[GRASS-SVN] r30899 - in grass-addons/gipe: . r.out.vic
Mon Apr 7 23:38:31 EDT 2008
Author: ychemin
Date: 2008-04-07 23:38:31 -0400 (Mon, 07 Apr 2008)
New Revision: 30899
Added:
   grass-addons/gipe/r.out.vic/
   grass-addons/gipe/r.out.vic/Makefile
   grass-addons/gipe/r.out.vic/description.html
   grass-addons/gipe/r.out.vic/main.c
   grass-addons/gipe/r.out.vic/veg_lib.c
Removed:
   grass-addons/gipe/r.out.vic_mask/
   grass-addons/gipe/r.out.vic_met/
   grass-addons/gipe/r.out.vic_veg/
Merged all vic modules in one
Added: grass-addons/gipe/r.out.vic/Makefile
--- grass-addons/gipe/r.out.vic/Makefile	                        (rev 0)
+++ grass-addons/gipe/r.out.vic/Makefile	2008-04-08 03:38:31 UTC (rev 30899)
@@ -0,0 +1,15 @@
+MODULE_TOPDIR = ../..
+PGM = r.out.vic_met
+LIBES =  $(GPROJLIB) $(GISLIB)
+DEPENDENCIES = $(GPROJDEP) $(GISDEP)
+EXTRA_INC = $(PROJINC)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+ifneq ($(USE_LARGEFILES),)
+	EXTRA_CFLAGS = -D_FILE_OFFSET_BITS=64
+endif
+default: cmd
Added: grass-addons/gipe/r.out.vic/description.html
--- grass-addons/gipe/r.out.vic/description.html	                        (rev 0)
+++ grass-addons/gipe/r.out.vic/description.html	2008-04-08 03:38:31 UTC (rev 30899)
@@ -0,0 +1,42 @@
+<H2>DESCRIPTION</H2>
+<EM>r.out.vic</EM> creates a set of VIC hydrological model meteorological input ascii files.
+1 - Meteorological: Three time series of GIS data are needed: Precipitation (mm/d), Tmax(C) and Tmin(C).
+Files are $prefix_latitude_longitude.
+Format is:
+"%.2f  %.2f  %.2f\n"
+with:
+double precipitation
+double Tmax
+double Tmin
+This is an input to VIC (Variable Infiltration Capacity) in forcing/ of TEST example.
+2 - Vegetation: Filling only Land cover class, with only one class, and one standard root system. Option to add monthly LAI (12 maps).
+3 - Soil: Barely complete, it takes elevation data and lat/long, the rest is filled up with dummy soil data.
+<H2>NOTES</H2>
+<H2>TODO</H2>
+Soil files input creation is incomplete, a lot to do here.
+<H2>SEE ALSO</H2>
+<em>
+</em>
+<H2>AUTHORS</H2>
+Yann Chemin<BR>
+<p>
+<i>Last changed: $Date: 2008/03/23 09:39:55 $</i>
Added: grass-addons/gipe/r.out.vic/main.c
--- grass-addons/gipe/r.out.vic/main.c	                        (rev 0)
+++ grass-addons/gipe/r.out.vic/main.c	2008-04-08 03:38:31 UTC (rev 30899)
@@ -0,0 +1,574 @@
+ * MODULE:       r.out.vic
+ * AUTHOR(S):    Yann Chemin - yann.chemin at gmail.com
+ * PURPOSE:      Creates VIC input files:
+ * 		 1 - Meteorological:
+ * 			Three time series of GIS data are needed:
+ * 		 	Precipitation (mm/d), Tmax(C) and Tmin(C)
+ * 		 2 - Vegetation:
+ * 		 	Filling only Land cover class, with only one class,
+ * 			 and one standard root system.
+ * 			 Option to add monthly LAI (12 maps).
+ * 		 3 - Soil:
+ *		 	Barely complete, it takes elevation data & lat/long,
+ *		 	the rest is filled up with dummy soil data.
+ * COPYRIGHT:    (C) 2008 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *   	    	 License (>=v2). Read the file COPYING that comes with GRASS
+ *   	    	 for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/gprojects.h>
+#include <grass/glocale.h>
+/* daily one year is: 	*/
+#define MAXFILES 366
+/* for vegeation: 	*/
+int veglib(char *filename);
+int main(int argc, char *argv[])
+	struct Cell_head cellhd; //region+header info
+	char *mapset; // mapset name
+	int nrows, ncols;
+	int row,col;
+	int not_ll=0;//if proj is not lat/long, it will be 1.
+	struct GModule *module;
+	struct Option *input1, *input2, *input3, *input4;
+	struct Option *input5, *input6;
+	struct Option *output1, *output2, *output3, *output4;
+	struct Flag *flag1;
+	struct History history; //metadata
+	struct pj_info iproj;
+	struct pj_info oproj;
+	/* FMEO Declarations*****************/
+	char 	*prcp_name;// input first time-series raster files names
+	char 	*tmax_name;// input second time_series raster files names
+	char 	*tmin_name;// input third time_series raster files names
+	char 	*landcover_name;// input raster name
+	char 	lai_name[12]; 	// input monthly raster files name
+	char 	*result1; 	//output file base name
+	char 	*result2; 	//output Soil file name
+	char	*result3; 	//output Veg file name
+	char 	result_lat_long[50]; 	//output file name
+	//File Descriptors
+	int 	infd_prcp[MAXFILES], infd_tmax[MAXFILES], infd_tmin[MAXFILES];
+	int	infd;
+	int 	infd_landcover, infd_lai[12];
+	int 	i=0,j=0;
+	double 	xp, yp;
+	double 	xmin, ymin;
+	double 	xmax, ymax;
+	double 	stepx,stepy;
+	double 	latitude, longitude;
+	void 			*inrast_prcp[MAXFILES];
+	void 			*inrast_tmax[MAXFILES];
+	void 			*inrast_tmin[MAXFILES];
+	void 			*inrast_elevation;
+	void 			*inrast_landcover;
+	void 			*inrast_lai[12];
+	RASTER_MAP_TYPE 	data_type_inrast_prcp[MAXFILES];
+	RASTER_MAP_TYPE 	data_type_inrast_tmax[MAXFILES];
+	RASTER_MAP_TYPE 	data_type_inrast_tmin[MAXFILES];
+	RASTER_MAP_TYPE 	data_type_inrast_elevation;
+	RASTER_MAP_TYPE 	data_type_inrast_landcover;
+	RASTER_MAP_TYPE 	data_type_inrast_lai[12];
+	/* Meteorological maps 			*/
+	FILE	*f; 		// output ascii file
+	int 	grid_count; 	// grid cell count
+	double	prcp[MAXFILES];	// Precipitation data
+	double	tmax[MAXFILES];	// Tmax data
+	double	tmin[MAXFILES];	// Tmin data
+	char 	**prcp_ptr;	// pointer to get the input1->answers
+	char 	**tmax_ptr;	// pointer to get the input2->answers
+	char 	**tmin_ptr;	// pointer to get the input3->answers
+	int	nfiles1, nfiles2, nfiles3, nfiles_shortest;// count no. input files
+	char	**test1, **test2, **test3; // test number of input files
+	char	**ptr1, **ptr2, **ptr3;	// test number of input files
+	/* Elevation map 			*/
+	char	*in;
+	FILE	*g; 		// output soil ascii file
+	int 	process; 	// process grid cell switch
+	char 	*dummy_data1; 	// dummy data part 1
+	char 	*dummy_data2; 	// dummy data part 2
+	double	elevation;	// average evevation of grid cell
+	/* Vegetation map 			*/
+	FILE	*h; 		// output ascii file
+	char 	*dummy_data3; 	// dummy data part 1
+	char 	*dummy_data4; 	// dummy data part 2
+	double	*lai[12];	// lAI data for each month
+	char 	**lai_ptr;	// pointer to get the input2->answers
+	int	nfiles; 	// count LAI input files
+	char	**test, **ptr;	// test number of LAI input files
+	G_gisinit(argv[0]);
+	module = G_define_module();
+	module->keywords = _("VIC, hydrology, precipitation, Tmax, Tmin, soil");
+	module->description = _("creates a meteorological ascii file for each non-null cell from 3 time series maps: precipitation, Tmax and Tmin. Also creates a dummy soil file from elevation.");
+	/* Define the different options */
+	input1 = G_define_standard_option(G_OPT_R_INPUT) ;
+	input1->key	   = _("prcp");
+	input1->multiple   = YES;
+	input1->description=_("Names of the precipitation input maps");
+	input2 = G_define_standard_option(G_OPT_R_INPUT) ;
+	input2->key	   = _("tmax");
+	input2->multiple   = YES;
+	input2->description=_("Names of the Tmax input maps");
+	input3 = G_define_standard_option(G_OPT_R_INPUT) ;
+	input3->key	   = _("tmin");
+	input3->multiple   = YES;
+	input3->description=_("Names of the Tmin input maps");
+	input4 = G_define_standard_option(G_OPT_R_INPUT) ;
+	input4->key	   = _("dem");
+	input4->description=_("Name of the elevation input map");
+	input5 = G_define_standard_option(G_OPT_R_INPUT) ;
+	input5->key	   = _("landcover");
+	input5->description=_("Name of the land cover input map");
+	input6 = G_define_standard_option(G_OPT_R_INPUT) ;
+	input6->key	   = _("LAI");
+	input6->multiple   = YES;
+	input6->required   = NO;
+	input6->description=_("Name of the LAI input maps (12 of them!)");
+	output1 = G_define_option();
+	output1->key      	=_("output");
+	output1->description	=_("Base Name of the output vic meteorological ascii files");
+	output1->answer     	=_("data_");
+	output2 = G_define_option() ;
+	output2->key        =_("output_soil");
+	output2->description=_("Name of the output vic soil ascii file");
+	output2->answer     =_("vic_soil.asc");
+	output3 = G_define_option() ;
+	output3->key        =_("output");
+	output3->description=_("Name of the output vic vegetation ascii file");
+	output3->answer     =_("vic_veg.asc");
+	output4 = G_define_option() ;
+	output4->key        =_("veglib");
+	output4->required   = NO;
+	output4->description=_("Name of a standard vegetation library file");
+	output4->answer     =_("veglib");
+	flag1 = G_define_flag() ;
+	flag1->key		= 'a';
+	flag1->description	=_("append meteorological data if file already exists (useful if adding additional year of data)");
+	if (G_parser(argc, argv))
+		exit (EXIT_FAILURE);
+	in			= input4->answer;
+	landcover_name	 	= input5->answer;
+	result1 		= output1->answer;
+	result2 		= output2->answer;
+	result3 	 	= output3->answer;
+	/* STANDARD VEGLIB CREATION HERE 		*/
+	if(output4->answer)
+		veglib(output4->answer);
+	/* LOADING TMAX TIME SERIES MAPS 		*/
+	test1 = input1->answers;
+	for (ptr1 = test1, nfiles1 = 0; *ptr1 != NULL; ptr1++, nfiles1++)
+	if (nfiles1 > MAXFILES){
+		G_fatal_error(_("Too many inputs1, change MAXFILES, recompile."));
+	prcp_ptr = input1->answers;
+	i=0;
+	for(; *prcp_ptr != NULL; prcp_ptr++){
+		prcp_name= *prcp_ptr;
+		mapset = G_find_cell2(prcp_name, "");
+		if (mapset == NULL)
+			G_fatal_error(_("cell file [%s] not found"), prcp_name);
+		data_type_inrast_prcp[i] = G_raster_map_type(prcp_name,mapset);
+		if ((infd_prcp[i] = G_open_cell_old (prcp_name,mapset)) < 0)
+			G_fatal_error (_("Cannot open cell file [%s]"), prcp_name);
+		if (G_get_cellhd (prcp_name, mapset, &cellhd) < 0)
+			G_fatal_error (_("Cannot read file header of [%s])"), prcp_name);
+		inrast_prcp[i] = G_allocate_raster_buf(data_type_inrast_prcp[i]);
+		i++;
+	nfiles1=i;
+	test2 = input2->answers;
+	for (ptr2 = test2, nfiles2 = 0; *ptr2 != NULL; ptr2++, nfiles2++)
+	if (nfiles2 > MAXFILES){
+		G_fatal_error(_("Too many inputs2, change MAXFILES, recompile."));
+	tmax_ptr = input2->answers;
+	i=0;
+	for(; *tmax_ptr != NULL; tmax_ptr++){
+		tmax_name = *tmax_ptr;
+		mapset = G_find_cell2(tmax_name, "");
+			G_fatal_error(_("cell file [%s] not found"), tmax_name);
+		data_type_inrast_tmax[i] = G_raster_map_type(tmax_name,mapset);
+		if ((infd_tmax[i] = G_open_cell_old (tmax_name,mapset)) < 0)
+			G_fatal_error (_("Cannot open cell file [%s]"),tmax_name);
+		if (G_get_cellhd (tmax_name, mapset, &cellhd) < 0)
+			G_fatal_error (_("Cannot read file header of [%s])"), tmax_name);
+		inrast_tmax[i] = G_allocate_raster_buf(data_type_inrast_tmax[i]);
+		i++;
+	nfiles2=i;
+	/* LOADING TMIN TIME SERIES MAPS 		*/
+	test3 = input3->answers;
+	for (ptr3 = test3, nfiles3 = 0; *ptr3 != NULL; ptr3++, nfiles3++)
+	if (nfiles3 > MAXFILES){
+		G_fatal_error(_("Too many inputs3, change MAXFILES, recompile."));
+	tmin_ptr = input3->answers;
+	i=0;
+	for(; *tmin_ptr != NULL; tmin_ptr++){
+		tmin_name = *tmin_ptr;
+		mapset = G_find_cell2(tmin_name, "");
+			G_fatal_error(_("cell file [%s] not found"), tmin_name);
+		data_type_inrast_tmin[i] = G_raster_map_type(tmin_name,mapset);
+		if ((infd_tmin[i] = G_open_cell_old (tmin_name,mapset)) < 0)
+			G_fatal_error (_("Cannot open cell file [%s]"), tmin_name);
+		if (G_get_cellhd (tmin_name, mapset, &cellhd) < 0)
+			G_fatal_error (_("Cannot read file header of [%s])"), tmin_name);
+		inrast_tmin[i] = G_allocate_raster_buf(data_type_inrast_tmin[i]);
+		i++;
+	nfiles3=i;
+	if(nfiles1<=nfiles2||nfiles1<=nfiles3){
+		nfiles_shortest = nfiles1;
+	} else if (nfiles2<=nfiles1||nfiles2<=nfiles3){
+		nfiles_shortest = nfiles2;
+	} else {
+		nfiles_shortest = nfiles3;
+	/* Load Elevation file				*/
+	mapset = G_find_cell2(in, "");
+	if (mapset == NULL) {
+		G_fatal_error(_("cell file [%s] not found"), in);
+	data_type_inrast_elevation = G_raster_map_type(in,mapset);
+	if ( (infd = G_open_cell_old (in,mapset)) < 0)
+		G_fatal_error (_("Cannot open cell file [%s]"), in);
+	if (G_get_cellhd (in, mapset, &cellhd) < 0)
+		G_fatal_error (_("Cannot read file header of [%s])"), in);
+	inrast_elevation = G_allocate_raster_buf(data_type_inrast_elevation);
+	/* LOADING OPTIONAL LAI MONTHLY MAPS 		*/
+	if (input6->answer){
+		test = input6->answers;
+		for (ptr = test, nfiles = 0; *ptr != NULL; ptr++, nfiles++)
+		if (nfiles < 12)
+			G_fatal_error(_("The exact number of LAI input maps is 12"));
+		lai_ptr = input6->answers;
+		for(; *lai_ptr != NULL; lai_ptr++){
+			strcpy(lai_name,*lai_ptr);
+		for(i=0;i<12;i++){
+			mapset = G_find_cell2(&lai_name[i], "");
+				G_fatal_error(_("cell file [%s] not found"), lai_name[i]);
+			data_type_inrast_lai[i] = G_raster_map_type(&lai_name[i],mapset);
+			if ((infd_lai[i] = G_open_cell_old (&lai_name[i],mapset)) < 0)
+				G_fatal_error (_("Cannot open cell file [%s]"), lai_name[i]);
+			if (G_get_cellhd (&lai_name[i], mapset, &cellhd) < 0)
+				G_fatal_error (_("Cannot read file header of [%s])"), lai_name[i]);
+			inrast_lai[i] = G_allocate_raster_buf(data_type_inrast_lai[i]);
+	/* LOADING REQUIRED LAND COVER MAP		*/
+	mapset = G_find_cell2(landcover_name, "");
+		G_fatal_error(_("cell file [%s] not found"), landcover_name);
+	data_type_inrast_landcover = G_raster_map_type(landcover_name,mapset);
+	if ( (infd_landcover = G_open_cell_old (landcover_name,mapset)) < 0)
+		G_fatal_error (_("Cannot open cell file [%s]"), landcover_name);
+	if (G_get_cellhd (landcover_name, mapset, &cellhd) < 0)
+		G_fatal_error (_("Cannot read file header of [%s])"), landcover_name);
+	inrast_landcover = G_allocate_raster_buf(data_type_inrast_landcover);
+	G_debug(3, "number of rows %d",cellhd.rows);
+	stepx=cellhd.ew_res;
+	stepy=cellhd.ns_res;
+	xmin=cellhd.west;
+	xmax=cellhd.east;
+	ymin=cellhd.south;
+	ymax=cellhd.north;
+	nrows = G_window_rows();
+	ncols = G_window_cols();
+	//Shamelessly stolen from r.sun !!!!
+	/* Set up parameters for projection to lat/long if necessary */
+	if ((G_projection() != PROJECTION_LL)) {
+		not_ll=1;
+		struct Key_Value *in_proj_info, *in_unit_info;
+		if ((in_proj_info = G_get_projinfo()) == NULL)
+			G_fatal_error(_("Can't get projection info of current location"));
+		if ((in_unit_info = G_get_projunits()) == NULL)
+			G_fatal_error(_("Can't get projection units of current location"));
+		if (pj_get_kv(&iproj, in_proj_info, in_unit_info) < 0)
+			G_fatal_error(_("Can't get projection key values of current location"));
+		G_free_key_value(in_proj_info);
+		G_free_key_value(in_unit_info);
+		/* Set output projection to latlong w/ same ellipsoid */
+		oproj.zone = 0;
+		oproj.meters = 1.;
+		sprintf(oproj.proj, "ll");
+		if ((oproj.pj = pj_latlong_from_proj(iproj.pj)) == NULL)
+			G_fatal_error(_("Unable to set up lat/long projection parameters"));
+	}//End of stolen from r.sun :P
+	/*Initialize grid cell process switch*/
+	g=fopen(result2,"w");
+	/*If =1 then process, if =0 then skip*/
+	process = 1;
+	/*Initialize grid cell count*/
+	grid_count = 1;
+	/*Initialize output file */
+	fprintf(g,"#RUN\tGRID\tLAT\tLNG\tINFILT\tDs\tDs_MAX\tWs\tC\tEXPT_1\tEXPT_2\tEXPT_3\tKsat_1\tKsat_2\tKsat_3\tPHI_1\tPHI_2\tPHI_3\tMOIST_1\tMOIST_2\tMOIST_3\tELEV\tDEPTH_1\tDEPTH_2\tDEPTH_3\tAVG_T\tDP\tBUBLE1\tBUBLE2\tBUBLE3\tQUARZ1\tQUARZ2\tQUARZ3\tBULKDN1\tBULKDN2\tBULKDN3\tPARTDN1\tPARTDN2\tPARTDN3\tOFF_GMT\tWcrFT1\tWcrFT2\tWcrFT3\tWpFT1\tWpFT2\tWpFT3\tZ0_SOIL\tZ0_SNOW\tPRCP\tRESM1\tRESM2\tRESM3\tFS_ACTV\tJULY_TAVG\n");
+	/*Initialize dummy data*/
+	dummy_data1 = "0.010\t1.e-4\t3.05\t0.93\t2\t4.0\t4.0\t4.0\t250.0\t250.0\t250.0\t-999\t-999\t-999\t0.4\t0.4\t0.4";
+	dummy_data2 = "0.1\t6.90\t2.000\t14.0\t4.0\t75.0\t75.0\t75.0\t0.24\t0.24\t0.24\t1306\t1367\t1367\t2650\t2650\t2650\t-6\t0.330\t0.330\t0.330\t0.133\t0.133\t0.133\t0.001\t0.010\t500\t0.02\t0.02\t0.02\t1\t18.665\n";
+	h=fopen(result1,"w");
+	dummy_data3 = "0.10 0.1 1.00 0.65 0.50 0.25";
+	dummy_data4 = "0.312 0.413 0.413 0.413 0.413 0.488 0.975 1.150 0.625 0.312 0.312 0.312";
+	for (row = 0; row < nrows; row++){
+		DCELL d_prcp[MAXFILES];
+		DCELL d_tmax[MAXFILES];
+		DCELL d_tmin[MAXFILES];
+		DCELL d_elevation;
+		CELL c_landcover;
+		DCELL d_lai[12];
+		G_percent(row,nrows,2);
+		for(i=0;i<nfiles_shortest;i++){
+			if(G_get_raster_row(infd_prcp[i],inrast_prcp[i],row,data_type_inrast_prcp[i])<0)
+				G_fatal_error(_("Could not read from prcp<%d>"),i+1);
+			if(G_get_raster_row(infd_tmax[i],inrast_tmax[i],row,data_type_inrast_tmax[i])<0)
+				G_fatal_error(_("Could not read from tmax<%d>"),i+1);
+			if(G_get_raster_row(infd_tmin[i],inrast_tmin[i],row,data_type_inrast_tmin[i])<0)
+				G_fatal_error(_("Could not read from tmin<%d>"),i+1);
+		if(G_get_raster_row(infd,inrast_elevation,row,data_type_inrast_elevation)<0)
+			G_fatal_error(_("Could not read from <%s>"),in);
+		if(G_get_raster_row(infd_landcover,inrast_landcover,row,data_type_inrast_landcover)<0)
+			G_fatal_error(_("Could not read from <%s>"),landcover_name);
+		if(input6->answer){
+				if(G_get_raster_row(infd_lai[i],inrast_lai[i],row,data_type_inrast_lai[i])<0)
+					G_fatal_error(_("Could not read from <%s>"),lai_name[i]);
+		for (col=0; col < ncols; col++){
+				/*Extract prcp time series data*/
+				switch(data_type_inrast_prcp[i]){
+					case CELL_TYPE:
+						d_prcp[i]= (double) ((CELL *) inrast_prcp[i])[col];
+						break;
+					case FCELL_TYPE:
+						d_prcp[i]= (double) ((FCELL *) inrast_prcp[i])[col];
+						break;
+					case DCELL_TYPE:
+						d_prcp[i]= (double) ((DCELL *) inrast_prcp[i])[col];
+						break;
+				/*Extract tmax time series data*/
+				switch(data_type_inrast_tmax[i]){
+					case CELL_TYPE:
+						d_tmax[i]= (double) ((CELL *) inrast_tmax[i])[col];
+						break;
+					case FCELL_TYPE:
+						d_tmax[i]= (double) ((FCELL *) inrast_tmax[i])[col];
+						break;
+					case DCELL_TYPE:
+						d_tmax[i]= (double) ((DCELL *) inrast_tmax[i])[col];
+						break;
+				/*Extract tmin time series data*/
+				switch(data_type_inrast_tmin[i]){
+					case CELL_TYPE:
+						d_tmin[i]= (double) ((CELL *) inrast_tmin[i])[col];
+						break;
+					case FCELL_TYPE:
+						d_tmin[i]= (double) ((FCELL *) inrast_tmin[i])[col];
+						break;
+					case DCELL_TYPE:
+						d_tmin[i]= (double) ((DCELL *) inrast_tmin[i])[col];
+						break;
+			/*Extract elevation data*/
+			switch(data_type_inrast_elevation){
+				case CELL_TYPE:
+					d_elevation = (double) ((CELL *) inrast_elevation)[col];
+					break;
+				case FCELL_TYPE:
+					d_elevation = (double) ((FCELL *) inrast_elevation)[col];
+					break;
+				case DCELL_TYPE:
+					d_elevation = ((DCELL *) inrast_elevation)[col];
+					break;
+			/*Extract landcover data*/
+			switch(data_type_inrast_landcover){
+				case CELL_TYPE:
+					c_landcover= (int) ((CELL *) inrast_landcover)[col];
+					break;
+				case FCELL_TYPE:
+					c_landcover= (int) ((FCELL *) inrast_landcover)[col];
+					break;
+				case DCELL_TYPE:
+					c_landcover= (int) ((DCELL *) inrast_landcover)[col];
+					break;
+			/*Extract lai monthly data*/
+					switch(data_type_inrast_lai[i]){
+					case CELL_TYPE:
+						d_lai[i]= (double) ((CELL *) inrast_lai[i])[col];
+						break;
+					case FCELL_TYPE:
+						d_lai[i]= (double) ((FCELL *) inrast_lai[i])[col];
+						break;
+					case DCELL_TYPE:
+						d_lai[i]= (double) ((DCELL *) inrast_lai[i])[col];
+						break;
+			/*Extract lat/long data*/
+			latitude = ymax - ( row * stepy );
+			longitude = xmin + ( col * stepx );
+			if(not_ll){
+				if (pj_do_proj(&longitude, &latitude, &iproj, &oproj) < 0) {
+				    G_fatal_error(_("Error in pj_do_proj"));
+			}else{
+				//Do nothing
+			if(G_is_d_null_value(&prcp[0])||
+			G_is_d_null_value(&d_tmax[0])||
+			G_is_d_null_value(&d_tmin[0])||
+			G_is_d_null_value(&d_elevation)||
+			G_is_c_null_value(&c_landcover)){
+				/* Do nothing */
+			} else {
+				/* Make the output .dat file name */
+				sprintf(result_lat_long,"%s%.4f%s%.4f",result1,latitude,"_",longitude);
+				/*Open new ascii file*/
+				if (flag1->answer){
+					/*Initialize grid cell in append mode*/
+					f=fopen(result_lat_long,"a");
+				} else {
+					/*Initialize grid cell in new file mode*/
+					f=fopen(result_lat_long,"w");
+				/*Print data into the file maps data if available*/
+					fprintf(f,"%.2f  %.2f  %.2f\n", d_prcp[i], d_tmax[i], d_tmin[i]);
+				fclose(f);
+				/*Print to soil ascii file*/
+				fprintf(g,"%d\t%d\t%6.3f\t%7.3f\t%s\t%7.2f\t%s\n", process, grid_count, latitude, longitude, dummy_data1, d_elevation, dummy_data2);
+				/*Print to vegetation ascii file*/
+				/*Grid cell count and number of classes in that grid cell (=1)*/
+				fprintf(h,"%d 1\n", grid_count);
+				/*Class number, percentage that this class covers in the
+				 * grid cell(=1.0, full grid cell)
+				 * 3 root zones with depths of 10cm, 10cm and 1.0m
+				 * for those 3 root zone depths, how much root in each (%)
+				 * here we have 0.65, 0.50 and 0.25
+				fprintf(h,"%d 1.0 %s\n", c_landcover, dummy_data1);
+				/*Load monthly LAI maps data if available*/
+					fprintf(h,"%5.3f %5.3f %5.3f %5.3f %5.3f %5.3f %5.3f %5.3f %5.3f %5.3f %5.3f %5.3f\n", lai[0], lai[1], lai[2], lai[3], lai[4], lai[5], lai[6], lai[7], lai[8], lai[9], lai[10], lai[11]);
+				} else {
+				//	fprintf(h,"%s\n", dummy_data4);
+				grid_count=grid_count+1;
+	G_message(_("Created %d VIC meteorological files"),grid_count);
+	G_message(_("Created %d VIC grid cells soil/vegetation definitions"),grid_count);
+	for(i=0;i<nfiles1;i++){
+		G_free (inrast_prcp[i]);
+		G_close_cell (infd_prcp[i]);
+	for(i=0;i<nfiles2;i++){
+		G_free (inrast_tmax[i]);
+		G_close_cell (infd_tmax[i]);
+	for(i=0;i<nfiles3;i++){
+		G_free (inrast_tmin[i]);
+		G_close_cell (infd_tmin[i]);
+	G_free (inrast_elevation);
+	G_close_cell (infd);
+	G_free (inrast_landcover);
+	G_close_cell (infd_landcover);
+			G_free (inrast_lai[i]);
+			G_close_cell (infd_lai[i]);
+	fclose(h);
+	fclose(g);
+	exit(EXIT_SUCCESS);
Added: grass-addons/gipe/r.out.vic/veg_lib.c
--- grass-addons/gipe/r.out.vic/veg_lib.c	                        (rev 0)
+++ grass-addons/gipe/r.out.vic/veg_lib.c	2008-04-08 03:38:31 UTC (rev 30899)
@@ -0,0 +1,24 @@
+#include<stdio.h>
+#include<stdlib.h>
+int veglib(char *filename){
+	FILE *f;
+	f=fopen(filename,"w");
+	fprintf(f,"#Class	OvrStry	Rarc	Rmin	JAN-LAI	FEB-LAI	MAR-LAI	APR-LAI	MAY-LAI	JUN-LAI	JUL-LAI	AUG-LAI	SEP-LAI	OCT-LAI	NOV-LAI	DEC-LAI	JAN-ALB	FEB_ALB	MAR-ALB	APR-ALB	MAY-ALB	JUN-ALB	JUL-ALB	AUG-ALB	SEP-ALB	OCT-ALB	NOV-ALB	DEC-ALB	JAN-ROU	FEB-ROU	MAR-ROU	APR-ROU	MAY-ROU	JUN-ROU	JUL-ROU	AUG-ROU	SEP-ROU	OCT-ROU	NOV-ROU	DEC-ROU	JAN-DIS	FEB-DIS	MAR-DIS	APR-DIS	MAY-DIS	JUN-DIS	JUL-DIS	AUG-DIS	SEP-DIS	OCT-DIS	NOV-DIS	DEC-DIS	WIND_H	RGL	SolAtn	WndAtn	Trunk	COMMENT\n\
+1	1	60.0	250.	3.400	3.400	3.500	3.700	4.000	4.400	4.400	4.300	4.200	3.700	3.500	3.400	0.12	0.12	0.12	0.12	0.12	0.12	0.12	0.12	0.12	0.12	0.12	0.12	1.476	1.476	1.476	1.476	1.476	1.476	1.476	1.476	1.476	1.476	1.476	1.476	8.04	8.04	8.04	8.04	8.04	8.04	8.04	8.04	8.04	8.04	8.04	8.04	50.0	30	0.5	0.5	0.2	Evergreen Needleleaf\n\
+2	1	60.0	250.	3.400	3.400	3.500	3.700	4.000	4.400	4.400	4.300	4.200	3.700	3.500	3.400	0.12	0.12	0.12	0.12	0.12	0.12	0.12	0.12	0.12	0.12	0.12	0.12	1.476	1.476	1.476	1.476	1.476	1.476	1.476	1.476	1.476	1.476	1.476	1.476	8.04	8.04	8.04	8.04	8.04	8.04	8.04	8.04	8.04	8.04	8.04	8.04	50.0	30	0.5	0.5	0.2	Evergreen Broadleaf\n\
+3	1	60.0	125.	1.680	1.520	1.680	2.900	4.900	5.000	5.000	4.600	3.440	3.040	2.160	2.000	0.18	0.18	0.18	0.18	0.18	0.18	0.18	0.18	0.18	0.18	0.18	0.18	1.230	1.230	1.230	1.230	1.230	1.230	1.230	1.230	1.230	1.230	1.230	1.230	6.70	6.70	6.70	6.70	6.70	6.70	6.70	6.70	6.70	6.70	6.70	6.70	50.0	30	0.5	0.5	0.2	Deciduous Needleleaf\n\
+4	1	60.0	125.	1.680	1.520	1.680	2.900	4.900	5.000	5.000	4.600	3.440	3.040	2.160	2.000	0.18	0.18	0.18	0.18	0.18	0.18	0.18	0.18	0.18	0.18	0.18	0.18	1.230	1.230	1.230	1.230	1.230	1.230	1.230	1.230	1.230	1.230	1.230	1.230	6.70	6.70	6.70	6.70	6.70	6.70	6.70	6.70	6.70	6.70	6.70	6.70	50.0	30	0.5	0.5	0.2	Deciduous Broadleaf\n\
+5	1	60.0	125.	1.680	1.520	1.680	2.900	4.900	5.000	5.000	4.600	3.440	3.040	2.160	2.000	0.18	0.18	0.18	0.18	0.18	0.18	0.18	0.18	0.18	0.18	0.18	0.18	1.230	1.230	1.230	1.230	1.230	1.230	1.230	1.230	1.230	1.230	1.230	1.230	6.70	6.70	6.70	6.70	6.70	6.70	6.70	6.70	6.70	6.70	6.70	6.70	50.0	50	0.5	0.5	0.2	Mixed Cover\n\
+6	1	60.0	125.	1.680	1.520	1.680	2.900	4.900	5.000	5.000	4.600	3.440	3.040	2.160	2.000	0.18	0.18	0.18	0.18	0.18	0.18	0.18	0.18	0.18	0.18	0.18	0.18	1.230	1.230	1.230	1.230	1.230	1.230	1.230	1.230	1.230	1.230	1.230	1.230	6.70	6.70	6.70	6.70	6.70	6.70	6.70	6.70	6.70	6.70	6.70	6.70	50.0	50	0.5	0.5	0.2	Woodland\n\
+7	0	40.0	125.	2.000	2.250	2.950	3.850	3.750	3.500	3.550	3.200	3.300	2.850	2.600	2.200	0.19	0.19	0.19	0.19	0.19	0.19	0.19	0.19	0.19	0.19	0.19	0.19	0.495	0.495	0.495	0.495	0.495	0.495	0.495	0.495	0.495	0.495	0.495	0.495	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	10	75.	0.5	0.5	0.2	Wooded Grasslands\n\
+8	0	50.0	135.	2.000	2.250	2.950	3.850	3.750	3.500	3.550	3.200	3.300	2.850	2.600	2.200	0.19	0.19	0.19	0.19	0.19	0.19	0.19	0.19	0.19	0.19	0.19	0.19	0.495	0.495	0.495	0.495	0.495	0.495	0.495	0.495	0.495	0.495	0.495	0.495	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	10	75.	0.5	0.5	0.2	Closed Shrublands\n\
+9	0	50.0	135.	2.000	2.250	2.950	3.850	3.750	3.500	3.550	3.200	3.300	2.850	2.600	2.200	0.19	0.19	0.19	0.19	0.19	0.19	0.19	0.19	0.19	0.19	0.19	0.19	0.495	0.495	0.495	0.495	0.495	0.495	0.495	0.495	0.495	0.495	0.495	0.495	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	10	75.	0.5	0.5	0.2	Open Shrublands\n\
+10	0	25.0	120.	2.000	2.250	2.950	3.850	3.750	3.500	3.550	3.200	3.300	2.850	2.600	2.200	0.20	0.20	0.20	0.20	0.20	0.20	0.20	0.20	0.20	0.20	0.20	0.20	0.0738	0.0738	0.0738	0.0738	0.0738	0.0738	0.0738	0.0738	0.0738	0.0738	0.0738	0.0738	0.402	0.402	0.402	0.402	0.402	0.402	0.402	0.402	0.402	0.402	0.402	0.402	10	100	0.5	0.5	0.2	Grasslands\n\
+11	0	25.0	120.	0.050	0.020	0.050	0.250	1.500	3.0000	4.500	5.0000	2.5000	0.500	0.050	0.020	0.10	0.10	0.10	0.10	0.20	0.20	0.20	0.20	0.20	0.10	0.10	0.10	0.006	0.006	0.006	0.006	0.012	0.062	0.123	0.185	0.215	0.215	0.006	0.006	0.034	0.034	0.034	0.034	0.067	0.335	0.670	1.005	1.173	1.173	0.034	0.034	10	100	0.5	0.5	0.2	Crop land (corn)\n");
+	fclose(f);
+	return;
