[GRASS-SVN] r30937 -
grass/branches/releasebranch_6_3/gui/wxpython/gui_modules
svn_grass at osgeo.org
Fri Apr 11 08:21:14 EDT 2008
Author: martinl
Date: 2008-04-11 08:21:14 -0400 (Fri, 11 Apr 2008)
New Revision: 30937
grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/location_wizard.py
wxGUI (location_wizard): set region settings bugfix, do not use 'g.mapset' here (which creates gislock) + minor fix (backported from trunk)
Modified: grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/location_wizard.py
--- grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/location_wizard.py 2008-04-11 12:16:12 UTC (rev 30936)
+++ grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/location_wizard.py 2008-04-11 12:21:14 UTC (rev 30937)
@@ -1219,7 +1219,7 @@
# self.DoLayout()
def OnEnterPage(self, event):
- if self.epsgcode:
+ if not self.epsgcode:
# disable 'next' button by default
wx.FindWindowById(wx.ID_FORWARD).Enable(False)
else:
@@ -2062,11 +2062,14 @@
envval[key] = val
self.currlocation = envval['LOCATION_NAME'].strip("';")
self.currmapset = envval['MAPSET'].strip("';")
- if self.currlocation == self.location and self.currmapset == 'PERMANENT':
- pass
- else:
- cmdlist = ['g.mapset', 'location=%s' % self.location, 'mapset=PERMANENT']
- gcmd.Command(cmdlist)
+ if self.currlocation != self.location or self.currmapset != 'PERMANENT':
+ # cmdlist = ['g.mapset', 'location=%s' % self.location, 'mapset=PERMANENT']
+ # gcmd.Command(cmdlist
+ gcmd.Command(["g.gisenv",
+ "set=LOCATION_NAME=%s" % self.location])
+ "set=MAPSET=PERMANENT"])
else:
dlg = wx.MessageBox(parent=self,
message=_('Invalid location selected.'),
