[GRASS-SVN] r31022 - in grass/trunk/gui/wxpython: . gui_modules
svn_grass at osgeo.org
Thu Apr 17 16:51:41 EDT 2008
Author: martinl
Date: 2008-04-17 16:51:40 -0400 (Thu, 17 Apr 2008)
New Revision: 31022
grass/trunk/gui/wxpython/gis_set.py
grass/trunk/gui/wxpython/gui_modules/mapdisp.py
wxGUI: i18n-related fixes
Modified: grass/trunk/gui/wxpython/gis_set.py
--- grass/trunk/gui/wxpython/gis_set.py 2008-04-17 10:20:46 UTC (rev 31021)
+++ grass/trunk/gui/wxpython/gis_set.py 2008-04-17 20:51:40 UTC (rev 31022)
@@ -125,8 +125,8 @@
self.bwizard = wx.Button(parent=self.panel, id=wx.ID_ANY,
label=_("Location wizard"))
self.manageloc = wx.Choice(parent=self.panel, id=wx.ID_ANY,
- choices=['Rename mapset','Rename location',
- 'Delete mapset', 'Delete location'])
+ choices=[_('Rename mapset'), _('Rename location'),
+ _('Delete mapset'), _('Delete location')])
self.manageloc.SetSelection(0)
# textinputs
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-04-17 10:20:46 UTC (rev 31021)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-04-17 20:51:40 UTC (rev 31022)
@@ -2261,15 +2261,14 @@
self.statusbar = self.CreateStatusBar(number=3, style=0)
self.statusbar.SetStatusWidths([-5, -2, -1])
self.toggleStatus = wx.Choice(self.statusbar, wx.ID_ANY,
- choices = ["Coordinates",
- "Extent",
- "Comp. region",
- "Show comp. extent",
- "Display mode",
- "Display geometry",
- "Map scale"])
- self.statusText = "Coordinates"
- self.toggleStatus.SetStringSelection(self.statusText)
+ choices = [_("Coordinates"),
+ _("Extent"),
+ _("Comp. region"),
+ _("Show comp. extent"),
+ _("Display mode"),
+ _("Display geometry"),
+ _("Map scale")])
+ self.toggleStatus.SetSelection(0)
self.statusbar.Bind(wx.EVT_CHOICE, self.OnToggleStatus, self.toggleStatus)
# auto-rendering checkbox
self.autoRender = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
@@ -2492,7 +2491,7 @@
Track mouse motion and update status bar
# update statusbar if required
- if self.statusText == "Coordinates":
+ if self.toggleStatus.GetSelection() == 0: # Coordinates
e, n = self.MapWindow.Pixel2Cell(event.GetPositionTuple())
self.statusbar.SetStatusText("%.2f, %.2f" % (e, n), 0)
@@ -2644,7 +2643,6 @@
def OnToggleStatus(self, event):
"""Toggle status text"""
- self.statusText = event.GetString()
self.StatusbarUpdate()
def OnChangeMapScale(self, event):
@@ -2681,34 +2679,34 @@
self.mapScale.Hide()
self.mapScaleValue = self.ppm = None
self.statusbar.SetStatusText("", 0)
- elif self.statusText == "Extent":
+ elif self.toggleStatus.GetSelection() == 1: # Extent
self.statusbar.SetStatusText("%.2f - %.2f, %.2f - %.2f" %
(self.Map.region["w"], self.Map.region["e"],
self.Map.region["s"], self.Map.region["n"]), 0)
- elif self.statusText == "Show comp. extent":
+ elif self.toggleStatus.GetSelection() == 2: # Show comp. extent
self.showRegion.Show()
- elif self.statusText == "Comp. region":
+ elif self.toggleStatus.GetSelection() == 3: # Comp. region
compregion = self.Map.GetRegion()
self.statusbar.SetStatusText("%.2f - %.2f, %.2f - %.2f (%.2f, %.2f)" %
(compregion["w"], compregion["e"],
compregion["s"], compregion["n"],
compregion["ewres"], compregion["nsres"]), 0)
- elif self.statusText == "Display mode":
+ elif self.toggleStatus.GetSelection() == 4: # Display mode
self.compResolution.Show()
- elif self.statusText == "Display geometry":
+ elif self.toggleStatus.GetSelection() == 5: # Display geometry
self.statusbar.SetStatusText("rows=%d; cols=%d; nsres=%.2f; ewres=%.2f" %
(self.Map.region["rows"], self.Map.region["cols"],
self.Map.region["nsres"], self.Map.region["ewres"]), 0)
- elif self.statusText == "Map scale":
+ elif self.toggleStatus.GetSelection() == 6: # Map scale
# TODO: need to be fixed...
### screen X region problem
### user should specify ppm
@@ -3415,7 +3413,6 @@
"""Set properies of map display window"""
self.autoRender.SetValue(render)
self.toggleStatus.SetSelection(mode)
- self.statusText = self.toggleStatus.GetStringSelection()
self.showRegion.SetValue(showCompExtent)
if showCompExtent:
