[GRASS-SVN] r31169 - in grass-addons/gipe: i.eb.deltat i.eb.disp
i.eb.eta i.eb.evapfr i.eb.g0 i.eb.h0 i.eb.h_iter
svn_grass at osgeo.org
Mon Apr 28 22:56:48 EDT 2008
Author: ychemin
Date: 2008-04-28 22:56:47 -0400 (Mon, 28 Apr 2008)
New Revision: 31169
grass-addons/gipe/i.eb.deltat/main.c
grass-addons/gipe/i.eb.disp/main.c
grass-addons/gipe/i.eb.eta/main.c
grass-addons/gipe/i.eb.evapfr/main.c
grass-addons/gipe/i.eb.g0/main.c
grass-addons/gipe/i.eb.h0/main.c
grass-addons/gipe/i.eb.h_iter/main.c
new coding standards, continued
Modified: grass-addons/gipe/i.eb.deltat/main.c
--- grass-addons/gipe/i.eb.deltat/main.c 2008-04-29 02:36:08 UTC (rev 31168)
+++ grass-addons/gipe/i.eb.deltat/main.c 2008-04-29 02:56:47 UTC (rev 31169)
@@ -30,7 +30,7 @@
int nrows, ncols;
int row,col;
- int verbose=1, wim=0;
+ int wim=0;
struct GModule *module;
struct Option *input1, *output1;
@@ -61,27 +61,16 @@
module->description = _("difference of temperature between two heights as seen in Pawan (2004), this is part of sensible heat flux calculations, as in SEBAL (Bastiaanssen, 1995). A 'w' flag allows for a very generic approximation.");
/* Define the different options */
- input1 = G_define_option() ;
+ input1 = G_define_standard_option(G_OPT_R_INPUT) ;
input1->key = _("tempk");
- input1->type = TYPE_STRING;
- input1->required = YES;
- input1->gisprompt =_("old,cell,raster") ;
- input1->description=_("Name of the surface skin temperature map [Degree Kelvin]");
+ input1->description=_("Name of the surface skin temperature map [Kelvin]");
input1->answer =_("tempk");
- output1 = G_define_option() ;
+ output1 = G_define_standard_option(G_OPT_R_INPUT) ;
output1->key =_("delta");
- output1->type = TYPE_STRING;
- output1->required = YES;
- output1->gisprompt =_("new,cell,raster");
output1->description=_("Name of the output delta layer");
output1->answer =_("delta");
- flag1 = G_define_flag();
- flag1->key = 'q';
- flag1->description = _("Quiet");
flag2 = G_define_flag();
flag2->key = 'w';
flag2->description = _("Wim's generic table");
@@ -93,7 +82,6 @@
tempk = input1->answer;
result1 = output1->answer;
- verbose = (!flag1->answer);
wim = flag2->answer;
mapset = G_find_cell2(tempk, "");
@@ -119,8 +107,7 @@
DCELL d;
DCELL d_tempk;
- if(verbose)
- G_percent(row,nrows,2);
+ G_percent(row,nrows,2);
// printf("row = %i/%i\n",row,nrows);
/* read soil input maps */
if(G_get_raster_row(infd_tempk,inrast_tempk,row,data_type_tempk)<0)
Modified: grass-addons/gipe/i.eb.disp/main.c
--- grass-addons/gipe/i.eb.disp/main.c 2008-04-29 02:36:08 UTC (rev 31168)
+++ grass-addons/gipe/i.eb.disp/main.c 2008-04-29 02:56:47 UTC (rev 31169)
@@ -31,7 +31,6 @@
int nrows, ncols;
int row,col;
- int verbose=1;
@@ -62,31 +61,19 @@
module->description = _("Displacement height above skin surface, as seen in Pawan (2004). A flag (-s) permits direct SAVI input using the equation in the same document, be careful using it.");
input1->key = _("lai");
input1->description=_("Name of the LAI map [-]");
input1->answer =_("lai");
+ output1 = G_define_standard_option(G_OPT_R_OUTPUT) ;
output1->key =_("disp");
- output1->gisprompt =_("new,dcell,raster");
output1->description=_("Name of the output disp layer");
output1->answer =_("disp");
- flag1->key = 'q';
flag2->key = 's';
flag2->description = _("use savi2lai conversion (Pawan, 2004)");
if (G_parser(argc, argv))
exit (EXIT_FAILURE);
@@ -94,7 +81,6 @@
lai = input1->answer;
mapset = G_find_cell2(lai, "");
if (mapset == NULL) {
@@ -119,8 +105,7 @@
DCELL d;
DCELL d_lai;
- if(verbose)
if(G_get_raster_row(infd_lai,inrast_lai,row,data_type_lai)<0)
Modified: grass-addons/gipe/i.eb.eta/main.c
--- grass-addons/gipe/i.eb.eta/main.c 2008-04-29 02:36:08 UTC (rev 31168)
+++ grass-addons/gipe/i.eb.eta/main.c 2008-04-29 02:56:47 UTC (rev 31169)
@@ -29,7 +29,6 @@
int nrows, ncols;
int row,col;
- int verbose=1;
struct Option *input1, *input2, *input3, *output1;
@@ -61,42 +60,25 @@
module->description = _("actual evapotranspiration for diurnal period (Bastiaanssen, 1995)");
input1->key = _("rnetday");
input1->description=_("Name of the diurnal Net Radiation map [W/m2]");
input1->answer =_("rnetday");
- input2 = G_define_option() ;
+ input2 = G_define_standard_option(G_OPT_R_INPUT) ;
input2->key =_("evapfr");
- input2->type = TYPE_STRING;
- input2->required = YES;
- input2->gisprompt =_("old,cell,raster");
input2->description=_("Name of the evaporative fraction map [-]");
input2->answer =_("evapfr");
- input3 = G_define_option() ;
+ input3 = G_define_standard_option(G_OPT_R_INPUT) ;
input3->key =_("tempk");
- input3->type = TYPE_STRING;
- input3->required = YES;
- input3->gisprompt =_("old,cell,raster");
input3->description=_("Name of the surface skin temperature [K]");
input3->answer =_("tempk");
output1->key =_("eta");
output1->description=_("Name of the output actual diurnal evapotranspiration layer");
output1->answer =_("eta");
- flag1->key = 'q';
@@ -106,7 +88,6 @@
tempk = input3->answer;
mapset = G_find_cell2(rnetday, "");
@@ -155,8 +136,7 @@
DCELL d_rnetday;
DCELL d_evapfr;
DCELL d_tempk;
- if(verbose)
/* read input maps */
if(G_get_raster_row(infd_rnetday,inrast_rnetday,row,data_type_rnetday)<0)
G_fatal_error(_("Could not read from <%s>"),rnetday);
Modified: grass-addons/gipe/i.eb.evapfr/main.c
--- grass-addons/gipe/i.eb.evapfr/main.c 2008-04-29 02:36:08 UTC (rev 31168)
+++ grass-addons/gipe/i.eb.evapfr/main.c 2008-04-29 02:56:47 UTC (rev 31169)
@@ -30,7 +30,6 @@
int nrows, ncols;
int row,col;
- int verbose=1;
int makin=0;//Makin Flag for root zone soil moisture output
struct Option *input1, *input2, *input3, *output1, *output2;
@@ -64,55 +63,36 @@
module->description = _("evaporative fraction (Bastiaanssen, 1995) and root zone soil moisture (Makin, Molden and Bastiaanssen, 2001)");
input1->key = _("rnet");
input1->description=_("Name of the Net Radiation map [W/m2]");
input1->answer =_("rnet");
input2->key =_("g0");
input2->description=_("Name of the soil heat flux map [W/m2]");
input2->answer =_("g0");
input3->key =_("h0");
input3->description=_("Name of the sensible heat flux map [W/m2]");
input3->answer =_("h0");
output1->key =_("evapfr");
output1->description=_("Name of the output evaporative fraction layer");
output1->answer =_("evapfr");
- output2 = G_define_option() ;
+ output2 = G_define_standard_option(G_OPT_R_OUTPUT) ;
output2->key =_("theta");
- output2->type = TYPE_STRING;
output2->required = NO;
- output2->gisprompt =_("new,cell,raster");
output2->description=_("Name of the output root zone soil moisture layer");
output2->answer =_("theta");
flag1->key = 'm';
flag1->description = _("root zone soil moisture output (Makin, Molden and Bastiaanssen, 2001)");
- flag2 = G_define_flag();
- flag2->key = 'q';
- flag2->description = _("Quiet");
@@ -124,7 +104,6 @@
result2 = output2->answer;
makin = flag1->answer;
- verbose = (!flag2->answer);
mapset = G_find_cell2(rnet, "");
@@ -180,8 +159,7 @@
DCELL d_rnet;
DCELL d_g0;
DCELL d_h0;
- if(verbose)
if(G_get_raster_row(infd_rnet,inrast_rnet,row,data_type_rnet)<0)
Modified: grass-addons/gipe/i.eb.g0/main.c
--- grass-addons/gipe/i.eb.g0/main.c 2008-04-29 02:36:08 UTC (rev 31168)
+++ grass-addons/gipe/i.eb.g0/main.c 2008-04-29 02:56:47 UTC (rev 31169)
@@ -30,12 +30,11 @@
int nrows, ncols;
int row,col;
- int verbose=1;
int roerink=0;//Roerink Flag for HAPEX-Sahel conditions
struct Option *input1, *input2, *input3, *input4, *input5, *output1;
- struct Flag *flag1, *flag2;
+ struct Flag *flag1;
struct History history; //metadata
@@ -100,11 +99,6 @@
flag1->key = 'r';
flag1->description = _("HAPEX-Sahel empirical correction (Roerink, 1995)");
- flag2->key = 'q';
Modified: grass-addons/gipe/i.eb.h0/main.c
--- grass-addons/gipe/i.eb.h0/main.c 2008-04-29 02:36:08 UTC (rev 31168)
+++ grass-addons/gipe/i.eb.h0/main.c 2008-04-29 02:56:47 UTC (rev 31169)
@@ -30,7 +30,6 @@
int nrows, ncols;
int row,col;
- int verbose=1;
int sebal=0;//SEBAL Flag for affine transform of surf. temp.
struct Option *input1, *input2, *input3, *input4, *input5;
@@ -68,11 +67,8 @@
module->description = _("sensible heat flux equation, including flag for SEBAL version (Bastiaanssen, 1995)");
input1->key = _("rohair");
input1->description=_("Name of the air density map ~[0.9;1.5]");
input1->answer =_("rohair");
@@ -84,29 +80,19 @@
input2->description=_("Value of the air specific heat [1000.0;1020.0]");
input2->answer =_("1004.0");
input3->key =_("dtair");
- input3->required = NO;
input3->description=_("Name of the skin-air Surface temperature difference map ~[0.0-80.0]");
-// input3->answer =_("dtair");
- input4 = G_define_option() ;
+ input4 = G_define_standard_option(G_OPT_R_INPUT) ;
input4->key =_("rah");
- input4->type = TYPE_STRING;
- input4->required = YES;
- input4->gisprompt =_("old,cell,raster");
input4->description=_("Name of the aerodynamic resistance to heat transport map [s/m]");
input4->answer =_("rah");
- input5 = G_define_option() ;
+ input5 = G_define_standard_option(G_OPT_R_INPUT) ;
input5->key =_("tempk");
- input5->type = TYPE_STRING;
input5->required = NO;
- input5->gisprompt =_("old,cell,raster");
input5->description=_("Name of the surface skin temperature map [degrees Kelvin], used with -s flag and affine coefs, disables dtair input");
-// input5->answer =_("tempk");
input6 = G_define_option() ;
input6->key =_("a");
@@ -122,21 +108,14 @@
input7->gisprompt =_("parameter, float number");
input7->description=_("Value of the intercept of the transform");
output1->key =_("h0");
output1->description=_("Name of the output h0 layer");
output1->answer =_("h0");
flag1->key = 's';
flag1->description = _("Affine transform of Surface temperature, needs input of slope and intercept (Bastiaanssen, 1995)");
- flag2->key = 'q';
@@ -151,7 +130,6 @@
result = output1->answer;
sebal = flag1->answer;
mapset = G_find_cell2(rohair, "");
@@ -217,8 +195,7 @@
DCELL d_dtair;
DCELL d_affine;
DCELL d_tempk;
- if(verbose)
if(G_get_raster_row(infd_rohair,inrast_rohair,row,data_type_rohair)<0)
Modified: grass-addons/gipe/i.eb.h_iter/main.c
--- grass-addons/gipe/i.eb.h_iter/main.c 2008-04-29 02:36:08 UTC (rev 31168)
+++ grass-addons/gipe/i.eb.h_iter/main.c 2008-04-29 02:56:47 UTC (rev 31169)
@@ -37,7 +37,6 @@
int nrows, ncols;
int row,col;
- int verbose=1;
//If !sebal then use Delta T input file
@@ -81,11 +80,8 @@
module->description = _("sensible heat flux equation as in Pawan (2004), including flags for delta T affine transform from surf. temp.");
input1->description=_("Name of the air density map ~[0.9;1.5], Pawan (2004) use 1.12 constant value");
@@ -97,19 +93,14 @@
input2->answer =_("1004.16");
input3->description=_("Name of the surface skin temperature map [degrees Kelvin],if used with -s flag and affine coefs, it disables dtair input");
input4->key =_("dtair");
input4->required = NO;
input4->description=_("Name of the skin-air Surface temperature difference map ~[0.0-80.0], required unless you use -s flag (then you must give a & b coefs below)");
@@ -126,43 +117,28 @@
input6->gisprompt =_("parameter, float number");
input6->description=_("-s flag: Value of the intercept of the affine transform");
- input7 = G_define_option() ;
+ input7 = G_define_stnadard_option(G_OPT_R_INPUT) ;
input7->key =_("disp");
- input7->type = TYPE_STRING;
- input7->required = YES;
- input7->gisprompt =_("old,cell,raster");
input7->description=_("Name of the displacement height input layer (m)");
input7->answer =_("disp");
- input8 = G_define_option() ;
+ input8 = G_define_standard_option(G_OPT_R_INPUT) ;
input8->key =_("z0m");
- input8->type = TYPE_STRING;
- input8->required = YES;
- input8->gisprompt =_("old,cell,raster");
input8->description=_("Name of the z0m input layer (s/m)");
input8->answer =_("z0m");
- input9 = G_define_option() ;
+ input9 = G_define_standard_option(G_OPT_R_INPUT) ;
input9->key =_("z0h");
- input9->type = TYPE_STRING;
- input9->required = YES;
- input9->gisprompt =_("old,cell,raster");
input9->description=_("Name of the z0h input layer (s/m)");
input9->answer =_("z0h");
- input10 = G_define_option() ;
+ input10 = G_define_standard_option(G_OPT_R_INPUT) ;
input10->key =_("u2m");
- input10->type = TYPE_STRING;
- input10->required = YES;
- input10->gisprompt =_("old,cell,raster");
input10->description=_("Name of the wind speed at 2m height input layer (m/s)");
input10->answer =_("u2m");
@@ -170,9 +146,6 @@
flag1->key = 's';
flag1->description = _("Affine transform of Surface temperature into delta T, needs input of slope and intercept (Bastiaanssen, 1995)");
- flag2->key = 'q';
@@ -198,7 +171,6 @@
/* TEST FOR -s FLAG COEFS
@@ -310,8 +282,7 @@
DCELL d_z0m;
DCELL d_z0h;
DCELL d_u2m;
- if(verbose)
/* printf("row = %i/%i\n",row,nrows);*/
