[GRASS-SVN] r31160 - in grass/trunk/gui/wxpython: gui_modules vdigit
svn_grass at osgeo.org
Mon Apr 28 15:27:23 EDT 2008
Author: martinl
Date: 2008-04-28 15:27:22 -0400 (Mon, 28 Apr 2008)
New Revision: 31160
Added:
grass/trunk/gui/wxpython/gui_modules/vdigit.py
Removed:
grass/trunk/gui/wxpython/gui_modules/digit.py
grass/trunk/gui/wxpython/gui_modules/__init__.py
grass/trunk/gui/wxpython/gui_modules/mapdisp.py
grass/trunk/gui/wxpython/gui_modules/preferences.py
grass/trunk/gui/wxpython/gui_modules/profile.py
grass/trunk/gui/wxpython/gui_modules/toolbars.py
grass/trunk/gui/wxpython/vdigit/line.cpp
wxGUI: sync'ed with develb6
digit module renamed to vdigit, minor fixes in vector digitizer
profile tool fixes (GUI layout), settings
Modified: grass/trunk/gui/wxpython/gui_modules/__init__.py
--- grass/trunk/gui/wxpython/gui_modules/__init__.py 2008-04-28 19:16:07 UTC (rev 31159)
+++ grass/trunk/gui/wxpython/gui_modules/__init__.py 2008-04-28 19:27:22 UTC (rev 31160)
@@ -1,6 +1,5 @@
all = [ "dbm",
"debug",
- "digit",
"disp_print",
"gcmd",
"georect",
@@ -22,5 +21,6 @@
"toolbox",
"track",
"utils",
+ "vdigit",
"workspace",
"wxgui_utils" ]
Deleted: grass/trunk/gui/wxpython/gui_modules/digit.py
--- grass/trunk/gui/wxpython/gui_modules/digit.py 2008-04-28 19:16:07 UTC (rev 31159)
+++ grass/trunk/gui/wxpython/gui_modules/digit.py 2008-04-28 19:27:22 UTC (rev 31160)
@@ -1,2578 +0,0 @@
-MODULE: digit
-CLASSES:
- * DigitError
- * AbstractDigit
- * VEdit
- * VDigit
- * AbstractDisplayDriver
- * CDisplayDriver
- * DigitSettingsDialog
- * DigitCategoryDialog
- * DigitZBulkDialog
-PURPOSE: Digitization tool wxPython GUI prototype
- Note: Initial version under development
- Progress:
- (1) v.edit called on the background (class VEdit)
- (2) Reimplentation of v.digit (VDigit)
- Import:
- from digit import Digit as Digit
-AUTHORS: The GRASS Development Team
- Martin Landa <landa.martin gmail.com>
-COPYRIGHT: (C) 2007-2008 by the GRASS Development Team
- This program is free software under the GNU General Public
- License (>=v2). Read the file COPYING that comes with GRASS
- for details.
-import os
-import sys
-import string
-import copy
-import wx
-import wx.lib.colourselect as csel
-import wx.lib.mixins.listctrl as listmix
-import gcmd
-import dbm
-from debug import Debug as Debug
-import gselect
-import globalvar
-from preferences import globalSettings as UserSettings
-try:
- digitPath = os.path.join(globalvar.ETCWXDIR, "vdigit")
- sys.path.append(digitPath)
- import grass6_wxvdigit as vdigit
- GV_LINES = vdigit.GV_LINES
- digitErr = ''
-except ImportError, err:
- GV_LINES = None
- digitErr = err
- # print >> sys.stderr, "%sWARNING: Digitization tool is disabled (%s). " \
- # "Detailed information in README file." % \
- # (os.linesep, err)
-# which interface to use?
-if UserSettings.Get(group='advanced', key='digitInterface', subkey='type') == 'vedit' and GV_LINES is not None:
- print >> sys.stderr, "%sWARNING: Digitization tool uses v.edit interface. " \
- "This can significantly slow down some operations especially for " \
- "middle-large vector maps. "\
- "You can change the digitization interface in 'User preferences' " \
- "(menu 'Config'->'Preferences')." % \
- os.linesep
-class AbstractDigit:
- Abstract digitization class
- def __init__(self, mapwindow):
- """Initialization
- @param mapwindow reference to mapwindow (MapFrame) instance
- @param settings initial settings of digitization tool
- self.map = None
- self.mapWindow = mapwindow
- Debug.msg (3, "AbstractDigit.__init__(): map=%s" % \
- self.map)
- #self.SetCategory()
- self.driver = CDisplayDriver(self, mapwindow)
- def SetCategoryNextToUse(self):
- """Find maximum category number in the map layer
- and update Digit.settings['category']
- @return 'True' on success, 'False' on failure
- # vector map layer without categories, reset to '1'
- UserSettings.Set(group='vdigit', key='category', subkey='value', value=1)
- if self.map:
- if UserSettings.Get(group='advanced', key='digitInterface', subkey='type') == 'vedit':
- categoryCmd = gcmd.Command(cmd=["v.category", "-g", "--q",
- "input=%s" % self.map,
- "option=report"])
- if categoryCmd.returncode != 0:
- return False
- for line in categoryCmd.ReadStdOutput():
- if "all" in line:
- if UserSettings.Get(group='vdigit', key='layer', subkey='value') != int(line.split(' ')[0]):
- continue
- try:
- maxCat = int(line.split(' ')[-1]) + 1
- UserSettings.Set(group='vdigit', key='category', subkey='value', value=maxCat)
- except:
- return False
- return True
- else:
- value=self.digit.GetCategory(UserSettings.Get(group='vdigit', key='layer', subkey='value') + 1))
- def SetCategory(self):
- """Return category number to use (according Settings)"""
- if UserSettings.Get(group='vdigit', key="categoryMode", subkey='value') == "No category":
- UserSettings.Set(group='vdigit', key="category", subkey='value', value=1)
- elif UserSettings.Get(group='vdigit', key="categoryMode", subkey='value') == "Next to use":
- self.SetCategoryNextToUse()
- return UserSettings.Get(group='vdigit', key="category", subkey='value')
- def SetMapName(self, map):
- """Set map name
- @param map map name to be set up or None (will close currently edited map)
- Debug.msg (3, "AbstractDigit.SetMapName map=%s" % map)
- self.map = map
- try:
- ret = self.driver.Reset(self.map)
- except StandardError, e:
- raise gcmd.DigitError('Unable to initialize display driver, '
- 'see README file for more information.%s%s'
- 'Details: %s (%s)' % (os.linesep, os.linesep, e, digitErr))
- if map and ret == -1:
- raise gcmd.DigitError(_('Unable to open vector map <%s> for editing. '
- 'Data are probably corrupted, '
- 'try to run v.build for rebuilding the topology.') % map)
- if not map and ret != 0:
- if UserSettings.Get(group='advanced', key='digitInterface', subkey='type') != 'v.edit':
- try:
- self.digit.InitCats()
- except:
- pass
- def SelectLinesByQueryThresh(self):
- """Generic method used for SelectLinesByQuery()
- -- to get threshold value"""
- thresh = 0.0
- if UserSettings.Get(group='vdigit', key='query', subkey='type') == "length":
- thresh = UserSettings.Get(group='vdigit', key='queryLength', subkey='thresh')
- if UserSettings.Get(group='vdigit', key="queryLength", subkey='than') == "shorter than":
- thresh = -1 * thresh
- else:
- thresh = UserSettings.Get(group='vdigit', key='queryDangle', subkey='thresh')
- if UserSettings.Get(group='vdigit', key="queryDangle", subkey='than') == "shorter than":
- return thresh
- def GetSelectType(self):
- """Get type(s) to be selected
- Used by SelectLinesByBox() and SelectLinesByPoint()"""
- type = 0
- for feature in (('Point', vdigit.GV_POINT),
- ('Line', vdigit.GV_LINE),
- ('Centroid', vdigit.GV_CENTROID),
- ('Boundary', vdigit.GV_BOUNDARY)):
- if UserSettings.Get(group='vdigit', key='selectFeature'+feature[0], subkey='enabled') is True:
- type |= feature[1]
- return type
- def SelectLinesFromBackgroundMap(self, pos1, pos2):
- """Select features from background map
- @param pos1,pos2 bounding box defifinition
- if UserSettings.Get(group='vdigit', key='backgroundMap', subkey='value') == '':
- Debug.msg(4, "VEdit.SelectLinesFromBackgroundMap(): []")
- return []
- x1, y1 = pos1
- x2, y2 = pos2
- vEditCmd = gcmd.Command(['v.edit',
- '--q',
- 'map=%s' % UserSettings.Get(group='vdigit', key='backgroundMap', subkey='value'),
- 'tool=select',
- 'bbox=%f,%f,%f,%f' % (pos1[0], pos1[1], pos2[0], pos2[1])])
- #'polygon=%f,%f,%f,%f,%f,%f,%f,%f,%f,%f' % \
- # (x1, y1, x2, y1, x2, y2, x1, y2, x1, y1)])
- try:
- output = vEditCmd.ReadStdOutput()[0] # first line
- ids = output.split(',')
- ids = map(int, ids) # str -> int
- except:
- return []
- Debug.msg(4, "VEdit.SelectLinesFromBackgroundMap(): %s" % \
- ",".join(["%d" % v for v in ids]))
- return ids
-class VEdit(AbstractDigit):
- Prototype of digitization class based on v.edit command
- Note: This should be replaced by VDigit class.
- """Initialization
- AbstractDigit.__init__(self, mapwindow)
- def AddPoint (self, map, point, x, y, z=None):
- """Add point/centroid
- @param point feature type (True for point, otherwise centroid)
- @param x,y,z coordinates
- if point:
- key = "P"
- else:
- key = "C"
- layer = UserSettings.Get(group='vdigit', key="layer", subkey='value')
- cat = self.SetCategory()
- if layer > 0 and cat != "None":
- addstring = "%s 1 1\n" % (key)
- else:
- addstring = "%s 1\n" % (key)
- addstring += "%f %f\n" % (x, y)
- addstring += "%d %d\n" % (layer, cat)
- Debug.msg (3, "VEdit.AddPoint(): map=%s, type=%s, layer=%d, cat=%d, x=%f, y=%f" % \
- (map, type, layer, cat, x, y))
- else:
- Debug.msg (3, "VEdit.AddPoint(): map=%s, type=%s, x=%f, y=%f" % \
- (map, type, x, y))
- Debug.msg (4, "Vline.AddPoint(): input=%s" % addstring)
- self.__AddFeature (map=map, input=addstring)
- def AddLine (self, map, line, coords):
- """Add line/boundary
- @param line feature type (True for line, otherwise boundary)
- @param list of coordinates
- if len(coords) < 2:
- return
- if line:
- key = "L"
- flags = []
- else:
- key = "B"
- flags = ['-c'] # close boundaries
- addstring = "%s %d 1\n" % (key, len(coords))
- else:
- addstring = "%s %d\n" % (key, len(coords))
- for point in coords:
- addstring += "%f %f\n" % \
- (float(point[0]), float(point [1]))
- Debug.msg (3, "Vline.AddLine(): type=%s, layer=%d, cat=%d coords=%s" % \
- (key, layer, cat, coords))
- else:
- Debug.msg (3, "Vline.AddLine(): type=%s, coords=%s" % \
- (key, coords))
- Debug.msg (4, "VEdit.AddLine(): input=%s" % addstring)
- self.__AddFeature (map=map, input=addstring, flags=flags)
- def __AddFeature (self, map, input, flags=[]):
- """Generic method to add new vector feature
- @param input feature definition in GRASS ASCII format
- @param flags additional flags
- if UserSettings.Get(group='vdigit', key='snapping', subkey='value') <= 0.0:
- snap = "no"
- else:
- if UserSettings.Get(group='vdigit', key='snapToVertex', subkey='enabled') is True:
- snap = "vertex"
- else:
- snap = "node"
- command = ["v.edit", "-n", "--q",
- "map=%s" % map,
- "tool=add",
- "thresh=%f,%f" % (self.driver.GetThreshold(type='selectThresh'), self.driver.GetThreshold(type='snapping')),
- "snap=%s" % snap]
- if UserSettings.Get(group='vdigit', key='backgroundMap', subkey='value') != '':
- command.append("bgmap=%s" % UserSettings.Get(group='vdigit', key='backgroundMap', subkey='value'))
- # additional flags
- for flag in flags:
- command.append(flag)
- # run the command
- Debug.msg(4, "VEdit.AddFeature(): input=%s" % input)
- vedit = gcmd.Command(cmd=command, stdin=input, stderr=None)
- # reload map (needed for v.edit)
- self.driver.ReloadMap()
- def DeleteSelectedLines(self):
- """Delete selected features"""
- selected = self.driver.GetSelected() # grassId
- if len(selected) <= 0:
- return False
- ids = ",".join(["%d" % v for v in selected])
- Debug.msg(4, "Digit.DeleteSelectedLines(): ids=%s" % \
- ids)
- # delete also attributes if requested
- if UserSettings.Get(group='vdigit', key='delRecord', subkey='enabled') is True:
- layerCommand = gcmd.Command(cmd=["v.db.connect",
- "-g", "--q",
- "map=%s" % self.map],
- rerr=None, stderr=None)
- if layerCommand.returncode == 0:
- layers = {}
- for line in layerCommand.ReadStdOutput():
- lineList = line.split(' ')
- layers[int(lineList[0])] = { "table" : lineList[1],
- "key" : lineList[2],
- "database" : lineList[3],
- "driver" : lineList[4] }
- for layer in layers.keys():
- printCats = gcmd.Command(['v.category',
- '--q',
- 'input=%s' % self.map,
- 'layer=%d' % layer,
- 'option=print',
- 'id=%s' % ids])
- sql = 'DELETE FROM %s WHERE' % layers[layer]['table']
- n_cats = 0
- for cat in printCats.ReadStdOutput():
- for c in cat.split('/'):
- sql += ' cat = %d or' % int(c)
- n_cats += 1
- sql = sql.rstrip(' or')
- if n_cats > 0:
- gcmd.Command(['db.execute',
- '--q',
- 'driver=%s' % layers[layer]['driver'],
- 'database=%s' % layers[layer]['database']],
- stdin=sql,
- command = [ "v.edit",
- "map=%s" % self.map,
- "tool=delete",
- "ids=%s" % ids]
- # run the command
- vedit = gcmd.Command(cmd=command, stderr=None)
- return True
- def MoveSelectedLines(self, move):
- """Move selected features
- @param move X,Y direction
- return self.__MoveFeature("move", None, move)
- def MoveSelectedVertex(self, coords, move):
- """Move selected vertex
- Feature geometry is changed.
- @param coords click coordinates
- return self.__MoveFeature("vertexmove", coords, move)
- def __MoveFeature(self, tool, coords, move):
- """Move selected vector feature (line, vertex)
- @param tool tool for v.edit
- @param move direction (x, y)
- return False
- Debug.msg(4, "Digit.MoveSelectedLines(): ids=%s, move=%s" % \
- (ids, move))
- snap = "no"
- else:
- snap = "vertex"
- else:
- snap = "node"
- command = ["v.edit", "--q",
- "tool=%s" % tool,
- "ids=%s" % ids,
- "move=%f,%f" % (float(move[0]),float(move[1])),
- "snap=%s" % snap]
- if tool == "vertexmove":
- command.append("coords=%f,%f" % (float(coords[0]), float(coords[1])))
- command.append("-1") # modify only first selected
- # run the command
- return True
- def AddVertex(self, coords):
- """Add new vertex to the selected line/boundary on position 'coords'
- @param coords coordinates to add vertex
- return self.__ModifyVertex(coords, "vertexadd")
- def RemoveVertex(self, coords):
- """Remove vertex from the selected line/boundary on position 'coords'
- @param coords coordinates to remove vertex
- return self.__ModifyVertex(coords, "vertexdel")
- def __ModifyVertex(self, coords, action):
- """Generic method for vertex manipulation
- @param action operation to perform
- try:
- line = self.driver.GetSelected()[0]
- except:
- return False
- "tool=%s" % action,
- "ids=%s" % line,
- "coords=%f,%f" % (float(coords[0]),float(coords[1])),
- "thresh=%f,%f" % (self.driver.GetThreshold(type='selectThresh'), self.driver.GetThreshold(type='snapping'))]
- # run the command
- return True
- def SplitLine(self, coords):
- """Split selected line/boundary on position 'coords'
- @param coords coordinates to split line
- try:
- except:
- return False
- "tool=break",
- "ids=%s" % line,
- "thresh=%f" % self.driver.GetThreshold(type='selectThresh')]
- # run the command
- # redraw map
- return True
- def EditLine(self, line, coords):
- """Edit existing line/boundary
- @param line id of line to be modified
- @param coords list of coordinates of modified line
- # remove line
- vEditDelete = gcmd.Command(['v.edit',
- '--q',
- 'map=%s' % self.map,
- 'tool=delete',
- 'ids=%s' % line], stderr=None)
- # add line
- if len(coords) > 0:
- self.AddLine(self.map, "line", coords)
- def __ModifyLines(self, tool):
- """Generic method to modify selected lines/boundaries
- @param tool operation to be performed by v.edit
- ids = self.driver.GetSelected()
- if len(ids) <= 0:
- return False
- vEdit = ['v.edit',
- '--q',
- 'tool=%s' % tool,
- 'ids=%s' % ",".join(["%d" % v for v in ids])]
- if tool in ['snap', 'connect']:
- vEdit.append("thresh=%f,%f" % (self.driver.GetThreshold(type='selectThresh'), self.driver.GetThreshold(type='snapping')))
- runCmd = gcmd.Command(vEdit)
- return True
- def FlipLine(self):
- """Flip selected lines/boundaries"""
- return self.__ModifyLines('flip')
- def MergeLine(self):
- """Merge selected lines/boundaries"""
- return self.__ModifyLines('merge')
- def BreakLine(self):
- """Break selected lines/boundaries"""
- return self.__ModifyLines('break')
- def SnapLine(self):
- """Snap selected lines/boundaries"""
- return self.__ModifyLines('snap')
- def ConnectLine(self):
- """Connect selected lines/boundaries"""
- return self.__ModifyLines('connect')
- def TypeConvForSelectedLines(self):
- """Feature type conversion for selected objects.
- Supported conversions:
- - point <-> centroid
- - line <-> boundary
- return self.__ModifyLines('chtype')
- def ZBulkLine(self, pos1, pos2, value, step):
- """Provide z bulk-labeling (automated assigment of z coordinate
- to 3d lines
- @param pos1,pos2 bounding box definition for selecting lines to be labeled
- @param value starting value
- @param step step value
- gcmd.Command(['v.edit',
- '--q',
- 'tool=zbulk',
- 'bbox=%f,%f,%f,%f' % (pos1[0], pos1[1], pos2[0], pos2[1]),
- 'zbulk=%f,%f' % (value, step)])
- def CopyLine(self, ids=None):
- """Copy features from (background) vector map
- @param ids list of line ids to be copied
- if not ids:
- if len(ids) <= 0:
- return False
- '--q',
- 'tool=copy',
- vEdit.append('bgmap=%s' % UserSettings.Get(group='vdigit', key='backgroundMap', subkey='value'))
- return True
- def CopyCats(self, cats, ids):
- """Copy given categories to objects with id listed in ids
- @param cats list of cats to be copied
- @param ids ids of lines to be modified
- if len(cats) == 0 or len(ids) == 0:
- return False
- # collect cats
- '--q',
- 'tool=catadd',
- 'cats=%s' % ",".join(["%d" % v for v in cats]),
- 'ids=%s' % ",".join(["%d" % v for v in ids])])
- return True
- def SelectLinesByQuery(self, pos1, pos2):
- """Select features by query
- @param pos1, pos2 bounding box definition
- thresh = self.SelectLinesByQueryThresh()
- w, n = pos1
- e, s = pos2
- if UserSettings.Get(group='vdigit', key='query', subkey='box') == False: # select globaly
- vInfo = gcmd.Command(['v.info',
- '-g'])
- for item in vInfo.ReadStdOutput():
- if 'north' in item:
- n = float(item.split('=')[1])
- elif 'south' in item:
- s = float(item.split('=')[1])
- elif 'east' in item:
- e = float(item.split('=')[1])
- elif 'west' in item:
- w = float(item.split('=')[1])
- vEdit = (['v.edit',
- '--q',
- 'tool=select',
- 'bbox=%f,%f,%f,%f' % (w, n, e, s),
- 'query=%s' % UserSettings.Get(group='vdigit', key='query', subkey='type'),
- 'thresh=0,0,%f' % thresh])
- vEditCmd = gcmd.Command(vEdit)
- try:
- except:
- return []
- Debug.msg(4, "VEdit.SelectLinesByQuery(): %s" % \
- return ids
- def GetLayers(self):
- """Return list of layers"""
- "-g", "--q",
- layers = []
- layers.append(int(lineList[0]))
- return layers
- return [1,]
- def Undo(self, level=-1):
- """Undo not implemented here"""
- wx.MessageBox(parent=self.mapWindow, message=_("Undondo is not implemented in vedit component. "
- "Use vdigit instead."),
- caption=_("Message"), style=wx.ID_OK | wx.ICON_INFORMATION | wx.CENTRE)
-class VDigit(AbstractDigit):
- Prototype of digitization class based on v.digit reimplementation
- Under development (wxWidgets C/C++ background)
- """Initialization
- try:
- self.digit = vdigit.Digit(self.driver.GetDevice())
- except (ImportError, NameError):
- self.digit = None
- self.toolbar = mapwindow.parent.digittoolbar
- def __del__(self):
- del self.digit
- """Add new point/centroid
- @param map map name (unused, for compatability with VEdit)
- @param point feature type (if true point otherwise centroid)
- if point:
- type = vdigit.GV_POINT
- else:
- type = vdigit.GV_CENTROID
- snap, thresh = self.__getSnapThreshold()
- if z:
- ret = self.digit.AddLine(type, [x, y, z], layer, cat,
- str(UserSettings.Get(group='vdigit', key="backgroundMap", subkey='value')), snap, thresh)
- else:
- ret = self.digit.AddLine(type, [x, y], layer, cat,
- if ret == -1:
- raise gcmd.DigitError, _("Adding new feature to vector map <%s> failed.") % map
- self.toolbar.EnableUndo()
- @param line feature type (if True line, otherwise boundary)
- return
- if line:
- type = vdigit.GV_LINE
- else:
- type = vdigit.GV_BOUNDARY
- listCoords = []
- for c in coords:
- for x in c:
- listCoords.append(x)
- ret = self.digit.AddLine(type, listCoords, layer, cat,
- if ret == -1:
- @return number of deleted lines
- nlines = self.digit.DeleteLines(UserSettings.Get(group='vdigit', key='delRecord', subkey='enabled'))
- if nlines > 0:
- return nlines
- nlines = self.digit.MoveLines(move[0], move[1], 0.0, # TODO 3D
- if nlines > 0:
- return nlines
- """Move selected vertex of the line
- @return 1 vertex moved
- @return 0 vertex not moved (not found, line is not selected)
- moved = self.digit.MoveVertex(coords[0], coords[1], 0.0, # TODO 3D
- move[0], move[1], 0.0,
- self.driver.GetThreshold(type='selectThresh'), thresh)
- if moved:
- return moved
- @return 1 vertex added
- @return 0 nothing changed
- @return -1 on failure
- added = self.digit.ModifyLineVertex(1, coords[0], coords[1], 0.0, # TODO 3D
- self.driver.GetThreshold(type='selectThresh'))
- if added > 0:
- return added
- @return 1 vertex removed
- deleted = self.digit.ModifyLineVertex(0, coords[0], coords[1], 0.0, # TODO 3D
- if deleted > 0:
- return deleted
- @return 1 line modified
- @return -1 error
- ret = self.digit.SplitLine(coords[0], coords[1], 0.0, # TODO 3D
- self.driver.GetThreshold('selectThresh'))
- if ret > 0:
- return ret
- @return feature id of new line
- @return -1 on error
- try:
- lineid = line[0]
- except:
- lineid = -1
- listCoords = []
- for c in coords:
- for x in c:
- ret = self.digit.RewriteLine(lineid, listCoords,
- if ret > 0:
- return ret
- @return number of modified lines
- ret = self.digit.FlipLines()
- if ret > 0:
- return ret
- ret = self.digit.MergeLines()
- if ret > 0:
- return ret
- ret = self.digit.BreakLines()
- if ret > 0:
- return ret
- @return on success
- ret = self.digit.SnapLines(thresh)
- if ret == 0:
- return ret
- @return 1 lines connected
- @return 0 lines not connected
- ret = self.digit.ConnectLines(thresh)
- if ret > 0:
- return ret
- @return number of copied features
- ret = self.digit.CopyLines(ids, str(UserSettings.Get(group='vdigit', key='backgroundMap', subkey='value')))
- if ret > 0:
- return ret
- @return number of modified features
- return 0
- ret = self.digit.CopyCats(cats, ids)
- if ret > 0:
- return ret
- w, n = pos1
- e, s = pos2
- query = vdigit.QUERY_UNKNOWN
- if UserSettings.Get(group='vdigit', key='query', subkey='type') == 'length':
- query = vdigit.QUERY_LENGTH
- elif UserSettings.Get(group='vdigit', key='query', subkey='type') == 'dangle':
- query = vdigit.QUERY_DANGLE
- type = vdigit.GV_POINTS | vdigit.GV_LINES # TODO: 3D
- ids = self.digit.SelectLinesByQuery(w, n, 0.0, e, s, 1000.0,
- UserSettings.Get(group='vdigit', key='query', subkey='box'),
- query, type, thresh)
- Debug.msg(4, "VDigit.SelectLinesByQuery(): %s" % \
- return ids
- def GetLineCats(self, line=-1):
- """Get layer/category pairs from given (selected) line
- @param line feature id (-1 for first selected line)
- return self.digit.GetLineCats(line)
- def SetLineCats(self, line, layer, cats, add=True):
- """Set categories for given line and layer
- @param layer layer number (-1 for first selected line)
- @param cats list of categories
- @param add if True to add, otherwise do delete categories
- @return new feature id (feature need to be rewritten)
- ret = self.digit.SetLineCats(line, layer, cats, add)
- if ret > 0:
- return ret
- """Get list of layers"""
- return self.digit.GetLayers()
- ret = self.digit.TypeConvLines()
- if ret > 0:
- return ret
- """Undo action
- @param level levels to undo (0 to revert all)
- @return id of current changeset
- try:
- ret = self.digit.Undo(level)
- except SystemExit:
- ret = -2
- if ret == -2:
- raise gcmd.DigitError, _("Undo failed, data corrupted.")
- self.mapWindow.UpdateMap(render=False)
- if ret < 0: # disable undo tool
- self.toolbar.EnableUndo(False)
- def __getSnapThreshold(self):
- """Get snap mode and threshold value
- @return (snap, thresh)
- thresh = self.driver.GetThreshold()
- if thresh > 0.0:
- snap = vdigit.SNAPVERTEX
- else:
- else:
- snap = v.digit.NO_SNAP
- return (snap, thresh)
-if UserSettings.Get(group='advanced', key='digitInterface', subkey='type') == 'vedit':
- class Digit(VEdit):
- """Default digit class"""
- VEdit.__init__(self, mapwindow)
- self.type = 'vedit'
-else:
- class Digit(VDigit):
- VDigit.__init__(self, mapwindow)
- self.type = 'vdigit'
- VDigit.__del__(self)
-class AbstractDisplayDriver:
- """Abstract classs for display driver"""
- def __init__(self, parent, mapwindow):
- """Initialization
- @param parent
- @param mapwindow reference to mapwindow (MFrame)
- self.parent = parent
- self.mapwindow = mapwindow
- self.ids = {} # dict[g6id] = [pdcId]
- self.selected = [] # list of selected objects (grassId!)
- def GetThreshold(self, type='snapping', value=None, units=None):
- """Return threshold in map units
- @param value threshold to be set up
- @param units units (map, screen)
- if not value:
- value = UserSettings.Get(group='vdigit', key=type, subkey='value')
- if not units:
- units = UserSettings.Get(group='vdigit', key=type, subkey='units')
- if units == "screen pixels":
- # pixel -> cell
- reg = self.mapwindow.Map.region
- if reg['nsres'] > reg['ewres']:
- res = reg['nsres']
- else:
- res = reg['ewres']
- threshold = value * res
- else:
- threshold = value
- Debug.msg(4, "AbstractDisplayDriver.GetThreshold(): type=%s, thresh=%f" % (type, threshold))
- return threshold
-class CDisplayDriver(AbstractDisplayDriver):
- Display driver using grass6_wxdriver module
- """Initialization
- @param parent
- AbstractDisplayDriver.__init__(self, parent, mapwindow)
- # initialize wx display driver
- try:
- self.__display = vdigit.DisplayDriver(mapwindow.pdcVector)
- except:
- self.__display = None
- self.UpdateSettings()
- def GetDevice(self):
- """Get device"""
- return self.__display
- def SetDevice(self, pdc):
- """Set device for driver
- @param pdc wx.PseudoDC instance
- self.__display.SetDevice(pdc)
- def Reset(self, map):
- """Reset map
- Open or close the vector map by driver.
- @param map map name or None to close the map
- @return 0 on success (close map)
- @return topo level on success (open map)
- @return non-zero (close map)
- @return -1 on error (open map)
- if map:
- name, mapset = map.split('@')
- try:
- ret = self.__display.OpenMap(str(name), str(mapset), False)
- else:
- ret = self.__display.OpenMap(str(name), str(mapset), True)
- ret = -1
- else:
- ret = self.__display.CloseMap()
- return ret
- def ReloadMap(self):
- """Reload map (close and re-open).
- Needed for v.edit, TODO: get rid of that..."""
- Debug.msg(4, "CDisplayDriver.ReloadMap():")
- self.__display.ReloadMap()
- def DrawMap(self):
- """Draw vector map layer content
- @return wx.Image instance
- nlines = self.__display.DrawMap(True) # force
- Debug.msg(3, "CDisplayDriver.DrawMap(): nlines=%d" % nlines)
- return nlines
- def SelectLinesByBox(self, begin, end, type=0):
- """Select vector features by given bounding box.
- If type is given, only vector features of given type are selected.
- @param begin,end bounding box definition
- @param type select only objects of given type
- x1, y1 = begin
- x2, y2 = end
- nselected = self.__display.SelectLinesByBox(x1, y1, -1.0 * vdigit.PORT_DOUBLE_MAX,
- x2, y2, vdigit.PORT_DOUBLE_MAX,
- type)
- Debug.msg(4, "CDisplayDriver.SelectLinesByBox(): selected=%d" % \
- nselected)
- return nselected
- def SelectLineByPoint(self, point, type=0):
- """Select vector feature by coordinates of click point (in given threshold).
- @param point click coordinates (bounding box given by threshold)
- pointOnLine = self.__display.SelectLineByPoint(point[0], point[1], 0.0,
- self.GetThreshold(type='selectThresh'),
- type, 0); # without_z
- if len(pointOnLine) > 0:
- Debug.msg(4, "CDisplayDriver.SelectLineByPoint(): pointOnLine=%f,%f" % \
- (pointOnLine[0], pointOnLine[1]))
- return pointOnLine
- else:
- Debug.msg(4, "CDisplayDriver.SelectLineByPoint(): no line found")
- return None
- def GetSelected(self, grassId=True):
- """Return ids of selected vector features
- @param grassId if grassId is True returns GRASS ids, otherwise
- internal ids of objects drawn in PseudoDC"""
- if grassId:
- selected = self.__display.GetSelected(True)
- else:
- selected = self.__display.GetSelected(False)
- Debug.msg(4, "CDisplayDriver.GetSelected(): grassId=%d, ids=%s" % \
- (grassId, (",".join(["%d" % v for v in selected]))))
- return selected
- def GetSelectedVertex(self, coords):
- """Get PseudoDC id(s) of vertex (of selected line)
- on position 'coords'
- @param coords click position
- x, y = coords
- id = self.__display.GetSelectedVertex(x, y, self.GetThreshold(type='selectThresh'))
- Debug.msg(4, "CDisplayDriver.GetSelectedVertex(): id=%s" % \
- (",".join(["%d" % v for v in id])))
- return id
- def SetSelected(self, id):
- """Set selected vector features
- @param id line id to be selected
- Debug.msg(4, "CDisplayDriver.SetSelected(): id=%s" % \
- ",".join(["%d" % v for v in id]))
- self.__display.SetSelected(id)
- def UpdateRegion(self):
- """Set geographical region
- Needed for 'cell2pixel' conversion"""
- map = self.mapwindow.Map
- reg = map.region
- self.__display.SetRegion(reg['n'],
- reg['s'],
- reg['e'],
- reg['w'],
- reg['nsres'],
- reg['ewres'],
- reg['center_easting'],
- reg['center_northing'],
- map.width, map.height)
- def GetMapBoundingBox(self):
- """Return bounding box of given vector map layer
- @return (w,s,b,e,n,t)
- return self.__display.GetMapBoundingBox()
- def UpdateSettings(self):
- """Update display driver settings"""
- # TODO map units
- if not self.__display:
- return
- self.__display.UpdateSettings (wx.Color(UserSettings.Get(group='vdigit', key='symbolHighlight', subkey='color')[0],
- UserSettings.Get(group='vdigit', key='symbolHighlight', subkey='color')[1],
- UserSettings.Get(group='vdigit', key='symbolHighlight', subkey='color')[2],
- 255).GetRGB(),
- UserSettings.Get(group='vdigit', key='symbolPoint', subkey='enabled'),
- wx.Color(UserSettings.Get(group='vdigit', key='symbolPoint', subkey='color')[0],
- UserSettings.Get(group='vdigit', key='symbolPoint', subkey='color')[1],
- UserSettings.Get(group='vdigit', key='symbolPoint', subkey='color')[2],
- 255).GetRGB(),
- UserSettings.Get(group='vdigit', key='symbolLine', subkey='enabled'),
- wx.Color(UserSettings.Get(group='vdigit', key='symbolLine', subkey='color')[0],
- UserSettings.Get(group='vdigit', key='symbolLine', subkey='color')[1],
- UserSettings.Get(group='vdigit', key='symbolLine', subkey='color')[2],
- 255).GetRGB(),
- UserSettings.Get(group='vdigit', key='symbolBoundaryNo', subkey='enabled'),
- wx.Color(UserSettings.Get(group='vdigit', key='symbolBoundaryNo', subkey='color')[0],
- UserSettings.Get(group='vdigit', key='symbolBoundaryNo', subkey='color')[1],
- UserSettings.Get(group='vdigit', key='symbolBoundaryNo', subkey='color')[2],
- 255).GetRGB(),
- UserSettings.Get(group='vdigit', key='symbolBoundaryOne', subkey='enabled'),
- wx.Color(UserSettings.Get(group='vdigit', key='symbolBoundaryOne', subkey='color')[0],
- UserSettings.Get(group='vdigit', key='symbolBoundaryOne', subkey='color')[1],
- UserSettings.Get(group='vdigit', key='symbolBoundaryOne', subkey='color')[2],
- 255).GetRGB(),
- UserSettings.Get(group='vdigit', key='symbolBoundaryTwo', subkey='enabled'),
- wx.Color(UserSettings.Get(group='vdigit', key='symbolBoundaryTwo', subkey='color')[0],
- UserSettings.Get(group='vdigit', key='symbolBoundaryTwo', subkey='color')[1],
- UserSettings.Get(group='vdigit', key='symbolBoundaryTwo', subkey='color')[2],
- 255).GetRGB(),
- UserSettings.Get(group='vdigit', key='symbolCentroidIn', subkey='enabled'),
- wx.Color(UserSettings.Get(group='vdigit', key='symbolCentroidIn', subkey='color')[0],
- UserSettings.Get(group='vdigit', key='symbolCentroidIn', subkey='color')[1],
- UserSettings.Get(group='vdigit', key='symbolCentroidIn', subkey='color')[2],
- 255).GetRGB(),
- UserSettings.Get(group='vdigit', key='symbolCentroidOut', subkey='enabled'),
- wx.Color(UserSettings.Get(group='vdigit', key='symbolCentroidOut', subkey='color')[0],
- UserSettings.Get(group='vdigit', key='symbolCentroidOut', subkey='color')[1],
- UserSettings.Get(group='vdigit', key='symbolCentroidOut', subkey='color')[2],
- 255).GetRGB(),
- UserSettings.Get(group='vdigit', key='symbolCentroidDup', subkey='enabled'),
- wx.Color(UserSettings.Get(group='vdigit', key='symbolCentroidDup', subkey='color')[0],
- UserSettings.Get(group='vdigit', key='symbolCentroidDup', subkey='color')[1],
- UserSettings.Get(group='vdigit', key='symbolCentroidDup', subkey='color')[2],
- 255).GetRGB(),
- UserSettings.Get(group='vdigit', key='symbolNodeOne', subkey='enabled'),
- wx.Color(UserSettings.Get(group='vdigit', key='symbolNodeOne', subkey='color')[0],
- UserSettings.Get(group='vdigit', key='symbolNodeOne', subkey='color')[1],
- UserSettings.Get(group='vdigit', key='symbolNodeOne', subkey='color')[2],
- 255).GetRGB(),
- UserSettings.Get(group='vdigit', key='symbolNodeTwo', subkey='enabled'),
- wx.Color(UserSettings.Get(group='vdigit', key='symbolNodeTwo', subkey='color')[0],
- UserSettings.Get(group='vdigit', key='symbolNodeTwo', subkey='color')[1],
- UserSettings.Get(group='vdigit', key='symbolNodeTwo', subkey='color')[2],
- 255).GetRGB(),
- UserSettings.Get(group='vdigit', key='symbolVertex', subkey='enabled'),
- wx.Color(UserSettings.Get(group='vdigit', key='symbolVertex', subkey='color')[0],
- UserSettings.Get(group='vdigit', key='symbolVertex', subkey='color')[1],
- UserSettings.Get(group='vdigit', key='symbolVertex', subkey='color')[2],
- 255).GetRGB(),
- UserSettings.Get(group='vdigit', key='lineWidth', subkey='value'))
-class DigitSettingsDialog(wx.Dialog):
- Standard settings dialog for digitization purposes
- def __init__(self, parent, title, style=wx.DEFAULT_DIALOG_STYLE):
- wx.Dialog.__init__(self, parent=parent, id=wx.ID_ANY, title=title, style=style)
- self.parent = parent # mapdisplay.BufferedWindow class instance
- # notebook
- notebook = wx.Notebook(parent=self, id=wx.ID_ANY, style=wx.BK_DEFAULT)
- self.__CreateSymbologyPage(notebook)
- parent.digit.SetCategory() # update category number (next to use)
- self.__CreateGeneralPage(notebook)
- self.__CreateAttributesPage(notebook)
- self.__CreateQueryPage(notebook)
- # buttons
- btnApply = wx.Button(self, wx.ID_APPLY)
- btnCancel = wx.Button(self, wx.ID_CANCEL)
- btnSave = wx.Button(self, wx.ID_SAVE)
- btnSave.SetDefault()
- # bindigs
- btnApply.Bind(wx.EVT_BUTTON, self.OnApply)
- btnApply.SetToolTipString(_("Apply changes for this session"))
- btnApply.SetDefault()
- btnSave.Bind(wx.EVT_BUTTON, self.OnSave)
- btnSave.SetToolTipString(_("Close dialog and save changes to user settings file"))
- btnCancel.Bind(wx.EVT_BUTTON, self.OnCancel)
- btnCancel.SetToolTipString(_("Close dialog and ignore changes"))
- # sizers
- btnSizer = wx.StdDialogButtonSizer()
- btnSizer.AddButton(btnCancel)
- btnSizer.AddButton(btnApply)
- btnSizer.AddButton(btnSave)
- btnSizer.Realize()
- mainSizer = wx.BoxSizer(wx.VERTICAL)
- mainSizer.Add(item=notebook, proportion=1, flag=wx.EXPAND | wx.ALL, border=5)
- mainSizer.Add(item=btnSizer, proportion=0,
- flag=wx.EXPAND | wx.ALL | wx.ALIGN_CENTER, border=5)
- self.SetSizer(mainSizer)
- mainSizer.Fit(self)
- def __CreateSymbologyPage(self, notebook):
- """Create notebook page concerning with symbology settings"""
- panel = wx.Panel(parent=notebook, id=wx.ID_ANY)
- notebook.AddPage(page=panel, text=_("Symbology"))
- sizer = wx.BoxSizer(wx.VERTICAL)
- flexSizer = wx.FlexGridSizer (cols=3, hgap=5, vgap=5)
- flexSizer.AddGrowableCol(0)
- self.symbology = {}
- for label, key in self.__SymbologyData():
- textLabel = wx.StaticText(panel, wx.ID_ANY, label)
- color = csel.ColourSelect(panel, id=wx.ID_ANY,
- colour=UserSettings.Get(group='vdigit', key=key, subkey='color'), size=(25, 25))
- isEnabled = UserSettings.Get(group='vdigit', key=key, subkey='enabled')
- if isEnabled is not None:
- enabled = wx.CheckBox(panel, id=wx.ID_ANY, label="")
- enabled.SetValue(isEnabled)
- self.symbology[key] = (enabled, color)
- else:
- enabled = (1, 1)
- self.symbology[key] = (None, color)
- flexSizer.Add(textLabel, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
- flexSizer.Add(enabled, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
- flexSizer.Add(color, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
- sizer.Add(item=flexSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=10)
- panel.SetSizer(sizer)
- return panel
- def __CreateGeneralPage(self, notebook):
- notebook.AddPage(page=panel, text=_("General"))
- border = wx.BoxSizer(wx.VERTICAL)
- # display section
- box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Display"))
- sizer = wx.StaticBoxSizer(box, wx.VERTICAL)
- # line width
- text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Line width"))
- self.lineWidthValue = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(75, -1),
- initial=UserSettings.Get(group='vdigit', key="lineWidth", subkey='value'),
- min=1, max=1e6)
- units = wx.StaticText(parent=panel, id=wx.ID_ANY, size=(115, -1),
- label=UserSettings.Get(group='vdigit', key="lineWidth", subkey='units'),
- style=wx.ALIGN_LEFT)
- flexSizer.Add(text, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
- flexSizer.Add(self.lineWidthValue, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
- flexSizer.Add(units, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE | wx.ALIGN_CENTER_VERTICAL | wx.LEFT,
- border=10)
- sizer.Add(item=flexSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=1)
- border.Add(item=sizer, proportion=0, flag=wx.ALL | wx.EXPAND, border=5)
- # snapping section
- box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Snapping"))
- flexSizer1 = wx.FlexGridSizer (cols=3, hgap=5, vgap=5)
- flexSizer1.AddGrowableCol(0)
- flexSizer2 = wx.FlexGridSizer (cols=2, hgap=5, vgap=5)
- flexSizer2.AddGrowableCol(0)
- # snapping
- text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Snapping threshold"))
- self.snappingValue = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(75, -1),
- initial=UserSettings.Get(group='vdigit', key="snapping", subkey='value'),
- min=1, max=1e6)
- self.snappingValue.Bind(wx.EVT_SPINCTRL, self.OnChangeSnappingValue)
- self.snappingUnit = wx.Choice(parent=panel, id=wx.ID_ANY, size=(125, -1),
- choices=["screen pixels", "map units"])
- self.snappingUnit.SetStringSelection(UserSettings.Get(group='vdigit', key="snapping", subkey='units'))
- self.snappingUnit.Bind(wx.EVT_CHOICE, self.OnChangeSnappingUnits)
- flexSizer1.Add(text, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
- flexSizer1.Add(self.snappingValue, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
- flexSizer1.Add(self.snappingUnit, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
- # background map
- text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Backgroud vector map"))
- self.backgroundMap = gselect.Select(parent=panel, id=wx.ID_ANY, size=(200,-1),
- type="vector")
- self.backgroundMap.SetValue(UserSettings.Get(group='vdigit', key="backgroundMap", subkey='value'))
- self.backgroundMap.Bind(wx.EVT_TEXT, self.OnChangeBackgroundMap)
- flexSizer2.Add(text, proportion=1, flag=wx.ALIGN_CENTER_VERTICAL)
- flexSizer2.Add(self.backgroundMap, proportion=1, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
- #flexSizer.Add(self.snappingUnit, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
- vertexSizer = wx.BoxSizer(wx.VERTICAL)
- self.snapVertex = wx.CheckBox(parent=panel, id=wx.ID_ANY,
- label=_("Snap also to vertex"))
- self.snapVertex.SetValue(UserSettings.Get(group='vdigit', key="snapToVertex", subkey='enabled'))
- vertexSizer.Add(item=self.snapVertex, proportion=0, flag=wx.EXPAND)
- self.mapUnits = self.parent.MapWindow.Map.ProjInfo()['units']
- self.snappingInfo = wx.StaticText(parent=panel, id=wx.ID_ANY,
- label=_("Snapping threshold is %(value).1f %(units)s") % \
- {'value' : self.parent.digit.driver.GetThreshold(),
- 'units' : self.mapUnits})
- vertexSizer.Add(item=self.snappingInfo, proportion=0,
- flag=wx.ALL | wx.EXPAND, border=1)
- sizer.Add(item=flexSizer1, proportion=1, flag=wx.TOP | wx.LEFT | wx.EXPAND, border=1)
- sizer.Add(item=flexSizer2, proportion=1, flag=wx.TOP | wx.LEFT | wx.EXPAND, border=1)
- sizer.Add(item=vertexSizer, proportion=1, flag=wx.BOTTOM | wx.LEFT | wx.EXPAND, border=1)
- border.Add(item=sizer, proportion=0, flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border=5)
- # select box
- box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Select vector features"))
- # feature type
- inSizer = wx.BoxSizer(wx.HORIZONTAL)
- self.selectFeature = {}
- for feature in ('Point', 'Line',
- 'Centroid', 'Boundary'):
- chkbox = wx.CheckBox(parent=panel, label=feature)
- self.selectFeature[feature] = chkbox.GetId()
- chkbox.SetValue(UserSettings.Get(group='vdigit', key='selectFeature'+feature, subkey='enabled'))
- inSizer.Add(item=chkbox, proportion=0,
- flag=wx.EXPAND | wx.ALL, border=5)
- sizer.Add(item=inSizer, proportion=0, flag=wx.EXPAND)
- # threshold
- text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Select threshold"))
- self.selectThreshValue = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(75, -1),
- initial=UserSettings.Get(group='vdigit', key="selectThresh", subkey='value'),
- min=1, max=1e6)
- flexSizer.Add(self.selectThreshValue, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
- border=10)
- sizer.Add(item=flexSizer, proportion=0, flag=wx.EXPAND)
- border.Add(item=sizer, proportion=0, flag=wx.EXPAND | wx.LEFT | wx.RIGHT | wx.BOTTOM, border=5)
- # save-on-exit box
- box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Save changes"))
- # save changes on exit?
- self.save = wx.CheckBox(parent=panel, label=_("Save changes on exit automatically"))
- self.save.SetValue(UserSettings.Get(group='vdigit', key='saveOnExit', subkey='enabled'))
- sizer.Add(item=self.save, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
- panel.SetSizer(border)
- return panel
- def __CreateQueryPage(self, notebook):
- """Create notebook page for query tool"""
- notebook.AddPage(page=panel, text=_("Query tool"))
- # query tool box
- box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Choose query tool"))
- LocUnits = self.parent.MapWindow.Map.ProjInfo()['units']
- self.queryBox = wx.CheckBox(parent=panel, id=wx.ID_ANY, label=_("Select by box"))
- self.queryBox.SetValue(UserSettings.Get(group='vdigit', key="query", subkey='box'))
- sizer.Add(item=self.queryBox, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
- sizer.Add((0, 5))
- # length
- self.queryLength = wx.RadioButton(parent=panel, id=wx.ID_ANY, label=_("length"))
- self.queryLength.Bind(wx.EVT_RADIOBUTTON, self.OnChangeQuery)
- sizer.Add(item=self.queryLength, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
- flexSizer = wx.FlexGridSizer (cols=4, hgap=5, vgap=5)
- txt = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Select lines"))
- self.queryLengthSL = wx.Choice (parent=panel, id=wx.ID_ANY,
- choices = [_("shorter than"), _("longer than")])
- self.queryLengthSL.SetStringSelection(UserSettings.Get(group='vdigit', key="queryLength", subkey='than'))
- self.queryLengthValue = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(100, -1),
- initial=1,
- min=0, max=1e6)
- self.queryLengthValue.SetValue(UserSettings.Get(group='vdigit', key="queryLength", subkey='thresh'))
- units = wx.StaticText(parent=panel, id=wx.ID_ANY, label="%s" % LocUnits)
- flexSizer.Add(txt, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
- flexSizer.Add(self.queryLengthSL, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
- flexSizer.Add(self.queryLengthValue, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
- flexSizer.Add(units, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
- sizer.Add(item=flexSizer, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
- # dangle
- self.queryDangle = wx.RadioButton(parent=panel, id=wx.ID_ANY, label=_("dangle"))
- self.queryDangle.Bind(wx.EVT_RADIOBUTTON, self.OnChangeQuery)
- sizer.Add(item=self.queryDangle, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
- txt = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Select dangles"))
- self.queryDangleSL = wx.Choice (parent=panel, id=wx.ID_ANY,
- self.queryDangleSL.SetStringSelection(UserSettings.Get(group='vdigit', key="queryDangle", subkey='than'))
- self.queryDangleValue = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(100, -1),
- initial=1,
- min=0, max=1e6)
- self.queryDangleValue.SetValue(UserSettings.Get(group='vdigit', key="queryDangle", subkey='thresh'))
- flexSizer.Add(self.queryDangleSL, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
- flexSizer.Add(self.queryDangleValue, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
- if UserSettings.Get(group='vdigit', key="query", subkey='type') == "length":
- self.queryLength.SetValue(True)
- else:
- self.queryDangle.SetValue(True)
- # enable & disable items
- self.OnChangeQuery(None)
- return panel
- def __CreateAttributesPage(self, notebook):
- notebook.AddPage(page=panel, text=_("Attributes"))
- # add new record
- box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Digitize new feature"))
- # checkbox
- self.addRecord = wx.CheckBox(parent=panel, id=wx.ID_ANY,
- label=_("Add new record into table"))
- self.addRecord.SetValue(UserSettings.Get(group='vdigit', key="addRecord", subkey='enabled'))
- sizer.Add(item=self.addRecord, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
- # settings
- flexSizer = wx.FlexGridSizer(cols=2, hgap=3, vgap=3)
- settings = ((_("Layer"), 1), (_("Category"), 1), (_("Mode"), _("Next to use")))
- # layer
- text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Layer"))
- if self.parent.digit.map:
- layers = map(str, self.parent.digit.GetLayers())
- if len(layers) == 0:
- layers = [str(UserSettings.Get(group='vdigit', key="layer", subkey='value')), ]
- else:
- self.layer = wx.Choice(parent=panel, id=wx.ID_ANY, size=(125, -1),
- choices=layers)
- self.layer.SetStringSelection(str(UserSettings.Get(group='vdigit', key="layer", subkey='value')))
- flexSizer.Add(item=text, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
- flexSizer.Add(item=self.layer, proportion=0,
- flag=wx.FIXED_MINSIZE | wx.ALIGN_CENTER_VERTICAL)
- # category number
- text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Category number"))
- self.category = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(125, -1),
- initial=UserSettings.Get(group='vdigit', key="category", subkey='value'),
- min=-1e9, max=1e9)
- if UserSettings.Get(group='vdigit', key="categoryMode", subkey='value') != "Manual entry":
- self.category.Enable(False)
- flexSizer.Add(item=self.category, proportion=0,
- # category mode
- text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Category mode"))
- self.categoryMode = wx.Choice(parent=panel, id=wx.ID_ANY, size=(125, -1),
- choices=[_("Next to use"), _("Manual entry"), _("No category")])
- self.categoryMode.SetStringSelection(UserSettings.Get(group='vdigit', key="categoryMode", subkey='value'))
- flexSizer.Add(item=self.categoryMode, proportion=0,
- flag=wx.ALL | wx.EXPAND, border=5)
- # delete existing record
- box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Delete existing feature(s)"))
- # checkbox
- self.deleteRecord = wx.CheckBox(parent=panel, id=wx.ID_ANY,
- label=_("Delete record from table"))
- self.deleteRecord.SetValue(UserSettings.Get(group='vdigit', key="delRecord", subkey='enabled'))
- sizer.Add(item=self.deleteRecord, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
- flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border=5)
- # bindings
- self.Bind(wx.EVT_CHECKBOX, self.OnChangeAddRecord, self.addRecord)
- self.Bind(wx.EVT_CHOICE, self.OnChangeCategoryMode, self.categoryMode)
- self.Bind(wx.EVT_CHOICE, self.OnChangeLayer, self.layer)
- return panel
- def __SymbologyData(self):
- Data for __CreateSymbologyPage()
- label | checkbox | color
- return (
- # ("Background", "symbolBackground"),
- ("Highlight", "symbolHighlight"),
- ("Point", "symbolPoint"),
- ("Line", "symbolLine"),
- ("Boundary (no area)", "symbolBoundaryNo"),
- ("Boundary (one area)", "symbolBoundaryOne"),
- ("Boundary (two areas)", "symbolBoundaryTwo"),
- ("Centroid (in area)", "symbolCentroidIn"),
- ("Centroid (outside area)", "symbolCentroidOut"),
- ("Centroid (duplicate in area)", "symbolCentroidDup"),
- ("Node (one line)", "symbolNodeOne"),
- ("Node (two lines)", "symbolNodeTwo"),
- ("Vertex", "symbolVertex"))
- def OnChangeCategoryMode(self, event):
- """Change category mode"""
- mode = event.GetString()
- UserSettings.Set(group='vdigit', key="categoryMode", subkey='value', value=mode)
- if mode == "Manual entry": # enable
- self.category.Enable(True)
- elif self.category.IsEnabled(): # disable
- if mode == "No category" and self.addRecord.IsChecked():
- self.addRecord.SetValue(False)
- self.parent.digit.SetCategory()
- self.category.SetValue(UserSettings.Get(group='vdigit', key='category', subkey='value'))
- def OnChangeLayer(self, event):
- """Layer changed"""
- layer = int(event.GetString())
- if layer > 0:
- UserSettings.Set(group='vdigit', key='layer', subkey='value', value=layer)
- event.Skip()
- def OnChangeAddRecord(self, event):
- """Checkbox 'Add new record' status changed"""
- self.category.SetValue(self.parent.digit.SetCategory())
- def OnChangeSnappingValue(self, event):
- """Change snapping value - update static text"""
- value = self.snappingValue.GetValue()
- if self.snappingUnit.GetStringSelection() == "map units":
- threshold = value
- else:
- threshold = self.parent.digit.driver.GetThreshold(value=value)
- self.snappingInfo.SetLabel(_("Snapping threshold is %(value).1f %(units)s") %
- {'value' : threshold,
- event.Skip()
- def OnChangeSnappingUnits(self, event):
- """Snapping units change -> update static text"""
- units = self.snappingUnit.GetStringSelection()
- threshold = self.parent.digit.driver.GetThreshold(value=value, units=units)
- if units == "map units":
- {'value' : value,
- else:
- event.Skip()
- def OnChangeBackgroundMap(self, event):
- """Change background map"""
- map = self.backgroundMap.GetValue()
- UserSettings.Set(group='vdigit', key='backgroundMap', subkey='value', value=map)
- def OnChangeQuery(self, event):
- """Change query"""
- if self.queryLength.GetValue():
- # length
- self.queryLengthSL.Enable(True)
- self.queryLengthValue.Enable(True)
- self.queryDangleSL.Enable(False)
- self.queryDangleValue.Enable(False)
- else:
- # dangle
- self.queryLengthSL.Enable(False)
- self.queryLengthValue.Enable(False)
- self.queryDangleSL.Enable(True)
- self.queryDangleValue.Enable(True)
- def OnSave(self, event):
- """Button 'Save' clicked"""
- self.parent.digittoolbar.settingsDialog = None
- fileSettings = {}
- UserSettings.ReadSettingsFile(settings=fileSettings)
- fileSettings['vdigit'] = UserSettings.Get(group='vdigit')
- file = UserSettings.SaveToFile(fileSettings)
- self.parent.gismanager.goutput.WriteLog('Vector digitizer settings saved to file <%s>.' % file)
- self.Close()
- def OnApply(self, event):
- """Button 'Apply' clicked"""
- def OnCancel(self, event):
- """Button 'Cancel' clicked"""
- self.Close()
- """Update UserSettings"""
- # symbology
- for key, (enabled, color) in self.symbology.iteritems():
- if enabled:
- UserSettings.Set(group='vdigit', key=key, subkey='enabled', value=enabled.IsChecked())
- UserSettings.Set(group='vdigit', key=key, subkey='color', value=color.GetColour())
- else:
- # display
- UserSettings.Set(group='vdigit', key="lineWidth", subkey='value', value=int(self.lineWidthValue.GetValue()))
- # snapping
- UserSettings.Set(group='vdigit', key="snapping", subkey='value', value=int(self.snappingValue.GetValue()))
- UserSettings.Set(group='vdigit', key="snapping", subkey='units', value=self.snappingUnit.GetStringSelection())
- UserSettings.Set(group='vdigit', key="snapToVertex", subkey='enabled', value=self.snapVertex.IsChecked())
- # digitize new feature
- UserSettings.Set(group='vdigit', key="addRecord", subkey='enabled', value=self.addRecord.IsChecked())
- UserSettings.Set(group='vdigit', key="layer", subkey='value', value=int(self.layer.GetStringSelection()))
- UserSettings.Set(group='vdigit', key="category", subkey='value', value=None)
- else:
- UserSettings.Set(group='vdigit', key="category", subkey='value', value=int(self.category.GetValue()))
- UserSettings.Set(group='vdigit', key="categoryMode", subkey='value', value=self.categoryMode.GetStringSelection())
- # delete existing feature
- UserSettings.Set(group='vdigit', key="delRecord", subkey='enabled', value=self.deleteRecord.IsChecked())
- # snapping threshold
- self.parent.digit.threshold = self.parent.digit.driver.GetThreshold()
- # query tool
- UserSettings.Set(group='vdigit', key="query", subkey='type', value="length")
- else:
- UserSettings.Set(group='vdigit', key="query", subkey='type', value="dangle")
- UserSettings.Set(group='vdigit', key="query", subkey='box', value=self.queryBox.IsChecked())
- UserSettings.Set(group='vdigit', key="queryLength", subkey='than', value=self.queryLengthSL.GetStringSelection())
- UserSettings.Set(group='vdigit', key="queryLength", subkey='thresh', value=int(self.queryLengthValue.GetValue()))
- UserSettings.Set(group='vdigit', key="queryDangle", subkey='than', value=self.queryDangleSL.GetStringSelection())
- UserSettings.Set(group='vdigit', key="queryDangle", subkey='thresh', value=int(self.queryDangleValue.GetValue()))
- # select features
- UserSettings.Set(group='vdigit', key='selectFeature'+feature, subkey='enabled',
- value=self.FindWindowById(self.selectFeature[feature]).IsChecked())
- UserSettings.Set(group='vdigit', key="selectThresh", subkey='value', value=int(self.selectThreshValue.GetValue()))
- # on-exit
- UserSettings.Set(group='vdigit', key="saveOnExit", subkey='enabled', value=self.save.IsChecked())
- # update driver settings
- self.parent.digit.driver.UpdateSettings()
- # redraw map if auto-rendering is enabled
- if self.parent.autoRender.GetValue():
- self.parent.OnRender(None)
-class DigitCategoryDialog(wx.Dialog, listmix.ColumnSorterMixin):
- Dialog used to display/modify categories of vector objects
- @param parent
- @param title dialog title
- @param query {coordinates, qdist} - v.edit/v.what
- @param cats directory of categories - vdigit
- @param line line id - vdigit
- @param pos
- @param style
- map, query=None, cats=None, line=None,
- pos=wx.DefaultPosition,
- style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
- # parent
- # map name
- self.map = map
- # line id (if not found remains 'None')
- self.line = None
- # {layer: [categories]}
- self.cats = {}
- # do not display dialog if no line is found (-> self.cats)
- if cats is None:
- if self.__GetCategories(query[0], query[1]) == 0 or not self.line:
- Debug.msg(3, "DigitCategoryDialog(): nothing found!")
- return
- else:
- # self.cats = dict(cats)
- for layer in cats.keys():
- self.cats[layer] = list(cats[layer]) # TODO: tuple to list
- self.line = line
- # make copy of cats (used for 'reload')
- self.cats_orig = copy.deepcopy(self.cats)
- Debug.msg(3, "DigitCategoryDialog(): line=%d, cats=%s" % \
- (self.line, self.cats))
- wx.Dialog.__init__(self, parent=self.parent, id=wx.ID_ANY, title=title,
- style=style, pos=pos)
- # list of categories
- box = wx.StaticBox(parent=self, id=wx.ID_ANY,
- label=" %s " % _("List of categories"))
- listSizer = wx.StaticBoxSizer(box, wx.VERTICAL)
- self.list = CategoryListCtrl(parent=self, id=wx.ID_ANY,
- style=wx.LC_REPORT |
- wx.BORDER_NONE |
- wx.LC_SORT_ASCENDING |
- wx.LC_HRULES |
- wx.LC_VRULES)
- # sorter
- self.itemDataMap = self.list.Populate()
- listmix.ColumnSorterMixin.__init__(self, 2)
- listSizer.Add(item=self.list, proportion=1, flag=wx.EXPAND)
- # add new category
- label=" %s " % _("Add new category"))
- addSizer = wx.StaticBoxSizer(box, wx.VERTICAL)
- flexSizer = wx.FlexGridSizer (cols=5, hgap=5, vgap=5)
- flexSizer.AddGrowableCol(3)
- layerNewTxt = wx.StaticText(parent=self, id=wx.ID_ANY,
- label="%s:" % _("Layer"))
- self.layerNew = wx.SpinCtrl(parent=self, id=wx.ID_ANY, size=(50, -1),
- initial=1, min=1, max=1e9)
- catNewTxt = wx.StaticText(parent=self, id=wx.ID_ANY,
- label="%s:" % _("Category"))
- try:
- newCat = max(self.cats[1]) + 1
- except:
- newCat = 1
- self.catNew = wx.SpinCtrl(parent=self, id=wx.ID_ANY, size=(75, -1),
- initial=newCat, min=-1e9, max=1e9)
- btnAddCat = wx.Button(self, wx.ID_ADD)
- flexSizer.Add(item=layerNewTxt, proportion=0,
- flexSizer.Add(item=self.layerNew, proportion=0,
- flexSizer.Add(item=catNewTxt, proportion=0,
- flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT | wx.LEFT,
- border=10)
- flexSizer.Add(item=self.catNew, proportion=0,
- flexSizer.Add(item=btnAddCat, proportion=0,
- flag=wx.EXPAND | wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
- addSizer.Add(item=flexSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=5)
- # buttons
- #btnReload = wx.Button(self, wx.ID_UNDO, _("&Reload"))
- btnOk = wx.Button(self, wx.ID_OK)
- btnOk.SetDefault()
- # sizers
- #btnSizer.AddButton(btnReload)
- #btnSizer.SetNegativeButton(btnReload)
- btnSizer.AddButton(btnOk)
- mainSizer.Add(item=listSizer, proportion=1,
- mainSizer.Add(item=addSizer, proportion=0,
- flag=wx.EXPAND | wx.ALIGN_CENTER |
- wx.LEFT | wx.RIGHT | wx.BOTTOM, border=5)
- self.SetAutoLayout(True)
- # set min size for dialog
- self.SetMinSize(self.GetBestSize())
- # bindings
- # buttons
- #btnReload.Bind(wx.EVT_BUTTON, self.OnReload)
- btnOk.Bind(wx.EVT_BUTTON, self.OnOK)
- btnAddCat.Bind(wx.EVT_BUTTON, self.OnAddCat)
- # list
- # self.Bind(wx.EVT_LIST_ITEM_SELECTED, self.OnItemSelected, self.list)
- # self.list.Bind(wx.EVT_RIGHT_DOWN, self.OnRightDown)
- self.list.Bind(wx.EVT_COMMAND_RIGHT_CLICK, self.OnRightUp) #wxMSW
- self.list.Bind(wx.EVT_RIGHT_UP, self.OnRightUp) #wxGTK
- self.Bind(wx.EVT_LIST_BEGIN_LABEL_EDIT, self.OnBeginEdit, self.list)
- self.Bind(wx.EVT_LIST_END_LABEL_EDIT, self.OnEndEdit, self.list)
- self.Bind(wx.EVT_LIST_COL_CLICK, self.OnColClick, self.list)
- def GetListCtrl(self):
- """Used by ColumnSorterMixin"""
- return self.list
- def OnColClick(self, event):
- """Click on column header (order by)"""
- event.Skip()
- def OnBeginEdit(self, event):
- """Editing of item started"""
- event.Allow()
- def OnEndEdit(self, event):
- """Finish editing of item"""
- itemIndex = event.GetIndex()
- layerOld = int (self.list.GetItem(itemIndex, 0).GetText())
- catOld = int (self.list.GetItem(itemIndex, 1).GetText())
- if event.GetColumn() == 0:
- layerNew = int(event.GetLabel())
- catNew = catOld
- else:
- layerNew = layerOld
- catNew = int(event.GetLabel())
- try:
- if layerNew not in self.cats.keys():
- self.cats[layerNew] = []
- self.cats[layerNew].append(catNew)
- self.cats[layerOld].remove(catOld)
- except:
- event.Veto()
- self.list.SetStringItem(itemIndex, 0, str(layerNew))
- self.list.SetStringItem(itemIndex, 1, str(catNew))
- dlg = wx.MessageDialog(self, _("Unable to add new layer/category <%(layer)s/%(category)s>.\n"
- "Layer and category number must be integer.\n"
- "Layer number must be greater then zero.") %
- { 'layer': str(self.layerNew.GetValue()),
- 'category' : str(self.catNew.GetValue()) },
- _("Error"), wx.OK | wx.ICON_ERROR)
- dlg.ShowModal()
- dlg.Destroy()
- return False
- def OnRightDown(self, event):
- """Mouse right button down"""
- x = event.GetX()
- y = event.GetY()
- item, flags = self.list.HitTest((x, y))
- if item != wx.NOT_FOUND and \
- flags & wx.LIST_HITTEST_ONITEM:
- self.list.Select(item)
- event.Skip()
- def OnRightUp(self, event):
- """Mouse right button up"""
- if not hasattr(self, "popupID1"):
- self.popupID1 = wx.NewId()
- self.popupID2 = wx.NewId()
- self.popupID3 = wx.NewId()
- self.Bind(wx.EVT_MENU, self.OnItemDelete, id=self.popupID1)
- self.Bind(wx.EVT_MENU, self.OnItemDeleteAll, id=self.popupID2)
- self.Bind(wx.EVT_MENU, self.OnReload, id=self.popupID3)
- # generate popup-menu
- menu = wx.Menu()
- menu.Append(self.popupID1, _("Delete selected"))
- if self.list.GetFirstSelected() == -1:
- menu.Enable(self.popupID1, False)
- menu.Append(self.popupID2, _("Delete all"))
- menu.AppendSeparator()
- menu.Append(self.popupID3, _("Reload"))
- self.PopupMenu(menu)
- menu.Destroy()
- def OnItemSelected(self, event):
- """Item selected"""
- event.Skip()
- def OnItemDelete(self, event):
- """Delete selected item(s) from the list (layer/category pair)"""
- item = self.list.GetFirstSelected()
- while item != -1:
- layer = int (self.list.GetItem(item, 0).GetText())
- cat = int (self.list.GetItem(item, 1).GetText())
- self.list.DeleteItem(item)
- self.cats[layer].remove(cat)
- event.Skip()
- def OnItemDeleteAll(self, event):
- """Delete all items from the list"""
- self.list.DeleteAllItems()
- self.cats = {}
- event.Skip()
- def __GetCategories(self, coords, qdist):
- """Get layer/category pairs for all available
- layers
- Return True line found or False if not found"""
- cmdWhat = gcmd.Command(cmd=['v.what',
- '--q',
- 'east_north=%f,%f' % \
- (float(coords[0]), float(coords[1])),
- 'distance=%f' % qdist])
- if cmdWhat.returncode != 0:
- return False
- for item in cmdWhat.ReadStdOutput():
- litem = item.lower()
- if "line:" in litem: # get line id
- self.line = int(item.split(':')[1].strip())
- elif "layer:" in litem: # add layer
- layer = int(item.split(':')[1].strip())
- if layer not in self.cats.keys():
- self.cats[layer] = []
- elif "category:" in litem: # add category
- self.cats[layer].append(int(item.split(':')[1].strip()))
- return True
- def OnReload(self, event):
- """Reload button pressed"""
- # restore original list
- self.cats = copy.deepcopy(self.cats_orig)
- # polulate list
- self.itemDataMap = self.list.Populate(update=True)
- event.Skip()
- """Cancel button pressed"""
- self.parent.parent.dialogs['category'] = None
- if self.parent.parent.digit:
- self.parent.parent.digit.driver.SetSelected([])
- self.parent.UpdateMap(render=False)
- else:
- self.parent.parent.OnRender(None)
- self.Close()
- """Apply button pressed"""
- # action : (catsFrom, catsTo)
- check = {'catadd': (self.cats, self.cats_orig),
- 'catdel': (self.cats_orig, self.cats)}
- # add/delete new category
- for action, cats in check.iteritems():
- for layer in cats[0].keys():
- catList = []
- for cat in cats[0][layer]:
- if layer not in cats[1].keys() or \
- cat not in cats[1][layer]:
- catList.append(cat)
- if catList != []:
- vEditCmd = ['v.edit', '--q',
- 'tool=%s' % action,
- 'cats=%s' % ",".join(["%d" % v for v in catList]),
- 'id=%d' % self.line]
- gcmd.Command(vEditCmd)
- else:
- if action == 'catadd':
- add = True
- else:
- add = False
- self.line = self.parent.parent.digit.SetLineCats(-1, layer,
- catList, add)
- if self.line < 0:
- wx.MessageBox(parent=self, message=_("Unable to update vector map."),
- caption=_("Error"), style=wx.OK | wx.ICON_ERROR)
- self.parent.parent.digit.driver.ReloadMap()
- event.Skip()
- def OnOK(self, event):
- """OK button pressed"""
- self.OnApply(event)
- self.OnCancel(event)
- def OnAddCat(self, event):
- """Button 'Add' new category pressed"""
- try:
- layer = int(self.layerNew.GetValue())
- cat = int(self.catNew.GetValue())
- if layer <= 0:
- raise ValueError
- except ValueError:
- {'layer' : str(self.layerNew.GetValue()),
- 'category' : str(self.catNew.GetValue())},
- dlg.ShowModal()
- dlg.Destroy()
- return False
- self.cats[layer].append(cat)
- # reload list
- # update category number for add
- self.catNew.SetValue(cat + 1)
- event.Skip()
- return True
- def GetLine(self):
- """Get id of selected line of 'None' if no line is selected"""
- return self.line
- def UpdateDialog(self, query=None, cats=None, line=None):
- """Update dialog
- @param query {coordinates, distance} - v.edit/v.what
- @param cats directory layer/cats - vdigit
- Return True if updated otherwise False
- self.line = None
- self.cats = {}
- if cats is None:
- ret = self.__GetCategories(query[0], query[1])
- else:
- self.line = line
- ret = 1
- if ret == 0 or not self.line:
- return False
- # polulate list
- try:
- except:
- newCat = 1
- self.catNew.SetValue(newCat)
- return True
-class CategoryListCtrl(wx.ListCtrl,
- listmix.ListCtrlAutoWidthMixin,
- listmix.TextEditMixin):
- """List of layers/categories"""
- def __init__(self, parent, id, pos=wx.DefaultPosition,
- size=wx.DefaultSize, style=0):
- wx.ListCtrl.__init__(self, parent, id, pos, size, style)
- listmix.ListCtrlAutoWidthMixin.__init__(self)
- listmix.TextEditMixin.__init__(self)
- def Populate(self, update=False):
- """Populate the list"""
- itemData = {} # requested by sorter
- if not update:
- self.InsertColumn(0, _("Layer"))
- self.InsertColumn(1, _("Category"))
- else:
- self.DeleteAllItems()
- i = 1
- for layer in self.parent.cats.keys():
- catsList = self.parent.cats[layer]
- for cat in catsList:
- index = self.InsertStringItem(sys.maxint, str(catsList[0]))
- self.SetStringItem(index, 0, str(layer))
- self.SetStringItem(index, 1, str(cat))
- self.SetItemData(index, i)
- itemData[i] = (str(layer), str(cat))
- i = i + 1
- if not update:
- self.SetColumnWidth(0, 100)
- self.SetColumnWidth(1, wx.LIST_AUTOSIZE)
- self.currentItem = 0
- return itemData
-class DigitZBulkDialog(wx.Dialog):
- Dialog used for Z bulk-labeling tool
- def __init__(self, parent, title, nselected, style=wx.DEFAULT_DIALOG_STYLE):
- # panel = wx.Panel(parent=self, id=wx.ID_ANY)
- txt = wx.StaticText(parent=self,
- label=_("%d lines selected for z bulk-labeling") % nselected);
- border.Add(item=txt, proportion=0, flag=wx.ALL | wx.EXPAND, border=5)
- box = wx.StaticBox (parent=self, id=wx.ID_ANY, label=" %s " % _("Set value"))
- flexSizer = wx.FlexGridSizer (cols=2, hgap=5, vgap=5)
- # starting value
- label=_("Starting value"));
- self.value = wx.SpinCtrl(parent=self, id=wx.ID_ANY, size=(150, -1),
- initial=0,
- min=-1e6, max=1e6)
- flexSizer.Add(self.value, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
- # step
- label=_("Step"))
- self.step = wx.SpinCtrl(parent=self, id=wx.ID_ANY, size=(150, -1),
- initial=0,
- min=0, max=1e6)
- flexSizer.Add(self.step, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
- border.Add(item=sizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=5)
- # buttons
- # sizers
- mainSizer.Add(item=border, proportion=1, flag=wx.EXPAND | wx.ALL, border=5)
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-04-28 19:16:07 UTC (rev 31159)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-04-28 19:27:22 UTC (rev 31160)
@@ -60,9 +60,9 @@
import globalvar
import utils
import gdialogs
-from digit import DigitCategoryDialog as DigitCategoryDialog
-from digit import DigitZBulkDialog as DigitZBulkDialog
-from digit import GV_LINES as Digit_Lines_Type
+from vdigit import VDigitCategoryDialog as VDigitCategoryDialog
+from vdigit import VDigitZBulkDialog as VDigitZBulkDialog
+from vdigit import GV_LINES as VDigit_Lines_Type
from debug import Debug as Debug
from icon import Icons as Icons
from preferences import globalSettings as UserSettings
@@ -1094,20 +1094,20 @@
if self.parent.dialogs['category'] is None:
# open new dialog
if digitClass.type == 'vedit':
- self.parent.dialogs['category'] = DigitCategoryDialog(parent=self,
- map=map,
- query=(coords, qdist),
- pos=posWindow,
- title=_("Update categories"))
+ self.parent.dialogs['category'] = VDigitCategoryDialog(parent=self,
+ map=map,
+ query=(coords, qdist),
+ pos=posWindow,
+ title=_("Update categories"))
else:
if digitClass.driver.SelectLineByPoint(coords,
digitClass.GetSelectType()) is not None:
- map=map,
- cats=digitClass.GetLineCats(),
- line=digitClass.driver.GetSelected()[0],
- pos=posWindow,
+ map=map,
+ cats=digitClass.GetLineCats(),
+ line=digitClass.driver.GetSelected()[0],
+ pos=posWindow,
else:
# update currently open dialog
@@ -1267,7 +1267,7 @@
# -> delete line || move line || move vertex
if digitToolbar.action in ["moveVertex", "editLine"]:
if len(digitClass.driver.GetSelected()) == 0:
- nselected = digitClass.driver.SelectLineByPoint(pos1, type=Digit_Lines_Type)
+ nselected = digitClass.driver.SelectLineByPoint(pos1, type=VDigit_Lines_Type)
if digitToolbar.action == "editLine":
self.UpdateMap(render=False)
selVertex = digitClass.driver.GetSelectedVertex(pos1)[0]
@@ -1290,7 +1290,7 @@
elif digitToolbar.action == "copyCats":
if not hasattr(self, "copyCatsIds"):
# collect categories
if nselected:
qdist = 10.0 * ((self.Map.region['e'] - self.Map.region['w']) / \
self.Map.width)
@@ -1360,7 +1360,7 @@
elif digitToolbar.action in ["splitLine", "addVertex", "removeVertex"]:
pointOnLine = digitClass.driver.SelectLineByPoint(pos1,
- type=Digit_Lines_Type)
+ type=VDigit_Lines_Type)
if pointOnLine:
self.UpdateMap(render=False) # highlight object
if digitToolbar.action in ["splitLine", "addVertex"]:
@@ -1643,8 +1643,8 @@
pos2 = self.polycoords[1]
selected = digitClass.driver.GetSelected()
- dlg = DigitZBulkDialog(parent=self, title=_("Z bulk-labeling dialog"),
- nselected=len(selected))
+ dlg = VDigitZBulkDialog(parent=self, title=_("Z bulk-labeling dialog"),
+ nselected=len(selected))
if dlg.ShowModal() == wx.ID_OK:
digitClass.ZBulkLine(pos1, pos2, dlg.value.GetValue(), dlg.step.GetValue())
@@ -2396,7 +2396,7 @@
CloseButton(False).Layer(2))
elif name == "digit":
- self.digittoolbar = toolbars.DigitToolbar(self, self.Map, self.tree)
+ self.digittoolbar = toolbars.VDigitToolbar(self, self.Map, self.tree)
for toolRow in range(0, self.digittoolbar.numOfRows):
self._mgr.AddPane(self.digittoolbar.toolbar[toolRow],
Modified: grass/trunk/gui/wxpython/gui_modules/preferences.py
--- grass/trunk/gui/wxpython/gui_modules/preferences.py 2008-04-28 19:16:07 UTC (rev 31159)
+++ grass/trunk/gui/wxpython/gui_modules/preferences.py 2008-04-28 19:27:22 UTC (rev 31160)
@@ -132,13 +132,13 @@
'addRecord' : { 'enabled' : True },
'layer' : {'value' : 1 },
'category' : {'value' : 1 },
- 'categoryMode' : {'value' : 'Next to use' },
+ 'categoryMode' : {'selection' : 0 },
# delete existing feature(s)
'delRecord' : { 'enabled' : True },
# query tool
- 'query' : { 'type' : 'length', 'box' : True },
- 'queryLength' : { 'than' : 'shorter than', 'thresh' : 0 },
- 'queryDangle' : { 'than' : 'shorter than', 'thresh' : 0 },
+ 'query' : { 'selection' : 0, 'box' : True },
+ 'queryLength' : { 'than-selection' : 0, 'thresh' : 0 },
+ 'queryDangle' : { 'than-selection' : 0, 'thresh' : 0 },
# select feature (point, line, centroid, boundary)
'selectFeaturePoint' : { 'enabled' : True },
'selectFeatureLine' : { 'enabled' : True },
Modified: grass/trunk/gui/wxpython/gui_modules/profile.py
--- grass/trunk/gui/wxpython/gui_modules/profile.py 2008-04-28 19:16:07 UTC (rev 31159)
+++ grass/trunk/gui/wxpython/gui_modules/profile.py 2008-04-28 19:27:22 UTC (rev 31160)
@@ -226,7 +226,7 @@
self.raster[r]['name'] = dlg.raster[r]['name']
# plot profile
- if self.raster[0]['name']:
+ if self.raster[0]['name'] and len(self.mapwin.polycoords) > 0:
self.OnCreateProfile(event=None)
dlg.Destroy()
@@ -728,15 +728,15 @@
self.coordstr = self.parent.coordstr
- if self.coordstr == '':
- dlg = wx.MessageDialog(parent=self,
- message=_('You must draw a transect to profile in the map display window.'),
- caption=_('Nothing to profile'),
- style=wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
- dlg.ShowModal()
- dlg.Destroy()
- self.Close(True)
- return
+ # if self.coordstr == '':
+ # dlg = wx.MessageDialog(parent=self,
+ # message=_('You must draw a transect to profile in the map display window.'),
+ # caption=_('Nothing to profile'),
+ # style=wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
+ # dlg.ShowModal()
+ # dlg.Destroy()
+ # self.Close(True)
+ # return
self.raster = { 0 : { 'name' : self.parent.raster[0]['name'],
'id' : None },
Modified: grass/trunk/gui/wxpython/gui_modules/toolbars.py
--- grass/trunk/gui/wxpython/gui_modules/toolbars.py 2008-04-28 19:16:07 UTC (rev 31159)
+++ grass/trunk/gui/wxpython/gui_modules/toolbars.py 2008-04-28 19:27:22 UTC (rev 31160)
@@ -5,7 +5,7 @@
* AbstractToolbar
* MapToolbar
* GRToolbar
- * DigitToolbar
+ * VDigitToolbar
* ProfileToolbar
PURPOSE: Toolbars for Map Display window
@@ -25,9 +25,9 @@
import globalvar
import gcmd
import grassenv
-import digit
import gdialogs
-from digit import DigitSettingsDialog as DigitSettingsDialog
+import vdigit
+from vdigit import VDigitSettingsDialog as VDigitSettingsDialog
@@ -255,7 +255,7 @@
if tool == "Digitize" and not self.mapdisplay.digittoolbar:
self.mapdisplay.AddToolbar("digit")
-class DigitToolbar(AbstractToolbar):
+class VDigitToolbar(AbstractToolbar):
Toolbar for digitization
@@ -408,14 +408,14 @@
def OnAddPoint(self, event):
"""Add point to the vector map Laier"""
- Debug.msg (2, "DigitToolbar.OnAddPoint()")
+ Debug.msg (2, "VDigitToolbar.OnAddPoint()")
self.action = "addLine"
self.type = "point"
self.parent.MapWindow.mouse['box'] = 'point'
def OnAddLine(self, event):
"""Add line to the vector map layer"""
- Debug.msg (2, "DigitToolbar.OnAddLine()")
+ Debug.msg (2, "VDigitToolbar.OnAddLine()")
self.type = "line"
self.parent.MapWindow.mouse['box'] = 'line'
@@ -423,7 +423,7 @@
def OnAddBoundary(self, event):
"""Add boundary to the vector map layer"""
- Debug.msg (2, "DigitToolbar.OnAddBoundary()")
+ Debug.msg (2, "VDigitToolbar.OnAddBoundary()")
self.type = "boundary"
@@ -431,7 +431,7 @@
def OnAddCentroid(self, event):
"""Add centroid to the vector map layer"""
- Debug.msg (2, "DigitToolbar.OnAddCentroid()")
+ Debug.msg (2, "VDigitToolbar.OnAddCentroid()")
self.type = "centroid"
@@ -541,13 +541,13 @@
"""Show settings dialog"""
if self.parent.digit is None:
- reload(digit)
- from digit import Digit as Digit
+ reload(vdigit)
+ from vdigit import Digit as Digit
self.parent.digit = Digit(mapwindow=self.parent.MapWindow)
if not self.settingsDialog:
- self.settingsDialog = DigitSettingsDialog(parent=self.parent, title=_("Digitization settings"),
- style=wx.DEFAULT_DIALOG_STYLE)
+ self.settingsDialog = VDigitSettingsDialog(parent=self.parent, title=_("Digitization settings"),
+ style=wx.DEFAULT_DIALOG_STYLE)
self.settingsDialog.Show()
def OnAdditionalToolMenu(self, event):
@@ -712,8 +712,8 @@
@return True on success
@return False on error
- reload(digit)
+ reload(vdigit)
try:
self.layerSelectedID = self.layers.index(layerSelected)
@@ -733,7 +733,7 @@
self.parent.maptoolbar.combo.SetValue ('Digitize')
# set initial category number for new features (layer=1), etc.
- Debug.msg (4, "DigitToolbar.StartEditing(): layerSelectedID=%d layer=%s" % \
+ Debug.msg (4, "VDigitToolbar.StartEditing(): layerSelectedID=%d layer=%s" % \
(self.layerSelectedID, mapLayer.name))
@@ -760,7 +760,7 @@
if self.layers[self.layerSelectedID] == layerSelected:
self.layerSelectedID = None
- Debug.msg (4, "DigitToolbar.StopEditing(): layer=%s" % \
+ Debug.msg (4, "VDigitToolbar.StopEditing(): layer=%s" % \
(layerSelected.name))
self.combo.SetValue (_('Select vector map'))
@@ -768,7 +768,7 @@
if UserSettings.Get(group='advanced', key='digitInterface', subkey='type') == 'vdigit':
if UserSettings.Get(group='vdigit', key='saveOnExit', subkey='enabled') is False:
dlg = wx.MessageDialog(parent=self.parent, message=_("Do you want to save changes "
- "to vector map <%s>?") % layerSelected.name,
+ "in vector map <%s>?") % layerSelected.name,
caption=_("Save changes?"),
style=wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
if dlg.ShowModal() == wx.ID_NO:
@@ -806,7 +806,7 @@
Optionaly also update toolbar
- Debug.msg (4, "DigitToolbar.UpdateListOfLayers(): updateTool=%d" % \
+ Debug.msg (4, "VDigitToolbar.UpdateListOfLayers(): updateTool=%d" % \
updateTool)
layerNameSelected = None
Copied: grass/trunk/gui/wxpython/gui_modules/vdigit.py (from rev 31150, grass/trunk/gui/wxpython/gui_modules/digit.py)
--- grass/trunk/gui/wxpython/gui_modules/vdigit.py (rev 0)
+++ grass/trunk/gui/wxpython/gui_modules/vdigit.py 2008-04-28 19:27:22 UTC (rev 31160)
@@ -0,0 +1,2616 @@
+MODULE: vdigit
+CLASSES:
+ * AbstractDigit
+ * VEdit
+ * VDigit
+ * AbstractDisplayDriver
+ * CDisplayDriver
+ * VDigitSettingsDialog
+ * VDigitCategoryDialog
+ * VDigitZBulkDialog
+PURPOSE: Vector digitization tool for wxPython GUI
+ Note: Initial version under development
+ Progress:
+ (1) v.edit called on the background (class VEdit)
+ (2) Reimplentation of v.digit (VDigit)
+ Import:
+ from vdigit import VDigit as VDigit
+AUTHORS: The GRASS Development Team
+ Martin Landa <landa.martin gmail.com>
+COPYRIGHT: (C) 2007-2008 by the GRASS Development Team
+ This program is free software under the GNU General Public
+ License (>=v2). Read the file COPYING that comes with GRASS
+ for details.
+import os
+import sys
+import string
+import copy
+import wx
+import wx.lib.colourselect as csel
+import wx.lib.mixins.listctrl as listmix
+import gcmd
+import dbm
+from debug import Debug as Debug
+import gselect
+import globalvar
+from preferences import globalSettings as UserSettings
+try:
+ digitPath = os.path.join(globalvar.ETCWXDIR, "vdigit")
+ sys.path.append(digitPath)
+ import grass6_wxvdigit as wxvdigit
+ GV_LINES = wxvdigit.GV_LINES
+ digitErr = ''
+except ImportError, err:
+ GV_LINES = None
+ digitErr = err
+ # print >> sys.stderr, "%sWARNING: Digitization tool is disabled (%s). " \
+ # "Detailed information in README file." % \
+ # (os.linesep, err)
+# which interface to use?
+if UserSettings.Get(group='advanced', key='digitInterface', subkey='type') == 'vedit' and GV_LINES is not None:
+ print >> sys.stderr, "%sWARNING: Digitization tool uses v.edit interface. " \
+ "This can significantly slow down some operations especially for " \
+ "middle-large vector maps. "\
+ "You can change the digitization interface in 'User preferences' " \
+ "(menu 'Config'->'Preferences')." % \
+ os.linesep
+class AbstractDigit:
+ Abstract digitization class
+ def __init__(self, mapwindow):
+ """Initialization
+ @param mapwindow reference to mapwindow (MapFrame) instance
+ @param settings initial settings of digitization tool
+ self.map = None
+ self.mapWindow = mapwindow
+ Debug.msg (3, "AbstractDigit.__init__(): map=%s" % \
+ self.map)
+ #self.SetCategory()
+ self.driver = CDisplayDriver(self, mapwindow)
+ def SetCategoryNextToUse(self):
+ """Find maximum category number in the map layer
+ and update Digit.settings['category']
+ @return 'True' on success, 'False' on failure
+ # vector map layer without categories, reset to '1'
+ UserSettings.Set(group='vdigit', key='category', subkey='value', value=1)
+ if self.map:
+ if UserSettings.Get(group='advanced', key='digitInterface', subkey='type') == 'vedit':
+ categoryCmd = gcmd.Command(cmd=["v.category", "-g", "--q",
+ "input=%s" % self.map,
+ "option=report"])
+ if categoryCmd.returncode != 0:
+ return False
+ for line in categoryCmd.ReadStdOutput():
+ if "all" in line:
+ if UserSettings.Get(group='vdigit', key='layer', subkey='value') != int(line.split(' ')[0]):
+ continue
+ try:
+ maxCat = int(line.split(' ')[-1]) + 1
+ UserSettings.Set(group='vdigit', key='category', subkey='value', value=maxCat)
+ except:
+ return False
+ return True
+ else:
+ cat = self.digit.GetCategory(UserSettings.Get(group='vdigit', key='layer', subkey='value'))
+ value=cat + 1)
+ def SetCategory(self):
+ """Return category number to use (according Settings)"""
+ if UserSettings.Get(group='vdigit', key="categoryMode", subkey='selection') == 0:
+ self.SetCategoryNextToUse()
+ return UserSettings.Get(group='vdigit', key="category", subkey='value')
+ def SetMapName(self, map):
+ """Set map name
+ @param map map name to be set up or None (will close currently edited map)
+ Debug.msg (3, "AbstractDigit.SetMapName map=%s" % map)
+ self.map = map
+ try:
+ ret = self.driver.Reset(self.map)
+ except StandardError, e:
+ raise gcmd.DigitError('Unable to initialize display driver, '
+ 'see README file for more information.%s%s'
+ 'Details: %s (%s)' % (os.linesep, os.linesep, e, digitErr))
+ if map and ret == -1:
+ raise gcmd.DigitError(_('Unable to open vector map <%s> for editing. '
+ 'Data are probably corrupted, '
+ 'try to run v.build for rebuilding the topology.') % map)
+ if not map and ret != 0:
+ if UserSettings.Get(group='advanced', key='digitInterface', subkey='type') != 'v.edit':
+ try:
+ self.digit.InitCats()
+ except:
+ pass
+ def SelectLinesByQueryThresh(self):
+ """Generic method used for SelectLinesByQuery()
+ -- to get threshold value"""
+ thresh = 0.0
+ if UserSettings.Get(group='vdigit', key='query', subkey='selection') == 0:
+ thresh = UserSettings.Get(group='vdigit', key='queryLength', subkey='thresh')
+ if UserSettings.Get(group='vdigit', key="queryLength", subkey='than-selection') == 0:
+ thresh = -1 * thresh
+ else:
+ thresh = UserSettings.Get(group='vdigit', key='queryDangle', subkey='thresh')
+ if UserSettings.Get(group='vdigit', key="queryDangle", subkey='than-selection') == 0:
+ return thresh
+ def GetSelectType(self):
+ """Get type(s) to be selected
+ Used by SelectLinesByBox() and SelectLinesByPoint()"""
+ type = 0
+ for feature in (('Point', wxvdigit.GV_POINT),
+ ('Line', wxvdigit.GV_LINE),
+ ('Centroid', wxvdigit.GV_CENTROID),
+ ('Boundary', wxvdigit.GV_BOUNDARY)):
+ if UserSettings.Get(group='vdigit', key='selectFeature'+feature[0], subkey='enabled') is True:
+ type |= feature[1]
+ return type
+ def SelectLinesFromBackgroundMap(self, pos1, pos2):
+ """Select features from background map
+ @param pos1,pos2 bounding box defifinition
+ if UserSettings.Get(group='vdigit', key='backgroundMap', subkey='value') == '':
+ Debug.msg(4, "VEdit.SelectLinesFromBackgroundMap(): []")
+ return []
+ x1, y1 = pos1
+ x2, y2 = pos2
+ vEditCmd = gcmd.Command(['v.edit',
+ '--q',
+ 'map=%s' % UserSettings.Get(group='vdigit', key='backgroundMap', subkey='value'),
+ 'tool=select',
+ 'bbox=%f,%f,%f,%f' % (pos1[0], pos1[1], pos2[0], pos2[1])])
+ #'polygon=%f,%f,%f,%f,%f,%f,%f,%f,%f,%f' % \
+ # (x1, y1, x2, y1, x2, y2, x1, y2, x1, y1)])
+ try:
+ output = vEditCmd.ReadStdOutput()[0] # first line
+ ids = output.split(',')
+ ids = map(int, ids) # str -> int
+ except:
+ return []
+ Debug.msg(4, "VEdit.SelectLinesFromBackgroundMap(): %s" % \
+ ",".join(["%d" % v for v in ids]))
+ return ids
+class VEdit(AbstractDigit):
+ Prototype of digitization class based on v.edit command
+ Note: This should be replaced by VDigit class.
+ """Initialization
+ AbstractDigit.__init__(self, mapwindow)
+ def AddPoint (self, map, point, x, y, z=None):
+ """Add point/centroid
+ @param point feature type (True for point, otherwise centroid)
+ @param x,y,z coordinates
+ if point:
+ key = "P"
+ else:
+ key = "C"
+ if UserSettings.Get(group='vdigit', key="categoryMode", subkey='selection') == 2:
+ layer = -1 # -> no category
+ cat = -1
+ else:
+ layer = UserSettings.Get(group='vdigit', key="layer", subkey='value')
+ cat = self.SetCategory()
+ if layer > 0 and cat != "None":
+ addstring = "%s 1 1\n" % (key)
+ else:
+ addstring = "%s 1\n" % (key)
+ addstring += "%f %f\n" % (x, y)
+ addstring += "%d %d\n" % (layer, cat)
+ Debug.msg (3, "VEdit.AddPoint(): map=%s, type=%s, layer=%d, cat=%d, x=%f, y=%f" % \
+ (map, type, layer, cat, x, y))
+ else:
+ Debug.msg (3, "VEdit.AddPoint(): map=%s, type=%s, x=%f, y=%f" % \
+ (map, type, x, y))
+ Debug.msg (4, "Vline.AddPoint(): input=%s" % addstring)
+ self.__AddFeature (map=map, input=addstring)
+ def AddLine (self, map, line, coords):
+ """Add line/boundary
+ @param line feature type (True for line, otherwise boundary)
+ @param list of coordinates
+ if len(coords) < 2:
+ return
+ cat = -1
+ else:
+ if line:
+ key = "L"
+ flags = []
+ else:
+ key = "B"
+ flags = ['-c'] # close boundaries
+ addstring = "%s %d 1\n" % (key, len(coords))
+ else:
+ addstring = "%s %d\n" % (key, len(coords))
+ for point in coords:
+ addstring += "%f %f\n" % \
+ (float(point[0]), float(point [1]))
+ Debug.msg (3, "Vline.AddLine(): type=%s, layer=%d, cat=%d coords=%s" % \
+ (key, layer, cat, coords))
+ else:
+ Debug.msg (3, "Vline.AddLine(): type=%s, coords=%s" % \
+ (key, coords))
+ Debug.msg (4, "VEdit.AddLine(): input=%s" % addstring)
+ self.__AddFeature (map=map, input=addstring, flags=flags)
+ def __AddFeature (self, map, input, flags=[]):
+ """Generic method to add new vector feature
+ @param input feature definition in GRASS ASCII format
+ @param flags additional flags
+ if UserSettings.Get(group='vdigit', key='snapping', subkey='value') <= 0.0:
+ snap = "no"
+ else:
+ if UserSettings.Get(group='vdigit', key='snapToVertex', subkey='enabled') is True:
+ snap = "vertex"
+ else:
+ snap = "node"
+ command = ["v.edit", "-n", "--q",
+ "map=%s" % map,
+ "tool=add",
+ "thresh=%f,%f" % (self.driver.GetThreshold(type='selectThresh'), self.driver.GetThreshold(type='snapping')),
+ "snap=%s" % snap]
+ if UserSettings.Get(group='vdigit', key='backgroundMap', subkey='value') != '':
+ command.append("bgmap=%s" % UserSettings.Get(group='vdigit', key='backgroundMap', subkey='value'))
+ # additional flags
+ for flag in flags:
+ command.append(flag)
+ # run the command
+ Debug.msg(4, "VEdit.AddFeature(): input=%s" % input)
+ vedit = gcmd.Command(cmd=command, stdin=input, stderr=None)
+ # reload map (needed for v.edit)
+ self.driver.ReloadMap()
+ def DeleteSelectedLines(self):
+ """Delete selected features"""
+ selected = self.driver.GetSelected() # grassId
+ if len(selected) <= 0:
+ return False
+ ids = ",".join(["%d" % v for v in selected])
+ Debug.msg(4, "Digit.DeleteSelectedLines(): ids=%s" % \
+ ids)
+ # delete also attributes if requested
+ if UserSettings.Get(group='vdigit', key='delRecord', subkey='enabled') is True:
+ layerCommand = gcmd.Command(cmd=["v.db.connect",
+ "-g", "--q",
+ "map=%s" % self.map],
+ rerr=None, stderr=None)
+ if layerCommand.returncode == 0:
+ layers = {}
+ for line in layerCommand.ReadStdOutput():
+ lineList = line.split(' ')
+ layers[int(lineList[0])] = { "table" : lineList[1],
+ "key" : lineList[2],
+ "database" : lineList[3],
+ "driver" : lineList[4] }
+ for layer in layers.keys():
+ printCats = gcmd.Command(['v.category',
+ '--q',
+ 'input=%s' % self.map,
+ 'layer=%d' % layer,
+ 'option=print',
+ 'id=%s' % ids])
+ sql = 'DELETE FROM %s WHERE' % layers[layer]['table']
+ n_cats = 0
+ for cat in printCats.ReadStdOutput():
+ for c in cat.split('/'):
+ sql += ' cat = %d or' % int(c)
+ n_cats += 1
+ sql = sql.rstrip(' or')
+ if n_cats > 0:
+ gcmd.Command(['db.execute',
+ '--q',
+ 'driver=%s' % layers[layer]['driver'],
+ 'database=%s' % layers[layer]['database']],
+ stdin=sql,
+ command = [ "v.edit",
+ "map=%s" % self.map,
+ "tool=delete",
+ "ids=%s" % ids]
+ # run the command
+ vedit = gcmd.Command(cmd=command, stderr=None)
+ return True
+ def MoveSelectedLines(self, move):
+ """Move selected features
+ @param move X,Y direction
+ return self.__MoveFeature("move", None, move)
+ def MoveSelectedVertex(self, coords, move):
+ """Move selected vertex
+ Feature geometry is changed.
+ @param coords click coordinates
+ return self.__MoveFeature("vertexmove", coords, move)
+ def __MoveFeature(self, tool, coords, move):
+ """Move selected vector feature (line, vertex)
+ @param tool tool for v.edit
+ @param move direction (x, y)
+ return False
+ Debug.msg(4, "Digit.MoveSelectedLines(): ids=%s, move=%s" % \
+ (ids, move))
+ snap = "no"
+ else:
+ snap = "vertex"
+ else:
+ snap = "node"
+ command = ["v.edit", "--q",
+ "tool=%s" % tool,
+ "ids=%s" % ids,
+ "move=%f,%f" % (float(move[0]),float(move[1])),
+ "snap=%s" % snap]
+ if tool == "vertexmove":
+ command.append("coords=%f,%f" % (float(coords[0]), float(coords[1])))
+ command.append("-1") # modify only first selected
+ # run the command
+ return True
+ def AddVertex(self, coords):
+ """Add new vertex to the selected line/boundary on position 'coords'
+ @param coords coordinates to add vertex
+ return self.__ModifyVertex(coords, "vertexadd")
+ def RemoveVertex(self, coords):
+ """Remove vertex from the selected line/boundary on position 'coords'
+ @param coords coordinates to remove vertex
+ return self.__ModifyVertex(coords, "vertexdel")
+ def __ModifyVertex(self, coords, action):
+ """Generic method for vertex manipulation
+ @param action operation to perform
+ try:
+ line = self.driver.GetSelected()[0]
+ except:
+ return False
+ "tool=%s" % action,
+ "ids=%s" % line,
+ "coords=%f,%f" % (float(coords[0]),float(coords[1])),
+ "thresh=%f,%f" % (self.driver.GetThreshold(type='selectThresh'), self.driver.GetThreshold(type='snapping'))]
+ # run the command
+ return True
+ def SplitLine(self, coords):
+ """Split selected line/boundary on position 'coords'
+ @param coords coordinates to split line
+ try:
+ except:
+ return False
+ "tool=break",
+ "ids=%s" % line,
+ "thresh=%f" % self.driver.GetThreshold(type='selectThresh')]
+ # run the command
+ # redraw map
+ return True
+ def EditLine(self, line, coords):
+ """Edit existing line/boundary
+ @param line id of line to be modified
+ @param coords list of coordinates of modified line
+ # remove line
+ vEditDelete = gcmd.Command(['v.edit',
+ '--q',
+ 'map=%s' % self.map,
+ 'tool=delete',
+ 'ids=%s' % line], stderr=None)
+ # add line
+ if len(coords) > 0:
+ self.AddLine(self.map, "line", coords)
+ def __ModifyLines(self, tool):
+ """Generic method to modify selected lines/boundaries
+ @param tool operation to be performed by v.edit
+ ids = self.driver.GetSelected()
+ if len(ids) <= 0:
+ return False
+ vEdit = ['v.edit',
+ '--q',
+ 'tool=%s' % tool,
+ 'ids=%s' % ",".join(["%d" % v for v in ids])]
+ if tool in ['snap', 'connect']:
+ vEdit.append("thresh=%f,%f" % (self.driver.GetThreshold(type='selectThresh'), self.driver.GetThreshold(type='snapping')))
+ runCmd = gcmd.Command(vEdit)
+ return True
+ def FlipLine(self):
+ """Flip selected lines/boundaries"""
+ return self.__ModifyLines('flip')
+ def MergeLine(self):
+ """Merge selected lines/boundaries"""
+ return self.__ModifyLines('merge')
+ def BreakLine(self):
+ """Break selected lines/boundaries"""
+ return self.__ModifyLines('break')
+ def SnapLine(self):
+ """Snap selected lines/boundaries"""
+ return self.__ModifyLines('snap')
+ def ConnectLine(self):
+ """Connect selected lines/boundaries"""
+ return self.__ModifyLines('connect')
+ def TypeConvForSelectedLines(self):
+ """Feature type conversion for selected objects.
+ Supported conversions:
+ - point <-> centroid
+ - line <-> boundary
+ return self.__ModifyLines('chtype')
+ def ZBulkLine(self, pos1, pos2, value, step):
+ """Provide z bulk-labeling (automated assigment of z coordinate
+ to 3d lines
+ @param pos1,pos2 bounding box definition for selecting lines to be labeled
+ @param value starting value
+ @param step step value
+ gcmd.Command(['v.edit',
+ '--q',
+ 'tool=zbulk',
+ 'bbox=%f,%f,%f,%f' % (pos1[0], pos1[1], pos2[0], pos2[1]),
+ 'zbulk=%f,%f' % (value, step)])
+ def CopyLine(self, ids=None):
+ """Copy features from (background) vector map
+ @param ids list of line ids to be copied
+ if not ids:
+ if len(ids) <= 0:
+ return False
+ '--q',
+ 'tool=copy',
+ vEdit.append('bgmap=%s' % UserSettings.Get(group='vdigit', key='backgroundMap', subkey='value'))
+ return True
+ def CopyCats(self, cats, ids):
+ """Copy given categories to objects with id listed in ids
+ @param cats list of cats to be copied
+ @param ids ids of lines to be modified
+ if len(cats) == 0 or len(ids) == 0:
+ return False
+ # collect cats
+ '--q',
+ 'tool=catadd',
+ 'cats=%s' % ",".join(["%d" % v for v in cats]),
+ 'ids=%s' % ",".join(["%d" % v for v in ids])])
+ return True
+ def SelectLinesByQuery(self, pos1, pos2):
+ """Select features by query
+ @param pos1, pos2 bounding box definition
+ thresh = self.SelectLinesByQueryThresh()
+ w, n = pos1
+ e, s = pos2
+ if UserSettings.Get(group='vdigit', key='query', subkey='box') == False: # select globaly
+ vInfo = gcmd.Command(['v.info',
+ '-g'])
+ for item in vInfo.ReadStdOutput():
+ if 'north' in item:
+ n = float(item.split('=')[1])
+ elif 'south' in item:
+ s = float(item.split('=')[1])
+ elif 'east' in item:
+ e = float(item.split('=')[1])
+ elif 'west' in item:
+ w = float(item.split('=')[1])
+ qtype = 'length'
+ else:
+ qtype = 'dangle'
+ vEdit = (['v.edit',
+ '--q',
+ 'tool=select',
+ 'bbox=%f,%f,%f,%f' % (w, n, e, s),
+ 'query=%s' % qtype,
+ 'thresh=0,0,%f' % thresh])
+ vEditCmd = gcmd.Command(vEdit)
+ try:
+ except:
+ return []
+ Debug.msg(4, "VEdit.SelectLinesByQuery(): %s" % \
+ return ids
+ def GetLayers(self):
+ """Return list of layers"""
+ "-g", "--q",
+ layers = []
+ layers.append(int(lineList[0]))
+ return layers
+ return [1,]
+ def Undo(self, level=-1):
+ """Undo not implemented here"""
+ wx.MessageBox(parent=self.mapWindow, message=_("Undondo is not implemented in vedit component. "
+ "Use vdigit instead."),
+ caption=_("Message"), style=wx.ID_OK | wx.ICON_INFORMATION | wx.CENTRE)
+class VDigit(AbstractDigit):
+ Prototype of digitization class based on v.digit reimplementation
+ Under development (wxWidgets C/C++ background)
+ """Initialization
+ try:
+ self.digit = wxvdigit.Digit(self.driver.GetDevice())
+ except (ImportError, NameError):
+ self.digit = None
+ self.toolbar = mapwindow.parent.digittoolbar
+ def __del__(self):
+ del self.digit
+ """Add new point/centroid
+ @param map map name (unused, for compatability with VEdit)
+ @param point feature type (if true point otherwise centroid)
+ cat = -1
+ else:
+ if point:
+ type = wxvdigit.GV_POINT
+ else:
+ type = wxvdigit.GV_CENTROID
+ snap, thresh = self.__getSnapThreshold()
+ if z:
+ ret = self.digit.AddLine(type, [x, y, z], layer, cat,
+ str(UserSettings.Get(group='vdigit', key="backgroundMap", subkey='value')), snap, thresh)
+ else:
+ ret = self.digit.AddLine(type, [x, y], layer, cat,
+ if ret == -1:
+ raise gcmd.DigitError, _("Adding new feature to vector map <%s> failed.") % map
+ self.toolbar.EnableUndo()
+ @param line feature type (if True line, otherwise boundary)
+ return
+ cat = -1
+ else:
+ if line:
+ type = wxvdigit.GV_LINE
+ else:
+ type = wxvdigit.GV_BOUNDARY
+ listCoords = []
+ for c in coords:
+ for x in c:
+ listCoords.append(x)
+ ret = self.digit.AddLine(type, listCoords, layer, cat,
+ if ret == -1:
+ @return number of deleted lines
+ nlines = self.digit.DeleteLines(UserSettings.Get(group='vdigit', key='delRecord', subkey='enabled'))
+ if nlines > 0:
+ return nlines
+ nlines = self.digit.MoveLines(move[0], move[1], 0.0, # TODO 3D
+ if nlines > 0:
+ return nlines
+ """Move selected vertex of the line
+ @return 1 vertex moved
+ @return 0 vertex not moved (not found, line is not selected)
+ moved = self.digit.MoveVertex(coords[0], coords[1], 0.0, # TODO 3D
+ move[0], move[1], 0.0,
+ self.driver.GetThreshold(type='selectThresh'), thresh)
+ if moved:
+ return moved
+ @return 1 vertex added
+ @return 0 nothing changed
+ @return -1 on failure
+ added = self.digit.ModifyLineVertex(1, coords[0], coords[1], 0.0, # TODO 3D
+ self.driver.GetThreshold(type='selectThresh'))
+ if added > 0:
+ return added
+ @return 1 vertex removed
+ deleted = self.digit.ModifyLineVertex(0, coords[0], coords[1], 0.0, # TODO 3D
+ if deleted > 0:
+ return deleted
+ @return 1 line modified
+ @return -1 error
+ ret = self.digit.SplitLine(coords[0], coords[1], 0.0, # TODO 3D
+ self.driver.GetThreshold('selectThresh'))
+ if ret > 0:
+ return ret
+ @return feature id of new line
+ @return -1 on error
+ try:
+ lineid = line[0]
+ except:
+ lineid = -1
+ listCoords = []
+ for c in coords:
+ for x in c:
+ ret = self.digit.RewriteLine(lineid, listCoords,
+ if ret > 0:
+ return ret
+ @return number of modified lines
+ ret = self.digit.FlipLines()
+ if ret > 0:
+ return ret
+ ret = self.digit.MergeLines()
+ if ret > 0:
+ return ret
+ ret = self.digit.BreakLines()
+ if ret > 0:
+ return ret
+ @return on success
+ ret = self.digit.SnapLines(thresh)
+ if ret == 0:
+ return ret
+ @return 1 lines connected
+ @return 0 lines not connected
+ ret = self.digit.ConnectLines(thresh)
+ if ret > 0:
+ return ret
+ @return number of copied features
+ ret = self.digit.CopyLines(ids, str(UserSettings.Get(group='vdigit', key='backgroundMap', subkey='value')))
+ if ret > 0:
+ return ret
+ @return number of modified features
+ return 0
+ ret = self.digit.CopyCats(cats, ids)
+ if ret > 0:
+ return ret
+ w, n = pos1
+ e, s = pos2
+ query = wxvdigit.QUERY_UNKNOWN
+ query = wxvdigit.QUERY_LENGTH
+ else:
+ query = wxvdigit.QUERY_DANGLE
+ type = wxvdigit.GV_POINTS | wxvdigit.GV_LINES # TODO: 3D
+ ids = self.digit.SelectLinesByQuery(w, n, 0.0, e, s, 1000.0,
+ UserSettings.Get(group='vdigit', key='query', subkey='box'),
+ query, type, thresh)
+ Debug.msg(4, "VDigit.SelectLinesByQuery(): %s" % \
+ return ids
+ def GetLineCats(self, line=-1):
+ """Get layer/category pairs from given (selected) line
+ @param line feature id (-1 for first selected line)
+ return self.digit.GetLineCats(line)
+ def SetLineCats(self, line, layer, cats, add=True):
+ """Set categories for given line and layer
+ @param layer layer number (-1 for first selected line)
+ @param cats list of categories
+ @param add if True to add, otherwise do delete categories
+ @return new feature id (feature need to be rewritten)
+ ret = self.digit.SetLineCats(line, layer, cats, add)
+ if ret > 0:
+ return ret
+ """Get list of layers"""
+ return self.digit.GetLayers()
+ ret = self.digit.TypeConvLines()
+ if ret > 0:
+ return ret
+ """Undo action
+ @param level levels to undo (0 to revert all)
+ @return id of current changeset
+ try:
+ ret = self.digit.Undo(level)
+ except SystemExit:
+ ret = -2
+ if ret == -2:
+ raise gcmd.DigitError, _("Undo failed, data corrupted.")
+ self.mapWindow.UpdateMap(render=False)
+ if ret < 0: # disable undo tool
+ self.toolbar.EnableUndo(False)
+ def __getSnapThreshold(self):
+ """Get snap mode and threshold value
+ @return (snap, thresh)
+ thresh = self.driver.GetThreshold()
+ if thresh > 0.0:
+ snap = wxvdigit.SNAPVERTEX
+ else:
+ else:
+ snap = v.digit.NO_SNAP
+ return (snap, thresh)
+if UserSettings.Get(group='advanced', key='digitInterface', subkey='type') == 'vedit':
+ class Digit(VEdit):
+ """Default digit class"""
+ VEdit.__init__(self, mapwindow)
+ self.type = 'vedit'
+else:
+ class Digit(VDigit):
+ VDigit.__init__(self, mapwindow)
+ self.type = 'vdigit'
+ VDigit.__del__(self)
+class AbstractDisplayDriver:
+ """Abstract classs for display driver"""
+ def __init__(self, parent, mapwindow):
+ """Initialization
+ @param parent
+ @param mapwindow reference to mapwindow (MFrame)
+ self.parent = parent
+ self.mapwindow = mapwindow
+ self.ids = {} # dict[g6id] = [pdcId]
+ self.selected = [] # list of selected objects (grassId!)
+ def GetThreshold(self, type='snapping', value=None, units=None):
+ """Return threshold in map units
+ @param value threshold to be set up
+ @param units units (map, screen)
+ if not value:
+ value = UserSettings.Get(group='vdigit', key=type, subkey='value')
+ if not units:
+ units = UserSettings.Get(group='vdigit', key=type, subkey='units')
+ if units == "screen pixels":
+ # pixel -> cell
+ reg = self.mapwindow.Map.region
+ if reg['nsres'] > reg['ewres']:
+ res = reg['nsres']
+ else:
+ res = reg['ewres']
+ threshold = value * res
+ else:
+ threshold = value
+ Debug.msg(4, "AbstractDisplayDriver.GetThreshold(): type=%s, thresh=%f" % (type, threshold))
+ return threshold
+class CDisplayDriver(AbstractDisplayDriver):
+ Display driver using grass6_wxdriver module
+ """Initialization
+ @param parent
+ AbstractDisplayDriver.__init__(self, parent, mapwindow)
+ # initialize wx display driver
+ try:
+ self.__display = wxvdigit.DisplayDriver(mapwindow.pdcVector)
+ except:
+ self.__display = None
+ self.UpdateSettings()
+ def GetDevice(self):
+ """Get device"""
+ return self.__display
+ def SetDevice(self, pdc):
+ """Set device for driver
+ @param pdc wx.PseudoDC instance
+ self.__display.SetDevice(pdc)
+ def Reset(self, map):
+ """Reset map
+ Open or close the vector map by driver.
+ @param map map name or None to close the map
+ @return 0 on success (close map)
+ @return topo level on success (open map)
+ @return non-zero (close map)
+ @return -1 on error (open map)
+ if map:
+ name, mapset = map.split('@')
+ try:
+ ret = self.__display.OpenMap(str(name), str(mapset), False)
+ else:
+ ret = self.__display.OpenMap(str(name), str(mapset), True)
+ ret = -1
+ else:
+ ret = self.__display.CloseMap()
+ return ret
+ def ReloadMap(self):
+ """Reload map (close and re-open).
+ Needed for v.edit, TODO: get rid of that..."""
+ Debug.msg(4, "CDisplayDriver.ReloadMap():")
+ self.__display.ReloadMap()
+ def DrawMap(self):
+ """Draw vector map layer content
+ @return wx.Image instance
+ nlines = self.__display.DrawMap(True) # force
+ Debug.msg(3, "CDisplayDriver.DrawMap(): nlines=%d" % nlines)
+ return nlines
+ def SelectLinesByBox(self, begin, end, type=0):
+ """Select vector features by given bounding box.
+ If type is given, only vector features of given type are selected.
+ @param begin,end bounding box definition
+ @param type select only objects of given type
+ x1, y1 = begin
+ x2, y2 = end
+ nselected = self.__display.SelectLinesByBox(x1, y1, -1.0 * wxvdigit.PORT_DOUBLE_MAX,
+ x2, y2, wxvdigit.PORT_DOUBLE_MAX,
+ type)
+ Debug.msg(4, "CDisplayDriver.SelectLinesByBox(): selected=%d" % \
+ nselected)
+ return nselected
+ def SelectLineByPoint(self, point, type=0):
+ """Select vector feature by coordinates of click point (in given threshold).
+ @param point click coordinates (bounding box given by threshold)
+ pointOnLine = self.__display.SelectLineByPoint(point[0], point[1], 0.0,
+ self.GetThreshold(type='selectThresh'),
+ type, 0); # without_z
+ if len(pointOnLine) > 0:
+ Debug.msg(4, "CDisplayDriver.SelectLineByPoint(): pointOnLine=%f,%f" % \
+ (pointOnLine[0], pointOnLine[1]))
+ return pointOnLine
+ else:
+ Debug.msg(4, "CDisplayDriver.SelectLineByPoint(): no line found")
+ return None
+ def GetSelected(self, grassId=True):
+ """Return ids of selected vector features
+ @param grassId if grassId is True returns GRASS ids, otherwise
+ internal ids of objects drawn in PseudoDC"""
+ if grassId:
+ selected = self.__display.GetSelected(True)
+ else:
+ selected = self.__display.GetSelected(False)
+ Debug.msg(4, "CDisplayDriver.GetSelected(): grassId=%d, ids=%s" % \
+ (grassId, (",".join(["%d" % v for v in selected]))))
+ return selected
+ def GetSelectedVertex(self, coords):
+ """Get PseudoDC id(s) of vertex (of selected line)
+ on position 'coords'
+ @param coords click position
+ x, y = coords
+ id = self.__display.GetSelectedVertex(x, y, self.GetThreshold(type='selectThresh'))
+ Debug.msg(4, "CDisplayDriver.GetSelectedVertex(): id=%s" % \
+ (",".join(["%d" % v for v in id])))
+ return id
+ def SetSelected(self, id):
+ """Set selected vector features
+ @param id line id to be selected
+ Debug.msg(4, "CDisplayDriver.SetSelected(): id=%s" % \
+ ",".join(["%d" % v for v in id]))
+ self.__display.SetSelected(id)
+ def UpdateRegion(self):
+ """Set geographical region
+ Needed for 'cell2pixel' conversion"""
+ map = self.mapwindow.Map
+ reg = map.region
+ self.__display.SetRegion(reg['n'],
+ reg['s'],
+ reg['e'],
+ reg['w'],
+ reg['nsres'],
+ reg['ewres'],
+ reg['center_easting'],
+ reg['center_northing'],
+ map.width, map.height)
+ def GetMapBoundingBox(self):
+ """Return bounding box of given vector map layer
+ @return (w,s,b,e,n,t)
+ return self.__display.GetMapBoundingBox()
+ def UpdateSettings(self):
+ """Update display driver settings"""
+ # TODO map units
+ if not self.__display:
+ return
+ self.__display.UpdateSettings (wx.Color(UserSettings.Get(group='vdigit', key='symbolHighlight', subkey='color')[0],
+ UserSettings.Get(group='vdigit', key='symbolHighlight', subkey='color')[1],
+ UserSettings.Get(group='vdigit', key='symbolHighlight', subkey='color')[2],
+ 255).GetRGB(),
+ UserSettings.Get(group='vdigit', key='symbolPoint', subkey='enabled'),
+ wx.Color(UserSettings.Get(group='vdigit', key='symbolPoint', subkey='color')[0],
+ UserSettings.Get(group='vdigit', key='symbolPoint', subkey='color')[1],
+ UserSettings.Get(group='vdigit', key='symbolPoint', subkey='color')[2],
+ 255).GetRGB(),
+ UserSettings.Get(group='vdigit', key='symbolLine', subkey='enabled'),
+ wx.Color(UserSettings.Get(group='vdigit', key='symbolLine', subkey='color')[0],
+ UserSettings.Get(group='vdigit', key='symbolLine', subkey='color')[1],
+ UserSettings.Get(group='vdigit', key='symbolLine', subkey='color')[2],
+ 255).GetRGB(),
+ UserSettings.Get(group='vdigit', key='symbolBoundaryNo', subkey='enabled'),
+ wx.Color(UserSettings.Get(group='vdigit', key='symbolBoundaryNo', subkey='color')[0],
+ UserSettings.Get(group='vdigit', key='symbolBoundaryNo', subkey='color')[1],
+ UserSettings.Get(group='vdigit', key='symbolBoundaryNo', subkey='color')[2],
+ 255).GetRGB(),
+ UserSettings.Get(group='vdigit', key='symbolBoundaryOne', subkey='enabled'),
+ wx.Color(UserSettings.Get(group='vdigit', key='symbolBoundaryOne', subkey='color')[0],
+ UserSettings.Get(group='vdigit', key='symbolBoundaryOne', subkey='color')[1],
+ UserSettings.Get(group='vdigit', key='symbolBoundaryOne', subkey='color')[2],
+ 255).GetRGB(),
+ UserSettings.Get(group='vdigit', key='symbolBoundaryTwo', subkey='enabled'),
+ wx.Color(UserSettings.Get(group='vdigit', key='symbolBoundaryTwo', subkey='color')[0],
+ UserSettings.Get(group='vdigit', key='symbolBoundaryTwo', subkey='color')[1],
+ UserSettings.Get(group='vdigit', key='symbolBoundaryTwo', subkey='color')[2],
+ 255).GetRGB(),
+ UserSettings.Get(group='vdigit', key='symbolCentroidIn', subkey='enabled'),
+ wx.Color(UserSettings.Get(group='vdigit', key='symbolCentroidIn', subkey='color')[0],
+ UserSettings.Get(group='vdigit', key='symbolCentroidIn', subkey='color')[1],
+ UserSettings.Get(group='vdigit', key='symbolCentroidIn', subkey='color')[2],
+ 255).GetRGB(),
+ UserSettings.Get(group='vdigit', key='symbolCentroidOut', subkey='enabled'),
+ wx.Color(UserSettings.Get(group='vdigit', key='symbolCentroidOut', subkey='color')[0],
+ UserSettings.Get(group='vdigit', key='symbolCentroidOut', subkey='color')[1],
+ UserSettings.Get(group='vdigit', key='symbolCentroidOut', subkey='color')[2],
+ 255).GetRGB(),
+ UserSettings.Get(group='vdigit', key='symbolCentroidDup', subkey='enabled'),
+ wx.Color(UserSettings.Get(group='vdigit', key='symbolCentroidDup', subkey='color')[0],
+ UserSettings.Get(group='vdigit', key='symbolCentroidDup', subkey='color')[1],
+ UserSettings.Get(group='vdigit', key='symbolCentroidDup', subkey='color')[2],
+ 255).GetRGB(),
+ UserSettings.Get(group='vdigit', key='symbolNodeOne', subkey='enabled'),
+ wx.Color(UserSettings.Get(group='vdigit', key='symbolNodeOne', subkey='color')[0],
+ UserSettings.Get(group='vdigit', key='symbolNodeOne', subkey='color')[1],
+ UserSettings.Get(group='vdigit', key='symbolNodeOne', subkey='color')[2],
+ 255).GetRGB(),
+ UserSettings.Get(group='vdigit', key='symbolNodeTwo', subkey='enabled'),
+ wx.Color(UserSettings.Get(group='vdigit', key='symbolNodeTwo', subkey='color')[0],
+ UserSettings.Get(group='vdigit', key='symbolNodeTwo', subkey='color')[1],
+ UserSettings.Get(group='vdigit', key='symbolNodeTwo', subkey='color')[2],
+ 255).GetRGB(),
+ UserSettings.Get(group='vdigit', key='symbolVertex', subkey='enabled'),
+ wx.Color(UserSettings.Get(group='vdigit', key='symbolVertex', subkey='color')[0],
+ UserSettings.Get(group='vdigit', key='symbolVertex', subkey='color')[1],
+ UserSettings.Get(group='vdigit', key='symbolVertex', subkey='color')[2],
+ 255).GetRGB(),
+ UserSettings.Get(group='vdigit', key='lineWidth', subkey='value'))
+class VDigitSettingsDialog(wx.Dialog):
+ Standard settings dialog for digitization purposes
+ def __init__(self, parent, title, style=wx.DEFAULT_DIALOG_STYLE):
+ wx.Dialog.__init__(self, parent=parent, id=wx.ID_ANY, title=title, style=style)
+ self.parent = parent # mapdisplay.BufferedWindow class instance
+ # notebook
+ notebook = wx.Notebook(parent=self, id=wx.ID_ANY, style=wx.BK_DEFAULT)
+ self.__CreateSymbologyPage(notebook)
+ parent.digit.SetCategory() # update category number (next to use)
+ self.__CreateGeneralPage(notebook)
+ self.__CreateAttributesPage(notebook)
+ self.__CreateQueryPage(notebook)
+ # buttons
+ btnApply = wx.Button(self, wx.ID_APPLY)
+ btnCancel = wx.Button(self, wx.ID_CANCEL)
+ btnSave = wx.Button(self, wx.ID_SAVE)
+ btnSave.SetDefault()
+ # bindigs
+ btnApply.Bind(wx.EVT_BUTTON, self.OnApply)
+ btnApply.SetToolTipString(_("Apply changes for this session"))
+ btnApply.SetDefault()
+ btnSave.Bind(wx.EVT_BUTTON, self.OnSave)
+ btnSave.SetToolTipString(_("Close dialog and save changes to user settings file"))
+ btnCancel.Bind(wx.EVT_BUTTON, self.OnCancel)
+ btnCancel.SetToolTipString(_("Close dialog and ignore changes"))
+ # sizers
+ btnSizer = wx.StdDialogButtonSizer()
+ btnSizer.AddButton(btnCancel)
+ btnSizer.AddButton(btnApply)
+ btnSizer.AddButton(btnSave)
+ btnSizer.Realize()
+ mainSizer = wx.BoxSizer(wx.VERTICAL)
+ mainSizer.Add(item=notebook, proportion=1, flag=wx.EXPAND | wx.ALL, border=5)
+ mainSizer.Add(item=btnSizer, proportion=0,
+ flag=wx.EXPAND | wx.ALL | wx.ALIGN_CENTER, border=5)
+ self.SetSizer(mainSizer)
+ mainSizer.Fit(self)
+ def __CreateSymbologyPage(self, notebook):
+ """Create notebook page concerning with symbology settings"""
+ panel = wx.Panel(parent=notebook, id=wx.ID_ANY)
+ notebook.AddPage(page=panel, text=_("Symbology"))
+ sizer = wx.BoxSizer(wx.VERTICAL)
+ flexSizer = wx.FlexGridSizer (cols=3, hgap=5, vgap=5)
+ flexSizer.AddGrowableCol(0)
+ self.symbology = {}
+ for label, key in self.__SymbologyData():
+ textLabel = wx.StaticText(panel, wx.ID_ANY, label)
+ color = csel.ColourSelect(panel, id=wx.ID_ANY,
+ colour=UserSettings.Get(group='vdigit', key=key, subkey='color'), size=(25, 25))
+ isEnabled = UserSettings.Get(group='vdigit', key=key, subkey='enabled')
+ if isEnabled is not None:
+ enabled = wx.CheckBox(panel, id=wx.ID_ANY, label="")
+ enabled.SetValue(isEnabled)
+ self.symbology[key] = (enabled, color)
+ else:
+ enabled = (1, 1)
+ self.symbology[key] = (None, color)
+ flexSizer.Add(textLabel, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
+ flexSizer.Add(enabled, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
+ flexSizer.Add(color, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
+ sizer.Add(item=flexSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=10)
+ panel.SetSizer(sizer)
+ return panel
+ def __CreateGeneralPage(self, notebook):
+ notebook.AddPage(page=panel, text=_("General"))
+ border = wx.BoxSizer(wx.VERTICAL)
+ # display section
+ box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Display"))
+ sizer = wx.StaticBoxSizer(box, wx.VERTICAL)
+ # line width
+ text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Line width"))
+ self.lineWidthValue = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(75, -1),
+ initial=UserSettings.Get(group='vdigit', key="lineWidth", subkey='value'),
+ min=1, max=1e6)
+ units = wx.StaticText(parent=panel, id=wx.ID_ANY, size=(115, -1),
+ label=UserSettings.Get(group='vdigit', key="lineWidth", subkey='units'),
+ style=wx.ALIGN_LEFT)
+ flexSizer.Add(text, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
+ flexSizer.Add(self.lineWidthValue, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
+ flexSizer.Add(units, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE | wx.ALIGN_CENTER_VERTICAL | wx.LEFT,
+ border=10)
+ sizer.Add(item=flexSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=1)
+ border.Add(item=sizer, proportion=0, flag=wx.ALL | wx.EXPAND, border=5)
+ # snapping section
+ box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Snapping"))
+ flexSizer1 = wx.FlexGridSizer (cols=3, hgap=5, vgap=5)
+ flexSizer1.AddGrowableCol(0)
+ flexSizer2 = wx.FlexGridSizer (cols=2, hgap=5, vgap=5)
+ flexSizer2.AddGrowableCol(0)
+ # snapping
+ text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Snapping threshold"))
+ self.snappingValue = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(75, -1),
+ initial=UserSettings.Get(group='vdigit', key="snapping", subkey='value'),
+ min=1, max=1e6)
+ self.snappingValue.Bind(wx.EVT_SPINCTRL, self.OnChangeSnappingValue)
+ self.snappingUnit = wx.Choice(parent=panel, id=wx.ID_ANY, size=(125, -1),
+ choices=["screen pixels", "map units"])
+ self.snappingUnit.SetStringSelection(UserSettings.Get(group='vdigit', key="snapping", subkey='units'))
+ self.snappingUnit.Bind(wx.EVT_CHOICE, self.OnChangeSnappingUnits)
+ flexSizer1.Add(text, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
+ flexSizer1.Add(self.snappingValue, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
+ flexSizer1.Add(self.snappingUnit, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
+ # background map
+ text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Backgroud vector map"))
+ self.backgroundMap = gselect.Select(parent=panel, id=wx.ID_ANY, size=(200,-1),
+ type="vector")
+ self.backgroundMap.SetValue(UserSettings.Get(group='vdigit', key="backgroundMap", subkey='value'))
+ self.backgroundMap.Bind(wx.EVT_TEXT, self.OnChangeBackgroundMap)
+ flexSizer2.Add(text, proportion=1, flag=wx.ALIGN_CENTER_VERTICAL)
+ flexSizer2.Add(self.backgroundMap, proportion=1, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
+ #flexSizer.Add(self.snappingUnit, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
+ vertexSizer = wx.BoxSizer(wx.VERTICAL)
+ self.snapVertex = wx.CheckBox(parent=panel, id=wx.ID_ANY,
+ label=_("Snap also to vertex"))
+ self.snapVertex.SetValue(UserSettings.Get(group='vdigit', key="snapToVertex", subkey='enabled'))
+ vertexSizer.Add(item=self.snapVertex, proportion=0, flag=wx.EXPAND)
+ self.mapUnits = self.parent.MapWindow.Map.ProjInfo()['units']
+ self.snappingInfo = wx.StaticText(parent=panel, id=wx.ID_ANY,
+ label=_("Snapping threshold is %(value).1f %(units)s") % \
+ {'value' : self.parent.digit.driver.GetThreshold(),
+ 'units' : self.mapUnits})
+ vertexSizer.Add(item=self.snappingInfo, proportion=0,
+ flag=wx.ALL | wx.EXPAND, border=1)
+ sizer.Add(item=flexSizer1, proportion=1, flag=wx.TOP | wx.LEFT | wx.EXPAND, border=1)
+ sizer.Add(item=flexSizer2, proportion=1, flag=wx.TOP | wx.LEFT | wx.EXPAND, border=1)
+ sizer.Add(item=vertexSizer, proportion=1, flag=wx.BOTTOM | wx.LEFT | wx.EXPAND, border=1)
+ border.Add(item=sizer, proportion=0, flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border=5)
+ # select box
+ box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Select vector features"))
+ # feature type
+ inSizer = wx.BoxSizer(wx.HORIZONTAL)
+ self.selectFeature = {}
+ for feature in ('Point', 'Line',
+ 'Centroid', 'Boundary'):
+ chkbox = wx.CheckBox(parent=panel, label=feature)
+ self.selectFeature[feature] = chkbox.GetId()
+ chkbox.SetValue(UserSettings.Get(group='vdigit', key='selectFeature'+feature, subkey='enabled'))
+ inSizer.Add(item=chkbox, proportion=0,
+ flag=wx.EXPAND | wx.ALL, border=5)
+ sizer.Add(item=inSizer, proportion=0, flag=wx.EXPAND)
+ # threshold
+ text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Select threshold"))
+ self.selectThreshValue = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(75, -1),
+ initial=UserSettings.Get(group='vdigit', key="selectThresh", subkey='value'),
+ min=1, max=1e6)
+ flexSizer.Add(self.selectThreshValue, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
+ border=10)
+ sizer.Add(item=flexSizer, proportion=0, flag=wx.EXPAND)
+ border.Add(item=sizer, proportion=0, flag=wx.EXPAND | wx.LEFT | wx.RIGHT | wx.BOTTOM, border=5)
+ # save-on-exit box
+ box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Save changes"))
+ # save changes on exit?
+ self.save = wx.CheckBox(parent=panel, label=_("Save changes on exit automatically"))
+ self.save.SetValue(UserSettings.Get(group='vdigit', key='saveOnExit', subkey='enabled'))
+ sizer.Add(item=self.save, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
+ panel.SetSizer(border)
+ return panel
+ def __CreateQueryPage(self, notebook):
+ """Create notebook page for query tool"""
+ notebook.AddPage(page=panel, text=_("Query tool"))
+ # query tool box
+ box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Choose query tool"))
+ LocUnits = self.parent.MapWindow.Map.ProjInfo()['units']
+ self.queryBox = wx.CheckBox(parent=panel, id=wx.ID_ANY, label=_("Select by box"))
+ self.queryBox.SetValue(UserSettings.Get(group='vdigit', key="query", subkey='box'))
+ sizer.Add(item=self.queryBox, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
+ sizer.Add((0, 5))
+ # length
+ self.queryLength = wx.RadioButton(parent=panel, id=wx.ID_ANY, label=_("length"))
+ self.queryLength.Bind(wx.EVT_RADIOBUTTON, self.OnChangeQuery)
+ sizer.Add(item=self.queryLength, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
+ flexSizer = wx.FlexGridSizer (cols=4, hgap=5, vgap=5)
+ txt = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Select lines"))
+ self.queryLengthSL = wx.Choice (parent=panel, id=wx.ID_ANY,
+ choices = [_("shorter than"), _("longer than")])
+ self.queryLengthSL.SetSelection(UserSettings.Get(group='vdigit', key="queryLength", subkey='than-selection'))
+ self.queryLengthValue = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(100, -1),
+ initial=1,
+ min=0, max=1e6)
+ self.queryLengthValue.SetValue(UserSettings.Get(group='vdigit', key="queryLength", subkey='thresh'))
+ units = wx.StaticText(parent=panel, id=wx.ID_ANY, label="%s" % LocUnits)
+ flexSizer.Add(txt, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
+ flexSizer.Add(self.queryLengthSL, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
+ flexSizer.Add(self.queryLengthValue, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
+ flexSizer.Add(units, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
+ sizer.Add(item=flexSizer, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
+ # dangle
+ self.queryDangle = wx.RadioButton(parent=panel, id=wx.ID_ANY, label=_("dangle"))
+ self.queryDangle.Bind(wx.EVT_RADIOBUTTON, self.OnChangeQuery)
+ sizer.Add(item=self.queryDangle, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
+ txt = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Select dangles"))
+ self.queryDangleSL = wx.Choice (parent=panel, id=wx.ID_ANY,
+ self.queryDangleSL.SetSelection(UserSettings.Get(group='vdigit', key="queryDangle", subkey='than-selection'))
+ self.queryDangleValue = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(100, -1),
+ initial=1,
+ min=0, max=1e6)
+ self.queryDangleValue.SetValue(UserSettings.Get(group='vdigit', key="queryDangle", subkey='thresh'))
+ flexSizer.Add(self.queryDangleSL, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
+ flexSizer.Add(self.queryDangleValue, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
+ if UserSettings.Get(group='vdigit', key="query", subkey='selection') == 0:
+ self.queryLength.SetValue(True)
+ else:
+ self.queryDangle.SetValue(True)
+ # enable & disable items
+ self.OnChangeQuery(None)
+ return panel
+ def __CreateAttributesPage(self, notebook):
+ notebook.AddPage(page=panel, text=_("Attributes"))
+ # add new record
+ box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Digitize new feature"))
+ # checkbox
+ self.addRecord = wx.CheckBox(parent=panel, id=wx.ID_ANY,
+ label=_("Add new record into table"))
+ self.addRecord.SetValue(UserSettings.Get(group='vdigit', key="addRecord", subkey='enabled'))
+ sizer.Add(item=self.addRecord, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
+ # settings
+ flexSizer = wx.FlexGridSizer(cols=2, hgap=3, vgap=3)
+ settings = ((_("Layer"), 1), (_("Category"), 1), (_("Mode"), _("Next to use")))
+ # layer
+ text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Layer"))
+ if self.parent.digit.map:
+ layers = map(str, self.parent.digit.GetLayers())
+ if len(layers) == 0:
+ layers = [str(UserSettings.Get(group='vdigit', key="layer", subkey='value')), ]
+ else:
+ self.layer = wx.Choice(parent=panel, id=wx.ID_ANY, size=(125, -1),
+ choices=layers)
+ self.layer.SetStringSelection(str(UserSettings.Get(group='vdigit', key="layer", subkey='value')))
+ flexSizer.Add(item=text, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
+ flexSizer.Add(item=self.layer, proportion=0,
+ flag=wx.FIXED_MINSIZE | wx.ALIGN_CENTER_VERTICAL)
+ # category number
+ text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Category number"))
+ self.category = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(125, -1),
+ initial=UserSettings.Get(group='vdigit', key="category", subkey='value'),
+ min=-1e9, max=1e9)
+ if UserSettings.Get(group='vdigit', key="categoryMode", subkey='selection') != 1:
+ self.category.Enable(False)
+ flexSizer.Add(item=self.category, proportion=0,
+ # category mode
+ text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Category mode"))
+ self.categoryMode = wx.Choice(parent=panel, id=wx.ID_ANY, size=(125, -1),
+ choices=[_("Next to use"), _("Manual entry"), _("No category")])
+ self.categoryMode.SetSelection(UserSettings.Get(group='vdigit', key="categoryMode", subkey='selection'))
+ flexSizer.Add(item=self.categoryMode, proportion=0,
+ flag=wx.ALL | wx.EXPAND, border=5)
+ # delete existing record
+ box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Delete existing feature(s)"))
+ # checkbox
+ self.deleteRecord = wx.CheckBox(parent=panel, id=wx.ID_ANY,
+ label=_("Delete record from table"))
+ self.deleteRecord.SetValue(UserSettings.Get(group='vdigit', key="delRecord", subkey='enabled'))
+ sizer.Add(item=self.deleteRecord, proportion=0, flag=wx.ALL | wx.EXPAND, border=1)
+ flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border=5)
+ # bindings
+ self.Bind(wx.EVT_CHECKBOX, self.OnChangeAddRecord, self.addRecord)
+ self.Bind(wx.EVT_CHOICE, self.OnChangeCategoryMode, self.categoryMode)
+ self.Bind(wx.EVT_CHOICE, self.OnChangeLayer, self.layer)
+ return panel
+ def __SymbologyData(self):
+ Data for __CreateSymbologyPage()
+ label | checkbox | color
+ return (
+ # ("Background", "symbolBackground"),
+ (_("Highlight"), "symbolHighlight"),
+ (_("Point"), "symbolPoint"),
+ (_("Line"), "symbolLine"),
+ (_("Boundary (no area)"), "symbolBoundaryNo"),
+ (_("Boundary (one area)"), "symbolBoundaryOne"),
+ (_("Boundary (two areas)"), "symbolBoundaryTwo"),
+ (_("Centroid (in area)"), "symbolCentroidIn"),
+ (_("Centroid (outside area)"), "symbolCentroidOut"),
+ (_("Centroid (duplicate in area)"), "symbolCentroidDup"),
+ (_("Node (one line)"), "symbolNodeOne"),
+ (_("Node (two lines)"), "symbolNodeTwo"),
+ (_("Vertex"), "symbolVertex"))
+ def OnChangeCategoryMode(self, event):
+ """Change category mode"""
+ mode = event.GetSelection()
+ UserSettings.Set(group='vdigit', key="categoryMode", subkey='selection', value=mode)
+ if mode == 1: # manual entry
+ self.category.Enable(True)
+ elif self.category.IsEnabled(): # disable
+ if mode == 2 and self.addRecord.IsChecked(): # no category
+ self.addRecord.SetValue(False)
+ self.parent.digit.SetCategory()
+ self.category.SetValue(UserSettings.Get(group='vdigit', key='category', subkey='value'))
+ def OnChangeLayer(self, event):
+ """Layer changed"""
+ layer = int(event.GetString())
+ if layer > 0:
+ UserSettings.Set(group='vdigit', key='layer', subkey='value', value=layer)
+ event.Skip()
+ def OnChangeAddRecord(self, event):
+ """Checkbox 'Add new record' status changed"""
+ self.category.SetValue(self.parent.digit.SetCategory())
+ def OnChangeSnappingValue(self, event):
+ """Change snapping value - update static text"""
+ value = self.snappingValue.GetValue()
+ if self.snappingUnit.GetStringSelection() == "map units":
+ threshold = value
+ else:
+ threshold = self.parent.digit.driver.GetThreshold(value=value)
+ self.snappingInfo.SetLabel(_("Snapping threshold is %(value).1f %(units)s") %
+ {'value' : threshold,
+ event.Skip()
+ def OnChangeSnappingUnits(self, event):
+ """Snapping units change -> update static text"""
+ units = self.snappingUnit.GetStringSelection()
+ threshold = self.parent.digit.driver.GetThreshold(value=value, units=units)
+ if units == "map units":
+ {'value' : value,
+ else:
+ event.Skip()
+ def OnChangeBackgroundMap(self, event):
+ """Change background map"""
+ map = self.backgroundMap.GetValue()
+ UserSettings.Set(group='vdigit', key='backgroundMap', subkey='value', value=map)
+ def OnChangeQuery(self, event):
+ """Change query"""
+ if self.queryLength.GetValue():
+ # length
+ self.queryLengthSL.Enable(True)
+ self.queryLengthValue.Enable(True)
+ self.queryDangleSL.Enable(False)
+ self.queryDangleValue.Enable(False)
+ else:
+ # dangle
+ self.queryLengthSL.Enable(False)
+ self.queryLengthValue.Enable(False)
+ self.queryDangleSL.Enable(True)
+ self.queryDangleValue.Enable(True)
+ def OnSave(self, event):
+ """Button 'Save' clicked"""
+ self.parent.digittoolbar.settingsDialog = None
+ fileSettings = {}
+ UserSettings.ReadSettingsFile(settings=fileSettings)
+ fileSettings['vdigit'] = UserSettings.Get(group='vdigit')
+ file = UserSettings.SaveToFile(fileSettings)
+ self.parent.gismanager.goutput.WriteLog('Vector digitizer settings saved to file <%s>.' % file)
+ self.Close()
+ def OnApply(self, event):
+ """Button 'Apply' clicked"""
+ def OnCancel(self, event):
+ """Button 'Cancel' clicked"""
+ self.Close()
+ """Update UserSettings"""
+ # symbology
+ for key, (enabled, color) in self.symbology.iteritems():
+ if enabled:
+ UserSettings.Set(group='vdigit', key=key, subkey='enabled',
+ value=enabled.IsChecked())
+ UserSettings.Set(group='vdigit', key=key, subkey='color',
+ value=color.GetColour())
+ else:
+ # display
+ UserSettings.Set(group='vdigit', key="lineWidth", subkey='value',
+ value=int(self.lineWidthValue.GetValue()))
+ # snapping
+ UserSettings.Set(group='vdigit', key="snapping", subkey='value',
+ value=int(self.snappingValue.GetValue()))
+ UserSettings.Set(group='vdigit', key="snapping", subkey='units',
+ value=self.snappingUnit.GetStringSelection())
+ UserSettings.Set(group='vdigit', key="snapToVertex", subkey='enabled',
+ value=self.snapVertex.IsChecked())
+ # digitize new feature
+ UserSettings.Set(group='vdigit', key="addRecord", subkey='enabled',
+ value=self.addRecord.IsChecked())
+ UserSettings.Set(group='vdigit', key="layer", subkey='value',
+ value=int(self.layer.GetStringSelection()))
+ UserSettings.Set(group='vdigit', key="category", subkey='value',
+ value=int(self.category.GetValue()))
+ value=self.categoryMode.GetSelection())
+ # delete existing feature
+ UserSettings.Set(group='vdigit', key="delRecord", subkey='enabled',
+ value=self.deleteRecord.IsChecked())
+ # snapping threshold
+ self.parent.digit.threshold = self.parent.digit.driver.GetThreshold()
+ # query tool
+ UserSettings.Set(group='vdigit', key="query", subkey='selection',
+ value=0)
+ else:
+ UserSettings.Set(group='vdigit', key="query", subkey='type',
+ value=1)
+ UserSettings.Set(group='vdigit', key="query", subkey='box',
+ value=self.queryBox.IsChecked())
+ UserSettings.Set(group='vdigit', key="queryLength", subkey='than-selection',
+ value=self.queryLengthSL.GetSelection())
+ UserSettings.Set(group='vdigit', key="queryLength", subkey='thresh',
+ value=int(self.queryLengthValue.GetValue()))
+ UserSettings.Set(group='vdigit', key="queryDangle", subkey='than-selection',
+ value=self.queryDangleSL.GetSelection())
+ UserSettings.Set(group='vdigit', key="queryDangle", subkey='thresh',
+ value=int(self.queryDangleValue.GetValue()))
+ # select features
+ UserSettings.Set(group='vdigit', key='selectFeature'+feature, subkey='enabled',
+ value=self.FindWindowById(self.selectFeature[feature]).IsChecked())
+ UserSettings.Set(group='vdigit', key="selectThresh", subkey='value',
+ value=int(self.selectThreshValue.GetValue()))
+ # on-exit
+ UserSettings.Set(group='vdigit', key="saveOnExit", subkey='enabled',
+ value=self.save.IsChecked())
+ # update driver settings
+ self.parent.digit.driver.UpdateSettings()
+ # redraw map if auto-rendering is enabled
+ if self.parent.autoRender.GetValue():
+ self.parent.OnRender(None)
+class VDigitCategoryDialog(wx.Dialog, listmix.ColumnSorterMixin):
+ Dialog used to display/modify categories of vector objects
+ @param parent
+ @param title dialog title
+ @param query {coordinates, qdist} - v.edit/v.what
+ @param cats directory of categories - vdigit
+ @param line line id - vdigit
+ @param pos
+ @param style
+ map, query=None, cats=None, line=None,
+ pos=wx.DefaultPosition,
+ style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
+ # parent
+ # map name
+ self.map = map
+ # line id (if not found remains 'None')
+ self.line = None
+ # {layer: [categories]}
+ self.cats = {}
+ # do not display dialog if no line is found (-> self.cats)
+ if cats is None:
+ if self.__GetCategories(query[0], query[1]) == 0 or not self.line:
+ Debug.msg(3, "VDigitCategoryDialog(): nothing found!")
+ return
+ else:
+ # self.cats = dict(cats)
+ for layer in cats.keys():
+ self.cats[layer] = list(cats[layer]) # TODO: tuple to list
+ self.line = line
+ # make copy of cats (used for 'reload')
+ self.cats_orig = copy.deepcopy(self.cats)
+ Debug.msg(3, "VDigitCategoryDialog(): line=%d, cats=%s" % \
+ (self.line, self.cats))
+ wx.Dialog.__init__(self, parent=self.parent, id=wx.ID_ANY, title=title,
+ style=style, pos=pos)
+ # list of categories
+ box = wx.StaticBox(parent=self, id=wx.ID_ANY,
+ label=" %s " % _("List of categories"))
+ listSizer = wx.StaticBoxSizer(box, wx.VERTICAL)
+ self.list = CategoryListCtrl(parent=self, id=wx.ID_ANY,
+ style=wx.LC_REPORT |
+ wx.BORDER_NONE |
+ wx.LC_SORT_ASCENDING |
+ wx.LC_HRULES |
+ wx.LC_VRULES)
+ # sorter
+ self.itemDataMap = self.list.Populate()
+ listmix.ColumnSorterMixin.__init__(self, 2)
+ listSizer.Add(item=self.list, proportion=1, flag=wx.EXPAND)
+ # add new category
+ label=" %s " % _("Add new category"))
+ addSizer = wx.StaticBoxSizer(box, wx.VERTICAL)
+ flexSizer = wx.FlexGridSizer (cols=5, hgap=5, vgap=5)
+ flexSizer.AddGrowableCol(3)
+ layerNewTxt = wx.StaticText(parent=self, id=wx.ID_ANY,
+ label="%s:" % _("Layer"))
+ self.layerNew = wx.SpinCtrl(parent=self, id=wx.ID_ANY, size=(50, -1),
+ initial=1, min=1, max=1e9)
+ catNewTxt = wx.StaticText(parent=self, id=wx.ID_ANY,
+ label="%s:" % _("Category"))
+ try:
+ newCat = max(self.cats[1]) + 1
+ except:
+ newCat = 1
+ self.catNew = wx.SpinCtrl(parent=self, id=wx.ID_ANY, size=(75, -1),
+ initial=newCat, min=-1e9, max=1e9)
+ btnAddCat = wx.Button(self, wx.ID_ADD)
+ flexSizer.Add(item=layerNewTxt, proportion=0,
+ flexSizer.Add(item=self.layerNew, proportion=0,
+ flexSizer.Add(item=catNewTxt, proportion=0,
+ flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT | wx.LEFT,
+ border=10)
+ flexSizer.Add(item=self.catNew, proportion=0,
+ flexSizer.Add(item=btnAddCat, proportion=0,
+ flag=wx.EXPAND | wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
+ addSizer.Add(item=flexSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=5)
+ # buttons
+ #btnReload = wx.Button(self, wx.ID_UNDO, _("&Reload"))
+ btnOk = wx.Button(self, wx.ID_OK)
+ btnOk.SetDefault()
+ # sizers
+ #btnSizer.AddButton(btnReload)
+ #btnSizer.SetNegativeButton(btnReload)
+ btnSizer.AddButton(btnOk)
+ mainSizer.Add(item=listSizer, proportion=1,
+ mainSizer.Add(item=addSizer, proportion=0,
+ flag=wx.EXPAND | wx.ALIGN_CENTER |
+ wx.LEFT | wx.RIGHT | wx.BOTTOM, border=5)
+ self.SetAutoLayout(True)
+ # set min size for dialog
+ self.SetMinSize(self.GetBestSize())
+ # bindings
+ # buttons
+ #btnReload.Bind(wx.EVT_BUTTON, self.OnReload)
+ btnOk.Bind(wx.EVT_BUTTON, self.OnOK)
+ btnAddCat.Bind(wx.EVT_BUTTON, self.OnAddCat)
+ # list
+ # self.Bind(wx.EVT_LIST_ITEM_SELECTED, self.OnItemSelected, self.list)
+ # self.list.Bind(wx.EVT_RIGHT_DOWN, self.OnRightDown)
+ self.list.Bind(wx.EVT_COMMAND_RIGHT_CLICK, self.OnRightUp) #wxMSW
+ self.list.Bind(wx.EVT_RIGHT_UP, self.OnRightUp) #wxGTK
+ self.Bind(wx.EVT_LIST_BEGIN_LABEL_EDIT, self.OnBeginEdit, self.list)
+ self.Bind(wx.EVT_LIST_END_LABEL_EDIT, self.OnEndEdit, self.list)
+ self.Bind(wx.EVT_LIST_COL_CLICK, self.OnColClick, self.list)
+ def GetListCtrl(self):
+ """Used by ColumnSorterMixin"""
+ return self.list
+ def OnColClick(self, event):
+ """Click on column header (order by)"""
+ event.Skip()
+ def OnBeginEdit(self, event):
+ """Editing of item started"""
+ event.Allow()
+ def OnEndEdit(self, event):
+ """Finish editing of item"""
+ itemIndex = event.GetIndex()
+ layerOld = int (self.list.GetItem(itemIndex, 0).GetText())
+ catOld = int (self.list.GetItem(itemIndex, 1).GetText())
+ if event.GetColumn() == 0:
+ layerNew = int(event.GetLabel())
+ catNew = catOld
+ else:
+ layerNew = layerOld
+ catNew = int(event.GetLabel())
+ try:
+ if layerNew not in self.cats.keys():
+ self.cats[layerNew] = []
+ self.cats[layerNew].append(catNew)
+ self.cats[layerOld].remove(catOld)
+ except:
+ event.Veto()
+ self.list.SetStringItem(itemIndex, 0, str(layerNew))
+ self.list.SetStringItem(itemIndex, 1, str(catNew))
+ dlg = wx.MessageDialog(self, _("Unable to add new layer/category <%(layer)s/%(category)s>.\n"
+ "Layer and category number must be integer.\n"
+ "Layer number must be greater then zero.") %
+ { 'layer': str(self.layerNew.GetValue()),
+ 'category' : str(self.catNew.GetValue()) },
+ _("Error"), wx.OK | wx.ICON_ERROR)
+ dlg.ShowModal()
+ dlg.Destroy()
+ return False
+ def OnRightDown(self, event):
+ """Mouse right button down"""
+ x = event.GetX()
+ y = event.GetY()
+ item, flags = self.list.HitTest((x, y))
+ if item != wx.NOT_FOUND and \
+ flags & wx.LIST_HITTEST_ONITEM:
+ self.list.Select(item)
+ event.Skip()
+ def OnRightUp(self, event):
+ """Mouse right button up"""
+ if not hasattr(self, "popupID1"):
+ self.popupID1 = wx.NewId()
+ self.popupID2 = wx.NewId()
+ self.popupID3 = wx.NewId()
+ self.Bind(wx.EVT_MENU, self.OnItemDelete, id=self.popupID1)
+ self.Bind(wx.EVT_MENU, self.OnItemDeleteAll, id=self.popupID2)
+ self.Bind(wx.EVT_MENU, self.OnReload, id=self.popupID3)
+ # generate popup-menu
+ menu = wx.Menu()
+ menu.Append(self.popupID1, _("Delete selected"))
+ if self.list.GetFirstSelected() == -1:
+ menu.Enable(self.popupID1, False)
+ menu.Append(self.popupID2, _("Delete all"))
+ menu.AppendSeparator()
+ menu.Append(self.popupID3, _("Reload"))
+ self.PopupMenu(menu)
+ menu.Destroy()
+ def OnItemSelected(self, event):
+ """Item selected"""
+ event.Skip()
+ def OnItemDelete(self, event):
+ """Delete selected item(s) from the list (layer/category pair)"""
+ item = self.list.GetFirstSelected()
+ while item != -1:
+ layer = int (self.list.GetItem(item, 0).GetText())
+ cat = int (self.list.GetItem(item, 1).GetText())
+ self.list.DeleteItem(item)
+ self.cats[layer].remove(cat)
+ event.Skip()
+ def OnItemDeleteAll(self, event):
+ """Delete all items from the list"""
+ self.list.DeleteAllItems()
+ self.cats = {}
+ event.Skip()
+ def __GetCategories(self, coords, qdist):
+ """Get layer/category pairs for all available
+ layers
+ Return True line found or False if not found"""
+ cmdWhat = gcmd.Command(cmd=['v.what',
+ '--q',
+ 'east_north=%f,%f' % \
+ (float(coords[0]), float(coords[1])),
+ 'distance=%f' % qdist])
+ if cmdWhat.returncode != 0:
+ return False
+ for item in cmdWhat.ReadStdOutput():
+ litem = item.lower()
+ if "line:" in litem: # get line id
+ self.line = int(item.split(':')[1].strip())
+ elif "layer:" in litem: # add layer
+ layer = int(item.split(':')[1].strip())
+ if layer not in self.cats.keys():
+ self.cats[layer] = []
+ elif "category:" in litem: # add category
+ self.cats[layer].append(int(item.split(':')[1].strip()))
+ return True
+ def OnReload(self, event):
+ """Reload button pressed"""
+ # restore original list
+ self.cats = copy.deepcopy(self.cats_orig)
+ # polulate list
+ self.itemDataMap = self.list.Populate(update=True)
+ event.Skip()
+ """Cancel button pressed"""
+ self.parent.parent.dialogs['category'] = None
+ if self.parent.parent.digit:
+ self.parent.parent.digit.driver.SetSelected([])
+ self.parent.UpdateMap(render=False)
+ else:
+ self.parent.parent.OnRender(None)
+ self.Close()
+ """Apply button pressed"""
+ # action : (catsFrom, catsTo)
+ check = {'catadd': (self.cats, self.cats_orig),
+ 'catdel': (self.cats_orig, self.cats)}
+ # add/delete new category
+ for action, cats in check.iteritems():
+ for layer in cats[0].keys():
+ catList = []
+ for cat in cats[0][layer]:
+ if layer not in cats[1].keys() or \
+ cat not in cats[1][layer]:
+ catList.append(cat)
+ if catList != []:
+ vEditCmd = ['v.edit', '--q',
+ 'tool=%s' % action,
+ 'cats=%s' % ",".join(["%d" % v for v in catList]),
+ 'id=%d' % self.line]
+ gcmd.Command(vEditCmd)
+ else:
+ if action == 'catadd':
+ add = True
+ else:
+ add = False
+ self.line = self.parent.parent.digit.SetLineCats(-1, layer,
+ catList, add)
+ if self.line < 0:
+ wx.MessageBox(parent=self, message=_("Unable to update vector map."),
+ caption=_("Error"), style=wx.OK | wx.ICON_ERROR)
+ self.parent.parent.digit.driver.ReloadMap()
+ event.Skip()
+ def OnOK(self, event):
+ """OK button pressed"""
+ self.OnApply(event)
+ self.OnCancel(event)
+ def OnAddCat(self, event):
+ """Button 'Add' new category pressed"""
+ try:
+ layer = int(self.layerNew.GetValue())
+ cat = int(self.catNew.GetValue())
+ if layer <= 0:
+ raise ValueError
+ except ValueError:
+ {'layer' : str(self.layerNew.GetValue()),
+ 'category' : str(self.catNew.GetValue())},
+ dlg.ShowModal()
+ dlg.Destroy()
+ return False
+ self.cats[layer].append(cat)
+ # reload list
+ # update category number for add
+ self.catNew.SetValue(cat + 1)
+ event.Skip()
+ return True
+ def GetLine(self):
+ """Get id of selected line of 'None' if no line is selected"""
+ return self.line
+ def UpdateDialog(self, query=None, cats=None, line=None):
+ """Update dialog
+ @param query {coordinates, distance} - v.edit/v.what
+ @param cats directory layer/cats - vdigit
+ Return True if updated otherwise False
+ self.line = None
+ self.cats = {}
+ if cats is None:
+ ret = self.__GetCategories(query[0], query[1])
+ else:
+ self.line = line
+ ret = 1
+ if ret == 0 or not self.line:
+ return False
+ # polulate list
+ try:
+ except:
+ newCat = 1
+ self.catNew.SetValue(newCat)
+ return True
+class CategoryListCtrl(wx.ListCtrl,
+ listmix.ListCtrlAutoWidthMixin,
+ listmix.TextEditMixin):
+ """List of layers/categories"""
+ def __init__(self, parent, id, pos=wx.DefaultPosition,
+ size=wx.DefaultSize, style=0):
+ wx.ListCtrl.__init__(self, parent, id, pos, size, style)
+ listmix.ListCtrlAutoWidthMixin.__init__(self)
+ listmix.TextEditMixin.__init__(self)
+ def Populate(self, update=False):
+ """Populate the list"""
+ itemData = {} # requested by sorter
+ if not update:
+ self.InsertColumn(0, _("Layer"))
+ self.InsertColumn(1, _("Category"))
+ else:
+ self.DeleteAllItems()
+ i = 1
+ for layer in self.parent.cats.keys():
+ catsList = self.parent.cats[layer]
+ for cat in catsList:
+ index = self.InsertStringItem(sys.maxint, str(catsList[0]))
+ self.SetStringItem(index, 0, str(layer))
+ self.SetStringItem(index, 1, str(cat))
+ self.SetItemData(index, i)
+ itemData[i] = (str(layer), str(cat))
+ i = i + 1
+ if not update:
+ self.SetColumnWidth(0, 100)
+ self.SetColumnWidth(1, wx.LIST_AUTOSIZE)
+ self.currentItem = 0
+ return itemData
+class VDigitZBulkDialog(wx.Dialog):
+ Dialog used for Z bulk-labeling tool
+ def __init__(self, parent, title, nselected, style=wx.DEFAULT_DIALOG_STYLE):
+ # panel = wx.Panel(parent=self, id=wx.ID_ANY)
+ txt = wx.StaticText(parent=self,
+ label=_("%d lines selected for z bulk-labeling") % nselected);
+ border.Add(item=txt, proportion=0, flag=wx.ALL | wx.EXPAND, border=5)
+ box = wx.StaticBox (parent=self, id=wx.ID_ANY, label=" %s " % _("Set value"))
+ flexSizer = wx.FlexGridSizer (cols=2, hgap=5, vgap=5)
+ # starting value
+ label=_("Starting value"));
+ self.value = wx.SpinCtrl(parent=self, id=wx.ID_ANY, size=(150, -1),
+ initial=0,
+ min=-1e6, max=1e6)
+ flexSizer.Add(self.value, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
+ # step
+ label=_("Step"))
+ self.step = wx.SpinCtrl(parent=self, id=wx.ID_ANY, size=(150, -1),
+ initial=0,
+ min=0, max=1e6)
+ flexSizer.Add(self.step, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
+ border.Add(item=sizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=5)
+ # buttons
+ # sizers
+ mainSizer.Add(item=border, proportion=1, flag=wx.EXPAND | wx.ALL, border=5)
Modified: grass/trunk/gui/wxpython/vdigit/line.cpp
--- grass/trunk/gui/wxpython/vdigit/line.cpp 2008-04-28 19:16:07 UTC (rev 31159)
+++ grass/trunk/gui/wxpython/vdigit/line.cpp 2008-04-28 19:27:22 UTC (rev 31160)
@@ -26,7 +26,7 @@
\param type feature type
\param coords pairs of coordinates list (2D or 3D map)
- \param layer layer number
+ \param layer layer number (layer < 1 -> no category)
\param cat category number
\param bgmap map of background map or NULL
\param snap snapping mode (see vedit.h)
@@ -66,10 +66,6 @@
return -1;
- if (layer < -1) {
- return -1;
BgMap = NULL;
nbgmaps = 0;
if (bgmap && strlen(bgmap) > 0) {
@@ -85,10 +81,12 @@
Points = Vect_new_line_struct();
Cats = Vect_new_cats_struct();
- Vect_cat_set(Cats, layer, cat);
+ if (layer > 0) {
+ Vect_cat_set(Cats, layer, cat);
- if (cat > GetCategory(layer)) {
- SetCategory(layer, cat); /* set up max category for layer */
+ if (cat > GetCategory(layer)) {
+ SetCategory(layer, cat); /* set up max category for layer */
i = 0;
