelection()
- if not self.layers.IsChecked(item):
- continue
- layerNames.append(self.layers.GetString(item) + '@' + mapset)
- return layerNames
- def GetLayerType(self):
- """Get selected layer type"""
- return self.layerType.GetStringSelection()
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2008-04-07 14:10:12 UTC (rev 30897)
+++ grass/trunk/gui/wxpython/wxgui.py 2008-04-07 20:07:19 UTC (rev 30898)
@@ -634,7 +634,7 @@
def OnWorkspaceLoad(self, event=None):
"""Load given map layers into layer tree"""
- dialog = wxgui_utils.LoadMapLayersDialog(parent=self, title=_("Load map layers into layer tree"))
+ dialog = gdialogs.LoadMapLayersDialog(parent=self, title=_("Load map layers into layer tree"))
if dialog.ShowModal() == wx.ID_OK:
# start new map display if no display is available
