[GRASS-SVN] r30938 - grass/trunk/locale/po
svn_grass at osgeo.org
Fri Apr 11 09:07:16 EDT 2008
Author: martinl
Date: 2008-04-11 09:06:55 -0400 (Fri, 11 Apr 2008)
New Revision: 30938
grass/trunk/locale/po/grasslibs_cs.po
grass/trunk/locale/po/grassmods_cs.po
grass/trunk/locale/po/grasstcl_cs.po
Czech translation updated by Jan Trochta <j.trochta seznam.cz>
Modified: grass/trunk/locale/po/grasslibs_cs.po
--- grass/trunk/locale/po/grasslibs_cs.po 2008-04-11 12:21:14 UTC (rev 30937)
+++ grass/trunk/locale/po/grasslibs_cs.po 2008-04-11 13:06:55 UTC (rev 30938)
@@ -2,7 +2,7 @@
# This file is distributed under the same license as the GRASS package.
# Copyright (C) 2004 GRASS Development Team
# Radim Bla¾ek <blazek itc.it>, 2004.
-# Martin Landa <landa.martin gmail.com>, 2005-2007
+# Martin Landa <landa.martin gmail.com>, 2005-2008.
# Jáchym Èepický <jachym.cepicky centrum.cz>, 2005.
# correction by Michal Bíl <michal.bil seznam.cz>, 2005.
# Záboj Hrázský <zabojhrazsky seznam.cz>, 2006.
@@ -12,70 +12,213 @@
msgstr ""
"Project-Id-Version: grasslibs_cs\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2008-01-24 17:42+0100\n"
-"PO-Revision-Date: 2008-01-22 15:27+0100\n"
+"POT-Creation-Date: 2008-04-11 15:58+0200\n"
+"PO-Revision-Date: 2008-03-30 20:18+0100\n"
"Last-Translator: honza <j.trochta at seznam.cz>\n"
"Language-Team: Czech <grass-translations at lists.osgeo.org>\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=ISO-8859-2\n"
"Content-Transfer-Encoding: 8bit\n"
-#: ../lib/gpde/test/test_tools.c:34
+#: ../lib/driver/main.c:89
+#, c-format
+msgid "Graphics driver [%s] started"
+msgstr "Grafický ovladaè [%s] spu¹tìn"
+#: ../lib/driver/command.c:517
+#, c-format
+msgid "Unknown command: %d last: %d"
+msgstr "Neznámý pøíkaz: %d poslední: %d"
+#: ../lib/driver/command.c:559
+msgid "Monitor: get_command: Premature EOF"
+msgstr "Monitor: get_command: Neoèekávaný konec souboru (EOF)"
+#: ../lib/driver/parse_ftcap.c:33
+#, c-format
+msgid "%s: Unable to read font definition file; use the default"
+msgstr "%s: Nelze èíst soubor s definicí písma; bude pou¾it výchozí"
+#: ../lib/driver/parse_ftcap.c:39
+#, c-format
+msgid "%s: No font definition file"
+msgstr "%s: Není dostupný ¾ádný soubor s definicí písma"
+#: ../lib/db/dbmi_client/column.c:106
+#, c-format
+msgid "Cannot describe table <%s>"
+msgstr "Nelze popsat tabulku <%s>"
+#: ../lib/db/dbmi_base/legal_dbname.c:24
+#, c-format
+msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'.\n"
+msgstr "Neplatný název vektorové mapy <%s>. Nesmí obsahovat '.' nebo 'NULL'.\n"
+#: ../lib/db/dbmi_base/legal_dbname.c:30
+#, c-format
+msgid "Illegal table map name <%s>. Must start with a letter.\n"
+msgstr "Neplatný název atributové tabulky <%s>. Musí zaèínat písmenem.\n"
+#: ../lib/db/dbmi_base/legal_dbname.c:36
+#, c-format
+msgid "Illegal table map name <%s>. Character <%c> not allowed.\n"
+msgstr "Neplatné název tabulky vektorové mapy <%s>. Znak <%c> není povolen.\n"
+#: ../lib/vask/V_support.c:58
+#, c-format
+msgid "Unable to open file %s"
+msgstr "Nelze otevøít soubor %s"
+#: ../lib/gpde/N_solvers.c:51
+msgid "The gauss elimination solver does not work with sparse matrices"
+msgstr "Gaussovu eliminaci nelze pou¾ít pro øídké matice"
+#: ../lib/gpde/N_solvers.c:56 ../lib/gpde/N_solvers.c:94
+#: ../lib/gpde/N_solvers.c:161 ../lib/gpde/N_solvers_krylov.c:78
+#: ../lib/gpde/N_solvers_krylov.c:255 ../lib/gpde/N_solvers_krylov.c:423
+#: ../lib/gpde/N_solvers_krylov.c:832 ../lib/gpde/N_solvers_classic_iter.c:57
+#: ../lib/gpde/N_solvers_classic_iter.c:94
+msgid "The linear equation system is not quadratic"
+msgstr "Lineární systém rovnic není kvadratický"
+#: ../lib/gpde/N_solvers.c:61
+msgid "Starting direct gauss elimination solver"
+msgstr "Gaussova eliminace spu¹tìna"
+#: ../lib/gpde/N_solvers.c:89
+msgid "The lu solver does not work with sparse matrices"
+msgstr "Lu metodu nelze pou¾ít pro øídké matice"
+#: ../lib/gpde/N_solvers.c:99
+msgid "Starting direct lu decomposition solver"
+msgstr "Lu dekompozice spu¹tìna"
+#: ../lib/gpde/N_solvers.c:156
+msgid "The cholesky solver does not work with sparse matrices"
+msgstr "Cholesky metodu nelze pou¾ít pro øídké matice"
+#: ../lib/gpde/N_solvers.c:167 ../lib/gpde/N_solvers_krylov.c:84
+#: ../lib/gpde/N_solvers_krylov.c:261
+msgid "Matrix is not symmetric!"
+msgstr "Matice není symetrická!"
+#: ../lib/gpde/N_solvers.c:171
+msgid "Starting cholesky decomposition solver"
+msgstr "Choleskyho dekompozice spu¹tìna"
+#: ../lib/gpde/N_solvers.c:174 ../lib/gpde/N_solvers_krylov.c:190
+#: ../lib/gpde/N_solvers_krylov.c:357 ../lib/gpde/N_solvers_krylov.c:481
+msgid "Unable to solve the linear equation system"
+msgstr "Nelze øe¹it lineární soustavu rovnic"
+#: ../lib/gpde/test/test_gradient.c:42
msgid ""
"\n"
-"++ Running math tool unit tests ++"
+"++ Running gradient unit tests ++"
msgstr ""
"\n"
-"++ Jednotkový math tool test spu¹tìn ++"
+"++ Jednotkový test gradient spu¹tìn ++"
-#: ../lib/gpde/test/test_tools.c:39
+#: ../lib/gpde/test/test_gradient.c:44
+msgid "\t 1. testing 2d gradient"
+msgstr "\t 1. testuji 2d gradient"
+#: ../lib/gpde/test/test_gradient.c:47
+msgid "\t 2. testing 3d gradient"
+msgstr "\t 2. testuji 3d gradient"
+#: ../lib/gpde/test/test_gradient.c:51
msgid ""
"\n"
-"-- math tool unit tests failure --"
+"-- Gradient unit tests failure --"
msgstr ""
"\n"
-"-- Math tool test selhal --"
+"-- Jednotkový test gradient havaroval --"
-#: ../lib/gpde/test/test_tools.c:41
+#: ../lib/gpde/test/test_gradient.c:53
msgid ""
"\n"
-"-- math tool unit tests finished successfully --"
+"-- Gradient unit tests finished successfully --"
msgstr ""
"\n"
-"-- Math tool test skonèil úspì¹nì --"
+"-- Jednotkový test gradient skonèil úspì¹nì --"
-#: ../lib/gpde/test/test_arrays.c:48
+#: ../lib/gpde/test/test_main.c:49
+msgid "Choose the unit tests to run"
+msgstr "Vyberte jednotkový test pro spu¹tìní"
+#: ../lib/gpde/test/test_main.c:56
+msgid "Choose the integration tests to run"
+msgstr "Vyberte integraèní test pro spu¹tìní"
+#: ../lib/gpde/test/test_main.c:61
+msgid "Run all unit tests"
+msgstr "Spustit v¹echny testy"
+#: ../lib/gpde/test/test_main.c:65
+msgid "Run all integration tests"
+msgstr "Spustit v¹echny integraèní testy"
+#: ../lib/gpde/test/test_main.c:69
+msgid "Run all unit and integration tests"
+msgstr "Spustit v¹echny jednotkové a integraèní testy"
+#: ../lib/gpde/test/test_main.c:85
+msgid "test, gpde"
+msgstr "test, gpde"
+#: ../lib/gpde/test/test_main.c:87
+msgid "Performs unit and integration tests for gpde library"
+msgstr "Provést jednotkové a integraèní test z gpde knihovny"
+#: ../lib/gpde/test/test_geom.c:36
msgid ""
"\n"
-"++ Running array unit tests ++"
+"++ Running geom_data unit tests ++"
msgstr ""
"\n"
-"++ Test jednotek pole spu¹tìn ++"
+"++ Jednotkový test geom_data spu¹tìn ++"
-#: ../lib/gpde/test/test_arrays.c:50
-msgid "\t 1. testing 2d arrays"
-msgstr "\t1. testuji 2d pole"
+#: ../lib/gpde/test/test_geom.c:41
+msgid ""
+"\n"
+"-- geom_data unit tests failure --"
+msgstr ""
+"\n"
+"-- Jednotkový test geom_data havaroval --"
-#: ../lib/gpde/test/test_arrays.c:53
-msgid "\t 2. testing 3d arrays"
-msgstr "\t 2. testuji 3d pole"
+#: ../lib/gpde/test/test_geom.c:43
+msgid ""
+"\n"
+"-- geom_data unit tests finished successfully --"
+msgstr ""
+"\n"
+"-- Jednotkový test geom_data skonèil úspì¹nì --"
-#: ../lib/gpde/test/test_arrays.c:57
+#: ../lib/gpde/test/test_solvers.c:37
msgid ""
"\n"
-"-- Array unit tests failure --"
+"++ Running solver unit tests ++"
msgstr ""
"\n"
-"-- Test jednotek pole havaroval --"
+"++ Jednotkový test solver spu¹tìn ++"
-#: ../lib/gpde/test/test_arrays.c:59
+#: ../lib/gpde/test/test_solvers.c:42
msgid ""
"\n"
-"-- Array unit tests finished successfully --"
+"-- Solver unit tests failure --"
msgstr ""
"\n"
-"-- Test jednotek pole skonèil úspì¹nì --"
+"-- Jednotkový test solver havaroval --"
+#: ../lib/gpde/test/test_solvers.c:44
+msgid ""
+"\n"
+"-- Solver unit tests finished successfully --"
+msgstr ""
+"\n"
+"-- Jednotkový test solver skonèil úspì¹nì --"
#: ../lib/gpde/test/test_heat.c:33
msgid ""
"\n"
@@ -108,66 +251,38 @@
"\n"
" -- Integraèní test heat flow skonèil úspì¹nì --"
-#: ../lib/gpde/test/test_les.c:34
+#: ../lib/gpde/test/test_solute_transport.c:43
msgid ""
"\n"
-"++ Running les creation unit tests ++"
+"++ Running solute_transport integration tests ++"
msgstr ""
"\n"
-"++ Jednotkový test les creation spu¹tìn ++"
+"++ Integraèní test solute_transport spu¹tìn ++"
-#: ../lib/gpde/test/test_les.c:39
+#: ../lib/gpde/test/test_solute_transport.c:45
+msgid "\t 1. testing 2d solute_transport"
+msgstr "\t 1. testuji 2d solute_transport"
+#: ../lib/gpde/test/test_solute_transport.c:48
+msgid "\t 2. testing 3d solute_transport"
+msgstr "\t 2. testuji 3d solute_transport"
+#: ../lib/gpde/test/test_solute_transport.c:52
msgid ""
"\n"
-"-- les creation unit tests failure --"
+"-- solute_transport integration tests failure --"
msgstr ""
"\n"
-"-- Jednotkový test les creation havaroval --"
+"-- Integraèní test solute_transport havaroval --"
-#: ../lib/gpde/test/test_les.c:41
+#: ../lib/gpde/test/test_solute_transport.c:55
msgid ""
"\n"
-"-- les creation unit tests finished successfully --"
+"-- solute_transport integration tests finished successfully --"
msgstr ""
"\n"
-"Jednotkový test les creation skonèil úspì¹nì --"
+"-- Integraèní test solute_transport skonèil úspì¹nì --"
-#: ../lib/gpde/test/test_les.c:95
-msgid "\t * testing les creation in parallel\n"
-msgstr "\t * testuji les creation paralelnì\n"
-#: ../lib/gpde/test/test_les.c:126
-msgid "\t * testing les creation in serial\n"
-msgstr "\t * testuji les creation seriovì\n"
-#: ../lib/gpde/test/test_main.c:49
-msgid "Choose the unit tests to run"
-msgstr "Vyberte jednotkový test pro spu¹tìní"
-#: ../lib/gpde/test/test_main.c:56
-msgid "Choose the integration tests to run"
-msgstr "Vyberte integraèní test pro spu¹tìní"
-#: ../lib/gpde/test/test_main.c:61
-msgid "Run all unit tests"
-msgstr "Spustit v¹echny testy"
-#: ../lib/gpde/test/test_main.c:65
-msgid "Run all integration tests"
-msgstr "Spustit v¹echny integraèní testy"
-#: ../lib/gpde/test/test_main.c:69
-msgid "Run all unit and integration tests"
-msgstr "Spustit v¹echny jednotkové a integraèní testy"
-#: ../lib/gpde/test/test_main.c:85
-msgid "test, gpde"
-msgstr "test, gpde"
-#: ../lib/gpde/test/test_main.c:87
-msgid "Performs unit and integration tests for gpde library"
-msgstr "Provést jednotkové a integraèní test z gpde knihovny"
#: ../lib/gpde/test/test_gwflow.c:43
msgid ""
"\n"
@@ -200,62 +315,94 @@
"\n"
" -- Integraèní test skonèil úspì¹nì --"
-#: ../lib/gpde/test/test_geom.c:36
+#: ../lib/gpde/test/test_tools.c:34
msgid ""
"\n"
-"++ Running geom_data unit tests ++"
+"++ Running math tool unit tests ++"
msgstr ""
"\n"
-"++ Jednotkový test geom_data spu¹tìn ++"
+"++ Jednotkový math tool test spu¹tìn ++"
-#: ../lib/gpde/test/test_geom.c:41
+#: ../lib/gpde/test/test_tools.c:39
msgid ""
"\n"
-"-- geom_data unit tests failure --"
+"-- math tool unit tests failure --"
msgstr ""
"\n"
-"-- Jednotkový test geom_data havaroval --"
+"-- Math tool test selhal --"
-#: ../lib/gpde/test/test_geom.c:43
+#: ../lib/gpde/test/test_tools.c:41
msgid ""
"\n"
-"-- geom_data unit tests finished successfully --"
+"-- math tool unit tests finished successfully --"
msgstr ""
"\n"
-"-- Jednotkový test geom_data skonèil úspì¹nì --"
+"-- Math tool test skonèil úspì¹nì --"
-#: ../lib/gpde/test/test_solute_transport.c:43
+#: ../lib/gpde/test/test_les.c:34
msgid ""
"\n"
-"++ Running solute_transport integration tests ++"
+"++ Running les creation unit tests ++"
msgstr ""
"\n"
-"++ Integraèní test solute_transport spu¹tìn ++"
+"++ Jednotkový test les creation spu¹tìn ++"
-#: ../lib/gpde/test/test_solute_transport.c:45
-msgid "\t 1. testing 2d solute_transport"
-msgstr "\t 1. testuji 2d solute_transport"
+#: ../lib/gpde/test/test_les.c:39
+msgid ""
+"\n"
+"-- les creation unit tests failure --"
+msgstr ""
+"\n"
+"-- Jednotkový test les creation havaroval --"
-#: ../lib/gpde/test/test_solute_transport.c:48
-msgid "\t 2. testing 3d solute_transport"
-msgstr "\t 2. testuji 3d solute_transport"
+#: ../lib/gpde/test/test_les.c:41
+msgid ""
+"\n"
+"-- les creation unit tests finished successfully --"
+msgstr ""
+"\n"
+"Jednotkový test les creation skonèil úspì¹nì --"
-#: ../lib/gpde/test/test_solute_transport.c:52
+#: ../lib/gpde/test/test_les.c:95
+msgid "\t * testing les creation in parallel\n"
+msgstr "\t * testuji les creation paralelnì\n"
+#: ../lib/gpde/test/test_les.c:126
+msgid "\t * testing les creation in serial\n"
+msgstr "\t * testuji les creation seriovì\n"
+#: ../lib/gpde/test/test_arrays.c:48
msgid ""
"\n"
-"-- solute_transport integration tests failure --"
+"++ Running array unit tests ++"
msgstr ""
"\n"
-"-- Integraèní test solute_transport havaroval --"
+"++ Test jednotek pole spu¹tìn ++"
-#: ../lib/gpde/test/test_solute_transport.c:55
+#: ../lib/gpde/test/test_arrays.c:50
+msgid "\t 1. testing 2d arrays"
+msgstr "\t1. testuji 2d pole"
+#: ../lib/gpde/test/test_arrays.c:53
+msgid "\t 2. testing 3d arrays"
+msgstr "\t 2. testuji 3d pole"
+#: ../lib/gpde/test/test_arrays.c:57
msgid ""
"\n"
-"-- solute_transport integration tests finished successfully --"
+"-- Array unit tests failure --"
msgstr ""
"\n"
-"-- Integraèní test solute_transport skonèil úspì¹nì --"
+"-- Test jednotek pole havaroval --"
+#: ../lib/gpde/test/test_arrays.c:59
+msgid ""
+"\n"
+"-- Array unit tests finished successfully --"
+msgstr ""
+"\n"
+"-- Test jednotek pole skonèil úspì¹nì --"
#: ../lib/gpde/test/test_assemble.c:42
msgid ""
"\n"
@@ -288,70 +435,66 @@
"\n"
"-- Test kompletaèních jednotek skonèil úspì¹nì --"
-#: ../lib/gpde/test/test_gradient.c:42
+#: ../lib/gpde/N_parse_options.c:59
msgid ""
-"\n"
-"++ Running gradient unit tests ++"
-msgstr ""
-"\n"
-"++ Jednotkový test gradient spu¹tìn ++"
+"The type of solver which should solve the symmetric linear equation system"
+msgstr "Typ solveru který by mìl øe¹it symetrickou lineární soustavu rovnic"
-#: ../lib/gpde/test/test_gradient.c:44
-msgid "\t 1. testing 2d gradient"
-msgstr "\t 1. testuji 2d gradient"
+#: ../lib/gpde/N_parse_options.c:71
+msgid "The type of solver which should solve the linear equation system"
+msgstr "Typ solveru, který by mìl øe¹it lineární soustavu rovnic"
-#: ../lib/gpde/test/test_gradient.c:47
-msgid "\t 2. testing 3d gradient"
-msgstr "\t 2. testuji 3d gradient"
+#: ../lib/gpde/N_parse_options.c:80
+msgid "Maximum number of iteration used to solver the linear equation system"
+msgstr "Maximální poèet iterací pou¾itá pro solver lineární soustavy rovnic"
-#: ../lib/gpde/test/test_gradient.c:51
+#: ../lib/gpde/N_parse_options.c:89
msgid ""
-"\n"
-"-- Gradient unit tests failure --"
-msgstr ""
-"\n"
-"-- Jednotkový test gradient havaroval --"
+"Error break criteria for iterative solvers (jacobi, sor, cg or bicgstab)"
+msgstr "Chyba kritéria pro iterativní solver (jacobi, sor, cg nebo bicgstab)"
-#: ../lib/gpde/test/test_gradient.c:53
+#: ../lib/gpde/N_parse_options.c:98
msgid ""
-"\n"
-"-- Gradient unit tests finished successfully --"
+"The relaxation parameter used by the jacobi and sor solver for speedup or "
+"stabilizing"
msgstr ""
-"\n"
-"-- Jednotkový test gradient skonèil úspì¹nì --"
+"Regeneraèní parametr pou¾itý pro jacobi a sor solver pro zrychlení nebo "
+"stabilizaci"
-#: ../lib/gpde/test/test_solvers.c:37
-msgid ""
-"\n"
-"++ Running solver unit tests ++"
-msgstr ""
-"\n"
-"++ Jednotkový test solver spu¹tìn ++"
+#: ../lib/gpde/N_parse_options.c:105
+msgid "The calculation time in seconds"
+msgstr "Doba výpoètu v sekundách"
-#: ../lib/gpde/test/test_solvers.c:42
-msgid ""
-"\n"
-"-- Solver unit tests failure --"
-msgstr ""
-"\n"
-"-- Jednotkový test solver havaroval --"
+#: ../lib/gpde/N_solvers_krylov.c:198
+#, c-format
+msgid "Sparse PCG -- iteration %i error %g\n"
+msgstr "Sparse PCG -- iterace %i chyba %g\n"
-#: ../lib/gpde/test/test_solvers.c:44
-msgid ""
-"\n"
-"-- Solver unit tests finished successfully --"
-msgstr ""
-"\n"
-"-- Jednotkový test solver skonèil úspì¹nì --"
+#: ../lib/gpde/N_solvers_krylov.c:200
+#, c-format
+msgid "PCG -- iteration %i error %g\n"
+msgstr "PCG -- iterace %i chyba %g\n"
-#: ../lib/gpde/N_solvers_classic_iter.c:57
-#: ../lib/gpde/N_solvers_classic_iter.c:94 ../lib/gpde/N_solvers.c:56
-#: ../lib/gpde/N_solvers.c:94 ../lib/gpde/N_solvers.c:161
-#: ../lib/gpde/N_solvers_krylov.c:78 ../lib/gpde/N_solvers_krylov.c:255
-#: ../lib/gpde/N_solvers_krylov.c:423 ../lib/gpde/N_solvers_krylov.c:832
-msgid "The linear equation system is not quadratic"
-msgstr "Lineární systém rovnic není kvadratický"
+#: ../lib/gpde/N_solvers_krylov.c:365
+#, c-format
+msgid "Sparse CG -- iteration %i error %g\n"
+msgstr "Sparse CG -- iterace %i chyba %g\n"
+#: ../lib/gpde/N_solvers_krylov.c:367
+#, c-format
+msgid "CG -- iteration %i error %g\n"
+msgstr "CG -- iterace %i chyba %g\n"
+#: ../lib/gpde/N_solvers_krylov.c:530
+#, c-format
+msgid "Sparse BiCGStab -- iteration %i error %g\n"
+msgstr "Sparse BiCGStab -- iterace %i chyba %g\n"
+#: ../lib/gpde/N_solvers_krylov.c:533
+#, c-format
+msgid "BiCGStab -- iteration %i error %g\n"
+msgstr "BiCGStab -- iterace %i chyba %g\n"
#: ../lib/gpde/N_solvers_classic_iter.c:152
#, c-format
msgid "sparse Jacobi -- iteration %5i error %g\n"
@@ -372,45 +515,15 @@
msgid "SOR -- iteration %5i error %g\n"
msgstr "SOR -- iterace %5i chyba %g\n"
-#: ../lib/gpde/N_parse_options.c:59
-msgid ""
-"The type of solver which should solve the symmetric linear equation system"
-msgstr "Typ solveru který by mìl øe¹it symetrickou lineární soustavu rovnic"
-#: ../lib/gpde/N_parse_options.c:71
-msgid "The type of solver which should solve the linear equation system"
-msgstr "Typ solveru, který by mìl øe¹it lineární soustavu rovnic"
-#: ../lib/gpde/N_parse_options.c:80
-msgid "Maximum number of iteration used to solver the linear equation system"
-msgstr "Maximální poèet iterací pou¾itá pro solver lineární soustavy rovnic"
-#: ../lib/gpde/N_parse_options.c:89
-msgid ""
-"Error break criteria for iterative solvers (jacobi, sor, cg or bicgstab)"
-msgstr "Chyba kritéria pro iterativní solver (jacobi, sor, cg nebo bicgstab)"
-#: ../lib/gpde/N_parse_options.c:98
-msgid ""
-"The relaxation parameter used by the jacobi and sor solver for speedup or "
-"stabilizing"
-msgstr ""
-"Regeneraèní parametr pou¾itý pro jacobi a sor solver pro zrychlení nebo "
-"stabilizaci"
-#: ../lib/gpde/N_parse_options.c:105
-msgid "The calculation time in seconds"
-msgstr "Doba výpoètu v sekundách"
#: ../lib/gpde/N_arrays_io.c:55
-#, fuzzy, c-format
+#, c-format
msgid "Raster map <%s> not found"
-msgstr "Vektorová mapa <%s> nebyla nalezena"
+msgstr "Rastrová mapa <%s> nebyla nalezena"
#: ../lib/gpde/N_arrays_io.c:67
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open raster map <%s>"
-msgstr "Nelze otevøít vektorovou mapu <%s>"
+msgstr "Nelze otevøít rastrovou mapu <%s>"
#: ../lib/gpde/N_arrays_io.c:96
#, c-format
@@ -430,9 +543,9 @@
msgstr "N_array_2d * pole je prázdné"
#: ../lib/gpde/N_arrays_io.c:190
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create raster map <%s>"
-msgstr "Nelze vytvoøit vektorovou mapu <%s>"
+msgstr "Nelze vytvoøit rastrovou mapu <%s>"
#: ../lib/gpde/N_arrays_io.c:199
#, c-format
@@ -469,1685 +582,906 @@
msgid "Write 3d array to g3d map <%s>"
msgstr "Zápis 3d pole do g3d mapy <%s>"
-#: ../lib/gpde/N_solvers.c:51
-msgid "The gauss elimination solver does not work with sparse matrices"
-msgstr "Gaussovu eliminaci nelze pou¾ít pro øídké matice"
+#: ../lib/g3d/g3dhistory.c:46 ../lib/gis/history.c:134
+#, c-format
+msgid "can't get history information for [%s] in mapset [%s]"
+msgstr "nelze získat informace o historii pro [%s] v mapsetu [%s]"
-#: ../lib/gpde/N_solvers.c:61
-msgid "Starting direct gauss elimination solver"
-msgstr "Gaussova eliminace spu¹tìna"
+#: ../lib/g3d/g3dopen.c:22
+msgid "G3d_openCellOldNoHeader: error in G3d_maskOpenOld"
+msgstr "G3d_openCellOldNoHeader: chyba v G3d_maskOpenOld"
-#: ../lib/gpde/N_solvers.c:89
-msgid "The lu solver does not work with sparse matrices"
-msgstr "Lu metodu nelze pou¾ít pro øídké matice"
+#: ../lib/g3d/g3dopen.c:28
+msgid "G3d_openCellOldNoHeader: error in G3d_malloc"
+msgstr "G3d_openCellOldNoHeader: chyba v G3d_malloc"
-#: ../lib/gpde/N_solvers.c:99
-msgid "Starting direct lu decomposition solver"
-msgstr "Lu dekompozice spu¹tìna"
+#: ../lib/g3d/g3dopen.c:46
+msgid "G3d_openCellOldNoHeader: error in G_open_old"
+msgstr "G3d_openCellOldNoHeader: chyba v G_open_old"
-#: ../lib/gpde/N_solvers.c:156
-msgid "The cholesky solver does not work with sparse matrices"
-msgstr "Cholesky metodu nelze pou¾ít pro øídké matice"
+#: ../lib/g3d/g3dopen.c:101
+msgid "G3d_openCellOld: error in G3d_openCellOldNoHeader"
+msgstr "G3d_openCellOld: chyba v G3d_openCellOldNoHeader"
-#: ../lib/gpde/N_solvers.c:167 ../lib/gpde/N_solvers_krylov.c:84
-#: ../lib/gpde/N_solvers_krylov.c:261
-msgid "Matrix is not symmetric!"
-msgstr "Matice není symetrická!"
+#: ../lib/g3d/g3dopen.c:106
+msgid "G3d_openCellOld: can't rewind file"
+msgstr "G3d_openCellOld: nemohu znovu natáhnoutsoubor"
-#: ../lib/gpde/N_solvers.c:171
-msgid "Starting cholesky decomposition solver"
-msgstr "Choleskyho dekompozice spu¹tìna"
+#: ../lib/g3d/g3dopen.c:119
+msgid "G3d_openCellOld: error in G3d_readHeader"
+msgstr "G3d_openCellOld: chyba v G3d_readHeader"
-#: ../lib/gpde/N_solvers.c:174 ../lib/gpde/N_solvers_krylov.c:190
-#: ../lib/gpde/N_solvers_krylov.c:357 ../lib/gpde/N_solvers_krylov.c:481
-msgid "Unable to solve the linear equation system"
-msgstr "Nelze øe¹it lineární soustavu rovnic"
+#: ../lib/g3d/g3dopen.c:126
+msgid "G3d_openCellOld: projection does not match window projection"
+msgstr "G3d_openCellOld: projekce mapy neodpovídá projekci okna"
-#: ../lib/gpde/N_solvers_krylov.c:198
-#, c-format
-msgid "Sparse PCG -- iteration %i error %g\n"
-msgstr "Sparse PCG -- iterace %i chyba %g\n"
+#: ../lib/g3d/g3dopen.c:130
+msgid "G3d_openCellOld: zone does not match window zone"
+msgstr "G3d_openCellOld: zóna neodpovídá zónì okna"
-#: ../lib/gpde/N_solvers_krylov.c:200
-#, c-format
-msgid "PCG -- iteration %i error %g\n"
-msgstr "PCG -- iterace %i chyba %g\n"
+#: ../lib/g3d/g3dopen.c:142 ../lib/g3d/g3dopen.c:159
+msgid "G3d_openCellOld: can't read header"
+msgstr "G3d_openCellOld: nemohu pøeèíst hlavièku"
-#: ../lib/gpde/N_solvers_krylov.c:365
-#, c-format
-msgid "Sparse CG -- iteration %i error %g\n"
-msgstr "Sparse CG -- iterace %i chyba %g\n"
+#: ../lib/g3d/g3dopen.c:148
+msgid "G3d_openCellOld: index does not fit into long"
+msgstr "G3d_openCellOld: index neodpovídá typu long"
-#: ../lib/gpde/N_solvers_krylov.c:367
-#, c-format
-msgid "CG -- iteration %i error %g\n"
-msgstr "CG -- iterace %i chyba %g\n"
+#: ../lib/g3d/g3dopen.c:152
+msgid "G3d_openCellOld: error in G3d_malloc"
+msgstr "G3d_openCellOld: chyba v G3d_malloc"
-#: ../lib/gpde/N_solvers_krylov.c:530
-#, c-format
-msgid "Sparse BiCGStab -- iteration %i error %g\n"
-msgstr "Sparse BiCGStab -- iterace %i chyba %g\n"
+#: ../lib/g3d/g3dopen.c:179
+msgid "G3d_openCellOld: error in G3d_fillHeader"
+msgstr "G3d_openCellOld: chyba v G3d_fillHeader"
-#: ../lib/gpde/N_solvers_krylov.c:533
-#, c-format
-msgid "BiCGStab -- iteration %i error %g\n"
-msgstr "BiCGStab -- iterace %i chyba %g\n"
+#: ../lib/g3d/g3dopen.c:227
+msgid "G3d_openCellNew: error in G3d_maskOpenOld"
+msgstr "G3d_openCellNew: chyba v G3d_maskOpenOld"
-#: ../lib/db/dbmi_base/legal_dbname.c:24
-#, c-format
-msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'.\n"
-msgstr "Neplatný název vektorové mapy <%s>. Nesmí obsahovat '.' nebo 'NULL'.\n"
+#: ../lib/g3d/g3dopen.c:236
+msgid "G3d_openCellNew: error in G3d_malloc"
+msgstr "G3d_openCellNew: chyba v G3d_malloc"
-#: ../lib/db/dbmi_base/legal_dbname.c:30
-#, c-format
-msgid "Illegal table map name <%s>. Must start with a letter.\n"
-msgstr "Neplatný název atributové tabulky <%s>. Musí zaèínat písmenem.\n"
+#: ../lib/g3d/g3dopen.c:249
+msgid "G3d_openCellNew: could not open file"
+msgstr "G3d_openCellNew: nemohu otevøít soubor"
-#: ../lib/db/dbmi_base/legal_dbname.c:36
-#, c-format
-msgid "Illegal table map name <%s>. Character <%c> not allowed.\n"
-msgstr "Neplatné název tabulky vektorové mapy <%s>. Znak <%c> není povolen.\n"
+#: ../lib/g3d/g3dopen.c:291 ../lib/g3d/g3dopen.c:296
+msgid "G3d_openCellNew: can't write header"
+msgstr "G3d_openCellNew: nemohu ulo¾it hlavièku"
-#: ../lib/db/dbmi_client/column.c:106
-#, c-format
-msgid "Cannot describe table <%s>"
-msgstr "Nelze popsat tabulku <%s>"
+#: ../lib/g3d/g3dopen.c:319
+msgid "G3d_openCellNew: error in G3d_fillHeader"
+msgstr "G3d_openCellNew: chyba v G3d_fillHeader"
-#: ../lib/driver/parse_ftcap.c:33
-#, c-format
-msgid "%s: Unable to read font definition file; use the default"
-msgstr "%s: Nelze èíst soubor s definicí písma; bude pou¾it výchozí"
+#: ../lib/g3d/g3dparam.c:54
+msgid "Data type used in the output file"
+msgstr "Datový typ pou¾itý ve výstupním souboru"
-#: ../lib/driver/parse_ftcap.c:39
-#, c-format
-msgid "%s: No font definition file"
-msgstr "%s: Není dostupný ¾ádný soubor s definicí písma"
+#: ../lib/g3d/g3dparam.c:63
+msgid "Precision used in the output file (default, max, or 0 to 52)"
+msgstr ""
+"Pøesnost pou¾itá ve výstupním souboru (výchozí, maximální nebo 0 a¾ 52)"
-#: ../lib/driver/command.c:517
-#, c-format
-msgid "Unknown command: %d last: %d"
-msgstr "Neznámý pøíkaz: %d poslední: %d"
+#: ../lib/g3d/g3dparam.c:73
+msgid "The compression method used in the output file"
+msgstr "Metoda komprese pou¾itá ve výstupním souboru"
-#: ../lib/driver/command.c:559
-msgid "Monitor: get_command: Premature EOF"
-msgstr "Monitor: get_command: Neoèekávaný konec souboru (EOF)"
+#: ../lib/g3d/g3dparam.c:83
+msgid "The dimensions of the tiles used in the output file"
+msgstr "Dimenze dla¾dic pou¾itá ve výstupním souboru"
-#: ../lib/driver/main.c:89
-#, c-format
-msgid "Graphics driver [%s] started"
-msgstr "Grafický ovladaè [%s] spu¹tìn"
+#: ../lib/g3d/g3dparam.c:118
+msgid "G3d_getStandard3dParams: precision value invalid"
+msgstr "G3d_getStandard3dParams: hodnota pøesnosti není platná"
-#: ../lib/raster/rem_io.c:43
-#, c-format
-msgid "ERROR %s from graphics driver.\n"
-msgstr "CHYBA %s grafického ovladaèe\n"
+#: ../lib/g3d/g3dparam.c:146
+msgid "G3d_getStandard3dParams: tile dimension value invalid"
+msgstr "G3d_getStandard3dParams: dimeze dla¾dic není platná"
-#: ../lib/raster/rem_io.c:172
-#, c-format
-msgid "Unable to allocate memory\n"
-msgstr "Nelze alokovat pamì»\n"
+#: ../lib/g3d/g3dparam.c:171
+msgid "Window replacing the default"
+msgstr "Výøez zamìní výchozí"
-#: ../lib/raster/rem_io.c:225
+#: ../lib/display/tran_colr.c:132 ../lib/display/tran_colr.c:134
#, c-format
-msgid "ERROR - eof from graphics monitor.\n"
-msgstr "CHYBA - eof z grafického monitoru.\n"
+msgid "[%s]: No such color"
+msgstr "[%s]: Neznámá barva"
-#: ../lib/raster/rem_io.c:244
+#: ../lib/gis/raster_metadata.c:111
#, c-format
-msgid "Warning - no response from graphics monitor <%s>.\n"
-msgstr "Upozornìní - ¾ádná odezva od grafického monitoru <%s>.\n"
+msgid "Can't read %s for [%s in %s]"
+msgstr "Nelze èíst %s pro [%s z %s]"
-#: ../lib/raster/rem_io.c:246
+#: ../lib/gis/raster_metadata.c:143
#, c-format
-msgid "Check to see if the mouse is still active.\n"
-msgstr "Zkontrolujte zda-li je my¹ stále aktivní.\n"
+msgid "Can't create %s metadata file for [%s in %s]"
+msgstr "Nelze vytvoøit soubor s metadaty %s pro [%s z %s]"
-#: ../lib/raster/rem_io.c:251
-#, c-format
-msgid "ERROR - no response from graphics monitor <%s>.\n"
-msgstr "CHYBA - ¾ádná odezva od grafického monitoru <%s>.\n"
+#: ../lib/gis/rd_cellhd.c:136
+msgid "duplicate projection field"
+msgstr "duplicitní polo¾ka mapové projekce"
-#: ../lib/raster/io_sock.c:65
-msgid "No graphics monitor has been selected for output."
-msgstr "Nebyl zvolen ¾ádný grafický monitor pro výstup."
+#: ../lib/gis/rd_cellhd.c:147
+msgid "duplicate zone field"
+msgstr "duplicitní polo¾ka zóny"
-#: ../lib/raster/io_sock.c:66
-msgid "Please run \"d.mon\" to select a graphics monitor."
-msgstr "Pro výbìr grafického monitoru zavolejte \"d.mon\"."
+#: ../lib/gis/rd_cellhd.c:157
+msgid "projection field missing"
+msgstr "chybìjící polo¾ka mapové projekce"
-#: ../lib/raster/io_sock.c:75
-#, c-format
-msgid "Failed to get socket name for monitor <%s>."
-msgstr "Nelze získat soket pro monitor <%s>."
+#: ../lib/gis/rd_cellhd.c:159
+msgid "zone field missing"
+msgstr "chybìjící polo¾ka zóny"
-#: ../lib/raster/io_sock.c:85
-#, c-format
-msgid "No socket to connect to for monitor <%s>."
-msgstr "Není dostupný ¾ádný soket pro pøipojení k monitoru <%s>."
+#: ../lib/gis/rd_cellhd.c:181
+msgid "duplicate north field"
+msgstr "duplicitní polo¾ka pro sever"
-#: ../lib/raster/io_sock.c:105
-msgid "Socket is already in use or not accepting connections."
-msgstr "Soket je ji¾ pou¾íván nebo není akceptováno spojení."
+#: ../lib/gis/rd_cellhd.c:190
+msgid "duplicate south field"
+msgstr "duplicitní polo¾ka pro jih"
-#: ../lib/raster/io_sock.c:106
-msgid "Use d.mon to select a monitor"
-msgstr "Pro výbìr grafického monitoru zavolejte d.mon."
+#: ../lib/gis/rd_cellhd.c:199
+msgid "duplicate east field"
+msgstr "duplicitní polo¾ka pro východ"
-#: ../lib/raster/io_sock.c:113
-msgid "Trying to connect to something not a socket."
-msgstr "Pokus o pøipojení k nìèemu, co není soketem."
+#: ../lib/gis/rd_cellhd.c:208
+msgid "duplicate west field"
+msgstr "duplicitní polo¾ka pro západ"
-#: ../lib/raster/io_sock.c:114
-msgid "Probably program error."
-msgstr "Pravdìpodobnì chyba programu."
+#: ../lib/gis/rd_cellhd.c:217
+msgid "duplicate top field"
+msgstr "duplicitní polo¾ka pro horní èást"
-#: ../lib/raster/io_sock.c:120
-msgid "Connect attempt timed out."
-msgstr "Pøipojení selhalo."
+#: ../lib/gis/rd_cellhd.c:226
+msgid "duplicate bottom field"
+msgstr "duplicitní polo¾ka pro spodní èást"
-#: ../lib/raster/io_sock.c:121
-msgid "Probably an error with the server."
-msgstr "Pravdìpodobnì je chyba na stranì serveru."
+#: ../lib/gis/rd_cellhd.c:235
+msgid "duplicate e-w resolution field"
+msgstr "duplicitní polo¾ka pro rozli¹ené e-w"
-#: ../lib/raster/io_sock.c:129
-msgid "Connection failed."
+#: ../lib/gis/rd_cellhd.c:246
+msgid "duplicate 3D e-w resolution field"
+msgstr "duplicitní polo¾ka pro 3D rozli¹ení e-w"
-#: ../lib/vector/diglib/plus_area.c:211 ../lib/vector/diglib/plus_area.c:648
-#: ../lib/vector/diglib/plus_area.c:654
-#, c-format
-msgid "Line [%d] already has area/isle [%d] to left."
-msgstr "Linie [%d] má ji¾ na levé stranì plochu/ostrov [%d]"
+#: ../lib/gis/rd_cellhd.c:257
+msgid "duplicate n-s resolution field"
+msgstr "duplicitní polo¾ka pro rozli¹ení n-s"
-#: ../lib/vector/diglib/plus_area.c:219
-#, c-format
-msgid "Line [%d] already has area/isle [%d] to right."
-msgstr "Linie [%d] má ji¾ na pravé stranì plochu/ostrov [%d]"
+#: ../lib/gis/rd_cellhd.c:268
+msgid "duplicate 3D n-s resolution field"
+msgstr "duplicitní polo¾ka pro 3D rozli¹ení n-s rozli¹ení"
-#: ../lib/vector/diglib/plus_area.c:302
-msgid "Attempt to delete isle from dead area"
-msgstr "Pokus o odstranìné ostrova z mrtvé plochy"
+#: ../lib/gis/rd_cellhd.c:279
+msgid "duplicate t-b resolution field"
+msgstr "duplicitní polo¾ka pro t-b rozli¹ení"
-#: ../lib/vector/diglib/plus_area.c:316
-#, c-format
-msgid "Attempt to delete not registered isle [%d] from area [%d]"
-msgstr "Pokus o odstranìní neregistrovaného ostrova [%d] z plochy [%d]"
+#: ../lib/gis/rd_cellhd.c:290
+msgid "duplicate rows field"
+msgstr "duplicitní polo¾ka pro øádky"
-#: ../lib/vector/diglib/plus_area.c:354
-msgid "Attempt to delete dead area"
-msgstr "Pokus o odstranìní mrtvé plochy"
+#: ../lib/gis/rd_cellhd.c:301
+msgid "duplicate 3D rows field"
+msgstr "duplicitní polo¾ka pro 3D øádky"
-#: ../lib/vector/diglib/plus_area.c:392
-#, c-format
-msgid "Dead centroid [%d] registered for area (bug in the library)."
-msgstr "Mrtvý centroid [%d] registrován k plo¹e (chyba v knihovnì)."
+#: ../lib/gis/rd_cellhd.c:312
+msgid "duplicate cols field"
+msgstr "duplicitní polo¾ka pro sloupce"
-#: ../lib/vector/diglib/plus_area.c:413
-#, c-format
-msgid "Attempt to delete area [%d] info from dead isle [%d]"
-msgstr "Pokus o odstranìní informace o plo¹e [%d] z mrtvého ostrovu [%d]"
+#: ../lib/gis/rd_cellhd.c:323
+msgid "duplicate 3D cols field"
+msgstr "duplicitní polo¾ka pro 3D sloupce"
-#: ../lib/vector/diglib/plus_area.c:741
-#, c-format
-msgid "Attempt to delete isle [%d] info from dead area [%d]"
-msgstr "Pokus o odstranìní informace o ostrovì [%d] z mrtvé plochy [%d]"
+#: ../lib/gis/rd_cellhd.c:334
+msgid "duplicate depths field"
+msgstr "duplicitní polo¾ka pro hloubky"
-#: ../lib/vector/diglib/plus.c:318
-msgid "Cannot read topo for nodes"
-msgstr "Nelze èíst topologie pro uzly"
+#: ../lib/gis/rd_cellhd.c:345
+msgid "duplicate format field"
+msgstr "duplicitní polo¾ka pro formát"
-#: ../lib/vector/diglib/plus.c:324
-#, c-format
-msgid "Cannot read topo for node [%d]"
-msgstr "Nelze èíst topologii pro uzly [%d]"
+#: ../lib/gis/rd_cellhd.c:354
+msgid "duplicate compressed field"
+msgstr "duplicitní komprimovaná polo¾ka"
-#: ../lib/vector/diglib/plus.c:329
-msgid "Cannot read topo for lines"
-msgstr "Nelze èíst topologii pro linie"
+#: ../lib/gis/rd_cellhd.c:365
+msgid "north field missing"
+msgstr "chybí polo¾ka pro sever"
-#: ../lib/vector/diglib/plus.c:335
-#, c-format
-msgid "Cannot read topo for line [%d]"
-msgstr "Nelze èíst topologii pro linii [%d]"
+#: ../lib/gis/rd_cellhd.c:367
+msgid "south field missing"
+msgstr "chybí polo¾ka pro jih"
-#: ../lib/vector/diglib/plus.c:340
-msgid "Cannot read topo for areas"
-msgstr "Nelze èíst topologii pro plochy"
+#: ../lib/gis/rd_cellhd.c:369
+msgid "west field missing"
+msgstr "chybí polo¾ka pro západ"
-#: ../lib/vector/diglib/plus.c:346
-#, c-format
-msgid "Cannot read topo for area [%d]"
-msgstr "Nelze èíst topologii pro plochu [%d]"
+#: ../lib/gis/rd_cellhd.c:371
+msgid "east field missing"
+msgstr "chybí polo¾ka pro východ"
-#: ../lib/vector/diglib/plus.c:351
-msgid "Cannot read topo for isles"
-msgstr "Nelze èíst topologii pro ostrovy"
+#: ../lib/gis/rd_cellhd.c:373
+msgid "cols field missing"
+msgstr "chybí polo¾ka pro sloupce"
-#: ../lib/vector/diglib/plus.c:357
-#, c-format
-msgid "Cannot read topo for isle [%d]"
-msgstr "Nelze èíst topologii pro ostrov [%d]"
+#: ../lib/gis/rd_cellhd.c:375
+msgid "rows field missing"
+msgstr "chybí polo¾ka pro øádky"
-#: ../lib/vector/diglib/plus_node.c:244
-#, c-format
-msgid ""
-"Attempt to read line angle for the line which is not connected to the node: "
-"node = [%d] line = [%d]"
-msgstr ""
-"Pokus o naètení úhlu linie pro linii, která není pøipojena k uzlu: \n"
-"uzel = [%d] linie = [%d]"
+#: ../lib/gis/rd_cellhd.c:386
+msgid "ewres3 field missing"
+msgstr "chybí polo¾ka pro ewres3"
-#: ../lib/vector/Vlib/build.c:29 ../lib/vector/Vlib/open.c:34
-#: ../lib/vector/Vlib/close.c:36 ../lib/vector/Vlib/read.c:27
-#: ../lib/vector/Vlib/rewind.c:34 ../lib/vector/Vlib/write.c:38
-msgid "Requested format is not compiled in this version"
-msgstr "Po¾adovaný formát není zkompilován v této verzi"
+#: ../lib/gis/rd_cellhd.c:388
+msgid "nsres3 field missing"
+msgstr "chybí polo¾ka pro nsres3"
-#: ../lib/vector/Vlib/build.c:143
-#, fuzzy, c-format
-msgid "Building topology for vector map <%s>...\n"
-msgstr "Vytvoøte prosím znovu topologii pro vektorovou mapu <%s@%s>"
+#: ../lib/gis/rd_cellhd.c:390
+msgid "cols3 field missing"
+msgstr "chybí polo¾ka pro cols3"
-#: ../lib/vector/Vlib/build.c:156
-#, fuzzy
-msgid "Topology was built\n"
-msgstr "Topologie byla vytvoøena.\n"
+#: ../lib/gis/rd_cellhd.c:392
+msgid "rows3 field missing"
+msgstr "chybí polo¾ka pro rows3"
-#: ../lib/vector/Vlib/build.c:168
+#: ../lib/gis/rd_cellhd.c:448
#, c-format
-msgid "Number of nodes : %d\n"
-msgstr "Poèet uzlù : %d\n"
+msgid "line %d: <%s>"
+msgstr "øádek %d: <%s>"
-#: ../lib/vector/Vlib/build.c:169
+#: ../lib/gis/range.c:195
#, c-format
-msgid "Number of primitives: %d\n"
-msgstr "Poèet primitiv : %d\n"
+msgid "can't read f_range file for [%s in %s]"
+msgstr "nelze pøeèíst f_range soubor z [%s v %s]"
-#: ../lib/vector/Vlib/build.c:170
+#: ../lib/gis/range.c:312
#, c-format
-msgid "Number of points : %d\n"
-msgstr "Poèet bodù : %d\n"
+msgid "can't read range file for [%s in %s]"
+msgstr "nelze èíst soubor s rozsahem hodnot z [%s v %s]"
-#: ../lib/vector/Vlib/build.c:171
+#: ../lib/gis/range.c:365 ../lib/gis/range.c:416
#, c-format
-msgid "Number of lines : %d\n"
-msgstr "Poèet linií : %d\n"
+msgid "can't write range file for [%s in %s]"
+msgstr "nelze vytvoøit soubor s rozsahem hodnot z [%s v %s]"
-#: ../lib/vector/Vlib/build.c:172
+#: ../lib/gis/get_window.c:69 ../lib/gis/get_window.c:88
#, c-format
-msgid "Number of boundaries: %d\n"
-msgstr "Poèet hranic : %d\n"
+msgid ""
+"region for current mapset %s\n"
+"run \"g.region\""
+msgstr ""
+"region pro aktuální mapset %s\n"
+"spus»te \"g.region\""
-#: ../lib/vector/Vlib/build.c:173
+#: ../lib/gis/get_window.c:124
#, c-format
-msgid "Number of centroids : %d\n"
-msgstr "Poèet centroidù : %d\n"
+msgid "default region %s"
+msgstr "výchozí region (zájmové území) %s"
-#: ../lib/vector/Vlib/build.c:176
-#, c-format
-msgid "Number of faces : %d\n"
-msgstr "Poèet stìn : %d\n"
+#: ../lib/gis/get_window.c:146
+msgid "is not set"
+msgstr "není nastaveno"
-#: ../lib/vector/Vlib/build.c:179
+#: ../lib/gis/get_window.c:156
#, c-format
-msgid "Number of kernels : %d\n"
-msgstr "Poèet jader: : %d\n"
+msgid ""
+"is invalid\n"
+"%s"
+msgstr ""
+"je neplatný\n"
+"%s"
-#: ../lib/vector/Vlib/build.c:214
+#: ../lib/gis/get_projname.c:32
#, c-format
-msgid "Number of areas : %d\n"
-msgstr "Poèet ploch : %d\n"
+msgid "%s not found"
+msgstr "%s nenalezen"
-#: ../lib/vector/Vlib/build.c:215
+#: ../lib/gis/get_projname.c:35
#, c-format
-msgid "Number of isles : %d\n"
-msgstr "Poèet ostrovù : %d\n"
+msgid "ERROR in reading %s"
+msgstr "CHYBA pøi ètení %s"
-#: ../lib/vector/Vlib/build.c:218
-#, c-format
-msgid "Number of incorrect boundaries : %d\n"
-msgstr "Poèet chybných hranic : %d\n"
+#: ../lib/gis/get_projname.c:39 ../lib/gis/get_datum_name.c:67
+#: ../lib/gis/get_ell_name.c:33
+msgid "Cannot open temp file"
+msgstr "Nelze otevøít doèasný soubor"
-#: ../lib/vector/Vlib/build.c:221
+#: ../lib/gis/get_projname.c:49
#, c-format
-msgid "Number of centroids outside area : %d\n"
-msgstr "Poèet centroidù mimo plochu : %d\n"
+msgid ""
+"\n"
+"\n"
+"Please specify projection name\n"
+msgstr ""
+"\n"
+"\n"
+"Specifikujte prosím mapovou projekci\n"
-#: ../lib/vector/Vlib/build.c:224
+#: ../lib/gis/get_projname.c:50
#, c-format
-msgid "Number of duplicate centroids : %d\n"
-msgstr "Poèet duplikátních centroidù : %d\n"
+msgid "Enter 'list' for the list of available projections\n"
+msgstr "Zadejte 'list' pro výpis dostupných mapových projekcí\n"
-#: ../lib/vector/Vlib/build.c:227
+#: ../lib/gis/get_projname.c:51 ../lib/gis/get_datum_name.c:56
+#: ../lib/gis/get_ell_name.c:46 ../lib/proj/datum.c:337
#, c-format
-msgid "Number of areas without centroid : %d\n"
-msgstr "Poèet ploch bez centroidu : %d\n"
+msgid "Hit RETURN to cancel request\n"
+msgstr "Pro ukonèení po¾adavku stisknìte RETURN\n"
-#: ../lib/vector/Vlib/build.c:230
-msgid "Number of areas : -\n"
-msgstr "Poèet ploch : -\n"
-#: ../lib/vector/Vlib/build.c:231
-msgid "Number of isles : -\n"
-msgstr "Poèet ostrovù : -\n"
-#: ../lib/vector/Vlib/build.c:261
-#, fuzzy, c-format
-msgid "Unable to open topo file for write <%s>"
-msgstr "Nelze otevøít soubor s topologií pro zápis: <%s>"
-#: ../lib/vector/Vlib/build.c:269
-#, fuzzy
-msgid "Error writing out topo file"
-msgstr "Chyba pøi sestavení souboru s topologií."
-#: ../lib/vector/Vlib/build.c:405
-#, fuzzy, c-format
-msgid "Unable open spatial index file for write <%s>"
-msgstr "Nelze otevøít soubor s prostorovým indexem pro zápis <%s>"
-#: ../lib/vector/Vlib/build.c:413
-#, fuzzy
-msgid "Error writing out spatial index file"
-msgstr "Chyba pøi sestavení souboru s prostorovým indexem."
-#: ../lib/vector/Vlib/intersect.c:127
-msgid "3D not supported by Vect_segment_intersection()"
-msgstr "3D není podporováno Vect_segment_intersection()"
-#: ../lib/vector/Vlib/intersect.c:265
-msgid "Vect_segment_intersection() ERROR (collinear vertical segments)"
-msgstr "Vect_segment_intersection() CHYBA (kolinerní vertikální segmenty)"
-#: ../lib/vector/Vlib/intersect.c:347
-msgid "Vect_segment_intersection() ERROR (collinear non vertical segments)"
-msgstr "Vect_segment_intersection() CHYBA (kolineární nevertikální segmenty)"
-#: ../lib/vector/Vlib/open.c:93
+#: ../lib/gis/get_projname.c:72
#, c-format
-msgid "Programmer requested unknown open level %d"
-msgstr "Programátor po¾adoval neznámé otevøení na úrovni %d"
+msgid ""
+"\n"
+"invalid projection\n"
+msgstr ""
+"\n"
+"neplatná mapová projekce\n"
-#: ../lib/vector/Vlib/open.c:156 ../lib/vector/Vlib/legal_vname.c:108
-#: ../lib/vector/Vlib/legal_vname.c:110 ../lib/vector/Vlib/map.c:305
+#: ../lib/gis/closecell.c:223
#, c-format
-msgid "Vector map <%s> not found"
-#: ../lib/vector/Vlib/open.c:166
msgid ""
-"Vector map which is not in the current mapset cannot be opened for update"
+"closecell: can't move %s\n"
+"to null file %s"
msgstr ""
-"Mapa, která není obsa¾ena v aktuálním mapsetu, nemù¾e být otevøena pro zápis"
+"closecell: nemohu pøesunout %s\n"
+"do souboru null %s"
-#: ../lib/vector/Vlib/open.c:184
+#: ../lib/gis/closecell.c:243
#, c-format
-msgid "Unable to open vector map <%s>"
+msgid "Error writing floating point format file for map %s"
+msgstr ""
+"Chyba pøi zapisování souboru s èísly s plovoucí desetinnou èárkou pro mapu %s"
-#: ../lib/vector/Vlib/open.c:194 ../lib/vector/Vlib/open.c:254
-#: ../lib/vector/Vlib/open.c:271
+#: ../lib/gis/closecell.c:289
#, c-format
-msgid "Unable to open vector map <%s> on topology level %d"
-msgstr "Nelze otevøít existující vektorovou mapu <%s> na úrovni %d"
+msgid ""
+"to cell file %s"
+msgstr ""
+"do rastrového souboru %s"
-#: ../lib/vector/Vlib/open.c:195
-msgid "Unable to read head file"
-msgstr "Nelze èíst hlavièkový soubor"
+#: ../lib/gis/closecell.c:343
+msgid "unable to write quant file!"
+msgstr "nemohu zapsat soubor quant!"
-#: ../lib/vector/Vlib/open.c:215
-#, c-format
-msgid "Unable to open topology file for vector map <%s>"
-msgstr "Nelze otevøít soubor s topologií pro vektorovou mapu <%s>"
+#: ../lib/gis/closecell.c:391
+msgid "unable to write f_format file for CELL maps"
+msgstr "neschopen zapsat soubor f_format pro mapy CELL "
-#: ../lib/vector/Vlib/open.c:238
+#: ../lib/gis/put_title.c:28
#, c-format
-msgid "Unable to open category index file for vector map <%s>"
-msgstr "Nelze otevøít soubor s historií pro vektorovou mapu <%s>"
+msgid "category information for [%s] in [%s] missing or invalid"
+msgstr "kategorie pro [%s] v [%s] chybí nebo jsou neplatné"
-#: ../lib/vector/Vlib/open.c:319 ../lib/vector/Vlib/open.c:530
+#: ../lib/gis/put_title.c:38
#, c-format
-msgid "Unable to open history file for vector map <%s>"
+msgid "G_put_title - can't create a temp file"
+msgstr "G_put_title - nelze vytvoøit doèasný soubor"
-#: ../lib/vector/Vlib/open.c:496 ../lib/vector/Vlib/map.c:169
-#: ../lib/vector/Vlib/map.c:293
+#: ../lib/gis/put_title.c:58
#, c-format
-msgid "Vector map name is not SQL compliant"
-msgstr "Název mapy nevyhovuje podmínkám SQL"
+msgid "category information for [%s] in [%s] invalid"
+msgstr "neplatné kategorie pro [%s] v [%s]"
-#: ../lib/vector/Vlib/open.c:503 ../lib/vector/Vlib/map.c:173
-#: ../lib/vector/Vlib/map.c:297
+#: ../lib/gis/put_title.c:66
#, c-format
-msgid "Vector map <%s> already exists and will be overwritten"
-msgstr "Vektorová mapa <%s> ji¾ existuje a bude pøepsána."
+msgid "G_put_title - can't reopen temp file"
+msgstr "G_put_title - nelze znovu otevøít doèasný soubor"
-#: ../lib/vector/Vlib/open.c:507 ../lib/vector/Vlib/map.c:176
+#: ../lib/gis/put_title.c:75
#, c-format
-msgid "Unable to delete vector map <%s>"
-msgstr "Nelze smazat vektorovou mapu <%s>"
+msgid "can't write category information for [%s] in [%s]"
+msgstr "nelze zapsat kategorie pro [%s] v [%s]"
-#: ../lib/vector/Vlib/open.c:521
-#, c-format
-msgid "Unable to create vector map <%s>"
+#: ../lib/gis/ask_cell.c:56 ../lib/gis/ask_cell.c:75 ../lib/gis/ask_cell.c:94
+#: ../lib/gis/ask_cell.c:101
+msgid "with titles"
+msgstr "s titulky"
-#: ../lib/vector/Vlib/open.c:576
-#, c-format
-msgid "Unable to stat file <%s>"
-msgstr "Nelze otevøít soubor <%s>"
+#: ../lib/gis/ask_cell.c:113
+msgid "(no title)"
+msgstr "(bez titulku)"
-#: ../lib/vector/Vlib/open.c:683
-msgid "Size of 'coor' file differs from value saved in topology file"
-msgstr ""
-"Velikost souboru 'coor' se li¹í od hodnot ulo¾ených v souboru s topologií"
+#: ../lib/gis/color_rules.c:115
+msgid "syntax error"
+msgstr "syntaktická chyba"
-#: ../lib/vector/Vlib/open.c:694
-#, c-format
-msgid "Please rebuild topology for vector map <%s@%s>"
+#: ../lib/gis/color_rules.c:116
+msgid "R/G/B not in range 0-255"
+msgstr "R/G/B není v rozsahu 0-255"
-#: ../lib/vector/Vlib/snap.c:119 ../lib/vector/Vlib/snap.c:159
-#: ../lib/vector/Vlib/break_polygons.c:191
-#: ../lib/vector/Vlib/break_polygons.c:198
-msgid "Registering points"
-msgstr "Registrace bodù"
+#: ../lib/gis/color_rules.c:117
+msgid "invalid color name"
+msgstr "neplatný název barvy"
-#: ../lib/vector/Vlib/snap.c:168
-msgid "All vertices"
-msgstr "V¹echny opìrné body"
+#: ../lib/gis/color_rules.c:118
+msgid "percentage not in range 0-100"
+msgstr "procenta nejsou v rozsahu 0-100"
-#: ../lib/vector/Vlib/snap.c:169
-msgid "Registered points"
-msgstr "Registrovaných bodù"
+#: ../lib/gis/color_rules.c:119
+msgid "invalid value"
+msgstr "neplatná hodnota"
-#: ../lib/vector/Vlib/snap.c:214
-msgid "Nodes marked as anchor"
-msgstr "Uzel oznaèen jako fixní"
+#: ../lib/gis/color_rules.c:120
+msgid "unknown error"
+msgstr "neznámá chyba"
-#: ../lib/vector/Vlib/snap.c:215
-msgid "Nodes marked to be snapped"
-msgstr "Uzel oznaèen jako pøipojený"
-#: ../lib/vector/Vlib/snap.c:224 ../lib/vector/Vlib/snap.c:364
-msgid "Snaps"
-msgstr "Pøipojení"
-#: ../lib/vector/Vlib/snap.c:372
-msgid "Snapped vertices"
-msgstr "Pøipojených opìrných bodù"
-#: ../lib/vector/Vlib/snap.c:373
-msgid "New vertices"
-msgstr "Nový opìrný bod"
-#: ../lib/vector/Vlib/close.c:126
+#: ../lib/gis/color_rules.c:152
#, fuzzy, c-format
-msgid "Unable to close vector <%s>"
+msgid "bad rule (%s): [%s]"
+msgstr "chybné pravidlo (%s): %s"
-#: ../lib/vector/Vlib/legal_vname.c:43
+#: ../lib/gis/get_cellhd.c:74 ../lib/gis/get_cellhd.c:103
#, c-format
-msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
-msgstr "Neplatný název vektorové mapy <%s>. Nesmí obsahovat '.' nebo 'NIC'."
+msgid "Unable to read header file for raster map <%s@%s>."
+msgstr "Nelze èíst hlavièkový soubor pro rsatrovou mapu <%s@%s>"
-#: ../lib/vector/Vlib/legal_vname.c:49
+#: ../lib/gis/get_cellhd.c:76
#, c-format
-msgid "Illegal vector map name <%s>. Must start with a letter."
-msgstr "Neplatný název vektorové mapy <%s>. Musí zaèínat písmenem."
+msgid " It is a reclass of raster map <%s@%s> "
+msgstr "Jde o reklasifikaci rastrové mapy <%s@%s> "
-#: ../lib/vector/Vlib/legal_vname.c:56
+#: ../lib/gis/get_cellhd.c:79
#, c-format
-msgid "Illegal vector map name <%s>. Character '%c' not allowed."
-msgstr "Neplatné název vektorové mapy <%s>. Znak <%c> není povolen."
+msgid "which is missing."
+msgstr "jen¾ chybí."
-#: ../lib/vector/Vlib/legal_vname.c:66
+#: ../lib/gis/get_cellhd.c:81
#, c-format
-msgid ""
-"Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
-msgstr ""
-"Neplatné název vektorové mapy <%s>. SQL klíèové slovo nelze pou¾ít jako "
-"název vektorové mapy."
+msgid "whose header file can't be opened."
+msgstr "jeho¾ hlavièkový soubor nelze otevøít."
-#: ../lib/vector/Vlib/legal_vname.c:95 ../lib/vector/Vlib/legal_vname.c:97
+#: ../lib/gis/get_cellhd.c:91
#, c-format
-msgid "Output vector map name <%s> is not valid map name"
-msgstr "Název výstupu <%s> není platným názvem rastrové mapy."
+msgid "Unable to open header file for raster map <%s@%s>"
+msgstr "Nelze otevøít hlavièkový soubor rastrové mapy <%s@%s>"
-#: ../lib/vector/Vlib/legal_vname.c:128 ../lib/vector/Vlib/legal_vname.c:130
+#: ../lib/gis/get_cellhd.c:107
#, c-format
-msgid "Output vector map <%s> is used as input"
-msgstr "Výstupní mapa <%s> je pou¾ita jako vstup."
+msgid " It is a reclass of raster map <%s@%s> whose header file is invalid."
+msgstr ""
+"Jde o reklasifikaci rastrové mapy <%s@%s> její¾ hlavièkový soubor je neplatný"
-#: ../lib/vector/Vlib/cindex.c:30
-msgid "Category index is not up to date"
-msgstr "Index kategorií není aktuální"
-#: ../lib/vector/Vlib/cindex.c:62 ../lib/vector/Vlib/cindex.c:129
-#: ../lib/vector/Vlib/cindex.c:148 ../lib/vector/Vlib/cindex.c:171
-msgid "Invalid layer index (index >= number of layers)"
-msgstr "©patný index vrstvy (index >= poèet vrstev)"
-#: ../lib/vector/Vlib/cindex.c:110
-msgid "Invalid layer index (index < 0 or index >= number of layers)"
-msgstr "©patný index vrstvy (index < 0 nebo index >= poèet vrstev)"
-#: ../lib/vector/Vlib/cindex.c:235
-msgid "Layer or category index out of range"
-msgstr "Index vrstev nebo kategorií mimo rozsah"
-#: ../lib/vector/Vlib/cindex.c:283
-msgid "Layer index out of range"
-msgstr "Index vrstev je mimo rozsah"
-#: ../lib/vector/Vlib/cindex.c:457
+#: ../lib/gis/get_cellhd.c:111
#, c-format
-msgid "Unable to open cidx file <%s> for write"
-msgstr "Nelze otevøít soubor s indexem kategorií <%s> pro zápis"
+msgid " Invalid format."
+msgstr "Neplatný formát."
-#: ../lib/vector/Vlib/cindex.c:465
+#: ../lib/gis/make_colr.c:41
#, c-format
-msgid "Error writing out category index file <%s>"
-msgstr "Chyba pøi zápisu souboru s indexem kategorií <%s>"
+msgid " The raster map %s@%s is empty"
+msgstr " Rastrová mapa %s@%s je prázdná"
-#: ../lib/vector/Vlib/cindex.c:508
+#: ../lib/gis/make_colr.c:49
#, c-format
-msgid "Unable to open category index file for vector map <%s@%s>"
-msgstr "Nelze otevøít soubor s indexem kategorií pro vektorovou mapu <%s@%s>"
-#: ../lib/vector/Vlib/clean_nodes.c:52 ../lib/vector/Vlib/clean_nodes.c:216
-msgid "Modifications"
+msgid ""
+"\n"
+"\n"
+"Color table needed for file [%s] in mapset [%s].\n"
msgstr ""
+"\n"
+"\n"
+"Tabulka barev potøebná pro soubor [%s] v mapsetu [%s].\n"
-#: ../lib/vector/Vlib/read.c:99
-#, fuzzy
-msgid "Vector map is not opened"
-#: ../lib/vector/Vlib/read.c:102
+#: ../lib/gis/make_colr.c:52
#, c-format
msgid ""
-"Vect_read_line(): line %d is not reasonable (max line in vector map: %d)"
+"\n"
+"Please identify the type desired:\n"
msgstr ""
+"\n"
+"Urèete prosím po¾adovaný typ:\n"
-#: ../lib/vector/Vlib/dangles.c:122 ../lib/vector/Vlib/dangles.c:211
-#: ../lib/vector/Vlib/dangles.c:219
-msgid "Removed dangles"
-msgstr ""
-#: ../lib/vector/Vlib/array.c:97
+#: ../lib/gis/make_colr.c:53
#, c-format
-msgid "%d errors in category string."
-msgstr "%d chyb v "
+msgid " 1: Random colors\n"
+msgstr " 1: Náhodné barvy:\n"
-#: ../lib/vector/Vlib/array.c:140 ../lib/vector/Vlib/array.c:255
-#, fuzzy
-msgid "Mixed area and other type requested for vector array"
-msgstr "Smíchané plochy a jiné typy jsou po¾adovány pro vektorové pole."
-#: ../lib/vector/Vlib/array.c:150 ../lib/vector/Vlib/array.c:170
-#: ../lib/vector/Vlib/array.c:289 ../lib/vector/Vlib/array.c:319
-#, fuzzy
-msgid "Not enough space in vector array"
-msgstr "Nedostatek místa ve vektorovém poli."
-#: ../lib/vector/Vlib/array.c:264 ../lib/vector/Vlib/map.c:227
-#: ../lib/vector/Vlib/map.c:340 ../lib/vector/Vlib/map.c:444
-#: ../lib/vector/Vlib/map.c:552 ../lib/vector/Vlib/map.c:639
-#: ../lib/vector/Vlib/net.c:170 ../lib/vector/Vlib/net.c:308
+#: ../lib/gis/make_colr.c:54
#, c-format
-msgid "Database connection not defined for layer %d"
-msgstr "Pro vrstvu %d nebylo definováno databázové pøipojení"
+msgid " 2: Red, green, and blue color ramps\n"
+msgstr " 2: Èervená, zelená a modrá\n"
-#: ../lib/vector/Vlib/array.c:270 ../lib/vector/Vlib/map.c:249
-#: ../lib/vector/Vlib/map.c:376 ../lib/vector/Vlib/map.c:578
-#: ../lib/vector/Vlib/net.c:176 ../lib/vector/Vlib/net.c:313
+#: ../lib/gis/make_colr.c:55
#, c-format
-msgid "Unable to open database <%s> by driver <%s>"
-msgstr "Nelze otevøít databázi <%s> pomocí ovladaèe <%s>"
+msgid " 3: Color wave\n"
+msgstr " 3: Barevná vlna\n"
-#: ../lib/vector/Vlib/array.c:280
-#, fuzzy, c-format
-msgid "Unable to select record from table <%s> (key %s, where %s)"
-msgstr "Nelze vytvoøit index pro tabulku <%s>, klíè <%s>"
-#: ../lib/vector/Vlib/break_polygons.c:200
-#, fuzzy
-msgid "All points (vertices)"
-#: ../lib/vector/Vlib/break_polygons.c:201
-#, fuzzy
-msgid "Registered points (unique coordinates)"
-#: ../lib/vector/Vlib/break_polygons.c:202
-#, fuzzy
-msgid "Points marked for break"
-#: ../lib/vector/Vlib/break_polygons.c:208
-#: ../lib/vector/Vlib/break_polygons.c:272
-#: ../lib/vector/Vlib/break_polygons.c:292
-msgid "Breaks"
-msgstr ""
-#: ../lib/vector/Vlib/bridges.c:118 ../lib/vector/Vlib/bridges.c:191
-#: ../lib/vector/Vlib/bridges.c:197
-msgid "Removed bridges"
-msgstr ""
-#: ../lib/vector/Vlib/poly.c:243
-#, fuzzy
-msgid "Unable to find point in polygon"
-msgstr "nelze nalézt [%s] v [%s]"
-#: ../lib/vector/Vlib/poly.c:661
-#, fuzzy
-msgid "Conditions failed"
-#: ../lib/vector/Vlib/cats.c:46
-msgid "Vect_new_cats_struct(): Out of memory"
-msgstr "Vect_new_cats_struct(): do¹la pamìt"
-#: ../lib/vector/Vlib/cats.c:135
+#: ../lib/gis/make_colr.c:56
#, c-format
-msgid "Too many categories (%d), unable to set cat %d (layer %d)"
-msgstr ""
-"Pøíli¹ mnoho kategorií (%d), není mo¾né nastavit kategorii %d (vrstva %d)"
+msgid " 4: Gray scale\n"
+msgstr " 4: Odstíny ¹edi\n"
-#: ../lib/vector/Vlib/cats.c:398
+#: ../lib/gis/make_colr.c:57
#, c-format
-msgid "Unable to convert category string '%s' (from '%s') to category range"
-msgstr ""
-"Nejsem schopen pøevézt název kategorie '%s' (z '%s') na rozsah kategorií"
+msgid " 5: Aspect\n"
+msgstr " 5: Expozice\n"
-#: ../lib/vector/Vlib/sindex.c:97
-msgid "Not implemented"
-msgstr ""
-#: ../lib/vector/Vlib/sindex.c:108
-#, fuzzy, c-format
-msgid "Unable to delete item %d from spatial index"
-msgstr "Nelze smazat soubor <%s>"
-#: ../lib/vector/Vlib/sindex.c:127
-msgid ""
-"Unable to build spatial index from topology, vector map is not opened at "
-"topo level 2"
-msgstr ""
-#: ../lib/vector/Vlib/sindex.c:169
-msgid "BUG (Vect_build_sidx_from_topo): node does not exist"
-msgstr ""
-#: ../lib/vector/Vlib/sindex.c:180
-msgid "BUG (Vect_build_sidx_from_topo): line does not exist"
-msgstr ""
-#: ../lib/vector/Vlib/sindex.c:198
-msgid "BUG (Vect_build_sidx_from_topo): area does not exist"
-msgstr ""
-#: ../lib/vector/Vlib/sindex.c:216
-msgid "BUG (Vect_build_sidx_from_topo): isle does not exist"
-msgstr ""
-#: ../lib/vector/Vlib/write_nat.c:38
+#: ../lib/gis/make_colr.c:58
#, c-format
-msgid "BUG (delete_area_cats_from_cidx): Area %d does not exist"
-msgstr ""
+msgid " 6: Rainbow colors\n"
+msgstr " 6: Barvy duhy\n"
-#: ../lib/vector/Vlib/write_nat.c:60
+#: ../lib/gis/make_colr.c:59
#, c-format
-msgid "BUG (add_area_cats_to_cidx): Area %d does not exist"
-msgstr ""
+msgid " 7: Red through yellow to green\n"
+msgstr " 7: Od èervené pøes ¾lutou k zelené\n"
-#: ../lib/vector/Vlib/write_nat.c:565
-#, fuzzy
-msgid "Attempt to delete dead line"
-#: ../lib/vector/Vlib/level_two.c:217 ../lib/vector/Vlib/level_two.c:242
-#: ../lib/vector/Vlib/level_two.c:266 ../lib/vector/Vlib/level_two.c:285
-#: ../lib/vector/Vlib/level_two.c:303 ../lib/vector/Vlib/level_two.c:322
-#, fuzzy, c-format
-msgid "Vector map <%s> is not open on level >= 2"
-#: ../lib/vector/Vlib/graph.c:107 ../lib/vector/Vlib/net.c:380
-msgid "GngFlatten error"
-msgstr "Chyba GngFlatten"
-#: ../lib/vector/Vlib/graph.c:137
-#, fuzzy
-msgid "Unable to add network arc"
-msgstr "Nelze pøidat arc sítì"
-#: ../lib/vector/Vlib/graph.c:218 ../lib/vector/Vlib/net.c:449
+#: ../lib/gis/make_colr.c:60
#, c-format
-msgid "dglShortestPath error: %s"
-msgstr ""
+msgid " 8: Green through yellow to red\n"
+msgstr " 8: Od zelené pøes ¾lutou k èervené\n"
-#: ../lib/vector/Vlib/build_nat.c:93
-#, fuzzy
-msgid "Unable to add area (map closed, topo saved)"
-msgstr "Nelze pøidat plochu (mapa uzavøena, topologie ulo¾ena)"
-#: ../lib/vector/Vlib/build_nat.c:101
-#, fuzzy
-msgid "Unable to add isle (map closed, topo saved)"
-msgstr "Nelze pøidat ostrov (mapa uzavøena, topologie ulo¾ena)"
-#: ../lib/vector/Vlib/build_nat.c:110
-msgid "Area of size = 0.0 ignored"
-msgstr "Plocha o velikosti = 0.0 ignorována"
-#: ../lib/vector/Vlib/build_nat.c:147
-msgid "Request to find area outside nonexisting isle"
-msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:485
-msgid "Registering lines: "
-msgstr "Registrace linií: "
-#: ../lib/vector/Vlib/build_nat.c:492
-#, fuzzy
-msgid "Unable to read vector map"
-msgstr "Nelze èíst vektorovou mapu <%s%s>"
-#: ../lib/vector/Vlib/build_nat.c:526
-#, fuzzy
-msgid "Primitives registered"
-msgstr "\r%d primitiv zaregistrováno \n"
-#: ../lib/vector/Vlib/build_nat.c:536
-#, fuzzy
-msgid "Building areas: "
-msgstr "Vytváøení struktury grafu ..."
-#: ../lib/vector/Vlib/build_nat.c:553
-#, fuzzy
-msgid "Areas built"
-msgstr "Struktura grafu sestavena"
-msgid "Isles built"
-msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:561
-msgid "Attaching islands: "
-msgstr "Pøidávání ostrovù: "
-#: ../lib/vector/Vlib/build_nat.c:576
-msgid "Attaching centroids: "
-msgstr "Pøipojování centroidù: "
-#: ../lib/vector/Vlib/open_nat.c:143
+#: ../lib/gis/make_colr.c:61
#, c-format
-msgid ""
-"Coor files of vector map <%s@%s> is larger than it should be (%ld bytes "
-"excess)"
-msgstr ""
+msgid "RETURN quit\n"
+msgstr "RETURN konec\n"
-#: ../lib/vector/Vlib/open_nat.c:146
+#: ../lib/gis/make_colr.c:82
#, c-format
msgid ""
-"Coor files of vector <%s@%s> is shorter than it should be (%ld bytes "
-"missing)."
+"\n"
+"%s invalid; Try again > "
msgstr ""
+"\n"
+"%s neplatné; Zkuste to znova > "
-#: ../lib/vector/Vlib/build_ogr.c:257
-#, fuzzy, c-format
-msgid "Unable to calculate centroid for area %d"
-msgstr "Nemohu urèit centroid pro plochu %d"
+#: ../lib/gis/alloc.c:42
+msgid "G_malloc: out of memory"
+msgstr "G_malloc: do¹la pamì»"
-#: ../lib/vector/Vlib/build_ogr.c:292 ../lib/vector/Vlib/read_ogr.c:112
-#: ../lib/vector/Vlib/read_ogr.c:285
-#, fuzzy, c-format
-msgid "OGR feature type %d not supported"
-msgstr "Typ prvku OGR %d není podporován)"
+#: ../lib/gis/alloc.c:75
+msgid "G_calloc: out of memory"
+msgstr "G_calloc: do¹la pamìt"
-#: ../lib/vector/Vlib/build_ogr.c:318
-msgid "Partial build for OGR is not supported"
-msgstr ""
+#: ../lib/gis/alloc.c:111
+msgid "G_realloc: out of memory"
+msgstr "G_realloc: do¹la pamì»"
-#: ../lib/vector/Vlib/build_ogr.c:329
-msgid ""
-"Random read is not supported by OGR for this layer, cannot build support"
-msgstr ""
+#: ../lib/gis/gishelp.c:49
+#, c-format
+msgid "one moment...\n"
+msgstr "momentíèek...\n"
-#: ../lib/vector/Vlib/build_ogr.c:336
-#, fuzzy
-msgid "Feature: "
-msgstr "Typ(y) vektorových objektù"
-#: ../lib/vector/Vlib/build_ogr.c:354
+#: ../lib/gis/gishelp.c:54
#, c-format
-msgid "Feature %d without geometry ignored"
-msgstr "Prvek %d bez geometrie je ignorován"
+msgid "No help available for command [%s]\n"
+msgstr "Nápovìda pro pøíkaz [%s] není dostupná\n"
-#: ../lib/vector/Vlib/build_ogr.c:361
-#, fuzzy
-msgid "OGR feature without ID ignored"
-msgstr "Prvek OGR bez ID je ignorován."
+#: ../lib/gis/myname.c:51
+msgid "Unknown Location"
+msgstr "Neznámá Location"
-#: ../lib/vector/Vlib/level.c:39
-#, fuzzy
-msgid "Map structure was never initialized"
-msgstr "Vektorová struktura nebyla inicializována"
+#: ../lib/gis/proj2.c:49
+msgid "Latitude-Longitude"
+msgstr "Zemìpisná ¹íøka a délka"
-#: ../lib/vector/Vlib/level.c:41
-msgid "Map structure has been closed"
-msgstr ""
+#: ../lib/gis/proj2.c:51
+msgid "Other Projection"
+msgstr "Ostatní mapové projekce"
-#: ../lib/vector/Vlib/area.c:55
-#, fuzzy
-msgid "Attempt to read points of nonexisting area"
+#: ../lib/gis/home.c:40
+msgid "unable to determine user's home directory"
+msgstr "nelze urèit domovský adresáø u¾ivatele"
-#: ../lib/vector/Vlib/area.c:131
-#, fuzzy, c-format
-msgid "Unable to read line %d"
+#: ../lib/gis/get_ellipse.c:87
+#, c-format
+msgid "Unable to open file %s in <%s>"
+msgstr "Nelze otevøít soubor %s v <%s>"
-#: ../lib/vector/Vlib/area.c:173 ../lib/vector/Vlib/area.c:205
-#: ../lib/vector/Vlib/area.c:274 ../lib/vector/Vlib/area.c:307
-#, fuzzy, c-format
-msgid "Attempt to read topo for dead area (%d)"
-msgstr "Pokus èíst mrtvou linii [%d]"
-#: ../lib/vector/Vlib/area.c:335
-#, fuzzy, c-format
-msgid "Attempt to read topo for dead isle (%d)"
-#: ../lib/vector/Vlib/open_ogr.c:54
-msgid "OGR format cannot be updated"
-msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:66
-#, fuzzy, c-format
-msgid "Unable to open OGR data source '%s'"
-msgstr "Nelze otevøít adresáø <%s>"
-#: ../lib/vector/Vlib/open_ogr.c:84
-#, fuzzy, c-format
-msgid "Unable to open layer <%s>"
-msgstr "Nelze otevøít soubor %s"
-#: ../lib/vector/Vlib/open_ogr.c:128
-#, fuzzy, c-format
-msgid "Unable to open fidx file for vector map <%s@%s>"
-#: ../lib/vector/Vlib/open_ogr.c:144
+#: ../lib/gis/get_ellipse.c:296 ../lib/proj/ellipse.c:213
#, c-format
-msgid ""
-"Feature index format version %d.%d is not supported by this release. Try to "
-"rebuild topology or upgrade GRASS."
-msgstr ""
+msgid "Unable to open ellipsoid table file <%s>"
+msgstr "Nelze otevøít soubor s tabulkou ref. elipsoidu: <%s>"
-#: ../lib/vector/Vlib/open_ogr.c:148
+#: ../lib/gis/get_ellipse.c:345
#, c-format
-msgid ""
-"Your GRASS version does not fully support feature index format %d.%d of the "
-"vector. Consider to rebuild topology or upgrade GRASS."
-msgstr ""
+msgid "Lines%s of ellipsoid table file <%s> are invalid"
+msgstr "Øádky%s v souboru s tabulkou elipsoidu <%s> jsou neplatné"
-#: ../lib/vector/Vlib/remove_areas.c:56 ../lib/vector/Vlib/remove_areas.c:168
-msgid "Removed areas"
-msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:93
-msgid "Area is composed of dead boundary"
-msgstr ""
-#: ../lib/vector/Vlib/remove_duplicates.c:67
-#: ../lib/vector/Vlib/remove_duplicates.c:129
-#, fuzzy
-msgid "Duplicates"
-msgstr "duplicitní polo¾ka pro východ"
-#, fuzzy
-msgid "Input vector map is not open"
-#: ../lib/vector/Vlib/map.c:65 ../lib/vector/Vlib/map.c:78
-#, fuzzy, c-format
-msgid "Unable to read vector map <%s>"
-#: ../lib/vector/Vlib/map.c:199 ../lib/vector/Vlib/map.c:308
+#: ../lib/gis/get_ellipse.c:346
#, c-format
-msgid "Unable to copy vector map <%s> to <%s>"
-msgstr "Nelze kopírovat vektorovou mapu <%s> do <%s>"
+msgid "Line%s of ellipsoid table file <%s> is invalid"
+msgstr "Øádek%s v souboru s tabulkou elipsoidu <%s> je neplatný"
-#: ../lib/vector/Vlib/map.c:241 ../lib/vector/Vlib/map.c:355
-#: ../lib/vector/Vlib/map.c:572 ../lib/vector/Vlib/map.c:665
+#: ../lib/gis/get_ellipse.c:365 ../lib/gis/get_ellipse.c:391
#, c-format
-msgid "Unable to copy table <%s>"
-msgstr "Nelze kopírovat tabulku <%s>"
+msgid "Invalid a: field '%s' in file %s in <%s>"
+msgstr "Neplatné a: polo¾ka '%s' v souboru %s v <%s>"
-#: ../lib/vector/Vlib/map.c:253 ../lib/vector/Vlib/map.c:380
-#: ../lib/vector/Vlib/map.c:582
+#: ../lib/gis/get_ellipse.c:378
#, c-format
-msgid "Unable to create index for table <%s>, key <%s>"
+msgid "Invalid ellipsoid '%s' in file %s in <%s>"
+msgstr "Neplatný ref. elipsoid '%s' v souboru %s v <%s>"
-#: ../lib/vector/Vlib/map.c:369 ../lib/vector/Vlib/map.c:462
+#: ../lib/gis/get_ellipse.c:395
#, c-format
-msgid "Unable to delete table <%s>"
-msgstr "Nelze smazat tabulku <%s>"
+msgid "Invalid es: field '%s' in file %s in <%s>"
+msgstr "Neplatné es: polo¾ka '%s' v souboru %s v <%s>"
-#: ../lib/vector/Vlib/map.c:417
-#, fuzzy, c-format
-msgid "Invalid vector map name <%s>"
-#: ../lib/vector/Vlib/map.c:433
-#, fuzzy, c-format
-msgid "Unable to open header file for vector map <%s>"
-#: ../lib/vector/Vlib/map.c:453
+#: ../lib/gis/get_ellipse.c:409
#, c-format
-msgid "Unable to find table <%s> linked to vector map <%s>"
-msgstr "Nelze nelézt tabulku <%s> pøipojenou k vektorové mapì <%s>"
+msgid "No ellipsoid info given in file %s in <%s>"
+msgstr "V souboru %s v <%s> chybí informace o ref. elipsoidu"
-#: ../lib/vector/Vlib/map.c:467
-#, fuzzy, c-format
-msgid "Table <%s> linked to vector map <%s> does not exist"
-#: ../lib/vector/Vlib/map.c:481
+#: ../lib/gis/view.c:180
#, c-format
-msgid "Unable to open directory '%s'"
+msgid "Unable to open %s for writing"
+msgstr "Nelze otevøít %s pro zápis"
-#: ../lib/vector/Vlib/map.c:492
+#: ../lib/gis/view.c:269 ../lib/gis/view.c:486
#, c-format
-msgid "Unable to delete file '%s'"
+msgid "Unable to open %s for reading"
+msgstr "Nelze otevøít %s pro ètení"
-#: ../lib/vector/Vlib/map.c:509
+#: ../lib/gis/view.c:472
#, c-format
-msgid "Unable to rename directory '%s' to '%s'"
-msgstr "Nelze pøejmenovat adresáø '%s' na '%s'"
+msgid "GRASS window when view was saved:\n"
+msgstr "Okno GRASSu kdy¾ byl ulo¾en pohled:\n"
-#: ../lib/vector/Vlib/map.c:517
+#: ../lib/gis/view.c:547
#, c-format
-msgid "Unable to remove directory '%s'"
-msgstr "Nelze smazat adresáø '%s'"
+msgid " Window saved in \"%s\" is completely outside of current GRASS window."
+msgstr " Okno ulo¾eno v \"%s\" je zcela mimo aktuální okno GRASSu."
-#: ../lib/vector/Vlib/map.c:564 ../lib/vector/Vlib/map.c:653
+#: ../lib/gis/view.c:550
#, c-format
-msgid "Unable to add database link for vector map <%s>"
-msgstr "Nelze pøipojit databázi k vektorové mapì <%s>"
-#: ../lib/vector/Vlib/read_nat.c:146
-#, fuzzy
-msgid "Attempt to read dead line"
-#: ../lib/vector/Vlib/overlay.c:76
-#, fuzzy
-msgid "Unknown operator"
-msgstr "neznámá chyba"
-#: ../lib/vector/Vlib/overlay.c:124
-msgid "Overlay: line/boundary types not supported by AND operator"
-msgstr ""
-#: ../lib/vector/Vlib/overlay.c:127
-msgid "Overlay: area x area types not supported by AND operator"
-msgstr ""
-#: ../lib/vector/Vlib/read_ogr.c:165
-#, fuzzy
-msgid "OGR feature without ID"
-msgstr "Prvek OGR bez ID."
-#: ../lib/vector/Vlib/read_ogr.c:352 ../lib/vector/Vlib/read_ogr.c:359
-#, fuzzy, c-format
-msgid "Unable to get feature geometry, FID %ld"
-msgstr "Nelze pøeèíst prvky geometrie, FID [%ld]"
-#: ../lib/vector/Vlib/field.c:90
-#, fuzzy
-msgid "Layer number must be 1 or greater"
-msgstr "Èíslo polo¾ky musí být vìt¹í nebo rovno 1."
-#: ../lib/vector/Vlib/field.c:95
-#, fuzzy
-msgid "Unable to add database link, map is not opened in WRITE mode"
-msgstr "Nelze pøidat spojení s databází, mapa není otevøena v módu pro ZÁPIS."
-#: ../lib/vector/Vlib/field.c:101
-#, fuzzy
-msgid "Unable to add database link"
-msgstr "Nelze pøidat spojení s databází."
-#: ../lib/vector/Vlib/field.c:107 ../lib/vector/Vlib/field.c:153
-#, fuzzy
-msgid "Unable to write database links"
-msgstr "Nelze zapsat spojení s databází."
-#: ../lib/vector/Vlib/field.c:221
-#, fuzzy, c-format
-msgid "Layer number %d or name <%s> already exists"
-msgstr "Pole s èíslem <%d> nebo názvem <%s> ji¾ existuje."
-#: ../lib/vector/Vlib/field.c:285
msgid ""
-"Default driver / database set to:\n"
-"driver: dbf\n"
-"database: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/"
-msgstr ""
-"Výchozí ovladaè / databáze nastavena na:\n"
-"ovladaè: dbf\n"
-"databáze: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/"
+" Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
+msgstr " Pouze %d%% z okna ulo¾eného v \"%s\" pokrývá aktuální okno GRASSu."
-#: ../lib/vector/Vlib/field.c:295
-msgid "Default driver is not set"
-msgstr "Výchozí ovladaè není nastaven"
+#: ../lib/gis/get_projinfo.c:36 ../lib/gis/get_projinfo.c:67
+#, c-format
+msgid "<%s> file not found for location <%s>"
+msgstr "soubor <%s> nebyl nalezen v location <%s>"
-#: ../lib/vector/Vlib/field.c:297
-msgid "Default database is not set"
-msgstr "Výchozí databáze není nastavena"
+#: ../lib/gis/get_projinfo.c:43 ../lib/gis/get_projinfo.c:74
+#, c-format
+msgid "ERROR in reading <%s> file for location <%s>"
+msgstr "CHYBA pøi ètení souboru <%s> v location <%s>"
-#: ../lib/vector/Vlib/field.c:352
+#: ../lib/gis/get_datum_name.c:53
#, c-format
-msgid "Requested dblink %d, maximum link number %d"
-msgstr "Po¾adovaný dblink %d, maximální poèet spojení %d"
-#: ../lib/vector/Vlib/field.c:487
-#, fuzzy
-msgid "Unable to open OGR DBMI driver"
-msgstr "Nelze otevøít ovladaè pro OGR DBMI"
-#: ../lib/vector/Vlib/field.c:516
msgid ""
-"All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' "
-"available in OGR DB table"
+"\n"
+"Please specify datum name\n"
msgstr ""
+"\n"
+"Specifikujte prosím vý¹kový systém (datum)\n"
-#: ../lib/vector/Vlib/field.c:557
+#: ../lib/gis/get_datum_name.c:54
#, c-format
-msgid "Don't know how to read links for format %d"
-msgstr "Neznámo jak pøeèíst linky pro formát %d"
+msgid "Enter 'list' for the list of available datums\n"
+msgstr "Zadejte 'list' pro výpis dostupných vý¹kových systémù (datumù)\n"
-#: ../lib/vector/Vlib/field.c:585
+#: ../lib/gis/get_datum_name.c:55
#, c-format
-msgid "Error in rule on row %d in %s"
-msgstr "Chyba v pravidlu na øádku %d v %s"
+msgid "or 'custom' if you wish to enter custom parameters\n"
+msgstr "nebo 'custom' pokud si pøejete vlo¾it volitelné parametry\n"
-#: ../lib/vector/Vlib/field.c:636
-#, fuzzy, c-format
-msgid "Unable to open vector database definition file '%s'"
-msgstr "nelze otevøít soubor s vý¹kovým systémem (datum): %s"
-#: ../lib/vector/Vlib/field.c:721
-#, fuzzy
-msgid "Bug: attempt to update map which is not in current mapset"
-msgstr "Bug: pokus o aktualizaci mapy, která není v aktuálním mapsetu."
-#: ../lib/vector/Vlib/net.c:119
-#, fuzzy
-msgid "Building graph..."
-#: ../lib/vector/Vlib/net.c:155
-#, fuzzy
-msgid "Unable to build network graph"
-msgstr "Nelze sestavit strukturu grafu"
-#: ../lib/vector/Vlib/net.c:161
-msgid "Forward costs column not specified"
-msgstr "Sloupec pro váhu smìr dopøedu není specifikován"
-#: ../lib/vector/Vlib/net.c:167
-msgid "Arc field < 1"
-msgstr "Arc vrtsva < 1"
-#: ../lib/vector/Vlib/net.c:181 ../lib/vector/Vlib/net.c:196
-#: ../lib/vector/Vlib/net.c:318
-#, fuzzy, c-format
-msgid "Column <%s> not found in table <%s>"
-#: ../lib/vector/Vlib/net.c:187 ../lib/vector/Vlib/net.c:202
-#: ../lib/vector/Vlib/net.c:324
-#, fuzzy, c-format
-msgid "Data type of column <%s> not supported (must be numeric)"
-msgstr "Datový typ sloupce z není podporován (musí být interger nebo double)"
-#: ../lib/vector/Vlib/net.c:213
-#, fuzzy
-msgid "Registering arcs..."
-msgstr "Registrace arcs ..."
-#: ../lib/vector/Vlib/net.c:235
+#: ../lib/gis/get_datum_name.c:93
#, c-format
msgid ""
-"Database record for line %d (cat = %d, forward/both direction(s)) not found "
-"(forward/both direction(s) of line skipped)"
+"\n"
+"invalid datum\n"
msgstr ""
-"Datová polo¾ka pro linii %d (cat = %d, dopøedu/oba smìry nebyla nalezena"
-"(dopøedu/oba smìry linie pøeskoèeny)"
+"\n"
+"neplatný vý¹kový systém (datum)\n"
-#: ../lib/vector/Vlib/net.c:249
+#: ../lib/gis/ask.c:339
+msgid "to cancel request"
+msgstr "pro zru¹ení po¾adavku"
+#: ../lib/gis/ask.c:395
#, c-format
-msgid ""
-"Database record for line %d (cat = %d, backword direction) not found"
-"(direction of line skipped)"
-msgstr ""
-"Datová polo¾ka pro linii %d (cat = %d, smìr dozadu) nebyla nalezena(smìr "
-"linie pøeskoèen)"
+msgid "Enter a new %s file name"
+msgstr "Zadejte název nového %s souboru"
-#: ../lib/vector/Vlib/net.c:282
-msgid "Cannot add network arc"
+#: ../lib/gis/ask.c:401
+#, c-format
+msgid "Enter the name of an existing %s file"
+msgstr "Zadejte název existujícího %s souboru"
-#: ../lib/vector/Vlib/net.c:304
-#, fuzzy
-msgid "Setting node costs..."
-msgstr "Nastavení váhy uzlù ..."
-#: ../lib/vector/Vlib/net.c:353
+#: ../lib/gis/ask.c:405
#, c-format
-msgid "Database record for node %d (cat = %d) not found (cost set to 0)"
-msgstr ""
-"Datový záznam pro uzel %d (cat = %d) nebyl nalezen (váha nastavena na 0)"
+msgid "Enter %s file name"
+msgstr "Zadatejte název %s souboru"
-#: ../lib/vector/Vlib/net.c:377
-#, fuzzy
-msgid "Flattening the graph..."
-msgstr "Zpracování grafu ..."
-#: ../lib/vector/Vlib/net.c:387
-msgid "Graph was built"
-#: ../lib/vector/Vlib/net.c:525
-msgid "Wrong line direction in Vect_net_get_line_cost()"
-msgstr "Chybný smìr linie ve Vect_net_get_line_cost()"
-#: ../lib/vector/Vlib/line.c:61
-#, fuzzy
-msgid "Out of memory"
-msgstr "G_malloc: do¹la pamì»"
-#: ../lib/vector/Vlib/line.c:205 ../lib/vector/Vlib/line.c:237
-#, fuzzy
-msgid "Index out of range in"
-#: ../lib/vector/Vlib/line.c:522
-msgid "Segment outside line, no segment created"
-msgstr ""
-#: ../lib/vector/Vlib/header.c:100 ../lib/vector/Vlib/header.c:149
-#, fuzzy, c-format
-msgid "Unable to open header file of vector <%s>"
-#: ../lib/vector/Vlib/header.c:156
+#: ../lib/gis/ask.c:425
#, c-format
-msgid "Corrupted row in head: %s"
-msgstr ""
+msgid "Enter 'list' for a list of existing %s files\n"
+msgstr "Zadejte 'list' pro výpis existujících %s souborù\n"
-#: ../lib/vector/Vlib/header.c:187
-#, fuzzy, c-format
-msgid "Unknown keyword %s in vector head"
-msgstr "Neznámý vektorový typ"
-#: ../lib/vector/Vlib/header.c:533 ../lib/gis/proj3.c:66
-msgid "Unknown projection"
-msgstr "Neznámá mapová projekce"
-#: ../lib/vector/Vlib/write.c:25 ../lib/vector/Vlib/write.c:29
-#: ../lib/vector/Vlib/write.c:33
-#, fuzzy
-msgid "for this format/level not supported"
-msgstr "Vect_write_line() pro tento formát/úroveò není podporován"
-#: ../lib/vector/Vlib/write.c:96
-#, fuzzy
-msgid "Unable to write line, vector map is not opened"
-msgstr "Nelze zapsat linii, mapa není otevøena"
-#: ../lib/vector/Vlib/write.c:107
-#, fuzzy
-msgid "Unable to write line (negative offset)"
-msgstr "Nelze zapsat linii (záporný offset)"
-#: ../lib/vector/Vlib/write.c:143
-#, fuzzy
-msgid "Unable to rewrite line, vector map is not opened"
-msgstr "Nelze pøepsat linii, mapa není otevøena"
-#: ../lib/vector/Vlib/write.c:154
-#, fuzzy, c-format
-msgid "Unable to rewrite line %d"
-#: ../lib/vector/Vlib/write.c:201
-#, fuzzy, c-format
-msgid "Unable to delete line %d, vector map <%s> is not opened on topo level 2"
-msgstr "Nelze odstranit linii, mapa '%s' není otevøena na úrovni 2"
-#: ../lib/vector/Vlib/write.c:206
-#, fuzzy, c-format
-msgid "Unable to delete line %d, vector map <%s> is not opened in 'write' mode"
-msgstr "Nelze odstranit linii, mapa '%s' není otevøena v módu pro 'zápis'"
-#: ../lib/vector/Vlib/write.c:219
-#, fuzzy, c-format
-msgid "Unable to delete line %d from vector map <%s>"
-#: ../lib/vask/V_support.c:58
+#: ../lib/gis/ask.c:428
#, c-format
-msgid "Unable to open file %s"
+msgid "Enter 'list -f' for "
+msgstr "Zadejte 'list -f' pro"
-#: ../lib/proj/get_proj.c:149
+#: ../lib/gis/ask.c:430
#, c-format
-msgid "Invalid zone %s specified"
-msgstr "Specifikována naplatná zóna %s"
+msgid "a list %s"
+msgstr "výpis %s"
-#: ../lib/proj/get_proj.c:228
-msgid "Unable to initialise PROJ.4 with the following parameter list:"
-msgstr "Nelze inicializovat PROJ.4 s následujícími parametry:"
-#: ../lib/proj/get_proj.c:235
+#: ../lib/gis/ask.c:432
#, c-format
-msgid "The error message: %s"
-msgstr "Chybová zpráva: %s"
+msgid "an extended list"
+msgstr "roz¹íøený výpis"
-#: ../lib/proj/get_proj.c:294
-msgid "Option input overflowed option table"
-msgstr "Nelze alokovat pamì»"
-#: ../lib/proj/get_proj.c:325
+#: ../lib/gis/ask.c:436
#, c-format
-msgid "Unable to initialize pj cause: %s"
-msgstr "Nelze inicializovat pj: %s"
+msgid "Hit RETURN %s\n"
+msgstr "Stisknìte RETURN %s\n"
-#: ../lib/proj/get_proj.c:400
-msgid "Input Projection Parameters"
-msgstr "Parametry vstupní projekce"
-#: ../lib/proj/get_proj.c:402
-msgid "Input Unit Factor"
-msgstr "Vstupní jednotkový faktor"
-#: ../lib/proj/get_proj.c:411
-msgid "Output Projection Parameters"
-#: ../lib/proj/get_proj.c:413
-msgid "Output Unit Factor"
-#: ../lib/proj/datum.c:252
-#, fuzzy
-msgid "Unable to open temporary file"
-#: ../lib/proj/datum.c:337 ../lib/gis/get_ell_name.c:46
-#: ../lib/gis/get_datum_name.c:56 ../lib/gis/get_projname.c:51
+#: ../lib/gis/ask.c:458 ../lib/gis/ask.c:565 ../lib/gis/ask.c:587
#, c-format
-msgid "Hit RETURN to cancel request\n"
-msgstr "Pro ukonèení po¾adavku stisknìte RETURN\n"
-#: ../lib/proj/datum.c:408 ../lib/proj/datum.c:471
-#, fuzzy, c-format
-msgid "Unable to open datum table file <%s>"
-#: ../lib/proj/datum.c:421 ../lib/proj/datum.c:485
-#, fuzzy, c-format
-msgid "Error in datum table file <%s>, line %d"
-msgstr "chyba v souboru obsahující vý¹kový systém (datum), na øádku %d"
-#: ../lib/proj/convert.c:107
-#, fuzzy
-msgid "Unable parse GRASS PROJ_INFO file"
-msgstr "Nelze parsovat soubor GRASS PROJ_FILE"
-#: ../lib/proj/convert.c:112
-#, fuzzy
-msgid "Unable get PROJ.4-style parameter string"
-msgstr "Nelze získat parametr ve stylu PROJ.4"
-#: ../lib/proj/convert.c:124
-#, fuzzy, c-format
msgid ""
-"OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
+"\n"
+"** %s - not found **\n"
msgstr ""
-"OGR se nepodaøilo parsovat parametr ve stylu PROJ.4:\n"
-"%s\n"
-"(kód OGR chyba je %d)"
+"\n"
+"** %s - nenalezeno **\n"
-#: ../lib/proj/convert.c:130
-#, fuzzy, c-format
-msgid "OGR can't get WKT-style parameter string (OGR Error code was %d)"
-msgstr ""
-"OGR se nepoøilo získat parametr ve stylu WKT\n"
-"(kód OGR chyby je %d)"
-#: ../lib/proj/convert.c:391
-msgid "No projection name! Projection parameters likely to be meaningless."
-msgstr ""
-"Nebyl definován název kartografické projekce! Parametry projekce nemají "
-"význam."
-#: ../lib/proj/convert.c:428
-#, fuzzy, c-format
-msgid "Datum <%s> not recognised by GRASS and no parameters found"
-msgstr ""
-"Geodetické datum <%s> nebylo GRASS rozpoznáno a nebyly nalezeny ¾ádné "
-"parametry."
-#: ../lib/proj/convert.c:445
+#: ../lib/gis/ask.c:465 ../lib/gis/ask.c:551
#, c-format
msgid ""
-"Datum <%s> apparently recognised by GRASS but no parameters found. You may "
-"want to look into this."
+"\n"
+"** %s exists. ok to overwrite? "
msgstr ""
-"Geodetické datum <%s> bylo zjevnì GRASSem rozpoznáno, nicménì nebyly "
-"nalezeny parametry. Zkontrolujte nastavení."
+"\n"
+"** %s existuje. Pøepsat? "
-#: ../lib/proj/convert.c:450
+#: ../lib/gis/ask.c:511
#, c-format
msgid ""
-"Invalid tranformation number %d; valid range is 1 to %d. Leaving datum "
-"transform parameters unspecified."
+"\n"
+"**<%s> illegal name **\n"
msgstr ""
-"Neplatný identifikátor transformace %d; platný rozsah je od 1 do %d. "
-"Geodetické datum zùstane nespecifikováno."
+"\n"
+"**<%s> neplatné jméno **\n"
-#: ../lib/proj/do_proj.c:105 ../lib/proj/do_proj.c:178
+#: ../lib/gis/ask.c:526
#, c-format
-msgid "pj_transform() failed: %s"
-msgstr ""
-#: ../lib/proj/ellipse.c:73
-#, fuzzy, c-format
-msgid "Invalid ellipsoid <%s> in file"
-msgstr "neplatný referenèní elipsoid %s v souboru"
-#: ../lib/proj/ellipse.c:96
-msgid "No secondary ellipsoid descriptor (rf, es or b) in file"
-msgstr ""
-#: ../lib/proj/ellipse.c:100
-#, fuzzy
-msgid "Invalid ellipsoid descriptors (a, rf, es or b) in file"
-#: ../lib/proj/ellipse.c:114
-msgid "No ellipsoid info given in file"
-msgstr "V souboru není uveden ¾ádný referenèní elipsoid"
-#: ../lib/proj/ellipse.c:212 ../lib/gis/get_ellipse.c:296
-#, fuzzy, c-format
-msgid "Unable to open ellipsoid table file <%s>"
-msgstr "nelze otevøít soubor s tabulkou ref. elipsoidu: %s"
-#: ../lib/g3d/g3dparam.c:54
-msgid "Data type used in the output file"
-msgstr "Datový typ pou¾itý ve výstupním souboru"
-#: ../lib/g3d/g3dparam.c:63
-msgid "Precision used in the output file (default, max, or 0 to 52)"
-msgstr ""
-"Pøesnost pou¾itá ve výstupním souboru (výchozí, maximální nebo 0 a¾ 52)"
-#: ../lib/g3d/g3dparam.c:73
-msgid "The compression method used in the output file"
-msgstr "Metoda komprese pou¾itá ve výstupním souboru"
-#: ../lib/g3d/g3dparam.c:83
-msgid "The dimensions of the tiles used in the output file"
-msgstr "Dimenze dla¾dic pou¾itá ve výstupním souboru"
-#: ../lib/g3d/g3dparam.c:118
-msgid "G3d_getStandard3dParams: precision value invalid"
-msgstr "G3d_getStandard3dParams: hodnota pøesnosti není platná"
-#: ../lib/g3d/g3dparam.c:146
-msgid "G3d_getStandard3dParams: tile dimension value invalid"
-msgstr "G3d_getStandard3dParams: dimeze dla¾dic není platná"
-#: ../lib/g3d/g3dparam.c:171
-msgid "Window replacing the default"
-msgstr "Výøez zamìní výchozí"
-#: ../lib/g3d/g3dopen.c:22
-msgid "G3d_openCellOldNoHeader: error in G3d_maskOpenOld"
-msgstr "G3d_openCellOldNoHeader: chyba v G3d_maskOpenOld"
-#: ../lib/g3d/g3dopen.c:28
-msgid "G3d_openCellOldNoHeader: error in G3d_malloc"
-msgstr "G3d_openCellOldNoHeader: chyba v G3d_malloc"
-#: ../lib/g3d/g3dopen.c:46
-msgid "G3d_openCellOldNoHeader: error in G_open_old"
-msgstr "G3d_openCellOldNoHeader: chyba v G_open_old"
-#: ../lib/g3d/g3dopen.c:101
-msgid "G3d_openCellOld: error in G3d_openCellOldNoHeader"
-msgstr "G3d_openCellOld: chyba v G3d_openCellOldNoHeader"
-#: ../lib/g3d/g3dopen.c:106
-msgid "G3d_openCellOld: can't rewind file"
-msgstr "G3d_openCellOld: nemohu znovu natáhnoutsoubor"
-#: ../lib/g3d/g3dopen.c:119
-msgid "G3d_openCellOld: error in G3d_readHeader"
-msgstr "G3d_openCellOld: chyba v G3d_readHeader"
-#: ../lib/g3d/g3dopen.c:126
-msgid "G3d_openCellOld: projection does not match window projection"
-msgstr "G3d_openCellOld: projekce mapy neodpovídá projekci okna"
-#: ../lib/g3d/g3dopen.c:130
-msgid "G3d_openCellOld: zone does not match window zone"
-msgstr "G3d_openCellOld: zóna neodpovídá zónì okna"
-#: ../lib/g3d/g3dopen.c:142 ../lib/g3d/g3dopen.c:159
-msgid "G3d_openCellOld: can't read header"
-msgstr "G3d_openCellOld: nemohu pøeèíst hlavièku"
-#: ../lib/g3d/g3dopen.c:148
-msgid "G3d_openCellOld: index does not fit into long"
-msgstr "G3d_openCellOld: index neodpovídá typu long"
-#: ../lib/g3d/g3dopen.c:152
-msgid "G3d_openCellOld: error in G3d_malloc"
-msgstr "G3d_openCellOld: chyba v G3d_malloc"
-#: ../lib/g3d/g3dopen.c:179
-msgid "G3d_openCellOld: error in G3d_fillHeader"
-msgstr "G3d_openCellOld: chyba v G3d_fillHeader"
-#: ../lib/g3d/g3dopen.c:227
-msgid "G3d_openCellNew: error in G3d_maskOpenOld"
-msgstr "G3d_openCellNew: chyba v G3d_maskOpenOld"
-#: ../lib/g3d/g3dopen.c:236
-msgid "G3d_openCellNew: error in G3d_malloc"
-msgstr "G3d_openCellNew: chyba v G3d_malloc"
-#: ../lib/g3d/g3dopen.c:249
-msgid "G3d_openCellNew: could not open file"
-msgstr "G3d_openCellNew: nemohu otevøít soubor"
-#: ../lib/g3d/g3dopen.c:291 ../lib/g3d/g3dopen.c:296
-msgid "G3d_openCellNew: can't write header"
-msgstr "G3d_openCellNew: nemohu ulo¾it hlavièku"
-#: ../lib/g3d/g3dopen.c:319
-msgid "G3d_openCellNew: error in G3d_fillHeader"
-msgstr "G3d_openCellNew: chyba v G3d_fillHeader"
-#: ../lib/g3d/g3dhistory.c:46 ../lib/gis/history.c:134
-#, c-format
-msgid "can't get history information for [%s] in mapset [%s]"
-msgstr "nelze získat informace o historii pro [%s] v mapsetu [%s]"
-#: ../lib/gis/get_ell_name.c:33 ../lib/gis/get_datum_name.c:67
-#: ../lib/gis/get_projname.c:39
-msgid "Cannot open temp file"
-msgstr "Nelze otevøít doèasný soubor"
-#: ../lib/gis/get_ell_name.c:44
-#, c-format
msgid ""
"\n"
-"Please specify ellipsoid name\n"
+"** %s - illegal request **\n"
msgstr ""
"\n"
-"Specifikujte prosím referenèní elipsoid\n"
+"** %s - neplatný po¾adavek **\n"
-#: ../lib/gis/get_ell_name.c:45
+#: ../lib/gis/ask.c:541
#, c-format
-msgid "Enter 'list' for the list of available ellipsoids\n"
-msgstr "Zadejte 'list' pro výpis dostupných ref. elipsoidù\n"
-#: ../lib/gis/get_ell_name.c:65
-#, c-format
msgid ""
"\n"
-"invalid ellipsoid\n"
+"** %s - exists, select another name **\n"
msgstr ""
"\n"
-"neplatný ref. elipsoid\n"
+"** %s - existuje, zvolte jiné jméno **\n"
-#: ../lib/gis/sample.c:81
-#, fuzzy
-msgid "Unknown interpolation type"
-msgstr "Neznámý zpùsob interpolace"
+#: ../lib/gis/ask.c:569
+msgid "ask: can't happen"
+msgstr "ask: nemù¾e nastat"
-#: ../lib/gis/sample.c:467
-msgid "\"no data\" label found; setting to zero"
-msgstr "nalezen prazdny retezec v popisu; nastavuji na nula"
-#: ../lib/gis/sample.c:481
-#, fuzzy
-msgid "Problem reading raster map"
-msgstr "Potí¾e pøi ètení souboru cell (rastrová data)"
-#: ../lib/gis/put_cellhd.c:26
+#: ../lib/gis/location.c:46
#, c-format
-msgid "Unable to create header file for [%s]"
-msgstr "Nelze vytvoøit hlavièkový soubor pro [%s]"
+msgid "LOCATION << %s >> not available"
+msgstr "LOCATION << %s >> není dostupná"
-#: ../lib/gis/legal_name.c:38
+#: ../lib/gis/timestamp.c:298
#, c-format
-msgid "Illegal filename. Cannot be '.' or 'NULL'\n"
-msgstr "Nedovolený název souboru. Soubor se nemù¾e jmenovat '.' nebo 'NIC'\n"
+msgid "Can't create timestamp file for %s map %s in mapset %s"
+msgstr "Nelze vytvoøit soubor s èasovou znaèkou pro %s mapu %s v mapsetu %s"
-#: ../lib/gis/legal_name.c:45
+#: ../lib/gis/timestamp.c:308
#, c-format
-msgid "Illegal filename. Character <%c> not allowed.\n"
-msgstr "Nedovolený název souboru. Znak <%c> není povolen.\n"
+msgid "Invalid timestamp specified for %s map %s in mapset %s"
+msgstr "Neplatná èasová znaèka specifikovaná pro %s mapu %s v mapsetu %s"
-#: ../lib/gis/legal_name.c:75 ../lib/gis/legal_name.c:77
+#: ../lib/gis/timestamp.c:332
#, c-format
-msgid "Output name '%s' is not valid rast name."
-msgstr "Název výstupu '%s' není platným názvem rastrové mapy."
+msgid "Can't open timestamp file for %s map %s in mapset %s"
+msgstr "Nelze otevøít soubor s èasovou znaèkou pro %s mapu %s v mapsetu %s"
-#: ../lib/gis/legal_name.c:88 ../lib/gis/legal_name.c:90
+#: ../lib/gis/timestamp.c:342
#, c-format
-msgid "Cannot find input map '%s'"
-msgstr "Vstupní mapa '%s' nebyla nalezena"
+msgid "Invalid timestamp file for %s map %s in mapset %s"
+msgstr "Neplatný soubor s èasovou znaèkou pro %s mapu %s v mapsetu %s"
-#: ../lib/gis/legal_name.c:109 ../lib/gis/legal_name.c:111
+#: ../lib/gis/get_row.c:47 ../lib/gis/get_row.c:937
#, c-format
-msgid "Output map '%s' is used as input"
-msgstr "Výstupní mapa '%s' je pou¾ita jako vstup."
+msgid "Reading raster map <%s@%s> request for row %d is outside region"
+msgstr "Ètení rastrové mapy <%s@%s> po¾adavek pro øádek %d je mimo region"
-#: ../lib/gis/debug.c:68
+#: ../lib/gis/get_row.c:315
#, c-format
-msgid "Cannot open debug file '%s'"
-msgstr "Nelze otevøít doèasný soubor '%s'"
+msgid "cell_values_float: xdr_float failed for index %d"
+msgstr "cell_values_float: xdr_float neúspì¹né pro index %d."
-#: ../lib/gis/get_datum_name.c:53
+#: ../lib/gis/get_row.c:359
#, c-format
-msgid ""
-"\n"
-"Please specify datum name\n"
-msgstr ""
-"\n"
-"Specifikujte prosím vý¹kový systém (datum)\n"
+msgid "cell_values_double: xdr_double failed for index %d"
+msgstr "cell_values_double: xdr_double neúspì¹né pro index %d"
-#: ../lib/gis/get_datum_name.c:54
+#: ../lib/gis/get_row.c:504
#, c-format
-msgid "Enter 'list' for the list of available datums\n"
-msgstr "Zadejte 'list' pro výpis dostupných vý¹kových systémù (datumù)\n"
+msgid "Error reading compressed map <%s@%s>, row %d"
+msgstr "chyba pøi ètení komprimované mapy <%s@%s>, øádek %d"
-#: ../lib/gis/get_datum_name.c:55
+#: ../lib/gis/get_row.c:507
#, c-format
-msgid "or 'custom' if you wish to enter custom parameters\n"
-msgstr "nebo 'custom' pokud si pøejete vlo¾it volitelné parametry\n"
+msgid "Error reading map <%s@%s>, row %d"
+msgstr "chyba pøi ètení mapy <%s@%s>, øádek %d"
-#: ../lib/gis/get_datum_name.c:93
+#: ../lib/gis/get_row.c:917 ../lib/gis/get_row.c:923
#, c-format
-msgid ""
-"\n"
-"invalid datum\n"
-msgstr ""
-"\n"
-"neplatný vý¹kový systém (datum)\n"
+msgid "Error reading null row %d"
+msgstr "chyba pøi ètení prázdného øádku %d"
-#: ../lib/gis/datum.c:172
-#, c-format
-msgid "unable to open datum table file: %s"
+#: ../lib/gis/get_row.c:1004
+msgid "Unable to realloc buffer"
+msgstr "Buffer nelze realokovat"
-#: ../lib/gis/datum.c:196
+#: ../lib/gis/format.c:162
#, c-format
-msgid "error in datum table file, line %d"
+msgid "Fail of initial read of compressed file [%s in %s]"
+msgstr "Selhání pøi poèáteèním ètení komprimovaného souboru [%s v %s]"
-#: ../lib/gis/list.c:116
+#: ../lib/gis/put_cellhd.c:26
#, c-format
-msgid "no %s files available in current mapset\n"
-msgstr "v aktuální mapsetu nejsou dostupné ¾ádné soubory %s\n"
+msgid "Unable to create header file for [%s]"
+msgstr "Nelze vytvoøit hlavièkový soubor pro [%s]"
-#: ../lib/gis/list.c:118
+#: ../lib/gis/gisinit.c:55
#, c-format
-msgid "no %s files available in mapset <%s>\n"
-msgstr "v mapsetu <%s> nejsou dostupné ¾ádné soubory %s\n"
+msgid "MAPSET %s - permission denied"
+msgstr "MAPSET %s - pøístup odepøen"
-#: ../lib/gis/list.c:132
+#: ../lib/gis/gisinit.c:58 ../lib/gis/mapset.c:58
#, c-format
-msgid "hit RETURN to continue -->"
-msgstr "stisknìte RETURN pro pokraèování -->"
+msgid "MAPSET %s not found"
+msgstr "MAPSET %s nebyl nalezen"
-#: ../lib/gis/list.c:184
-#, c-format
-msgid "%s files available in mapset <%s>:\n"
-msgstr "v mapsetu <%s> je dostupných souborù %s:\n"
+#: ../lib/gis/gisinit.c:101
+msgid "System not initialized. Programmer forgot to call G_gisinit()."
+msgstr "Systém není inicializován. Programátor zapomnìl zavolat G_gisinit()."
-#: ../lib/gis/list.c:258
-msgid "G_list: Unknown element type"
-msgstr "G_list: Neznámý typ elementu"
+#: ../lib/gis/null_val.c:94
+msgid "EmbedGivenNulls: wrong data type!"
+msgstr "EmbedGivenNulls: ¹patný datový typ!"
-#: ../lib/gis/proj2.c:49
-msgid "Latitude-Longitude"
-msgstr "Zemìpisná ¹íøka a délka"
+#: ../lib/gis/null_val.c:115
+msgid "Null values have not been initialized. "
+msgstr "Nebyly inicializovány nulové hodnoty. "
-#: ../lib/gis/proj2.c:51
-msgid "Other Projection"
-msgstr "Ostatní mapové projekce"
+#: ../lib/gis/null_val.c:116
+msgid "G_gisinit() must be called first. "
+msgstr "G_gisinit() musí být volán jako první. "
+#: ../lib/gis/null_val.c:117
+msgid "Please advise GRASS developers of this error.\n"
+msgstr "Prosím, oznamte tuto chybu vývojáøùm GRASSu.\n"
+#: ../lib/gis/null_val.c:231
+msgid "G_set_null_value: wrong data type!"
+msgstr "G_set_null_value: ¹patný datový typ!"
+#: ../lib/gis/set_window.c:82
+msgid ""
+"G_set_window(): projection/zone differs from that of currently open raster "
+"maps"
+msgstr ""
+"G_set_window(): mapová projekce/zóna se li¹í od aktuálnì otevøených "
+"rastrových souborù"
+#: ../lib/gis/done_msg.c:37
+#, c-format
+msgid "%s complete. %s"
+msgstr "%s hotovo. %s"
#: ../lib/gis/opencell.c:185
#, c-format
msgid "unable to open raster map [%s in %s]"
@@ -2216,356 +1550,191 @@
msgid "invalid type: field %s in file %s "
msgstr "neplatný typ: polo¾ka %s v souboru %s"
-#: ../lib/gis/put_title.c:28
-#, c-format
-msgid "category information for [%s] in [%s] missing or invalid"
-msgstr "kategorie pro [%s] v [%s] chybí nebo jsou neplatné"
+#: ../lib/gis/adj_cellhd.c:47 ../lib/gis/adj_cellhd.c:196
+msgid "Illegal n-s resolution value"
+msgstr "Neplatná hodnota rozli¹ení sever-jih"
-#: ../lib/gis/put_title.c:38
-#, c-format
-msgid "G_put_title - can't create a temp file"
-msgstr "G_put_title - nelze vytvoøit doèasný soubor"
+#: ../lib/gis/adj_cellhd.c:52 ../lib/gis/adj_cellhd.c:203
+msgid "Illegal row value"
+msgstr "Neplatná hodnota øádku"
-#: ../lib/gis/put_title.c:58
-#, c-format
-msgid "category information for [%s] in [%s] invalid"
-msgstr "neplatné kategorie pro [%s] v [%s]"
+#: ../lib/gis/adj_cellhd.c:57 ../lib/gis/adj_cellhd.c:210
+msgid "Illegal e-w resolution value"
+msgstr "Neplatná hodnota rozli¹ení východ-západ"
-#: ../lib/gis/put_title.c:66
-#, c-format
-msgid "G_put_title - can't reopen temp file"
-msgstr "G_put_title - nelze znovu otevøít doèasný soubor"
+#: ../lib/gis/adj_cellhd.c:62 ../lib/gis/adj_cellhd.c:217
+msgid "Illegal col value"
+msgstr "Neplatná hodnota sloupce"
-#: ../lib/gis/put_title.c:75
+#: ../lib/gis/adj_cellhd.c:81 ../lib/gis/adj_cellhd.c:248
#, c-format
-msgid "can't write category information for [%s] in [%s]"
-msgstr "nelze zapsat kategorie pro [%s] v [%s]"
+msgid "Fixing subtle input data rounding error of north boundary (%g>%g)"
+msgstr "O¹etøuji podrobná vstupní data zaokrouhlením severní hranice (%g>%g)"
-#: ../lib/gis/quant_io.c:92
-#, c-format
-msgid "The floating data range for %s@%s is empty"
-msgstr "Rozsah dat s plovoucí desetinnou èárkou pro %s@%s je prázdný"
+#: ../lib/gis/adj_cellhd.c:84 ../lib/gis/adj_cellhd.c:251
+msgid "Illegal latitude for North"
+msgstr "Neplatná zem. ¹íøka pro sever"
-#: ../lib/gis/quant_io.c:101
+#: ../lib/gis/adj_cellhd.c:89 ../lib/gis/adj_cellhd.c:256
#, c-format
-msgid "The integer data range for %s@%s is empty"
-msgstr "Rozsah celoèíselných dat pro %s@%s je prázdný"
+msgid "Fixing subtle input data rounding error of south boundary (%g>%g)"
+msgstr ""
+"O¹etøuji pøíli¹ podrobná vstupní data zaokrouhlením ji¾ní hranice (%g>%g)"
-#: ../lib/gis/quant_io.c:167
-#, c-format
-msgid "quantization file [%s] in mapset [%s] %s"
-msgstr "kvantizaèní soubor [%s] v mapsetu [%s] %s"
+#: ../lib/gis/adj_cellhd.c:92 ../lib/gis/adj_cellhd.c:259
+msgid "Illegal latitude for South"
+msgstr "Neplatná zem. ¹íøka pro jih"
-#: ../lib/gis/system.c:90
-msgid "Can not create a new process!"
-msgstr "nelze vytvoøit nový proces"
-#: ../lib/gis/myname.c:51
-msgid "Unknown Location"
-msgstr "Neznámá Location"
-#: ../lib/gis/color_rules.c:115
-msgid "syntax error"
-msgstr "syntaktická chyba"
-#: ../lib/gis/color_rules.c:116
-msgid "R/G/B not in range 0-255"
-msgstr "R/G/B není v rozsahu 0-255"
-#: ../lib/gis/color_rules.c:117
-msgid "invalid color name"
-msgstr "neplatný název barvy"
-#: ../lib/gis/color_rules.c:118
-msgid "percentage not in range 0-100"
-msgstr "procenta nejsou v rozsahu 0-100"
-#: ../lib/gis/color_rules.c:119
-msgid "invalid value"
-msgstr "neplatná hodnota"
-#: ../lib/gis/color_rules.c:120
-msgid "unknown error"
-#: ../lib/gis/color_rules.c:151
+#: ../lib/gis/adj_cellhd.c:103 ../lib/gis/adj_cellhd.c:270
#, c-format
-msgid "bad rule (%s): %s"
-msgstr "chybné pravidlo (%s): %s"
+msgid "Fixing subtle input data rounding error of west boundary (%g>%g)"
+msgstr ""
+"O¹etøuji pøíli¹ podrobná vstupní data zaokrouhlením západní hranice (%g>%g)"
-#: ../lib/gis/spawn.c:77 ../lib/gis/spawn.c:110
-msgid "Too many arguments"
-msgstr "Pøíli¹ mnoho argumentù"
-#: ../lib/gis/spawn.c:132 ../lib/gis/spawn.c:385
-msgid "Unable to create a new process"
-msgstr "Nelze vytvoøit nový proces"
-#: ../lib/gis/spawn.c:142 ../lib/gis/spawn.c:410
-msgid "Unable to execute command"
-msgstr "Nelze spustit pøíkaz"
-#: ../lib/gis/spawn.c:237 ../lib/gis/spawn.c:245
+#: ../lib/gis/adj_cellhd.c:113 ../lib/gis/adj_cellhd.c:280
#, c-format
-msgid "G_spawn: unable to restore signal %d"
-msgstr "G_spawn: nelze navrátit signál %d"
+msgid "Fixing subtle input data rounding error of east boundary (%g>%g)"
+msgstr ""
+"O¹etøuji pøíli¹ podrobná vstupní data zaokrouhlením východní hranice (%g>%g)"
-#: ../lib/gis/spawn.c:278
-#, c-format
-msgid "G_spawn: unable to reset signal %d"
-msgstr "G_spawn: nelze obnovit signál %d"
+#: ../lib/gis/adj_cellhd.c:127 ../lib/gis/adj_cellhd.c:294
+msgid "North must be north of South"
+msgstr "Sever musí být severnì oproti jihu"
-#: ../lib/gis/spawn.c:288
-#, c-format
-msgid "G_spawn: unable to ignore signal %d"
-msgstr "G_spawn: nelze zamítnout signál %d"
+#: ../lib/gis/adj_cellhd.c:129 ../lib/gis/adj_cellhd.c:296
+msgid "North must be larger than South"
+msgstr "Hodnota pro sever musí být vìt¹í ne¾ pro jih"
-#: ../lib/gis/spawn.c:299
-#, c-format
-msgid "G_spawn: unable to block signal %d"
-msgstr "G_spawn: nelze pozastavit signál %d"
+#: ../lib/gis/adj_cellhd.c:132 ../lib/gis/adj_cellhd.c:299
+msgid "East must be larger than West"
+msgstr "Hodnota pro východ musí být vìt¹í ne¾ pro západ"
-#: ../lib/gis/spawn.c:308
-#, c-format
-msgid "G_spawn: unable to unblock signal %d"
-msgstr "G_spawn: nelze uvolnit signál %d"
+#: ../lib/gis/adj_cellhd.c:150 ../lib/gis/adj_cellhd.c:337
+msgid "Invalid coordinates"
+msgstr "Neplatné souøadnice"
-#: ../lib/gis/spawn.c:334
-#, c-format
-msgid "G_spawn: unable to open file %s"
-msgstr "G_spawn: nelze otevøít soubor %s"
+#: ../lib/gis/adj_cellhd.c:198
+msgid "Illegal n-s3 resolution value"
+msgstr "Neplatné n-s3 rozli¹ení"
-#: ../lib/gis/spawn.c:340 ../lib/gis/spawn.c:350
-#, c-format
-msgid "G_spawn: unable to duplicate descriptor %d to %d"
-msgstr "G_spawn: nelze duplikovat popisovaè %d na %d"
+#: ../lib/gis/adj_cellhd.c:205
+msgid "Illegal row3 value"
+msgstr "Neplatný poèet øádek (row3)"
-#: ../lib/gis/spawn.c:402
-#, c-format
-msgid "Unable to change directory to %s"
-msgstr "Nelze zmìnit adresáø na %s"
+#: ../lib/gis/adj_cellhd.c:212
+msgid "Illegal e-w3 resolution value"
+msgstr "Neplatné e-w3 rozli¹ení"
-#: ../lib/gis/mapset.c:41
-msgid "MAPSET is not set"
-msgstr "MAPSET není nastaven"
+#: ../lib/gis/adj_cellhd.c:219
+msgid "Illegal col3 value"
+msgstr "Neplatný poèet sloupcù (col3)"
-#: ../lib/gis/mapset.c:60 ../lib/gis/gisinit.c:58
-#, c-format
-msgid "MAPSET %s not found"
-msgstr "MAPSET %s nebyl nalezen"
+#: ../lib/gis/adj_cellhd.c:224
+msgid "Illegal t-b3 resolution value"
+msgstr "Neplatná hodnota rozli¹ení t-b3"
-#: ../lib/gis/gishelp.c:49
-#, c-format
-msgid "one moment...\n"
-msgstr "momentíèek...\n"
+#: ../lib/gis/adj_cellhd.c:229
+msgid "Illegal depths value"
+msgstr "Neplatný poèet øádek"
-#: ../lib/gis/gishelp.c:54
-#, c-format
-msgid "No help available for command [%s]\n"
-msgstr "Nápovìda pro pøíkaz [%s] není dostupná\n"
+#: ../lib/gis/adj_cellhd.c:301
+msgid "Top must be larger than Bottom"
+msgstr "Svrní hodnota musí být vìt¹í, ne¾ spodní."
-#: ../lib/gis/make_colr.c:41
+#: ../lib/gis/ls.c:63
#, c-format
-msgid " The raster map %s@%s is empty"
-msgstr " Rastrová mapa %s@%s je prázdná"
+msgid "Unable to open directory %s"
+msgstr "Nelze otevøít adresáø %s"
-#: ../lib/gis/make_colr.c:49
+#: ../lib/gis/quant_io.c:92
#, c-format
-msgid ""
-"\n"
-"\n"
-"Color table needed for file [%s] in mapset [%s].\n"
-msgstr ""
-"\n"
-"\n"
-"Tabulka barev potøebná pro soubor [%s] v mapsetu [%s].\n"
+msgid "The floating data range for %s@%s is empty"
+msgstr "Rozsah dat s plovoucí desetinnou èárkou pro %s@%s je prázdný"
-#: ../lib/gis/make_colr.c:52
+#: ../lib/gis/quant_io.c:101
#, c-format
-msgid ""
-"\n"
-"Please identify the type desired:\n"
-msgstr ""
-"\n"
-"Urèete prosím po¾adovaný typ:\n"
+msgid "The integer data range for %s@%s is empty"
+msgstr "Rozsah celoèíselných dat pro %s@%s je prázdný"
-#: ../lib/gis/make_colr.c:53
+#: ../lib/gis/quant_io.c:167
#, c-format
-msgid " 1: Random colors\n"
-msgstr " 1: Náhodné barvy:\n"
+msgid "quantization file [%s] in mapset [%s] %s"
+msgstr "kvantizaèní soubor [%s] v mapsetu [%s] %s"
-#: ../lib/gis/make_colr.c:54
+#: ../lib/gis/mask_info.c:42
#, c-format
-msgid " 2: Red, green, and blue color ramps\n"
-msgstr " 2: Èervená, zelená a modrá\n"
+msgid "<%s> in mapset <%s>"
+msgstr "<%s> v mapsetu <%s>"
-#: ../lib/gis/make_colr.c:55
-#, c-format
-msgid " 3: Color wave\n"
-msgstr " 3: Barevná vlna\n"
+#: ../lib/gis/mask_info.c:45
+msgid "none"
+msgstr "nic"
-#: ../lib/gis/make_colr.c:56
-#, c-format
-msgid " 4: Gray scale\n"
-msgstr " 4: Odstíny ¹edi\n"
+#: ../lib/gis/mask_info.c:48
+msgid "not known"
+msgstr "neznámý"
-#: ../lib/gis/make_colr.c:57
+#: ../lib/gis/histogram.c:60
#, c-format
-msgid " 5: Aspect\n"
-msgstr " 5: Expozice\n"
+msgid "Histogram for [%s in %s] missing (run r.support)"
+msgstr "Chybí histogram pro [%s v %s] (spus»te r.support)"
-#: ../lib/gis/make_colr.c:58
+#: ../lib/gis/histogram.c:68
#, c-format
-msgid " 6: Rainbow colors\n"
-msgstr " 6: Barvy duhy\n"
+msgid "Can't read histogram for [%s in %s]"
+msgstr "Nelze èíst histogram z [%s v %s]"
-#: ../lib/gis/make_colr.c:59
+#: ../lib/gis/histogram.c:79 ../lib/gis/histogram.c:89
#, c-format
-msgid " 7: Red through yellow to green\n"
-msgstr " 7: Od èervené pøes ¾lutou k zelené\n"
+msgid "Invalid histogram file for [%s in %s]"
+msgstr "Neplatný soubor s histogramem z [%s v %s]"
-#: ../lib/gis/make_colr.c:60
+#: ../lib/gis/histogram.c:370
#, c-format
-msgid " 8: Green through yellow to red\n"
-msgstr " 8: Od zelené pøes ¾lutou k èervené\n"
+msgid "can't create histogram for [%s in %s]"
+msgstr "nelze vytvoøit histogram z [%s v %s]"
-#: ../lib/gis/make_colr.c:61
+#: ../lib/gis/debug.c:68
#, c-format
-msgid "RETURN quit\n"
-msgstr "RETURN konec\n"
+msgid "Cannot open debug file '%s'"
+msgstr "Nelze otevøít doèasný soubor '%s'"
-#: ../lib/gis/make_colr.c:82
-#, c-format
-msgid ""
-"\n"
-"%s invalid; Try again > "
-msgstr ""
-"\n"
-"%s neplatné; Zkuste to znova > "
+#: ../lib/gis/sample.c:81
+msgid "Unknown interpolation type"
+msgstr "Neznámý zpùsob interpolace"
-#: ../lib/gis/range.c:195
-#, c-format
-msgid "can't read f_range file for [%s in %s]"
-msgstr "nelze pøeèíst f_range soubor z [%s v %s]"
+#: ../lib/gis/sample.c:467
+msgid "\"no data\" label found; setting to zero"
+msgstr "nalezen prazdny retezec v popisu; nastavuji na nula"
-#: ../lib/gis/range.c:312
-#, c-format
-msgid "can't read range file for [%s in %s]"
-msgstr "nelze èíst soubor s rozsahem hodnot z [%s v %s]"
+#: ../lib/gis/sample.c:481
+msgid "Problem reading raster map"
+msgstr "Potí¾e pøi ètení rastrové mapy"
-#: ../lib/gis/range.c:365 ../lib/gis/range.c:416
+#: ../lib/gis/datum.c:172
#, c-format
-msgid "can't write range file for [%s in %s]"
-msgstr "nelze vytvoøit soubor s rozsahem hodnot z [%s v %s]"
+msgid "unable to open datum table file: %s"
+msgstr "nelze otevøít soubor s vý¹kovým systémem (datum): %s"
-#: ../lib/gis/gisinit.c:55
+#: ../lib/gis/datum.c:196
#, c-format
-msgid "MAPSET %s - permission denied"
-msgstr "MAPSET %s - pøístup odepøen"
+msgid "error in datum table file, line %d"
+msgstr "chyba v souboru obsahující vý¹kový systém (datum), na øádku %d"
-#: ../lib/gis/gisinit.c:101
-#, fuzzy
-msgid "System not initialized. Programmer forgot to call G_gisinit()."
-msgstr ""
-"CHYBA: Systém není inicializován. Programátor zapomnìl zavolat G_gisinit()\n"
+#: ../lib/gis/auto_mask.c:66
+msgid "Unable to open automatic MASK file"
+msgstr "Nelze automaticky otevøít soubor MASK"
-#: ../lib/gis/get_row.c:47 ../lib/gis/get_row.c:939
-#, fuzzy, c-format
-msgid "Reading raster map <%s@%s> request for row %d is outside region"
-msgstr "[%s v %s] - po¾adavek na ètení øádku %d vnì regionu"
-#: ../lib/gis/get_row.c:315
+#: ../lib/gis/quant_rw.c:208
#, c-format
-msgid "cell_values_float: xdr_float failed for index %d"
-msgstr "cell_values_float: xdr_float neúspì¹né pro index %d."
+msgid "Cannot write quant rules: map %s is integer"
+msgstr "Nelze zapsat kvantizaèní pravidla: mapa %s je celoèíselná"
-#: ../lib/gis/get_row.c:359
-#, fuzzy, c-format
-msgid "cell_values_double: xdr_double failed for index %d"
-msgstr "cell_values_double: xdr_double neúspì¹né pro index %d."
-#: ../lib/gis/get_row.c:504
-#, fuzzy, c-format
-msgid "Error reading compressed map <%s@%s>, row %d"
-msgstr "chyba pøi ètení komprimované mapy [%s] v mapsetu [%s], øádek %d"
-#: ../lib/gis/get_row.c:507
-#, fuzzy, c-format
-msgid "Error reading map <%s@%s>, row %d"
-msgstr "chyba pøi ètení mapy [%s] v mapsetu [%s], øádek %d"
-#: ../lib/gis/get_row.c:919 ../lib/gis/get_row.c:925
-#, fuzzy, c-format
-msgid "Error reading null row %d"
-msgstr "chyba pøi ètení prázdného øádku %d"
-#: ../lib/gis/get_row.c:1006
-#, fuzzy
-msgid "Unable to realloc buffer"
-msgstr "Buffer nelze realokovat"
-#: ../lib/gis/get_projname.c:32
+#: ../lib/gis/quant_rw.c:218
#, c-format
-msgid "%s not found"
-msgstr "%s nenalezen"
+msgid "Cannot write quant rules for map %s"
+msgstr "Nelze zapsat kvantizaèní pravidla pro mapu %s"
-#: ../lib/gis/get_projname.c:35
-#, c-format
-msgid "ERROR in reading %s"
-msgstr "CHYBA pøi ètení %s"
-#: ../lib/gis/get_projname.c:49
-#, c-format
-msgid ""
-"\n"
-"\n"
-"Please specify projection name\n"
-msgstr ""
-"\n"
-"\n"
-"Specifikujte prosím mapovou projekci\n"
-#: ../lib/gis/get_projname.c:50
-#, c-format
-msgid "Enter 'list' for the list of available projections\n"
-msgstr "Zadejte 'list' pro výpis dostupných mapových projekcí\n"
-#: ../lib/gis/get_projname.c:72
-#, c-format
-msgid ""
-"\n"
-"invalid projection\n"
-msgstr ""
-"\n"
-"neplatná mapová projekce\n"
-#: ../lib/gis/ask_cell.c:56 ../lib/gis/ask_cell.c:75 ../lib/gis/ask_cell.c:94
-#: ../lib/gis/ask_cell.c:101
-msgid "with titles"
-msgstr "s titulky"
-#: ../lib/gis/ask_cell.c:113
-msgid "(no title)"
-msgstr "(bez titulku)"
-#: ../lib/gis/ls.c:63
-#, c-format
-msgid "Unable to open directory %s"
-msgstr "Nelze otevøít adresáø %s"
-#: ../lib/gis/set_window.c:82
-msgid ""
-"G_set_window(): projection/zone differs from that of currently open raster "
-"maps"
-msgstr ""
-"G_set_window(): mapová projekce/zóna se li¹í od aktuálnì otevøených "
-"rastrových souborù"
-#: ../lib/gis/format.c:162
-#, c-format
-msgid "Fail of initial read of compressed file [%s in %s]"
-msgstr "Selhání pøi poèáteèním ètení komprimovaného souboru [%s v %s]"
#: ../lib/gis/put_row.c:212
#, c-format
msgid "G_put_map_row: %s is not integer! Use G_put_[f/d]_raster_row()!"
@@ -2632,170 +1801,36 @@
msgstr ""
"V souboru s historií není dostatek místa pro pøíkazovou øádku (zkráceno)"
-#: ../lib/gis/closecell.c:223
+#: ../lib/gis/legal_name.c:38
#, c-format
-msgid ""
-"closecell: can't move %s\n"
-"to null file %s"
-msgstr ""
-"closecell: nemohu pøesunout %s\n"
-"do souboru null %s"
+msgid "Illegal filename. Cannot be '.' or 'NULL'\n"
+msgstr "Nedovolený název souboru. Soubor se nemù¾e jmenovat '.' nebo 'NIC'\n"
-#: ../lib/gis/closecell.c:243
+#: ../lib/gis/legal_name.c:45
#, c-format
-msgid "Error writing floating point format file for map %s"
-msgstr ""
-"Chyba pøi zapisování souboru s èísly s plovoucí desetinnou èárkou pro mapu %s"
+msgid "Illegal filename. Character <%c> not allowed.\n"
+msgstr "Nedovolený název souboru. Znak <%c> není povolen.\n"
-#: ../lib/gis/closecell.c:289
+#: ../lib/gis/legal_name.c:75 ../lib/gis/legal_name.c:77
#, c-format
-msgid ""
-"to cell file %s"
-msgstr ""
-"do rastrového souboru %s"
+msgid "Output name '%s' is not valid rast name."
+msgstr "Název výstupu '%s' není platným názvem rastrové mapy."
-#: ../lib/gis/closecell.c:343
-msgid "unable to write quant file!"
-msgstr "nemohu zapsat soubor quant!"
-#: ../lib/gis/closecell.c:391
-msgid "unable to write f_format file for CELL maps"
-msgstr "neschopen zapsat soubor f_format pro mapy CELL "
-#: ../lib/gis/home.c:40
-msgid "unable to determine user's home directory"
-msgstr "nelze urèit domovský adresáø u¾ivatele"
-#: ../lib/gis/error.c:315
-msgid "WARNING: "
-msgstr "UPOZORNÌNÍ: "
-#: ../lib/gis/error.c:316
-msgid "ERROR: "
-msgstr "CHYBA: "
-#: ../lib/gis/get_cellhd.c:74 ../lib/gis/get_cellhd.c:103
-#, fuzzy, c-format
-msgid "Unable to read header file for raster map <%s@%s>."
-msgstr "Nelze vytvoøit hlavièkový soubor pro [%s v %s]"
-#: ../lib/gis/get_cellhd.c:76
-#, fuzzy, c-format
-msgid " It is a reclass of raster map <%s@%s> "
-msgstr "Jde o reklasifikaci [%s v %s] "
-#: ../lib/gis/get_cellhd.c:79
-#, fuzzy, c-format
-msgid "which is missing."
-msgstr "jen¾ chybí"
-#: ../lib/gis/get_cellhd.c:81
-#, fuzzy, c-format
-msgid "whose header file can't be opened."
-msgstr "jeho¾ hlavièkový soubor nelze otevøít"
-#: ../lib/gis/get_cellhd.c:91
-#, fuzzy, c-format
-msgid "Unable to open header file for raster map <%s@%s>"
-#: ../lib/gis/get_cellhd.c:107
-#, fuzzy, c-format
-msgid " It is a reclass of raster map <%s@%s> whose header file is invalid."
-msgstr "Jde o reklasifikaci [%s v %s] jeho¾ hlavièkový soubor je neplatný\n"
-#: ../lib/gis/get_cellhd.c:111
-#, fuzzy, c-format
-msgid " Invalid format."
-msgstr "Neplatný formát\n"
-#: ../lib/gis/cats.c:385
+#: ../lib/gis/legal_name.c:88 ../lib/gis/legal_name.c:90
#, c-format
-msgid "category support for [%s] in mapset [%s] %s"
-msgstr "podpora kategorií pro [%s] v mapsetu [%s] %s"
+msgid "Cannot find input map '%s'"
+msgstr "Vstupní mapa '%s' nebyla nalezena"
-#: ../lib/gis/cats.c:424
+#: ../lib/gis/legal_name.c:109 ../lib/gis/legal_name.c:111
#, c-format
-msgid "category support for vector map [%s] in mapset [%s] %s"
-msgstr "podpora kategorií pro vektorový soubor [%s] v mapsetu [%s] %s"
+msgid "Output map '%s' is used as input"
+msgstr "Výstupní mapa '%s' je pou¾ita jako vstup."
-#: ../lib/gis/get_ellipse.c:87
-#, fuzzy, c-format
-msgid "Unable to open file %s in <%s>"
-msgstr "Nelze otevøít soubor %s v %s"
-#: ../lib/gis/get_ellipse.c:345
+#: ../lib/gis/color_read.c:123
#, c-format
-msgid "Lines%s of ellipsoid table file <%s> are invalid"
-msgstr "Øádky%s v souboru s tabulkou elipsoidu <%s> jsou neplatné"
+msgid "color support for [%s] in mapset [%s] %s"
+msgstr "podpora barev pro [%s] v mapsetu [%s] %s"
-#: ../lib/gis/get_ellipse.c:346
-#, c-format
-msgid "Line%s of ellipsoid table file <%s> is invalid"
-msgstr "Øádek%s v souboru s tabulkou elipsoidu <%s> je neplatný"
-#: ../lib/gis/get_ellipse.c:365 ../lib/gis/get_ellipse.c:391
-#, fuzzy, c-format
-msgid "Invalid a: field '%s' in file %s in <%s>"
-msgstr "neplatná a: polo¾ka %s v souboru %s v %s"
-#: ../lib/gis/get_ellipse.c:378
-#, fuzzy, c-format
-msgid "Invalid ellipsoid '%s' in file %s in <%s>"
-msgstr "neplatný ref. elipsoid %s v souboru %s v %s"
-#: ../lib/gis/get_ellipse.c:395
-#, fuzzy, c-format
-msgid "Invalid es: field '%s' in file %s in <%s>"
-msgstr "neplatná es: polo¾ka %s v souboru %s v %s"
-#: ../lib/gis/get_ellipse.c:409
-#, fuzzy, c-format
-msgid "No ellipsoid info given in file %s in <%s>"
-msgstr "V souboru %s v %s chybí informace o ref. elipsoidu"
-#: ../lib/gis/location.c:46
-#, c-format
-msgid "LOCATION << %s >> not available"
-msgstr "LOCATION << %s >> není dostupná"
-#: ../lib/gis/null_val.c:94
-msgid "EmbedGivenNulls: wrong data type!"
-msgstr "EmbedGivenNulls: ¹patný datový typ!"
-#: ../lib/gis/null_val.c:115
-msgid "Null values have not been initialized. "
-msgstr "Nebyly inicializovány nulové hodnoty. "
-#: ../lib/gis/null_val.c:116
-msgid "G_gisinit() must be called first. "
-msgstr "G_gisinit() musí být volán jako první. "
-#: ../lib/gis/null_val.c:117
-msgid "Please advise GRASS developers of this error.\n"
-msgstr "Prosím, oznamte tuto chybu vývojáøùm GRASSu.\n"
-#: ../lib/gis/null_val.c:231
-msgid "G_set_null_value: wrong data type!"
-msgstr "G_set_null_value: ¹patný datový typ!"
-#: ../lib/gis/get_projinfo.c:36 ../lib/gis/get_projinfo.c:67
-#, c-format
-msgid "<%s> file not found for location <%s>"
-msgstr "soubor <%s> nebyl nalezen v location <%s>"
-#: ../lib/gis/get_projinfo.c:43 ../lib/gis/get_projinfo.c:74
-#, c-format
-msgid "ERROR in reading <%s> file for location <%s>"
-msgstr "CHYBA pøi ètení souboru <%s> v location <%s>"
-#: ../lib/gis/mapset_msc.c:49
-#, c-format
-msgid "can't make mapset element %s (%s)"
-msgstr "nelze vytvoøit prvek %s(%s) mapsetu"
#: ../lib/gis/parser.c:345
msgid "WHERE conditions of SQL statement without 'where' keyword"
msgstr "Podmínka WHERE pøíkazu SQL bez klíèového slova 'where'"
@@ -2943,15 +1978,16 @@
#: ../lib/gis/parser.c:787
#, c-format
msgid "BUG in descriptions, option %s in %s does not exist"
-msgstr ""
+msgstr "BUG v popisu, volba %s v %s neexistuje"
#: ../lib/gis/parser.c:900
msgid "Use either --quiet or --verbose flag, not both. Assuming --verbose."
msgstr ""
+"Pou¾ijte buï --quiet nebo --verbose indikátor ne oba. Pou¾iji --verbose."
#: ../lib/gis/parser.c:914
msgid "Use either --quiet or --verbose flag, not both. Assuming --quiet."
-msgstr ""
+msgstr "Pou¾ijte buï --quiet nebo --verbose indikátor ne oba. Pou¾iji --quiet."
#: ../lib/gis/parser.c:949
#, c-format
@@ -2996,7 +2032,7 @@
"\n"
"Pøepínaèe:\n"
-#: ../lib/gis/parser.c:1166 ../lib/gis/parser.c:1654 ../lib/gis/parser.c:1940
+#: ../lib/gis/parser.c:1166 ../lib/gis/parser.c:1654 ../lib/gis/parser.c:1941
msgid "Allow output files to overwrite existing files"
msgstr "Povolit výstupním souborùm pøepsat existující soubory"
@@ -3050,49 +2086,48 @@
msgid "Default"
msgstr "Výchozí"
-#: ../lib/gis/parser.c:1942
+#: ../lib/gis/parser.c:1943
msgid "Allow overwrite"
msgstr "Povolit pøepsání"
-#: ../lib/gis/parser.c:1950
+#: ../lib/gis/parser.c:1951
msgid "Run with minimal output messages"
msgstr "Spustit s minimálním mno¾ství výstupních správ"
-#: ../lib/gis/parser.c:1952
+#: ../lib/gis/parser.c:1953
msgid "Run quietly"
msgstr "Spustit v tichém módu"
-#: ../lib/gis/parser.c:1985
+#: ../lib/gis/parser.c:1986
#, fuzzy
-msgid "Unable to spawn wish"
-msgstr "Nelze otevøít %s"
+msgid "Unable to spawn the 'wish' program"
+msgstr "Nelze ovyvoøit pøání"
-#: ../lib/gis/parser.c:2004
-#, fuzzy
+#: ../lib/gis/parser.c:2005
msgid "Unable to determine program name"
+msgstr "nelze urèit jméno programu"
-#: ../lib/gis/parser.c:2059
+#: ../lib/gis/parser.c:2060
#, c-format
msgid " %*s options: "
msgstr " %*s volby:"
-#: ../lib/gis/parser.c:2108 ../lib/gis/parser.c:2125
+#: ../lib/gis/parser.c:2109 ../lib/gis/parser.c:2126
#, c-format
msgid "Sorry, <%c> is not a valid flag\n"
msgstr "Promiòte, ale <%c> není platný pøepínaè\n"
-#: ../lib/gis/parser.c:2180
+#: ../lib/gis/parser.c:2181
#, c-format
msgid "Sorry, <%s=> is ambiguous\n"
msgstr "Promiòte, ale <%s=> je dvojznaèný\n"
-#: ../lib/gis/parser.c:2187
+#: ../lib/gis/parser.c:2188
#, c-format
msgid "Sorry, <%s> is not a valid parameter\n"
msgstr "Promiòte, ale <%s> není platný parametr\n"
-#: ../lib/gis/parser.c:2272
+#: ../lib/gis/parser.c:2273
#, c-format
msgid ""
"\n"
@@ -3101,12 +2136,12 @@
"\n"
"CHYBA: neplatná syntaxe rozsahu pro parametr <%s>\n"
-#: ../lib/gis/parser.c:2274
+#: ../lib/gis/parser.c:2275
#, c-format
msgid " Presented as: %s\n"
msgstr " Zadáno: %s\n"
-#: ../lib/gis/parser.c:2277
+#: ../lib/gis/parser.c:2278
#, c-format
msgid ""
"\n"
@@ -3115,12 +2150,12 @@
"\n"
"CHYBA: hodnota <%s> mimo rozsah parametru <%s>\n"
-#: ../lib/gis/parser.c:2279
+#: ../lib/gis/parser.c:2280
#, c-format
msgid " Legal range: %s\n"
msgstr " Povolený rozsah: %s\n"
-#: ../lib/gis/parser.c:2282
+#: ../lib/gis/parser.c:2283
#, c-format
msgid ""
"\n"
@@ -3129,7 +2164,7 @@
"\n"
"CHYBA: Chybí hodnota pro parametr <%s>\n"
-#: ../lib/gis/parser.c:2442
+#: ../lib/gis/parser.c:2443
#, c-format
msgid ""
"\n"
@@ -3140,7 +2175,7 @@
"CHYBA: Povinný parametr <%s> nebyl zadán:\n"
" (%s).\n"
-#: ../lib/gis/parser.c:2545
+#: ../lib/gis/parser.c:2546
#, c-format
msgid ""
"\n"
@@ -3149,17 +2184,17 @@
"\n"
"CHYBA: volba <%s> musí být zadána jako násobek %d\n"
-#: ../lib/gis/parser.c:2547
+#: ../lib/gis/parser.c:2548
#, c-format
msgid " You provided %d items:\n"
msgstr " Bylo zadáno %d polo¾ek:\n"
-#: ../lib/gis/parser.c:2602
+#: ../lib/gis/parser.c:2603
#, c-format
msgid "ERROR: option <%s>: <%s> exists.\n"
msgstr "CHYBA: volba <%s>: <%s> existuje.\n"
-#: ../lib/gis/parser.c:2649
+#: ../lib/gis/parser.c:2650
#, c-format
msgid ""
"\n"
@@ -3168,7 +2203,7 @@
"\n"
"PØEPÍNAÈ: Nastavit nasledující pøepínaè?\n"
-#: ../lib/gis/parser.c:2663
+#: ../lib/gis/parser.c:2664
#, c-format
msgid ""
"\n"
@@ -3177,51 +2212,51 @@
"\n"
"VOLBY: %s\n"
-#: ../lib/gis/parser.c:2664
+#: ../lib/gis/parser.c:2665
#, c-format
msgid " key: %s\n"
msgstr " klíè: %s\n"
-#: ../lib/gis/parser.c:2666
+#: ../lib/gis/parser.c:2667
#, c-format
msgid " format: %s\n"
msgstr " formát: %s\n"
-#: ../lib/gis/parser.c:2668
+#: ../lib/gis/parser.c:2669
#, c-format
msgid " default: %s\n"
msgstr " výchozí: %s\n"
-#: ../lib/gis/parser.c:2669
+#: ../lib/gis/parser.c:2670
#, c-format
msgid "required: %s\n"
msgstr "povinný: %s\n"
-#: ../lib/gis/parser.c:2671
+#: ../lib/gis/parser.c:2672
#, c-format
msgid "multiple: %s\n"
msgstr "vícenásobný: %s\n"
-#: ../lib/gis/parser.c:2673
+#: ../lib/gis/parser.c:2674
#, c-format
msgid " options: %s\n"
msgstr " volby: %s\n"
-#: ../lib/gis/parser.c:2688
+#: ../lib/gis/parser.c:2689
#, c-format
msgid "enter option > "
msgstr "zadejte volbu > "
-#: ../lib/gis/parser.c:2702 ../lib/gis/parser.c:2713
+#: ../lib/gis/parser.c:2703 ../lib/gis/parser.c:2714
msgid " Try again? "
msgstr " Zkusit znovu? "
-#: ../lib/gis/parser.c:2711
+#: ../lib/gis/parser.c:2712
#, c-format
msgid "Sorry, %s is not accepted.\n"
msgstr "Promiòte, ale %s není akceptován.\n"
-#: ../lib/gis/parser.c:2722
+#: ../lib/gis/parser.c:2723
#, c-format
msgid ""
"\n"
@@ -3232,14 +2267,154 @@
"Bylo vybráno:\n"
" %s\n"
-#: ../lib/gis/parser.c:2723
+#: ../lib/gis/parser.c:2724
msgid "Is this correct? "
msgstr "Je to správnì? "
-#: ../lib/gis/parser.c:2792
+#: ../lib/gis/parser.c:2793
msgid "to accept the default"
msgstr "pou¾ít výchozí"
+#: ../lib/gis/cats.c:385
+#, c-format
+msgid "category support for [%s] in mapset [%s] %s"
+msgstr "podpora kategorií pro [%s] v mapsetu [%s] %s"
+#: ../lib/gis/cats.c:424
+#, c-format
+msgid "category support for vector map [%s] in mapset [%s] %s"
+msgstr "podpora kategorií pro vektorový soubor [%s] v mapsetu [%s] %s"
+#: ../lib/gis/error.c:308
+msgid "WARNING: "
+msgstr "UPOZORNÌNÍ: "
+#: ../lib/gis/error.c:309
+msgid "ERROR: "
+msgstr "CHYBA: "
+#: ../lib/gis/get_ell_name.c:44
+#, c-format
+msgid ""
+"\n"
+"Please specify ellipsoid name\n"
+msgstr ""
+"\n"
+"Specifikujte prosím referenèní elipsoid\n"
+#: ../lib/gis/get_ell_name.c:45
+#, c-format
+msgid "Enter 'list' for the list of available ellipsoids\n"
+msgstr "Zadejte 'list' pro výpis dostupných ref. elipsoidù\n"
+#: ../lib/gis/get_ell_name.c:65
+#, c-format
+msgid ""
+"\n"
+"invalid ellipsoid\n"
+msgstr ""
+"\n"
+"neplatný ref. elipsoid\n"
+#: ../lib/gis/list.c:116
+#, c-format
+msgid "no %s files available in current mapset\n"
+msgstr "v aktuální mapsetu nejsou dostupné ¾ádné soubory %s\n"
+#: ../lib/gis/list.c:118
+#, c-format
+msgid "no %s files available in mapset <%s>\n"
+msgstr "v mapsetu <%s> nejsou dostupné ¾ádné soubory %s\n"
+#: ../lib/gis/list.c:132
+#, c-format
+msgid "hit RETURN to continue -->"
+msgstr "stisknìte RETURN pro pokraèování -->"
+#: ../lib/gis/list.c:184
+#, c-format
+msgid "%s files available in mapset <%s>:\n"
+msgstr "v mapsetu <%s> je dostupných souborù %s:\n"
+#: ../lib/gis/list.c:258
+msgid "G_list: Unknown element type"
+msgstr "G_list: Neznámý typ elementu"
+#: ../lib/gis/system.c:90
+msgid "Can not create a new process!"
+msgstr "nelze vytvoøit nový proces"
+#: ../lib/gis/env.c:248
+msgid "GISRC - variable not set"
+msgstr "GISRC - promìnná není nastavena"
+#: ../lib/gis/env.c:279
+#, c-format
+msgid "G_getenv(): Variable %s not set"
+msgstr "G_getenv(): Promìnná %s není nastavena"
+#: ../lib/gis/env.c:305
+#, c-format
+msgid "%s not set"
+msgstr "%s není nastaveno"
+#: ../lib/gis/mapset_msc.c:63
+#, fuzzy, c-format
+msgid "Unable to make mapset element %s (%s)"
+msgstr "nelze vytvoøit prvek %s(%s) mapsetu"
+#: ../lib/gis/spawn.c:77 ../lib/gis/spawn.c:110
+msgid "Too many arguments"
+msgstr "Pøíli¹ mnoho argumentù"
+#: ../lib/gis/spawn.c:132 ../lib/gis/spawn.c:408
+msgid "Unable to create a new process"
+msgstr "Nelze vytvoøit nový proces"
+#: ../lib/gis/spawn.c:142 ../lib/gis/spawn.c:232 ../lib/gis/spawn.c:433
+msgid "Unable to execute command"
+msgstr "Nelze spustit pøíkaz"
+#: ../lib/gis/spawn.c:260 ../lib/gis/spawn.c:268
+#, c-format
+msgid "G_spawn: unable to restore signal %d"
+msgstr "G_spawn: nelze navrátit signál %d"
+#: ../lib/gis/spawn.c:301
+#, c-format
+msgid "G_spawn: unable to reset signal %d"
+msgstr "G_spawn: nelze obnovit signál %d"
+#: ../lib/gis/spawn.c:311
+#, c-format
+msgid "G_spawn: unable to ignore signal %d"
+msgstr "G_spawn: nelze zamítnout signál %d"
+#: ../lib/gis/spawn.c:322
+#, c-format
+msgid "G_spawn: unable to block signal %d"
+msgstr "G_spawn: nelze pozastavit signál %d"
+#: ../lib/gis/spawn.c:331
+#, c-format
+msgid "G_spawn: unable to unblock signal %d"
+msgstr "G_spawn: nelze uvolnit signál %d"
+#: ../lib/gis/spawn.c:357
+#, c-format
+msgid "G_spawn: unable to open file %s"
+msgstr "G_spawn: nelze otevøít soubor %s"
+#: ../lib/gis/spawn.c:363 ../lib/gis/spawn.c:373
+#, c-format
+msgid "G_spawn: unable to duplicate descriptor %d to %d"
+msgstr "G_spawn: nelze duplikovat popisovaè %d na %d"
+#: ../lib/gis/spawn.c:425
+#, c-format
+msgid "Unable to change directory to %s"
+msgstr "Nelze zmìnit adresáø na %s"
#: ../lib/gis/reclass.c:150
#, c-format
msgid "Too many reclass categories for [%s in %s]"
@@ -3268,520 +2443,1246 @@
msgid "Unable to create dependency file in [%s in %s]"
msgstr "Nelze vytvoøit soubor závislostí v [%s v %s]"
-#: ../lib/gis/quant_rw.c:208
+#: ../lib/gis/proj3.c:66 ../lib/vector/Vlib/header.c:533
+msgid "Unknown projection"
+msgstr "Neznámá mapová projekce"
+#: ../lib/gis/mapset.c:39
+msgid "MAPSET is not set"
+msgstr "MAPSET není nastaven"
+#: ../lib/vector/vedit/select.c:196
+#, fuzzy
+msgid "Unknown query tool"
+msgstr "neznámý operátor"
+#: ../lib/vector/vedit/break.c:245
+#, fuzzy, c-format
+msgid "Unable to connect lines %d,%d"
+msgstr "Nelze èíst linii %d"
+#: ../lib/vector/vedit/cats.c:65
+#, fuzzy, c-format
+msgid "Unable to set category %d for line %d"
+#: ../lib/vector/vedit/cats.c:74
+#, fuzzy, c-format
+msgid "Unable to delete layer/category %d/%d line %d"
+msgstr "Nelze smazat vektorovou mapu <%s>"
+#: ../lib/vector/diglib/spindex.c:232
+#, fuzzy, c-format
+msgid "Unable to delete node %d from spatial index"
+msgstr "Nelze smazat soubor <%s>"
+#: ../lib/vector/diglib/spindex.c:268
+#, fuzzy, c-format
+msgid "Unable to delete line %d from spatial index"
+#: ../lib/vector/diglib/spindex.c:295
+#, fuzzy
+msgid "Attempt to delete sidx for dead area"
+msgstr "Pokus o odstranìné ostrova z mrtvé plochy"
+#: ../lib/vector/diglib/spindex.c:304
+#, fuzzy, c-format
+msgid "Unable to delete area %d from spatial index"
+#: ../lib/vector/diglib/spindex.c:336
+#, fuzzy, c-format
+msgid "Unable to delete isle %d from spatial index"
+#: ../lib/vector/diglib/plus_node.c:220
+#, fuzzy, c-format
+msgid ""
+"Attempt to read line angle for the line which is not connected to the node: "
+"node %d, line %d"
+msgstr ""
+"Pokus o naètení úhlu linie pro linii, která není pøipojena k uzlu: \n"
+"uzel = [%d] linie = [%d]"
+#: ../lib/vector/diglib/plus_area.c:191 ../lib/vector/diglib/plus_area.c:615
+#: ../lib/vector/diglib/plus_area.c:621
+#, fuzzy, c-format
+msgid "Line %d already has area/isle %d to left"
+msgstr "Linie [%d] má ji¾ na levé stranì plochu/ostrov [%d]"
+#: ../lib/vector/diglib/plus_area.c:199
+#, fuzzy, c-format
+msgid "Line %d already has area/isle %d to right"
+msgstr "Linie [%d] má ji¾ na pravé stranì plochu/ostrov [%d]"
+#: ../lib/vector/diglib/plus_area.c:278
+msgid "Attempt to delete isle from dead area"
+#: ../lib/vector/diglib/plus_area.c:292
+#, fuzzy, c-format
+msgid "Attempt to delete not registered isle %d from area %d"
+msgstr "Pokus o odstranìní neregistrovaného ostrova [%d] z plochy [%d]"
+#: ../lib/vector/diglib/plus_area.c:328
+msgid "Attempt to delete dead area"
+msgstr "Pokus o odstranìní mrtvé plochy"
+#: ../lib/vector/diglib/plus_area.c:366
+#, fuzzy, c-format
+msgid "Dead centroid %d registered for area (bug in the vector library)"
+msgstr "Mrtvý centroid [%d] registrován k plo¹e (chyba v knihovnì)."
+#: ../lib/vector/diglib/plus_area.c:387
+#, fuzzy, c-format
+msgid "Attempt to delete area %d info from dead isle %d"
+msgstr "Pokus o odstranìní informace o plo¹e [%d] z mrtvého ostrovu [%d]"
+#: ../lib/vector/diglib/plus_area.c:704
+#, fuzzy, c-format
+msgid "Attempt to delete isle %d info from dead area %d"
+msgstr "Pokus o odstranìní informace o ostrovì [%d] z mrtvé plochy [%d]"
+#: ../lib/vector/diglib/plus.c:288
+#, fuzzy
+msgid "Unable read topology for nodes"
+msgstr "Nelze èíst topologie pro uzly"
+#: ../lib/vector/diglib/plus.c:294
+#, fuzzy, c-format
+msgid "Unable to read topology for node %d"
+msgstr "Nelze èíst topologii pro uzly [%d]"
+#: ../lib/vector/diglib/plus.c:299
+#, fuzzy
+msgid "Unable read topology for lines"
+msgstr "Nelze èíst topologii pro linie"
+#: ../lib/vector/diglib/plus.c:305
+#, fuzzy, c-format
+msgid "Unable to read topology for line %d"
+#: ../lib/vector/diglib/plus.c:310
+#, fuzzy
+msgid "Unable to read topo for areas"
+msgstr "Nelze èíst topologii pro plochy"
+#: ../lib/vector/diglib/plus.c:316
+#, fuzzy, c-format
+msgid "Unable read topology for area %d"
+msgstr "Nelze èíst topologii pro plochu [%d]"
+#: ../lib/vector/diglib/plus.c:321
+#, fuzzy
+msgid "Unable to read topology for isles"
+msgstr "Nelze èíst topologii pro ostrovy"
+#: ../lib/vector/diglib/plus.c:327
+#, fuzzy, c-format
+msgid "Unable to read topology for isle %d"
+msgstr "Nelze èíst topologii pro ostrov [%d]"
+#: ../lib/vector/diglib/plus.c:352 ../lib/vector/diglib/plus.c:383
+#, fuzzy
+msgid "Unable to write head to plus file"
+msgstr "Nelze èíst hlavièkový soubor"
+#: ../lib/vector/diglib/plus.c:358
+#, fuzzy
+msgid "Unable to write nodes to plus file"
+msgstr "nemohu zapsat soubor quant!"
+#: ../lib/vector/diglib/plus.c:364
+#, fuzzy
+msgid "Unable to write lines to plus file"
+#: ../lib/vector/diglib/plus.c:370
+#, fuzzy
+msgid "Unable to write areas to plus file"
+msgstr "Nelze zapsat øádku rastru %i"
+#: ../lib/vector/diglib/plus.c:376
+#, fuzzy
+msgid "Unable to write isles to plus file"
+#: ../lib/vector/Vlib/map.c:55
+#, fuzzy
+msgid "input vector map is not open"
+msgstr "Vstupní vektorová mapa není otevøena"
+#: ../lib/vector/Vlib/map.c:65 ../lib/vector/Vlib/map.c:78
#, c-format
-msgid "Cannot write quant rules: map %s is integer"
-msgstr "Nelze zapsat kvantizaèní pravidla: mapa %s je celoèíselná"
+msgid "Unable to read vector map <%s>"
+msgstr "Nelze èíst vektorovou mapu <%s>"
-#: ../lib/gis/quant_rw.c:218
+#: ../lib/vector/Vlib/map.c:169 ../lib/vector/Vlib/map.c:293
+#: ../lib/vector/Vlib/open.c:496
#, c-format
-msgid "Cannot write quant rules for map %s"
-msgstr "Nelze zapsat kvantizaèní pravidla pro mapu %s"
+msgid "Vector map name is not SQL compliant"
+msgstr "Název mapy nevyhovuje podmínkám SQL"
-#: ../lib/gis/raster_metadata.c:111
+#: ../lib/vector/Vlib/map.c:173 ../lib/vector/Vlib/map.c:297
+#: ../lib/vector/Vlib/open.c:503
#, c-format
-msgid "Can't read %s for [%s in %s]"
-msgstr "Nelze èíst %s pro [%s z %s]"
+msgid "Vector map <%s> already exists and will be overwritten"
+msgstr "Vektorová mapa <%s> ji¾ existuje a bude pøepsána."
-#: ../lib/gis/raster_metadata.c:143
+#: ../lib/vector/Vlib/map.c:176 ../lib/vector/Vlib/open.c:507
#, c-format
-msgid "Can't create %s metadata file for [%s in %s]"
-msgstr "Nelze vytvoøit soubor s metadaty %s pro [%s z %s]"
+msgid "Unable to delete vector map <%s>"
-#: ../lib/gis/timestamp.c:298
+#: ../lib/vector/Vlib/map.c:199 ../lib/vector/Vlib/map.c:308
#, c-format
-msgid "Can't create timestamp file for %s map %s in mapset %s"
-msgstr "Nelze vytvoøit soubor s èasovou znaèkou pro %s mapu %s v mapsetu %s"
+msgid "Unable to copy vector map <%s> to <%s>"
+msgstr "Nelze kopírovat vektorovou mapu <%s> do <%s>"
-#: ../lib/gis/timestamp.c:308
+#: ../lib/vector/Vlib/map.c:227 ../lib/vector/Vlib/map.c:340
+#: ../lib/vector/Vlib/map.c:444 ../lib/vector/Vlib/map.c:552
+#: ../lib/vector/Vlib/map.c:639 ../lib/vector/Vlib/array.c:264
+#: ../lib/vector/Vlib/net.c:170 ../lib/vector/Vlib/net.c:308
#, c-format
-msgid "Invalid timestamp specified for %s map %s in mapset %s"
-msgstr "Neplatná èasová znaèka specifikovaná pro %s mapu %s v mapsetu %s"
+msgid "Database connection not defined for layer %d"
+msgstr "Pro vrstvu %d nebylo definováno databázové pøipojení"
-#: ../lib/gis/timestamp.c:332
+#: ../lib/vector/Vlib/map.c:241 ../lib/vector/Vlib/map.c:355
+#: ../lib/vector/Vlib/map.c:572 ../lib/vector/Vlib/map.c:665
#, c-format
-msgid "Can't open timestamp file for %s map %s in mapset %s"
-msgstr "Nelze otevøít soubor s èasovou znaèkou pro %s mapu %s v mapsetu %s"
+msgid "Unable to copy table <%s>"
+msgstr "Nelze kopírovat tabulku <%s>"
-#: ../lib/gis/timestamp.c:342
+#: ../lib/vector/Vlib/map.c:249 ../lib/vector/Vlib/map.c:376
+#: ../lib/vector/Vlib/map.c:578 ../lib/vector/Vlib/array.c:270
+#: ../lib/vector/Vlib/net.c:176 ../lib/vector/Vlib/net.c:313
#, c-format
-msgid "Invalid timestamp file for %s map %s in mapset %s"
-msgstr "Neplatný soubor s èasovou znaèkou pro %s mapu %s v mapsetu %s"
+msgid "Unable to open database <%s> by driver <%s>"
+msgstr "Nelze otevøít databázi <%s> pomocí ovladaèe <%s>"
-#: ../lib/gis/adj_cellhd.c:47 ../lib/gis/adj_cellhd.c:196
-msgid "Illegal n-s resolution value"
-msgstr "Neplatná hodnota rozli¹ení sever-jih"
+#: ../lib/vector/Vlib/map.c:253 ../lib/vector/Vlib/map.c:380
+#: ../lib/vector/Vlib/map.c:582
+#, c-format
+msgid "Unable to create index for table <%s>, key <%s>"
+msgstr "Nelze vytvoøit index pro tabulku <%s>, klíè <%s>"
-#: ../lib/gis/adj_cellhd.c:52 ../lib/gis/adj_cellhd.c:203
-msgid "Illegal row value"
-msgstr "Neplatná hodnota øádku"
+#: ../lib/vector/Vlib/map.c:305 ../lib/vector/Vlib/legal_vname.c:108
+#: ../lib/vector/Vlib/legal_vname.c:110 ../lib/vector/Vlib/open.c:156
+#, c-format
+msgid "Vector map <%s> not found"
+msgstr "Vektorová mapa <%s> nebyla nalezena"
-#: ../lib/gis/adj_cellhd.c:57 ../lib/gis/adj_cellhd.c:210
-msgid "Illegal e-w resolution value"
-msgstr "Neplatná hodnota rozli¹ení východ-západ"
+#: ../lib/vector/Vlib/map.c:369 ../lib/vector/Vlib/map.c:462
+#, c-format
+msgid "Unable to delete table <%s>"
+msgstr "Nelze smazat tabulku <%s>"
-#: ../lib/gis/adj_cellhd.c:62 ../lib/gis/adj_cellhd.c:217
-msgid "Illegal col value"
-msgstr "Neplatná hodnota sloupce"
+#: ../lib/vector/Vlib/map.c:417
+#, c-format
+msgid "Invalid vector map name <%s>"
+msgstr "Nesrpávné jméno vektorové mapy <%s>"
-#: ../lib/gis/adj_cellhd.c:81 ../lib/gis/adj_cellhd.c:248
+#: ../lib/vector/Vlib/map.c:433
#, c-format
-msgid "Fixing subtle input data rounding error of north boundary (%g>%g)"
-msgstr "O¹etøuji podrobná vstupní data zaokrouhlením severní hranice (%g>%g)"
+msgid "Unable to open header file for vector map <%s>"
+msgstr "Nelze otevøít hlavièkový soubor pro vektorovou mapu <%s>"
-#: ../lib/gis/adj_cellhd.c:84 ../lib/gis/adj_cellhd.c:251
-msgid "Illegal latitude for North"
-msgstr "Neplatná zem. ¹íøka pro sever"
+#: ../lib/vector/Vlib/map.c:453
+#, c-format
+msgid "Unable to find table <%s> linked to vector map <%s>"
+msgstr "Nelze nelézt tabulku <%s> pøipojenou k vektorové mapì <%s>"
-#: ../lib/gis/adj_cellhd.c:89 ../lib/gis/adj_cellhd.c:256
+#: ../lib/vector/Vlib/map.c:467
#, c-format
-msgid "Fixing subtle input data rounding error of south boundary (%g>%g)"
-msgstr ""
-"O¹etøuji pøíli¹ podrobná vstupní data zaokrouhlením ji¾ní hranice (%g>%g)"
+msgid "Table <%s> linked to vector map <%s> does not exist"
+msgstr "Tabulka <%s> pøipojená k vektorové mapì <%s> neexistuje"
-#: ../lib/gis/adj_cellhd.c:92 ../lib/gis/adj_cellhd.c:259
-msgid "Illegal latitude for South"
-msgstr "Neplatná zem. ¹íøka pro jih"
+#: ../lib/vector/Vlib/map.c:481
+#, c-format
+msgid "Unable to open directory '%s'"
+msgstr "Nelze otevøít adresáø <%s>"
-#: ../lib/gis/adj_cellhd.c:103 ../lib/gis/adj_cellhd.c:270
+#: ../lib/vector/Vlib/map.c:492
#, c-format
-msgid "Fixing subtle input data rounding error of west boundary (%g>%g)"
+msgid "Unable to delete file '%s'"
+#: ../lib/vector/Vlib/map.c:509
+#, c-format
+msgid "Unable to rename directory '%s' to '%s'"
+msgstr "Nelze pøejmenovat adresáø '%s' na '%s'"
+#: ../lib/vector/Vlib/map.c:517
+#, c-format
+msgid "Unable to remove directory '%s'"
+msgstr "Nelze smazat adresáø '%s'"
+#: ../lib/vector/Vlib/map.c:564 ../lib/vector/Vlib/map.c:653
+#, c-format
+msgid "Unable to add database link for vector map <%s>"
+msgstr "Nelze pøipojit databázi k vektorové mapì <%s>"
+#: ../lib/vector/Vlib/open_nat.c:143
+#, c-format
+msgid ""
+"Coor files of vector map <%s@%s> is larger than it should be (%ld bytes "
+"excess)"
msgstr ""
-"O¹etøuji pøíli¹ podrobná vstupní data zaokrouhlením západní hranice (%g>%g)"
-#: ../lib/gis/adj_cellhd.c:113 ../lib/gis/adj_cellhd.c:280
+#: ../lib/vector/Vlib/open_nat.c:146
#, c-format
-msgid "Fixing subtle input data rounding error of east boundary (%g>%g)"
+msgid ""
+"Coor files of vector <%s@%s> is shorter than it should be (%ld bytes "
+"missing)."
msgstr ""
-"O¹etøuji pøíli¹ podrobná vstupní data zaokrouhlením východní hranice (%g>%g)"
-#: ../lib/gis/adj_cellhd.c:127 ../lib/gis/adj_cellhd.c:294
-msgid "North must be north of South"
-msgstr "Sever musí být severnì oproti jihu"
+#: ../lib/vector/Vlib/legal_vname.c:43
+#, c-format
+msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
+msgstr "Neplatný název vektorové mapy <%s>. Nesmí obsahovat '.' nebo 'NIC'."
-#: ../lib/gis/adj_cellhd.c:129 ../lib/gis/adj_cellhd.c:296
-msgid "North must be larger than South"
-msgstr "Hodnota pro sever musí být vìt¹í ne¾ pro jih"
+#: ../lib/vector/Vlib/legal_vname.c:49
+#, c-format
+msgid "Illegal vector map name <%s>. Must start with a letter."
+msgstr "Neplatný název vektorové mapy <%s>. Musí zaèínat písmenem."
-#: ../lib/gis/adj_cellhd.c:132 ../lib/gis/adj_cellhd.c:299
-msgid "East must be larger than West"
-msgstr "Hodnota pro východ musí být vìt¹í ne¾ pro západ"
+#: ../lib/vector/Vlib/legal_vname.c:56
+#, c-format
+msgid "Illegal vector map name <%s>. Character '%c' not allowed."
+msgstr "Neplatné název vektorové mapy <%s>. Znak <%c> není povolen."
-#: ../lib/gis/adj_cellhd.c:150 ../lib/gis/adj_cellhd.c:337
-msgid "Invalid coordinates"
-msgstr "Neplatné souøadnice"
+#: ../lib/vector/Vlib/legal_vname.c:66
+#, c-format
+msgid ""
+"Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
+msgstr ""
+"Neplatné název vektorové mapy <%s>. SQL klíèové slovo nelze pou¾ít jako "
+"název vektorové mapy."
-#: ../lib/gis/adj_cellhd.c:198
-msgid "Illegal n-s3 resolution value"
-msgstr "Neplatné n-s3 rozli¹ení"
+#: ../lib/vector/Vlib/legal_vname.c:95 ../lib/vector/Vlib/legal_vname.c:97
+#, c-format
+msgid "Output vector map name <%s> is not valid map name"
+msgstr "Název výstupu <%s> není platným názvem rastrové mapy."
-#: ../lib/gis/adj_cellhd.c:205
-msgid "Illegal row3 value"
-msgstr "Neplatný poèet øádek (row3)"
+#: ../lib/vector/Vlib/legal_vname.c:128 ../lib/vector/Vlib/legal_vname.c:130
+#, c-format
+msgid "Output vector map <%s> is used as input"
+msgstr "Výstupní mapa <%s> je pou¾ita jako vstup."
-#: ../lib/gis/adj_cellhd.c:212
-msgid "Illegal e-w3 resolution value"
-msgstr "Neplatné e-w3 rozli¹ení"
+#: ../lib/vector/Vlib/break_lines.c:116
+#, c-format
+msgid "%s %5d"
+msgstr ""
-#: ../lib/gis/adj_cellhd.c:219
-msgid "Illegal col3 value"
-msgstr "Neplatný poèet sloupcù (col3)"
+#: ../lib/vector/Vlib/break_lines.c:116 ../lib/vector/Vlib/break_lines.c:323
+#: ../lib/vector/Vlib/break_lines.c:341
+#, fuzzy
+msgid "Intersections:"
+msgstr "Ostatní mapové projekce"
-#: ../lib/gis/adj_cellhd.c:224
-msgid "Illegal t-b3 resolution value"
-msgstr "Neplatná hodnota rozli¹ení t-b3"
+#: ../lib/vector/Vlib/write_nat.c:38
+#, c-format
+msgid "BUG (delete_area_cats_from_cidx): Area %d does not exist"
+msgstr "BUG (delete_area_cats_from_cidx): Plocha %d neexistuje"
-#: ../lib/gis/adj_cellhd.c:229
-msgid "Illegal depths value"
-msgstr "Neplatný poèet øádek"
+#: ../lib/vector/Vlib/write_nat.c:60
+#, c-format
+msgid "BUG (add_area_cats_to_cidx): Area %d does not exist"
+msgstr "BUG (add_area_cats_to_cidx):Plocha %d neexistuje"
-#: ../lib/gis/adj_cellhd.c:301
-msgid "Top must be larger than Bottom"
-msgstr "Svrní hodnota musí být vìt¹í, ne¾ spodní."
+#: ../lib/vector/Vlib/write_nat.c:565
+msgid "Attempt to delete dead line"
+msgstr "Pokus o odstranìní mrtvé linie"
-#: ../lib/gis/rd_cellhd.c:136
-msgid "duplicate projection field"
-msgstr "duplicitní polo¾ka mapové projekce"
+#: ../lib/vector/Vlib/snap.c:119 ../lib/vector/Vlib/snap.c:159
+#: ../lib/vector/Vlib/break_polygons.c:191
+#: ../lib/vector/Vlib/break_polygons.c:198
+msgid "Registering points"
+msgstr "Registrace bodù"
-#: ../lib/gis/rd_cellhd.c:147
-msgid "duplicate zone field"
-msgstr "duplicitní polo¾ka zóny"
+#: ../lib/vector/Vlib/snap.c:168
+msgid "All vertices"
+msgstr "V¹echny opìrné body"
-#: ../lib/gis/rd_cellhd.c:157
-msgid "projection field missing"
-msgstr "chybìjící polo¾ka mapové projekce"
+#: ../lib/vector/Vlib/snap.c:169
+msgid "Registered points"
+msgstr "Registrovaných bodù"
-#: ../lib/gis/rd_cellhd.c:159
-msgid "zone field missing"
-msgstr "chybìjící polo¾ka zóny"
+#: ../lib/vector/Vlib/snap.c:214
+msgid "Nodes marked as anchor"
+msgstr "Uzel oznaèen jako fixní"
-#: ../lib/gis/rd_cellhd.c:181
-msgid "duplicate north field"
-msgstr "duplicitní polo¾ka pro sever"
+#: ../lib/vector/Vlib/snap.c:215
+msgid "Nodes marked to be snapped"
+msgstr "Uzel oznaèen jako pøipojený"
-#: ../lib/gis/rd_cellhd.c:190
-msgid "duplicate south field"
-msgstr "duplicitní polo¾ka pro jih"
+#: ../lib/vector/Vlib/snap.c:224 ../lib/vector/Vlib/snap.c:364
+msgid "Snaps"
+msgstr "Pøipojení"
-#: ../lib/gis/rd_cellhd.c:199
-msgid "duplicate east field"
-msgstr "duplicitní polo¾ka pro východ"
+#: ../lib/vector/Vlib/snap.c:372
+msgid "Snapped vertices"
+msgstr "Pøipojených opìrných bodù"
-#: ../lib/gis/rd_cellhd.c:208
-msgid "duplicate west field"
-msgstr "duplicitní polo¾ka pro západ"
+#: ../lib/vector/Vlib/snap.c:373
+msgid "New vertices"
+msgstr "Nový opìrný bod"
-#: ../lib/gis/rd_cellhd.c:217
-msgid "duplicate top field"
-msgstr "duplicitní polo¾ka pro horní èást"
+#: ../lib/vector/Vlib/poly.c:243
+msgid "Unable to find point in polygon"
+msgstr "Nelze nalézt bod v polygonu"
-#: ../lib/gis/rd_cellhd.c:226
-msgid "duplicate bottom field"
-msgstr "duplicitní polo¾ka pro spodní èást"
+#: ../lib/vector/Vlib/poly.c:661
+#, fuzzy
+msgid "conditions failed"
+msgstr "Pøipojení selhalo."
-#: ../lib/gis/rd_cellhd.c:235
-msgid "duplicate e-w resolution field"
-msgstr "duplicitní polo¾ka pro rozli¹ené e-w"
+#: ../lib/vector/Vlib/open_ogr.c:54
+msgid "OGR format cannot be updated"
+msgstr "Formát OGR nelze aktualizovat"
-#: ../lib/gis/rd_cellhd.c:246
-msgid "duplicate 3D e-w resolution field"
-msgstr "duplicitní polo¾ka pro 3D rozli¹ení e-w"
+#: ../lib/vector/Vlib/open_ogr.c:66
+#, c-format
+msgid "Unable to open OGR data source '%s'"
+msgstr "Nelze otevøít zdroj dat OGR '%s'"
-#: ../lib/gis/rd_cellhd.c:257
-msgid "duplicate n-s resolution field"
-msgstr "duplicitní polo¾ka pro rozli¹ení n-s"
+#: ../lib/vector/Vlib/open_ogr.c:84
+#, c-format
+msgid "Unable to open layer <%s>"
+msgstr "Nelze otevøít vrstvu <%s>"
-#: ../lib/gis/rd_cellhd.c:268
-msgid "duplicate 3D n-s resolution field"
-msgstr "duplicitní polo¾ka pro 3D rozli¹ení n-s rozli¹ení"
+#: ../lib/vector/Vlib/open_ogr.c:128
+#, c-format
+msgid "Unable to open fidx file for vector map <%s@%s>"
+msgstr "Nelze otevøít soubor fidx pro vektorovou mapu <%s@%s>"
-#: ../lib/gis/rd_cellhd.c:279
-msgid "duplicate t-b resolution field"
-msgstr "duplicitní polo¾ka pro t-b rozli¹ení"
+#: ../lib/vector/Vlib/open_ogr.c:144
+#, c-format
+msgid ""
+"Feature index format version %d.%d is not supported by this release. Try to "
+"rebuild topology or upgrade GRASS."
+msgstr ""
-#: ../lib/gis/rd_cellhd.c:290
-msgid "duplicate rows field"
-msgstr "duplicitní polo¾ka pro øádky"
+#: ../lib/vector/Vlib/open_ogr.c:148
+#, c-format
+msgid ""
+"Your GRASS version does not fully support feature index format %d.%d of the "
+"vector. Consider to rebuild topology or upgrade GRASS."
+msgstr ""
+"Va¹e verze GRASS plnì nepodporuje formát indexování prvkù %d. %d vektorové "
+"mapy. Zva¾te pøebudování topologie nebo upgrade GRASS."
-#: ../lib/gis/rd_cellhd.c:301
-msgid "duplicate 3D rows field"
-msgstr "duplicitní polo¾ka pro 3D øádky"
+#: ../lib/vector/Vlib/graph.c:107 ../lib/vector/Vlib/net.c:380
+msgid "GngFlatten error"
+msgstr "Chyba GngFlatten"
-#: ../lib/gis/rd_cellhd.c:312
-msgid "duplicate cols field"
-msgstr "duplicitní polo¾ka pro sloupce"
+#: ../lib/vector/Vlib/graph.c:137
+msgid "Unable to add network arc"
+msgstr "Nelze pøidat arc do sítì"
-#: ../lib/gis/rd_cellhd.c:323
-msgid "duplicate 3D cols field"
-msgstr "duplicitní polo¾ka pro 3D sloupce"
+#: ../lib/vector/Vlib/graph.c:218 ../lib/vector/Vlib/net.c:449
+#, c-format
+msgid "dglShortestPath error: %s"
+msgstr "chyba dglShortestPath: %s"
-#: ../lib/gis/rd_cellhd.c:334
-msgid "duplicate depths field"
-msgstr "duplicitní polo¾ka pro hloubky"
+#: ../lib/vector/Vlib/level_two.c:217 ../lib/vector/Vlib/level_two.c:242
+#: ../lib/vector/Vlib/level_two.c:266 ../lib/vector/Vlib/level_two.c:285
+#: ../lib/vector/Vlib/level_two.c:303 ../lib/vector/Vlib/level_two.c:322
+#, c-format
+msgid "Vector map <%s> is not open on level >= 2"
+msgstr "Vektorová mapa <%s> není otevøena na úrovòi >= 2"
-#: ../lib/gis/rd_cellhd.c:345
-msgid "duplicate format field"
-msgstr "duplicitní polo¾ka pro formát"
+#: ../lib/vector/Vlib/clean_nodes.c:52 ../lib/vector/Vlib/clean_nodes.c:216
+msgid "Modifications"
+msgstr "Modifikace"
-#: ../lib/gis/rd_cellhd.c:354
-msgid "duplicate compressed field"
-msgstr "duplicitní komprimovaná polo¾ka"
+#: ../lib/vector/Vlib/cindex.c:30
+msgid "Category index is not up to date"
+msgstr "Index kategorií není aktuální"
-#: ../lib/gis/rd_cellhd.c:365
-msgid "north field missing"
-msgstr "chybí polo¾ka pro sever"
+#: ../lib/vector/Vlib/cindex.c:62 ../lib/vector/Vlib/cindex.c:129
+#: ../lib/vector/Vlib/cindex.c:148 ../lib/vector/Vlib/cindex.c:171
+msgid "Invalid layer index (index >= number of layers)"
+msgstr "©patný index vrstvy (index >= poèet vrstev)"
-#: ../lib/gis/rd_cellhd.c:367
-msgid "south field missing"
-msgstr "chybí polo¾ka pro jih"
+#: ../lib/vector/Vlib/cindex.c:110
+msgid "Invalid layer index (index < 0 or index >= number of layers)"
+msgstr "©patný index vrstvy (index < 0 nebo index >= poèet vrstev)"
-#: ../lib/gis/rd_cellhd.c:369
-msgid "west field missing"
-msgstr "chybí polo¾ka pro západ"
+#: ../lib/vector/Vlib/cindex.c:235
+msgid "Layer or category index out of range"
+msgstr "Index vrstev nebo kategorií mimo rozsah"
-#: ../lib/gis/rd_cellhd.c:371
-msgid "east field missing"
-msgstr "chybí polo¾ka pro východ"
+#: ../lib/vector/Vlib/cindex.c:283
+msgid "Layer index out of range"
+msgstr "Index vrstev je mimo rozsah"
-#: ../lib/gis/rd_cellhd.c:373
-msgid "cols field missing"
-msgstr "chybí polo¾ka pro sloupce"
+#: ../lib/vector/Vlib/cindex.c:457
+#, c-format
+msgid "Unable to open cidx file <%s> for write"
+msgstr "Nelze otevøít soubor s indexem kategorií <%s> pro zápis"
-#: ../lib/gis/rd_cellhd.c:375
-msgid "rows field missing"
-msgstr "chybí polo¾ka pro øádky"
+#: ../lib/vector/Vlib/cindex.c:465
+#, c-format
+msgid "Error writing out category index file <%s>"
+msgstr "Chyba pøi zápisu souboru s indexem kategorií <%s>"
-#: ../lib/gis/rd_cellhd.c:386
-msgid "ewres3 field missing"
-msgstr "chybí polo¾ka pro ewres3"
+#: ../lib/vector/Vlib/cindex.c:508
+#, c-format
+msgid "Unable to open category index file for vector map <%s@%s>"
+msgstr "Nelze otevøít soubor s indexem kategorií pro vektorovou mapu <%s@%s>"
-#: ../lib/gis/rd_cellhd.c:388
-msgid "nsres3 field missing"
-msgstr "chybí polo¾ka pro nsres3"
+#: ../lib/vector/Vlib/remove_duplicates.c:69
+#: ../lib/vector/Vlib/remove_duplicates.c:137
+msgid "Duplicates"
+msgstr "Zdvojení"
-#: ../lib/gis/rd_cellhd.c:390
-msgid "cols3 field missing"
-msgstr "chybí polo¾ka pro cols3"
+#: ../lib/vector/Vlib/write.c:25 ../lib/vector/Vlib/write.c:29
+#: ../lib/vector/Vlib/write.c:33
+msgid "for this format/level not supported"
+msgstr "pro tento formát/úroveò není podpora"
-#: ../lib/gis/rd_cellhd.c:392
-msgid "rows3 field missing"
-msgstr "chybí polo¾ka pro rows3"
+#: ../lib/vector/Vlib/write.c:38 ../lib/vector/Vlib/open.c:34
+#: ../lib/vector/Vlib/rewind.c:34 ../lib/vector/Vlib/build.c:29
+#: ../lib/vector/Vlib/close.c:36 ../lib/vector/Vlib/read.c:27
+msgid "Requested format is not compiled in this version"
+msgstr "Po¾adovaný formát není zkompilován v této verzi"
-#: ../lib/gis/rd_cellhd.c:448
-#, c-format
-msgid "line %d: <%s>"
-msgstr "øádek %d: <%s>"
+#: ../lib/vector/Vlib/write.c:96
+msgid "Unable to write line, vector map is not opened"
+msgstr "Nelze zapsat linii, vektorová mapa není otevøena"
-#: ../lib/gis/auto_mask.c:66
-msgid "Unable to open automatic MASK file"
-msgstr "Nelze automaticky otevøít soubor MASK"
+#: ../lib/vector/Vlib/write.c:107
+msgid "Unable to write line (negative offset)"
+msgstr "Nelze zapsat linii (záporný offset)"
-#: ../lib/gis/env.c:248
-msgid "GISRC - variable not set"
-msgstr "GISRC - promìnná není nastavena"
+#: ../lib/vector/Vlib/write.c:143
+msgid "Unable to rewrite line, vector map is not opened"
+msgstr "Nelze pøepsat linii, vektorová mapa není otevøena"
-#: ../lib/gis/env.c:279
-#, fuzzy, c-format
-msgid "G_getenv(): Variable %s not set"
-#: ../lib/gis/env.c:305
+#: ../lib/vector/Vlib/write.c:154
#, c-format
-msgid "%s not set"
-msgstr "%s není nastaveno"
+msgid "Unable to rewrite line %d"
+msgstr "Nelze pøepsat linii %d"
-#: ../lib/gis/done_msg.c:37
+#: ../lib/vector/Vlib/write.c:201
#, c-format
-msgid "%s complete. %s"
-msgstr "%s hotovo. %s"
+msgid "Unable to delete line %d, vector map <%s> is not opened on topo level 2"
+msgstr ""
+"Nelze odstranit linii %d, vektorová mapa <%s> není otevøena na úrovni "
+"topologie 2"
-#: ../lib/gis/get_window.c:69 ../lib/gis/get_window.c:88
+#: ../lib/vector/Vlib/write.c:206
#, c-format
-msgid ""
-"region for current mapset %s\n"
-"run \"g.region\""
+msgid "Unable to delete line %d, vector map <%s> is not opened in 'write' mode"
msgstr ""
-"region pro aktuální mapset %s\n"
-"spus»te \"g.region\""
+"Nelze odstranit linii %d, vektorová mapa <%s> není otevøena v módu pro "
+"'zápis'"
-#: ../lib/gis/get_window.c:124
+#: ../lib/vector/Vlib/write.c:219
#, c-format
-msgid "default region %s"
-msgstr "výchozí region (zájmové území) %s"
+msgid "Unable to delete line %d from vector map <%s>"
+msgstr "Nelze smazat linii %d z vektorové vrstvy <%s>"
-#: ../lib/gis/get_window.c:146
-msgid "is not set"
-msgstr "není nastaveno"
+#: ../lib/vector/Vlib/remove_areas.c:56 ../lib/vector/Vlib/remove_areas.c:168
+msgid "Removed areas"
+msgstr "Odstranìné plochy"
-#: ../lib/gis/get_window.c:156
+#: ../lib/vector/Vlib/remove_areas.c:93
+msgid "Area is composed of dead boundary"
+msgstr "Plocha je poslkládána z mrtvých hranic"
+#: ../lib/vector/Vlib/level.c:39
+msgid "Map structure was never initialized"
+msgstr "Vektorová struktura nebyla nikdy inicializována"
+#: ../lib/vector/Vlib/level.c:41
+msgid "Map structure has been closed"
+msgstr "Struktura mapy byla uzavøena"
+#: ../lib/vector/Vlib/array.c:97
#, c-format
+msgid "%d errors in category string."
+msgstr "%d chyb v "
+#: ../lib/vector/Vlib/array.c:140 ../lib/vector/Vlib/array.c:255
+msgid "Mixed area and other type requested for vector array"
+msgstr "Pro vektorové pole jsou po¾adovány plochy a jiné typy dat"
+#: ../lib/vector/Vlib/array.c:150 ../lib/vector/Vlib/array.c:170
+#: ../lib/vector/Vlib/array.c:289 ../lib/vector/Vlib/array.c:319
+msgid "Not enough space in vector array"
+msgstr "Nedostatek místa ve vektorovém poli"
+#: ../lib/vector/Vlib/array.c:280
+#, c-format
+msgid "Unable to select record from table <%s> (key %s, where %s)"
+msgstr "Nelze vybrat záznam z tabulky <%s> (klíè %s, where %s)"
+#: ../lib/vector/Vlib/dangles.c:169 ../lib/vector/Vlib/dangles.c:263
+#: ../lib/vector/Vlib/dangles.c:274
+#, fuzzy
+msgid "Removed dangles:"
+msgstr "Odstranìné mosty"
+#: ../lib/vector/Vlib/open.c:93
+#, c-format
+msgid "Programmer requested unknown open level %d"
+msgstr "Programátor po¾adoval neznámé otevøení na úrovni %d"
+#: ../lib/vector/Vlib/open.c:166
msgid ""
-"is invalid\n"
-"%s"
+"Vector map which is not in the current mapset cannot be opened for update"
msgstr ""
-"je neplatný\n"
-"%s"
+"Mapa, která není obsa¾ena v aktuálním mapsetu, nemù¾e být otevøena pro zápis"
-#: ../lib/gis/mask_info.c:42
+#: ../lib/vector/Vlib/open.c:184
#, c-format
-msgid "<%s> in mapset <%s>"
-msgstr "<%s> v mapsetu <%s>"
+msgid "Unable to open vector map <%s>"
+msgstr "Nelze otevøít vektorovou mapu <%s>"
-#: ../lib/gis/mask_info.c:45
-msgid "none"
-msgstr "nic"
+#: ../lib/vector/Vlib/open.c:194 ../lib/vector/Vlib/open.c:254
+#: ../lib/vector/Vlib/open.c:271
+#, c-format
+msgid "Unable to open vector map <%s> on topology level %d"
+msgstr "Nelze otevøít existující vektorovou mapu <%s> na úrovni %d"
-#: ../lib/gis/mask_info.c:48
-msgid "not known"
-msgstr "neznámý"
+#: ../lib/vector/Vlib/open.c:195
+msgid "Unable to read head file"
-#: ../lib/gis/color_read.c:123
+#: ../lib/vector/Vlib/open.c:215
#, c-format
-msgid "color support for [%s] in mapset [%s] %s"
-msgstr "podpora barev pro [%s] v mapsetu [%s] %s"
+msgid "Unable to open topology file for vector map <%s>"
+msgstr "Nelze otevøít soubor s topologií pro vektorovou mapu <%s>"
-#: ../lib/gis/view.c:180
+#: ../lib/vector/Vlib/open.c:238
#, c-format
-msgid "Unable to open %s for writing"
-msgstr "Nelze otevøít %s pro zápis"
+msgid "Unable to open category index file for vector map <%s>"
+msgstr "Nelze otevøít soubor s historií pro vektorovou mapu <%s>"
-#: ../lib/gis/view.c:269 ../lib/gis/view.c:486
+#: ../lib/vector/Vlib/open.c:319 ../lib/vector/Vlib/open.c:530
#, c-format
-msgid "Unable to open %s for reading"
-msgstr "Nelze otevøít %s pro ètení"
+msgid "Unable to open history file for vector map <%s>"
-#: ../lib/gis/view.c:472
+#: ../lib/vector/Vlib/open.c:521
#, c-format
-msgid "GRASS window when view was saved:\n"
-msgstr "Okno GRASSu kdy¾ byl ulo¾en pohled:\n"
+msgid "Unable to create vector map <%s>"
+msgstr "Nelze vytvoøit vektorovou mapu <%s>"
-#: ../lib/gis/view.c:547
+#: ../lib/vector/Vlib/open.c:576
#, c-format
-msgid " Window saved in \"%s\" is completely outside of current GRASS window."
-msgstr " Okno ulo¾eno v \"%s\" je zcela mimo aktuální okno GRASSu."
+msgid "Unable to stat file <%s>"
+msgstr "Nelze otevøít soubor <%s>"
-#: ../lib/gis/view.c:550
+#: ../lib/vector/Vlib/open.c:683
+msgid "Size of 'coor' file differs from value saved in topology file"
+msgstr ""
+"Velikost souboru 'coor' se li¹í od hodnot ulo¾ených v souboru s topologií"
+#: ../lib/vector/Vlib/open.c:694
#, c-format
-msgid ""
-" Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
-msgstr " Pouze %d%% z okna ulo¾eného v \"%s\" pokrývá aktuální okno GRASSu."
+msgid "Please rebuild topology for vector map <%s@%s>"
+msgstr "Vytvoøte prosím znovu topologii pro vektorovou mapu <%s@%s>"
-#: ../lib/gis/ask.c:339
-msgid "to cancel request"
-msgstr "pro zru¹ení po¾adavku"
+#: ../lib/vector/Vlib/net.c:119
+msgid "Building graph..."
+msgstr "Vytváøení grafu ..."
-#: ../lib/gis/ask.c:395
+#: ../lib/vector/Vlib/net.c:155
+msgid "Unable to build network graph"
+msgstr "Nelze sestavit sí»ový grafu"
+#: ../lib/vector/Vlib/net.c:161
+msgid "Forward costs column not specified"
+msgstr "Sloupec pro váhu smìr dopøedu není specifikován"
+#: ../lib/vector/Vlib/net.c:167
+msgid "Arc field < 1"
+msgstr "Arc vrtsva < 1"
+#: ../lib/vector/Vlib/net.c:181 ../lib/vector/Vlib/net.c:196
+#: ../lib/vector/Vlib/net.c:318
#, c-format
-msgid "Enter a new %s file name"
-msgstr "Zadejte název nového %s souboru"
+msgid "Column <%s> not found in table <%s>"
+msgstr "Sloupec <%s> nebyl nalezen v tabulce <%s>"
-#: ../lib/gis/ask.c:401
+#: ../lib/vector/Vlib/net.c:187 ../lib/vector/Vlib/net.c:202
+#: ../lib/vector/Vlib/net.c:324
#, c-format
-msgid "Enter the name of an existing %s file"
-msgstr "Zadejte název existujícího %s souboru"
+msgid "Data type of column <%s> not supported (must be numeric)"
+msgstr ""
+"Datový typ sloupce <%s> není podporován (musí být interger nebo double)"
-#: ../lib/gis/ask.c:405
+#: ../lib/vector/Vlib/net.c:213
+#, fuzzy
+msgid "Registering arcs..."
+msgstr "Registrace arcs ..."
+#: ../lib/vector/Vlib/net.c:235
#, c-format
-msgid "Enter %s file name"
-msgstr "Zadatejte název %s souboru"
+msgid ""
+"Database record for line %d (cat = %d, forward/both direction(s)) not found "
+"(forward/both direction(s) of line skipped)"
+msgstr ""
+"Datová polo¾ka pro linii %d (cat = %d, dopøedu/oba smìry nebyla nalezena"
+"(dopøedu/oba smìry linie pøeskoèeny)"
-#: ../lib/gis/ask.c:425
+#: ../lib/vector/Vlib/net.c:249
#, c-format
-msgid "Enter 'list' for a list of existing %s files\n"
-msgstr "Zadejte 'list' pro výpis existujících %s souborù\n"
+msgid ""
+"Database record for line %d (cat = %d, backword direction) not found"
+"(direction of line skipped)"
+msgstr ""
+"Datová polo¾ka pro linii %d (cat = %d, smìr dozadu) nebyla nalezena(smìr "
+"linie pøeskoèen)"
-#: ../lib/gis/ask.c:428
+#: ../lib/vector/Vlib/net.c:282
+msgid "Cannot add network arc"
+msgstr "Nelze pøidat arc sítì"
+#: ../lib/vector/Vlib/net.c:304
+#, fuzzy
+msgid "Setting node costs..."
+msgstr "Nastavení váhy uzlù ..."
+#: ../lib/vector/Vlib/net.c:353
#, c-format
-msgid "Enter 'list -f' for "
-msgstr "Zadejte 'list -f' pro"
+msgid "Database record for node %d (cat = %d) not found (cost set to 0)"
+msgstr ""
+"Datový záznam pro uzel %d (cat = %d) nebyl nalezen (váha nastavena na 0)"
-#: ../lib/gis/ask.c:430
+#: ../lib/vector/Vlib/net.c:377
+msgid "Flattening the graph..."
+msgstr "Zpracování grafu ..."
+#: ../lib/vector/Vlib/net.c:387
+msgid "Graph was built"
+msgstr "Struktura grafu sestavena"
+#: ../lib/vector/Vlib/net.c:525
+msgid "Wrong line direction in Vect_net_get_line_cost()"
+msgstr "Chybný smìr linie ve Vect_net_get_line_cost()"
+#: ../lib/vector/Vlib/area.c:55
+msgid "Attempt to read points of nonexisting area"
+msgstr "Pokus o ètení bodù z neexistující plochy"
+#: ../lib/vector/Vlib/area.c:131
#, c-format
-msgid "a list %s"
-msgstr "výpis %s"
+msgid "Unable to read line %d"
-#: ../lib/gis/ask.c:432
+#: ../lib/vector/Vlib/area.c:173 ../lib/vector/Vlib/area.c:205
+#: ../lib/vector/Vlib/area.c:274 ../lib/vector/Vlib/area.c:307
#, c-format
-msgid "an extended list"
-msgstr "roz¹íøený výpis"
+msgid "Attempt to read topo for dead area (%d)"
+msgstr "Pokus èíst topologii pro mrtvou plochu (%d)"
-#: ../lib/gis/ask.c:436
+#: ../lib/vector/Vlib/area.c:335
+#, fuzzy, c-format
+msgid "Attempt to read topo for dead isle (%d)"
+msgstr "Pokus èíst mrtvou linii [%d]"
+#: ../lib/vector/Vlib/line.c:61
+msgid "Out of memory"
+msgstr "Nedostatek pamìti"
+#: ../lib/vector/Vlib/line.c:205 ../lib/vector/Vlib/line.c:237
+msgid "Index out of range in"
+msgstr "Index je mimo rozsah"
+#: ../lib/vector/Vlib/line.c:522
+msgid "Segment outside line, no segment created"
+msgstr "Segment je mimo linii, ¾ádný segment nebude vytvoøen"
+#: ../lib/vector/Vlib/build_nat.c:93
+msgid "Unable to add area (map closed, topo saved)"
+msgstr "Nelze pøidat plochu (mapa uzavøena, topologie ulo¾ena)"
+#: ../lib/vector/Vlib/build_nat.c:101
+msgid "Unable to add isle (map closed, topo saved)"
+msgstr "Nelze pøidat ostrov (mapa uzavøena, topologie ulo¾ena)"
+#: ../lib/vector/Vlib/build_nat.c:110
+msgid "Area of size = 0.0 ignored"
+msgstr "Plocha o velikosti = 0.0 ignorována"
+#: ../lib/vector/Vlib/build_nat.c:147
+msgid "Request to find area outside nonexisting isle"
+msgstr "Po¾adavek najít plochy mimo neexistující ostrov"
+#: ../lib/vector/Vlib/build_nat.c:485
+msgid "Registering lines: "
+msgstr "Registrace linií: "
+#: ../lib/vector/Vlib/build_nat.c:492
+msgid "Unable to read vector map"
+msgstr "Nelze èíst vektorovou vrstvu"
+#: ../lib/vector/Vlib/build_nat.c:526
+#, fuzzy
+msgid "primitives registered"
+msgstr "\r%d primitiv zaregistrováno \n"
+#: ../lib/vector/Vlib/build_nat.c:536
+msgid "Building areas: "
+msgstr "Vytváøení ploch:"
+#: ../lib/vector/Vlib/build_nat.c:553
+#, fuzzy
+msgid "areas built"
+msgstr "Plochy vytvoøeny"
+#, fuzzy
+msgid "isles built"
+msgstr "Ostrovy vytvoøeny"
+#: ../lib/vector/Vlib/build_nat.c:561
+msgid "Attaching islands: "
+msgstr "Pøidávání ostrovù: "
+#: ../lib/vector/Vlib/build_nat.c:576
+msgid "Attaching centroids: "
+msgstr "Pøipojování centroidù: "
+#: ../lib/vector/Vlib/build_ogr.c:257
#, c-format
-msgid "Hit RETURN %s\n"
-msgstr "Stisknìte RETURN %s\n"
+msgid "Unable to calculate centroid for area %d"
+msgstr "Nemohu urèit centroid pro plochu %d"
-#: ../lib/gis/ask.c:458 ../lib/gis/ask.c:565 ../lib/gis/ask.c:587
+#: ../lib/vector/Vlib/build_ogr.c:292 ../lib/vector/Vlib/read_ogr.c:112
+#: ../lib/vector/Vlib/read_ogr.c:285
#, c-format
+msgid "OGR feature type %d not supported"
+msgstr "Typ prvku OGR %d není podporován"
+#: ../lib/vector/Vlib/build_ogr.c:318
+msgid "Partial build for OGR is not supported"
+msgstr "Èásteèné vytvoøení pro OGR není podporováno"
+#: ../lib/vector/Vlib/build_ogr.c:329
msgid ""
-"\n"
-"** %s - not found **\n"
+"Random read is not supported by OGR for this layer, cannot build support"
msgstr ""
-"\n"
-"** %s - nenalezeno **\n"
+"Náhodné ètení není podporováno OGR pro tuto vrstvu, nelze vytvoøit podporu"
-#: ../lib/gis/ask.c:465 ../lib/gis/ask.c:551
+#: ../lib/vector/Vlib/build_ogr.c:336
+msgid "Feature: "
+msgstr "Prvek:"
+#: ../lib/vector/Vlib/build_ogr.c:354
#, c-format
-msgid ""
-"\n"
-"** %s exists. ok to overwrite? "
+msgid "Feature %d without geometry ignored"
+msgstr "Prvek %d bez geometrie je ignorován"
+#: ../lib/vector/Vlib/build_ogr.c:361
+msgid "OGR feature without ID ignored"
+msgstr "Prvek OGR bez ID je ignorován"
+#: ../lib/vector/Vlib/bridges.c:118 ../lib/vector/Vlib/bridges.c:191
+#: ../lib/vector/Vlib/bridges.c:197
+msgid "Removed bridges"
+#: ../lib/vector/Vlib/cats.c:46
+msgid "Vect_new_cats_struct(): Out of memory"
+msgstr "Vect_new_cats_struct(): do¹la pamìt"
+#: ../lib/vector/Vlib/cats.c:135
+#, c-format
+msgid "Too many categories (%d), unable to set cat %d (layer %d)"
msgstr ""
-"\n"
-"** %s existuje. Pøepsat? "
+"Pøíli¹ mnoho kategorií (%d), není mo¾né nastavit kategorii %d (vrstva %d)"
-#: ../lib/gis/ask.c:511
+#: ../lib/vector/Vlib/cats.c:398
#, c-format
+msgid "Unable to convert category string '%s' (from '%s') to category range"
+msgstr ""
+"Nejsem schopen pøevézt název kategorie '%s' (z '%s') na rozsah kategorií"
+#: ../lib/vector/Vlib/read_ogr.c:165
+msgid "OGR feature without ID"
+msgstr "Prvek OGR bez ID."
+#: ../lib/vector/Vlib/read_ogr.c:352 ../lib/vector/Vlib/read_ogr.c:359
+#, c-format
+msgid "Unable to get feature geometry, FID %ld"
+msgstr "Nelze zjistit prvky geometrie, FID %ld"
+#: ../lib/vector/Vlib/sindex.c:97
+#, fuzzy
+msgid "not implemented"
+msgstr "Není implementováno"
+#: ../lib/vector/Vlib/sindex.c:108
+#, fuzzy, c-format
+msgid "Unable to delete item %d from spatial index"
+#: ../lib/vector/Vlib/sindex.c:127
msgid ""
-"\n"
-"**<%s> illegal name **\n"
+"Unable to build spatial index from topology, vector map is not opened at "
+"topo level 2"
msgstr ""
-"\n"
-"**<%s> neplatné jméno **\n"
+"Nelze vytvoøit prostorový index z topologie, vektorová mapa není otevøena na "
+"úrovni 2"
-#: ../lib/gis/ask.c:526
+#: ../lib/vector/Vlib/sindex.c:169
+msgid "BUG (Vect_build_sidx_from_topo): node does not exist"
+msgstr "BUG (Vect_build_sidx_from_topo): bod neexistuje"
+#: ../lib/vector/Vlib/sindex.c:180
+msgid "BUG (Vect_build_sidx_from_topo): line does not exist"
+msgstr "BUG (Vect_build_sidx_from_topo): Linie neexistuje"
+#: ../lib/vector/Vlib/sindex.c:198
+msgid "BUG (Vect_build_sidx_from_topo): area does not exist"
+msgstr "BUG (Vect_build_sidx_from_topo): Plocha neexistuje"
+#: ../lib/vector/Vlib/sindex.c:216
+msgid "BUG (Vect_build_sidx_from_topo): isle does not exist"
+msgstr "BUG (Vect_build_sidx_from_topo): Ostrov neexistuje"
+#: ../lib/vector/Vlib/read_nat.c:146
+msgid "Attempt to read dead line"
+msgstr "Pokus èíst mrtvou linii "
+#: ../lib/vector/Vlib/intersect.c:127
+msgid "3D not supported by Vect_segment_intersection()"
+msgstr "3D není podporováno Vect_segment_intersection()"
+#: ../lib/vector/Vlib/intersect.c:265
+msgid "Vect_segment_intersection() ERROR (collinear vertical segments)"
+msgstr "Vect_segment_intersection() CHYBA (kolinerní vertikální segmenty)"
+#: ../lib/vector/Vlib/intersect.c:347
+msgid "Vect_segment_intersection() ERROR (collinear non vertical segments)"
+msgstr "Vect_segment_intersection() CHYBA (kolineární nevertikální segmenty)"
+#: ../lib/vector/Vlib/break_polygons.c:200
+msgid "All points (vertices)"
+#: ../lib/vector/Vlib/break_polygons.c:201
+msgid "Registered points (unique coordinates)"
+msgstr "Registrované body (unikátní souøadnice)"
+#: ../lib/vector/Vlib/break_polygons.c:202
+msgid "Points marked for break"
+msgstr "Body vyznaèeny pro zlom"
+#: ../lib/vector/Vlib/break_polygons.c:208
+#: ../lib/vector/Vlib/break_polygons.c:272
+#: ../lib/vector/Vlib/break_polygons.c:292
+msgid "Breaks"
+msgstr "Zlomy"
+#: ../lib/vector/Vlib/build.c:143
#, c-format
+msgid "Building topology for vector map <%s>...\n"
+msgstr "Vytváøím topologii pro vektorovou vrstvu <%s>...\n"
+#: ../lib/vector/Vlib/build.c:156
+msgid "Topology was built\n"
+msgstr "Topologie byla vytvoøena\n"
+#: ../lib/vector/Vlib/build.c:168
+#, c-format
+msgid "Number of nodes : %d\n"
+msgstr "Poèet uzlù : %d\n"
+#: ../lib/vector/Vlib/build.c:169
+#, c-format
+msgid "Number of primitives: %d\n"
+msgstr "Poèet primitiv : %d\n"
+#: ../lib/vector/Vlib/build.c:170
+#, c-format
+msgid "Number of points : %d\n"
+msgstr "Poèet bodù : %d\n"
+#: ../lib/vector/Vlib/build.c:171
+#, c-format
+msgid "Number of lines : %d\n"
+msgstr "Poèet linií : %d\n"
+#: ../lib/vector/Vlib/build.c:172
+#, c-format
+msgid "Number of boundaries: %d\n"
+msgstr "Poèet hranic : %d\n"
+#: ../lib/vector/Vlib/build.c:173
+#, c-format
+msgid "Number of centroids : %d\n"
+msgstr "Poèet centroidù : %d\n"
+#: ../lib/vector/Vlib/build.c:176
+#, c-format
+msgid "Number of faces : %d\n"
+msgstr "Poèet stìn : %d\n"
+#: ../lib/vector/Vlib/build.c:179
+#, c-format
+msgid "Number of kernels : %d\n"
+msgstr "Poèet jader: : %d\n"
+#: ../lib/vector/Vlib/build.c:214
+#, c-format
+msgid "Number of areas : %d\n"
+msgstr "Poèet ploch : %d\n"
+#: ../lib/vector/Vlib/build.c:215
+#, c-format
+msgid "Number of isles : %d\n"
+msgstr "Poèet ostrovù : %d\n"
+#: ../lib/vector/Vlib/build.c:218
+#, c-format
+msgid "Number of incorrect boundaries : %d\n"
+msgstr "Poèet chybných hranic : %d\n"
+#: ../lib/vector/Vlib/build.c:221
+#, c-format
+msgid "Number of centroids outside area : %d\n"
+msgstr "Poèet centroidù mimo plochu : %d\n"
+#: ../lib/vector/Vlib/build.c:224
+#, c-format
+msgid "Number of duplicate centroids : %d\n"
+msgstr "Poèet duplikátních centroidù : %d\n"
+#: ../lib/vector/Vlib/build.c:227
+#, c-format
+msgid "Number of areas without centroid : %d\n"
+msgstr "Poèet ploch bez centroidu : %d\n"
+#: ../lib/vector/Vlib/build.c:230
+msgid "Number of areas : -\n"
+msgstr "Poèet ploch : -\n"
+#: ../lib/vector/Vlib/build.c:231
+msgid "Number of isles : -\n"
+msgstr "Poèet ostrovù : -\n"
+#: ../lib/vector/Vlib/build.c:261
+#, c-format
+msgid "Unable to open topo file for write <%s>"
+msgstr "Nelze otevøít soubor s topologií pro zápis <%s>"
+#: ../lib/vector/Vlib/build.c:269
+msgid "Error writing out topo file"
+msgstr "Chyba pøi sestavení souboru s topologií"
+#: ../lib/vector/Vlib/build.c:405
+#, c-format
+msgid "Unable open spatial index file for write <%s>"
+msgstr "Nelze otevøít soubor s prostorovým indexem pro zápis <%s>"
+#: ../lib/vector/Vlib/build.c:413
+msgid "Error writing out spatial index file"
+msgstr "Chyba pøi zapisování souboru s prostorovým indexem."
+#: ../lib/vector/Vlib/close.c:126
+#, c-format
+msgid "Unable to close vector <%s>"
+msgstr "Nelze zavøít vektorovou vrstvu <%s>"
+#: ../lib/vector/Vlib/field.c:90
+msgid "Layer number must be 1 or greater"
+msgstr "Èíslo vrstvy musí být vìt¹í nebo rovno 1"
+#: ../lib/vector/Vlib/field.c:95
+msgid "Unable to add database link, map is not opened in WRITE mode"
+msgstr "Nelze pøidat spojení s databází, mapa není otevøena v módu pro ZÁPIS."
+#: ../lib/vector/Vlib/field.c:101
+msgid "Unable to add database link"
+msgstr "Nelze pøidat spojení s databází."
+#: ../lib/vector/Vlib/field.c:107 ../lib/vector/Vlib/field.c:153
+msgid "Unable to write database links"
+msgstr "Nelze zapsat spojení s databází."
+#: ../lib/vector/Vlib/field.c:221
+#, c-format
+msgid "Layer number %d or name <%s> already exists"
+msgstr "Vrstva èíslo <%d> nebo jménem <%s> ji¾ existuje."
+#: ../lib/vector/Vlib/field.c:290
+#, fuzzy, c-format
msgid ""
-"\n"
-"** %s - illegal request **\n"
+"Default driver / database set to:\n"
+"driver: %s\n"
+"database: %s"
msgstr ""
-"\n"
-"** %s - neplatný po¾adavek **\n"
+"Výchozí ovladaè / databáze nastavena na:\n"
+"ovladaè: dbf\n"
+"databáze: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/"
-#: ../lib/gis/ask.c:541
+#: ../lib/vector/Vlib/field.c:297
+msgid "Default driver is not set"
+msgstr "Výchozí ovladaè není nastaven"
+#: ../lib/vector/Vlib/field.c:299
+msgid "Default database is not set"
+msgstr "Výchozí databáze není nastavena"
+#: ../lib/vector/Vlib/field.c:355
#, c-format
+msgid "Requested dblink %d, maximum link number %d"
+msgstr "Po¾adovaný dblink %d, maximální poèet spojení %d"
+#: ../lib/vector/Vlib/field.c:490
+msgid "Unable to open OGR DBMI driver"
+msgstr "Nelze otevøít ovladaè pro OGR DBMI"
+#: ../lib/vector/Vlib/field.c:519
msgid ""
-"\n"
-"** %s - exists, select another name **\n"
+"All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' "
+"available in OGR DB table"
msgstr ""
-"\n"
-"** %s - existuje, zvolte jiné jméno **\n"
-#: ../lib/gis/ask.c:569
-msgid "ask: can't happen"
-msgstr "ask: nemù¾e nastat"
+#: ../lib/vector/Vlib/field.c:560
+#, c-format
+msgid "Don't know how to read links for format %d"
+msgstr "Neznámo jak pøeèíst linky pro formát %d"
-#: ../lib/gis/alloc.c:42
-msgid "G_malloc: out of memory"
-msgstr "G_malloc: do¹la pamì»"
+#: ../lib/vector/Vlib/field.c:588
+#, c-format
+msgid "Error in rule on row %d in %s"
+msgstr "Chyba v pravidlu na øádku %d v %s"
-#: ../lib/gis/alloc.c:75
-msgid "G_calloc: out of memory"
-msgstr "G_calloc: do¹la pamìt"
+#: ../lib/vector/Vlib/field.c:639
+#, c-format
+msgid "Unable to open vector database definition file '%s'"
+msgstr "Nelze otevøít soubor s definicí vektorové databáze '%s'"
-#: ../lib/gis/alloc.c:111
-msgid "G_realloc: out of memory"
-msgstr "G_realloc: do¹la pamì»"
+#: ../lib/vector/Vlib/field.c:724
+msgid "Bug: attempt to update map which is not in current mapset"
+msgstr "Bug: pokus o aktualizaci mapy, která není v aktuálním mapsetu."
-#: ../lib/gis/histogram.c:60
+#: ../lib/vector/Vlib/overlay.c:76
+#, fuzzy
+msgid "unknown operator"
+#: ../lib/vector/Vlib/overlay.c:124
+msgid "Overlay: line/boundary types not supported by AND operator"
+msgstr "Pøekrytí: typy hranice x linie nejsou podporovány operátorem AND"
+#: ../lib/vector/Vlib/overlay.c:127
+msgid "Overlay: area x area types not supported by AND operator"
+msgstr "Pøekrytí: typy plocha x plocha nejsou podporovány operátorem AND"
+#: ../lib/vector/Vlib/read.c:99
+#, fuzzy
+msgid "vector map is not opened"
+msgstr "Vektorová mapa není otevøena"
+#: ../lib/vector/Vlib/read.c:102
#, c-format
-msgid "Histogram for [%s in %s] missing (run r.support)"
-msgstr "Chybí histogram pro [%s v %s] (spus»te r.support)"
+msgid ""
+"Vect_read_line(): line %d is not reasonable (max line in vector map: %d)"
+msgstr ""
+"Vect_red_line(): Linie %d není pøijatelná (maximální poèet linií ve "
+"vektorové mapì: %d)"
-#: ../lib/gis/histogram.c:68
+#: ../lib/vector/Vlib/header.c:100 ../lib/vector/Vlib/header.c:149
#, c-format
-msgid "Can't read histogram for [%s in %s]"
-msgstr "Nelze èíst histogram z [%s v %s]"
+msgid "Unable to open header file of vector <%s>"
+msgstr "Nelze otevøít hlavièkový soubor vektorové mapy <%s>"
-#: ../lib/gis/histogram.c:79 ../lib/gis/histogram.c:89
+#: ../lib/vector/Vlib/header.c:156
#, c-format
-msgid "Invalid histogram file for [%s in %s]"
-msgstr "Neplatný soubor s histogramem z [%s v %s]"
+msgid "Corrupted row in head: %s"
+msgstr "Poru¹ený øádek v hlavièce: %s"
-#: ../lib/gis/histogram.c:370
+#: ../lib/vector/Vlib/header.c:187
#, c-format
-msgid "can't create histogram for [%s in %s]"
-msgstr "nelze vytvoøit histogram z [%s v %s]"
+msgid "Unknown keyword %s in vector head"
+msgstr "Neznámé klíèové slovo %s v hlavièce vektorové mapy"
-#: ../lib/imagery/fopen.c:28
+#: ../lib/raster/rem_io.c:43
#, c-format
-msgid "Unable to create file [%s] of group [%s in %s]"
-msgstr "Nelze vytvoøit soubor [%s] pro skupinu [%s v %s]"
+msgid "ERROR %s from graphics driver.\n"
+msgstr "CHYBA %s grafického ovladaèe\n"
-#: ../lib/imagery/fopen.c:46 ../lib/imagery/fopen.c:73
+#: ../lib/raster/rem_io.c:172
#, c-format
-msgid "Unable to open file [%s] of group [%s in %s]"
-msgstr "Nelze otevøít soubor [%s] skupiny [%s v %s]"
+msgid "Unable to allocate memory\n"
+msgstr "Nelze alokovat pamì»\n"
-#: ../lib/imagery/fopen.c:62
+#: ../lib/raster/rem_io.c:225
#, c-format
-msgid "Unable to find file [%s] of group [%s in %s]"
-msgstr "Nelze nalézt soubor [%s] skupiny [%s v %s]"
+msgid "ERROR - eof from graphics monitor.\n"
+msgstr "CHYBA - eof z grafického monitoru.\n"
-#: ../lib/imagery/fopen.c:94
+#: ../lib/raster/rem_io.c:244
#, c-format
-msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr "Nelze vytvoøit soubor [%s] pro podskupinu [%s] skupiny [%s v %s]"
+msgid "Warning - no response from graphics monitor <%s>.\n"
+msgstr "Upozornìní - ¾ádná odezva od grafického monitoru <%s>.\n"
-#: ../lib/imagery/fopen.c:115 ../lib/imagery/fopen.c:145
+#: ../lib/raster/rem_io.c:246
#, c-format
-msgid "Unable to open file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr "Nelze otevøít soubor [%s] pro podskupinu [%s] skupiny [%s v %s]"
+msgid "Check to see if the mouse is still active.\n"
+msgstr "Zkontrolujte zda-li je my¹ stále aktivní.\n"
-#: ../lib/imagery/fopen.c:134
+#: ../lib/raster/rem_io.c:251
#, c-format
-msgid "Unable to find file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr "Nemohu nalézt soubor [%s] pro podskupinu [%s] skupiny [%s v %s]"
+msgid "ERROR - no response from graphics monitor <%s>.\n"
+msgstr "CHYBA - ¾ádná odezva od grafického monitoru <%s>.\n"
+#: ../lib/raster/io_sock.c:65
+msgid "No graphics monitor has been selected for output."
+msgstr "Nebyl zvolen ¾ádný grafický monitor pro výstup."
+#: ../lib/raster/io_sock.c:66
+msgid "Please run \"d.mon\" to select a graphics monitor."
+msgstr "Pro výbìr grafického monitoru zavolejte \"d.mon\"."
+#: ../lib/raster/io_sock.c:75
+#, c-format
+msgid "Failed to get socket name for monitor <%s>."
+msgstr "Nelze získat soket pro monitor <%s>."
+#: ../lib/raster/io_sock.c:85
+#, c-format
+msgid "No socket to connect to for monitor <%s>."
+msgstr "Není dostupný ¾ádný soket pro pøipojení k monitoru <%s>."
+#: ../lib/raster/io_sock.c:105
+msgid "Socket is already in use or not accepting connections."
+msgstr "Soket je ji¾ pou¾íván nebo není akceptováno spojení."
+#: ../lib/raster/io_sock.c:106
+msgid "Use d.mon to select a monitor"
+msgstr "Pro výbìr grafického monitoru zavolejte d.mon."
+#: ../lib/raster/io_sock.c:113
+msgid "Trying to connect to something not a socket."
+msgstr "Pokus o pøipojení k nìèemu, co není soketem."
+#: ../lib/raster/io_sock.c:114
+msgid "Probably program error."
+msgstr "Pravdìpodobnì chyba programu."
+#: ../lib/raster/io_sock.c:120
+msgid "Connect attempt timed out."
+#: ../lib/raster/io_sock.c:121
+msgid "Probably an error with the server."
+msgstr "Pravdìpodobnì je chyba na stranì serveru."
+#: ../lib/raster/io_sock.c:129
+msgid "Connection failed."
#: ../lib/gmath/la.c:63 ../lib/gmath/la.c:120
msgid "Matrix dimensions out of range"
msgstr "Rozmìr matice je mimo povolený rozsah"
@@ -3963,42 +3864,48 @@
msgid " taking inverse FFT..."
msgstr " provádím inverzní FFT..."
-#: ../lib/display/tran_colr.c:132 ../lib/display/tran_colr.c:134
+#: ../lib/imagery/target.c:42
+#, fuzzy, c-format
+msgid "Unable to read target file for group [%s]"
+msgstr "Nelze vytvoøit hlavièkový soubor pro [%s]"
+#: ../lib/imagery/fopen.c:28
#, c-format
-msgid "[%s]: No such color"
-msgstr "[%s]: Neznámá barva"
+msgid "Unable to create file [%s] of group [%s in %s]"
+msgstr "Nelze vytvoøit soubor [%s] pro skupinu [%s v %s]"
-#: ../lib/symbol/read.c:203
+#: ../lib/imagery/fopen.c:46 ../lib/imagery/fopen.c:73
#, c-format
-msgid "Cannot read symbol line coordinates: %s"
-msgstr "Nemohu pøeèíst souøadnice symbolu: %s"
+msgid "Unable to open file [%s] of group [%s in %s]"
+msgstr "Nelze otevøít soubor [%s] skupiny [%s v %s]"
-#: ../lib/symbol/read.c:252
+#: ../lib/imagery/fopen.c:62
#, c-format
-msgid ""
-"Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
-msgstr ""
-"Nesprávné jméno symbolu: '%s' (mìlo by být: skupina/jméno nebo skupina/"
-"jméno at mapset)"
+msgid "Unable to find file [%s] of group [%s in %s]"
+msgstr "Nelze nalézt soubor [%s] skupiny [%s v %s]"
-#: ../lib/symbol/read.c:274
+#: ../lib/imagery/fopen.c:94
#, c-format
-msgid "Cannot find/open symbol: '%s'"
-msgstr "Nemohu nalézt/otevøít symbol: '%s'"
+msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
+msgstr "Nelze vytvoøit soubor [%s] pro podskupinu [%s] skupiny [%s v %s]"
-#: ../lib/symbol/read.c:358 ../lib/symbol/read.c:367 ../lib/symbol/read.c:374
-#: ../lib/symbol/read.c:383
+#: ../lib/imagery/fopen.c:115 ../lib/imagery/fopen.c:145
#, c-format
-msgid "Incorrect symbol color: '%s', using default."
-msgstr "Nesprávná barva pro symbol: '%s', pou¾ívám výchozí"
+msgid "Unable to open file [%s] for subgroup [%s] of group [%s in %s]"
+msgstr "Nelze otevøít soubor [%s] pro podskupinu [%s] skupiny [%s v %s]"
+#: ../lib/imagery/fopen.c:134
+#, c-format
+msgid "Unable to find file [%s] for subgroup [%s] of group [%s in %s]"
+msgstr "Nemohu nalézt soubor [%s] pro podskupinu [%s] skupiny [%s v %s]"
#: ../lib/rst/interp_float/segmen2d.c:123
msgid ""
"taking too long to find points for interpolation--please change the region "
"to area where your points are. Continuing calculations..."
msgstr ""
-"hledání bodù pro interpolaci trvá pøíli¹ dlouho -- prosím, zmìòtì region \n"
-"na území, které je tìmito body pokryto. Pokraèuji ve výpoètu..."
+"hledání bodù pro interpolaci trvá pøíli¹ dlouho -- prosím, zmìòtì region na "
+"území, které je tìmito body pokryto. Pokraèuji ve výpoètu..."
#: ../lib/rst/interp_float/vinput2d.c:81
msgid "Vector is not 3D"
@@ -4089,14 +3996,168 @@
msgstr "nìkteré body mimo region -- budou ignorovány..."
#: ../lib/rst/interp_float/input2d.c:49
-#, fuzzy, c-format
+#, c-format
msgid "Mask raster map <%s> not found"
-msgstr "Po¾adovaná rastrová mapa <%s> nebyla nalezena"
+msgstr " rastrová MAKSA <%s> nebyla nalezena"
#: ../lib/rst/interp_float/input2d.c:72
msgid "Bitmap mask created"
+msgstr "bitmapová maska vytvoøena"
+#: ../lib/proj/do_proj.c:105 ../lib/proj/do_proj.c:178
+#, c-format
+msgid "pj_transform() failed: %s"
+msgstr "pj_transform() selhalo: %s"
+#: ../lib/proj/ellipse.c:73
+#, c-format
+msgid "Invalid ellipsoid <%s> in file"
+msgstr "Neplatný referenèní elipsoid <%s> v souboru"
+#: ../lib/proj/ellipse.c:96
+msgid "No secondary ellipsoid descriptor (rf, es or b) in file"
+msgstr "Chybí dal¹í popis elipsoidu (rf, es, nebo b) v souboru"
+#: ../lib/proj/ellipse.c:100
+msgid "Invalid ellipsoid descriptors (a, rf, es or b) in file"
+msgstr "Neplatné popisy ref. elipsoidu (a, rf, es, nebo b) v souboru"
+#: ../lib/proj/ellipse.c:113
+msgid "No ellipsoid info given in file"
+msgstr "V souboru není uveden ¾ádný referenèní elipsoid"
+#: ../lib/proj/datum.c:252
+msgid "Unable to open temporary file"
+msgstr "Nelze otevøít doèasný sobor"
+#: ../lib/proj/datum.c:408 ../lib/proj/datum.c:471
+#, fuzzy, c-format
+msgid "Unable to open datum table file <%s>"
+msgstr "nelze otevøít soubor s vý¹kovým systémem (datum): %s"
+#: ../lib/proj/datum.c:421 ../lib/proj/datum.c:485
+#, c-format
+msgid "Error in datum table file <%s>, line %d"
+msgstr "Chyba v souboru obsahující vý¹kový systém (datum)<%s>, na øádku %d"
+#: ../lib/proj/get_proj.c:149
+#, c-format
+msgid "Invalid zone %s specified"
+msgstr "Specifikována naplatná zóna %s"
+#: ../lib/proj/get_proj.c:228
+msgid "Unable to initialise PROJ.4 with the following parameter list:"
+msgstr "Nelze inicializovat PROJ.4 s následujícími parametry:"
+#: ../lib/proj/get_proj.c:235
+#, c-format
+msgid "The error message: %s"
+msgstr "Chybová zpráva: %s"
+#: ../lib/proj/get_proj.c:294
+msgid "Option input overflowed option table"
+msgstr "Nelze alokovat pamì»"
+#: ../lib/proj/get_proj.c:325
+#, c-format
+msgid "Unable to initialize pj cause: %s"
+msgstr "Nelze inicializovat pj: %s"
+#: ../lib/proj/get_proj.c:400
+msgid "Input Projection Parameters"
+msgstr "Parametry vstupní projekce"
+#: ../lib/proj/get_proj.c:402
+msgid "Input Unit Factor"
+msgstr "Vstupní jednotkový faktor"
+#: ../lib/proj/get_proj.c:411
+msgid "Output Projection Parameters"
+#: ../lib/proj/get_proj.c:413
+msgid "Output Unit Factor"
+#: ../lib/proj/convert.c:107
+msgid "Unable parse GRASS PROJ_INFO file"
+msgstr "Nelze parsovat soubor GRASS PROJ_FILE"
+#: ../lib/proj/convert.c:112
+msgid "Unable get PROJ.4-style parameter string"
+msgstr "Nelze získat parametr ve stylu PROJ.4"
+#: ../lib/proj/convert.c:124
+#, c-format
+msgid ""
+"OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
msgstr ""
+"OGR se nepodaøilo parsovat parametr ve stylu PROJ.4. Parametr:%s (kód chyby "
+"OGR je %d)"
+#: ../lib/proj/convert.c:130
+#, c-format
+msgid "OGR can't get WKT-style parameter string (OGR Error code was %d)"
+msgstr "OGR se nepoøilo získat parametr ve stylu WKT (kód chyby OGR je %d)"
+#: ../lib/proj/convert.c:391
+msgid "No projection name! Projection parameters likely to be meaningless."
+msgstr ""
+"Nebyl definován název kartografické projekce! Parametry projekce nemají "
+"význam."
+#: ../lib/proj/convert.c:428
+#, c-format
+msgid "Datum <%s> not recognised by GRASS and no parameters found"
+msgstr ""
+"Geodetické datum <%s> nebylo GRASS rozpoznáno a nebyly nalezeny ¾ádné "
+"parametry."
+#: ../lib/proj/convert.c:445
+#, c-format
+msgid ""
+"Datum <%s> apparently recognised by GRASS but no parameters found. You may "
+"want to look into this."
+msgstr ""
+"Geodetické datum <%s> bylo zjevnì GRASSem rozpoznáno, nicménì nebyly "
+"nalezeny parametry. Zkontrolujte nastavení."
+#: ../lib/proj/convert.c:450
+#, c-format
+msgid ""
+"Invalid tranformation number %d; valid range is 1 to %d. Leaving datum "
+"transform parameters unspecified."
+msgstr ""
+"Neplatný identifikátor transformace %d; platný rozsah je od 1 do %d. "
+"Geodetické datum zùstane nespecifikováno."
+#: ../lib/symbol/read.c:203
+#, c-format
+msgid "Cannot read symbol line coordinates: %s"
+msgstr "Nemohu pøeèíst souøadnice symbolu: %s"
+#: ../lib/symbol/read.c:252
+#, c-format
+msgid ""
+"Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
+msgstr ""
+"Nesprávné jméno symbolu: '%s' (mìlo by být: skupina/jméno nebo skupina/"
+"jméno at mapset)"
+#: ../lib/symbol/read.c:274
+#, c-format
+msgid "Cannot find/open symbol: '%s'"
+msgstr "Nemohu nalézt/otevøít symbol: '%s'"
+#: ../lib/symbol/read.c:358 ../lib/symbol/read.c:367 ../lib/symbol/read.c:374
+#: ../lib/symbol/read.c:383
+#, c-format
+msgid "Incorrect symbol color: '%s', using default."
+msgstr "Nesprávná barva pro symbol: '%s', pou¾ívám výchozí"
+#~ msgid "Cannot read topo for line [%d]"
+#~ msgstr "Nelze èíst topologii pro linii [%d]"
#~ msgid "Error opening raster map %s"
#~ msgstr "Chyba pøi otevøení rastrové mapy %s"
Modified: grass/trunk/locale/po/grassmods_cs.po
--- grass/trunk/locale/po/grassmods_cs.po 2008-04-11 12:21:14 UTC (rev 30937)
+++ grass/trunk/locale/po/grassmods_cs.po 2008-04-11 13:06:55 UTC (rev 30938)
@@ -1,9 +1,9 @@
# translation of grassmods_cs.po to Czech
# This file is distributed under the same license as the GRASS package.
-# Copyright (C) 2004 GRASS Development Team
+# Copyright (C) 2004-2008 GRASS Development Team
# Radim Bla¾ek <blazek at itc.it>, 2004.
-# Martin Landa <landa.martin at gmail.com>, 2005.
+# Martin Landa <landa.martin at gmail.com>, 2005-2008.
# Jáchym Èepický <jachym.cepicky at gmail.com>, 2005.
# correction Michal Bíl <michal.bil at seznam.cz>, 2005.
# Jan Trochta <j.trochta at seznam.cz>, 2008.
@@ -12,8 +12,8 @@
msgstr ""
"Project-Id-Version: grassmods_cs\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2008-01-24 17:42+0100\n"
-"PO-Revision-Date: 2008-01-22 23:15+0100\n"
+"POT-Creation-Date: 2008-04-11 15:58+0200\n"
+"PO-Revision-Date: 2008-04-08 18:17+0200\n"
"Last-Translator: honza <j.trochta at seznam.cz>\n"
"Language-Team: Czech <grass-translations at lists.osgeo.org>\n"
"MIME-Version: 1.0\n"
@@ -21,1733 +21,937 @@
"Content-Transfer-Encoding: 8bit\n"
"X-Generator: KBabel 1.11.4\n"
-#: ../db/base/execute.c:61 ../db/base/createdb.c:42 ../db/base/dropdb.c:42
-#: ../db/base/tables.c:45 ../db/base/droptable.c:43 ../db/base/select.c:63
-#: ../db/base/columns.c:44 ../db/base/describe.c:49 ../db/base/databases.c:51
-#: ../vector/v.db.connect/main.c:171 ../vector/v.db.connect/main.c:226
-#: ../vector/v.edit/cmd/select.c:529 ../vector/v.out.svg/main.c:138
-#: ../vector/v.out.ogr/main.c:298 ../vector/v.extract/main.c:224
-#: ../display/d.vect/main.c:471
-#, c-format
-msgid "Unable to start driver <%s>"
-msgstr "Nelze spustit ovladaè <%s>"
-#: ../db/base/execute.c:67 ../db/base/tables.c:50 ../db/base/select.c:69
-#: ../db/base/describe.c:54 ../display/d.vect/main.c:476
-#, c-format
-msgid "Unable to open database <%s>"
-msgstr "Nelze otevøít databázi <%s>"
-#: ../db/base/execute.c:78 ../db/base/execute.c:83
-#, c-format
-msgid "Error while executing: '%s'"
-msgstr "Chyba pøi vykonávání: '%s'"
-#: ../db/base/execute.c:108 ../db/base/createdb.c:71 ../db/base/copy.c:34
-#: ../db/base/dropdb.c:71 ../db/base/tables.c:95 ../db/base/droptable.c:78
-#: ../db/base/drivers.c:73 ../db/base/select.c:236 ../db/base/columns.c:91
-#: ../db/base/describe.c:124 ../db/base/databases.c:89 ../db/base/connect.c:41
-#: ../db/db.login/main.c:42
-msgid "database, SQL"
-msgstr "databáze, SQL"
-#: ../db/base/execute.c:109
-msgid "Executes any SQL statement."
-msgstr "Vykoná jakýkoliv pøíkaz SQL."
-#: ../db/base/execute.c:113
-msgid "Name of file containing SQL statements"
-msgstr "Soubor obsahující pøíkazy SQL"
-#: ../db/base/execute.c:126
-msgid "Ignore SQL errors and continue"
-msgstr "Ignoruj chyby SQL a pokraèuj"
-#: ../db/base/execute.c:152
-msgid "Use db.select for SELECT SQL statements"
-msgstr "Pou¾ijte db.select pro povel SQL SELECT "
-#: ../db/base/createdb.c:72
-msgid "Creates an empty database."
-msgstr "Vytvoøit prázdnou databázi."
-#: ../db/base/copy.c:35
+#: ../locale/scriptstrings/v.db.addcol_to_translate.c:1
msgid ""
-"Copy a table. Either 'from_table' (optionaly with 'where') can be used or "
-"'select' option, but not 'from_table' and 'select' at the same time."
+"Adds one or more columns to the attribute table connected to a given vector "
+"map."
msgstr ""
-"Kopíruj tabulku. Pou¾ita mù¾e být buï volba 'from_table' (volitelnì s "
-"'where') nebo volba 'select', ale nikoliv 'from_table' a 'select' souèasnì."
+"Pøidává jeden nebo více sloupeèkù k atributové tabulce pøipojené k zadané "
+"vektorové mapì."
-#: ../db/base/copy.c:43
-msgid "Input driver name"
-msgstr "Název vstupního ovladaèe"
+#: ../locale/scriptstrings/v.db.addcol_to_translate.c:2
+#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:2
+#: ../locale/scriptstrings/v.db.droptable_to_translate.c:2
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:2
+#: ../locale/scriptstrings/v.db.join_to_translate.c:2
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:2
+#: ../locale/scriptstrings/v.db.update_to_translate.c:2
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:2
+#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:2
+#: ../vector/v.db.select/main.c:46 ../vector/v.db.connect/main.c:48
+#: ../vector/v.distance/main.c:109 ../vector/v.to.db/main.c:32
+msgid "vector, database, attribute table"
+msgstr "vektor, databáze, tabulka atributù"
-#: ../db/base/copy.c:51
-msgid "Input database name"
-msgstr "Název vstupní databáze"
+#: ../locale/scriptstrings/v.db.addcol_to_translate.c:3
+msgid "Vector map for which to edit attribute table"
+msgstr "Vektorová mapa, její¾ atributová tabulka má být editována"
-#: ../db/base/copy.c:59
-msgid "Input table name (only, if 'select' is not used)"
-msgstr "Název vstupní tabulky (pouze pokud nebyla pou¾ita klauzule 'select')"
+#: ../locale/scriptstrings/v.db.addcol_to_translate.c:4
+msgid "Layer where to add column"
+msgstr "Vrstva, kam pøidat sloupec"
-#: ../db/base/copy.c:66
-msgid "Output driver name"
-msgstr "Název výstupního ovladaèe"
-#: ../db/base/copy.c:74
-msgid "Output database name"
-msgstr "Název výstupní databáze"
-#: ../db/base/copy.c:82
-msgid "Output table name"
-msgstr "Název výstupní tabulky"
-#: ../db/base/copy.c:88
+#: ../locale/scriptstrings/v.db.addcol_to_translate.c:5
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:6
msgid ""
-"Optional where condition (without WHERE key word), e.g.:\n"
-"\t\tobec = 'Liptakov'"
+"Name and type of the new column(s) (types depend on database backend, but "
+"all support VARCHAR(), INT, DOUBLE and DATE)"
msgstr ""
-"Volitelná podmínka where (bez klíèového slova WHERE), napø.:\n"
+"Jména a typ nového(ých) sloupeèku(ù) (typ závisí na pou¾ité databázi, ale "
+"v¹echny podporují VARCHAR(), INT, DOUBLE a DATE)"
-#: ../db/base/copy.c:95
-msgid ""
-"Full select statement (only, if 'from_table' and 'where' is not used), e."
-"g.:\n"
-"\t\tSELECT dedek FROM starobince WHERE obec = 'Frimburg'"
-msgstr ""
-"Úplný pøíkaz select (pouze pokud nebyly pou¾ity 'from_table' a 'where'), "
-"napø.:\n"
+#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:1
+msgid "Calculates new grid3D volume from r3.mapcalc expression."
+msgstr "Tvorba nové grid3d volume mapy na základì výrazu pro r3.mapcalc."
-#: ../db/base/copy.c:104
-msgid "Cannot combine 'from_table' and 'select' options"
-msgstr "Nelze kombinovat volby 'from_table' a 'select'"
+#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:2
+msgid "A (grid3D file)"
+msgstr "A (soubor grid3D)"
-#: ../db/base/copy.c:116
-msgid "Either 'from_table' or 'select' option must be given."
-msgstr "Musíte zadat buï 'from_table' nebo 'select'."
+#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:3
+msgid "B (grid3D file)"
+msgstr "B (soubor grid3D)"
-#: ../db/base/copy.c:119
-msgid "Cannot combine 'select' and 'where' options"
-msgstr "Nelze kombinovat volby 'select' a 'where'"
+#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:4
+msgid "C (grid3D file)"
+msgstr "C (soubor grid3D)"
-#: ../db/base/copy.c:127
-msgid "Copy table failed"
-msgstr "Kopírování tabulky se nezdaøilo"
+#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:5
+msgid "D (grid3D file)"
+msgstr "D (soubor grid3D)"
-#: ../db/base/dropdb.c:72
-msgid "Removes a database."
-msgstr "Odstraòuji databázi."
+#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:6
+msgid "E (grid3D file)"
+msgstr "E (soubor grid3D)"
-#: ../db/base/tables.c:87
-msgid "Print tables and exit"
-msgstr "vypi¹ tabulky a ukonèi se."
+#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:7
+msgid "F (grid3D file)"
+msgstr "F (soubor grid3D)"
-#: ../db/base/tables.c:91
-msgid "System tables instead of user tables"
-msgstr "systémové tabulky místo u¾ivatelských"
+#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:8
+#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:8
+msgid "Formula (e.g. A-B or A*C+B)"
+msgstr "Vzorec (napø. A-B nebo A*C+B)"
-#: ../db/base/tables.c:96
-msgid "Lists all tables for a given database."
-msgstr "Vypí¹e v¹echny tabulky pro danou databázi."
+#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:9
+msgid "Name for output grid3D volume"
+msgstr "Název výstupního souboru grid3D objem"
-#: ../db/base/droptable.c:79
-msgid "Removes a table from database."
-msgstr "Odstraní tabulku z databáze."
+#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:10
+#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:10
+msgid "Show help"
+msgstr "Zobraz nápovìdu"
-#: ../db/base/drivers.c:40
-msgid "Error trying to read dbmscap file\n"
-msgstr "Chyba pøi pokusu èíst soubor dbmscap\n"
+#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:11
+msgid "Expert mode (enter a set of r3.mapcalc expressions)"
+msgstr "Expertní mód (zadejte soubor výrazù pro r3.mapcalc)"
-#: ../db/base/drivers.c:65
-msgid "Full output"
-msgstr "Úplný výstup"
+#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:12
+#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:12
+msgid "Do not overwrite existing map"
+msgstr "Nepøepisuj existující mapu"
-#: ../db/base/drivers.c:69
-msgid "print drivers and exit"
-msgstr "vypi¹ ovladaèe a ukonèi se"
+#: ../locale/scriptstrings/r.blend_to_translate.c:1
+msgid "Blends color components of two raster maps by a given ratio."
+msgstr "Spojí barevné èásti dvou rastrových map zadaným pomìrem."
-#: ../db/base/drivers.c:74
-msgid "List all database drivers."
-msgstr "Vypi¹ v¹echny databázové ovladaèe."
+#: ../locale/scriptstrings/r.blend_to_translate.c:2
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:152
+#: ../raster/r.gwflow/main.c:219 ../raster/r.neighbors/main.c:103
+#: ../raster/r.digit/main.c:44 ../raster/r.mode/main.c:48
+#: ../raster/r.fill.dir/main.c:85 ../raster/r.sun/main.c:175
+#: ../raster/r.region/main.c:53 ../raster/r.to.vect/main.c:49
+#: ../raster/r.out.mpeg/main.c:395 ../raster/r.info/main.c:68
+#: ../raster/r.recode/main.c:42 ../raster/r.in.mat/main.c:90
+#: ../raster/r.his/main.c:64 ../raster/r.surf.random/main.c:41
+#: ../raster/r.surf.gauss/main.c:43 ../raster/r.basins.fill/main.c:51
+#: ../raster/r.texture/main.c:71 ../raster/r.circle/dist.c:52
+#: ../raster/r.null/null.c:45 ../raster/r.distance/main.c:38
+#: ../raster/r.kappa/main.c:49 ../raster/r.in.arc/main.c:58
+#: ../raster/r.rescale/main.c:48 ../raster/r.quant/main.c:41
+#: ../raster/r.lake/main.c:156 ../raster/r.sum/main.c:47
+#: ../raster/r.clump/main.c:50 ../raster/r.out.png/r.out.png.c:135
+#: ../raster/r.surf.contour/main.c:50 ../raster/r.rescale.eq/main.c:51
+#: ../raster/r.what/main.c:89 ../raster/r.coin/cmd_parms.c:42
+#: ../raster/r.patch/main.c:53 ../raster/r.out.vtk/main.c:150
+#: ../raster/r.surf.idw2/main.c:60 ../raster/r.reclass/main.c:48
+#: ../raster/r.random/main.c:46 ../raster/r.cats/main.c:49
+#: ../raster/r.profile/main.c:53 ../raster/r.walk/main.c:172
+#: ../raster/r.out.ppm3/main.c:54 ../raster/r.topmodel/main.c:56
+#: ../raster/r.contour/main.c:90 ../raster/wildfire/r.ros/main.c:212
+#: ../raster/wildfire/r.spreadpath/main.c:71
+#: ../raster/wildfire/r.spread/main.c:102
+#: ../raster/r.surf.fractal/interface.c:32 ../raster/r.volume/main.c:56
+#: ../raster/r.thin/main.c:54 ../raster/r.bilinear/main.c:41
+#: ../raster/r.what.color/main.c:89 ../raster/r.out.pov/main.c:120
+#: ../raster/r.transect/main.c:53 ../raster/r.stats/main.c:87
+#: ../raster/r.topidx/main.c:37 ../raster/r.composite/main.c:71
+#: ../raster/r.in.gridatb/main.c:43 ../raster/r.los/main.c:81
+#: ../raster/r.out.gridatb/main.c:46 ../raster/r.resample/main.c:53
+#: ../raster/r.le/r.le.patch/main.c:47 ../raster/r.le/r.le.pixel/main.c:45
+#: ../raster/r.le/r.le.setup/main.c:60 ../raster/r.le/r.le.trace/main.c:57
+#: ../raster/r.average/main.c:51 ../raster/r.grow2/main.c:127
+#: ../raster/r.surf.idw/main.c:68 ../raster/r.random.cells/main.c:39
+#: ../raster/r.covar/main.c:52 ../raster/r.cross/main.c:65
+#: ../raster/r.slope.aspect/main.c:152 ../raster/r.drain/main.c:103
+#: ../raster/r.resamp.rst/main.c:155 ../raster/r.describe/main.c:58
+#: ../raster/r.watershed/front/main.c:49 ../raster/r.out.bin/main.c:63
+#: ../raster/r.carve/main.c:76 ../raster/r.out.arc/main.c:58
+#: ../raster/r.compress/main.c:63 ../raster/r.median/main.c:44
+#: ../raster/r.sunmask/main.c:124 ../raster/r.bitpattern/main.c:62
+#: ../raster/r.random.surface/main.c:47 ../raster/r.surf.area/main.c:89
+#: ../raster/r.timestamp/main.c:34
+msgid "raster"
+msgstr "rastr"
-#: ../db/base/select.c:197
-msgid "SQL select statement"
-msgstr "SQL povel pro výbìr (select)"
+#: ../locale/scriptstrings/r.blend_to_translate.c:3
+msgid "Name of first raster map for blending"
+msgstr "Jméno nového rastru pro mí¹ení"
-#: ../db/base/select.c:198
-msgid "For example: 'select * from rybniky where kapri = 'hodne'"
-msgstr ""
-"Pøíkaz SQL select, napø.: 'select * from rybniky where kapri = 'hodne'"
+#: ../locale/scriptstrings/r.blend_to_translate.c:4
+msgid "Name of second raster map for blending"
+msgstr "Jméno druhého rastru pro smí¹ení"
-#: ../db/base/select.c:201 ../raster/r.distance/parse.c:50
-#: ../raster/r.stats/main.c:108 ../raster/r.cats/main.c:70
-#: ../vector/v.db.select/main.c:57
-msgid "Output field separator"
-msgstr "Výstupní oddìlovaè sloupcù"
-#: ../db/base/select.c:205 ../vector/v.db.select/main.c:61
-msgid "Output vertical record separator"
-msgstr "Výstupní vertikální oddìlovaè záznamù"
-#: ../db/base/select.c:212 ../vector/v.db.select/main.c:68
-msgid "Null value indicator"
-msgstr "Indikátor hodnoty NULL záznamu"
-#: ../db/base/select.c:216
-msgid "Name of file with sql statement"
-msgstr "Název souboru s pøíkazy sql"
-#: ../db/base/select.c:220 ../vector/v.db.select/main.c:72
-msgid "Do not include column names in output"
-msgstr "Nezahrnuj jména sloupcù do výstupu"
-#: ../db/base/select.c:224
-msgid "Describe query only (don't run it)"
-msgstr "Dotaz pouze popi¹ (neprovádìj)"
-#: ../db/base/select.c:228 ../vector/v.db.select/main.c:76
-msgid "Vertical output (instead of horizontal)"
-msgstr "Vertikální výstup (místo horizontálního)"
-#: ../db/base/select.c:232
-msgid "Only test query, do not execute"
-msgstr "Pouze otestovat dotaz, neprovádìt"
-#: ../db/base/select.c:237
-msgid "Selects data from table."
-msgstr "Vyber data z tabulky."
-#: ../db/base/columns.c:92
-msgid "List all columns for a given table."
-msgstr "vypí¹e v¹echny sloupce pro zadanou tabulku."
-#: ../db/base/describe.c:61 ../vector/v.db.connect/main.c:180
-#: ../vector/v.in.ascii/in.c:399 ../vector/v.patch/main.c:140
-#: ../vector/v.patch/main.c:181 ../vector/v.out.svg/main.c:150
-#: ../vector/v.out.ogr/main.c:307
-#, c-format
-msgid "Unable to describe table <%s>"
-msgstr "Nelze popsat tabulku <%s>"
-#: ../db/base/describe.c:103
-msgid "Print column names only instead of full column descriptions"
-msgstr "vypi¹ pouze jména sloupcù místo plného popisu sloupcù"
-#: ../db/base/describe.c:108
-msgid "Print table structure"
-msgstr "Vypi¹ strukturu tabulky"
-#: ../db/base/describe.c:125
-msgid "Describes a table in detail."
-msgstr "Popi¹ tabulku (detailnì)."
-#: ../db/base/databases.c:54
-msgid "Unable to list databases"
-msgstr "Nelze vypsat databáze"
-#: ../db/base/databases.c:84
-msgid "Location name"
-msgstr "Jméno location"
-#: ../db/base/databases.c:90
-msgid "List all databases for a given driver and location."
-msgstr "Vypi¹ v¹echny databáze pro daný ovladaè a umístìní."
-#: ../db/base/connect.c:43
-msgid "Prints/sets general DB connection for current mapset and exits."
+#: ../locale/scriptstrings/r.blend_to_translate.c:5
+msgid "Base name for red, green and blue output maps containing the blend"
msgstr ""
-"Vytisknout/nastavit obecné DB pøipojení aktuálního mapsetu a ukonèit se."
+"Základní jméno map pro èervenou, zelenou a modrou výstupní mapu spojení"
-#: ../db/base/connect.c:48
-msgid "Print current connection parameters and exit"
-msgstr "Vypi¹ parametry souèasného pøipojení a ukonèi se"
+#: ../locale/scriptstrings/r.blend_to_translate.c:6
+msgid "Percentage weight of first map for color blending"
+msgstr "Procenta váhy první mapy barevného spojení"
-#: ../db/base/connect.c:63
-msgid "Database schema"
-msgstr "Schéma databáze."
-#: ../db/base/connect.c:64
+#: ../locale/scriptstrings/r.plane_to_translate.c:1
msgid ""
-"Do not use this option if schemas are not supported by driver/database server"
+"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
+"point."
msgstr ""
-"Tuto volbu nepou¾ívejte, pokud schémata nejsou podporována ovladaèem/"
-"databázovým serverem."
+"Vytvoøí rastrovou mapu plochy pøi zadání ponoru (sklonu), expozice (azimut) "
+"a jednoho bodu."
-#: ../db/base/connect.c:73
-msgid "Default group of database users to which select privilege is granted"
-msgstr ""
-"Výchozí skupina u¾ivatelù databáze, které jsou pøiøazeny práva na select."
+#: ../locale/scriptstrings/r.plane_to_translate.c:2
+#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:2
+msgid "raster, elevation"
+msgstr "rastr, elevace"
-#: ../db/base/connect.c:124
-msgid "Database connection not defined. Run db.connect."
-msgstr "Spojení s databází nebylo pro ovladaè definováno. Spus»te db.connect"
+#: ../locale/scriptstrings/r.plane_to_translate.c:3
+msgid "Name of raster plane to be created"
+msgstr "Jméno rastru plochy, který má být vytvoøen"
-#: ../db/db.login/main.c:43
-msgid "Sets user/password for driver/database."
-msgstr "Nastavit u¾ivatele/heslo pro ovladaè/databázi"
+#: ../locale/scriptstrings/r.plane_to_translate.c:4
+msgid "Dip of plane. Value must be between -90 and 90 degrees"
+msgstr "Spád plochy. Hodnota musí být mezi -90 a 90 stupni"
-#: ../db/db.login/main.c:59
-msgid "Username"
-msgstr "U¾ivatel"
+#: ../locale/scriptstrings/r.plane_to_translate.c:5
+msgid "Azimuth of the plane. Value must be between 0 and 360 degrees"
+msgstr "Úhel plochy. Hodnota musí být mezi 0 a 360 stupni"
-#: ../db/db.login/main.c:66
-msgid "Password"
-msgstr "Heslo"
+#: ../locale/scriptstrings/r.plane_to_translate.c:6
+msgid "Easting coordinate of a point on the plane"
+msgstr "Souøadnice x bodu na plo¹e"
-#: ../db/db.login/main.c:81
-#, c-format
-msgid ""
-"\n"
-"Enter database password for connection\n"
-"<%s:%s:user=%s>\n"
-msgstr ""
-"\n"
-"Zadajte heslo k databázi pro spojení\n"
+#: ../locale/scriptstrings/r.plane_to_translate.c:7
+msgid "Northing coordinate of a point on the plane"
+msgstr "Souøadnice y bodu na plo¹e"
-#: ../db/db.login/main.c:82
-#, c-format
-msgid "Hit RETURN to cancel request\n"
-msgstr "Stisknìte RETURN pro ukonèení ¾ádosti\n"
+#: ../locale/scriptstrings/r.plane_to_translate.c:8
+msgid "Elevation coordinate of a point on the plane"
+msgstr "Souøadnice z bodu na plo¹e"
-#: ../db/db.login/main.c:90
-msgid "Exiting. Not changing current settings"
-msgstr "Konèím, nemìním aktuální nastavení"
+#: ../locale/scriptstrings/r.plane_to_translate.c:9
+msgid "Type of the raster map to be created"
+msgstr "Typ rastru, který bude vytvoøen"
-#: ../db/db.login/main.c:93
-msgid "New password set"
-msgstr "Nové heslo bylo nastaveno."
-#: ../db/db.login/main.c:100
-msgid "Unable to set user/password"
-msgstr "Nelze nastavit u¾ivatele/heslo"
-#: ../db/db.login/main.c:104
-msgid "The password was stored in file"
-msgstr "Heslo bylo ulo¾eno v souboru."
-#: ../db/drivers/sqlite/describe.c:161
-#, c-format
-msgid "SQLite driver: column '%s', SQLite type %d is not supported"
-msgstr "Ovladaè SQLite: sloupec '%s', typ SQLite %d není podporován"
-#: ../db/drivers/mysql/listtab.c:37
-msgid "Cannot get list of tables:\n"
-msgstr "Nelze získat seznam tabulek:\n"
-#: ../db/drivers/mysql/parse.c:59
-msgid "Wrong port number in MySQL database definition: "
-msgstr "©patný port v definici databáze MySQL: "
-#: ../db/drivers/mysql/parse.c:72 ../db/drivers/postgres/parse.c:53
-msgid "'user' in database definition is not supported, use db.login"
-msgstr "'u¾ivatel' v definici databáze není podporován, pou¾ijte db.login"
-#: ../db/drivers/mysql/parse.c:77 ../db/drivers/postgres/parse.c:57
-msgid "'password' in database definition is not supported, use db.login"
-msgstr "'heslo' v definici databáze není podporováno, pou¾ijte db.login"
-#: ../db/drivers/mysql/parse.c:82
-msgid "Unknown option in database definition for "
-msgstr "Neznámá volba v definici databáze pro "
-#: ../db/drivers/mysql/cursor.c:46
-msgid "Cannot allocate cursor."
-msgstr "Nelze alokovat kurzor"
-#: ../db/drivers/mysql/cursor.c:55
-msgid "Cannot ad new token."
-msgstr "Nelze pøidat dal¹í token."
-#: ../db/drivers/mysql/select.c:44
-msgid "Cannot select data: \n"
-msgstr "Nelze vybrat data: \n"
-#: ../db/drivers/mysql/describe.c:120
-#, c-format
-msgid "MySQL driver: column '%s', type %d is not supported"
-msgstr "ovladaè MySQL: sloupec '%s', typu %d není podporován"
-#: ../db/drivers/mysql/describe.c:126
-#, c-format
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:1
msgid ""
-"column '%s' : type BIGINT is stored as integer (4 bytes) some data may be "
-"damaged"
+"Georeference, rectify and import Terra-ASTER imagery and relative DEM's "
+"using gdalwarp."
msgstr ""
-"sloupec '%s' : typ BITINT byl ulo¾en jako integer nìkterá data mohou být "
-"po¹kozena"
+"Georeferencuje, rektifikuje a importuje snímky ve formátu Terra-ASTER a "
+"pøíbuzných DMTù za pou¾ití gdalwarp."
-#: ../db/drivers/mysql/db.c:66
-msgid "Cannot connect to MySQL: "
-msgstr "Nelze se pøipojit k MySQL: "
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:2
+#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:2
+msgid "raster, imagery, import"
+msgstr "rastr, obrazová data, import"
-#: ../db/drivers/mysql/db.c:83
-msgid "Cannot parse MySQL embedded database name"
-msgstr "Nelze parsovat MySQL pøipojené jméno databáze"
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:3
+msgid "Input ASTER image to be georeferenced & rectified"
+msgstr "Vstupní snímek ASTER urèení ke georeferencingu a rektifikaci"
-#: ../db/drivers/mysql/db.c:100
-msgid "Cannot initialize MySQL embedded server"
-msgstr "Nelze inicializovat pøipojený MySQL server"
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:4
+msgid "ASTER imagery processing type (Level 1A, Level 1B, or relative DEM)"
+msgstr "Typ souboru ASTER (Level 1A, Level 1B, nebo pøíbuzný DEM)"
-#: ../db/drivers/mysql/db.c:118
-msgid "Cannot connect to MySQL embedded server: "
-msgstr "Nelzese pøipojit na MySQL server"
-#: ../db/drivers/mysql/fetch.c:34
-msgid "Cursor not found"
-msgstr "Kurzor nenalezen"
-#: ../db/drivers/mysql/fetch.c:53
-msgid "Cursor position is not supported by MySQL driver"
-msgstr "Pozice kurzoru není podporována ovladaèem MySQL"
-#: ../db/drivers/mysql/fetch.c:181
-msgid "Cannot scan timestamp: "
-msgstr "Nelze zjistit èasovou znaèku: "
-#: ../db/drivers/mysql/fetch.c:189
-msgid "Unknown timestamp format: "
-msgstr "Neznámý formát èasové znaèky: "
-#: ../db/drivers/mysql/fetch.c:203
-msgid "Cannot scan date: "
-msgstr "Nelze získat datum: "
-#: ../db/drivers/mysql/fetch.c:216
-msgid "Cannot scan time: "
-msgstr "Nelze získat èas: "
-#: ../db/drivers/mysql/fetch.c:231
-msgid "Cannot scan datetime: "
-msgstr "Nelze získat datumaèas: "
-#: ../db/drivers/mysql/error.c:29
-msgid "DBMI-MySQL driver error:\n"
-msgstr "Chyba ovladaèe DBMI-MySQL :\n"
-#: ../db/drivers/postgres/parse.c:61
-msgid "Unknown option in database definition for PostgreSQL: "
-msgstr "Neznámá volba v definici databáze pro PostgreSQL: "
-#: ../db/drivers/postgres/describe.c:101
-#, c-format
-msgid "pg driver: PostGIS column '%s', type 'geometry' will not be converted"
-msgstr "ovladaè pg: Sloupec PostGIS '%s', typu 'geometry' nebude pøeveden"
-#: ../db/drivers/postgres/describe.c:105
-#, c-format
-msgid "pg driver: column '%s', type %d is not supported"
-msgstr "ovladaè pg: sloupec '%s', typu %d není podporován"
-#: ../db/drivers/postgres/describe.c:111
-#, c-format
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:5
msgid ""
-"column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data "
-"may be damaged"
+"L1A or L1B band to translate (1, 2, 3n, 3b, 4-14). Can only translate a "
+"single band"
msgstr ""
-"sloupec '%s' : typ int8 (bigint) byl ulo¾en jako integer (celé èíslo - 4 "
-"byty) nìkterá data mohou být po¹kozena"
+"L1A nebo L1B k pøelo¾ení (1,2,3n,3b,4-14). Umím pøelo¾it pouze jeden kanál"
-#: ../db/drivers/postgres/describe.c:115
-#, c-format
-msgid ""
-"column '%s' : type character varying is stored as varchar(250) some data may "
-"be lost"
-msgstr ""
-"sloupec '%s' : typ character varying byl ulo¾en jako varchar(250), nìkterá "
-"data mohou být ztracena"
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:6
+#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:5
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:4
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:15
+#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:9
+#: ../raster/r.in.gridatb/main.c:55
+msgid "Name for output raster map"
+msgstr "Název výstupní rastrové mapy"
-#: ../db/drivers/postgres/describe.c:121
-#, c-format
-msgid ""
-"column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 "
-"(true)"
-msgstr ""
-"sloupec '%s' : typ boolean je ulo¾en jako char(1), hodnoty: 0 (false), 1 "
-"(true)"
+#: ../locale/scriptstrings/r.univar.sh_to_translate.c:1
+msgid "calculates univariate statistics from a GRASS raster map"
+msgstr "Spoèítá základní statistiku z GRASS rastrové mapy."
-#: ../db/drivers/postgres/fetch.c:169
-msgid "Cannot recognize boolean value"
-msgstr "Nelze rozpoznat booleanovskou hodnotu"
+#: ../locale/scriptstrings/r.univar.sh_to_translate.c:2
+#: ../locale/scriptstrings/r.regression.line_to_translate.c:2
+#: ../raster/r.univar2/r.univar_main.c:75 ../raster/r.report/main.c:27
+#: ../raster/r.quantile/main.c:233 ../raster/r.statistics/main.c:41
+msgid "raster, statistics"
+msgstr "rastr, statistika"
-#: ../db/drivers/ogr/describe.c:88
-#, c-format
-msgid "OGR driver: column '%s', OGR type %d is not supported"
-msgstr "Ovladaè OGR: sloupec '%s', typu %d není podporován"
+#: ../locale/scriptstrings/r.univar.sh_to_translate.c:3
+msgid "extended statistics (quartiles and percentile)"
+msgstr "roz¹íøená statistika (kvartily a percentily)"
-#: ../db/drivers/ogr/describe.c:144
-#, c-format
-msgid ""
-"column '%s', type 'string': unknown width -> stored as varchar(250) some "
-"data may be lost"
-msgstr ""
-"sloupec '%s' typu 'string': neznámé ¹íøky -> ulo¾en jako varchar(250), "
-"nìkterá data mohou být ztracena"
+#: ../locale/scriptstrings/r.univar.sh_to_translate.c:4
+#: ../display/d.legend/main.c:92 ../display/d.zoom/main.c:92
+msgid "Name of raster map"
+msgstr "Název rastrové mapy"
-#: ../db/drivers/ogr/describe.c:152 ../db/drivers/ogr/fetch.c:124
-msgid "Unknown type"
-msgstr "Neznámý typ"
+#: ../locale/scriptstrings/r.univar.sh_to_translate.c:5
+msgid "Percentile to calculate (requires -e flag)"
+msgstr "Percentil, který se má spoèítat (vy¾aduje pøepínaè -e)"
-#: ../raster3d/r3.in.ascii/main.c:79
-msgid "Ascii raster map to be imported"
-msgstr "Název ASCII rastrového souboru, který má být naimportován"
-#: ../raster3d/r3.in.ascii/main.c:90
-msgid "String representing NULL value data cell (use 'none' if no such value)"
-msgstr ""
-"Textový øetìzec reprezentující hodnotu NULL (pou¾ít 'none' v pøípadì "
-"takovéto hodnoty)"
-#: ../raster3d/r3.in.ascii/main.c:177
-#, c-format
-msgid "Loading data ... (%dx%dx%d)"
-msgstr "Naèítám data ... (%dx%dx%d)"
-#: ../raster3d/r3.in.ascii/main.c:191
-msgid "End of file reached while still loading data."
-msgstr "Konec rastru byl dosa¾en je¹tì pøi naèítání dat."
-#: ../raster3d/r3.in.ascii/main.c:210
-#, c-format
+#: ../locale/scriptstrings/v.in.gns_to_translate.c:1
msgid ""
-"Data exists in input file after fully importing expected data. [%.4f ...]"
+"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
+"points map."
msgstr ""
-"Po plném importu oèekávaných dat, nìkterá data zbyla ve vstupním souboru "
-"[%.4f ...]"
+"Importuje US-NGA GEOnet jmenný server (GNS) soubory o státech do vektorové "
+"bodové mapy mapy GRASSu"
-#: ../raster3d/r3.in.ascii/main.c:240
-msgid "raster3d, voxel, import"
-msgstr "rastr3d, voxel, import"
+#: ../locale/scriptstrings/v.in.gns_to_translate.c:2
+msgid "vector, import, gazetteer"
+msgstr "vektor, import gazetteer"
-#: ../raster3d/r3.in.ascii/main.c:242
-msgid "Convert a 3D ASCII raster text file into a (binary) 3D raster map layer"
-msgstr ""
-"Pøevede 3D ASCII rastrový textový soubor na (binární) 3D rastrovou mapovou "
-"vrstvu "
+#: ../locale/scriptstrings/v.in.gns_to_translate.c:3
+msgid "Uncompressed GNS file from NGA (with .txt extension)"
+msgstr "Rozbalený soubor GNS z NGA (s koncovkou .txt)"
-#: ../raster3d/r3.in.ascii/main.c:265 ../raster3d/r3.out.ascii/main.c:282
-#: ../raster3d/r3.in.v5d/main.c:217 ../raster3d/r3.out.v5d/main.c:311
-#: ../raster/r.to.rast3elev/main.c:484 ../raster/r.to.rast3/main.c:301
-msgid "Error opening 3d raster map"
-msgstr "Chyba pøi otevírání g3d souboru"
+#: ../locale/scriptstrings/v.in.gns_to_translate.c:4
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:4
+#: ../locale/scriptstrings/v.centroids_to_translate.c:4
+#: ../locale/scriptstrings/v.in.e00_to_translate.c:6
+msgid "Name for output vector map"
+msgstr "Název výstupní vektorové vrstvy"
-#: ../raster3d/r3.in.ascii/main.c:271
-msgid "Error closing new 3d raster map"
-msgstr "Chyba pøi zavírání 3d rastru"
+#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:1
+msgid ""
+"Drops a column from the attribute table connected to a given vector map."
+msgstr "Ma¾e sloupce z tabulky atributù pøipojené k zadané vektorové mapì."
-#: ../raster3d/r3.in.ascii/main.c:281
-msgid "Error closing ascii file"
-msgstr "Chyba pøi zavírání souboru ASCII"
+#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:3
+msgid "Vector map for which to drop attribute column"
+msgstr "Vektorová mapa, v její¾ atributové tabulce bude sloupec smazán"
-#: ../raster3d/r3.out.ascii/main.c:59 ../raster3d/r3.out.ascii/main.c:318
-#: ../raster3d/r3.in.v5d/main.c:222 ../raster3d/r3.out.v5d/main.c:324
-#: ../raster3d/base/r3.info.main.c:422 ../raster3d/r3.to.rast/main.c:389
-#: ../raster/r.to.rast3elev/main.c:547 ../raster/r.to.rast3/main.c:333
-msgid "Error closing 3d raster map"
-msgstr "Chyba pøi zavírání g3d souboru"
+#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:4
+msgid "Layer where to drop column"
+msgstr "Vrstva, odkud smazat sloupec"
-#: ../raster3d/r3.out.ascii/main.c:78
-msgid "3d raster map to be converted to ASCII"
-msgstr "mapa 3dcell pro konverzi do ASCII"
+#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:5
+#: ../locale/scriptstrings/db.dropcol_to_translate.c:5
+msgid "Name of the column"
+msgstr "Jméno sloupce"
-#: ../raster3d/r3.out.ascii/main.c:85
-msgid "Name for ASCII output file"
-msgstr "Název výstupního ASCII souboru"
+#: ../locale/scriptstrings/r.mask_to_translate.c:1
+msgid "Create a MASK for limiting raster operation"
+msgstr "Vytvoø MASKu pro limitní rastrové operace"
-#: ../raster3d/r3.out.ascii/main.c:94
-msgid "Number of decimal places for floats"
-msgstr "Poèet míst za desetinnou èárkou"
+#: ../locale/scriptstrings/r.mask_to_translate.c:2
+msgid "raster, mask"
+msgstr "rastr, maska"
-#: ../raster3d/r3.out.ascii/main.c:100 ../raster/r.transect/main.c:84
-#: ../raster/r.what/main.c:113
-msgid "Char string to represent no data cell"
-msgstr "Znak pro oznaèení bunìk s hodnotou NULL"
+#: ../locale/scriptstrings/r.mask_to_translate.c:3
+msgid "Raster map to use as MASK"
+msgstr "Rastrová mapa pou¾itá jako MASKa"
-#: ../raster3d/r3.out.ascii/main.c:105 ../raster/r.out.ascii/main.c:101
-#: ../raster/r.out.arc/main.c:86
-msgid "Suppress printing of header information"
-msgstr "Potlaè výpis informací z hlavièky"
+#: ../locale/scriptstrings/r.mask_to_translate.c:4
+msgid "Category values to use for MASK (format: 1 2 3 thru 7 *)"
+msgstr "Hodnoty kategorií pou¾itých jako maska (MASK) (formát: 1 2 3 thru 7 *)"
-#: ../raster3d/r3.out.ascii/main.c:109 ../raster3d/r3.to.rast/main.c:90
-#: ../raster/r.to.rast3elev/main.c:233
-msgid "Use G3D mask (if exists) with input map"
-msgstr "Pou¾ít masku G3D (pokud existuje) s vstupní mapou"
+#: ../locale/scriptstrings/r.mask_to_translate.c:5
+msgid "Create inverse MASK from specified 'maskcats' list"
+msgstr "Vytvoøit inverzní MASKU z daného seznamu 'maskcats' "
-#: ../raster3d/r3.out.ascii/main.c:259
-msgid "raster3d, voxel, export"
-msgstr "rastr3d, voxel, export"
+#: ../locale/scriptstrings/r.mask_to_translate.c:6
+msgid "Overwrite existing MASK"
+msgstr "Pøepi¹ existující MASKu"
-#: ../raster3d/r3.out.ascii/main.c:260
-msgid "Converts a 3D raster map layer into an ASCII text file"
-msgstr "Pøevede 3D rastrovou mapovou vrstvu do ASCII textového souboru"
+#: ../locale/scriptstrings/r.mask_to_translate.c:7
+msgid "Remove existing MASK (overrides other options)"
+msgstr "Vymazávám existující MASKu (jiné volby budou ignorovány)"
-#: ../raster3d/r3.out.ascii/main.c:273 ../raster3d/r3.out.v5d/main.c:305
-#: ../raster3d/base/r3.null.main.c:104 ../raster3d/base/r3.mask.main.c:78
-msgid "Requested 3d raster map not found"
-msgstr "Po¾adovaný soubor g3d nebyl nalezen"
+#: ../locale/scriptstrings/v.db.droptable_to_translate.c:1
+msgid "Removes existing attribute table of a vector map."
+msgstr "Vyma¾e existující atributovou tabulku vektorové mapy."
-#: ../raster3d/r3.out.ascii/main.c:323
-msgid "Error closing new ASCII file"
-msgstr "Chyba pøi uzavírání nového souboru ASCII"
+#: ../locale/scriptstrings/v.db.droptable_to_translate.c:3
+msgid "Force removal (required for actual deletion of table)"
+msgstr "Vynucené odstranìní ( po¾adováno pro souèasné mazání tabulek)"
-#: ../raster3d/r3.stats/main.c:565 ../raster/r.univar2/r3.univar_main.c:76
-msgid "raster3d, statistics"
-msgstr "rastr3d, statistika"
+#: ../locale/scriptstrings/v.db.droptable_to_translate.c:4
+msgid "Vector map from which to remove attribute table"
+msgstr "Vektorová mapa, ze které má být odstranìna atributová tabulka."
-#: ../raster3d/r3.stats/main.c:566
-msgid "Generates volume statistics for raster3d maps."
-msgstr "Vytvoøí statistiku ploch pro r3d rastrové mapy."
+#: ../locale/scriptstrings/v.db.droptable_to_translate.c:5
+msgid "Name of existing attribute table (default: vector map name)"
+msgstr "Jméno existující atributové tabulky (výchozí: jméno vektorové mapy)"
-#: ../raster3d/r3.stats/main.c:577
-msgid "Number of sub-ranges to collect stats from"
-msgstr "Poèet podintervalù pro které bude vytvoøena statistika"
+#: ../locale/scriptstrings/v.db.droptable_to_translate.c:6
+msgid "Layer from which to drop linked attribute table"
+msgstr "Vrstva, z ní¾ má být odstranìno spojení s tabulkou"
-#: ../raster3d/r3.stats/main.c:582
-msgid "Calculate statistics based on equal value groups"
-msgstr "vypoèítat statistiku zalo¾enou na stejných hodnotách skupin"
+#: ../locale/scriptstrings/r.in.srtm_to_translate.c:1
+msgid "Import SRTM HGT files into GRASS"
+msgstr "Importuje SRTM HGT soubory do GRASSu"
-#: ../raster3d/r3.stats/main.c:603
-msgid "The number of subranges has to be equal or greater than 1"
-msgstr "Poèet subrozmezí musí být >= 1"
+#: ../locale/scriptstrings/r.in.srtm_to_translate.c:2
+#: ../raster/r.in.poly/main.c:28 ../raster/r.in.bin/main.c:112
+#: ../raster/r.in.gdal/main.c:78
+msgid "raster, import"
+msgstr "rastr, import"
-#: ../raster3d/r3.stats/main.c:608 ../raster/r.univar2/r3.univar_main.c:102
-#, c-format
-msgid "Requested g3d map <%s> not found"
-msgstr "Po¾adovaná mapa g3d <%s> nebyla nalezena"
+#: ../locale/scriptstrings/r.in.srtm_to_translate.c:3
+msgid "SRTM input tile (file without .hgt.zip extension)"
+msgstr "Vstupní dla¾dice SRTM (soubor bez koncovky hgt nebo zip)"
-#: ../raster3d/r3.stats/main.c:615 ../raster3d/r3.gwflow/main.c:376
-#: ../raster/r.univar2/r3.univar_main.c:110
-#, c-format
-msgid "Error opening g3d map <%s>"
-msgstr "Chyba pøi otevírání mapy g3d <%s>"
+#: ../locale/scriptstrings/r.in.srtm_to_translate.c:4
+msgid "Output raster map (default: input tile)"
+msgstr "Výstupní rastrová mapa (výchozí: vstup dla¾dice)"
-#: ../raster3d/r3.stats/main.c:660
-msgid "Sort non-null values"
-msgstr "Uspoøádat neNULLové hodnoty"
+#: ../locale/scriptstrings/r.in.srtm_to_translate.c:5
+msgid "Input is a 1-arcsec tile (default: 3-arcsec)"
+msgstr "Vstup je 1-arcsec dla¾dice (výchozí: 3-arcsec)"
-#: ../raster3d/r3.cross.rast/main.c:55
-msgid "Could not close G3D map"
-msgstr "Nemohl jsem uzavøít G3D mapu"
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:1
+msgid "import GetFeature from WFS"
+msgstr "Imoprtovat GetFeature z WFS"
-#: ../raster3d/r3.cross.rast/main.c:77 ../raster3d/r3.cross.rast/main.c:387
-#: ../raster3d/r3.to.rast/main.c:194
-msgid "Unable to close output map"
-msgstr "Nelze zavøít výstupní mapu"
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:2
+msgid "GetFeature URL starting with http"
+msgstr "GetFeature startovací adresa URL s http"
-#: ../raster3d/r3.cross.rast/main.c:91
-msgid "Input 3D raster map for cross section."
-msgstr "Vstupní 3D rastrový soubor pro prùnik."
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:3
+msgid "Vector output map"
+msgstr "Výstupní vektorová mapa"
-#: ../raster3d/r3.cross.rast/main.c:98
-msgid "2D elevation map used to create the cross section map"
-msgstr "2D mapa s elevací pou¾itá pro vytvoøení prùnikù"
-#: ../raster3d/r3.cross.rast/main.c:105
-msgid "Resulting cross section 2D raster map"
-msgstr "Výsledná 2D rastrová mapa prùseèíkù"
-#: ../raster3d/r3.cross.rast/main.c:110
-msgid "Use g3d mask (if exists) with input map"
-msgstr "Pou¾ít masku G3D (pokud existuje) se vstupní mapou"
-#: ../raster3d/r3.cross.rast/main.c:162
-msgid "Unable to get elevation raster row"
-msgstr "Nelze naèíst øádek rastru elevace"
-#: ../raster3d/r3.cross.rast/main.c:229 ../raster3d/r3.cross.rast/main.c:235
-msgid "Could not write raster row"
-msgstr "Nelze zapsat øádek rastrové mapy"
-#: ../raster3d/r3.cross.rast/main.c:268 ../raster3d/r3.in.v5d/main.c:198
-#: ../raster3d/r3.mkdspf/main.c:74 ../raster3d/r3.out.v5d/main.c:284
-#: ../raster3d/r3.gwflow/main.c:172 ../raster3d/base/r3.null.main.c:203
-#: ../raster3d/base/r3.info.main.c:78 ../raster3d/base/r3.mask.main.c:153
-#: ../raster3d/base/r3.timestamp.main.c:42 ../raster3d/r3.out.vtk/main.c:374
-#: ../raster3d/r3.to.rast/main.c:215
-msgid "raster3d, voxel"
-msgstr "rastr3d, voxel"
-#: ../raster3d/r3.cross.rast/main.c:271
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:1
msgid ""
-"Creates cross section 2D raster map from 3d raster map based on 2D elevation "
-"map"
-msgstr "Vytvoøí prùniky 2D mapy z g3d rastru objemù na základ 2D mapy elevace"
+"Dissolves boundaries between adjacent areas sharing a common category number "
+"or attribute."
+msgstr ""
+"Rozlo¾í hranice mezi sousedícími plochami, sdílejícími spoleèné èíslo "
+"kategorie nebo atribut."
-#: ../raster3d/r3.cross.rast/main.c:283 ../raster3d/r3.to.rast/main.c:228
-#, c-format
-msgid "3d raster map <%s> not found"
-msgstr "3D rastrová mapa <%s> nebyla nalezena"
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:2
+msgid "vector, area, dissolve"
+msgstr "vektor, plocha, spojení"
-#: ../raster3d/r3.cross.rast/main.c:296 ../raster/r.to.rast3elev/main.c:464
-#: ../raster/r.to.rast3/main.c:214
-msgid ""
-"The 2d and 3d region settings are different. I will use the g3d settings to "
-"adjust the 2d region."
-msgstr ""
-"2d a 3d nastavení regionu jsou rùzná. Pou¾iji hodnoty z nastavení g3d a "
-"pøenastavím 2d region."
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:3
+#: ../locale/scriptstrings/v.report_to_translate.c:5
+#: ../locale/scriptstrings/v.centroids_to_translate.c:3
+msgid "Name of input vector map"
+msgstr "Název vstupní vektorové vrstvy"
-#: ../raster3d/r3.cross.rast/main.c:316 ../raster3d/r3.out.vtk/main.c:208
-#: ../raster3d/r3.out.vtk/main.c:291 ../raster3d/r3.out.vtk/main.c:515
-#: ../raster3d/r3.to.rast/main.c:243 ../raster3d/r3.to.rast/main.c:284
-#, c-format
-msgid "Error opening 3d raster map <%s>"
-msgstr "Chyba pøi otevírání 3d rastrové mapy <%s>"
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:5
+msgid "Layer number. If -1, all layers are extracted"
+msgstr "Èíslo vrstvy. Pokud -1, jsou vyjmuty v¹echny vrstvy"
-#: ../raster3d/r3.cross.rast/main.c:330
-msgid "Elevation map not found"
-msgstr "Soubor s elevací nebyl nalezen"
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:6
+msgid "Name of column used to dissolve common boundaries"
+msgstr "Název sloupce atributu, který má být pou¾it pøi mazání hranic"
-#: ../raster3d/r3.cross.rast/main.c:335
-msgid "Unable to open elevation map"
-msgstr "nelze zavøít mapu elevace"
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:1
+msgid "Imports attribute tables in various formats."
+msgstr "Importuje atributové tabulky v rùzných formátech."
-#: ../raster3d/r3.cross.rast/main.c:346 ../raster3d/r3.to.rast/main.c:302
-#: ../raster/r.to.rast3/main.c:231
-msgid "Illegal output file name"
-msgstr "Neplatný název výstupního souboru"
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:2
+#: ../locale/scriptstrings/db.droptable_to_translate.c:2
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:2
+#: ../locale/scriptstrings/db.dropcol_to_translate.c:2
+#: ../locale/scriptstrings/db.test_to_translate.c:2
+msgid "database, attribute table"
+msgstr "databáze, atributová tabulka"
-#: ../raster3d/r3.cross.rast/main.c:349
-msgid "Output map already exists. Will be overwritten!"
-msgstr "Výstupní mapa ji¾ existuje. Mapa bude pøepsána!"
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:3
+msgid "Table file to be imported or DB connection string"
+msgstr "Tabulka pro import nebo textový øetìzec databázového spojení"
-#: ../raster3d/r3.cross.rast/main.c:354 ../raster3d/r3.cross.rast/main.c:359
-msgid "Unable to create raster map"
-msgstr "Nejsem schopen vytvoøit rastrovou mapu"
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:4
+msgid "Table name of SQL DB table"
+msgstr "Jméno tabulky v SQL DB tabulce"
-#: ../raster3d/r3.cross.rast/main.c:389
-msgid "Unable to close elevation map"
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:5
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:6
+msgid "Name for output table"
+msgstr "Název výstupní tabulky"
-#: ../raster3d/r3.cross.rast/main.c:394
-msgid "Wrong G3D Datatype! Cannot create raster map."
-msgstr "Chybný G3D datový typ! Nelze vytvoøit rastrové mapy."
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:6
+msgid "Name for auto-generated unique key column"
+msgstr "Jmémo slooupce s automaticky vytoøeným unikátním klíèem"
-#: ../raster3d/r3.cross.rast/main.c:399
-#, c-format
-msgid "Could not close G3D map <%s>"
-msgstr "Nemohl jsem uzavøít mapu G3D <%s>"
-#: ../raster3d/r3.mkdspf/main.c:75
+#: ../locale/scriptstrings/v.in.garmin_to_translate.c:1
msgid ""
-"Creates a display file from an existing grid3 file according to specified "
-"threshold levels."
+"Download waypoints, routes, and tracks from a Garmin GPS receiver into a "
+"vector map."
msgstr ""
-"Vytvoøí a zobrazí soubor z existujícího grid3 souboru podle zadaných "
-"prahových hodnot."
+"Ulo¾ Waypoints, Routes a Tracks z pøístroje GPS Garmin jako vektorovou mapu."
-#: ../raster3d/r3.mkdspf/main.c:83
-msgid "Name of an existing 3d raster map"
-msgstr "Název existující 3D rastrové mapy"
+#: ../locale/scriptstrings/v.in.garmin_to_translate.c:2
+#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:2
+msgid "vector, import, GPS"
+msgstr "vektor, import, GPS"
-#: ../raster3d/r3.mkdspf/main.c:89
-msgid "Name of output display file"
-msgstr "Název výstupního souboru"
+#: ../locale/scriptstrings/v.in.garmin_to_translate.c:3
+#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:3
+#: ../locale/scriptstrings/v.in.e00_to_translate.c:3
+#: ../raster/r.in.mat/main.c:113 ../raster/r.out.tiff/r.out.tiff.c:137
+#: ../raster/r.out.mat/main.c:79
+msgid "Verbose mode"
+msgstr "Roz¹íøený mód"
-#: ../raster3d/r3.mkdspf/main.c:96
-msgid "List of thresholds for isosurfaces"
-msgstr "Seznam prahových hodnot pro iso-povrchy"
+#: ../locale/scriptstrings/v.in.garmin_to_translate.c:4
+msgid "Download Waypoints from GPS"
+msgstr "Stáhni Waypoints z GPSky"
-#: ../raster3d/r3.mkdspf/main.c:102
-msgid "Minimum isosurface level"
-msgstr "Minimální íºroveò isopovrchu"
+#: ../locale/scriptstrings/v.in.garmin_to_translate.c:5
+msgid "Download Routes from GPS"
+msgstr "Stáhni Routes z GPSky"
-#: ../raster3d/r3.mkdspf/main.c:108
-msgid "Maximum isosurface level"
-msgstr "Maximální íºroveò isopovrchu"
+#: ../locale/scriptstrings/v.in.garmin_to_translate.c:6
+msgid "Download Track from GPS"
+msgstr "Stáhni Tracky z GPSky"
-#: ../raster3d/r3.mkdspf/main.c:114
-msgid "Positive increment between isosurface levels"
-msgstr "Kladný pøírùstek mezi jednotlivými íºrovnìmi isopovrchù"
+#: ../locale/scriptstrings/v.in.garmin_to_translate.c:7
+msgid "Force import of track or route data as points"
+msgstr "Importuj tracky a routy jako body"
-#: ../raster3d/r3.mkdspf/main.c:121
-msgid "Number of isosurface threshold levels"
-msgstr "Poèet prahových íºrovní isopovrchù"
+#: ../locale/scriptstrings/v.in.garmin_to_translate.c:8
+msgid "Use gardump instead of gpstrans as the download program"
+msgstr "Pou¾ít gardump místo gpstrans jako stahovací program"
-#: ../raster3d/r3.mkdspf/main.c:125
-msgid "Suppress progress report & min/max information"
-msgstr "Potlaè zprávu o prùbìhu & min/max informaci"
+#: ../locale/scriptstrings/v.in.garmin_to_translate.c:9
+msgid "Import track in 3D (gardump only)"
+msgstr "Importovat stopu ve 3D ( pouze gardump)"
-#: ../raster3d/r3.mkdspf/main.c:129
-msgid "Use flat shading rather than gradient"
-msgstr "Pou¾ij plo¹né stínování místo gradientu"
+#: ../locale/scriptstrings/v.in.garmin_to_translate.c:10
+#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:8
+msgid "Do not attempt projection transform from WGS84"
+msgstr "Neprovádìt pøevod projekce z WGS84"
-#: ../raster3d/r3.mkdspf/main.c:137
-#, c-format
-msgid "Region from getWindow: %d %d %d"
-msgstr "Region z getWindow: %d %d %d"
-#: ../raster3d/r3.mkdspf/main.c:147
-#, c-format
-msgid "Not able to find grid3 file for [%s]"
-msgstr "Nejsem schopen nalézt soubor grid3 pro [%s]"
-#: ../raster3d/r3.mkdspf/main.c:159 ../raster3d/base/r3.info.main.c:130
-#, c-format
-msgid "Error opening grid3 file [%s]"
-msgstr "Chyba pøi otevírání souboru grid3 [%s]"
-#: ../raster3d/r3.mkdspf/main.c:162 ../raster3d/base/r3.info.main.c:289
-#: ../raster3d/base/r3.info.main.c:351
-#, c-format
-msgid "Error reading range for [%s]"
-msgstr "Chyba pøi ètení rozsahu pro [%s]"
-#: ../raster3d/r3.mkdspf/main.c:191
-#, c-format
-msgid "Error opening display file [%s]"
-msgstr "Chyba pøi otevírání souboru [%s]"
-#: ../raster3d/r3.mkdspf/main.c:212
-#, c-format
-msgid "Writing %s from %s..."
-msgstr "Zapisuji %s z %s..."
-#: ../raster3d/r3.out.v5d/main.c:68
-msgid "3d raster map to be converted to Vis5d (v5d) file"
-msgstr "mapa 3dcell pro konverzi na soubor Vis5d (v5d)"
-#: ../raster3d/r3.out.v5d/main.c:75
-msgid "Name for v5d output file"
-msgstr "Název výstupního v5d souboru"
-#: ../raster3d/r3.out.v5d/main.c:145
-#, c-format
-msgid "Viz5D allows %d cols, you have %d cols"
-msgstr "Viz5D dovoluje %d sloupcù, vy máte %d sloupcù"
-#: ../raster3d/r3.out.v5d/main.c:147
-#, c-format
-msgid "Viz5D allows %d rows, you have %d rows"
-msgstr "Viz5D dovoluje %d øádkù, vy máte %d øádkù"
-#: ../raster3d/r3.out.v5d/main.c:197 ../raster3d/r3.to.rast/main.c:299
-#: ../raster/r.li/r.li.daemon/list.c:43 ../raster/r.gwflow/main.c:376
-#: ../raster/r.to.rast3/main.c:228 ../vector/v.edit/cmd/a2b.c:191
-#: ../vector/v.in.ascii/a2b.c:161 ../vector/v.generalize/smoothing.c:93
-#: ../vector/v.generalize/smoothing.c:150
-#: ../vector/v.generalize/smoothing.c:250
-#: ../vector/v.generalize/smoothing.c:368
-#: ../vector/v.generalize/smoothing.c:399
-#: ../vector/v.generalize/simplification.c:33
-#: ../vector/v.generalize/simplification.c:40
-#: ../vector/v.generalize/simplification.c:306
-#: ../vector/v.generalize/simplification.c:314
-#: ../vector/v.generalize/simplification.c:336
-#: ../vector/v.generalize/point.c:118 ../vector/v.generalize/network.c:92
-#: ../vector/v.generalize/network.c:124 ../vector/v.mkgrid/write_grid.c:140
-#: ../vector/v.surf.rst/main.c:826 ../vector/v.mapcalc/list.c:56
-#: ../vector/v.mapcalc/list.c:549 ../imagery/i.ask/popup.c:179
-msgid "Out of memory"
-msgstr "Pamì» vyèerpána"
-#: ../raster3d/r3.out.v5d/main.c:257
-#, c-format
-msgid "Error: couldn't create %s"
-msgstr "Chyba: nemohu vytvoøit %s"
-#: ../raster3d/r3.out.v5d/main.c:262
-msgid "Error while writing grid. Disk full?"
-msgstr "Chyba pøi zapisování møí¾ky. Disk je plný?"
-#: ../raster3d/r3.out.v5d/main.c:286
-msgid "Export of GRASS 3D raster map to 3-dimensional Vis5D file."
+#: ../locale/scriptstrings/v.in.garmin_to_translate.c:11
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:6
+#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:10
+msgid "Name for output vector map (omit for display to stdout)"
msgstr ""
-"Exportuje 3D rastrový soubor GRASSu do 3-dimenzionálního Vis5D souboru."
+"Jméno nového vektorového souboru (vynechává se pro zobrazení na standardní "
+"výstup)"
-#: ../raster3d/r3.out.v5d/main.c:293
-msgid "Use map coordinates instead of xyz coordinates"
-msgstr "Pou¾ít mapové souøadnice namísto souøadnic xyz"
+#: ../locale/scriptstrings/v.in.garmin_to_translate.c:12
+msgid "Port Garmin receiver is connected to"
+msgstr "Port, na kterém je Garmina pøipojena"
-#: ../raster3d/r3.gwflow/main.c:55 ../raster/r.gwflow/main.c:57
-msgid "The initial piezometric head in [m]"
-msgstr "Poèáteèní piezometrická hodnota v [m]"
-#: ../raster3d/r3.gwflow/main.c:64
-msgid "The status for each cell, = 0 - inactive, 1 - active, 2 - dirichlet"
+#: ../locale/scriptstrings/i.spectral_to_translate.c:1
+msgid ""
+"displays spectral response at user specified locations in group or images"
msgstr ""
-"Status pro ka¾dou buòku, = 0 -neaktivní, 1 - aktivní, 2 - Dirichletovo ¹íøení"
+"zobrazí spektrální odrazivost na u¾ivatelem zadaných mapách ve skupinì snímkù"
-#: ../raster3d/r3.gwflow/main.c:72
-msgid "The x-part of the hydraulic conductivity tensor in [m/s]"
-msgstr "souøadnice x hydraulického napøimovaèe vodivosti v [m/s]"
+#: ../locale/scriptstrings/i.spectral_to_translate.c:2
+msgid "imagery, raster, multispectral"
+msgstr "rastr, dpz, multispektrální"
-#: ../raster3d/r3.gwflow/main.c:80
-msgid "The y-part of the hydraulic conductivity tensor in [m/s]"
-msgstr "souøadnice y hydraulického napøimovaèe vodivosti v [m/s]"
+#: ../locale/scriptstrings/i.spectral_to_translate.c:3
+msgid "group input"
+msgstr "vstupní skupina"
-#: ../raster3d/r3.gwflow/main.c:88
-msgid "The z-part of the hydraulic conductivity tensor in [m/s]"
-msgstr "souøadnice z hydraulického napøimovaèe vodivosti v [m/s]"
+#: ../locale/scriptstrings/i.spectral_to_translate.c:4
+msgid "raster input maps"
+msgstr "Vstupní rastrové soubory"
-#: ../raster3d/r3.gwflow/main.c:95
-#, fuzzy
-msgid "Sources and sinks in [m^3/s]"
-msgstr "Prameny a jezera v [m^3/s]"
+#: ../locale/scriptstrings/i.spectral_to_translate.c:5
+msgid "write output to PNG image"
+msgstr "Zapsat výstup jako soubor PNG"
-#: ../raster3d/r3.gwflow/main.c:102
-msgid "Specific yield in 1/m"
-msgstr "Specifický výnos 1/m"
+#: ../locale/scriptstrings/i.spectral_to_translate.c:6
+msgid "Use image list and not group"
+msgstr "Pou¾ij seznam snímkù a ne skupinu"
-#: ../raster3d/r3.gwflow/main.c:109
-msgid "Recharge raster map in m^3/s"
-msgstr "Mapa obohacení v m^3/s "
+#: ../locale/scriptstrings/i.spectral_to_translate.c:7
+msgid "Select multiple points"
+msgstr "Vyber více bodù"
-#: ../raster3d/r3.gwflow/main.c:118
-msgid ""
-"The piezometric head result of the numerical calculation will be written to "
-"this map"
-msgstr ""
-"Výsledná piezometrická hodnota numerického výpoètu bude zapsána do mapy"
+#: ../locale/scriptstrings/i.spectral_to_translate.c:8
+msgid "label with coordinates instead of numbering"
+msgstr "oznaè souøadnicemi místo èíslováním"
-#: ../raster3d/r3.gwflow/main.c:127
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:1
msgid ""
-"Calculate the groundwater distance velocity vector field and write the x, y, "
-"and z components to maps named name_[xyz]. Name is basename for the new "
-"raster3d maps"
+"Calculates univariate statistics from a GRASS raster map based on vector "
+"polygons and uploads statistics to new attribute columns."
msgstr ""
-"Vypoèítat prùtokovou rychlost vektorového pole a zapi¹ x,y a z èásti do map "
-"pojmenovaných jmeno_[xyz]. Jméno mapy je základ pro r3d rastrovou mapu."
+"Spoèítá základní statistiku rastrového souboru na základì vektorových "
+"polygonù a ulo¾í ji do nových sloupeèkù atributové tabulky."
-#: ../raster3d/r3.gwflow/main.c:138
-msgid "Use G3D mask (if exists)"
-msgstr "Pou¾ít masku G3D (pokud existuje)"
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:2
+msgid "vector, raster, statistics"
+msgstr "vektor, rastr, statistika"
-#: ../raster3d/r3.gwflow/main.c:144
-msgid ""
-"Use a sparse linear equation system, only available with iterative solvers"
-msgstr ""
-"Pou¾ít lineární systém rovnic pro øídké matice, dostupný pouze pro "
-"iterativní solvery"
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:3
+msgid "Continue if upload column(s) already exist"
+msgstr "Pokraèuj, i kdy¾ sloupec pro ulo¾ení dat ji¾ existuje"
-#: ../raster3d/r3.gwflow/main.c:175
-msgid ""
-"Numerical calculation program for transient, confined groundwater flow in "
-"three dimensions"
-msgstr "Numerický výpoèet pro pøechodný uzavøený tok ve tøech dimenzích"
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:4
+#: ../vector/v.univar/main.c:94 ../raster/r.univar2/r.univar_main.c:48
+#: ../raster/r.univar2/r3.univar_main.c:47
+msgid "Calculate extended statistics"
+msgstr "Spoèítej roz¹íøenou statistiku"
-#: ../raster3d/r3.gwflow/main.c:193 ../raster/r.gwflow/main.c:266
-msgid "The direct LU solver do not work with sparse matrices"
-msgstr "Pøímý LU øe¹itel nepracuje s øídkou maticí"
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:5
+msgid "Name of vector polygon map"
+msgstr "Název polygonové mapy"
-#: ../raster3d/r3.gwflow/main.c:195 ../raster/r.gwflow/main.c:269
-msgid "The direct Gauss solver do not work with sparse matrices"
-msgstr "Pøímá Gausova analýza nepracuje s øídkou maticí"
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:6
+#: ../locale/scriptstrings/v.db.update_to_translate.c:4
+msgid "Layer to which the table to be changed is connected"
+msgstr "Vrstva ke které je zmìnìná tabulka pøipojena"
-#: ../raster3d/r3.gwflow/main.c:197 ../raster/r.gwflow/main.c:272
-msgid "The direct cholesky solver do not work with sparse matrices"
-msgstr "Pøímá choleskyho analýza nepracuje s øídkou maticí"
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:7
+msgid "Name of raster map to calculate statistics from"
+msgstr "Název rastrové mapy, na kterém se bude statistika poèítat"
-#: ../raster3d/r3.gwflow/main.c:300 ../raster/r.gwflow/main.c:556
-msgid "Unable to create and solve the linear equation system"
-msgstr "Nelze vytvoøit a vyøe¹it soustavu lineárních rovnic"
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:8
+msgid "Column prefix for new attribute columns"
+msgstr "Pøedpona v názvu nových sloupeèkù"
-#: ../raster3d/r3.gwflow/main.c:378
-#, c-format
-msgid "Write the result to g3d map <%s>"
-msgstr "Zapsat výsledek do g3d mapy <%s>"
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:9
+#: ../vector/v.univar/main.c:86 ../raster/r.univar2/r.univar_main.c:40
+#: ../raster/r.univar2/r3.univar_main.c:39
+msgid "Percentile to calculate (requires extended statistics flag)"
+msgstr ""
+"Percentil, který se má spoèítat (vy¾aduje pøepínaè roz¹íøení statistiky)"
-#: ../raster3d/r3.gwflow/main.c:422
-msgid "Error closing g3d file"
-msgstr "Chyba pøi zavírání souboru g3d"
+#: ../locale/scriptstrings/i.oif_to_translate.c:1
+msgid "Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7"
+msgstr ""
+"Spoèítá tabulku optimálního faktoru indexu pro kanály 1-5 a 7 dru¾ice "
+"LANDSAT TM"
-#: ../raster3d/base/r3.null.main.c:57
-msgid "3d raster map for which to modify null values"
-msgstr "mapa 3dcell pro modifikaci hodnot NULL"
+#: ../locale/scriptstrings/i.oif_to_translate.c:2
+msgid "raster, imagery, statistics"
+msgstr "rastr, dpz, statistika"
-#: ../raster3d/base/r3.null.main.c:65 ../raster/r.null/null.c:63
-msgid "List of cell values to be set to NULL"
-msgstr "Seznam hodnot bunìk pro nastavení NULL"
+#: ../locale/scriptstrings/i.oif_to_translate.c:3
+msgid "LANDSAT TM band 1."
+msgstr "LANDSAT TM kanál 1"
-#: ../raster3d/base/r3.null.main.c:72 ../raster/r.null/null.c:70
-msgid "The value to replace the null value by"
-msgstr "Hodnota pro nahrazení hodnoty NULL"
+#: ../locale/scriptstrings/i.oif_to_translate.c:4
+msgid "LANDSAT TM band 2."
+msgstr "LANDSAT TM kanál 2."
-#: ../raster3d/base/r3.null.main.c:86
-msgid "Illegal value for null"
-msgstr "Neplatná hodnota pro null"
+#: ../locale/scriptstrings/i.oif_to_translate.c:5
+msgid "LANDSAT TM band 3."
+msgstr "LANDSAT TM kanál 3."
-#: ../raster3d/base/r3.null.main.c:111
-msgid "modifyNull: error opening map"
-msgstr "modifyNull: chyba pøi otevøení mapy"
+#: ../locale/scriptstrings/i.oif_to_translate.c:6
+msgid "LANDSAT TM band 4."
+msgstr "LANDSAT TM kanál 4."
-#: ../raster3d/base/r3.null.main.c:123
-msgid "modifyNull: error opening tmp file"
-msgstr "modifyNull: chyba pøi otevøení souboru tmp"
+#: ../locale/scriptstrings/i.oif_to_translate.c:7
+msgid "LANDSAT TM band 5."
+msgstr "LANDSAT TM kanál 5."
-#: ../raster3d/base/r3.null.main.c:172
-msgid "modifyNull: error flushing tiles in cube"
-msgstr "modifyNull: chyba pøi zarovnání dla¾dic do kostky"
+#: ../locale/scriptstrings/i.oif_to_translate.c:8
+msgid "LANDSAT TM band 7."
+msgstr "LANDSAT TM kanál 7."
-#: ../raster3d/base/r3.null.main.c:178
-msgid "modifyNull: error flushing all tiles"
-msgstr "modifyNull: chyba pøi zarovnání v¹ech dla¾dic"
+#: ../locale/scriptstrings/i.oif_to_translate.c:9
+#: ../locale/scriptstrings/r.regression.line_to_translate.c:3
+#: ../general/g.region/main.c:134
+msgid "Print in shell script style"
+msgstr "Vypi¹ ve stylu pro shell skript."
-#: ../raster3d/base/r3.null.main.c:186
-msgid "modifyNull: error closing map"
-msgstr "modifyNull: chyba pøi uzavøení mapy"
+#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:1
+msgid "Auto-balancing of colors for LANDSAT images"
+msgstr "Automatické vyvá¾ení barev pro snímky z dru¾ice LANDSAT"
-#: ../raster3d/base/r3.null.main.c:188
-msgid "modifyNull: error closing tmp file"
-msgstr "modifyNull: chyba pøi zavírání souboru tmp"
+#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:2
+msgid "raster, imagery, colors"
+msgstr "rastr, dpz, barvy"
-#: ../raster3d/base/r3.null.main.c:204
-msgid "Explicitly create the 3D NULL-value bitmap file."
-msgstr "Vytvoøit výluènì soubor s bitmapou 3D NULL-hodnota"
+#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:3
+msgid "LANDSAT red channel"
+msgstr "èervený kanál LANDSAT"
-#: ../raster3d/base/r3.info.main.c:81
-msgid "Outputs basic information about a user-specified 3D raster map layer."
-msgstr "Vypí¹e základní informace o u¾ivatelem vybrané 3D rastrové mapì."
+#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:4
+msgid "LANDSAT green channel"
+msgstr "zelený kanál LANDSAT"
-#: ../raster3d/base/r3.info.main.c:88
-msgid "Name of input 3D raster map"
-msgstr "Název vstupní 3D rastrové mapy"
+#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:5
+msgid "LANDSAT blue channel"
+msgstr "modrý kanál LANDSAT"
-#: ../raster3d/base/r3.info.main.c:92 ../raster/r.info/main.c:76
-msgid "Print range only"
-msgstr "Vytiskni pouze rozsah"
+#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:6
+msgid "Cropping intensity (upper brightness level)"
+msgstr "Oøezávám intenzitu (horní hodnoty svìtlosti)"
-#: ../raster3d/base/r3.info.main.c:97
-msgid "Print 3D raster map resolution (NS-res, EW-res, TB-res) only"
-msgstr "Vytiskni pouze rozli¹ení 3D rastru (NS-roz, EW-roz, TB-roz)"
+#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:7
+msgid "Extend colors to full range of data on each channel"
+msgstr "Na ka¾dém kanálu roztáhne barvy po celé ¹kále "
-#: ../raster3d/base/r3.info.main.c:101
-msgid "Print 3D raster map type (float/double) only"
-msgstr "Vytiskne pouze typ 3D rastrové mapy (float/double)"
+#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:8
+msgid "Preserve relative colors, adjust brightness only"
+msgstr "Zachovej relativní barvy, hýbej pouze se svìtlostí"
-#: ../raster3d/base/r3.info.main.c:105
-msgid "Print 3D raster map region only"
-msgstr "Vytiskni pouze region rastrové 3D rastrové mapy"
+#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:9
+msgid "Reset to standard color range"
+msgstr "Nastav zpìt na standardní barevný rozsah"
-#: ../raster3d/base/r3.info.main.c:109
-msgid "Print 3D raster history instead of info"
-msgstr "Vytiskne historii 3D rastru místo informací"
+#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:1
+msgid "Import of SPOT VGT NDVI file into a raster map"
+msgstr "Import SPOT VGT NDVI souboru jako rastrové mapy"
-#: ../raster3d/base/r3.info.main.c:115
-msgid "Print 3D raster map timestamp (day.month.year hour:minute:seconds) only"
+#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:3
+msgid "also import quality map (SM status map layer) and filter NDVI map"
msgstr ""
-"Vypsat pouze èasovou znaèku 3D rastrové mapy (den.mìsíc.rok hodiny:minuty:"
-"sekondy)"
+"importuj také mapu kvality (SM status map layer) a filtruj jím NDVI mapu"
-#: ../raster3d/base/r3.info.main.c:123 ../raster/r.resamp.stats/main.c:302
-#: ../raster/r.param.scale/interface.c:165 ../raster/r.surf.area/main.c:121
-#: ../raster/r.resamp.interp/main.c:102 ../raster/r.coin/cmd_parms.c:96
-#: ../raster/r.coin/cmd_parms.c:99 ../raster/r.distance/parse.c:78
-#: ../raster/r.distance/parse.c:85 ../raster/r.reclass/main.c:77
-#: ../raster/r.los/main.c:152 ../raster/r.los/main.c:158
-#: ../raster/r.drain/main.c:155 ../raster/r.out.ascii/main.c:145
-#: ../raster/r.carve/main.c:173 ../raster/r.profile/main.c:142
-#: ../raster/r.texture/main.c:224 ../raster/r.basins.fill/main.c:92
-#: ../raster/r.basins.fill/main.c:104 ../raster/r.sum/main.c:64
-#: ../raster/r.null/null.c:104 ../raster/r.average/main.c:71
-#: ../raster/r.average/main.c:74 ../raster/r.out.gridatb/check_ready.c:13
-#: ../raster/r.surf.idw2/read_cell.c:20 ../raster/r.transect/main.c:117
-#: ../raster/simwe/simlib/input.c:171 ../raster/simwe/simlib/input.c:176
-#: ../raster/simwe/simlib/input.c:181 ../raster/simwe/simlib/input.c:186
-#: ../raster/simwe/simlib/input.c:192 ../raster/simwe/simlib/input.c:198
-#: ../raster/simwe/simlib/input.c:205 ../raster/simwe/simlib/input.c:212
-#: ../raster/simwe/simlib/input.c:219 ../raster/simwe/simlib/input.c:226
-#: ../raster/simwe/simlib/input.c:233 ../raster/r.out.mat/main.c:94
-#: ../raster/r.to.rast3elev/main.c:114 ../raster/r.to.rast3elev/main.c:129
-#: ../raster/r.statistics/main.c:75 ../raster/r.statistics/main.c:81
-#: ../raster/r.info/main.c:116 ../raster/r.patch/main.c:115
-#: ../raster/r.grow2/main.c:185 ../raster/r.surf.idw/main.c:108
-#: ../raster/r.thin/io.c:97 ../raster/r.flow/io.c:65
-#: ../raster/r.topidx/check_ready.c:12 ../raster/r.out.pov/main.c:171
-#: ../raster/r.covar/main.c:96 ../raster/r.out.arc/main.c:110
-#: ../raster/r.report/parse.c:249 ../raster/r.random/main.c:106
-#: ../raster/r.random/main.c:111 ../raster/r.his/main.c:128
-#: ../raster/r.his/main.c:169 ../raster/r.his/main.c:197
-#: ../raster/r.bilinear/main.c:78 ../raster/r.kappa/stats.c:30
-#: ../raster/r.kappa/stats.c:35 ../raster/r.kappa/main.c:141
-#: ../raster/r.median/main.c:73 ../raster/r.resamp.rst/main.c:400
-#: ../raster/r.resamp.rst/main.c:426 ../raster/r.stats/main.c:263
-#: ../raster/r.slope.aspect/main.c:383 ../raster/r.colors/main.c:237
-#: ../raster/r.colors/main.c:323 ../raster/r.out.ppm/main.c:115
-#: ../raster/r.fill.dir/main.c:163 ../raster/r.mfilter.fp/main.c:124
-#: ../raster/r.cost/main.c:319 ../raster/r.out.vtk/main.c:47
-#: ../raster/r.out.vtk/main.c:60 ../raster/r.support/modcolr/modcolr.c:43
-#: ../raster/r.support/front/front.c:218 ../raster/r.out.bin/main.c:129
-#: ../raster/r.neighbors/main.c:180 ../raster/r.clump/main.c:88
-#: ../raster/r.to.vect/main.c:109 ../raster/r.region/main.c:161
-#: ../raster/r.region/main.c:218 ../raster/r.region/main.c:353
-#: ../raster/r.out.ppm3/main.c:117 ../raster/r.univar2/r.univar_main.c:93
-#: ../raster/r.watershed/ram/init_vars.c:341
-#: ../raster/r.watershed/seg/init_vars.c:371 ../raster/r.contour/main.c:156
-#: ../raster/r.cross/main.c:116 ../raster/r.cats/main.c:120
-#: ../raster/r.cats/main.c:140 ../raster/r.series/main.c:170
-#: ../raster/r.water.outlet/legal.c:23 ../raster/r.out.tiff/r.out.tiff.c:167
-#: ../raster/r.out.mpeg/main.c:222 ../raster/r.walk/main.c:523
-#: ../raster/r.walk/main.c:526 ../raster/r.mapcalc/map.c:380
-#: ../raster/r.recode/main.c:82 ../raster/r.mfilter/main.c:117
-#: ../raster/r.composite/main.c:162 ../raster/wildfire/r.ros/main.c:312
-#: ../raster/wildfire/r.ros/main.c:322 ../raster/wildfire/r.ros/main.c:326
-#: ../raster/wildfire/r.ros/main.c:330 ../raster/wildfire/r.ros/main.c:334
-#: ../raster/wildfire/r.ros/main.c:348 ../raster/wildfire/r.ros/main.c:352
-#: ../raster/wildfire/r.ros/main.c:367 ../raster/wildfire/r.ros/main.c:371
-#: ../raster/wildfire/r.ros/main.c:381 ../raster/wildfire/r.spread/main.c:344
-#: ../raster/wildfire/r.spread/main.c:350
-#: ../raster/wildfire/r.spread/main.c:356
-#: ../raster/wildfire/r.spread/main.c:363
-#: ../raster/wildfire/r.spread/main.c:368
-#: ../raster/wildfire/r.spread/main.c:373 ../raster/r.resample/main.c:96
-#: ../raster/r.buffer/main.c:115 ../raster/r.support.stats/main.c:47
-#: ../raster/r.bitpattern/main.c:101 ../vector/v.what.rast/main.c:132
-#: ../vector/v.extrude/main.c:178 ../vector/v.sample/main.c:157
-#: ../vector/v.vol.rst/main.c:577 ../vector/v.drape/main.c:120
-#: ../doc/raster/r.example/main.c:110 ../ps/ps.map/outl_io.c:72
-#: ../imagery/i.his.rgb/openfiles.c:32 ../imagery/i.his.rgb/openfiles.c:37
-#: ../imagery/i.his.rgb/openfiles.c:42 ../imagery/i.group/main.c:181
-#: ../imagery/i.group/main.c:218 ../imagery/i.rgb.his/openfiles.c:15
-#: ../imagery/i.rgb.his/openfiles.c:17 ../imagery/i.rgb.his/openfiles.c:19
-#: ../imagery/i.pca/main.c:122 ../imagery/i.class/main.c:108
-#: ../imagery/i.gensig/parse.c:48 ../imagery/i.zc/main.c:110
-#: ../imagery/i.fft/fftmain.c:120
-#: ../imagery/i.ortho.photo/photo.2target/main.c:202
-#: ../imagery/i.ortho.photo/photo.2target/main.c:236
-#: ../visualization/xganim/main.c:342 ../display/d.histogram/main.c:157
-#: ../display/d.profile/main.c:92 ../display/d.rast.num/number.c:150
-#: ../display/d.what.rast/main.c:150 ../display/d.title/main.c:105
-#: ../display/d.legend/main.c:252 ../display/d.rast.arrow/arrow.c:196
-#: ../display/d.rast.arrow/arrow.c:238 ../display/d.rast.arrow/arrow.c:374
-#: ../display/d.rast/main.c:111 ../display/d.rgb/main.c:100
-#: ../display/d.his/main.c:137 ../display/d.his/main.c:176
-#: ../display/d.his/main.c:204 ../display/d.zoom/main.c:218
-#: ../display/d.nviz/main.c:183 ../display/d.colortable/main.c:101
-#: ../display/d.extend/main.c:62
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:383
-#: ../general/g.region/cmd/main.c:449 ../general/g.region/cmd/main.c:813
-#: ../general/g.region/cmd/main.c:822
-#, c-format
-msgid "Raster map <%s> not found"
-msgstr "Rastrová mapa <%s> nenalezena"
+#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:4
+msgid "existing SPOT VGT NDVI HDF file (0001_NDV.HDF)"
+msgstr "existující souboru SPOT VGT NDVI HDF (0001_NDV.HDF)"
-#: ../raster3d/base/r3.info.main.c:160 ../raster3d/base/r3.info.main.c:168
-#: ../raster3d/base/r3.info.main.c:174 ../raster3d/base/r3.info.main.c:179
-#: ../raster3d/base/r3.info.main.c:186 ../raster3d/base/r3.info.main.c:197
-#: ../raster3d/base/r3.info.main.c:203 ../raster3d/base/r3.info.main.c:219
-#: ../raster3d/base/r3.info.main.c:226 ../raster3d/base/r3.info.main.c:233
-#: ../raster3d/base/r3.info.main.c:238 ../raster3d/base/r3.info.main.c:243
-#: ../raster3d/base/r3.info.main.c:250 ../raster3d/base/r3.info.main.c:257
-#: ../raster3d/base/r3.info.main.c:267 ../raster3d/base/r3.info.main.c:277
-#: ../raster3d/base/r3.info.main.c:287 ../raster3d/base/r3.info.main.c:300
-#: ../raster3d/base/r3.info.main.c:310 ../raster3d/base/r3.info.main.c:315
-#: ../raster3d/base/r3.info.main.c:323 ../raster3d/base/r3.info.main.c:336
-#: ../raster/r.info/main.c:299 ../raster/r.info/main.c:419
-msgid "Cannot allocate memory for string"
-msgstr "Nelze alokovat pro øetìzec pamì»"
-#: ../raster3d/base/r3.info.main.c:401
-msgid "Error while reading history file"
-msgstr "Chyba pøi ètení souboru s historií"
-#: ../raster3d/base/r3.mask.main.c:44
-msgid "3d raster map with reference values"
-msgstr "mapa 3dcell s referenèními hodnotami"
-#: ../raster3d/base/r3.mask.main.c:52
-msgid "List of cell values to be masked out"
-msgstr "Seznam hodnot bunìk pro maskování"
-#: ../raster3d/base/r3.mask.main.c:84
-msgid "makeMask: error opening map."
-msgstr "makeMask: chyba pøi otevírání mapy."
-#: ../raster3d/base/r3.mask.main.c:95
-msgid "makeMask: error opening g3d mask file"
-msgstr "makeMask: chyba pøi otevírání souboru s maskou g3d"
-#: ../raster3d/base/r3.mask.main.c:124
-msgid "makeMask: error flushing tiles in cube"
-msgstr "makeMask: chyba pøi zarovnávání dla¾dic do kostky"
-#: ../raster3d/base/r3.mask.main.c:129
-msgid "makeMask: error flushing all tiles"
-msgstr "makeMask: chyba pøi zarovnávání v¹ech dla¾dic"
-#: ../raster3d/base/r3.mask.main.c:137
-msgid "makeMask: error closing g3d mask file"
-msgstr "makeMask: chyba pøi uzavírání souboru g3d mask"
-#: ../raster3d/base/r3.mask.main.c:139
-msgid "makeMask: error closing map"
-msgstr "makeMask: chyba pøi uzavírání mapy"
-#: ../raster3d/base/r3.mask.main.c:154
-msgid "Establishes the current working 3D raster mask."
-msgstr "Vytvoøí aktuální pracovní 3D rastrovou masku."
-#: ../raster3d/base/r3.mask.main.c:159
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:1
msgid ""
-"Cannot create mask file: G3D_MASK already exists!\n"
-" Use 'g.remove rast3d=G3D_MASK' to remove the existing mask."
+"Creates and adds a new attribute table to a given layer of an existing "
+"vector map."
msgstr ""
-"Nelze vytvoøit soubor s maskou: G3D_MASK ji¾ existuje!\n"
-" Pro odstranìní existující masky pou¾ijte 'g.remove rast3d=G3D_MASK'."
+"Vytvoøí a pøidá novou atributovou tabulku k zadané vrstvì existující "
+"vektorové mapy."
-#: ../raster3d/base/mask_functions.c:82
-#, c-format
-msgid "Adding rule: %lf - %lf"
-msgstr "Pøidávám pravidlo: %lf - %lf"
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:3
+msgid "Vector map for which to add new attribute table"
+msgstr "Vektorová mapa pro kterou bude pøidána nová atributová tabulka"
-#: ../raster3d/base/mask_functions.c:100
-#, c-format
-msgid "%s: illegal value spec"
-msgstr "%s: neplatná hodnota pro spec"
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:4
+msgid "Name of new attribute table (default: vector map name)"
+msgstr "Jméno nové atributové tabulky (výchozí: jméno mapy)"
-#: ../raster3d/base/r3.timestamp.main.c:43
-msgid "Print/add/remove a timestamp for a 3D raster map"
-msgstr "Vytiskni/pøidej/sma¾ èasovou znaèku pro 3D rastrovou mapu"
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:5
+msgid "Layer where to add new attribute table"
+msgstr "Vrstva, kam bude pøidána nová atributová tabulka"
-#: ../raster3d/base/r3.timestamp.main.c:50
-msgid "Input grid3 filename"
-msgstr "Vstupní soubor grid3"
+#: ../locale/scriptstrings/v.db.join_to_translate.c:1
+msgid "Allows to join a table to a vector map table."
+msgstr "Umo¾ní spojení tabulky s tabulkou pøipojenou k vektorové mapì."
-#: ../raster3d/base/r3.timestamp.main.c:57 ../raster/r.timestamp/main.c:45
-msgid "Datetime, datetime1/datetime2, or none"
-msgstr "Datetime, datetime1/datetime2, nebo ¾ádný"
+#: ../locale/scriptstrings/v.db.join_to_translate.c:3
+msgid "Vector map to which to join other table"
+msgstr "Vektorová mapa, k její¾ tabulce bude pøipojena tabulka nová"
-#: ../raster3d/base/r3.timestamp.main.c:72
-#, c-format
-msgid "Grid3 <%s> not found %s"
-msgstr "Grid3 <%s> nebyl nalezen %s"
+#: ../locale/scriptstrings/v.db.join_to_translate.c:4
+msgid "Layer where to join"
+msgstr "Vrstva, na které dojde ke spojení"
-#: ../raster3d/r3.out.vtk/errorHandling.c:52
-msgid "unable to close input raster map"
-msgstr "Nelze zavøít vstupní rastrovou mapu"
+#: ../locale/scriptstrings/v.db.join_to_translate.c:5
+msgid "Join column in map table"
+msgstr "Sloupec atributové tabulky mapy, pøes který do jde ke spojení"
-#: ../raster3d/r3.out.vtk/errorHandling.c:67
-msgid "unable to close input 3d raster map"
-msgstr "Nelze zavøít vstupní 3D rastr"
+#: ../locale/scriptstrings/v.db.join_to_translate.c:6
+msgid "Other table name"
+msgstr "Jméno pøipojované tabulky"
-#: ../raster3d/r3.out.vtk/parameters.c:30
-msgid "G3D map(s) to be converted to VTK-ASCII data format"
-msgstr "G3D mapa(y) pro konverzi do datového formátu VTK-ASCII"
+#: ../locale/scriptstrings/v.db.join_to_translate.c:7
+msgid "Join column in other table"
+msgstr "Sloupec pøipojované tabulky"
-#: ../raster3d/r3.out.vtk/parameters.c:34 ../raster/r.out.vtk/parameters.c:38
-msgid "Name for VTK-ASCII output file"
-msgstr "Název výstupního souboru VTK-ASCII"
+#: ../locale/scriptstrings/d.resize_to_translate.c:1
+msgid "Resizes active display monitor"
+msgstr "Mìní velikost aktivního monitoru"
-#: ../raster3d/r3.out.vtk/parameters.c:41
-msgid "Float value to represent no data cell/points"
-msgstr ""
-"Hodnota s plovoucí desetinnou èárkou reprezentující hodnotu \"¾ádná data\""
+#: ../locale/scriptstrings/d.resize_to_translate.c:2
+#: ../locale/scriptstrings/d.split_to_translate.c:2
+#: ../locale/scriptstrings/d.mvmon_to_translate.c:2
+#: ../locale/scriptstrings/d.monsize_to_translate.c:2
+#: ../display/d.colortable/main.c:65 ../display/d.extend/main.c:32
+msgid "display, setup"
+msgstr "zobrazení, nastavení"
-#: ../raster3d/r3.out.vtk/parameters.c:47
-msgid "Create VTK pointdata instead of VTK celldata (celldata is default)"
-msgstr ""
-"Vytvoøí bodová data VTK z rastrových dat VTK (rastrová data jsou výchozí)"
+#: ../locale/scriptstrings/d.resize_to_translate.c:3
+msgid "New width for window"
+msgstr "Nová ¹íøka okna"
-#: ../raster3d/r3.out.vtk/parameters.c:56
-msgid "top surface 2D raster map"
-msgstr "2D mapa svrchního povrchu"
+#: ../locale/scriptstrings/d.resize_to_translate.c:4
+msgid "New height for window"
+msgstr "Nová vý¹ka okna"
-#: ../raster3d/r3.out.vtk/parameters.c:65
-msgid "bottom surface 2D raster map"
-msgstr "2D mapa spodního povrchu"
+#: ../locale/scriptstrings/d.slide.show_to_translate.c:1
+msgid "Slide show of GRASS raster/vector maps."
+msgstr "Slide show rastrù/vektorù."
-#: ../raster3d/r3.out.vtk/parameters.c:72
-msgid ""
-"Create 3d elevation output with a top and a bottom surface, both raster maps "
-"are required."
-msgstr ""
-"Vytvoøí 3D elevaci se svrchním a spodním povrchem. Obì rastrové mapy jsou "
-"po¾adovány."
+#: ../locale/scriptstrings/d.slide.show_to_translate.c:2
+msgid "display, slideshow"
+msgstr "zobrazení, prezentace"
-#: ../raster3d/r3.out.vtk/parameters.c:84
-msgid ""
-"Three (r,g,b) 3d raster maps to create rgb values [redmap,greenmap,bluemap]"
-msgstr ""
-"3 rastrové mapy (r,g,b) g3d, které jsou pou¾ity pro vytvoøení hodnot RGB "
-"[redmap,greenmap,bluemap]"
+#: ../locale/scriptstrings/d.slide.show_to_translate.c:3
+msgid "Show vector maps rather than raster maps"
+msgstr "Zobrazit vektory, místo rastrù"
-#: ../raster3d/r3.out.vtk/parameters.c:95
-msgid "Three (x,y,z) 3d raster maps to create vector values [xmap,ymap,zmap]"
-msgstr ""
-"3 rastrové mapy (r,g,b) g3d, které jsou pou¾ity pro vytvoøení hodnot vektorù "
-"[xmap,ymap,zmap]"
+#: ../locale/scriptstrings/d.slide.show_to_translate.c:4
+msgid "Map prefix. Specify character(s) to view selected maps only"
+msgstr "Pøedpona mapy. Zadejte písmeno(na) pro zobrazení pouze vybraných map"
-#: ../raster3d/r3.out.vtk/parameters.c:102 ../raster/r.out.vtk/parameters.c:97
-#: ../vector/v.out.vtk/main.c:74
-msgid "Scale factor for elevation"
-msgstr "Mìøítkový faktor pro vý¹kový model"
+#: ../locale/scriptstrings/d.slide.show_to_translate.c:5
+msgid "Map number show across the monitor"
+msgstr "Poèet map zobrazených na monitoru"
-#: ../raster3d/r3.out.vtk/parameters.c:115 ../raster/r.out.ascii/main.c:84
-#: ../raster/r.out.vtk/parameters.c:109 ../vector/v.out.ascii/out.c:81
-#: ../vector/v.out.vtk/main.c:68 ../display/d.rast.num/number.c:118
-msgid "Number of significant digits (floating point only)"
-msgstr ""
-"Poèet míst za desetinnou èárkou (pouze pro mapy s plovoucí desetinnou èárkou)"
+#: ../locale/scriptstrings/d.slide.show_to_translate.c:6
+msgid "Map number show down the monitor"
+msgstr "Poèet map zobrazených pod monitorem"
-#: ../raster3d/r3.out.vtk/parameters.c:120
-msgid "Use g3d mask (if exists) with input maps"
-msgstr "Pou¾ít masku G3D (pokud existuje) se vstupními mapami"
+#: ../locale/scriptstrings/d.slide.show_to_translate.c:7
+msgid "Mapsets to use. Specify multiple mapsets comma separated"
+msgstr "Mapset který bude pou¾it. Více mapsetù lze oddìlit èárkou"
-#: ../raster3d/r3.out.vtk/parameters.c:125
-msgid "Scale factor effects the origin"
-msgstr "Mìøítkový faktor ovlivní zdroj"
+#: ../locale/scriptstrings/d.slide.show_to_translate.c:8
+msgid "Number of seconds to pause between slides"
+msgstr "Poèet vteøin pro pøestávku mezi slidy."
-#: ../raster3d/r3.out.vtk/parameters.c:130
-#: ../raster/r.out.vtk/parameters.c:139 ../vector/v.out.vtk/main.c:86
-msgid "Correct the coordinates to fit the VTK-OpenGL precision"
-msgstr "Opravte souøadnice tak, aby odpovídaly VTK-OpenGL pøesnosti"
+#: ../locale/scriptstrings/m.proj_to_translate.c:1
+msgid "Convert coordinates from one projection to another (cs2cs frontend)."
+msgstr "Pøevede souøadnice z jedné projekce do druhé (rozhraní k cs2cs)"
-#: ../raster3d/r3.out.vtk/main.c:97
-#, c-format
-msgid "Could not open map %s"
-msgstr "Nelze otevøít mapu %s"
+#: ../locale/scriptstrings/m.proj_to_translate.c:2
+msgid "miscellaneous, projection"
+msgstr "rùzné, projekce"
-#: ../raster3d/r3.out.vtk/main.c:116
-msgid "You have to specify top and bottom map"
-msgstr "Musíte zadat spodní a svrchní mapu"
-#: ../raster3d/r3.out.vtk/main.c:123
-#, c-format
-msgid "Top cell map <%s> not found"
-msgstr "Svrchní rastr <%s> nenalezen"
-#: ../raster3d/r3.out.vtk/main.c:132
-#, c-format
-msgid "Bottom cell map <%s> not found"
-msgstr "Spodní rastr <%s> nenalezen"
-#: ../raster3d/r3.out.vtk/main.c:141
-#, c-format
-msgid "Requested 3d raster map <%s> not found"
-msgstr "Po¾adovaný soubor g3d <%s> nebyl nalezen"
-#: ../raster3d/r3.out.vtk/main.c:151
-#, c-format
-msgid "Requested g3d RGB map <%s> not found"
-msgstr "Po¾adovaná mapa g3d RGB <%s> nebyla nalezena"
-#: ../raster3d/r3.out.vtk/main.c:155
-msgid "Please provide three g3d RGB maps"
-msgstr "Prosím zadejte tøi g3d RGB mapy"
-#: ../raster3d/r3.out.vtk/main.c:165
-#, c-format
-msgid "Requested g3d vector map <%s> not found"
-msgstr "Po¾adovaná mapa g3d vektor <%s> nebyla nalezena"
-#: ../raster3d/r3.out.vtk/main.c:170
-msgid "Please provide three g3d vector maps [x,y,z]"
-msgstr "Prosím zadejte tøi g3d vektory [x,y,z]"
-#: ../raster3d/r3.out.vtk/main.c:178
-msgid ""
-"No g3d data, RGB or xyz-vector maps are provided! Will only write the "
-"geometry."
+#: ../locale/scriptstrings/m.proj_to_translate.c:3
+msgid "Input coordinate file (omit to read from stdin)"
msgstr ""
-"®ádná g3d data, RGB nebo xyz-vektorová mapa jsou po¾adována! Zapí¹i pouze "
-"geometrii."
+"Vstupní soubor se souøadnicemi (vynechává se pøi ètení ze standardního "
+"vstupu)"
-#: ../raster3d/r3.out.vtk/main.c:197
-#, c-format
-msgid "Open rgb 3d raster map %s"
-msgstr "Otevøít rgb g3d rastrový soubor %s"
-#: ../raster3d/r3.out.vtk/main.c:210
-msgid "No RGB Data will be created."
-msgstr "Nebudou vytvoøena ¾ádná RGB data"
-#: ../raster3d/r3.out.vtk/main.c:253
-msgid "Error closing g3d rgb map."
-msgstr "Chyba pøi zavírání g3d rgb souboru"
-#: ../raster3d/r3.out.vtk/main.c:293
-msgid "No vector data will be created."
-msgstr "®ádná vektorová data nebudou vytvoøena."
-#: ../raster3d/r3.out.vtk/main.c:337
-msgid "Error closing g3d vector map."
-msgstr "Chyba pøi zavírání g3d vektorového souboru"
-#: ../raster3d/r3.out.vtk/main.c:376
-msgid "Converts 3D raster maps (G3D) into the VTK-Ascii format"
-msgstr "Pøevede 3D rastrové mapy (G3D) do formátu VTK-Ascii"
-#: ../raster3d/r3.out.vtk/main.c:387
-msgid "failed to interpret dp as an integer"
-msgstr "selhal pøevod dp na celé èíslo"
-#: ../raster3d/r3.out.vtk/main.c:389 ../raster/r.out.ascii/main.c:123
-msgid "dp has to be from 0 to 20"
-msgstr "dp musí být od 0 do 20"
-#: ../raster3d/r3.out.vtk/main.c:450
-msgid ""
-"The 2d and 3d region settings are different. The g3d settings are used to "
+#: ../locale/scriptstrings/m.proj_to_translate.c:4
+msgid "Output coordinate file (omit to send to stdout)"
msgstr ""
-"2d a 3d nastavení regionu jsou rùzná. Pou¾iji hodnoty z nastavení g3d pro "
-"zmìnu 2d regionu."
+"Výstup souøadnicového souboru (vynechává se pøi výpisu na standardní výstup)"
-#: ../raster3d/r3.out.vtk/main.c:487
-msgid "unable to close top raster map"
-msgstr "nelze zavøít svrchní rastrovou mapu"
+#: ../locale/scriptstrings/m.proj_to_translate.c:5
+#: ../locale/scriptstrings/r.out.xyz_to_translate.c:5
+msgid "Field separator"
+msgstr "Oddìlovaè sloupcù"
-#: ../raster3d/r3.out.vtk/main.c:492
-msgid "unable to close bottom raster map"
-msgstr "nelze zavøít spodní rastrovou mapu"
+#: ../locale/scriptstrings/m.proj_to_translate.c:6
+msgid "Input projection parameters (PROJ.4 style)"
+msgstr "Parametry vstupní projekce (ve stylu PROJ.4)"
-#: ../raster3d/r3.out.vtk/main.c:545
-msgid "Error closing 3d raster map, the VTK file may be incomplete."
-msgstr "Chyba pøi zavírání mapy g3d, soubor VTK je asi nekompletní."
+#: ../locale/scriptstrings/m.proj_to_translate.c:7
+msgid "Output projection parameters (PROJ.4 style)"
+msgstr "Parametry výstupní projekce (ve stylu PROJ.4)"
-#: ../raster3d/r3.out.vtk/main.c:560 ../raster/r.out.vtk/main.c:390
-msgid "Error closing VTK-ASCII file"
-msgstr "Chyba pøi uzavøení souboru VTK-ASCII"
+#: ../locale/scriptstrings/m.proj_to_translate.c:8
+msgid "Use LL WGS84 as input and current location as output projection"
+msgstr "Jako vstup pou¾ij LL WGS84 a aktuální location jako výstupní projekci"
-#: ../raster3d/r3.out.vtk/writeVTKData.c:121
-msgid "write_vtk_points: Writing point coordinates"
-msgstr "write_vtk_points: Zapisuji souøadnice bodù"
+#: ../locale/scriptstrings/m.proj_to_translate.c:9
+msgid "Use current location as input and LL WGS84 as output projection"
+msgstr "Pou¾ij aktuální location jako vstup a LL WGS84 jako výstupní projekci"
-#: ../raster3d/r3.out.vtk/writeVTKData.c:130
-msgid "Could not get top raster row \n"
-msgstr "Nelze naèíst øádek svrchního rastru\n"
-#: ../raster3d/r3.out.vtk/writeVTKData.c:134
-msgid "Could not get bottom raster row \n"
-msgstr "Nelze naèít øádek spodního rastru\n"
-#: ../raster3d/r3.out.vtk/writeVTKData.c:251
-msgid "write_vtk_unstructured_grid_cells: Writing the cells"
-msgstr "write_vtk_unstructured_grid_cells: Zapisuji buòky"
-#: ../raster3d/r3.out.vtk/writeVTKData.c:330
-#, c-format
+#: ../locale/scriptstrings/m.proj_to_translate.c:10
msgid ""
-"write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-"
-"ascii file"
+"Output long/lat in decimal degrees or other projections with many decimal "
+"places"
msgstr ""
-"write_vtk_data: Zapisuji Celldata %s o %i øádkù %i sloupcù %i hloubky do "
-"souboru vtk-ascii."
+"Výstup lat/long v decimálních stupních nebo jiné projekce s mnoha "
+"desetinnými místy"
-#: ../raster3d/r3.out.vtk/writeVTKData.c:388
-msgid "write_vtk_rgb_data: writing rgb data"
-msgstr "write_vtk_data: Zapisuji data RGB"
-#: ../raster3d/r3.out.vtk/writeVTKData.c:425
-#: ../raster3d/r3.out.vtk/writeVTKData.c:458
-msgid "Wrong 3d raster map values! Values should in between 0 and 255!\n"
+#: ../locale/scriptstrings/m.proj_to_translate.c:11
+msgid "Verbose mode (print projection parameters and filenames to stderr)"
msgstr ""
-"Chybné hodnoty 3d raster mapy! Hodnoty by mìly být v rozmezí 0 a 255!\n"
+"Vypovídej se, chlapèe (vytiskni parametry projekce a jména souborù na "
+"standardní chybu)"
-#: ../raster3d/r3.out.vtk/writeVTKData.c:488
-msgid "write_vtk_vector_data: writing vector data"
-msgstr "write_vtk_vector_data: Zapisuji data vektorová data"
-#: ../raster3d/r3.to.rast/main.c:55
-msgid "Unable to close the 3d raster map"
-#: ../raster3d/r3.to.rast/main.c:79
-msgid "3d raster map(s) to be converted to 2D raster slices"
-msgstr "Pøevod rastrové 3d mapy na rastrovou 2D mapu"
-#: ../raster3d/r3.to.rast/main.c:85
-msgid "Basename for resultant raster slice maps"
-msgstr "Základ názvu výsledného výøezu rastrové mapy"
-#: ../raster3d/r3.to.rast/main.c:95
+#: ../locale/scriptstrings/r.tileset_to_translate.c:1
msgid ""
-"Use the same resolution as the input G3D map for the 2d output maps, "
-"independent of the current region settings"
+"Produces tilings of the source projection for use in the destination region "
+"and projection."
msgstr ""
-"Pou¾ij stejné rozli¹ení jako je vstupní G3D mapa pro 2d výstupní mapu, "
-"nezávisle na aktuálním rozli¹ení"
+"Vytvoøí dla¾dice zdrojové projekce pro pou¾ití v cílovém regionu a projekci."
-#: ../raster3d/r3.to.rast/main.c:152 ../raster3d/r3.to.rast/main.c:159
-msgid "Unable to write raster row"
-msgstr "Nelze ènyní zapsat rastrovou mapu."
+#: ../locale/scriptstrings/r.tileset_to_translate.c:2
+msgid "raster, tiling"
+msgstr "rastr, dla¾dice"
-#: ../raster3d/r3.to.rast/main.c:183 ../raster/r.resamp.stats/main.c:346
-#: ../raster/r.resamp.interp/main.c:147 ../raster/r.los/main.c:193
-#: ../raster/r.in.ascii/main.c:210 ../raster/r.carve/main.c:182
-#: ../raster/r.texture/main.c:303 ../raster/r.basins.fill/main.c:116
-#: ../raster/r.null/null.c:312 ../raster/r.surf.idw2/main.c:111
-#: ../raster/r.patch/main.c:147 ../raster/r.grow2/main.c:207
-#: ../raster/r.circle/dist.c:127 ../raster/r.surf.idw/main.c:147
-#: ../raster/r.thin/io.c:176 ../raster/r.li/r.li.daemon/daemon.c:113
-#: ../raster/r.flow/io.c:179 ../raster/r.flow/io.c:217
-#: ../raster/r.in.gdal/main.c:722 ../raster/r.in.gdal/main.c:727
-#: ../raster/r.in.gdal/main.c:743 ../raster/r.sunmask/main.c:437
-#: ../raster/r.bilinear/main.c:103 ../raster/r.surf.random/randsurf.c:29
-#: ../raster/r.surf.random/randsurf.c:33 ../raster/r.in.xyz/main.c:465
-#: ../raster/r.clump/main.c:99 ../raster/r.in.mat/main.c:386
-#: ../raster/r.cross/main.c:137 ../raster/r.series/main.c:185
-#: ../raster/r.mapcalc/map3.c:598 ../raster/r.mapcalc/map.c:513
-#: ../raster/r.composite/main.c:200 ../raster/r.buffer/write_map.c:39
-#: ../raster/r.in.arc/main.c:151 ../raster/r.bitpattern/main.c:125
-#: ../vector/lidar/v.surf.bspline/main.c:284 ../vector/v.kernel/main.c:236
-#: ../vector/v.surf.idw/main.c:234 ../vector/v.neighbors/main.c:94
-#: ../vector/v.to.rast/vect2rast.c:120 ../vector/v.to.rast/vect2rast.c:124
-#: ../doc/raster/r.example/main.c:140 ../imagery/i.his.rgb/openfiles.c:16
-#: ../imagery/i.his.rgb/openfiles.c:18 ../imagery/i.his.rgb/openfiles.c:20
-#: ../imagery/i.smap/shapiro/opencell.c:31 ../imagery/i.pca/main.c:395
-#, c-format
-msgid "Unable to create raster map <%s>"
-msgstr "Nejsem schopen vytvoøit rastrovou mapu <%s>"
+#: ../locale/scriptstrings/r.tileset_to_translate.c:3
+msgid "Produces shell script output"
+msgstr "Výstup ve formátu pro shell skript"
-#: ../raster3d/r3.to.rast/main.c:216
-msgid "Converts 3D raster maps to 2D raster maps"
-msgstr "Pøevede 3D rastrové mapy na 2D rastrové mapy"
+#: ../locale/scriptstrings/r.tileset_to_translate.c:4
+msgid "Produces web map server query string output"
+msgstr "Vytvoøí øetìzec urèený pro mapový server"
-#: ../raster3d/r3.to.rast/main.c:225
-#, c-format
-msgid "Open 3d raster map <%s>"
-msgstr "Otevøi mapu g3d <%s>"
-#: ../raster3d/r3.to.rast/main.c:267
+#: ../locale/scriptstrings/r.tileset_to_translate.c:5
msgid ""
-"The 2d and 3d region settings are different. Using the 2D window settings to "
-"adjust the 2D part of the 3D region."
+"Name of region to use instead of current region for bounds and resolution"
msgstr ""
-"2d a 3d rozli¹ení jsou rùzná. Pou¾iji nastavení 2d regionu pro nastavení 2d "
-"èásti 3d regionu."
+"Jméno regionu pou¾itého místo aktuálního regionu pro okraje a rozli¹ení"
-#: ../raster3d/r3.to.rast/main.c:304
-#, c-format
-msgid "Creating %i raster maps"
-msgstr "Vytváøím %i rastrové mapy"
+#: ../locale/scriptstrings/r.tileset_to_translate.c:6
+msgid "Source projection"
+msgstr "Zdrojová projekce"
-#: ../raster3d/r3.to.rast/main.c:310
-#, c-format
-msgid "Raster map %i Filename: %s"
-msgstr "Rastrová mapa %i Název souboru: %s"
+#: ../locale/scriptstrings/r.tileset_to_translate.c:7
+#: ../locale/scriptstrings/r.tileset_to_translate.c:9
+msgid "Conversion factor from units to meters in source projection"
+msgstr "Pøevodní faktor z jednotek na metry ve zdrojové projekci"
-#: ../raster3d/r3.to.rast/main.c:314
-#, c-format
-msgid "Raster map %d Filename: %s already exists. Will be overwritten!"
-msgstr "Rastrová mapa %d Jméno souboru: %s ji¾ existuje. Mapa bude pøepsána!"
+#: ../locale/scriptstrings/r.tileset_to_translate.c:8
+msgid "Destination projection, defaults to this location's projection"
+msgstr "Cílová projekce, výchozí je projekce aktuální location"
-#: ../locale/scriptstrings/d.m_to_translate.c:1
-msgid "Display manager for GRASS"
-msgstr "GIS manager pro GRASS"
+#: ../locale/scriptstrings/r.tileset_to_translate.c:10
+msgid "Maximum number of columns for a tile in the source projection"
+msgstr "Maximální poèet sloupcù dla¾dic ve vstupní projekci"
-#: ../locale/scriptstrings/d.m_to_translate.c:2
-msgid "Name of .dmrc settings file"
-msgstr "Jméno souboru s nastavením .dmrc"
+#: ../locale/scriptstrings/r.tileset_to_translate.c:11
+msgid "Maximum number of rows for a tile in the source projection"
+msgstr "Maximální poèet øádkù pro dla¾dice ve zdrojové projekci"
-#: ../locale/scriptstrings/gis.m_to_translate.c:1
-msgid "GIS manager for GRASS"
+#: ../locale/scriptstrings/r.tileset_to_translate.c:12
+msgid "Number of cells tiles should overlap in each direction"
+msgstr "Poèet dla¾dic by mìl být stejný v obou smìrech"
-#: ../locale/scriptstrings/gis.m_to_translate.c:2
-msgid "Name of GIS manager settings file (.grc)"
-msgstr "Jméno souboru s nastavením pro GIS manager (.grc)"
+#: ../locale/scriptstrings/r.tileset_to_translate.c:13
+msgid "Output field seperator"
+msgstr "Výstupní oddìlovaè"
-#: ../locale/scriptstrings/r.li.setup_to_translate.c:1
-msgid "Configuration editor for r.li.'index'"
-msgstr "Konfiguraèní editor pro r.li.'index'"
+#: ../locale/scriptstrings/r.tileset_to_translate.c:14
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:44
+msgid "Verbosity level"
+msgstr "Úroveò upovídanosti"
-#: ../locale/scriptstrings/r.li.setup_to_translate.c:2
-msgid "raster, landscape structure analysis"
-msgstr "rastr, anylýza krajiny"
+#: ../locale/scriptstrings/v.build.all_to_translate.c:1
+msgid "Rebuilds topology on all vector maps in the current mapset."
+msgstr "Pøebuduje topologii v¹ech vektorových map v aktuálním mapsetu."
-#: ../locale/scriptstrings/d.correlate_to_translate.c:1
-msgid "prints a graph of the correlation between data layers (in pairs)"
-msgstr "vytiskne graf korelace mezi datovými vrstvami (v párech)"
+#: ../locale/scriptstrings/v.build.all_to_translate.c:2
+#: ../vector/v.mkgrid/main.c:62 ../vector/v.in.region/main.c:38
+#: ../vector/v.sample/main.c:86 ../vector/v.patch-tab/main.c:58
+#: ../vector/v.surf.rst/main.c:159 ../vector/v.perturb/main.c:73
+#: ../vector/v.out.vtk/main.c:45 ../vector/v.buffer/main.c:245
+#: ../vector/v.vol.rst/main.c:201 ../vector/v.clean/test/topocheck.c:40
+#: ../vector/v.external/main.c:58 ../vector/v.voronoi/dt_main.c:44
+#: ../vector/v.voronoi/vo_main.c:107 ../vector/v.select/main.c:129
+#: ../vector/v.patch/main.c:68 ../vector/v.out.ascii/out.c:43
+#: ../vector/v.info/main.c:63 ../vector/v.info/main.c:227
+#: ../vector/v.extract/main.c:73
+msgid "vector"
+msgstr "vektor"
-#: ../locale/scriptstrings/d.correlate_to_translate.c:2
-#: ../locale/scriptstrings/d.polar_to_translate.c:2
-msgid "display, diagram"
-msgstr "zobrazení, diagram"
+#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:1
+msgid "Creates shaded relief map from an elevation map (DEM)."
+msgstr "Vytvoøí mapu stínovaného reliéfu ze vstupní mapy elevace (DMT)."
-#: ../locale/scriptstrings/d.correlate_to_translate.c:3
-#: ../locale/scriptstrings/d.correlate_to_translate.c:4
-#: ../locale/scriptstrings/d.correlate_to_translate.c:5
-#: ../locale/scriptstrings/d.correlate_to_translate.c:6
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:4
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:3
-msgid "raster input map"
-msgstr "vstupní rastrová mapa"
+#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:3
+#: ../raster/r.topidx/main.c:42
+msgid "Input elevation map"
+msgstr "Vstupní mapa elevace."
-#: ../locale/scriptstrings/d.monsize_to_translate.c:1
-msgid "Selects/starts specified monitor at specified size"
-msgstr "Vybere/nastartuje zadaný monitor o zadané velikosti"
+#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:4
+msgid "Output shaded relief map name"
+msgstr "Výstupní mapa stínovaného reliéfu"
-#: ../locale/scriptstrings/d.monsize_to_translate.c:2
-#: ../locale/scriptstrings/d.mvmon_to_translate.c:2
-#: ../locale/scriptstrings/d.resize_to_translate.c:2
-#: ../locale/scriptstrings/d.split_to_translate.c:2
-#: ../display/d.colortable/main.c:65 ../display/d.extend/main.c:32
-msgid "display, setup"
-msgstr "zobrazení, nastavení"
+#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:5
+msgid "Altitude of the sun in degrees above the horizon"
+msgstr "Vý¹ka slunce ve stupních nad horizontem"
-#: ../locale/scriptstrings/d.monsize_to_translate.c:3
-msgid "Display monitor to start"
-msgstr "Monitor, která má být spu¹tìn"
+#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:6
+msgid "Azimuth of the sun in degrees to the east of north"
+msgstr "Azimut slunce ve stupních od serveru (k východu)"
-#: ../locale/scriptstrings/d.monsize_to_translate.c:4
-msgid "Width in pixels of new display monitor"
-msgstr "©íøka nového monitoru v pixelech "
+#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:7
+msgid "Factor for exaggerating relief"
+msgstr "Faktor zvýraznìní reliéfu"
-#: ../locale/scriptstrings/d.monsize_to_translate.c:5
-msgid "Height in pixels of new display monitor"
-msgstr "Vý¹ka nového monitoru v pixelech"
-#: ../locale/scriptstrings/d.mvmon_to_translate.c:1
-msgid "Moves displayed maps to another monitor"
-msgstr "Pøesune aktuálnì zobrazené mapy do jiného monitoru"
-#: ../locale/scriptstrings/d.mvmon_to_translate.c:3
-msgid "clear target monitor before moving"
-msgstr "Vyèisti cílový monitor pøed pøesunem"
-#: ../locale/scriptstrings/d.mvmon_to_translate.c:4
-msgid "stay with source monitor"
-msgstr "zùstaò ve zdrojovém monitoru"
-#: ../locale/scriptstrings/d.mvmon_to_translate.c:5
-msgid "kill source monitor after moving"
-msgstr "zab zdrojový monitor po pøesunu"
-#: ../locale/scriptstrings/d.mvmon_to_translate.c:6
-msgid "Target monitor"
-msgstr "Cílový monitor"
-#: ../locale/scriptstrings/d.mvmon_to_translate.c:7
-msgid "Source monitor"
-msgstr "Zdrojový monitor"
-#: ../locale/scriptstrings/d.out.gpsdrive_to_translate.c:1
-msgid "Export display monitor to a GpsDrive compatible backdrop image"
-msgstr "Exportuj monitor do souboru kompatibilním s GpsDrive"
-#: ../locale/scriptstrings/d.out.gpsdrive_to_translate.c:2
-msgid "display, export, GPS"
-msgstr "zobrazení, export, GPS"
-#: ../locale/scriptstrings/d.out.gpsdrive_to_translate.c:3
-msgid "name for new map image (lives in ~/.gpsdrive)"
-msgstr "jméno nového obrázku (bude ulo¾en do ~/.gpsdrive)"
-#: ../locale/scriptstrings/d.out.gpsdrive_to_translate.c:4
-msgid "Make JPEG instead of PNG image"
-msgstr "Vytvoø JPEG místo PNG"
-#: ../locale/scriptstrings/d.out.png_to_translate.c:1
-msgid "Saves active display monitor to PNG file in home directory"
-msgstr "Ulo¾í aktuální obsah monitoru do souboru PNG v domovském adresáøi"
-#: ../locale/scriptstrings/d.out.png_to_translate.c:2
-#: ../locale/scriptstrings/d.out.file_to_translate.c:2
-msgid "display, export"
-msgstr "zobrazení, export"
-#: ../locale/scriptstrings/d.out.png_to_translate.c:3
-msgid "Name of PNG file"
-msgstr "Jméno souboru PNG"
-#: ../locale/scriptstrings/d.out.png_to_translate.c:4
-msgid "Resolution of output file (single=1, double=2, quad=4)"
-msgstr "Rozli¹ení výstupního souboru (1x, 2x, 4x)"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:1
-msgid "Saves the contents of the active display monitor to a graphics file."
-msgstr "Ulo¾í obsah aktuálního monitoru jako soubor s obrázkem."
-#: ../locale/scriptstrings/d.out.file_to_translate.c:3
-msgid "Name for output file (do NOT add extension)"
-msgstr "Jméno obrázku (NEpøidávejte koncovku)"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:4
-msgid "Graphics file format"
-msgstr "Výstupní formát "
-#: ../locale/scriptstrings/d.out.file_to_translate.c:5
-msgid "Dimensions of output file versus current window size"
-msgstr "Rozmìry výstupu versus souèasná velikost okna"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:6
-msgid "(same=1, double size=2, quadruple size=4)"
-msgstr "(stejná velikost=1, dvojitá=2, ètyønásobná=4)"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:7
-#: ../locale/scriptstrings/d.out.file_to_translate.c:9
-#: ../locale/scriptstrings/d.out.file_to_translate.c:12
-#: ../locale/scriptstrings/d.out.file_to_translate.c:15
-#: ../locale/scriptstrings/d.out.file_to_translate.c:22
-#: ../locale/scriptstrings/d.out.file_to_translate.c:24
-msgid "Images"
-msgstr "Obrázky"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:8
-msgid "Width and height of output image (overrides resolution setting)"
-msgstr "©íøka a vý¹ka výstupního obrazu (pøepí¹e nastavení rozli¹ení)"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:10
-msgid "Compression for PNG files"
-msgstr "Komprese pro soubory PNG"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:11
-msgid "(0=none, 1=fastest, 9=most; lossless, only time vs. filesize)"
-msgstr "(0=nic, 1=nejrychleji, 9=bezeztrát; pouze èas vs velikost souboru)"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:13
-msgid "File size/quality for JPEG files"
-msgstr "Velikost/kvalita souboru JPEG"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:14
-msgid "(10=smallest/worst, 100=largest/best)"
-msgstr "(10=nejmen¹í/nejhor¹í, 100=nejvìt¹í/nejlep¹í)"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:16
-msgid "Paper size for PostScript output"
-msgstr "Velikost papíru pro výstup v PostScript."
-#: ../locale/scriptstrings/d.out.file_to_translate.c:17
-#: ../locale/scriptstrings/d.out.file_to_translate.c:19
-#: ../locale/scriptstrings/d.out.file_to_translate.c:26
-msgid "PostScript"
-msgstr "PostScript"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:18
-msgid "PostScript level (only limits functionality!)"
-msgstr "Úroveò Postscriptu ( pouze omezuje funkènost!)"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:20
-msgid "Set background color to black (white default)"
-msgstr "Nastav barvu pozadí na èernou (bílá je výchozí)"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:21
-msgid "Set transparent background"
-msgstr "Nastavit prùhledné pozadí"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:23
-msgid "Use the Cario driver to render images"
-msgstr "Pou¾ít ovladaè Cairo pro vykreslení obrazù"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:25
-msgid "Set paper orientation to landscape (for PostScript output)"
-msgstr "Nastavit papír na orientaci krajina (pro výstup Postscript)"
-#: ../locale/scriptstrings/d.polar_to_translate.c:1
-msgid "Draws polar diagram of angle map such as aspect or flow directions"
-msgstr "Vykreslí polární diagram íºhlové mapy jako je smìr povrchového odtoku"
-#: ../locale/scriptstrings/d.polar_to_translate.c:3
-msgid "Name of raster angle map"
-msgstr "Jméno rastru s íºhly"
-#: ../locale/scriptstrings/d.polar_to_translate.c:4
-msgid "Pixel value to be interpreted as undefined (different from NULL)"
+#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:8
+msgid "Scale factor for converting horizontal units to elevation units"
msgstr ""
-"Hodnota pixelu, která má být interpretována jako nedefinováno (rùzná od NULL)"
+"Mìøítkový faktor pro pøevod horizontálních jednotek na jednotky elevace "
-#: ../locale/scriptstrings/d.polar_to_translate.c:5
-msgid "Name of optional EPS output file"
-msgstr "Název volitelného výstupního souboru ve formátu EPS"
+#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:9
+msgid "Set scaling factor (applies to lat./long. locations only)"
+msgstr "Nastav mìøítkový faktor (bude pou¾ito pouze na location lat/long)"
-#: ../locale/scriptstrings/d.polar_to_translate.c:6
-msgid "Plot using Xgraph"
-msgstr "Vytisknout pomocí Xgraph"
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:1
#: ../display/d.rast.edit/main.c:60
msgid "Interactively edit cell values in a raster map."
@@ -1759,23 +963,14 @@
msgstr "zobrazení, rastr"
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:3
+#: ../locale/scriptstrings/r.out.xyz_to_translate.c:3
#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:5
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:3
-#: ../raster/r.random/main.c:52 ../raster/r.resamp.rst/main.c:167
-#: ../raster/r.out.bin/main.c:73 ../raster/r.water.outlet/main.c:54
+#: ../raster/r.water.outlet/main.c:54 ../raster/r.random/main.c:52
+#: ../raster/r.resamp.rst/main.c:167 ../raster/r.out.bin/main.c:73
#: ../imagery/i.zc/main.c:68
msgid "Name of input raster map"
msgstr "Název vstupní rastrové mapy"
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:4
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:5
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:6
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:15
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:9
-#: ../raster/r.in.gridatb/main.c:55
-msgid "Name for output raster map"
-msgstr "Název výstupní rastrové mapy"
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:5
msgid "Name of aspect raster map"
msgstr "Název rastrové mapy expozice"
@@ -1806,25 +1001,24 @@
#: ../locale/scriptstrings/d.rast.leg_to_translate.c:2
#: ../locale/scriptstrings/d.redraw_to_translate.c:2
-#: ../visualization/ximgview/main.c:271 ../display/d.histogram/main.c:69
-#: ../display/d.mapgraph/main.c:48 ../display/d.erase/main.c:32
-#: ../display/d.profile/main.c:60 ../display/d.measure/main.c:48
-#: ../display/d.colors/main.c:51 ../display/d.what.vect/main.c:53
-#: ../display/d.font/main.c:42 ../display/d.rast.num/number.c:86
-#: ../display/d.linegraph/linegraph.c:113 ../display/d.colorlist/main.c:35
-#: ../display/d.what.rast/main.c:44 ../display/d.title/main.c:45
-#: ../display/d.geodesic/main.c:45 ../display/d.text/main.c:67
-#: ../display/d.font.freetype/main.c:58 ../display/d.info/main.c:33
-#: ../display/d.save/main.c:81 ../display/d.vect/main.c:126
-#: ../display/d.vect.chart/main.c:62 ../display/d.rast.arrow/arrow.c:112
-#: ../display/d.menu/main.c:65 ../display/d.text.freetype/main.c:140
-#: ../display/d.rast/main.c:52 ../display/d.extract/main.c:48
-#: ../display/d.rgb/main.c:53 ../display/d.where/main.c:41
-#: ../display/d.paint.labels/main.c:45 ../display/d.text.new/main.c:139
-#: ../display/d.ask/main.c:35 ../display/d.his/main.c:65
-#: ../display/d.zoom/main.c:56 ../display/d.rhumbline/main.c:43
-#: ../display/d.nviz/main.c:68 ../display/d.mon/cmd/main.c:47
-#: ../display/d.frame/frame.c:60
+#: ../display/d.what.vect/main.c:53 ../display/d.mon/cmd/main.c:47
+#: ../display/d.rast.arrow/arrow.c:112 ../display/d.info/main.c:33
+#: ../display/d.font/main.c:42 ../display/d.title/main.c:45
+#: ../display/d.rast.num/number.c:86 ../display/d.font.freetype/main.c:58
+#: ../display/d.measure/main.c:48 ../display/d.save/main.c:81
+#: ../display/d.profile/main.c:60 ../display/d.his/main.c:65
+#: ../display/d.frame/frame.c:60 ../display/d.what.rast/main.c:44
+#: ../display/d.colors/main.c:51 ../display/d.rhumbline/main.c:43
+#: ../display/d.geodesic/main.c:45 ../display/d.thematic.area/main.c:72
+#: ../display/d.mapgraph/main.c:48 ../display/d.linegraph/linegraph.c:113
+#: ../display/d.extract/main.c:48 ../display/d.rast/main.c:52
+#: ../display/d.nviz/main.c:68 ../display/d.ask/main.c:35
+#: ../display/d.menu/main.c:65 ../display/d.erase/main.c:32
+#: ../display/d.rgb/main.c:53 ../display/d.text.new/main.c:139
+#: ../display/d.paint.labels/main.c:45 ../display/d.text/main.c:67
+#: ../display/d.text.freetype/main.c:140 ../display/d.zoom/main.c:56
+#: ../display/d.histogram/main.c:69 ../display/d.where/main.c:41
+#: ../display/d.colorlist/main.c:35 ../visualization/ximgview/main.c:271
msgid "display"
msgstr "zobrazení"
@@ -1832,111 +1026,150 @@
msgid "omit entries with missing label"
msgstr "pøeskoèit záznamy bez popisku"
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:4
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:3
+#: ../locale/scriptstrings/d.correlate_to_translate.c:3
+#: ../locale/scriptstrings/d.correlate_to_translate.c:4
+#: ../locale/scriptstrings/d.correlate_to_translate.c:5
+#: ../locale/scriptstrings/d.correlate_to_translate.c:6
+msgid "raster input map"
+msgstr "vstupní rastrová mapa"
#: ../locale/scriptstrings/d.rast.leg_to_translate.c:5
msgid "Number of lines to appear in the legend"
msgstr "Poèet øádkù v legendì"
-#: ../locale/scriptstrings/d.redraw_to_translate.c:1
-msgid "Redraws the current display frame in the GRASS monitor"
-msgstr "Pøekreslí aktuálnì zobrazené mapy v monitoru"
+#: ../locale/scriptstrings/d.polar_to_translate.c:1
+msgid "Draws polar diagram of angle map such as aspect or flow directions"
+msgstr "Vykreslí polární diagram íºhlové mapy jako je smìr povrchového odtoku"
-#: ../locale/scriptstrings/d.redraw_to_translate.c:3
-#, fuzzy
-msgid "Redraw all frames"
-msgstr "Ulo¾ v¹echny rámy"
+#: ../locale/scriptstrings/d.polar_to_translate.c:2
+#: ../locale/scriptstrings/d.correlate_to_translate.c:2
+msgid "display, diagram"
+msgstr "zobrazení, diagram"
-#: ../locale/scriptstrings/d.redraw_to_translate.c:4
-msgid "Do not preserve individual regions when redrawing all frames"
+#: ../locale/scriptstrings/d.polar_to_translate.c:3
+msgid "Name of raster angle map"
+msgstr "Jméno rastru s íºhly"
+#: ../locale/scriptstrings/d.polar_to_translate.c:4
+msgid "Pixel value to be interpreted as undefined (different from NULL)"
msgstr ""
+"Hodnota pixelu, která má být interpretována jako nedefinováno (rùzná od NULL)"
-#: ../locale/scriptstrings/d.resize_to_translate.c:1
-msgid "Resizes active display monitor"
-msgstr "Mìní velikost aktivního monitoru"
+#: ../locale/scriptstrings/d.polar_to_translate.c:5
+msgid "Name of optional EPS output file"
+msgstr "Název volitelného výstupního souboru ve formátu EPS"
-#: ../locale/scriptstrings/d.resize_to_translate.c:3
-msgid "New width for window"
-msgstr "Nová ¹íøka okna"
+#: ../locale/scriptstrings/d.polar_to_translate.c:6
+msgid "Plot using Xgraph"
+msgstr "Vytisknout pomocí Xgraph"
-#: ../locale/scriptstrings/d.resize_to_translate.c:4
-msgid "New height for window"
-msgstr "Nová vý¹ka okna"
+#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:1
+msgid ""
+"Brovey transform to merge multispectral and high-res panchromatic channels"
+msgstr ""
+"Broveyova transformace pro slouèení multispektrálních kanálù s "
+"panchromatickými kanály vy¹¹ího rozli¹ení"
-#: ../locale/scriptstrings/d.shadedmap_to_translate.c:1
-msgid "Drapes a color raster over a shaded relief map using d.his"
-msgstr "Pøekrýt barevnou rastrovou mapy pøes stínovaný reliéf s pou¾itím d.his"
+#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:2
+msgid "raster, imagery, fusion"
+msgstr "rastr, obrazová data, fíºze"
-#: ../locale/scriptstrings/d.shadedmap_to_translate.c:2
-msgid "Name of shaded relief or aspect map"
-msgstr "Jméno mapy stínovaného reliéfu nebo expozice"
+#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:3
+msgid "sensor: LANDSAT"
+msgstr "senzor: LANDSAT"
-#: ../locale/scriptstrings/d.shadedmap_to_translate.c:3
-msgid "Name of raster to drape over relief map"
-msgstr "Jméno rastru pro pøeta¾ení pøes mapu reliéfu"
+#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:4
+msgid "sensor: QuickBird"
+msgstr "senzor: QuickBird"
-#: ../locale/scriptstrings/d.shadedmap_to_translate.c:4
-msgid "Percent to brighten"
-msgstr "Procenta zesvìtlení"
+#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:5
+msgid "sensor: SPOT"
+msgstr "senzor: SPOT"
-#: ../locale/scriptstrings/d.slide.show_to_translate.c:1
-msgid "Slide show of GRASS raster/vector maps."
-msgstr "Slide show rastrù/vektorù."
+#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:6
+msgid "raster input map (green: tm2 | qbird_green | spot1)"
+msgstr "vstupní rastrová mapa (zelená: tm2 | qbird_green | spot1)"
-#: ../locale/scriptstrings/d.slide.show_to_translate.c:2
-msgid "display, slideshow"
-msgstr "zobrazení, prezentace"
+#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:7
+msgid "raster input map (NIR: tm4 | qbird_nir | spot2)"
+msgstr "vstupní rastrová mapa (blízká infra èervená: tm4 | qbird_nir | spot2)"
-#: ../locale/scriptstrings/d.slide.show_to_translate.c:3
-msgid "Show vector maps rather than raster maps"
-msgstr "Zobrazit vektory, místo rastrù"
+#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:8
+msgid "raster input map (MIR; tm5 | qbird_red | spot3)"
+msgstr "vstupní rastrová mapa (støední infra èervená: tm5 | qbird_red | spot3)"
-#: ../locale/scriptstrings/d.slide.show_to_translate.c:4
-msgid "Map prefix. Specify character(s) to view selected maps only"
-msgstr "Pøedpona mapy. Zadejte písmeno(na) pro zobrazení pouze vybraných map"
+#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:9
+msgid "raster input map (etmpan | qbird_pan | spotpan)"
+msgstr "vstupní rastrová mapa (etmpan | qbird_pan | spotpan)"
-#: ../locale/scriptstrings/d.slide.show_to_translate.c:5
-msgid "Map number show across the monitor"
-msgstr "Poèet map zobrazených na monitoru"
+#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:10
+msgid "raster output map prefix (e.g. 'brov')"
+msgstr "pøedpona výstupního rastru (napø. 'brov')"
-#: ../locale/scriptstrings/d.slide.show_to_translate.c:6
-msgid "Map number show down the monitor"
-msgstr "Poèet map zobrazených pod monitorem"
+#: ../locale/scriptstrings/gis.m_to_translate.c:1
+msgid "GIS manager for GRASS"
+msgstr "GIS manager pro GRASS"
-#: ../locale/scriptstrings/d.slide.show_to_translate.c:7
-msgid "Mapsets to use. Specify multiple mapsets comma separated"
-msgstr "Mapset který bude pou¾it. Více mapsetù lze oddìlit èárkou"
+#: ../locale/scriptstrings/gis.m_to_translate.c:2
+msgid "Name of GIS manager settings file (.grc)"
+msgstr "Jméno souboru s nastavením pro GIS manager (.grc)"
-#: ../locale/scriptstrings/d.slide.show_to_translate.c:8
-msgid "Number of seconds to pause between slides"
-msgstr "Poèet vteøin pro pøestávku mezi slidy."
+#: ../locale/scriptstrings/db.droptable_to_translate.c:1
+msgid "Drops an attribute table"
+msgstr "Vyjmout atributovou tabulku"
-#: ../locale/scriptstrings/d.split_to_translate.c:1
-msgid ""
-"Divides active display into two frames & displays maps/executes commands in "
-"each frame."
+#: ../locale/scriptstrings/db.droptable_to_translate.c:3
+#: ../locale/scriptstrings/g.mremove_to_translate.c:4
+#: ../locale/scriptstrings/db.dropcol_to_translate.c:3
+msgid "Force removal (required for actual deletion of files)"
+msgstr "Vynutit odstranìní ( po¾adováno pro souèasné mazání souborù)"
+#: ../locale/scriptstrings/db.droptable_to_translate.c:4
+msgid "Table to drop"
+msgstr "Tabulka k vyjmutí"
+#: ../locale/scriptstrings/g.manual_to_translate.c:1
+msgid "Display the HTML man pages of GRASS"
+msgstr "Zobrazuje manuálové stránky GRASSu ve formátu HTML"
+#: ../locale/scriptstrings/g.manual_to_translate.c:2
+msgid "general, manual, help"
+msgstr "obecné, návod, pomoc"
+#: ../locale/scriptstrings/g.manual_to_translate.c:3
+msgid "Display index"
+msgstr "Zobrazit obsah"
+#: ../locale/scriptstrings/g.manual_to_translate.c:4
+msgid "Display as MAN text page instead of HTML page in browser"
msgstr ""
-"Rozdìlí aktivní monitor na dva rámy a v ka¾dém rámu zobrazí mapu a pøíkaz "
-"pro její vytvoøení."
+"Zobrazit jako textovou manuálovou stránku MAN místo formátu HTML v prohlí¾eèi"
-#: ../locale/scriptstrings/d.split_to_translate.c:3
-msgid "Enter raster map to display in 1st frame"
-msgstr "Rastrová mapa, která má být zobrazena v první rámu"
+#: ../locale/scriptstrings/g.manual_to_translate.c:5
+msgid "Manual entry to be displayed"
+msgstr "Záznam manuálu, který chcete zobrazit"
-#: ../locale/scriptstrings/d.split_to_translate.c:4
-msgid "Enter command to execute in 1st frame"
-msgstr "Vlo¾te pøíkaz pro vykonání v první rámu"
+#: ../locale/scriptstrings/r.out.xyz_to_translate.c:1
+msgid ""
+"Export a raster map to a text file as x,y,z values based on cell centers."
+msgstr ""
+"Exportuje rastrovou mapu do textového souboru jako hodnoty x,y,z dle støedù "
+"bunìk."
-#: ../locale/scriptstrings/d.split_to_translate.c:5
-msgid "Enter raster map to display in 2nd frame"
-msgstr "Rastrová mapa, která má být zobrazena v druhém rámu"
+#: ../locale/scriptstrings/r.out.xyz_to_translate.c:2
+#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:2
+#: ../raster/r.out.ppm/main.c:52 ../raster/r.out.ascii/main.c:60
+#: ../raster/r.out.tiff/r.out.tiff.c:100 ../raster/r.out.gdal/main.c:375
+#: ../raster/r.out.mat/main.c:61
+msgid "raster, export"
+msgstr "rastr, export"
-#: ../locale/scriptstrings/d.split_to_translate.c:6
-msgid "Enter command to execute in 2nd frame"
-msgstr "Vlo¾te pøíkaz pro vykonání v druhém rámu"
+#: ../locale/scriptstrings/r.out.xyz_to_translate.c:4
+msgid "Name for output file (if omitted or \"-\" output to stdout)"
+msgstr "Název výstupní mapy (pro standardní výstup pou¾ijte \"-\")"
-#: ../locale/scriptstrings/d.split_to_translate.c:7
-msgid "How to split display"
-msgstr "Jak rozdìlit monitor"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:1
msgid "Displays thematic vectormap"
msgstr "Tématicky zobrazuje vektorovou mapu"
@@ -2089,8 +1322,8 @@
"Ulo¾ pøíkazy pro vytvoøení tématické mapy do souboru skupiny pro GIS Manager"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:40
+#: ../locale/scriptstrings/v.univar.sh_to_translate.c:8
#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
-#: ../locale/scriptstrings/v.univar.sh_to_translate.c:8
msgid "WHERE conditions of SQL statement without 'where' keyword"
msgstr "Podmínka SQL WHERE ov¹em bez slova 'where'"
@@ -2127,155 +1360,22 @@
msgid "Use math notation brackets in legend"
msgstr "Pou¾ij matematický zápis závorek v legendì"
-#: ../locale/scriptstrings/db.dropcol_to_translate.c:1
-msgid "Drops a column from selected attribute table"
-msgstr "Sma¾e sloupeèky z vybrané atributové tabulky"
+#: ../locale/scriptstrings/g.mremove_to_translate.c:1
+msgid "Apply regular expressions and wildcards to g.remove"
+msgstr "Pou¾ij regulární výrazy a zástupné znaky pro g.remove "
-#: ../locale/scriptstrings/db.dropcol_to_translate.c:2
-#: ../locale/scriptstrings/db.droptable_to_translate.c:2
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:2
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:2
-#: ../locale/scriptstrings/db.test_to_translate.c:2
-msgid "database, attribute table"
-msgstr "databáze, atributová tabulka"
-#: ../locale/scriptstrings/db.dropcol_to_translate.c:3
-#: ../locale/scriptstrings/db.droptable_to_translate.c:3
-#: ../locale/scriptstrings/g.mremove_to_translate.c:4
-msgid "Force removal (required for actual deletion of files)"
-msgstr "Vynutit odstranìní ( po¾adováno pro souèasné mazání souborù)"
-#: ../locale/scriptstrings/db.dropcol_to_translate.c:4
-msgid "Table from which to drop attribute column"
-msgstr "Tabulka, ze které mude sloupeèek vymazán"
-#: ../locale/scriptstrings/db.dropcol_to_translate.c:5
-#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:5
-msgid "Name of the column"
-msgstr "Jméno sloupce"
-#: ../locale/scriptstrings/db.droptable_to_translate.c:1
-#, fuzzy
-msgid "Drops an attribute table"
-msgstr "Zkopíruj také atributovou tabulku."
-#: ../locale/scriptstrings/db.droptable_to_translate.c:4
-#, fuzzy
-msgid "Table to drop"
-msgstr "Nelze pokraèovat"
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:1
-msgid "Imports attribute tables in various formats."
-msgstr "Importuje atributové tabulky v rùzných formátech."
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:3
-msgid "Table file to be imported or DB connection string"
-msgstr "Tabulka pro import nebo textový øetìzec databázového spojení"
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:4
-msgid "Table name of SQL DB table"
-msgstr "Jméno tabulky v SQL DB tabulce"
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:5
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:6
-msgid "Name for output table"
-msgstr "Název výstupní tabulky"
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:6
-msgid "Name for auto-generated unique key column"
-msgstr ""
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:1
-#, fuzzy
-msgid "Exports attribute tables into various formats."
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:3
-#, fuzzy
-msgid "GRASS table name"
-msgstr "Jméno vstupní tabulky"
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:4
-#, fuzzy
-msgid "Table file to be exported or DB connection string"
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:5
-#, fuzzy
-msgid "Table format"
-msgstr "Formát"
-#: ../locale/scriptstrings/db.test_to_translate.c:1
-msgid "Test database driver, database must exist and set by db.connect."
-msgstr ""
-"Otestuj ovladaè databáze, databáze musí existovat a nastavena pomocí db."
-"connect"
-#: ../locale/scriptstrings/db.test_to_translate.c:3
-msgid "Test name"
-msgstr "Jméno testu"
-#: ../locale/scriptstrings/g.manual_to_translate.c:1
-msgid "Display the HTML man pages of GRASS"
-msgstr "Zobrazuje manuálové stránky GRASSu ve formátu HTML"
-#: ../locale/scriptstrings/g.manual_to_translate.c:2
-msgid "general, manual, help"
-msgstr "obecné, návod, pomoc"
-#: ../locale/scriptstrings/g.manual_to_translate.c:3
-msgid "Display index"
-msgstr "Zobrazit obsah"
-#: ../locale/scriptstrings/g.manual_to_translate.c:4
-msgid "Display as MAN text page instead of HTML page in browser"
-msgstr ""
-"Zobrazit jako textovou manuálovou stránku MAN místo formátu HTML v prohlí¾eèi"
-#: ../locale/scriptstrings/g.manual_to_translate.c:5
-msgid "Manual entry to be displayed"
-msgstr "Záznam manuálu, který chcete zobrazit"
-#: ../locale/scriptstrings/g.mlist_to_translate.c:1
-msgid "Apply regular expressions and wildcards to g.list"
-msgstr "Pou¾ij regulární výrazy a zástupné znaky na g.list"
+#: ../locale/scriptstrings/g.mremove_to_translate.c:2
#: ../locale/scriptstrings/g.mlist_to_translate.c:2
-#: ../locale/scriptstrings/g.mremove_to_translate.c:2
-#: ../general/manage/cmd/rename.c:40 ../general/manage/cmd/copy.c:38
-#: ../general/manage/cmd/list.c:40 ../general/manage/cmd/remove.c:45
+#: ../general/manage/cmd/remove.c:110 ../general/manage/cmd/rename.c:40
+#: ../general/manage/cmd/copy.c:38 ../general/manage/cmd/list.c:40
msgid "general, map management"
msgstr "obecné, ovládání map"
+#: ../locale/scriptstrings/g.mremove_to_translate.c:3
#: ../locale/scriptstrings/g.mlist_to_translate.c:3
-#: ../locale/scriptstrings/g.mremove_to_translate.c:3
msgid "Use regular expression instead of wildcard"
msgstr "Pou¾ij regulární výrazy místo zástupných znakù"
-#: ../locale/scriptstrings/g.mlist_to_translate.c:4
-msgid "Print mapset name"
-msgstr "Vytiskne jméno mapsetu"
-#: ../locale/scriptstrings/g.mlist_to_translate.c:5
-msgid "Data type"
-msgstr "Typ dat"
-#: ../locale/scriptstrings/g.mlist_to_translate.c:6
-msgid "Mapset(s) to list (default: current mapset search path)"
-msgstr "Mapset, ze kterého má být seznam udìlán (výchozí: aktuální)"
-#: ../locale/scriptstrings/g.mlist_to_translate.c:7
-msgid "Output separator (default: newline)"
-msgstr "Oddìlovaè výstupu (výchozí: øádkový zlom)"
-#: ../locale/scriptstrings/g.mlist_to_translate.c:8
-msgid "Map name search pattern (default: all)"
-msgstr "Øìtìzec v názvu mapy, musí být 'uvozen' (výchozí: v¹echny)"
-#: ../locale/scriptstrings/g.mremove_to_translate.c:1
-msgid "Apply regular expressions and wildcards to g.remove"
-msgstr "Pou¾ij regulární výrazy a zástupné znaky pro g.remove "
#: ../locale/scriptstrings/g.mremove_to_translate.c:5
msgid "Raster to remove"
msgstr "Rastrová mapa ke smazání"
@@ -2308,451 +1408,36 @@
msgid "Group to remove"
msgstr "Skupina ke smazání"
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:1
-msgid ""
-"Brovey transform to merge multispectral and high-res panchromatic channels"
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:1
+msgid "Uploads vector values at positions of vector points to the table."
msgstr ""
-"Broveyova transformace pro slouèení multispektrálních kanálù s "
-"panchromatickými kanály vy¹¹ího rozli¹ení"
+"Ulo¾í hodnoty rastrové mapy na pozicích bodù pøekryvné vektorové mapy do "
+"atributové tabulky."
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:2
-msgid "raster, imagery, fusion"
-msgstr "rastr, obrazová data, fíºze"
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:3
+msgid "Points vector map to modify"
+msgstr "Bodová mapa, která bude zmìnìna"
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:3
-msgid "sensor: LANDSAT"
-msgstr "senzor: LANDSAT"
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:4
+msgid "Layer in the vector to be modified"
+msgstr "Vektorová vrstva, která bude mìnìna"
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:4
-msgid "sensor: QuickBird"
-msgstr "senzor: QuickBird"
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:5
+msgid "Column to be updated with the query result"
+msgstr "Sloupec který má být aktualizován výsledky dotazu"
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:5
-msgid "sensor: SPOT"
-msgstr "senzor: SPOT"
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:6
+msgid "Vector map to be queried"
+msgstr "Vektorová mapa, její¾ hodnoty budou vy¹etøovány"
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:6
-msgid "raster input map (green: tm2 | qbird_green | spot1)"
-msgstr "vstupní rastrová mapa (zelená: tm2 | qbird_green | spot1)"
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:7
+msgid "Layer of the query vector containg data"
+msgstr "Vrstva vektorové mapy, ve které jsou zájmová data"
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:7
-msgid "raster input map (NIR: tm4 | qbird_nir | spot2)"
-msgstr "vstupní rastrová mapa (blízká infra èervená: tm4 | qbird_nir | spot2)"
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:8
+msgid "Column to be queried"
+msgstr "Sloupec vektorové mapy, ze kterého se budou brát hodnoty"
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:8
-msgid "raster input map (MIR; tm5 | qbird_red | spot3)"
-msgstr "vstupní rastrová mapa (støední infra èervená: tm5 | qbird_red | spot3)"
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:9
-msgid "raster input map (etmpan | qbird_pan | spotpan)"
-msgstr "vstupní rastrová mapa (etmpan | qbird_pan | spotpan)"
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:10
-msgid "raster output map prefix (e.g. 'brov')"
-msgstr "pøedpona výstupního rastru (napø. 'brov')"
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:1
-msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
-msgstr ""
-"Vytvoøí mozaiku ze 4 a více snmkù, roztáhne barevnou paletu a vytvoøí mapu *."
-"mosaic"
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:2
-msgid "raster, imagery, mosaicking"
-msgstr "rastr, dpz, mozaikování"
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:3
-msgid "1st map for mosaic (top of image stack)."
-msgstr "První mapa pro mozaiku (v seznamu mozaiky zcela nahoøe)"
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:4
-msgid "2nd map for mosaic."
-msgstr "druhá mapa mozaiky"
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:5
-msgid "3rd map for mosaic."
-msgstr "tøetí mapa mozaiky"
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:6
-msgid "4th map for mosaic."
-msgstr "ètvrtá mapa mozaiky"
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:1
-msgid "Import of SPOT VGT NDVI file into a raster map"
-msgstr "Import SPOT VGT NDVI souboru jako rastrové mapy"
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:2
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:2
-msgid "raster, imagery, import"
-msgstr "rastr, obrazová data, import"
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:3
-msgid "also import quality map (SM status map layer) and filter NDVI map"
-msgstr ""
-"importuj také mapu kvality (SM status map layer) a filtruj jím NDVI mapu"
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:4
-msgid "existing SPOT VGT NDVI HDF file (0001_NDV.HDF)"
-msgstr "existující souboru SPOT VGT NDVI HDF (0001_NDV.HDF)"
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:1
-msgid "Auto-balancing of colors for LANDSAT images"
-msgstr "Automatické vyvá¾ení barev pro snímky z dru¾ice LANDSAT"
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:2
-msgid "raster, imagery, colors"
-msgstr "rastr, dpz, barvy"
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:3
-msgid "LANDSAT red channel"
-msgstr "èervený kanál LANDSAT"
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:4
-msgid "LANDSAT green channel"
-msgstr "zelený kanál LANDSAT"
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:5
-msgid "LANDSAT blue channel"
-msgstr "modrý kanál LANDSAT"
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:6
-msgid "Cropping intensity (upper brightness level)"
-msgstr "Oøezávám intenzitu (horní hodnoty svìtlosti)"
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:7
-msgid "Extend colors to full range of data on each channel"
-msgstr "Na ka¾dém kanálu roztáhne barvy po celé ¹kále "
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:8
-msgid "Preserve relative colors, adjust brightness only"
-msgstr "Zachovej relativní barvy, hýbej pouze se svìtlostí"
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:9
-msgid "Reset to standard color range"
-msgstr "Nastav zpìt na standardní barevný rozsah"
-#: ../locale/scriptstrings/i.oif_to_translate.c:1
-msgid "Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7"
-msgstr ""
-"Spoèítá tabulku optimálního faktoru indexu pro kanály 1-5 a 7 dru¾ice "
-"LANDSAT TM"
-#: ../locale/scriptstrings/i.oif_to_translate.c:2
-msgid "raster, imagery, statistics"
-msgstr "rastr, dpz, statistika"
-#: ../locale/scriptstrings/i.oif_to_translate.c:3
-msgid "LANDSAT TM band 1."
-msgstr "LANDSAT TM kanál 1"
-#: ../locale/scriptstrings/i.oif_to_translate.c:4
-msgid "LANDSAT TM band 2."
-msgstr "LANDSAT TM kanál 2."
-#: ../locale/scriptstrings/i.oif_to_translate.c:5
-msgid "LANDSAT TM band 3."
-msgstr "LANDSAT TM kanál 3."
-#: ../locale/scriptstrings/i.oif_to_translate.c:6
-msgid "LANDSAT TM band 4."
-msgstr "LANDSAT TM kanál 4."
-#: ../locale/scriptstrings/i.oif_to_translate.c:7
-msgid "LANDSAT TM band 5."
-msgstr "LANDSAT TM kanál 5."
-#: ../locale/scriptstrings/i.oif_to_translate.c:8
-msgid "LANDSAT TM band 7."
-msgstr "LANDSAT TM kanál 7."
-#: ../locale/scriptstrings/i.oif_to_translate.c:9
-#: ../locale/scriptstrings/r.regression.line_to_translate.c:3
-#: ../general/g.region/cmd/main.c:135
-msgid "Print in shell script style"
-msgstr "Vypi¹ ve stylu pro shell skript."
-#: ../locale/scriptstrings/i.spectral_to_translate.c:1
-msgid ""
-"displays spectral response at user specified locations in group or images"
-msgstr ""
-"zobrazí spektrální odrazivost na u¾ivatelem zadaných mapách ve skupinì snímkù"
-#: ../locale/scriptstrings/i.spectral_to_translate.c:2
-msgid "imagery, raster, multispectral"
-msgstr "rastr, dpz, multispektrální"
-#: ../locale/scriptstrings/i.spectral_to_translate.c:3
-msgid "group input"
-msgstr "vstupní skupina"
-#: ../locale/scriptstrings/i.spectral_to_translate.c:4
-msgid "raster input maps"
-msgstr "Vstupní rastrové soubory"
-#: ../locale/scriptstrings/i.spectral_to_translate.c:5
-msgid "write output to PNG image"
-msgstr "Zapsat výstup jako soubor PNG"
-#: ../locale/scriptstrings/i.spectral_to_translate.c:6
-msgid "Use image list and not group"
-msgstr "Pou¾ij seznam snímkù a ne skupinu"
-#: ../locale/scriptstrings/i.spectral_to_translate.c:7
-msgid "Select multiple points"
-msgstr "Vyber více bodù"
-#: ../locale/scriptstrings/i.spectral_to_translate.c:8
-msgid "label with coordinates instead of numbering"
-msgstr "oznaè souøadnicemi místo èíslováním"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:1
-msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
-msgstr "Transformace Cap (Kauth Thomas) pro data LANDSAT-TM"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:2
-msgid "raster, imagery"
-msgstr "rastr, obrazová data"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:3
-msgid "use transformation rules for LANDSAT-4"
-msgstr "pou¾ít transformaèní pravidla pro LANDSAT-4"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:4
-msgid "use transformation rules for LANDSAT-5"
-msgstr "pou¾ít pravidla transformace pro LANDSAT-5"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:5
-msgid "use transformation rules for LANDSAT-7"
-msgstr "pou¾ít pravidla transformace pro LANDSAT-7"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:6
-msgid "raster input map (LANDSAT channel 1)"
-msgstr "vstupní rastrová mapa (LANDSAT kanál 1)"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:7
-msgid "raster input map (LANDSAT channel 2)"
-msgstr "vstupní rastrová mapa (LANDSAT kanál 2)"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:8
-msgid "raster input map (LANDSAT channel 3)"
-msgstr "vstupní rastrová mapa (LANDSAT kanál 3)"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:9
-msgid "raster input map (LANDSAT channel 4)"
-msgstr "vstupní rastrová mapa (LANDSAT kanál 4)"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:10
-msgid "raster input map (LANDSAT channel 5)"
-msgstr "vstupní rastrová mapa (LANDSAT kanál 5)"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:11
-msgid "raster input map (LANDSAT channel 7)"
-msgstr "vstupní rastrová mapa (LANDSAT kanál 7)"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:12
-msgid "raster output TC maps prefix"
-msgstr "pøedpona výstupního rastru TC"
-#: ../locale/scriptstrings/m.proj_to_translate.c:1
-msgid "Convert coordinates from one projection to another (cs2cs frontend)."
-msgstr "Pøevede souøadnice z jedné projekce do druhé (rozhraní k cs2cs)"
-#: ../locale/scriptstrings/m.proj_to_translate.c:2
-msgid "miscellaneous, projection"
-msgstr "rùzné, projekce"
-#: ../locale/scriptstrings/m.proj_to_translate.c:3
-msgid "Input coordinate file (omit to read from stdin)"
-msgstr ""
-"Vstupní soubor se souøadnicemi (vynechává se pøi ètení ze standardního "
-"vstupu)"
-#: ../locale/scriptstrings/m.proj_to_translate.c:4
-msgid "Output coordinate file (omit to send to stdout)"
-msgstr ""
-"Výstup souøadnicového souboru (vynechává se pøi výpisu na standardní výstup)"
-#: ../locale/scriptstrings/m.proj_to_translate.c:5
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:5
-msgid "Field separator"
-msgstr "Oddìlovaè sloupcù"
-#: ../locale/scriptstrings/m.proj_to_translate.c:6
-msgid "Input projection parameters (PROJ.4 style)"
-msgstr "Parametry vstupní projekce (ve stylu PROJ.4)"
-#: ../locale/scriptstrings/m.proj_to_translate.c:7
-msgid "Output projection parameters (PROJ.4 style)"
-msgstr "Parametry výstupní projekce (ve stylu PROJ.4)"
-#: ../locale/scriptstrings/m.proj_to_translate.c:8
-msgid "Use LL WGS84 as input and current location as output projection"
-msgstr "Jako vstup pou¾ij LL WGS84 a aktuální location jako výstupní projekci"
-#: ../locale/scriptstrings/m.proj_to_translate.c:9
-msgid "Use current location as input and LL WGS84 as output projection"
-msgstr "Pou¾ij aktuální location jako vstup a LL WGS84 jako výstupní projekci"
-#: ../locale/scriptstrings/m.proj_to_translate.c:10
-msgid ""
-"Output long/lat in decimal degrees or other projections with many decimal "
-"places"
-msgstr ""
-"Výstup lat/long v decimálních stupních nebo jiné projekce s mnoha "
-"desetinnými místy"
-#: ../locale/scriptstrings/m.proj_to_translate.c:11
-msgid "Verbose mode (print projection parameters and filenames to stderr)"
-msgstr ""
-"Vypovídej se, chlapèe (vytiskni parametry projekce a jména souborù na "
-"standardní chybu)"
-#: ../locale/scriptstrings/r.blend_to_translate.c:1
-msgid "Blends color components of two raster maps by a given ratio"
-msgstr "Spojí barevné èásti dvou rastrových map zadaným pomìrem"
-#: ../locale/scriptstrings/r.blend_to_translate.c:2
-#: ../raster/r.describe/main.c:58 ../raster/r.rescale.eq/main.c:51
-#: ../raster/r.surf.area/main.c:89 ../raster/r.coin/cmd_parms.c:42
-#: ../raster/r.out.png/r.out.png.c:135 ../raster/r.distance/main.c:38
-#: ../raster/r.surf.fractal/interface.c:32 ../raster/r.reclass/main.c:48
-#: ../raster/r.los/main.c:78 ../raster/r.drain/main.c:103
-#: ../raster/r.carve/main.c:76 ../raster/r.profile/main.c:53
-#: ../raster/r.texture/main.c:71 ../raster/r.basins.fill/main.c:51
-#: ../raster/r.sum/main.c:47 ../raster/r.sun/main.c:153
-#: ../raster/r.volume/main.c:56 ../raster/r.null/null.c:45
-#: ../raster/r.average/main.c:51 ../raster/r.lake/main.c:156
-#: ../raster/r.out.gridatb/main.c:46 ../raster/r.surf.idw2/main.c:60
-#: ../raster/r.transect/main.c:53 ../raster/r.mode/main.c:48
-#: ../raster/simwe/r.sim.sediment/main.c:94
-#: ../raster/simwe/r.sim.water/main.c:97 ../raster/r.info/main.c:68
-#: ../raster/r.compress/main.c:63 ../raster/r.patch/main.c:53
-#: ../raster/r.le/r.le.setup/main.c:60 ../raster/r.le/r.le.pixel/main.c:45
-#: ../raster/r.le/r.le.trace/main.c:57 ../raster/r.le/r.le.patch/main.c:47
-#: ../raster/r.digit/main.c:44 ../raster/r.grow2/main.c:127
-#: ../raster/r.circle/dist.c:52 ../raster/r.surf.idw/main.c:68
-#: ../raster/r.thin/main.c:54 ../raster/r.surf.contour/main.c:50
-#: ../raster/r.topidx/main.c:37 ../raster/r.out.pov/main.c:120
-#: ../raster/r.covar/main.c:52 ../raster/r.out.arc/main.c:58
-#: ../raster/r.rescale/main.c:48 ../raster/r.random/main.c:46
-#: ../raster/r.sunmask/main.c:124 ../raster/r.his/main.c:64
-#: ../raster/r.topmodel/main.c:56 ../raster/r.bilinear/main.c:41
-#: ../raster/r.kappa/main.c:49 ../raster/r.median/main.c:44
-#: ../raster/r.resamp.rst/main.c:155 ../raster/r.stats/main.c:87
-#: ../raster/r.surf.random/main.c:41 ../raster/r.slope.aspect/main.c:152
-#: ../raster/r.surf.gauss/main.c:43 ../raster/r.colors/main.c:125
-#: ../raster/r.fill.dir/main.c:85 ../raster/r.timestamp/main.c:34
-#: ../raster/r.what/main.c:88 ../raster/r.random.surface/main.c:47
-#: ../raster/r.out.vtk/main.c:150 ../raster/r.support/front/front.c:54
-#: ../raster/r.out.bin/main.c:63 ../raster/r.neighbors/main.c:103
-#: ../raster/r.clump/main.c:50 ../raster/r.what.color/main.c:89
-#: ../raster/r.in.gridatb/main.c:43 ../raster/r.random.cells/main.c:39
-#: ../raster/r.to.vect/main.c:49 ../raster/r.region/main.c:53
-#: ../raster/r.out.ppm3/main.c:54 ../raster/r.in.mat/main.c:93
-#: ../raster/r.watershed/front/main.c:49 ../raster/r.quant/main.c:41
-#: ../raster/r.contour/main.c:90 ../raster/r.cross/main.c:65
-#: ../raster/r.cats/main.c:49 ../raster/r.out.mpeg/main.c:395
-#: ../raster/r.walk/main.c:172 ../raster/r.recode/main.c:42
-#: ../raster/r.composite/main.c:71 ../raster/r.gwflow/main.c:219
-#: ../raster/wildfire/r.ros/main.c:212
-#: ../raster/wildfire/r.spreadpath/main.c:71
-#: ../raster/wildfire/r.spread/main.c:102 ../raster/r.resample/main.c:53
-#: ../raster/r.in.arc/main.c:58 ../raster/r.bitpattern/main.c:62
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:152
-msgid "raster"
-msgstr "rastr"
-#: ../locale/scriptstrings/r.blend_to_translate.c:3
-msgid "Name of first raster map for blending"
-msgstr "Jméno nového rastru pro mí¹ení"
-#: ../locale/scriptstrings/r.blend_to_translate.c:4
-msgid "Name of second raster map for blending"
-msgstr "Jméno druhého rastru pro smí¹ení"
-#: ../locale/scriptstrings/r.blend_to_translate.c:5
-msgid "Base name for red, green, & blue output maps containing the blend"
-msgstr ""
-"Základní mapa pro èervenou, zelenou a modrou výstupní mapu obsahující spojení"
-#: ../locale/scriptstrings/r.blend_to_translate.c:6
-msgid "Percentage weight of first map for color blending"
-msgstr "Procenta váhy první mapy barevného spojení"
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:1
-msgid ""
-"Fills no-data areas in raster maps using v.surf.rst splines interpolation"
-msgstr ""
-"V rastrových mapách vyplní plochy s prázdnými hodnotami za pou¾ití v.surf."
-"rst spline interpolace"
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:2
-msgid "raster, elevation, interpolation"
-msgstr "rastr, elevace, interpolace"
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:3
-msgid "Raster map in which to fill nulls"
-msgstr "Rastrové mapy v nich¾ mají být vyplnìny NULLy"
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:4
-msgid ""
-"Output raster map with nulls filled by interpolation from surrounding values"
-msgstr ""
-"Výstupní rastrová mapa její¾ prázdná místa budou vyplnìna okolními hodnotami"
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:5
-msgid "Spline tension parameter"
-msgstr "Parametr pnutí (tension)"
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:6
-msgid "Spline smoothing parameter"
-msgstr "Parametr vyhlazení (smoothing)"
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:1
-msgid ""
-"Georeference, rectify and import Terra-ASTER imagery and relative DEM's "
-"using gdalwarp."
-msgstr ""
-"Georeferencuje, rektifikuje a importuje snímky ve formátu Terra-ASTER a "
-"pøíbuzných DMTù za pou¾ití gdalwarp."
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:3
-msgid "Input ASTER image to be georeferenced & rectified"
-msgstr "Vstupní snímek ASTER urèení ke georeferencingu a rektifikaci"
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:4
-msgid "ASTER imagery processing type (Level 1A, Level 1B, or relative DEM)"
-msgstr "Typ souboru ASTER (Level 1A, Level 1B, nebo pøíbuzný DEM)"
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:5
-msgid ""
-"L1A or L1B band to translate (1, 2, 3n, 3b, 4-14). Can only translate a "
-"single band"
-msgstr ""
-"L1A nebo L1B k pøelo¾ení (1,2,3n,3b,4-14). Umím pøelo¾it pouze jeden kanál"
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:1
-msgid "Import SRTM HGT files into GRASS"
-msgstr "Importuje SRTM HGT soubory do GRASSu"
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:2
-#: ../raster/r.in.bin/main.c:111 ../raster/r.in.gdal/main.c:78
-#: ../raster/r.in.poly/main.c:28
-msgid "raster, import"
-msgstr "rastr, import"
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:3
-msgid "SRTM input tile (file without .hgt.zip extension)"
-msgstr "Vstupní dla¾dice SRTM (soubor bez koncovky hgt nebo zip)"
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:4
-msgid "Output raster map (default: input tile)"
-msgstr "Výstupní rastrová mapa (výchozí: vstup dla¾dice)"
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:5
-msgid "Input is a 1-arcsec tile (default: 3-arcsec)"
-msgstr "Vstup je 1-arcsec dla¾dice (výchozí: 3-arcsec)"
msgid "Downloads and imports data from WMS servers."
msgstr "Stáhne a importuje data z WMS serverù."
@@ -2872,11 +1557,103 @@
msgid "Reprojection method to use"
msgstr "Reprojekèní metoda, která má být pou¾ita"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:44
-#: ../locale/scriptstrings/r.tileset_to_translate.c:14
-msgid "Verbosity level"
-msgstr "Úroveò upovídanosti"
+#: ../locale/scriptstrings/d.out.png_to_translate.c:1
+msgid "Saves active display monitor to PNG file in home directory"
+msgstr "Ulo¾í aktuální obsah monitoru do souboru PNG v domovském adresáøi"
+#: ../locale/scriptstrings/d.out.png_to_translate.c:2
+#: ../locale/scriptstrings/d.out.file_to_translate.c:2
+msgid "display, export"
+msgstr "zobrazení, export"
+#: ../locale/scriptstrings/d.out.png_to_translate.c:3
+msgid "Name of PNG file"
+msgstr "Jméno souboru PNG"
+#: ../locale/scriptstrings/d.out.png_to_translate.c:4
+msgid "Resolution of output file (single=1, double=2, quad=4)"
+msgstr "Rozli¹ení výstupního souboru (1x, 2x, 4x)"
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:1
+msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
+msgstr "Transformace Cap (Kauth Thomas) pro data LANDSAT-TM"
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:2
+msgid "raster, imagery"
+msgstr "rastr, obrazová data"
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:3
+msgid "use transformation rules for LANDSAT-4"
+msgstr "pou¾ít transformaèní pravidla pro LANDSAT-4"
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:4
+msgid "use transformation rules for LANDSAT-5"
+msgstr "pou¾ít pravidla transformace pro LANDSAT-5"
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:5
+msgid "use transformation rules for LANDSAT-7"
+msgstr "pou¾ít pravidla transformace pro LANDSAT-7"
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:6
+msgid "raster input map (LANDSAT channel 1)"
+msgstr "vstupní rastrová mapa (LANDSAT kanál 1)"
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:7
+msgid "raster input map (LANDSAT channel 2)"
+msgstr "vstupní rastrová mapa (LANDSAT kanál 2)"
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:8
+msgid "raster input map (LANDSAT channel 3)"
+msgstr "vstupní rastrová mapa (LANDSAT kanál 3)"
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:9
+msgid "raster input map (LANDSAT channel 4)"
+msgstr "vstupní rastrová mapa (LANDSAT kanál 4)"
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:10
+msgid "raster input map (LANDSAT channel 5)"
+msgstr "vstupní rastrová mapa (LANDSAT kanál 5)"
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:11
+msgid "raster input map (LANDSAT channel 7)"
+msgstr "vstupní rastrová mapa (LANDSAT kanál 7)"
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:12
+msgid "raster output TC maps prefix"
+msgstr "pøedpona výstupního rastru TC"
+#: ../locale/scriptstrings/d.out.gpsdrive_to_translate.c:1
+msgid "Export display monitor to a GpsDrive compatible backdrop image"
+msgstr "Exportuj monitor do souboru kompatibilním s GpsDrive"
+#: ../locale/scriptstrings/d.out.gpsdrive_to_translate.c:2
+msgid "display, export, GPS"
+msgstr "zobrazení, export, GPS"
+#: ../locale/scriptstrings/d.out.gpsdrive_to_translate.c:3
+msgid "name for new map image (lives in ~/.gpsdrive)"
+msgstr "jméno nového obrázku (bude ulo¾en do ~/.gpsdrive)"
+#: ../locale/scriptstrings/d.out.gpsdrive_to_translate.c:4
+msgid "Make JPEG instead of PNG image"
+msgstr "Vytvoø JPEG místo PNG"
+#: ../locale/scriptstrings/d.shadedmap_to_translate.c:1
+msgid "Drapes a color raster over a shaded relief map using d.his"
+msgstr "Pøekrýt barevnou rastrovou mapy pøes stínovaný reliéf s pou¾itím d.his"
+#: ../locale/scriptstrings/d.shadedmap_to_translate.c:2
+msgid "Name of shaded relief or aspect map"
+msgstr "Jméno mapy stínovaného reliéfu nebo expozice"
+#: ../locale/scriptstrings/d.shadedmap_to_translate.c:3
+msgid "Name of raster to drape over relief map"
+msgstr "Jméno rastru pro pøeta¾ení pøes mapu reliéfu"
+#: ../locale/scriptstrings/d.shadedmap_to_translate.c:4
+msgid "Percent to brighten"
+msgstr "Procenta zesvìtlení"
#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:1
msgid "Calculate new raster map from a r.mapcalc expression."
msgstr "Poèítá novou mapu z výrazu pro r.mapcalc."
@@ -2905,152 +1682,10 @@
msgid "F"
msgstr "F"
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:8
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:8
-msgid "Formula (e.g. A-B or A*C+B)"
-msgstr "Vzorec (napø. A-B nebo A*C+B)"
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:10
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:10
-msgid "Show help"
-msgstr "Zobraz nápovìdu"
#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:11
msgid "Expert mode (enter a set of r.mapcalc expressions)"
msgstr "Expertní mód (zadejte soubor výrazù pro r.mapcalc)"
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:12
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:12
-msgid "Do not overwrite existing map"
-msgstr "Nepøepisuj existující mapu"
-#: ../locale/scriptstrings/r.mask_to_translate.c:1
-msgid "Create a MASK for limiting raster operation"
-msgstr "Vytvoø MASKu pro limitní rastrové operace"
-#: ../locale/scriptstrings/r.mask_to_translate.c:2
-msgid "raster, mask"
-msgstr "rastr, maska"
-#: ../locale/scriptstrings/r.mask_to_translate.c:3
-msgid "Raster map to use as MASK"
-msgstr "Rastrová mapa pou¾itá jako MASKa"
-#: ../locale/scriptstrings/r.mask_to_translate.c:4
-msgid "Category values to use for MASK (format: 1 2 3 thru 7 *)"
-msgstr "Hodnoty kategorií pou¾itých jako maska (MASK) (formát: 1 2 3 thru 7 *)"
-#: ../locale/scriptstrings/r.mask_to_translate.c:5
-msgid "Create inverse MASK from specified 'maskcats' list"
-msgstr "Vytvoøit inverzní MASKU z daného seznamu 'maskcats' "
-#: ../locale/scriptstrings/r.mask_to_translate.c:6
-msgid "Overwrite existing MASK"
-msgstr "Pøepi¹ existující MASKu"
-#: ../locale/scriptstrings/r.mask_to_translate.c:7
-msgid "Remove existing MASK (overrides other options)"
-msgstr "Vymazávám existující MASKu (jiné volby budou ignorovány)"
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:1
-msgid "Exports GRASS raster into GDAL supported formats."
-msgstr ""
-"Exportuje GRASS rastry do jednoho z formátù podporovaných knihovnou GDAL."
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:2
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:2
-#: ../raster/r.out.ascii/main.c:60 ../raster/r.out.gdal/main.c:375
-#: ../raster/r.out.mat/main.c:61 ../raster/r.out.ppm/main.c:52
-#: ../raster/r.out.tiff/r.out.tiff.c:100
-msgid "raster, export"
-msgstr "rastr, export"
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:3
-#: ../raster/r.out.gdal/main.c:379
-msgid "List supported output formats"
-msgstr "Seznam podporovaných výstupních formátù"
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:4
-msgid "Region sensitive output"
-msgstr "Výstup s ohledem na region"
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:6
-#: ../raster/r.out.gdal/main.c:391
-msgid "GIS format to write (case sensitive, see also -l flag)"
-msgstr "Formát souboru (na velikosti písmen zále¾í, viz také pøepínaè -l)"
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:7
-#: ../raster/r.out.gdal/main.c:412
-msgid "File type"
-msgstr "Typ souboru"
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:8
-#: ../raster/r.out.mpeg/main.c:419
-msgid "Name for output file"
-msgstr "Název výstupního souboru"
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:9
-msgid ""
-"Creation option to the output format driver. Multiple options may be listed"
-msgstr "Volby pro ovladaè výstupního formátu. Volby je mo¾no kombinovat."
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:10
-#: ../raster/r.out.gdal/main.c:434
-msgid "Metadata key passed on the output dataset if possible"
-msgstr "Pokud je to mo¾né, pøedat na výstup klíè metadat"
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:1
-msgid ""
-"Export a raster map to a text file as x,y,z values based on cell centers."
-msgstr ""
-"Exportuje rastrovou mapu do textového souboru jako hodnoty x,y,z dle støedù "
-"bunìk."
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:4
-msgid "Name for output file (if omitted or \"-\" output to stdout)"
-msgstr "Název výstupní mapy (pro standardní výstup pou¾ijte \"-\")"
-#: ../locale/scriptstrings/r.plane_to_translate.c:1
-msgid ""
-"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
-"point."
-msgstr ""
-"Vytvoøí rastrovou mapu plochy pøi zadání ponoru (sklonu), expozice (azimut) "
-"a jednoho bodu."
-#: ../locale/scriptstrings/r.plane_to_translate.c:2
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:2
-msgid "raster, elevation"
-msgstr "rastr, elevace"
-#: ../locale/scriptstrings/r.plane_to_translate.c:3
-msgid "Name of raster plane to be created"
-msgstr "Jméno rastru plochy, který má být vytvoøen"
-#: ../locale/scriptstrings/r.plane_to_translate.c:4
-msgid "Dip of plane. Value must be between -90 and 90 degrees"
-msgstr "Spád plochy. Hodnota musí být mezi -90 a 90 stupni"
-#: ../locale/scriptstrings/r.plane_to_translate.c:5
-msgid "Azimuth of the plane. Value must be between 0 and 360 degrees"
-msgstr "Úhel plochy. Hodnota musí být mezi 0 a 360 stupni"
-#: ../locale/scriptstrings/r.plane_to_translate.c:6
-msgid "Easting coordinate of a point on the plane"
-msgstr "Souøadnice x bodu na plo¹e"
-#: ../locale/scriptstrings/r.plane_to_translate.c:7
-msgid "Northing coordinate of a point on the plane"
-msgstr "Souøadnice y bodu na plo¹e"
-#: ../locale/scriptstrings/r.plane_to_translate.c:8
-msgid "Elevation coordinate of a point on the plane"
-msgstr "Souøadnice z bodu na plo¹e"
-#: ../locale/scriptstrings/r.plane_to_translate.c:9
-msgid "Type of the raster map to be created"
-msgstr "Typ rastru, který bude vytvoøen"
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:1
msgid ""
"Reclasses a raster map greater or less than user specified area size (in "
@@ -3075,386 +1710,142 @@
msgid "reclass raster output map"
msgstr "reklasifikovaná výstupní mapa"
-#: ../locale/scriptstrings/r.regression.line_to_translate.c:1
-msgid "Calculates linear regression from two raster maps: y = a + b*x"
-msgstr "Poèítá lineární regresi pro dvì rastrové mapy: y = a + b*x"
-#: ../locale/scriptstrings/r.regression.line_to_translate.c:2
-#: ../locale/scriptstrings/r.univar.sh_to_translate.c:2
-#: ../raster/r.statistics/main.c:41 ../raster/r.report/main.c:27
-#: ../raster/r.univar2/r.univar_main.c:77
-msgid "raster, statistics"
-msgstr "rastr, statistika"
-#: ../locale/scriptstrings/r.regression.line_to_translate.c:4
-msgid "Map for x coefficient"
-msgstr "Mapa koeficientu x"
-#: ../locale/scriptstrings/r.regression.line_to_translate.c:5
-msgid "Map for y coefficient"
-msgstr "Mapa koeficientu y"
-#: ../locale/scriptstrings/r.regression.line_to_translate.c:6
+#: ../locale/scriptstrings/v.db.update_to_translate.c:1
msgid ""
-"ASCII file for storing regression coefficients (output to screen if file not "
-"specified)."
+"Allows to update a column in the attribute table connected to a vector map."
msgstr ""
-"Soubor ASCII, kam se mají ulo¾it koeficienty regrese (výstup na obrazovku, "
-"pokud není zadán)."
+"Umo¾ní pøiøadit novou hodnotu sloupci v atributové tabulce pøipojené k "
+"zadané mapì."
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:1
-msgid "Creates shaded relief map from an elevation map (DEM)."
-msgstr "Vytvoøí mapu stínovaného reliéfu ze vstupní mapy elevace (DMT)."
+#: ../locale/scriptstrings/v.db.update_to_translate.c:3
+msgid "Vector map to edit the attribute table for"
+msgstr "Vektorová mapa, její¾ atributová tabulka má být editována"
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:3
-#: ../raster/r.topidx/main.c:42
-msgid "Input elevation map"
-msgstr "Vstupní mapa elevace."
+#: ../locale/scriptstrings/v.db.update_to_translate.c:5
+msgid "Column to update"
+msgstr "Sloupeèek, který má být aktualizován"
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:4
-msgid "Output shaded relief map name"
-msgstr "Výstupní mapa stínovaného reliéfu"
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:5
-msgid "Altitude of the sun in degrees above the horizon"
-msgstr "Vý¹ka slunce ve stupních nad horizontem"
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:6
-msgid "Azimuth of the sun in degrees to the east of north"
-msgstr "Azimut slunce ve stupních od serveru (k východu)"
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:7
-msgid "Factor for exaggerating relief"
-msgstr "Faktor zvýraznìní reliéfu"
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:8
-msgid "Scale factor for converting horizontal units to elevation units"
+#: ../locale/scriptstrings/v.db.update_to_translate.c:6
+msgid ""
+"Value to update the column with (varchar values have to be in single quotes, "
+"e.g. 'grass')"
msgstr ""
-"Mìøítkový faktor pro pøevod horizontálních jednotek na jednotky elevace "
+"Nová hodnota, která bude pøiøazena do sloupeèku (textové øetìzce misí být "
+"'uvozeny')"
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:9
-msgid "Set scaling factor (applies to lat./long. locations only)"
-msgstr "Nastav mìøítkový faktor (bude pou¾ito pouze na location lat/long)"
+#: ../locale/scriptstrings/v.db.update_to_translate.c:7
+msgid "Column to query"
+msgstr "Sloupeèek, jeho¾ hodnoty mají být zji¹tìny"
+#: ../locale/scriptstrings/v.db.update_to_translate.c:8
msgid ""
-"Produces tilings of the source projection for use in the destination region "
-"and projection."
+"WHERE conditions for update, without 'where' keyword (e.g. cat=1 or col1/"
+"col2>1)"
msgstr ""
-"Vytvoøí dla¾dice zdrojové projekce pro pou¾ití v cílovém regionu a projekci."
+"Podmínka SQL WHERE ov¹em bez slova 'where' (napø. 'cat=1' nebo 'sloup1/"
+"sloup2>1')"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:2
-msgid "raster, tiling"
-msgstr "rastr, dla¾dice"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:3
-msgid "Produces shell script output"
-msgstr "Výstup ve formátu pro shell skript"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:4
-msgid "Produces web map server query string output"
-msgstr "Vytvoøí øetìzec urèený pro mapový server"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:5
-msgid ""
-"Name of region to use instead of current region for bounds and resolution"
+#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:1
+msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
msgstr ""
-"Jméno regionu pou¾itého místo aktuálního regionu pro okraje a rozli¹ení"
+"Vytvoøí mozaiku ze 4 a více snmkù, roztáhne barevnou paletu a vytvoøí mapu *."
+"mosaic"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:6
-msgid "Source projection"
-msgstr "Zdrojová projekce"
+#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:2
+msgid "raster, imagery, mosaicking"
+msgstr "rastr, dpz, mozaikování"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:7
-#: ../locale/scriptstrings/r.tileset_to_translate.c:9
-msgid "Conversion factor from units to meters in source projection"
-msgstr "Pøevodní faktor z jednotek na metry ve zdrojové projekci"
+#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:3
+msgid "1st map for mosaic (top of image stack)."
+msgstr "První mapa pro mozaiku (v seznamu mozaiky zcela nahoøe)"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:8
-msgid "Destination projection, defaults to this location's projection"
-msgstr "Cílová projekce, výchozí je projekce aktuální location"
+#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:4
+msgid "2nd map for mosaic."
+msgstr "druhá mapa mozaiky"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:10
-msgid "Maximum number of columns for a tile in the source projection"
-msgstr "Maximální poèet sloupcù dla¾dic ve vstupní projekci"
+#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:5
+msgid "3rd map for mosaic."
+msgstr "tøetí mapa mozaiky"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:11
-msgid "Maximum number of rows for a tile in the source projection"
-msgstr "Maximální poèet øádkù pro dla¾dice ve zdrojové projekci"
+#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:6
+msgid "4th map for mosaic."
+msgstr "ètvrtá mapa mozaiky"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:12
-msgid "Number of cells tiles should overlap in each direction"
-msgstr "Poèet dla¾dic by mìl být stejný v obou smìrech"
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:1
+msgid "Exports attribute tables into various formats."
+msgstr "Exportuje atributové tabulky v rùzných formátech."
-#: ../locale/scriptstrings/r.tileset_to_translate.c:13
-msgid "Output field seperator"
-msgstr "Výstupní oddìlovaè"
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:3
+msgid "GRASS table name"
+msgstr "Jméno vstupní tabulky GRASS"
-#: ../locale/scriptstrings/r.univar.sh_to_translate.c:1
-msgid "calculates univariate statistics from a GRASS raster map"
-msgstr "Spoèítá základní statistiku z GRASS rastrové mapy."
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:4
+msgid "Table file to be exported or DB connection string"
+msgstr "Tabulka pro export nebo textový øetìzec databázového spojení"
-#: ../locale/scriptstrings/r.univar.sh_to_translate.c:3
-msgid "extended statistics (quartiles and percentile)"
-msgstr "roz¹íøená statistika (kvartily a percentily)"
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:5
+msgid "Table format"
+msgstr "Formát tabulky"
-#: ../locale/scriptstrings/r.univar.sh_to_translate.c:4
-#: ../display/d.legend/main.c:92 ../display/d.zoom/main.c:92
-msgid "Name of raster map"
-msgstr "Název rastrové mapy"
+#: ../locale/scriptstrings/v.report_to_translate.c:1
+msgid "Reports geometry statistics for vectors."
+msgstr "Vypí¹e íºdaje o geometrii vektorové mapy."
-#: ../locale/scriptstrings/r.univar.sh_to_translate.c:5
-msgid "Percentile to calculate (requires -e flag)"
-msgstr "Percentil, který se má spoèítat (vy¾aduje pøepínaè -e)"
+#: ../locale/scriptstrings/v.report_to_translate.c:2
+msgid "vector, report, statistics"
+msgstr "vektor, zpráva, statistika"
-msgid "Calculates new grid3D volume from r3.mapcalc expression."
-msgstr "Tvorba nové grid3d volume mapy na základì výrazu pro r3.mapcalc."
+#: ../locale/scriptstrings/v.report_to_translate.c:3
+msgid "Reverse sort the result"
+msgstr "Obrácené øazení výsledkù"
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:2
-msgid "A (grid3D file)"
-msgstr "A (soubor grid3D)"
+#: ../locale/scriptstrings/v.report_to_translate.c:4
+msgid "Sort the result"
+msgstr "Seøadit výsledky"
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:3
-msgid "B (grid3D file)"
-msgstr "B (soubor grid3D)"
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:4
-msgid "C (grid3D file)"
-msgstr "C (soubor grid3D)"
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:5
-msgid "D (grid3D file)"
-msgstr "D (soubor grid3D)"
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:6
-msgid "E (grid3D file)"
-msgstr "E (soubor grid3D)"
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:7
-msgid "F (grid3D file)"
-msgstr "F (soubor grid3D)"
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:9
-msgid "Name for output grid3D volume"
-msgstr "Název výstupního souboru grid3D objem"
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:11
-msgid "Expert mode (enter a set of r3.mapcalc expressions)"
-msgstr "Expertní mód (zadejte soubor výrazù pro r3.mapcalc)"
-#: ../locale/scriptstrings/v.build.all_to_translate.c:1
-msgid "Rebuilds topology on all vector maps in the current mapset."
-msgstr "Pøebuduje topologii v¹ech vektorových map v aktuálním mapsetu."
-#: ../locale/scriptstrings/v.build.all_to_translate.c:2
-#: ../vector/v.external/main.c:58 ../vector/v.perturb/main.c:73
-#: ../vector/v.out.ascii/out.c:43 ../vector/v.sample/main.c:86
-#: ../vector/v.in.region/main.c:38 ../vector/v.info/main.c:63
-#: ../vector/v.info/main.c:227 ../vector/v.patch/main.c:68
-#: ../vector/v.vol.rst/main.c:201 ../vector/v.mkgrid/main.c:62
-#: ../vector/v.category/main.c:66 ../vector/v.clean/test/topocheck.c:40
-#: ../vector/v.voronoi/dt_main.c:44 ../vector/v.voronoi/vo_main.c:107
-#: ../vector/v.out.vtk/main.c:45 ../vector/v.select/main.c:129
-#: ../vector/v.surf.rst/main.c:159 ../vector/v.buffer/main.c:245
-#: ../vector/v.extract/main.c:73
-msgid "vector"
-msgstr "vektor"
-#: ../locale/scriptstrings/v.centroids_to_translate.c:1
-msgid "Adds missing centroids to closed boundaries."
-msgstr "K uzavøeným hranicím pøidá chybìjící centroidy."
-#: ../locale/scriptstrings/v.centroids_to_translate.c:2
-msgid "vector, centroid, area"
-msgstr "vektor, centroid, plocha"
-#: ../locale/scriptstrings/v.centroids_to_translate.c:3
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:3
-#: ../locale/scriptstrings/v.report_to_translate.c:5
-msgid "Name of input vector map"
-msgstr "Název vstupní vektorové vrstvy"
-#: ../locale/scriptstrings/v.centroids_to_translate.c:4
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:4
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:6
-#: ../locale/scriptstrings/v.in.gns_to_translate.c:4
-msgid "Name for output vector map"
-msgstr "Název výstupní vektorové vrstvy"
-#: ../locale/scriptstrings/v.centroids_to_translate.c:5
-msgid "Action to be taken"
-msgstr "Akce, mající být vykonána"
+#: ../locale/scriptstrings/v.report_to_translate.c:6
#: ../locale/scriptstrings/v.centroids_to_translate.c:6
-#: ../locale/scriptstrings/v.report_to_translate.c:6
#: ../vector/v.out.vtk/main.c:82
msgid "Layer number"
msgstr "Èíslo vrstvy"
-#: ../locale/scriptstrings/v.centroids_to_translate.c:7
-msgid "Category number starting value"
-msgstr "Poèáteèní hodnota kategorií"
+#: ../locale/scriptstrings/v.report_to_translate.c:7
+msgid "Value to calculate"
+msgstr "Hodnota, která se má spoèítat"
-#: ../locale/scriptstrings/v.centroids_to_translate.c:8
-#: ../vector/v.category/main.c:103
-msgid "Category increment"
-msgstr "Zvìt¹ení hodnoty kategorií o"
-#: ../locale/scriptstrings/v.convert.all_to_translate.c:1
-msgid ""
-"Convert all old GRASS < Ver5.7 vector maps in current mapset to current "
-"format"
+#: ../locale/scriptstrings/v.report_to_translate.c:8
+msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
msgstr ""
-"Pøevede v¹echny staré vektorové mapy (GRASS < 5.7) do aktuálního mapsetu v "
-"aktuálním formátu"
+"mi(míle),f(stopy),me(metry),k(kilometery),a(akry),h(hektary),p(procenta)"
-#: ../locale/scriptstrings/v.convert.all_to_translate.c:2
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:2
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:2
-#: ../vector/v.in.dxf/main.c:60 ../vector/v.in.ascii/in.c:48
-#: ../vector/v.in.ogr/main.c:98 ../vector/v.in.sites/main.c:56
-#: ../vector/v.in.dwg/main.c:66 ../vector/v.in.db/main.c:51
-msgid "vector, import"
-msgstr "vektor, import"
-#: ../locale/scriptstrings/v.convert.all_to_translate.c:3
-msgid "run non-interactively"
-msgstr "spustit neinteraktivnì"
-#: ../locale/scriptstrings/v.db.addcol_to_translate.c:1
+#: ../locale/scriptstrings/d.split_to_translate.c:1
msgid ""
-"Adds one or more columns to the attribute table connected to a given vector "
-"map."
+"Divides active display into two frames & displays maps/executes commands in "
+"each frame."
msgstr ""
-"Pøidává jeden nebo více sloupeèkù k atributové tabulce pøipojené k zadané "
-"vektorové mapì."
+"Rozdìlí aktivní monitor na dva rámy a v ka¾dém rámu zobrazí mapu a pøíkaz "
+"pro její vytvoøení."
-#: ../locale/scriptstrings/v.db.addcol_to_translate.c:2
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:2
-#: ../locale/scriptstrings/v.db.join_to_translate.c:2
-#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:2
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:2
-#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:2
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:2
-#: ../locale/scriptstrings/v.db.update_to_translate.c:2
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:2
-#: ../vector/v.db.connect/main.c:48 ../vector/v.distance/main.c:109
-#: ../vector/v.db.select/main.c:46 ../vector/v.to.db/main.c:32
-msgid "vector, database, attribute table"
-msgstr "vektor, databáze, tabulka atributù"
+#: ../locale/scriptstrings/d.split_to_translate.c:3
+msgid "Enter raster map to display in 1st frame"
+msgstr "Rastrová mapa, která má být zobrazena v první rámu"
-#: ../locale/scriptstrings/v.db.addcol_to_translate.c:3
-msgid "Vector map for which to edit attribute table"
-msgstr "Vektorová mapa, její¾ atributová tabulka má být editována"
+#: ../locale/scriptstrings/d.split_to_translate.c:4
+msgid "Enter command to execute in 1st frame"
+msgstr "Vlo¾te pøíkaz pro vykonání v první rámu"
-#: ../locale/scriptstrings/v.db.addcol_to_translate.c:4
-msgid "Layer where to add column"
-msgstr "Vrstva, kam pøidat sloupec"
+#: ../locale/scriptstrings/d.split_to_translate.c:5
+msgid "Enter raster map to display in 2nd frame"
+msgstr "Rastrová mapa, která má být zobrazena v druhém rámu"
-#: ../locale/scriptstrings/v.db.addcol_to_translate.c:5
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:6
-msgid ""
-"Name and type of the new column(s) (types depend on database backend, but "
-"all support VARCHAR(), INT, DOUBLE and DATE)"
-msgstr ""
-"Jména a typ nového(ých) sloupeèku(ù) (typ závisí na pou¾ité databázi, ale "
-"v¹echny podporují VARCHAR(), INT, DOUBLE a DATE)"
+#: ../locale/scriptstrings/d.split_to_translate.c:6
+msgid "Enter command to execute in 2nd frame"
+msgstr "Vlo¾te pøíkaz pro vykonání v druhém rámu"
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:1
-msgid ""
-"Creates and adds a new attribute table to a given layer of an existing "
-"vector map."
-msgstr ""
-"Vytvoøí a pøidá novou atributovou tabulku k zadané vrstvì existující "
-"vektorové mapy."
+#: ../locale/scriptstrings/d.split_to_translate.c:7
+msgid "How to split display"
+msgstr "Jak rozdìlit monitor"
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:3
-msgid "Vector map for which to add new attribute table"
-msgstr "Vektorová mapa pro kterou bude pøidána nová atributová tabulka"
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:4
-msgid "Name of new attribute table (default: vector map name)"
-msgstr "Jméno nové atributové tabulky (výchozí: jméno mapy)"
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:5
-msgid "Layer where to add new attribute table"
-msgstr "Vrstva, kam bude pøidána nová atributová tabulka"
-#: ../locale/scriptstrings/v.db.join_to_translate.c:1
-msgid "Allows to join a table to a vector map table."
-msgstr "Umo¾ní spojení tabulky s tabulkou pøipojenou k vektorové mapì."
-#: ../locale/scriptstrings/v.db.join_to_translate.c:3
-msgid "Vector map to which to join other table"
-msgstr "Vektorová mapa, k její¾ tabulce bude pøipojena tabulka nová"
-#: ../locale/scriptstrings/v.db.join_to_translate.c:4
-msgid "Layer where to join"
-msgstr "Vrstva, na které dojde ke spojení"
-#: ../locale/scriptstrings/v.db.join_to_translate.c:5
-msgid "Join column in map table"
-msgstr "Sloupec atributové tabulky mapy, pøes který do jde ke spojení"
-#: ../locale/scriptstrings/v.db.join_to_translate.c:6
-msgid "Other table name"
-msgstr "Jméno pøipojované tabulky"
-#: ../locale/scriptstrings/v.db.join_to_translate.c:7
-msgid "Join column in other table"
-msgstr "Sloupec pøipojované tabulky"
-#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:1
-msgid ""
-"Drops a column from the attribute table connected to a given vector map."
-msgstr "Ma¾e sloupce z tabulky atributù pøipojené k zadané vektorové mapì."
-#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:3
-msgid "Vector map for which to drop attribute column"
-msgstr "Vektorová mapa, v její¾ atributové tabulce bude sloupec smazán"
-#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:4
-msgid "Layer where to drop column"
-msgstr "Vrstva, odkud smazat sloupec"
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:1
-msgid "Removes existing attribute table of a vector map."
-msgstr "Vyma¾e existující atributovou tabulku vektorové mapy."
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:3
-msgid "Force removal (required for actual deletion of table)"
-msgstr "Vynucené odstranìní ( po¾adováno pro souèasné mazání tabulek)"
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:4
-msgid "Vector map from which to remove attribute table"
-msgstr "Vektorová mapa, ze které má být odstranìna atributová tabulka."
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:5
-msgid "Name of existing attribute table (default: vector map name)"
-msgstr "Jméno existující atributové tabulky (výchozí: jméno vektorové mapy)"
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:6
-msgid "Layer from which to drop linked attribute table"
-msgstr "Vrstva, z ní¾ má být odstranìno spojení s tabulkou"
-#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:1
-msgid "Renames a column in a attribute table connected to a given vector map."
-msgstr ""
-"Pøejmenuje sloupec v atributové tabulce pøipojené k zadané vektorové mapì."
-#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:3
-msgid "Vector map for which to rename attribute column"
-msgstr "Vektorová mapa, v její¾ atributové tabulce bude sloupec pøejmenován"
-#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:4
-msgid "Layer where to rename column"
-msgstr "Vrstva, ve které bude sloupec pøejmenován"
-#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:5
-msgid "Old and new name of the column (old,new)"
-msgstr "Staré a nové jméno slupce (staré,nové)"
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:1
msgid "Reconnects vectors to a new database."
msgstr "Znovu pøipojí vektory k nové databázi."
@@ -3479,195 +1870,223 @@
msgid "New schema"
msgstr "Nové schéma"
+#: ../locale/scriptstrings/d.correlate_to_translate.c:1
+msgid "prints a graph of the correlation between data layers (in pairs)"
+msgstr "vytiskne graf korelace mezi datovými vrstvami (v párech)"
+#: ../locale/scriptstrings/d.redraw_to_translate.c:1
+msgid "Redraws the current display frame in the GRASS monitor"
+msgstr "Pøekreslí aktuálnì zobrazené mapy v monitoru"
+#: ../locale/scriptstrings/d.redraw_to_translate.c:3
+msgid "Redraw all frames"
+msgstr "Pøekreslit v¹echny rámy"
+#: ../locale/scriptstrings/d.redraw_to_translate.c:4
+msgid "Do not preserve individual regions when redrawing all frames"
+msgstr "Nedor¾ovat individuální regiony pokud pøekraslují v¹echny rámy"
+#: ../locale/scriptstrings/v.univar.sh_to_translate.c:1
#: ../locale/scriptstrings/v.db.univar_to_translate.c:1
-#: ../locale/scriptstrings/v.univar.sh_to_translate.c:1
msgid ""
"Calculates univariate statistics on selected table column for a GRASS vector "
"map."
msgstr "Spoèítá základní statistiku vybraného sloupce tabulky vektorové mapy."
+#: ../locale/scriptstrings/v.univar.sh_to_translate.c:2
#: ../locale/scriptstrings/v.db.univar_to_translate.c:2
-#: ../locale/scriptstrings/v.univar.sh_to_translate.c:2
-#: ../vector/lidar/v.outlier/main.c:68 ../vector/v.univar/main.c:60
-#: ../vector/v.qcount/main.c:68 ../vector/v.random/main.c:77
-#: ../vector/v.kcv/main.c:76 ../vector/v.normal/main.c:78
+#: ../vector/v.normal/main.c:78 ../vector/v.random/main.c:77
+#: ../vector/lidar/v.outlier/main.c:68 ../vector/v.qcount/main.c:68
+#: ../vector/v.univar/main.c:60 ../vector/v.kcv/main.c:76
+#: ../vector/v.class/main.c:45
msgid "vector, statistics"
msgstr "vektor, statistika"
+#: ../locale/scriptstrings/v.univar.sh_to_translate.c:3
#: ../locale/scriptstrings/v.db.univar_to_translate.c:3
-#: ../locale/scriptstrings/v.univar.sh_to_translate.c:3
msgid "Extended statistics (quartiles and 90th percentile)"
msgstr "Roz¹íøený výstup (kvartily a 90-té procentily)"
+#: ../locale/scriptstrings/v.univar.sh_to_translate.c:4
#: ../locale/scriptstrings/v.db.univar_to_translate.c:4
-#: ../locale/scriptstrings/v.univar.sh_to_translate.c:4
msgid "Name of data table"
msgstr "Jméno tabulky"
+#: ../locale/scriptstrings/v.univar.sh_to_translate.c:5
#: ../locale/scriptstrings/v.db.univar_to_translate.c:5
-#: ../locale/scriptstrings/v.univar.sh_to_translate.c:5
msgid "Column on which to calculate statistics (must be numeric)"
msgstr "Sloupec na kterém se bude poèítat statistika (musí být èíselného typu)"
+#: ../locale/scriptstrings/v.univar.sh_to_translate.c:6
#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
-#: ../locale/scriptstrings/v.univar.sh_to_translate.c:6
msgid "Database/directory for table"
msgstr "Databáze nebo adresáø s tabulkou"
+#: ../locale/scriptstrings/v.univar.sh_to_translate.c:7
#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
-#: ../locale/scriptstrings/v.univar.sh_to_translate.c:7
msgid "Database driver"
msgstr "Ovladaè databáze"
-#: ../locale/scriptstrings/v.db.update_to_translate.c:1
+#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:1
msgid ""
-"Allows to update a column in the attribute table connected to a vector map."
+"Renames a column in the attribute table connected to a given vector map."
msgstr ""
-"Umo¾ní pøiøadit novou hodnotu sloupci v atributové tabulce pøipojené k "
-"zadané mapì."
+"Pøejmenuje sloupec v atributové tabulce pøipojené k zadané vektorové mapì."
-#: ../locale/scriptstrings/v.db.update_to_translate.c:3
-msgid "Vector map to edit the attribute table for"
+#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:3
+msgid "Vector map for which to rename attribute column"
+msgstr "Vektorová mapa, v její¾ atributové tabulce bude sloupec pøejmenován"
-#: ../locale/scriptstrings/v.db.update_to_translate.c:4
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:6
-msgid "Layer to which the table to be changed is connected"
-msgstr "Vrstva ke které je zmìnìná tabulka pøipojena"
+#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:4
+msgid "Layer where to rename column"
+msgstr "Vrstva, ve které bude sloupec pøejmenován"
-#: ../locale/scriptstrings/v.db.update_to_translate.c:5
-msgid "Column to update"
-msgstr "Sloupeèek, který má být aktualizován"
+#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:5
+msgid "Old and new name of the column (old,new)"
+msgstr "Staré a nové jméno slupce (staré,nové)"
-#: ../locale/scriptstrings/v.db.update_to_translate.c:6
-msgid ""
-"Value to update the column with (varchar values have to be in single quotes, "
-"e.g. 'grass')"
-msgstr ""
-"Nová hodnota, která bude pøiøazena do sloupeèku (textové øetìzce misí být "
-"'uvozeny')"
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:1
+msgid "Import Mapgen or Matlab vector maps into GRASS."
+msgstr "Importuje vektory ve formátu Mapgen nebo Matlab do GRASSu"
-#: ../locale/scriptstrings/v.db.update_to_translate.c:7
-msgid "Column to query"
-msgstr "Sloupeèek, jeho¾ hodnoty mají být zji¹tìny"
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:2
+#: ../locale/scriptstrings/v.in.e00_to_translate.c:2
+#: ../locale/scriptstrings/v.convert.all_to_translate.c:2
+#: ../vector/v.in.ascii/in.c:48 ../vector/v.in.sites/main.c:56
+#: ../vector/v.in.dxf/main.c:60 ../vector/v.in.db/main.c:51
+#: ../vector/v.in.ogr/main.c:98 ../vector/v.in.dwg/main.c:66
+msgid "vector, import"
+msgstr "vektor, import"
-#: ../locale/scriptstrings/v.db.update_to_translate.c:8
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:3
+msgid "Input map is in Matlab format"
+msgstr "Vstupní mapa je ve formátu Matlab"
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:4
+msgid "Create a 3D vector points map from 3 column Matlab data"
+msgstr "Vytvoøí 3D vektorovou bodovou mapu ze tøí sloupcových dat Matlab"
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:5
+msgid "Name of input file in Mapgen/Matlab format"
+msgstr "Jméno vstupního souboru ve formátu Mapgen/Matlab"
+#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:1
msgid ""
-"WHERE conditions for update, without 'where' keyword (e.g. cat=1 or col1/"
-"col2>1)"
+"Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps."
msgstr ""
-"Podmínka SQL WHERE ov¹em bez slova 'where' (napø. 'cat=1' nebo 'sloup1/"
-"sloup2>1')"
+"Pøevede v¹echny staré vektorové mapy (GRASS < 5.7) v bodovém forátu (sites) "
+"na vektorovou mapu."
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:1
-msgid ""
-"Dissolves boundaries between adjacent areas sharing a common category number "
-"or attribute."
+#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:2
+msgid "sites, vector, import"
+msgstr "body, vektor, import"
+#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:3
+msgid "Run non-interactively"
+msgstr "Spustit neinteraktivnì"
+#: ../locale/scriptstrings/r.regression.line_to_translate.c:1
+msgid "Calculates linear regression from two raster maps: y = a + b*x"
+msgstr "Poèítá lineární regresi pro dvì rastrové mapy: y = a + b*x"
+#: ../locale/scriptstrings/r.regression.line_to_translate.c:4
+msgid "Slower but accurate (applies to FP maps only)"
msgstr ""
-"Rozlo¾í hranice mezi sousedícími plochami, sdílejícími spoleèné èíslo "
-"kategorie nebo atribut."
+"Pomalej¹í, ale pøesnìj¹í (pou¾itelné pouze pro mapy s desetinným èíslem)"
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:2
-msgid "vector, area, dissolve"
-msgstr "vektor, plocha, spojení"
+#: ../locale/scriptstrings/r.regression.line_to_translate.c:5
+msgid "Map for x coefficient"
+msgstr "Mapa koeficientu x"
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:5
-msgid "Layer number. If -1, all layers are extracted"
-msgstr "Èíslo vrstvy. Pokud -1, jsou vyjmuty v¹echny vrstvy"
+#: ../locale/scriptstrings/r.regression.line_to_translate.c:6
+msgid "Map for y coefficient"
+msgstr "Mapa koeficientu y"
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:6
-msgid "Name of column used to dissolve common boundaries"
-msgstr "Název sloupce atributu, který má být pou¾it pøi mazání hranic"
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:1
+#: ../locale/scriptstrings/r.regression.line_to_translate.c:7
msgid ""
-"Download waypoints, routes, and tracks from a Garmin GPS receiver into a "
-"vector map."
+"ASCII file for storing regression coefficients (output to screen if file not "
+"specified)."
msgstr ""
-"Ulo¾ Waypoints, Routes a Tracks z pøístroje GPS Garmin jako vektorovou mapu."
+"Soubor ASCII, kam se mají ulo¾it koeficienty regrese (výstup na obrazovku, "
+"pokud není zadán)."
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:2
-#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:2
-msgid "vector, import, GPS"
-msgstr "vektor, import, GPS"
+#: ../locale/scriptstrings/d.mvmon_to_translate.c:1
+msgid "Moves displayed maps to another monitor"
+msgstr "Pøesune aktuálnì zobrazené mapy do jiného monitoru"
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:3
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:3
-#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:3
-#: ../raster/r.out.mat/main.c:79 ../raster/r.in.mat/main.c:116
-#: ../raster/r.out.tiff/r.out.tiff.c:137
-msgid "Verbose mode"
-msgstr "Roz¹íøený mód"
+#: ../locale/scriptstrings/d.mvmon_to_translate.c:3
+msgid "clear target monitor before moving"
+msgstr "Vyèisti cílový monitor pøed pøesunem"
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:4
-msgid "Download Waypoints from GPS"
-msgstr "Stáhni Waypoints z GPSky"
+#: ../locale/scriptstrings/d.mvmon_to_translate.c:4
+msgid "stay with source monitor"
+msgstr "zùstaò ve zdrojovém monitoru"
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:5
-msgid "Download Routes from GPS"
-msgstr "Stáhni Routes z GPSky"
+#: ../locale/scriptstrings/d.mvmon_to_translate.c:5
+msgid "kill source monitor after moving"
+msgstr "zab zdrojový monitor po pøesunu"
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:6
-msgid "Download Track from GPS"
-msgstr "Stáhni Tracky z GPSky"
+#: ../locale/scriptstrings/d.mvmon_to_translate.c:6
+msgid "Target monitor"
+msgstr "Cílový monitor"
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:7
-msgid "Force import of track or route data as points"
-msgstr "Importuj tracky a routy jako body"
+#: ../locale/scriptstrings/d.mvmon_to_translate.c:7
+msgid "Source monitor"
+msgstr "Zdrojový monitor"
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:8
-msgid "Use gardump instead of gpstrans as the download program"
-msgstr "Pou¾ít gardump místo gpstrans jako stahovací program"
+#: ../locale/scriptstrings/v.centroids_to_translate.c:1
+msgid "Adds missing centroids to closed boundaries."
+msgstr "K uzavøeným hranicím pøidá chybìjící centroidy."
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:9
-msgid "Import track in 3D (gardump only)"
-msgstr "Importovat stopu ve 3D ( pouze gardump)"
+#: ../locale/scriptstrings/v.centroids_to_translate.c:2
+msgid "vector, centroid, area"
+msgstr "vektor, centroid, plocha"
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:10
-#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:8
-msgid "Do not attempt projection transform from WGS84"
-msgstr "Neprovádìt pøevod projekce z WGS84"
+#: ../locale/scriptstrings/v.centroids_to_translate.c:5
+msgid "Action to be taken"
+msgstr "Akce, mající být vykonána"
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:11
-#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:10
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:6
-msgid "Name for output vector map (omit for display to stdout)"
-msgstr ""
-"Jméno nového vektorového souboru (vynechává se pro zobrazení na standardní "
-"výstup)"
+#: ../locale/scriptstrings/v.centroids_to_translate.c:7
+msgid "Category number starting value"
+msgstr "Poèáteèní hodnota kategorií"
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:12
-msgid "Port Garmin receiver is connected to"
-msgstr "Port, na kterém je Garmina pøipojena"
+#: ../locale/scriptstrings/v.centroids_to_translate.c:8
+#: ../vector/v.category/main.c:104
+msgid "Category increment"
+msgstr "Zvìt¹ení hodnoty kategorií o"
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:1
-msgid "Import E00 file into a vector map."
-msgstr "Importuje soubory ve formátu E00 jako vektorovou mapu."
+#: ../locale/scriptstrings/g.mlist_to_translate.c:1
+msgid "Apply regular expressions and wildcards to g.list"
+msgstr "Pou¾ij regulární výrazy a zástupné znaky na g.list"
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:4
-msgid "E00 file"
-msgstr "soubor E00"
+#: ../locale/scriptstrings/g.mlist_to_translate.c:4
+msgid "Print mapset name"
+msgstr "Vytiskne jméno mapsetu"
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:5
-msgid "Input type point, line or area"
-msgstr "Typ vstupu linie nebo plocha"
+#: ../locale/scriptstrings/g.mlist_to_translate.c:5
+msgid "Data type"
+msgstr "Typ dat"
-#: ../locale/scriptstrings/v.in.gns_to_translate.c:1
-msgid ""
-"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
-"points map."
-msgstr ""
-"Importuje US-NGA GEOnet jmenný server (GNS) soubory o státech do vektorové "
-"bodové mapy mapy GRASSu"
+#: ../locale/scriptstrings/g.mlist_to_translate.c:6
+msgid "Mapset(s) to list (default: current mapset search path)"
+msgstr "Mapset, ze kterého má být seznam udìlán (výchozí: aktuální)"
-#: ../locale/scriptstrings/v.in.gns_to_translate.c:2
-msgid "vector, import, gazetteer"
-msgstr "vektor, import gazetteer"
+#: ../locale/scriptstrings/g.mlist_to_translate.c:7
+msgid "Output separator (default: newline)"
+msgstr "Oddìlovaè výstupu (výchozí: øádkový zlom)"
-#: ../locale/scriptstrings/v.in.gns_to_translate.c:3
-msgid "Uncompressed GNS file from NGA (with .txt extension)"
-msgstr "Rozbalený soubor GNS z NGA (s koncovkou .txt)"
+#: ../locale/scriptstrings/g.mlist_to_translate.c:8
+msgid "Map name search pattern (default: all)"
+msgstr "Øìtìzec v názvu mapy, musí být 'uvozen' (výchozí: v¹echny)"
+#: ../locale/scriptstrings/db.dropcol_to_translate.c:1
+msgid "Drops a column from selected attribute table"
+msgstr "Sma¾e sloupeèky z vybrané atributové tabulky"
+#: ../locale/scriptstrings/db.dropcol_to_translate.c:4
+msgid "Table from which to drop attribute column"
+msgstr "Tabulka, ze které mude sloupeèek vymazán"
msgid ""
"Import waypoints, routes, and tracks from a GPS receiver or GPS download "
@@ -3707,5888 +2126,3170 @@
"Projekce vstupních dat (pou¾ijte volby PROJ.4), pokud není nastaveno, "
"pøedpokládáse, ¾e tato projekce je Lat/Long WGS84"
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:1
-msgid "Import Mapgen or Matlab vector maps into GRASS."
-msgstr "Importuje vektory ve formátu Mapgen nebo Matlab do GRASSu"
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:3
-msgid "Input map is in Matlab format"
-msgstr "Vstupní mapa je ve formátu Matlab"
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:4
-msgid "Create a 3D vector points map from 3 column Matlab data"
-msgstr "Vytvoøí 3D vektorovou bodovou mapu ze tøí sloupcových dat Matlab"
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:5
-msgid "Name of input file in Mapgen/Matlab format"
-msgstr "Jméno vstupního souboru ve formátu Mapgen/Matlab"
-#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:1
-msgid ""
-"Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps."
+#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:1
+msgid "Exports GRASS raster into GDAL supported formats."
msgstr ""
-"Pøevede v¹echny staré vektorové mapy (GRASS < 5.7) v bodovém forátu (sites) "
-"na vektorovou mapu."
+"Exportuje GRASS rastry do jednoho z formátù podporovaných knihovnou GDAL."
-#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:2
-msgid "sites, vector, import"
-msgstr "body, vektor, import"
+#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:3
+#: ../raster/r.out.gdal/main.c:379
+msgid "List supported output formats"
+msgstr "Seznam podporovaných výstupních formátù"
-#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:3
-msgid "Run non-interactively"
-msgstr "Spustit neinteraktivnì"
+#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:4
+msgid "Region sensitive output"
+msgstr "Výstup s ohledem na region"
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:1
-msgid "import GetFeature from WFS"
-msgstr "Imoprtovat GetFeature z WFS"
+#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:6
+#: ../raster/r.out.gdal/main.c:391
+msgid "GIS format to write (case sensitive, see also -l flag)"
+msgstr "Formát souboru (na velikosti písmen zále¾í, viz také pøepínaè -l)"
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:2
-msgid "GetFeature URL starting with http"
-msgstr "GetFeature startovací adresa URL s http"
+#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:7
+#: ../raster/r.out.gdal/main.c:412
+msgid "File type"
+msgstr "Typ souboru"
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:3
-msgid "Vector output map"
-msgstr "Výstupní vektorová mapa"
+#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:8
+#: ../raster/r.out.mpeg/main.c:419
+msgid "Name for output file"
+msgstr "Název výstupního souboru"
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:1
+#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:9
msgid ""
-"Calculates univariate statistics from a GRASS raster map based on vector "
-"polygons and uploads statistics to new attribute columns."
-msgstr ""
-"Spoèítá základní statistiku rastrového souboru na základì vektorových "
-"polygonù a ulo¾í ji do nových sloupeèkù atributové tabulky."
+"Creation option to the output format driver. Multiple options may be listed"
+msgstr "Volby pro ovladaè výstupního formátu. Volby je mo¾no kombinovat."
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:2
-msgid "vector, raster, statistics"
-msgstr "vektor, rastr, statistika"
+#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:10
+#: ../raster/r.out.gdal/main.c:434
+msgid "Metadata key passed on the output dataset if possible"
+msgstr "Pokud je to mo¾né, pøedat na výstup klíè metadat"
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:3
-msgid "Continue if upload column(s) already exist"
-msgstr "Pokraèuj, i kdy¾ sloupec pro ulo¾ení dat ji¾ existuje"
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:4
-#: ../raster/r.univar2/r.univar_main.c:45
-#: ../raster/r.univar2/r3.univar_main.c:46 ../vector/v.univar/main.c:94
-msgid "Calculate extended statistics"
-msgstr "Spoèítej roz¹íøenou statistiku"
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:5
-msgid "Name of vector polygon map"
-msgstr "Název polygonové mapy"
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:7
-msgid "Name of raster map to calculate statistics from"
-msgstr "Název rastrové mapy, na kterém se bude statistika poèítat"
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:8
-msgid "Column prefix for new attribute columns"
-msgstr "Pøedpona v názvu nových sloupeèkù"
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:9
-#: ../raster/r.univar2/r.univar_main.c:37
-#: ../raster/r.univar2/r3.univar_main.c:38 ../vector/v.univar/main.c:86
-msgid "Percentile to calculate (requires extended statistics flag)"
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:1
+msgid ""
+"Fills no-data areas in raster maps using v.surf.rst splines interpolation"
msgstr ""
-"Percentil, který se má spoèítat (vy¾aduje pøepínaè roz¹íøení statistiky)"
+"V rastrových mapách vyplní plochy s prázdnými hodnotami za pou¾ití v.surf."
+"rst spline interpolace"
-#: ../locale/scriptstrings/v.report_to_translate.c:1
-msgid "Reports geometry statistics for vectors."
-msgstr "Vypí¹e íºdaje o geometrii vektorové mapy."
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:2
+msgid "raster, elevation, interpolation"
+msgstr "rastr, elevace, interpolace"
-#: ../locale/scriptstrings/v.report_to_translate.c:2
-msgid "vector, report, statistics"
-msgstr "vektor, zpráva, statistika"
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:3
+msgid "Raster map in which to fill nulls"
+msgstr "Rastrové mapy v nich¾ mají být vyplnìny NULLy"
-#: ../locale/scriptstrings/v.report_to_translate.c:3
-msgid "Reverse sort the result"
-msgstr "Obrácené øazení výsledkù"
-#: ../locale/scriptstrings/v.report_to_translate.c:4
-msgid "Sort the result"
-msgstr "Seøadit výsledky"
-#: ../locale/scriptstrings/v.report_to_translate.c:7
-msgid "Value to calculate"
-msgstr "Hodnota, která se má spoèítat"
-#: ../locale/scriptstrings/v.report_to_translate.c:8
-msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:4
+msgid ""
+"Output raster map with nulls filled by interpolation from surrounding values"
msgstr ""
-"mi(míle),f(stopy),me(metry),k(kilometery),a(akry),h(hektary),p(procenta)"
+"Výstupní rastrová mapa její¾ prázdná místa budou vyplnìna okolními hodnotami"
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:1
-msgid "Uploads vector values at positions of vector points to the table."
-msgstr ""
-"Ulo¾í hodnoty rastrové mapy na pozicích bodù pøekryvné vektorové mapy do "
-"atributové tabulky."
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:5
+msgid "Spline tension parameter"
+msgstr "Parametr pnutí (tension)"
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:3
-msgid "Points vector map to modify"
-msgstr "Bodová mapa, která bude zmìnìna"
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:6
+msgid "Spline smoothing parameter"
+msgstr "Parametr vyhlazení (smoothing)"
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:4
-msgid "Layer in the vector to be modified"
-msgstr "Vektorová vrstva, která bude mìnìna"
+#: ../locale/scriptstrings/r.li.setup_to_translate.c:1
+msgid "Configuration editor for r.li.'index'"
+msgstr "Konfiguraèní editor pro r.li.'index'"
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:5
-msgid "Column to be updated with the query result"
-msgstr "Sloupec který má být aktualizován výsledky dotazu"
+#: ../locale/scriptstrings/r.li.setup_to_translate.c:2
+msgid "raster, landscape structure analysis"
+msgstr "rastr, anylýza krajiny"
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:6
-msgid "Vector map to be queried"
-msgstr "Vektorová mapa, její¾ hodnoty budou vy¹etøovány"
+#: ../locale/scriptstrings/v.in.e00_to_translate.c:1
+msgid "Import E00 file into a vector map."
+msgstr "Importuje soubory ve formátu E00 jako vektorovou mapu."
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:7
-msgid "Layer of the query vector containg data"
-msgstr "Vrstva vektorové mapy, ve které jsou zájmová data"
+#: ../locale/scriptstrings/v.in.e00_to_translate.c:4
+msgid "E00 file"
+msgstr "soubor E00"
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:8
-msgid "Column to be queried"
-msgstr "Sloupec vektorové mapy, ze kterého se budou brát hodnoty"
+#: ../locale/scriptstrings/v.in.e00_to_translate.c:5
+msgid "Input type point, line or area"
+msgstr "Typ vstupu linie nebo plocha"
-#: ../raster/r.describe/main.c:60
-msgid "Prints terse list of category values found in a raster map layer."
+#: ../locale/scriptstrings/db.test_to_translate.c:1
+msgid "Test database driver, database must exist and set by db.connect."
msgstr ""
-"Vytiskne pouze struèný seznam hodnot kategorií, nalezených v rastrové mapì."
+"Otestuj ovladaè databáze, databáze musí existovat a nastavena pomocí db."
+"connect"
-#: ../raster/r.describe/main.c:71 ../raster/r.stats/main.c:116
-msgid "String representing no data cell value"
-msgstr "Textový øetìzec reprezentující buòky s hodnotou \"no data\""
+#: ../locale/scriptstrings/db.test_to_translate.c:3
+msgid "Test name"
+msgstr "Jméno testu"
-#: ../raster/r.describe/main.c:79
-msgid "Number of quantization steps"
-msgstr "Poèet dávkových krokù"
+#: ../locale/scriptstrings/d.m_to_translate.c:1
+msgid "Display manager for GRASS"
+msgstr "GIS manager pro GRASS"
-#: ../raster/r.describe/main.c:85
-msgid "Print the output one value per line"
-msgstr "Na výstup vytiskni jednu hodnotu na øádek"
+#: ../locale/scriptstrings/d.m_to_translate.c:2
+msgid "Name of .dmrc settings file"
+msgstr "Jméno souboru s nastavením .dmrc"
-#: ../raster/r.describe/main.c:89
-msgid "Only print the range of the data"
-msgstr "Vytiskni pouze rozsah dat"
-#: ../raster/r.describe/main.c:93 ../raster/r.stats/main.c:164
-msgid "Suppress reporting of any NULLs"
-msgstr "Potlaè výpis NULL"
-#: ../raster/r.describe/main.c:97
-msgid "Use the current region"
-msgstr "Pou¾ij aktuální region"
-#: ../raster/r.describe/main.c:101
-msgid "Read fp map as integer"
-msgstr "Naèti mapu s plovoucí desetinnou èárkou jako celoèíselnou"
-#: ../raster/r.describe/main.c:106 ../raster/r.coin/cmd_parms.c:78
-#: ../raster/r.distance/parse.c:63 ../raster/r.carve/main.c:113
-#: ../raster/r.compress/main.c:82 ../raster/r.covar/main.c:66
-#: ../raster/r.colors/main.c:192 ../raster/r.out.ppm/main.c:68
-#: ../raster/r.neighbors/main.c:158 ../raster/r.clump/main.c:69
-#: ../raster/r.out.ppm3/main.c:86 ../raster/r.contour/main.c:133
-#: ../raster/r.cross/main.c:90 ../raster/r.series/main.c:125
-#: ../raster/r.buffer/main.c:89 ../imagery/i.smap/shapiro/parse.c:54
-#: ../imagery/i.maxlik/main.c:86
-msgid "Run quietly"
-msgstr "Potichu"
-#: ../raster/r.describe/main.c:114 ../raster/r.rescale.eq/main.c:105
-#: ../raster/r.coin/cmd_parms.c:87 ../raster/r.out.png/r.out.png.c:145
-#: ../raster/r.distance/parse.c:71 ../raster/r.carve/main.c:123
-#: ../raster/r.texture/main.c:217 ../raster/r.compress/main.c:90
-#: ../raster/r.patch/main.c:86 ../raster/r.covar/main.c:74
-#: ../raster/r.rescale/main.c:101 ../raster/r.slope.aspect/main.c:319
-#: ../raster/r.colors/main.c:202 ../raster/r.random.surface/init.c:107
-#: ../raster/r.neighbors/main.c:276 ../raster/r.clump/main.c:78
-#: ../raster/r.to.vect/main.c:95 ../raster/r.out.ppm3/main.c:98
-#: ../raster/r.cross/main.c:97 ../raster/r.series/main.c:137
-#: ../raster/r.resample/main.c:89 ../raster/r.buffer/main.c:98
-#: ../vector/v.qcount/main.c:115 ../vector/v.mkgrid/main.c:122
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:319
+#: ../locale/scriptstrings/v.convert.all_to_translate.c:1
msgid ""
-"The '-q' flag is superseded and will be removed in future. Please use '--"
-"quiet' instead."
+"Convert all old GRASS < Ver5.7 vector maps in current mapset to current "
+"format"
msgstr ""
-"Pøepínaè '-q' je zastaralý a bude v budoucnosti odstranìn. prosím, peou¾ijte "
-"pøepínaè '--quiet'."
+"Pøevede v¹echny staré vektorové mapy (GRASS < 5.7) do aktuálního mapsetu v "
+"aktuálním formátu"
-#: ../raster/r.describe/main.c:125
-#, c-format
-msgid "%s = %s -- must be greater than zero"
-msgstr "%s = %s -- musí být vìt¹í ne¾ nula"
+#: ../locale/scriptstrings/v.convert.all_to_translate.c:3
+msgid "run non-interactively"
+msgstr "spustit neinteraktivnì"
-#: ../raster/r.describe/main.c:137
-#, c-format
-msgid "%s: [%s] not found"
-msgstr "%s: [%s] nebyl nalezen"
+#: ../locale/scriptstrings/d.monsize_to_translate.c:1
+msgid "Selects/starts specified monitor at specified size"
+msgstr "Vybere/nastartuje zadaný monitor o zadané velikosti"
-#: ../raster/r.rescale.eq/main.c:53
-msgid ""
-"Rescales histogram equalized the range of category values in a raster map "
-"layer."
-msgstr ""
-"Zmìní kategorie histogramu rastrové mapy podle rozsahu hodnot kategorií."
+#: ../locale/scriptstrings/d.monsize_to_translate.c:3
+msgid "Display monitor to start"
+msgstr "Monitor, která má být spu¹tìn"
-#: ../raster/r.rescale.eq/main.c:63 ../raster/r.rescale/main.c:60
-msgid "The name of the raster map to be rescaled"
-msgstr "Název rastrové mapy, její¾ mìøítko má být zmìnìno."
+#: ../locale/scriptstrings/d.monsize_to_translate.c:4
+msgid "Width in pixels of new display monitor"
+msgstr "©íøka nového monitoru v pixelech "
-#: ../raster/r.rescale.eq/main.c:70 ../raster/r.rescale/main.c:67
-msgid "The input data range to be rescaled (default: full range of input map)"
-msgstr ""
-"Vstupní rozsah hodnot, pro které bude provedena zmìna mìøítka (výchozí: celý "
-"rozsah hodnot)"
+#: ../locale/scriptstrings/d.monsize_to_translate.c:5
+msgid "Height in pixels of new display monitor"
+msgstr "Vý¹ka nového monitoru v pixelech"
-#: ../raster/r.rescale.eq/main.c:77 ../raster/r.rescale/main.c:74
-msgid "The resulting raster map name"
-msgstr "Výsledná rastrová mapa"
+#: ../locale/scriptstrings/d.out.file_to_translate.c:1
+msgid "Saves the contents of the active display monitor to a graphics file."
+msgstr "Ulo¾í obsah aktuálního monitoru jako soubor s obrázkem."
-#: ../raster/r.rescale.eq/main.c:84 ../raster/r.rescale/main.c:81
-msgid "The output data range"
-msgstr "Rozsah výstupních dat"
+#: ../locale/scriptstrings/d.out.file_to_translate.c:3
+msgid "Name for output file (do NOT add extension)"
+msgstr "Jméno obrázku (NEpøidávejte koncovku)"
-#: ../raster/r.rescale.eq/main.c:91 ../raster/r.rescale/main.c:88
-msgid "Title for new raster map"
-msgstr "Titulek pro novou rastrovou mapu"
+#: ../locale/scriptstrings/d.out.file_to_translate.c:4
+msgid "Graphics file format"
+msgstr "Výstupní formát "
-#: ../raster/r.rescale.eq/main.c:96 ../raster/r.texture/main.c:108
-#: ../raster/r.patch/main.c:72 ../raster/r.grow2/main.c:165
-#: ../raster/r.report/parse.c:90 ../raster/r.kappa/main.c:82
-#: ../raster/r.slope.aspect/main.c:281 ../raster/r.mfilter.fp/main.c:89
-#: ../raster/r.mfilter/main.c:82 ../raster/r.resample/main.c:78
-#: ../raster/r.bitpattern/main.c:87 ../vector/v.perturb/main.c:116
-#: ../vector/v.sample/main.c:128 ../vector/v.kcv/main.c:104
-#: ../doc/raster/r.example/main.c:95 ../imagery/i.cluster/main.c:135
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:281
-msgid "Quiet"
-msgstr "Potichu"
+#: ../locale/scriptstrings/d.out.file_to_translate.c:5
+msgid "Dimensions of output file versus current window size"
+msgstr "Rozmìry výstupu versus souèasná velikost okna"
-#: ../raster/r.rescale.eq/main.c:149
-#, c-format
-msgid "Rescale %s[%d,%d] to %s[%d,%d]"
-msgstr "Pøevzorkování%s[%d,%d] na %s[%d,%d]"
+#: ../locale/scriptstrings/d.out.file_to_translate.c:6
+msgid "(same=1, double size=2, quadruple size=4)"
+msgstr "(stejná velikost=1, dvojitá=2, ètyønásobná=4)"
-#: ../raster/r.rescale.eq/get_stats.c:19 ../raster/r.rescale/get_range.c:27
-#: ../raster/r.colors/stats.c:37
-#, c-format
-msgid "Reading %s ..."
-msgstr "Naèítám %s..."
+#: ../locale/scriptstrings/d.out.file_to_translate.c:7
+#: ../locale/scriptstrings/d.out.file_to_translate.c:9
+#: ../locale/scriptstrings/d.out.file_to_translate.c:12
+#: ../locale/scriptstrings/d.out.file_to_translate.c:15
+#: ../locale/scriptstrings/d.out.file_to_translate.c:22
+#: ../locale/scriptstrings/d.out.file_to_translate.c:24
+msgid "Images"
+msgstr "Obrázky"
-#: ../raster/r.resamp.stats/main.c:265 ../raster/r.resamp.interp/main.c:71
-msgid "raster, resample"
-msgstr "rastr, pøevzorkování"
+#: ../locale/scriptstrings/d.out.file_to_translate.c:8
+msgid "Width and height of output image (overrides resolution setting)"
+msgstr "©íøka a vý¹ka výstupního obrazu (pøepí¹e nastavení rozli¹ení)"
-#: ../raster/r.resamp.stats/main.c:267
-msgid "Resamples raster map layers using aggregation."
-msgstr "Pøevzorkovat rastrovou vrstvu s vyu¾itím agregace."
+#: ../locale/scriptstrings/d.out.file_to_translate.c:10
+msgid "Compression for PNG files"
+msgstr "Komprese pro soubory PNG"
-#: ../raster/r.resamp.stats/main.c:277
-msgid "Aggregation method"
-msgstr "Agregaèní metoda"
+#: ../locale/scriptstrings/d.out.file_to_translate.c:11
+msgid "(0=none, 1=fastest, 9=most; lossless, only time vs. filesize)"
+msgstr "(0=nic, 1=nejrychleji, 9=bezeztrát; pouze èas vs velikost souboru)"
-#: ../raster/r.resamp.stats/main.c:283 ../raster/r.series/main.c:129
-msgid "Propagate NULLs"
-msgstr "Vytváøej hodnoty NULL"
+#: ../locale/scriptstrings/d.out.file_to_translate.c:13
+msgid "File size/quality for JPEG files"
+msgstr "Velikost/kvalita souboru JPEG"
-#: ../raster/r.resamp.stats/main.c:287
-msgid "Weight according to area (slower)"
-msgstr "Váha podle plochy (pomalej¹í)"
+#: ../locale/scriptstrings/d.out.file_to_translate.c:14
+msgid "(10=smallest/worst, 100=largest/best)"
+msgstr "(10=nejmen¹í/nejhor¹í, 100=nejvìt¹í/nejlep¹í)"
-#: ../raster/r.resamp.stats/main.c:296 ../raster/r.series/main.c:150
-#, c-format
-msgid "Unknown method <%s>"
-msgstr "Neznámá metoda <%s>."
+#: ../locale/scriptstrings/d.out.file_to_translate.c:16
+msgid "Paper size for PostScript output"
+msgstr "Velikost papíru pro výstup v PostScript."
-#: ../raster/r.resamp.stats/main.c:335 ../raster/r.surf.area/main.c:124
-#: ../raster/r.resamp.interp/main.c:137 ../raster/r.los/main.c:188
-#: ../raster/r.los/main.c:199 ../raster/r.out.ascii/main.c:150
-#: ../raster/r.carve/main.c:176 ../raster/r.profile/main.c:144
-#: ../raster/r.texture/main.c:230 ../raster/r.sum/main.c:68
-#: ../raster/r.null/null.c:307 ../raster/r.out.gdal/main.c:101
-#: ../raster/r.surf.idw2/read_cell.c:36 ../raster/r.out.mat/main.c:99
-#: ../raster/r.to.rast3elev/main.c:161 ../raster/r.grow2/main.c:201
-#: ../raster/r.surf.idw/main.c:135 ../raster/r.thin/io.c:102
-#: ../raster/r.out.pov/main.c:175 ../raster/r.covar/main.c:99
-#: ../raster/r.out.arc/main.c:114 ../raster/r.random/count.c:24
-#: ../raster/r.random/count.c:29 ../raster/r.sunmask/main.c:435
-#: ../raster/r.his/main.c:132 ../raster/r.his/main.c:158
-#: ../raster/r.his/main.c:186 ../raster/r.bilinear/main.c:92
-#: ../raster/r.resamp.rst/main.c:405 ../raster/r.resamp.rst/main.c:437
-#: ../raster/r.out.ppm/main.c:120 ../raster/r.cost/main.c:337
-#: ../raster/r.out.vtk/main.c:224 ../raster/r.out.vtk/main.c:286
-#: ../raster/r.out.vtk/main.c:314 ../raster/r.out.vtk/main.c:360
-#: ../raster/r.support/front/front.c:221 ../raster/r.out.bin/main.c:133
-#: ../raster/r.clump/main.c:95 ../raster/r.to.vect/main.c:112
-#: ../raster/r.out.ppm3/main.c:121 ../raster/r.univar2/r.univar_main.c:98
-#: ../raster/r.contour/main.c:160 ../raster/r.cross/main.c:120
-#: ../raster/r.cats/main.c:143 ../raster/r.out.tiff/r.out.tiff.c:188
-#: ../raster/r.walk/main.c:545 ../raster/r.walk/main.c:548
-#: ../raster/r.walk/main.c:855 ../raster/r.mapcalc/map3.c:527
-#: ../raster/r.composite/main.c:166 ../raster/wildfire/r.ros/main.c:441
-#: ../raster/wildfire/r.ros/main.c:446 ../raster/wildfire/r.ros/main.c:451
-#: ../raster/wildfire/r.ros/main.c:456 ../raster/wildfire/r.ros/main.c:461
-#: ../raster/wildfire/r.ros/main.c:466 ../raster/wildfire/r.ros/main.c:471
-#: ../raster/wildfire/r.ros/main.c:477 ../raster/wildfire/r.ros/main.c:482
-#: ../raster/wildfire/r.ros/main.c:488 ../raster/wildfire/r.spread/main.c:423
-#: ../raster/wildfire/r.spread/main.c:430
-#: ../raster/wildfire/r.spread/main.c:437
-#: ../raster/wildfire/r.spread/main.c:445
-#: ../raster/wildfire/r.spread/main.c:451
-#: ../raster/wildfire/r.spread/main.c:457
-#: ../raster/wildfire/r.spread/main.c:525 ../raster/r.buffer/read_map.c:41
-#: ../raster/r.buffer/write_map.c:45 ../raster/r.bitpattern/main.c:108
-#: ../raster/r.to.rast3/main.c:358 ../vector/v.what.rast/main.c:135
-#: ../vector/v.extrude/main.c:182 ../vector/v.sample/main.c:160
-#: ../vector/v.vol.rst/main.c:580 ../vector/v.to.rast/support.c:247
-#: ../vector/v.to.rast/support.c:396 ../vector/v.drape/main.c:125
-#: ../doc/raster/r.example/main.c:121 ../imagery/i.his.rgb/openfiles.c:34
-#: ../imagery/i.his.rgb/openfiles.c:39 ../imagery/i.his.rgb/openfiles.c:44
-#: ../imagery/i.smap/shapiro/opencell.c:16 ../imagery/i.pca/main.c:125
-#: ../imagery/i.gensig/opencell.c:12 ../visualization/xganim/main.c:346
-#: ../display/d.rast.edit/cell.c:90 ../display/d.profile/ExtractProf.c:95
-#: ../display/d.profile/What.c:30 ../display/d.rast.num/number.c:154
-#: ../display/d.rast.arrow/arrow.c:382 ../display/d.rast/display.c:80
-#: ../display/d.rgb/main.c:104 ../display/d.his/main.c:141
-#: ../display/d.his/main.c:166 ../display/d.nviz/main.c:185
-#, c-format
-msgid "Unable to open raster map <%s>"
-msgstr "Nelze otevøít rastrovou mapu <%s>"
+#: ../locale/scriptstrings/d.out.file_to_translate.c:17
+#: ../locale/scriptstrings/d.out.file_to_translate.c:19
+#: ../locale/scriptstrings/d.out.file_to_translate.c:26
+msgid "PostScript"
+msgstr "PostScript"
-#: ../raster/r.resamp.stats/main.c:378 ../raster/r.resamp.interp/main.c:337
-#: ../raster/r.colors/main.c:326
-#, c-format
-msgid "Unable to read color table for %s"
-msgstr "Nelze èíst barevnou tabulku pro %s"
+#: ../locale/scriptstrings/d.out.file_to_translate.c:18
+msgid "PostScript level (only limits functionality!)"
+msgstr "Úroveò Postscriptu ( pouze omezuje funkènost!)"
-#: ../raster/r.resamp.stats/main.c:381 ../raster/r.resamp.interp/main.c:340
-#, c-format
-msgid "Unable to write color table for %s"
-msgstr "Nelze zapsat barevnou tabulku pro %s"
+#: ../locale/scriptstrings/d.out.file_to_translate.c:20
+msgid "Set background color to black (white default)"
+msgstr "Nastav barvu pozadí na èernou (bílá je výchozí)"
-#: ../raster/r.param.scale/interface.c:44
-msgid "raster, geomorphology"
-msgstr "rastr, geomorfologie"
+#: ../locale/scriptstrings/d.out.file_to_translate.c:21
+msgid "Set transparent background"
+msgstr "Nastavit prùhledné pozadí"
-#: ../raster/r.param.scale/interface.c:45
-msgid "Extracts terrain parameters from a DEM."
-msgstr "Spoèítá parametry reliéfu z digitálního modelu terénu"
+#: ../locale/scriptstrings/d.out.file_to_translate.c:23
+msgid "Use the Cario driver to render images"
+msgstr "Pou¾ít ovladaè Cairo pro vykreslení obrazù"
-#: ../raster/r.param.scale/interface.c:46
-msgid ""
-"Uses a multi-scale approach by taking fitting quadratic parameters to any "
-"size window (via least squares)."
-msgstr ""
-"Pou¾ívá multisklalární pøístup, vypoèítává kvadratické koeficienty pro okno "
-"libovolné velikosti (pomocí metody nejmen¹ích ètvercù)."
+#: ../locale/scriptstrings/d.out.file_to_translate.c:25
+msgid "Set paper orientation to landscape (for PostScript output)"
+msgstr "Nastavit papír na orientaci krajina (pro výstup Postscript)"
-#: ../raster/r.param.scale/interface.c:63
-msgid "Output raster layer containing morphometric parameter"
-msgstr "Výstupní rastrový soubor s morphometrickými parametry"
+#: ../db/db.login/main.c:42 ../db/base/connect.c:44 ../db/base/select.c:236
+#: ../db/base/createdb.c:71 ../db/base/databases.c:89 ../db/base/tables.c:95
+#: ../db/base/droptable.c:78 ../db/base/dropdb.c:71 ../db/base/copy.c:34
+#: ../db/base/describe.c:126 ../db/base/drivers.c:73 ../db/base/execute.c:108
+#: ../db/base/columns.c:91
+msgid "database, SQL"
+msgstr "databáze, SQL"
-#: ../raster/r.param.scale/interface.c:66
-msgid "Slope tolerance that defines a 'flat' surface (degrees)"
-msgstr ""
-"Nejni¾¹í sklon svahu, do kterého je povrch pova¾ován za plochý (ve stupních)"
+#: ../db/db.login/main.c:43
+msgid "Sets user/password for driver/database."
+msgstr "Nastavit u¾ivatele/heslo pro ovladaè/databázi"
-#: ../raster/r.param.scale/interface.c:72
-msgid "Curvature tolerance that defines 'planar' surface"
-msgstr "Limitní hodnota køivosti, pod kterou je povrch pova¾ován za plochý"
+#: ../db/db.login/main.c:59
+msgid "Username"
+msgstr "U¾ivatel"
-#: ../raster/r.param.scale/interface.c:77
-#, c-format
-msgid "Size of processing window (odd number only, max: %i)"
-msgstr "Velikost okna filtru (pouze lichá èísla, max: %i)"
+#: ../db/db.login/main.c:66
+msgid "Password"
+msgstr "Heslo"
-#: ../raster/r.param.scale/interface.c:85
-msgid "Morphometric parameter in 'size' window to calculate"
-msgstr "Které morfometrické parametry se budou poèítat"
-#: ../raster/r.param.scale/interface.c:92
-msgid "Exponent for distance weighting (0.0-4.0)"
-msgstr "Exponent pro vyvá¾ení vzdálenosti (0.0-4.0)"
-#: ../raster/r.param.scale/interface.c:98 ../raster/r.out.pov/main.c:154
-msgid "Vertical scaling factor"
-msgstr "Vertikální mìøítko"
-#: ../raster/r.param.scale/interface.c:104
-msgid "Constrain model through central window cell"
-msgstr " Model omezen na centrální buòku okna"
-#: ../raster/r.param.scale/interface.c:157
-msgid "Morphometric parameter not recognised. Assuming 'Elevation'"
-msgstr "Morfometrické parametry nebyly rozpoznané. Pøedpokládá se 'Elevation'"
-#: ../raster/r.param.scale/interface.c:181
-msgid "Inappropriate window size (too big or even)"
-msgstr "Nesprávná velikost okna (pøíli¹ veliké nebo sudé)"
-#: ../raster/r.param.scale/write_cats.c:37
+#: ../db/db.login/main.c:81
#, c-format
-msgid "Cannot write category file for raster map <%s>"
-msgstr "Nelze soubor s kategoriemi pro <%s>"
+msgid ""
+"\n"
+"Enter database password for connection\n"
+"<%s:%s:user=%s>\n"
+msgstr ""
+"\n"
+"Zadajte heslo k databázi pro spojení\n"
-#: ../raster/r.param.scale/process.c:67
-msgid "E-W and N-S grid resolutions are different. Taking average."
-msgstr "Rozli¹ení V-Z a S-J jsou rùzná, beru prùmìr."
-#: ../raster/r.param.scale/open_files.c:19 ../raster/r.topidx/file_io.c:17
-#: ../raster/r.random/random.c:39 ../raster/r.mfilter.fp/perform.c:37
-#: ../raster/r.mfilter/perform.c:37 ../imagery/i.rgb.his/openfiles.c:22
-#: ../imagery/i.rgb.his/openfiles.c:24 ../imagery/i.rgb.his/openfiles.c:26
-#: ../imagery/i.cca/main.c:180
+#: ../db/db.login/main.c:82
#, c-format
-msgid "Cannot open raster map <%s>"
+msgid "Hit RETURN to cancel request\n"
+msgstr "Stisknìte RETURN pro ukonèení ¾ádosti\n"
-#: ../raster/r.param.scale/open_files.c:26
-#: ../raster/r.param.scale/open_files.c:29 ../raster/r.reclass/reclass.c:244
-#: ../raster/r.topidx/file_io.c:84 ../raster/r.random/random.c:49
-#: ../raster/r.mfilter.fp/perform.c:82 ../raster/r.mfilter/perform.c:82
-#: ../imagery/i.rgb.his/openfiles.c:30 ../imagery/i.rgb.his/openfiles.c:32
-#: ../imagery/i.rgb.his/openfiles.c:34 ../imagery/i.cca/main.c:186
-#, c-format
-msgid "Cannot create raster map <%s>"
-msgstr "Nelze vytvoøit rastrový soubor <%s>"
+#: ../db/db.login/main.c:90
+msgid "Exiting. Not changing current settings"
+msgstr "Konèím, nemìním aktuální nastavení"
-#: ../raster/r.param.scale/main.c:41
-msgid "Lat/Long location is not supported"
-msgstr "Location lat/long není podporována"
+#: ../db/db.login/main.c:93
+msgid "New password set"
+msgstr "Nové heslo bylo nastaveno."
-#: ../raster/r.surf.area/main.c:91
-msgid "Surface area estimation for rasters."
-msgstr "Odhad plochy povrchù rastrových map."
+#: ../db/db.login/main.c:100
+msgid "Unable to set user/password"
+msgstr "Nelze nastavit u¾ivatele/heslo"
-#: ../raster/r.surf.area/main.c:99
-msgid "Raster file for surface"
-msgstr "Rastrový soubor pro povrch"
+#: ../db/db.login/main.c:104
+msgid "The password was stored in file"
+msgstr "Heslo bylo ulo¾eno v souboru."
-#: ../raster/r.surf.area/main.c:106
-msgid "Vertical scale"
+#: ../db/drivers/mysql/fetch.c:34
+msgid "Cursor not found"
+msgstr "Kurzor nenalezen"
-#: ../raster/r.proj.seg/main.c:138 ../raster/r.proj/main.c:132
-msgid "raster, projection"
-msgstr "raster, projekce"
+#: ../db/drivers/mysql/fetch.c:53
+msgid "Cursor position is not supported by MySQL driver"
+msgstr "Pozice kurzoru není podporována ovladaèem MySQL"
-#: ../raster/r.proj.seg/main.c:140 ../raster/r.proj/main.c:134
-msgid "Re-projects a raster map from one location to the current location."
-msgstr "Zmìna projekce rastrové mapy ze zvolené location do aktuální location."
+#: ../db/drivers/mysql/fetch.c:181
+msgid "Cannot scan timestamp: "
+msgstr "Nelze zjistit èasovou znaèku: "
-#: ../raster/r.proj.seg/main.c:143 ../raster/r.proj/main.c:137
-msgid "Name of input raster map to re-project"
-msgstr "Název vstupní rastrové mapy"
+#: ../db/drivers/mysql/fetch.c:189
+msgid "Unknown timestamp format: "
+msgstr "Neznámý formát èasové znaèky: "
-#: ../raster/r.proj.seg/main.c:150 ../raster/r.proj/main.c:144
-msgid "Location of input raster map"
-msgstr "Location vstupní mapy"
+#: ../db/drivers/mysql/fetch.c:203
+msgid "Cannot scan date: "
+msgstr "Nelze získat datum: "
-#: ../raster/r.proj.seg/main.c:156 ../raster/r.proj/main.c:150
-msgid "Mapset of input raster map"
-msgstr "Mapset vstupní rastrové mapy"
+#: ../db/drivers/mysql/fetch.c:216
+msgid "Cannot scan time: "
+msgstr "Nelze získat èas: "
-#: ../raster/r.proj.seg/main.c:162 ../raster/r.proj/main.c:156
-#: ../vector/v.proj/main.c:86
-msgid "Path to GRASS database of input location"
-msgstr "Cesta k databázi GRASSu vstupní pro location"
+#: ../db/drivers/mysql/fetch.c:231
+msgid "Cannot scan datetime: "
+msgstr "Nelze získat datumaèas: "
-#: ../raster/r.proj.seg/main.c:166 ../raster/r.proj/main.c:160
-msgid "Name for output raster map (default: input)"
-msgstr "Jméno výstupní rastrové mapy (výchozí: jméno vstupní mapy)"
+#: ../db/drivers/mysql/db.c:66
+msgid "Cannot connect to MySQL: "
+msgstr "Nelze se pøipojit k MySQL: "
-#: ../raster/r.proj.seg/main.c:176 ../raster/r.proj/main.c:170
-msgid "Interpolation method to use"
-msgstr "Interpolaèní metoda, která má být pou¾ita"
+#: ../db/drivers/mysql/db.c:83
+msgid "Cannot parse MySQL embedded database name"
+msgstr "Nelze parsovat MySQL pøipojené jméno databáze"
-#: ../raster/r.proj.seg/main.c:182
-msgid "Cache size (MiB)"
-msgstr "Velikost cache (MiB)"
+#: ../db/drivers/mysql/db.c:100
+msgid "Cannot initialize MySQL embedded server"
+msgstr "Nelze inicializovat pøipojený MySQL server"
-#: ../raster/r.proj.seg/main.c:188 ../raster/r.proj/main.c:176
-msgid "Resolution of output map"
-msgstr "Rozli¹ení výstupní mapy"
+#: ../db/drivers/mysql/db.c:118
+msgid "Cannot connect to MySQL embedded server: "
+msgstr "Nelzese pøipojit na MySQL server"
-#: ../raster/r.proj.seg/main.c:192 ../raster/r.proj/main.c:180
-msgid "List raster maps in input location and exit"
-msgstr "Vypi¹ rastrové soubory vstupní location a ukonèi se"
+#: ../db/drivers/mysql/select.c:44
+msgid "Cannot select data: \n"
+msgstr "Nelze vybrat data: \n"
-#: ../raster/r.proj.seg/main.c:196 ../raster/r.proj/main.c:184
-msgid "Do not perform region cropping optimization"
-msgstr "Nepou¾ívej optimalizaci oøíznutím regionu"
+#: ../db/drivers/mysql/listtab.c:37
+msgid "Cannot get list of tables:\n"
+msgstr "Nelze získat seznam tabulek:\n"
-#: ../raster/r.proj.seg/main.c:212 ../raster/r.statistics/main.c:98
-#: ../raster/r.neighbors/main.c:214 ../raster/r.proj/main.c:200
-#, c-format
-msgid "<%s=%s> unknown %s"
-msgstr "<%s=%s> neznámé %s"
+#: ../db/drivers/mysql/cursor.c:46
+msgid "Cannot allocate cursor."
+msgstr "Nelze alokovat kurzor"
-#: ../raster/r.proj.seg/main.c:218 ../raster/r.proj/main.c:206
-#: ../vector/v.proj/main.c:116
-#, c-format
-msgid "option <%s>: <%s> exists."
-msgstr "volba <%s>: <%s> ji¾ existuje"
+#: ../db/drivers/mysql/cursor.c:55
+msgid "Cannot ad new token."
+msgstr "Nelze pøidat dal¹í token."
-#: ../raster/r.proj.seg/main.c:224
-msgid "You have to use a different location for input than the current"
-msgstr "Pro vstup musíte pou¾ít location rùznou od souèasné"
+#: ../db/drivers/mysql/parse.c:59
+msgid "Wrong port number in MySQL database definition: "
+msgstr "©patný port v definici databáze MySQL: "
-#: ../raster/r.proj.seg/main.c:230 ../raster/r.proj/main.c:218
-msgid "Unable to get projection info of output raster map"
-msgstr "Nelze získat informace o projekci výstupní mapy"
+#: ../db/drivers/mysql/parse.c:72 ../db/drivers/postgres/parse.c:53
+msgid "'user' in database definition is not supported, use db.login"
+msgstr "'u¾ivatel' v definici databáze není podporován, pou¾ijte db.login"
-#: ../raster/r.proj.seg/main.c:233 ../raster/r.proj/main.c:221
-msgid "Unable to get projection units of output raster map"
-msgstr "Nelze získat jednotky výstupní mapy"
+#: ../db/drivers/mysql/parse.c:77 ../db/drivers/postgres/parse.c:57
+msgid "'password' in database definition is not supported, use db.login"
+msgstr "'heslo' v definici databáze není podporováno, pou¾ijte db.login"
-#: ../raster/r.proj.seg/main.c:236 ../raster/r.proj/main.c:224
-msgid "Unable to get projection key values of output raster map"
-msgstr "Nelze získat klíèové hodnoty mapové projekce výstupní mapové vrstvy"
+#: ../db/drivers/mysql/parse.c:82
+msgid "Unknown option in database definition for "
+msgstr "Neznámá volba v definici databáze pro "
-#: ../raster/r.proj.seg/main.c:245 ../raster/r.proj/main.c:233
+#: ../db/drivers/mysql/describe.c:120
#, c-format
-msgid "Mapset <%s> in input location <%s> - %s"
-msgstr "Mapset <%s> ve vstupní location <%s> - <%s>"
+msgid "MySQL driver: column '%s', type %d is not supported"
+msgstr "ovladaè MySQL: sloupec '%s', typu %d není podporován"
-#: ../raster/r.proj.seg/main.c:248 ../raster/r.in.gdal/main.c:642
-#: ../raster/r.proj/main.c:236
-msgid "permission denied"
-msgstr "Pøístup odepøen"
-#: ../raster/r.proj.seg/main.c:249 ../raster/r.in.gdal/main.c:643
-#: ../raster/r.proj/main.c:237
-msgid "not found"
-msgstr "nenalezen"
-#: ../raster/r.proj.seg/main.c:255 ../raster/r.proj/main.c:243
+#: ../db/drivers/mysql/describe.c:126
#, c-format
-msgid "Checking location <%s>, mapset <%s>..."
-msgstr "Kontroluji location <%s>, mapset <%s>..."
+msgid ""
+"column '%s' : type BIGINT is stored as integer (4 bytes) some data may be "
+"damaged"
+msgstr ""
+"sloupec '%s' : typ BITINT byl ulo¾en jako integer nìkterá data mohou být "
+"po¹kozena"
-#: ../raster/r.proj.seg/main.c:262 ../raster/r.out.gdal/main.c:460
-#: ../raster/r.in.gdal/main.c:197 ../raster/r.proj/main.c:250
-#: ../vector/v.in.ogr/main.c:262 ../vector/v.in.ogr/main.c:311
-#: ../vector/v.proj/main.c:154
-#, c-format
-msgid "Required parameter <%s> not set"
-msgstr "Po¾adovaný parametr <%s> nebyl zadán"
+#: ../db/drivers/mysql/error.c:29
+msgid "DBMI-MySQL driver error:\n"
+msgstr "Chyba ovladaèe DBMI-MySQL :\n"
-#: ../raster/r.proj.seg/main.c:265 ../raster/r.proj/main.c:253
-#, c-format
-msgid "Raster map <%s> in location <%s> in mapset <%s> not found"
-msgstr "Rastrová mapa <%s> v location <%s>, mapsetu <%s> není dostupná"
+#: ../db/drivers/ogr/fetch.c:124 ../db/drivers/ogr/describe.c:152
+msgid "Unknown type"
+msgstr "Neznámý typ"
-#: ../raster/r.proj.seg/main.c:273 ../raster/r.proj/main.c:261
-msgid "Unable to get projection info of input map"
-msgstr "Nelze získat informace o projekci vstupní mapy"
-#: ../raster/r.proj.seg/main.c:276 ../raster/r.proj/main.c:264
-msgid "Unable to get projection units of input map"
-msgstr "Nelze získat jednotky mapové projekce vstupní mapy"
-#: ../raster/r.proj.seg/main.c:279 ../raster/r.proj/main.c:267
-msgid "Unable to get projection key values of input map"
-msgstr "Nelze získat klíèové hodnoty mapové projekce vstupní mapy"
-#: ../raster/r.proj.seg/main.c:293 ../raster/r.proj/main.c:281
-msgid "Unable to work with unprojected data (xy location)"
-msgstr "Nelze pracovat s nepøipojenými daty (xy location)"
-#: ../raster/r.proj.seg/main.c:361 ../raster/r.proj/main.c:349
-msgid "Input:"
-msgstr "Vstup:"
-#: ../raster/r.proj.seg/main.c:362 ../raster/r.proj.seg/main.c:373
-#: ../raster/r.proj/main.c:350 ../raster/r.proj/main.c:361
+#: ../db/drivers/ogr/describe.c:88
#, c-format
-msgid "Cols: %d (%d)"
-msgstr "Sloupce: %d (%d)"
+msgid "OGR driver: column '%s', OGR type %d is not supported"
+msgstr "Ovladaè OGR: sloupec '%s', typu %d není podporován"
-#: ../raster/r.proj.seg/main.c:363 ../raster/r.proj.seg/main.c:374
-#: ../raster/r.proj/main.c:351 ../raster/r.proj/main.c:362
+#: ../db/drivers/ogr/describe.c:144
#, c-format
-msgid "Rows: %d (%d)"
-msgstr "Øádky: %d (%d)"
-#: ../raster/r.proj.seg/main.c:364 ../raster/r.proj.seg/main.c:375
-#: ../raster/r.proj/main.c:352 ../raster/r.proj/main.c:363
-#, c-format
-msgid "North: %f (%f)"
-msgstr "Sever: %f (%f)"
-#: ../raster/r.proj.seg/main.c:365 ../raster/r.proj.seg/main.c:376
-#: ../raster/r.proj/main.c:353 ../raster/r.proj/main.c:364
-#, c-format
-msgid "South: %f (%f)"
-msgstr "Jih: %f (%f)"
-#: ../raster/r.proj.seg/main.c:366 ../raster/r.proj.seg/main.c:377
-#: ../raster/r.proj/main.c:354 ../raster/r.proj/main.c:365
-#, c-format
-msgid "West: %f (%f)"
-msgstr "Západ: %f (%f)"
-#: ../raster/r.proj.seg/main.c:367 ../raster/r.proj.seg/main.c:378
-#: ../raster/r.proj/main.c:355 ../raster/r.proj/main.c:366
-#, c-format
-msgid "East: %f (%f)"
-msgstr "Východ: %f (%f)"
-#: ../raster/r.proj.seg/main.c:368 ../raster/r.proj.seg/main.c:379
-#: ../raster/r.proj/main.c:356 ../raster/r.proj/main.c:367
-#, c-format
-msgid "EW-res: %f"
-msgstr "rozli¹ení vz: %f"
-#: ../raster/r.proj.seg/main.c:369 ../raster/r.proj.seg/main.c:380
-#: ../raster/r.proj/main.c:357 ../raster/r.proj/main.c:368
-#, c-format
-msgid "NS-res: %f"
-msgstr "rozli¹ení sj: %f"
-#: ../raster/r.proj.seg/main.c:372 ../raster/r.proj/main.c:360
-msgid "Output:"
-msgstr "Výstup:"
-#: ../raster/r.proj.seg/main.c:411 ../raster/r.proj/main.c:399
-msgid "Projecting..."
-msgstr "Pøevádím..."
-#: ../raster/r.proj.seg/main.c:442 ../raster/r.los/main.c:352
-#: ../raster/r.texture/main.c:349 ../raster/r.texture/main.c:352
-#: ../raster/r.texture/main.c:358 ../raster/r.in.mat/main.c:439
-#: ../raster/r.buffer/write_map.c:81 ../raster/r.proj/main.c:430
-#, c-format
-msgid "Failed writing raster map <%s> row %d"
-msgstr "Nejsem zapsat rastrovou mapu <%s> øádek [%d]"
-#: ../raster/r.proj.seg/bordwalk.c:161 ../raster/r.proj/bordwalk.c:161
-msgid "Input raster map is outside current region"
-msgstr "Vstupní rastrová mapa je mimo aktuální region"
-#: ../raster/r.proj.seg/readcell.c:57
-msgid "Unable to open temporary file"
-msgstr "Nelze otevøít doèasný soubor"
-#: ../raster/r.proj.seg/readcell.c:63 ../raster/r.proj/readcell.c:23
-msgid "Allocating memory and reading input map..."
-msgstr "Alokuji pamì» a ètu vstupní mapu ..."
-#: ../raster/r.proj.seg/readcell.c:83
-msgid "Error reading input"
-msgstr "Chyba pøi ètení vstupu"
-#: ../raster/r.proj.seg/readcell.c:91 ../raster/r.proj.seg/readcell.c:131
-msgid "Error writing segment file"
-msgstr "Chyba pøi zápisu souboru se segmenty"
-#: ../raster/r.proj.seg/readcell.c:119
-msgid "Internal error: cache miss on fully-cached map"
-msgstr "Interní chyba: cache není dostupná"
-#: ../raster/r.proj.seg/readcell.c:128
-msgid "Error seeking on segment file"
-msgstr "Chyba pøi hledání v souboru se segmenty"
-#: ../raster/r.resamp.interp/main.c:73
-msgid "Resamples raster map layers using interpolation."
-msgstr "Pøevzorkovat rastrovou vrstvu s vyu¾itím interpolace."
-#: ../raster/r.resamp.interp/main.c:82
-msgid "Interpolation method"
-msgstr "Interpolaèní metoda"
-#: ../raster/r.resamp.interp/main.c:96
-#, c-format
-msgid "Invalid method: %s"
-msgstr "Neplatná metoda: %s"
-#: ../raster/r.coin/inter.c:34
-msgid "GIS Coincidence Tabulation Facility\n"
-msgstr "Schopnost spoèítat tabulku koincidence\n"
-#: ../raster/r.coin/inter.c:35
msgid ""
-"This utility will allow you to compare the coincidence of two map layers\n"
-msgstr "Tento nástroj vám umo¾ní porovnat coincidence dvou mapových vrstev\n"
+"column '%s', type 'string': unknown width -> stored as varchar(250) some "
+"data may be lost"
+msgstr ""
+"sloupec '%s' typu 'string': neznámé ¹íøky -> ulo¾en jako varchar(250), "
+"nìkterá data mohou být ztracena"
-#: ../raster/r.coin/inter.c:53
-msgid "The report can be made in one of 8 units."
-msgstr "Zprávu lze vytvoøit za pomoci nìkteré z osmi jednotek."
+#: ../db/drivers/postgres/fetch.c:169
+msgid "Cannot recognize boolean value"
+msgstr "Nelze rozpoznat booleanovskou hodnotu"
-#: ../raster/r.coin/inter.c:54
-msgid "Please choose a unit by entering one of the following letter codes:"
-msgstr "Vyberte prosím jednotky zadáním jednoho z následujících písmen:"
+#: ../db/drivers/postgres/parse.c:61
+msgid "Unknown option in database definition for PostgreSQL: "
+msgstr "Neznámá volba v definici databáze pro PostgreSQL: "
-#: ../raster/r.coin/inter.c:56
-msgid " 'c': cells"
-msgstr " 'c': pixely"
-#: ../raster/r.coin/inter.c:57
-msgid " 'p': percent cover of region"
-msgstr " 'p': procenta pokryvnosti regionu"
-#: ../raster/r.coin/inter.c:58
+#: ../db/drivers/postgres/describe.c:101
#, c-format
-msgid " 'x': percent of '%s' category (column)"
-msgstr " 'x': procenta '%s' kategorie (sloupec)"
+msgid "pg driver: PostGIS column '%s', type 'geometry' will not be converted"
+msgstr "ovladaè pg: Sloupec PostGIS '%s', typu 'geometry' nebude pøeveden"
-#: ../raster/r.coin/inter.c:59
+#: ../db/drivers/postgres/describe.c:105
#, c-format
-msgid " 'y': percent of '%s' category (row)"
-msgstr " 'y': procenta '%s' kategorie (øádek)"
+msgid "pg driver: column '%s', type %d is not supported"
+msgstr "ovladaè pg: sloupec '%s', typu %d není podporován"
-#: ../raster/r.coin/inter.c:60
-msgid " 'a': acres"
-msgstr " 'a': akry"
-#: ../raster/r.coin/inter.c:61
-msgid " 'h': hectares"
-msgstr " 'h': hektary"
-#: ../raster/r.coin/inter.c:62
-msgid " 'k': square kilometers"
-msgstr " 'k': ètvereèní kilometry"
-#: ../raster/r.coin/inter.c:63
-msgid " 'm': square miles\n"
-msgstr " 'm': ètvereèní míle\n"
-#: ../raster/r.coin/inter.c:64
-msgid " 'Q': quit"
-msgstr " 'Q': konec"
-#: ../raster/r.coin/inter.c:93
+#: ../db/drivers/postgres/describe.c:111
#, c-format
-msgid "Do you wish to save this report in a file? (y/n) [n] "
-msgstr "Pøejete si ulo¾it tuto zprávu do souboru? (y/n) [n] "
-#: ../raster/r.coin/inter.c:99
-#, c-format
msgid ""
-"Enter the file name or path\n"
+"column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data "
+"may be damaged"
msgstr ""
-"Zadejte jméno souboru\n"
+"sloupec '%s' : typ int8 (bigint) byl ulo¾en jako integer (celé èíslo - 4 "
+"byty) nìkterá data mohou být po¹kozena"
-#: ../raster/r.coin/inter.c:102
+#: ../db/drivers/postgres/describe.c:115
#, c-format
-msgid "'%s' being saved\n"
-msgstr "'%s' ulo¾en\n"
-#: ../raster/r.coin/inter.c:111
-#, c-format
msgid ""
-"Do you wish to print this report (requires Unix lpr command)? (y/n) [n] "
+"column '%s' : type character varying is stored as varchar(250) some data may "
+"be lost"
msgstr ""
-"Pøejete si vytisknout tuto zprávu (vy¾aduje Unixový pøíkaz lpr)? (y/n) [n] "
+"sloupec '%s' : typ character varying byl ulo¾en jako varchar(250), nìkterá "
+"data mohou být ztracena"
-#: ../raster/r.coin/inter.c:117
+#: ../db/drivers/postgres/describe.c:121
#, c-format
msgid ""
-"Do you wish it printed in 80 or 132 columns?\n"
+"column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 "
+"(true)"
msgstr ""
-"Pøejete si vytisknout ji v 80 nebo 132 sloupcích?\n"
+"sloupec '%s' : typ boolean je ulo¾en jako char(1), hodnoty: 0 (false), 1 "
+"(true)"
-#: ../raster/r.coin/inter.c:130
+#: ../db/drivers/sqlite/describe.c:161
#, c-format
-msgid ""
-"Do you wish to run this report with a different unit of measure? (y/n) [y] "
-msgstr "Pøejete si vytvoøit tuto zprávu s rùznými jednotkami? (y/n) [y]"
+msgid "SQLite driver: column '%s', SQLite type %d is not supported"
+msgstr "Ovladaè SQLite: sloupec '%s', typ SQLite %d není podporován"
-#: ../raster/r.coin/print_coin.c:45
-#, c-format
-msgid "Preparing report ..."
-msgstr "Pøipravuji zprávu ..."
-#: ../raster/r.coin/cmd_parms.c:44
-msgid ""
-"Tabulates the mutual occurrence (coincidence) of categories for two raster "
-"map layers."
+#: ../db/base/connect.c:46
+msgid "Prints/sets general DB connection for current mapset and exits."
msgstr ""
-"Vytvoøí tabulku mutualoccurrence (koincidence) kategorií pro dvì rastrové "
-"mapy."
+"Vytisknout/nastavit obecné DB pøipojení aktuálního mapsetu a ukonèit se."
-#: ../raster/r.coin/cmd_parms.c:52
-msgid "Name of first raster map"
-msgstr "Název první rastrové mapy"
+#: ../db/base/connect.c:51
+msgid "Print current connection parameters and exit"
+msgstr "Vypi¹ parametry souèasného pøipojení a ukonèi se"
-#: ../raster/r.coin/cmd_parms.c:59
-msgid "Name of second raster map"
-msgstr "Název druhé rastrové mapy"
+#: ../db/base/connect.c:56
+msgid "Check connection parameters, set if uninitialized, and exit"
+msgstr ""
+"Zkontrolovat nastavení parametrù souèasného pøipojení, nastavit je pokud "
+"nejsou, a ukonèit se"
-#: ../raster/r.coin/cmd_parms.c:65
-msgid "Unit of measure"
-msgstr "Jednotky mìøítka"
+#: ../db/base/connect.c:71
+msgid "Database schema"
+msgstr "Schéma databáze."
-#: ../raster/r.coin/cmd_parms.c:66
+#: ../db/base/connect.c:72
msgid ""
-"c(ells), p(ercent), x(percent of category [column]), y(percent of category "
-"[row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
+"Do not use this option if schemas are not supported by driver/database server"
msgstr ""
+"Tuto volbu nepou¾ívejte, pokud schémata nejsou podporována ovladaèem/"
+"databázovým serverem."
-#: ../raster/r.coin/cmd_parms.c:73
-msgid "Wide report, 132 columns (default: 80)"
-msgstr "Del¹í zpráva, 132 sloupcù (výchozí: 80)"
+#: ../db/base/connect.c:81
+msgid "Default group of database users to which select privilege is granted"
+msgstr ""
+"Výchozí skupina u¾ivatelù databáze, které jsou pøiøazeny práva na select."
-#: ../raster/r.coin/make_coin.c:48
-#, c-format
-msgid "Tabulating Coincidence between '%s' and '%s'"
-msgstr "Vypoèítávám koincidenci mezi '%s' a '%s'"
+#: ../db/base/connect.c:113
+msgid "Database connection not defined. Run db.connect."
+msgstr "Spojení s databází nebylo pro ovladaè definováno. Spus»te db.connect"
-#: ../raster/r.coin/make_coin.c:58
-msgid "Unable to create any tempfiles"
-msgstr "Nelze vytvoøit ¾ádné doèasné soubory"
-#: ../raster/r.coin/make_coin.c:62
-msgid "Unable to run r.stats"
-msgstr "Nelze spustit r.stats"
-#: ../raster/r.coin/make_coin.c:72
-msgid "Unexpected output from r.stats"
-msgstr "Neoèekávaný výstup z r.stats"
-#: ../raster/r.coin/make_coin.c:83
-msgid "Unable to open tempfile"
-#: ../raster/r.out.png/r.out.png.c:179 ../raster/r.out.ppm/main.c:109
-#: ../raster/r.out.ppm3/main.c:105
+#: ../db/base/connect.c:133
#, c-format
-msgid "rows = %d, cols = %d"
-msgstr "øádkù = %d, sloupcù = %d"
+msgid ""
+"Default driver / database set to:\n"
+"driver: %s\n"
+"database: %s"
+msgstr ""
+"Výchozí ovladaè /databáze nastavena na:\n"
+"ovladaè: %s\n"
+"databáze: %s"
-#: ../raster/r.out.png/r.out.png.c:253
-#, c-format
-msgid "Converting %s..."
-msgstr "Pøevádím %s..."
+#: ../db/base/connect.c:139
+msgid "Default driver is not set"
+msgstr "Základní ovladaè není nastaven"
-#: ../raster/r.distance/main.c:40
-msgid "Locates the closest points between objects in two raster maps."
-msgstr "Nalezne nejbli¾¹í body mezi objekty ze dvou rastrových map."
+#: ../db/base/connect.c:142
+msgid "Default database is not set"
+msgstr "Název vstupní databáze není nastaven"
-#: ../raster/r.distance/edges.c:40
+#: ../db/base/select.c:63 ../db/base/createdb.c:42 ../db/base/databases.c:51
+#: ../db/base/tables.c:45 ../db/base/droptable.c:43 ../db/base/dropdb.c:42
+#: ../db/base/describe.c:51 ../db/base/execute.c:61 ../db/base/columns.c:44
+#: ../display/d.vect/main.c:480 ../display/d.thematic.area/main.c:207
+#: ../vector/v.edit1/cmd/select.c:505 ../vector/v.db.connect/main.c:173
+#: ../vector/v.db.connect/main.c:228 ../vector/v.edit/select.c:531
+#: ../vector/v.out.ogr/main.c:304 ../vector/v.out.svg/main.c:138
+#: ../vector/v.extract/main.c:224
#, c-format
-msgid "Reading map %s ..."
-msgstr "Naèítám mapu %s ..."
+msgid "Unable to start driver <%s>"
+msgstr "Nelze spustit ovladaè <%s>"
-#: ../raster/r.distance/distance.c:97
+#: ../db/base/select.c:69 ../db/base/tables.c:50 ../db/base/describe.c:56
+#: ../db/base/execute.c:67 ../display/d.vect/main.c:485
+#: ../display/d.thematic.area/main.c:212
#, c-format
-msgid "Reading maps <%s,%s> while finding 0 distance ..."
-msgstr "Naèítám mapy <%s,%s> bìhem hledání vzdálenosti 0 ..."
+msgid "Unable to open database <%s>"
+msgstr "Nelze otevøít databázi <%s>"
-#: ../raster/r.distance/parse.c:41
-msgid "Maps for computing inter-class distances"
-msgstr "Mapy pro poèítání vzdáleností mezi tøídami"
+#: ../db/base/select.c:197
+msgid "SQL select statement"
+msgstr "SQL povel pro výbìr (select)"
-#: ../raster/r.distance/parse.c:54
-msgid "Include category labels in the output"
-msgstr "Zahrò do výstupu ¹títky kategorií"
-#: ../raster/r.distance/parse.c:58
-msgid "Report zero distance if rasters are overlapping"
-msgstr "Vypi¹ nulovou vzdálenost pokud se rastry pøekrývají"
-#: ../raster/r.distance/report.c:41
-msgid "Processing..."
-msgstr "Zpracovávám..."
-#: ../raster/r.surf.fractal/interface.c:34
-msgid "Creates a fractal surface of a given fractal dimension."
-msgstr "Vytváøí fraktální povrch o zadané fraktální dimenzi"
-#: ../raster/r.surf.fractal/interface.c:50
-msgid "Name of fractal surface raster layer"
-msgstr "Název rastrové mapy s fraktálním povrchem"
-#: ../raster/r.surf.fractal/interface.c:55
-msgid "Fractal dimension of surface (2 < D < 3)"
-msgstr "Fraktální dimenze povrchu (2 < D < 3)"
-#: ../raster/r.surf.fractal/interface.c:61
-msgid "Number of intermediate images to produce"
-msgstr "Poèet snímkù k vytvoøení spektrálních koeficientù"
-#: ../raster/r.surf.fractal/interface.c:74
-#, c-format
-msgid "Steps=%d"
-msgstr "Kroky=%d"
-#: ../raster/r.surf.fractal/interface.c:84 ../raster/r.reclass/main.c:80
-#: ../raster/r.los/main.c:163 ../raster/r.in.ascii/main.c:207
-#: ../raster/r.texture/main.c:227 ../raster/r.average/main.c:77
-#: ../raster/r.surf.idw2/main.c:84 ../raster/r.mode/main.c:95
-#: ../raster/r.to.rast3elev/main.c:474 ../raster/r.surf.idw/main.c:112
-#: ../raster/r.in.gdal/main.c:206 ../raster/r.random/main.c:136
-#: ../raster/r.random/main.c:141 ../raster/r.median/main.c:75
-#: ../raster/r.slope.aspect/opennew.c:11 ../raster/r.surf.gauss/main.c:74
-#: ../raster/r.cost/main.c:324 ../raster/r.neighbors/main.c:185
-#: ../raster/r.clump/main.c:91 ../raster/r.in.mat/main.c:352
-#: ../raster/r.watershed/ram/init_vars.c:330
-#: ../raster/r.watershed/shed/com_line.c:194
-#: ../raster/r.watershed/shed/com_line.c:224
-#: ../raster/r.watershed/seg/init_vars.c:360
-#: ../raster/r.water.outlet/legal.c:10 ../raster/r.walk/main.c:531
-#: ../raster/r.recode/main.c:85 ../raster/wildfire/r.spread/main.c:383
-#: ../raster/wildfire/r.spread/main.c:395
-#: ../raster/wildfire/r.spread/main.c:408 ../raster/r.buffer/main.c:118
-#: ../raster/r.bitpattern/main.c:104 ../vector/v.to.rast3/main.c:68
-#: ../vector/v.kernel/main.c:232 ../vector/v.in.ogr/main.c:316
-#: ../vector/v.surf.idw/main.c:121 ../vector/v.random/main.c:123
-#: ../doc/raster/r.example/main.c:113 ../imagery/i.ifft/ifftmain.c:107
-#: ../imagery/i.zc/main.c:118
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/opennew.c:11
-#: ../general/manage/cmd/rename.c:87 ../general/manage/cmd/copy.c:92
-#, c-format
-msgid "<%s> is an illegal file name"
-msgstr "<%s> je neplatné jméno souboru"
-#: ../raster/r.surf.fractal/interface.c:93
-#, c-format
-msgid "Fractal dimension of [%.2lf] must be between 2 and 3."
-msgstr "Fraktální dimenze povrchu [%.2lf] musí být mezi 2 a 3."
-#: ../raster/r.surf.fractal/open_files.c:19
-#: ../raster/r.surf.fractal/write_rast.c:52
-msgid "ERROR: Problem opening output file."
-msgstr "Problém pøi otevøení výstupního souboru."
-#: ../raster/r.surf.fractal/spec_syn.c:52
-msgid "Preliminary surface calculations."
-msgstr "Pøedbì¾né kalkulace povrchu."
-#: ../raster/r.surf.fractal/spec_syn.c:110
-#, c-format
-msgid "Calculating surface %d (of %d)"
-msgstr "Poèítám povrch %d (z %d)"
-#: ../raster/r.reclass/main.c:50
-msgid ""
-"Creates a new map layer whose category values are based upon a "
-"reclassification of the categories in an existing raster map layer."
+#: ../db/base/select.c:198
+msgid "For example: 'select * from rybniky where kapri = 'hodne'"
msgstr ""
-"Vytvoøí novou mapovou vrstvu její¾ hodnoty budou zalo¾eny na reklasifikaci "
-"hodnot výchozí rastrové mapy."
+"Pøíkaz SQL select, napø.: 'select * from rybniky where kapri = 'hodne'"
-#: ../raster/r.reclass/main.c:55
-msgid "Raster map to be reclassified"
-msgstr "Rastrová mapa, která má být reklasifikována"
+#: ../db/base/select.c:201 ../vector/v.db.select/main.c:57
+#: ../raster/r.distance/parse.c:50 ../raster/r.cats/main.c:70
+#: ../raster/r.stats/main.c:108
+msgid "Output field separator"
+msgstr "Výstupní oddìlovaè sloupcù"
-#: ../raster/r.reclass/main.c:62
-msgid "File containing reclass rules"
-msgstr "Soubor obsahující pravidla reklasifikace"
+#: ../db/base/select.c:205 ../vector/v.db.select/main.c:61
+msgid "Output vertical record separator"
+msgstr "Výstupní vertikální oddìlovaè záznamù"
-#: ../raster/r.reclass/main.c:70 ../raster/r.recode/main.c:61
-msgid "Title for the resulting raster map"
-msgstr "Titulek výsledné rastrové mapy"
+#: ../db/base/select.c:212 ../vector/v.db.select/main.c:68
+msgid "Null value indicator"
+msgstr "Indikátor hodnoty NULL záznamu"
-#: ../raster/r.reclass/main.c:83 ../raster/r.recode/main.c:88
-msgid "Input map can NOT be the same as output map"
-msgstr "Vstupní mapa NEmù¾e být stejná jako výstupní"
+#: ../db/base/select.c:216
+msgid "Name of file with sql statement"
+msgstr "Název souboru s pøíkazy sql"
-#: ../raster/r.reclass/main.c:90 ../raster/r.recode/main.c:95
-#, c-format
-msgid "Cannot open rules file <%s>"
-msgstr "Nelze otevøít soubor s pravidly <%s>"
+#: ../db/base/select.c:220 ../vector/v.db.select/main.c:72
+msgid "Do not include column names in output"
+msgstr "Nezahrnuj jména sloupcù do výstupu"
-#: ../raster/r.reclass/main.c:103
-#, c-format
-msgid "Enter rule(s), \"end\" when done, \"help\" if you need it\n"
-msgstr "Zadejte pravidla, \"end\" pro ukonèení, \"help\" pro nápovìdu\n"
+#: ../db/base/select.c:224
+msgid "Describe query only (don't run it)"
+msgstr "Dotaz pouze popi¹ (neprovádìj)"
-#: ../raster/r.reclass/main.c:105
-#, c-format
-msgid "fp: Data range is %.25f to %.25f\n"
-msgstr "fp: Rozsah dat je %.25f a¾ %.25f\n"
+#: ../db/base/select.c:228 ../vector/v.db.select/main.c:76
+msgid "Vertical output (instead of horizontal)"
+msgstr "Vertikální výstup (místo horizontálního)"
-#: ../raster/r.reclass/main.c:107 ../raster/r.colors/rules.c:51
-#, c-format
-msgid "Data range is %ld to %ld\n"
-msgstr "Rozsah dat je %ld a¾ %ld\n"
+#: ../db/base/select.c:232
+msgid "Only test query, do not execute"
+msgstr "Pouze otestovat dotaz, neprovádìt"
-#: ../raster/r.reclass/main.c:117
-#, c-format
-msgid "Illegal reclass rule -"
-msgstr "Neplatné pravidlo reklasifikace -"
+#: ../db/base/select.c:237
+msgid "Selects data from table."
+msgstr "Vyber data z tabulky."
-#: ../raster/r.reclass/main.c:118
-#, c-format
-msgid " ignored\n"
-msgstr "ignorováno\n"
+#: ../db/base/createdb.c:72
+msgid "Creates an empty database."
+msgstr "Vytvoøit prázdnou databázi."
-#: ../raster/r.reclass/main.c:122
-msgid " - invalid reclass rule"
-msgstr " - neplatné pravidlo reclasifikace"
+#: ../db/base/databases.c:54
+msgid "Unable to list databases"
+msgstr "Nelze vypsat databáze"
-#: ../raster/r.reclass/main.c:136
-#, c-format
-msgid "No rules specified. Raster map <%s> not created"
-msgstr "®ádná pravidla nebyla zadána. Rastrová mapa <%s> nebyla vytvoøena"
+#: ../db/base/databases.c:84
+msgid "Location name"
+msgstr "Jméno location"
-#: ../raster/r.reclass/main.c:138 ../raster/r.recode/main.c:103
-msgid "No rules specified"
-msgstr "®ádná pravidla nebyla zadána"
+#: ../db/base/databases.c:90
+msgid "List all databases for a given driver and location."
+msgstr "Vypi¹ v¹echny databáze pro daný ovladaè a umístìní."
-#: ../raster/r.reclass/parse.c:43 ../raster/r.colors/rules.c:103
-#, c-format
-msgid "Enter a rule in one of these formats:\n"
-msgstr "Zadejte pravidlo v jednom z tìchto formátù:\n"
+#: ../db/base/tables.c:87
+msgid "Print tables and exit"
+msgstr "vypi¹ tabulky a ukonèi se."
-#: ../raster/r.reclass/parse.c:44
-msgid "poor quality"
-msgstr "nízká kvalita"
+#: ../db/base/tables.c:91
+msgid "System tables instead of user tables"
+msgstr "systémové tabulky místo u¾ivatelských"
-#: ../raster/r.reclass/parse.c:46
-msgid "medium quality"
-msgstr "støední kvalita"
+#: ../db/base/tables.c:96
+msgid "Lists all tables for a given database."
+msgstr "Vypí¹e v¹echny tabulky pro danou databázi."
-#: ../raster/r.reclass/parse.c:63
-msgid "Can't have null on the left-hand side of the rule"
-msgstr "Nelze mít NULL na levé stranì pravidla"
+#: ../db/base/droptable.c:79
+msgid "Removes a table from database."
+msgstr "Odstraní tabulku z databáze."
-#: ../raster/r.reclass/parse.c:92 ../raster/r.reclass/parse.c:105
-msgid "Can't have null on the right-hand side of the rule"
-msgstr "Nelze mít NULL na pravé stranì pravidla"
+#: ../db/base/dropdb.c:72
+msgid "Removes a database."
+msgstr "Odstraòuji databázi."
-#: ../raster/r.reclass/parse.c:211
-#, c-format
-msgid "%f rounded up to %d\n"
-msgstr "%f zaokrouhleno nahoru na %d\n"
+#: ../db/base/copy.c:35
+msgid ""
+"Copy a table. Either 'from_table' (optionaly with 'where') can be used or "
+"'select' option, but not 'from_table' and 'select' at the same time."
+msgstr ""
+"Kopíruj tabulku. Pou¾ita mù¾e být buï volba 'from_table' (volitelnì s "
+"'where') nebo volba 'select', ale nikoliv 'from_table' a 'select' souèasnì."
-#: ../raster/r.reclass/reclass.c:51 ../raster/r.reclass/reclass.c:116
-msgid "Too many categories"
-msgstr "Pøíli¹ mnoho kategorií"
+#: ../db/base/copy.c:43
+msgid "Input driver name"
+msgstr "Název vstupního ovladaèe"
-#: ../raster/r.reclass/reclass.c:222
-#, c-format
-msgid "Cannot read header file of <%s@%s>"
-msgstr "Nelze èíst hlavièkový soubor pro <%s@%s>"
+#: ../db/base/copy.c:51
+msgid "Input database name"
+msgstr "Název vstupní databáze"
-#: ../raster/r.reclass/reclass.c:238
-#, c-format
-msgid "Cannot create reclass file of <%s>"
-msgstr "Nelze vytvoøit reklasifikaèní soubor <%s>"
+#: ../db/base/copy.c:59
+msgid "Input table name (only, if 'select' is not used)"
+msgstr "Název vstupní tabulky (pouze pokud nebyla pou¾ita klauzule 'select')"
-#: ../raster/r.reclass/reclass.c:251
-#, c-format
-msgid "Cannot create category file of <%s>"
-msgstr "Nelze vytvoøit soubor s kategoriemi <%s>"
+#: ../db/base/copy.c:66
+msgid "Output driver name"
+msgstr "Název výstupního ovladaèe"
-#: ../raster/r.los/main.c:79
-msgid "Line-of-sight raster analysis program."
-msgstr "Vytváøí rastrovou mapu linií dohlednosti."
+#: ../db/base/copy.c:74
+msgid "Output database name"
+msgstr "Název výstupní databáze"
-#: ../raster/r.los/main.c:93
-msgid "Coordinate identifying the viewing position"
-msgstr "Souøadnice identifikující místo rozhledu"
+#: ../db/base/copy.c:82
+msgid "Output table name"
+msgstr "Název výstupní tabulky"
-#: ../raster/r.los/main.c:98
-msgid "Binary (1/0) raster map to use as a mask"
-msgstr "Binární (1/0) rastrová mapa pou¾itelná jako MASKA"
+#: ../db/base/copy.c:88
+msgid ""
+"Optional where condition (without WHERE key word), e.g.:\n"
+"\t\tobec = 'Liptakov'"
+msgstr ""
+"Volitelná podmínka where (bez klíèového slova WHERE), napø.:\n"
-#: ../raster/r.los/main.c:105
-msgid "Viewing position height above the ground"
-msgstr "Vý¹ka místa rozhledu nad terénem "
+#: ../db/base/copy.c:95
+msgid ""
+"Full select statement (only, if 'from_table' and 'where' is not used), e."
+"g.:\n"
+"\t\tSELECT dedek FROM starobince WHERE obec = 'Frimburg'"
+msgstr ""
+"Úplný pøíkaz select (pouze pokud nebyly pou¾ity 'from_table' a 'where'), "
+"napø.:\n"
-#: ../raster/r.los/main.c:113
-msgid "Maximum distance from the viewing point (meters)"
-msgstr "Maximální vzdálenost od bodu rozhledu (metry)"
+#: ../db/base/copy.c:104
+msgid "Cannot combine 'from_table' and 'select' options"
+msgstr "Nelze kombinovat volby 'from_table' a 'select'"
-#: ../raster/r.los/main.c:139
-msgid "Lat/Long support is not (yet) implemented for this module."
-msgstr "Tento modul prozatím nepodporuje lat/long"
+#: ../db/base/copy.c:116
+msgid "Either 'from_table' or 'select' option must be given."
+msgstr "Musíte zadat buï 'from_table' nebo 'select'."
-#: ../raster/r.los/main.c:145
-msgid "Specified observer coordinate is outside current region bounds."
-msgstr "Specifikovaná pozici pozorovatele je mimo souèasný region."
+#: ../db/base/copy.c:119
+msgid "Cannot combine 'select' and 'where' options"
+msgstr "Nelze kombinovat volby 'select' a 'where'"
-#: ../raster/r.los/main.c:167 ../raster/r.los/main.c:172
-#: ../raster/r.resamp.rst/main.c:408 ../raster/r.resamp.rst/main.c:431
-#, c-format
-msgid "[%s]: Cannot read map header"
-msgstr "Nelze èíst hlavièkový soubor mapy [%s]"
+#: ../db/base/copy.c:127
+msgid "Copy table failed"
+msgstr "Kopírování tabulky se nezdaøilo"
-#: ../raster/r.los/main.c:201
-msgid "Pattern map should be a binary 0/1 CELL map"
-msgstr "Vzorová mapa by mìla být binární (0/1 CELL) "
-#: ../raster/r.los/main.c:241 ../raster/r.los/main.c:248
-#: ../raster/r.profile/read_rast.c:47 ../raster/r.profile/read_rast.c:73
-#: ../raster/r.profile/read_rast.c:99 ../raster/r.out.gdal/main.c:236
-#: ../raster/r.out.gdal/main.c:266 ../raster/r.out.gdal/main.c:296
-#: ../raster/r.patch/main.c:160 ../raster/r.patch/main.c:168
-#: ../raster/r.topidx/file_io.c:64 ../raster/r.out.ppm/main.c:187
-#: ../raster/r.cost/main.c:399 ../raster/r.cost/main.c:603
-#: ../raster/r.walk/main.c:700 ../raster/r.walk/main.c:758
-#: ../raster/r.walk/main.c:873 ../raster/r.walk/main.c:1413
-#: ../raster/r.walk/main.c:1448 ../raster/r.walk/main.c:1482
-#: ../raster/r.buffer/read_map.c:60 ../raster/r.buffer/write_map.c:65
-#: ../raster/r.bitpattern/main.c:135 ../vector/v.what.rast/main.c:258
-#: ../vector/v.what.rast/main.c:261 ../vector/v.to.rast/support.c:411
-#: ../doc/raster/r.example/main.c:153 ../imagery/i.gensig/get_train.c:33
+#: ../db/base/describe.c:63 ../vector/v.in.ascii/in.c:401
+#: ../vector/v.patch-tab/main.c:522 ../vector/v.patch-tab/main.c:563
+#: ../vector/v.db.connect/main.c:182 ../vector/v.out.ogr/main.c:313
+#: ../vector/v.patch/main.c:140 ../vector/v.patch/main.c:181
+#: ../vector/v.out.svg/main.c:150
#, c-format
-msgid "Unable to read raster map <%s> row %d"
-msgstr "Nelze èíst rastrovou mapu <%s> øádek %d"
+msgid "Unable to describe table <%s>"
+msgstr "Nelze popsat tabulku <%s>"
-#: ../raster/r.drain/main.c:105
-msgid "Traces a flow through an elevation model on a raster map layer."
-msgstr "Urèí smìr povrchového odtoku na rastrovém modelu reliéfu."
+#: ../db/base/describe.c:105
+msgid "Print column names only instead of full column descriptions"
+msgstr "vypi¹ pouze jména sloupcù místo plného popisu sloupcù"
-#: ../raster/r.drain/main.c:109 ../raster/r.fill.dir/main.c:91
-msgid "Name of existing raster map containing elevation surface"
-msgstr "Jméno existujícího rastru obsahujícího digitální model terénu."
+#: ../db/base/describe.c:110
+msgid "Print table structure"
+msgstr "Vypi¹ strukturu tabulky"
-#: ../raster/r.drain/main.c:112
-msgid "Output drain raster map"
-msgstr "Název rastrové mapy odtoku"
+#: ../db/base/describe.c:127
+msgid "Describes a table in detail."
+msgstr "Popi¹ tabulku (detailnì)."
-#: ../raster/r.drain/main.c:121
-msgid "The E and N coordinates of starting point(s)"
-msgstr "Mapa V a S souøadnic gridu poèáteèního bodu(ù)"
+#: ../db/base/drivers.c:40
+msgid "Error trying to read dbmscap file\n"
+msgstr "Chyba pøi pokusu èíst soubor dbmscap\n"
-#: ../raster/r.drain/main.c:131
-msgid "Vector map(s) containing starting point(s)"
-msgstr "Vektorové mapy obsahující poèáteèní bod(y)"
+#: ../db/base/drivers.c:65
+msgid "Full output"
+msgstr "Úplný výstup"
-#: ../raster/r.drain/main.c:135
-msgid "Copy input cell values on output"
-msgstr "Kopíruj vstupní hodnoty bunìk na výstup"
+#: ../db/base/drivers.c:69
+msgid "print drivers and exit"
+msgstr "vypi¹ ovladaèe a ukonèi se"
-#: ../raster/r.drain/main.c:139
-msgid "Accumulate input values along the path"
-msgstr "Proveï akumulaci hodnot ve smìru pohybu/odtoku"
+#: ../db/base/drivers.c:74
+msgid "List all database drivers."
+msgstr "Vypi¹ v¹echny databázové ovladaèe."
-#: ../raster/r.drain/main.c:143
-msgid "Count cell numbers along the path"
-msgstr "Spoèítej buòky ve smìru pohybu/odtoku"
-#: ../raster/r.drain/main.c:164
-msgid "Specify just one of the -c, -a and -n flags"
-msgstr "Pouze jedna z voleb -c, -a a -n"
-#: ../raster/r.drain/main.c:183
-msgid "Metrics allocation"
-msgstr "Alokace metriky"
-#: ../raster/r.drain/main.c:194
+#: ../db/base/execute.c:78 ../db/base/execute.c:83
#, c-format
-msgid "Starting point %d is outside the current region"
-msgstr "Poèáteèní bod %d je mimo souèasný region"
+msgid "Error while executing: '%s'"
+msgstr "Chyba pøi vykonávání: '%s'"
-#: ../raster/r.drain/main.c:201 ../raster/r.drain/main.c:239
-#, fuzzy
-msgid "Too many start points"
-msgstr "Pøíli¹ mnoho poèáteèních bodù"
+#: ../db/base/execute.c:109
+msgid "Executes any SQL statement."
+msgstr "Vykoná jakýkoliv pøíkaz SQL."
-#: ../raster/r.drain/main.c:215 ../raster/r.carve/main.c:167
-#: ../raster/r.cost/main.c:298 ../raster/r.region/main.c:230
-#: ../vector/v.db.connect/main.c:113 ../vector/v.perturb/main.c:153
-#: ../vector/v.edit/cmd/main.c:124
-#: ../vector/lidar/v.lidar.edgedetection/main.c:164
-#: ../vector/lidar/v.lidar.correction/main.c:138
-#: ../vector/lidar/v.outlier/main.c:143
-#: ../vector/lidar/v.lidar.growing/main.c:119
-#: ../vector/lidar/v.surf.bspline/main.c:224
-#: ../vector/lidar/v.surf.bspline/main.c:241
-#: ../vector/v.net.salesman/main.c:158 ../vector/v.distance/main.c:283
-#: ../vector/v.reclass/main.c:99 ../vector/v.to.points/main.c:228
-#: ../vector/v.segment/main.c:95 ../vector/v.db.select/main.c:91
-#: ../vector/v.univar/main.c:109 ../vector/v.what.rast/main.c:116
-#: ../vector/v.build.polylines/main.c:136 ../vector/v.net.iso/main.c:174
-#: ../vector/v.extrude/main.c:143 ../vector/v.kernel/main.c:192
-#: ../vector/v.sample/main.c:151 ../vector/v.generalize/main.c:300
-#: ../vector/v.info/main.c:96 ../vector/v.qcount/main.c:126
-#: ../vector/v.out.pov/main.c:93 ../vector/v.transform/main.c:228
-#: ../vector/v.convert/old2new.c:27 ../vector/v.overlay/main.c:184
-#: ../vector/v.net.path/main.c:126 ../vector/v.label.sa/labels.c:56
-#: ../vector/v.clean/main.c:225 ../vector/v.kcv/main.c:132
-#: ../vector/v.net/main.c:139 ../vector/v.net/main.c:153
-#: ../vector/v.out.dxf/main.c:67 ../vector/v.normal/main.c:128
-#: ../vector/v.voronoi/dt_main.c:75 ../vector/v.voronoi/vo_main.c:145
-#: ../vector/v.what/main.c:142 ../vector/v.hull/main.c:253
-#: ../vector/v.out.svg/main.c:124 ../vector/v.to.db/parse.c:112
-#: ../vector/v.select/main.c:180 ../vector/v.net.alloc/main.c:130
-#: ../vector/v.label/main.c:265 ../vector/v.type/main.c:204
-#: ../vector/v.surf.rst/main.c:513 ../vector/v.to.rast/vect2rast.c:37
-#: ../vector/v.drape/main.c:138 ../vector/v.out.ogr/main.c:196
-#: ../vector/v.net.steiner/main.c:394 ../vector/v.lrs/v.lrs.label/main.c:272
-#: ../vector/v.lrs/v.lrs.segment/main.c:135
-#: ../vector/v.lrs/v.lrs.create/main.c:236
-#: ../vector/v.lrs/v.lrs.create/main.c:244
-#: ../vector/v.lrs/v.lrs.where/main.c:123
-#: ../vector/v.lrs/v.lrs.where/main.c:131 ../vector/v.buffer/main.c:353
-#: ../vector/v.extract/main.c:139 ../doc/vector/v.example/main.c:61
-#: ../display/d.what.vect/main.c:149 ../display/d.vect/main.c:450
-#: ../display/d.vect.chart/main.c:227 ../display/d.extract/main.c:96
-#: ../display/d.zoom/main.c:259 ../display/d.extend/main.c:103
-#: ../display/d.path/main.c:192 ../general/g.region/cmd/main.c:518
-#, c-format
-msgid "Vector map <%s> not found"
-msgstr "Vektorová mapa <%s> nebyla nalezena"
+#: ../db/base/execute.c:113
+msgid "Name of file containing SQL statements"
+msgstr "Soubor obsahující pøíkazy SQL"
-#: ../raster/r.drain/main.c:221
-msgid "Failed to guess site file format"
-msgstr "Selhal jsem pøi hádání formátu bodù"
+#: ../db/base/execute.c:126
+msgid "Ignore SQL errors and continue"
+msgstr "Ignoruj chyby SQL a pokraèuj"
-#: ../raster/r.drain/main.c:245
-#, fuzzy, c-format
-msgid "Starting vector map <%s> contains no points in the current region"
-msgstr "Poèáteèní vektorová mapa <%s> je mimo souèasný region"
+#: ../db/base/execute.c:152
+msgid "Use db.select for SELECT SQL statements"
+msgstr "Pou¾ijte db.select pro povel SQL SELECT "
-#: ../raster/r.drain/main.c:251
-msgid "No start/stop point(s) specified"
-msgstr "Nebyly specifikovány poèáteèní/koncové bod(y)"
+#: ../db/base/columns.c:92
+msgid "List all columns for a given table."
+msgstr "vypí¹e v¹echny sloupce pro zadanou tabulku."
-#: ../raster/r.in.ascii/gethead.c:37
-msgid "input file is not a Surfer ascii grid file"
-msgstr "vstupní souboru není typu Surfer ascii"
+#: ../raster3d/r3.to.rast/main.c:55
+msgid "Unable to close the 3d raster map"
+msgstr "Nelze zavøít vstupní 3D rastr"
-#: ../raster/r.in.ascii/gethead.c:44
-msgid "error reading the column and row dimension from the Surfer grid file"
-msgstr "chyba pøi ètení dimenzí øádku a sloupce ze rastrového souboru Surfer"
+#: ../raster3d/r3.to.rast/main.c:79
+msgid "3d raster map(s) to be converted to 2D raster slices"
+msgstr "Pøevod rastrové 3d mapy na rastrovou 2D mapu"
-#: ../raster/r.in.ascii/gethead.c:51
-msgid "error reading the X range from the Surfer grid file"
-msgstr "chyba pøi ètení rozsahu X v rastrovém souboru Surfer"
+#: ../raster3d/r3.to.rast/main.c:85
+msgid "Basename for resultant raster slice maps"
+msgstr "Základ názvu výsledného výøezu rastrové mapy"
-#: ../raster/r.in.ascii/gethead.c:58
-msgid "error reading the Y range from the Surfer grid file"
-msgstr "chyba pøi ètení rozsahu Y z rastrového souboru Surfer"
+#: ../raster3d/r3.to.rast/main.c:90 ../raster3d/r3.out.ascii/main.c:109
+#: ../raster/r.to.rast3elev/main.c:233
+msgid "Use G3D mask (if exists) with input map"
+msgstr "Pou¾ít masku G3D (pokud existuje) s vstupní mapou"
-#: ../raster/r.in.ascii/gethead.c:65
-msgid "error reading the Z range from the Surfer grid file"
-msgstr "chyba pøi ètení rozsahu Z z rastrového souboru Surfer"
-#: ../raster/r.in.ascii/gethead.c:115
-msgid "error getting file position"
-msgstr "chyba pøi získání souboru s pozicí"
-#: ../raster/r.in.ascii/gethead.c:174
-msgid "illegal type field: using type int"
-msgstr "nevhodný typ pole, pou¾ívám celé èíslo"
-#: ../raster/r.in.ascii/gethead.c:179
-msgid "ignoring type filed in header, type is set on command line"
-msgstr "ignoruji typ pole v hlavièce, typ byl nastaven na pøíkazovém øádku"
-#: ../raster/r.in.ascii/gethead.c:189
-msgid "illegal multiplier field: using 1.0"
-msgstr "nalezen ¹patný èinitel pole: pou¾ívám 1.0"
-#: ../raster/r.in.ascii/gethead.c:194
-msgid "ignoring multiplier filed in header, multiplier is set on command line"
-msgstr ""
-"ignoruji pole s èitatelem v hlavièc, èitatel byl nastaven v pøíkazovém øádku"
-#: ../raster/r.in.ascii/gethead.c:203
-msgid "ignoring null filed in header, null string is set on command line"
-msgstr ""
-"ignoruji nullové pole v hlavièce, nullový øetìzec byl nastaven v pøíkazovém "
-"øádku"
-#: ../raster/r.in.ascii/gethead.c:232
-msgid "error in ascii data format"
-msgstr "chyba ve formátu ascii dat"
-#: ../raster/r.in.ascii/gethead.c:268 ../raster/r.in.arc/gethead.c:160
-#, c-format
-msgid "Duplicate \"%s\" field in header"
-msgstr "Dvojité pole \"%s\" v hlavièce"
-#: ../raster/r.in.ascii/gethead.c:273
-#, c-format
-msgid "Illegal \"%s\" value in header: %s"
-msgstr "Neplatná hodnota \"%s\" v hlavièce: %s"
-#: ../raster/r.in.ascii/gethead.c:280 ../raster/r.in.arc/gethead.c:172
-#, c-format
-msgid "\"%s\" field missing from header"
-msgstr "Pole \"%s\" v hlavièce chybí"
-#: ../raster/r.in.ascii/main.c:67
-msgid "raster, import, conversion"
-msgstr "rastr, import, pøevod"
-#: ../raster/r.in.ascii/main.c:69
-msgid "Converts ASCII raster file to binary raster map layer."
-msgstr "Pøevede ASCII rastrový soubor na binární rastrovou mapu."
-#: ../raster/r.in.ascii/main.c:73
+#: ../raster3d/r3.to.rast/main.c:95
msgid ""
-"ASCII raster file to be imported. If not given reads from standard input"
+"Use the same resolution as the input G3D map for the 2d output maps, "
+"independent of the current region settings"
msgstr ""
-"Soubor ASCII, který bude importován. Pokud není zadán, ète se standardní "
-"vstup"
+"Pou¾ij stejné rozli¹ení jako je vstupní G3D mapa pro 2d výstupní mapu, "
+"nezávisle na aktuálním rozli¹ení"
-#: ../raster/r.in.ascii/main.c:84 ../raster/r.in.bin/main.c:158
-#: ../raster/r.in.gdal/main.c:112 ../raster/r.in.poly/main.c:42
-#: ../raster/r.in.arc/main.c:85
-msgid "Title for resultant raster map"
-msgstr "Titulek pro výslednou rastrovou mapu"
+#: ../raster3d/r3.to.rast/main.c:152 ../raster3d/r3.to.rast/main.c:159
+msgid "Unable to write raster row"
+msgstr "Nelze ènyní zapsat rastrovou mapu."
-#: ../raster/r.in.ascii/main.c:91 ../raster/r.in.arc/main.c:92
-msgid "Multiplier for ASCII data"
-msgstr "Multiplikátor ASCII dat"
-#: ../raster/r.in.ascii/main.c:99
-msgid "String representing NULL value data cell"
-msgstr "Textový øetìzec pøedstavující NULLové hodnoty bunìk"
-#: ../raster/r.in.ascii/main.c:104
-msgid "Integer values are imported"
-msgstr "Celoèíselné hodnoty jsou importovány"
-#: ../raster/r.in.ascii/main.c:109
-msgid "Floating point values are imported"
-msgstr "Hodnoty s plovoucí desetinnou èárkou jsou importovány"
-#: ../raster/r.in.ascii/main.c:114
-msgid "Double floating point values are imported"
-msgstr "Hodnoty s plovoucí desetinnou èárkou (double) jsou importovány"
-#: ../raster/r.in.ascii/main.c:119
-msgid "SURFER (Golden Software) ASCII file will be imported"
-msgstr "Bude naimportován SURFER (Golden Software) ASCII rastrový soubor"
-#: ../raster/r.in.ascii/main.c:130 ../raster/r.in.ascii/main.c:160
-#: ../raster/r.resamp.rst/main.c:616 ../raster/r.resamp.rst/main.c:627
-#: ../raster/r.resamp.rst/main.c:639 ../raster/r.resamp.rst/main.c:652
-#: ../raster/r.resamp.rst/main.c:664 ../raster/r.resamp.rst/main.c:676
-#: ../raster/r.in.arc/main.c:113 ../vector/v.in.ascii/in.c:237
-#: ../vector/v.surf.rst/main.c:590 ../vector/v.surf.rst/main.c:598
-#: ../vector/v.surf.rst/main.c:606 ../vector/v.surf.rst/main.c:615
-#: ../vector/v.surf.rst/main.c:623 ../vector/v.surf.rst/main.c:631
-#: ../display/d.title/main.c:117 ../display/d.text/main.c:191
-#: ../display/d.text.new/main.c:398 ../general/g.setproj/get_stp.c:156
-#: ../general/g.setproj/get_stp.c:160 ../general/g.setproj/get_stp.c:272
-#: ../general/g.setproj/get_stp.c:277
+#: ../raster3d/r3.to.rast/main.c:183 ../doc/raster/r.example/main.c:140
+#: ../vector/lidar/v.surf.bspline/main.c:284 ../vector/v.neighbors/main.c:94
+#: ../vector/v.kernel/main.c:236 ../vector/v.to.rast/vect2rast.c:120
+#: ../vector/v.to.rast/vect2rast.c:124 ../vector/v.surf.idw/main.c:234
+#: ../raster/r.in.mat/main.c:413 ../raster/r.buffer/write_map.c:39
+#: ../raster/r.surf.random/randsurf.c:29 ../raster/r.surf.random/randsurf.c:33
+#: ../raster/r.resamp.interp/main.c:147 ../raster/r.basins.fill/main.c:116
+#: ../raster/r.texture/main.c:303 ../raster/r.circle/dist.c:127
+#: ../raster/r.series/main.c:185 ../raster/r.null/null.c:312
+#: ../raster/r.in.arc/main.c:151 ../raster/r.in.xyz/main.c:468
+#: ../raster/r.clump/main.c:99 ../raster/r.in.ascii/main.c:211
+#: ../raster/r.patch/main.c:147 ../raster/r.surf.idw2/main.c:111
+#: ../raster/r.thin/io.c:176 ../raster/r.bilinear/main.c:103
+#: ../raster/r.composite/main.c:200 ../raster/r.los/main.c:201
+#: ../raster/r.in.gdal/main.c:722 ../raster/r.in.gdal/main.c:727
+#: ../raster/r.in.gdal/main.c:743 ../raster/r.grow2/main.c:207
+#: ../raster/r.surf.idw/main.c:147 ../raster/r.mapcalc/map.c:513
+#: ../raster/r.mapcalc/map3.c:600 ../raster/r.li/r.li.daemon/daemon.c:113
+#: ../raster/r.cross/main.c:137 ../raster/r.carve/main.c:182
+#: ../raster/r.resamp.stats/main.c:346 ../raster/r.sunmask/main.c:437
+#: ../raster/r.bitpattern/main.c:125 ../raster/r.flow/io.c:179
+#: ../raster/r.flow/io.c:217 ../imagery/i.pca/main.c:395
+#: ../imagery/i.smap/shapiro/opencell.c:31 ../imagery/i.his.rgb/openfiles.c:16
+#: ../imagery/i.his.rgb/openfiles.c:18 ../imagery/i.his.rgb/openfiles.c:20
#, c-format
-msgid "Unable to open temporary file <%s>"
-msgstr "Nelze otevøít doèasný soubor <%s>"
+msgid "Unable to create raster map <%s>"
+msgstr "Nejsem schopen vytvoøit rastrovou mapu <%s>"
-#: ../raster/r.in.ascii/main.c:138
-#, c-format
-msgid "Wrong entry for multiplier: %s"
-msgstr "©patná hodnota násobitele: %s"
+#: ../raster3d/r3.to.rast/main.c:194 ../raster3d/r3.cross.rast/main.c:77
+#: ../raster3d/r3.cross.rast/main.c:387
+msgid "Unable to close output map"
+msgstr "Nelze zavøít výstupní mapu"
-#: ../raster/r.in.ascii/main.c:163
-msgid "Unable to read input from stdin"
-msgstr "Nelze èíst vstup ze standardního vstupu"
+#: ../raster3d/r3.to.rast/main.c:215 ../raster3d/r3.out.vtk/main.c:374
+#: ../raster3d/r3.cross.rast/main.c:268 ../raster3d/r3.gwflow/main.c:172
+#: ../raster3d/r3.mkdspf/main.c:74 ../raster3d/r3.in.v5d/main.c:198
+#: ../raster3d/base/r3.info.main.c:78 ../raster3d/base/r3.timestamp.main.c:42
+#: ../raster3d/base/r3.mask.main.c:153 ../raster3d/base/r3.null.main.c:203
+#: ../raster3d/r3.out.v5d/main.c:284
+msgid "raster3d, voxel"
+msgstr "rastr3d, voxel"
-#: ../raster/r.in.ascii/main.c:171
-#, c-format
-msgid "Unable to read input from <%s>"
-msgstr "Nelze èíst øádek vstupu z <%s>"
+#: ../raster3d/r3.to.rast/main.c:216
+msgid "Converts 3D raster maps to 2D raster maps"
+msgstr "Pøevede 3D rastrové mapy na 2D rastrové mapy"
-#: ../raster/r.in.ascii/main.c:191 ../raster/r.in.arc/main.c:126
-msgid "Can't get cell header"
-msgstr "Nelze dostat hlavièku rastrového souboru"
-#: ../raster/r.in.ascii/main.c:196 ../raster/r.out.tiff/r.out.tiff.c:173
-#: ../raster/r.in.arc/main.c:131
-msgid "Can't set window"
-msgstr "Nelze nastavit výøez"
-#: ../raster/r.in.ascii/main.c:199 ../raster/r.in.arc/main.c:134
+#: ../raster3d/r3.to.rast/main.c:225
#, c-format
-msgid "OOPS: rows changed from %d to %d"
-msgstr "JÉMINÁNKU: øádky se zmìnily z %d na %d"
+msgid "Open 3d raster map <%s>"
+msgstr "Otevøi mapu g3d <%s>"
-#: ../raster/r.in.ascii/main.c:201 ../raster/r.in.arc/main.c:136
+#: ../raster3d/r3.to.rast/main.c:228 ../raster3d/r3.cross.rast/main.c:283
#, c-format
-msgid "OOPS: cols changed from %d to %d"
-msgstr "JÉMINÁNKU: sloupce se zmìnily z %d na %d"
+msgid "3d raster map <%s> not found"
+msgstr "3D rastrová mapa <%s> nebyla nalezena"
-#: ../raster/r.in.ascii/main.c:219 ../raster/r.in.arc/main.c:161
+#: ../raster3d/r3.to.rast/main.c:243 ../raster3d/r3.to.rast/main.c:284
+#: ../raster3d/r3.out.vtk/main.c:208 ../raster3d/r3.out.vtk/main.c:291
+#: ../raster3d/r3.out.vtk/main.c:515 ../raster3d/r3.cross.rast/main.c:316
#, c-format
-msgid "Data conversion failed at row %d, col %d"
-msgstr "Selhal pøevod dat na øádku %d a sloupce %d"
+msgid "Error opening 3d raster map <%s>"
+msgstr "Chyba pøi otevírání 3d rastrové mapy <%s>"
-#: ../raster/r.in.ascii/main.c:296
-msgid "Unable to write to file"
-msgstr "Nelze zapisovat do souboru"
-#: ../raster/r.out.ascii/main.c:62
-msgid "Converts a raster map layer into an ASCII text file."
-msgstr "Pøevede rastrovou mapu do ASCII souboru."
-#: ../raster/r.out.ascii/main.c:71 ../raster/r.out.pov/main.c:130
-msgid "Name of an existing raster map"
-msgstr "Název existující rastrové mapy"
-#: ../raster/r.out.ascii/main.c:78
-msgid "Name for output ASCII grid map (use out=- for stdout)"
-msgstr "Název výstupního ASCII souboru (pro standardní výstup pou¾ijte out=-)"
-#: ../raster/r.out.ascii/main.c:90
+#: ../raster3d/r3.to.rast/main.c:267
msgid ""
-"Number of values printed before wrapping a line (only SURFER or MODFLOW "
-"format)"
+"The 2d and 3d region settings are different. Using the 2D window settings to "
+"adjust the 2D part of the 3D region."
msgstr ""
-"Poèet hodnot vyti¹tìných pøed zalomením øádku (pouze pro formáty SURFER nebo "
-"MODFLOW)"
+"2d a 3d rozli¹ení jsou rùzná. Pou¾iji nastavení 2d regionu pro nastavení 2d "
+"èásti 3d regionu."
-#: ../raster/r.out.ascii/main.c:97
-msgid "String to represent null cell (GRASS grid only)"
-msgstr "Textový øetìzec, reprezentující hodnotu NULL (pouze pro formát GRASS)"
+#: ../raster3d/r3.to.rast/main.c:299 ../raster3d/r3.out.v5d/main.c:197
+#: ../vector/v.mkgrid/write_grid.c:140 ../vector/v.in.ascii/a2b.c:161
+#: ../vector/v.surf.rst/main.c:826 ../vector/v.edit1/cmd/a2b.c:191
+#: ../vector/v.generalize/smoothing.c:93
+#: ../vector/v.generalize/smoothing.c:150
+#: ../vector/v.generalize/smoothing.c:250
+#: ../vector/v.generalize/smoothing.c:373
+#: ../vector/v.generalize/smoothing.c:402 ../vector/v.generalize/point.c:118
+#: ../vector/v.generalize/network.c:92 ../vector/v.generalize/network.c:124
+#: ../vector/v.generalize/simplification.c:33
+#: ../vector/v.generalize/simplification.c:40
+#: ../vector/v.generalize/simplification.c:306
+#: ../vector/v.generalize/simplification.c:314
+#: ../vector/v.generalize/simplification.c:336 ../vector/v.edit/a2b.c:191
+#: ../vector/v.mapcalc/list.c:56 ../vector/v.mapcalc/list.c:549
+#: ../raster/r.gwflow/main.c:376 ../raster/r.to.rast3/main.c:228
+#: ../raster/r.li/r.li.daemon/list.c:43 ../imagery/i.ask/popup.c:179
+msgid "Out of memory"
+msgstr "Pamì» vyèerpána"
-#: ../raster/r.out.ascii/main.c:105
-msgid "Write SURFER (Golden Software) ASCII grid"
-msgstr "Ulo¾ jako SURFER (Golden Software) ASCII rastr"
+#: ../raster3d/r3.to.rast/main.c:302 ../raster3d/r3.cross.rast/main.c:346
+#: ../raster/r.to.rast3/main.c:231
+msgid "Illegal output file name"
+msgstr "Neplatný název výstupního souboru"
-#: ../raster/r.out.ascii/main.c:109
-msgid "Write MODFLOW (USGS) ASCII array"
-msgstr "Ulo¾ jako MODFLOW (USGS) ASCII pole"
-#: ../raster/r.out.ascii/main.c:113
-msgid "Force output of integer values"
-msgstr "Vynucený výstup celoèíselných hodnot"
-#: ../raster/r.out.ascii/main.c:121
-#, fuzzy
-msgid "Failed to interpret dp as an integer"
-msgstr "selhal pøevod dp na celé èíslo"
-#: ../raster/r.out.ascii/main.c:130
-#, fuzzy
-msgid "Failed to interpret width as an integer"
-#: ../raster/r.out.ascii/main.c:136
-msgid "Both -s and -h doesn't make sense"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:139
-#, fuzzy
-msgid "Use -M or -s, not both"
-msgstr "Vyberte pouze jeden z pøepínaèù -n nebo -s, ne oba"
-#: ../raster/r.out.ascii/main.c:173 ../raster/r.profile/main.c:157
-#: ../raster/r.out.arc/main.c:132 ../raster/r.out.ppm3/main.c:147
-#: ../raster/r.cats/main.c:170 ../vector/v.out.ascii/out.c:137
-#: ../vector/v.out.vtk/main.c:163 ../display/d.nviz/main.c:202
-#: ../general/g.pnmcomp/main.c:262 ../general/g.pnmcomp/main.c:280
+#: ../raster3d/r3.to.rast/main.c:304
#, c-format
-msgid "Unable to open file <%s>"
-msgstr "Nelze otevøít soubor <%s>"
+msgid "Creating %i raster maps"
+msgstr "Vytváøím %i rastrové mapy"
-#: ../raster/r.out.ascii/main.c:184
-#, fuzzy, c-format
-msgid "Unable to read fp range for <%s>"
-msgstr "Nemohu èíst rozsah pro <%s>"
-#: ../raster/r.out.ascii/main.c:200
-#, fuzzy, c-format
-msgid "Read failed at row %d"
-msgstr "Pøed selhal na øádku %d"
-#: ../raster/r.carve/raster.c:12 ../raster/r.texture/main.c:258
-#: ../raster/r.out.tiff/r.out.tiff.c:286 ../imagery/i.zc/main.c:168
-msgid "Reading raster map..."
-msgstr "Naèítám rastrovou mapu..."
-#: ../raster/r.carve/raster.c:31 ../raster/r.in.poly/poly2rast.c:67
-msgid "Writing raster map..."
-msgstr "Zapisuji rastrovou mapu..."
-#: ../raster/r.carve/lobf.c:75
-msgid "trying to divide by zero...no unique solution for system...skipping..."
-msgstr ""
-"pokou¹ím se dìlit nulou pro systém není ¾ádné jednoznaèné øe¹ení "
-"pøeskakuji..."
-#: ../raster/r.carve/main.c:77
-msgid ""
-"Takes vector stream data, transforms it to raster and subtracts depth from "
-"the output DEM."
-msgstr ""
-"Vezme vektorová data potokù, pøevede je na rastr a odeète hloubku z "
-"výstupního DMT."
-#: ../raster/r.carve/main.c:82
-msgid "Name of input raster elevation map"
-msgstr "Název vstupní rastrové mapy elevace "
-#: ../raster/r.carve/main.c:86
-msgid "Name of vector input map containing stream(s)"
-msgstr "Název vstupní vektorové vrstvy obsahující dráhy odtoku"
-#: ../raster/r.carve/main.c:93
-msgid "Name for output vector map for adjusted stream points"
-msgstr "Jméno výstupního vektoru pro zarovnané body bystøin"
-#: ../raster/r.carve/main.c:98
-msgid "Stream width (in meters). Default is raster cell width"
-msgstr "©íøka bystøiny (v metrech). Výchozí je ¹íøka rastrové buòky"
-#: ../raster/r.carve/main.c:104
-msgid "Additional stream depth (in meters)"
-msgstr "Pøídavná hloubka (v metrech)"
-#: ../raster/r.carve/main.c:108
-msgid "No flat areas allowed in flow direction"
-msgstr "Ve smìru toku nejsou povoleny ¾ádná plochá místa"
-#: ../raster/r.carve/main.c:145
+#: ../raster3d/r3.to.rast/main.c:310
#, c-format
-msgid "Invalid width value '%s' - using default."
-msgstr "Neplatná hodnota ¹íøky '%s' - bude pou¾ita výchozí."
+msgid "Raster map %i Filename: %s"
+msgstr "Rastrová mapa %i Název souboru: %s"
-#: ../raster/r.carve/main.c:158
+#: ../raster3d/r3.to.rast/main.c:314
#, c-format
-msgid "Invalid depth value '%s' - using default."
-msgstr "Neplatná hodnota hloubky '%s' - bude pou¾ita výchozí."
+msgid "Raster map %d Filename: %s already exists. Will be overwritten!"
+msgstr "Rastrová mapa %d Jméno souboru: %s ji¾ existuje. Mapa bude pøepsána!"
-#: ../raster/r.carve/main.c:223
-msgid "lat/lon projection not supported at this time."
-msgstr "lat/long projekce není v souèasnosti podporována"
+#: ../raster3d/r3.to.rast/main.c:389 ../raster3d/r3.in.v5d/main.c:222
+#: ../raster3d/base/r3.info.main.c:422 ../raster3d/r3.out.v5d/main.c:324
+#: ../raster3d/r3.out.ascii/main.c:59 ../raster3d/r3.out.ascii/main.c:318
+#: ../raster/r.to.rast3/main.c:333 ../raster/r.to.rast3elev/main.c:547
+msgid "Error closing 3d raster map"
+msgstr "Chyba pøi zavírání g3d souboru"
-#: ../raster/r.carve/enforce_ds.c:76
-msgid "Processing lines... "
-msgstr "Zpracovávám øádky..."
-#: ../raster/r.carve/enforce_ds.c:170
-msgid ""
-"Vect runs out of region and re-enters - this case is not yet implemented."
-msgstr ""
-"Vektor pokraèuje mimo region a opìt se vrací- tento pøípad zatím není "
-"o¹etøen."
-#: ../raster/r.profile/input.c:31 ../raster/r.profile/input.c:48
-#: ../raster/r.profile/input.c:61
-msgid "One coordinate pair per line, please"
-msgstr "Jeden pár souøadnic na øádek, prosím."
-#: ../raster/r.profile/main.c:55
-msgid "Outputs the raster map layer values lying on user-defined line(s)."
-msgstr ""
-"Vytvoøí rastrovou mapu hodnot, le¾ících na u¾ivatelem definovaných liniích."
-#: ../raster/r.profile/main.c:66
-msgid "Name of file for output (use output=- for stdout)"
-msgstr "Název výstupního souboru (pro standardní výstup pou¾ijte output=-)"
-#: ../raster/r.profile/main.c:74
-msgid "Profile coordinate pairs"
-msgstr "Souøadnice vymezující profil"
-#: ../raster/r.profile/main.c:81
-msgid "Resolution along profile (default = current region resolution)"
-msgstr "Rozli¹ení podél profilu (výchozí = aktuální rozli¹ení regionu)"
-#: ../raster/r.profile/main.c:88
-msgid "Character to represent no data cell"
-msgstr "Znak pro oznaèení bunìk s hodnotou NULL"
-#: ../raster/r.profile/main.c:92
-msgid "Interactively select End-Points"
-msgstr "Interaktivní výbìr koncových bodù"
-#: ../raster/r.profile/main.c:97 ../raster/r.transect/main.c:96
-msgid "Output easting and northing in first two columns of four column output"
-msgstr ""
-"Výstup ve formì V a S souøadnic v prvních dvou sloupeècích "
-"zeètyøsloupeèkového výstupu"
-#: ../raster/r.profile/main.c:102
-msgid "Output RRR:GGG:BBB color values for each profile point"
-msgstr "Výstupní barevné hodnoty RRR:GGG:BBB pro ka¾dý bod profilu"
-#: ../raster/r.profile/main.c:121
+#: ../raster3d/r3.out.vtk/main.c:97
#, c-format
-msgid "Illegal resolution! [%g]"
-msgstr "Neplatné rozli¹ení! [%g]"
+msgid "Could not open map %s"
+msgstr "Nelze otevøít mapu %s"
-#: ../raster/r.profile/main.c:130
-#, c-format
-msgid "Using resolution [%g]"
-msgstr "Pou¾ívám rozli¹ení [%g]"
+#: ../raster3d/r3.out.vtk/main.c:116
+msgid "You have to specify top and bottom map"
+msgstr "Musíte zadat spodní a svrchní mapu"
-#: ../raster/r.profile/main.c:176
-msgid "Output Format:"
-msgstr "Výstupní formát:"
-#: ../raster/r.profile/main.c:178
+#: ../raster3d/r3.out.vtk/main.c:123
#, c-format
-msgid "[Easting] [Northing] [Along Track Dist.(m)] [Elevation]"
-msgstr "[Východ][Sever][Vzdálenost (m)][Elevace]"
+msgid "Top cell map <%s> not found"
+msgstr "Svrchní rastr <%s> nenalezen"
-#: ../raster/r.profile/main.c:180
+#: ../raster3d/r3.out.vtk/main.c:132
#, c-format
-msgid "[Along Track Dist.(m)] [Elevation]"
-msgstr "[Vzdálenost (m)][Elevace]"
+msgid "Bottom cell map <%s> not found"
+msgstr "Spodní rastr <%s> nenalezen"
-#: ../raster/r.profile/main.c:182
-msgid " [RGB Color]"
-msgstr " [Barva RGB]"
-#: ../raster/r.profile/main.c:193
+#: ../raster3d/r3.out.vtk/main.c:141
#, c-format
-msgid "Invalid coordinates %s %s"
-msgstr "Neplatné souøadnice %s %s"
+msgid "Requested 3d raster map <%s> not found"
+msgstr "Po¾adovaný soubor g3d <%s> nebyl nalezen"
-#: ../raster/r.profile/main.c:208
+#: ../raster3d/r3.out.vtk/main.c:151
#, c-format
-msgid "Use mouse to select Start Point\n"
-msgstr "Pro výbìr poèáteèního bodu pou¾ijte my¹\n"
+msgid "Requested g3d RGB map <%s> not found"
+msgstr "Po¾adovaná mapa g3d RGB <%s> nebyla nalezena"
-#: ../raster/r.profile/main.c:213
-#, c-format
-msgid ""
-"\n"
-"Use mouse to draw profile line\n"
-msgstr ""
-"\n"
-"Pou¾ít my¹ pro kreslení linie profilu\n"
+#: ../raster3d/r3.out.vtk/main.c:155
+msgid "Please provide three g3d RGB maps"
+msgstr "Prosím zadejte tøi g3d RGB mapy"
-#: ../raster/r.profile/main.c:214
+#: ../raster3d/r3.out.vtk/main.c:165
#, c-format
-msgid "Buttons:\n"
-msgstr "Tlaèítka:\n"
+msgid "Requested g3d vector map <%s> not found"
+msgstr "Po¾adovaná mapa g3d vektor <%s> nebyla nalezena"
-#: ../raster/r.profile/main.c:215
-#, c-format
-msgid "Left: Mark next point\n"
-msgstr "Levé tlaèítko: Oznaè dal¹í bod\n"
+#: ../raster3d/r3.out.vtk/main.c:170
+msgid "Please provide three g3d vector maps [x,y,z]"
+msgstr "Prosím zadejte tøi g3d vektory [x,y,z]"
-#: ../raster/r.profile/main.c:216
-#, c-format
-msgid "Middle: Mark next point\n"
-msgstr "Prostøední tlaèítko: Oznaè dal¹í bod\n"
-#: ../raster/r.profile/main.c:217
-#, c-format
+#: ../raster3d/r3.out.vtk/main.c:178
msgid ""
-"Right: Finish profile and exit\n"
-"\n"
+"No g3d data, RGB or xyz-vector maps are provided! Will only write the "
+"geometry."
msgstr ""
-"Pravé: ukonèit profil a opustit\n"
-"\n"
+"®ádná g3d data, RGB nebo xyz-vektorová mapa jsou po¾adována! Zapí¹i pouze "
+"geometrii."
-#: ../raster/r.profile/main.c:297
+#: ../raster3d/r3.out.vtk/main.c:197
#, c-format
-msgid "Approx. transect length [%f] m"
-msgstr "Prùmìrná délka transektu [%f] m"
+msgid "Open rgb 3d raster map %s"
+msgstr "Otevøít rgb g3d rastrový soubor %s"
-#: ../raster/r.profile/main.c:300
-msgid "Endpoint coordinates are outside of current region settings"
-msgstr "Koncový bod je mimo aktuální region"
+#: ../raster3d/r3.out.vtk/main.c:210
+msgid "No RGB Data will be created."
+msgstr "Nebudou vytvoøena ¾ádná RGB data"
-#: ../raster/r.texture/main.c:73
-msgid "Generate images with textural features from a raster map."
-msgstr "Vytvoøí obrázky s texturálními vlastnostmi rastrové mapy."
+#: ../raster3d/r3.out.vtk/main.c:253
+msgid "Error closing g3d rgb map."
+msgstr "Chyba pøi zavírání g3d rgb souboru"
-#: ../raster/r.texture/main.c:84
-msgid "Prefix for ouput raster map(s)"
-msgstr "Pøedpona výstupních rastrových map"
+#: ../raster3d/r3.out.vtk/main.c:293
+msgid "No vector data will be created."
+msgstr "®ádná vektorová data nebudou vytvoøena."
-#: ../raster/r.texture/main.c:91
-msgid "The size of sliding window (odd and >= 3)"
-msgstr "Velikost okna filtru (liché èíslo >= 3)"
+#: ../raster3d/r3.out.vtk/main.c:337
+msgid "Error closing g3d vector map."
+msgstr "Chyba pøi zavírání g3d vektorového souboru"
-#: ../raster/r.texture/main.c:101
-msgid "The distance between two samples (>= 1)"
-msgstr "Vzdálenost mezi dvìma vzorky (>=1)"
+#: ../raster3d/r3.out.vtk/main.c:376
+msgid "Converts 3D raster maps (G3D) into the VTK-Ascii format"
+msgstr "Pøevede 3D rastrové mapy (G3D) do formátu VTK-Ascii"
-#: ../raster/r.texture/main.c:119
-msgid "Angular Second Moment"
-msgstr "Druhý íºhlový moment"
+#: ../raster3d/r3.out.vtk/main.c:387
+msgid "failed to interpret dp as an integer"
+msgstr "selhal pøevod dp na celé èíslo"
-#: ../raster/r.texture/main.c:120 ../raster/r.texture/main.c:125
-#: ../raster/r.texture/main.c:130 ../raster/r.texture/main.c:135
-#: ../raster/r.texture/main.c:140 ../raster/r.texture/main.c:145
-#: ../raster/r.texture/main.c:150 ../raster/r.texture/main.c:155
-#: ../raster/r.texture/main.c:160 ../raster/r.texture/main.c:165
-#: ../raster/r.texture/main.c:170 ../raster/r.texture/main.c:175
-#: ../raster/r.texture/main.c:180 ../raster/r.texture/main.c:185
-msgid "Features"
-msgstr "Prvky"
+#: ../raster3d/r3.out.vtk/main.c:389 ../raster/r.out.ascii/main.c:123
+msgid "dp has to be from 0 to 20"
+msgstr "dp musí být od 0 do 20"
-#: ../raster/r.texture/main.c:124
-msgid "Contrast"
-msgstr "Kontrast"
-#: ../raster/r.texture/main.c:129
-msgid "Correlation"
-msgstr "Korelace"
-#: ../raster/r.texture/main.c:134
-msgid "Variance"
-msgstr "Variance"
-#: ../raster/r.texture/main.c:139
-msgid "Inverse Diff Moment"
-msgstr "Inverzní diferenèní moment"
-#: ../raster/r.texture/main.c:144
-msgid "Sum Average"
-msgstr "Suma prùmìru"
-#: ../raster/r.texture/main.c:149
-msgid "Sum Variance"
-msgstr "Suma variance"
-#: ../raster/r.texture/main.c:154
-msgid "Sum Entropy"
-msgstr "Suma entropie"
-#: ../raster/r.texture/main.c:159
-msgid "Entropy"
-msgstr "Entropie"
-#: ../raster/r.texture/main.c:164
-msgid "Difference Variance"
-msgstr "Diferenèní variance"
-#: ../raster/r.texture/main.c:169
-msgid "Difference Entropy"
-msgstr "Diferenèní entropie"
-#: ../raster/r.texture/main.c:174
-msgid "Measure of Correlation-1"
-msgstr "Korelaèní koeficient-1"
-#: ../raster/r.texture/main.c:179
-msgid "Measure of Correlation-2"
-msgstr "Korelaèní koeficient-2"
-#: ../raster/r.texture/main.c:184
-msgid "Max Correlation Coeff"
-msgstr "Maximální koeficient korelace"
-#: ../raster/r.texture/main.c:212
-msgid "Nothing to compute. Use at least one of the flags."
-msgstr "Není co poèítat. Pou¾ijte prosím nìkterý z pøepínaèù."
-#: ../raster/r.texture/main.c:236 ../raster/r.out.tiff/r.out.tiff.c:170
-#: ../raster/r.bitpattern/main.c:114 ../imagery/i.rectify/main.c:173
-#: ../imagery/i.rectify/main.c:177
-#, c-format
-msgid "Unable to read header of raster map <%s>"
-msgstr "Nelze èíst hlavièku rastrové mapy <%s>"
-#: ../raster/r.texture/main.c:361
-#, c-format
-msgid "Calculated measure #%d (56 measures available)"
-msgstr "Spoèítána míra #%d (56 mìr je dostupno)"
-#: ../raster/r.texture/h_measure.c:85
+#: ../raster3d/r3.out.vtk/main.c:450
msgid ""
-"Negative or no data pixel found. This module is not yet able to process no "
-"data holes in a map, please fill with r.fillnulls or other algorithms"
+"The 2d and 3d region settings are different. The g3d settings are used to "
+"adjust the 2d region."
msgstr ""
-"Byl nalezen pixel se zápornou nebo ¾ádnou hodnotou. Tento modul není schopen "
-"zpracovat díry v mapì, prosím vyplòte je pomocí r.fillnulls nebo jiným "
-"algoritmem."
+"2d a 3d nastavení regionu jsou rùzná. Pou¾iji hodnoty z nastavení g3d pro "
+"zmìnu 2d regionu."
-#: ../raster/r.texture/h_measure.c:89
-#, c-format
-msgid ""
-"Too many categories (found: %i, max: %i). Try to rescale or reclassify the "
-"map"
-msgstr ""
-"Pøíli¹ mnoho kategorií (nalezeno: %i, max: %i). Zkuste zmìnit mìøítko nebo "
-"reklasifikovat mapu"
+#: ../raster3d/r3.out.vtk/main.c:487
+msgid "unable to close top raster map"
+msgstr "nelze zavøít svrchní rastrovou mapu"
-#: ../raster/r.texture/h_measure.c:675 ../raster/r.cost/main.c:597
-#: ../imagery/i.smap/bouman/interp.c:71
-msgid "Unable to allocate memory"
-msgstr "Nelze alokovat pamì»."
+#: ../raster3d/r3.out.vtk/main.c:492
+msgid "unable to close bottom raster map"
+msgstr "nelze zavøít spodní rastrovou mapu"
-#: ../raster/r.texture/h_measure.c:877
-#, c-format
-msgid "Too many iterations to required to find %s - giving up"
-msgstr "Pøíli¹ mnoho iterací je po¾adováno pro nalezení %s - vzdávám to."
+#: ../raster3d/r3.out.vtk/main.c:545
+msgid "Error closing 3d raster map, the VTK file may be incomplete."
+msgstr "Chyba pøi zavírání mapy g3d, soubor VTK je asi nekompletní."
-#: ../raster/r.basins.fill/main.c:53
-msgid "Generates a raster map layer showing watershed subbasins."
-msgstr "Vytvoøí rastrovou mapu ukazující dílèí povodí v povodích."
+#: ../raster3d/r3.out.vtk/main.c:560 ../raster/r.out.vtk/main.c:390
+msgid "Error closing VTK-ASCII file"
+msgstr "Chyba pøi uzavøení souboru VTK-ASCII"
-#: ../raster/r.basins.fill/main.c:60
-msgid "Number of passes through the dataset"
-msgstr "Poèet prùchodù pøes dataset"
+#: ../raster3d/r3.out.vtk/parameters.c:30
+msgid "G3D map(s) to be converted to VTK-ASCII data format"
+msgstr "G3D mapa(y) pro konverzi do datového formátu VTK-ASCII"
-#: ../raster/r.basins.fill/main.c:67
-msgid "Coded stream network file name"
-msgstr "Soubor øíèní sítì, obsahující kódové oznaèení øádu tokù"
+#: ../raster3d/r3.out.vtk/parameters.c:34 ../raster/r.out.vtk/parameters.c:38
+msgid "Name for VTK-ASCII output file"
+msgstr "Název výstupního souboru VTK-ASCII"
-#: ../raster/r.basins.fill/main.c:74
-msgid "Thinned ridge network file name"
-msgstr "Soubor se sítí ztenèených høbetù"
+#: ../raster3d/r3.out.vtk/parameters.c:41
+msgid "Float value to represent no data cell/points"
+msgstr ""
+"Hodnota s plovoucí desetinnou èárkou reprezentující hodnotu \"¾ádná data\""
-#: ../raster/r.basins.fill/main.c:81
-msgid "Name for the resultant watershed partition file"
-msgstr "Jméno výsledného souboru s rozdìlenými povodími"
-#: ../raster/r.basins.fill/main.c:109 ../raster/r.in.gdal/main.c:213
-#, c-format
-msgid "Raster map <%s> already exists"
-msgstr "Rastrová vrstva <%s> ji¾ existuje."
-#: ../raster/r.basins.fill/main.c:140
-#, fuzzy
-msgid "Forward sweep complete"
-msgstr "úklid vpøed dokonèen"
-#: ../raster/r.basins.fill/main.c:155
-#, fuzzy
-msgid "Reverse sweep complete"
-msgstr "úklid vzad dokonèen"
-#: ../raster/r.basins.fill/main.c:162 ../raster/r.cross/main.c:188
-#: ../raster/r.resample/main.c:153 ../imagery/i.smap/shapiro/closefiles.c:14
-#, fuzzy, c-format
-msgid "Creating support files for <%s>..."
-msgstr "Vytváøím podpùrné soubory pro %s..."
-#: ../raster/r.sum/main.c:49
-msgid "Sums up the raster cell values."
-msgstr "Seète hodnoty bunìk rastrového souboru."
-#: ../raster/r.sum/main.c:56
-msgid "Name of incidence or density file."
-msgstr "Název souboru pùsobení nebo hustoty."
-#: ../raster/r.sum/main.c:77 ../raster/r.walk/main.c:685
-#: ../raster/r.walk/main.c:746 ../raster/wildfire/r.spread/main.c:537
-#, c-format
-msgid "Reading %s..."
-msgstr "Naèítám %s..."
-#: ../raster/r.sun/main.c:154
-msgid "Solar irradiance and irradiation model."
-msgstr "Sluneèní záøení a model záøení."
-#: ../raster/r.sun/main.c:156
-msgid ""
-"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
-"for given day, latitude, surface and atmospheric conditions. Solar "
-"parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
-"irradiance, daylight length) are saved in the map history file. "
-"Alternatively, a local time can be specified to compute solar incidence "
-"angle and/or irradiance raster maps. The shadowing effect of the topography "
-"is optionally incorporated."
+#: ../raster3d/r3.out.vtk/parameters.c:47
+msgid "Create VTK pointdata instead of VTK celldata (celldata is default)"
msgstr ""
-"Poèítá mapu pøímého (paprsek), difíºzního a odra¾eného sluneèního záøení pro "
-"zadaný den, zem. ¹íøku, povrch a atmosférické podmínky. Sluneèní parametry "
-"(napø. východ a západ slunce) jsou ulo¾eny do do souboru s historií mapy. "
-"Alternativnì staèí specifikovat èas pro výpoèet sluneèního íºhlu a/nebo mapy "
-"ozáøení. Také lze volitelnì zahrnout efekt stínu terénu."
+"Vytvoøí bodová data VTK z rastrových dat VTK (rastrová data jsou výchozí)"
-#: ../raster/r.sun/main.c:185
-msgid "Name of the input elevation raster map [meters]"
-msgstr "Název vstupního souboru s digitálním modelem terénu"
+#: ../raster3d/r3.out.vtk/parameters.c:56
+msgid "top surface 2D raster map"
+msgstr "2D mapa svrchního povrchu"
-#: ../raster/r.sun/main.c:186 ../raster/r.sun/main.c:194
-#: ../raster/r.sun/main.c:203 ../raster/r.sun/main.c:212
-#: ../raster/r.sun/main.c:220 ../raster/r.sun/main.c:231
-#: ../raster/r.sun/main.c:239 ../raster/r.sun/main.c:250
-#: ../raster/r.sun/main.c:257 ../raster/r.sun/main.c:268
-#: ../raster/r.sun/main.c:277 ../raster/simwe/r.sim.sediment/main.c:152
-#: ../raster/simwe/r.sim.sediment/main.c:160
-#: ../raster/simwe/r.sim.sediment/main.c:168
-#: ../raster/simwe/r.sim.sediment/main.c:176
-#: ../raster/simwe/r.sim.sediment/main.c:185
-#: ../raster/simwe/r.sim.sediment/main.c:194
-#: ../raster/simwe/r.sim.sediment/main.c:202
-#: ../raster/simwe/r.sim.sediment/main.c:210
-#: ../raster/simwe/r.sim.sediment/main.c:219
-#: ../raster/simwe/r.sim.water/main.c:153
-#: ../raster/simwe/r.sim.water/main.c:161
-#: ../raster/simwe/r.sim.water/main.c:169
-#: ../raster/simwe/r.sim.water/main.c:177
-#: ../raster/simwe/r.sim.water/main.c:185
-#: ../raster/simwe/r.sim.water/main.c:193
-#: ../raster/simwe/r.sim.water/main.c:201
-#: ../raster/simwe/r.sim.water/main.c:210
-#: ../raster/r.watershed/front/main.c:54 ../raster/r.watershed/front/main.c:62
-#: ../raster/r.watershed/front/main.c:70 ../raster/r.watershed/front/main.c:78
-#: ../raster/r.watershed/front/main.c:86 ../raster/r.watershed/front/main.c:94
-#: ../raster/r.watershed/front/main.c:102
-msgid "Input_options"
-msgstr "Vstupní_volby"
+#: ../raster3d/r3.out.vtk/parameters.c:65
+msgid "bottom surface 2D raster map"
+msgstr "2D mapa spodního povrchu"
-#: ../raster/r.sun/main.c:193
+#: ../raster3d/r3.out.vtk/parameters.c:72
msgid ""
-"Name of the input aspect map (terrain aspect or azimuth of the solar panel) "
-"[decimal degrees]"
+"Create 3d elevation output with a top and a bottom surface, both raster maps "
+"are required."
msgstr ""
-"Jméno vstupní mapy expozice (expozice terénu nebo azimut slunce) [dicimální "
-"stupnì]"
+"Vytvoøí 3D elevaci se svrchním a spodním povrchem. Obì rastrové mapy jsou "
+"po¾adovány."
-#: ../raster/r.sun/main.c:202
+#: ../raster3d/r3.out.vtk/parameters.c:84
msgid ""
-"Name of the input slope raster map (terrain slope or solar panel "
-"inclination) [decimal degrees]"
+"Three (r,g,b) 3d raster maps to create rgb values [redmap,greenmap,bluemap]"
msgstr ""
-"Jméno vstupní mapy sklonových pomìrù (míra svahù terénu nebo inklinace "
-"slunce [decimální stupnì]"
+"3 rastrové mapy (r,g,b) g3d, které jsou pou¾ity pro vytvoøení hodnot RGB "
+"[redmap,greenmap,bluemap]"
-#: ../raster/r.sun/main.c:211
-msgid ""
-"Name of the Linke atmospheric turbidity coefficient input raster map [-]"
+#: ../raster3d/r3.out.vtk/parameters.c:95
+msgid "Three (x,y,z) 3d raster maps to create vector values [xmap,ymap,zmap]"
msgstr ""
-"Název rastrového souboru Linkovými koeficienty atmosferické turbulence [-]"
+"3 rastrové mapy (r,g,b) g3d, které jsou pou¾ity pro vytvoøení hodnot vektorù "
+"[xmap,ymap,zmap]"
-#: ../raster/r.sun/main.c:222
-msgid "A single value of the Linke atmospheric turbidity coefficient [-]"
-msgstr "Jedineèná hodnota Linkových koeficientù atmosferické turbulence [-]"
+#: ../raster3d/r3.out.vtk/parameters.c:102 ../vector/v.out.vtk/main.c:74
+#: ../raster/r.out.vtk/parameters.c:97
+msgid "Scale factor for elevation"
+msgstr "Mìøítkový faktor pro vý¹kový model"
-#: ../raster/r.sun/main.c:230
-msgid "Name of the ground albedo coefficient input raster map [-]"
-msgstr "Název rastrového souboru s hodnotami odrazivosti (albeda) [-]"
+#: ../raster3d/r3.out.vtk/parameters.c:115 ../display/d.rast.num/number.c:118
+#: ../vector/v.out.vtk/main.c:68 ../vector/v.out.ascii/out.c:81
+#: ../raster/r.out.ascii/main.c:84 ../raster/r.out.vtk/parameters.c:109
+msgid "Number of significant digits (floating point only)"
+msgstr ""
+"Poèet míst za desetinnou èárkou (pouze pro mapy s plovoucí desetinnou èárkou)"
-#: ../raster/r.sun/main.c:240
-msgid "A single value of the ground albedo coefficient [-]"
-msgstr "Jedineèná hodnota koeficientu odrazivosti (albeda)"
+#: ../raster3d/r3.out.vtk/parameters.c:120
+msgid "Use g3d mask (if exists) with input maps"
+msgstr "Pou¾ít masku G3D (pokud existuje) se vstupními mapami"
-#: ../raster/r.sun/main.c:249
-msgid "Name of the latitudes input raster map [decimal degrees]"
-msgstr "Název rastrového souboru zem. ¹íøky [stupnì]"
+#: ../raster3d/r3.out.vtk/parameters.c:125
+msgid "Scale factor effects the origin"
+msgstr "Mìøítkový faktor ovlivní zdroj"
-#: ../raster/r.sun/main.c:258
-msgid "A single value of latitude [decimal degrees]"
-msgstr "Jednotná hodnota zem. délky [stupnì]"
+#: ../raster3d/r3.out.vtk/parameters.c:130 ../vector/v.out.vtk/main.c:86
+#: ../raster/r.out.vtk/parameters.c:139
+msgid "Correct the coordinates to fit the VTK-OpenGL precision"
+msgstr "Opravte souøadnice tak, aby odpovídaly VTK-OpenGL pøesnosti"
-#: ../raster/r.sun/main.c:267
-msgid "Name of real-sky beam radiation coefficient raster map [-]"
-msgstr "Soubor s koeficientem pøímého sluneèního záøení [-]"
+#: ../raster3d/r3.out.vtk/writeVTKData.c:121
+msgid "write_vtk_points: Writing point coordinates"
+msgstr "write_vtk_points: Zapisuji souøadnice bodù"
-#: ../raster/r.sun/main.c:276
-msgid "Name of real-sky diffuse radiation coefficient raster map [-]"
-msgstr "Název rastrové mapy s koeficientem real-sky difíºzního záøení [-]"
+#: ../raster3d/r3.out.vtk/writeVTKData.c:130
+msgid "Could not get top raster row \n"
+msgstr "Nelze naèíst øádek svrchního rastru\n"
-#: ../raster/r.sun/main.c:284
-msgid "Output incidence angle raster map (mode 1 only)"
-msgstr "Výstupní rastrový soubor íºhlu dopadu paprsku (pouze mód 1)"
+#: ../raster3d/r3.out.vtk/writeVTKData.c:134
+msgid "Could not get bottom raster row \n"
+msgstr "Nelze naèít øádek spodního rastru\n"
-#: ../raster/r.sun/main.c:285 ../raster/r.sun/main.c:294
-#: ../raster/r.sun/main.c:302 ../raster/r.sun/main.c:311
-#: ../raster/r.sun/main.c:320 ../raster/simwe/r.sim.sediment/main.c:227
-#: ../raster/simwe/r.sim.sediment/main.c:236
-#: ../raster/simwe/r.sim.sediment/main.c:244
-#: ../raster/simwe/r.sim.sediment/main.c:252
-#: ../raster/simwe/r.sim.sediment/main.c:260
-#: ../raster/simwe/r.sim.water/main.c:218
-#: ../raster/simwe/r.sim.water/main.c:226
-#: ../raster/simwe/r.sim.water/main.c:234
-#: ../raster/simwe/r.sim.water/main.c:242 ../raster/r.resamp.rst/main.c:194
-#: ../raster/r.resamp.rst/main.c:202 ../raster/r.resamp.rst/main.c:210
-#: ../raster/r.resamp.rst/main.c:218 ../raster/r.resamp.rst/main.c:226
-#: ../raster/r.resamp.rst/main.c:290 ../raster/r.watershed/front/main.c:110
-#: ../raster/r.watershed/front/main.c:118
-#: ../raster/r.watershed/front/main.c:126
-#: ../raster/r.watershed/front/main.c:134
-#: ../raster/r.watershed/front/main.c:142
-#: ../raster/r.watershed/front/main.c:150
-#: ../raster/r.watershed/front/main.c:158
-#: ../raster/r.watershed/front/main.c:166 ../vector/v.vol.rst/main.c:350
-#: ../vector/v.vol.rst/main.c:367 ../vector/v.vol.rst/main.c:376
-#: ../vector/v.vol.rst/main.c:385 ../vector/v.vol.rst/main.c:394
-#: ../vector/v.vol.rst/main.c:403 ../vector/v.vol.rst/main.c:412
-#: ../vector/v.surf.rst/main.c:199 ../vector/v.surf.rst/main.c:226
-#: ../vector/v.surf.rst/main.c:232 ../vector/v.surf.rst/main.c:238
-#: ../vector/v.surf.rst/main.c:244 ../vector/v.surf.rst/main.c:250
-msgid "Output_options"
-msgstr "Výstupní_volby"
+#: ../raster3d/r3.out.vtk/writeVTKData.c:251
+msgid "write_vtk_unstructured_grid_cells: Writing the cells"
+msgstr "write_vtk_unstructured_grid_cells: Zapisuji buòky"
-#: ../raster/r.sun/main.c:293
+#: ../raster3d/r3.out.vtk/writeVTKData.c:330
+#, c-format
msgid ""
-"Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
-"day-1] (mode 2)"
+"write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-"
+"ascii file"
msgstr ""
-"Výstupní osvìtlení paprskem [W.m-2] (mode 1) nebo rastrovou mapu osvìtlení "
-"[Wh.m-2.den-1] (mode 2)"
+"write_vtk_data: Zapisuji Celldata %s o %i øádkù %i sloupcù %i hloubky do "
+"souboru vtk-ascii."
-#: ../raster/r.sun/main.c:301
-msgid "Output insolation time raster map [h] (mode 2 only)"
-msgstr "Výstupní rastrový soubor s hodnotami insolace [h] (pouze mód 2)"
+#: ../raster3d/r3.out.vtk/writeVTKData.c:388
+msgid "write_vtk_rgb_data: writing rgb data"
+msgstr "write_vtk_data: Zapisuji data RGB"
-#: ../raster/r.sun/main.c:310
-msgid ""
-"Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
-"day-1] (mode 2)"
+#: ../raster3d/r3.out.vtk/writeVTKData.c:425
+#: ../raster3d/r3.out.vtk/writeVTKData.c:458
+msgid "Wrong 3d raster map values! Values should in between 0 and 255!\n"
msgstr ""
-"Výstupní difùzní osvìtlení [W.m-2] (mode 1) nebo mapa osvìtlení [Wh.m-2.den-"
-"1] (mode 2)"
+"Chybné hodnoty 3d raster mapy! Hodnoty by mìly být v rozmezí 0 a 255!\n"
-#: ../raster/r.sun/main.c:319
-msgid ""
-"Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster "
-"map [Wh.m-2.day-1] (mode 2)"
-msgstr ""
-"Výstupní záøení odra¾ené od zemì [W.m-2] (mode 1) nebo rastrová mapa ozáøení "
+#: ../raster3d/r3.out.vtk/writeVTKData.c:488
+msgid "write_vtk_vector_data: writing vector data"
+msgstr "write_vtk_vector_data: Zapisuji data vektorová data"
-#: ../raster/r.sun/main.c:326
-msgid "No. of day of the year (1-365)"
-msgstr "Poèet dní v roce (1-365)"
+#: ../raster3d/r3.out.vtk/errorHandling.c:52
+msgid "unable to close input raster map"
+msgstr "Nelze zavøít vstupní rastrovou mapu"
-#: ../raster/r.sun/main.c:333
-msgid "Time step when computing all-day radiation sums [decimal hours]"
-msgstr "Èasový krok pøi výpoètu celodenní radiance [decimální hodiny]"
+#: ../raster3d/r3.out.vtk/errorHandling.c:67
+msgid "unable to close input 3d raster map"
-#: ../raster/r.sun/main.c:340
-msgid "Declination value (overriding the internally computed value) [radians]"
-msgstr "Po¾adována hodnota deklinace (vnitøní hodnota bude pøepsána) [radiány]"
+#: ../raster3d/r3.cross.rast/main.c:55
+msgid "Could not close G3D map"
+msgstr "Nemohl jsem uzavøít G3D mapu"
-#: ../raster/r.sun/main.c:347
-msgid "Local (solar) time (to be set for mode 1 only) [decimal hours]"
-msgstr "Místní (sluneèní) èas (nastaveno pouze pro mód 1) [decimální hodiny]"
+#: ../raster3d/r3.cross.rast/main.c:91
+msgid "Input 3D raster map for cross section."
+msgstr "Vstupní 3D rastrový soubor pro prùnik."
-#: ../raster/r.sun/main.c:352
-msgid "Incorporate the shadowing effect of terrain"
-msgstr "Zahrnout vliv zastínìní okolním reliéfem"
+#: ../raster3d/r3.cross.rast/main.c:98
+msgid "2D elevation map used to create the cross section map"
+msgstr "2D mapa s elevací pou¾itá pro vytvoøení prùnikù"
-#: ../raster/r.sun/main.c:374
-msgid "insol_time and incidout are incompatible options"
-msgstr "insol_time a incidout jsou nesluèitelné volby"
+#: ../raster3d/r3.cross.rast/main.c:105
+msgid "Resulting cross section 2D raster map"
+msgstr "Výsledná 2D rastrová mapa prùseèíkù"
-#: ../raster/r.sun/main.c:382
-msgid "time and insol_time are incompatible options"
-msgstr "time a insol_time jsou nesluèitelné volby"
+#: ../raster3d/r3.cross.rast/main.c:110
+msgid "Use g3d mask (if exists) with input map"
+msgstr "Pou¾ít masku G3D (pokud existuje) se vstupní mapou"
-#: ../raster/r.sun/main.c:383
-msgid ""
-"Mode 1: instantaneous solar incidence angle & irradiance given a set local "
-"time"
-msgstr "Mode 1: okam¾itý solární íºhel dopadu & ozáøenost daná lokálním èasem"
+#: ../raster3d/r3.cross.rast/main.c:162
+msgid "Unable to get elevation raster row"
+msgstr "Nelze naèíst øádek rastru elevace"
-#: ../raster/r.sun/main.c:388
-msgid "incidout requires time parameter to be set"
-msgstr "incidout po¾aduje nastavený parametr èasu"
+#: ../raster3d/r3.cross.rast/main.c:229 ../raster3d/r3.cross.rast/main.c:235
+msgid "Could not write raster row"
+msgstr "Nelze zapsat øádek rastrové mapy"
-#: ../raster/r.sun/main.c:389
-msgid "Mode 2: integrated daily irradiation for a given day of the year"
-msgstr "Mode 2: denní ozáøenost pro zadaný den roku."
+#: ../raster3d/r3.cross.rast/main.c:271
+msgid ""
+"Creates cross section 2D raster map from 3d raster map based on 2D elevation "
+"map"
+msgstr "Vytvoøí prùniky 2D mapy z g3d rastru objemù na základ 2D mapy elevace"
-#: ../raster/r.sun/main.c:438
+#: ../raster3d/r3.cross.rast/main.c:296 ../raster/r.to.rast3/main.c:214
+#: ../raster/r.to.rast3elev/main.c:464
msgid ""
-"Can't get projection info of current location: please set latitude via 'lat' "
-"or 'latin' option!"
+"The 2d and 3d region settings are different. I will use the g3d settings to "
msgstr ""
-"Nelze získat informaci o mapové projekci aktuální location: prosím, nastavte "
-"¹íøkupomocí volby 'lat' nebo 'latin'!"
+"2d a 3d nastavení regionu jsou rùzná. Pou¾iji hodnoty z nastavení g3d a "
+"pøenastavím 2d region."
-#: ../raster/r.sun/main.c:441 ../display/d.where/main.c:92
-#: ../general/g.region/cmd/printwindow.c:248
-#: ../general/g.region/cmd/printwindow.c:498
-msgid "Can't get projection units of current location"
-msgstr "Nelze získat jednotky mapové projekce aktuální location"
+#: ../raster3d/r3.cross.rast/main.c:330
+msgid "Elevation map not found"
+msgstr "Soubor s elevací nebyl nalezen"
-#: ../raster/r.sun/main.c:445 ../ps/ps.map/do_geogrid.c:268
-#: ../display/d.where/main.c:95 ../display/d.grid/plot.c:266
-#: ../general/g.region/cmd/printwindow.c:252
-#: ../general/g.region/cmd/printwindow.c:502
-msgid "Can't get projection key values of current location"
-msgstr "Nelze získat klíèové hodnoty mapové projekce aktuální location"
+#: ../raster3d/r3.cross.rast/main.c:335
+msgid "Unable to open elevation map"
+msgstr "nelze zavøít mapu elevace"
-#: ../raster/r.sun/main.c:455 ../ps/ps.map/do_geogrid.c:274
-#: ../display/d.where/main.c:103 ../display/d.where/main.c:130
-#: ../display/d.grid/plot.c:274 ../display/d.grid/plot.c:302
-msgid "Unable to set up lat/long projection parameters"
-msgstr "Nelze nastavit parametry mapové projekce lat/long"
+#: ../raster3d/r3.cross.rast/main.c:349
+msgid "Output map already exists. Will be overwritten!"
+msgstr "Výstupní mapa ji¾ existuje. Mapa bude pøepsána!"
-#: ../raster/r.sun/main.c:493
-#, c-format
-msgid "elevin raster map <%s> not found"
-msgstr "vstupní rastr s elevací <%s> nebyl nalezen"
+#: ../raster3d/r3.cross.rast/main.c:354 ../raster3d/r3.cross.rast/main.c:359
+msgid "Unable to create raster map"
+msgstr "Nelze vytvoøit rastrovou mapu"
-#: ../raster/r.sun/main.c:496
-#, c-format
-msgid "aspin raster map <%s> not found"
-msgstr "vstupní rastr s expozicí <%s> nebyl nalezen"
+#: ../raster3d/r3.cross.rast/main.c:389
+msgid "Unable to close elevation map"
-#: ../raster/r.sun/main.c:499
-#, c-format
-msgid "slopein raster map <%s> not found"
-msgstr "vstupní rastr sklonu <%s> nebyl nalezen"
+#: ../raster3d/r3.cross.rast/main.c:394
+msgid "Wrong G3D Datatype! Cannot create raster map."
+msgstr "Chybný G3D datový typ! Nelze vytvoøit rastrové mapy."
-#: ../raster/r.sun/main.c:512
+#: ../raster3d/r3.cross.rast/main.c:399
#, c-format
-msgid "linkein raster map <%s> not found"
-msgstr "vstupní rastr s Linkovými koeficienty <%s> nebyl nalezen"
+msgid "Could not close G3D map <%s>"
+msgstr "Nemohl jsem uzavøít mapu G3D <%s>"
-#: ../raster/r.sun/main.c:524
-#, c-format
-msgid "albedo raster map <%s> not found"
-msgstr "rastrový soubor albeda <%s> nebyl nalezen"
+#: ../raster3d/r3.gwflow/main.c:55 ../raster/r.gwflow/main.c:57
+msgid "The initial piezometric head in [m]"
+msgstr "Poèáteèní piezometrická hodnota v [m]"
-#: ../raster/r.sun/main.c:536
-#, c-format
-msgid "latin raster map <%s> not found"
-msgstr "rastrový soubor se zem. ¹íøkou <%s> nebyl nalezen"
-#: ../raster/r.sun/main.c:548
-#, c-format
-msgid "coefbh raster map <%s> not found"
+#: ../raster3d/r3.gwflow/main.c:64
+msgid "The status for each cell, = 0 - inactive, 1 - active, 2 - dirichlet"
msgstr ""
-"raststrový soubor s koeficientem pøímého sluneèního záøení <%s> nebyl nalezen"
+"Status pro ka¾dou buòku, = 0 -neaktivní, 1 - aktivní, 2 - Dirichletovo ¹íøení"
-#: ../raster/r.sun/main.c:560
-#, c-format
-msgid "coefdh raster map <%s> not found"
-msgstr "rastrový soubor s koeficientem difíºzního záøení <%s> nebyl nalezen"
+#: ../raster3d/r3.gwflow/main.c:72
+msgid "The x-part of the hydraulic conductivity tensor in [m/s]"
+msgstr "souøadnice x hydraulického napøimovaèe vodivosti v [m/s]"
-#: ../raster/r.sun/main.c:699 ../raster/r.sun/main.c:706
-#: ../raster/r.sun/main.c:713 ../raster/r.sun/main.c:720
-#: ../raster/r.sun/main.c:727 ../raster/r.in.bin/main.c:460
-#, c-format
-msgid "Unable to create raster map %s"
-msgstr "Nejsem schopen vytvoøit rastrovou mapu %s."
+#: ../raster3d/r3.gwflow/main.c:80
+msgid "The y-part of the hydraulic conductivity tensor in [m/s]"
+msgstr "souøadnice y hydraulického napøimovaèe vodivosti v [m/s]"
-#: ../raster/r.sun/main.c:735
-#, c-format
-msgid "rows changed from %d to %d"
-msgstr "øádky zmìnìny z %d na %d"
+#: ../raster3d/r3.gwflow/main.c:88
+msgid "The z-part of the hydraulic conductivity tensor in [m/s]"
+msgstr "souøadnice z hydraulického napøimovaèe vodivosti v [m/s]"
-#: ../raster/r.sun/main.c:738
-#, c-format
-msgid "cols changed from %d to %d"
-msgstr "sloupce zmìnìny z %d na %d"
+#: ../raster3d/r3.gwflow/main.c:95
+#, fuzzy
+msgid "Sources and sinks in [m^3/s]"
+msgstr "Prameny a jezera v [m^3/s]"
-#: ../raster/r.sun/main.c:1301 ../ps/ps.map/do_geogrid.c:86
-#: ../ps/ps.map/do_geogrid.c:91 ../ps/ps.map/do_geogrid.c:115
-#: ../ps/ps.map/do_geogrid.c:120 ../ps/ps.map/do_geogrid.c:189
-#: ../ps/ps.map/do_geogrid.c:227 ../ps/ps.map/do_geogrid.c:303
-#: ../ps/ps.map/do_geogrid.c:317 ../ps/ps.map/do_geogrid.c:332
-#: ../ps/ps.map/do_geogrid.c:347 ../ps/ps.map/do_geogrid.c:399
-#: ../ps/ps.map/do_geogrid.c:405 ../ps/ps.map/do_geogrid.c:409
-#: ../ps/ps.map/do_geogrid.c:417 ../ps/ps.map/do_geogrid.c:421
-#: ../display/d.grid/plot.c:162 ../display/d.grid/plot.c:168
-#: ../display/d.grid/plot.c:214 ../display/d.grid/plot.c:220
-#: ../display/d.grid/plot.c:355 ../display/d.grid/plot.c:369
-#: ../display/d.grid/plot.c:384 ../display/d.grid/plot.c:399
-msgid "Error in pj_do_proj"
-msgstr "Chyba v pj_do_proj"
+#: ../raster3d/r3.gwflow/main.c:102
+msgid "Specific yield in 1/m"
+msgstr "Specifický výnos 1/m"
-#: ../raster/r.volume/main.c:58
+#: ../raster3d/r3.gwflow/main.c:109
+msgid "Recharge raster map in m^3/s"
+msgstr "Mapa obohacení v m^3/s "
+#: ../raster3d/r3.gwflow/main.c:118
msgid ""
-"Calculates the volume of data \"clumps\", and (optionally) produces a GRASS "
-"vector points map containing the calculated centroids of these clumps."
+"The piezometric head result of the numerical calculation will be written to "
+"this map"
msgstr ""
-"Spoèítá objem spojitých oblastí a (volitelnì) vytvoøí bodovou vektorovou "
-"mapu obsahující spoèítané centroidy tìhto spojitých oblastí."
+"Výsledná piezometrická hodnota numerického výpoètu bude zapsána do mapy"
-#: ../raster/r.volume/main.c:68
-msgid "Existing raster map representing data that will be summed within clumps"
+#: ../raster3d/r3.gwflow/main.c:127
+msgid ""
+"Calculate the groundwater distance velocity vector field and write the x, y, "
+"and z components to maps named name_[xyz]. Name is basename for the new "
+"raster3d maps"
msgstr ""
-"Existující rastrová mapa pøedstavující data, která budou seètena v rámci "
-"spojitých oblastí"
+"Vypoèítat prùtokovou rychlost vektorového pole a zapi¹ x,y a z èásti do map "
+"pojmenovaných jmeno_[xyz]. Jméno mapy je základ pro r3d rastrovou mapu."
-#: ../raster/r.volume/main.c:76
-msgid "Existing raster map, preferably the output of r.clump"
-msgstr "Existující rastrová mapa, nejlépe výstup z r.clump"
+#: ../raster3d/r3.gwflow/main.c:138
+msgid "Use G3D mask (if exists)"
+msgstr "Pou¾ít masku G3D (pokud existuje)"
-#: ../raster/r.volume/main.c:83
-msgid "Vector points map to contain clump centroids"
-msgstr "Výstupní vektorová mapa obsahující centroidy spojitých oblastí"
-#: ../raster/r.volume/main.c:87
-msgid "Generate unformatted report"
-msgstr "Vytvoøí neformátovanou zprávu"
-#: ../raster/r.volume/main.c:116
-msgid "No data map specified"
-msgstr "Nebyly specifikovány ¾ádné vstupní mapy."
-#: ../raster/r.volume/main.c:127
-msgid "No clump map specified and MASK not set."
-msgstr "Nebyla zadána mapa spojitých oblastí a nastavena MASKa"
-#: ../raster/r.volume/main.c:132
-msgid "Unable to find data map"
-msgstr "Nelze nalézt mapu s daty"
-#: ../raster/r.volume/main.c:140
-msgid "Unable to find clump map"
-msgstr "Nelze nalézt mapu shlukù (clump)"
-#: ../raster/r.volume/main.c:148
-msgid "Unable to open centroids vector points map"
-msgstr "Nelze otevøít vektorovou mapu pro centroidy."
-#: ../raster/r.volume/main.c:170
-msgid "Data or Clump file not open"
-msgstr "Datový (data) nebo shlukový (clump) soubor nebyl otevøen"
-#: ../raster/r.volume/main.c:214
-msgid "Memory allocation error"
-msgstr "Chyba pøi alokaci pamìti."
-#: ../raster/r.null/null.c:47
-msgid "Creates explicitly the NULL-value bitmap file."
-msgstr "Vytvoøí mapu s hodnotami NULL."
-#: ../raster/r.null/null.c:55
-msgid "Raster map for which to edit null file"
-msgstr "Rastrová její¾ soubor NULL bude editován"
-#: ../raster/r.null/null.c:74
-msgid "Only do the work if the map is floating-point"
-msgstr "Pracuj pouze pokud je mapa s plovoucí desetinnou èárkou"
-#: ../raster/r.null/null.c:78
-msgid "Only do the work if the map is integer"
-msgstr "Pracuj pouze pokud je mapa celoèíselná"
-#: ../raster/r.null/null.c:82
-msgid "Only do the work if the map doesn't have a NULL-value bitmap file"
-msgstr "Udìlej svou práci pouze pokud mapa nemá soubor NULL"
-#: ../raster/r.null/null.c:86
-msgid "Create NULL-value bitmap file validating all data cells"
-msgstr "Vytvoø soubor s hodnotami NULL pøi validaci v¹ech bunìk"
-#: ../raster/r.null/null.c:90
-msgid "Remove NULL-value bitmap file"
-msgstr "Smazat soubor NULL"
-#: ../raster/r.average/main.c:53
+#: ../raster3d/r3.gwflow/main.c:144
msgid ""
-"Finds the average of values in a cover map within areas assigned the same "
-"category value in a user-specified base map."
+"Use a sparse linear equation system, only available with iterative solvers"
msgstr ""
-"Nalezne prùmìr hodnot z pøekrývající mapy, která bude rozdìlena podle ploch "
-"se stejnými hodnotami z pokladové mapy."
+"Pou¾ít lineární systém rovnic pro øídké matice, dostupný pouze pro "
+"iterativní solvery"
-#: ../raster/r.average/main.c:65 ../raster/r.statistics/main.c:69
-msgid "Cover values extracted from the category labels of the cover map"
-msgstr "Hodnoty získané z oznaèení kategorií pøekrývající mapy (cover map)"
+#: ../raster3d/r3.gwflow/main.c:175
+msgid ""
+"Numerical calculation program for transient, confined groundwater flow in "
+"three dimensions"
+msgstr "Numerický výpoèet pro pøechodný uzavøený tok ve tøech dimenzích"
-#: ../raster/r.average/main.c:82 ../raster/r.grow2/main.c:211
-#, c-format
-msgid "Error reading category file for <%s>"
-msgstr "Chyba pøi ètení soubor kategeorií pro <%s>"
+#: ../raster3d/r3.gwflow/main.c:193 ../raster/r.gwflow/main.c:266
+msgid "The direct LU solver do not work with sparse matrices"
+msgstr "Pøímý LU øe¹itel nepracuje s øídkou maticí"
-#: ../raster/r.average/main.c:93
-#, c-format
-msgid "%s: ERROR running %s command"
-msgstr "%s: CHYBA pøi spu¹tìní pøíkazu %s"
+#: ../raster3d/r3.gwflow/main.c:195 ../raster/r.gwflow/main.c:269
+msgid "The direct Gauss solver do not work with sparse matrices"
+msgstr "Pøímá Gausova analýza nepracuje s øídkou maticí"
-#: ../raster/r.average/main.c:102 ../raster/r.statistics/o_distrib.c:41
-#: ../raster/r.statistics/o_sum.c:43 ../raster/r.statistics/o_average.c:42
-#, c-format
-msgid "%s: unable to open temporary file"
-msgstr "%s: nelze otevøít doèasný soubor"
+#: ../raster3d/r3.gwflow/main.c:197 ../raster/r.gwflow/main.c:272
+msgid "The direct cholesky solver do not work with sparse matrices"
+msgstr "Pøímá choleskyho analýza nepracuje s øídkou maticí"
-#: ../raster/r.lake/main.c:46
-msgid "Saving new map"
-msgstr "Ukládám novou mapu"
+#: ../raster3d/r3.gwflow/main.c:300 ../raster/r.gwflow/main.c:556
+msgid "Unable to create and solve the linear equation system"
+msgstr "Nelze vytvoøit a vyøe¹it soustavu lineárních rovnic"
-#: ../raster/r.lake/main.c:52
+#: ../raster3d/r3.gwflow/main.c:376 ../raster3d/r3.stats/main.c:615
+#: ../raster/r.univar2/r3.univar_main.c:111
#, c-format
-msgid "Cell area: %f"
-msgstr "Plocha bunìk: %f"
+msgid "Error opening g3d map <%s>"
+msgstr "Chyba pøi otevírání mapy g3d <%s>"
-#: ../raster/r.lake/main.c:80
-msgid "Error writing result map file!"
-msgstr "Chyba pøi zápisu výsledného mapového souboru!"
+#: ../raster3d/r3.gwflow/main.c:378
+#, c-format
+msgid "Write the result to g3d map <%s>"
+msgstr "Zapsat výsledek do g3d mapy <%s>"
-#: ../raster/r.lake/main.c:158
-msgid "Fills lake from seed at given level"
-msgstr "Vytvoøí jezero ze zadaného bodu dané íºrovnì"
+#: ../raster3d/r3.gwflow/main.c:422
+msgid "Error closing g3d file"
+msgstr "Chyba pøi zavírání souboru g3d"
-#: ../raster/r.lake/main.c:163
-msgid "Terrain raster map (DEM)"
-msgstr "Mapa s modelem terénu (DMT)"
+#: ../raster3d/r3.stats/main.c:565 ../raster/r.univar2/r3.univar_main.c:78
+msgid "raster3d, statistics"
+msgstr "rastr3d, statistika"
-#: ../raster/r.lake/main.c:170
-msgid "Water level"
-msgstr "Úroveò hladiny"
+#: ../raster3d/r3.stats/main.c:566
+msgid "Generates volume statistics for raster3d maps."
+msgstr "Vytvoøí statistiku ploch pro r3d rastrové mapy."
-#: ../raster/r.lake/main.c:177
-msgid "Output raster map with lake"
-msgstr "Výstupní rastrová mapa s jezerem"
+#: ../raster3d/r3.stats/main.c:577
+msgid "Number of sub-ranges to collect stats from"
+msgstr "Poèet podintervalù pro které bude vytvoøena statistika"
-#: ../raster/r.lake/main.c:184
-msgid "Seed point coordinates"
-msgstr "Poèáteèní mapové souøadnice"
+#: ../raster3d/r3.stats/main.c:582
+msgid "Calculate statistics based on equal value groups"
+msgstr "vypoèítat statistiku zalo¾enou na stejných hodnotách skupin"
-#: ../raster/r.lake/main.c:193
-msgid "Raster map with seed (at least 1 cell > 0)"
-msgstr "Rastrová mapa s poèátkem (alespoò jedna buòka > 0)"
+#: ../raster3d/r3.stats/main.c:603
+msgid "The number of subranges has to be equal or greater than 1"
+msgstr "Poèet subrozmezí musí být >= 1"
-#: ../raster/r.lake/main.c:200
-msgid "Use negative depth values for lake raster map"
-msgstr "Pou¾ij negativní hodnoty pro hloubku jezera"
+#: ../raster3d/r3.stats/main.c:608 ../raster/r.univar2/r3.univar_main.c:103
+#, c-format
+msgid "Requested g3d map <%s> not found"
+msgstr "Po¾adovaná mapa g3d <%s> nebyla nalezena"
-#: ../raster/r.lake/main.c:204
-msgid "Overwrite seed map with result (lake) map"
-msgstr "Pøepi¹ poèáteèní mapu výslednou mapou (jezerem)"
+#: ../raster3d/r3.stats/main.c:660
+msgid "Sort non-null values"
+msgstr "Uspoøádat neNULLové hodnoty"
-#: ../raster/r.lake/main.c:212
-msgid "Both seed map and coordinates cannot be specifed"
-msgstr "Nelze zadat obojí: mapu s poèátky a poèáteèní souøadnice"
-#: ../raster/r.lake/main.c:215
-msgid "Seed map or seed coordinates must be set!"
+#: ../raster3d/r3.mkdspf/main.c:75
+msgid ""
+"Creates a display file from an existing grid3 file according to specified "
+"threshold levels."
msgstr ""
-"Musí být zadán právì jeden z parametrù mapa s poèátky (seed map) nebo "
-"souøadnice poèátkù!"
+"Vytvoøí a zobrazí soubor z existujícího grid3 souboru podle zadaných "
+"prahových hodnot."
-#: ../raster/r.lake/main.c:218
-msgid "Seed coordinates and output map lake= must be set!"
-msgstr "Poèáteèní souøadnice a mapa lake= musí být nastaveny!"
+#: ../raster3d/r3.mkdspf/main.c:83
+msgid "Name of an existing 3d raster map"
+msgstr "Název existující 3D rastrové mapy"
-#: ../raster/r.lake/main.c:221
-msgid "Both lake and overwrite cannot be specifed"
-msgstr "Nelze zadat najednou 'lake' a 'pøepi¹'"
+#: ../raster3d/r3.mkdspf/main.c:89
+msgid "Name of output display file"
+msgstr "Název výstupního souboru"
-#: ../raster/r.lake/main.c:224
-msgid "Output lake map or overwrite flag must be set!"
-msgstr "Jeden z parametrù 'lake' nebo 'pøepi¹' musí být zadán!"
+#: ../raster3d/r3.mkdspf/main.c:96
+msgid "List of thresholds for isosurfaces"
+msgstr "Seznam prahových hodnot pro iso-povrchy"
-#: ../raster/r.lake/main.c:236
-#, c-format
-msgid "Cannot write lake raster map <%s>!"
-msgstr "Nelze zapsat rastrový soubor s jezerem <%s>!"
+#: ../raster3d/r3.mkdspf/main.c:102
+msgid "Minimum isosurface level"
+msgstr "Minimální íºroveò isopovrchu"
-#: ../raster/r.lake/main.c:256
-msgid "Seed point outside the current region."
-msgstr "Poèáteèní bod je mimo souèasný region"
+#: ../raster3d/r3.mkdspf/main.c:108
+msgid "Maximum isosurface level"
+msgstr "Maximální íºroveò isopovrchu"
-#: ../raster/r.lake/main.c:262
-#, c-format
-msgid "Terrain raster map <%s> not found!"
-msgstr "Rastrová mapa s terénem <%s> nebyla nalezena"
+#: ../raster3d/r3.mkdspf/main.c:114
+msgid "Positive increment between isosurface levels"
+msgstr "Kladný pøírùstek mezi jednotlivými íºrovnìmi isopovrchù"
-#: ../raster/r.lake/main.c:265
-#, c-format
-msgid "Cannot open terrain raster map <%s@%s>!"
-msgstr "Nelze otevøít rastrový soubor s terénem <%s@%s>!"
+#: ../raster3d/r3.mkdspf/main.c:121
+msgid "Number of isosurface threshold levels"
+msgstr "Poèet prahových íºrovní isopovrchù"
-#: ../raster/r.lake/main.c:272
-#, c-format
-msgid "Seed map <%s> not found!"
-msgstr "Mapa s poèátky <%s> nebyla nalezena!"
+#: ../raster3d/r3.mkdspf/main.c:125
+msgid "Suppress progress report & min/max information"
+msgstr "Potlaè zprávu o prùbìhu & min/max informaci"
-#: ../raster/r.lake/main.c:275
-#, c-format
-msgid "Cannot open seed map <%s@%s>!"
-msgstr "Nelze otevøít soubor s poèátky <%s@%s>!"
+#: ../raster3d/r3.mkdspf/main.c:129
+msgid "Use flat shading rather than gradient"
+msgstr "Pou¾ij plo¹né stínování místo gradientu"
-#: ../raster/r.lake/main.c:282
-msgid "Failure to allocate memory for row pointers"
-msgstr "Nelze alokovat pamì» pro øádek rastru"
-#: ../raster/r.lake/main.c:285
-msgid "Loading maps: "
-msgstr "Naèítám mapy: "
-#: ../raster/r.lake/main.c:294
-msgid "Error reading terrain raster map. Probably broken file."
-msgstr ""
-"Chyba pøi ètení vrstvy vý¹kového modelu. Pravdìpodobnì je soubor po¹kozen."
-#: ../raster/r.lake/main.c:298
-msgid "Error reading seed raster map. Probably broken file."
-msgstr ""
-"Chyba pøi ètení zárodeèné rastrové vrstvy. Pravdìpodobnì je soubor po¹kozen."
-#: ../raster/r.lake/main.c:307
-msgid ""
-"Given water level at seed point is below earth surface. \n"
-" Increase water level or move seed point."
-msgstr ""
-"Zadaná hladina vody je na místì poèáteèního bodu pod povrchem\n"
-" Zvy¹te íºroveò vody a nebo posuòte poèáteèní bod."
-#: ../raster/r.lake/main.c:322
+#: ../raster3d/r3.mkdspf/main.c:137
#, c-format
-msgid "Cannot write lake raster map <%s@%s>!"
-msgstr "Nelze zapsat rastrový soubor s jezerem <%s@%s>!"
+msgid "Region from getWindow: %d %d %d"
+msgstr "Region z getWindow: %d %d %d"
-#: ../raster/r.lake/main.c:328
+#: ../raster3d/r3.mkdspf/main.c:147
#, c-format
-msgid ""
-"Starting lake filling at level of %8.4f in %d passes. \n"
-"Percent done:"
-msgstr ""
-"Zaèínám plnit jezero na íºrovni %8.4f v %d fázích. \n"
-"Hotovo procent: "
+msgid "Not able to find grid3 file for [%s]"
+msgstr "Nejsem schopen nalézt soubor grid3 pro [%s]"
-#: ../raster/r.lake/main.c:334
+#: ../raster3d/r3.mkdspf/main.c:159 ../raster3d/base/r3.info.main.c:130
#, c-format
-msgid "Pass: %d\n"
-msgstr "Prùchod: %d\n"
+msgid "Error opening grid3 file [%s]"
+msgstr "Chyba pøi otevírání souboru grid3 [%s]"
-#: ../raster/r.lake/main.c:392
+#: ../raster3d/r3.mkdspf/main.c:162 ../raster3d/base/r3.info.main.c:289
+#: ../raster3d/base/r3.info.main.c:351
#, c-format
-msgid "Lake depth from %f to %f"
-msgstr "Hloubka jezera je %f do %f"
+msgid "Error reading range for [%s]"
+msgstr "Chyba pøi ètení rozsahu pro [%s]"
-#: ../raster/r.lake/main.c:393
+#: ../raster3d/r3.mkdspf/main.c:191
#, c-format
-msgid "Lake area %f square meters"
-msgstr "Plocha jezera %f metrù ètverèních"
+msgid "Error opening display file [%s]"
+msgstr "Chyba pøi otevírání souboru [%s]"
-#: ../raster/r.lake/main.c:394
+#: ../raster3d/r3.mkdspf/main.c:212
#, c-format
-msgid "Lake volume %f cubic meters"
-msgstr "Objem jezera %f metrù krychlových"
+msgid "Writing %s from %s..."
+msgstr "Zapisuji %s z %s..."
-#: ../raster/r.lake/main.c:395
-msgid "Volume is correct only if lake depth (terrain raster map) is in meters"
-msgstr "Objem je správný pouze pokud je jeho hloubka (rastr terénu) v metrech"
+#: ../raster3d/r3.in.v5d/main.c:217 ../raster3d/r3.out.v5d/main.c:311
+#: ../raster3d/r3.in.ascii/main.c:265 ../raster3d/r3.out.ascii/main.c:282
+#: ../raster/r.to.rast3/main.c:301 ../raster/r.to.rast3elev/main.c:484
+msgid "Error opening 3d raster map"
+msgstr "Chyba pøi otevírání g3d souboru"
-#: ../raster/r.lake/main.c:415
-#, c-format
-msgid "Error writing color file for <%s@%s>!"
-msgstr "Chyba pøi zápisu souboru color pro <%s@%s>!"
+#: ../raster3d/base/r3.info.main.c:81
+msgid "Outputs basic information about a user-specified 3D raster map layer."
+msgstr "Vypí¹e základní informace o u¾ivatelem vybrané 3D rastrové mapì."
-#: ../raster/r.lake/main.c:420
-msgid "All done."
-msgstr "Dokonáno jest."
+#: ../raster3d/base/r3.info.main.c:88
+msgid "Name of input 3D raster map"
+msgstr "Název vstupní 3D rastrové mapy"
-#: ../raster/r.out.gdal/main.c:47
-#, c-format
-msgid "Supported formats:\n"
-msgstr "Podporované formáty:\n"
+#: ../raster3d/base/r3.info.main.c:92 ../raster/r.info/main.c:76
+msgid "Print range only"
+msgstr "Vytiskni pouze rozsah"
-#: ../raster/r.out.gdal/main.c:108
-msgid "Unable to get raster band"
-msgstr "Nelze dostat jedno z rastrových pásem"
+#: ../raster3d/base/r3.info.main.c:97
+msgid "Print 3D raster map resolution (NS-res, EW-res, TB-res) only"
+msgstr "Vytiskni pouze rozli¹ení 3D rastru (NS-roz, EW-roz, TB-roz)"
-#: ../raster/r.out.gdal/main.c:216 ../raster/r.out.gdal/main.c:221
-msgid "Unable to allocate buffer for reading raster map"
-msgstr "Nelze alokovat buffer pro ètení rastru"
+#: ../raster3d/base/r3.info.main.c:101
+msgid "Print 3D raster map type (float/double) only"
+msgstr "Vytiskne pouze typ 3D rastrové mapy (float/double)"
-#: ../raster/r.out.gdal/main.c:253 ../raster/r.out.gdal/main.c:283
-#: ../raster/r.out.gdal/main.c:313
-msgid "Unable to write GDAL raster file"
-msgstr "Nelze zapisovat do rastrového souboru GDAL"
+#: ../raster3d/base/r3.info.main.c:105
+msgid "Print 3D raster map region only"
+msgstr "Vytiskni pouze region rastrové 3D rastrové mapy"
-#: ../raster/r.out.gdal/main.c:322
-#, c-format
-msgid ""
-"Input raster map constains cells with NULL-value (no-data). For no-data "
-"values was used value %d. You can specify nodata value by %s parameter."
-msgstr ""
-"Vstupní rastrová mapa obsahuje NULLové hodnoty (¾ádná data). Pro NULLové "
-"hodnoty bude pou¾ita hodnota %d. Mù¾ete specifikovat pøizazenou hodnotu "
-"parametrem %s."
+#: ../raster3d/base/r3.info.main.c:109
+msgid "Print 3D raster history instead of info"
+msgstr "Vytiskne historii 3D rastru místo informací"
-#: ../raster/r.out.gdal/main.c:327
-#, c-format
-msgid ""
-"values was used value %g. You can specify nodata value by %s parameter."
+#: ../raster3d/base/r3.info.main.c:115
+msgid "Print 3D raster map timestamp (day.month.year hour:minute:seconds) only"
msgstr ""
-"hodnoty bude pou¾ita hodnota %g. Mù¾ete specifikovat pøizazenou hodnotu "
-"parametrem %s."
+"Vypsat pouze èasovou znaèku 3D rastrové mapy (den.mìsíc.rok hodiny:minuty:"
+"sekondy)"
-#: ../raster/r.out.gdal/main.c:374
-msgid "Exports GRASS raster map into GDAL supported formats."
-msgstr ""
-"Exportuje GRASS rastry do jednoho z formátù podporovaných knihovnou GDAL."
-#: ../raster/r.out.gdal/main.c:380 ../raster/r.in.gdal/main.c:132
-#: ../vector/v.to.db/parse.c:90 ../vector/v.to.db/parse.c:95
-#: ../vector/v.to.db/parse.c:100 ../imagery/i.group/main.c:74
-#: ../imagery/i.group/main.c:79 ../general/g.region/cmd/main.c:100
-#: ../general/g.region/cmd/main.c:106 ../general/g.region/cmd/main.c:111
-#: ../general/g.region/cmd/main.c:116 ../general/g.region/cmd/main.c:121
-#: ../general/g.region/cmd/main.c:126 ../general/g.region/cmd/main.c:131
-#: ../general/g.region/cmd/main.c:136
-msgid "Print"
-msgstr "Tisk"
-#: ../raster/r.out.gdal/main.c:384
-#, fuzzy
-msgid "Name of raster map (or group) to export"
-msgstr "Jméno rastrové mapy, obsahující výsledky"
-#: ../raster/r.out.gdal/main.c:385 ../raster/r.out.gdal/main.c:421
-#: ../raster/r.in.gdal/main.c:89 ../raster/r.in.gdal/main.c:93
-#: ../vector/v.in.ogr/main.c:111 ../vector/v.in.ogr/main.c:115
-msgid "Required"
-msgstr "Po¾adováno"
-#: ../raster/r.out.gdal/main.c:420
-#, fuzzy
-msgid "Name for output raster file"
-msgstr "Název výstupní rastrové mapy"
-#: ../raster/r.out.gdal/main.c:426
-msgid ""
-"Creation option to the output format driver. Multiple options may be listed."
-msgstr "Volby pro ovladaè výstupního formátu. Volby je mo¾no kombinovat."
-#: ../raster/r.out.gdal/main.c:442
-msgid "Assign a specified nodata value to output bands"
-msgstr "Pøidìlit specifickou hodnotu NULLovým buòkám ve výstupních skupinách"
-#: ../raster/r.out.gdal/main.c:475
+#: ../raster3d/base/r3.info.main.c:123 ../general/g.region/main.c:451
+#: ../general/g.region/main.c:815 ../general/g.region/main.c:824
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:383
+#: ../display/d.rast.arrow/arrow.c:196 ../display/d.rast.arrow/arrow.c:238
+#: ../display/d.rast.arrow/arrow.c:374 ../display/d.colortable/main.c:101
+#: ../display/d.legend/main.c:252 ../display/d.title/main.c:105
+#: ../display/d.rast.num/number.c:150 ../display/d.extend/main.c:62
+#: ../display/d.profile/main.c:92 ../display/d.his/main.c:137
+#: ../display/d.his/main.c:176 ../display/d.his/main.c:204
+#: ../display/d.what.rast/main.c:150 ../display/d.what.rast/opencell.c:15
+#: ../display/d.rast/main.c:111 ../display/d.nviz/main.c:183
+#: ../display/d.rgb/main.c:100 ../display/d.zoom/main.c:218
+#: ../display/d.histogram/main.c:157 ../doc/raster/r.example/main.c:110
+#: ../ps/ps.map/outl_io.c:72 ../vector/v.what.rast/main.c:132
+#: ../vector/v.sample/main.c:157 ../vector/v.vol.rst/main.c:577
+#: ../vector/v.drape/main.c:120 ../vector/v.extrude/main.c:178
+#: ../visualization/xganim/main.c:342 ../raster/r.neighbors/main.c:180
+#: ../raster/r.fill.dir/main.c:163 ../raster/r.region/main.c:161
+#: ../raster/r.region/main.c:218 ../raster/r.region/main.c:353
+#: ../raster/r.to.vect/main.c:109 ../raster/r.out.mpeg/main.c:222
+#: ../raster/r.info/main.c:116 ../raster/r.recode/main.c:82
+#: ../raster/r.buffer/main.c:115 ../raster/r.his/main.c:128
+#: ../raster/r.his/main.c:169 ../raster/r.his/main.c:197
+#: ../raster/r.resamp.interp/main.c:102 ../raster/r.basins.fill/main.c:92
+#: ../raster/r.basins.fill/main.c:104 ../raster/r.texture/main.c:224
+#: ../raster/r.series/main.c:170 ../raster/r.null/null.c:104
+#: ../raster/r.distance/parse.c:78 ../raster/r.distance/parse.c:85
+#: ../raster/r.kappa/stats.c:30 ../raster/r.kappa/stats.c:35
+#: ../raster/r.kappa/main.c:141 ../raster/r.out.ppm/main.c:115
+#: ../raster/r.sum/main.c:64 ../raster/r.clump/main.c:88
+#: ../raster/r.univar2/r.univar_main.c:149 ../raster/r.mfilter.fp/main.c:124
+#: ../raster/r.coin/inter.c:40 ../raster/r.coin/inter.c:44
+#: ../raster/r.coin/cmd_parms.c:96 ../raster/r.coin/cmd_parms.c:99
+#: ../raster/r.patch/main.c:115 ../raster/r.water.outlet/legal.c:23
+#: ../raster/r.out.ascii/main.c:145 ../raster/simwe/simlib/input.c:177
+#: ../raster/simwe/simlib/input.c:183 ../raster/simwe/simlib/input.c:188
+#: ../raster/simwe/simlib/input.c:197 ../raster/simwe/simlib/input.c:205
+#: ../raster/simwe/simlib/input.c:211 ../raster/simwe/simlib/input.c:217
+#: ../raster/simwe/simlib/input.c:224 ../raster/simwe/simlib/input.c:231
+#: ../raster/simwe/simlib/input.c:238 ../raster/simwe/simlib/input.c:245
+#: ../raster/r.support.stats/main.c:47 ../raster/r.out.vtk/main.c:47
+#: ../raster/r.out.vtk/main.c:60 ../raster/r.surf.idw2/read_cell.c:20
+#: ../raster/r.reclass/main.c:77 ../raster/r.random/main.c:106
+#: ../raster/r.random/main.c:111 ../raster/r.out.tiff/r.out.tiff.c:167
+#: ../raster/r.report/parse.c:247 ../raster/r.cats/main.c:120
+#: ../raster/r.cats/main.c:140 ../raster/r.param.scale/interface.c:165
+#: ../raster/r.profile/main.c:142 ../raster/r.walk/main.c:523
+#: ../raster/r.walk/main.c:526 ../raster/r.out.ppm3/main.c:117
+#: ../raster/r.contour/main.c:156 ../raster/wildfire/r.ros/main.c:312
+#: ../raster/wildfire/r.ros/main.c:322 ../raster/wildfire/r.ros/main.c:326
+#: ../raster/wildfire/r.ros/main.c:330 ../raster/wildfire/r.ros/main.c:334
+#: ../raster/wildfire/r.ros/main.c:348 ../raster/wildfire/r.ros/main.c:352
+#: ../raster/wildfire/r.ros/main.c:367 ../raster/wildfire/r.ros/main.c:371
+#: ../raster/wildfire/r.ros/main.c:381 ../raster/wildfire/r.spread/main.c:344
+#: ../raster/wildfire/r.spread/main.c:350
+#: ../raster/wildfire/r.spread/main.c:356
+#: ../raster/wildfire/r.spread/main.c:363
+#: ../raster/wildfire/r.spread/main.c:368
+#: ../raster/wildfire/r.spread/main.c:373 ../raster/r.thin/io.c:97
+#: ../raster/r.bilinear/main.c:78 ../raster/r.out.pov/main.c:171
+#: ../raster/r.transect/main.c:117 ../raster/r.stats/main.c:263
+#: ../raster/r.topidx/check_ready.c:12 ../raster/r.composite/main.c:162
+#: ../raster/r.los/main.c:160 ../raster/r.los/main.c:166
+#: ../raster/r.out.gridatb/check_ready.c:13 ../raster/r.resample/main.c:96
+#: ../raster/r.colors/main.c:266 ../raster/r.colors/main.c:352
+#: ../raster/r.average/main.c:71 ../raster/r.average/main.c:74
+#: ../raster/r.grow2/main.c:185 ../raster/r.surf.idw/main.c:108
+#: ../raster/r.support/front/front.c:218
+#: ../raster/r.support/modcolr/modcolr.c:43
+#: ../raster/r.to.rast3elev/main.c:114 ../raster/r.to.rast3elev/main.c:129
+#: ../raster/r.out.mat/main.c:101 ../raster/r.mfilter/main.c:117
+#: ../raster/r.mapcalc/map.c:380 ../raster/r.covar/main.c:96
+#: ../raster/r.cross/main.c:116 ../raster/r.slope.aspect/main.c:383
+#: ../raster/r.drain/main.c:155 ../raster/r.resamp.rst/main.c:400
+#: ../raster/r.resamp.rst/main.c:426 ../raster/r.statistics/main.c:75
+#: ../raster/r.statistics/main.c:81 ../raster/r.watershed/seg/init_vars.c:371
+#: ../raster/r.watershed/ram/init_vars.c:341 ../raster/r.out.bin/main.c:129
+#: ../raster/r.carve/main.c:173 ../raster/r.out.arc/main.c:111
+#: ../raster/r.median/main.c:73 ../raster/r.resamp.stats/main.c:302
+#: ../raster/r.bitpattern/main.c:101 ../raster/r.flow/io.c:65
+#: ../raster/r.cost/main.c:319 ../raster/r.surf.area/main.c:121
+#: ../imagery/i.fft/fftmain.c:120 ../imagery/i.gensig/parse.c:48
+#: ../imagery/i.class/main.c:124 ../imagery/i.zc/main.c:110
+#: ../imagery/i.pca/main.c:122
+#: ../imagery/i.ortho.photo/photo.2target/main.c:202
+#: ../imagery/i.ortho.photo/photo.2target/main.c:236
+#: ../imagery/i.his.rgb/openfiles.c:32 ../imagery/i.his.rgb/openfiles.c:37
+#: ../imagery/i.his.rgb/openfiles.c:42 ../imagery/i.rgb.his/openfiles.c:15
+#: ../imagery/i.rgb.his/openfiles.c:17 ../imagery/i.rgb.his/openfiles.c:19
+#: ../imagery/i.group/main.c:195 ../imagery/i.group/main.c:232
#, c-format
-msgid "Raster map or group <%s> not found"
-msgstr "Rastrová mapa nebo skupina <%s> nebyla nalezena"
+msgid "Raster map <%s> not found"
+msgstr "Rastrová mapa <%s> nenalezena"
-#: ../raster/r.out.gdal/main.c:479
-#, c-format
-msgid "No raster maps in group <%s>"
-msgstr "Ve skupinì <%s> nejsou ¾ádné rastrové mapy"
+#: ../raster3d/base/r3.info.main.c:160 ../raster3d/base/r3.info.main.c:168
+#: ../raster3d/base/r3.info.main.c:174 ../raster3d/base/r3.info.main.c:179
+#: ../raster3d/base/r3.info.main.c:186 ../raster3d/base/r3.info.main.c:197
+#: ../raster3d/base/r3.info.main.c:203 ../raster3d/base/r3.info.main.c:219
+#: ../raster3d/base/r3.info.main.c:226 ../raster3d/base/r3.info.main.c:233
+#: ../raster3d/base/r3.info.main.c:238 ../raster3d/base/r3.info.main.c:243
+#: ../raster3d/base/r3.info.main.c:250 ../raster3d/base/r3.info.main.c:257
+#: ../raster3d/base/r3.info.main.c:267 ../raster3d/base/r3.info.main.c:277
+#: ../raster3d/base/r3.info.main.c:287 ../raster3d/base/r3.info.main.c:300
+#: ../raster3d/base/r3.info.main.c:310 ../raster3d/base/r3.info.main.c:315
+#: ../raster3d/base/r3.info.main.c:323 ../raster3d/base/r3.info.main.c:336
+#: ../raster/r.info/main.c:299 ../raster/r.info/main.c:419
+msgid "Cannot allocate memory for string"
+msgstr "Nelze alokovat pro øetìzec pamì»"
-#: ../raster/r.out.gdal/main.c:491
-#, c-format
-msgid "Unable to get <%s> driver"
-msgstr "Nelze získat ovladaè <%s>"
+#: ../raster3d/base/r3.info.main.c:401
+msgid "Error while reading history file"
+msgstr "Chyba pøi ètení souboru s historií"
-#: ../raster/r.out.gdal/main.c:497
+#: ../raster3d/base/mask_functions.c:82
#, c-format
-msgid ""
-"Driver <%s> does not support direct writing. Using MEM driver for "
-"intermediate dataset."
-msgstr ""
-"Ovladaè <%s> nepodporuje pøímý zápis. Pou¾ívám ovladaè MEM pro pøechodný "
-"dataset."
+msgid "Adding rule: %lf - %lf"
+msgstr "Pøidávám pravidlo: %lf - %lf"
-#: ../raster/r.out.gdal/main.c:502
-msgid "Unable to get in-memory raster driver"
-msgstr "Nelze se dostat do pamì»ového rastrového ovladaèe"
-#: ../raster/r.out.gdal/main.c:506
+#: ../raster3d/base/mask_functions.c:100
#, c-format
-msgid "Driver <%s> does not support creating rasters"
-msgstr "Ovladaè <%s> nepodporuje vytváøení rastrù"
+msgid "%s: illegal value spec"
+msgstr "%s: neplatná hodnota pro spec"
-#: ../raster/r.out.gdal/main.c:626
-#, c-format
-msgid "Exporting to GDAL data type: %s"
-msgstr "export do datového typu GDAL: %s"
+#: ../raster3d/base/r3.timestamp.main.c:43
+msgid "Print/add/remove a timestamp for a 3D raster map"
+msgstr "Vytiskni/pøidej/sma¾ èasovou znaèku pro 3D rastrovou mapu"
-#: ../raster/r.out.gdal/main.c:642
-msgid "Output file name not specified"
-msgstr "Nebylo zadáno jméno výstupního rastrového souboru"
+#: ../raster3d/base/r3.timestamp.main.c:50
+msgid "Input grid3 filename"
+msgstr "Vstupní soubor grid3"
-#: ../raster/r.out.gdal/main.c:648
-msgid "Unable to create dataset using memory raster driver"
-msgstr "Nelze vytvoøit dataset pomocí pamì»ového ovladaèe rastrù"
+#: ../raster3d/base/r3.timestamp.main.c:57 ../raster/r.timestamp/main.c:45
+msgid "Datetime, datetime1/datetime2, or none"
+msgstr "Datetime, datetime1/datetime2, nebo ¾ádný"
-#: ../raster/r.out.gdal/main.c:657
+#: ../raster3d/base/r3.timestamp.main.c:72
#, c-format
-msgid "Unable to create <%s> dataset using <%s> driver"
-msgstr "Nelze vytvoøit dataset <%s> pomocí ovladaèe <%s>"
+msgid "Grid3 <%s> not found %s"
+msgstr "Grid3 <%s> nebyl nalezen %s"
-#: ../raster/r.out.gdal/main.c:671
-msgid "Unable to set geo transform"
-msgstr "Nelze nastavit geo transform"
+#: ../raster3d/base/r3.mask.main.c:44
+msgid "3d raster map with reference values"
+msgstr "mapa 3dcell s referenèními hodnotami"
-#: ../raster/r.out.gdal/main.c:678
-msgid "Unable to set projection"
-msgstr "Nelze nastavit projekci"
+#: ../raster3d/base/r3.mask.main.c:52
+msgid "List of cell values to be masked out"
+msgstr "Seznam hodnot bunìk pro maskování"
-#: ../raster/r.out.gdal/main.c:687
-#, fuzzy, c-format
-msgid "Exporting raster map <%s> (band %d)..."
-msgstr "Zapisuji rastrovou mapu <%s>... "
+#: ../raster3d/base/r3.mask.main.c:78 ../raster3d/base/r3.null.main.c:104
+#: ../raster3d/r3.out.v5d/main.c:305 ../raster3d/r3.out.ascii/main.c:273
+msgid "Requested 3d raster map not found"
+msgstr "Po¾adovaný soubor g3d nebyl nalezen"
-#: ../raster/r.out.gdal/main.c:694
-#, c-format
-msgid "Unable to export raster map <%s>"
-msgstr "Nelze exportovat rastrovou mapu <%s>"
+#: ../raster3d/base/r3.mask.main.c:84
+msgid "makeMask: error opening map."
+msgstr "makeMask: chyba pøi otevírání mapy."
-#: ../raster/r.out.gdal/main.c:704
-#, c-format
-msgid "Unable to create raster map <%s> using driver <%s>"
-msgstr "Nelze vytvoøit rastrovou mapu <%s> ovladaèem <%s>"
+#: ../raster3d/base/r3.mask.main.c:95
+msgid "makeMask: error opening g3d mask file"
+msgstr "makeMask: chyba pøi otevírání souboru s maskou g3d"
-#: ../raster/r.in.bin/main.c:113
-msgid "Import a binary raster file into a GRASS raster map layer."
-msgstr "Importuje binární rastrový soubor jako GRASS rastrovou mapu."
+#: ../raster3d/base/r3.mask.main.c:124
+msgid "makeMask: error flushing tiles in cube"
+msgstr "makeMask: chyba pøi zarovnávání dla¾dic do kostky"
-#: ../raster/r.in.bin/main.c:119
-msgid "Import as Floating Point Data (default: Integer)"
-msgstr ""
-"Naimportuj jako hodnoty s plovoucí desetinnou èárkou (float) (výchozí: "
-"celoèíselné)"
+#: ../raster3d/base/r3.mask.main.c:129
+msgid "makeMask: error flushing all tiles"
+msgstr "makeMask: chyba pøi zarovnávání v¹ech dla¾dic"
-#: ../raster/r.in.bin/main.c:124
-msgid "Import as Double Precision Data (default: Integer)"
-msgstr ""
-"Naimportuj jako hodnoty s plovoucí desetinnou èárkou (double) (výchozí: "
-"celoèíselné)"
+#: ../raster3d/base/r3.mask.main.c:137
+msgid "makeMask: error closing g3d mask file"
+msgstr "makeMask: chyba pøi uzavírání souboru g3d mask"
-#: ../raster/r.in.bin/main.c:129
-msgid "Signed data (high bit means negative value)"
-msgstr "Oznaèená data (vysoký bit znamená negativní hodnotu)"
+#: ../raster3d/base/r3.mask.main.c:139
+msgid "makeMask: error closing map"
+msgstr "makeMask: chyba pøi uzavírání mapy"
-#: ../raster/r.in.bin/main.c:130 ../raster/r.in.bin/main.c:136
-#: ../raster/r.in.bin/main.c:166 ../raster/r.in.bin/main.c:219
-#: ../raster/r.resamp.rst/main.c:234 ../raster/r.resamp.rst/main.c:242
-#: ../raster/r.resamp.rst/main.c:250 ../raster/r.resamp.rst/main.c:258
-#: ../raster/r.resamp.rst/main.c:266 ../raster/r.slope.aspect/main.c:188
-#: ../raster/r.slope.aspect/main.c:197 ../raster/r.slope.aspect/main.c:268
-#: ../raster/r.slope.aspect/main.c:276 ../raster/r.slope.aspect/main.c:286
-#: ../vector/lidar/v.lidar.edgedetection/main.c:87
-#: ../vector/lidar/v.lidar.edgedetection/main.c:95
-#: ../vector/lidar/v.lidar.edgedetection/main.c:103
-#: ../vector/lidar/v.lidar.edgedetection/main.c:111
-#: ../vector/lidar/v.lidar.edgedetection/main.c:119
-#: ../vector/lidar/v.lidar.edgedetection/main.c:127
-#: ../vector/lidar/v.lidar.edgedetection/main.c:135
-#: ../vector/lidar/v.surf.bspline/main.c:113
-#: ../vector/lidar/v.surf.bspline/main.c:123
-#: ../vector/lidar/v.surf.bspline/main.c:133
-#: ../vector/lidar/v.surf.bspline/main.c:142
-#: ../vector/lidar/v.surf.bspline/main.c:149
-#: ../vector/lidar/v.surf.bspline/main.c:157 ../vector/v.vol.rst/main.c:258
-#: ../vector/v.vol.rst/main.c:266 ../vector/v.vol.rst/main.c:274
-#: ../vector/v.vol.rst/main.c:307 ../vector/v.vol.rst/main.c:316
-#: ../vector/v.vol.rst/main.c:325 ../vector/v.vol.rst/main.c:334
-#: ../vector/v.vol.rst/main.c:342 ../vector/v.surf.rst/main.c:193
-#: ../vector/v.surf.rst/main.c:263 ../vector/v.surf.rst/main.c:270
-#: ../vector/v.surf.rst/main.c:278 ../vector/v.surf.rst/main.c:286
-#: ../vector/v.surf.rst/main.c:295 ../vector/v.surf.rst/main.c:304
-#: ../vector/v.surf.rst/main.c:313 ../vector/v.surf.rst/main.c:322
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:188
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:197
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:268
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:276
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:286
-msgid "Settings"
-msgstr "Nastavení"
+#: ../raster3d/base/r3.mask.main.c:154
+msgid "Establishes the current working 3D raster mask."
+msgstr "Vytvoøí aktuální pracovní 3D rastrovou masku."
-#: ../raster/r.in.bin/main.c:135
-msgid "Byte Swap the Data During Import"
-msgstr "Swap bytù bìhem importu"
-#: ../raster/r.in.bin/main.c:141
-msgid "Get region info from GMT style header"
-msgstr "Získej informace o regionu z GMT hlavièky"
-#: ../raster/r.in.bin/main.c:142 ../raster/r.in.bin/main.c:174
-#: ../raster/r.in.bin/main.c:182 ../raster/r.in.bin/main.c:190
-#: ../raster/r.in.bin/main.c:198 ../raster/r.in.bin/main.c:205
-#: ../raster/r.in.bin/main.c:212 ../general/g.region/cmd/main.c:142
-#: ../general/g.region/cmd/main.c:201 ../general/g.region/cmd/main.c:211
-#: ../general/g.region/cmd/main.c:221 ../general/g.region/cmd/main.c:231
-#: ../general/g.region/cmd/main.c:240 ../general/g.region/cmd/main.c:249
-#: ../general/g.region/cmd/main.c:334
-msgid "Bounds"
-msgstr "Hranice"
-#: ../raster/r.in.bin/main.c:148
-msgid "Binary raster file to be imported"
-msgstr "Název rastrového souboru, který má být importován"
-#: ../raster/r.in.bin/main.c:165
-msgid "Number of bytes per cell (1, 2, 4)"
-msgstr "Poèet bytù na buòku (1, 2, 4)"
-#: ../raster/r.in.bin/main.c:173
-msgid "Northern limit of geographic region (outer edge)"
-msgstr "Severní hranice geografického regionu (vnìj¹í hrana)"
-#: ../raster/r.in.bin/main.c:181
-msgid "Southern limit of geographic region (outer edge)"
-msgstr "Ji¾ní hranice geografického regionu (vnìj¹í hrana)"
-#: ../raster/r.in.bin/main.c:189
-msgid "Eastern limit of geographic region (outer edge)"
-msgstr "Východní hranice geografického regionu (vnìj¹í hrana)"
-#: ../raster/r.in.bin/main.c:197
-msgid "Western limit of geographic region (outer edge)"
-msgstr "Západní hranice geografického regionu (vnìj¹í hrana)"
-#: ../raster/r.in.bin/main.c:204
-msgid "Number of rows"
-msgstr "Poèet øádkù"
-#: ../raster/r.in.bin/main.c:211
-msgid "Number of columns"
-msgstr "Poèet sloupcù"
-#: ../raster/r.in.bin/main.c:218
-msgid "Set Value to NULL"
-msgstr "Nastav hodnotu na NULL"
-#: ../raster/r.in.bin/main.c:243
-msgid "Byte Swapping Turned On."
-msgstr "Zapnuto dokládání bytù."
-#: ../raster/r.in.bin/main.c:275
+#: ../raster3d/base/r3.mask.main.c:159
msgid ""
-"Missing parameters ...\n"
-"Must provide at least[north= south= east= west=] OR [r=\tc=]"
+"Cannot create mask file: G3D_MASK already exists!\n"
+" Use 'g.remove rast3d=G3D_MASK' to remove the existing mask."
msgstr ""
-"Chybìjící parametry ...\n"
-"Musíte zadat alespoò [north= south= east= west=] NEBO [r=\tc=]"
+"Nelze vytvoøit soubor s maskou: G3D_MASK ji¾ existuje!\n"
+" Pro odstranìní existující masky pou¾ijte 'g.remove rast3d=G3D_MASK'."
-#: ../raster/r.in.bin/main.c:281
-msgid "You have to provide all limits of geographic region (n,s,e,w)"
-msgstr "Musíte zadat v¹echny hranièní hodnoty (s,j,v,z)"
+#: ../raster3d/base/r3.null.main.c:57
+msgid "3d raster map for which to modify null values"
+msgstr "mapa 3dcell pro modifikaci hodnot NULL"
-#: ../raster/r.in.bin/main.c:301
-#, c-format
-msgid "Using N=%f S=%f E=%f W=%f"
-msgstr "Pou¾ívám N=%f S=%f E=%f W=%f"
+#: ../raster3d/base/r3.null.main.c:65 ../raster/r.null/null.c:63
+msgid "List of cell values to be set to NULL"
+msgstr "Seznam hodnot bunìk pro nastavení NULL"
-#: ../raster/r.in.bin/main.c:319
-#, c-format
-msgid "Using rows=%d cols=%d\n"
-msgstr "Pou¾ívám øádkù=%d sloupcù=%d\n"
+#: ../raster3d/base/r3.null.main.c:72 ../raster/r.null/null.c:70
+msgid "The value to replace the null value by"
+msgstr "Hodnota pro nahrazení hodnoty NULL"
-#: ../raster/r.in.bin/main.c:423 ../raster/r.in.bin/main.c:430
-#: ../raster/r.in.bin/main.c:439
-msgid "Bytes do not match File size"
-msgstr "Byty neodpovídají velikosti souboru"
+#: ../raster3d/base/r3.null.main.c:86
+msgid "Illegal value for null"
+msgstr "Neplatná hodnota pro null"
-#: ../raster/r.in.bin/main.c:424 ../raster/r.in.bin/main.c:431
-#: ../raster/r.in.bin/main.c:440
-#, c-format
-msgid "File Size %d ... Total Bytes %d"
-msgstr "Velikost souboru %d ... Celkovì bytù %d"
+#: ../raster3d/base/r3.null.main.c:111
+msgid "modifyNull: error opening map"
+msgstr "modifyNull: chyba pøi otevøení mapy"
-#: ../raster/r.in.bin/main.c:425 ../raster/r.in.bin/main.c:432
-#: ../raster/r.in.bin/main.c:441
-#, c-format
-msgid "Try bytes=%d or adjusting input parameters"
-msgstr "Zkuste bytes=%d nebo pøenastavit vstupní parametry"
+#: ../raster3d/base/r3.null.main.c:123
+msgid "modifyNull: error opening tmp file"
+msgstr "modifyNull: chyba pøi otevøení souboru tmp"
-#: ../raster/r.in.bin/main.c:479
-#, c-format
-msgid "Conversion failed at row %d"
-msgstr "Pøed selhal na øádku %d"
+#: ../raster3d/base/r3.null.main.c:172
+msgid "modifyNull: error flushing tiles in cube"
+msgstr "modifyNull: chyba pøi zarovnání dla¾dic do kostky"
-#: ../raster/r.out.gridatb/main.c:48
-msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)"
-msgstr "Exportuje rastrovou mapu GRASSu do GRIDATB.FOR souboru (TOPMODEL)"
+#: ../raster3d/base/r3.null.main.c:178
+msgid "modifyNull: error flushing all tiles"
+msgstr "modifyNull: chyba pøi zarovnání v¹ech dla¾dic"
-#: ../raster/r.out.gridatb/main.c:52
-msgid "Input map"
-msgstr "Vstupní mapa"
+#: ../raster3d/base/r3.null.main.c:186
+msgid "modifyNull: error closing map"
+msgstr "modifyNull: chyba pøi uzavøení mapy"
-#: ../raster/r.out.gridatb/main.c:59 ../raster/r.in.gridatb/main.c:49
-msgid "GRIDATB i/o map file"
-msgstr "GRIDATB vstup/výstup soubor"
+#: ../raster3d/base/r3.null.main.c:188
+msgid "modifyNull: error closing tmp file"
+msgstr "modifyNull: chyba pøi zavírání souboru tmp"
-#: ../raster/r.out.gridatb/main.c:65
-msgid "Overwrite output map file"
-msgstr "Pøepsat výstupní soubor mapy"
+#: ../raster3d/base/r3.null.main.c:204
+msgid "Explicitly create the 3D NULL-value bitmap file."
+msgstr "Vytvoøit výluènì soubor s bitmapou 3D NULL-hodnota"
-#: ../raster/r.out.gridatb/file_io.c:39
-msgid "Setting window header"
-msgstr "Nastavuji hlavièku výøezu"
+#: ../raster3d/r3.out.v5d/main.c:68
+msgid "3d raster map to be converted to Vis5d (v5d) file"
+msgstr "mapa 3dcell pro konverzi na soubor Vis5d (v5d)"
-#: ../raster/r.out.gridatb/file_io.c:42 ../raster/r.in.gridatb/file_io.c:35
-msgid "Rows changed"
-msgstr "Øádky zmìnìny"
+#: ../raster3d/r3.out.v5d/main.c:75
+msgid "Name for v5d output file"
+msgstr "Název výstupního v5d souboru"
-#: ../raster/r.out.gridatb/file_io.c:45 ../raster/r.in.gridatb/file_io.c:37
-msgid "Cols changed"
-msgstr "Sloupce zmìnìny"
-#: ../raster/r.surf.idw2/main.c:62
-msgid "Surface generation program."
-msgstr "Program pro tvorbu povrchù."
-#: ../raster/r.surf.idw2/main.c:73 ../raster/r.surf.idw/main.c:80
-#: ../vector/v.surf.idw/main.c:95
-msgid "Number of interpolation points"
-msgstr "Poèet bodù pro interpolaci"
-#: ../raster/r.surf.idw2/main.c:81
-msgid ""
-"Lat/long databases not supported by r.surf.idw2. Use r.surf.idw instead!"
-msgstr ""
-"Location v systému lat/long není r.surf.idw2 není podporována, pou¾ijte r."
-"surf.idw"
-#: ../raster/r.surf.idw2/main.c:87 ../vector/v.surf.idw/main.c:124
+#: ../raster3d/r3.out.v5d/main.c:145
#, c-format
-msgid "%s=%s - illegal number of interpolation points"
-msgstr "%s=%s - neplatný poèet bodù pro interpolaci"
+msgid "Viz5D allows %d cols, you have %d cols"
+msgstr "Viz5D dovoluje %d sloupcù, vy máte %d sloupcù"
-#: ../raster/r.surf.idw2/main.c:96
+#: ../raster3d/r3.out.v5d/main.c:147
#, c-format
-msgid "%s: no data points found"
-msgstr "%s: nebyly nalezeny ¾ádné body"
+msgid "Viz5D allows %d rows, you have %d rows"
+msgstr "Viz5D dovoluje %d øádkù, vy máte %d øádkù"
-#: ../raster/r.surf.idw2/main.c:113 ../raster/r.surf.idw/main.c:232
+#: ../raster3d/r3.out.v5d/main.c:257
#, c-format
-msgid "Interpolating raster map <%s>... %d rows... "
-msgstr "Interpoluji rastrovou mapu <%s> ... øádek %d ..."
+msgid "Error: couldn't create %s"
+msgstr "Chyba: nemohu vytvoøit %s"
-#: ../raster/r.surf.idw2/main.c:124
-msgid "Cannot get row"
-msgstr "Nelze získat øádek"
+#: ../raster3d/r3.out.v5d/main.c:262
+msgid "Error while writing grid. Disk full?"
+msgstr "Chyba pøi zapisování møí¾ky. Disk je plný?"
-#: ../raster/r.surf.idw2/read_cell.c:40 ../raster/r.series/main.c:172
-#, c-format
-msgid "Reading raster map <%s>..."
-msgstr "Naèítám rastrový soubor <%s>..."
-#: ../raster/r.transect/main.c:55
-msgid ""
-"Outputs raster map layer values lying along user defined transect line(s)."
+#: ../raster3d/r3.out.v5d/main.c:286
+msgid "Export of GRASS 3D raster map to 3-dimensional Vis5D file."
msgstr ""
-"Vytvoøí rastrovou mapu, její¾ hodnoty le¾í na u¾ivatelem definovaném "
-"transektu."
+"Exportuje 3D rastrový soubor GRASSu do 3-dimenzionálního Vis5D souboru."
-#: ../raster/r.transect/main.c:59
-msgid "Raster map to be queried"
-msgstr "Rastrová mapa, která bude dotazována"
+#: ../raster3d/r3.out.v5d/main.c:293
+msgid "Use map coordinates instead of xyz coordinates"
+msgstr "Pou¾ít mapové souøadnice namísto souøadnic xyz"
-#: ../raster/r.transect/main.c:75
-msgid "Transect definition"
-msgstr "Definice transektu"
+#: ../raster3d/r3.in.ascii/main.c:79
+msgid "Ascii raster map to be imported"
+msgstr "Název ASCII rastrového souboru, který má být naimportován"
-#: ../raster/r.mode/main.c:50
-msgid ""
-"Finds the mode of values in a cover map within areas assigned the same "
+#: ../raster3d/r3.in.ascii/main.c:90
+msgid "String representing NULL value data cell (use 'none' if no such value)"
msgstr ""
-"Nalezne modus hodnot z pøekrývající mapy, která bude rozdìlena podle ploch "
+"Textový øetìzec reprezentující hodnotu NULL (pou¾ít 'none' v pøípadì "
+"takovéto hodnoty)"
-#: ../raster/r.mode/main.c:56
-msgid "Base map to be reclassified"
-msgstr "Základní mapa, která má být reklasifikována"
-#: ../raster/r.mode/main.c:63
-msgid "Coverage map"
-msgstr "Krycí mapa"
-#: ../raster/r.mode/main.c:70
-msgid "Output map"
-msgstr "Výstupní mapa"
-#: ../raster/r.mode/main.c:85
+#: ../raster3d/r3.in.ascii/main.c:177
#, c-format
-msgid "%s: base raster map not found"
-msgstr "%s: základní mapa nebyla nalezena"
+msgid "Loading data ... (%dx%dx%d)"
+msgstr "Naèítám data ... (%dx%dx%d)"
-#: ../raster/r.mode/main.c:91
-#, c-format
-msgid "%s: cover raster map not found"
-msgstr "%s: pøekryvná mapa nebyla nalezena"
+#: ../raster3d/r3.in.ascii/main.c:191
+msgid "End of file reached while still loading data."
+msgstr "Konec rastru byl dosa¾en je¹tì pøi naèítání dat."
-#: ../raster/r.mode/main.c:99
+#: ../raster3d/r3.in.ascii/main.c:210
#, c-format
-msgid "%s: base map and output map must be different"
-msgstr "%s: základní mapa a výstupní mapa musí být rùzné"
-#: ../raster/r.mode/main.c:104
-#, c-format
-msgid "%s: Unable to read category labels"
-msgstr "%s: Nemohu naèít popisky kategorií"
-#: ../raster/r.mode/read_stats.c:15
-msgid "reading r.stats output"
-msgstr "ètu výstup z r.stats"
-#: ../raster/simwe/r.sim.sediment/main.c:96
-#: ../raster/simwe/r.sim.water/main.c:99
msgid ""
-"Overland flow hydrologic model based on duality particle-field concept "
-"(SIMWE)"
+"Data exists in input file after fully importing expected data. [%.4f ...]"
msgstr ""
-"Hydrologický model povrchového odtoku zalo¾ený na dualitì pole èásteèek "
-"(SIMWE)"
+"Po plném importu oèekávaných dat, nìkterá data zbyla ve vstupním souboru "
+"[%.4f ...]"
-#: ../raster/simwe/r.sim.sediment/main.c:151
-msgid "Name of the elevation raster map"
-msgstr "Název vstupního rastrového souboru elevace"
+#: ../raster3d/r3.in.ascii/main.c:240
+msgid "raster3d, voxel, import"
+msgstr "rastr3d, voxel, import"
-#: ../raster/simwe/r.sim.sediment/main.c:159
-msgid "Name of the water height raster map"
-msgstr "Jméno rastrové mapy s vý¹kou vodní hladiny"
+#: ../raster3d/r3.in.ascii/main.c:242
+msgid "Convert a 3D ASCII raster text file into a (binary) 3D raster map layer"
+msgstr ""
+"Pøevede 3D ASCII rastrový textový soubor na (binární) 3D rastrovou mapovou "
+"vrstvu "
-#: ../raster/simwe/r.sim.sediment/main.c:167
-msgid "Name of the x-derivatives raster map"
-msgstr "Název rastrového souboru derivací x"
+#: ../raster3d/r3.in.ascii/main.c:271
+msgid "Error closing new 3d raster map"
+msgstr "Chyba pøi zavírání 3d rastru"
-#: ../raster/simwe/r.sim.sediment/main.c:175
-msgid "Name of the y-derivatives raster map"
-msgstr "Název rastrového souboru derivací y"
+#: ../raster3d/r3.in.ascii/main.c:281
+msgid "Error closing ascii file"
+msgstr "Chyba pøi zavírání souboru ASCII"
-#: ../raster/simwe/r.sim.sediment/main.c:184
-msgid "Name of the detachment capacity coefficient raster map"
-msgstr "Jméno rastrové mapy s koeficientem odstupòované kapacity"
+#: ../raster3d/r3.out.ascii/main.c:78
+msgid "3d raster map to be converted to ASCII"
+msgstr "mapa 3dcell pro konverzi do ASCII"
-#: ../raster/simwe/r.sim.sediment/main.c:193
-msgid "Name of the transport capacity coefficient raster map"
-msgstr "Jméno rastrové mapy koeficientu transportní kapacity."
+#: ../raster3d/r3.out.ascii/main.c:85
+msgid "Name for ASCII output file"
+msgstr "Název výstupního ASCII souboru"
-#: ../raster/simwe/r.sim.sediment/main.c:201
-msgid "Name of the critical shear stress raster map"
-msgstr "Jméno rastrové mapy kritických støihù"
+#: ../raster3d/r3.out.ascii/main.c:94
+msgid "Number of decimal places for floats"
+msgstr "Poèet míst za desetinnou èárkou"
-#: ../raster/simwe/r.sim.sediment/main.c:209
-#: ../raster/simwe/r.sim.water/main.c:200
-msgid "Name of the Mannings n raster map"
-msgstr "Název rastrového souboru Manningova n"
+#: ../raster3d/r3.out.ascii/main.c:100 ../raster/r.what/main.c:114
+#: ../raster/r.transect/main.c:84
+msgid "Char string to represent no data cell"
+msgstr "Znak pro oznaèení bunìk s hodnotou NULL"
-#: ../raster/simwe/r.sim.sediment/main.c:218
-#: ../raster/simwe/r.sim.water/main.c:209
-msgid "Name of the vector points map with x,y locations"
-msgstr "Jméno vektorového bodového souboru s x,y místy"
+#: ../raster3d/r3.out.ascii/main.c:105 ../raster/r.out.ascii/main.c:101
+#: ../raster/r.out.arc/main.c:86
+msgid "Suppress printing of header information"
+msgstr "Potlaè výpis informací z hlavièky"
-#: ../raster/simwe/r.sim.sediment/main.c:226
-msgid "Output transport capacity raster map"
-msgstr "Výstupní rastr transportní kapacity"
+#: ../raster3d/r3.out.ascii/main.c:259
+msgid "raster3d, voxel, export"
+msgstr "rastr3d, voxel, export"
-#: ../raster/simwe/r.sim.sediment/main.c:235
-msgid "Output transp.limited erosion-deposition raster map"
-msgstr "Výstupní rastr transportem limitované eroze-depozice"
+#: ../raster3d/r3.out.ascii/main.c:260
+msgid "Converts a 3D raster map layer into an ASCII text file"
+msgstr "Pøevede 3D rastrovou mapovou vrstvu do ASCII textového souboru"
-#: ../raster/simwe/r.sim.sediment/main.c:243
-msgid "Output sediment concentration raster map"
-msgstr "Výstupní rastr koncentrace sedimentu"
+#: ../raster3d/r3.out.ascii/main.c:323
+msgid "Error closing new ASCII file"
+msgstr "Chyba pøi uzavírání nového souboru ASCII"
-#: ../raster/simwe/r.sim.sediment/main.c:251
-msgid "Output sediment flux raster map"
-msgstr "Výstupní rastrová mapa sedimentù"
+#: ../misc/m.cogo/main.c:248
+msgid "miscellaneous"
+msgstr "rùzné"
-#: ../raster/simwe/r.sim.sediment/main.c:259
-msgid "Output erosion-deposition raster map"
-msgstr "Výstupní rastrová mapa depozice erozí"
+#: ../misc/m.cogo/main.c:249
+msgid ""
+"A simple utility for converting bearing and distance measurements to "
+"coordinates and vice versa."
+msgstr ""
+"Jednoduchá utilita pro pøevod orientace a vzdálenosti na souøadnice a naopak."
-#: ../raster/simwe/r.sim.sediment/main.c:267
-#: ../raster/simwe/r.sim.water/main.c:249
-msgid "Number of walkers"
-msgstr "Poèet chodcù"
+#: ../misc/m.cogo/main.c:252
+msgid "It assumes a cartesian coordinate system"
+msgstr "Pøepokladem je carteziánský souøadný systém"
-#: ../raster/simwe/r.sim.sediment/main.c:268
-#: ../raster/simwe/r.sim.sediment/main.c:276
-#: ../raster/simwe/r.sim.sediment/main.c:284
-#: ../raster/simwe/r.sim.sediment/main.c:292
-#: ../raster/simwe/r.sim.sediment/main.c:300
-#: ../raster/simwe/r.sim.water/main.c:250
-#: ../raster/simwe/r.sim.water/main.c:258
-#: ../raster/simwe/r.sim.water/main.c:266
-#: ../raster/simwe/r.sim.water/main.c:274
-#: ../raster/simwe/r.sim.water/main.c:282
-#: ../raster/simwe/r.sim.water/main.c:290
-#: ../raster/simwe/r.sim.water/main.c:298
-#: ../raster/simwe/r.sim.water/main.c:306
-msgid "Parameters"
-msgstr "Parametry"
+#: ../misc/m.cogo/main.c:256
+msgid "Lines are labelled"
+msgstr "Linie jsou popsány"
-#: ../raster/simwe/r.sim.sediment/main.c:275
-#: ../raster/simwe/r.sim.water/main.c:257
-msgid "Number of time iterations (sec.)"
-msgstr "Poèet èasových iterací (sek.)"
+#: ../misc/m.cogo/main.c:260
+msgid "Suppress warnings"
+msgstr "Potlaè varování"
-#: ../raster/simwe/r.sim.sediment/main.c:283
-#: ../raster/simwe/r.sim.water/main.c:265
-msgid "Time step for saving output maps (sec.)"
-msgstr "Èasový krok pro ulo¾ení výstupních map (sek.)"
+#: ../misc/m.cogo/main.c:264
+msgid "Convert from coordinates to bearing and distance"
+msgstr "Pøevod souøadnic na orientaci a vzdálenost"
-#: ../raster/simwe/r.sim.sediment/main.c:291
-#: ../raster/simwe/r.sim.water/main.c:273
-msgid "Density of output walkers"
-msgstr "Hustota výstupních chodcù"
+#: ../misc/m.cogo/main.c:279
+msgid "Starting coordinate pair"
+msgstr "Poèáteèní pár souøadnic"
-#: ../raster/simwe/r.sim.sediment/main.c:299
-#: ../raster/simwe/r.sim.water/main.c:281
-msgid "Water diffusion constant"
-msgstr "Konstanta prostupnosti vody"
-#: ../raster/simwe/r.sim.sediment/main.c:304
-#: ../raster/simwe/r.sim.water/main.c:310
-msgid "Multiscale simulation"
-msgstr "Více mìøítková simulace"
-#: ../raster/simwe/r.sim.sediment/main.c:308
-#: ../raster/simwe/r.sim.water/main.c:314
-msgid "Time-series (dynamic) output"
-msgstr "Dynamický výstup èasových øad"
-#: ../raster/simwe/r.sim.sediment/main.c:342
-#: ../raster/simwe/r.sim.water/main.c:350
+#: ../misc/m.cogo/main.c:290
#, c-format
-msgid "Using metric conversion factor %f, step=%f"
-msgstr "Pou¾ívám konverzní faktor %f, krok=%f"
+msgid "Couldn't open COGO file <%s>"
+msgstr "Nelze otevøít COGO soubor <%s>"
-#: ../raster/simwe/r.sim.sediment/main.c:350
-msgid "You are not outputing any raster or site files"
-msgstr "®ádný rastrový nebo bodový soubor nebyl zadán"
-#: ../raster/simwe/r.sim.sediment/main.c:354
-#: ../raster/simwe/r.sim.water/main.c:362 ../vector/v.surf.rst/main.c:654
-#: ../vector/v.surf.rst/main.c:708
-msgid "Input failed"
-msgstr "Vstup selhal"
-#: ../raster/simwe/r.sim.sediment/main.c:434
-#: ../raster/simwe/r.sim.water/main.c:423
-msgid "Cannot write raster maps"
-msgstr "Nelze zapsat rastrové mapy"
-#: ../raster/simwe/simlib/input.c:49
+#: ../misc/m.cogo/main.c:301
#, c-format
-msgid "File [%s] not found"
-msgstr "Soubor <%s> nebyl nalezen"
+msgid "Couldn't open output file <%s>"
+msgstr "Nelze otevøít výstupní soubor <%s>"
-#: ../raster/simwe/simlib/input.c:52
-#, c-format
-msgid "Unable to open file [%s]"
-msgstr "Nelze otevøít soubor <%s>"
+#: ../misc/m.cogo/main.c:336 ../misc/m.cogo/main.c:339
+msgid "Converting starting coordinate pair"
+msgstr "Pøevádím poèáteèní pár souøadnic"
-#: ../raster/simwe/simlib/input.c:55
-msgid "Failed to guess file format"
-msgstr "Selhal jsem pøi odhadu formátu souboru"
-#: ../raster/simwe/simlib/input.c:58
+#: ../misc/m.cogo/main.c:352
#, c-format
-msgid "Reading sites map (%s) ..."
-msgstr "Naèítám bodový soubor <%s> ..."
+msgid "Input parse error on line %d"
+msgstr "Vstupní chyba parzování na øádku %d"
-#: ../raster/simwe/simlib/input.c:168
-msgid "Running MAY 10 version"
-msgstr "Spustit verzi z 10. kvìtna"
+#: ../general/g.gisenv/main.c:36 ../general/g.access/main.c:37
+#: ../general/g.ask/main.c:39 ../general/g.proj/main.c:54
+#: ../general/g.transform/main.c:236 ../general/g.tempfile/main.c:35
+#: ../general/g.region/main.c:79 ../general/g.findfile/main.c:33
+#: ../general/temp1/main.c:31 ../general/g.message/main.c:32
+#: ../general/g.filename/main.c:38 ../general/temp/main.c:31
+#: ../general/g.findetc/main.c:27 ../general/g.pnmcomp/main.c:302
+#: ../general/g.version/main.c:33
+msgid "general"
+msgstr "obecné"
-#: ../raster/simwe/simlib/input.c:468
-msgid "Zero value in Mannings n"
-msgstr "Nulová hodnota v Manningovì souèiniteli n (drsnost koryta)"
+#: ../general/g.gisenv/main.c:38
+msgid "Outputs and modifies the user's current GRASS variable settings."
+msgstr "Vypí¹e a modifikuje u¾ivatelské nastavení promìnných GRASSu."
-#: ../raster/simwe/simlib/input.c:522
-msgid "Infiltration exceeds the rainfall rate everywhere! No overland flow."
-msgstr ""
-"Vsak je vìt¹í ne¾ mno¾ství srá¾ek na celém území! nevznikne ¾ádný povrchový "
-"odtok."
+#: ../general/g.gisenv/main.c:43
+msgid "GRASS variable to get"
+msgstr "Promìnné GRASSu pro získání"
-#: ../raster/simwe/simlib/input.c:602
-msgid "Unable to write et file"
-msgstr "Nelze zapsat soubor eroze/transportu"
+#: ../general/g.gisenv/main.c:50
+msgid "GRASS variable to set"
+msgstr "Promìnné GRASSu pro nastavení"
-#: ../raster/simwe/simlib/hydro.c:112
-msgid "nwalk > maxw!"
-msgstr "nwalk > maxw!"
+#: ../general/g.gisenv/main.c:59
+msgid "Where GRASS variable is stored"
+msgstr "Kde jsou ulo¾eny promìnné GRASSu"
-#: ../raster/simwe/simlib/hydro.c:323
-msgid "Unable to write raster maps"
+#: ../general/g.access/main.c:39
+msgid "Controls access to the current mapset for other users on the system."
+msgstr "Øídí pøístup k aktuálnímu mapsetu pro ostatní u¾ivatele v systému."
-#: ../raster/simwe/r.sim.water/main.c:152
-msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
-msgstr "Jméno rastrové mapy elevace, stejné jednotky jako S,V: [m] nebo [ft] "
+#: ../general/g.access/main.c:46
+msgid "Access for group"
+msgstr "Pøístup pro skupinu"
-#: ../raster/simwe/r.sim.water/main.c:160
-msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
-msgstr "Jméno rastrové mapy x-derivátù [m/m] nebo [ft/ft]"
+#: ../general/g.access/main.c:53
+msgid "Access for others"
+msgstr "Pøístup pro ostatní"
-#: ../raster/simwe/r.sim.water/main.c:168
-msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
-msgstr "Jméno rastrové mapy y-derivátù [m/m] nebo [ft/ft]"
+#: ../general/g.access/main.c:64
+msgid "Access to the PERMANENT mapset must be open, nothing changed"
+msgstr "Pøístup pro mapset PERMANENT musí být otevøený, nic nemìním."
-#: ../raster/simwe/r.sim.water/main.c:176
-msgid "Name of the rainfall excess rate (rain-infilt) raster map [mm/hr]"
-msgstr "Jméno rastrové mapy míry nadbyteènosti srá¾ej (rein-infilt) [mm/hod]"
+#: ../general/g.access/main.c:68
+msgid "Unable to determine mapset permssions"
+msgstr "Nelze zjistit práva k mapsetu"
-#: ../raster/simwe/r.sim.water/main.c:184
-msgid "Name of the runoff infiltration rate raster map [mm/hr]"
-msgstr "Jméno rastrové mapy pomìru odtoku a infiltrace [mm/hod]"
+#: ../general/g.proj/main.c:56
+msgid ""
+"Converts co-ordinate system descriptions (i.e. projection information) "
+"between various formats (including GRASS format). Can also be used to create "
+"GRASS locations."
+msgstr ""
+"Pøevede popisy souøadných systémù (napø. informace o projekci) mezi rùzné "
+"formáty (vèetnì formátù GRASSu). Lze pou¾ít také pro vytvoøení GRASS "
+"location."
-#: ../raster/simwe/r.sim.water/main.c:192
-msgid "Name of the flow controls raster map (permeability ratio 0-1)"
-msgstr "Jméno rastrového souboru kontroly proudìní (pomìr permeability 0-1)"
+#: ../general/g.proj/main.c:64
+msgid "Print projection information (in conventional GRASS format)"
+msgstr "Vypí¹e informace o projekci (v konvenèním formátu GRASSu)"
-#: ../raster/simwe/r.sim.water/main.c:217
-msgid "Output water depth raster map"
-msgstr "Výstupní rastr hloubky vody"
+#: ../general/g.proj/main.c:70
+msgid "Verify datum information and print transformation parameters"
+msgstr "Ovìø informace o datumu a vypi¹ transformaèní parametry"
-#: ../raster/simwe/r.sim.water/main.c:225
-msgid "Output water discharge raster map"
-msgstr "Název výstupní mapy vypu¹tìní vody"
+#: ../general/g.proj/main.c:76
+msgid "Print projection information in PROJ.4 format"
+msgstr "Vytiskni informace o projekci ve formátu pro PROJ.4"
-#: ../raster/simwe/r.sim.water/main.c:233
-msgid "Output simulation error raster map"
-msgstr "Výstupní rastrová mapa chyb simulace"
+#: ../general/g.proj/main.c:82
+msgid "Print projection information in WKT format"
+msgstr "Vypi¹ informace o projekci ve formátu WKT"
-#: ../raster/simwe/r.sim.water/main.c:241
-msgid "Name of the output walkers vector points map"
-msgstr "Jméno výstupního vektorového bodového souboru chodce"
+#: ../general/g.proj/main.c:88
+msgid "Use ESRI-style format (applies to WKT output only)"
+msgstr "Pou¾ít styl ESRI formátu (aplikováno pouze na výstup WKT)"
-#: ../raster/simwe/r.sim.water/main.c:289
+#: ../general/g.proj/main.c:94
msgid ""
-"Threshold water depth (diffusion increases after this water depth is reached)"
+"Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
msgstr ""
-"Prahová hloubka vody (prostupnost se zvìt¹uje, pokud je tato hloubka "
-"dosa¾ena)"
+"Vypi¹ 'flat' výstup bez øádkových zlom (pou¾ito pro výstup WKT a PROJ.4)"
-#: ../raster/simwe/r.sim.water/main.c:297
-msgid "Diffusion increase constant"
-msgstr "Konstanta zvìt¹ení prostupnosti"
+#: ../general/g.proj/main.c:103
+msgid "Georeferenced data file to read projection information from"
+msgstr "Georeferencovaný soubor, ze které se mají pøeèíst informace o projekci"
-#: ../raster/simwe/r.sim.water/main.c:305
-msgid "Weighting factor for water flow velocity vector"
-msgstr "Váhový faktor pro vektor rychlosti proudìní vody"
+#: ../general/g.proj/main.c:112
+msgid "ASCII file containing a WKT projection description (- for stdin)"
+msgstr ""
+"Soubor ASCII obsahující samostatný popis projekce ve formátu WTK (- pro "
+"standardní vstup)"
-#: ../raster/simwe/r.sim.water/main.c:358
-msgid "You are not outputting any raster or vector points maps"
-msgstr "Nebyla zadána ¾ádná rastrová nebo vektorová mapa pro výstup"
+#: ../general/g.proj/main.c:121
+msgid "PROJ.4 projection description (- for stdin)"
+msgstr "Popis projekce ve stylu PROJ.4 (- pro standardní vstup)"
-#: ../raster/r.out.mat/main.c:63
-msgid "Exports a GRASS raster to a binary MAT-File."
-msgstr "Exportuje rastrový soubor GRASSu do binárního souboru MAT."
+#: ../general/g.proj/main.c:129
+msgid "EPSG projection code"
+msgstr "EPSG kód projekce"
-#: ../raster/r.out.mat/main.c:74
-msgid "Name for the output binary MAT-File"
-msgstr "Název výstupního binárního souboru MAT"
-#: ../raster/r.out.mat/main.c:106 ../raster/r.out.pov/main.c:183
-#, c-format
-msgid "Unable to open output file <%s>"
-msgstr "Nelze otevøít výstupní soubor <%s>"
-#: ../raster/r.out.mat/main.c:128
-#, c-format
-msgid "Exporting <%s>"
-msgstr "Exportuji <%s>"
-#: ../raster/r.out.mat/main.c:189 ../raster/r.cost/main.c:225
-#: ../raster/r.in.mat/main.c:378 ../raster/r.out.tiff/r.out.tiff.c:145
-#: ../raster/wildfire/r.ros/main.c:304 ../raster/wildfire/r.spread/main.c:248
-#: ../vector/v.kernel/main.c:171 ../display/d.vect/main.c:366
-#: ../display/d.mon/pgms/release.c:37
+#: ../general/g.proj/main.c:138
msgid ""
-"The '-v' flag is superseded and will be removed in future. Please use '--"
-"verbose' instead."
+"Index number of datum transform parameters, \"0\" for unspecified or \"-1\" "
+"to list and exit"
msgstr ""
-"Pøepínaè '-v' byl nahrazen a bude v budoucnosti vyjmut. Prosím pou¾ijte "
-"místo nìjpøepínaè '--verbose'."
+"Èíslo indexu parametrù transformace datumu, \"0\" pro nespecifikováno nebo "
+"\"-1\" pro výpis a ukonèení"
-#: ../raster/r.out.mat/main.c:195
-msgid "Using the Current Region settings:"
-msgstr "Pou¾ívám nastavení aktuálního regionu:"
-#: ../raster/r.out.mat/main.c:196
-#, c-format
-msgid "northern edge=%f"
-msgstr "severní okraj=%f"
-#: ../raster/r.out.mat/main.c:197
-#, c-format
-msgid "southern edge=%f"
-msgstr "Ji¾ní okraj=%f"
-#: ../raster/r.out.mat/main.c:198
-#, c-format
-msgid "eastern edge=%f"
-msgstr "východní okraj=%f"
-#: ../raster/r.out.mat/main.c:199
-#, c-format
-msgid "western edge=%f"
-msgstr "západní hrana=%f"
-#: ../raster/r.out.mat/main.c:200
-#, c-format
-msgid "nsres=%f"
-msgstr "nsres=%f"
-#: ../raster/r.out.mat/main.c:201
-#, c-format
-msgid "ewres=%f"
-msgstr "ewres=%f"
-#: ../raster/r.out.mat/main.c:202
-#, c-format
-msgid "rows=%d"
-msgstr "øádky=%d"
-#: ../raster/r.out.mat/main.c:203
-#, c-format
-msgid "cols=%d"
-msgstr "sloupce=%d"
-#: ../raster/r.out.mat/main.c:269
-msgid "Exporting raster as integer values"
-msgstr "Exportuji rastr jako celoèíselnou mapu"
-#: ../raster/r.out.mat/main.c:274
-msgid "Exporting raster as floating point values"
-msgstr "Exportuji rastr jako mapu s hodnotami s plovoucí desetinnou èárkou"
-#: ../raster/r.out.mat/main.c:279
-msgid "Exporting raster as double FP values"
+#: ../general/g.proj/main.c:145
+msgid ""
+"Force override of datum transformation information in input co-ordinate "
+"system"
msgstr ""
-"Exportuji rastr jako mapu s hodnotami s plovoucí desetinnou èárkou (double)"
+"Vynutit pøepsání informace o datumu transformace ve vstupním souøadém "
+"systému "
-#: ../raster/r.out.mat/main.c:319
-msgid "Reading in map ... "
-msgstr "Ètu v mapì ... "
-#: ../raster/r.out.mat/main.c:331
-msgid "Writing out map..."
-msgstr "Zapisuji výstupní mapu..."
-#: ../raster/r.out.mat/main.c:385
-#, c-format
-msgid "%ld bytes written to '%s'"
-msgstr "%ld bytù zapsáno do '%s'"
-#: ../raster/r.to.rast3elev/main.c:139
-msgid "The number of input and elevation maps is not equal"
-msgstr "Poèet vstupních mapových vrstev a vý¹kových modelù není roven"
-#: ../raster/r.to.rast3elev/main.c:172 ../raster/r.to.rast3/main.c:370
-msgid "Unable to close input map"
-msgstr "Nelze zavøít vstupní mapu"
-#: ../raster/r.to.rast3elev/main.c:184 ../raster/r.to.rast3/main.c:57
-msgid "Could not close the map"
-msgstr "Nemohl jsem uzavøít mapu"
-#: ../raster/r.to.rast3elev/main.c:212
-msgid "The value to fill the upper cells, default is null"
-msgstr "Hodnota, kterou budou vyplnìny svrchní buòky, výchozí je null"
-#: ../raster/r.to.rast3elev/main.c:219
-msgid "The value to fill the lower cells, default is null"
-msgstr "Hodnota, kterou budou vyplnìny spodní buòky, výchozí je null"
-#: ../raster/r.to.rast3elev/main.c:224
-msgid "Use the input map values to fill the upper cells"
-msgstr "Pou¾ij hodnoty mapy pro výplò svrchních bunìk"
-#: ../raster/r.to.rast3elev/main.c:229
-msgid "Use the input map values to fill the lower cells"
-msgstr "Pou¾ij hodnoty mapy pro výplò spodních bunìk"
-#: ../raster/r.to.rast3elev/main.c:277
-msgid "Could not get raster row from input map"
-msgstr "Nelze získat øádek rastru z vstupní vrstvy"
-#: ../raster/r.to.rast3elev/main.c:279
-msgid "Could not get raster row from elev map"
-msgstr "Nelze získat øádek rastru z vý¹kového modelu"
-#: ../raster/r.to.rast3elev/main.c:326 ../raster/r.to.rast3elev/main.c:360
-msgid "Error writing G3D double data"
-msgstr "Chyba pøi zápisu G3D dat s plovoucí desetinnou èárkou"
-#: ../raster/r.to.rast3elev/main.c:400
-msgid "raster, raster3d, voxel, conversion"
-msgstr "rastr, rastr3d, voxel, pøevod"
-#: ../raster/r.to.rast3elev/main.c:403
-msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
+#: ../general/g.proj/main.c:151
+msgid ""
+"Create new projection files (modifies current location unless 'location' "
+"option specified)"
msgstr ""
-"Vytvoøí 3D volume vrstvu zalo¾enou na 2D vý¹kového modelu a hodnotových "
-"rastrových mapách."
+"Vytvoø nové soubory s projekcí (zmìní aktuální location, pokud není zadána "
+"volba 'location')"
-#: ../raster/r.to.rast3elev/main.c:434
-msgid "The upper value is not valid"
-msgstr "Horní hodnota není platná"
+#: ../general/g.proj/main.c:160
+msgid "Name of new location to create"
+msgstr "Název nové location, která má být vytvoøena"
-#: ../raster/r.to.rast3elev/main.c:445
-msgid "The lower value is not valid"
-msgstr "Dolní hodnota není platná"
+#: ../general/g.proj/main.c:165
+msgid "Enable interactive prompting (for command-line use only)"
+msgstr "Povolit interaktivní vyzívání (pouze s pou¾itím pøíkazového øádku)"
-#: ../raster/r.to.rast3elev/main.c:499 ../raster/r.to.rast3/main.c:277
-msgid "Creating 3D raster map"
-msgstr "Vytváøím 3D rastrovou mapu"
-#: ../raster/r.statistics/o_kurt.c:102
-msgid "o_kurto: No data in array"
-msgstr "o_kurto: V mno¾inì ¾ádná data"
-#: ../raster/r.statistics/o_var.c:106 ../raster/r.statistics/o_sdev.c:106
-msgid "o_var: No data in array"
-msgstr "o_var: V mno¾inì ¾ádná data"
-#: ../raster/r.statistics/o_distrib.c:32 ../raster/r.statistics/o_sum.c:34
-#: ../raster/r.statistics/o_average.c:33
+#: ../general/g.proj/main.c:183
#, c-format
-msgid "%s: running %s command"
-msgstr "%s: spou¹tím pøíkaz %s"
+msgid "Only one of '%s', '%s', '%s' or '%s' options may be specified"
+msgstr "Pouze jedna volba z '%s', '%s', '%s' nebo '%s' mù¾e být zadána"
-#: ../raster/r.statistics/main.c:43
-msgid "Calculates category or object oriented statistics."
-msgstr "Poèítá statistky podle kategorií nebo objektovì orientované."
+#: ../general/g.proj/main.c:213
+msgid "Projection files missing"
+msgstr "Soubory s projekcí chybí"
-#: ../raster/r.statistics/main.c:53
-msgid "Method of object-based statistic"
-msgstr "Metoda statistiky zalo¾ené na objektech"
-#: ../raster/r.statistics/main.c:65
-msgid "Resultant raster map (not used with 'distribution')"
-msgstr "Výsledná rastrová mapa (nelze pou¾ít s 'distribution')"
-#: ../raster/r.statistics/main.c:78 ../raster/r.statistics/main.c:84
-msgid "This module currently only works for integer (CELL) maps"
-msgstr "Tento modul zatím pracuje jenom pro mapy typu integer (CELL)"
-#: ../raster/r.statistics/main.c:88 ../raster/r.report/parse.c:274
-#: ../raster/r.support/front/front.c:224 ../raster/r.cats/main.c:148
-#: ../raster/r.cats/main.c:204 ../raster/r.mapcalc/map3.c:195
-#: ../raster/r.mapcalc/map.c:88 ../display/d.title/main.c:111
-#, fuzzy, c-format
-msgid "Unable to read category file of raster map <%s@%s>"
-msgstr "Nelze èíst soubor s kategoriemi rastrové mapy <%s@%s>"
-#: ../raster/r.statistics/main.c:108
+#: ../general/g.proj/output.c:142
#, c-format
-msgid "Output map <%s> ignored"
-msgstr "Výstupní mapa <%s> ignorována"
+msgid "%s: Unable to convert to WKT"
+msgstr "%s: Neschopen pøevést WKT"
-#: ../raster/r.statistics/main.c:175
-msgid "Not yet implemented!"
-msgstr "Zatím nebylo implementováno!"
-#: ../raster/r.statistics/main.c:185
+#: ../general/g.proj/output.c:154
#, c-format
-msgid "An output map needs to be defined with method '%s'"
-msgstr "Výstupní mapa musí být definována metodu '%s'"
+msgid "Location %s created!"
+msgstr "Location %s vytvoøena!"
-#: ../raster/r.statistics/o_skew.c:104
-msgid "o_skew: No data in array"
-msgstr "o_skew: V mno¾inì ¾ádná data"
-#: ../raster/r.statistics/read_stats.c:21 ../raster/r.median/read_stats.c:14
-msgid "Reading r.stats output"
-msgstr "Ètu výstup z r.stats"
-#: ../raster/r.statistics/o_adev.c:105
-msgid "o_adev: No data in array"
-msgstr "o_adev: V mno¾inì ¾ádná data"
-#: ../raster/r.info/main.c:70
-msgid "Output basic information about a raster map layer."
-msgstr "Vypí¹e základní informace o u¾ivatelem vybrané rastrové mapì."
-#: ../raster/r.info/main.c:80
-msgid "Print raster map resolution (NS-res, EW-res) only"
-msgstr "Vytiskni pouze rozli¹ení (NS-roz, EW-roz)"
-#: ../raster/r.info/main.c:84
-msgid "Print raster map type only"
-msgstr "Vytiskni pouze typ rastrové mapy"
-#: ../raster/r.info/main.c:88 ../vector/v.info/main.c:81
-msgid "Print map region only"
-msgstr "Vytiskni pouze region rastrové mapy"
-#: ../raster/r.info/main.c:92
-msgid "Print raster history instead of info"
-msgstr "Vypí¹e historii rastrové mapy namísto infa"
-#: ../raster/r.info/main.c:96
-msgid "Print raster map data units only"
-msgstr "Vytiskni pouze jednotky rastrové mapy"
-#: ../raster/r.info/main.c:100
-msgid "Print raster map vertical datum only"
-msgstr "Vytiskni pouze vertikální datum rastrové mapy"
-#: ../raster/r.info/main.c:104 ../vector/v.info/main.c:85
-msgid "Print map title only"
-msgstr "Vytiskni pouze titulek rastrové mapy"
-#: ../raster/r.info/main.c:109
-msgid "Print raster map timestamp (day.month.year hour:minute:seconds) only"
-msgstr "Vypsat pouze èasovou znaèku (den.mìsíc.rok hodiny:minuty:sekundy)"
-#: ../raster/r.info/main.c:140
-msgid "Unable to read range file"
-msgstr "Nelze èíst soubor s rozsahem"
-#: ../raster/r.compress/main.c:65
-msgid "Compresses and decompresses raster maps."
-msgstr "Komprimuje a dekomprimuje rastrové soubory."
-#: ../raster/r.compress/main.c:73 ../display/d.what.rast/main.c:75
-msgid "Name of existing raster map(s)"
-msgstr "Jméno existující(ch) rastrové(ých) map(y)"
-#: ../raster/r.compress/main.c:77
-msgid "Uncompress the map"
-msgstr "Dekomprimuj mapu"
-#: ../raster/r.compress/main.c:119
+#: ../general/g.proj/output.c:156
#, c-format
-msgid "[%s] not found"
-msgstr "[%s] nenalezen"
+msgid "Unable to create location: %s"
+msgstr "Nelze vytvoøit location: %s"
-#: ../raster/r.compress/main.c:125
+#: ../general/g.proj/output.c:158
#, c-format
-msgid "[%s] is a reclass file of map <%s> in mapset <%s> - can't uncompress"
-msgstr "[%s] je reklasifikací mapy <%s> v mapsetu <%s> - nelze rozbalit"
+msgid "Unable to create projection files: %s"
+msgstr "Nelze vytvoøit soubor s informacemi o mapové projekci: %s"
-#: ../raster/r.compress/main.c:126
-#, c-format
-msgid "[%s] is a reclass file of map <%s> in mapset <%s> - can't compress"
-msgstr "[%s] je reklasifikací mapy <%s> v mapsetu <%s> - nelze komprimovat"
+#: ../general/g.proj/output.c:161
+msgid "Unspecified error while creating new location"
+msgstr "Nejasná chyba pøi vytváøení nové location"
-#: ../raster/r.compress/main.c:171
+#: ../general/g.proj/output.c:173
#, c-format
-msgid "DONE: uncompressed file is %lu bytes smaller"
-msgstr "HOTOVO: komprimovaný soubor je %lu bytù men¹í"
+msgid ""
+"You must select the PERMANENT mapset before updating the current location's "
+"projection. (Current mapset is %s)"
+msgstr ""
+"Musíte vybrat mapset PERMANENT, døíve ne¾ aktualizujete projekci aktuální "
+"location (Aktuální mapset je %s)"
-#: ../raster/r.compress/main.c:172
+#: ../general/g.proj/output.c:187
#, c-format
-msgid "DONE: compressed file is %lu bytes smaller"
-#: ../raster/r.compress/main.c:176
-#, c-format
-msgid "DONE: uncompressed file is %lu bytes bigger"
-msgstr "HOTOVO: rozbalený soubor je %lu bytù vìt¹í"
-#: ../raster/r.compress/main.c:177
-#, c-format
-msgid "DONE: compressed file is %lu bytes bigger"
-msgstr "HOTOVO: komprimovaný soubor je %lu bytù vìt¹í"
-#: ../raster/r.compress/main.c:202
-#, c-format
-msgid "[%s] already uncompressed"
-msgstr "[%s] je ji¾ rozbalena"
-#: ../raster/r.compress/main.c:207
-#, c-format
-msgid "[%s] already compressed"
-msgstr "[%s] je ji¾ komprimována"
-#: ../raster/r.compress/main.c:211
-#, c-format
msgid ""
"\n"
-"%sCOMPRESS [%s]"
+"\n"
+"WARNING! A projection file already exists for this location\n"
msgstr ""
"\n"
-"%sKOMPRIMUJI [%s]"
+"\n"
+"VAROVÁNÍ! V této location ji¾ existuje soubor s projekcí\n"
-#: ../raster/r.patch/main.c:55
-msgid ""
-"Creates a composite raster map layer by using known category values from one "
-"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
-msgstr ""
-"Vytváøí slo¾enou rastrovou mapu tak, ¾e pou¾ije známé hodnoty kategorií z "
-"jedné nebo nìkolika map tak, ¾e vyplní oblasti \"bez ¾ádných dat\" v "
-"jinémapové vrstvì."
+#: ../general/g.proj/output.c:194
+msgid "Would you still like to overwrite the current projection information "
+msgstr "Stále si pøejete pøepsat aktuální informace o projekci"
-#: ../raster/r.patch/main.c:62
-msgid "Name of raster maps to be patched together"
-msgstr "Názvy rastrových map, které mají být spojeny"
+#: ../general/g.proj/output.c:215
+msgid "Error writing PROJ_INFO"
+msgstr "Chyba pøi zápisu PROJ_INFO"
-#: ../raster/r.patch/main.c:65
-#, fuzzy
-msgid "Name for resultant raster map"
-msgstr "Titulek pro výslednou rastrovou mapu"
+#: ../general/g.proj/output.c:222
+msgid "Error writing PROJ_UNITS"
+msgstr "Chyba pøi zápisu PROJ_UNITS"
-#: ../raster/r.patch/main.c:76
-msgid "Use zero (0) for transparency instead of NULL"
-msgstr "Pou¾ij nulu (0) jako transparentní hodnotu, namísto NULLy"
-#: ../raster/r.patch/main.c:102
-#, fuzzy
-msgid "The minimum number of input raster maps is two"
-msgstr "Minimální poèet vstupních map jsou dvì."
-#: ../raster/r.patch/main.c:142
-#, fuzzy
-msgid "One or more input raster maps not found"
-msgstr "Jedna nebo více mapy nebyly nalezeny"
-#: ../raster/r.patch/main.c:155 ../raster/r.series/main.c:196
-msgid "Percent complete..."
-msgstr "Hotových procent..."
-#: ../raster/r.patch/main.c:185
-#, fuzzy, c-format
-msgid "Creating support files for raster map <%s>"
-msgstr "Vytváøím podpùrné soubory pro %s"
-#: ../raster/r.le/r.le.setup/sample.c:939
-msgid "Cannot read vector"
-msgstr "Nelze èíst vektorovou mapu"
-#: ../raster/r.le/r.le.setup/main.c:62
+#: ../general/g.proj/output.c:230
msgid ""
-"Interactive tool used to setup the sampling and analysis framework that will "
-"be used by the other r.le programs."
+"N.B. The default region was updated to the new projection, but if you have "
+"multiple mapsets g.region -d should be run in each to update the region from "
+"the default."
msgstr ""
-"Interkativní nástroj pou¾itý pro nastavení nástroje pro vzorkování a "
-"analýzu, které budou pou¾ity dal¹ími programy r.le."
+"Pozn. Pøednastavený region byl aktualizován pro novou projekci, ale jestli "
+"máte více mapsetù g.region -d by jste mìli spustit v ka¾dém z nich pro "
+"aktualizaci."
-#: ../raster/r.le/r.le.setup/main.c:66
-msgid "Raster map to use to setup sampling"
-msgstr "Rastrová mapa pro nastavení vzorkování"
+#: ../general/g.proj/output.c:234
+msgid "Projection information updated!"
+msgstr "Informace o projekci aktualizovány!"
-#: ../raster/r.le/r.le.setup/main.c:70
-msgid "Vector map to overlay"
-msgstr "Vektorová mapa pro pøekrytí"
+#: ../general/g.proj/output.c:237
+msgid "The projection information will not be updated."
+msgstr "Informace o projekci nebudou aktualizovány."
-#: ../raster/r.le/r.le.pixel/main.c:47
-msgid ""
-"Contains a set of measures for attributes, diversity, texture, "
-"juxtaposition, and edge."
-msgstr ""
-"Obsahuje pouze sadu mìøení atributù, diverzity, textury, sousednost a hrany."
+#: ../general/g.proj/input.c:82
+msgid "Error reading WKT projection description"
+msgstr "Chyba pøi ètení popisu projekce ve formátu WKT"
-#: ../raster/r.le/r.le.trace/main.c:59
-msgid ""
-"Displays the boundary of each r.le patch and shows how the boundary is "
-"traced, displays the attribute, size, perimeter and shape indices for each "
-"patch and saves the data in an output file."
-msgstr ""
-"Zobrazí hranice ka¾dé r.le plo¹ky a uká¾e jak byla hranice trasována, "
-"zobrazí atribut, velikost, obvod, tvar pro ka¾dou plo¹ku a ulo¾í data do "
-"výstupního souboru."
-#: ../raster/r.le/r.le.patch/main.c:49
-msgid ""
-"Calculates attribute, patch size, core (interior) size, shape, fractal "
-"dimension, and perimeter measures for sets of patches in a landscape."
-msgstr ""
-"Poèítá atributy, velikost plo¹ek, hrubou (vnitøní) velikost, tvar, fraktální "
-"dimenzi a obvod pro sadu plo¹ek v krajinì."
-#: ../raster/r.digit/digitize.c:47
-msgid "Quit without creating a map?? "
-msgstr "Skonèit bez vytvoøení mapy?"
-#: ../raster/r.digit/get_label.c:32
+#: ../general/g.proj/input.c:89
#, c-format
-msgid "Enter the category number for this %s: "
-msgstr "Vlo¾te èíslo kategorie pro tento %s:"
+msgid "Unable to open file [%s] for reading"
+msgstr "Nejsem schopen otevøít soubor [%s] pro ètení"
-#: ../raster/r.digit/get_label.c:47
-#, c-format
-msgid "Enter a label for category %ld [%s] "
-msgstr "Vlo¾te popis kategorie %ld [%s] "
+#: ../general/g.proj/input.c:134
+msgid "Can't parse PROJ.4-style parameter string"
+msgstr "Nelze parsovat PROJ.4 styl parametrù"
-#: ../raster/r.digit/get_label.c:69
-msgid "Look ok? "
-msgstr "Vypadá to v pohodì?"
+#: ../general/g.proj/input.c:173
+msgid "Trying to open with OGR..."
+msgstr "Zkou¹ím otevøít pomocí OGR..."
-#: ../raster/r.digit/get_type.c:31
-#, c-format
-msgid "Please choose one of the following\n"
-msgstr "Prosím, vyberte jedenu volbu z nasledujících\n"
+#: ../general/g.proj/input.c:181 ../general/g.proj/input.c:200
+msgid "...succeeded."
+msgstr "...uspìl."
-#: ../raster/r.digit/get_type.c:32
-#, c-format
-msgid " A define an area\n"
-msgstr " A definuj plochu\n"
+#: ../general/g.proj/input.c:194
+msgid "Trying to open with GDAL..."
+msgstr "Zkou¹ím otevøít GDALem..."
-#: ../raster/r.digit/get_type.c:33
+#: ../general/g.proj/input.c:207
#, c-format
-msgid " C define a circle\n"
-msgstr " C definuj kruh\n"
+msgid "Could not read georeferenced file %s using either OGR nor GDAL"
+msgstr "Nelze èíst georeferencovaný soubor %s a» u¾ zkou¹ím GDAL nebo OGR"
-#: ../raster/r.digit/get_type.c:34
+#: ../general/g.proj/input.c:212
#, c-format
-msgid " L define a line\n"
-msgstr " L definuj linii\n"
-#: ../raster/r.digit/get_type.c:35
-#, c-format
-msgid " X exit (and create map)\n"
-msgstr " X ukonèi se (a vytvoø mapu)\n"
-#: ../raster/r.digit/get_type.c:36
-#, c-format
-msgid " Q quit (without creating map)\n"
-msgstr " Q ukonèi se (a nevytváøej mapu)\n"
-#: ../raster/r.digit/main.c:46
msgid ""
-"Interactive tool used to draw and save vector features on a graphics monitor "
-"using a pointing device (mouse) and save to a raster map."
+"Read of file %s was successful, but it did not contain projection "
+"information. 'XY (unprojected)' will be used"
msgstr ""
-"Interaktivní nástroj pro kreslení vektorových prvkù v grafickém monitoru "
-"pomocí polohového zaøízení (my¹i) a jejich ulo¾ení do rastrové mapy."
+"Ètení souboru %s bylo íºspì¹né. ale tento neobsahuje informace o projekci. "
+"Pou¾iji 'XY (unprojected)'"
-#: ../raster/r.digit/main.c:55 ../vector/v.digit/main.c:107
-msgid "Display commands to be used for canvas backdrop (separated by ';')"
-msgstr "Pøíkazy ze skupiny d.* pro vykreslení pozadí (oddìlené ';')"
+#: ../general/g.dirseps/main.c:34
+msgid "Internal GRASS utility for converting directory separator characters."
+msgstr "Vnitøní utilitas GRASSu pro zmìnu znakového oddìlovaèe adresáøù."
-#: ../raster/r.digit/main.c:79
-msgid "No graphics device selected!"
-msgstr "®ádné grafické zaøízení nebylo vybráno"
+#: ../general/g.transform/main.c:238
+msgid "Computes a coordinate transformation based on the control points"
+msgstr "Souøadnicová transformace na základì vlícovacích bodù"
-#: ../raster/r.digit/main.c:98
-msgid "No map created"
-msgstr "Nebyla vytvoøena ¾ádná mapa"
+#: ../general/g.transform/main.c:245 ../imagery/i.rectify/main.c:66
+#: ../imagery/i.ortho.photo/photo.2target/main.c:54
+#: ../imagery/i.group/main.c:56
+msgid "Name of imagery group"
+msgstr "Název obrazové skupiny"
-#: ../raster/r.grow2/main.c:129
-msgid "Generates a raster map layer with contiguous areas grown by one cell."
-msgstr "Vytvoøí rastrovou spojitých oblastí zvìt¹ených o jednu buòku."
+#: ../general/g.transform/main.c:252
+msgid "Rectification polynomial order"
+msgstr "Stupeò polynomu rektifikace"
-#: ../raster/r.grow2/main.c:140
-msgid "Radius of buffer in raster cells"
-msgstr "Polomìr obalové zóny (bufferu) v poètu bunìk"
+#: ../general/g.transform/main.c:261 ../vector/v.out.ascii/out.c:65
+msgid "Output format"
+msgstr "Výstupní formát"
-#: ../raster/r.grow2/main.c:147
-msgid "Metric"
-msgstr "Metrický"
+#: ../general/g.transform/main.c:265
+msgid "Display summary information"
+msgstr "Zobrazit souhrnnou informaci"
-#: ../raster/r.grow2/main.c:155
-msgid "Value to write for input cells which are non-NULL (-1 => NULL)"
-msgstr ""
-"Hodnota, která bude pøiøazena vstupním, nenulovým, buòkám, které jsou ne-"
-"NULLOvé (-1 => NULL)"
+#: ../general/g.region/main.c:81
+msgid "Manages the boundary definitions for the geographic region."
+msgstr "Správuje definice hranic geografického regionu."
-#: ../raster/r.grow2/main.c:161
-msgid "Value to write for \"grown\" cells"
-msgstr "Hodnota, která bude pøiøazena buòkám \"grown\""
+#: ../general/g.region/main.c:88 ../raster/r.region/main.c:69
+msgid "Set from default region"
+msgstr "Nastav z výchozího regionu"
-#: ../raster/r.grow2/main.c:197
-#, c-format
-msgid "Unknown metric: [%s]."
-msgstr "Neznámá metrika: [%s]."
+#: ../general/g.region/main.c:89 ../general/g.region/main.c:94
+#: ../general/g.region/main.c:158 ../general/g.region/main.c:165
+#: ../general/g.region/main.c:173 ../general/g.region/main.c:180
+#: ../general/g.region/main.c:190
+msgid "Existing"
+msgstr "Existuje"
-#: ../raster/r.grow2/main.c:217
-#, c-format
-msgid "Error in reading color file for <%s>"
-msgstr "Chyba pøi ètení souboru color pro <%s>"
+#: ../general/g.region/main.c:93
+msgid "Save as default region"
+msgstr "Nastav jako výchozí region"
-#: ../raster/r.grow2/main.c:309
-#, c-format
-msgid "Error writing category file for <%s>"
-msgstr "Chyba pøi zápisu souboru kategorií pro <%s>"
+#: ../general/g.region/main.c:98
+msgid "Print the current region"
+msgstr "Vypi¹ aktuální region"
-#: ../raster/r.grow2/main.c:313
-#, c-format
-msgid "Error writing color file for <%s>"
-msgstr "Chyba pøi zápisu souboru color pro <%s>"
+#: ../general/g.region/main.c:99 ../general/g.region/main.c:105
+#: ../general/g.region/main.c:110 ../general/g.region/main.c:115
+#: ../general/g.region/main.c:120 ../general/g.region/main.c:125
+#: ../general/g.region/main.c:130 ../general/g.region/main.c:135
+#: ../vector/v.to.db/parse.c:90 ../vector/v.to.db/parse.c:95
+#: ../vector/v.to.db/parse.c:100 ../raster/r.out.gdal/main.c:380
+#: ../raster/r.in.gdal/main.c:132 ../imagery/i.group/main.c:75
+#: ../imagery/i.group/main.c:80
+msgid "Print"
+msgstr "Tisk"
-#: ../raster/r.circle/dist.c:54
-msgid "Creates a raster map containing concentric rings around a given point."
-msgstr "Vytvoøí rastrovou mapu obsahující centrické kruhy okolo zadaného bodu."
+#: ../general/g.region/main.c:103
+msgid "Print the current region in lat/long using the current ellipsoid/datum"
+msgstr ""
+"Vypi¹ aktuální region v zem. délce/¹íøce s pou¾itím souèasného ellipsoidu/"
+"datumu"
-#: ../raster/r.circle/dist.c:64
-msgid "The coordinate of the center (east,north)"
-msgstr "Souøadnice støedu (východ, sever)"
+#: ../general/g.region/main.c:109
+msgid "Print the current region extent"
+msgstr "Vypi¹ rozsah aktuálního regionu"
-#: ../raster/r.circle/dist.c:70
-msgid "Minimum radius for ring/circle map (in meters)"
-msgstr "Minimální polomìr pro mapu kruhu (v metrech)"
+#: ../general/g.region/main.c:114
+msgid "Print the current region map center coordinates"
+msgstr "Vypi¹ mapové souøadnice støedu aktuálního regionu"
-#: ../raster/r.circle/dist.c:76
-msgid "Maximum radius for ring/circle map (in meters)"
-msgstr "Maximální polomìr kruhu (v metrech)"
+#: ../general/g.region/main.c:119
+msgid "Print region resolution in meters (geodesic)"
+msgstr "Vypi¹ rozli¹ení regionu v metrech (geodetické)"
-#: ../raster/r.circle/dist.c:82
-msgid "Data value multiplier"
-msgstr ""
+#: ../general/g.region/main.c:124
+msgid "Print also 3D settings"
+msgstr "Vypi¹ také 3D nastavení"
-#: ../raster/r.circle/dist.c:86
-msgid "Generate binary raster map"
-msgstr "Generuji rastrovou mapu"
+#: ../general/g.region/main.c:129
+msgid "Print the maximum bounding box in lat/long on WGS84"
+msgstr "Zobrazí hranièní souøadnice v lat/long na WGS84 "
-#: ../raster/r.circle/dist.c:109
-msgid "Please specify a radius in which min < max"
-msgstr "Prosím, zadejte polomìr, kde min < max"
-#: ../raster/r.circle/dist.c:116
-msgid "Please specify min and/or max radius when using the binary flag"
+#: ../general/g.region/main.c:139
+msgid ""
+"Align region to resolution (default = align to bounds, works only for 2D "
+"resolution)"
msgstr ""
-"Prosím zadejte minimální a/nebo maximální polomìr, kdy¾ pou¾íváte pøepínaè "
-"pro vytvoøení binární rastrové mapy"
+"Vyrovná region na rozli¹ení (výchozí = vyrovnat na hranice, funguje pouze "
+"pro 2D rozli¹ení)"
-#: ../raster/r.surf.idw/main.c:70
-msgid "Surface interpolation utility for raster map layers."
-msgstr "Nástroj pro interpolaci povrchù rastrových map."
+#: ../general/g.region/main.c:141 ../general/g.region/main.c:200
+#: ../general/g.region/main.c:210 ../general/g.region/main.c:220
+#: ../general/g.region/main.c:230 ../general/g.region/main.c:239
+#: ../general/g.region/main.c:248 ../general/g.region/main.c:324
+#: ../general/g.region/main.c:335 ../raster/r.in.bin/main.c:143
+#: ../raster/r.in.bin/main.c:175 ../raster/r.in.bin/main.c:183
+#: ../raster/r.in.bin/main.c:191 ../raster/r.in.bin/main.c:199
+#: ../raster/r.in.bin/main.c:206 ../raster/r.in.bin/main.c:213
+msgid "Bounds"
+msgstr "Hranice"
-#: ../raster/r.surf.idw/main.c:85
-msgid "Output is the interpolation error"
-msgstr "Výstup je chyba interpolace"
+#: ../general/g.region/main.c:145
+msgid "Do not update the current region"
+msgstr "Neaktualizuj aktuální region"
-#: ../raster/r.surf.idw/main.c:91
-#, c-format
-msgid "%s=%s - illegal value"
-msgstr "%s=%s - neplatná hodnota"
+#: ../general/g.region/main.c:146 ../general/g.region/main.c:346
+#: ../vector/v.label/main.c:91 ../vector/v.label/main.c:96
+#: ../vector/v.label/main.c:170 ../vector/v.label/main.c:183
+msgid "Effects"
+msgstr "Efekty"
-#: ../raster/r.surf.idw/main.c:103
-msgid "Unable to read current region parameters"
-msgstr "Nelze naèíst parametry souèasného regionu"
+#: ../general/g.region/main.c:156
+msgid "Set current region from named region"
+msgstr "Nastaví aktuální region z pojmenovaného regionu"
-#: ../raster/r.surf.idw/main.c:240 ../raster/r.surf.idw/main.c:688
-msgid "Cannot read row"
-msgstr "Nelze naèíst øádek"
+#: ../general/g.region/main.c:164 ../raster/r.region/main.c:96
+msgid "Set region to match this raster map"
+msgstr "Nastav region tak, aby odpovídal této rastrové mapì"
-#: ../raster/r.thin/main.c:56
-msgid "Thins non-zero cells that denote linear features in a raster map layer."
-msgstr "Zmen¹í nenulové buòky tak, aby vznikly lineární struktury."
+#: ../general/g.region/main.c:171
+msgid "Set region to match this 3D raster map (both 2D and 3D values)"
+msgstr ""
+"Nastav region tak, aby odpovídal této 3D rastrové mapì (obì 2D a 3D hodnoty)"
-#: ../raster/r.thin/main.c:68
-msgid "Maximal number of iterations"
-msgstr "Maximální poèet iterací"
+#: ../general/g.region/main.c:179 ../raster/r.region/main.c:104
+msgid "Set region to match this vector map"
+msgstr "Nastav region tak, aby odpovídal této vektorové mapì"
-#: ../raster/r.thin/io.c:107
-#, c-format
-msgid "File %s -- %d rows X %d columns"
-msgstr "Soubor %s -- %d øádkù X %d sloupcù"
+#: ../general/g.region/main.c:188 ../raster/r.region/main.c:112
+msgid "Set region to match this 3dview file"
+msgstr "Nastav region tak, aby odpovídal souboru 3dview"
-#: ../raster/r.thin/io.c:118
-#, c-format
-msgid "%s: Unable to create temporary file <%s> -- errno = %d"
-msgstr "%s: Nelze vytvoøit doèasný soubor <%s> -- errno = %d"
+#: ../general/g.region/main.c:198 ../raster/r.region/main.c:120
+msgid "Value for the northern edge"
+msgstr "Severní okraj"
-#: ../raster/r.thin/io.c:129 ../raster/r.thin/io.c:143
-#: ../raster/r.thin/io.c:155
-#, c-format
-msgid "%s: Error writing temporary file"
-msgstr "%s: Chyba pøi zapisování do doèasného souboru"
+#: ../general/g.region/main.c:208 ../raster/r.region/main.c:128
+msgid "Value for the southern edge"
+msgstr "Ji¾ní okraj"
-#: ../raster/r.thin/io.c:137
-#, c-format
-msgid "%s: Error reading from raster map <%s> in mapset <%s>"
-msgstr "%s: Chyba pøi ètení z rastrové mapy <%s> v mapsetu <%s>"
+#: ../general/g.region/main.c:218 ../raster/r.region/main.c:136
+msgid "Value for the eastern edge"
+msgstr "Východní okraj"
-#: ../raster/r.thin/io.c:181
-#, c-format
-msgid "Output file %d rows X %d columns"
-msgstr "Výstupní soubor %d øádkù X %d sloupcù"
+#: ../general/g.region/main.c:228 ../raster/r.region/main.c:144
+msgid "Value for the western edge"
+msgstr "Západní okraj"
-#: ../raster/r.thin/io.c:182
-#, c-format
-msgid "Window %d rows X %d columns"
-msgstr "Výøez %d øádkù X %d sloupcù"
+#: ../general/g.region/main.c:238
+msgid "Value for the top edge"
+msgstr "Horní okraj"
-#: ../raster/r.thin/thin_lines.c:71
-#, c-format
-msgid "%s: Unable to find bounding box for lines"
-msgstr "%s: Nelze nalézt bounding box pro linie"
+#: ../general/g.region/main.c:247
+msgid "Value for the bottom edge"
+msgstr "Spodní okraj"
-#: ../raster/r.thin/thin_lines.c:73
-#, c-format
-msgid "Bounding box: l = %d, r = %d, t = %d, b = %d"
-msgstr "Bounding box: l = %d, r = %d, t = %d, b = %d"
+#: ../general/g.region/main.c:256
+msgid "Number of rows in the new region"
+msgstr "Poèet øádkù v novém regionu"
-#: ../raster/r.thin/thin_lines.c:121
-#, c-format
-msgid "Pass number %d"
-msgstr "Prùchod èíslo %d"
+#: ../general/g.region/main.c:257 ../general/g.region/main.c:266
+#: ../general/g.region/main.c:275 ../general/g.region/main.c:284
+#: ../general/g.region/main.c:294 ../general/g.region/main.c:304
+#: ../general/g.region/main.c:313
+msgid "Resolution"
+msgstr "Rozli¹ení"
-#: ../raster/r.thin/thin_lines.c:172
-#, c-format
-msgid "Deleted %d pixels "
-msgstr "%d pixelù smazáno "
+#: ../general/g.region/main.c:265
+msgid "Number of columns in the new region"
+msgstr "Poèet sloupcù v novém regionu"
-#: ../raster/r.thin/thin_lines.c:176
-msgid "Thinning completed successfully."
-msgstr "Ztenèování bylo íºspì¹nì dokonèeno."
+#: ../general/g.region/main.c:274
+msgid "Grid resolution 2D (both north-south and east-west)"
+msgstr "2D rozli¹ení (obì severo-ji¾ní a východnì-západní)"
-#: ../raster/r.thin/thin_lines.c:178
-msgid "Thinning not completed, consider to increase 'iterations' parameter."
-msgstr "Ztenèení nedokonèeno, zkuste zvý¹it parametr 'iterations'."
+#: ../general/g.region/main.c:283
+msgid "3D grid resolution (north-south, east-west and top-bottom)"
+msgstr "3D rozli¹ení (severo-ji¾ní, východo-západní a horní-spodní)"
-#: ../raster/r.li/r.li.mpa/mpa.c:38
-msgid "Calculates mean pixel attribute index on a raster map"
-msgstr "Poèítám index støední hodnoty atributu pixelu rastrové mapy"
+#: ../general/g.region/main.c:292
+msgid "North-south grid resolution 2D"
+msgstr "Severo-ji¾ní 2D rozli¹ení"
-#: ../raster/r.li/r.li.mpa/mpa.c:39 ../raster/r.li/r.li.patchnum/main.c:31
-#: ../raster/r.li/r.li.padrange/padrange.c:38
-#: ../raster/r.li/r.li.cwed/cwed.c:43 ../raster/r.li/r.li.padsd/padsd.c:36
-#: ../raster/r.li/r.li.padcv/padcv.c:36
-#: ../raster/r.li/r.li.patchdensity/main.c:30 ../raster/r.li/r.li.mps/mps.c:40
-#: ../raster/r.li/r.li.shape/main.c:32
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:38
-msgid "raster, landscape structure analysis, patch index"
-msgstr "rastr, analýza krajiny, index místa"
+#: ../general/g.region/main.c:302
+msgid "East-west grid resolution 2D"
+msgstr "HVýchodo-západní 2D rozli¹ení"
-#: ../raster/r.li/r.li.mpa/mpa.c:46 ../raster/r.li/r.li.richness/richness.c:47
-#: ../raster/r.li/r.li.patchnum/main.c:39
-#: ../raster/r.li/r.li.padrange/padrange.c:44
-#: ../raster/r.li/r.li.cwed/cwed.c:51 ../raster/r.li/r.li.simpson/simpson.c:47
-#: ../raster/r.li/r.li.padsd/padsd.c:42 ../raster/r.li/r.li.padcv/padcv.c:42
-#: ../raster/r.li/r.li.dominance/dominance.c:49
-#: ../raster/r.li/r.li.patchdensity/main.c:38 ../raster/r.li/r.li.mps/mps.c:47
-#: ../raster/r.li/r.li.shape/main.c:40
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:46
-#: ../raster/r.li/r.li.shannon/shannon.c:46
-msgid "Configuration file"
-msgstr "Neplatný konfiguraèní soubor"
+#: ../general/g.region/main.c:312
+msgid "Top-bottom grid resolution 3D"
+msgstr "Horní-spodní 3D rozli¹ení"
-#: ../raster/r.li/r.li.richness/richness.c:38
-#: ../raster/r.li/r.li.dominance/dominance.c:40
-msgid "Calculates dominance's diversity index on a raster map"
-msgstr "Poèítám index diversity dominance rastrové mapy"
-#: ../raster/r.li/r.li.richness/richness.c:39
-msgid "raster, landscape structure analysis, dominance index"
-msgstr "rastr, analýza krajiny, index vlivu"
-#: ../raster/r.li/r.li.patchnum/main.c:30
-msgid ""
-"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+#: ../general/g.region/main.c:322
+msgid "Shrink region until it meets non-NULL data from this raster map"
msgstr ""
-"Poèítá index poètu plo¹ek na rastrové mapì za pou¾ití altoritmu 4 sousedù."
+"Nastavit region tak, aby ze zadané rastrové mapy nebyly vidìt ¾ádné NULLové "
+"hodnoty"
-#: ../raster/r.li/r.li.padrange/padrange.c:37
-msgid "Calculates range of patch area size on a raster map"
-msgstr "Poèítá rozsah velikosti plo¹ek na v rastrové mapì"
+#: ../general/g.region/main.c:333
+msgid "Adjust region cells to cleanly align with this raster map"
+msgstr "Nastavit region tak, aby odpovídal této rastrové mapì"
-#: ../raster/r.li/r.li.cwed/cwed.c:42
-msgid "Calculates contrast weighted edge density index on a raster map"
-msgstr "Poèítej podle kontrastu vá¾ený index hustoty hran"
+#: ../general/g.region/main.c:344
+msgid "Save current region settings in named region file"
+msgstr "Ulo¾it aktuální region jako region se jménem"
-#: ../raster/r.li/r.li.simpson/simpson.c:38
-msgid "Calculates Simpson's diversity index on a raster map"
-msgstr "Spoèítá Simpsonùv index diversity index rastrové mapy"
-#: ../raster/r.li/r.li.simpson/simpson.c:39
-#: ../raster/r.li/r.li.dominance/dominance.c:41
-#: ../raster/r.li/r.li.shannon/shannon.c:38
-msgid "raster, landscape structure analysis, diversity index"
-msgstr "rastr, analýza krajiny, index diverzity"
-#: ../raster/r.li/r.li.padsd/padsd.c:35
-msgid "Calculates standard deviation of patch area a raster map"
-msgstr "Poèítá standardní odchylku plo¹ek rastrové mapy"
-#: ../raster/r.li/r.li.padcv/padcv.c:35
-msgid "Calculates coefficient of variation of patch area on a raster map"
-msgstr "Poèítám koeficient variance plo¹ky v rastrové mapì"
-#: ../raster/r.li/r.li.patchdensity/main.c:29
-msgid ""
-"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
-msgstr ""
-"Poèítá index hustoty plo¹ek na rastrové mapì za pou¾ití algoritmu 4 sousedù"
-#: ../raster/r.li/r.li.mps/mps.c:39
-msgid ""
-"Calculates mean patch size index on a raster map, using a 4 neighbour "
-"algorithm"
-msgstr ""
-"Poèítá prùmìrný index velikosti plo¹ek rastrové mapy za pou¾ití algoritmu 4 "
-"sousedù."
-#: ../raster/r.li/r.li.shape/main.c:31
-msgid "Calculates shape index on a raster map"
-msgstr "Poèítám index tvaru rastrové mapy"
-#: ../raster/r.li/r.li.daemon/daemon.c:72
-msgid "Error in pipe creation"
-msgstr "Chyba pøi vytváøení roury"
-#: ../raster/r.li/r.li.daemon/daemon.c:80
+#: ../general/g.region/main.c:397 ../raster/r.region/main.c:177
#, c-format
-msgid "Error opening channel %i"
-msgstr "Chyba pøi otevírání kanálu %i"
+msgid "Region <%s> not found"
+msgstr "Region <%s> nebyl nalezen"
-#: ../raster/r.li/r.li.daemon/daemon.c:118
-msgid "Cannot create random access file"
-msgstr "Nelze vytvoøit soubor náhodného pøístupu"
-#: ../raster/r.li/r.li.daemon/daemon.c:126
+#: ../general/g.region/main.c:399 ../raster/r.region/main.c:179
#, c-format
-msgid "Cannot create %s/.r.li/ directory"
-msgstr "Nelze vytvoøit adresáø %s/r.li/"
+msgid "Unable to read region <%s> in <%s>"
+msgstr "Nelze èíst region <%s> v <%s>"
-#: ../raster/r.li/r.li.daemon/daemon.c:130
+#: ../general/g.region/main.c:411 ../raster/r.region/main.c:190
#, c-format
-msgid "Cannot create %s/.r.li/output/ directory"
-msgstr "Nelze vytvoøit adresáø %s/r.li/output/"
+msgid "3dview file <%s> not found"
+msgstr "soubor 3dview <%s> nebyl nalezen"
-#: ../raster/r.li/r.li.daemon/daemon.c:219
-#: ../raster/r.li/r.li.daemon/daemon.c:239
+#: ../general/g.region/main.c:416 ../raster/r.region/main.c:196
#, c-format
-msgid "r.li.worker (pid %i) exited with abnormal status %i"
-msgstr "r.li.worker (pid %i) byl ukonèen s abnormálním statusem %i"
+msgid "Unable to open 3dview file <%s> in <%s>"
+msgstr "Nelze otevøít soubor 3dview <%s> v <%s>"
-#: ../raster/r.li/r.li.daemon/daemon.c:222
-#: ../raster/r.li/r.li.daemon/daemon.c:242
+#: ../general/g.region/main.c:421 ../raster/r.region/main.c:200
#, c-format
-msgid "r.li.worker (pid %i) terminated"
-msgstr "r.li.worker (pid %i) ukonèen"
+msgid "Unable to read 3dview file <%s> in <%s>"
+msgstr "Nelze èíst soubor 3dview <%s> v <%s>"
-#: ../raster/r.li/r.li.daemon/daemon.c:226
+#: ../general/g.region/main.c:423 ../raster/r.region/main.c:202
#, c-format
-msgid "Cannot close %s file (PIPE)"
-msgstr "Nelze uzavøít %s soubor (ROURA)"
+msgid "Old 3dview file. Region <%s> not found in <%s>"
+msgstr "Starý soubor 3dview. Region <%s> nebyl nalezen <%s>"
-#: ../raster/r.li/r.li.daemon/daemon.c:228
+#: ../general/g.region/main.c:453 ../general/g.region/main.c:826
+#: ../display/d.title/main.c:108 ../raster/r.region/main.c:163
+#: ../raster/r.region/main.c:220 ../raster/r.region/main.c:355
#, c-format
-msgid "Cannot delete %s file (PIPE)"
-msgstr "Nelze smazat %s soubor (ROURA)"
+msgid "Unable to read header of raster map <%s@%s>"
+msgstr "Nelze èíst hlavièku rastrové mapy <%s@%s> "
-#: ../raster/r.li/r.li.daemon/daemon.c:245
+#: ../general/g.region/main.c:479
#, c-format
-msgid "Cannot close %s file (PIPE2)"
-msgstr "Nemohou zavøít %s soubor (ROURA2)"
+msgid "3D raster map <%s> not found"
+msgstr "3D rastrová mapa <%s> nebyla nalezena"
-#: ../raster/r.li/r.li.daemon/daemon.c:247
+#: ../general/g.region/main.c:482
#, c-format
-msgid "Cannot delete %s file (PIPE2)"
-msgstr "Nelze smazat %s soubor (ROURA2)"
+msgid "Unable to read header of 3D raster map <%s@%s>"
+msgstr "Nelze èíst hlavièku 3D rastrové mapy <%s@%s> "
-#: ../raster/r.li/r.li.daemon/daemon.c:266
-msgid "Cannot close receive channel file"
-msgstr "Nelze ukonèit soubor s pøíjmovým kanálem"
-#: ../raster/r.li/r.li.daemon/daemon.c:268
+#: ../general/g.region/main.c:520 ../display/d.what.vect/main.c:149
+#: ../display/d.path/main.c:192 ../display/d.vect/main.c:459
+#: ../display/d.extend/main.c:103 ../display/d.vect.chart/main.c:234
+#: ../display/d.thematic.area/main.c:187 ../display/d.extract/main.c:96
+#: ../display/d.zoom/main.c:259 ../doc/vector/v.example/main.c:61
+#: ../vector/v.net.salesman/main.c:158 ../vector/v.segment/main.c:95
+#: ../vector/v.what.rast/main.c:116 ../vector/v.normal/main.c:128
+#: ../vector/v.label.sa/labels.c:56 ../vector/v.to.points/main.c:228
+#: ../vector/v.transform/main.c:228 ../vector/v.db.select/main.c:91
+#: ../vector/v.sample/main.c:151 ../vector/v.reclass/main.c:99
+#: ../vector/v.surf.rst/main.c:513
+#: ../vector/lidar/v.lidar.edgedetection/main.c:164
+#: ../vector/lidar/v.lidar.correction/main.c:138
+#: ../vector/lidar/v.outlier/main.c:143
+#: ../vector/lidar/v.surf.bspline/main.c:224
+#: ../vector/lidar/v.surf.bspline/main.c:241
+#: ../vector/lidar/v.lidar.growing/main.c:119 ../vector/v.perturb/main.c:153
+#: ../vector/v.qcount/main.c:126 ../vector/v.net.iso/main.c:174
+#: ../vector/v.type/main.c:204 ../vector/v.univar/main.c:109
+#: ../vector/v.kernel/main.c:192 ../vector/v.buffer/main.c:353
+#: ../vector/v.overlay/main.c:184 ../vector/v.out.dxf/main.c:67
+#: ../vector/v.edit1/cmd/main.c:124 ../vector/v.convert/old2new.c:27
+#: ../vector/v.clean/main.c:226 ../vector/v.generalize/main.c:300
+#: ../vector/v.build.polylines/main.c:136 ../vector/v.voronoi/dt_main.c:75
+#: ../vector/v.voronoi/vo_main.c:145 ../vector/v.label/main.c:265
+#: ../vector/v.lrs/v.lrs.where/main.c:123
+#: ../vector/v.lrs/v.lrs.where/main.c:131
+#: ../vector/v.lrs/v.lrs.label/main.c:272
+#: ../vector/v.lrs/v.lrs.create/main.c:236
+#: ../vector/v.lrs/v.lrs.create/main.c:244
+#: ../vector/v.lrs/v.lrs.segment/main.c:135 ../vector/v.hull0/main.c:288
+#: ../vector/v.db.connect/main.c:113 ../vector/v.select/main.c:180
+#: ../vector/v.drape/main.c:138 ../vector/v.net.path/main.c:126
+#: ../vector/v.edit/main.c:138 ../vector/v.kcv/main.c:132
+#: ../vector/v.extrude/main.c:143 ../vector/v.out.ogr/main.c:202
+#: ../vector/v.to.rast/vect2rast.c:37 ../vector/v.what/main.c:142
+#: ../vector/v.net.alloc/main.c:130 ../vector/v.distance/main.c:283
+#: ../vector/v.net/main.c:139 ../vector/v.net/main.c:153
+#: ../vector/v.hull/main.c:295 ../vector/v.class/main.c:95
+#: ../vector/v.out.pov/main.c:93 ../vector/v.net.steiner/main.c:394
+#: ../vector/v.out.svg/main.c:124 ../vector/v.info/main.c:96
+#: ../vector/v.extract/main.c:139 ../vector/v.to.db/parse.c:112
+#: ../raster/r.region/main.c:230 ../raster/r.drain/main.c:215
+#: ../raster/r.carve/main.c:167 ../raster/r.cost/main.c:298
#, c-format
-msgid "Cannot delete %s file"
-msgstr "Nelze smazat %s soubor"
+msgid "Vector map <%s> not found"
+msgstr "Vektorová mapa <%s> nebyla nalezena"
-#: ../raster/r.li/r.li.daemon/daemon.c:284
+#: ../general/g.region/main.c:526
#, c-format
-msgid "Cannot make stat of %s configuration file"
-msgstr "Nelze vytvoøit statistiku pro konfiguraèní soubor %s"
+msgid "Unable to open vector map <%s@%s>"
+msgstr "Nelze otevøít vektorovou mapu <%s@%s>"
-#: ../raster/r.li/r.li.daemon/daemon.c:289
-#: ../raster/r.li/r.li.daemon/daemon.c:292
-msgid "Cannot read setup file"
-msgstr "Nelze èíst soubor s nastavením"
-#: ../raster/r.li/r.li.daemon/daemon.c:297
-msgid "Illegal configuration file"
-#: ../raster/r.li/r.li.daemon/daemon.c:306
-msgid "Cannot read raster header file"
-msgstr "Nelze èíst hlavièku rastrového souboru"
-#: ../raster/r.li/r.li.daemon/daemon.c:438
-msgid "Irregular maskedoverlay areas definition"
-msgstr "Nepravidelná definice pøekryvných maskovacích ploch"
-#: ../raster/r.li/r.li.daemon/daemon.c:441
+#: ../general/g.region/main.c:829
#, c-format
-msgid "The configuration file can be used only with \t\t\t%s rasterfile"
-msgstr ""
-"Konfiguraèní soubor mù¾e být pou¾it pouze s \t\t\t%s rastrovým souborem"
+msgid "Raster map <%s@%s>: %s"
+msgstr "rastrová mapa <%s@%s>: %s"
-#: ../raster/r.li/r.li.daemon/daemon.c:448
-msgid "Illegal configuration file (sample area)"
-msgstr "Neplatný konfiguraèní soubor (vzorková plocha)"
-#: ../raster/r.li/r.li.daemon/daemon.c:479
-msgid "Too many units to place"
-msgstr "Pøíli¹ mnoho jednotek k umístìní"
-#: ../raster/r.li/r.li.daemon/daemon.c:542
-msgid "Too many strats for raster map"
-msgstr "Pøíli¹ mnoho strats pro rastrovou mapu"
-#: ../raster/r.li/r.li.daemon/daemon.c:574
-msgid "Illegal areas disposition"
-msgstr "Nesprávné dispozice ploch"
-#: ../raster/r.li/r.li.daemon/daemon.c:629
-msgid "Cannot make lseek"
-msgstr "Nelze provést lseek"
-#: ../raster/r.li/r.li.daemon/worker.c:63
+#: ../general/g.region/main.c:836
#, c-format
-msgid "CHILD[pid = %i] cannot open raster map"
-msgstr "DCERA[pid = %i] nemohu rastrovou mapu"
+msgid "<%s> is an illegal region name"
+msgstr "<%s> je neplatný název regionu"
-#: ../raster/r.li/r.li.daemon/worker.c:100
-#: ../raster/r.li/r.li.daemon/worker.c:107
+#: ../general/g.region/main.c:840
#, c-format
-msgid "CHILD[pid = %i] cannot open receive channel"
-msgstr "DCEØINÝ PROCES [pid = %i] nelze otevøít vstupní kanál"
+msgid "Unable to set region <%s>"
+msgstr "Nelze nastavit region <%s>"
-#: ../raster/r.li/r.li.daemon/worker.c:137
-#: ../raster/r.li/r.li.daemon/worker.c:146
-#, c-format
-msgid "CHILD[pid = %i]: unable to open %s mask ... continue without!!!"
-msgstr ""
-"DCEØINÝ PROCES[pid = %i]: nelze otevøít soubor s maskou %s ... pokraèuji bez "
-"ní!"
+#: ../general/g.region/main.c:847
+msgid "Unable to update current region"
+msgstr "Neschopen aktualizovat aktuální region"
-#: ../raster/r.li/r.li.daemon/ipc.c:43
-#, c-format
-msgid ""
-"\t\t\t\tAREA MESSAGE: \n"
-" \t\t\t\taid = %i \n"
-" \t\t\t\tx = %i \n"
-" \t\t\t\ty = %i \n"
-" \t\t\t\trl = %i \n"
-" \t\t\t\tcl = %i \n"
-msgstr ""
-"\t\t\t\tZPRÁVA O PLOCHÁCH: \n"
+#: ../general/g.region/main.c:855
+msgid "Unable to change default region. The current mapset is not <PERMANENT>."
+msgstr "nelze zmìnit základní region. Souèasný mapset není <PERMANENT>."
-#: ../raster/r.li/r.li.daemon/ipc.c:52
+#: ../general/g.region/main.c:872
#, c-format
-msgid ""
-" \t\t\t\tMASKEDAREA MESSAGE: \n"
-" \t\t\t\tmask = %s \n"
-msgstr ""
-" \t\t\t\tZPRÁVA O VYMASKOVANÉCH PLOCHÁCH \n"
+msgid "Invalid input <%s=%s>"
+msgstr "Neplatný vstup <%s=%s>"
-#: ../raster/r.li/r.li.daemon/ipc.c:63
-#, c-format
-msgid ""
-" \t\t\t\tDONE MESSAGE: \n"
-" \t\t\t\tpid = %i \n"
-" \t\t\t\tresult = %f \n"
-msgstr ""
-" \t\t\t\tKONEÈNÁ ZPRÁVA: \n"
-"\t\t\t\tvýsledek = %f \n"
+#: ../general/g.region/main.c:889
+msgid "format"
+msgstr "Formát"
-#: ../raster/r.li/r.li.daemon/ipc.c:70
+#: ../general/g.region/zoom.c:23
#, c-format
-msgid ""
-" \t\t\t\tERROR MESSAGE: \n"
-msgstr ""
-" \t\t\t\tZPRÁVA O CHYBÁCH: \n"
+msgid "Unable to open raster map <%s> in <%s>"
+msgstr "Nelze otevøít rastrovou mapu <%s> v <%s>"
-#: ../raster/r.li/r.li.daemon/ipc.c:76
+#: ../general/g.region/zoom.c:36
#, c-format
-msgid ""
-" \t\t\t\tTERM MESSAGE: \n"
-msgstr ""
-" \t\t\t\tZPRÁVA O UKONÈENÍ: \n"
+msgid "Could not read from <%s>"
+msgstr "Nelze èíst z <%s>"
-#: ../raster/r.li/r.li.daemon/main.c:37
-msgid "Calculates <simple> index on a raster map"
-msgstr "Spoèítá <simple> index rastrové mapy"
+#: ../general/g.region/printwindow.c:244 ../general/g.region/printwindow.c:494
+#: ../display/d.where/main.c:89
+msgid "Can't get projection info of current location"
+msgstr "Nelze získat info mapové projekce aktuální location"
-#: ../raster/r.li/r.li.daemon/main.c:38
-msgid "raster, landscape structure analysis, job launcher"
-msgstr "rastr, analýza krajiny, dosa¾itelnost práce"
+#: ../general/g.region/printwindow.c:248 ../general/g.region/printwindow.c:498
+#: ../display/d.where/main.c:92 ../raster/r.sun/main.c:488
+msgid "Can't get projection units of current location"
+msgstr "Nelze získat jednotky mapové projekce aktuální location"
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:37
-msgid ""
-"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
-msgstr "Poèítá index hustoty hran rastrové mapy za pou¾ití algoritmu 4 sousedù"
+#: ../general/g.region/printwindow.c:252 ../general/g.region/printwindow.c:502
+#: ../display/d.grid/plot.c:298 ../display/d.where/main.c:95
+#: ../ps/ps.map/do_geogrid.c:268 ../raster/r.sun/main.c:492
+msgid "Can't get projection key values of current location"
+msgstr "Nelze získat klíèové hodnoty mapové projekce aktuální location"
-#: ../raster/r.li/r.li.shannon/shannon.c:37
-msgid "Calculates Shannon's diversity index on a raster map"
-msgstr "Poèítám Shannonùv index diversity rastrové mapy"
+#: ../general/g.region/printwindow.c:263 ../general/g.region/printwindow.c:523
+msgid "Unable to update lat/long projection parameters"
+msgstr "Nelze nastavit parametry mapové projekce lat/long"
-#: ../raster/r.flow/mem.c:41
-#, c-format
-msgid "Unable to write segment file for %s"
-msgstr "Nelze vytvoøit soubor segmentù pro %s"
+#: ../general/g.region/printwindow.c:282 ../general/g.region/printwindow.c:291
+#: ../general/g.region/printwindow.c:300 ../general/g.region/printwindow.c:309
+#: ../general/g.region/printwindow.c:553 ../general/g.region/printwindow.c:562
+#: ../general/g.region/printwindow.c:571 ../general/g.region/printwindow.c:580
+msgid "Error in pj_do_proj (projection of input coordinate pair)"
+msgstr "Chyba v pj_do_proj (projekce vstupního páru souøadnic)"
-#: ../raster/r.flow/calc.c:316
-msgid "Calculating maps ..."
-msgstr "Poèítám mapy ..."
+#: ../general/g.region/printwindow.c:406
+msgid "You are already in lat/long. Use -p flag instead."
+msgstr "Ji¾ jste v lat/long. Pou¾ijte volbu -p."
-#: ../raster/r.flow/calc.c:424
-msgid "Unable to get current region"
-msgstr "Nelze získat aktuální region"
+#: ../general/g.region/printwindow.c:408
+msgid "You are in xy location (no projection possible, use -p flag instead)."
+msgstr "Jste v location xy (¾ádná projekce není mo¾ná, pou¾ijte pøepínaè -p)."
-#: ../raster/r.flow/calc.c:429
+#: ../general/g.region/printwindow.c:512
msgid ""
-"Construction of slope curves (flowlines), flowpath lengths, and flowline "
-"densities (upslope areas) from a raster digital elevation model (DEM)"
+"WGS84 output not possible as this location does not contain datum "
+"transformation parameters. Try running g.setproj."
msgstr ""
-"Konsrukce svahových køivek (drah odtoku), délek odtoku a hustoty odtoku (do "
-"svahu) z rastrové mapy elevace (DMT)"
+"Výstup WGS84 není mo¾ný, jeliko¾ tato location neobsahujetransformaèní "
+"parametry. Zkuste spustit g.setproj."
-#: ../raster/r.flow/calc.c:464
-msgid "Input elevation raster map"
-msgstr "Název vstupní mapy digitálního modelu terénu"
+#: ../general/g.region/printwindow.c:662
+msgid "No LatLong information for XY-Projection"
+msgstr "®ádné LatLong informace pro XY-projekci"
-#: ../raster/r.flow/calc.c:471
-msgid "Input aspect raster map"
-msgstr "Název vstupního souboru expozic svahù"
-#: ../raster/r.flow/calc.c:478
-msgid "Input barrier raster map"
-msgstr "Vstupní rastrová mapa bariér"
-#: ../raster/r.flow/calc.c:485
-msgid "Number of cells between flowlines"
-msgstr "Poèet bunìk mezi drahami odtoku"
-#: ../raster/r.flow/calc.c:493
-msgid "Maximum number of segments per flowline"
-msgstr "Maximální poèet segmentù na linii"
-#: ../raster/r.flow/calc.c:501
-msgid "Output flowline vector map"
-msgstr "Výstupní vektorový soubor drah odtoku"
-#: ../raster/r.flow/calc.c:508
-msgid "Output flowpath length raster map"
-msgstr "Výstupní rastr délky svahu"
-#: ../raster/r.flow/calc.c:515
-msgid "Output flowline density raster map"
-msgstr "Výstupní rastr hustoty povrchového odtoku"
-#: ../raster/r.flow/calc.c:519
-msgid "Compute upslope flowlines instead of default downhill flowlines"
-msgstr "Spoèítá dráhy odtoku do svahu místo výchozího ze svahu"
-#: ../raster/r.flow/calc.c:523
-msgid "3-D lengths instead of 2-D"
-msgstr "3-D délky místo 2-D"
-#: ../raster/r.flow/calc.c:527
-msgid "Use less memory, at a performance penalty"
-msgstr "Pou¾ij ménì pamìti na íºkor rychlosti"
-#: ../raster/r.flow/calc.c:545
-msgid "You must select one or more output maps (flout, lgout, dsout)"
-msgstr "Musíte vybrat jednu nebo více výstupních map (flout, lgout, dsout)"
-#: ../raster/r.flow/calc.c:561
-msgid ""
-"lat/long projection not supported by r.flow. Please use 'r.watershed' for "
-"calculating flow accumulation."
-msgstr ""
-"Projekce zem. délka/¹íøka není r.flow podporována. Prosím, pou¾ijte 'r."
-"watershed' pro výpoèet akumulace odtoku."
-#: ../raster/r.flow/precomp.c:48
-msgid "Precomputing: e/w distances"
-msgstr "Poèítám vzdálenosti e/w"
-#: ../raster/r.flow/precomp.c:50
-msgid "Precomputing: quantization tolerances"
-msgstr "Poèítám: kvantizaèní tolerance"
-#: ../raster/r.flow/precomp.c:54
-msgid "Precomputing: inverted elevations"
-msgstr "Poèítám: obrácené vý¹ky"
-#: ../raster/r.flow/precomp.c:59
-msgid "Precomputing: interpolated border elevations"
-msgstr "Poèítám: Interpolované vý¹ky hranic"
-#: ../raster/r.flow/precomp.c:67
-msgid "Precomputing: re-oriented aspects"
-msgstr "Poèítám: pøeorientované expozice"
-#: ../raster/r.flow/precomp.c:72
-msgid "Precomputing: aspects"
-msgstr "Poèítám: expozice"
-#: ../raster/r.flow/precomp.c:120
+#: ../general/g.region/adjust.c:11 ../raster/r.region/main.c:364
#, c-format
-msgid ""
-"Resolution too unbalanced:\n"
-"atan2(%f deg, %f deg) =%f < %f tolerance\n"
-"please resample input map"
-msgstr ""
-"Rozli¹ení je pøíli¹ nevyvá¾ené:\n"
-"atan2(%f deg,%f deg) =%f <%f tolerance\n"
-"prosím pøevzorkujte vstupní mapu"
+msgid "Invalid region: %s"
+msgstr "chybný region: %s"
-#: ../raster/r.flow/precomp.c:125
-#, c-format
-msgid "Resolution too unbalanced (%f x %f); please resample input map"
-msgstr ""
-"Rozli¹ení je pøíli¹ nevyvá¾ené (%fx %f); prosím pøevzorkujte vstupní mapu"
+#: ../general/g.mapset/main.c:48 ../general/g.mapsets/main_cmd.c:49
+msgid "general, settings"
+msgstr "obecné, nastavení"
-#: ../raster/r.flow/io.c:68
-#, c-format
-msgid "Unable to get header for %s"
-msgstr "Nejsem schopen zapsat hlavièku pro %s"
+#: ../general/g.mapset/main.c:49
+msgid "Change current mapset."
+msgstr "Zmìnit souèasný mapset"
-#: ../raster/r.flow/io.c:80
-msgid "Reading input files: elevation"
-msgstr "Naèítám vstupní soubory: elevation"
+#: ../general/g.mapset/main.c:56
+msgid "New MAPSET name"
+msgstr "Nové jméno MAPSETU"
-#: ../raster/r.flow/io.c:85
-msgid "Elevation file's resolution differs from current region resolution"
-msgstr "Rozli¹ení mapy elevace je rùzné od souèasného rozli¹ení regionu"
+#: ../general/g.mapset/main.c:63
+msgid "New LOCATION name (not location path)"
+msgstr "nové jméno LOCATION (ne cesta k location)"
-#: ../raster/r.flow/io.c:99
-msgid "Reading input files: aspect"
-msgstr "Naèítám vstupní soubory: aspect"
+#: ../general/g.mapset/main.c:70
+msgid "New GISDBASE (full path to the directory where the new location is)"
+msgstr "nová GISDBASE (celá cesta k adre¹áøi, kde je ulo¾ena nová location)"
-#: ../raster/r.flow/io.c:103
-msgid "Resolution of aspect file differs from current region resolution"
-msgstr ""
-"Rozli¹ení rastrové mapy expozice je rùzné od aktuálního rozli¹ení regionu"
+#: ../general/g.mapset/main.c:74
+msgid "Create mapset if it doesn't exist"
+msgstr "Vytvoøí nový mapset, pokud neexistuje."
-#: ../raster/r.flow/io.c:119
-msgid "Reading input files: barrier"
-msgstr "Naèítám vstupní soubory: barrier"
+#: ../general/g.mapset/main.c:79
+msgid "List available mapsets"
+msgstr "Vypi¹ v¹echny dostupné mapsety"
-#: ../raster/r.flow/io.c:151
-#, c-format
-msgid "Cannot create segment file %s"
-msgstr "Nelze vytvoøit soubor segmentù %s"
+#: ../general/g.mapset/main.c:85
+msgid "Either mapset= or -l must be used"
+msgstr "Buï mapset= nebo -l musí být zadáno"
-#: ../raster/r.flow/io.c:156
+#: ../general/g.mapset/main.c:131
#, c-format
-msgid "Cannot format segment file %s"
-msgstr "Nelze formátovat soubor segmentù %s"
+msgid "<%s> is already the current mapset"
+msgstr "<%s> ji¾ existuje v souèasném mapsetu "
-#: ../raster/r.flow/io.c:162
-#, c-format
-msgid "Cannot open segment file %s"
-msgstr "Nelze otevøít soubor segmentù %s"
+#: ../general/g.mapset/main.c:139
+msgid "You don't have permission to use this mapset"
+msgstr "Nemáte povolení pou¾ívat tento mapset."
-#: ../raster/r.flow/io.c:182 ../vector/v.net.visibility/main.c:86
-#: ../vector/v.edit/cmd/main.c:85
-#: ../vector/lidar/v.lidar.edgedetection/main.c:169
-#: ../vector/lidar/v.lidar.correction/main.c:147
-#: ../vector/lidar/v.lidar.correction/main.c:153
-#: ../vector/lidar/v.outlier/main.c:149 ../vector/lidar/v.outlier/main.c:153
-#: ../vector/lidar/v.outlier/main.c:159
-#: ../vector/lidar/v.surf.bspline/main.c:260 ../vector/v.generalize/main.c:312
-#: ../vector/v.mkgrid/main.c:196 ../vector/v.net.path/main.c:134
-#: ../vector/v.voronoi/dt_main.c:82 ../vector/v.voronoi/vo_main.c:152
-#: ../vector/v.hull/main.c:273 ../doc/vector/v.example/main.c:70
-#, c-format
-msgid "Unable to create vector map <%s>"
-msgstr "Nelze vytvoøit vektorovou mapu <%s>"
+#: ../general/g.mapset/main.c:147
+msgid "The mapset does not exist. Use -c flag to create it."
+msgstr "Mapset neexistuje. Pøidejte pøepínaè -c pro vytvoøení nového mapsetu."
-#: ../raster/r.flow/io.c:212
-msgid "Cannot reset current region"
-msgstr "Nelze pøenastavit aktuální region"
+#: ../general/g.mapset/main.c:156
+msgid "Unable to read GIS_LOCK enviroment variable"
+msgstr "Nelze èíst promìnnou prostøedí GIS_LOCK."
-#: ../raster/r.flow/io.c:214
-msgid "Writing density file"
-msgstr "Zapisuji soubor s hustotou"
-#: ../raster/r.flow/io.c:238
+#: ../general/g.mapset/main.c:170
#, c-format
-msgid "Unable to find file %s"
-msgstr "Nejsem schopen najít soubor %s"
-#: ../raster/r.surf.contour/main.c:52
-msgid "Surface generation program from rasterized contours."
-msgstr "Program pro tvorbu povrchù z vrstevnic ulo¾ených v rastrové podobì."
-#: ../raster/r.surf.contour/main.c:59
-msgid "Name of existing raster map containing contours"
-msgstr "Název existující rastrové mapy obsahující vrstevnice"
-#: ../raster/r.surf.contour/main.c:66
-msgid "Output elevation raster map"
-msgstr "Název výstupního digitálního modelu terénu"
-#: ../raster/r.surf.contour/main.c:70
-msgid "Unused; retained for compatibility purposes, will be removed in future"
-msgstr "Nepou¾ito; zbylo z dùvodù kompatibility, bude v budoucnosti vymazáno"
-#: ../raster/r.surf.contour/main.c:75
msgid ""
-"Invoke slow, but memory frugal operation (generally not needed, will be "
-"removed in future)"
+"%s is currently running GRASS in selected mapset or lock file cannot be "
+"checked"
msgstr ""
-"Vyvolá pomalou, ale na pamì» nenároènou operaci (obecnì není potøeba a bude "
-"v budoucnu vyjmuto)"
+"%s právì pou¾ívá GRASS s daným mapsetem nebo uzamykací soubor nelze "
+"zkontrolovat."
-#: ../raster/r.topidx/main.c:39
-msgid "Creates topographic index [ln(a/tan(beta))] map from elevation map."
-msgstr ""
-"Vytvoøí mapu topografického indexu, [ln(a/tan(beta))], z rastrové mapy "
-"digitálního modelu terénu."
+#: ../general/g.mapset/main.c:174
+msgid "Erasing monitors..."
+msgstr "Ma¾u monitory ... "
-#: ../raster/r.topidx/main.c:46
-msgid "Output topographic index map"
-msgstr "Výstupní mapa topografického indexu:"
+#: ../general/g.mapset/main.c:190
+msgid "Cleaning up temporary files..."
+msgstr "Ma¾u doèasné soubory..."
-#: ../raster/r.topidx/main.c:54
-#, c-format
-msgid "Lat/Long location is not supported by %s. Please reproject map first."
-msgstr "Location Lat/Long není podporována %s. Prosím zmìòte projekci."
+#: ../general/g.mapset/main.c:204
+msgid "Your shell continues to use the history for the old mapset"
+msgstr "Vá¹ shell pokraèuje v pou¾ívání historie pro starý mapset."
-#: ../raster/r.topidx/file_io.c:31
-msgid "Reading elevation map..."
-msgstr "Naèítám mapu elevace:"
-#: ../raster/r.topidx/file_io.c:86
-msgid "Writing topographic index map..."
-msgstr "Zapisuji mapu topografického indexu..."
-#: ../raster/r.out.pov/main.c:122
-msgid "Converts a raster map layer into a height-field file for POVRAY."
-msgstr "Pøevede rastrovou mapu do souboru pro POVRAY."
-#: ../raster/r.out.pov/main.c:136
-msgid "Name of output povray file (TGA height field file)"
-msgstr "Název výstupního souboru povray (soubor tabulky vý¹ek TGA)"
-#: ../raster/r.out.pov/main.c:142
-msgid "Height-field type (0=actual heights 1=normalized)"
-msgstr "Pole vý¹ek (0=aktuální vý¹ky, 1=normalizované)"
-#: ../raster/r.out.pov/main.c:148
-msgid "Elevation bias"
-msgstr "Chyba v neurèitosti nadmoøských vý¹ek"
-#: ../raster/r.out.pov/main.c:180
+#: ../general/g.mapset/main.c:208
#, c-format
-msgid "Invalid output filename <%s>"
-msgstr "Neplatný název výstupního souboru <%s>"
-#: ../raster/r.out.pov/main.c:190
-#, c-format
-msgid "Raster map is too big! Exceeds %d columns or %d rows"
-msgstr "Rastrová mapa je pøíli¹ velká! Pokraèuje %d sloupcù nebo %d øádkù"
-#: ../raster/r.out.pov/main.c:211
-msgid "Negative elevation values in input"
-msgstr "Záporné hodnoty elevace ve vstupu"
-#: ../raster/r.covar/main.c:54
msgid ""
-"Outputs a covariance/correlation matrix for user-specified raster map layer"
-"(s)."
+"You can switch the history by commands:\n"
+"history -w; history -r %s/.bash_history; HISTFILE=%s/.bash_history"
msgstr ""
-"Vytvoøí kovarianèní/korelaèní matici pro u¾ivatelem zadanou rastrovou mapu"
-"(y)."
+"Mù¾ete zmìnit historii pøíkazy:\n"
-#: ../raster/r.covar/main.c:61
-msgid "Print correlation matrix"
-msgstr "Vytiskne korelaèní matici"
-#: ../raster/r.covar/main.c:105
+#: ../general/g.mapset/main.c:212
#, c-format
-msgid "%s: complete ... "
-msgstr "%s: hotovo ... "
-#: ../raster/r.covar/main.c:133
-msgid "No non-null values"
-msgstr "®ádné prázdné hodnoty"
-#: ../raster/r.out.arc/main.c:60
-msgid "Converts a raster map layer into an ESRI ARCGRID file."
-msgstr "Pøevede rastrovou mapu na soubor ESRI ARCGRID."
-#: ../raster/r.out.arc/main.c:68
-msgid "Name of an existing raster map layer"
-msgstr "Název existujícího rastru"
-#: ../raster/r.out.arc/main.c:75
-msgid "Name of an output ARC-GID map (use out=- for stdout)"
-msgstr ""
-"Název výstupního ARC-GRID souboru (pro standardní výstup pou¾ijte out=-)"
-#: ../raster/r.out.arc/main.c:82
-msgid "Number of decimal places"
-msgstr "Poèet míst za desetinnou èárkou"
-#: ../raster/r.out.arc/main.c:91
-msgid "List one entry per line instead of full row"
-msgstr "Vypi¹ jeden záznam na øádek"
-#: ../raster/r.report/stats.c:62
-#, c-format
-msgid "Unable to open result file <%s>"
-msgstr "Nelze otevøít výsledný soubor <%s>"
-#: ../raster/r.report/stats.c:100 ../raster/r.kappa/stats.c:13
-msgid "Problem reading r.stats output"
-msgstr "Problém pøi ètení výstupu r.stats"
-#: ../raster/r.report/main.c:29
-msgid "Reports statistics for raster map layers."
-msgstr "Vypí¹e statistiku pro rastrovou mapu."
-#: ../raster/r.report/parse.c:37
-msgid "Raster map(s) to report on"
-msgstr "Rastrové mapy, pro které má být vytvoøena zpráva"
-#: ../raster/r.report/parse.c:45
msgid ""
-"mi(les),me(ters),k(ilometers),a(cres),h(ectares),c(ell_counts),p"
-"(ercent_cover)"
-msgstr "mí(le), me(try),k(ilometry),a(kry),h(ektary),c(ell_counts),p(rocenta)"
-#: ../raster/r.report/parse.c:54
-msgid "Character representing no data cell value"
-msgstr "Znak, reprezentující hodnoty bez dat"
-#: ../raster/r.report/parse.c:55 ../raster/r.report/parse.c:63
-#: ../raster/r.report/parse.c:71 ../raster/r.report/parse.c:95
-#: ../raster/r.report/parse.c:100 ../raster/r.report/parse.c:105
-msgid "Formatting"
-msgstr "Formátuji"
-#: ../raster/r.report/parse.c:61
-#, c-format
-msgid "Page length (default: %d lines)"
-msgstr "Délka stránky (výchozí: %d øádkù)"
-#: ../raster/r.report/parse.c:69
-#, c-format
-msgid "Page width (default: %d characters)"
-msgstr "©íøka stránky (výchozí: %d znakù)"
-#: ../raster/r.report/parse.c:78
-msgid "Name of an output file to hold the report"
-msgstr "Název výstupního souboru, pro ulo¾ení zprávy"
-#: ../raster/r.report/parse.c:86 ../raster/r.stats/main.c:131
-msgid "Number of fp subranges to collect stats from"
+"history -S; history -L %s/.history; setenv histfile=%s/.history"
msgstr ""
-"Poèet podintervalù rastrové mapy s plovoucí desetinnou èárkou, pro které "
-"bude vytvoøena statistika"
-#: ../raster/r.report/parse.c:94
-msgid "Suppress page headers"
-msgstr "Potlaè hlavièky stránky"
+#: ../general/g.setproj/main.c:78
+msgid "general, projection"
+msgstr "obecné, projekce"
-#: ../raster/r.report/parse.c:99
-msgid "Use formfeeds between pages"
-msgstr "Pou¾ij oddìlovaèe mezi stránkami"
+#: ../general/g.setproj/main.c:80
+msgid "Interactively reset the location's projection settings."
+msgstr "Interaktivnì znovunastavit vlastnosti projekce location"
-#: ../raster/r.report/parse.c:104
-msgid "Scientific format"
-msgstr "Vìdecký formát"
+#: ../general/g.setproj/main.c:88
+msgid "You must be in the PERMANENT mapset to run g.setproj"
+msgstr "Musíte být v mapsetu PERMANENT pro spu¹tìní g.setproj"
-#: ../raster/r.report/parse.c:109
-msgid "Filter out all no data cells"
-msgstr "Odfiltruj v¹echny buòky hodnotou ¾ádná data"
+#: ../general/g.setproj/main.c:101
+msgid "PERMANENT: permission denied"
+msgstr "PERMANENT: Pøístup odepøen"
-#: ../raster/r.report/parse.c:113
-msgid "Filter out cells where all maps have no data"
-msgstr "Odfiltruj v¹echny buòky s hodnotou ¾ádná data pro celou mapu"
+#: ../general/g.setproj/main.c:105
+msgid "Current region cannot be set"
+msgstr "Nelze nastavit aktuální region."
-#: ../raster/r.report/parse.c:117 ../raster/r.stats/main.c:180
-msgid "Report for cats fp ranges (fp maps only)"
-msgstr ""
-"Zpráva pro jednotlivé kategorie rastrových map s plovoucí desetinnou èárkou"
+#: ../general/g.setproj/main.c:108 ../raster/r.resamp.rst/main.c:296
+msgid "Retrieving and setting region failed"
+msgstr "Obnovení a nastavené regionu selhalo"
-#: ../raster/r.report/parse.c:121 ../raster/r.stats/main.c:188
-msgid "Read fp map as integer (use map's quant rules)"
-msgstr ""
-"Naèti mapu s plovoucí desetinnou øárkou jako celoèíselnou (pou¾ij kvatizaèní "
-"pravidla mapy)"
+#: ../general/g.setproj/main.c:132
+msgid "Would you still like to change some of the parameters?"
+msgstr "Poøád je¹tì chcete zmìnit nìkteré parametry?"
-#: ../raster/r.report/parse.c:168
-msgid "nsteps has to be > 0; using nsteps=255"
-msgstr "nsteps musí být vìt¹í, ne¾ nula; pou¾ívám nsteps=255"
+#: ../general/g.setproj/main.c:133
+msgid "The projection information will not be updated"
+msgstr "Informace o projekci nebudou aktualizovány"
-#: ../raster/r.report/parse.c:176
-msgid "Illegal page length"
-msgstr "Neplatná délka stránky"
-#: ../raster/r.report/parse.c:184
-msgid "Illegal page width"
-msgstr "Neplatná ¹íøka stránky"
-#: ../raster/r.report/parse.c:227
+#: ../general/g.setproj/main.c:144
#, c-format
-msgid "Only %d unit%s allowed"
-msgstr "Povoleno pouze %d jednotek%s"
-#: ../raster/r.report/parse.c:265
-#, c-format
-msgid "Unable to read fp range for raster map <%s>"
-msgstr ""
-"Nelze èíst rozmezí s pou¾itím desetinného èísla pro rastrovou mapu <%s>"
-#: ../raster/r.in.gdal/main.c:80
-msgid "Import GDAL supported raster file into a binary raster map layer."
-msgstr "Import rastrových souborù podporovaných knihovnou GDAL."
-#: ../raster/r.in.gdal/main.c:86
-msgid "Raster file to be imported"
-msgstr "Název rastrového souboru, který má být importován"
-#: ../raster/r.in.gdal/main.c:99
-msgid "Band to select (default is all bands)"
-msgstr "Kanál, který má být vybrán (výchozí: v¹echny kanály)"
-#: ../raster/r.in.gdal/main.c:105
-msgid "Name of location to read projection from for GCPs transformation"
-msgstr ""
-"Název location, ze které bude naètena mapová projekce pro GCP transformaci"
-#: ../raster/r.in.gdal/main.c:113
-msgid "Metadata"
-msgstr "Metadata"
-#: ../raster/r.in.gdal/main.c:119 ../vector/v.in.ogr/main.c:175
-msgid "Name for new location to create"
-msgstr "Název nové location, která má být vytvoøena"
-#: ../raster/r.in.gdal/main.c:123
-msgid "Override projection (use location's projection)"
-msgstr "Pøepi¹ mapovou projekci (pou¾ij map. projekci location)"
-#: ../raster/r.in.gdal/main.c:127 ../vector/v.in.ogr/main.c:220
-msgid "Extend location extents based on new dataset"
-msgstr "Hranice location se zvìt¹í podle nového datasetu"
-#: ../raster/r.in.gdal/main.c:131 ../vector/v.in.ogr/main.c:193
-msgid "List supported formats and exit"
-msgstr "Vypi¹ podporované formáty a ukonèi se"
-#: ../raster/r.in.gdal/main.c:136
-msgid "Keep band numbers instead of using band color names"
-msgstr "Ponechej èísla kanálù místo pou¾ití jmen jejich barev"
-#: ../raster/r.in.gdal/main.c:158
-msgid "You have to specify a target location different from output location"
-msgstr "Musíte zadat cílovou location rùznou od souèasné"
-#: ../raster/r.in.gdal/main.c:176
-#, c-format
-msgid "Supported Formats:\n"
-msgstr "Podporované formáty:\n"
-#: ../raster/r.in.gdal/main.c:202
-msgid "Name for output raster map not specified"
-msgstr "Název výstupní rastrové mapy nebyl specifikován"
-#: ../raster/r.in.gdal/main.c:211
-#, c-format
-msgid "Raster map <%s> already exists and will be overwritten"
-msgstr "Vektorová vrstva <%s> ji¾ existuje a bude pøepsána."
-#: ../raster/r.in.gdal/main.c:230
msgid ""
-"The polynomial rectification used in i.rectify does not work well with NOAA/"
-"AVHRR data. Try using gdalwarp with thin plate spline rectification instead. "
-"(-tps)"
+"Zone in default geographic region definition: %d\n"
+" is different from zone in PROJ_INFO file: %d"
msgstr ""
-"Polynomická rektifikace pou¾ita v i.rectify nepracuje dobøe s daty NOAA/"
-"AVHRR. Zkuste místo toho pou¾ít gdalwarp rektifikaci pomocí køivek tenkých "
-"plátù (-tps)"
+"Zóna v základní definici geografického regionu: %d\n"
+"se li¹í od zóny v souboru PROJ_INFO: %d"
-#: ../raster/r.in.gdal/main.c:247
-msgid ""
-"Input raster map is rotated - cannot import. You may use 'gdalwarp' to "
-"transform the map to North-up."
-msgstr ""
-"Vstupní mapa je pootoèená - nelze ji naimportovat. Pou¾ijte 'gdalwarp' pro "
-"její transformaci severem-nahoru."
+#: ../general/g.setproj/main.c:154
+msgid "XY-location cannot be projected"
+msgstr "XY-location nemù¾e být promístnuta"
-#: ../raster/r.in.gdal/main.c:293
-msgid ""
-"Unable to convert input map projection to GRASS format; cannot create new "
-"location."
-msgstr ""
-"Nelze pøevést vstupní mapovou projekci do formátu GRASSu; nelze vytvoøit "
-"novou location."
+#: ../general/g.setproj/main.c:188
+msgid "Unknown projection"
+msgstr "Neznámá projekce"
-#: ../raster/r.in.gdal/main.c:299
+#: ../general/g.setproj/main.c:195
#, c-format
-msgid "Location <%s> created"
-msgstr "Location <%s> vytvoøena"
+msgid "Projection %s is not specified in the file 'proj-parms.table'"
+msgstr "Projekce %s není specifikována v souboru 'proj-parms.table'"
-#: ../raster/r.in.gdal/main.c:307
-msgid ""
-"Unable to convert input raster map projection information to GRASS format "
-"for checking"
-msgstr ""
-"Nelze pøevést informace o vstupní mapové projekci do formátu GRASSu (pro "
-"kontrolu)"
+#: ../general/g.setproj/main.c:200
+msgid "Do you wish to specify a geodetic datum for this location?"
+msgstr "Pøejete si zadat geodetické datum pro tuto location?"
-#: ../raster/r.in.gdal/main.c:326 ../vector/v.in.ogr/main.c:480
-msgid "Over-riding projection check"
-msgstr "Pøeskakuji kontrolu projekce."
-#: ../raster/r.in.gdal/main.c:335 ../vector/v.in.ogr/main.c:489
-msgid ""
-"Projection of dataset does not appear to match current location.\n"
-"\n"
-msgstr ""
-"Vypadá to, ¾e projekce datasetu neodpovídá projekci aktuální location \n"
-"\n"
-#: ../raster/r.in.gdal/main.c:341
-msgid "Location PROJ_INFO is:\n"
-msgstr "PROJ_INFO location je:\n"
-#: ../raster/r.in.gdal/main.c:353
-msgid "Dataset PROJ_INFO is:\n"
-msgstr "PROJ_INFO datasetu je:\n"
-#: ../raster/r.in.gdal/main.c:371 ../vector/v.in.ogr/main.c:507
-#: ../vector/v.in.ogr/main.c:515
-msgid "Import dataset PROJ_INFO is:\n"
-msgstr "iMPORT PROJ_INFO datasetu je:\n"
-#: ../raster/r.in.gdal/main.c:394
-msgid ""
-"\n"
-"You can use the -o flag to r.in.gdal to override this check and use the "
-"location definition for the dataset.\n"
-msgstr ""
-"\n"
-"Mù¾ete pou¾ít pøepínaè -o zru¹ení této kontroly.\n"
-#: ../raster/r.in.gdal/main.c:397
-msgid ""
-"Consider generating a new location from the input dataset using the "
-"'location' parameter.\n"
-msgstr ""
-"Zva¾te vytvoøení nové location s parametry 'location' ze vstupního "
-"datasetu.\n"
-#: ../raster/r.in.gdal/main.c:402 ../vector/v.in.ogr/main.c:566
-msgid "Projection of input dataset and current location appear to match"
-msgstr "Mapová projekce vstupního datasetu a aktuální location souhlasí."
-#: ../raster/r.in.gdal/main.c:408
-msgid "Proceeding with import..."
-msgstr "Pokraèuje importování..."
-#: ../raster/r.in.gdal/main.c:436
+#: ../general/g.setproj/main.c:207
#, c-format
-msgid "Selected band (%d) does not exist"
-msgstr "Vybraný kanál (%d) neexistuje"
+msgid "The current datum is %s (%s)"
+msgstr "Souèasné datum je %s (%s)"
-#: ../raster/r.in.gdal/main.c:515
-#, c-format
-msgid "Copying %d GCPS in points file for <%s>"
-msgstr "Kopíruji %d GCPS v souboru bodù pro <%s>"
+#: ../general/g.setproj/main.c:210
+msgid "Do you wish to change the datum (or datum transformation parameters)?"
+msgstr "Pøejete si zmìnit datum ( nebo parametry transformace datumu)?"
-#: ../raster/r.in.gdal/main.c:520
-msgid "GCPs have the following OpenGIS WKT Coordinate System:"
-msgstr "GCPs mají následující OpenGIS WTK souøadný systém:"
+#: ../general/g.setproj/main.c:217
+msgid "The datum information has not been changed"
+msgstr "Informace o datumu se nezmìnily"
-#: ../raster/r.in.gdal/main.c:529
-msgid "Re-projecting GCPs table:"
-msgstr "Zmìna projekce GCPs tabulky:"
-#: ../raster/r.in.gdal/main.c:530
+#: ../general/g.setproj/main.c:278
#, c-format
-msgid "* Input projection for GCP table: %s"
-msgstr "* Vstupní projekce pro GCP tabulku: %s"
+msgid "The current ellipsoid is %s"
+msgstr "Souèasný elipsoid je %s"
-#: ../raster/r.in.gdal/main.c:532
-#, c-format
-msgid "* Output projection for GCP table: %s"
-msgstr "á Výstupní projekce pro GCP tabulk: %s"
+#: ../general/g.setproj/main.c:279
+msgid "Do you want to change ellipsoid parameter?"
+msgstr "Pøejete si zmìnit parametry elipsoidu?"
-#: ../raster/r.in.gdal/main.c:551
-#, c-format
-msgid "Error in pj_do_proj (can't re-projection GCP %i)"
-msgstr "Chyba v pj_do_proj (nelze reprojekovat GCP %i)"
+#: ../general/g.setproj/main.c:282
+msgid "The ellipse information has not been changed"
+msgstr "Informace o elipsoidu se nezmìily"
-#: ../raster/r.in.gdal/main.c:615
-msgid "Unable to translate projection key values of input GCPs"
-msgstr "Nelze získat klíèové hodnoty mapové projekce vstupní GCPs"
-#: ../raster/r.in.gdal/main.c:631
-msgid "Unable to get projection info of target location"
-msgstr "Nelze získat info mapové projekce cílové location"
-#: ../raster/r.in.gdal/main.c:633
-msgid "Unable to get projection units of target location"
-msgstr "Nelze získat jednotky mapové projekce cílové location"
-#: ../raster/r.in.gdal/main.c:635
-msgid "Unable to get projection key values of target location"
-msgstr "Nelze získat klíèové hodnoty mapové projekce cílové location"
-#: ../raster/r.in.gdal/main.c:639
+#: ../general/g.setproj/main.c:299
#, c-format
-msgid "Mapset <%s> in target location <%s> - "
-msgstr "Mapset <%s> ve vstupní location <%s> - "
+msgid "The radius is currently %f"
+msgstr "Souèasný polomìr je %f"
-#: ../raster/r.rescale/main.c:50
-msgid "Rescales the range of category values in a raster map layer."
-msgstr "Zmìní rozsahy hodnot v kategoriích rastrové mapy."
+#: ../general/g.setproj/main.c:300
+msgid "Do you want to change the radius?"
+msgstr "Oøejete si zmìnit polomìr?"
-#: ../raster/r.rescale/main.c:93
-msgid "Quietly"
-msgstr "Potichu"
+#: ../general/g.setproj/main.c:302 ../general/g.setproj/main.c:307
+msgid "Enter radius for the sphere in meters"
+msgstr "Vlo¾te polomìr pro kouli v metrech"
-#: ../raster/r.rescale/main.c:144
-#, c-format
-msgid "Rescale %s[%ld,%ld] to %s[%ld,%ld]"
-msgstr "Pøevzorkování %s[%ld,%ld] na %s[%ld,%ld]"
+#: ../general/g.setproj/main.c:322
+msgid "Invalid input ellipsoid"
+msgstr "Neplatný vstuní elipsoid"
-#: ../raster/r.random/random.c:43
+#: ../general/g.setproj/main.c:428
#, c-format
-msgid "Cannot open cover raster map <%s>"
-msgstr "Nelze otevøít krycí rastrovou mapu <%s>"
+msgid "The UTM zone is now set to %d"
+msgstr "UTM zóna je nyní nastavena na %d"
-#: ../raster/r.random/random.c:65 ../vector/v.to.points/main.c:266
-#: ../vector/v.net.path/path.c:90
-#, c-format
-msgid "Cannot open database <%s> by driver <%s>"
-msgstr "Nelze otevøít databázi <%s> ovladaèem <%s>"
+#: ../general/g.setproj/main.c:429
+msgid "Do you want to change the UTM zone?"
+msgstr "Pøejete si zmìnit UTM zónu?"
-#: ../raster/r.random/random.c:90
-msgid "Cannot create new table"
-msgstr "Nelze vytvoøit novou tabulku"
+#: ../general/g.setproj/main.c:430
+msgid "UTM zone information has not been updated"
+msgstr "Informace o UTM zónì nebyly aktualizovány."
-#: ../raster/r.random/random.c:100
-#, c-format
-msgid "Writing raster map <%s> and vector map <%s> ..."
-msgstr "Zapisuji rastrovou mapu <%s> a vektorovou mapu <%s>..."
-#: ../raster/r.random/random.c:103
-#, c-format
-msgid "Writing raster map <%s> ..."
-msgstr "Zapisuji rastrovou mapu <%s>... "
-#: ../raster/r.random/random.c:105
-#, c-format
-msgid "Writing vector map <%s> ..."
-msgstr "Zapisuji do vektorové mapy <%s> ..."
-#: ../raster/r.random/random.c:117
-#, c-format
-msgid "Cannot read raster row [%d] from raster map <%s>"
-msgstr "Nelze èíst øádek [%d] rastrové mapy <%s>"
-#: ../raster/r.random/random.c:121
-#, c-format
-msgid "Cannot read raster row [%d] from cover raster map <%s>"
-msgstr "Nelze èíst øádek [%d] z krycí rastrové mapy <%s>"
-#: ../raster/r.random/random.c:176 ../vector/v.to.points/main.c:60
-#: ../vector/v.net.path/path.c:274
-#, c-format
-msgid "Cannot insert new record: %s"
-msgstr "Nelze vlo¾it nový záznam: %s"
-#: ../raster/r.random/random.c:211
-#, c-format
-msgid "Only [%ld] random points created"
-msgstr "Jenom [%ld] náhodných bodù bylo vytvoøeno"
-#: ../raster/r.random/main.c:48
+#: ../general/g.setproj/main.c:435
msgid ""
-"Creates a raster map layer and vector point map containing randomly located "
-"sites."
+"But if you change zone, all the existing data will be interpreted by "
+"projection software. GRASS will not automatically re-project or even change "
+"the headers for existing maps."
msgstr ""
-"Vytvoøí rastrovou mapu a bodovou vektorovou mapu obsahující náhodnì "
-"rozmístìné body."
+"Ale jestli¾e zmìníte zónu, v¹echna existující data budou pøekládána "
+"projekèním softwarem. GRASS neumí automaticky znìnit projekci nebo dokonce "
+"zmìnit hlavièky existujících map."
-#: ../raster/r.random/main.c:57 ../raster/r.median/main.c:56
-msgid "Name of cover raster map"
-msgstr "Jméno svrchní rastrové mapy"
+#: ../general/g.setproj/main.c:439
+msgid "Would you still like to change the UTM zone?"
+msgstr "Poøád je¹tì si pøejete zmìnit UTM zónu?"
-#: ../raster/r.random/main.c:64
-msgid "The number of points to allocate"
-msgstr "Poèet bodù, které mají být rozmístìny"
-#: ../raster/r.random/main.c:76
-msgid "Generate vector points for category zero also"
-msgstr "Generuje také body s kategorií nula"
-#: ../raster/r.random/main.c:80
-msgid "Report information about input raster and exit"
-msgstr "Nahla¹ informace o vstupním rastru a ukonèi se"
-#: ../raster/r.random/main.c:84
-msgid "Generate vector points as 3D points"
-msgstr "Vytvoøit vektorové body jako 3D body"
-#: ../raster/r.random/main.c:131
+#: ../general/g.setproj/main.c:475
#, c-format
-msgid "Note: one (or both) of %s and %s must be specified"
-msgstr "Musí být zadána alespoò jedna volba z %s a %s"
+msgid "Error writing PROJ_INFO file <%s>"
+msgstr "Chyba pøi zápisu PROJ_INFO <%s>"
-#: ../raster/r.random/main.c:151
+#: ../general/g.setproj/main.c:549
#, c-format
-msgid "<%s=%s> invalid percentage"
-msgstr "<%s=%s> neplatná procenta"
+msgid "Enter plural form of units [meters]: "
+msgstr "Vlo¾te mno¾né èíslo jednotek[metry]:"
-#: ../raster/r.random/main.c:158
+#: ../general/g.setproj/main.c:579
#, c-format
-msgid "<%s=%s> invalid number of points"
-msgstr "<%s=%s> neplatný poèet bodù "
+msgid "Enter singular for unit: "
+msgstr "Vlo¾te jednotné èíslo jednotky:"
-#: ../raster/r.random/main.c:173
+#: ../general/g.setproj/main.c:587
#, c-format
-msgid "There aren't [%ld] cells in the current region"
-msgstr "V aktuálním regionu nejsou ¾ádné buòky [%ld]"
+msgid "Enter conversion factor from %s to meters: "
+msgstr "Pøevodní faktor z %s na metry:"
-#: ../raster/r.random/main.c:176
+#: ../general/g.setproj/main.c:612
#, c-format
-msgid "There aren't [%ld] non-zero cells in the current region"
-msgstr "Není [%ld] nenulových buòek v souèasném regionu"
+msgid "Error writing into UNITS output file <%s>"
+msgstr "Chyba pøi zápisu do výstupního souboru JEDNOTEK: %s"
-#: ../raster/r.random/main.c:181
-msgid "There are no valid locations in the current region"
-msgstr "Neexistuje ¾ádné správné umístìní v souèasném regioinu"
+#: ../general/g.setproj/main.c:618
+msgid "Unable to write to DEFAULT_WIND region file"
+msgstr "Nelze zapsat do souboru regionu DEFAULT_WIND"
-#: ../raster/r.random/count.c:67
-msgid "Collecting Stats..."
-msgstr "Sbírám statistiky ... "
-#: ../raster/r.random/count.c:72 ../imagery/i.pca/main.c:254
-#: ../imagery/i.pca/main.c:305 ../imagery/i.pca/main.c:317
-#: ../imagery/i.pca/main.c:432
+#: ../general/g.setproj/main.c:620
#, c-format
-msgid "Cannot read raster row [%d]"
-msgstr "Nelze èíst øádek rastru [%d]"
+msgid ""
+"\n"
+"Projection information has been recorded for this location\n"
+"\n"
+msgstr ""
+"\n"
+"Informace o projekci pro tuto location byly ulo¾eny\n"
+"\n"
-#: ../raster/r.random/count.c:77
-#, c-format
-msgid "Cannot read cover raster row [%d]"
-msgstr "Nelze èíst øádek [%d] rastru"
+#: ../general/g.setproj/main.c:622
+msgid "The geographic region information in WIND is now obsolete"
+msgstr "Informace o geografickém regionu v souboru WIND jsou zastaralé."
-#: ../raster/r.random/count.c:125
-msgid "Programmer error in get_stats/switch"
-msgstr "Chyba programátora get_stats/switch"
+#: ../general/g.setproj/main.c:623
+msgid "Run g.region -d to update it"
+msgstr "Spus»te g.region -d pro aktualizaci"
-#: ../raster/r.sunmask/solpos00.c:953
-#, c-format
-msgid "S_decode ==> Please fix the year: %d [1950-2050]"
-msgstr "S_decode ==> Prosím opravte rok: %d [1950-250]"
+#: ../general/g.setproj/get_stp.c:39
+msgid "This should not happen see your system admin"
+msgstr ""
+"Toto se nemìlo stát, nav¹tivte prosím va¹eho systémovho administrátora..."
-#: ../raster/r.sunmask/solpos00.c:956
-#, c-format
-msgid "S_decode ==> Please fix the month: %d"
-msgstr "S_decode ==> Prosím opravte mìsíc: %d"
+#: ../general/g.setproj/get_stp.c:95
+#, fuzzy
+msgid "Unable to open FIPS code file"
+msgstr "Nelze otevøít soubor obrazové skupiny"
-#: ../raster/r.sunmask/solpos00.c:959
+#: ../general/g.setproj/get_stp.c:120
#, c-format
-msgid "S_decode ==> Please fix the day-of-month: %d"
-msgstr "S_decode ==> prosím opravte den-v-mìsíci: %d"
+msgid "No match of fips state %d county %d"
+msgstr ""
-#: ../raster/r.sunmask/solpos00.c:962
+#: ../general/g.setproj/get_stp.c:156 ../general/g.setproj/get_stp.c:160
+#: ../general/g.setproj/get_stp.c:272 ../general/g.setproj/get_stp.c:277
+#: ../display/d.title/main.c:117 ../display/d.text.new/main.c:398
+#: ../display/d.text/main.c:191 ../vector/v.in.ascii/in.c:239
+#: ../vector/v.surf.rst/main.c:590 ../vector/v.surf.rst/main.c:598
+#: ../vector/v.surf.rst/main.c:606 ../vector/v.surf.rst/main.c:615
+#: ../vector/v.surf.rst/main.c:623 ../vector/v.surf.rst/main.c:631
+#: ../raster/r.in.arc/main.c:113 ../raster/r.in.ascii/main.c:131
+#: ../raster/r.in.ascii/main.c:161 ../raster/r.resamp.rst/main.c:616
+#: ../raster/r.resamp.rst/main.c:627 ../raster/r.resamp.rst/main.c:639
+#: ../raster/r.resamp.rst/main.c:652 ../raster/r.resamp.rst/main.c:664
+#: ../raster/r.resamp.rst/main.c:676
#, c-format
-msgid "S_decode ==> Please fix the day-of-year: %d"
-msgstr "S_decode ==> Prosím opravte den-v-roce: %d"
+msgid "Unable to open temporary file <%s>"
+msgstr "Nelze otevøít doèasný soubor <%s>"
-#: ../raster/r.sunmask/solpos00.c:965
-#, c-format
-msgid "S_decode ==> Please fix the hour: %d"
-msgstr "S_decode ==> Prosím opravte hodinu: %d"
+#: ../general/g.setproj/get_stp.c:175
+#, fuzzy
+msgid "Reading sf key_value temp file"
+msgstr "Vytváøím nìjaké doèasné soubory"
-#: ../raster/r.sunmask/solpos00.c:968
-#, c-format
-msgid "S_decode ==> Please fix the minute: %d"
-msgstr "S_decode ==> Prosím opravte minutu: %d"
+#: ../general/g.setproj/get_stp.c:205
+#, fuzzy
+msgid "Invalid State FIPS code"
+msgstr "Chybná vzdálenost"
-#: ../raster/r.sunmask/solpos00.c:971
-#, c-format
-msgid "S_decode ==> Please fix the second: %d"
-msgstr "S_decode ==> prosím opravte vteøiny: %d"
+#: ../general/g.setproj/get_stp.c:293
+#, fuzzy
+msgid "Reading cf key_value temp file"
+msgstr "Naèítám soubor dig_att..."
-#: ../raster/r.sunmask/solpos00.c:974
-#, c-format
-msgid "S_decode ==> Please fix the time zone: %f"
-msgstr "S_decode ==> Prosím opravte èasovou zónu: %f"
+#: ../general/g.setproj/get_stp.c:322
+#, fuzzy
+msgid "Invalid County FIPS code"
+msgstr "Chybné písmo: %s"
-#: ../raster/r.sunmask/solpos00.c:977
+#: ../general/g.setproj/proj.c:176
#, c-format
-msgid "S_decode ==> Please fix the interval: %d"
-msgstr "S_decode ==> Prosím opravte interval: %d"
+msgid "Unrecognized 'ask' value in proj-parms.table: %s"
+msgstr "Nerozpoznaná hodnota 'ask' v proj-parms.table: %s"
-#: ../raster/r.sunmask/solpos00.c:980
+#: ../general/g.setproj/proj.c:186
#, c-format
-msgid "S_decode ==> Please fix the latitude: %f"
-msgstr "S_decode ==> Prosím opravte zem. ¹íøku: %f"
+msgid "Unrecognized default value in proj-parms.table: %s"
+msgstr "Nerozpoznaná zíkladní tabulka v proj_parms.tabla: %s"
-#: ../raster/r.sunmask/solpos00.c:983
+#: ../general/g.findfile/main.c:73
#, c-format
-msgid "S_decode ==> Please fix the longitude: %f"
-msgstr "S_decode ==> Prosím opravte zem. délku: %f"
-#: ../raster/r.sunmask/solpos00.c:986
-#, c-format
-msgid "S_decode ==> Please fix the temperature: %f"
-msgstr "S_decode ==> Prosím opravte teplotu: %f"
-#: ../raster/r.sunmask/solpos00.c:989
-#, c-format
-msgid "S_decode ==> Please fix the pressure: %f"
-msgstr "S_decode ==> Prosím opravte tlak: %f"
-#: ../raster/r.sunmask/solpos00.c:992
-#, c-format
-msgid "S_decode ==> Please fix the tilt: %f"
-msgstr "S_decode ==> Prosím opravte sklon: %f"
-#: ../raster/r.sunmask/solpos00.c:995
-#, c-format
-msgid "S_decode ==> Please fix the aspect: %f"
-msgstr "S_decode ==> Prosím opravte expozici: %f"
-#: ../raster/r.sunmask/solpos00.c:998
-#, c-format
-msgid "S_decode ==> Please fix the shadowband width: %f"
-msgstr "S_decode ==> Prosím opravte ¹íøku pásma stínu: %f"
-#: ../raster/r.sunmask/solpos00.c:1001
-#, c-format
-msgid "S_decode ==> Please fix the shadowband radius: %f"
-msgstr "S_decode ==> Prosím opravte radius stinného pásu: %f"
-#: ../raster/r.sunmask/solpos00.c:1004
-#, c-format
-msgid "S_decode ==> Please fix the shadowband sky factor: %f"
-msgstr "S_decode ==> Prosím opravte faktor oblohy stinného pásu: %f"
-#: ../raster/r.sunmask/main.c:126
msgid ""
-"Calculates cast shadow areas from sun position and DEM. Either A: exact sun "
-"position is specified, or B: date/time to calculate the sun position by r."
-"sunmask itself."
+"Parameter 'file' contains reference to <%s> mapset, but mapset parameter <%"
+"s> does not correspond"
msgstr ""
-"Poèítá plnì zastínìné oblasti z polohy Slunce a DMT buï A: je-li "
-"specifikována pøesná pozice Slunce nebo B: pozice je spoèítána samostatnì z "
-"hodnoty datum/èas pomocí r.sunmask."
+"'Soubor' s parametry obsahuje odkaz na <%s> mapset, ale parametry mapsetu <%"
+"s> si neodpovídají "
-#: ../raster/r.sunmask/main.c:136
-msgid "Name of elevation raster map"
-msgstr "Název rastrového souboru s digitálním modelem terénu"
+#: ../general/temp1/main.c:33 ../general/temp/main.c:33
+msgid "Starts GRASS GUI."
+msgstr ""
-#: ../raster/r.sunmask/main.c:144
-msgid "Output raster map having shadows"
-msgstr "Výstupní rastrová mapa obsahující plochy ve stínu"
+#: ../general/temp1/main.c:39 ../general/temp/main.c:39
+#, fuzzy
+msgid "GUI type to be started"
+msgstr "Typy, které budou extrahovány "
-#: ../raster/r.sunmask/main.c:151
-msgid "A: altitude of the sun above horizon, degrees"
-msgstr "A: vý¹ka Slunce nad horizontem, stupnì"
+#: ../general/g.message/main.c:34
+msgid "Prints a message, warning, or fatal error the GRASS way."
+msgstr "Vytiskni zprávu, varování nebo fatální chybu GRASSovským zpùsobem"
-#: ../raster/r.sunmask/main.c:152 ../raster/r.sunmask/main.c:160
-msgid "By_position"
-msgstr "Podle_pozice"
-#: ../raster/r.sunmask/main.c:159
-msgid "A: azimuth of the sun from the north, degrees"
-msgstr "A: azimut Slunce od serveru, stupnì"
-#: ../raster/r.sunmask/main.c:166
-msgid "B: year (1950..2050)"
-msgstr "B: rok (1950..2050)"
-#: ../raster/r.sunmask/main.c:167 ../raster/r.sunmask/main.c:174
-#: ../raster/r.sunmask/main.c:181 ../raster/r.sunmask/main.c:188
-#: ../raster/r.sunmask/main.c:195 ../raster/r.sunmask/main.c:202
-#: ../raster/r.sunmask/main.c:209
-msgid "By_time"
-msgstr "Podle_èasu"
-#: ../raster/r.sunmask/main.c:173
-msgid "B: month (0..12)"
-msgstr "B: mìsíc (0..12)"
-#: ../raster/r.sunmask/main.c:180
-msgid "B: day (0..31)"
-msgstr "B: den (0..31)"
-#: ../raster/r.sunmask/main.c:187
-msgid "B: hour (0..24)"
-msgstr "B: hodina (0..24)"
-#: ../raster/r.sunmask/main.c:194
-msgid "B: minutes (0..60)"
-msgstr "B: minuty (0..60)"
-#: ../raster/r.sunmask/main.c:201
-msgid "B: seconds (0..60)"
-msgstr "B: vteøiny (0..60)"
-#: ../raster/r.sunmask/main.c:208
-msgid ""
-"B: timezone (east positive, offset from GMT, also use to adjust daylight "
-"savings)"
+#: ../general/g.message/main.c:36
+msgid "This module should be used in scripts for messages served to user."
msgstr ""
-"B: èasová zóna (východ kladná, vzdálenost od Greewichského støedního èasu "
-"(GMT), lze také zahrnout letní/zimní èas)"
+"Tento modul by mìl být pou¾it ve skriptech pro zprávy slou¾ící u¾ivateli."
-#: ../raster/r.sunmask/main.c:216
-#, fuzzy
-msgid "East coordinate (point of interest, default: map center)"
-msgstr "východní souøadnice (bod zájmu, výchozí: støed mapy)"
+#: ../general/g.message/main.c:42
+msgid "Print message as GRASS warning"
+msgstr "Vytiskni zprávu jako GRASS varování"
-#: ../raster/r.sunmask/main.c:223
-#, fuzzy
-msgid "North coordinate (point of interest, default: map center)"
-msgstr "severní souøadnice (bod zájmu, výchozí: støed mapy)"
+#: ../general/g.message/main.c:48
+msgid "Print message as GRASS fatal error"
+msgstr "Vytiskni zprávu jako GRASS fatální chyba"
-#: ../raster/r.sunmask/main.c:227
-msgid "Zero is a real elevation"
-msgstr "Nula oznaèuje také vý¹ku nad moøem"
+#: ../general/g.message/main.c:54
+msgid "Print message as GRASS debug message"
+msgstr "Vytiskni zprávu jako GRASS ladící zpráva"
-#: ../raster/r.sunmask/main.c:231
-#, fuzzy
-msgid "Verbose output (also print out sun position etc.)"
-msgstr "roz¹íøený výstup (vytiskne také pozici Slunce atd.)"
+#: ../general/g.message/main.c:60
+msgid "Print message in all but full quiet mode"
+msgstr "Vytiskni zprávu ve ve¹ech módech, kromì tichého"
-#: ../raster/r.sunmask/main.c:235
-#, fuzzy
-msgid "Calculate sun position only and exit"
-msgstr "vypoèítej pouze polohu Slunce a ukonèi se"
+#: ../general/g.message/main.c:66
+msgid "Print message only if in verbose mode"
+msgstr "Vytiskni zprávu jenom v mluvícím módu"
-#: ../raster/r.sunmask/main.c:239
-msgid "Print the sun position output in shell script style"
-msgstr "Vytiskni polohu Slunce ve stylu pou¾itelném pro shell skript"
+#: ../general/g.message/main.c:74
+msgid "Text of the message to be printed"
+msgstr "Text zprávy který bude vytisknut"
-#: ../raster/r.sunmask/main.c:251
-msgid "Using map center coordinates\n"
-msgstr "Pou¾ívám souøadnice støedu mapy\n"
+#: ../general/g.message/main.c:83
+msgid "Level to use for debug messages"
+msgstr "Úroveò pro ladící zprávy"
-#: ../raster/r.sunmask/main.c:260
-msgid "Empty east coordinate specified!"
-msgstr "Nebyla zadána východní souøadnice!"
+#: ../general/g.message/main.c:91
+msgid "Select only one message level."
+msgstr "Vyberte pouze jednu úroveò zpráv."
-#: ../raster/r.sunmask/main.c:262
-msgid "Empty north coordinate specified!"
-msgstr "Nebyla zadána severní souøadnice!"
+#: ../general/g.filename/main.c:40
+msgid "Prints GRASS data base file names."
+msgstr "Vypí¹e jména souborù v GRASS databázi"
-#: ../raster/r.sunmask/main.c:281
-msgid "Either define sun position or location/date/time parameters."
-msgstr "Buï zadejte pozici Slunce nebo parametry místo/datum/èas."
+#: ../general/g.filename/main.c:48
+msgid "Name of an element"
+msgstr "Jméno prvku"
-#: ../raster/r.sunmask/main.c:284
-msgid ""
-"Neither sun position nor east/north, date/time/timezone definition are "
-"complete."
-msgstr ""
-"Ani pozice Slunce ani východ/sever, specifikace datumu/èasu/èasová zóny není "
-"kompletní."
+#: ../general/g.filename/main.c:54
+msgid "Name of a database file"
+msgstr "Jméno databázového souboru"
-#: ../raster/r.sunmask/main.c:289
-#, c-format
-msgid "Calculating sun position... (using solpos (V. %s) from NREL)\n"
-msgstr "Poèítám pozici Slunce... (pou¾ívám solpos (V. %s) z NREL)\n"
+#: ../general/g.filename/main.c:60
+msgid "Name of a mapset (default: current)"
+msgstr "Jméno mapsetu (výchozí: souèasný)"
-#: ../raster/r.sunmask/main.c:294
-msgid ""
-"Using user defined sun azimuth, altitude settings (ignoring eventual other "
-"values)\n"
-msgstr ""
-"Pou¾ívám azimut Slunce zadaný u¾ivatelem, nastavení zem. ¹íøky (ingnoruji "
-"pøípadné dal¹í hodnoty)\n"
-#: ../raster/r.sunmask/main.c:364
+#: ../general/manage/cmd/remove.c:41
#, c-format
-msgid " %d.%02d.%02d, daynum %d, time: %02i:%02i:%02i (decimal time: %f)\n"
-msgstr " %d.%02d.%02d, èíslo dne %d, èas: %02i:%02i:%02i (decimálnì: %f)\n"
+msgid "[%s@%s] is a base map for [%s]. Remove forced."
+msgstr "[%s@%s] je základní mapa pro [%s]. Ma¾u násilím."
-#: ../raster/r.sunmask/main.c:368
+#: ../general/manage/cmd/remove.c:45
#, c-format
-msgid " long: %f, lat: %f, timezone: %f\n"
-msgstr " délka: %f, ¹íøka: %f, èasová zóna: %f\n"
+msgid "[%s@%s] is a base map. Remove reclassed map first: %s"
+msgstr "[%s@%s] je základní mapa. Sma¾te reklasifikovanou mapu %s."
-#: ../raster/r.sunmask/main.c:369
+#: ../general/manage/cmd/remove.c:70 ../general/manage/cmd/remove.c:86
#, c-format
-msgid ""
-" Solar position: sun azimuth: %f,\n"
-" sun angle above horz.(refraction corrected): %f\n"
-msgstr ""
-" Poloha Slunce: Azimut: %f,\n"
-" vý¹ka Slunce nad horizontem. (odraz opraven): %f\n"
+msgid "Removing information about reclassed map from [%s@%s] failed"
+msgstr "Mazání informace o reklasifikované mapì z [%s@%s] selhalo."
-#: ../raster/r.sunmask/main.c:373
-#, c-format
-msgid " Sunrise time (without refraction): %02d:%02d:%02d\n"
-msgstr " Èas východu Slunce (bez refrakce): %02d:%02d:%02d\n"
+#: ../general/manage/cmd/remove.c:112
+msgid "Removes data base element files from the user's current mapset."
+msgstr "Ma¾e datové soubory z aktuálního mapsetu"
-#: ../raster/r.sunmask/main.c:374
+#: ../general/manage/cmd/remove.c:117
+msgid "Force remove"
+msgstr "Násilné vyjmutí"
+#: ../general/manage/cmd/remove.c:131
#, c-format
-msgid " Sunset time (without refraction): %02d:%02d:%02d\n"
-msgstr " Èas západu Slunce (bez refrakce): %02d:%02d:%02d\n"
+msgid "%s file(s) to be removed"
+msgstr "%s soubor(y) urèené ke smazání"
-#: ../raster/r.sunmask/main.c:383
-#, fuzzy
-msgid "Please correct settings"
-msgstr "Opravte prosím nastavení."
+#: ../general/manage/cmd/rename.c:42
+msgid "Renames data base element files in the user's current mapset."
+msgstr "Pøejmenuje data v aktuálním mapsetu"
-#: ../raster/r.sunmask/main.c:400
+#: ../general/manage/cmd/rename.c:57
#, c-format
-msgid "Time (%02i:%02i:%02i) is before sunrise (%02d:%02d:%02d)!\n"
-msgstr "Èas (%02i:%02i:%02i) je pøed východem Slunce (%02d:%02d:%02d)!\n"
+msgid "%s file(s) to be renamed"
+msgstr "%s soubor(y) k pøejmenování"
-#: ../raster/r.sunmask/main.c:403
+#: ../general/manage/cmd/rename.c:77
#, c-format
-msgid "Time (%02i:%02i:%02i) is before sunrise!\n"
-msgstr "Èas (%02i:%02i:%02i) je pøed západem Slunce!\n"
+msgid "%s <%s> not found"
+msgstr "%s <%s> nebyl nalezen"
-#: ../raster/r.sunmask/main.c:405 ../raster/r.sunmask/main.c:414
-msgid "Nothing to calculate. Please verify settings."
-msgstr "Není co poèítat. Ovìøte prosím nastavení."
-#: ../raster/r.sunmask/main.c:410
+#: ../general/manage/cmd/rename.c:82
#, c-format
-msgid "Time (%02i:%02i:%02i) is after sunset (%02d:%02d:%02d)!\n"
-msgstr "Èas (%02i:%02i:%02i) je po západu Slunce (%02d:%02d:%02d)!\n"
+msgid "<%s> already exists in mapset <%s>"
+msgstr "<%s> ji¾ existuje v mapsetu <%s>"
-#: ../raster/r.sunmask/main.c:413
+#: ../general/manage/cmd/rename.c:87 ../general/manage/cmd/copy.c:92
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/opennew.c:11
+#: ../doc/raster/r.example/main.c:113 ../vector/v.to.rast3/main.c:68
+#: ../vector/v.random/main.c:123 ../vector/v.kernel/main.c:232
+#: ../vector/v.in.ogr/main.c:316 ../vector/v.edit/main.c:85
+#: ../vector/v.surf.idw/main.c:121 ../raster/r.neighbors/main.c:185
+#: ../raster/r.mode/main.c:95 ../raster/r.recode/main.c:85
+#: ../raster/r.in.mat/main.c:372 ../raster/r.buffer/main.c:118
+#: ../raster/r.surf.gauss/main.c:74 ../raster/r.texture/main.c:227
+#: ../raster/r.clump/main.c:91 ../raster/r.in.ascii/main.c:208
+#: ../raster/r.water.outlet/legal.c:10 ../raster/r.surf.idw2/main.c:84
+#: ../raster/r.reclass/main.c:80 ../raster/r.random/main.c:136
+#: ../raster/r.random/main.c:141 ../raster/r.walk/main.c:531
+#: ../raster/wildfire/r.spread/main.c:383
+#: ../raster/wildfire/r.spread/main.c:395
+#: ../raster/wildfire/r.spread/main.c:408
+#: ../raster/r.surf.fractal/interface.c:84 ../raster/r.los/main.c:171
+#: ../raster/r.in.gdal/main.c:206 ../raster/r.average/main.c:77
+#: ../raster/r.surf.idw/main.c:112 ../raster/r.to.rast3elev/main.c:474
+#: ../raster/r.slope.aspect/opennew.c:11
+#: ../raster/r.watershed/seg/init_vars.c:360
+#: ../raster/r.watershed/ram/init_vars.c:330
+#: ../raster/r.watershed/shed/com_line.c:194
+#: ../raster/r.watershed/shed/com_line.c:224 ../raster/r.median/main.c:75
+#: ../raster/r.bitpattern/main.c:104 ../raster/r.cost/main.c:324
+#: ../imagery/i.zc/main.c:118 ../imagery/i.ifft/ifftmain.c:107
#, c-format
-msgid "Time (%02i:%02i:%02i) is after sunset!\n"
-msgstr "Èas (%02i:%02i:%02i) je po západu Slunce!\n"
+msgid "<%s> is an illegal file name"
+msgstr "<%s> je neplatné jméno souboru"
-#: ../raster/r.sunmask/main.c:420
-msgid "No map calculation requested. Finished.\n"
-msgstr "Není po¾adována ¾ádný výpoèet mapy. Konèím.\n"
-#: ../raster/r.sunmask/main.c:427
-msgid "You already know the sun position.\n"
-msgstr "Pozice Slunce je ji¾ známa.\n"
-#: ../raster/r.sunmask/main.c:447
-#, fuzzy, c-format
-msgid "Can't open range file for %s"
-msgstr "nemohu otevøít soubor s rozsahem pro %s"
-#: ../raster/r.sunmask/main.c:464
-msgid "Calculating shadows from DEM..."
-msgstr "Poèítám stíny pro DMT..."
-#: ../raster/r.sunmask/main.c:472
-#, fuzzy
-msgid "Can't read row in input elevation map"
-msgstr "nemohu èíst øádek ze vstupní mapy reliéfu"
-#: ../raster/r.his/main.c:66
-msgid ""
-"Generates red, green and blue raster map layers combining hue, intensity and "
-"saturation (HIS) values from user-specified input raster map layers."
-msgstr ""
-"Vytvoøí èervené, zelené a modré rastrové mapy kombinací hodnot odstínu,"
-"intenzity a nasycení (his) z u¾ivatelem zadaných vstupních rastrových map."
-#: ../raster/r.his/main.c:75 ../display/d.his/main.c:76
-msgid "Name of layer to be used for HUE"
-msgstr "Jméno mapy, která má být pou¾ita jako ODSTÍN v systému IHS"
-#: ../raster/r.his/main.c:82 ../display/d.his/main.c:83
-msgid "Name of layer to be used for INTENSITY"
-msgstr "Název mapy, která má být pou¾ita jako INTENZITA systému IHS"
-#: ../raster/r.his/main.c:89 ../display/d.his/main.c:90
-msgid "Name of layer to be used for SATURATION"
-msgstr "Název mapy, která má být pou¾ita jako NASYCENOST v systému IHS"
-#: ../raster/r.his/main.c:96
-msgid "Name of output layer to be used for RED"
-msgstr "Název výstupní mapy, která bude pou¾ita jako ÈERVENÁ v systému RGB"
-#: ../raster/r.his/main.c:103
-msgid "Name of output layer to be used for GREEN"
-msgstr "Název výstupní mapy, která bude pou¾ita jako ZELENÁ v systému RGB"
-#: ../raster/r.his/main.c:110
-msgid "Name of output layer to be used for BLUE"
-msgstr "Název výstupní mapy, která bude pou¾ita jako MODRÁ v systému RGB"
-#: ../raster/r.his/main.c:114 ../display/d.his/main.c:101
-msgid "Respect NULL values while drawing"
-msgstr "Pøi vykreslování respektuj NULLové hodnoty"
-#: ../raster/r.his/main.c:143 ../raster/r.his/main.c:165
-#: ../raster/r.his/main.c:193 ../raster/r.out.ppm3/main.c:128
-#: ../raster/r.composite/main.c:174 ../display/d.rast.edit/cell.c:51
-#: ../display/d.histogram/main.c:160 ../display/d.rast.num/number.c:281
-#: ../display/d.legend/main.c:255 ../display/d.rast/display.c:22
-#: ../display/d.rgb/main.c:110 ../display/d.his/main.c:152
-#: ../display/d.his/main.c:173 ../display/d.his/main.c:201
+#: ../general/manage/cmd/rename.c:92
#, c-format
-msgid "Color file for <%s> not available"
-msgstr "Soubor s tabulkou barev pro <%s> není dostupný"
+msgid "%s=%s,%s: files are the same, no rename required"
+msgstr "%s=%s,%s: soubory jsou stejné a není potøeba je pøejmenovávat"
-#: ../raster/r.his/main.c:254
-msgid "Error reading 'hue' map"
-msgstr "Chyba pøi ètení mapy odstínu (hue)"
+#: ../general/manage/cmd/rename.c:103
+msgid "Renaming reclass maps"
+msgstr "Pøejmenování reklasifikované mapy"
-#: ../raster/r.his/main.c:256
-msgid "Error reading 'intensity' map"
-msgstr "Chyba pøi ètení mapy intenzity"
-#: ../raster/r.his/main.c:258
-msgid "Error reading 'saturation' map"
-msgstr "Chyba pøi ètení mapy nasycení (saturation))"
-#: ../raster/r.topmodel/main.c:58
-msgid "Simulates TOPMODEL which is a physically based hydrologic model."
-msgstr "Simuluje TOPMODEL, co¾ je dynamický hydrologický model."
-#: ../raster/r.topmodel/main.c:64
-msgid "(i) Basin map created by r.water.outlet (MASK)"
-msgstr "(i) Mapa povodí vytvoøená r.water.outlet (MASKa)"
-#: ../raster/r.topmodel/main.c:72
-msgid "(i) Elevation map"
-msgstr "(i) Digitální model terénu"
-#: ../raster/r.topmodel/main.c:80
-msgid "(o) Depressionless elevation map"
-msgstr "(o) Mapa vý¹ek zbavená depresí"
-#: ../raster/r.topmodel/main.c:88
-msgid "(o) Direction map for depressionless elevation map"
-msgstr "(o) Mapa smìrù s mapou vý¹ek bez depresí"
-#: ../raster/r.topmodel/main.c:96
-msgid "(o/i) Basin elevation map (MASK applied)"
-msgstr "(i/o) Mapa vý¹ek v povodí (MASKa aplikována)"
-#: ../raster/r.topmodel/main.c:104
-msgid "(o) Topographic index ln(a/tanB) map (MASK applied)"
-msgstr "(i/o) Mapa topografického indexu ln(a/tanB) (MASKa aplikována)"
-#: ../raster/r.topmodel/main.c:112
-msgid "(i) Number of topographic index classes"
-msgstr "(i) Poèet tøíd topografického indexu"
-#: ../raster/r.topmodel/main.c:120
-msgid "(o/i) Topographic index statistics file"
-msgstr "(i/o) Soubor se statistikou topografického indexu"
-#: ../raster/r.topmodel/main.c:127
-msgid "(i) TOPMODEL Parameters file"
-msgstr "(i) Soubor s parametry pro TOPMODEL"
-#: ../raster/r.topmodel/main.c:134
-msgid "(i) Rainfall and potential evapotranspiration data file"
-msgstr "(i) Soubor srá¾ek a potenciální evapotranspirací"
-#: ../raster/r.topmodel/main.c:141
-msgid "(o) Output file"
-msgstr "(o) Výstupní soubor"
-#: ../raster/r.topmodel/main.c:148
-msgid "(i) OPTIONAL Observed flow file"
-msgstr "(i) VOLITELNÉ pozorované dráhy odtoku"
-#: ../raster/r.topmodel/main.c:155
-msgid "(i) OPTIONAL Output for given time step"
-msgstr "(i) VOLITELNÉ Výstup pro danou èasovou znaèku"
-#: ../raster/r.topmodel/main.c:162
-msgid "(i) OPTIONAL Output for given topographic index class"
-msgstr "(i) VOLITELNÉ Výstup pro danou tøídu topografického indexu"
-#: ../raster/r.topmodel/main.c:171
-msgid "Input data given for (o/i)"
-msgstr "Vstupní data dána (i/o)"
-#: ../raster/r.bilinear/main.c:43
-msgid "Bilinear interpolation utility for raster map layers."
-msgstr "Nástroj pro bilineární interpolaci rastrových map."
-#: ../raster/r.bilinear/main.c:52 ../raster/r.bilinear/main.c:58
+#: ../general/manage/cmd/copy.c:40
msgid ""
-"Specific input value to be assigned to the north and/or south poles for "
-"longitude-latitude grids"
+"Copies available data files in the user's current mapset search path and "
+"location to the appropriate element directories under the user's current "
+"mapset."
msgstr ""
-"Specifická hodnota vstupu, která bude pøiøa¾ena severnímu a/nebo ji¾nímu "
-"pólu pro rastrové mapy v systému zem. délka/¹íøka"
+"Kopíruje dostupná data z u¾ivatelem zadaného mapsetu a location do "
+"aktuálního mapsetu."
-#: ../raster/r.bilinear/main.c:64
-msgid "This module is deprecated. Please use 'r.resamp.interp' instead."
-msgstr "Tento modul je zastaralý. Prosím, pou¾ijte 'r.stats.interp'."
-#: ../raster/r.kappa/calc_kappa.c:33
+#: ../general/manage/cmd/copy.c:57
#, c-format
-msgid "Cannot open file <%s> to write kappa and relevant parameters"
-msgstr "Nelze otevøít soubor <%s> pro zapsání kappa a dal¹ích parametrù"
+msgid "%s file(s) to be copied"
+msgstr "%s soubor(y) ke kopírování"
-#: ../raster/r.kappa/prt_hdr.c:18
+#: ../general/manage/cmd/copy.c:75
#, c-format
-msgid "Cannot open file <%s> to write header"
-msgstr "nemohu otevøít soubor <%s> abych zapsal hlavièku"
+msgid "<%s> not found"
+msgstr "<%s> nenalezen"
-#: ../raster/r.kappa/main.c:51
-msgid ""
-"Calculate error matrix and kappa parameter for accuracy assessment of "
-"classification result."
-msgstr ""
-"Spoèítá chybovou matici a parametr kappa pro evaluaci výsledkù klasifikace."
-#: ../raster/r.kappa/main.c:57
-msgid "Name of raster map containing classification result"
-msgstr "Název existující rastrové mapy obsahující výsledky klasifikace"
-#: ../raster/r.kappa/main.c:61
-msgid "Name of raster map containing reference classes"
-msgstr "Název rastrové mapy obsahující referenèní tøídy"
-#: ../raster/r.kappa/main.c:65
-msgid "Name for output file containing error matrix and kappa"
-msgstr "Název výstupního souboru obsahujícího chybovou matici a parametr kappa"
-#: ../raster/r.kappa/main.c:71
-msgid "Title for error matrix and kappa"
-msgstr "Titulek pro chybovou matici a parametr kappa"
-#: ../raster/r.kappa/main.c:76
-msgid "Wide report"
-msgstr "Rozsáhlá zpráva"
-#: ../raster/r.kappa/main.c:77
-msgid "132 columns (default: 80)"
-msgstr "132 sloupcù (výchozí: 80)"
-#: ../raster/r.kappa/main.c:86
-msgid "No header in the report"
-msgstr "Zpráva bez hlavièky"
-#: ../raster/r.kappa/main.c:101 ../imagery/i.cca/main.c:116
+#: ../general/manage/cmd/copy.c:81
#, c-format
-msgid "Illegal output file name <%s>"
+msgid "%s=%s,%s: files are the same, no copy required"
+msgstr "%s=%s,%s: soubory jsou stejné, není tøeba kopírovat"
-#: ../raster/r.kappa/main.c:113 ../raster/r.out.ppm/main.c:80
-#: ../raster/r.mfilter.fp/main.c:107 ../raster/r.mfilter/main.c:100
-msgid ""
-"The '-q' flag is superseded and will be removed in future. Please use '--"
-"quiet' instead"
-msgstr ""
-"Pøepínaè '-q' je zastaralý a bude v budoucnosti odstranìn. prosím, peou¾ijte "
-"pøepínaè '--quiet'."
-#: ../raster/r.kappa/prt_mat.c:39
+#: ../general/manage/cmd/copy.c:87
#, c-format
-msgid "Cannot open file <%s> to write cats and counts (error matrix)"
-msgstr "Nelze otevøít soubor <%s> pro zápis kategorií a poètù (chybové matice)"
+msgid "<%s> already exists"
+msgstr "<%s> ji¾ existuje"
-#: ../raster/r.median/main.c:46
+#: ../general/manage/cmd/list.c:42
msgid ""
-"Finds the median of values in a cover map within areas assigned the same "
-"category value in a user-specified base map."
+"Lists available GRASS data base files of the user-specified data type to "
+"standard output."
msgstr ""
-"Nalezne median hodnot z pøekrývající mapy, která bude rozdìlena podle ploch "
-"se stejnými hodnotami z pokladové mapy."
+"Seznam dostupných souborù u¾ivatelem zadaného typu dat na standardní výstup"
-#: ../raster/r.median/main.c:52
-msgid "Name of base raster map"
-msgstr "Název základní rastrové mapy"
+#: ../general/manage/cmd/list.c:72
+msgid "Mapset to list (default: current search path)"
+msgstr "mapset, ze kterého má být seznam udìlán (výchozí: aktuální)"
-#: ../raster/r.median/main.c:69
-#, fuzzy, c-format
-msgid "Base raster map <%s> not found"
-msgstr "vstupní rastr s expozicí <%s> nebyl nalezen"
+#: ../general/manage/cmd/list.c:77
+msgid "Verbose listing (also list map titles)"
+msgstr "upovídaný výstup (vypi¹ také titulky map)"
-#: ../raster/r.median/main.c:77
+#: ../general/g.pnmcomp/main.c:38
#, c-format
-msgid "Base map and output map <%s> must be different"
-msgstr "Základní mapa a výstupní <%s> mapa musí být rùzné"
+msgid "Invalid color: %s"
+msgstr "Chybná barva :%s"
-#: ../raster/r.median/main.c:80
-#, c-format
-msgid "Unable to read category labels of raster map <%s>"
-msgstr "Nelze èíst soubor se ¹tíky kategorí mapy <%s>"
+#: ../general/g.pnmcomp/main.c:56
+msgid "Error reading PPM file"
+msgstr "Chyba pøi ètení souboru PPM"
-#: ../raster/r.resamp.rst/main.c:157
-#, fuzzy
-msgid ""
-"Reinterpolates and optionally computes topographic analysis from input "
-"raster map to a new raster map (possibly with different resolution) using "
-"regularized spline with tension and smoothing."
-msgstr ""
-"Reinterpoluje a spoèítá topografickou analýzu ze vstupního rastrového "
-"souborudo nové rastrové mapy (volitelnì s novým rozli¹eném) za pou¾ití "
-"regularizovaného spline s tenzí a vyhlezním."
+#: ../general/g.pnmcomp/main.c:72 ../general/g.pnmcomp/main.c:77
+#: ../general/g.pnmcomp/main.c:87 ../general/g.pnmcomp/main.c:144
+#: ../general/g.pnmcomp/main.c:157
+msgid "Invalid PPM file"
+msgstr "©patný soubor PPM"
-#: ../raster/r.resamp.rst/main.c:173
-msgid "Desired east-west resolution"
-msgstr "Po¾adované rozli¹ení východ-západ"
-#: ../raster/r.resamp.rst/main.c:179
-msgid "Desired north-south resolution"
-msgstr "Po¾adované rozli¹ení sever-jih"
-#: ../raster/r.resamp.rst/main.c:186
-msgid "Output z-file (elevation) map"
-msgstr "Výstupní z-soubor nadmoøských vý¹ek"
-#: ../raster/r.resamp.rst/main.c:193
-msgid "Output slope map (or fx)"
-msgstr "Výstupní mapa sklonu svahu (nebo fx)"
-#: ../raster/r.resamp.rst/main.c:201
-msgid "Output aspect map (or fy)"
-msgstr "Výstupní mapa expozice (nebo fy)"
-#: ../raster/r.resamp.rst/main.c:209
-msgid "Output profile curvature map (or fxx)"
-msgstr "Výstupní mapa profilové køivosti (nebo fxx)"
-#: ../raster/r.resamp.rst/main.c:217
-msgid "Output tangential curvature map (or fyy)"
-msgstr "Název výstupního souboru tangenciálních køivostí (nebo fyy)"
-#: ../raster/r.resamp.rst/main.c:225
-msgid "Output mean curvature map (or fxy)"
-msgstr "Název rastrové mapy støední køivosti (nebo fxy)"
-#: ../raster/r.resamp.rst/main.c:233
-msgid "Name of raster map containing smoothing"
-msgstr "Název rastrového souboru obsahujícího vyhlazení"
-#: ../raster/r.resamp.rst/main.c:241
-msgid "Name of raster map to be used as mask"
-msgstr "Název rastrové mapy, která má být pou¾ita jako maska"
-#: ../raster/r.resamp.rst/main.c:249
-msgid "Rows/columns overlap for segmentation"
-msgstr "Pøekryv øádkù/sloupcù pro segmentaci"
-#: ../raster/r.resamp.rst/main.c:257
-msgid "Multiplier for z-values"
-msgstr "Multiplikátor pro hodnoty z"
-#: ../raster/r.resamp.rst/main.c:265
-msgid "Spline tension value"
-msgstr "Hodnota pnutí køivek"
-#: ../raster/r.resamp.rst/main.c:272
-msgid "Anisotropy angle (in degrees)"
-msgstr "Úhel anizotropie (ve stupních)"
-#: ../raster/r.resamp.rst/main.c:273 ../raster/r.resamp.rst/main.c:280
-#: ../vector/v.surf.rst/main.c:358 ../vector/v.surf.rst/main.c:365
-msgid "Anisotropy"
-msgstr "Anisotropie"
-#: ../raster/r.resamp.rst/main.c:279 ../vector/v.surf.rst/main.c:364
-msgid "Anisotropy scaling factor"
-msgstr "Míra anisotropie"
-#: ../raster/r.resamp.rst/main.c:284
-msgid "Use dnorm independent tension"
-msgstr "Pou¾ij dnorm nezávislou tenzi"
-#: ../raster/r.resamp.rst/main.c:289 ../vector/v.surf.rst/main.c:198
-msgid "Output partial derivatives instead of topographic parameters"
-msgstr "Výstup ve formì parciálních derivací místo topografických parametrù"
-#: ../raster/r.resamp.rst/main.c:296 ../general/g.setproj/main.c:108
-msgid "Retrieving and setting region failed"
-msgstr "Obnovení a nastavené regionu selhalo"
-#: ../raster/r.resamp.rst/main.c:324
-msgid "Cannot read ew_res value"
-msgstr "Nelze èíst hodnotu ew_res"
-#: ../raster/r.resamp.rst/main.c:327
-msgid "Cannot read ns_res value"
-msgstr "Nelze èíst hodnotu ns_res"
-#: ../raster/r.resamp.rst/main.c:330
-msgid "Invalid value for tension"
-msgstr "©patná hodnota pro pnutí"
-#: ../raster/r.resamp.rst/main.c:333
-msgid "Invalid value for zmult"
-msgstr "Neplatná hodnota pro zmult"
-#: ../raster/r.resamp.rst/main.c:336
-msgid "Invalid value for overlap"
-msgstr "©patná hodnota pro pøekryv."
-#: ../raster/r.resamp.rst/main.c:340
-msgid "Invalid value for theta"
-msgstr "©patná hodnota pro theta"
-#: ../raster/r.resamp.rst/main.c:344
-msgid "Invalid value for scalex"
-msgstr "Neplatná hodnota pro scalex"
-#: ../raster/r.resamp.rst/main.c:346
-msgid "When using anisotropy both theta and scalex must be specified"
-msgstr "Pøi pou¾ití anisotropie musí být zadány theta i scalex"
-#: ../raster/r.resamp.rst/main.c:369 ../vector/v.surf.rst/main.c:468
-msgid "Not enough memory for az"
-msgstr "Pro az není dostatek pamìti"
-#: ../raster/r.resamp.rst/main.c:374 ../vector/v.surf.rst/main.c:473
-msgid "Not enough memory for adx"
-msgstr "Pro adx není dostatek pamìti"
-#: ../raster/r.resamp.rst/main.c:378 ../vector/v.surf.rst/main.c:477
-msgid "Not enough memory for ady"
-msgstr "Pro ady není dostatek pamìti"
-#: ../raster/r.resamp.rst/main.c:383 ../vector/v.surf.rst/main.c:482
-msgid "Not enough memory for adxx"
-msgstr "Pro adxx není dostatek pamìti"
-#: ../raster/r.resamp.rst/main.c:387 ../vector/v.surf.rst/main.c:486
-msgid "Not enough memory for adyy"
-msgstr "Pro adyy není dostatek pamìti"
-#: ../raster/r.resamp.rst/main.c:391 ../vector/v.surf.rst/main.c:490
-msgid "Not enough memory for adxy"
-msgstr "Pro adxy není dostatek pamìti"
-#: ../raster/r.resamp.rst/main.c:411
+#: ../general/g.pnmcomp/main.c:101
#, c-format
-msgid "[%s]: Map is the wrong resolution"
-msgstr "[%s]: Mapa je ve ¹patném rozli¹ení"
+msgid "File <%s> not found"
+msgstr "Soubor <%s> nebyl nalezen"
-#: ../raster/r.resamp.rst/main.c:419
-msgid "Smoothing values can not be negative or NULL"
-msgstr "Hodnota vyhlazení nesmí být negativní èi NULL"
+#: ../general/g.pnmcomp/main.c:110
+msgid "Expecting PPM but got PGM"
+msgstr "Oèekávám PPM ale dostal jsem PGM"
-#: ../raster/r.resamp.rst/main.c:434
-msgid "Input map resolution differs from current region resolution!"
-msgstr "Rozli¹ení rastrové mapy je rùzné od aktuálního rozli¹ení regionu!"
+#: ../general/g.pnmcomp/main.c:115
+msgid "Expecting PGM but got PPM"
+msgstr "Oèekávám PGM ale dostal jsem PPM"
-#: ../raster/r.resamp.rst/main.c:454
-msgid "Processing all selected output files will require"
-msgstr "Zpracování v¹ech vybraných vektorových vrstev bude vy¾adovat"
-#: ../raster/r.resamp.rst/main.c:455
+#: ../general/g.pnmcomp/main.c:118
#, c-format
-msgid "%d bytes of disk space for temp files."
-msgstr "%d bytù prostoru na disku pro doèasné soubory."
+msgid "Invalid magic number: 'P%c'"
+msgstr "Chybné magické èíslo: 'P%c'"
-#: ../raster/r.resamp.rst/main.c:480
-#, c-format
-msgid "Cannot get row %d (error = %d)"
-msgstr "Nelze naèíst øádek %d (chyba = %d)"
+#: ../general/g.pnmcomp/main.c:134 ../general/g.pnmcomp/main.c:152
+msgid "Invalid PGM file"
+msgstr "Chybný soubor PGM"
-#: ../raster/r.resamp.rst/main.c:489
-msgid "Maximum value of a raster map is NULL."
-msgstr "Maximální hodnota rastru je NULL"
-#: ../raster/r.resamp.rst/main.c:516
-msgid "Temporarily changing the region to desired resolution ..."
-msgstr "Doèasnì mìním region na po¾adované rozli¹ení"
-#: ../raster/r.resamp.rst/main.c:522
-msgid "Changing back to the original region ..."
-msgstr "Nastavuje zpìt pùvodní rozli¹ení"
-#: ../raster/r.resamp.rst/main.c:524
-msgid "Cannot set region to back to the initial region !!!"
-msgstr "Nelze nastavit region zpìt na poèáteèní rozli¹ení!!!"
-#: ../raster/r.resamp.rst/main.c:528 ../raster/r.slope.aspect/main.c:609
-#: ../raster/r.resample/main.c:137 ../vector/v.surf.rst/main.c:566
-#: ../vector/v.surf.rst/main.c:712
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:609
-msgid "Percent complete: "
-msgstr "Hotovo procent:"
-#: ../raster/r.resamp.rst/main.c:540
+#: ../general/g.pnmcomp/main.c:262 ../general/g.pnmcomp/main.c:280
+#: ../display/d.nviz/main.c:202 ../vector/v.out.vtk/main.c:163
+#: ../vector/v.out.ascii/out.c:137 ../raster/r.out.ascii/main.c:173
+#: ../raster/r.cats/main.c:170 ../raster/r.profile/main.c:157
+#: ../raster/r.out.ppm3/main.c:147 ../raster/r.out.arc/main.c:133
#, c-format
-msgid "dnorm in mainc after grid before out1= %f"
-msgstr "dnorm v mainc po grid pøed out1=%f"
+msgid "Unable to open file <%s>"
+msgstr "Nelze otevøít soubor <%s>"
-#: ../raster/r.resamp.rst/main.c:557
-#, c-format
-msgid "dnorm in mainc after grid before out2= %f"
-msgstr "dnorm v mainc po grid pøed out2=%f"
+#: ../general/g.pnmcomp/main.c:267
+msgid "Error writing PPM file"
+msgstr "Chyba pøi zápisu souboru PPM"
-#: ../raster/r.resamp.rst/main.c:607 ../vector/v.surf.rst/main.c:582
-msgid "Not enough memory for zero_array_cell"
-msgstr "Pro zero_array_cell není dostatek pamìti"
+#: ../general/g.pnmcomp/main.c:285
+msgid "Error writing PGM file"
+msgstr "Chyba pøi zápisu souboru PGM"
-#: ../raster/r.resamp.rst/main.c:621 ../raster/r.resamp.rst/main.c:633
-#: ../raster/r.resamp.rst/main.c:645 ../raster/r.resamp.rst/main.c:658
-#: ../raster/r.resamp.rst/main.c:670 ../raster/r.resamp.rst/main.c:682
-#: ../vector/v.surf.rst/main.c:593 ../vector/v.surf.rst/main.c:601
-#: ../vector/v.surf.rst/main.c:609 ../vector/v.surf.rst/main.c:618
-#: ../vector/v.surf.rst/main.c:626 ../vector/v.surf.rst/main.c:634
-msgid "Not enough disk space -- cannot write files"
-msgstr "Plné místo na disku -- nemohu zapsat soubory"
+#: ../general/g.pnmcomp/main.c:311
+msgid "Names of input files"
+msgstr "Jména vstupních souborù"
-#: ../raster/r.stats/main.c:89
-msgid "Generates area statistics for raster map layers."
-msgstr "Vytvoøí statistiku ploch pro rastrové mapy."
+#: ../general/g.pnmcomp/main.c:318
+msgid "Names of mask files"
+msgstr "Jména souborù s maskou"
-#: ../raster/r.stats/main.c:99
-msgid "Raster input maps(s)"
-msgstr "Vstupní rastrové mapy"
+#: ../general/g.pnmcomp/main.c:325
+msgid "Layer opacities"
+msgstr "Prùhlednost vrstev"
-#: ../raster/r.stats/main.c:123
-msgid "Output file name"
-msgstr "Název výstupního souboru"
+#: ../general/g.pnmcomp/main.c:331
+msgid "Name of output file"
+msgstr "Jméno výstpuního souboru"
-#: ../raster/r.stats/main.c:140
-msgid "One cell (range) per line"
-msgstr "Jedna buòka (rozsah) na øádek"
+#: ../general/g.pnmcomp/main.c:338
+msgid "Name of output mask file"
+msgstr "Jméno výstupního souboru s maskou"
-#: ../raster/r.stats/main.c:144
-msgid "Print averaged values instead of intervals"
-msgstr "Vytiskni prùmìrné hodnoty namísto intervalù"
+#: ../general/g.pnmcomp/main.c:345
+msgid "Image width"
+msgstr "©íøka obrázku"
-#: ../raster/r.stats/main.c:148
-msgid "Print area totals"
-msgstr "Vytiskni celkový rozsah ploch"
+#: ../general/g.pnmcomp/main.c:351
+msgid "Image height"
+msgstr "Vý¹ka obrázku"
-#: ../raster/r.stats/main.c:152
-msgid "Print cell counts"
-msgstr "Vytiskni poèty bunìk"
+#: ../general/g.pnmcomp/main.c:356 ../display/d.path/main.c:114
+#: ../vector/v.label.sa/main.c:170 ../vector/v.label/main.c:187
+#: ../vector/v.lrs/v.lrs.label/main.c:221
+msgid "Background color"
+msgstr "Barva pozadí"
-#: ../raster/r.stats/main.c:156
-msgid "Print APPROXIMATE percents (total percent may not be 100%)"
-msgstr "Vypi¹ PØIBLI®NÁ procenta (suma nemusí být 100%)"
-#: ../raster/r.stats/main.c:160
-msgid "Print category labels"
-msgstr "Vytiskni oznaèení kategorií"
-#: ../raster/r.stats/main.c:168
-msgid "Suppress reporting of NULLs when all values are NULL"
-msgstr "Potlaè výpis NULL, pokud jsou v¹echny hodnoty NULL"
-#: ../raster/r.stats/main.c:172
-msgid "Print grid coordinates (east and north)"
-msgstr "Vytiskni souøadnice rastrového souboru (východní a severní)"
-#: ../raster/r.stats/main.c:176
-msgid "Print x and y (column and row)"
-msgstr "Vytiskni x a y (sloupec a øádek)"
-#: ../raster/r.stats/main.c:184
-msgid "Print raw indexes of fp ranges (fp maps only)"
-msgstr ""
-"Vytiskni neupravené indexy rozsahu hodnot s plovoucí desetinnou èárkou "
-"(pouze mapy s plovoucí desetinnou èárkou)"
-#: ../raster/r.stats/main.c:205
-msgid "nsteps must be greater than zero; using nsteps=255"
-#: ../raster/r.stats/main.c:253 ../raster/r.series/main.c:160
-msgid "Raster map not found"
-msgstr "Rastrová mapa nebyla nalezena"
-#: ../raster/r.stats/main.c:278
-#, c-format
+#: ../general/g.mapsets/main_cmd.c:51
msgid ""
-"%s: -i means read %s as integer! -C flag and/or nsteps option will be ignored"
+"Modifies the user's current mapset search path, affecting the user's access "
+"to data existing under the other GRASS mapsets in the current location."
msgstr ""
-"%s: -i znamená, ¾e %s bude naètena jako celoèíselná mapa! Pøepínaè -C a "
-"volba nsteps budou ignorovány"
+"Mìní nastavení aktuálního mapsetu, mìní pøístup k datùm umístìnýchv jiných "
+"mapsetech GRASSu v aktuální location."
-#: ../raster/r.stats/main.c:295
-#, c-format
-msgid ""
-"%s: cats for %s are either missing or have no explicit labels. Using nsteps=%"
-"d"
-msgstr ""
-"%s: kategorie pro %s buï chybí nebo nemají ¾ádné ¹títky. Pou¾ívám nsteps=%d"
+#: ../general/g.mapsets/main_cmd.c:60
+msgid "Name(s) of existing mapset(s)"
+msgstr "Jméno(a) existující(ch) mapset(ù)"
-#: ../raster/r.stats/main.c:299
-#, c-format
-msgid ""
-"%s: -C flag was given, using cats fp ranges of %s, ignoring nsteps option"
-msgstr ""
-"%s: Pøepínaè -C byl zadán, pou¾ívám hranièní hodnoty s plovoucí desetinnou "
-"èárkou z %s, ignoruji volbu nsteps"
+#: ../general/g.mapsets/main_cmd.c:67
+msgid "Name(s) of existing mapset(s) to add to search list"
+msgstr "Název existující(ch) rastrové(ých) map(y) pro dotazování."
-#: ../raster/r.stats/main.c:304
-#, c-format
-msgid "%s: can't read fp range for [%s]"
-msgstr "%s: nemohu èíst hranièní hodnoty pro [%s]"
-#: ../raster/r.stats/main.c:322 ../raster/r.recode/read_rules.c:35
-#, fuzzy, c-format
-msgid "Unable to read range for map <%s>"
-msgstr "Nelze èíst rozsah mapy %s"
-#: ../raster/r.surf.random/main.c:43
-msgid ""
-"Produces a raster map layer of uniform random deviates whose range can be "
-"expressed by the user."
-msgstr ""
-"Vytvoøí rastrovou mapu uniformních náhodných odchylek, jejich¾ rozsah mù¾e "
-"být zadán u¾ivatelem."
-#: ../raster/r.surf.random/main.c:51
-msgid "Minimum random value"
-msgstr "Minimální náhodná hodnota"
-#: ../raster/r.surf.random/main.c:57
-msgid "Maximum random value"
-msgstr "Maximální náhodná hodnota"
-#: ../raster/r.surf.random/main.c:63
-msgid "Create an integer map"
-msgstr "Vytvoøit celoèíselnou mapu"
-#: ../raster/r.in.xyz/main.c:151
+#: ../general/g.mapsets/main_cmd.c:74
#, fuzzy
-msgid "raster, import, LIDAR"
-msgstr "rastr, import"
+msgid "Name(s) of existing mapset(s) to remove from search list"
-#: ../raster/r.in.xyz/main.c:153
-msgid ""
-"Create a raster map from an assemblage of many coordinates using univariate "
-"statistics."
-msgstr ""
-"Vytvoøí rastrovou mapu smontováním více souøadnic za pomoci univariantní "
-"statistiky"
+#: ../general/g.mapsets/main_cmd.c:78
+msgid "List all available mapsets"
+msgstr "Vypi¹ v¹echny dostupné mapsety"
-#: ../raster/r.in.xyz/main.c:156
-msgid "ASCII file containing input data (or \"-\" to read from stdin)"
-msgstr "ASCII soubor obsahující vstupní data (\"-\" pro standardní vstup)"
+#: ../general/g.mapsets/main_cmd.c:82
+msgid "Print current mapset search path"
+msgstr "Vypi¹ aktuální cestu k mapsetùm"
-#: ../raster/r.in.xyz/main.c:164
-msgid "Statistic to use for raster values"
-msgstr "Statistika pou¾itá pro rastrové hodnoty"
+#: ../general/g.mapsets/main_cmd.c:104 ../general/g.mapsets/main_cmd.c:131
+#, c-format
+msgid "Mapset <%s> not found"
+msgstr "Mapset <%s> nebyl nalezen"
-#: ../raster/r.in.xyz/main.c:167 ../raster/r.in.xyz/main.c:176
-#: ../vector/v.out.ogr/main.c:111 ../vector/v.out.ogr/main.c:124
-#: ../vector/v.out.ogr/main.c:133 ../vector/v.out.ogr/main.c:142
-#, fuzzy
-msgid "Output"
-msgstr "Výstup:"
+#: ../general/g.mapsets/main_cmd.c:173
+msgid "Cannot open SEARCH_PATH for write"
+msgstr "Nelze otevøít SEARCH_PATH pro zápis"
-#: ../raster/r.in.xyz/main.c:175 ../raster/r.in.arc/main.c:78
-msgid "Storage type for resultant raster map"
-msgstr "Typ ulo¾ení výsledné rastrové mapy"
+#: ../general/g.version/main.c:34
+msgid "Displays version and copyright information."
+msgstr "Zobrazí verzi a informace o licenci a autorských právech"
-#: ../raster/r.in.xyz/main.c:179 ../raster/r.in.xyz/main.c:188
-#: ../raster/r.in.xyz/main.c:197 ../raster/r.in.xyz/main.c:206
-#: ../raster/r.in.xyz/main.c:214 ../vector/v.edit/cmd/args.c:98
-#: ../vector/v.edit/cmd/args.c:211 ../vector/v.out.ogr/main.c:96
-#: ../vector/v.out.ogr/main.c:114
-#, fuzzy
-msgid "Input"
-msgstr "Vstup:"
+#: ../general/g.version/main.c:38
+msgid "Print the copyright message"
+msgstr "Vytiskni také zprávu o autorských právech"
-#: ../raster/r.in.xyz/main.c:187
-msgid "Column number of x coordinates in input file (first column is 1)"
-msgstr ""
-"Èíslo sloupce pou¾itého jako souøadnice x ve vstupním souboru (první sloupec "
-"je 1)"
+#: ../general/g.version/main.c:42
+msgid "Print the GRASS build information"
+msgstr "Vypi¹ informace o zpùsobu sestavení GRASSu"
-#: ../raster/r.in.xyz/main.c:196
-msgid "Column number of y coordinates in input file"
-msgstr "Èíslo sloupeèku pro souøadnice y ve vstupním souboru"
+#: ../general/g.gui/main.c:35
+msgid "general, gui"
+msgstr "obecné, grafické prostøedí"
-#: ../raster/r.in.xyz/main.c:205
-msgid "Column number of data values in input file"
-msgstr "Èíslo sloupeèku hodnot bunìk ve vstupním souboru"
+#: ../general/g.gui/main.c:37
+msgid "Launches a GRASS graphical user interface (GUI) session."
+msgstr "Spu¹tí se GRASS grafické prostøedí."
-#: ../raster/r.in.xyz/main.c:213
-msgid "Filter range for z data (min,max)"
-msgstr "Rozsah filtru pro z data: (min,max)"
+#: ../general/g.gui/main.c:43
+msgid "GUI type"
+msgstr "Typ grafického prostøedí"
-#: ../raster/r.in.xyz/main.c:222 ../raster/r.cost/main.c:198
-#: ../raster/r.walk/main.c:258
-msgid "Percent of map to keep in memory"
-msgstr "Èást mapy v procentech, která má být uchována v pamìti"
-#: ../raster/r.in.xyz/main.c:229
-#, fuzzy
-msgid "pth percentile of the values"
-msgstr "Výstupní mapa s modrým kanálem"
-#: ../raster/r.in.xyz/main.c:237
+#: ../general/g.gui/main.c:44
msgid ""
-"Discard <trim> percent of the smallest and <trim> percent of the largest "
-"observations"
+"tcltk;Tcl/Tk based GUI - GIS Manager (gis.m);oldtcltk;Old Tcl/Tk based GUI - "
+"Display Manager (d.m);wxpython;wxPython based next generation GUI"
msgstr ""
+"tcltk;Tcl/Tk grafické prostøedí - GIS Manager (gis.m);oldtcltk;Strar¹í Tcl/"
+"Tk grafické prostøedí - Display Manager (d.m);wxpython; Grafické prostøedí "
+"budoucí generace zalo¾ené na WxPyton"
-#: ../raster/r.in.xyz/main.c:241
-msgid "Scan data file for extent then exit"
-msgstr "Projdi soubor, nalezni okrajové hodnoty a ukonèi se"
+#: ../general/g.gui/main.c:59
+msgid "Name of workspace file"
+msgstr "Jméno souboru pracovního prostøedí"
-#: ../raster/r.in.xyz/main.c:245
-msgid "In scan mode, print using shell script style"
-msgstr "Ve scan módu tiskni ve stylu pro shell skript"
+#: ../general/g.gui/main.c:63
+msgid "Update default GUI setting"
+msgstr "Aktualizovat základní nastavení grafického prostøedí"
-#: ../raster/r.in.xyz/main.c:269
-msgid "Please specify a reasonable column number."
-msgstr "Prosím, zadejte pøijatelné èíslo sloupce."
-#: ../raster/r.in.xyz/main.c:364
-#, fuzzy
-msgid "Unable to calculate percentile without the pth option specified!"
-msgstr "Nelze vypoèítat výstupní vektory"
-#: ../raster/r.in.xyz/main.c:377
-msgid "Unable to calculate trimmed mean without the trim option specified!"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:438 ../raster/r.in.mat/main.c:138
-#: ../raster/r.in.arc/main.c:123 ../vector/v.segment/main.c:89
-#: ../vector/v.net.path/path.c:46 ../vector/v.lrs/v.lrs.segment/main.c:129
-#: ../display/d.linegraph/linegraph.c:194
-#: ../display/d.linegraph/linegraph.c:206
+#: ../general/g.gui/main.c:71
#, c-format
-msgid "Unable to open input file <%s>"
-msgstr "Nelze otevøít vstupní soubor <%s>"
+msgid "<%s> is now the default GUI"
+msgstr "<%s> je nyní nastaveno jako základní grafické prostøedí"
-#: ../raster/r.in.xyz/main.c:445
-msgid ""
-"If input is not from a file it is only possible to perform a single pass."
-msgstr "Pokud není vstupem soubor je mo¾né provést pouze jeden prùchod."
-#: ../raster/r.in.xyz/main.c:451
-msgid "zrange will not be taken into account during scan"
-msgstr "na rozsah z nebude bìhem hledání brán zøetel"
-#: ../raster/r.in.xyz/main.c:487 ../raster/r.in.xyz/main.c:1017
-msgid "Scanning data ..."
-msgstr "Prohledávání dat ..."
-#: ../raster/r.in.xyz/main.c:494 ../raster/r.in.poly/poly2rast.c:42
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/opennew.c:19
+#: ../raster/r.slope.aspect/opennew.c:19
#, c-format
-msgid "Pass #%d (of %d) ..."
-msgstr "Prùchod #%d (z %d) ..."
+msgid "Failed in attempt to open %s"
+msgstr "Chyba pøi otevírání %s"
-#: ../raster/r.in.xyz/main.c:563
-#, c-format
-msgid ""
-"Not enough data columns. Incorrect delimiter or column number? Found the "
-"following character(s) in row %d:\n"
-"[%s]"
-msgstr ""
-"Nenalezl jsem dostateèný poèet sloupcù. ®eby ¹patný oddìlovaè nebo poèet "
-"sloupcù? Na øádku jsou následující písmenka %d:\n"
-"[%s]"
-#: ../raster/r.in.xyz/main.c:575 ../raster/r.in.xyz/main.c:1054
-#, c-format
-msgid "Bad y-coordinate line %d column %d. <%s>"
-msgstr "©patná souøadnice y øádek %d sloupec %d. <%s>"
-#: ../raster/r.in.xyz/main.c:581 ../raster/r.in.xyz/main.c:1042
-#, c-format
-msgid "Bad x-coordinate line %d column %d. <%s>"
-msgstr "©patná souøadnice x øádek %d sloupec %d. <%s>"
-#: ../raster/r.in.xyz/main.c:587 ../raster/r.in.xyz/main.c:1066
-#, c-format
-msgid "Bad z-coordinate line %d column %d. <%s>"
-msgstr "©patná souøadnice z øádek %d sloupec %d. <%s>"
-#: ../raster/r.in.xyz/main.c:660
-msgid "Writing to map ..."
-msgstr "Zapisuji do vrstvy ..."
-#: ../raster/r.in.xyz/main.c:951
-#, c-format
-msgid "Writing map, row %d"
-msgstr "Zapisuji mapu, øádek %d"
-#: ../raster/r.in.xyz/main.c:992
-#, c-format
-msgid "%d points found in region."
-msgstr "%d bodù nalezeno v regionu."
-#: ../raster/r.in.xyz/main.c:1031
-#, c-format
-msgid ""
-"Not enough data columns. Incorrect delimiter or column number?\n"
-"[%s]"
-msgstr ""
-"Nenalezl jsem dostatek sloupcù. Žeby ¹patný oddìlovaè nebo poèet sloupcù?\n"
-"[%s]"
-#: ../raster/r.in.xyz/main.c:1083
-#, c-format
-msgid "Range: min max\n"
-msgstr "Rozsah: min max\n"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:154
#: ../raster/r.slope.aspect/main.c:154
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:154
msgid ""
"Generates raster map layers of slope, aspect, curvatures and partial "
"derivatives from a raster map layer of true elevation values. Aspect is "
@@ -9598,47 +5299,73 @@
"odvozenou z digitálního modelu terénu. Expozice je poèítána proti smìru "
"hodinových ruèièek s poèátkem na východì."
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:163
#: ../raster/r.slope.aspect/main.c:163
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:163
msgid "Raster elevation file name"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:171
#: ../raster/r.slope.aspect/main.c:171
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:171
msgid "Output slope filename"
msgstr "Název výstupního souboru sklonù svahù"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:179
#: ../raster/r.slope.aspect/main.c:179
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:179
msgid "Output aspect filename"
msgstr "Název výstupního souboru expozic svahù"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:187
#: ../raster/r.slope.aspect/main.c:187
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:187
msgid "Format for reporting the slope"
msgstr "Formát sklonu svahu"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:188
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:197
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:268
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:276
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:286
+#: ../vector/v.surf.rst/main.c:193 ../vector/v.surf.rst/main.c:263
+#: ../vector/v.surf.rst/main.c:270 ../vector/v.surf.rst/main.c:278
+#: ../vector/v.surf.rst/main.c:286 ../vector/v.surf.rst/main.c:295
+#: ../vector/v.surf.rst/main.c:304 ../vector/v.surf.rst/main.c:313
+#: ../vector/v.surf.rst/main.c:322
+#: ../vector/lidar/v.lidar.edgedetection/main.c:87
+#: ../vector/lidar/v.lidar.edgedetection/main.c:95
+#: ../vector/lidar/v.lidar.edgedetection/main.c:103
+#: ../vector/lidar/v.lidar.edgedetection/main.c:111
+#: ../vector/lidar/v.lidar.edgedetection/main.c:119
+#: ../vector/lidar/v.lidar.edgedetection/main.c:127
+#: ../vector/lidar/v.lidar.edgedetection/main.c:135
+#: ../vector/lidar/v.surf.bspline/main.c:113
+#: ../vector/lidar/v.surf.bspline/main.c:123
+#: ../vector/lidar/v.surf.bspline/main.c:133
+#: ../vector/lidar/v.surf.bspline/main.c:142
+#: ../vector/lidar/v.surf.bspline/main.c:149
+#: ../vector/lidar/v.surf.bspline/main.c:157 ../vector/v.vol.rst/main.c:258
+#: ../vector/v.vol.rst/main.c:266 ../vector/v.vol.rst/main.c:274
+#: ../vector/v.vol.rst/main.c:307 ../vector/v.vol.rst/main.c:316
+#: ../vector/v.vol.rst/main.c:325 ../vector/v.vol.rst/main.c:334
+#: ../vector/v.vol.rst/main.c:342 ../raster/r.in.bin/main.c:131
+#: ../raster/r.in.bin/main.c:137 ../raster/r.in.bin/main.c:167
+#: ../raster/r.in.bin/main.c:220 ../raster/r.slope.aspect/main.c:188
+#: ../raster/r.slope.aspect/main.c:197 ../raster/r.slope.aspect/main.c:268
+#: ../raster/r.slope.aspect/main.c:276 ../raster/r.slope.aspect/main.c:286
+#: ../raster/r.resamp.rst/main.c:234 ../raster/r.resamp.rst/main.c:242
+#: ../raster/r.resamp.rst/main.c:250 ../raster/r.resamp.rst/main.c:258
+#: ../raster/r.resamp.rst/main.c:266
+msgid "Settings"
+msgstr "Nastavení"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:196
#: ../raster/r.slope.aspect/main.c:196
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:196
msgid "Type of output aspect and slope maps"
msgstr "Typ výstupních map expozice a sklonu svahu"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:205
#: ../raster/r.slope.aspect/main.c:205
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:205
msgid "Output profile curvature filename"
msgstr "Název výstupního souboru profilových køivostí"
-#: ../raster/r.slope.aspect/main.c:206 ../raster/r.slope.aspect/main.c:215
-#: ../raster/r.slope.aspect/main.c:224 ../raster/r.slope.aspect/main.c:233
-#: ../raster/r.slope.aspect/main.c:242 ../raster/r.slope.aspect/main.c:251
-#: ../raster/r.slope.aspect/main.c:260 ../vector/v.buffer/main.c:269
-#: ../vector/v.buffer/main.c:277 ../vector/v.buffer/main.c:284
-#: ../vector/v.buffer/main.c:294 ../display/d.legend/main.c:107
-#: ../display/d.legend/main.c:116 ../display/d.legend/main.c:124
-#: ../display/d.legend/main.c:143 ../display/d.legend/main.c:151
-#: ../display/d.legend/main.c:161 ../display/d.legend/main.c:166
-#: ../display/d.legend/main.c:171 ../display/d.legend/main.c:176
-#: ../display/d.legend/main.c:181
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:206
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:215
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:224
@@ -9646,5166 +5373,5205 @@
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:242
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:251
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:260
+#: ../display/d.legend/main.c:107 ../display/d.legend/main.c:116
+#: ../display/d.legend/main.c:124 ../display/d.legend/main.c:143
+#: ../display/d.legend/main.c:151 ../display/d.legend/main.c:161
+#: ../display/d.legend/main.c:166 ../display/d.legend/main.c:171
+#: ../display/d.legend/main.c:176 ../display/d.legend/main.c:181
+#: ../vector/v.buffer/main.c:269 ../vector/v.buffer/main.c:277
+#: ../vector/v.buffer/main.c:284 ../vector/v.buffer/main.c:294
+#: ../raster/r.slope.aspect/main.c:206 ../raster/r.slope.aspect/main.c:215
+#: ../raster/r.slope.aspect/main.c:224 ../raster/r.slope.aspect/main.c:233
+#: ../raster/r.slope.aspect/main.c:242 ../raster/r.slope.aspect/main.c:251
+#: ../raster/r.slope.aspect/main.c:260
msgid "Advanced"
msgstr "Pokroèilé"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:214
#: ../raster/r.slope.aspect/main.c:214
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:214
msgid "Output tangential curvature filename"
msgstr "Název výstupního souboru tangenciálních køivostí"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:223
#: ../raster/r.slope.aspect/main.c:223
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:223
msgid "Output first order partial derivative dx (E-W slope) filename"
msgstr ""
"Název výstupního souboru parciálních derivací prvního øádu dx (V - Z sklon "
"svahu)"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:232
#: ../raster/r.slope.aspect/main.c:232
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:232
msgid "Output first order partial derivative dy (N-S slope) filename"
msgstr ""
"Název výstupního souboru parciálních derivací prvního øádu dy (S - J sklon "
"svahu)"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:241
#: ../raster/r.slope.aspect/main.c:241
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:241
msgid "Output second order partial derivative dxx filename"
msgstr "Název výstupního souboru parciálních derivací druhého øádu dxx"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:250
#: ../raster/r.slope.aspect/main.c:250
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:250
msgid "Output second order partial derivative dyy filename"
msgstr "Název výstupního souboru parciálních derivací druhého øádu dyy"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:259
#: ../raster/r.slope.aspect/main.c:259
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:259
msgid "Output second order partial derivative dxy filename"
msgstr "Název výstupního soubor parciálních derivací druhého øádu dxy"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:264
#: ../raster/r.slope.aspect/main.c:264
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:264
msgid "Multiplicative factor to convert elevation units to meters"
msgstr "Koeficient pro pøevod jednotek vý¹ky na metry"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:272
#: ../raster/r.slope.aspect/main.c:272
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:272
msgid "Minimum slope val. (in percent) for which aspect is computed"
msgstr ""
"Minimální hodnota sklonu svahu (v procentech), pro kterou je poèítána "
"expozice"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:281
+#: ../doc/raster/r.example/main.c:95 ../vector/v.sample/main.c:128
+#: ../vector/v.perturb/main.c:116 ../vector/v.kcv/main.c:104
+#: ../raster/r.texture/main.c:108 ../raster/r.kappa/main.c:82
+#: ../raster/r.rescale.eq/main.c:96 ../raster/r.mfilter.fp/main.c:89
+#: ../raster/r.patch/main.c:72 ../raster/r.report/parse.c:90
+#: ../raster/r.resample/main.c:78 ../raster/r.grow2/main.c:165
+#: ../raster/r.mfilter/main.c:82 ../raster/r.slope.aspect/main.c:281
+#: ../raster/r.bitpattern/main.c:87 ../imagery/i.cluster/main.c:135
+msgid "Quiet"
+msgstr "Potichu"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:285
#: ../raster/r.slope.aspect/main.c:285
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:285
msgid "Do not align the current region to the elevation layer"
msgstr "Nenastavuj aktuální region podle mapy vý¹ek "
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:319
+#: ../vector/v.mkgrid/main.c:122 ../vector/v.qcount/main.c:115
+#: ../raster/r.neighbors/main.c:276 ../raster/r.to.vect/main.c:95
+#: ../raster/r.buffer/main.c:98 ../raster/r.texture/main.c:217
+#: ../raster/r.series/main.c:137 ../raster/r.distance/parse.c:71
+#: ../raster/r.rescale/main.c:101 ../raster/r.clump/main.c:78
+#: ../raster/r.out.png/r.out.png.c:145 ../raster/r.rescale.eq/main.c:105
+#: ../raster/r.coin/cmd_parms.c:87 ../raster/r.patch/main.c:86
+#: ../raster/r.out.ppm3/main.c:98 ../raster/r.resample/main.c:89
+#: ../raster/r.colors/main.c:231 ../raster/r.covar/main.c:74
+#: ../raster/r.cross/main.c:97 ../raster/r.slope.aspect/main.c:319
+#: ../raster/r.describe/main.c:114 ../raster/r.carve/main.c:123
+#: ../raster/r.compress/main.c:90 ../raster/r.random.surface/init.c:107
+msgid ""
+"The '-q' flag is superseded and will be removed in future. Please use '--"
+"quiet' instead."
+msgstr ""
+"Pøepínaè '-q' je zastaralý a bude v budoucnosti odstranìn. prosím, peou¾ijte "
+"pøepínaè '--quiet'."
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:405
#: ../raster/r.slope.aspect/main.c:405
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:405
#, c-format
msgid "wrong type: %s"
msgstr "chybný typ: %s"
-#: ../raster/r.slope.aspect/main.c:1035 ../raster/r.clump/main.c:103
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:609
+#: ../vector/v.surf.rst/main.c:566 ../vector/v.surf.rst/main.c:712
+#: ../raster/r.resample/main.c:137 ../raster/r.slope.aspect/main.c:609
+#: ../raster/r.resamp.rst/main.c:528
+msgid "Percent complete: "
+msgstr "Hotovo procent:"
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1035
+#: ../raster/r.clump/main.c:103 ../raster/r.slope.aspect/main.c:1035
msgid "Creating support files..."
msgstr "Vytváøím podpùrné soubory..."
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1037
#: ../raster/r.slope.aspect/main.c:1037
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1037
#, c-format
msgid "Elevation products for mapset [%s] in [%s]"
msgstr "Výsledky z elevace mapsetu [%s] v [%s]"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1055
#: ../raster/r.slope.aspect/main.c:1055
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1055
#, c-format
msgid "Min computed aspect %.4f, max computed aspect %.4f"
msgstr "Min vypoètená expozice %.4f, max vypoètená expozice %.4f"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1108
#: ../raster/r.slope.aspect/main.c:1108
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1108
#, c-format
msgid "ASPECT [%s] COMPLETE"
msgstr "MAPA EXPOZICE [%s] DOKONÈENA"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1148
#: ../raster/r.slope.aspect/main.c:1148
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1148
#, c-format
msgid "Min computed slope %.4f, max computed slope %.4f"
msgstr "Min vypoètený sklon svahu %.4f, max vypoètený sklon svahu %.4f"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1198
#: ../raster/r.slope.aspect/main.c:1198
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1198
#, c-format
msgid "SLOPE [%s] COMPLETE"
msgstr "MAPA SKLONOVÝCH POMÌRÙ [%s] DOKONÈENA"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1267
#: ../raster/r.slope.aspect/main.c:1267
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1267
#, c-format
msgid "PROFILE CURVE [%s] COMPLETE"
msgstr "PROFILOVÁ KØIVOST [%s] DOKONÈENA"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1294
#: ../raster/r.slope.aspect/main.c:1294
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1294
#, c-format
msgid "TANGENTIAL CURVE [%s] COMPLETE"
msgstr "TANGENCIÁLNÍ KØIVOST [%s] DOKONÈENA"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1319
#: ../raster/r.slope.aspect/main.c:1319
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1319
#, c-format
msgid "E-W SLOPE [%s] COMPLETE"
msgstr "MAPA V-Z SKLONOVÝCH POMÌRÙ [%s] DOKONÈENA"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1344
#: ../raster/r.slope.aspect/main.c:1344
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1344
#, c-format
msgid "N-S SLOPE [%s] COMPLETE"
msgstr "MAPA S-J SKLONOVÝCH POMÌRÙ [%s] DOKONÈENA"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1369
#: ../raster/r.slope.aspect/main.c:1369
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1369
#, c-format
msgid "DXX [%s] COMPLETE"
msgstr "MAPA DXX [%s] DOKONÈENA"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1394
#: ../raster/r.slope.aspect/main.c:1394
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1394
#, c-format
msgid "DYY [%s] COMPLETE"
msgstr "MAPA DYY [%s] DOKONÈENA"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1419
#: ../raster/r.slope.aspect/main.c:1419
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1419
#, c-format
msgid "DXY [%s] COMPLETE"
msgstr "MAPA DXY [%s] DOKONÈENA"
-#: ../raster/r.slope.aspect/opennew.c:19
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/opennew.c:19
-#, c-format
-msgid "Failed in attempt to open %s"
-msgstr "Chyba pøi otevírání %s"
+#: ../sites/s.in.ascii/main.c:50 ../sites/s.out.ascii/main.c:46
+msgid "sites"
+msgstr "body"
-#: ../raster/r.surf.gauss/main.c:45
+#: ../display/d.grid/main.c:51 ../display/d.legend/main.c:86
+#: ../display/d.graph/main.c:53 ../display/d.vect.chart/main.c:62
+#: ../display/d.barscale/main.c:55
+msgid "display, cartography"
+msgstr "zobrazení, kartografie"
+#: ../display/d.grid/main.c:53
msgid ""
-"GRASS module to produce a raster map layer of gaussian deviates whose mean "
-"and standard deviation can be expressed by the user. It uses a gaussian "
-"random number generator."
+"Overlays a user-specified grid in the active display frame on the graphics "
+"monitor."
msgstr ""
-"Modul GRASSu slou¾ící k tvorbì rastrové mapy náhodných gaussových hodnot "
-"jejich¾ prùmìr a smìrodatná odchylka mù¾e být zadána u¾ivatelem. Pou¾ívá "
-"Gaussùv generátor náhodných èísel."
+"Zobrazí u¾ivatelem specifikovanou sí» (møí¾ku) v aktivním rámci grafického "
+"monitoru."
-#: ../raster/r.surf.gauss/main.c:52
-msgid "Name of the output random surface"
-msgstr "Název výstupního náhodného povrchu"
+#: ../display/d.grid/main.c:61
+msgid "Size of grid to be drawn"
+msgstr "Velikost møí¾ky pro vykreslení"
-#: ../raster/r.surf.gauss/main.c:56
-msgid "Distribution mean"
-msgstr "Prùmìr rozdìlení"
+#: ../display/d.grid/main.c:62
+msgid "In map units or DDD:MM:SS format. Example: \"1000\" or \"0:10\""
+msgstr ""
+"V jednotkách mapy nebo ve formátu DDD:MM:SS. Na pøíklad: \"1000\" nebo \"0:10"
-#: ../raster/r.surf.gauss/main.c:62
-msgid "Standard deviation"
-msgstr "Smìrodatná odchylka"
+#: ../display/d.grid/main.c:71
+msgid "Lines of the grid pass through this coordinate"
+msgstr "Linie sítì procházející tìmito souøadnicemi"
-#: ../raster/r.surf.gauss/main.c:77
-#, c-format
-msgid ""
-"Raster map [%s] already exists.\n"
-"Please try another."
-msgstr ""
-"Rastrová mapa <%s> ji¾ existuje.\n"
-"Zkuste prosím jiné jméno."
+#: ../display/d.grid/main.c:75
+msgid "Grid color"
+msgstr "Barva rámeèku"
-#: ../raster/r.colors/main.c:127
-#, fuzzy
-msgid "Creates/modifies the color table associated with a raster map layer."
-msgstr "Vytvoøí/mìní tabulku barev spojenou s rastrovou mapou."
+#: ../display/d.grid/main.c:79 ../vector/v.label.sa/main.c:189
+#: ../vector/v.label/main.c:193 ../vector/v.lrs/v.lrs.label/main.c:229
+msgid "Border color"
-#: ../raster/r.colors/main.c:140
-msgid "Type of color table"
-msgstr "Typ tabulky barev"
+#: ../display/d.grid/main.c:84 ../vector/v.label.sa/main.c:145
+#: ../vector/v.label/main.c:151 ../vector/v.lrs/v.lrs.label/main.c:188
+msgid "Text color"
+msgstr "Barva textu"
-#: ../raster/r.colors/main.c:152
-msgid "Raster map name from which to copy color table"
-msgstr "Název rastrové mapy, ze které se má kopírovat tabulka barev"
+#: ../display/d.grid/main.c:92
+msgid "Font size for gridline coordinate labels"
+msgstr "Velikost písma pro popisky souøadnicové sítì"
-#: ../raster/r.colors/main.c:158
-msgid "Path to rules file"
-msgstr "Cesta k souboru s pravidly"
+#: ../display/d.grid/main.c:97
+msgid "Draw geographic grid (referenced to current ellipsoid)"
+msgstr "Zobrazit zemìpisnou møí¾ku (na aktuálním ref. elipsoidu)"
-#: ../raster/r.colors/main.c:163
-msgid "Remove existing color table"
-msgstr "Smazat existující tabulku barev"
+#: ../display/d.grid/main.c:102
+msgid "Draw geographic grid (referenced to WGS84 ellipsoid)"
+msgstr "Vykreslí souøadnicovou møí¾ku (vzta¾eno k elipsoidu WGS84)"
-#: ../raster/r.colors/main.c:167
-msgid "Only write new color table if one doesn't already exist"
-msgstr "Pouze zapi¹ novou tabulku barev pokud ¾ádná zatím neexistuje"
+#: ../display/d.grid/main.c:106
+msgid "Draw '+' marks instead of grid lines"
+msgstr "Nakreslit '+' znaèky místo zemìpisných èar"
-#: ../raster/r.colors/main.c:171
-msgid "List available rules then exit"
-msgstr "Vypi¹ dostupná pravidla barev a ukonèi se"
+#: ../display/d.grid/main.c:110
+msgid "Draw fiducial marks instead of grid lines"
+msgstr "Nakreslí referneèní znaèky místo zemìpisných èar"
-#: ../raster/r.colors/main.c:175
-msgid "Invert colors"
-msgstr "Invertovat barvy"
+#: ../display/d.grid/main.c:114
+msgid "Disable grid drawing"
+msgstr "Vypnout vykreslení rámeèku"
-#: ../raster/r.colors/main.c:179
-#, fuzzy
-msgid "Logarithmic scaling"
-msgstr "Logaritmické ¹kálování"
+#: ../display/d.grid/main.c:118
+msgid "Disable border drawing"
-#: ../raster/r.colors/main.c:183
-msgid "Histogram equalization"
-msgstr "Vyrovnání histogramu"
+#: ../display/d.grid/main.c:122
+msgid "Disable text drawing"
+msgstr "Vypnout vykreslení textu"
-#: ../raster/r.colors/main.c:187
-msgid "Enter rules interactively"
-msgstr "Spustit interaktivnì"
+#: ../display/d.grid/main.c:132
+msgid "Both grid and border drawing are disabled"
+msgstr "Vykreslení souø. sítì a hranic je znemo¾nìno."
-#: ../raster/r.colors/main.c:223
-msgid "No map specified"
-msgstr "Nebyly specifikovány ¾ádné mapy"
+#: ../display/d.grid/main.c:136
+msgid "Geo-Grid option is not available for LL projection"
+msgstr "Volba Geo-Grid není pro mapovou projekci LL dostupná"
-#: ../raster/r.colors/main.c:226
+#: ../display/d.grid/main.c:138
+msgid "Geo-Grid option is not available for XY projection"
+msgstr "Volba Geo-Grid není pro mapovou projekci XY dostupná"
+#: ../display/d.grid/main.c:147
+msgid "Chose a single mark style"
+msgstr "Vybrat jednoduchý styl oznaèování"
+#: ../display/d.grid/main.c:157
+#, c-format
+msgid "Invalid geo-grid size <%s>"
+msgstr "Neplatná velikost geo-grid <%s>"
+#: ../display/d.grid/main.c:160
+#, c-format
+msgid "Invalid grid size <%s>"
+msgstr "Chybná velikost sítì: <%s>"
+#: ../display/d.grid/main.c:167
+#, c-format
+msgid "Illegal east coordinate <%s>"
+msgstr "Neplatná východní souøadnice <%s>"
+#: ../display/d.grid/main.c:175
+#, c-format
+msgid "Illegal north coordinate <%s>"
+msgstr "Neplatná severní souøadnice <%s>"
+#: ../display/d.grid/main.c:181 ../display/d.what.vect/main.c:160
+#: ../display/d.rast.arrow/arrow.c:246 ../display/d.path/main.c:158
+#: ../display/d.info/main.c:72 ../display/d.vect/main.c:385
+#: ../display/d.font/main.c:81 ../display/d.legend/main.c:271
+#: ../display/d.graph/main.c:95 ../display/d.rast.num/number.c:129
+#: ../display/d.extend/main.c:42 ../display/d.font.freetype/main.c:101
+#: ../display/d.measure/main.c:86 ../display/d.profile/main.c:135
+#: ../display/d.vect.chart/main.c:243 ../display/d.his/main.c:117
+#: ../display/d.frame/select.c:36 ../display/d.frame/frame.c:130
+#: ../display/d.frame/frame.c:189 ../display/d.frame/frame.c:230
+#: ../display/d.frame/list.c:24 ../display/d.what.rast/main.c:110
+#: ../display/d.thematic.area/main.c:314
+#: ../display/d.linegraph/linegraph.c:256 ../display/d.extract/main.c:77
+#: ../display/d.rast/main.c:114 ../display/d.nviz/main.c:247
+#: ../display/d.barscale/main.c:136 ../display/d.menu/main.c:107
+#: ../display/d.erase/main.c:57 ../display/d.rgb/main.c:87
+#: ../display/d.text.new/main.c:285 ../display/d.paint.labels/main.c:87
+#: ../display/d.text/main.c:131 ../display/d.text.freetype/main.c:309
+#: ../display/d.zoom/main.c:162 ../display/d.zoom/main.c:311
+#: ../display/d.zoom/redraw.c:45 ../display/d.histogram/main.c:175
+#: ../display/d.where/main.c:142 ../vector/v.label/main.c:232
+#: ../imagery/i.points/main.c:79 ../imagery/i.class/main.c:87
+#: ../imagery/i.ortho.photo/photo.2target/main.c:89
+msgid "No graphics device selected"
+msgstr "®ádné grafické zaøízení nebylo vybráno"
+#: ../display/d.grid/plot.c:194 ../display/d.grid/plot.c:200
+#: ../display/d.grid/plot.c:246 ../display/d.grid/plot.c:252
+#: ../display/d.grid/plot.c:387 ../display/d.grid/plot.c:401
+#: ../display/d.grid/plot.c:416 ../display/d.grid/plot.c:431
+#: ../ps/ps.map/do_geogrid.c:86 ../ps/ps.map/do_geogrid.c:91
+#: ../ps/ps.map/do_geogrid.c:115 ../ps/ps.map/do_geogrid.c:120
+#: ../ps/ps.map/do_geogrid.c:189 ../ps/ps.map/do_geogrid.c:227
+#: ../ps/ps.map/do_geogrid.c:303 ../ps/ps.map/do_geogrid.c:317
+#: ../ps/ps.map/do_geogrid.c:332 ../ps/ps.map/do_geogrid.c:347
+#: ../ps/ps.map/do_geogrid.c:399 ../ps/ps.map/do_geogrid.c:405
+#: ../ps/ps.map/do_geogrid.c:409 ../ps/ps.map/do_geogrid.c:417
+#: ../ps/ps.map/do_geogrid.c:421 ../raster/r.sun/main.c:1354
+msgid "Error in pj_do_proj"
+msgstr "Chyba v pj_do_proj"
+#: ../display/d.grid/plot.c:306 ../display/d.grid/plot.c:334
+#: ../display/d.where/main.c:103 ../display/d.where/main.c:130
+#: ../ps/ps.map/do_geogrid.c:274 ../raster/r.sun/main.c:502
+msgid "Unable to set up lat/long projection parameters"
+msgstr "Nelze nastavit parametry mapové projekce lat/long"
+#: ../display/d.grid/plot.c:321
msgid ""
-"One of \"-i\" or \"-r\" or options \"color\", \"rast\" or \"rules\" must be "
-"specified!"
+"WGS84 grid output not possible as this location does not contain\n"
+"datum transformation parameters. Try running g.setproj."
msgstr ""
-"Jeden z pøepínaèù \"-i\" nebo \"-r\" nebo voleb \"color\", \"rast\" nebo "
-"\"rules\" MUSÍ být zadána!"
+"Výstup do rastru WGS84 není mo¾ný, jeliko¾ tato location neobsahuje\n"
+"transformaèní parametry. Zkuste spustit g.setproj."
-#: ../raster/r.colors/main.c:229
+#: ../display/d.grid/plot.c:489
+msgid "Error in pj_do_proj1"
+msgstr "Chyba v pj_do_proj1"
+#: ../display/d.grid/plot.c:495
+msgid "Error in pj_do_proj2"
+msgstr "Chyba v pj_do_proj2"
+#: ../display/d.grid/plot.c:499
+msgid "Error in pj_do_proj3"
+msgstr "Chyba v pj_do_proj3"
+#: ../display/d.grid/plot.c:507
+msgid "Error in pj_do_proj5"
+msgstr "Chyba v pj_do_proj5"
+#: ../display/d.grid/plot.c:511
+msgid "Error in pj_do_proj6"
+msgstr "Chyba v pj_do_proj6"
+#: ../display/d.grid/fiducial.c:49
+msgid "Reading symbol"
+msgstr "Ètu symbol"
+#: ../display/d.what.vect/main.c:55
msgid ""
-"Interactive mode is incompatible with \"color\", \"rules\", and \"raster\" "
-"options"
+"Allows the user to interactively query a vector map layer at user-selected "
+"locations within the current geographic region."
msgstr ""
-"Interaktivní mód nelze pou¾ít s volbami \"barva\", \"pravidlo\", a \"rastr\" "
+"Umo¾òuje u¾ivateli aktivní dotaz na vektorové mapy na místech definovaných "
+"my¹í v rámci aktuálního regionu."
-#: ../raster/r.colors/main.c:232
-msgid "\"color\", \"rules\", and \"raster\" options are mutually exclusive"
-msgstr "\"barva\", \"pravidlo\", a \"rastr\" volby se vzájemnì vyluèují"
+#: ../display/d.what.vect/main.c:75 ../display/d.what.rast/main.c:88
+msgid "Identify just one location"
+msgstr "Oznaète pouze jednu oblast"
-#: ../raster/r.colors/main.c:244
+#: ../display/d.what.vect/main.c:86 ../vector/v.distance/main.c:115
+#: ../vector/v.distance/main.c:120
+msgid "Name of existing vector map"
+msgstr "Jméno existující vektorové mapy"
+#: ../display/d.what.vect/main.c:90 ../display/d.what.rast/main.c:92
+msgid "Terse output. For parsing by programs"
+msgstr "Struèný výstup pro pou¾ití ve skriptech."
+#: ../display/d.what.vect/main.c:94
+msgid "Print information as plain text to terminal window"
+msgstr "Vytiskni informace v èistém textu do okna terminálu"
+#: ../display/d.what.vect/main.c:98 ../vector/v.what/main.c:83
+msgid "Print topological information (debugging)"
+msgstr "Vytiskni informace o topologii (odv¹ivení)"
+#: ../display/d.what.vect/main.c:102
+msgid "Enable flashing (slower)"
+msgstr "Umo¾ni probliknutí (pomalej¹í)"
+#: ../display/d.what.vect/main.c:106
+msgid "Open form in edit mode"
+msgstr "Otevøi formuláø v editaèním módu"
+#: ../display/d.what.vect/main.c:128 ../doc/vector/v.example/main.c:66
+#: ../vector/v.support/main.c:126 ../vector/v.surf.rst/main.c:517
+#: ../vector/v.surf.rst/main.c:661 ../vector/v.surf.rst/main.c:752
+#: ../vector/lidar/v.lidar.edgedetection/main.c:174
+#: ../vector/lidar/v.lidar.correction/main.c:142
+#: ../vector/lidar/v.lidar.growing/main.c:125
+#: ../vector/lidar/v.lidar.growing/main.c:128 ../vector/v.edit1/cmd/main.c:138
+#: ../vector/v.generalize/main.c:305 ../vector/v.hull0/main.c:295
+#: ../vector/v.edit/main.c:152 ../vector/v.net/main.c:159
+#: ../vector/v.net.visibility/main.c:81 ../vector/v.net.visibility/main.c:94
#, c-format
-msgid "%s - unable to remove color table"
-msgstr "%s - nelze smazat tabulku barev"
+msgid "Unable to open vector map <%s>"
+msgstr "Nelze otevøít vektorovou mapu <%s>"
-#: ../raster/r.colors/main.c:246
+#: ../display/d.what.vect/main.c:152
#, c-format
-msgid "%s - color table not found"
-msgstr "%s - tabulka barev nebyla nalezena"
+msgid "%s: You must build topology on vector map"
+msgstr "%s: Pro vektorový soubor musíte vybudovat topologii"
-#: ../raster/r.colors/main.c:277
-msgid "Can't make random color table for floating point map"
-msgstr ""
-"Pro mapu s plovoucí desetinnou èárkou nelze vytvoøit náhodnou barevenou "
-"tabulku"
+#: ../display/d.what.vect/main.c:154 ../vector/v.what/main.c:152
+msgid "Building spatial index..."
+msgstr "Vytváøím prostorový index ..."
-#: ../raster/r.colors/main.c:283
-msgid "Can't make grey.eq color table for floating point map"
-msgstr ""
-"Pro mapu s plovoucí desetinnou èárkou nelze vytvoøit barevnou tabulku greq eq"
+#: ../display/d.what.vect/main.c:172 ../raster/r.support/front/front.c:348
+#: ../imagery/i.gensig/write_sig.c:20
+msgid "Done."
+msgstr "Dokonáno jest."
-#: ../raster/r.colors/main.c:291
-msgid "Can't make logarithmic color table for floating point map"
-msgstr ""
-"Pro mapu s plovoucí desetinnou èárkou nelze vytvoøit logaritmickou barevnou "
-"tabulku"
+#: ../display/d.what.vect/what.c:155 ../display/d.what.vect/what.c:156
+#: ../vector/v.what/what.c:87 ../vector/v.what/what.c:89
+#, c-format
+msgid "Nothing Found.\n"
+msgstr "Nic nebylo nalezeno.\n"
-#: ../raster/r.colors/main.c:304
+#: ../display/d.what.vect/what.c:204
#, c-format
-msgid "%s - unknown color request"
-msgstr "%s - neznámý barevný po¾adavek"
+msgid "Line: %d Type: %s Left: %d Right: %d "
+msgstr "Linie: %d Typ: %s Nalevo: %d Napravo: %d "
-#: ../raster/r.colors/main.c:315
+#: ../display/d.what.vect/what.c:207 ../vector/v.what/what.c:137
+#: ../vector/v.what/what.c:171
#, c-format
-msgid "Unable to load rules file %s"
-msgstr "Nelze naèíst soubor pravidel %s"
+msgid "Length: %f\n"
+msgstr "Délka: %f\n"
-#: ../raster/r.colors/main.c:353
+#: ../display/d.what.vect/what.c:220
#, c-format
-msgid "Color table for <%s> set to %s"
-msgstr "Tabulka barev pro <%s> nastavena na %s"
+msgid " Node[%d]: %d Number of lines: %d Coordinates: %.6f, %.6f, %.6f\n"
+msgstr " Uzel[%d]: %d Poèet linií: %d Souøadnice: %.6f, %.6f, %.6f\n"
-#: ../raster/r.colors/rules.c:39
+#: ../display/d.what.vect/what.c:225
#, c-format
-msgid "Enter rules, \"end\" when done, \"help\" if you need it.\n"
-msgstr "Zadejte pravidla, \"end\" pro ukonèení, \"help\" pro nápovìdu.\n"
+msgid " Line: %5d Angle: %.8f\n"
+msgstr " Linie: %5d Úhel: %.8f\n"
-#: ../raster/r.colors/rules.c:48
+#: ../display/d.what.vect/what.c:231
#, c-format
-msgid "fp: Data range is %s to %s\n"
-msgstr "fp: Rozsah dat je %s a¾ %s\n"
+msgid "length %f\n"
+msgstr "délka %f\n"
-#: ../raster/r.colors/rules.c:61
+#: ../display/d.what.vect/what.c:249 ../vector/v.what/what.c:182
#, c-format
-msgid ""
-"Your color rules do not cover the whole range of data!\n"
-" (rules %f to %f but data %f to %f)"
-msgstr ""
-"Va¹e pravidla pro barvy nepokrývají celý rozsah dat!\n"
-" (pravidla %f do %f, data %f do %f)"
+msgid "Point height: %f\n"
+msgstr "Vý¹ka bodu: %f\n"
-#: ../raster/r.colors/rules.c:104
+#: ../display/d.what.vect/what.c:261 ../vector/v.what/what.c:194
#, c-format
-msgid " val color\n"
-msgstr " hodnota barvy\n"
+msgid "Line height: %f\n"
+msgstr "Vý¹ka linie: %f\n"
-#: ../raster/r.colors/rules.c:105
+#: ../display/d.what.vect/what.c:267
#, c-format
-msgid " n%% color\n"
-msgstr " n%% barva\n"
+msgid "Line height min: %f max: %f\n"
+msgstr "Vý¹ka linie min: %f max: %f\n"
-#: ../raster/r.colors/rules.c:106
+#: ../display/d.what.vect/what.c:284
#, c-format
-msgid " nv color\n"
-msgstr " nv barva\n"
+msgid "Area height: %f\n"
+msgstr "Vý¹ka plochy: %f\n"
-#: ../raster/r.colors/rules.c:107
+#: ../display/d.what.vect/what.c:291
#, c-format
-msgid " default color\n"
-msgstr " výchozí barva\n"
+msgid "Area\n"
+msgstr "Plocha\n"
-#: ../raster/r.colors/rules.c:108
+#: ../display/d.what.vect/what.c:304
#, c-format
-msgid "color can be one of:\n"
-msgstr "barva mù¾e být jednou z:\n"
+msgid "Area: %d Number of isles: %d\n"
+msgstr "Plocha: %d Poèet ostrovù: %d\n"
-#: ../raster/r.colors/rules.c:110
+#: ../display/d.what.vect/what.c:308
#, c-format
-msgid "or an R:G:B triplet, e.g.: 0:127:255\n"
-msgstr "nebo trojice R:G:B, napø.: 0:127:255\n"
+msgid " Isle[%d]: %d\n"
+msgstr " Ostrov[%d]: %d\n"
-#: ../raster/r.colors/rules.c:130
+#: ../display/d.what.vect/what.c:315
#, c-format
-msgid "bad rule (%s); rule not added"
-msgstr "¹patné pravidlo (%s); pravidlo nebylo pøidáno"
+msgid "Island: %d In area: %d\n"
+msgstr "Ostrov: %d V plo¹e: %d\n"
-#: ../raster/r.colors/rules.c:132
+#: ../display/d.what.vect/what.c:319 ../display/d.what.vect/what.c:327
#, c-format
-msgid "bad rule (%s): %s"
-msgstr "neplatné pravidlo (%s): %s"
+msgid "Size - Sq Meters: %.3f\t\tHectares: %.3f\n"
+msgstr "Výmìra - ètvereèní metry: %.3f\t\thektary: %.3f\n"
-#: ../raster/r.out.ppm/main.c:54
+#: ../display/d.what.vect/what.c:322 ../display/d.what.vect/what.c:331
+#, c-format
+msgid " Acres: %.3f\t\tSq Miles: %.4f\n"
+msgstr " Akry: %.3f\t\tètvereèní míle: %.4f\n"
+#: ../display/d.what.vect/what.c:357
+#, c-format
msgid ""
-"Converts a GRASS raster map to a PPM image file at the pixel resolution of "
-"the currently defined region."
+"Layer: %d\n"
+"category: %d\n"
msgstr ""
-"Pøevede GRASS rastr do formátu PPM v rozli¹ení daném aktuálním regionem."
+"Vrstva: %d\n"
+"kategorie: %d\n"
-#: ../raster/r.out.ppm/main.c:63
-msgid "Name for new PPM file (use '-' for stdout)"
-msgstr "Název nového souboru PPM (pro standardní výstup pou¾ijte '-')"
+#: ../display/d.what.vect/what.c:366 ../display/d.vect/main.c:475
+#: ../display/d.thematic.area/main.c:203 ../vector/v.db.connect/main.c:150
+#, c-format
+msgid "Database connection not defined"
+msgstr "Spojení s databází nebylo definováno"
-#: ../raster/r.out.ppm/main.c:72
-msgid "Output greyscale instead of color"
-msgstr "Výstup v ¹edé stupnici, místo barevné"
+#: ../display/d.what.vect/what.c:374
+#, c-format
+msgid ""
+"driver: %s\n"
+"database: %s\n"
+"table: %s\n"
+"key column: %s\n"
+msgstr ""
+"ovladaè: %s\n"
+"databáze: %s\n"
+"tabulka: %s\n"
+"sloupec s klíèem: %s\n"
-#: ../raster/r.out.ppm/main.c:137
+#: ../display/d.what.vect/what.c:429
#, c-format
-msgid "Unable to open file <%s> for write"
-msgstr "Nejsem schopen otevøít soubor <%s> pro zápis"
+msgid ""
+"\n"
+"Click mouse button on desired location\n"
+"\n"
+msgstr ""
+"\n"
+"Kliknìte my¹í na po¾adované místo\n"
+"\n"
-#: ../raster/r.out.ppm/main.c:166
-msgid "Converting..."
-msgstr "Pøevádím..."
+#: ../display/d.what.vect/what.c:434
+#, c-format
+msgid "Buttons\n"
+msgstr "Tlaèítka\n"
-#: ../raster/r.out.ppm/main.c:248
+#: ../display/d.what.vect/what.c:435
#, c-format
-msgid "File <%s> created"
-msgstr "Soubor <%s> vytvoøen"
+msgid " Left: what's here\n"
+msgstr " Levé: copak je tu\n"
-#: ../raster/r.fill.dir/resolve.c:128
+#: ../display/d.what.vect/what.c:437
#, c-format
-msgid "Downward pass %d"
-msgstr "Sní¾ený prùchod %d"
+msgid " Middle: toggle flash color\n"
+msgstr " Prostøední: zmìnit barvu\n"
-#: ../raster/r.fill.dir/resolve.c:167
+#: ../display/d.what.vect/what.c:442
#, c-format
-msgid "Upward pass %d"
-msgstr "Zvý¹ený prùchod %d"
+msgid " Right: quit\n"
+msgstr " Pravé: ukonèit\n"
-#: ../raster/r.fill.dir/wtrshed.c:90
+#: ../display/d.what.vect/openvect.c:12
#, c-format
-msgid "wtrshed pass %d"
-msgstr "prùchod povodí %d"
+msgid "warning: %s - vector map not found\n"
+msgstr "varování: %s - vektorový soubor nenalezen\n"
-#: ../raster/r.fill.dir/main.c:87
-#, fuzzy
-msgid ""
-"Filters and generates a depressionless elevation map and a flow direction "
-"map from a given elevation layer."
-msgstr ""
-"Z gridu digitálního modelu terénu odstraní umìle vytvoøené sní¾eniny a "
-"vytvoøí mapu smìru odtoku"
+#: ../display/d.mon/cmd/main.c:49
+msgid "To establish and control use of a graphics display monitor."
+msgstr "Slou¾í k vytvoøení a kontrole grafického monitoru."
-#: ../raster/r.fill.dir/main.c:98
-msgid "Output elevation raster map after filling"
-msgstr "Výstupní rastrová mapa digitálního modelu terénu po vyplnìní sní¾enin"
+#: ../display/d.mon/cmd/main.c:55
+msgid "Name of graphics monitor to start"
+msgstr "Jméno grafického monitoru, který bude spu¹tìn"
-#: ../raster/r.fill.dir/main.c:105
-msgid "Output direction raster map"
-msgstr "Výstupní rastrová mapa orientace"
+#: ../display/d.mon/cmd/main.c:61
+msgid "Name of graphics monitor to stop"
+msgstr "Jméno grafického monitoru, který bude vypnut"
-#: ../raster/r.fill.dir/main.c:112
-msgid "Output raster map of problem areas"
-msgstr "Výstupní rastrová mapa problémových oblastí"
+#: ../display/d.mon/cmd/main.c:67
+msgid "Name of graphics monitor to select"
+msgstr "Jméno grafického monitoru, který bude vybrán"
-#: ../raster/r.fill.dir/main.c:118
-msgid "Output aspect direction format (agnps, answers, or grass)"
-msgstr "Výstupní formát smìru expozice (agnps, answers, or grass)("
+#: ../display/d.mon/cmd/main.c:73
+msgid "Name of graphics monitor to unlock"
+msgstr "Jméno monitoru k odemèení"
-#: ../raster/r.fill.dir/main.c:126
-#, fuzzy
-msgid "Find unresolved areas only"
-msgstr "najdi pouze nevyøe¹ené oblasti"
+#: ../display/d.mon/cmd/main.c:77
+msgid "List all monitors"
+msgstr "Seznam v¹ech monitorù"
-#: ../raster/r.fill.dir/main.c:203
-msgid "Reading map..."
-msgstr "Naèítám mapu..."
+#: ../display/d.mon/cmd/main.c:81
+msgid "List all monitors (with current status)"
+msgstr "Seznam monitorù (s aktuálním stavem)"
-#: ../raster/r.fill.dir/main.c:212
-msgid "Filling sinks..."
-msgstr "Vyplòuji deprese..."
+#: ../display/d.mon/cmd/main.c:85
+msgid "Print name of currently selected monitor"
+msgstr "Vypi¹ jméno aktuálnì vybraného monitoru"
-#: ../raster/r.fill.dir/main.c:216
-msgid "Determining flow directions for ambiguous cases..."
-msgstr "Urèuji smìr odtokù pro sporné pøípady..."
+#: ../display/d.mon/cmd/main.c:89
+msgid "Release currently selected monitor"
+msgstr "Uvolni souèasný vybraný monitor"
-#: ../raster/r.fill.dir/main.c:230
-msgid "Repeat to get the final directions..."
-msgstr "Opakovat pro získání výsledných smìrù..."
+#: ../display/d.mon/cmd/main.c:94
+msgid "Do not automatically select when starting"
+msgstr "Nevybírej monitor automaticky pøi startu"
-#: ../raster/r.fill.dir/dopolys.c:87
+#: ../display/d.mon/cmd/main.c:136
#, c-format
-msgid "Found %d unresolved areas"
-msgstr "Nalezeno %d nevyøe¹ených oblastí"
+msgid "Problem selecting %s. Will try once more"
+msgstr "Problém pøi výbìru monitoru %s. Zkusím to je¹tì jednou"
-#: ../raster/r.timestamp/main.c:36
-msgid "Print/add/remove a timestamp for a raster map."
-msgstr "Vytiskni/pøidej/sma¾ èasovou znaèku rastrových map."
+#: ../display/d.mon/pgms/start.c:68 ../display/d.mon/pgms/select.c:20
+#, c-format
+msgid "Usage: %s monitor_name"
+msgstr "Pou¾ití: %s jmeno_monitoru"
-#: ../raster/r.timestamp/main.c:84
-msgid "Invalid timestamp"
-msgstr "Chybný èasový otisk"
-#: ../raster/r.what/main.c:90
-msgid "Queries raster map layers on their category values and category labels."
+#: ../display/d.mon/pgms/release.c:37 ../display/d.vect/main.c:375
+#: ../vector/v.kernel/main.c:171 ../raster/r.in.mat/main.c:123
+#: ../raster/r.out.tiff/r.out.tiff.c:145 ../raster/wildfire/r.ros/main.c:304
+#: ../raster/wildfire/r.spread/main.c:248 ../raster/r.out.mat/main.c:88
+#: ../raster/r.cost/main.c:225
+msgid ""
+"The '-v' flag is superseded and will be removed in future. Please use '--"
+"verbose' instead."
msgstr ""
-"Program slou¾ící k dotazování rastrových map podle jejich kategorií a "
-"oznaèení."
+"Pøepínaè '-v' byl nahrazen a bude v budoucnosti vyjmut. Prosím pou¾ijte "
+"místo nìjpøepínaè '--verbose'."
-#: ../raster/r.what/main.c:98
-msgid "Name of existing raster map(s) to query"
-msgstr "Název existující(ch) rastrové(ých) map(y) pro dotazování."
+#: ../display/d.mon/pgms/release.c:40 ../display/d.mon/pgms/stop.c:33
+#, c-format
+msgid "%s: -%c unrecognized option"
+msgstr "%s: -%c nerozpoznaná volba"
-#: ../raster/r.what/main.c:105
-msgid "Size of point cache"
-msgstr "Velikost bodové vyrovnávací pamìti"
+#: ../display/d.mon/pgms/release.c:68
+#, c-format
+msgid "Monitor <%s> released"
+msgstr "monitor <%s> byl uvolnìn"
-#: ../raster/r.what/main.c:121 ../vector/v.what/main.c:71
-msgid "Coordinates for query"
-msgstr "Souøadnice dotazu"
+#: ../display/d.mon/pgms/release.c:71
+#, c-format
+msgid "Monitor <%s> in use by another user"
+msgstr "Monitor <%s> je pou¾íván jiným u¾ivatelem"
-#: ../raster/r.what/main.c:125
-msgid "Show the category label in the grid cell(s)"
-msgstr "Uka¾ ¹títek kategorie v buòce rastrového souboru"
+#: ../display/d.mon/pgms/release.c:75 ../display/d.mon/pgms/select.c:30
+#: ../display/d.mon/pgms/stop.c:80
+#, c-format
+msgid "No such monitor as <%s>"
+msgstr "Monitor <%s> neexistuje"
-#: ../raster/r.what/main.c:129
-msgid "Turn on cache reporting"
-msgstr "Zapnout cache"
+#: ../display/d.mon/pgms/release.c:78
+msgid "Failed testing lock mechanism"
+msgstr "Testování uzamykacího mechanismu selhalo"
-#: ../raster/r.what/main.c:133 ../raster/r.out.bin/main.c:92
-msgid "Output integer category values, not cell values"
-msgstr "Výstup celoèíselných hodnot kategorií, ne hodnoty bunìk"
+#: ../display/d.mon/pgms/release.c:90
+#, c-format
+msgid "Usage: %s [-fv] [name]"
+msgstr "Pou¾ití: %s [-fv] [jmeno]"
-#: ../raster/r.what/main.c:137
-msgid "Output color values as RRR:GGG:BBB"
-msgstr "Výstupní barevné hodnoty jako ÈÈÈ:ZZZ:MMM"
+#: ../display/d.mon/pgms/stop.c:51
+#, c-format
+msgid "Usage: %s [-f] monitor_name"
+msgstr "Pou¾ití: %s [-f] jmeno_monitoru"
-#: ../raster/r.what/main.c:173
+#: ../display/d.mon/pgms/stop.c:74
#, c-format
-msgid "%s: can only do up to %d raster maps, sorry\n"
-msgstr "%s: mohu vytvoøit pouze %d rastrových map\n"
+msgid "Monitor '%s' terminated"
+msgstr "Monitor '%s' ukonèen"
-#: ../raster/r.mfilter.fp/getfilt.c:28 ../raster/r.mfilter/getfilt.c:27
+#: ../display/d.mon/pgms/stop.c:77
#, c-format
-msgid "Cannot open filter file '%s'"
-msgstr "Nelze otevøít soubor s filtrem '%s'"
+msgid "Error - Monitor '%s' was not running"
+msgstr "Chyba - Monitor '%s' nebì¾í"
-#: ../raster/r.mfilter.fp/getfilt.c:52 ../raster/r.mfilter/getfilt.c:51
-msgid "Illegal filter matrix size specified"
-msgstr "Byla zadána neplatná velikost matice filtru"
+#: ../display/d.mon/pgms/stop.c:83
+#, c-format
+msgid "Error - Monitor '%s' in use by another user"
+msgstr "Chyba - Monitor '%s' je pou¾íván jiným u¾ivatelem"
-#: ../raster/r.mfilter.fp/getfilt.c:56 ../raster/r.mfilter/getfilt.c:55
-msgid "Even filter matrix size specified"
-msgstr "Bylo zadáno sudé èíslo jako velikost matice"
+#: ../display/d.mon/pgms/stop.c:86
+msgid "Error - Locking mechanism failed"
+msgstr "Chyba - selhal zamykací mechanismus"
-#: ../raster/r.mfilter.fp/getfilt.c:79 ../raster/r.mfilter/getfilt.c:78
-msgid "Illegal filter matrix"
-msgstr "Neplatná matice filtru"
+#: ../display/d.rast.arrow/arrow.c:114
+msgid ""
+"Draws arrows representing cell aspect direction for a raster map containing "
+"aspect data."
+msgstr "Nakreslí ¹ipky pøedstavující smìr expozice pro rastrové mapy expozice."
-#: ../raster/r.mfilter.fp/getfilt.c:88 ../raster/r.mfilter.fp/getfilt.c:118
-#: ../raster/r.mfilter.fp/getfilt.c:139 ../raster/r.mfilter/getfilt.c:87
-#: ../raster/r.mfilter/getfilt.c:117 ../raster/r.mfilter/getfilt.c:138
-msgid "Filter file format error"
-msgstr "Chyba formátu souboru s maticí"
+#: ../display/d.rast.arrow/arrow.c:123
+msgid "Name of raster aspect map to be displayed"
+msgstr "Název rastrové mapy expozice, která bude zobrazena"
-#: ../raster/r.mfilter.fp/getfilt.c:92 ../raster/r.mfilter/getfilt.c:91
-msgid "Duplicate filter divisor specified"
-msgstr "Dvakrát urèený filtr rozdìlení"
+#: ../display/d.rast.arrow/arrow.c:131
+msgid "Type of existing raster aspect map"
+msgstr "Typ existující rastrové mapy expozice"
-#: ../raster/r.mfilter.fp/getfilt.c:110 ../raster/r.mfilter/getfilt.c:109
-msgid "Illegal divisor matrix"
-msgstr "©patná dìlící matice"
+#: ../display/d.rast.arrow/arrow.c:139
+msgid "Color for drawing arrows"
+msgstr "Barva pro ¹ipky"
-#: ../raster/r.mfilter.fp/getfilt.c:122 ../raster/r.mfilter/getfilt.c:121
-msgid "Duplicate filter type specified"
-msgstr "Dvakrát specifikovaný typ filtru"
+#: ../display/d.rast.arrow/arrow.c:147
+msgid "Color for drawing grid or \"none\""
+msgstr "Barva pro vykreslení sítì, nebo \"none\""
-#: ../raster/r.mfilter.fp/getfilt.c:130 ../raster/r.mfilter/getfilt.c:129
-msgid "Illegal filter type specified"
-msgstr "Byl zadán neplatný typ filtru"
+#: ../display/d.rast.arrow/arrow.c:155
+msgid "Color for drawing X's (Null values)"
+msgstr "Barva pro vykreslení Xek (nullové hodnoty)"
-#: ../raster/r.mfilter.fp/getfilt.c:143 ../raster/r.mfilter/getfilt.c:142
-msgid "Duplicate filter start specified"
-msgstr "Dvakrát specifikovaný start filtru"
+#: ../display/d.rast.arrow/arrow.c:163
+msgid "Color for showing unknown information"
+msgstr "Barva pro zobrazení neznámé informace"
-#: ../raster/r.mfilter.fp/getfilt.c:151 ../raster/r.mfilter/getfilt.c:150
-#, c-format
-msgid "Filter start %s ignored, using UL"
-msgstr "Poèátek filtru %s ignorován, pou¾ívám UL"
+#: ../display/d.rast.arrow/arrow.c:170
+msgid "Draw arrow every Nth grid cell"
+msgstr "Vykreslit ¹ipku ka¾dou Ntou buòku"
-#: ../raster/r.mfilter.fp/getfilt.c:174 ../raster/r.mfilter/getfilt.c:173
-msgid "Illegal filter file format"
-msgstr "Byl zadán neplatný formát filtru"
+#: ../display/d.rast.arrow/arrow.c:178
+msgid "Raster map containing values used for arrow length"
+msgstr "Rastrová mapa obsahující hodnoty pou¾ité pro délku ¹ipek"
-#: ../raster/r.mfilter.fp/main.c:56 ../raster/r.mfilter/main.c:49
-msgid "raster, map algebra"
-msgstr "rastr, mapová algebra"
+#: ../display/d.rast.arrow/arrow.c:185
+msgid "Scale factor for arrows (magnitude map)"
+msgstr "Mìøítkový faktor pro ¹ipky (mapa mocnosti)"
-#: ../raster/r.mfilter.fp/main.c:57 ../raster/r.mfilter/main.c:50
-msgid "Raster map matrix filter."
-msgstr "Maticový filtr rastrových map."
+#: ../display/d.rast.arrow/arrow.c:225
+msgid "Illegal value for scale factor"
+msgstr "Neplatná hodnota mìøítkového faktoru"
-#: ../raster/r.mfilter.fp/main.c:68 ../raster/r.mfilter/main.c:61
-msgid "Name of filter file"
-msgstr "Název souboru s filtrem"
+#: ../display/d.rast.arrow/arrow.c:229
+msgid "Illegal value for skip factor"
+msgstr "Neplatná hodnota faktoru pøeskoèení"
-#: ../raster/r.mfilter.fp/main.c:76 ../raster/r.mfilter/main.c:69
-msgid "Number of times to repeat the filter"
-msgstr "Poèet iterací"
+#: ../display/d.rast.arrow/arrow.c:234
+msgid "Magnitude is only supported for GRASS and compass aspect maps."
+msgstr "Velikost je podporována pouze pro GRASS a mapy kompasové expozice"
-#: ../raster/r.mfilter.fp/main.c:82 ../raster/r.mfilter/main.c:75
-msgid "Output raster map title"
-msgstr "Titulek výstupního rastru"
+#: ../display/d.rast.arrow/arrow.c:241
+msgid "Scale option requires magnitude_map"
+msgstr "volba mìøítka vy¾aduje magnitude_map"
-#: ../raster/r.mfilter.fp/main.c:99
-msgid "Apply filter only to null data values"
-msgstr "Aplikuj filtr pouze na NULLové hodnoty dat"
+#: ../display/d.rast.arrow/arrow.c:249 ../display/d.info/main.c:104
+#: ../display/d.info/main.c:129 ../display/d.legend/main.c:274
+#: ../display/d.graph/main.c:116 ../display/d.rast.num/number.c:163
+#: ../display/d.barscale/main.c:139 ../display/d.text.new/main.c:299
+#: ../display/d.paint.labels/main.c:121 ../display/d.text/main.c:151
+#: ../display/d.text.freetype/main.c:315
+msgid "No current window"
+msgstr "®ádné aktuální okno"
-#: ../raster/r.mfilter.fp/main.c:137 ../raster/r.mfilter/main.c:130
-msgid "Raster map too small for the size of the filter"
-msgstr "Rastrové mapa je pøíli¹ malá pro velikost filtru"
+#: ../display/d.rast.arrow/arrow.c:252 ../display/d.info/main.c:106
+#: ../display/d.info/main.c:131 ../display/d.legend/main.c:277
+#: ../display/d.graph/main.c:119 ../display/d.rast.num/number.c:166
+#: ../display/d.barscale/main.c:142 ../display/d.text.new/main.c:302
+#: ../display/d.paint.labels/main.c:124 ../display/d.text/main.c:154
+#: ../display/d.text.freetype/main.c:317
+msgid "Current window not available"
+msgstr "Aktuální okno není dostupné"
-#: ../raster/r.mfilter.fp/getrow.c:12 ../raster/r.mfilter/getrow.c:12
-#, c-format
-msgid "Cannot read raster row %d"
-msgstr "Nelze naèíst øádek rastrové mapy %d"
+#: ../display/d.rast.arrow/arrow.c:258 ../display/d.info/main.c:112
+#: ../display/d.rast.edit/cell.c:35 ../display/d.rast.num/number.c:173
+#: ../display/d.barscale/main.c:158 ../display/d.paint.labels/main.c:127
+msgid "Setting map window"
+msgstr "Nastavuji mapové okno"
-#: ../raster/r.mfilter.fp/getrow.c:23 ../raster/r.mfilter/getrow.c:23
-msgid "Error reading temporary file"
-msgstr "Chyba pøi ètení doèasného souboru"
+#: ../display/d.rast.arrow/arrow.c:261 ../display/d.rast.edit/cell.c:38
+#: ../display/d.rast.num/number.c:176 ../display/d.barscale/main.c:161
+#: ../display/d.paint.labels/main.c:130
+msgid "Current window not settable"
+msgstr "Aktuální okno nelze nastavit"
-#: ../raster/r.mfilter.fp/perform.c:42 ../raster/r.mfilter.fp/perform.c:53
-#: ../raster/r.mfilter/perform.c:42 ../raster/r.mfilter/perform.c:53
-msgid "Unable to create temporary file"
-msgstr "Nelze èíst doèasný soubor"
+#: ../display/d.rast.arrow/arrow.c:265 ../display/d.info/main.c:114
+#: ../display/d.graph/main.c:122 ../display/d.rast.num/number.c:181
+#: ../display/d.barscale/main.c:165 ../display/d.paint.labels/main.c:134
+msgid "Getting screen window"
+msgstr "Získání obrazového okna"
-#: ../raster/r.mfilter.fp/perform.c:85 ../raster/r.mfilter/perform.c:85
+#: ../display/d.rast.arrow/arrow.c:267 ../display/d.info/main.c:116
+#: ../display/d.rast.num/number.c:183 ../display/d.what.rast/main.c:131
+#: ../display/d.barscale/main.c:167 ../display/d.paint.labels/main.c:136
+msgid "Error in calculating conversions"
+msgstr "Chyba pøi pøepoèítávání"
+#: ../display/d.rast.arrow/arrow.c:314
+msgid "Problem reading range file"
+msgstr "Problém pøi èetní souboru s rozsahem hodnot"
+#: ../display/d.rast.arrow/arrow.c:370
+msgid "No raster map exists in the current window"
+msgstr "V aktuálním oknì neexistuje ¾ádná rastrová mapa"
+#: ../display/d.rast.arrow/arrow.c:382 ../display/d.rast.edit/cell.c:90
+#: ../display/d.rast.num/number.c:154 ../display/d.profile/What.c:30
+#: ../display/d.profile/ExtractProf.c:95 ../display/d.his/main.c:141
+#: ../display/d.his/main.c:166 ../display/d.what.rast/opencell.c:26
+#: ../display/d.rast/display.c:80 ../display/d.nviz/main.c:185
+#: ../display/d.rgb/main.c:104 ../doc/raster/r.example/main.c:121
+#: ../vector/v.what.rast/main.c:135 ../vector/v.sample/main.c:160
+#: ../vector/v.vol.rst/main.c:580 ../vector/v.drape/main.c:125
+#: ../vector/v.extrude/main.c:182 ../vector/v.to.rast/support.c:247
+#: ../vector/v.to.rast/support.c:396 ../visualization/xganim/main.c:346
+#: ../raster/r.to.rast3/main.c:358 ../raster/r.to.vect/main.c:112
+#: ../raster/r.buffer/read_map.c:41 ../raster/r.buffer/write_map.c:45
+#: ../raster/r.his/main.c:132 ../raster/r.his/main.c:158
+#: ../raster/r.his/main.c:186 ../raster/r.resamp.interp/main.c:137
+#: ../raster/r.texture/main.c:230 ../raster/r.null/null.c:307
+#: ../raster/r.out.ppm/main.c:120 ../raster/r.sum/main.c:68
+#: ../raster/r.clump/main.c:95 ../raster/r.univar2/r.univar_main.c:154
+#: ../raster/r.out.ascii/main.c:150 ../raster/r.out.vtk/main.c:224
+#: ../raster/r.out.vtk/main.c:286 ../raster/r.out.vtk/main.c:314
+#: ../raster/r.out.vtk/main.c:360 ../raster/r.surf.idw2/read_cell.c:36
+#: ../raster/r.random/count.c:24 ../raster/r.random/count.c:29
+#: ../raster/r.out.tiff/r.out.tiff.c:188 ../raster/r.cats/main.c:143
+#: ../raster/r.profile/main.c:144 ../raster/r.walk/main.c:545
+#: ../raster/r.walk/main.c:548 ../raster/r.walk/main.c:855
+#: ../raster/r.out.ppm3/main.c:121 ../raster/r.contour/main.c:160
+#: ../raster/wildfire/r.ros/main.c:441 ../raster/wildfire/r.ros/main.c:446
+#: ../raster/wildfire/r.ros/main.c:451 ../raster/wildfire/r.ros/main.c:456
+#: ../raster/wildfire/r.ros/main.c:461 ../raster/wildfire/r.ros/main.c:466
+#: ../raster/wildfire/r.ros/main.c:471 ../raster/wildfire/r.ros/main.c:477
+#: ../raster/wildfire/r.ros/main.c:482 ../raster/wildfire/r.ros/main.c:488
+#: ../raster/wildfire/r.spread/main.c:423
+#: ../raster/wildfire/r.spread/main.c:430
+#: ../raster/wildfire/r.spread/main.c:437
+#: ../raster/wildfire/r.spread/main.c:445
+#: ../raster/wildfire/r.spread/main.c:451
+#: ../raster/wildfire/r.spread/main.c:457
+#: ../raster/wildfire/r.spread/main.c:525 ../raster/r.thin/io.c:102
+#: ../raster/r.bilinear/main.c:92 ../raster/r.out.pov/main.c:175
+#: ../raster/r.composite/main.c:166 ../raster/r.out.gdal/main.c:101
+#: ../raster/r.los/main.c:196 ../raster/r.los/main.c:207
+#: ../raster/r.quantile/main.c:287 ../raster/r.grow2/main.c:201
+#: ../raster/r.surf.idw/main.c:135 ../raster/r.support/front/front.c:221
+#: ../raster/r.to.rast3elev/main.c:161 ../raster/r.out.mat/main.c:106
+#: ../raster/r.mapcalc/map3.c:527 ../raster/r.covar/main.c:99
+#: ../raster/r.cross/main.c:120 ../raster/r.resamp.rst/main.c:405
+#: ../raster/r.resamp.rst/main.c:437 ../raster/r.out.bin/main.c:133
+#: ../raster/r.carve/main.c:176 ../raster/r.out.arc/main.c:115
+#: ../raster/r.resamp.stats/main.c:335 ../raster/r.sunmask/main.c:435
+#: ../raster/r.bitpattern/main.c:108 ../raster/r.cost/main.c:337
+#: ../raster/r.surf.area/main.c:124 ../imagery/i.gensig/opencell.c:12
+#: ../imagery/i.pca/main.c:125 ../imagery/i.smap/shapiro/opencell.c:16
+#: ../imagery/i.his.rgb/openfiles.c:34 ../imagery/i.his.rgb/openfiles.c:39
+#: ../imagery/i.his.rgb/openfiles.c:44
#, c-format
-msgid "Writing raster map <%s>"
-msgstr "Zapisuji rastrovou mapu <%s>"
+msgid "Unable to open raster map <%s>"
+msgstr "Nelze otevøít rastrovou mapu <%s>"
-#: ../raster/r.random.surface/save.c:103
-#, c-format
+#: ../display/d.path/select.c:35
msgid ""
-"%s: saving [%s] raster map layer.\n"
-"Percent complete:"
+"\n"
+"Mouse Buttons:"
msgstr ""
-"%s: ukládám [%s] rastr\n"
-"Hotovo procent:"
+"\n"
+"Tlaèítka my¹i:"
-#: ../raster/r.random.surface/init.c:196
+#: ../display/d.path/select.c:36
#, c-format
-msgid "Seed [%d] larger than maximum [%d]"
-msgstr "Poèátek [%d] je vìt¹í ne¾ maximum [%d]"
+msgid "Left: Select From\n"
+msgstr " Levé: Vybrat z\n"
-#: ../raster/r.random.surface/init.c:199 ../raster/r.random.surface/init.c:207
+#: ../display/d.path/select.c:37
#, c-format
-msgid " seed is set to %d"
-msgstr " poèátek nastaven na %d"
+msgid "Middle: Select To\n"
+msgstr "Prostøední tlaèítko: Vybrat do\n"
-#: ../raster/r.random.surface/init.c:203
+#: ../display/d.path/select.c:38
#, c-format
-msgid "Seed [%d] smaller than minimum [%d]"
-msgstr "Poèátek [%d] je men¹í, ne¾ minimum [%d]"
+msgid ""
+"Right: Quit\n"
+"\n"
+msgstr ""
+" Pravé tlaèítko: ukonèit\n"
+"\n"
-#: ../raster/r.random.surface/main.c:49
-msgid "Generates random surface(s) with spatial dependence."
-msgstr "Vytvoøí prostorovì závislé povrchy náhodných hodnot."
+#: ../display/d.path/select.c:63 ../display/d.path/select.c:221
+#: ../display/d.path/select.c:237
+#, c-format
+msgid "Node %d: %f %f\n"
+msgstr "Uzel %d: %f %f\n"
-#: ../raster/r.random.surface/main.c:61
+#: ../display/d.path/select.c:139 ../display/d.path/select.c:255
#, c-format
-msgid "Starting map [%s]"
-msgstr "Vytváøím mapu [%s]"
+msgid "Destination unreachable\n"
+msgstr "Místo urèení nedosa¾itelné\n"
-#: ../raster/r.random.surface/main.c:72
+#: ../display/d.path/select.c:142 ../display/d.path/select.c:257
#, c-format
-msgid "Starting filter #%d, distance: %.*lf, exponent: %.*lf, flat: %.*lf"
-msgstr "Zaèínám filtrovat #%d, vzdálenost: %.*lf, exponent: %.*lf, flat: % *lf"
+msgid "Costs on the network = %f\n"
+msgstr "Náklady v síti = %f\n"
-#: ../raster/r.random.surface/main.c:81
-msgid "Percent done:"
-msgstr "Hotovo procent:"
+#: ../display/d.path/select.c:143 ../display/d.path/select.c:258
+#, c-format
+msgid ""
+" Distance to the network = %f, distance from the network = %f\n"
+"\n"
+msgstr " Vzdálenost k síti = %f, vzdálenost ze sítì = %f\n"
-#: ../raster/r.cost/btree.c:56
-msgid "new_cell is NULL"
-msgstr "new_cell je NULLa"
+#: ../display/d.path/main.c:48
+msgid "display, networking"
+msgstr "zobrazení, sítì"
-#: ../raster/r.cost/btree.c:154
-#, c-format
-msgid "Can't find %d,%d:%f"
-msgstr "Nelze nalézt %d,%d:%f"
+#: ../display/d.path/main.c:50
+msgid "Finds shortest path for selected starting and ending node."
+msgstr ""
+"Nalézá nejkrat¹í cestu ve vektorové síti pro zadaný poèáteèní a koncový bod."
-#: ../raster/r.cost/btree.c:196
-msgid "Illegal delete request"
-msgstr "Neplatná ¾ádost delete"
+#: ../display/d.path/main.c:57 ../vector/v.net.salesman/main.c:102
+#: ../vector/v.net.iso/main.c:79 ../vector/v.net.path/main.c:48
+#: ../vector/v.net.alloc/main.c:69 ../vector/v.net.steiner/main.c:331
+msgid "Arc type"
+msgstr "Typ hrany grafu"
-#: ../raster/r.cost/btree.c:406
-msgid "Nothing to show"
-msgstr "Není co ukázat"
+#: ../display/d.path/main.c:64
+msgid "Starting and ending coordinates"
+msgstr "Souøadnice poèátku a konce"
-#: ../raster/r.cost/btree.c:439
-msgid "Bad Start Cell"
-msgstr "©patná poèáteèní buòka"
+#: ../display/d.path/main.c:69 ../vector/v.net.salesman/main.c:106
+#: ../vector/v.net.iso/main.c:83 ../vector/v.net.path/main.c:53
+#: ../vector/v.net.alloc/main.c:74 ../vector/v.net.steiner/main.c:336
+msgid "Arc layer"
+msgstr "Vrstva hran"
-#: ../raster/r.cost/btree.c:455
-#, c-format
-msgid "%s %f-%f lower cost higher or equal"
-msgstr "%s %f-%f men¹í náklad vy¹íí nebo roven"
+#: ../display/d.path/main.c:74 ../vector/v.net.iso/main.c:88
+#: ../vector/v.net.path/main.c:58 ../vector/v.net.alloc/main.c:79
+msgid "Node layer"
+msgstr "Vrstva uzlu grafu"
-#: ../raster/r.cost/btree.c:462
-#, c-format
-msgid "%s lower above pointer wrong"
-msgstr "%s vý¹e nad poèátkem ¹patnì"
+#: ../display/d.path/main.c:80 ../vector/v.net.path/main.c:71
+msgid "Arc forward/both direction(s) cost column"
+msgstr "Sloupeèek nesoucí cenu pohybu ve smìru dopøedu nebo i zpìt."
-#: ../raster/r.cost/btree.c:471
-#, c-format
-msgid "%s %f-%f higher cost lower"
-msgstr "%s %f-%f vy¹¹í náklad"
+#: ../display/d.path/main.c:86 ../vector/v.net.path/main.c:77
+msgid "Arc backward direction cost column"
+msgstr "Sloupeèek nesoucí cenu pohybu ve smìru zpìt."
-#: ../raster/r.cost/btree.c:478
-#, c-format
-msgid "%s higher above pointer wrong"
-msgstr "%s ¹patnì vý¹e nad poèátkem"
+#: ../display/d.path/main.c:92 ../vector/v.net.path/main.c:83
+msgid "Node cost column"
+msgstr "Sloupec pro ocenìní uzlu"
-#: ../raster/r.cost/main.c:123
-msgid "raster, cost surface, cumulative costs"
-msgstr "rastrová mapa, povrch nákladù, kumulativní náklady"
+#: ../display/d.path/main.c:98 ../display/d.extract/main.c:63
+msgid "Original line color"
+msgstr "Pùvodní barva linie"
-#: ../raster/r.cost/main.c:125
-msgid ""
-"Outputs a raster map layer showing the cumulative cost of moving between "
-"different geographic locations on an input raster map layer whose cell "
-"category values represent cost."
-msgstr ""
-"Výstupní rastrová kumulativních nákladù pohybu mezi rùznými geografickými "
-"polohami na vstupní rastrové mapì s hodnotami nákladù."
+#: ../display/d.path/main.c:100 ../display/d.path/main.c:108
+#: ../display/d.path/main.c:116 ../display/d.path/main.c:126
+msgid "Rendering"
+msgstr "Vykresluji"
-#: ../raster/r.cost/main.c:132
-msgid "Name of raster map containing grid cell cost information"
-msgstr "Název rastrové mapy obsahující informace o nákladech"
+#: ../display/d.path/main.c:106 ../display/d.extract/main.c:69
+msgid "Highlight color"
+msgstr "Barva zvýraznìní"
-#: ../raster/r.cost/main.c:141 ../raster/r.walk/main.c:208
-msgid "Starting points vector map"
-msgstr "Vektorová mapa s poèáteèními body"
+#: ../display/d.path/main.c:121 ../vector/v.net.salesman/main.c:127
+#: ../vector/v.net.iso/main.c:124 ../vector/v.net.path/main.c:99
+#: ../vector/v.net.alloc/main.c:108 ../vector/v.net.steiner/main.c:364
+msgid "Use geodesic calculation for longitude-latitude locations"
+msgstr "Pou¾ít geodetický výpoèet pro location se zemìpisných systémem"
-#: ../raster/r.cost/main.c:148 ../raster/r.walk/main.c:215
-msgid "Stop points vector map"
-msgstr "Vektorová mapa s cílovými body"
+#: ../display/d.path/main.c:125
+msgid "Render bold lines"
+msgstr "Vykreslit silné linie"
-#: ../raster/r.cost/main.c:155
-msgid "Starting points raster map"
-msgstr "Rastrová mapa s poèáteèními body"
+#: ../display/d.path/main.c:142
+msgid "No coordinates given"
+msgstr "Nezadány ¾ádné mapové souøadnice"
-#: ../raster/r.cost/main.c:163 ../raster/r.walk/main.c:223
-msgid "The map E and N grid coordinates of a starting point (E,N)"
-msgstr "V a S souøadnice poèáteèního bodu (V,S)"
+#: ../display/d.path/main.c:145 ../display/d.path/main.c:149
+#, c-format
+msgid "%s - illegal x value"
+msgstr "%s - neplatná hodnota x"
-#: ../raster/r.cost/main.c:171 ../raster/r.walk/main.c:231
-msgid "The map E and N grid coordinates of a stopping point (E,N)"
-msgstr "V a S souøadnice cílového bodu (V,S)"
+#: ../display/d.path/main.c:147 ../display/d.path/main.c:151
+#, c-format
+msgid "%s - illegal y value"
+msgstr "%s - neplatná hodnota y"
-#: ../raster/r.cost/main.c:180 ../raster/r.walk/main.c:240
-msgid "An optional maximum cumulative cost"
-msgstr "Volitelné maximální kumulativní náklady"
+#: ../display/d.path/main.c:185 ../vector/v.net.path/main.c:117
+msgid "The current projection is not longitude-latitude"
+msgstr "Souèasná projekce není longitude-latidude (¹íøka-délka)"
-#: ../raster/r.cost/main.c:189 ../raster/r.walk/main.c:249
-msgid "Cost assigned to null cells. By default, null cells are excluded"
-msgstr ""
-"Náklad pøiøazený buòkám s hodnotou NULL. Pøi výchozím nastavení jsou tyto "
-"vynechány"
+#: ../display/d.info/main.c:35
+msgid "Display information about the active display monitor"
+msgstr "Zobraz informace o aktivním monitoru"
-#: ../raster/r.cost/main.c:203 ../raster/r.walk/main.c:301
-msgid "Use the 'Knight's move'; slower, but more accurate"
-msgstr "Pou¾ij '¹achového konì'; pomalej¹í, ale pøesnìj¹í"
+#: ../display/d.info/main.c:39
+msgid "Display screen rectangle (left, right, top, bottom)"
+msgstr "Zobrazit hranice obrazovky (levý, pravý, horní, dolní)"
-#: ../raster/r.cost/main.c:207 ../raster/r.walk/main.c:305
-msgid "Keep null values in output map"
-msgstr "Nullové hodnoty ponechej ve výstupní mapì"
+#: ../display/d.info/main.c:43
+msgid "Display screen dimensions (width, height)"
+msgstr "Zobrazit rozmìry obrazovky (¹íøka, vý¹ka)"
-#: ../raster/r.cost/main.c:211 ../raster/r.walk/main.c:309
-msgid "Start with values in raster map"
-msgstr "Zaèni s hodnotami v rastrové mapì"
+#: ../display/d.info/main.c:47
+msgid "Display active frame rectangle"
+msgstr "Zobrazit hranice aktivního rámce"
-#: ../raster/r.cost/main.c:216 ../raster/wildfire/r.ros/main.c:291
-#: ../vector/v.kernel/main.c:156 ../display/d.vect/main.c:320
-msgid "Run verbosely"
-msgstr "Roz¹íøený výpis"
+#: ../display/d.info/main.c:51
+msgid "Display screen rectangle of current region"
+msgstr "Zobrazit hranice obrazovky aktuálního regionu"
-#: ../raster/r.cost/main.c:237 ../raster/r.water.outlet/main.c:85
-#: ../raster/r.walk/main.c:324
-msgid "Unable to read current window parameters"
-msgstr "Nelze pøeèíst parametry aktuálního okna"
-#: ../raster/r.cost/main.c:270
-msgid "Must specify exactly one of start_points, start_rast or coordinate"
+#: ../display/d.info/main.c:55
+msgid ""
+"Display screen rectangle coordinates and resolution (west, east, north, "
+"south, ewres, nsres)"
msgstr ""
-"Alespoò jedna z voleb start_points, start_rast nebo coordinate musí být "
-"zadána"
+"Zobrazit pravoúhlé souøadnice a rozli¹ení displeje (západ, východ, sever, "
+"jih, VZrozl, SJrozl)"
-#: ../raster/r.cost/main.c:275 ../raster/r.cost/main.c:525
-#: ../raster/r.cost/main.c:630
-msgid "No start points"
-msgstr "®ádné poèáteèní body"
+#: ../display/d.info/main.c:59
+msgid "Display number of colors"
+msgstr "Zobraz poèet barev"
-#: ../raster/r.cost/main.c:282 ../raster/r.walk/main.c:351
-#, c-format
-msgid "Inappropriate maximum cost: %d"
-msgstr "Nevhodné maximální náklady: %d"
+#: ../display/d.colortable/main.c:66
+msgid "Displays the color table associated with a raster map layer."
+msgstr "Vytvoøí/mìní tabulku barev spojenou s rastrovou mapou."
-#: ../raster/r.cost/main.c:285 ../raster/r.walk/main.c:354
-#, c-format
-msgid "Inappropriate percent memory: %d"
-msgstr "Nevhodné procento pamìti: %d"
+#: ../display/d.vect/main.c:126
+msgid "display, vector"
+msgstr "zobrazení, vekrotové mapa"
-#: ../raster/r.cost/main.c:289 ../raster/r.walk/main.c:393
-msgid "Null cells excluded from cost evaluation."
-msgstr "Buòky bez hodnot jsou vylouèeny pro poèítání nákladù"
+#: ../display/d.vect/main.c:128
+msgid "Displays vector data in the active frame on the graphics monitor."
+msgstr "Zobrazit vektorová data v aktivním rámu grafického monitoru."
-#: ../raster/r.cost/main.c:293 ../raster/r.walk/main.c:397
-msgid "Input null cell will be retained into output map"
-msgstr "Vstupní buòky neobsahující hodnotu budou pøevedeny do výstupní mapy"
+#: ../display/d.vect/main.c:140
+msgid "Display"
+msgstr "Zobrazit"
-#: ../raster/r.cost/main.c:303 ../raster/r.walk/main.c:495
-msgid "Warning: assigning negative cost to null cell. Null cells excluded."
-msgstr ""
-"Varování: pøiøazuji negativní hodnotu nákladù pro buòku bez hodnoty. Buòky "
-"neobsahující hodnotu jsou vylouèeny."
+#: ../display/d.vect/main.c:146 ../display/d.vect/main.c:150
+#: ../display/d.vect/main.c:153 ../display/d.vect/main.c:156
+#: ../display/d.vect/main.c:346 ../display/d.thematic.area/main.c:106
+#: ../vector/v.edit1/cmd/args.c:40 ../vector/v.edit1/cmd/args.c:45
+#: ../vector/v.edit1/cmd/args.c:120 ../vector/v.edit1/cmd/args.c:125
+#: ../vector/v.edit1/cmd/args.c:134 ../vector/v.edit1/cmd/args.c:143
+#: ../vector/v.edit1/cmd/args.c:152 ../vector/v.edit1/cmd/args.c:155
+#: ../vector/v.edit1/cmd/args.c:168 ../vector/v.in.ogr/main.c:126
+#: ../vector/v.in.ogr/main.c:139 ../vector/v.in.ogr/main.c:160
+#: ../vector/v.edit/args.c:40 ../vector/v.edit/args.c:45
+#: ../vector/v.edit/args.c:123 ../vector/v.edit/args.c:128
+#: ../vector/v.edit/args.c:137 ../vector/v.edit/args.c:146
+#: ../vector/v.edit/args.c:155 ../vector/v.edit/args.c:158
+#: ../vector/v.edit/args.c:171
+msgid "Query"
+msgstr "Dotaz"
-#: ../raster/r.cost/main.c:346
-msgid "Source map is: Integer cell type"
-msgstr "Zdrojová mapa je celoèíselného typu"
+#: ../display/d.vect/main.c:149 ../display/d.thematic.area/main.c:103
+msgid "Layer number. If -1, all layers are displayed."
+msgstr "Èíslo vrstvy. Pokud -1, jsou zobrazeny v¹echny vrstvy."
-#: ../raster/r.cost/main.c:349
-msgid "Source map is: Floating point (float) cell type"
-msgstr "Zdrojová mapa obsahuje hodnoty s plovoucí desetinnou èárkou (float)"
+#: ../display/d.vect/main.c:163
+msgid "Line color"
+msgstr "Barva linie"
-#: ../raster/r.cost/main.c:352
-msgid "Source map is: Floating point (double) cell type"
-msgstr "Zdrojová mapa obsahuje hodnoty s plovoucí desetinnou èárkou (double)"
+#: ../display/d.vect/main.c:164 ../display/d.vect/main.c:172
+#: ../display/d.vect/main.c:180 ../display/d.vect/main.c:332
+#: ../display/d.vect/main.c:338 ../vector/v.label.sa/main.c:150
+#: ../vector/v.label.sa/main.c:159 ../vector/v.label.sa/main.c:166
+#: ../vector/v.label.sa/main.c:175 ../vector/v.label.sa/main.c:185
+#: ../vector/v.label.sa/main.c:194 ../vector/v.label.sa/main.c:201
+#: ../vector/v.label/main.c:152 ../vector/v.label/main.c:176
+#: ../vector/v.label/main.c:189 ../vector/v.label/main.c:195
+#: ../vector/v.label/main.c:205 ../raster/r.colors/main.c:172
+#: ../raster/r.colors/main.c:185 ../raster/r.colors/main.c:202
+#: ../raster/r.colors/main.c:207 ../raster/r.colors/main.c:212
+msgid "Colors"
+msgstr "Barvy"
-#: ../raster/r.cost/main.c:355 ../raster/r.walk/main.c:585
-#: ../raster/r.walk/main.c:602 ../raster/r.walk/main.c:639
-#, c-format
-msgid " %d rows, %d cols"
-msgstr "%d øádkù, %d sloupcù"
+#: ../display/d.vect/main.c:171
+msgid "Area fill color"
+msgstr "Barva výplnì plochy"
-#: ../raster/r.cost/main.c:366 ../raster/r.walk/main.c:657
-#, fuzzy
-msgid "Creating some temporary files..."
-msgstr "Vytváøím nìjaké doèasné soubory..."
+#: ../display/d.vect/main.c:182
+msgid "Name of color definition column (for use with -a flag)"
+msgstr "Jméno sloupce s definicí barvy (pou¾it spolu s volbou -a)"
-#: ../raster/r.cost/main.c:387 ../raster/r.cost/main.c:599
-#, c-format
-msgid "Reading %s"
-msgstr "Naèítám %s"
+#: ../display/d.vect/main.c:190 ../display/d.vect/main.c:196
+#: ../display/d.vect/main.c:203
+msgid "Lines"
+msgstr "Linie"
-#: ../raster/r.cost/main.c:450 ../raster/r.walk/main.c:813
-msgid "Initializing output "
-msgstr "Inicializuji výstup"
+#: ../display/d.vect/main.c:191
+msgid "Line width"
+msgstr "©íøka linie"
-#: ../raster/r.cost/main.c:459 ../raster/r.walk/main.c:821
-msgid "Unable to allocate memory for segment fbuff == NULL"
-msgstr "Nelze alokovat pamì» pro segment fbuff == NULL"
+#: ../display/d.vect/main.c:197
+msgid "Name of column for line widths (these values will be scaled by wscale)"
+msgstr ""
+"Jméno sloupce se ¹íøkou linií (tyto hodnoty budou upraveny parametrem wscale)"
-#: ../raster/r.cost/main.c:587
-#, c-format
-msgid "can't open raster map [%s] needed for input coordinates"
-msgstr "nemohu otevøít rastrový soubor [%s] potøebný pro vstupní souøadnice"
+#: ../display/d.vect/main.c:204
+msgid "Scale factor for wcolumn"
+msgstr "Mìøítkový faktor wcolumn"
-#: ../raster/r.cost/main.c:645 ../raster/r.walk/main.c:913
-msgid "Specified starting location outside database window"
-msgstr "Zadaná poèáteèní pozice je mimo aktuální výøez"
+#: ../display/d.vect/main.c:212 ../display/d.vect/main.c:222
+msgid "Symbols"
+msgstr "Symboly"
-#: ../raster/r.cost/main.c:660 ../raster/r.walk/main.c:930
-msgid "Finding cost path"
-msgstr "Hledám nákladovou cestu"
+#: ../display/d.vect/main.c:216
+msgid "Point and centroid symbol"
+msgstr "Bod nebo centroid symbolu"
-#: ../raster/r.cost/main.c:885 ../raster/r.walk/main.c:1377
-msgid "End of map!"
-msgstr "Konec mapy!"
+#: ../display/d.vect/main.c:223
+msgid "Symbol size"
+msgstr "Velikost symbolu"
-#: ../raster/r.cost/main.c:889 ../raster/r.walk/main.c:1381
-msgid "Error, ct == pres_cell"
-msgstr "Chyba, ct == pres_cell"
+#: ../display/d.vect/main.c:231 ../display/d.vect/main.c:237
+#: ../display/d.vect/main.c:245 ../display/d.vect/main.c:252
+#: ../display/d.vect/main.c:260 ../display/d.vect/main.c:268
+#: ../display/d.vect/main.c:274 ../display/d.vect/main.c:280
+#: ../display/d.vect/main.c:288
+msgid "Labels"
+msgstr "©títky"
-#: ../raster/r.cost/main.c:901
-#, c-format
-msgid "Writing %s"
-msgstr "Zapisuji %s"
+#: ../display/d.vect/main.c:232
+msgid "Name of column to be displayed"
+msgstr "Název sloupce pro zobrazení"
-#: ../raster/r.cost/main.c:905 ../raster/r.walk/main.c:1399
-msgid "Will copy input map null values into output map"
-msgstr "Zkopíruje buòky bez hodnoty do výstupní mapy."
+#: ../display/d.vect/main.c:238
+msgid "Layer for labels (default: the given layer number)"
+msgstr "Vrstva pro poisování (základ: daná vrstva)"
-#: ../raster/r.cost/main.c:912 ../raster/r.walk/main.c:1406
-msgid ""
-"Integer cell type.\n"
-"Writing..."
-msgstr ""
-"Celoèíselná mapa\n"
-"Zapisuji..."
+#: ../display/d.vect/main.c:244
+msgid "Label color"
+msgstr "Barva popiskù"
-#: ../raster/r.cost/main.c:917 ../raster/r.cost/main.c:949
-#: ../raster/r.cost/main.c:981
-msgid "Error getting input null cells"
-msgstr "Chyba pøi získávání bunìk bez hodnot"
+#: ../display/d.vect/main.c:253
+msgid "Label background color"
+msgstr "Barva pozadí popiskù"
-#: ../raster/r.cost/main.c:944 ../raster/r.walk/main.c:1441
-msgid ""
-"Float cell type.\n"
-"Writing..."
-msgstr ""
-"Mapa s plovoucí desetinnou èárkou (float)\n"
-"Zapisuji..."
+#: ../display/d.vect/main.c:261
+msgid "Label border color"
+msgstr "Barva rámeèku popiskù"
-#: ../raster/r.cost/main.c:976 ../raster/r.walk/main.c:1476
-msgid ""
-"Double cell type.\n"
-"Writing..."
-msgstr ""
-"Mapa s plovoucí desetinnou èárkou (double)\n"
-"Zapisuji..."
+#: ../display/d.vect/main.c:269
+msgid "Label size (pixels)"
+msgstr "Velikost popiskù (v pixelech)"
-#: ../raster/r.cost/main.c:1008 ../raster/r.walk/main.c:1511
-#, c-format
-msgid "Peak cost value: %f"
-msgstr "Nejvy¹¹í náklady: %f"
+#: ../display/d.vect/main.c:275 ../display/d.text.new/main.c:212
+#: ../display/d.text.freetype/main.c:170 ../vector/v.label/main.c:123
+msgid "Font name"
+msgstr "Název písma"
-#: ../raster/r.cost/main.c:1051 ../raster/r.walk/main.c:1562
-#, c-format
-msgid "Illegal x coordinate <%s>"
-msgstr "Neplatná souøadnice x <%s>"
+#: ../display/d.vect/main.c:283
+msgid "Label horizontal justification"
+msgstr "Horizontální zarovnání popiskù"
-#: ../raster/r.cost/main.c:1053 ../raster/r.walk/main.c:1564
-#, c-format
-msgid "Illegal y coordinate <%s>"
-msgstr "Neplatná souøadnice y <%s>"
+#: ../display/d.vect/main.c:291
+msgid "Label vertical justification"
+msgstr "Vertikální zarovnání popiskù"
-#: ../raster/r.cost/main.c:1057 ../raster/r.walk/main.c:1568
-#, c-format
-msgid "Warning, ignoring point outside window: %.4f,%.4f"
-msgstr "Varování, ignoruji bod mimo okno: %.4f, %.4f"
-#: ../raster/r.out.vtk/parameters.c:48
-msgid "Elevation raster map"
-msgstr "Rastrová mapa elevace"
-#: ../raster/r.out.vtk/parameters.c:54
-msgid "Value to represent no data cell"
-msgstr "Hodnota pro oznaèení bunìk \"¾ádná data\""
-#: ../raster/r.out.vtk/parameters.c:61
-msgid "Elevation (if no elevation map is specified)"
-msgstr "Elevace (pokud není zadána mapa elevace)"
-#: ../raster/r.out.vtk/parameters.c:68
+#: ../display/d.vect/main.c:297
msgid ""
-"Create VTK point data instead of VTK cell data (if no elevation map is given)"
+"Minimum region size (average from height and width) when map is displayed"
msgstr ""
-"Vytvoøí bodová data VTK z rastrových dat VTK (pokud není zadána ¾ádná mapa s "
-"elevací)"
+"Minimální velikost regionu (prùmìr vý¹ky a ¹íøky), kdy¾ je mapa zobrazena"
-#: ../raster/r.out.vtk/parameters.c:79
+#: ../display/d.vect/main.c:305
msgid ""
-"Three (r,g,b) raster maps to create rgb values [redmap,greenmap,bluemap]"
+"Maximum region size (average from height and width) when map is displayed"
msgstr ""
-"Tøi rastrové mapy (r,g,b), které jsou pou¾ity pro vytvoøení hodnot rgb "
-"[redmap,greenmap,bluemap]"
+"Maximální velikost regionu (prùmìr vý¹ky a ¹íøky), kdy¾ je mapa zobrazena"
-#: ../raster/r.out.vtk/parameters.c:90
-msgid "Three (x,y,z) raster maps to create vector values [xmap,ymap,zmap]"
+#: ../display/d.vect/main.c:315 ../display/d.thematic.area/main.c:130
+msgid "Rendering method for filled polygons"
+msgstr "Vykreslovací metoda pro plné polygony"
+#: ../display/d.vect/main.c:317 ../display/d.thematic.area/main.c:132
+msgid ""
+"g;use the libgis render functions (features: clipping);r;use the raster "
+"graphics library functions (features: polylines);d;use the display library "
+"basic functions (features: polylines);c;use the display library clipping "
+"functions (features: clipping);l;use the display library culling functions "
+"(features: culling, polylines)"
msgstr ""
-"Tøi rastrové mapy (x,y,z), které jsou pou¾ity pro vytvoøení hodnot vektorù "
-"[xmap,ymap,zmap]"
+"g;pou¾ití vykreslovacích funkcí(prvky:vystøihování);r;pou¾ití knihovny "
+"funkcí pro rastrovou grafiku (prvky: lomená èára);d;pou¾ití knihovny "
+"základních zobrazovacích funkcí (prvky: lomená èára);c; pou¾ití knihovny "
+"zobrazovacích vystøihovacích funkcí (prvky: vystøihování);l;pou¾ití knihovny "
+"zobrazovacích odstraòovacích funkcí (prvky: odstranìní, lomená èára)"
-#: ../raster/r.out.vtk/parameters.c:115
-msgid "Use structured grid for elevation (not recommended)"
-msgstr "Pou¾ít strukturovanou møí¾ku pro vý¹kový model (není doporuèeno)"
+#: ../display/d.vect/main.c:327 ../vector/v.kernel/main.c:156
+#: ../raster/wildfire/r.ros/main.c:291 ../raster/r.cost/main.c:216
+msgid "Run verbosely"
+msgstr "Roz¹íøený výpis"
-#: ../raster/r.out.vtk/parameters.c:121
-msgid "Use polydata-trianglestrips for elevation grid creation"
-msgstr "Pou¾ij polygonové trojíºhelníkové pásy pro vytvoøení mapy elevace"
+#: ../display/d.vect/main.c:334
+msgid "Get colors from map table column (of form RRR:GGG:BBB)"
+msgstr "Získat barvu z atributové tabulky (ve formì RRR:GGG:BBB)"
-#: ../raster/r.out.vtk/parameters.c:128
+#: ../display/d.vect/main.c:340
msgid ""
-"Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
+"Random colors according to category number (or layer number if 'layer=-1' is "
+"given)"
msgstr ""
-"Pou¾ij vrcholy polygonù pro vytvoøení rastru elevace (k pou¾ití spolu s "
-"vtkDelauny2D)"
+"Náhodné barvy podle èísel kategorií (nebo èísla vrstvy, pokud je zadáno "
+"'layer=-1')"
-#: ../raster/r.out.vtk/parameters.c:134
-msgid "Scale factor effects the origin (if no elevation map is given)"
-msgstr "Faktor mìøítka ovlivní vstup (pokud není zadaná mapa elevace)"
+#: ../display/d.vect/main.c:347
+msgid "Use values from 'cats' option as feature id"
+msgstr "Pou¾ít hodnoty z 'cats' jako ID prvku"
-#: ../raster/r.out.vtk/writeascii.c:73
-msgid "write_vtk_normal_header: Writing VTK-Header"
-msgstr "write_vtk_normal_header: Zapisuji hlavièku VTK"
+#: ../display/d.vect/main.c:352 ../display/d.thematic.area/main.c:152
+msgid ""
+"Don't add to list of vectors and commands in monitor (it won't be drawn if "
+"the monitor is refreshed)"
+msgstr ""
+"Nepøidávej do seznamu vektorù a pøíkazù v monitoru (nebude vykresleno, pokud "
+"monitoru bude pøekreslen)"
-#: ../raster/r.out.vtk/writeascii.c:104
-msgid "write_vtk_structured_elevation_header: Writing VTK-Header"
-msgstr "write_vtk_structured_elevation_header: Zapisuji hlavièku VTK"
+#: ../display/d.vect/main.c:395 ../display/d.paint.labels/main.c:99
+msgid "Region size is lower than minreg, nothing displayed."
+msgstr "Velikost oblasti je men¹í, ne¾ minreg, nic není zobrazeno."
-#: ../raster/r.out.vtk/writeascii.c:120
-msgid "write_vtk_polygonal_elevation_header: Writing VTK-Header"
-msgstr "write_vtk_polygonal_elevation_header: Zapisuji hlavièku VTK"
+#: ../display/d.vect/main.c:404 ../display/d.paint.labels/main.c:108
+msgid "Region size is greater than maxreg, nothing displayed."
+msgstr "Velikost regionu je vìt¹í, ne¾ maxreg, zobrazeno není nic."
-#: ../raster/r.out.vtk/writeascii.c:135
-msgid "write_vtk_celldata_header: Writing VTK-DataHeader"
-msgstr "write_vtk_celldata_header: Zapisuji hlavièku VTK"
+#: ../display/d.vect/main.c:420
+msgid ""
+"The '-c' and '-a' flags cannot be used together, the '-c' flag will be "
+"ignored!"
+msgstr ""
+"Pøepínaèe '-c' a '-a' nemohou být pou¾ity spolu, ignoruji pøepínaè 'c'!"
-#: ../raster/r.out.vtk/writeascii.c:144
-msgid "writeVTKPointHeader: Writing VTK-DataHeader"
-msgstr "writeVTKPointHeader: Zapisuji hlavièku VTK"
-#: ../raster/r.out.vtk/writeascii.c:165
-msgid "write_vtk_structured_coordinates: Writing Coordinates"
-msgstr "write_vtk_structured_coordinates: Zapisuji souøadnice"
-#: ../raster/r.out.vtk/writeascii.c:181 ../raster/r.out.vtk/writeascii.c:238
-#: ../raster/r.out.vtk/writeascii.c:347 ../raster/r.out.vtk/writeascii.c:393
-#: ../raster/r.out.vtk/writeascii.c:397 ../raster/r.out.vtk/writeascii.c:401
-#: ../raster/r.out.vtk/writeascii.c:459 ../raster/r.out.vtk/writeascii.c:463
-#: ../raster/r.out.vtk/writeascii.c:467
+#: ../display/d.vect/main.c:434 ../display/d.vect/main.c:447
+#: ../display/d.thematic.area/main.c:271
#, c-format
-msgid "Unable to read row %i\n"
-msgstr "Nelze èíst øádek %i\n"
+msgid "Unknown color: [%s]"
+msgstr "Neznámá barva: [%s]"
-#: ../raster/r.out.vtk/writeascii.c:220
-msgid "write_vtk_polygonal_coordinates: Writing VTK Polygonal data"
-msgstr "write_vtk_polygonal_coordinates: Zapisuji polygony VTK"
+#: ../display/d.vect/main.c:452 ../display/d.graph/do_graph.c:426
+#: ../imagery/i.vpoints/plot.c:62 ../imagery/i.vpoints/plot.c:145
+msgid "Cannot read symbol, cannot display points"
+msgstr "Nelze èíst symbol, nemohu zobrazit body"
-#: ../raster/r.out.vtk/writeascii.c:329
-msgid "write_vtk_data: Writing VTK-Data"
-msgstr "write_vtk_data: Zapisuji data VTK"
+#: ../display/d.vect/main.c:472 ../vector/v.surf.rst/main.c:404
+#: ../vector/v.extract/main.c:212
+msgid "'layer' must be > 0 for 'where'."
+msgstr "'layer' musí být . 0 pro 'where'"
-#: ../raster/r.out.vtk/writeascii.c:381
-msgid "write_vtk_rgb_image_data: Writing VTK-ImageData"
-msgstr "write_vtk_rgb_image_data: Zapisuji VTK-ImageData"
+#: ../display/d.vect/main.c:499
+msgid "'layer' must be > 0 for 'cats'."
+msgstr "pøi volbì 'cats' musí být parametr 'layer'> 0"
-#: ../raster/r.out.vtk/writeascii.c:419
-msgid "Wrong map values! Values should in between 0 and 255!\n"
-msgstr "Chybné hodnoty mapy! Hodnoty by mìly být v rozmezí 0 a 255!\n"
+#: ../display/d.vect/main.c:503
+#, c-format
+msgid "%d errors in cat option"
+msgstr "%d chyb ve volbì cat"
-#: ../raster/r.out.vtk/writeascii.c:447
-msgid "write_vtk_vector_data: Writing VTK-vector data"
-msgstr "write_vtk_vector_data: Zapisuji data VTK-vektor"
+#: ../display/d.vect/main.c:623 ../display/d.thematic.area/main.c:322
+msgid "Plotting ..."
+msgstr "Tisknu ..."
-#: ../raster/r.out.vtk/main.c:79
-#, fuzzy, c-format
-msgid "RGB raster map <%s> not found"
-msgstr "Rastrová mapa <%s> nenalezena"
+#: ../display/d.vect/main.c:632 ../display/d.thematic.area/main.c:330
+msgid ""
+"The bounding box of the map is outside the current region, nothing drawn."
+msgstr "Okraj mapy je mimo souèasný region, nic není vykresleno."
-#: ../raster/r.out.vtk/main.c:87
-msgid "Cannot create RGB data, please provide three maps [r,g,b]"
-msgstr "Nelze vytvoøit data RGB, prosím zadejte tøi mapy [r,g,b]"
+#: ../display/d.vect/main.c:658
+msgid "Cannot display areas, topology not available"
+msgstr "Nelze zobrazit plochy, topologie není dostupná"
-#: ../raster/r.out.vtk/main.c:103
-#, fuzzy, c-format
-msgid "Vector cell map <%s> not found"
-msgstr "Vektorová mapa <%s> nebyla nalezena"
+#: ../display/d.vect/main.c:663
+msgid "Cannot display lines by id, topology not available"
+msgstr "Nelze zobrazit linie podle id, topologie není dostupná"
-#: ../raster/r.out.vtk/main.c:111
-msgid "Cannot create vector data, please provide three maps [x,y,z]"
-msgstr ""
-"Nelze vytvoøit vektorová data, prosím zadejte tøi mapové vrstvy [x,y,z]"
+#: ../display/d.vect/main.c:701
+msgid "Cannot display topology, not available"
+msgstr "Nelze zobrazit topologii, není dostupná"
-#: ../raster/r.out.vtk/main.c:151
-msgid "Converts raster maps into the VTK-Ascii format"
-msgstr "Pøevede rastrové mapy do formátu VTK-Ascii"
-#: ../raster/r.out.vtk/main.c:217 ../raster/r.out.vtk/main.c:278
-#: ../raster/r.out.vtk/main.c:305 ../raster/r.out.vtk/main.c:350
+#: ../display/d.vect/topo.c:38 ../display/d.thematic.area/plot1.c:289
#, c-format
-msgid "Open Raster file %s"
-msgstr "Otevøít rastrový soubor %s"
-#: ../raster/r.out.vtk/main.c:321
-msgid "Writing VTK ImageData\n"
-msgstr "Zapisuji obrazová data VTK\n"
-#: ../raster/r.out.vtk/main.c:331
-msgid "Wrong RGB maps. Maps should have the same type! RGB output not added!"
+msgid ""
+"\n"
+"ERROR: vector map - can't read\n"
msgstr ""
-"Chybná mapa RGB. Mapy by mìly být stejného typu! Nebyl pøidán RGB výstup!"
+"\n"
+"CHYBA: vektorový soubor - nelze èíst\n"
-#: ../raster/r.out.vtk/main.c:368
-msgid "Writing VTK Vector Data\n"
-msgstr "Zapisuji VTK Vector data\n"
+#: ../display/d.vect/label.c:31 ../display/d.vect/attr.c:53
+#: ../display/d.vect/dir.c:30
+msgid "Can't read vector map"
+msgstr "Nelze èíst vektorovtou mapu"
-#: ../raster/r.out.vtk/main.c:378
-msgid ""
-"Wrong vector maps. Maps should have the same type! Vector output not added!"
-msgstr ""
-"Chybné vektorové vrstvy. Mapy by mìly být stejného typu! Vektorový výstup "
-"nebyla pøidána!"
+#: ../display/d.vect/attr.c:30
+msgid "attrcol not specified, cannot display attributes"
+msgstr "Parametr attrcol nebyl zadán, nemohu zobrazit atributy"
-#: ../raster/r.support/modcolr/modcolr.c:37
-msgid "Which raster map needs a color table"
-msgstr "Který rastrový soubor vy¾aduje tabulku barev"
-#: ../raster/r.support/modcolr/modcolr.c:51
+#: ../display/d.vect/attr.c:44 ../display/d.vect/area.c:57
+#: ../display/d.vect/plot1.c:203 ../display/d.thematic.area/plot1.c:198
+#: ../vector/v.surf.rst/main.c:553 ../vector/v.in.dxf/write_vect.c:185
+#: ../vector/v.in.ogr/main.c:707
#, c-format
-msgid "Color table for <%s> updated"
-msgstr "Tabulka barev pro <%s> byla aktualizována"
+msgid "Cannot open database %s by driver %s"
+msgstr "Nelze otevøít databázi %s ovladaèem %s"
-#: ../raster/r.support/modhead/modhead.c:70
+#: ../display/d.vect/attr.c:103
#, c-format
-msgid "Edit header for [%s]\n"
-msgstr "Edituj hlavièku pro [%s]\n"
+msgid "Cannot select attributes: %s"
+msgstr "Nelze vybrat atributy: %s"
-#: ../raster/r.support/modhead/modhead.c:73
+#: ../display/d.vect/attr.c:119
#, c-format
-msgid "[%s] cannot be found!"
-msgstr "[%s] nemù¾e být nalezen!"
+msgid "No attribute found for cat %d: %s"
+msgstr "®ádné atributy pro kategorii %d nebyly nalezeny: %s"
-#: ../raster/r.support/modhead/modhead.c:75
-msgid "For what layer shall the header file be edited? "
-msgstr "Pro kterou vrstvu má být upraven soubor s hlavièkou? "
+#: ../display/d.vect/area.c:52 ../display/d.vect/plot1.c:198
+#: ../display/d.thematic.area/plot1.c:193
+#: ../vector/lidar/v.surf.bspline/main.c:291
+msgid "Cannot read field info"
+msgstr "Nelze èíst informace o vrstvì"
-#: ../raster/r.support/modhead/modhead.c:85
+#: ../display/d.vect/area.c:65 ../display/d.vect/plot1.c:210
+#: ../display/d.thematic.area/plot1.c:206
+msgid "Color definition column not specified."
+msgstr "Nebyl zadán sloupec s definicí barvy."
+#: ../display/d.vect/area.c:75 ../display/d.vect/plot1.c:220
+#: ../display/d.thematic.area/plot1.c:216
#, c-format
-msgid "[%s] is a reclass of [%s] - cannot edit header! Run support on [%s]."
+msgid ""
+"Color definition column (%s) not a string. Column must be of form RRR:GGG:"
+"BBB where RGB values range 0-255."
msgstr ""
-"[%s] je reklasifikací [%s] - nemohu upravit hlavièku! Spus»te r.support pro "
-"[%s]."
+"Sloupec s definicí barvy (%s) není textového typu. Sloupec musí být ve formì "
+"ÈÈÈ:ZZZ:MMM, kde hodnoty barev (èervená, zelená, modrá) jsou v rozmení 0-255"
-#: ../raster/r.support/modhead/modhead.c:89
+#: ../display/d.vect/area.c:80 ../display/d.vect/area.c:105
+#: ../display/d.vect/plot1.c:224 ../display/d.vect/plot1.c:249
+#: ../display/d.thematic.area/main.c:230
+#: ../display/d.thematic.area/plot1.c:221
+#: ../display/d.thematic.area/plot1.c:248
#, c-format
-msgid "[%s] is a reclass of [%s in %s] - cannot edit header!"
-msgstr "[%s] je reklasifikací [%s v %s] - nemohu upravit hlavièku!"
+msgid "Cannot select data (%s) from table"
+msgstr "Nelze vybrat data (%s) z tabulky"
-#: ../raster/r.support/modhead/modhead.c:95
-#, c-format
-msgid "Cannot open raster map [%s]!"
-msgstr "Nelze otevøít rastrový soubor [%s]!"
+#: ../display/d.vect/area.c:92 ../display/d.vect/plot1.c:236
+#: ../display/d.thematic.area/plot1.c:233
+msgid "Line width column not specified."
+msgstr "Nebyl zadán sloupec se ¹íøkou linie."
-#: ../raster/r.support/modhead/modhead.c:100
+#: ../display/d.vect/area.c:102 ../display/d.vect/plot1.c:246
+#: ../display/d.thematic.area/plot1.c:244
#, c-format
-msgid "Raster file [%s] is empty."
-msgstr "Rastrový soubor [%s] je prázdný."
+msgid "Line width column (%s) not a number."
+msgstr "sloupec ¹íøky linie (%s) není èíselného typu"
-#: ../raster/r.support/modhead/modhead.c:102
+#: ../display/d.vect/area.c:236
#, c-format
-msgid "Error reading raster map [%s]."
-msgstr "Chyba pøi ètení rastrového souboru [%s]."
+msgid ""
+"Error in color definition column (%s), area %d with cat %d: colorstring [%s]"
+msgstr ""
+"Chyba ve sloupci s definicí barvy (%s), plocha %d, kategorie %d: barevný "
+"øetìzec [%s]"
-#: ../raster/r.support/modhead/modhead.c:191
+#: ../display/d.vect/area.c:242
#, c-format
-msgid "cellhd compression: %d\n"
-msgstr "komprese cellhd: %d\n"
+msgid "Error in color definition column (%s), area %d with cat %d"
+msgstr "Chyba ve sloupci s definicí barvy (%s), plocha %d, kategorie %d"
-#: ../raster/r.support/modhead/modhead.c:192
+#: ../display/d.vect/area.c:295 ../display/d.vect/plot1.c:421
+#: ../display/d.thematic.area/plot1.c:437
#, c-format
-msgid "3.0 compression %sindicated\n"
-msgstr "%sindikována 3.0 komprese\n"
+msgid ""
+"Error in line width column (%s), element %d with cat %d: line width [%d]"
+msgstr ""
+"Chyba ve sloupci se ¹íøkou linie (%s), prvek %d, kategorie %d: ¹íøka [%d]"
-#: ../raster/r.support/modhead/modhead.c:194
+#: ../display/d.vect/plot1.c:285 ../vector/v.label.sa/labels.c:140
+#: ../vector/v.label/main.c:291
+msgid "Unable to read vector map"
+msgstr "Nelze èíst vektorovou mapy"
+#: ../display/d.vect/plot1.c:353 ../display/d.thematic.area/plot1.c:362
#, c-format
-msgid "Pre 3.0 compression %sindicated\n"
-msgstr "%sindikována pøedbì¾ná 3.0 komprese\n"
+msgid ""
+"Error in color definition column (%s), element %d with cat %d: colorstring [%"
+"s]"
+msgstr ""
+"Chyba ve sloupci s definicí barvy (%s), prvek %d, kategorie %d: barevný "
+"øetìzec [%s]"
-#: ../raster/r.support/modhead/modhead.c:200
+#: ../display/d.vect/plot1.c:359 ../display/d.thematic.area/plot1.c:370
#, c-format
-msgid "[%s] appears to be compressed. Is it? "
-msgstr "[%s] se jeví jako komprimovaný. Je tomu tak?"
+msgid "Error in color definition column (%s), element %d with cat %d"
+msgstr "Chyba ve sloupci s definicí barvy (%s), prvek %d, kategorie %d"
-#: ../raster/r.support/modhead/modhead.c:207
-msgid "Please indicate the type of compression:\n"
-msgstr "Prosím, udejte typ komprese:\n"
+#: ../display/d.font/main.c:44 ../display/d.font.freetype/main.c:60
+msgid ""
+"Selects the font in which text will be displayed on the user's graphics "
+"monitor."
+msgstr "Vybere písmo, kterým bude zobrazen text na u¾ivatelském monitoru."
-#: ../raster/r.support/modhead/modhead.c:208
-msgid " 1. Pre 3.0 compression\n"
-msgstr " 1. Pøedbì¾ná 3.0 komprese\n"
+#: ../display/d.font/main.c:52
+msgid "Choose new current font"
+msgstr "Pou¾ijte nový aktuální font"
-#: ../raster/r.support/modhead/modhead.c:209
-msgid " 2. 3.0 compression\n"
-msgstr " 2. 3.0 komprese\n"
+#: ../display/d.font/main.c:58
+msgid "Path to Freetype-compatible font including file name"
+msgstr "Cesta k TrueType fontùm vèetnì jména souboru"
-#: ../raster/r.support/modhead/modhead.c:244
-#, c-format
-msgid "The header for [%s] says the file is not compressed. "
-msgstr "Hlavièka pro [%s] øíká, ¾e soubor není komprimován. "
+#: ../display/d.font/main.c:66 ../display/d.font.freetype/main.c:74
+msgid "Character encoding"
+msgstr "Kódování znakù"
-#: ../raster/r.support/modhead/modhead.c:245
-msgid "The file appears to be compressed.\n"
-msgstr "Soubor se ukazuje být komprimován.\n"
+#: ../display/d.font/main.c:70
+msgid "List fonts"
+msgstr "Seznam v¹ech fontù"
-#: ../raster/r.support/modhead/modhead.c:246
-#: ../raster/r.support/modhead/modhead.c:253
-msgid "Most likely the header is wrong, but I want you to decide.\n"
-msgstr "Hlavièka je pravdìpodobnì chybná, rozhodnutí je na Vás.\n"
+#: ../display/d.font/main.c:74
+msgid "List fonts verbosely"
+msgstr "Seznam v¹ech fontù (upovídaný re¾im)"
-#: ../raster/r.support/modhead/modhead.c:251
+#: ../display/d.rast.edit/cell.c:43
+msgid "Can't clear current graphics window"
+msgstr "Nelze vyèistit aktuální okno"
+#: ../display/d.rast.edit/cell.c:51 ../display/d.legend/main.c:255
+#: ../display/d.rast.num/number.c:281 ../display/d.his/main.c:152
+#: ../display/d.his/main.c:173 ../display/d.his/main.c:201
+#: ../display/d.rast/display.c:22 ../display/d.rgb/main.c:110
+#: ../display/d.histogram/main.c:160 ../raster/r.his/main.c:143
+#: ../raster/r.his/main.c:165 ../raster/r.his/main.c:193
+#: ../raster/r.out.ppm3/main.c:128 ../raster/r.composite/main.c:174
#, c-format
-msgid "The header for [%s] says the file is compressed. "
-msgstr "Hlavièka pro [%s] øíká, ¾e je soubor komprimován. "
+msgid "Color file for <%s> not available"
+msgstr "Soubor s tabulkou barev pro <%s> není dostupný"
-#: ../raster/r.support/modhead/modhead.c:252
-msgid "The file does NOT appear to be compressed.\n"
-msgstr ""
-"Soubor se NEJEVÍ jako komprimovaný.\n"
-"\n"
+#: ../display/d.rast.edit/cell.c:84 ../display/d.rast/display.c:76
+msgid "Cannot use current window"
+msgstr "Nelze pou¾ít aktuální okno"
-#: ../raster/r.support/modhead/modhead.c:267
-#, c-format
+#: ../display/d.legend/main.c:88
msgid ""
-"Header indicates %d row%s in the raster map, but the actual file format "
-"indicates %d row%s"
+"Displays a legend for a raster map in the active frame of the graphics "
+"monitor."
msgstr ""
-"Hlavièka uvádí %d øádkù %s v souboru, ale platný formát souboru uvádí %d "
-"øádkù %s"
+"Zobrazí legendu pro rastrovou mapu v aktivním rámci grafického monitoru."
-#: ../raster/r.support/modhead/modhead.c:299
-#, c-format
-msgid "Unable to write header for [%s]."
-msgstr "Nejsem schopen zapsat hlavièku pro [%s]"
+#: ../display/d.legend/main.c:99
+msgid "Sets the legend's text color"
+msgstr "Nastaví barvu textu legendy"
-#: ../raster/r.support/modhead/modhead.c:301
-#, c-format
-msgid "Header for raster map [%s] updated."
-msgstr "Hlavièka rastrového souboru [%s] byla aktualizována."
+#: ../display/d.legend/main.c:106
+msgid "Number of text lines (useful for truncating long legends)"
+msgstr "Poèet øádek textu (vhodné pro zkracování dlouhé legendy)"
-#: ../raster/r.support/modhead/hitreturn.c:12
-msgid ""
-"\n"
-"hit RETURN to continue -->"
-msgstr ""
-"\n"
-"Stisknìte RETURN pro pokraèování -->"
+#: ../display/d.legend/main.c:115
+msgid "Thinning factor (thin=10 gives cats 0,10,20...)"
+msgstr "Faktor kroku (thin=10 dá cats 0,10,20...)"
-#: ../raster/r.support/modhead/ask_format.c:24
-#, c-format
-msgid "Please enter the following information for [%s]:"
-msgstr "Prosím, zadejte následující informace pro [%s]:"
+#: ../display/d.legend/main.c:123
+msgid "Number of text labels for smooth gradient legend"
+msgstr "Poèet textových ¹títkù pro legendu vyhlazený gradient"
-#: ../raster/r.support/modhead/ask_format.c:29
-msgid " Number of rows"
-msgstr " Poèet øádkù"
+#: ../display/d.legend/main.c:132
+msgid "Placement as percentage of screen coordinates (0,0 is lower left)"
+msgstr "Umístìní jako souøadnice procent displeje (0,0 je spodní levý roh)"
-#: ../raster/r.support/modhead/ask_format.c:30
-msgid " Number of cols"
-msgstr " Poèet sloupcù"
+#: ../display/d.legend/main.c:141
+msgid "List of discrete category numbers/values for legend"
+msgstr "Vypsat nespojité èísla/hodnoty kategorií pro legendu"
-#: ../raster/r.support/modhead/ask_format.c:32
-msgid " Number of bytes per cell"
-msgstr " Poèet bytù na buòku (1, 2, 4)"
+#: ../display/d.legend/main.c:150
+msgid "Use a subset of the map range for the legend (min,max)"
+msgstr "Pou¾ít èást rozsahu mapy pro legendu (min,max)"
-#: ../raster/r.support/modhead/ask_format.c:33
-msgid " Floating point map"
-msgstr " Mapa s plovoucí desetinnou èárkou"
+#: ../display/d.legend/main.c:156
+msgid "Use mouse to size & place legend"
+msgstr "Pou¾ít my¹ pro velikost a umístìní legendy"
-#: ../raster/r.support/modhead/ask_format.c:51
-#, c-format
-msgid "rows * cols * bytes per cell must be same as file size (%lu)"
-msgstr ""
-"øádky * sloupce * byty na buòku musí mít stejnou velikost jako soubor (%lu)"
+#: ../display/d.legend/main.c:160
+msgid "Do not show category labels"
+msgstr "Nezobrazovat ¹títky kategorií"
-#: ../raster/r.support/modhead/ask_format.c:54
-msgid "If you need help figuring them out, just hit ESC"
-msgstr "Pokud potøebujete pomoc s vyèíslením, stisknìte ESC"
+#: ../display/d.legend/main.c:165
+msgid "Do not show category numbers"
+msgstr "Nezobrazovat kategorie"
-#: ../raster/r.support/modhead/ask_format.c:76
-msgid "** Negative values not allowed!"
-msgstr "** Záporné hodnoty nejsou povoleny!"
+#: ../display/d.legend/main.c:170
+msgid "Skip categories with no label"
+msgstr "Pøeskoèit kategorie bez ¹títku"
-#: ../raster/r.support/modhead/ask_format.c:78
-msgid "** Positive values only please!"
-msgstr "** Pouze kladné hodnoty, prosím!"
+#: ../display/d.legend/main.c:175
+msgid "Draw smooth gradient"
+msgstr "Zobrazit vyhlazený gradient"
-#: ../raster/r.support/modhist/modhist.c:37
-msgid "Which raster map needs an updated history? "
-msgstr "Který rastrový soubor vy¾aduje aktualizovanou historii? "
+#: ../display/d.legend/main.c:180
+msgid "Flip legend"
+msgstr "Obrátit legendu"
-#: ../raster/r.support/modhist/modhist.c:43
+#: ../display/d.legend/main.c:202 ../display/d.menu/main.c:112
+#: ../display/d.menu/main.c:118 ../display/d.menu/main.c:124
#, c-format
-msgid "Raster file [%s] not found. Exiting."
-msgstr "Rastrový soubor [%s] nebyl nalezen. Ukonèuji se."
+msgid "Don't know the color %s"
+msgstr "Neznám barvu %s"
-#: ../raster/r.support/modhist/modhist.c:48
+#: ../display/d.legend/main.c:266 ../display/d.histogram/main.c:163
+#: ../ps/ps.map/ps_clrtbl.c:35
#, c-format
-msgid "History file for [%s] updated."
-msgstr "Soubor s historií pro [%s] byl aktualizován."
+msgid "Category file for <%s> not available"
+msgstr "Soubor s kategoriemi pro <%s> není dostupný"
-#: ../raster/r.support/modhist/modhist.c:50
-#, c-format
-msgid "History file for [%s] not updated."
-msgstr "Soubor s historií pro [%s] nebyl aktualizován."
+#: ../display/d.legend/main.c:335
+msgid "Legend box lies outside of frame. Text may not display properly."
+msgstr "Rámeèek legendy je mimo rámec. Text se mo¾ná nezobrazí správnì."
-#: ../raster/r.support/front/hitreturn.c:15
-msgid ""
-"\n"
-"Hit RETURN to continue -->"
-msgstr ""
-"\n"
-"Stiknìte RETURN pro pokraèování -->"
+#: ../display/d.legend/main.c:339
+msgid "Drawing horizontal legend as box width exceeds height"
+msgstr "Vykreslení horizontální legendy jako rámeèku pøesahující její vý¹ku."
-#: ../raster/r.support/front/front.c:55
-msgid "Allows creation and/or modification of raster map layer support files."
-msgstr "Umo¾òuje vytvoøit a/nebo modifikovat podpùrné soubory rastrové mapy."
+#: ../display/d.legend/main.c:350
+#, c-format
+msgid "Range information for <%s> not available (run r.support)"
+msgstr "Informace o rozsahu pro <%s> nejsou dostupné (spus»te r.support)"
-#: ../raster/r.support/front/front.c:65
-msgid "Text to use for map title"
-msgstr "Text pro titulek nové mapy"
+#: ../display/d.legend/main.c:363 ../display/d.legend/main.c:514
+msgid "Color range exceeds lower limit of actual data"
+msgstr "Barevný rozsah pøesahuje dolní mez aktuálních dat"
-#: ../raster/r.support/front/front.c:72
-msgid "Text to append to the next line of the map's metadata file"
-msgstr "Text který bude pøipojen jako dal¹í øádek souboru s metadaty."
+#: ../display/d.legend/main.c:367 ../display/d.legend/main.c:518
+msgid "Color range exceeds upper limit of actual data"
+msgstr "Barevný rozsah pøesahuje horní mez pro aktuální data"
-#: ../raster/r.support/front/front.c:78
-msgid "Text to use for map data units"
-msgstr "Text pro jednotky nové mapy"
+#: ../display/d.legend/main.c:421
+#, c-format
+msgid "use=%s out of range [%d,%d] (extend with range= ?)"
+msgstr "use=%s mimo rozsah [%d,%d]. (zvìt¹it s range= ?)"
-#: ../raster/r.support/front/front.c:84
-msgid "Text to use for map vertical datum"
-msgstr "Text pro vertikální dataum nové mapy"
+#: ../display/d.legend/main.c:461
+msgid "Nothing to draw! (no categories with labels? out of range?)"
+msgstr "Nic k vykreslení! (¾ádné kategorie se ¹títky? mimo rozsah?)"
-#: ../raster/r.support/front/front.c:91
-msgid "Text to use for data source, line 1"
-msgstr "Text pro zdroj dat, øádek 1"
+#: ../display/d.legend/main.c:471
+msgid "Forcing a smooth legend: too many categories for current window height"
+msgstr ""
+"Zdùraznìní vyhlazené legendy: pøíli¹ mnoho kategorií pro vý¹ku aktuálního "
+"okna."
-#: ../raster/r.support/front/front.c:98
-msgid "Text to use for data source, line 2"
-msgstr "Text pro zdroj dat, øádek 2"
-#: ../raster/r.support/front/front.c:105
-msgid "Text to use for data description or keyword(s)"
-msgstr "Text pou¾itý pro popis dat nebo jako klíèové slova"
-#: ../raster/r.support/front/front.c:112 ../raster/r.cats/main.c:75
-msgid "Raster map from which to copy category table"
-msgstr "Název rastrové mapy, ze které se má kopírovat tabulka kategorií"
-#: ../raster/r.support/front/front.c:123 ../raster/r.cats/main.c:131
+#: ../display/d.legend/main.c:501 ../display/d.histogram/main.c:166
#, c-format
-msgid "Raster map <%s> not found in current mapset"
-msgstr "Rastrová mapa <%s> nebyla v aktuálním mapsetu nalezena"
+msgid "Range information for <%s> not available"
+msgstr "Informace o rozsahu pro <%s> nejsou dostupné"
-#: ../raster/r.support/front/front.c:140
-msgid "Not enough room in history file"
-msgstr "Pro soubor s historií není dost místa"
-#: ../raster/r.support/front/front.c:228
+#: ../display/d.legend/main.c:525
#, c-format
-msgid "cats table for [%s] set to %s"
-msgstr "Tabulka kategorií pro <%s> nastavena na %s"
+msgid "use=%s out of range [%.3f, %.3f] (extend with range= ?)"
+msgstr "use=%s mimo rozsah [%.3f, %.3f]. (zvìt¹it s range= ?)"
-#: ../raster/r.support/front/front.c:241
-#, c-format
-msgid "Edit header for [%s]? "
-msgstr "Editovat hlavièku pro [%s]?"
+#: ../display/d.legend/main.c:856
+msgid "Nothing to draw! (no categories with labels?)"
+msgstr "Nic k vykreslení! (¾ádné kategorie se ¹títky?)"
-#: ../raster/r.support/front/front.c:243
-#, c-format
+#: ../display/d.graph/main.c:55
msgid ""
-"\n"
-"NOTE: [%s] is a reclass of [%s in %s]"
+"Program for generating and displaying simple graphics on the display monitor."
+msgstr "Program pro tvorbu a zobrazení jednoduché grafiky v monitoru."
+#: ../display/d.graph/main.c:62
+msgid ""
+"Name of file containing graphics commands, if not given reads from standard "
+"input"
msgstr ""
-"\n"
-"POZNÁMKA: [%s] je reklasifikací [%s z %s]"
+"Název souboru obsahující grafické pøíkazy, pokud nezadáno, ète se standardní "
+"vstup"
-#: ../raster/r.support/front/front.c:254
-msgid "Canceling from edit header."
-msgstr "Stornování editace hlavièky."
+#: ../display/d.graph/main.c:70
+msgid "Color to draw with, either a standard GRASS color or R:G:B triplet"
+msgstr "Barva kresby, buï standardní GRASS barva nebo trojice R:G:B"
-#: ../raster/r.support/front/front.c:261
+#: ../display/d.graph/main.c:77
+msgid "Coordinates are given in map units"
+msgstr "Souøadnice jsou zadány v mapových jednotkách"
+#: ../display/d.graph/main.c:88
#, c-format
-msgid "Edit the category file for [%s]? "
-msgstr "Editace souboru s kategoriemi pro [%s]? "
+msgid "Graph file <%s> not found"
+msgstr "Soubor s grafem <%s> nebyl nalezen"
-#: ../raster/r.support/front/front.c:270
+#: ../display/d.graph/main.c:102 ../display/d.graph/do_graph.c:112
+#: ../display/d.graph/do_graph.c:404 ../display/d.graph/do_graph.c:419
+#: ../display/d.paint.labels/color.c:68 ../display/d.text/main.c:146
+#: ../display/d.text.freetype/main.c:879
#, c-format
-msgid "Create/Update the color table for [%s]? "
-msgstr "Vytvoøení/Aktualizace tabulky barev pro [%s]?"
+msgid "[%s]: No such color"
+msgstr "[%s]: ®ádná taková barva"
-#: ../raster/r.support/front/front.c:279
+#: ../display/d.graph/graphics.c:62 ../display/d.graph/do_graph.c:136
+#: ../display/d.graph/do_graph.c:214 ../display/d.graph/do_graph.c:237
+#: ../display/d.graph/do_graph.c:303 ../display/d.graph/do_graph.c:374
#, c-format
-msgid "Edit the history file for [%s]? "
-msgstr "Editace souboru s historií pro [%s]?"
+msgid "Problem parsing command [%s]"
+msgstr "Problém pøi zpracování pøíkazu [%s]"
-#: ../raster/r.support/front/front.c:288
+#: ../display/d.graph/do_graph.c:56 ../display/d.graph/do_graph.c:84
#, c-format
-msgid ""
-"\n"
-"The null file for [%s] may indicate that some cells contain\n"
-" no data. If the null file for [%s] doesn't exist, zero cells in\n"
-" it are treated by GRASS application programs as no data."
-msgstr ""
-"\n"
-"Soubor \"null\" pro [%s] mù¾e naznaèovat, ¾e nìkteré buòky obsahují\n"
-" \"¾ádná data\". Pokud tento soubor pro [%s] neexistuje, pak jsou nulové "
-"buòky\n"
-"interpretovány moduly GRASSu jako \"¾ádná data\"."
+msgid "Problem parsing coordinates [%s]"
+msgstr "Problém pøi zpracování souøadnice [%s]"
-#: ../raster/r.support/front/front.c:294
-#, c-format
+#: ../display/d.graph/do_graph.c:105
+msgid "Unable to read color"
+msgstr "Nelze èíst barvu"
+#: ../display/d.title/main.c:47
msgid ""
-"\n"
-"Do you want to create/reset the null file for [%s] so that null cell values "
-"are considered valid data? "
+"Create a TITLE for a raster map in a form suitable for display with d.text."
msgstr ""
-"\n"
-"Pøejete si vytvoøit/obnovit soubor \"null\" pro [%s], tak¾e hodnoty bunìk "
-"NULL budou pova¾ovány za platná data?"
+"Vytvoøí titulek rastrové mapy ve formì pou¾itelné pro zobrazení pomocí d."
+"text."
-#: ../raster/r.support/front/front.c:302 ../raster/r.support/front/front.c:336
-#, c-format
-msgid "[%s] is a reclass of another map. Exiting."
-msgstr "[%s] je reklasifikací jiné mapy. Ukonèuji se."
+#: ../display/d.title/main.c:58
+msgid "Sets the text color"
+msgstr "Nastaví barvu textu"
-#: ../raster/r.support/front/front.c:313
-#, c-format
-msgid "Writing new null file for [%s]... "
-msgstr "Zapisuji nový soubor \"null\" pro [%s]... "
+#: ../display/d.title/main.c:66
+msgid "Sets the text size as percentage of the frame's height"
+msgstr "Vý¹ka písmen v procentech vý¹ky rámce"
-#: ../raster/r.support/front/front.c:317
+#: ../display/d.title/main.c:70
+msgid "Draw title on current display"
+msgstr "Vykreslit titulek mapy do souèasného onka"
+#: ../display/d.title/main.c:74
+msgid "Do a fancier title"
+msgstr "Vytvoø hezèí titulek"
+#: ../display/d.title/main.c:79
+msgid "Do a simple title"
+msgstr "Vytvoø jednoduchý titulek"
+#: ../display/d.title/main.c:97
+msgid "Title can be fancy or simple, not both"
+msgstr "Titulek mù¾e být buï hezký nebo jednoduchý, ale ne obojí"
+#: ../display/d.title/main.c:100
+msgid "No map name given"
+msgstr "Nebyly specifikovány ¾ádné mapy"
+#: ../display/d.title/main.c:111 ../raster/r.report/parse.c:269
+#: ../raster/r.cats/main.c:148 ../raster/r.cats/main.c:204
+#: ../raster/r.support/front/front.c:224 ../raster/r.mapcalc/map.c:88
+#: ../raster/r.mapcalc/map3.c:195 ../raster/r.statistics/main.c:88
#, c-format
-msgid "Error writing null row [%d]."
-msgstr "Chyba pøi zápisu nulové øádky [%d]."
+msgid "Unable to read category file of raster map <%s@%s>"
+msgstr "Nelze èíst soubor s kategoriemi rastrové mapy <%s@%s>"
-#: ../raster/r.support/front/front.c:329
-#, c-format
+#: ../display/d.rast.num/number.c:88
msgid ""
-"\n"
-"Do you want to delete the null file for [%s]\n"
-"(all zero cells will then be considered no data)? "
-msgstr ""
-"\n"
-"Pøejete si odstranit soubor \"null\" pro [%s]\n"
-"(v¹echny nulové buòky budou poté pova¾ovány za \"no data\")?"
+"Overlays cell category values on a raster map layer displayed to the "
+"graphics monitor."
+msgstr "Zobrazí hodnoty bunìk jako èísla v grafickém monitoru."
-#: ../raster/r.support/front/front.c:341
-#, c-format
-msgid "Removing null file for [%s]...\n"
-msgstr "Odstraòuji soubor \"null\" pro [%s]...\n"
+#: ../display/d.rast.num/number.c:101
+msgid "Color for drawing grid, or \"none\""
+msgstr "Barva pro vykreslení sítì, nebo \"none\""
-#: ../raster/r.support/front/front.c:348 ../imagery/i.gensig/write_sig.c:20
-#: ../imagery/i.target/main.c:99 ../display/d.what.vect/main.c:172
-msgid "Done."
-msgstr "Dokonáno jest."
+#: ../display/d.rast.num/number.c:110
+msgid "Color for drawing text"
+msgstr "Barva pro zobrazený text"
-#: ../raster/r.support/front/check.c:29
+#: ../display/d.rast.num/number.c:122
+msgid "Get text color from cell color value"
+msgstr "Pøevezmi barvu textu z barvy buòky"
+#: ../display/d.rast.num/number.c:135
+msgid "No raster map exists in current window"
+msgstr "V aktuálním oknì není ¾ádná rastrová mapa"
+#: ../display/d.rast.num/number.c:207
+msgid "Current window size:"
+msgstr "Velikost aktuálního okna: "
+#: ../display/d.rast.num/number.c:208
#, c-format
-msgid "Update the statistics (histogram, range) for [%s]? "
-msgstr "Aktualizovat statistiku (histogram, rozsah) pro [%s]?"
+msgid "rows: %d"
+msgstr "øádky: %d"
-#: ../raster/r.support/front/check.c:34
+#: ../display/d.rast.num/number.c:209
#, c-format
-msgid ""
-"\n"
-" Updating statistics for [%s]"
-msgstr ""
-"\n"
-" Aktualizuji statistiku pro [%s]"
+msgid "columns: %d"
+msgstr "sloupce: %d"
-#: ../raster/r.support/front/check.c:76
-#, c-format
+#: ../display/d.rast.num/number.c:211
msgid ""
-" Updating the number of categories for [%s]\n"
"\n"
+"Your current window setting may be too large. Cells displayed on your "
+"graphics window may be too small for cell category number to be visible."
msgstr ""
-" Aktualizuji poèet kategorií pro [%s]\n"
"\n"
+"Va¹e souèasné nastavení regionu je pøíli¹ velké. Buòky jsou tak pøíli¹ malé "
+"aby se v nich daly zobrazit èísla jejich kategorií."
-#: ../raster/r.support/modcats/modcats.c:46
-msgid "Which vector map needs updated categories?"
-msgstr "Který vektorový soubor vy¾aduje aktualizované kategorie?"
+#: ../display/d.rast.num/number.c:217
+msgid "Aborting."
+msgstr "Pøeru¹uji."
-#: ../raster/r.support/modcats/modcats.c:49
-msgid "Which raster map needs updated categories?"
-msgstr "Který rastrový soubor vy¾aduje aktualizované kategorie?"
+#: ../display/d.extend/main.c:53
+msgid "No raster or vector map displayed"
+msgstr "Název rastrové nebo vektorové mapy, která bude zobrazena"
-#: ../raster/r.support/modcats/modcats.c:53
-#: ../raster/r.support/modcats/modcats.c:61
-#, fuzzy, c-format
-msgid "%s map <%s> not found"
-msgstr "%s <%s> nebyl nalezen"
+#: ../display/d.font.freetype/main.c:67
+msgid "Font name or pathname of TTF file"
+msgstr "Jméno nebo cesta k TTF souboru."
-#: ../raster/r.support/modcats/modcats.c:73
-#: ../raster/r.support/modcats/modcats.c:79
-#, fuzzy, c-format
-msgid "Category file for <%s> not updated"
-msgstr "Soubor s kategoriemi pro [%s] nebyl aktualizován."
+#: ../display/d.font.freetype/main.c:166
+msgid "Setting release of FreeType"
+msgstr "Nastavuji verzi FreeType"
-#: ../raster/r.support/modcats/modcats.c:90
-#, fuzzy, c-format
-msgid "Category file for <%s> updated"
-msgstr "Soubor s kategoriemi pro [%s] byl aktualizován."
+#: ../display/d.measure/main.c:50
+msgid ""
+"Measures the lengths and areas of features drawn by the user in the active "
+"display frame on the graphics monitor."
+msgstr "Mìøí délky a plochy objektù nakreslených u¾ivatelem do monitoru."
-#: ../raster/r.out.bin/main.c:64
-msgid "Exports a GRASS raster to a binary array."
-msgstr "Exportuje rastrový soubor GRASSu do binárního pole."
+#: ../display/d.measure/main.c:56
+msgid "Line color 1"
+msgstr "Barva linie 1"
-#: ../raster/r.out.bin/main.c:80
-msgid "Name for output binary map (use output=- for stdout)"
-msgstr "Název výstupní binární mapy (pro standardní výstup pou¾ijte out=-)"
+#: ../display/d.measure/main.c:64
+msgid "Line color 2"
+msgstr "Barva linie 2"
-#: ../raster/r.out.bin/main.c:87
-msgid "Value to write out for null"
-msgstr "Hodnota místo NULL"
+#: ../display/d.measure/main.c:72
+msgid "Suppress clear screen"
+msgstr "Potlaè vymazání obrazovky"
-#: ../raster/r.out.bin/main.c:96
-msgid "Export array with GMT compatible header"
-msgstr "Export pole s GMT kompatibilní hlavièkou:q"
+#: ../display/d.measure/main.c:76
+msgid "Output in meters only"
+msgstr "Výstup pouze v metrech"
-#: ../raster/r.out.bin/main.c:100
-msgid "Generate BIL world and header files"
-msgstr "Generuje BIL world a hlavièkový soubor"
+#: ../display/d.measure/main.c:80
+msgid "Output in kilometers as well"
+msgstr "Výstup také v kilometrech"
-#: ../raster/r.out.bin/main.c:104
-msgid "Byte swap output"
-msgstr "Výstup bytového swapu"
+#: ../display/d.measure/main.c:89 ../display/d.erase/main.c:61
+msgid "No current frame"
+msgstr "®ádný aktuální rámec"
-#: ../raster/r.out.bin/main.c:110
-msgid "Invalid value for null (integers only)"
-msgstr "©patná hodnota pro ¾ádná data (pouze celá èísla)"
+#: ../display/d.measure/main.c:92 ../display/d.erase/main.c:63
+msgid "Current frame not available"
+msgstr "Aktuální rámec není dostupný"
-#: ../raster/r.out.bin/main.c:145 ../raster/r.out.bin/main.c:231
-#: ../raster/r.out.bin/main.c:235
-#, c-format
-msgid "Unable to create file <%s>"
-msgstr "Nelze vytvoøit soubor <%s>"
+#: ../display/d.save/main.c:83
+msgid "Creates a list of commands for recreating screen graphics."
+msgstr "Vytvoøí seznam pøíkazù pro obnovení obsahu monitoru."
-#: ../raster/r.out.bin/main.c:181
-msgid "Swapping header data"
-msgstr "Odkládám hlavièková data"
+#: ../display/d.save/main.c:88
+msgid "Name of frame(s) to save"
+msgstr "Název rámu(ù) urèeného k ulo¾ení"
-#: ../raster/r.out.bin/main.c:238
-msgid "Creating BIL support files..."
-msgstr "Vytváøím podpùrné soubory BIL..."
+#: ../display/d.save/main.c:127
+msgid ""
+"List of object numbers to remove which are displayed after \"#\". -1 for the "
+"last object."
+msgstr ""
+"Seznam èísel objektù k vyjmutí, které jsou zobrazeny po \"#\" -1 pro "
+"poslední objekt."
-#: ../raster/r.out.bin/main.c:239
-#, c-format
-msgid "Header File = %s"
-msgstr "Hlavièkový soubor = %s"
+#: ../display/d.save/main.c:135
+msgid ""
+"List of object numbers to move (\"from\" to \"to\"). remove= option will be "
+"done first, if any."
+msgstr ""
+"Seznam èísel objektù, které budou pøejmenovány (\"from\" na \"to\"). Nejprve "
+"bude provedena volba remove=."
-#: ../raster/r.out.bin/main.c:240
-#, c-format
-msgid "World File = %s"
-msgstr "World File = %s"
+#: ../display/d.save/main.c:144
+msgid "Save current frame"
+msgstr "Ulo¾ souèasný rám"
-#: ../raster/r.out.bin/main.c:316
-#, c-format
-msgid "Exporting raster as integer values (bytes=%d)"
-msgstr "Exportuji rastr s celoèíselnými hodnotami (bytes=%d)"
+#: ../display/d.save/main.c:149
+msgid "Save all the frames"
+msgstr "Ulo¾ v¹echny rámy"
-#: ../raster/r.out.bin/main.c:319
-msgid "Writing GMT integer format ID=2"
-msgstr "Zapisuji GMT celoèíselný formát ID=2"
+#: ../display/d.save/main.c:155
+msgid "Only map objects without extra header and tailer"
+msgstr "Pouze mapové objekty bez extra hlavièky a patièky"
-#: ../raster/r.out.bin/main.c:322
-#, c-format
-msgid "Exporting raster as floating values (bytes=%d)"
-msgstr "Exportuji rastr s neceloèíselnými hodnotami (bytes=%d)"
+#: ../display/d.save/main.c:163
+msgid "No monitor selected"
+msgstr "Nebyl vybrán ¾ádný monitor"
-#: ../raster/r.out.bin/main.c:325
-msgid "Writing GMT float format ID=1"
-msgstr "Zapisuji formát GMT s plovoucí desetinnou èárkou ID=1"
-#: ../raster/r.out.bin/main.c:328
+#: ../display/d.save/main.c:491 ../display/d.save/main.c:526
#, c-format
-msgid "Exporting raster as double values (bytes=%d)"
-msgstr "Exportuji rastr s neceloèíselnými hodnotami (double) (bytes=%d)"
+msgid "Unknown item type in pad: %s"
+msgstr "Neznámý prvek v podlo¾ce: %s"
-#: ../raster/r.out.bin/main.c:331
-msgid "Using the current region settings..."
-msgstr "Pou¾ívám nastavení aktuálního regionu..."
+#: ../display/d.profile/What.c:36
+msgid "Error reading raster map"
+msgstr "chyba pøi ètení rastrové mapy"
-#: ../raster/r.out.bin/main.c:332
-#, c-format
-msgid "north=%f"
-msgstr "sever=%f"
+#: ../display/d.profile/main.c:62
+msgid "Interactive profile plotting utility with optional output."
+msgstr "Nástroj pro interaktivní vytváøení profilù s volitelným výstupem."
-#: ../raster/r.out.bin/main.c:333
-#, c-format
-msgid "south=%f"
-msgstr "jih=%f"
+#: ../display/d.profile/main.c:70
+msgid "Raster map to be profiled"
+msgstr "Rastrová mapa pro tvorbu profilu"
-#: ../raster/r.out.bin/main.c:334
-#, c-format
-msgid "east=%f"
-msgstr "východ=%f"
+#: ../display/d.profile/main.c:77
+msgid "Optional display raster"
+msgstr "Volitelný rastr, který bude zobrazen"
-#: ../raster/r.out.bin/main.c:335
-#, c-format
-msgid "west=%f"
-msgstr "západ=%f"
+#: ../display/d.profile/main.c:83
+msgid "Output profile data to file(s) with prefix 'name'"
+msgstr "Výstupní data profilu ulo¾it do souboru(ù) s prefixem 'jméno'"
-#: ../raster/r.out.bin/main.c:336
+#: ../display/d.profile/main.c:106
#, c-format
-msgid "r=%d"
-msgstr "r=%d"
+msgid "Display raster [%s] not found. Using profile raster."
+msgstr "Rastr ke zobrazení [%s] nenalezen. Pou¾iji rastr profilu."
-#: ../raster/r.out.bin/main.c:337
-#, c-format
-msgid "c=%d"
-msgstr "c=%d"
-#: ../raster/r.out.bin/main.c:341
-msgid "Reading map"
-msgstr "Naèítám mapu"
-#: ../raster/r.neighbors/main.c:105
+#: ../display/d.profile/main.c:131
msgid ""
-"Makes each cell category value a function of the category values assigned to "
-"the cells around it, and stores new cell values in an output raster map "
-"layer."
+"\n"
+"\n"
+"Use mouse to choose action"
msgstr ""
-"Hodnota ka¾dé buòky v novém rastru bude funkcí hodnot kategorii sousedních "
-"bunìk a bude ulo¾ena jako hodnota ve výstupní rastrové mapì."
+"\n"
+"\n"
+"Pou¾ít my¹ pro vybraní akce"
-#: ../raster/r.neighbors/main.c:128
-msgid "Neighborhood operation"
-msgstr "Operace s okolím"
+#: ../display/d.profile/main.c:201 ../display/d.profile/main.c:386
+msgid "Use 'd.frame -e' to remove left over frames"
+msgstr "Pou¾ijte 'd.frame -e' pro smazání zbylých rámcù"
-#: ../raster/r.neighbors/main.c:134
-msgid "Neighborhood size"
-msgstr "Velikost okolí"
+#: ../display/d.profile/main.c:289
+msgid "Error opening cell-file"
+msgstr "Chyba pøi otevírání souboru cell"
-#: ../raster/r.neighbors/main.c:142
-msgid "Title of the output raster map"
-msgstr "Titulek výstupní rastrové mapy"
+#: ../display/d.profile/main.c:291
+msgid "Error reading from cell-file"
+msgstr "Chyba pøi ètení souboru cell"
-#: ../raster/r.neighbors/main.c:149
-msgid "File containing weights"
-msgstr "Soubor obsahující váhy"
+#: ../display/d.profile/main.c:293
+msgid "Mysterious window inconsistancy error"
+msgstr "Záhadná chyba nekonzistence okna"
-#: ../raster/r.neighbors/main.c:153
-msgid "Do not align output with the input"
-msgstr "Nezarovnávej výstup se vstupem"
+#: ../display/d.profile/main.c:426
+#, c-format
+msgid "%s: Couldn't open raster <%s@%s>"
+msgstr "%s: Nelze otevøít rastrový soubor <%s@%s>"
-#: ../raster/r.neighbors/main.c:162
-msgid "Use circular neighborhood"
-msgstr "Pou¾ít kruhové okolí"
+#: ../display/d.profile/main.c:430
+#, c-format
+msgid "%s: Couldn't read color table for <%s@%s>"
+msgstr "%s: Nelze èíst tabulku barev pro <%s@%s>"
-#: ../raster/r.neighbors/main.c:169
-msgid "Neighborhood size must be positive"
-msgstr "Velikost sousedù musí být vìt¹í ne¾ nula"
+#: ../display/d.profile/Range.c:92
+msgid "one moment ..."
+msgstr "momentíèek ..."
-#: ../raster/r.neighbors/main.c:171
-msgid "Neighborhood size must be odd"
-msgstr "Velikost sousedù musí být lichá"
-#: ../raster/r.neighbors/main.c:175
-msgid "weight= and -c are mutually exclusive"
-msgstr "weight= a -c se navzájem vyluèují"
-#: ../raster/r.neighbors/main.c:203 ../raster/r.series/main.c:175
-#: ../ps/ps.map/outl_io.c:77
+#: ../display/d.profile/utils.c:8
#, c-format
-msgid "Unable to open raster map <%s> in mapset <%s>"
-msgstr "Nelze otevøít rastrovou mapu <%s> v mapsetu <%s>"
+msgid "%s: 'is_null_value()' got NULL pointer!"
+msgstr "%s: 'is_null_value()' dostala NULLový pointer!"
-#: ../raster/r.neighbors/readweights.c:17
+#: ../display/d.profile/utils.c:11
#, c-format
-msgid "Unable to open weights file %s"
-msgstr "Nelze otevøít soubor s vahami %s"
+msgid "%s: 'is_null_value()' got negative column index"
+msgstr "%s: 'is_null_value()' dostala negativní index sloupeèku"
-#: ../raster/r.neighbors/readweights.c:22
+#: ../display/d.profile/utils.c:23
#, c-format
-msgid "Error reading weights file %s"
-msgstr "Chyba pøi ètení souboru s vahami %s"
+msgid "%s: 'is_null_value()' Unknown RASTER_MAP_TYPE '%d'"
+msgstr "%s: 'is_null_value()' Neznámý RASTER_MAP_TYPE '%d'"
-#: ../raster/r.clump/clump.c:100
-#, c-format
-msgid "CLUMP PASS %d ... "
-msgstr "SPOJENÝ PRÙCHOD %d ... "
+#: ../display/d.vect.chart/main.c:64
+msgid ""
+"Displays charts of vector data in the active frame on the graphics monitor."
+msgstr "Zobrazí grafy vektorových dat v aktivním grafickém monitoru."
-#: ../raster/r.clump/clump.c:104
-msgid "Unable to properly read input raster map"
-msgstr "Nelze správnì naèít vstupní rastrový soubor"
+#: ../display/d.vect.chart/main.c:81
+msgid "Chart type"
+msgstr "Typ grafu"
-#: ../raster/r.clump/clump.c:249
-msgid "Unable to properly write output raster map"
-msgstr "Nelze správnì zapsat výsledný rastrový soubor"
+#: ../display/d.vect.chart/main.c:82 ../display/d.vect.chart/main.c:96
+#: ../display/d.vect.chart/main.c:103 ../display/d.vect.chart/main.c:110
+#: ../display/d.vect.chart/main.c:118 ../display/d.vect.chart/main.c:127
+#: ../display/d.vect.chart/main.c:132
+msgid "Chart properties"
+msgstr "Vlastnosti grafu"
-#: ../raster/r.clump/main.c:52
-msgid ""
-"Recategorizes data in a raster map layer by grouping cells that form "
-"physically discrete areas into unique categories."
-msgstr ""
-"Zmìní kategorie dat rastrového souboru tak, ¾e seskupí sousedící buòky "
-"formující fyzicky spojité oblasti do jednineèných kategorií."
+#: ../display/d.vect.chart/main.c:89
+msgid "Attribute columns containing data"
+msgstr "Atributový sloupec obsahující data"
-#: ../raster/r.clump/main.c:64
-msgid "Title, in quotes"
-msgstr "Titulek v uvozovkách"
+#: ../display/d.vect.chart/main.c:95
+msgid "Column used for pie chart size"
+msgstr "Sloupec pou¾itý pro velikost koláèového grafu"
-#: ../raster/r.clump/main.c:121
-#, c-format
-msgid "%d clumps"
-msgstr "%d tøíd"
+#: ../display/d.vect.chart/main.c:102
+msgid "Size of chart (diameter for pie, total width for bar)"
+msgstr "Velikost grafu (prùmìr koláèe, celková ¹íøka pro sloupce)"
-#: ../raster/r.what.color/main.c:91
-msgid "Queries colors for a raster map layer."
-msgstr "Zji¹»uje barvy rastrové mapové vrstvy."
+#: ../display/d.vect.chart/main.c:109
+msgid "Scale for size (to get size in pixels)"
+msgstr "Mìøítko velikosti (pro získání velikosti v pixelech)"
-#: ../raster/r.what.color/main.c:99
-msgid "Name of existing raster map to query colors"
-msgstr "Název existující(ch) rastrové(ých) map(y) pro dotazování barev."
+#: ../display/d.vect.chart/main.c:116
+msgid "Outline color"
+msgstr "Barva zvýraznìní"
-#: ../raster/r.what.color/main.c:106
-msgid "Values to query colors for"
-msgstr "Hodnoty, jejich¾ barvy budou zji¹tìny"
+#: ../display/d.vect.chart/main.c:125
+msgid "Colors used to fill charts"
+msgstr "Barvy pou¾ité pro výplò grafù"
-#: ../raster/r.what.color/main.c:113
-msgid "Output format (printf-style)"
-msgstr "Výstupní formát (ve stylu printf)"
+#: ../display/d.vect.chart/main.c:131
+msgid "Center the bar chart around a data point"
+msgstr "Vycentruj sloupcový graf okolo datového bodu"
-#: ../raster/r.what.color/main.c:117
-msgid "Read values from stdin"
-msgstr "Èti hodnoty ze standardního výstupu"
+#: ../display/d.vect.chart/main.c:139
+msgid "Maximum value used for bar plot reference"
+msgstr "Maximální hodnota pou¾itá pro mìøítko sloupcového grafu"
-#: ../raster/r.what.color/main.c:123
-msgid "Either \"-i\" or \"value=\" must be given"
-msgstr "Mìl by být zadán \"value=\" nebo \"-i\""
+#: ../display/d.vect.chart/main.c:143 ../display/d.thematic.area/main.c:143
+msgid "Create legend information and send to stdout"
+msgstr "Vytvoøit legendu a poslat ji na standartní výstup"
-#: ../raster/r.in.gridatb/main.c:45
-msgid "Imports GRIDATB.FOR map file (TOPMODEL) into GRASS raster map"
+#: ../display/d.his/main.c:67
+msgid ""
+"Displays the result obtained by combining hue, intensity, and saturation "
+"(his) values from user-specified input raster map layers."
msgstr ""
-"Importuje mapový soubor GRIDATB.FOR (TOPMODEL) jako rastrovou mapu GRASSu"
+"Vytvoøí èervené, zelené a modré(RGB) rastrové mapy kombinací hodnot odstínu,"
+"intenzity a nasycení (his) z u¾ivatelem zadaných vstupních rastrových map."
-#: ../raster/r.in.gridatb/main.c:70
-#, c-format
-msgid "File not found: %s"
-msgstr "Soubor nenalezen: %s"
+#: ../display/d.his/main.c:76 ../raster/r.his/main.c:75
+msgid "Name of layer to be used for HUE"
+msgstr "Jméno mapy, která má být pou¾ita jako ODSTÍN v systému IHS"
-#: ../raster/r.in.gridatb/file_io.c:33
-msgid "Setting window header failed"
-msgstr "Nastavení hlavièky selhalo"
+#: ../display/d.his/main.c:83 ../raster/r.his/main.c:82
+msgid "Name of layer to be used for INTENSITY"
+msgstr "Název mapy, která má být pou¾ita jako INTENZITA systému IHS"
-#: ../raster/r.random.cells/main.c:41
-msgid "Generates random cell values with spatial dependence."
-msgstr "Vytvoøí prostorovì závislé pole náhodných hodnot."
+#: ../display/d.his/main.c:90 ../raster/r.his/main.c:89
+msgid "Name of layer to be used for SATURATION"
+msgstr "Název mapy, která má být pou¾ita jako NASYCENOST v systému IHS"
-#: ../raster/r.to.vect/lines_io.c:75
-msgid "write_line: found half a loop!"
-msgstr "write_line: nalezena polovina smyèky!"
+#: ../display/d.his/main.c:95
+msgid "Percent to brighten intensity channel"
+msgstr "Procent zesvìtlení kanálu intenzity"
-#: ../raster/r.to.vect/lines_io.c:126
-#, c-format
-msgid ""
-"write_line: line terminated unexpectedly\n"
-" previous (%d) point %p (%d,%d,%d) %p %p"
-msgstr ""
-"write_line: linie zkonèila pøedèasnì\n"
-" pøedchozí (%d) bod %p (%d,%d,%d) %p %p"
+#: ../display/d.his/main.c:101 ../raster/r.his/main.c:114
+msgid "Respect NULL values while drawing"
+msgstr "Pøi vykreslování respektuj NULLové hodnoty"
-#: ../raster/r.to.vect/areas_io.c:103
-#, c-format
-msgid ""
-"Line terminated unexpectedly\n"
-"previous (%d) point %p (%d,%d,%d) %p %p"
-msgstr ""
-"Øádek neoèekávanì skonèil\n"
-"pøedchozí (%d) bod %p (%d,%d,%d) %p %p"
+#: ../display/d.his/main.c:120 ../display/d.what.rast/main.c:113
+msgid "No current graphics window"
+msgstr "®ádný vybraný monitor"
-#: ../raster/r.to.vect/areas_io.c:367 ../raster/r.to.vect/util.c:164
-#: ../vector/v.in.ogr/main.c:790
-#, c-format
-msgid "Cannot insert new row: %s"
-msgstr "Nelze vlo¾it nový øádek: %s"
+#: ../display/d.his/main.c:123 ../display/d.what.rast/main.c:116
+msgid "Current graphics window not available"
+msgstr "Aktuální monitor není dostupný"
-#: ../raster/r.to.vect/main.c:50
-msgid "Converts a raster map into a vector map layer."
-msgstr "Pøevede rastrovou mapu na vektorovou."
+#: ../display/d.his/main.c:224
+msgid "Error reading hue data"
+msgstr "Chyba pøi ètení mapy odstínu (hue)"
-#: ../raster/r.to.vect/main.c:63
-msgid "Feature type"
-msgstr "Typ prvku"
+#: ../display/d.his/main.c:227
+msgid "Error reading intensity data"
+msgstr "Chyba pøi ètení mapy intenzity"
-#: ../raster/r.to.vect/main.c:67
-msgid "Smooth corners of area features"
-msgstr "Jemné rohy plo¹ných prvkù"
+#: ../display/d.his/main.c:230
+msgid "Error reading saturation data"
+msgstr "Chyba pøi ètení mapy nasycení (saturation)"
-#: ../raster/r.to.vect/main.c:72
-msgid "Use raster values as categories instead of unique sequence (CELL only)"
-msgstr ""
-"Pou¾ij rastrové hodnoty jako kategorie místo jedineèné sekvence (pouze CELL)"
+#: ../display/drivers/XDRIVER/Serve_Xevent.c:132
+#, c-format
+msgid "Monitor: waitpid: expected %d but got %d"
+msgstr "Monitor: waitpid: oèekával jsem %d, ale dostal jsem %d"
-#: ../raster/r.to.vect/main.c:76
-msgid ""
-"Write raster values as z coordinate. Table is not created. Currently "
-"supported only for points."
-msgstr ""
-"Zapí¹e rastrové hodnoty jako souøadnice z. Není vytvoøena tabulka. V "
-"souèasné dobì jsou podporovány pouze body."
+#: ../display/drivers/XDRIVER/Serve_Xevent.c:339
+msgid "Monitor: XGetWMName failed"
+msgstr "Monitor: XgetWMName selhalo"
-#: ../raster/r.to.vect/main.c:82
-msgid "Do not build vector topology (use with care for massive point export)"
-msgstr ""
-"Nevytváøej vektorovou topologii (pou¾ít opatrnì pøi importu velkého mno¾ství "
-"bodù)b"
+#: ../display/drivers/XDRIVER/Serve_Xevent.c:345
+msgid "Monitor: XGetWMName: bad result"
+msgstr "Monitor: XGetWMName: ¹patný výsledek"
-#: ../raster/r.to.vect/main.c:87
-msgid "Quiet - Do not show progress"
-msgstr "Ti¹e - potlaè hlá¹ení o prùbìhu zpracování"
+#: ../display/drivers/XDRIVER/Get_w_line.c:38
+#: ../display/drivers/XDRIVER/Get_w_pointer.c:22
+#: ../display/drivers/XDRIVER/Get_w_box.c:37
+msgid "Monitor: interactive command in redraw"
+msgstr "Monitor: interaktivní pøíkaz v pøekreslení"
-#: ../raster/r.to.vect/main.c:105
-msgid "z flag is supported only for points"
-msgstr "pøepínaè -z není u bodù podporován"
+#: ../display/drivers/XDRIVER/Graph_set.c:114
+#, c-format
+msgid "found %d visuals of type TrueColor"
+msgstr "nalezeno %d zobrazení typu TrueColor"
-#: ../raster/r.to.vect/main.c:119
-msgid ""
-"Raster is not CELL, '-v' flag ignored, raster values will be written to the "
-"table."
-msgstr ""
-"Rastrová mapa není typu CELL, pøepínaè '-v' ignorován, rastrové hodnoty "
-"budou zapsány do tabulky."
+#: ../display/drivers/XDRIVER/Graph_set.c:116
+msgid "searching for highest bit depth"
+msgstr "hledám nejvìt¹í bitovou hloubku"
-#: ../raster/r.to.vect/main.c:154 ../raster/r.contour/main.c:179
-#: ../vector/v.db.connect/main.c:176 ../vector/v.db.connect/main.c:268
-#: ../vector/v.to.rast3/main.c:85 ../vector/v.edit/cmd/select.c:537
-#: ../vector/lidar/v.surf.bspline/main.c:297 ../vector/v.distance/main.c:342
-#: ../vector/v.distance/main.c:376 ../vector/v.reclass/main.c:117
-#: ../vector/v.in.ascii/in.c:308 ../vector/v.db.select/main.c:103
-#: ../vector/v.db.select/main.c:173 ../vector/v.what.rast/main.c:127
-#: ../vector/v.extrude/main.c:167 ../vector/v.sample/main.c:201
-#: ../vector/v.patch/main.c:132 ../vector/v.patch/main.c:164
-#: ../vector/v.patch/main.c:287 ../vector/v.patch/main.c:347
-#: ../vector/v.surf.idw/read_sites.c:39 ../vector/v.vol.rst/user1.c:96
-#: ../vector/v.vol.rst/main.c:561 ../vector/v.transform/trans_digit.c:58
-#: ../vector/v.mkgrid/main.c:207 ../vector/v.overlay/main.c:168
-#: ../vector/v.overlay/main.c:261 ../vector/v.label.sa/labels.c:79
-#: ../vector/v.kcv/main.c:173 ../vector/v.normal/main.c:141
-#: ../vector/v.out.svg/main.c:145 ../vector/v.to.db/update.c:32
-#: ../vector/v.to.db/query.c:81 ../vector/v.label/main.c:277
-#: ../vector/v.in.db/main.c:113 ../vector/v.to.rast/support.c:130
-#: ../vector/v.to.rast/support.c:265 ../vector/v.to.rast/vect2rast.c:55
-#: ../vector/v.out.ogr/main.c:303 ../vector/v.lrs/v.lrs.create/main.c:273
-#: ../vector/v.lrs/v.lrs.create/main.c:281 ../vector/v.buffer/main.c:375
-#: ../vector/v.extract/main.c:229 ../ps/ps.map/catval.c:52
-#: ../ps/ps.map/catval.c:110 ../ps/ps.map/catval.c:171
+#: ../display/drivers/XDRIVER/Graph_set.c:133
#, c-format
-msgid "Unable to open database <%s> by driver <%s>"
-msgstr "Nelze otevøít databázi <%s> ovladaèem <%s>"
+msgid "selected %d bit depth"
+msgstr "vybrána hloubka %d bitù"
-#: ../raster/r.to.vect/main.c:189 ../raster/r.contour/main.c:188
-#: ../vector/lidar/lidarlib/raster.c:74 ../vector/lidar/lidarlib/raster.c:88
-#: ../vector/lidar/lidarlib/raster.c:100 ../vector/lidar/lidarlib/raster.c:116
-#: ../vector/lidar/lidarlib/raster.c:130 ../vector/lidar/lidarlib/raster.c:142
-#: ../vector/lidar/lidarlib/raster.c:156 ../vector/lidar/lidarlib/raster.c:167
-#: ../vector/v.in.ascii/in.c:377 ../vector/v.mkgrid/main.c:220
-#: ../vector/v.lrs/v.lrs.create/main.c:309
+#: ../display/drivers/XDRIVER/Graph_set.c:195
#, c-format
-msgid "Unable to create table: %s"
-msgstr "Neschopen vytvoøit tabulku: %s"
+msgid "using default visual which is %s"
+msgstr "pou¾ívám výchozí zobrazení, co¾ je %s"
-#: ../raster/r.to.vect/main.c:192 ../vector/v.mkgrid/main.c:224
-#: ../vector/v.overlay/main.c:427
-msgid "Unable to create index"
-msgstr "Nelze vytvoøit index"
-#: ../raster/r.to.vect/main.c:195 ../raster/r.contour/main.c:195
-#: ../vector/v.distance/main.c:759 ../vector/v.in.ascii/in.c:386
-#: ../vector/v.sample/main.c:216 ../vector/v.mkgrid/main.c:227
-#: ../vector/v.overlay/main.c:430
+#: ../display/d.frame/select.c:42
#, c-format
-msgid "Unable to grant privileges on table <%s>"
-msgstr "Nelze poskytnou práva na tabulku <%s>"
+msgid "Error choosing frame [%s]\n"
+msgstr "Chyba pøi výbìru rámce [%s]\n"
-#: ../raster/r.to.vect/main.c:258
+#: ../display/d.frame/select.c:52
#, c-format
-msgid "Unable to insert into table: %s"
-msgstr "Nelze vlo¾it do tabulky: %s"
-#: ../raster/r.to.vect/lines.c:68
-msgid "Extracting lines..."
-msgstr "Extrahuji linie... "
-#: ../raster/r.to.vect/lines.c:512
msgid ""
-"Raster map is not thinned properly.\n"
-"Please run r.thin."
+"\n"
+"Buttons:\n"
msgstr ""
-"Rastrový soubor nebyl øádnì ztenèen. \n"
-"prosím spus»te r.thin"
+"\n"
+"Tlaèítka:\n"
-#: ../raster/r.to.vect/lines.c:588
-msgid "join_lines: p front pointer not NULL!"
-msgstr "join_lines: p front pointer není NULL!"
+#: ../display/d.frame/select.c:53
+#, c-format
+msgid "Left: Select frame\n"
+msgstr " Levé: Vybrat rámec\n"
-#: ../raster/r.to.vect/lines.c:595
-msgid "join_lines: q front pointer not NULL!"
-msgstr "join_lines: q front pointer není NULL!"
+#: ../display/d.frame/select.c:54
+#, c-format
+msgid "Middle: Keep original frame\n"
+msgstr "Prostøední: Ponechat pùvodní rám\n"
-#: ../raster/r.to.vect/lines.c:614
-msgid "extend line: p is NULL"
-msgstr "extend line: p je NULL"
+#: ../display/d.frame/select.c:55
+#, c-format
+msgid "Right: Accept frame\n"
+msgstr "Pravé: Potvrï rámec\n"
-#: ../raster/r.to.vect/lines.c:642
-msgid "extend_lines: p front pointer not NULL!"
-msgstr "extend_lines: p front pointer není NULL!"
+#: ../display/d.frame/frame.c:62
+msgid "Manages display frames on the user's graphics monitor."
+msgstr "Správa rámcù v grafickém monitoru"
-#: ../raster/r.to.vect/lines.c:650
-msgid "extend_lines: q back pointer not NULL!"
-msgstr "extend_lines: q back pointer není NULL!"
+#: ../display/d.frame/frame.c:66
+msgid "Create a new frame"
+msgstr "Vytvoøit nový rámec"
-#: ../raster/r.to.vect/areas.c:121
-msgid "Extracting areas..."
-msgstr "Extrahuji plochy..."
+#: ../display/d.frame/frame.c:70
+msgid "Select a frame"
+msgstr "Vybrat rámec"
-#: ../raster/r.to.vect/points.c:35
-msgid "Extracting points..."
-msgstr "Extrahuji body..."
+#: ../display/d.frame/frame.c:74 ../display/d.erase/main.c:47
+msgid "Remove all frames and erase the screen"
+msgstr "Odstranit v¹echny rámce a vymazat obrazovku"
-#: ../raster/r.region/main.c:55
-msgid "Sets the boundary definitions for a raster map."
-msgstr "Definuje hranice rastrové mapy."
+#: ../display/d.frame/frame.c:78
+msgid "Print name of current frame"
+msgstr "Vypsat aktuální rámec"
-#: ../raster/r.region/main.c:65
-msgid "Set from current region"
-msgstr "Nastav z aktuálního regionu"
+#: ../display/d.frame/frame.c:82
+msgid "Print names of all frames"
+msgstr "Vytisknout jména v¹ech rámcù"
-#: ../raster/r.region/main.c:69 ../general/g.region/cmd/main.c:89
-msgid "Set from default region"
-msgstr "Nastav z výchozího regionu"
+#: ../display/d.frame/frame.c:86
+msgid "List map names displayed in GRASS monitor"
+msgstr "Vypi¹ jména map zobrazených v grafickém monitoru"
-#: ../raster/r.region/main.c:80
-msgid "Raster map to change"
-msgstr "Rastrová mapa, která má být zmìnìna"
+#: ../display/d.frame/frame.c:90
+msgid "Debugging output"
+msgstr "Roz¹íøený výstup"
-#: ../raster/r.region/main.c:88
-msgid "Set region from named region"
-msgstr "Nastaví aktuální region z pojmenovaného regionu"
+#: ../display/d.frame/frame.c:95
+msgid "name"
+msgstr "jméno"
-#: ../raster/r.region/main.c:96 ../general/g.region/cmd/main.c:165
-msgid "Set region to match this raster map"
-msgstr "Nastav region tak, aby odpovídal této rastrové mapì"
+#: ../display/d.frame/frame.c:98
+msgid "Frame to be created/selected"
+msgstr "Rámec, který má být vytvoøen/vybrán"
-#: ../raster/r.region/main.c:104 ../general/g.region/cmd/main.c:180
-msgid "Set region to match this vector map"
-msgstr "Nastav region tak, aby odpovídal této vektorové mapì"
+#: ../display/d.frame/frame.c:102
+msgid "bottom,top,left,right"
+msgstr "spodní,svrchní,levý,pravý"
-#: ../raster/r.region/main.c:112 ../general/g.region/cmd/main.c:189
-msgid "Set region to match this 3dview file"
-msgstr "Nastav region tak, aby odpovídal souboru 3dview"
+#: ../display/d.frame/frame.c:107
+msgid "Where to place the frame, values in percent (implies -c)"
+msgstr "Kam umístit rám, hodnoty v procentech (potøebuje volbu -c)"
-#: ../raster/r.region/main.c:120 ../general/g.region/cmd/main.c:199
-msgid "Value for the northern edge"
-msgstr "Severní okraj"
+#: ../display/d.what.rast/main.c:46
+msgid ""
+"Allows the user to interactively query the category contents of multiple "
+"raster map layers at user specified locations within the current geographic "
+"region."
+msgstr ""
+"Umo¾òí u¾ivateli interaktivní dotaz na kategorii rastrových map pomocí my¹i "
+"v rámci aktuálního regionu."
-#: ../raster/r.region/main.c:128 ../general/g.region/cmd/main.c:209
-msgid "Value for the southern edge"
-msgstr "Ji¾ní okraj"
+#: ../display/d.what.rast/main.c:75 ../raster/r.compress/main.c:73
+msgid "Name of existing raster map(s)"
+msgstr "Jméno existující(ch) rastrové(ých) map(y)"
-#: ../raster/r.region/main.c:136 ../general/g.region/cmd/main.c:219
-msgid "Value for the eastern edge"
-msgstr "Východní okraj"
+#: ../display/d.what.rast/main.c:83
+msgid "Field separator (terse mode only)"
+msgstr "Oddìlovaè sloupcù (pouze pro struèný výstup)"
-#: ../raster/r.region/main.c:144 ../general/g.region/cmd/main.c:229
-msgid "Value for the western edge"
-msgstr "Západní okraj"
+#: ../display/d.what.rast/main.c:97
+msgid "Print out col/row for the entire map in grid resolution of the region"
+msgstr "Vytiskni sloupec/øádek pro celou mapu v aktuálním rozli¹ení regionu"
-#: ../raster/r.region/main.c:152 ../general/g.region/cmd/main.c:332
-msgid "Raster map to align to"
-msgstr "Rastrová mapa, podle které se má zarovnat"
+#: ../display/d.what.rast/main.c:122
+msgid "Setting graphics window"
+msgstr "Nastavuji mapové okno"
-#: ../raster/r.region/main.c:163 ../raster/r.region/main.c:220
-#: ../raster/r.region/main.c:355 ../display/d.title/main.c:108
-#: ../general/g.region/cmd/main.c:451 ../general/g.region/cmd/main.c:824
-#, c-format
-msgid "Unable to read header of raster map <%s@%s>"
-msgstr "Nelze èíst hlavièku rastrové mapy <%s@%s> "
+#: ../display/d.what.rast/main.c:125
+msgid "Can't set current graphics window"
-#: ../raster/r.region/main.c:177 ../general/g.region/cmd/main.c:395
-#, c-format
-msgid "Region <%s> not found"
-msgstr "Region <%s> nebyl nalezen"
+#: ../display/d.what.rast/main.c:129
+msgid "Getting graphics window coordinates"
+msgstr "Pou¾ívám souøadnice monitoru"
-#: ../raster/r.region/main.c:179 ../general/g.region/cmd/main.c:397
-#, c-format
-msgid "Unable to read region <%s> in <%s>"
-msgstr "Nelze èíst region <%s> v <%s>"
+#: ../display/d.what.rast/what.c:57
+msgid "You are clicking outside the map"
+msgstr "Klikáte mimo mapu"
-#: ../raster/r.region/main.c:190 ../general/g.region/cmd/main.c:409
-#, c-format
-msgid "3dview file <%s> not found"
-msgstr "soubor 3dview <%s> nebyl nalezen"
-#: ../raster/r.region/main.c:196 ../general/g.region/cmd/main.c:414
-#, c-format
-msgid "Unable to open 3dview file <%s> in <%s>"
-msgstr "Nelze otevøít soubor 3dview <%s> v <%s>"
-#: ../raster/r.region/main.c:200 ../general/g.region/cmd/main.c:419
-#, c-format
-msgid "Unable to read 3dview file <%s> in <%s>"
-msgstr "Nelze èíst soubor 3dview <%s> v <%s>"
-#: ../raster/r.region/main.c:202 ../general/g.region/cmd/main.c:421
-#, c-format
-msgid "Old 3dview file. Region <%s> not found in <%s>"
-msgstr "Starý soubor 3dview. Region <%s> nebyl nalezen <%s>"
-#: ../raster/r.region/main.c:234
-#, fuzzy, c-format
-msgid "Unable to open vector map <%s> in <%s>"
-msgstr "Nelze otevøít vektorovou mapu <%s@%s>"
-#: ../raster/r.region/main.c:364 ../general/g.region/cmd/adjust.c:11
-#, c-format
-msgid "Invalid region: %s"
-msgstr "chybný region: %s"
-#: ../raster/r.region/main.c:372
-#, fuzzy
-msgid "Unable to update boundaries"
-msgstr "neschopen zmìnit hranice"
-#: ../raster/r.out.ppm3/main.c:56
+#: ../display/d.thematic.area/main.c:74
msgid ""
-"Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel "
-"resolution of the CURRENTLY DEFINED REGION."
+"Displays a thematic vector area map in the activeframe on the graphics "
+"monitor."
msgstr ""
-"Pøevede 3 GRASSové rastrové mapy (R,G,B) do souboru PPM s rozli¹ením pixelu "
-"podle aktuálnì definovaného regionu."
+"Zobrazí plochy tématické vektorové mapy v aktivním rámci grafického monitoru."
-#: ../raster/r.out.ppm3/main.c:62 ../display/d.rgb/main.c:69
-#, c-format
-msgid "Name of raster map to be used for <%s>"
-msgstr "Název rastrové mapy, která má být pou¾ita pro <%s>"
+#: ../display/d.thematic.area/main.c:84
+msgid "Data to be classified: column name or expression"
+msgstr "Data ke klasifikaci: sloupec nebo výraz"
-#: ../raster/r.out.ppm3/main.c:81
-msgid "Name for new PPM file. (use out=- for stdout)"
-msgstr "Název nového souboru PPM. (pro standardní výstup pou¾ijte out=-)"
+#: ../display/d.thematic.area/main.c:91
+msgid "Class breaks, without minimum and maximum"
+msgstr ""
-#: ../raster/r.out.ppm3/main.c:90
-msgid "Add comments to describe the region"
-msgstr "Pøidej komentáøe pro popis regionu"
+#: ../display/d.thematic.area/main.c:98
+msgid "Colors (one more than class breaks)."
+msgstr "Barvy (o jednu více ne¾ je tøíd)."
-#: ../raster/r.out.ppm3/main.c:176
-msgid "Converting ... "
-msgstr "Pøevádím ... "
+#: ../display/d.thematic.area/main.c:112 ../display/d.thematic.area/main.c:120
+msgid "Boundaries"
+msgstr "Hranice"
-#: ../raster/r.out.vrml/main.c:46
-msgid "raster, export, VRML"
-msgstr "rastr, export, VRML"
+#: ../display/d.thematic.area/main.c:113
+msgid "Boundary width"
+msgstr "©íøka hranice"
-#: ../raster/r.out.vrml/main.c:48
-msgid "Export a raster map to the Virtual Reality Modeling Language (VRML)"
-msgstr "Export rastrové mapy do Virtual Reality Modeling Language (VRML)"
+#: ../display/d.thematic.area/main.c:119
+msgid "Boundary color"
+msgstr "Barva hranice"
-#: ../raster/r.out.vrml/main.c:55
-msgid "Name of elevation map"
-msgstr "Jméno mapy elevace"
+#: ../display/d.thematic.area/main.c:147
+msgid "Do not draw map, only output the legend"
+msgstr "Nevykraslovat mapu, jako výstup pouze legenda"
-#: ../raster/r.out.vrml/main.c:62
-msgid "Name of color file"
-msgstr "Jméno souboru s barvou"
+#: ../display/d.thematic.area/main.c:194
+#, c-format
+msgid "%s: You must build topology on vector map. Run v.build."
+msgstr "%s: Pro vektorovou mapu musíte vybudovat topologii. Spus»te v.build"
-#: ../raster/r.out.vrml/main.c:69
-msgid "Vertical exaggeration"
-msgstr "Vertikální mìøítko"
+#: ../display/d.thematic.area/main.c:201
+msgid "'layer' must be > 0"
+msgstr "'layer' musí být > 0"
-#: ../raster/r.out.vrml/main.c:76
-msgid "Name for new VRML file"
-msgstr "Jméno nového souboru VRML"
+#: ../display/d.thematic.area/main.c:226
+#, c-format
+msgid "Data (%s) not numeric. Column must be numeric."
+msgstr "Data (%s) nejsou èísla. sloupec musí být èíslo."
-#: ../raster/r.out.vrml/main.c:163
+#: ../display/d.thematic.area/main.c:296
#, c-format
-msgid "Opening %s for writing... "
-msgstr "Otevírám %s pro zápis..."
+msgid ""
+"Not enough colors or error in color specifications.\n"
+"Need %i colors."
+msgstr ""
+"Nedostateèný poèet barev v zadávání barev.\n"
+"Je potøeba zadat %i barev."
-#: ../raster/r.out.vrml/put_grid.c:37
-msgid "Writing vertices..."
-msgstr "Zapisuji body ..."
+#: ../display/d.thematic.area/main.c:301
+#, c-format
+msgid "Error interpreting color %s"
+msgstr "Chyba pøi ètení barvy %s"
-#: ../raster/r.out.vrml/put_grid.c:81
-msgid "Writing color file..."
-msgstr "Zapisuji soubor s barvou ..."
+#: ../display/d.mapgraph/main.c:50
+msgid ""
+"Generates and displays simple graphics on map layers drawn in the active "
+"graphics monitor display frame."
+msgstr ""
+"Vytvoøí a zobrazí jednoduché grafické prvky na mapì vykreslené v aktivním "
+"grafickém monitoru."
-#: ../raster/r.in.mat/main.c:95
-msgid "Imports a binary MAT-File(v4) to a GRASS raster."
-msgstr "Importuje soubor MAT (v4) jako rastrový soubor GRASSu."
+#: ../display/d.mapgraph/main.c:57
+msgid ""
+"Unix file containg graphing instructions, if not given reads from standard "
+"input"
+msgstr ""
+"Soubor (Unix) obsahující grafické instrukce, pokud není zadáno, ète se "
+"standardní vstup"
-#: ../raster/r.in.mat/main.c:104
-msgid "Name of an existing MAT-File(v4)"
-msgstr "Název existujícího MAT-souboru(v4)"
+#: ../display/d.mapgraph/main.c:67
+msgid ""
+"Color to draw with, either a standard GRASS color or R:G:B triplet "
+"(separated by colons)"
+msgstr ""
+"Barva kresby, buï standardní GRASS barva nebo trojice R:G:B (oddìleno "
+"dvojteèkou)"
-#: ../raster/r.in.mat/main.c:111
-msgid "Name for the output raster map (override)"
-msgstr "Název výstupní rastrové mapy (pøepi¹)"
+#: ../display/d.linegraph/linegraph.c:115
+msgid ""
+"Generates and displays simple line graphs in the active graphics monitor "
+"display frame."
+msgstr ""
-#: ../raster/r.in.mat/main.c:161
-msgid "Reading MAT-File..."
-msgstr "Naèítám soubor MAT..."
+#: ../display/d.linegraph/linegraph.c:119
+msgid "Name of data file for X axis of graph"
+msgstr "Jméno souboru obsahujícího data osy X grafu"
-#: ../raster/r.in.mat/main.c:187
-msgid "Array contains no data"
-msgstr "Oblast neobsahuje ¾ádná data"
+#: ../display/d.linegraph/linegraph.c:125
+msgid "Name of data file(s) for Y axis of graph"
+msgstr "Jméno souboru s daty pro osu Y grafu"
-#: ../raster/r.in.mat/main.c:192
-msgid "Array contains imaginary data"
-msgstr "Oblast obsahuje snímek"
+#: ../display/d.linegraph/linegraph.c:132
+msgid "Path to file location"
+msgstr "Cesta k souboru"
-#: ../raster/r.in.mat/main.c:198
-msgid "Invalid array name"
-msgstr "©patné jméno oblasti"
+#: ../display/d.linegraph/linegraph.c:139
+msgid "Color for Y data"
+msgstr "Barva pro data osy Y"
-#: ../raster/r.in.mat/main.c:217
-msgid "Invalid 'map_name' array"
-msgstr "©patná oblast 'map_name'"
+#: ../display/d.linegraph/linegraph.c:148
+msgid "Color for axis, tics, numbers, and title"
+msgstr "Barva pro osy, znaèky èísla a název"
-#: ../raster/r.in.mat/main.c:226
-msgid "Error reading 'map_name' array"
-msgstr "Chyba pøi ètení pole 'map_name'"
+#: ../display/d.linegraph/linegraph.c:156
+msgid "Title for X data"
+msgstr "Titulek pro data osy X"
-#: ../raster/r.in.mat/main.c:236
-msgid "Invalid 'map_northern_edge' array"
-msgstr "©patná oblast 'map_northern_edge'"
+#: ../display/d.linegraph/linegraph.c:163
+msgid "Title for Y data"
+msgstr "Titulek pro data osy Y"
-#: ../raster/r.in.mat/main.c:244
-msgid "Invalid 'map_southern_edge' array"
-msgstr "©patná oblast 'map_southern_edge'"
+#: ../display/d.linegraph/linegraph.c:170
+msgid "Title for Graph"
+msgstr "Titulek grafu"
-#: ../raster/r.in.mat/main.c:252
-msgid "Invalid 'map_eastern_edge' array"
-msgstr "©patná oblast 'map_eastern_edge'"
+#: ../display/d.linegraph/linegraph.c:194
+#: ../display/d.linegraph/linegraph.c:206 ../vector/v.segment/main.c:89
+#: ../vector/v.lrs/v.lrs.segment/main.c:129 ../vector/v.net.path/path.c:46
+#: ../raster/r.in.mat/main.c:141 ../raster/r.in.arc/main.c:123
+#: ../raster/r.in.xyz/main.c:441
+#, c-format
+msgid "Unable to open input file <%s>"
+msgstr "Nelze otevøít vstupní soubor <%s>"
-#: ../raster/r.in.mat/main.c:260
-msgid "Invalid 'map_western_edge' array"
-msgstr "©patná oblast 'map_western_edge'"
+#: ../display/d.linegraph/linegraph.c:210
+msgid "Maximum of 10 Y data files exceeded"
+msgstr "maximální poèet souborù (10) byl pøekroèen"
-#: ../raster/r.in.mat/main.c:268
-msgid "Invalid 'map_title' array"
-msgstr "©patná oblast 'map_title'"
+#: ../display/d.linegraph/linegraph.c:243
+#, c-format
+msgid "Only <%d> colors given for <%d> lines"
+msgstr "Jenom <%d> barev pøidìleno <%d> liniím"
-#: ../raster/r.in.mat/main.c:277
-msgid "Error reading 'map_title' array"
-msgstr "Chyba pøi ètení pole 'map_title'"
+#: ../display/d.linegraph/linegraph.c:299
+#, c-format
+msgid "Y input file <%s> contains %s data points than the X input file"
+msgstr "Yvstupní soubor <%s> obsahuje %s data bodù ne¾ X vstupní soubor"
-#: ../raster/r.in.mat/main.c:290
-msgid "Invalid 'map_data' array"
-msgstr "©patná oblasti 'map_data'"
+#: ../display/d.linegraph/linegraph.c:303
+#, c-format
+msgid "The last %d point(s) will be ignored"
+msgstr "Poslední %d bod(y) budou ignorovány"
-#: ../raster/r.in.mat/main.c:312 ../raster/r.in.mat/main.c:418
-#: ../raster/r.in.mat/main.c:495
-msgid "Please contact the GRASS development team"
-msgstr "Prosím, kontaktujte GRASS development team"
-#: ../raster/r.in.mat/main.c:317
+#: ../display/d.linegraph/linegraph.c:370
#, c-format
-msgid "Skipping unknown array '%s'"
-msgstr "Pøeskakuji neznámé pole '%s'"
+msgid "Problem reading X data file at line %d"
+msgstr "Problém pøi ètení øádku %d v souboru s daty osy X"
-#: ../raster/r.in.mat/main.c:344
+#: ../display/d.linegraph/linegraph.c:383
#, c-format
-msgid "No 'map_data' array found in <%s>"
-msgstr "Oblast 'map_data' nenalezena v <%s>"
+msgid "Problem reading <%s> data file at line %d"
+msgstr "Problém pøi ètení souboru s daty <%s> øádku %d"
-#: ../raster/r.in.mat/main.c:358
-msgid "Missing bound"
-msgstr "Postrádám hranici"
+#: ../display/d.extract/main.c:50
+msgid "Selects and extracts vectors with mouse into new vector map."
+msgstr "Vybere a extrahuje vektory vybrané my¹í do nové mapy"
-#: ../raster/r.in.mat/main.c:362
-msgid "Using default bounds"
-msgstr "Pou¾ívám výchozí hranice"
+#: ../display/d.extract/main.c:115
+msgid "Copying tables..."
+msgstr "Kopírování tabulky ..."
-#: ../raster/r.in.mat/main.c:389
-msgid "Writing new raster map..."
-msgstr "Zapisuji novou rastrovou mapu..."
+#: ../display/d.extract/main.c:123
+msgid "Cannot get db link info -> cannot copy table."
+msgstr ""
+"Nelze získat informace o odkazu na databázi -> nelze kopírovat tabulku."
-#: ../raster/r.univar2/r.univar_main.c:41
-#: ../raster/r.univar2/r3.univar_main.c:42 ../vector/v.univar/main.c:90
-msgid "Print the stats in shell script style"
-msgstr "Vypi¹ statistiku ve stylu pro shell skript"
+#: ../display/d.extract/extract.c:42
+msgid "Select vector(s) with mouse"
+msgstr "Vyberte vektor(y) my¹í"
-#: ../raster/r.univar2/r.univar_main.c:80
-msgid ""
-"Calculates univariate statistics from the non-null cells of a raster map."
-msgstr "Spoèítá univariantní statistiku z ne-nullových bunìk rastrové mapy."
+#: ../display/d.extract/extract.c:43
+msgid " - L: draw box with left mouse button to select"
+msgstr " - L: nakreslit levým tlaèítkem rámeèek pro výbìr"
-#: ../raster/r.univar2/r.univar_main.c:113
-#, c-format
-msgid "Reading row %d"
-msgstr "Naèítám øádek %d"
+#: ../display/d.extract/extract.c:44
+msgid " - M: draw box with middle mouse button to remove from display"
+msgstr " - M: nakreslit prostøedním tlaèítkem rámeèek pro vyjmutí ze zobrazení"
-#: ../raster/r.univar2/r3.univar_main.c:79
+#: ../display/d.extract/extract.c:45
+msgid " - R: quit and save selected vectors to new map\n"
+msgstr " - R: ukonèit a ulo¾it vybrané vektory do nové mapy\n"
+#: ../display/d.extract/extract.c:47
+msgid "L: add M: remove R: quit and save\n"
+msgstr ""
+"L: pøidat M: odstranit R: ukonèit a ulo¾it\n"
+"\n"
+#: ../display/d.rast/main.c:54
msgid ""
-"Calculates univariate statistics from the non-null 3d cells of a raster3d "
-"map."
-msgstr "Spoèítá základní statistiku z ne NULLových 3d bunìk 3d rastrové mapy."
+"Displays and overlays raster map layers in the active display frame on the "
+msgstr "Zobrazí a pøekryje rastrovou mapu v aktivním rámu GRASS monitoru"
-#: ../raster/r.watershed/ram/init_vars.c:66
-#, c-format
-msgid "SECTION 1a (of %1d): Initiating Memory."
-msgstr "ÈÁST 1a (z %d1d): inicializace pamìti."
+#: ../display/d.rast/main.c:63
+msgid "Raster map to be displayed"
+msgstr "Rastrová mapa, která má být zobrazena"
-#: ../raster/r.watershed/ram/init_vars.c:108
-msgid "unable to open elevation map layer"
-msgstr "nemohu otevøít mapu elevace"
+#: ../display/d.rast/main.c:71
+msgid "List of categories to be displayed (INT maps)"
+msgstr "Seznam kategorií, které budou zobrazeny (celoèíselné mapy)"
-#: ../raster/r.watershed/ram/init_vars.c:125
-msgid "unable to open runoff map layer"
-msgstr "nemohu otevøít mapu odtoku"
+#: ../display/d.rast/main.c:79
+msgid "List of values to be displayed (FP maps)"
+msgstr ""
+"Seznam hodnot, které mají být vykresleny (mapy s plovoucí desetinnou èárkou)"
-#: ../raster/r.watershed/ram/init_vars.c:146
-msgid "unable to open depression map layer"
-msgstr "nemohu otevøít mapu depresí"
+#: ../display/d.rast/main.c:87
+msgid "Background color (for null)"
+msgstr "Barva pozadí (pro hodnoty null)"
-#: ../raster/r.watershed/ram/init_vars.c:160
-msgid "unable to open blocking map layer"
-msgstr "nemohu otevøít mapu pøeká¾ek"
+#: ../display/d.rast/main.c:91 ../display/d.rgb/main.c:60
+msgid "Overlay (non-null values only)"
+msgstr "Pøekrýt (pouze ne-nullové hodnoty)"
-#: ../raster/r.watershed/ram/init_vars.c:173
-msgid "unable to open rill map layer"
-msgstr "nemohu otevøít mapu drah soustøedìného odtoku"
+#: ../display/d.rast/main.c:95
+msgid "Invert catlist"
+msgstr "Obrácený seznam kategorií"
-#: ../raster/r.watershed/ram/init_vars.c:183
-msgid "unable to open MASK"
-msgstr "nemohu otevøít MASKu"
+#: ../display/d.rast/main.c:99
+msgid "Don't add to list of rasters and commands in monitor"
+msgstr "Nepøidávat do seznamu rastrù a pøíkazù v monitoru"
-#: ../raster/r.watershed/ram/init_vars.c:209
-#: ../raster/r.watershed/seg/init_vars.c:196
-#, c-format
-msgid "SECTION 1b (of %1d): Determining Offmap Flow."
-msgstr "ÈÁST 1b (z %1d): Urèuji odtok mimo mapu."
+#: ../display/d.rast/main.c:119
+msgid "Ignoring catlist: map is floating point (please use 'val=')"
+msgstr ""
+"Ignoruji seznam kategorií: mapa obsahuje hodnoty s
