[GRASS-SVN] r30956 - grass/trunk/locale/po
svn_grass at osgeo.org
Sat Apr 12 15:30:48 EDT 2008
Author: cdavilam
Date: 2008-04-12 15:30:46 -0400 (Sat, 12 Apr 2008)
New Revision: 30956
grass/trunk/locale/po/grasswxpy_es.po
Translation updated
Modified: grass/trunk/locale/po/grasswxpy_es.po
--- grass/trunk/locale/po/grasswxpy_es.po 2008-04-12 18:32:36 UTC (rev 30955)
+++ grass/trunk/locale/po/grasswxpy_es.po 2008-04-12 19:30:46 UTC (rev 30956)
@@ -7,8 +7,8 @@
msgstr ""
"Project-Id-Version: grasswxpy_es\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2008-03-26 21:14+0100\n"
-"PO-Revision-Date: 2008-03-26 22:54+0100\n"
+"POT-Creation-Date: 2008-04-11 20:52+0200\n"
+"PO-Revision-Date: 2008-04-12 21:28+0200\n"
"Last-Translator: Carlos Davila <carluti at users.sourceforge.net>\n"
"Language-Team: Español <grass-translations at lists.osgeo.org>\n"
"MIME-Version: 1.0\n"
@@ -19,74 +19,161 @@
#: ../gui/wxpython/icons/icon.py:153
msgid "Unable to load icon theme, using default icon theme..."
-msgstr ""
+msgstr "No se puede cargar el tema de iconos, se usa el predeterminado..."
-#: ../gui/wxpython/gui_modules/gdialogs.py:43
+#: ../gui/wxpython/gui_modules/gdialogs.py:50
msgid "Name for new vector map:"
-msgstr ""
+msgstr "Nombre para el nuevo mapa vectorial:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:51
-#: ../gui/wxpython/gui_modules/preferences.py:552
+#: ../gui/wxpython/gui_modules/gdialogs.py:58
+#: ../gui/wxpython/gui_modules/preferences.py:593
msgid "Allow output files to overwrite existing files"
-msgstr ""
+msgstr "Permitir que los archivos de salida sobrescriban archivos existente"
-#: ../gui/wxpython/gui_modules/gdialogs.py:99
-#: ../gui/wxpython/gui_modules/menudata.py:1180
+#: ../gui/wxpython/gui_modules/gdialogs.py:106
+#: ../gui/wxpython/gui_modules/menudata.py:1185
msgid "Create new vector map"
-msgstr ""
+msgstr "Crear nuevo mapa vectorial"
-#: ../gui/wxpython/gui_modules/gdialogs.py:111
+#: ../gui/wxpython/gui_modules/gdialogs.py:118
#, python-format
msgid "Unable to create vector map <%s>."
-msgstr ""
+msgstr "No se puede crear el mapa vectorial <%s>."
-#: ../gui/wxpython/gui_modules/gdialogs.py:112
+#: ../gui/wxpython/gui_modules/gdialogs.py:119
#: ../gui/wxpython/gui_modules/location_wizard.py:215
#: ../gui/wxpython/gui_modules/location_wizard.py:528
-#: ../gui/wxpython/gui_modules/location_wizard.py:1320
-#: ../gui/wxpython/gui_modules/location_wizard.py:1630
-#: ../gui/wxpython/gui_modules/location_wizard.py:1731
-#: ../gui/wxpython/gui_modules/location_wizard.py:1805
-#: ../gui/wxpython/gui_modules/location_wizard.py:1906
-#: ../gui/wxpython/gui_modules/location_wizard.py:2070
-#: ../gui/wxpython/gui_modules/location_wizard.py:2089
-#: ../gui/wxpython/gui_modules/location_wizard.py:2396
-#: ../gui/wxpython/gui_modules/menuform.py:1286
-#: ../gui/wxpython/gui_modules/mapdisp.py:920
-#: ../gui/wxpython/gui_modules/mapdisp.py:1504
-#: ../gui/wxpython/gui_modules/digit.py:2058
-#: ../gui/wxpython/gui_modules/digit.py:2202
-#: ../gui/wxpython/gui_modules/digit.py:2229
-#: ../gui/wxpython/gui_modules/dbm.py:1058
-#: ../gui/wxpython/gui_modules/dbm.py:1157
-#: ../gui/wxpython/gui_modules/dbm.py:1237
-#: ../gui/wxpython/gui_modules/dbm.py:1247
-#: ../gui/wxpython/gui_modules/dbm.py:1260
-#: ../gui/wxpython/gui_modules/dbm.py:1326
-#: ../gui/wxpython/gui_modules/dbm.py:1345
-#: ../gui/wxpython/gui_modules/dbm.py:2419
-#: ../gui/wxpython/gui_modules/dbm.py:2457
+#: ../gui/wxpython/gui_modules/location_wizard.py:1323
+#: ../gui/wxpython/gui_modules/location_wizard.py:1633
+#: ../gui/wxpython/gui_modules/location_wizard.py:1734
+#: ../gui/wxpython/gui_modules/location_wizard.py:1808
+#: ../gui/wxpython/gui_modules/location_wizard.py:1909
+#: ../gui/wxpython/gui_modules/location_wizard.py:2076
+#: ../gui/wxpython/gui_modules/location_wizard.py:2095
+#: ../gui/wxpython/gui_modules/location_wizard.py:2402
+#: ../gui/wxpython/gui_modules/menuform.py:1299
+#: ../gui/wxpython/gui_modules/mapdisp.py:967
+#: ../gui/wxpython/gui_modules/mapdisp.py:1554
+#: ../gui/wxpython/gui_modules/digit.py:2227
+#: ../gui/wxpython/gui_modules/digit.py:2375
+#: ../gui/wxpython/gui_modules/digit.py:2402
+#: ../gui/wxpython/gui_modules/dbm.py:1059
+#: ../gui/wxpython/gui_modules/dbm.py:1158
+#: ../gui/wxpython/gui_modules/dbm.py:1240
+#: ../gui/wxpython/gui_modules/dbm.py:1252
+#: ../gui/wxpython/gui_modules/dbm.py:1266
+#: ../gui/wxpython/gui_modules/dbm.py:1359
+#: ../gui/wxpython/gui_modules/dbm.py:1381
+#: ../gui/wxpython/gui_modules/dbm.py:2447
+#: ../gui/wxpython/gui_modules/dbm.py:2485
#: ../gui/wxpython/gui_modules/gcmd.py:54
#: ../gui/wxpython/gui_modules/gcmd.py:70
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:317
-#: ../gui/wxpython/gis_set.py:655 ../gui/wxpython/wxgui.py:617
-#: ../gui/wxpython/wxgui.py:761 ../gui/wxpython/wxgui.py:785
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:316
+#: ../gui/wxpython/gui_modules/workspace.py:181 ../gui/wxpython/gis_set.py:668
+#: ../gui/wxpython/wxgui.py:627 ../gui/wxpython/wxgui.py:813
+#: ../gui/wxpython/wxgui.py:837
msgid "Error"
msgstr "Error"
+#: ../gui/wxpython/gui_modules/gdialogs.py:161
+msgid "Load region:"
+msgstr "Cargar región:"
+#: ../gui/wxpython/gui_modules/gdialogs.py:169
+msgid "Save region:"
+msgstr "Guardar región:"
+#: ../gui/wxpython/gui_modules/gdialogs.py:233
+msgid "Set options"
+msgstr "Establecer opciones"
+#: ../gui/wxpython/gui_modules/gdialogs.py:240
+#, python-format
+msgid ""
+"Drag %s with mouse in pointer mode to position.\n"
+"Double-click to change options."
+msgstr ""
+"Arrastrar %s con el ratón en modo puntero a la posición.\n"
+"Doble pulsación para cambiar las opciones."
+#: ../gui/wxpython/gui_modules/gdialogs.py:243
+msgid ""
+"\n"
+"Define raster map name for legend in properties dialog."
+msgstr ""
+"\n"
+"Definir nombre de mapa ráster para la leyenda en el diálogo de propiedades."
+#: ../gui/wxpython/gui_modules/gdialogs.py:294
+#: ../gui/wxpython/gui_modules/gdialogs.py:374
+#, python-format
+msgid "Legend of raster map <%s>"
+msgstr "Leyenda del mapa ráster <%s>"
+#: ../gui/wxpython/gui_modules/gdialogs.py:402
+msgid "Enter text:"
+msgstr "Introducir texto:"
+#: ../gui/wxpython/gui_modules/gdialogs.py:415
+msgid "Rotation:"
+msgstr "Rotación:"
+#: ../gui/wxpython/gui_modules/gdialogs.py:428
+#: ../gui/wxpython/gui_modules/preferences.py:497
+msgid "Set font"
+msgstr "Establecer tipo de letra"
+#: ../gui/wxpython/gui_modules/gdialogs.py:439
+msgid ""
+"Drag text with mouse in pointer mode to position.\n"
+"Double-click to change options"
+msgstr ""
+"Arrastrar texto con el ratón en modo puntero a la posición.\n"
+#: ../gui/wxpython/gui_modules/gdialogs.py:527
+msgid "Load"
+msgstr "Cargar"
+#: ../gui/wxpython/gui_modules/gdialogs.py:562
+msgid "Map layer type:"
+msgstr "Tipo de capa de mapa:"
+#: ../gui/wxpython/gui_modules/gdialogs.py:573
+msgid "Mapset:"
+msgstr "Directorio de mapas:"
+#: ../gui/wxpython/gui_modules/gdialogs.py:586
+msgid "Filter:"
+msgstr "Filtro:"
+#: ../gui/wxpython/gui_modules/gdialogs.py:598
+msgid "List of maps:"
+msgstr "Lista de mapas:"
+#: ../gui/wxpython/gui_modules/gdialogs.py:654
+#: ../gui/wxpython/gui_modules/dbm.py:913
+msgid "Select all"
+msgstr "Seleccionar todo"
+#: ../gui/wxpython/gui_modules/gdialogs.py:655
+#: ../gui/wxpython/gui_modules/dbm.py:914
+msgid "Deselect all"
+msgstr "Deseleccionar todo"
#: ../gui/wxpython/gui_modules/location_wizard.py:129
msgid "Define GRASS Database and Location Name"
-msgstr ""
+msgstr "Definir base de datos de GRASS y nombre de localización"
#: ../gui/wxpython/gui_modules/location_wizard.py:135
#: ../gui/wxpython/gui_modules/location_wizard.py:1064
#: ../gui/wxpython/gui_modules/location_wizard.py:1156
-#: ../gui/wxpython/gui_modules/menuform.py:1123 ../gui/wxpython/gis_set.py:125
+#: ../gui/wxpython/gui_modules/menuform.py:1130 ../gui/wxpython/gis_set.py:122
msgid "Browse"
-msgstr ""
+msgstr "Explorar"
#: ../gui/wxpython/gui_modules/location_wizard.py:143
-#: ../gui/wxpython/gis_set.py:101
+#: ../gui/wxpython/gis_set.py:98
msgid "GIS Data Directory:"
msgstr "Directorio de datos de SIG:"
@@ -96,12 +183,12 @@
#: ../gui/wxpython/gui_modules/location_wizard.py:197
msgid "Choose GRASS data directory:"
-msgstr ""
+msgstr "Seleccionar directorio de datos de GRASS:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1730
+#: ../gui/wxpython/gui_modules/location_wizard.py:1733
msgid "Location already exists in GRASS Database."
-msgstr ""
+msgstr "La localización ya existe en la base de datos de GRASS."
#: ../gui/wxpython/gui_modules/location_wizard.py:211
msgid "Unable to create location"
@@ -117,23 +204,24 @@
#: ../gui/wxpython/gui_modules/location_wizard.py:247
msgid "Select EPSG code of coordinate system"
-msgstr ""
+msgstr "Seleccionar código EPSG del sistema de coordenadas"
#: ../gui/wxpython/gui_modules/location_wizard.py:249
msgid "Use coordinate system of selected georeferenced file"
-msgstr ""
+msgstr "Usar sistema de coordenadas del archivo georreferenciado seleccionado"
#: ../gui/wxpython/gui_modules/location_wizard.py:252
msgid "Create custom PROJ.4 parameters string for coordinate system"
-msgstr ""
+msgstr "Crear cadena de parámetros PROJ.4 personalizada para el sistema de coordenadas"
#: ../gui/wxpython/gui_modules/location_wizard.py:255
+#, fuzzy
msgid "Use arbitrary non-earth coordinate system (XY)"
-msgstr ""
+msgstr "Usar sistema de coordenadas "
#: ../gui/wxpython/gui_modules/location_wizard.py:320
msgid "Choose projection"
-msgstr ""
+msgstr "Seleccionar proyección"
#: ../gui/wxpython/gui_modules/location_wizard.py:335
#: ../gui/wxpython/gui_modules/location_wizard.py:759
@@ -141,7 +229,7 @@
#: ../gui/wxpython/gui_modules/location_wizard.py:952
#: ../gui/wxpython/gui_modules/location_wizard.py:1164
msgid "Code"
-msgstr ""
+msgstr "Código"
@@ -149,291 +237,291 @@
msgid "Description"
-msgstr ""
+msgstr "Descripción"
#: ../gui/wxpython/gui_modules/location_wizard.py:338
msgid "Projection code:"
-msgstr ""
+msgstr "Código de la proyección:"
#: ../gui/wxpython/gui_modules/location_wizard.py:346
#: ../gui/wxpython/gui_modules/location_wizard.py:781
#: ../gui/wxpython/gui_modules/location_wizard.py:964
#: ../gui/wxpython/gui_modules/location_wizard.py:1147
msgid "Search in description:"
-msgstr ""
+msgstr "Buscar en la descripción:"
#: ../gui/wxpython/gui_modules/location_wizard.py:527
#, python-format
msgid "Unable to read list: %s"
-msgstr ""
+msgstr "No se puede leer la lista: %s"
#: ../gui/wxpython/gui_modules/location_wizard.py:627
-#: ../gui/wxpython/gui_modules/location_wizard.py:1330
+#: ../gui/wxpython/gui_modules/location_wizard.py:1333
msgid "Choose method of specifying georeferencing parameters"
-msgstr ""
+msgstr "Seleccionar método para especificar los parámetros de georreferenciación"
#: ../gui/wxpython/gui_modules/location_wizard.py:635
msgid "Select datum with associated ellipsoid"
-msgstr ""
+msgstr "Seleccionar datum con elipsoide asociado"
#: ../gui/wxpython/gui_modules/location_wizard.py:638
msgid "Select ellipsoid"
-msgstr ""
+msgstr "Seleccionar elipsoide"
#: ../gui/wxpython/gui_modules/location_wizard.py:639
msgid "Set zone for UTM projection:"
-msgstr ""
+msgstr "Establecer zona para proyección UTM:"
#: ../gui/wxpython/gui_modules/location_wizard.py:641
msgid "Zone:"
-msgstr ""
+msgstr "Zona:"
#: ../gui/wxpython/gui_modules/location_wizard.py:644
msgid "Hemisphere for zone:"
-msgstr ""
+msgstr "Hemisferio para la zona:"
#: ../gui/wxpython/gui_modules/location_wizard.py:732
msgid "Specify geodetic datum"
-msgstr ""
+msgstr "Especificar datum geodésico"
msgid "Ellipsoid"
-msgstr ""
+msgstr "Elipsoide"
#: ../gui/wxpython/gui_modules/location_wizard.py:767
msgid "Datum"
-msgstr ""
+msgstr "Datum"
#: ../gui/wxpython/gui_modules/location_wizard.py:772
msgid "Datum code:"
-msgstr ""
+msgstr "Código del datum:"
#: ../gui/wxpython/gui_modules/location_wizard.py:796
msgid "Transformation parameters:"
-msgstr ""
+msgstr "Parámetros de transformación:"
#: ../gui/wxpython/gui_modules/location_wizard.py:929
msgid "Specify ellipsoid"
-msgstr ""
+msgstr "Especificar elipsoide"
#: ../gui/wxpython/gui_modules/location_wizard.py:956
msgid "Ellipsoid code:"
-msgstr ""
+msgstr "Código del elipsoide:"
#: ../gui/wxpython/gui_modules/location_wizard.py:1057
#: ../gui/wxpython/gui_modules/location_wizard.py:1116
msgid "Select georeferenced file"
-msgstr ""
+msgstr "Seleccionar archivo georreferenciado"
#: ../gui/wxpython/gui_modules/location_wizard.py:1062
msgid "Georeferenced file:"
-msgstr ""
+msgstr "Archivo georreferenciado:"
#: ../gui/wxpython/gui_modules/location_wizard.py:1135
msgid "Choose EPSG Code"
-msgstr ""
+msgstr "Seleccionar código EPSG"
#: ../gui/wxpython/gui_modules/location_wizard.py:1143
msgid "Path to the EPSG-codes file:"
-msgstr ""
+msgstr "Ruta al archivo de códigos EPSG:"
#: ../gui/wxpython/gui_modules/location_wizard.py:1145
msgid "EPSG code:"
-msgstr ""
+msgstr "Código EPSG:"
#: ../gui/wxpython/gui_modules/location_wizard.py:1157
msgid "Browse EPSG Codes"
-msgstr ""
+msgstr "Explorar códigos EPSG"
msgid "Parameters"
-msgstr ""
+msgstr "Parámetros"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1271
+#: ../gui/wxpython/gui_modules/location_wizard.py:1274
msgid "Choose EPSG codes file:"
-msgstr ""
+msgstr "Seleccionar archivo de códigos EPSG:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1319
+#: ../gui/wxpython/gui_modules/location_wizard.py:1322
#, python-format
msgid "Unable to read EPGS codes: %s"
-msgstr ""
+msgstr "No se pueden leer los códigos EPSG: %s"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1338
+#: ../gui/wxpython/gui_modules/location_wizard.py:1341
msgid "Enter PROJ.4 parameters string:"
-msgstr ""
+msgstr "Introducir cadena de parámetros PROJ.4:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1389
+#: ../gui/wxpython/gui_modules/location_wizard.py:1392
msgid "Summary"
-msgstr ""
+msgstr "Resumen"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1411
+#: ../gui/wxpython/gui_modules/location_wizard.py:1414
msgid "GRASS Database:"
-msgstr ""
+msgstr "Base de datos de GRASS:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1417
+#: ../gui/wxpython/gui_modules/location_wizard.py:1420
msgid "Location Name:"
-msgstr ""
+msgstr "Nombre de la localización:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1423
+#: ../gui/wxpython/gui_modules/location_wizard.py:1426
msgid "Projection:"
-msgstr ""
+msgstr "Proyección:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1462
+#: ../gui/wxpython/gui_modules/location_wizard.py:1465
msgid "PROJ.4 definition:"
-msgstr ""
+msgstr "Definición PROJ.4:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1504
+#: ../gui/wxpython/gui_modules/location_wizard.py:1507
#, python-format
msgid "Do you want to create GRASS location <%s>?"
-msgstr ""
+msgstr "¿Quiere crear la localización de GRASS <%s>?"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1505
+#: ../gui/wxpython/gui_modules/location_wizard.py:1508
msgid "Create new location?"
-msgstr ""
+msgstr "¿Crear nueva localización?"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1541
+#: ../gui/wxpython/gui_modules/location_wizard.py:1544
msgid "Define new GRASS Location"
-msgstr ""
+msgstr "Definir nueva localización de GRASS"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1614
+#: ../gui/wxpython/gui_modules/location_wizard.py:1617
msgid "Do you want to set the default region extents and resolution now?"
-msgstr ""
+msgstr "¿Quiere establecer la extensión y resolución de la región predeterminada ahora?"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1616
+#: ../gui/wxpython/gui_modules/location_wizard.py:1619
#, python-format
msgid "Location <%s> created"
-msgstr ""
+msgstr "Localización <%s> creada"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1629
-#: ../gui/wxpython/gui_modules/location_wizard.py:1728
-#: ../gui/wxpython/gui_modules/location_wizard.py:1804
-#: ../gui/wxpython/gui_modules/location_wizard.py:1905
-#: ../gui/wxpython/gui_modules/location_wizard.py:1970
+#: ../gui/wxpython/gui_modules/location_wizard.py:1632
+#: ../gui/wxpython/gui_modules/location_wizard.py:1731
+#: ../gui/wxpython/gui_modules/location_wizard.py:1807
+#: ../gui/wxpython/gui_modules/location_wizard.py:1908
+#: ../gui/wxpython/gui_modules/location_wizard.py:1973
msgid "Unable to create new location"
-msgstr ""
+msgstr "No se puede crear la nueva localización"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1638
+#: ../gui/wxpython/gui_modules/location_wizard.py:1641
msgid "Location wizard canceled. Location not created."
-msgstr ""
+msgstr "Se ha cancelado el asistente de localizaciones. La localización no se ha creado."
-#: ../gui/wxpython/gui_modules/location_wizard.py:1640
-#: ../gui/wxpython/gis_set.py:129
+#: ../gui/wxpython/gui_modules/location_wizard.py:1643
+#: ../gui/wxpython/gis_set.py:126
msgid "Location wizard"
-msgstr ""
+msgstr "Asistente de localizaciones"
msgid "EPSG code missing."
-msgstr ""
+msgstr "Falta el código EPSG."
-#: ../gui/wxpython/gui_modules/location_wizard.py:1924
+#: ../gui/wxpython/gui_modules/location_wizard.py:1927
msgid "Select datum transformation"
-msgstr ""
+msgstr "Seleccionar transformación del datum"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1938
+#: ../gui/wxpython/gui_modules/location_wizard.py:1941
msgid "Datum transform is required."
-msgstr ""
+msgstr "Se requiere una transformación del datum."
-#: ../gui/wxpython/gui_modules/location_wizard.py:1971
+#: ../gui/wxpython/gui_modules/location_wizard.py:1974
msgid "file not found"
-msgstr ""
+msgstr "no se ha encontrado el archivo"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1992
+#: ../gui/wxpython/gui_modules/location_wizard.py:1995
msgid "Set default region extent and resolution"
-msgstr ""
+msgstr "Establecer la extensión y resolución de la región predeterminada"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2036
+#: ../gui/wxpython/gui_modules/location_wizard.py:2039
msgid "&Set region"
-msgstr ""
+msgstr "E&stablecer región"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2069
+#: ../gui/wxpython/gui_modules/location_wizard.py:2075
msgid "Invalid location selected."
-msgstr ""
+msgstr "Seleccionada una localizacióń no válida."
-#: ../gui/wxpython/gui_modules/location_wizard.py:2088
+#: ../gui/wxpython/gui_modules/location_wizard.py:2094
msgid "Invalid region"
-msgstr ""
+msgstr "Región no válida"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2118
+#: ../gui/wxpython/gui_modules/location_wizard.py:2124
msgid "Click here to show 3D settings"
-msgstr ""
+msgstr "Pulse aquí para mostrar configuración 3D"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2119
+#: ../gui/wxpython/gui_modules/location_wizard.py:2125
msgid "Click here to hide 3D settings"
-msgstr ""
+msgstr "Pulse aquí para ocultar configuración 3D"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2142
-#: ../gui/wxpython/gui_modules/location_wizard.py:2423
+#: ../gui/wxpython/gui_modules/location_wizard.py:2148
+#: ../gui/wxpython/gui_modules/location_wizard.py:2429
#, python-format
msgid "Rows: %d"
-msgstr ""
+msgstr "Filas: %d"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2143
-#: ../gui/wxpython/gui_modules/location_wizard.py:2424
+#: ../gui/wxpython/gui_modules/location_wizard.py:2149
+#: ../gui/wxpython/gui_modules/location_wizard.py:2430
#, python-format
msgid "Cols: %d"
-msgstr ""
+msgstr "Columnas: %d"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2144
-#: ../gui/wxpython/gui_modules/location_wizard.py:2425
+#: ../gui/wxpython/gui_modules/location_wizard.py:2150
+#: ../gui/wxpython/gui_modules/location_wizard.py:2431
#, python-format
msgid "Cells: %d"
-msgstr ""
+msgstr "Celdas: %d"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2185
-#: ../gui/wxpython/gui_modules/location_wizard.py:2427
+#: ../gui/wxpython/gui_modules/location_wizard.py:2191
+#: ../gui/wxpython/gui_modules/location_wizard.py:2433
#, python-format
msgid "Depth: %d"
-msgstr ""
+msgstr "Profundida: %d"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2186
-#: ../gui/wxpython/gui_modules/location_wizard.py:2428
+#: ../gui/wxpython/gui_modules/location_wizard.py:2192
+#: ../gui/wxpython/gui_modules/location_wizard.py:2434
#, python-format
msgid "3D Cells: %d"
-msgstr ""
+msgstr "Celdas 3D: %d"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2189
+#: ../gui/wxpython/gui_modules/location_wizard.py:2195
msgid "Top"
-msgstr ""
+msgstr "Superior"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2197
+#: ../gui/wxpython/gui_modules/location_wizard.py:2203
msgid "Bottom"
-msgstr ""
+msgstr "Inferior"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2205
+#: ../gui/wxpython/gui_modules/location_wizard.py:2211
msgid "T-B resolution"
-msgstr ""
+msgstr "Resolución Sup-Inf"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2268
+#: ../gui/wxpython/gui_modules/location_wizard.py:2274
msgid "North"
-msgstr ""
+msgstr "Norte"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2276
+#: ../gui/wxpython/gui_modules/location_wizard.py:2282
msgid "West"
-msgstr ""
+msgstr "Oeste"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2296
+#: ../gui/wxpython/gui_modules/location_wizard.py:2302
msgid "East"
-msgstr ""
+msgstr "Este"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2305
+#: ../gui/wxpython/gui_modules/location_wizard.py:2311
msgid "South"
-msgstr ""
+msgstr "Sur"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2309
+#: ../gui/wxpython/gui_modules/location_wizard.py:2315
msgid "N-S resolution"
msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:2317
+#: ../gui/wxpython/gui_modules/location_wizard.py:2323
msgid "E-W resolution"
msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:2395
+#: ../gui/wxpython/gui_modules/location_wizard.py:2401
#, python-format
msgid "Invalid value: %s"
msgstr ""
#: ../gui/wxpython/gui_modules/menuform.py:139
-#: ../gui/wxpython/gui_modules/menuform.py:1085
+#: ../gui/wxpython/gui_modules/menuform.py:1092
msgid "Select Color"
msgstr ""
@@ -489,7 +577,7 @@
msgstr ""
#: ../gui/wxpython/gui_modules/menuform.py:673
-#: ../gui/wxpython/gui_modules/preferences.py:562
+#: ../gui/wxpython/gui_modules/preferences.py:603
msgid "Close dialog on finish"
msgstr ""
@@ -513,7 +601,7 @@
#: ../gui/wxpython/gui_modules/menuform.py:837
#: ../gui/wxpython/gui_modules/menuform.py:850
-#: ../gui/wxpython/gui_modules/menuform.py:1177
+#: ../gui/wxpython/gui_modules/menuform.py:1184
msgid "Required"
msgstr ""
@@ -534,35 +622,35 @@
msgid "[multiple]"
msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:984
+#: ../gui/wxpython/gui_modules/menuform.py:988
msgid "Valid range"
msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1104
+#: ../gui/wxpython/gui_modules/menuform.py:1111
msgid "Transparent"
msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1121
+#: ../gui/wxpython/gui_modules/menuform.py:1128
#, python-format
msgid "Choose %s"
msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1122
+#: ../gui/wxpython/gui_modules/menuform.py:1129
#: ../gui/wxpython/gui_modules/menudata.py:26
msgid "File"
msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1305
+#: ../gui/wxpython/gui_modules/menuform.py:1318
#, python-format
msgid "Unable to fetch interface description for command '%s'."
msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1389
+#: ../gui/wxpython/gui_modules/menuform.py:1402
#, python-format
msgid "Unable to parse command %s"
msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1450
+#: ../gui/wxpython/gui_modules/menuform.py:1463
#, python-format
msgid "usage: %s <grass command>"
msgstr ""
@@ -632,113 +720,149 @@
msgid "overwrite existing file"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:919
-#: ../gui/wxpython/gui_modules/mapdisp.py:1503
+#: ../gui/wxpython/gui_modules/mapdisp.py:966
+#: ../gui/wxpython/gui_modules/mapdisp.py:1553
msgid "No vector map selected for editing."
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1055
-#: ../gui/wxpython/gui_modules/mapdisp.py:1064
+#: ../gui/wxpython/gui_modules/mapdisp.py:1101
+#: ../gui/wxpython/gui_modules/mapdisp.py:1110
msgid "Update categories"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1597
+#: ../gui/wxpython/gui_modules/mapdisp.py:1646
msgid "Z bulk-labeling dialog"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:2078
+#: ../gui/wxpython/gui_modules/mapdisp.py:2087
+msgid "Zoom to saved region extents"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2138
#, python-format
msgid "Region file <%s> already exists. Do you want to overwrite it?"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:2080 ../gui/wxpython/wxgui.py:669
-#: ../gui/wxpython/wxgui.py:687
+#: ../gui/wxpython/gui_modules/mapdisp.py:2140
+#: ../gui/wxpython/gui_modules/workspace.py:197 ../gui/wxpython/wxgui.py:721
+#: ../gui/wxpython/wxgui.py:739
msgid "Warning"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:2214
+#: ../gui/wxpython/gui_modules/mapdisp.py:2186
+msgid "GRASS GIS - Map display"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2276
msgid "Render"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:2217
+#: ../gui/wxpython/gui_modules/mapdisp.py:2279
msgid "Enable/disable auto-rendering"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:2220
-msgid "Show"
+#: ../gui/wxpython/gui_modules/mapdisp.py:2282
+msgid "Show computational extent"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:2224
-msgid "Show/hide computational region extent (set with g.region)"
+#: ../gui/wxpython/gui_modules/mapdisp.py:2287
+msgid ""
+"Show/hide computational region extent (set with g.region). Display region "
+"drawn as a blue box inside the computational region, computational region "
+"inside a display region as a red box)."
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:2795
+#: ../gui/wxpython/gui_modules/mapdisp.py:2295
+#: ../gui/wxpython/gui_modules/preferences.py:544
+msgid "Constrain display resolution to computational settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2299
+msgid ""
+"Constrain display resolution to computational region settings. Default value "
+"for new map displays can be set up in 'User GUI settings' dialog."
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2903
msgid "No map layer selected for querying."
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:2796
-#: ../gui/wxpython/gui_modules/dbm.py:2641
-#: ../gui/wxpython/gui_modules/toolbars.py:488 ../gui/wxpython/wxgui.py:982
-#: ../gui/wxpython/wxgui.py:1268
+#: ../gui/wxpython/gui_modules/mapdisp.py:2904
+#: ../gui/wxpython/gui_modules/mapdisp.py:2963
+#: ../gui/wxpython/gui_modules/digit.py:747
+#: ../gui/wxpython/gui_modules/dbm.py:2669 ../gui/wxpython/wxgui.py:1038
+#: ../gui/wxpython/wxgui.py:1368
msgid "Message"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:3062
+#: ../gui/wxpython/gui_modules/mapdisp.py:2962
+msgid "No vector map selected for querying."
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3115
+#, python-format
+msgid ""
+"Click and drag with left mouse button to measure.%sDouble click with left "
+"button to clear."
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3122
+msgid "Measuring distance ("
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3126
+msgid "Measuring distance:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3279
msgid "Scale and North arrow"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:3068
+#: ../gui/wxpython/gui_modules/mapdisp.py:3285
msgid "Show/hide scale and North arrow"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:3069
+#: ../gui/wxpython/gui_modules/mapdisp.py:3286
msgid "scale object"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:3122
+#: ../gui/wxpython/gui_modules/mapdisp.py:3312
msgid "Show/hide legend"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:3123
+#: ../gui/wxpython/gui_modules/mapdisp.py:3313
msgid "legend object"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:3232
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:241
+#: ../gui/wxpython/gui_modules/mapdisp.py:3337
+msgid "Add text layer"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3385
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:240
msgid "Zoom to selected map"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:3236
+#: ../gui/wxpython/gui_modules/mapdisp.py:3389
msgid "Zoom to computational region (set with g.region)"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:3240
-msgid "Set computational region from display"
+#: ../gui/wxpython/gui_modules/mapdisp.py:3393
+msgid "Zoom to default region"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:3244
+#: ../gui/wxpython/gui_modules/mapdisp.py:3397
msgid "Zoom to saved region"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:3248
-msgid "Save display geometry to named region"
+#: ../gui/wxpython/gui_modules/mapdisp.py:3401
+msgid "Set computational region from display"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:3295
-msgid "Set options"
+#: ../gui/wxpython/gui_modules/mapdisp.py:3405
+msgid "Save display geometry to named region"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:3302
-#, python-format
-msgid ""
-"Drag %s with mouse in pointer mode to position. Double-click to change "
-"options."
-msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:3380
-msgid "Enter text:"
-msgstr ""
#: ../gui/wxpython/gui_modules/menudata.py:27
msgid "Workspace"
msgstr ""
@@ -763,1011 +887,1021 @@
msgid "Load map layers"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:40 ../gui/wxpython/wxgui.py:627
+#: ../gui/wxpython/gui_modules/menudata.py:40 ../gui/wxpython/wxgui.py:637
msgid "Load map layers into layer tree"
msgstr ""
#: ../gui/wxpython/gui_modules/menudata.py:44
+msgid "Load GRC file (Tcl/Tk GUI)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:45
+msgid "Load map layers from GRC file to layer tree (not fully implemented)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:49
msgid "Save workspace"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:45
+#: ../gui/wxpython/gui_modules/menudata.py:50
msgid "Save current workspace to file"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:49
+#: ../gui/wxpython/gui_modules/menudata.py:54
msgid "Save workspace as"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:50
+#: ../gui/wxpython/gui_modules/menudata.py:55
msgid "Save current workspace as file"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:54
+#: ../gui/wxpython/gui_modules/menudata.py:59
msgid "Close current workspace"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:55
+#: ../gui/wxpython/gui_modules/menudata.py:60
msgid "Close current workspace file"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:61
+#: ../gui/wxpython/gui_modules/menudata.py:66
msgid "Import raster map"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:63
+#: ../gui/wxpython/gui_modules/menudata.py:68
msgid "Multiple import formats using GDAL"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:64
+#: ../gui/wxpython/gui_modules/menudata.py:69
msgid "Import GDAL supported raster file into a binary raster map layer."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:69
+#: ../gui/wxpython/gui_modules/menudata.py:74
msgid "Aggregate ASCII xyz import"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:70
+#: ../gui/wxpython/gui_modules/menudata.py:75
msgid ""
"Create a raster map from an assemblage of many coordinates using univariate "
"statistics."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:74
+#: ../gui/wxpython/gui_modules/menudata.py:79
msgid "ASCII grid import"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:75
+#: ../gui/wxpython/gui_modules/menudata.py:80
msgid "Converts ASCII raster file to binary raster map layer."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:79
+#: ../gui/wxpython/gui_modules/menudata.py:84
msgid "ASCII polygons and lines import"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:80
+#: ../gui/wxpython/gui_modules/menudata.py:85
msgid "Creates raster maps from ASCII polygon/line/point data files."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:85
+#: ../gui/wxpython/gui_modules/menudata.py:90
msgid "Binary file import"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:86
+#: ../gui/wxpython/gui_modules/menudata.py:91
msgid "Import a binary raster file into a GRASS raster map layer."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:90
+#: ../gui/wxpython/gui_modules/menudata.py:95
msgid "ESRI ASCII grid import"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:91
+#: ../gui/wxpython/gui_modules/menudata.py:96
msgid ""
"Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster "
"map layer."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:95
+#: ../gui/wxpython/gui_modules/menudata.py:100
msgid "GRIDATB.FOR import"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:96
+#: ../gui/wxpython/gui_modules/menudata.py:101
msgid "Imports GRIDATB.FOR map file (TOPMODEL) into GRASS raster map"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:100
+#: ../gui/wxpython/gui_modules/menudata.py:105
msgid "MAT-File (v.4) import"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:101
+#: ../gui/wxpython/gui_modules/menudata.py:106
msgid "Imports a binary MAT-File(v4) to a GRASS raster."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:105
+#: ../gui/wxpython/gui_modules/menudata.py:110
msgid "SPOT NDVI import"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:106
+#: ../gui/wxpython/gui_modules/menudata.py:111
msgid "Import of SPOT VGT NDVI file into a raster map"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:110
+#: ../gui/wxpython/gui_modules/menudata.py:115
msgid "SRTM HGT import"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:111
+#: ../gui/wxpython/gui_modules/menudata.py:116
msgid "Import SRTM HGT files into GRASS"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:115
+#: ../gui/wxpython/gui_modules/menudata.py:120
msgid "Terra ASTER HDF import"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:116
+#: ../gui/wxpython/gui_modules/menudata.py:121
msgid ""
"Georeference, rectify and import Terra-ASTER imagery and relative DEM's "
"using gdalwarp."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:121
+#: ../gui/wxpython/gui_modules/menudata.py:126
msgid "WMS import"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:122
+#: ../gui/wxpython/gui_modules/menudata.py:127
msgid "Downloads and imports data from WMS servers."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:127
+#: ../gui/wxpython/gui_modules/menudata.py:132
msgid "Import vector map"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:129
-#: ../gui/wxpython/gui_modules/menudata.py:192
+#: ../gui/wxpython/gui_modules/menudata.py:134
+#: ../gui/wxpython/gui_modules/menudata.py:197
msgid "Multiple import formats using OGR"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:130
+#: ../gui/wxpython/gui_modules/menudata.py:135
msgid "Convert OGR vector layers to GRASS vector map."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:135
+#: ../gui/wxpython/gui_modules/menudata.py:140
msgid "ASCII points/GRASS ASCII vector import"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:136
+#: ../gui/wxpython/gui_modules/menudata.py:141
msgid "Creates a vector map from ASCII points file or ASCII vector file."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:140
+#: ../gui/wxpython/gui_modules/menudata.py:145
msgid "Old GRASS vector import"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:141
+#: ../gui/wxpython/gui_modules/menudata.py:146
msgid "Imports older versions of GRASS vector maps."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:146
+#: ../gui/wxpython/gui_modules/menudata.py:151
msgid "DXF import"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:147
+#: ../gui/wxpython/gui_modules/menudata.py:152
msgid "Converts files in DXF format to GRASS vector map format."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:151
+#: ../gui/wxpython/gui_modules/menudata.py:156
msgid "ESRI e00 import"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:152
+#: ../gui/wxpython/gui_modules/menudata.py:157
msgid "Import E00 file into a vector map."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:156
+#: ../gui/wxpython/gui_modules/menudata.py:161
msgid "Garmin GPS import"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:157
+#: ../gui/wxpython/gui_modules/menudata.py:162
msgid ""
"Download waypoints, routes, and tracks from a Garmin GPS receiver into a "
"vector map."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:161
+#: ../gui/wxpython/gui_modules/menudata.py:166
msgid "GPSBabel GPS import"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:162
+#: ../gui/wxpython/gui_modules/menudata.py:167
msgid ""
"Import waypoints, routes, and tracks from a GPS receiver or GPS download "
"file into a vector map."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:166
+#: ../gui/wxpython/gui_modules/menudata.py:171
msgid "GEOnet import"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:167
+#: ../gui/wxpython/gui_modules/menudata.py:172
msgid ""
"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
"points map."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:171
+#: ../gui/wxpython/gui_modules/menudata.py:176
msgid "Matlab and MapGen import"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:172
+#: ../gui/wxpython/gui_modules/menudata.py:177
msgid "Import Mapgen or Matlab vector maps into GRASS."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:177
+#: ../gui/wxpython/gui_modules/menudata.py:182
msgid "Import grid 3D volume"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:179
+#: ../gui/wxpython/gui_modules/menudata.py:184
msgid "ASCII 3D import"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:180
+#: ../gui/wxpython/gui_modules/menudata.py:185
msgid "Convert a 3D ASCII raster text file into a (binary) 3D raster map layer"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:184
+#: ../gui/wxpython/gui_modules/menudata.py:189
msgid "Vis5D import"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:185
+#: ../gui/wxpython/gui_modules/menudata.py:190
msgid ""
"import of 3-dimensional Vis5D files (i.e. the v5d file with 1 variable and 1 "
"time step)"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:190
+#: ../gui/wxpython/gui_modules/menudata.py:195
msgid "Import database table"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:193
+#: ../gui/wxpython/gui_modules/menudata.py:198
msgid "Imports attribute tables in various formats."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:199
+#: ../gui/wxpython/gui_modules/menudata.py:204
msgid "Export raster map"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:201
+#: ../gui/wxpython/gui_modules/menudata.py:206
msgid "Multiple export formats using GDAL"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:202
+#: ../gui/wxpython/gui_modules/menudata.py:207
msgid "Exports GRASS raster map into GDAL supported formats."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:207
+#: ../gui/wxpython/gui_modules/menudata.py:212
msgid "ASCII grid export"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:208
+#: ../gui/wxpython/gui_modules/menudata.py:213
msgid "Converts a raster map layer into an ASCII text file."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:212
+#: ../gui/wxpython/gui_modules/menudata.py:217
msgid "ASCII x,y,z export"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:213
+#: ../gui/wxpython/gui_modules/menudata.py:218
msgid "Export a raster map to a text file as x,y,z values based on cell centers."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:218
+#: ../gui/wxpython/gui_modules/menudata.py:223
msgid "ESRI ASCII grid export"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:219
+#: ../gui/wxpython/gui_modules/menudata.py:224
msgid "Converts a raster map layer into an ESRI ARCGRID file."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:223
+#: ../gui/wxpython/gui_modules/menudata.py:228
msgid "GRIDATB.FOR export"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:224
+#: ../gui/wxpython/gui_modules/menudata.py:229
msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:228
+#: ../gui/wxpython/gui_modules/menudata.py:233
msgid "MAT-File (v.4) export"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:229
+#: ../gui/wxpython/gui_modules/menudata.py:234
msgid "Exports a GRASS raster to a binary MAT-File."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:234
+#: ../gui/wxpython/gui_modules/menudata.py:239
msgid "Binary export"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:235
+#: ../gui/wxpython/gui_modules/menudata.py:240
msgid "Exports a GRASS raster to a binary array."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:240
+#: ../gui/wxpython/gui_modules/menudata.py:245
msgid "MPEG-1 export"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:241
+#: ../gui/wxpython/gui_modules/menudata.py:246
msgid "Raster File Series to MPEG Conversion Program."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:245
+#: ../gui/wxpython/gui_modules/menudata.py:250
msgid "PNG export"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:246
+#: ../gui/wxpython/gui_modules/menudata.py:251
msgid "Export GRASS raster as non-georeferenced PNG image format."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:250
+#: ../gui/wxpython/gui_modules/menudata.py:255
msgid "PPM export"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:251
+#: ../gui/wxpython/gui_modules/menudata.py:256
msgid ""
"Converts a GRASS raster map to a PPM image file at the pixel resolution of "
"the currently defined region."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:255
+#: ../gui/wxpython/gui_modules/menudata.py:260
msgid "PPM from RGB export"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:256
+#: ../gui/wxpython/gui_modules/menudata.py:261
msgid ""
"Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel "
"resolution of the CURRENTLY DEFINED REGION."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:260
-#: ../gui/wxpython/gui_modules/menudata.py:299
+#: ../gui/wxpython/gui_modules/menudata.py:265
+#: ../gui/wxpython/gui_modules/menudata.py:304
msgid "POV-Ray export"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:261
+#: ../gui/wxpython/gui_modules/menudata.py:266
msgid "Converts a raster map layer into a height-field file for POVRAY."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:265
+#: ../gui/wxpython/gui_modules/menudata.py:270
msgid "TIFF export"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:266
+#: ../gui/wxpython/gui_modules/menudata.py:271
msgid ""
"Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel "
"resolution of the currently defined region."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:270
+#: ../gui/wxpython/gui_modules/menudata.py:275
msgid "VRML export"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:271
+#: ../gui/wxpython/gui_modules/menudata.py:276
msgid "Export a raster map to the Virtual Reality Modeling Language (VRML)"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:275
-#: ../gui/wxpython/gui_modules/menudata.py:309
-#: ../gui/wxpython/gui_modules/menudata.py:327
+#: ../gui/wxpython/gui_modules/menudata.py:280
+#: ../gui/wxpython/gui_modules/menudata.py:314
+#: ../gui/wxpython/gui_modules/menudata.py:332
msgid "VTK export"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:276
+#: ../gui/wxpython/gui_modules/menudata.py:281
msgid "Converts raster maps into the VTK-Ascii format"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:281
+#: ../gui/wxpython/gui_modules/menudata.py:286
msgid "Export vector map"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:283
+#: ../gui/wxpython/gui_modules/menudata.py:288
msgid "Multiple export formats using OGR"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:284
+#: ../gui/wxpython/gui_modules/menudata.py:289
msgid "Converts to one of the supported OGR vector formats."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:289
+#: ../gui/wxpython/gui_modules/menudata.py:294
msgid "ASCII points/GRASS ASCII vector export"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:290
+#: ../gui/wxpython/gui_modules/menudata.py:295
msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:294
+#: ../gui/wxpython/gui_modules/menudata.py:299
msgid "DXF export"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:295
+#: ../gui/wxpython/gui_modules/menudata.py:300
msgid "Exports GRASS vector map layers to DXF file format."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:300
+#: ../gui/wxpython/gui_modules/menudata.py:305
msgid "Converts to POV-Ray format, GRASS x,y,z -> POV-Ray x,z,y"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:304
+#: ../gui/wxpython/gui_modules/menudata.py:309
msgid "SVG export"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:305
+#: ../gui/wxpython/gui_modules/menudata.py:310
msgid "Exports a GRASS vector map to SVG."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:310
+#: ../gui/wxpython/gui_modules/menudata.py:315
msgid "Converts a GRASS binary vector map to VTK ASCII output."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:315
+#: ../gui/wxpython/gui_modules/menudata.py:320
msgid "Export grid 3D volume"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:317
+#: ../gui/wxpython/gui_modules/menudata.py:322
msgid "ASCII 3D export"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:318
+#: ../gui/wxpython/gui_modules/menudata.py:323
msgid "Converts a 3D raster map layer into an ASCII text file"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:322
+#: ../gui/wxpython/gui_modules/menudata.py:327
msgid "Vis5D export"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:323
+#: ../gui/wxpython/gui_modules/menudata.py:328
msgid "Export of GRASS 3D raster map to 3-dimensional Vis5D file."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:328
+#: ../gui/wxpython/gui_modules/menudata.py:333
msgid "Converts 3D raster maps (G3D) into the VTK-Ascii format"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:334
+#: ../gui/wxpython/gui_modules/menudata.py:339
msgid "Manage maps and volumes"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:336
+#: ../gui/wxpython/gui_modules/menudata.py:341
msgid "Copy"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:337
+#: ../gui/wxpython/gui_modules/menudata.py:342
msgid ""
"Copies available data files in the user's current mapset search path and "
"location to the appropriate element directories under the user's current "
"mapset."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:342
+#: ../gui/wxpython/gui_modules/menudata.py:347
msgid "List"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:343
+#: ../gui/wxpython/gui_modules/menudata.py:348
msgid ""
"Lists available GRASS data base files of the user-specified data type to "
"standard output."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:347
+#: ../gui/wxpython/gui_modules/menudata.py:352
msgid "List filtered"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:348
+#: ../gui/wxpython/gui_modules/menudata.py:353
msgid "Apply regular expressions and wildcards to g.list"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:353
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:225
+#: ../gui/wxpython/gui_modules/menudata.py:358
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:224
msgid "Rename"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:354
+#: ../gui/wxpython/gui_modules/menudata.py:359
msgid "Renames data base element files in the user's current mapset."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:359
+#: ../gui/wxpython/gui_modules/menudata.py:364
msgid "Delete"
msgstr "Borrar"
-#: ../gui/wxpython/gui_modules/menudata.py:360
+#: ../gui/wxpython/gui_modules/menudata.py:365
msgid "Removes data base element files from the user's current mapset."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:364
+#: ../gui/wxpython/gui_modules/menudata.py:369
msgid "Delete filtered"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:365
+#: ../gui/wxpython/gui_modules/menudata.py:370
msgid "Apply regular expressions and wildcards to g.remove"
msgstr "Aplicar expresiones regulares y comodines a g.remove"
-#: ../gui/wxpython/gui_modules/menudata.py:370
+#: ../gui/wxpython/gui_modules/menudata.py:375
msgid "Map type conversions"
msgstr "Conversiones de tipos de mapa"
-#: ../gui/wxpython/gui_modules/menudata.py:372
+#: ../gui/wxpython/gui_modules/menudata.py:377
msgid "Raster to vector"
msgstr "Ráster a vectorial"
-#: ../gui/wxpython/gui_modules/menudata.py:373
+#: ../gui/wxpython/gui_modules/menudata.py:378
msgid "Converts a raster map into a vector map layer."
msgstr "Convierte un mapa ráster en una capa de mapa vectorial."
-#: ../gui/wxpython/gui_modules/menudata.py:377
+#: ../gui/wxpython/gui_modules/menudata.py:382
msgid "Raster series to volume"
msgstr "Series ráster a volumen"
-#: ../gui/wxpython/gui_modules/menudata.py:378
+#: ../gui/wxpython/gui_modules/menudata.py:383
msgid "Converts 2D raster map slices to one 3D raster volume map."
msgstr "Convierte rodajas de mapas ráster 2D en un mapa de volumen ráster 3D."
-#: ../gui/wxpython/gui_modules/menudata.py:382
+#: ../gui/wxpython/gui_modules/menudata.py:387
msgid "Raster 2.5D to volume"
msgstr "Ráster 2.5D a volumen"
-#: ../gui/wxpython/gui_modules/menudata.py:383
+#: ../gui/wxpython/gui_modules/menudata.py:388
msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
msgstr "Crea un mapa de volumen 3D basado en mapas ráster de elevación y valor 2D."
-#: ../gui/wxpython/gui_modules/menudata.py:388
+#: ../gui/wxpython/gui_modules/menudata.py:393
msgid "Vector to raster"
msgstr "Vectorial a ráster"
-#: ../gui/wxpython/gui_modules/menudata.py:389
+#: ../gui/wxpython/gui_modules/menudata.py:394
msgid "Converts a binary GRASS vector map layer into a GRASS raster map layer."
-msgstr "Convierte una capa de mapa vectorial binario de GRASS en una capa de mapa ráster de GRASS."
+msgstr ""
+"Convierte una capa de mapa vectorial binario de GRASS en una capa de mapa "
+"ráster de GRASS."
-#: ../gui/wxpython/gui_modules/menudata.py:393
+#: ../gui/wxpython/gui_modules/menudata.py:398
msgid "Vector to volume"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:394
+#: ../gui/wxpython/gui_modules/menudata.py:399
msgid ""
"Converts a binary GRASS vector map (only points) layer into a 3D GRASS "
"raster map layer."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:398
+#: ../gui/wxpython/gui_modules/menudata.py:403
msgid "Sites to vector"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:399
+#: ../gui/wxpython/gui_modules/menudata.py:404
msgid "Converts a GRASS site_lists file into a vector map."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:404
+#: ../gui/wxpython/gui_modules/menudata.py:409
msgid "Volume to raster series"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:405
+#: ../gui/wxpython/gui_modules/menudata.py:410
msgid "Converts 3D raster maps to 2D raster maps"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:412
+#: ../gui/wxpython/gui_modules/menudata.py:417
msgid "Georectify"
msgstr "Georrectificar"
-#: ../gui/wxpython/gui_modules/menudata.py:413
+#: ../gui/wxpython/gui_modules/menudata.py:418
msgid "Georectify raster and vector maps"
msgstr "Georrectifica mapas ráster y vectoriales"
-#: ../gui/wxpython/gui_modules/menudata.py:418
+#: ../gui/wxpython/gui_modules/menudata.py:423
msgid "NVIZ (requires Tcl/Tk)"
msgstr "NVIZ (requiere Tcl/Tk)"
-#: ../gui/wxpython/gui_modules/menudata.py:419
+#: ../gui/wxpython/gui_modules/menudata.py:424
msgid "nviz - Visualization and animation tool for GRASS data"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:424
+#: ../gui/wxpython/gui_modules/menudata.py:429
msgid "Bearing/distance to coordinates"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:425
+#: ../gui/wxpython/gui_modules/menudata.py:430
msgid "It assumes a cartesian coordinate system"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:430
+#: ../gui/wxpython/gui_modules/menudata.py:435
msgid "Postscript plot"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:431
+#: ../gui/wxpython/gui_modules/menudata.py:436
msgid "Hardcopy PostScript map output utility."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:436
+#: ../gui/wxpython/gui_modules/menudata.py:441
msgid "E&xit"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:437
+#: ../gui/wxpython/gui_modules/menudata.py:442
msgid "Exit GUI"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:442
+#: ../gui/wxpython/gui_modules/menudata.py:447
msgid "Config"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:443
+#: ../gui/wxpython/gui_modules/menudata.py:448
msgid "Region"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:445
+#: ../gui/wxpython/gui_modules/menudata.py:450
msgid "Display region"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:446
#: ../gui/wxpython/gui_modules/menudata.py:451
+#: ../gui/wxpython/gui_modules/menudata.py:456
msgid "Manages the boundary definitions for the geographic region."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:450
+#: ../gui/wxpython/gui_modules/menudata.py:455
msgid "Set region"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:456
+#: ../gui/wxpython/gui_modules/menudata.py:461
msgid "GRASS working environment"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:458
+#: ../gui/wxpython/gui_modules/menudata.py:463
msgid "Mapset access"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:459
+#: ../gui/wxpython/gui_modules/menudata.py:464
msgid "Set/unset access to other mapsets in current location"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:463
+#: ../gui/wxpython/gui_modules/menudata.py:468
msgid "Change working environment"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:464
+#: ../gui/wxpython/gui_modules/menudata.py:469
msgid "Change current mapset."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:468
+#: ../gui/wxpython/gui_modules/menudata.py:473
msgid "User access"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:469
+#: ../gui/wxpython/gui_modules/menudata.py:474
msgid "Controls access to the current mapset for other users on the system."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:473
+#: ../gui/wxpython/gui_modules/menudata.py:478
msgid "Show settings"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:474
#: ../gui/wxpython/gui_modules/menudata.py:479
+#: ../gui/wxpython/gui_modules/menudata.py:484
msgid "Outputs and modifies the user's current GRASS variable settings."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:478
+#: ../gui/wxpython/gui_modules/menudata.py:483
msgid "Change settings"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:483
+#: ../gui/wxpython/gui_modules/menudata.py:488
msgid "Version"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:484
+#: ../gui/wxpython/gui_modules/menudata.py:489
msgid "Displays version and copyright information."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:489
-#: ../gui/wxpython/gui_modules/menudata.py:491
+#: ../gui/wxpython/gui_modules/menudata.py:494
+#: ../gui/wxpython/gui_modules/menudata.py:496
msgid "Manage projections"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:492
+#: ../gui/wxpython/gui_modules/menudata.py:497
msgid ""
"Converts co-ordinate system descriptions (i.e. projection information) "
"between various formats (including GRASS format). Can also be used to create "
"GRASS locations."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:496
+#: ../gui/wxpython/gui_modules/menudata.py:501
msgid "Projection for current location"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:497
+#: ../gui/wxpython/gui_modules/menudata.py:502
msgid "Create/edit projection information for current location"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:502
+#: ../gui/wxpython/gui_modules/menudata.py:507
msgid "Convert coordinates"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:503
+#: ../gui/wxpython/gui_modules/menudata.py:508
msgid "Convert coordinates from one projection to another (cs2cs frontend)."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:509
+#: ../gui/wxpython/gui_modules/menudata.py:514
msgid "Preferences"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:510
+#: ../gui/wxpython/gui_modules/menudata.py:515
msgid "User GUI preferences (display font, commands, digitizer, etc.)"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:515
+#: ../gui/wxpython/gui_modules/menudata.py:520
msgid "Raster"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:516
+#: ../gui/wxpython/gui_modules/menudata.py:521
msgid "Develop raster map"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:518
+#: ../gui/wxpython/gui_modules/menudata.py:523
msgid "Digitize raster (requires XTerm)"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:519
+#: ../gui/wxpython/gui_modules/menudata.py:524
msgid "Digitize raster map"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:524
+#: ../gui/wxpython/gui_modules/menudata.py:529
msgid "Compress/decompress"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:525
+#: ../gui/wxpython/gui_modules/menudata.py:530
msgid "Compresses and decompresses raster maps."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:530
+#: ../gui/wxpython/gui_modules/menudata.py:535
msgid "Region boundaries"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:531
+#: ../gui/wxpython/gui_modules/menudata.py:536
msgid "Sets the boundary definitions for a raster map."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:535
+#: ../gui/wxpython/gui_modules/menudata.py:540
msgid "Manage NULL values"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:536
+#: ../gui/wxpython/gui_modules/menudata.py:541
msgid "Creates explicitly the NULL-value bitmap file."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:540
+#: ../gui/wxpython/gui_modules/menudata.py:545
msgid "Quantization"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:541
+#: ../gui/wxpython/gui_modules/menudata.py:546
msgid "Produces the quantization file for a floating-point map."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:545
+#: ../gui/wxpython/gui_modules/menudata.py:550
msgid "Timestamp"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:546
+#: ../gui/wxpython/gui_modules/menudata.py:551
msgid "Print/add/remove a timestamp for a raster map."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:551
+#: ../gui/wxpython/gui_modules/menudata.py:556
msgid "Resample using aggregate statistics"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:552
+#: ../gui/wxpython/gui_modules/menudata.py:557
msgid "Resamples raster map layers using aggregation."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:556
+#: ../gui/wxpython/gui_modules/menudata.py:561
msgid "Resample using multiple methods"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:557
+#: ../gui/wxpython/gui_modules/menudata.py:562
msgid "Resamples raster map layers using interpolation."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:561
+#: ../gui/wxpython/gui_modules/menudata.py:566
msgid "Resample using nearest neighbor"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:562
+#: ../gui/wxpython/gui_modules/menudata.py:567
msgid "GRASS raster map layer data resampling capability."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:566
+#: ../gui/wxpython/gui_modules/menudata.py:571
msgid "Resample using spline tension"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:567
+#: ../gui/wxpython/gui_modules/menudata.py:572
msgid ""
"Reinterpolates and optionally computes topographic analysis from input "
"raster map to a new raster map (possibly with different resolution) using "
"regularized spline with tension and smoothing."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:572
+#: ../gui/wxpython/gui_modules/menudata.py:577
msgid "Support file maintenance"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:573
+#: ../gui/wxpython/gui_modules/menudata.py:578
msgid "Allows creation and/or modification of raster map layer support files."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:577
+#: ../gui/wxpython/gui_modules/menudata.py:582
msgid "Update map statistics"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:578
+#: ../gui/wxpython/gui_modules/menudata.py:583
msgid "Update raster map statistics"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:583
+#: ../gui/wxpython/gui_modules/menudata.py:588
msgid "Reproject raster"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:584
+#: ../gui/wxpython/gui_modules/menudata.py:589
msgid "Re-projects a raster map from one location to the current location."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:588
+#: ../gui/wxpython/gui_modules/menudata.py:593
msgid "Tiling"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:589
+#: ../gui/wxpython/gui_modules/menudata.py:594
msgid ""
"Produces tilings of the source projection for use in the destination region "
"and projection."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:594
+#: ../gui/wxpython/gui_modules/menudata.py:599
msgid "Manage colors"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:596
+#: ../gui/wxpython/gui_modules/menudata.py:601
msgid "Color tables"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:597
+#: ../gui/wxpython/gui_modules/menudata.py:602
msgid "Creates/modifies the color table associated with a raster map layer."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:601
+#: ../gui/wxpython/gui_modules/menudata.py:606
msgid "Color rules"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:602
+#: ../gui/wxpython/gui_modules/menudata.py:607
msgid "Set colors interactively by entering color rules"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:607
+#: ../gui/wxpython/gui_modules/menudata.py:612
msgid "Blend 2 color rasters"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:608
+#: ../gui/wxpython/gui_modules/menudata.py:613
msgid "Blends color components of two raster maps by a given ratio."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:612
+#: ../gui/wxpython/gui_modules/menudata.py:617
msgid "Create RGB"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:613
+#: ../gui/wxpython/gui_modules/menudata.py:618
msgid "Combines red, green and blue map layers into a single composite map layer."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:617
-#: ../gui/wxpython/gui_modules/menudata.py:1571
+#: ../gui/wxpython/gui_modules/menudata.py:622
+#: ../gui/wxpython/gui_modules/menudata.py:1576
msgid "RGB to HIS"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:618
+#: ../gui/wxpython/gui_modules/menudata.py:623
msgid ""
"Generates red, green and blue raster map layers combining hue, intensity and "
"saturation (HIS) values from user-specified input raster map layers."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:624
+#: ../gui/wxpython/gui_modules/menudata.py:629
msgid "Query by coordinates"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:625
+#: ../gui/wxpython/gui_modules/menudata.py:630
msgid "Queries raster map layers on their category values and category labels."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:630
+#: ../gui/wxpython/gui_modules/menudata.py:635
msgid "Buffer rasters"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:631
+#: ../gui/wxpython/gui_modules/menudata.py:636
msgid ""
"Creates a raster map layer showing buffer zones surrounding cells that "
"contain non-NULL category values."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:635
+#: ../gui/wxpython/gui_modules/menudata.py:640
msgid "Closest points"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:636
+#: ../gui/wxpython/gui_modules/menudata.py:641
msgid "Locates the closest points between objects in two raster maps."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:640
+#: ../gui/wxpython/gui_modules/menudata.py:645
msgid "Mask"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:641
+#: ../gui/wxpython/gui_modules/menudata.py:646
msgid "Create a MASK for limiting raster operation"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:645
+#: ../gui/wxpython/gui_modules/menudata.py:650
msgid "Map calculator"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:646
+#: ../gui/wxpython/gui_modules/menudata.py:651
msgid "Map calculator for raster map algebra"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:649
+#: ../gui/wxpython/gui_modules/menudata.py:654
msgid "Neighborhood analysis"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:651
+#: ../gui/wxpython/gui_modules/menudata.py:656
msgid "Moving window"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:652
+#: ../gui/wxpython/gui_modules/menudata.py:657
msgid ""
"Makes each cell category value a function of the category values assigned to "
"the cells around it, and stores new cell values in an output raster map "
"layer."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:656
+#: ../gui/wxpython/gui_modules/menudata.py:661
msgid "Neighborhood points"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:657
+#: ../gui/wxpython/gui_modules/menudata.py:662
msgid ""
"Makes each cell value a function of the attribute values assigned to the "
"vector points or centroids around it, and stores new cell values in an "
"output raster map layer."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:662
+#: ../gui/wxpython/gui_modules/menudata.py:667
msgid "Overlay rasters"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:664
+#: ../gui/wxpython/gui_modules/menudata.py:669
msgid "Cross product"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:665
+#: ../gui/wxpython/gui_modules/menudata.py:670
msgid ""
"Creates a cross product of the category values from multiple raster map "
"layers."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:669
+#: ../gui/wxpython/gui_modules/menudata.py:674
msgid "Raster series"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:670
+#: ../gui/wxpython/gui_modules/menudata.py:675
msgid ""
"Makes each output cell value a function of the values assigned to the "
"corresponding cells in the input raster map layers."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:674
+#: ../gui/wxpython/gui_modules/menudata.py:679
msgid "Patch raster maps"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:675
+#: ../gui/wxpython/gui_modules/menudata.py:680
msgid ""
"Creates a composite raster map layer by using known category values from one "
"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:680
+#: ../gui/wxpython/gui_modules/menudata.py:685
msgid "Statistical overlay"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:681
+#: ../gui/wxpython/gui_modules/menudata.py:686
msgid "Calculates category or object oriented statistics."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:686
+#: ../gui/wxpython/gui_modules/menudata.py:691
msgid "Solar radiance and shadows"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:688
+#: ../gui/wxpython/gui_modules/menudata.py:693
msgid "Solar irradiance and irradiation"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:689
+#: ../gui/wxpython/gui_modules/menudata.py:694
msgid ""
"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
"for given day, latitude, surface and atmospheric conditions. Solar "
@@ -1778,26 +1912,26 @@
"is optionally incorporated."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:693
+#: ../gui/wxpython/gui_modules/menudata.py:698
msgid "Shadows map"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:694
+#: ../gui/wxpython/gui_modules/menudata.py:699
msgid ""
"Calculates cast shadow areas from sun position and DEM. Either A: exact sun "
"position is specified, or B: date/time to calculate the sun position by r."
"sunmask itself."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:699
+#: ../gui/wxpython/gui_modules/menudata.py:704
msgid "Terrain analysis"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:701
+#: ../gui/wxpython/gui_modules/menudata.py:706
msgid "Cumulative movement costs"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:702
+#: ../gui/wxpython/gui_modules/menudata.py:707
msgid ""
"Outputs a raster map layer showing the anisotropic cumulative cost of moving "
"between different geographic locations on an input elevation raster map "
@@ -1805,373 +1939,373 @@
"raster map layer whose cell values represent friction cost."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:706
+#: ../gui/wxpython/gui_modules/menudata.py:711
msgid "Cost surface"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:707
+#: ../gui/wxpython/gui_modules/menudata.py:712
msgid ""
"Outputs a raster map layer showing the cumulative cost of moving between "
"different geographic locations on an input raster map layer whose cell "
"category values represent cost."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:711
+#: ../gui/wxpython/gui_modules/menudata.py:716
msgid "Least cost route or flow"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:712
+#: ../gui/wxpython/gui_modules/menudata.py:717
msgid "Traces a flow through an elevation model on a raster map layer."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:717
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:495
+#: ../gui/wxpython/gui_modules/menudata.py:722
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:496
msgid "Shaded relief"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:718
+#: ../gui/wxpython/gui_modules/menudata.py:723
msgid "Creates shaded relief map from an elevation map (DEM)."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:723
+#: ../gui/wxpython/gui_modules/menudata.py:728
msgid "Slope and aspect"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:724
+#: ../gui/wxpython/gui_modules/menudata.py:729
msgid ""
"Generates raster map layers of slope, aspect, curvatures and partial "
"derivatives from a raster map layer of true elevation values. Aspect is "
"calculated counterclockwise from east."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:728
+#: ../gui/wxpython/gui_modules/menudata.py:733
msgid "Terrain parameters"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:729
+#: ../gui/wxpython/gui_modules/menudata.py:734
msgid ""
"Uses a multi-scale approach by taking fitting quadratic parameters to any "
"size window (via least squares)."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:733
+#: ../gui/wxpython/gui_modules/menudata.py:738
msgid "Textural features"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:734
+#: ../gui/wxpython/gui_modules/menudata.py:739
msgid "Generate images with textural features from a raster map."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:739
+#: ../gui/wxpython/gui_modules/menudata.py:744
msgid "Visibility"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:740
+#: ../gui/wxpython/gui_modules/menudata.py:745
msgid "Line-of-sight raster analysis program."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:745
+#: ../gui/wxpython/gui_modules/menudata.py:750
msgid "Transform features"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:747
+#: ../gui/wxpython/gui_modules/menudata.py:752
msgid "Clump"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:748
+#: ../gui/wxpython/gui_modules/menudata.py:753
msgid ""
"Recategorizes data in a raster map layer by grouping cells that form "
"physically discrete areas into unique categories."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:752
+#: ../gui/wxpython/gui_modules/menudata.py:757
msgid "Grow"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:753
+#: ../gui/wxpython/gui_modules/menudata.py:758
msgid "Generates a raster map layer with contiguous areas grown by one cell."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:757
+#: ../gui/wxpython/gui_modules/menudata.py:762
msgid "Thin"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:758
+#: ../gui/wxpython/gui_modules/menudata.py:763
msgid "Thins non-zero cells that denote linear features in a raster map layer."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:764
+#: ../gui/wxpython/gui_modules/menudata.py:769
msgid "Hydrologic modeling"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:766
+#: ../gui/wxpython/gui_modules/menudata.py:771
msgid "Carve stream channels"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:767
+#: ../gui/wxpython/gui_modules/menudata.py:772
msgid ""
"Takes vector stream data, transforms it to raster and subtracts depth from "
"the output DEM."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:771
+#: ../gui/wxpython/gui_modules/menudata.py:776
msgid "Fill lake"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:772
+#: ../gui/wxpython/gui_modules/menudata.py:777
msgid "Fills lake from seed at given level"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:777
+#: ../gui/wxpython/gui_modules/menudata.py:782
msgid "Depressionless map and flowlines"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:778
+#: ../gui/wxpython/gui_modules/menudata.py:783
msgid ""
"Filters and generates a depressionless elevation map and a flow direction "
"map from a given elevation layer."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:782
+#: ../gui/wxpython/gui_modules/menudata.py:787
msgid "Flow accumulation"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:783
+#: ../gui/wxpython/gui_modules/menudata.py:788
msgid "Flow computation for massive grids (Float version)."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:787
+#: ../gui/wxpython/gui_modules/menudata.py:792
msgid "Flow lines"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:788
+#: ../gui/wxpython/gui_modules/menudata.py:793
msgid ""
"Construction of slope curves (flowlines), flowpath lengths, and flowline "
"densities (upslope areas) from a raster digital elevation model (DEM)"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:793
+#: ../gui/wxpython/gui_modules/menudata.py:798
msgid "SIMWE Overland flow modeling"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:794
+#: ../gui/wxpython/gui_modules/menudata.py:799
msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:798
+#: ../gui/wxpython/gui_modules/menudata.py:803
msgid "SIMWE Sediment flux modeling"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:799
+#: ../gui/wxpython/gui_modules/menudata.py:804
msgid ""
"Sediment transport and erosion/deposition simulation using path sampling "
"method (SIMWE)"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:804
+#: ../gui/wxpython/gui_modules/menudata.py:809
msgid "Topographic index map"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:805
+#: ../gui/wxpython/gui_modules/menudata.py:810
msgid "Creates topographic index [ln(a/tan(beta))] map from elevation map."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:809
+#: ../gui/wxpython/gui_modules/menudata.py:814
msgid "TOPMODEL simulation"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:810
+#: ../gui/wxpython/gui_modules/menudata.py:815
msgid "Simulates TOPMODEL which is a physically based hydrologic model."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:815
+#: ../gui/wxpython/gui_modules/menudata.py:820
msgid "Watershed subbasins"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:816
+#: ../gui/wxpython/gui_modules/menudata.py:821
msgid "Generates a raster map layer showing watershed subbasins."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:820
+#: ../gui/wxpython/gui_modules/menudata.py:825
msgid "Watershed analysis"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:821
+#: ../gui/wxpython/gui_modules/menudata.py:826
msgid "Watershed basin analysis program."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:825
+#: ../gui/wxpython/gui_modules/menudata.py:830
msgid "Watershed basin creation"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:826
+#: ../gui/wxpython/gui_modules/menudata.py:831
msgid "Watershed basin creation program."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:831
+#: ../gui/wxpython/gui_modules/menudata.py:836
msgid "Landscape structure modeling"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:833
+#: ../gui/wxpython/gui_modules/menudata.py:838
msgid "Set up (requires XTerm)"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:834
-#: ../gui/wxpython/gui_modules/menudata.py:857
+#: ../gui/wxpython/gui_modules/menudata.py:839
+#: ../gui/wxpython/gui_modules/menudata.py:862
msgid "Set up sampling and analysis framework"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:839
+#: ../gui/wxpython/gui_modules/menudata.py:844
msgid "Analyze landscape"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:840
+#: ../gui/wxpython/gui_modules/menudata.py:845
msgid ""
"Contains a set of measures for attributes, diversity, texture, "
"juxtaposition, and edge."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:844
+#: ../gui/wxpython/gui_modules/menudata.py:849
msgid "Analyze patches"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:845
+#: ../gui/wxpython/gui_modules/menudata.py:850
msgid ""
"Calculates attribute, patch size, core (interior) size, shape, fractal "
"dimension, and perimeter measures for sets of patches in a landscape."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:849
+#: ../gui/wxpython/gui_modules/menudata.py:854
msgid "Output"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:850
+#: ../gui/wxpython/gui_modules/menudata.py:855
msgid ""
"Displays the boundary of each r.le patch and shows how the boundary is "
"traced, displays the attribute, size, perimeter and shape indices for each "
"patch and saves the data in an output file."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:855
+#: ../gui/wxpython/gui_modules/menudata.py:860
msgid "Landscape patch analysis"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:858
+#: ../gui/wxpython/gui_modules/menudata.py:863
msgid "Configuration editor for r.li.'index'"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:863
+#: ../gui/wxpython/gui_modules/menudata.py:868
msgid "Edge density"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:864
+#: ../gui/wxpython/gui_modules/menudata.py:869
msgid "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:868
+#: ../gui/wxpython/gui_modules/menudata.py:873
msgid "Contrast weighted edge density"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:869
+#: ../gui/wxpython/gui_modules/menudata.py:874
msgid "Calculates contrast weighted edge density index on a raster map"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:874
+#: ../gui/wxpython/gui_modules/menudata.py:879
msgid "Patch area mean"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:875
+#: ../gui/wxpython/gui_modules/menudata.py:880
msgid ""
"Calculates mean patch size index on a raster map, using a 4 neighbour "
"algorithm"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:879
+#: ../gui/wxpython/gui_modules/menudata.py:884
msgid "Patch area range"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:880
+#: ../gui/wxpython/gui_modules/menudata.py:885
msgid "Calculates range of patch area size on a raster map"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:884
+#: ../gui/wxpython/gui_modules/menudata.py:889
msgid "Patch area Std Dev"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:885
+#: ../gui/wxpython/gui_modules/menudata.py:890
msgid "Calculates standard deviation of patch area a raster map"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:889
+#: ../gui/wxpython/gui_modules/menudata.py:894
msgid "Patch area Coeff Var"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:890
+#: ../gui/wxpython/gui_modules/menudata.py:895
msgid "Calculates coefficient of variation of patch area on a raster map"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:894
+#: ../gui/wxpython/gui_modules/menudata.py:899
msgid "Patch density"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:895
+#: ../gui/wxpython/gui_modules/menudata.py:900
msgid "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:899
+#: ../gui/wxpython/gui_modules/menudata.py:904
msgid "Patch number"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:900
+#: ../gui/wxpython/gui_modules/menudata.py:905
msgid "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:905
+#: ../gui/wxpython/gui_modules/menudata.py:910
msgid "Dominance's diversity"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:906
-#: ../gui/wxpython/gui_modules/menudata.py:922
+#: ../gui/wxpython/gui_modules/menudata.py:911
+#: ../gui/wxpython/gui_modules/menudata.py:927
msgid "Calculates dominance's diversity index on a raster map"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:910
+#: ../gui/wxpython/gui_modules/menudata.py:915
msgid "Shannon's diversity"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:911
+#: ../gui/wxpython/gui_modules/menudata.py:916
msgid "Calculates Shannon's diversity index on a raster map"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:915
+#: ../gui/wxpython/gui_modules/menudata.py:920
msgid "Simpson's diversity"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:916
+#: ../gui/wxpython/gui_modules/menudata.py:921
msgid "Calculates Simpson's diversity index on a raster map"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:921
+#: ../gui/wxpython/gui_modules/menudata.py:926
msgid "Richness"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:926
+#: ../gui/wxpython/gui_modules/menudata.py:931
msgid "Shape index"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:927
+#: ../gui/wxpython/gui_modules/menudata.py:932
msgid "Calculates shape index on a raster map"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:932
+#: ../gui/wxpython/gui_modules/menudata.py:937
msgid "Wildfire modeling"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:934
+#: ../gui/wxpython/gui_modules/menudata.py:939
msgid "Rate of spread"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:935
+#: ../gui/wxpython/gui_modules/menudata.py:940
msgid ""
"Generates three, or four raster map layers showing 1) the base "
"(perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the "
@@ -2179,1647 +2313,1651 @@
"spotting distance."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:939
+#: ../gui/wxpython/gui_modules/menudata.py:944
msgid "Least-cost spread paths"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:940
+#: ../gui/wxpython/gui_modules/menudata.py:945
msgid ""
"Recursively traces the least cost path backwards to cells from which the "
"cumulative cost was determined."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:944
+#: ../gui/wxpython/gui_modules/menudata.py:949
msgid "Anisotropic spread simulation"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:945
+#: ../gui/wxpython/gui_modules/menudata.py:950
msgid ""
"It optionally produces raster maps to contain backlink UTM coordinates for "
"tracing spread paths."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:951
+#: ../gui/wxpython/gui_modules/menudata.py:956
msgid "Change category values and labels"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:953
+#: ../gui/wxpython/gui_modules/menudata.py:958
msgid "Interactively edit category values"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:954
+#: ../gui/wxpython/gui_modules/menudata.py:959
msgid "Interactively edit cell values in a raster map."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:959
+#: ../gui/wxpython/gui_modules/menudata.py:964
msgid "Reclassify by size"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:960
+#: ../gui/wxpython/gui_modules/menudata.py:965
msgid ""
"Reclasses a raster map greater or less than user specified area size (in "
"hectares)"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:964
+#: ../gui/wxpython/gui_modules/menudata.py:969
msgid "Reclassify interactively"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:965
+#: ../gui/wxpython/gui_modules/menudata.py:970
msgid "Reclassify raster categories interactively by entering reclass rules"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:969
+#: ../gui/wxpython/gui_modules/menudata.py:974
msgid "Reclassify using rules file"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:970
+#: ../gui/wxpython/gui_modules/menudata.py:975
msgid ""
"Creates a new map layer whose category values are based upon a "
"reclassification of the categories in an existing raster map layer."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:975
+#: ../gui/wxpython/gui_modules/menudata.py:980
msgid "Recode interactively"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:976
+#: ../gui/wxpython/gui_modules/menudata.py:981
msgid ""
"Recode raster categories interactively by entering recode rules (create new "
"raster map)"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:980
+#: ../gui/wxpython/gui_modules/menudata.py:985
msgid "Recode using rules file"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:981
+#: ../gui/wxpython/gui_modules/menudata.py:986
msgid "r.recode.rules - Use ascii rules file to recode categories in raster map"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:986
+#: ../gui/wxpython/gui_modules/menudata.py:991
msgid "Rescale"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:987
+#: ../gui/wxpython/gui_modules/menudata.py:992
msgid "Rescales the range of category values in a raster map layer."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:991
+#: ../gui/wxpython/gui_modules/menudata.py:996
msgid "Rescale with histogram"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:992
+#: ../gui/wxpython/gui_modules/menudata.py:997
msgid ""
"Rescales histogram equalized the range of category values in a raster map "
"layer."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:999
+#: ../gui/wxpython/gui_modules/menudata.py:1004
msgid "Concentric circles"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1000
+#: ../gui/wxpython/gui_modules/menudata.py:1005
msgid "Creates a raster map containing concentric rings around a given point."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1003
+#: ../gui/wxpython/gui_modules/menudata.py:1008
msgid "Generate random cells"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1005
+#: ../gui/wxpython/gui_modules/menudata.py:1010
msgid "Random cells"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1006
+#: ../gui/wxpython/gui_modules/menudata.py:1011
msgid "Generates random cell values with spatial dependence."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1010
+#: ../gui/wxpython/gui_modules/menudata.py:1015
msgid "Random cells and vector points"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1011
+#: ../gui/wxpython/gui_modules/menudata.py:1016
msgid ""
"Creates a raster map layer and vector point map containing randomly located "
"sites."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1016
+#: ../gui/wxpython/gui_modules/menudata.py:1021
msgid "Generate surfaces"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1018
+#: ../gui/wxpython/gui_modules/menudata.py:1023
msgid "Fractal surface"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1019
+#: ../gui/wxpython/gui_modules/menudata.py:1024
msgid "Creates a fractal surface of a given fractal dimension."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1024
+#: ../gui/wxpython/gui_modules/menudata.py:1029
msgid "Gaussian kernel density surface"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1025
+#: ../gui/wxpython/gui_modules/menudata.py:1030
msgid ""
"Generates a raster density map from vector points data using a moving 2D "
"isotropic Gaussian kernel or optionally generates a vector density map on "
"vector network with a 1D kernel."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1029
+#: ../gui/wxpython/gui_modules/menudata.py:1034
msgid "Gaussian deviates surface"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1030
+#: ../gui/wxpython/gui_modules/menudata.py:1035
msgid ""
"GRASS module to produce a raster map layer of gaussian deviates whose mean "
"and standard deviation can be expressed by the user. It uses a gaussian "
"random number generator."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1035
+#: ../gui/wxpython/gui_modules/menudata.py:1040
msgid "Plane"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1036
+#: ../gui/wxpython/gui_modules/menudata.py:1041
msgid ""
"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
"point."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1041
+#: ../gui/wxpython/gui_modules/menudata.py:1046
msgid "Random deviates surface"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1042
+#: ../gui/wxpython/gui_modules/menudata.py:1047
msgid ""
"Produces a raster map layer of uniform random deviates whose range can be "
"expressed by the user."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1046
+#: ../gui/wxpython/gui_modules/menudata.py:1051
msgid "Random surface with spatial dependence"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1047
+#: ../gui/wxpython/gui_modules/menudata.py:1052
msgid "Generates random surface(s) with spatial dependence."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1053
+#: ../gui/wxpython/gui_modules/menudata.py:1058
msgid "Generate contour lines"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1054
+#: ../gui/wxpython/gui_modules/menudata.py:1059
msgid "Produces a vector map layer of specified contours from a raster map layer."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1057
+#: ../gui/wxpython/gui_modules/menudata.py:1062
msgid "Interpolate surfaces"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1059
+#: ../gui/wxpython/gui_modules/menudata.py:1064
msgid "Bilinear from raster points"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1060
+#: ../gui/wxpython/gui_modules/menudata.py:1065
msgid "Bilinear interpolation utility for raster map layers."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1064
+#: ../gui/wxpython/gui_modules/menudata.py:1069
msgid "Bilinear and bicubic from vector points"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1065
+#: ../gui/wxpython/gui_modules/menudata.py:1070
msgid "Bicubic or bilinear spline interpolation with Tykhonov regularization."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1070
+#: ../gui/wxpython/gui_modules/menudata.py:1075
msgid "IDW from raster points"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1071
+#: ../gui/wxpython/gui_modules/menudata.py:1076
msgid "Surface interpolation utility for raster map layers."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1075
+#: ../gui/wxpython/gui_modules/menudata.py:1080
msgid "IDW from vector points"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1076
+#: ../gui/wxpython/gui_modules/menudata.py:1081
msgid ""
"Surface interpolation from vector point data by Inverse Distance Squared "
"Weighting."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1081
+#: ../gui/wxpython/gui_modules/menudata.py:1086
msgid "Raster contours"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1082
+#: ../gui/wxpython/gui_modules/menudata.py:1087
msgid "Surface generation program from rasterized contours."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1086
+#: ../gui/wxpython/gui_modules/menudata.py:1091
msgid "Regularized spline tension"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1087
+#: ../gui/wxpython/gui_modules/menudata.py:1092
msgid ""
"Spatial approximation and topographic analysis from given point or isoline "
"data in vector format to floating point raster format using regularized "
"spline with tension."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1092
+#: ../gui/wxpython/gui_modules/menudata.py:1097
msgid "Fill NULL cells"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1093
+#: ../gui/wxpython/gui_modules/menudata.py:1098
msgid "Fills no-data areas in raster maps using v.surf.rst splines interpolation"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1099
-#: ../gui/wxpython/gui_modules/menudata.py:1680
+#: ../gui/wxpython/gui_modules/menudata.py:1104
+#: ../gui/wxpython/gui_modules/menudata.py:1685
msgid "Report and statistics"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1101
+#: ../gui/wxpython/gui_modules/menudata.py:1106
msgid "Basic raster metadata"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1102
+#: ../gui/wxpython/gui_modules/menudata.py:1107
msgid "Output basic information about a raster map layer."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1106
+#: ../gui/wxpython/gui_modules/menudata.py:1111
msgid "Manage category information"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1107
+#: ../gui/wxpython/gui_modules/menudata.py:1112
msgid ""
"Manages category values and labels associated with user-specified raster map "
"layers."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1112
+#: ../gui/wxpython/gui_modules/menudata.py:1117
msgid "General statistics"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1113
+#: ../gui/wxpython/gui_modules/menudata.py:1118
msgid "Generates area statistics for raster map layers."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1117
+#: ../gui/wxpython/gui_modules/menudata.py:1122
msgid "Range of category values"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1118
+#: ../gui/wxpython/gui_modules/menudata.py:1123
msgid "Prints terse list of category values found in a raster map layer."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1122
+#: ../gui/wxpython/gui_modules/menudata.py:1127
msgid "Sum category values"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1123
+#: ../gui/wxpython/gui_modules/menudata.py:1128
msgid "Sums up the raster cell values."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1127
+#: ../gui/wxpython/gui_modules/menudata.py:1132
msgid "Sum area by raster map and category"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1128
+#: ../gui/wxpython/gui_modules/menudata.py:1133
msgid "Reports statistics for raster map layers."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1132
+#: ../gui/wxpython/gui_modules/menudata.py:1137
msgid "Statistics for clumped cells"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1133
+#: ../gui/wxpython/gui_modules/menudata.py:1138
msgid ""
"Calculates the volume of data \"clumps\", and (optionally) produces a GRASS "
"vector points map containing the calculated centroids of these clumps."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1137
+#: ../gui/wxpython/gui_modules/menudata.py:1142
msgid "Total corrected area"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1138
+#: ../gui/wxpython/gui_modules/menudata.py:1143
msgid "Surface area estimation for rasters."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1142
+#: ../gui/wxpython/gui_modules/menudata.py:1147
msgid "Univariate raster statistics"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1143
+#: ../gui/wxpython/gui_modules/menudata.py:1148
msgid "Calculates univariate statistics from the non-null cells of a raster map."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1148
+#: ../gui/wxpython/gui_modules/menudata.py:1153
msgid "Sample transects"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1149
+#: ../gui/wxpython/gui_modules/menudata.py:1154
msgid "Outputs the raster map layer values lying on user-defined line(s)."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1153
+#: ../gui/wxpython/gui_modules/menudata.py:1158
msgid "Sample transects (bearing/distance)"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1154
+#: ../gui/wxpython/gui_modules/menudata.py:1159
msgid "Outputs raster map layer values lying along user defined transect line(s)."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1159
+#: ../gui/wxpython/gui_modules/menudata.py:1164
msgid "Covariance/correlation"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1160
+#: ../gui/wxpython/gui_modules/menudata.py:1165
msgid ""
"Outputs a covariance/correlation matrix for user-specified raster map layer"
"(s)."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1164
+#: ../gui/wxpython/gui_modules/menudata.py:1169
msgid "Linear regression"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1165
+#: ../gui/wxpython/gui_modules/menudata.py:1170
msgid "Calculates linear regression from two raster maps: y = a + b*x"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1169
+#: ../gui/wxpython/gui_modules/menudata.py:1174
msgid "Mutual category occurrences"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1170
+#: ../gui/wxpython/gui_modules/menudata.py:1175
msgid ""
"Tabulates the mutual occurrence (coincidence) of categories for two raster "
"map layers."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1177
+#: ../gui/wxpython/gui_modules/menudata.py:1182
msgid "Vector"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1178
+#: ../gui/wxpython/gui_modules/menudata.py:1183
msgid "Develop vector map"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1181
+#: ../gui/wxpython/gui_modules/menudata.py:1186
msgid "Create new empty vector map"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1186
+#: ../gui/wxpython/gui_modules/menudata.py:1191
msgid "Create/rebuild topology"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1187
+#: ../gui/wxpython/gui_modules/menudata.py:1192
msgid "Creates topology for GRASS vector map."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1191
+#: ../gui/wxpython/gui_modules/menudata.py:1196
msgid "Clean vector map"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1192
+#: ../gui/wxpython/gui_modules/menudata.py:1197
msgid "Toolset for cleaning topology of vector map."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1196
+#: ../gui/wxpython/gui_modules/menudata.py:1201
msgid "Generalization"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1197
+#: ../gui/wxpython/gui_modules/menudata.py:1202
msgid "Vector based generalization."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1202
+#: ../gui/wxpython/gui_modules/menudata.py:1207
msgid "Convert object types"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1203
+#: ../gui/wxpython/gui_modules/menudata.py:1208
msgid "Change the type of geometry elements."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1208
+#: ../gui/wxpython/gui_modules/menudata.py:1213
msgid "Add centroids"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1209
+#: ../gui/wxpython/gui_modules/menudata.py:1214
msgid "Adds missing centroids to closed boundaries."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1214
+#: ../gui/wxpython/gui_modules/menudata.py:1219
msgid "Build polylines"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1215
+#: ../gui/wxpython/gui_modules/menudata.py:1220
msgid "Builds polylines from lines or boundaries."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1219
+#: ../gui/wxpython/gui_modules/menudata.py:1224
msgid "Split polylines"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1220
+#: ../gui/wxpython/gui_modules/menudata.py:1225
msgid "Creates points/segments from input vector lines and positions."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1224
+#: ../gui/wxpython/gui_modules/menudata.py:1229
msgid "Parallel lines"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1225
+#: ../gui/wxpython/gui_modules/menudata.py:1230
msgid "Create parallel line to input lines"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1230
+#: ../gui/wxpython/gui_modules/menudata.py:1235
msgid "Dissolve boundaries"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1231
+#: ../gui/wxpython/gui_modules/menudata.py:1236
msgid ""
"Dissolves boundaries between adjacent areas sharing a common category number "
"or attribute."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1236
+#: ../gui/wxpython/gui_modules/menudata.py:1241
msgid "Create 3D vector over raster"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1237
+#: ../gui/wxpython/gui_modules/menudata.py:1242
msgid "Converts vector map to 3D by sampling of elevation raster map."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1241
+#: ../gui/wxpython/gui_modules/menudata.py:1246
msgid "Extrude 3D vector map"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1242
+#: ../gui/wxpython/gui_modules/menudata.py:1247
msgid "Extrudes flat vector object to 3D with defined height."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1247
+#: ../gui/wxpython/gui_modules/menudata.py:1252
msgid "Link to OGR"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1248
+#: ../gui/wxpython/gui_modules/menudata.py:1253
msgid ""
"Available drivers: ESRI Shapefile,MapInfo File,UK .NTF,SDTS,TIGER,S57,DGN,"
"VRT,REC,Memory,BNA,CSV,GML,GPX,KML,GeoJSON,GMT,SQLite,ODBC,PGeo,PostgreSQL,"
"AVCBin"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1253
+#: ../gui/wxpython/gui_modules/menudata.py:1258
msgid "Create labels"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1254
+#: ../gui/wxpython/gui_modules/menudata.py:1259
msgid "Creates paint labels for a vector map from attached attributes."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1259
+#: ../gui/wxpython/gui_modules/menudata.py:1264
msgid "Reposition vector map"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1260
+#: ../gui/wxpython/gui_modules/menudata.py:1265
msgid ""
"Performs an affine transformation (shift, scale and rotate, or GPCs) on "
"vector map."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1264
+#: ../gui/wxpython/gui_modules/menudata.py:1269
msgid "Reproject vector map"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1265
+#: ../gui/wxpython/gui_modules/menudata.py:1270
msgid "Allows projection conversion of vector maps."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1272
+#: ../gui/wxpython/gui_modules/menudata.py:1277
msgid "Query with attributes"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1273
+#: ../gui/wxpython/gui_modules/menudata.py:1278
msgid ""
"Selects vector objects from an existing vector map and creates a new map "
"containing only the selected objects."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1277
+#: ../gui/wxpython/gui_modules/menudata.py:1282
msgid "Query with coordinate(s)"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1278
+#: ../gui/wxpython/gui_modules/menudata.py:1283
msgid "Queries a vector map layer at given locations."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1282
+#: ../gui/wxpython/gui_modules/menudata.py:1287
msgid "Query with another vector map"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1283
+#: ../gui/wxpython/gui_modules/menudata.py:1288
msgid "Select features from ainput by features from binput"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1288
+#: ../gui/wxpython/gui_modules/menudata.py:1293
msgid "Buffer vectors"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1289
+#: ../gui/wxpython/gui_modules/menudata.py:1294
msgid "Creates a buffer around features of given type (areas must contain centroid)."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1292
+#: ../gui/wxpython/gui_modules/menudata.py:1297
msgid "Lidar analysis"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1294
+#: ../gui/wxpython/gui_modules/menudata.py:1299
msgid "Detect edges"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1295
+#: ../gui/wxpython/gui_modules/menudata.py:1300
msgid "Detects the object's edges from a LIDAR data set."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1299
+#: ../gui/wxpython/gui_modules/menudata.py:1304
msgid "Detect interiors"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1300
+#: ../gui/wxpython/gui_modules/menudata.py:1305
msgid ""
"Building contour determination and Region Growing algorithm for determining "
"the building inside"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1304
+#: ../gui/wxpython/gui_modules/menudata.py:1309
msgid "Correct and reclassify objects"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1305
+#: ../gui/wxpython/gui_modules/menudata.py:1310
msgid ""
"Correction of the v.lidar.growing output. It is the last of the three "
"algorithms for LIDAR filtering."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1310
+#: ../gui/wxpython/gui_modules/menudata.py:1315
msgid "Linear referencing"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1312
+#: ../gui/wxpython/gui_modules/menudata.py:1317
msgid "Create LRS"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1313
+#: ../gui/wxpython/gui_modules/menudata.py:1318
msgid "Create Linear Reference System"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1317
+#: ../gui/wxpython/gui_modules/menudata.py:1322
msgid "Create stationing"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1318
+#: ../gui/wxpython/gui_modules/menudata.py:1323
msgid "Create stationing from input lines, and linear reference system"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1322
+#: ../gui/wxpython/gui_modules/menudata.py:1327
msgid "Create points/segments"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1323
+#: ../gui/wxpython/gui_modules/menudata.py:1328
msgid ""
"Creates points/segments from input lines, linear reference system and "
"positions read from stdin or a file."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1327
+#: ../gui/wxpython/gui_modules/menudata.py:1332
msgid "Find line id and offset"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1328
+#: ../gui/wxpython/gui_modules/menudata.py:1333
msgid ""
"Finds line id and real km+offset for given points in vector map using linear "
"reference system."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1334
+#: ../gui/wxpython/gui_modules/menudata.py:1339
msgid "Nearest features"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1335
+#: ../gui/wxpython/gui_modules/menudata.py:1340
msgid ""
"Finds the nearest element in vector map 'to' for elements in vector map "
"'from'."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1338
+#: ../gui/wxpython/gui_modules/menudata.py:1343
msgid "Network analysis"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1340
+#: ../gui/wxpython/gui_modules/menudata.py:1345
msgid "Allocate subnets"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1341
+#: ../gui/wxpython/gui_modules/menudata.py:1346
msgid ""
"Centre node must be opened (costs >= 0). Costs of centre node are used in "
"calculation"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1345
+#: ../gui/wxpython/gui_modules/menudata.py:1350
msgid "Network maintenance"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1346
+#: ../gui/wxpython/gui_modules/menudata.py:1351
msgid "Network maintenance."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1350
+#: ../gui/wxpython/gui_modules/menudata.py:1355
msgid "Visibility network"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1351
+#: ../gui/wxpython/gui_modules/menudata.py:1356
msgid "Visibility graph construction."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1355
+#: ../gui/wxpython/gui_modules/menudata.py:1360
msgid "Shortest path"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1356
+#: ../gui/wxpython/gui_modules/menudata.py:1361
msgid "Finds shortest path on vector network."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1360
+#: ../gui/wxpython/gui_modules/menudata.py:1365
msgid "Display shortest route (requires XTerm)"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1361
+#: ../gui/wxpython/gui_modules/menudata.py:1366
msgid ""
"Display shortest route along network between 2 nodes (visualization only, "
"requires XTerm))"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1365
+#: ../gui/wxpython/gui_modules/menudata.py:1370
msgid "Split net"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1366
+#: ../gui/wxpython/gui_modules/menudata.py:1371
msgid ""
"Splits net to bands between cost isolines (direction from centre). Centre "
"node must be opened (costs >= 0). Costs of centre node are used in "
"calculation."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1370
+#: ../gui/wxpython/gui_modules/menudata.py:1375
msgid "Steiner tree"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1371
+#: ../gui/wxpython/gui_modules/menudata.py:1376
msgid ""
"Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm "
"is used in this module so the result may be sub optimal"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1375
+#: ../gui/wxpython/gui_modules/menudata.py:1380
msgid "Traveling salesman analysis"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1376
+#: ../gui/wxpython/gui_modules/menudata.py:1381
msgid ""
"Note that TSP is NP-hard, heuristic algorithm is used by this module and "
"created cycle may be sub optimal"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1381
-#: ../gui/wxpython/gui_modules/menudata.py:1383
+#: ../gui/wxpython/gui_modules/menudata.py:1386
+#: ../gui/wxpython/gui_modules/menudata.py:1388
msgid "Overlay vector maps"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1384
+#: ../gui/wxpython/gui_modules/menudata.py:1389
msgid "Overlays two vector maps."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1388
+#: ../gui/wxpython/gui_modules/menudata.py:1393
msgid "Patch vector maps"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1389
+#: ../gui/wxpython/gui_modules/menudata.py:1394
msgid "Create a new vector map layer by combining other vector map layers."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1395
+#: ../gui/wxpython/gui_modules/menudata.py:1400
msgid "Change attributes"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1397
+#: ../gui/wxpython/gui_modules/menudata.py:1402
msgid "Manage or report categories"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1398
+#: ../gui/wxpython/gui_modules/menudata.py:1403
msgid "Attach, delete or report vector categories to map geometry."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1402
+#: ../gui/wxpython/gui_modules/menudata.py:1407
msgid "Reclassify objects interactively"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1403
+#: ../gui/wxpython/gui_modules/menudata.py:1408
msgid "Reclassify vector objects interactively by entering SQL rules"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1407
+#: ../gui/wxpython/gui_modules/menudata.py:1412
msgid "Reclassify objects using rules file"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1408
+#: ../gui/wxpython/gui_modules/menudata.py:1413
msgid ""
"Changes vector category values for an existing vector map according to "
"results of SQL queries or a value in attribute table column."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1415
+#: ../gui/wxpython/gui_modules/menudata.py:1420
msgid "Generate area for current region"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1416
+#: ../gui/wxpython/gui_modules/menudata.py:1421
msgid "Create a new vector from the current region."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1419
+#: ../gui/wxpython/gui_modules/menudata.py:1424
msgid "Generate areas from points"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1421
+#: ../gui/wxpython/gui_modules/menudata.py:1426
msgid "Convex hull"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1422
+#: ../gui/wxpython/gui_modules/menudata.py:1427
msgid "Uses a GRASS vector points map to produce a convex hull vector map."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1426
+#: ../gui/wxpython/gui_modules/menudata.py:1431
msgid "Delaunay triangles"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1427
+#: ../gui/wxpython/gui_modules/menudata.py:1432
msgid ""
"Creates a Delaunay triangulation from an input vector map containing points "
"or centroids."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1431
+#: ../gui/wxpython/gui_modules/menudata.py:1436
msgid "Voronoi diagram/Thiessen polygons"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1432
+#: ../gui/wxpython/gui_modules/menudata.py:1437
msgid ""
"Creates a Voronoi diagram from an input vector map containing points or "
"centroids."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1438
+#: ../gui/wxpython/gui_modules/menudata.py:1443
msgid "Generate grid"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1439
+#: ../gui/wxpython/gui_modules/menudata.py:1444
msgid "Creates a GRASS vector map of a user-defined grid."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1442
+#: ../gui/wxpython/gui_modules/menudata.py:1447
msgid "Generate points"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1444
+#: ../gui/wxpython/gui_modules/menudata.py:1449
msgid "Generate from database"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1445
+#: ../gui/wxpython/gui_modules/menudata.py:1450
msgid "Creates new vector (points) map from database table containing coordinates."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1449
+#: ../gui/wxpython/gui_modules/menudata.py:1454
msgid "Generate points along lines"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1450
+#: ../gui/wxpython/gui_modules/menudata.py:1455
msgid "Create points along input lines in new vector with 2 layers."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1454
+#: ../gui/wxpython/gui_modules/menudata.py:1459
msgid "Generate random points"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1455
+#: ../gui/wxpython/gui_modules/menudata.py:1460
msgid "Randomly generate a 2D/3D vector points map."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1459
+#: ../gui/wxpython/gui_modules/menudata.py:1464
msgid "Perturb points"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1460
+#: ../gui/wxpython/gui_modules/menudata.py:1465
msgid "Random location perturbations of GRASS vector points"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1467
+#: ../gui/wxpython/gui_modules/menudata.py:1472
msgid "Remove outliers in point sets"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1468
+#: ../gui/wxpython/gui_modules/menudata.py:1473
msgid "Removes outliers from vector point data."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1472
+#: ../gui/wxpython/gui_modules/menudata.py:1477
msgid "Test/training point sets"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1473
+#: ../gui/wxpython/gui_modules/menudata.py:1478
msgid "Randomly partition points into test/train sets."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1478
+#: ../gui/wxpython/gui_modules/menudata.py:1483
msgid "Update area attributes from raster"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1479
+#: ../gui/wxpython/gui_modules/menudata.py:1484
msgid ""
"Calculates univariate statistics from a GRASS raster map based on vector "
"polygons and uploads statistics to new attribute columns."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1483
+#: ../gui/wxpython/gui_modules/menudata.py:1488
msgid "Update point attributes from areas"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1484
+#: ../gui/wxpython/gui_modules/menudata.py:1489
msgid "Uploads vector values at positions of vector points to the table."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1487
+#: ../gui/wxpython/gui_modules/menudata.py:1492
msgid "Update point attributes from raster"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1489
+#: ../gui/wxpython/gui_modules/menudata.py:1494
msgid "Sample raster maps at point locations"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1490
+#: ../gui/wxpython/gui_modules/menudata.py:1495
msgid "Uploads raster values at positions of vector points to the table."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1494
+#: ../gui/wxpython/gui_modules/menudata.py:1499
msgid "Sample raster neighborhood around points"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1495
+#: ../gui/wxpython/gui_modules/menudata.py:1500
msgid "Samples a raster map at vector point locations."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1501
+#: ../gui/wxpython/gui_modules/menudata.py:1506
msgid "Reports and statistics"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1503
+#: ../gui/wxpython/gui_modules/menudata.py:1508
msgid "Basic vector metadata"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1504
+#: ../gui/wxpython/gui_modules/menudata.py:1509
msgid "Outputs basic information about a user-specified vector map layer."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1509
+#: ../gui/wxpython/gui_modules/menudata.py:1514
msgid "Report topology by category"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1510
+#: ../gui/wxpython/gui_modules/menudata.py:1515
msgid "Reports geometry statistics for vectors."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1514
+#: ../gui/wxpython/gui_modules/menudata.py:1519
msgid "Upload or report topology"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1515
+#: ../gui/wxpython/gui_modules/menudata.py:1520
msgid "Populate database values from vector features."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1520
+#: ../gui/wxpython/gui_modules/menudata.py:1525
msgid "Univariate attribute statistics"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1521
+#: ../gui/wxpython/gui_modules/menudata.py:1526
msgid ""
"Calculates univariate statistics for attribute. Variance and standard "
"deviation is calculated only for points if specified."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1526
+#: ../gui/wxpython/gui_modules/menudata.py:1531
msgid "Quadrat indices"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1527
+#: ../gui/wxpython/gui_modules/menudata.py:1532
msgid "Indices for quadrat counts of sites lists."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1531
+#: ../gui/wxpython/gui_modules/menudata.py:1536
msgid "Test normality"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1532
+#: ../gui/wxpython/gui_modules/menudata.py:1537
msgid "Tests for normality for points."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1539
+#: ../gui/wxpython/gui_modules/menudata.py:1544
msgid "Imagery"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1540
+#: ../gui/wxpython/gui_modules/menudata.py:1545
msgid "Develop images and groups"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1542
+#: ../gui/wxpython/gui_modules/menudata.py:1547
msgid "Create/edit group"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1543
+#: ../gui/wxpython/gui_modules/menudata.py:1548
msgid "Creates, edits, and lists groups and subgroups of imagery files."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1547
+#: ../gui/wxpython/gui_modules/menudata.py:1552
msgid "Target group"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1548
+#: ../gui/wxpython/gui_modules/menudata.py:1553
msgid "Targets an imagery group to a GRASS location and mapset."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1553
+#: ../gui/wxpython/gui_modules/menudata.py:1558
msgid "Mosaic images"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1554
+#: ../gui/wxpython/gui_modules/menudata.py:1559
msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1559
+#: ../gui/wxpython/gui_modules/menudata.py:1564
msgid "Manage image colors"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1561
+#: ../gui/wxpython/gui_modules/menudata.py:1566
msgid "Color balance for RGB"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1562
+#: ../gui/wxpython/gui_modules/menudata.py:1567
msgid "Auto-balancing of colors for LANDSAT images"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1566
+#: ../gui/wxpython/gui_modules/menudata.py:1571
msgid "HIS to RGB"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1567
+#: ../gui/wxpython/gui_modules/menudata.py:1572
msgid ""
"Hue-intensity-saturation (his) to red-green-blue (rgb) raster map color "
"transformation function."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1572
+#: ../gui/wxpython/gui_modules/menudata.py:1577
msgid ""
"Red-green-blue (rgb) to hue-intensity-saturation (his) raster map color "
"transformation function"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1578
+#: ../gui/wxpython/gui_modules/menudata.py:1583
msgid "Rectify image or raster"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1579
+#: ../gui/wxpython/gui_modules/menudata.py:1584
msgid ""
"Rectifies an image by computing a coordinate transformation for each pixel "
"in the image based on the control points"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1583
+#: ../gui/wxpython/gui_modules/menudata.py:1588
msgid "Ortho photo rectification (requires Xterm)"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1584
+#: ../gui/wxpython/gui_modules/menudata.py:1589
msgid "Ortho Photo rectification"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1589
+#: ../gui/wxpython/gui_modules/menudata.py:1594
msgid "Brovey sharpening"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1590
+#: ../gui/wxpython/gui_modules/menudata.py:1595
msgid "Brovey transform to merge multispectral and high-res panchromatic channels"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1593
+#: ../gui/wxpython/gui_modules/menudata.py:1598
msgid "Classify image"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1595
+#: ../gui/wxpython/gui_modules/menudata.py:1600
msgid "Clustering input for unsupervised classification"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1596
+#: ../gui/wxpython/gui_modules/menudata.py:1601
msgid ""
"The resulting signature file is used as input for i.maxlik, to generate an "
"unsupervised image classification."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1601
+#: ../gui/wxpython/gui_modules/menudata.py:1606
msgid "Maximum likelihood classification (MLC)"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1602
+#: ../gui/wxpython/gui_modules/menudata.py:1607
msgid ""
"Classification is based on the spectral signature information generated by "
"either i.cluster, i.class, or i.gensig."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1606
+#: ../gui/wxpython/gui_modules/menudata.py:1611
msgid "Sequential maximum a posteriori classification (SMAP)"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1607
+#: ../gui/wxpython/gui_modules/menudata.py:1612
msgid ""
"Performs contextual image classification using sequential maximum a "
"posteriori (SMAP) estimation."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1612
+#: ../gui/wxpython/gui_modules/menudata.py:1617
msgid "Interactive input for supervised classification (requires Xterm)"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1613
+#: ../gui/wxpython/gui_modules/menudata.py:1618
msgid "Interactive input for supervised classification"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1617
+#: ../gui/wxpython/gui_modules/menudata.py:1622
msgid "Input for supervised MLC"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1618
+#: ../gui/wxpython/gui_modules/menudata.py:1623
msgid "Generates statistics for i.maxlik from raster map layer."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1622
+#: ../gui/wxpython/gui_modules/menudata.py:1627
msgid "Input for supervised SMAP"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1623
+#: ../gui/wxpython/gui_modules/menudata.py:1628
msgid "Generate statistics for i.smap from raster map layer."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1628
+#: ../gui/wxpython/gui_modules/menudata.py:1633
msgid "Filter image"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1630
+#: ../gui/wxpython/gui_modules/menudata.py:1635
msgid "Edge detection"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1631
+#: ../gui/wxpython/gui_modules/menudata.py:1636
msgid "Zero-crossing \"edge detection\" raster function for image processing."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1635
+#: ../gui/wxpython/gui_modules/menudata.py:1640
msgid "Matrix/convolving filter"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1636
+#: ../gui/wxpython/gui_modules/menudata.py:1641
msgid "Raster map matrix filter."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1642
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:284
+#: ../gui/wxpython/gui_modules/menudata.py:1647
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:283
msgid "Histogram"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1643
+#: ../gui/wxpython/gui_modules/menudata.py:1648
msgid "Generate histogram of image"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1647
+#: ../gui/wxpython/gui_modules/menudata.py:1652
msgid "Spectral response"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1648
+#: ../gui/wxpython/gui_modules/menudata.py:1653
msgid "displays spectral response at user specified locations in group or images"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1652
+#: ../gui/wxpython/gui_modules/menudata.py:1657
msgid "Tasseled cap vegetation index"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1653
+#: ../gui/wxpython/gui_modules/menudata.py:1658
msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1656
+#: ../gui/wxpython/gui_modules/menudata.py:1661
msgid "Transform image"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1658
+#: ../gui/wxpython/gui_modules/menudata.py:1663
msgid "Canonical correlation"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1659
+#: ../gui/wxpython/gui_modules/menudata.py:1664
msgid "Canonical components analysis (cca) program for image processing."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1663
+#: ../gui/wxpython/gui_modules/menudata.py:1668
msgid "Principal components"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1664
+#: ../gui/wxpython/gui_modules/menudata.py:1669
msgid "Principal components analysis (pca) program for image processing."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1668
+#: ../gui/wxpython/gui_modules/menudata.py:1673
msgid "Fast Fourier"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1669
+#: ../gui/wxpython/gui_modules/menudata.py:1674
msgid "Fast Fourier Transform (FFT) for image processing."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1673
+#: ../gui/wxpython/gui_modules/menudata.py:1678
msgid "Inverse Fast Fourier"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1674
+#: ../gui/wxpython/gui_modules/menudata.py:1679
msgid "Inverse Fast Fourier Transform (IFFT) for image processing."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1682
+#: ../gui/wxpython/gui_modules/menudata.py:1687
msgid "Bit pattern comparison "
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1683
+#: ../gui/wxpython/gui_modules/menudata.py:1688
msgid "Compares bit patterns with a raster map."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1687
+#: ../gui/wxpython/gui_modules/menudata.py:1692
msgid "Kappa analysis"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1688
+#: ../gui/wxpython/gui_modules/menudata.py:1693
msgid ""
"Calculate error matrix and kappa parameter for accuracy assessment of "
"classification result."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1692
+#: ../gui/wxpython/gui_modules/menudata.py:1697
msgid "OIF for LandSat TM"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1693
+#: ../gui/wxpython/gui_modules/menudata.py:1698
msgid "Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1700
+#: ../gui/wxpython/gui_modules/menudata.py:1705
msgid "Volumes"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1701
+#: ../gui/wxpython/gui_modules/menudata.py:1706
msgid "Develop volumes"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1703
+#: ../gui/wxpython/gui_modules/menudata.py:1708
msgid "Manage 3D NULL values"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1704
+#: ../gui/wxpython/gui_modules/menudata.py:1709
msgid "Explicitly create the 3D NULL-value bitmap file."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1708
+#: ../gui/wxpython/gui_modules/menudata.py:1713
msgid "Manage timestamp"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1709
+#: ../gui/wxpython/gui_modules/menudata.py:1714
msgid "Print/add/remove a timestamp for a 3D raster map"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1716
+#: ../gui/wxpython/gui_modules/menudata.py:1721
msgid "3D Mask"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1717
+#: ../gui/wxpython/gui_modules/menudata.py:1722
msgid "Establishes the current working 3D raster mask."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1721
+#: ../gui/wxpython/gui_modules/menudata.py:1726
msgid "3D raster map calculator"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1722
+#: ../gui/wxpython/gui_modules/menudata.py:1727
msgid "Map calculator for volumetric map algebra"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1726
+#: ../gui/wxpython/gui_modules/menudata.py:1731
msgid "Cross section"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1727
+#: ../gui/wxpython/gui_modules/menudata.py:1732
msgid ""
"Creates cross section 2D raster map from 3d raster map based on 2D elevation "
"map"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1731
+#: ../gui/wxpython/gui_modules/menudata.py:1736
msgid "Interpolate volume from points"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1732
+#: ../gui/wxpython/gui_modules/menudata.py:1737
msgid ""
"Interpolates point data to a G3D grid volume using regularized spline with "
"tension (RST) algorithm."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1736
+#: ../gui/wxpython/gui_modules/menudata.py:1741
msgid "Report and Statistics"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1738
+#: ../gui/wxpython/gui_modules/menudata.py:1743
msgid "Basic volume metadata"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1739
+#: ../gui/wxpython/gui_modules/menudata.py:1744
msgid "Outputs basic information about a user-specified 3D raster map layer."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1746
-#: ../gui/wxpython/gui_modules/dbm.py:1894
-#: ../gui/wxpython/gui_modules/dbm.py:2008
-#: ../gui/wxpython/gui_modules/dbm.py:2246
+#: ../gui/wxpython/gui_modules/menudata.py:1751
+#: ../gui/wxpython/gui_modules/dbm.py:1922
+#: ../gui/wxpython/gui_modules/dbm.py:2036
+#: ../gui/wxpython/gui_modules/dbm.py:2274
msgid "Database"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1747
+#: ../gui/wxpython/gui_modules/menudata.py:1752
msgid "Database information"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1749
+#: ../gui/wxpython/gui_modules/menudata.py:1754
msgid "Describe table"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1750
+#: ../gui/wxpython/gui_modules/menudata.py:1755
msgid "Describes a table in detail."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1754
+#: ../gui/wxpython/gui_modules/menudata.py:1759
msgid "List columns"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1755
+#: ../gui/wxpython/gui_modules/menudata.py:1760
msgid "List all columns for a given table."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1759
+#: ../gui/wxpython/gui_modules/menudata.py:1764
msgid "List drivers"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1760
+#: ../gui/wxpython/gui_modules/menudata.py:1765
msgid "List all database drivers."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1764
+#: ../gui/wxpython/gui_modules/menudata.py:1769
msgid "List tables"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1765
+#: ../gui/wxpython/gui_modules/menudata.py:1770
msgid "Lists all tables for a given database."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1771
+#: ../gui/wxpython/gui_modules/menudata.py:1776
msgid "Manage databases"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1773
+#: ../gui/wxpython/gui_modules/menudata.py:1778
msgid "Connect"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1774
+#: ../gui/wxpython/gui_modules/menudata.py:1779
msgid "Prints/sets general DB connection for current mapset and exits."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1778
+#: ../gui/wxpython/gui_modules/menudata.py:1783
msgid "Login"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1779
-#: ../gui/wxpython/gui_modules/menudata.py:1795
+#: ../gui/wxpython/gui_modules/menudata.py:1784
+#: ../gui/wxpython/gui_modules/menudata.py:1800
msgid "Sets user/password for driver/database."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1784
+#: ../gui/wxpython/gui_modules/menudata.py:1789
msgid "Copy table"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1785
+#: ../gui/wxpython/gui_modules/menudata.py:1790
msgid ""
"Copy a table. Either 'from_table' (optionaly with 'where') can be used or "
"'select' option, but not 'from_table' and 'select' at the same time."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1789
+#: ../gui/wxpython/gui_modules/menudata.py:1794
msgid "New table"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1790
+#: ../gui/wxpython/gui_modules/menudata.py:1795
msgid ""
"Creates and adds a new attribute table to a given layer of an existing "
"vector map."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1794
+#: ../gui/wxpython/gui_modules/menudata.py:1799
msgid "Remove table"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1800
+#: ../gui/wxpython/gui_modules/menudata.py:1805
msgid "Add columns"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1801
+#: ../gui/wxpython/gui_modules/menudata.py:1806
msgid ""
"Adds one or more columns to the attribute table connected to a given vector "
"map."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1805
+#: ../gui/wxpython/gui_modules/menudata.py:1810
msgid "Change values"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1806
+#: ../gui/wxpython/gui_modules/menudata.py:1811
msgid "Allows to update a column in the attribute table connected to a vector map."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1810
-#: ../gui/wxpython/gui_modules/dbm.py:721
+#: ../gui/wxpython/gui_modules/menudata.py:1815
+#: ../gui/wxpython/gui_modules/dbm.py:724
msgid "Rename column"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1811
+#: ../gui/wxpython/gui_modules/menudata.py:1816
msgid "Renames a column in the attribute table connected to a given vector map."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1816
+#: ../gui/wxpython/gui_modules/menudata.py:1821
msgid "Test"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1817
+#: ../gui/wxpython/gui_modules/menudata.py:1822
msgid "Test database driver, database must exist and set by db.connect."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1822
+#: ../gui/wxpython/gui_modules/menudata.py:1827
msgid "Query"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1824
+#: ../gui/wxpython/gui_modules/menudata.py:1829
msgid "Query any table"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1825
+#: ../gui/wxpython/gui_modules/menudata.py:1830
msgid "Selects data from table."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1829
+#: ../gui/wxpython/gui_modules/menudata.py:1834
msgid "Query vector attribute data"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1830
+#: ../gui/wxpython/gui_modules/menudata.py:1835
msgid "Prints vector map attributes."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1834
+#: ../gui/wxpython/gui_modules/menudata.py:1839
msgid "SQL statement"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1835
+#: ../gui/wxpython/gui_modules/menudata.py:1840
msgid "Executes any SQL statement."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1841
+#: ../gui/wxpython/gui_modules/menudata.py:1846
msgid "Vector database connections"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1843
+#: ../gui/wxpython/gui_modules/menudata.py:1848
msgid "Reconnect vector to database"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1844
+#: ../gui/wxpython/gui_modules/menudata.py:1849
msgid "Reconnects vectors to a new database."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1848
+#: ../gui/wxpython/gui_modules/menudata.py:1853
msgid "Set vector map - database connection"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1849
+#: ../gui/wxpython/gui_modules/menudata.py:1854
msgid "Prints/sets DB connection for a vector map to attribute table."
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1856
+#: ../gui/wxpython/gui_modules/menudata.py:1861
msgid "Help"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1858
+#: ../gui/wxpython/gui_modules/menudata.py:1863
msgid "GRASS GIS help"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1859
#: ../gui/wxpython/gui_modules/menudata.py:1864
+#: ../gui/wxpython/gui_modules/menudata.py:1869
msgid "Display the HTML man pages of GRASS"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1863
+#: ../gui/wxpython/gui_modules/menudata.py:1868
msgid "GRASS GIS GUI help"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1868
-#: ../gui/wxpython/gui_modules/menudata.py:1869
+#: ../gui/wxpython/gui_modules/menudata.py:1873
+#: ../gui/wxpython/gui_modules/menudata.py:1874
msgid "About GRASS GIS"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:155
+#: ../gui/wxpython/gui_modules/preferences.py:159
msgid "Mapset search path"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:156
+#: ../gui/wxpython/gui_modules/preferences.py:160
msgid "All available mapsets"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:157
-#: ../gui/wxpython/gui_modules/dbm.py:902
+#: ../gui/wxpython/gui_modules/preferences.py:161
+#: ../gui/wxpython/gui_modules/dbm.py:905
msgid "Edit selected record"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:158
-#: ../gui/wxpython/gui_modules/dbm.py:913
+#: ../gui/wxpython/gui_modules/preferences.py:162
+#: ../gui/wxpython/gui_modules/dbm.py:916
msgid "Display selected"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:268
+#: ../gui/wxpython/gui_modules/preferences.py:272
msgid "Uknown settings file location."
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:313
+#: ../gui/wxpython/gui_modules/preferences.py:317
msgid "Unable to get value"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:336
+#: ../gui/wxpython/gui_modules/preferences.py:340
msgid "Unable to set "
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:342
+#: ../gui/wxpython/gui_modules/preferences.py:346
msgid "User GUI settings"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:365
+#: ../gui/wxpython/gui_modules/preferences.py:369
msgid "Set to default"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:373
+#: ../gui/wxpython/gui_modules/preferences.py:377
msgid "Revert settings to default and apply changes"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:375
-#: ../gui/wxpython/gui_modules/digit.py:1352
+#: ../gui/wxpython/gui_modules/preferences.py:379
+#: ../gui/wxpython/gui_modules/digit.py:1508
msgid "Apply changes for this session"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:377
-#: ../gui/wxpython/gui_modules/digit.py:1355
+#: ../gui/wxpython/gui_modules/preferences.py:381
+#: ../gui/wxpython/gui_modules/digit.py:1511
msgid "Close dialog and save changes to user settings file"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:380
-#: ../gui/wxpython/gui_modules/digit.py:1357
+#: ../gui/wxpython/gui_modules/preferences.py:384
+#: ../gui/wxpython/gui_modules/digit.py:1513
msgid "Close dialog and ignore changes"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:408
-#: ../gui/wxpython/gui_modules/digit.py:1413
+#: ../gui/wxpython/gui_modules/preferences.py:412
+#: ../gui/wxpython/gui_modules/digit.py:1569
msgid "General"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:411
+#: ../gui/wxpython/gui_modules/preferences.py:415
msgid "General settings"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:422
+#: ../gui/wxpython/gui_modules/preferences.py:426
msgid "Mapsets path:"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:444
+#: ../gui/wxpython/gui_modules/preferences.py:448
msgid "Layer Manager settings"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:455
+#: ../gui/wxpython/gui_modules/preferences.py:459
msgid "Opacity level editable"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:473
-#: ../gui/wxpython/gui_modules/digit.py:1420
+#: ../gui/wxpython/gui_modules/preferences.py:477
+#: ../gui/wxpython/gui_modules/digit.py:1576
msgid "Display"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:476
+#: ../gui/wxpython/gui_modules/preferences.py:481
msgid "Font settings"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:487
+#: ../gui/wxpython/gui_modules/preferences.py:492
msgid "Default font for GRASS displays:"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:492
-msgid "Set font"
+#: ../gui/wxpython/gui_modules/preferences.py:506
+msgid "Default display settings"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:503
+#: ../gui/wxpython/gui_modules/preferences.py:517
msgid "Display driver:"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:537
+#: ../gui/wxpython/gui_modules/preferences.py:557
+msgid "Enable auto-rendering"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:578
msgid "Command"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:540
+#: ../gui/wxpython/gui_modules/preferences.py:581
msgid "Command dialog settings"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:572
+#: ../gui/wxpython/gui_modules/preferences.py:613
msgid "Verbosity level:"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:591
+#: ../gui/wxpython/gui_modules/preferences.py:632
msgid "Raster settings"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:602
+#: ../gui/wxpython/gui_modules/preferences.py:643
msgid "Overlay raster maps"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:620
+#: ../gui/wxpython/gui_modules/preferences.py:661
#: ../gui/wxpython/gui_modules/dbm.py:406
msgid "Attribute Table Manager"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:628
+#: ../gui/wxpython/gui_modules/preferences.py:669
msgid "Highlighting"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:642
+#: ../gui/wxpython/gui_modules/preferences.py:683
msgid "Line width (in pixels)"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:665
+#: ../gui/wxpython/gui_modules/preferences.py:706
msgid "Data browser"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:670
+#: ../gui/wxpython/gui_modules/preferences.py:711
msgid "Left mouse double click"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:697
-#: ../gui/wxpython/gui_modules/dbm.py:556
+#: ../gui/wxpython/gui_modules/preferences.py:738
+#: ../gui/wxpython/gui_modules/dbm.py:558
msgid "Advanced"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:700
+#: ../gui/wxpython/gui_modules/preferences.py:741
msgid "Advanced settings"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:712
+#: ../gui/wxpython/gui_modules/preferences.py:753
msgid "Place where to store settings:"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:733
+#: ../gui/wxpython/gui_modules/preferences.py:774
msgid "Icon theme:"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:750
+#: ../gui/wxpython/gui_modules/preferences.py:791
msgid "Note: Requires GUI restart."
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:764
+#: ../gui/wxpython/gui_modules/preferences.py:805
msgid "Digitization interface:"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:782
+#: ../gui/wxpython/gui_modules/preferences.py:823
msgid ""
"Note: User can choose from two interfaces for digitization. The simple one "
"uses v.edit command on the background. Map topology is rebuild on each "
@@ -3828,206 +3966,220 @@
"itself."
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:806
+#: ../gui/wxpython/gui_modules/preferences.py:847
msgid "Select default display font"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:833
+#: ../gui/wxpython/gui_modules/preferences.py:874
#, python-format
msgid "Settings saved to file '%s'."
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:986
+#: ../gui/wxpython/gui_modules/preferences.py:1027
msgid "Set/unset access to mapsets in current location"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:999
+#: ../gui/wxpython/gui_modules/preferences.py:1040
#, python-format
msgid ""
"Check mapset to make it accessible, uncheck it to hide it.%sNote: PERMANENT "
"and current mapset are always accessible."
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1071
+#: ../gui/wxpython/gui_modules/preferences.py:1112
msgid "Mapset"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1072
+#: ../gui/wxpython/gui_modules/preferences.py:1113
msgid "Owner"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1073
+#: ../gui/wxpython/gui_modules/preferences.py:1114
msgid "Group"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:148
-#: ../gui/wxpython/gui_modules/digit.py:152
+#: ../gui/wxpython/gui_modules/digit.py:149
+#: ../gui/wxpython/gui_modules/digit.py:153
#, python-format
msgid ""
"Unable to open vector map <%s> for editing. Data are probably corrupted, try "
"to run v.build for rebuilding the topology."
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:786
-#: ../gui/wxpython/gui_modules/digit.py:817
+#: ../gui/wxpython/gui_modules/digit.py:745
+msgid "Undondo is not implemented in vedit component. Use vdigit instead."
+msgstr ""
+#: ../gui/wxpython/gui_modules/digit.py:798
+#: ../gui/wxpython/gui_modules/digit.py:831
#, python-format
msgid "Adding new feature to vector map <%s> failed."
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1378
+#: ../gui/wxpython/gui_modules/digit.py:1151
+msgid "Undo failed, data corrupted."
+msgstr ""
+#: ../gui/wxpython/gui_modules/digit.py:1534
msgid "Symbology"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1425
+#: ../gui/wxpython/gui_modules/digit.py:1581
msgid "Line width"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1443
+#: ../gui/wxpython/gui_modules/digit.py:1599
msgid "Snapping"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1450
+#: ../gui/wxpython/gui_modules/digit.py:1606
msgid "Snapping threshold"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1463
+#: ../gui/wxpython/gui_modules/digit.py:1619
msgid "Backgroud vector map"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1474
+#: ../gui/wxpython/gui_modules/digit.py:1630
msgid "Snap also to vertex"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1479
-#: ../gui/wxpython/gui_modules/digit.py:1753
-#: ../gui/wxpython/gui_modules/digit.py:1766
-#: ../gui/wxpython/gui_modules/digit.py:1770
+#: ../gui/wxpython/gui_modules/digit.py:1635
+#: ../gui/wxpython/gui_modules/digit.py:1919
+#: ../gui/wxpython/gui_modules/digit.py:1932
+#: ../gui/wxpython/gui_modules/digit.py:1936
#, python-format
msgid "Snapping threshold is %(value).1f %(units)s"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1493
+#: ../gui/wxpython/gui_modules/digit.py:1649
msgid "Select vector features"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1509
+#: ../gui/wxpython/gui_modules/digit.py:1665
msgid "Select threshold"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1532
+#: ../gui/wxpython/gui_modules/digit.py:1682
+msgid "Save changes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/digit.py:1685
+msgid "Save changes on exit automatically"
+msgstr ""
+#: ../gui/wxpython/gui_modules/digit.py:1698
msgid "Query tool"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1539
+#: ../gui/wxpython/gui_modules/digit.py:1705
msgid "Choose query tool"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1544
+#: ../gui/wxpython/gui_modules/digit.py:1710
msgid "Select by box"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1553
+#: ../gui/wxpython/gui_modules/digit.py:1719
msgid "length"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1558
+#: ../gui/wxpython/gui_modules/digit.py:1724
msgid "Select lines"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1560
-#: ../gui/wxpython/gui_modules/digit.py:1583
+#: ../gui/wxpython/gui_modules/digit.py:1726
+#: ../gui/wxpython/gui_modules/digit.py:1749
msgid "shorter than"
msgstr ""
msgid "longer than"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1576
+#: ../gui/wxpython/gui_modules/digit.py:1742
msgid "dangle"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1581
+#: ../gui/wxpython/gui_modules/digit.py:1747
msgid "Select dangles"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1614
+#: ../gui/wxpython/gui_modules/digit.py:1780
msgid "Attributes"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1621
+#: ../gui/wxpython/gui_modules/digit.py:1787
msgid "Digitize new feature"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1626
+#: ../gui/wxpython/gui_modules/digit.py:1792
msgid "Add new record into table"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1632
-#: ../gui/wxpython/gui_modules/digit.py:1634
-#: ../gui/wxpython/gui_modules/digit.py:1945
-#: ../gui/wxpython/gui_modules/digit.py:2315
-#: ../gui/wxpython/gui_modules/dbm.py:490
-#: ../gui/wxpython/gui_modules/dbm.py:637
-#: ../gui/wxpython/gui_modules/dbm.py:1997
-#: ../gui/wxpython/gui_modules/dbm.py:2232
-#: ../gui/wxpython/gui_modules/dbm.py:2874
+#: ../gui/wxpython/gui_modules/digit.py:1798
+#: ../gui/wxpython/gui_modules/digit.py:1800
+#: ../gui/wxpython/gui_modules/digit.py:2114
+#: ../gui/wxpython/gui_modules/digit.py:2488
+#: ../gui/wxpython/gui_modules/dbm.py:2025
+#: ../gui/wxpython/gui_modules/dbm.py:2260
+#: ../gui/wxpython/gui_modules/dbm.py:2905
msgid "Layer"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1949
-#: ../gui/wxpython/gui_modules/digit.py:2316
-#: ../gui/wxpython/gui_modules/dbm.py:2907
-#: ../gui/wxpython/gui_modules/dbm.py:3196
+#: ../gui/wxpython/gui_modules/digit.py:2118
+#: ../gui/wxpython/gui_modules/digit.py:2489
+#: ../gui/wxpython/gui_modules/dbm.py:2938
+#: ../gui/wxpython/gui_modules/dbm.py:3227
msgid "Category"
msgstr ""
msgid "Mode"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1661
+#: ../gui/wxpython/gui_modules/digit.py:1827
msgid "Next to use"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1649
+#: ../gui/wxpython/gui_modules/digit.py:1815
msgid "Category number"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1659
+#: ../gui/wxpython/gui_modules/digit.py:1825
msgid "Category mode"
msgstr ""
msgid "Manual entry"
msgstr ""
msgid "No category"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1674
+#: ../gui/wxpython/gui_modules/digit.py:1840
msgid "Delete existing feature(s)"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1679
+#: ../gui/wxpython/gui_modules/digit.py:1845
msgid "Delete record from table"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1923
+#: ../gui/wxpython/gui_modules/digit.py:2092
msgid "List of categories"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1939
+#: ../gui/wxpython/gui_modules/digit.py:2108
msgid "Add new category"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:2053
-#: ../gui/wxpython/gui_modules/digit.py:2224
+#: ../gui/wxpython/gui_modules/digit.py:2222
+#: ../gui/wxpython/gui_modules/digit.py:2397
#, python-format
msgid ""
"Unable to add new layer/category <%(layer)s/%(category)s>.\n"
@@ -4035,38 +4187,38 @@
"Layer number must be greater then zero."
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:2087
+#: ../gui/wxpython/gui_modules/digit.py:2256
msgid "Delete selected"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:2091
+#: ../gui/wxpython/gui_modules/digit.py:2260
msgid "Delete all"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:2093
-#: ../gui/wxpython/gui_modules/dbm.py:921
-#: ../gui/wxpython/gui_modules/dbm.py:1281
+#: ../gui/wxpython/gui_modules/digit.py:2262
+#: ../gui/wxpython/gui_modules/dbm.py:924
+#: ../gui/wxpython/gui_modules/dbm.py:1297
msgid "Reload"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:2201
+#: ../gui/wxpython/gui_modules/digit.py:2374
msgid "Unable to update vector map."
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:2353
+#: ../gui/wxpython/gui_modules/digit.py:2526
#, python-format
msgid "%d lines selected for z bulk-labeling"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:2356
+#: ../gui/wxpython/gui_modules/digit.py:2529
msgid "Set value"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:2363
+#: ../gui/wxpython/gui_modules/digit.py:2536
msgid "Starting value"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:2372
+#: ../gui/wxpython/gui_modules/digit.py:2545
msgid "Step"
msgstr ""
@@ -4105,6 +4257,14 @@
msgid "Click here to hide database connection information"
msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:490
+#: ../gui/wxpython/gui_modules/dbm.py:640
+#: ../gui/wxpython/gui_modules/dbm.py:2042
+#: ../gui/wxpython/gui_modules/dbm.py:2280
+msgid "Table"
+msgstr ""
#: ../gui/wxpython/gui_modules/dbm.py:496
msgid "Attribute data - right-click to edit/manage records"
msgstr ""
@@ -4113,258 +4273,242 @@
msgid "SQL Query"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:549
-#: ../gui/wxpython/gui_modules/dbm.py:1579
+#: ../gui/wxpython/gui_modules/dbm.py:551
+#: ../gui/wxpython/gui_modules/dbm.py:1620
msgid "SQL Builder"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:553
+#: ../gui/wxpython/gui_modules/dbm.py:555
msgid "Simple"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:623
-#: ../gui/wxpython/gui_modules/dbm.py:927
-#: ../gui/wxpython/gui_modules/dbm.py:1367
-#: ../gui/wxpython/gui_modules/dbm.py:1472
+#: ../gui/wxpython/gui_modules/dbm.py:626
+#: ../gui/wxpython/gui_modules/dbm.py:930
+#: ../gui/wxpython/gui_modules/dbm.py:1409
+#: ../gui/wxpython/gui_modules/dbm.py:1513
#, python-format
msgid "Number of loaded records: %d"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:653
+#: ../gui/wxpython/gui_modules/dbm.py:656
#, python-format
-msgid "Table %s"
+msgid "Table %s - right-click to delete records"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:666
-#: ../gui/wxpython/gui_modules/dbm.py:1841
+#: ../gui/wxpython/gui_modules/dbm.py:669
+#: ../gui/wxpython/gui_modules/dbm.py:1869
msgid "Column name"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:677
+#: ../gui/wxpython/gui_modules/dbm.py:680
msgid "Data type"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:694
+#: ../gui/wxpython/gui_modules/dbm.py:697
msgid "Data length"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:731
+#: ../gui/wxpython/gui_modules/dbm.py:734
msgid "To"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:741
+#: ../gui/wxpython/gui_modules/dbm.py:744
msgid "&Rename"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:797
+#: ../gui/wxpython/gui_modules/dbm.py:800
msgid "Layers of vector map"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:806
+#: ../gui/wxpython/gui_modules/dbm.py:809
msgid "List of layers"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:906
-#: ../gui/wxpython/gui_modules/dbm.py:1016
+#: ../gui/wxpython/gui_modules/dbm.py:909
+#: ../gui/wxpython/gui_modules/dbm.py:1017
msgid "Insert new record"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:907
+#: ../gui/wxpython/gui_modules/dbm.py:910
msgid "Delete selected record(s)"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:908
+#: ../gui/wxpython/gui_modules/dbm.py:911
msgid "Delete all records"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:910
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:1233
-msgid "Select all"
-msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:911
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:1234
-msgid "Deselect all"
-msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:916
-#: ../gui/wxpython/gui_modules/dbm.py:1634
-#: ../gui/wxpython/gui_modules/dbm.py:1638
+#: ../gui/wxpython/gui_modules/dbm.py:919
+#: ../gui/wxpython/gui_modules/dbm.py:1646
+#: ../gui/wxpython/gui_modules/dbm.py:1650
msgid "Extract selected"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1027
+#: ../gui/wxpython/gui_modules/dbm.py:1028
#, python-format
msgid "Record with category number %d already exists in the table."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1037
+#: ../gui/wxpython/gui_modules/dbm.py:1038
#, python-format
msgid "Category number (column %s) is missing."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1045
-#: ../gui/wxpython/gui_modules/dbm.py:1142
+#: ../gui/wxpython/gui_modules/dbm.py:1046
+#: ../gui/wxpython/gui_modules/dbm.py:1143
#, python-format
msgid "Casting value '%(value)s' to %(type)s failed."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1056
+#: ../gui/wxpython/gui_modules/dbm.py:1057
msgid "Unable to insert new record."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1121
+#: ../gui/wxpython/gui_modules/dbm.py:1122
msgid "Update existing record"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1155
+#: ../gui/wxpython/gui_modules/dbm.py:1156
msgid "Unable to update existing record."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1235
+#: ../gui/wxpython/gui_modules/dbm.py:1238
msgid "Unable to rename column. No column name defined."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1243
+#: ../gui/wxpython/gui_modules/dbm.py:1247
#, python-format
msgid ""
-"Unable to rename column <%(column)s>. Column <%(columnTo)s> already exists "
-"in the table <%(table)s>."
+"Unable to rename column <%(column)s> to <%(columnTo)s>. Column already "
+"exists in the table <%(table)s>."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1257
+#: ../gui/wxpython/gui_modules/dbm.py:1263
#, python-format
msgid ""
"Unable to rename column. Column <%(column)s> doesn't exist in the table <%"
"(table)s>."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1276
+#: ../gui/wxpython/gui_modules/dbm.py:1292
msgid "Drop selected column"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1279
+#: ../gui/wxpython/gui_modules/dbm.py:1295
msgid "Drop all columns"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1324
+#: ../gui/wxpython/gui_modules/dbm.py:1357
msgid "Unable to add column to the table. No column name defined."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1343
+#: ../gui/wxpython/gui_modules/dbm.py:1379
#, python-format
msgid "Column <%(column)s> already exists in table <%(table)s>."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1533
+#: ../gui/wxpython/gui_modules/dbm.py:1574
msgid "Database connection"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1633
+#: ../gui/wxpython/gui_modules/dbm.py:1645
msgid "Nothing to extract."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1709
-#: ../gui/wxpython/gui_modules/dbm.py:2174
-#: ../gui/wxpython/gui_modules/dbm.py:2545
+#: ../gui/wxpython/gui_modules/dbm.py:1737
+#: ../gui/wxpython/gui_modules/dbm.py:2202
+#: ../gui/wxpython/gui_modules/dbm.py:2573
#, python-format
msgid "Drop also linked attribute table (%s)"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2003
-#: ../gui/wxpython/gui_modules/dbm.py:2240
+#: ../gui/wxpython/gui_modules/dbm.py:2031
+#: ../gui/wxpython/gui_modules/dbm.py:2268
msgid "Driver"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2014
-#: ../gui/wxpython/gui_modules/dbm.py:2252
-msgid "Table"
-msgstr ""
msgid "Key"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1969
+#: ../gui/wxpython/gui_modules/dbm.py:1997
msgid ""
"Unable to determine default DB connection settings. Please define DB "
"connection using db.connect module."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1986
+#: ../gui/wxpython/gui_modules/dbm.py:2014
msgid "Add layer"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2019
-#: ../gui/wxpython/gui_modules/dbm.py:2042
-#: ../gui/wxpython/gui_modules/dbm.py:2258
+#: ../gui/wxpython/gui_modules/dbm.py:2047
+#: ../gui/wxpython/gui_modules/dbm.py:2070
+#: ../gui/wxpython/gui_modules/dbm.py:2286
msgid "Key column"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2037
+#: ../gui/wxpython/gui_modules/dbm.py:2065
msgid "Table name"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2050
+#: ../gui/wxpython/gui_modules/dbm.py:2078
msgid "&Create table"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2054
+#: ../gui/wxpython/gui_modules/dbm.py:2082
msgid "&Add layer"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2058
+#: ../gui/wxpython/gui_modules/dbm.py:2086
msgid "&Set default"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2071
+#: ../gui/wxpython/gui_modules/dbm.py:2099
msgid "Layer description"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2118
+#: ../gui/wxpython/gui_modules/dbm.py:2146
msgid "Table description"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2157
+#: ../gui/wxpython/gui_modules/dbm.py:2185
msgid "Delete selected layer"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2160
+#: ../gui/wxpython/gui_modules/dbm.py:2188
msgid "Layer to detele"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2181
+#: ../gui/wxpython/gui_modules/dbm.py:2209
msgid "&Delete layer"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2225
+#: ../gui/wxpython/gui_modules/dbm.py:2253
msgid "Modify selected layer"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2289
+#: ../gui/wxpython/gui_modules/dbm.py:2317
msgid "&Modify layer"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2417
+#: ../gui/wxpython/gui_modules/dbm.py:2445
msgid "Unable to create new table. Table name or key column name is missing."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2454
+#: ../gui/wxpython/gui_modules/dbm.py:2482
#, python-format
msgid ""
"Unable to add new layer to vector map <%(vector)s>. Layer %(layer)d already "
"exists."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2631
+#: ../gui/wxpython/gui_modules/dbm.py:2659
msgid "Database connection is not defined in DB file."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2635
+#: ../gui/wxpython/gui_modules/dbm.py:2663
#, python-format
msgid ""
"No attribute table linked to vector map <%(vector)s> found. %(msg)s\n"
@@ -4372,35 +4516,35 @@
"and link attribute table to the vector map using Attribute Table Manager."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2655
+#: ../gui/wxpython/gui_modules/dbm.py:2683
msgid "Close dialog on submit"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2662
+#: ../gui/wxpython/gui_modules/dbm.py:2690
msgid "Update attributes"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2664
+#: ../gui/wxpython/gui_modules/dbm.py:2692
msgid "Add attributes"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2666
+#: ../gui/wxpython/gui_modules/dbm.py:2694
msgid "Display attributes"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2670
+#: ../gui/wxpython/gui_modules/dbm.py:2698
msgid "&Reload"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2671
+#: ../gui/wxpython/gui_modules/dbm.py:2699
msgid "&Submit"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2886
+#: ../gui/wxpython/gui_modules/dbm.py:2917
msgid "No database record available."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:3293 ../gui/wxpython/wxgui.py:1004
+#: ../gui/wxpython/gui_modules/dbm.py:3324 ../gui/wxpython/wxgui.py:1060
msgid "GRASS GIS Attribute Table Manager"
msgstr ""
@@ -4440,305 +4584,318 @@
msgid "GRASS %s Map Calculator"
msgstr ""
-#: ../gui/wxpython/gui_modules/render.py:114
+#: ../gui/wxpython/gui_modules/render.py:124
#, python-format
msgid "<%(name)s>: layer type <%(type)s> is not supported yet."
msgstr ""
-#: ../gui/wxpython/gui_modules/render.py:264
+#: ../gui/wxpython/gui_modules/render.py:335
msgid "GISBASE not set. You must be in GRASS GIS to run this program."
msgstr ""
-#: ../gui/wxpython/gui_modules/render.py:286
+#: ../gui/wxpython/gui_modules/render.py:357
msgid "Unable to open file"
msgstr ""
-#: ../gui/wxpython/gui_modules/render.py:436
+#: ../gui/wxpython/gui_modules/render.py:511
#, python-format
msgid "Unable to zoom to raster map <%s>."
msgstr ""
-#: ../gui/wxpython/gui_modules/render.py:439
+#: ../gui/wxpython/gui_modules/render.py:514
#, python-format
msgid "Unable to zoom to vector map <%s>."
msgstr ""
-#: ../gui/wxpython/gui_modules/render.py:743
-#: ../gui/wxpython/gui_modules/render.py:806
+#: ../gui/wxpython/gui_modules/render.py:828
+#: ../gui/wxpython/gui_modules/render.py:910
#, python-format
msgid "Unable to render map layer <%s>."
msgstr ""
-#: ../gui/wxpython/gui_modules/render.py:915
-#: ../gui/wxpython/gui_modules/render.py:949
+#: ../gui/wxpython/gui_modules/render.py:1026
#, python-format
msgid "Unable render overlay <%s>."
msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:99
+#: ../gui/wxpython/gui_modules/render.py:1060
+#, python-format
+msgid "Unable render overlay <%s>"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:98
msgid "GRASS GIS Map Display: "
msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:109
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:108
msgid "Map Layers"
msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:221
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:220
msgid "Remove"
msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:232
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:231
msgid "Change opacity level"
msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:239
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:238
msgid "Properties"
msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:252
-msgid "Show attribute table"
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:251
+msgid "Show attribute data"
msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:255
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:254
msgid "Start editing"
msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:256
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:255
msgid "Stop editing"
msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:277
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:286
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:276
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:285
msgid "Metadata"
msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:315
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:314
msgid "Unable to display histogram of raster map."
msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:437
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:436
msgid "Layer group:"
msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:486
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:487
msgid "raster"
msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:489
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:492
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:495
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:498
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:501
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:504
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:507
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:510
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:513
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:516
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:519
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:522
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:490
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:493
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:496
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:499
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:502
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:505
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:508
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:511
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:514
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:517
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:520
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:523
msgid "(double click to set properties)"
msgstr ""
msgid "RGB"
msgstr ""
msgid "HIS"
msgstr ""
msgid "raster cell numbers"
msgstr ""
msgid "raster flow arrows"
msgstr ""
msgid "vector"
msgstr ""
msgid "thematic map"
msgstr ""
msgid "thematic charts"
msgstr ""
msgid "grid"
msgstr ""
msgid "geodesic line"
msgstr ""
msgid "rhumbline"
msgstr ""
msgid "vector labels"
msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:1118
-msgid "Load"
+#: ../gui/wxpython/gui_modules/toolbars.py:541
+msgid "Digitization settings"
msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:1153
-msgid "Map layer type:"
+#: ../gui/wxpython/gui_modules/toolbars.py:679
+#: ../gui/wxpython/gui_modules/toolbars.py:756
+#: ../gui/wxpython/gui_modules/toolbars.py:817
+msgid "Select vector map"
msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:1164
-msgid "Mapset:"
+#: ../gui/wxpython/gui_modules/toolbars.py:761
+#, python-format
+msgid "Do you want to save changes to vector map <%s>?"
msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:1177
-msgid "List of maps:"
+#: ../gui/wxpython/gui_modules/toolbars.py:763
+msgid "Save changes?"
msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:487
-msgid "Undo is not implemented yet."
+#: ../gui/wxpython/gui_modules/toolbars.py:823
+#: ../gui/wxpython/gui_modules/toolbars.py:828
+msgid "New vector map"
msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:500
-msgid "Digitization settings"
+#: ../gui/wxpython/gui_modules/workspace.py:180
+#, python-format
+msgid "Unable to open file <%s> for reading."
msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:638
-#: ../gui/wxpython/gui_modules/toolbars.py:764
-msgid "Select vector map"
+#: ../gui/wxpython/gui_modules/workspace.py:193
+#, python-format
+msgid ""
+"Some lines were skipped when reading settings from file <%s>.\n"
+"See 'Command output' window for details.\n"
+"\n"
+"Number of skipped lines: %d"
msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:770
-#: ../gui/wxpython/gui_modules/toolbars.py:775
-msgid "New vector map"
+#: ../gui/wxpython/gui_modules/workspace.py:351
+#, python-format
+msgid " row %d:"
msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:137
+#: ../gui/wxpython/gui_modules/goutput.py:156
msgid "Unable to run the command, another command is running..."
msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:170
+#: ../gui/wxpython/gui_modules/goutput.py:189
#, python-format
msgid "Command '%s' not yet implemented."
msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:241
+#: ../gui/wxpython/gui_modules/goutput.py:260
msgid "Save file as..."
msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:272
+#: ../gui/wxpython/gui_modules/goutput.py:292
msgid "Command aborted"
msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:276
+#: ../gui/wxpython/gui_modules/goutput.py:296
#, python-format
msgid "Command finished (%d sec)"
msgstr ""
-#: ../gui/wxpython/gis_set.py:86
+#: ../gui/wxpython/gis_set.py:83
msgid "Choose project location and mapset"
msgstr ""
-#: ../gui/wxpython/gis_set.py:89
+#: ../gui/wxpython/gis_set.py:86
msgid "Manage"
msgstr ""
-#: ../gui/wxpython/gis_set.py:91
+#: ../gui/wxpython/gis_set.py:88
#, python-format
msgid ""
"Welcome to GRASS GIS %s\n"
"The world's leading open source GIS"
msgstr ""
-#: ../gui/wxpython/gis_set.py:97
+#: ../gui/wxpython/gis_set.py:94
msgid ""
"Select an existing project location and mapset\n"
"or define a new location"
msgstr ""
-#: ../gui/wxpython/gis_set.py:103
+#: ../gui/wxpython/gis_set.py:100
msgid ""
"Project location\n"
"(projection/coordinate system)"
msgstr ""
-#: ../gui/wxpython/gis_set.py:106
+#: ../gui/wxpython/gis_set.py:103
msgid ""
"Accessible mapsets\n"
"(directories of GIS files)"
msgstr ""
-#: ../gui/wxpython/gis_set.py:109
+#: ../gui/wxpython/gis_set.py:106
msgid ""
"Create new mapset\n"
"in selected location"
msgstr ""
-#: ../gui/wxpython/gis_set.py:112
+#: ../gui/wxpython/gis_set.py:109
msgid "Define new location"
msgstr ""
-#: ../gui/wxpython/gis_set.py:115
+#: ../gui/wxpython/gis_set.py:112
msgid ""
"Rename/delete selected\n"
"mapset or location"
msgstr ""
-#: ../gui/wxpython/gis_set.py:120
+#: ../gui/wxpython/gis_set.py:117
msgid "Start GRASS"
msgstr ""
-#: ../gui/wxpython/gis_set.py:127
+#: ../gui/wxpython/gis_set.py:124
msgid "Create mapset"
msgstr ""
-#: ../gui/wxpython/gis_set.py:171
+#: ../gui/wxpython/gis_set.py:168
msgid "Welcome to GRASS GIS"
msgstr ""
-#: ../gui/wxpython/gis_set.py:179
+#: ../gui/wxpython/gis_set.py:176
msgid "Enter GRASS session"
msgstr ""
-#: ../gui/wxpython/gis_set.py:203
+#: ../gui/wxpython/gis_set.py:200
#, python-format
-msgid "ERROR: Location <%s> not found in GISDBASE (%s)"
+msgid "ERROR: Location <%s> not found"
msgstr ""
-#: ../gui/wxpython/gis_set.py:214
+#: ../gui/wxpython/gis_set.py:211
#, python-format
msgid "ERROR: Mapset <%s> not found"
msgstr ""
-#: ../gui/wxpython/gis_set.py:422 ../gui/wxpython/gis_set.py:446
+#: ../gui/wxpython/gis_set.py:419 ../gui/wxpython/gis_set.py:443
#, python-format
msgid ""
"Current name: %s\n"
"Enter new name:"
msgstr ""
-#: ../gui/wxpython/gis_set.py:423
+#: ../gui/wxpython/gis_set.py:420
msgid "Rename selected mapset"
msgstr ""
-#: ../gui/wxpython/gis_set.py:434
+#: ../gui/wxpython/gis_set.py:431
msgid "Unable to rename mapset"
msgstr ""
-#: ../gui/wxpython/gis_set.py:447
+#: ../gui/wxpython/gis_set.py:444
msgid "Rename selected location"
msgstr ""
-#: ../gui/wxpython/gis_set.py:460
+#: ../gui/wxpython/gis_set.py:457
msgid "Unable to rename location"
msgstr ""
-#: ../gui/wxpython/gis_set.py:472
+#: ../gui/wxpython/gis_set.py:469
#, python-format
msgid ""
"Do you want to continue with deleting mapset <%(mapset)s> from location <%"
@@ -4747,15 +4904,15 @@
"ALL MAPS included in this mapset will be PERMANENTLY DELETED!"
msgstr ""
-#: ../gui/wxpython/gis_set.py:477
+#: ../gui/wxpython/gis_set.py:474
msgid "Delete selected mapset"
msgstr ""
-#: ../gui/wxpython/gis_set.py:486
+#: ../gui/wxpython/gis_set.py:483
msgid "Unable to delete mapset"
msgstr ""
-#: ../gui/wxpython/gis_set.py:497
+#: ../gui/wxpython/gis_set.py:494
#, python-format
msgid ""
"Do you want to continue with deleting location <%s>?\n"
@@ -4763,24 +4920,24 @@
"ALL MAPS included in this location will be PERMANENTLY DELETED!"
msgstr ""
-#: ../gui/wxpython/gis_set.py:501
+#: ../gui/wxpython/gis_set.py:498
msgid "Delete selected location"
msgstr ""
-#: ../gui/wxpython/gis_set.py:512
+#: ../gui/wxpython/gis_set.py:509
msgid "Unable to delete location"
msgstr ""
-#: ../gui/wxpython/gis_set.py:640
+#: ../gui/wxpython/gis_set.py:653
msgid "Enter name for new mapset:"
msgstr ""
-#: ../gui/wxpython/gis_set.py:654
+#: ../gui/wxpython/gis_set.py:667
#, python-format
msgid "Unable to create new mapset: %s"
msgstr ""
-#: ../gui/wxpython/gis_set.py:685
+#: ../gui/wxpython/gis_set.py:698
msgid "GRASS Quickstart"
msgstr ""
@@ -4796,72 +4953,77 @@
msgid "Type GRASS command and run by pressing ENTER"
msgstr ""
-#: ../gui/wxpython/wxgui.py:501
+#: ../gui/wxpython/wxgui.py:505
msgid ""
"Workspace is not empty. Do you want to store current settings to workspace "
"file?"
msgstr ""
-#: ../gui/wxpython/wxgui.py:504
+#: ../gui/wxpython/wxgui.py:508
msgid "Save current settings?"
msgstr ""
-#: ../gui/wxpython/wxgui.py:519
+#: ../gui/wxpython/wxgui.py:523
msgid "Choose workspace file"
msgstr ""
-#: ../gui/wxpython/wxgui.py:580 ../gui/wxpython/wxgui.py:585
+#: ../gui/wxpython/wxgui.py:588 ../gui/wxpython/wxgui.py:593
#, python-format
msgid ""
"Reading workspace file <%s> failed. Invalid file, unable to parse XML "
"document."
msgstr ""
-#: ../gui/wxpython/wxgui.py:590 ../gui/wxpython/wxgui.py:631
+#: ../gui/wxpython/wxgui.py:598 ../gui/wxpython/wxgui.py:645
+#: ../gui/wxpython/wxgui.py:681
msgid "Please wait, loading map layers into layer tree..."
msgstr ""
-#: ../gui/wxpython/wxgui.py:615
+#: ../gui/wxpython/wxgui.py:625
msgid "Unable to read workspace file"
msgstr ""
-#: ../gui/wxpython/wxgui.py:652
+#: ../gui/wxpython/wxgui.py:665
+msgid "Choose GRC file to load"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:704
msgid "Choose file to save current workspace"
msgstr ""
-#: ../gui/wxpython/wxgui.py:667 ../gui/wxpython/wxgui.py:684
+#: ../gui/wxpython/wxgui.py:719 ../gui/wxpython/wxgui.py:736
#, python-format
msgid "Workspace file <%s> already exists. Do you want to overwrite this file?"
msgstr ""
-#: ../gui/wxpython/wxgui.py:760
+#: ../gui/wxpython/wxgui.py:812
#, python-format
msgid "Unable to open workspace file <%s> for writing."
msgstr ""
-#: ../gui/wxpython/wxgui.py:784
+#: ../gui/wxpython/wxgui.py:836
#, python-format
msgid "Writing current settings to workspace file failed (%s)."
msgstr ""
-#: ../gui/wxpython/wxgui.py:980
+#: ../gui/wxpython/wxgui.py:1036
msgid "Attribute management is available only for vector maps."
msgstr ""
-#: ../gui/wxpython/wxgui.py:1230
+#: ../gui/wxpython/wxgui.py:1330
#, python-format
msgid "Do you want to remove map layer <%s> from layer tree?"
msgstr ""
-#: ../gui/wxpython/wxgui.py:1233
+#: ../gui/wxpython/wxgui.py:1333
msgid "Do you want to remove selected map layer from layer tree?"
msgstr ""
-#: ../gui/wxpython/wxgui.py:1237
+#: ../gui/wxpython/wxgui.py:1337
msgid "Remove map layer"
msgstr ""
-#: ../gui/wxpython/wxgui.py:1267
+#: ../gui/wxpython/wxgui.py:1367
msgid "No map layer selected. Operation cancelled."
msgstr ""
