[GRASS-SVN] r31021 -
grass/branches/releasebranch_6_3/gui/tcltk/gis.m
svn_grass at osgeo.org
Thu Apr 17 06:20:46 EDT 2008
Author: marisn
Date: 2008-04-17 06:20:46 -0400 (Thu, 17 Apr 2008)
New Revision: 31021
grass/branches/releasebranch_6_3/gui/tcltk/gis.m/mapcanvas.tcl
Fix saving saving current display geometry to named region in gis.m (Ticket #112). Thanks to Ivan Shmakov for help. (merged from trunk)
Modified: grass/branches/releasebranch_6_3/gui/tcltk/gis.m/mapcanvas.tcl
--- grass/branches/releasebranch_6_3/gui/tcltk/gis.m/mapcanvas.tcl 2008-04-17 10:04:09 UTC (rev 31020)
+++ grass/branches/releasebranch_6_3/gui/tcltk/gis.m/mapcanvas.tcl 2008-04-17 10:20:46 UTC (rev 31021)
@@ -25,23 +25,23 @@
# source $gmpath/maptool.tcl
namespace eval MapCanvas {
- variable array displayrequest # Indexed by mon, true if it wants to get displayed.
+ variable array displayrequest ;# Indexed by mon, true if it wants to get displayed.
# Something's modified the canvas or view, indexed by mon.
# Degree of modification 0 - none, 1 - zoom, 2 - canvas
variable array canmodified
- variable array can # The canvas widgets of the monitors, indexed by mon
- variable array mapframe # Frame widgets, indexed by mon
- variable array canvas_w # Width and height of canvas. Indexed by mon
- variable array canvas_h # mon
- variable array driver_w # Actual width and height used while drawing / compositing. Indexed by mon
- variable array driver_h # Actual width and height used while drawing / compositing. Indexed by mon
- variable array exploremode # Whether or not to change regions to match monitor, indexed by mon
- variable array map_ind # Indicator widgets, indexed by mon
- variable array msg # status message, indexed by mon
- variable b1north # capture north coordinate on clicking mouse
- variable b1east # capture east coordinate on clicking mouse
+ variable array can ;# The canvas widgets of the monitors, indexed by mon
+ variable array mapframe ;# Frame widgets, indexed by mon
+ variable array canvas_w ;# Width and height of canvas. Indexed by mon
+ variable array canvas_h ;# mon
+ variable array driver_w ;# Actual width and height used while drawing / compositing. Indexed by mon
+ variable array driver_h ;# Actual width and height used while drawing / compositing. Indexed by mon
+ variable array exploremode ;# Whether or not to change regions to match monitor, indexed by mon
+ variable array map_ind ;# Indicator widgets, indexed by mon
+ variable array msg ;# status message, indexed by mon
+ variable b1north ;# capture north coordinate on clicking mouse
+ variable b1east ;# capture east coordinate on clicking mouse
# zoom box corners indexed by mon
@@ -83,7 +83,7 @@
# Their masks
variable array masklist
- global geoentry "" # variable holds path of entry widgets that use coordinates from canvas
+ global geoentry "" ;# variable holds path of entry widgets that use coordinates from canvas
# Current region and region historys
# Indexed by mon, history (1 (current) - zoomhistories), part (n, s, e, w, nsres, ewres, rows, cols).
@@ -1171,7 +1171,7 @@
global devnull
#get current region settings for resolution
- if {![catch {open [concat "|g.region" "-ugp" $args "2> $devnull"] r} input]} {
+ if {![catch {open [concat "|g.region" "-ugp " "2> $devnull"] r} input]} {
while {[gets $input line] >= 0} {
if { [regexp -nocase {^([a-z]+)=(.*)$} $line trash key value] } {
set parts($key) $value
@@ -1180,10 +1180,12 @@
if {[catch {close $input} error]} {
GmLib::errmsg $error [G_msg "Error reading current resolution with g.region"]
+ return
} else {
- puts $input
+ GmLib::errmsg $input [G_msg "Error reading current resolution with g.region"]
+ return
#set computational region extents while maintaining current resolution
