[GRASS-SVN] r31170 - grass-addons/gipe/r.out.vic
svn_grass at osgeo.org
Mon Apr 28 23:29:33 EDT 2008
Author: ychemin
Date: 2008-04-28 23:29:33 -0400 (Mon, 28 Apr 2008)
New Revision: 31170
grass-addons/gipe/r.out.vic/main.c
Added r.watershed to AGNPS flow direction conversion flag in r.out.vic
Modified: grass-addons/gipe/r.out.vic/main.c
--- grass-addons/gipe/r.out.vic/main.c 2008-04-29 02:56:47 UTC (rev 31169)
+++ grass-addons/gipe/r.out.vic/main.c 2008-04-29 03:29:33 UTC (rev 31170)
@@ -14,6 +14,7 @@
* Barely complete, it takes elevation data & lat/long,
* the rest is filled up with dummy soil data.
* 4 - Routing file from GRASS flow direction file:
+ * Direct AGNPS or flag for r.watershed format
* Recoding to rout input file for VIC post-processing
* of hydrological surface runoff flow.
* http://www.hydro.washington.edu/Lettenmaier/
@@ -56,7 +57,7 @@
struct Option *input5, *input6, *input7;
struct Option *output1, *output2, *output3, *output4, *output5;
- struct Flag *flag1;
+ struct Flag *flag1, *flag2;
struct History history; //metadata
struct pj_info iproj;
@@ -227,6 +228,10 @@
flag1 = G_define_flag() ;
flag1->key = 'a';
flag1->description =_("append meteorological data if file already exists (useful if adding additional year of data)");
+ flag2 = G_define_flag() ;
+ flag2->key = 'b';
+ flag2->description =_("Convert flow direction from r.watershed to AGNPS");
if (G_parser(argc, argv))
exit (EXIT_FAILURE);
@@ -448,15 +453,20 @@
/*Initialize grid cell process switch*/
ef=fopen(result4,"w");
/*Print to ascii file*/
+ G_message("Your ncols,nrows for flow direction map are (%d,%d)\n",ncols,nrows);
fprintf(ef,"ncols\t%d\n", ncols);
fprintf(ef,"nrows\t%d\n", nrows);
/*NORTHWEST LONGITUDE*/
+ G_message("Your xllcorner for flow direction map is %f\n",xmin);
fprintf(ef,"xllcorner\t%f\n", xmin);
/*NORTHWEST LATITUDE*/
+ G_message("Your yllcorner for flow direction map is %f\n",ymin);
fprintf(ef,"yllcorner\t%f\n", ymin);
/*CELLSIZE*/
+ G_message("Your cellsize for flow direction map is %f\n",stepx);
fprintf(ef,"cellsize\t%f\n", stepx);
/*NODATA_value*/
+ G_message("Your NODATA_value for flow direction map is 0\n");
fprintf(ef,"NODATA_value\t0\n");
@@ -634,8 +644,14 @@
grid_count=grid_count+1;
- /*Grid cell value in that grid cell*/
- fprintf(ef,"%d ",c_fdir);
+ /*Grid cell flow direction value in that grid cell*/
+ if(flag2->answer){
+ /* Convert r.watershed flow dir to AGNPS */
+ fprintf(ef,"%d ",c_fdir+1);
+ } else {
+ /* Flow direction format is AGNPS */
+ fprintf(ef,"%d ",c_fdir);
fprintf(ef,"\n");
