[GRASS-SVN] r32573 - grass-addons/gipe/i.eb.h_SEBAL01
svn_grass at osgeo.org
Wed Aug 6 07:18:16 EDT 2008
Author: ychemin
Date: 2008-08-06 07:18:16 -0400 (Wed, 06 Aug 2008)
New Revision: 32573
grass-addons/gipe/i.eb.h_SEBAL01/description.html
grass-addons/gipe/i.eb.h_SEBAL01/main.c
Added Rnet and g0 input maps, removed h_dry manual input
Modified: grass-addons/gipe/i.eb.h_SEBAL01/description.html
--- grass-addons/gipe/i.eb.h_SEBAL01/description.html 2008-08-06 11:16:24 UTC (rev 32572)
+++ grass-addons/gipe/i.eb.h_SEBAL01/description.html 2008-08-06 11:18:16 UTC (rev 32573)
@@ -4,7 +4,7 @@
<H2>DESCRIPTION</H2>
-<p><EM>i.eb.h_SEBAL01</EM> will calculate the sensible heat flux map (h0), given the surface roughness (z0m), a map of the altitude corrected temperature (t0dem), a point data of the frictional velocity (u*), a value of actual vapour pressure (ea[KPa]), a value of the sensible heat flux (h=Rn-g0) at dry pixel and the (x,y) pairs for wet and dry pixels.
+<p><EM>i.eb.h_SEBAL01</EM> will calculate the sensible heat flux map (h0), given both maps of Net Radiation and soil Heat flux (Rn, g0) at instantaneous time, the surface roughness (z0m), a map of the altitude corrected temperature (t0dem), a point data of the frictional velocity (u*), a value of actual vapour pressure (ea[KPa]) and the (x,y) pairs for wet and dry pixels.
<p>For more details on the algorithms see [1].
Modified: grass-addons/gipe/i.eb.h_SEBAL01/main.c
--- grass-addons/gipe/i.eb.h_SEBAL01/main.c 2008-08-06 11:16:24 UTC (rev 32572)
+++ grass-addons/gipe/i.eb.h_SEBAL01/main.c 2008-08-06 11:18:16 UTC (rev 32573)
@@ -44,6 +44,7 @@
char *mapset; // mapset name
/* buffer for in, tmp and out raster */
+ void *inrast_Rn, *inrast_g0;
void *inrast_z0m, *inrast_t0dem;
DCELL *outrast;
@@ -53,23 +54,28 @@
int row_dry, col_dry;
double m_row_wet, m_col_wet;
double m_row_dry, m_col_dry;
+ int infd_Rn, infd_g0;
int infd_z0m, infd_t0dem;
- //int tmprohfd, tmprahfd;
int outfd;
+ char *mapset_Rn, *mapset_g0;
char *mapset_z0m, *mapset_t0dem;
+ char *Rn, *g0;
char *z0m, *t0dem;
char *h0;
- double ustar, ea, h_dry;
+ double ustar, ea;
struct History history;
struct GModule *module;
+ struct Option *input_Rn, *input_g0;
struct Option *input_z0m, *input_t0dem, *input_ustar;
- struct Option *input_ea, *input_h_dry, *output;
+ struct Option *input_ea, *output;
struct Option *input_row_wet, *input_col_wet;
struct Option *input_row_dry, *input_col_dry;
struct Flag *flag3;
+ RASTER_MAP_TYPE data_type_Rn;
+ RASTER_MAP_TYPE data_type_g0;
RASTER_MAP_TYPE data_type_z0m;
RASTER_MAP_TYPE data_type_t0dem;
RASTER_MAP_TYPE data_type_output=DCELL_TYPE;
@@ -88,6 +94,14 @@
module->description = _("Sensible Heat Flux iteration SEBAL 01");
/* Define different options */
+ input_Rn = G_define_standard_option(G_OPT_R_INPUT);
+ input_Rn->key = "Rn";
+ input_Rn->description = _("Name of instantaneous Net Radiation map [W/m2]");
+ input_g0 = G_define_standard_option(G_OPT_R_INPUT);
+ input_g0->key = "g0";
+ input_g0->description = _("Name of instantaneous soil heat flux map [W/m2]");
input_z0m = G_define_standard_option(G_OPT_R_INPUT);
input_z0m->key = "z0m";
input_z0m->description = _("Name of aerodynamic resistance to heat momentum [s/m]");
@@ -114,15 +128,6 @@
input_ea->description = _("Value of the actual vapour pressure [KPa]");
input_ea->guisection = _("Parameters");
- input_h_dry = G_define_option();
- input_h_dry->key = "h_dry";
- input_h_dry->type = TYPE_DOUBLE;
- input_h_dry->required = YES;
- input_h_dry->gisprompt = "old,value";
- input_h_dry->answer = "222.07";
- input_h_dry->description = _("Initial value of h0 at dry pixel (Rn-g0) [W/m2]");
- input_h_dry->guisection = _("Parameters");
input_row_wet = G_define_option();
input_row_wet->key = "row_wet";
input_row_wet->type = TYPE_DOUBLE;
@@ -168,6 +173,8 @@
exit(EXIT_FAILURE);
/* get entered parameters */
+ Rn = input_Rn->answer;
+ g0 = input_g0->answer;
z0m = input_z0m->answer;
t0dem = input_t0dem->answer;
@@ -175,7 +182,6 @@
ustar = atof(input_ustar->answer);
ea = atof(input_ea->answer);
- h_dry = atof(input_h_dry->answer);
m_row_wet = atof(input_row_wet->answer);
m_col_wet = atof(input_col_wet->answer);
@@ -190,6 +196,12 @@
G_message("Dry Pixel=> row:%.0f col:%.0f",m_row_dry,m_col_dry);
/* find maps in mapset */
+ mapset_Rn = G_find_cell2 (Rn, "");
+ if (mapset_Rn == NULL)
+ G_fatal_error (_("cell file [%s] not found"), Rn);
+ mapset_g0 = G_find_cell2 (g0, "");
+ if (mapset_g0 == NULL)
+ G_fatal_error (_("cell file [%s] not found"), g0);
mapset_z0m = G_find_cell2 (z0m, "");
if (mapset_z0m == NULL)
G_fatal_error (_("cell file [%s] not found"), z0m);
@@ -202,20 +214,32 @@
G_fatal_error (_("[%s] is an illegal name"), h0);
/* determine the input map type (CELL/FCELL/DCELL) */
+ data_type_Rn = G_raster_map_type(Rn, mapset_Rn);
+ data_type_g0 = G_raster_map_type(g0, mapset_g0);
data_type_z0m = G_raster_map_type(z0m, mapset_z0m);
data_type_t0dem = G_raster_map_type(t0dem, mapset_t0dem);
+ if ( (infd_Rn = G_open_cell_old (Rn, mapset_Rn)) < 0)
+ G_fatal_error (_("Cannot open cell file [%s]"), Rn);
+ if ( (infd_g0 = G_open_cell_old (g0, mapset_g0)) < 0)
+ G_fatal_error (_("Cannot open cell file [%s]"), g0);
if ( (infd_z0m = G_open_cell_old (z0m, mapset_z0m)) < 0)
G_fatal_error (_("Cannot open cell file [%s]"), z0m);
if ( (infd_t0dem = G_open_cell_old (t0dem, mapset_t0dem)) < 0)
G_fatal_error (_("Cannot open cell file [%s]"),t0dem);
+ if (G_get_cellhd (Rn, mapset_Rn, &cellhd) < 0)
+ G_fatal_error (_("Cannot read file header of [%s]"), Rn);
+ if (G_get_cellhd (g0, mapset_g0, &cellhd) < 0)
+ G_fatal_error (_("Cannot read file header of [%s]"), g0);
if (G_get_cellhd (z0m, mapset_z0m, &cellhd) < 0)
G_fatal_error (_("Cannot read file header of [%s]"), z0m);
if (G_get_cellhd (t0dem, mapset_t0dem, &cellhd) < 0)
G_fatal_error (_("Cannot read file header of [%s]"), t0dem);
/* Allocate input buffer */
+ inrast_Rn = G_allocate_raster_buf(data_type_Rn);
+ inrast_g0 = G_allocate_raster_buf(data_type_g0);
inrast_z0m = G_allocate_raster_buf(data_type_z0m);
inrast_t0dem = G_allocate_raster_buf(data_type_t0dem);
@@ -251,6 +275,8 @@
/* MANUAL T0DEM WET/DRY PIXELS */
+ DCELL d_Rn_dry;
+ DCELL d_g0_dry;
DCELL d_t0dem_dry;
DCELL d_t0dem_wet;
/*DRY PIXEL*/
@@ -266,8 +292,34 @@
rowDry=row;
colDry=col;
+ if(G_get_raster_row(infd_Rn,inrast_Rn,row,data_type_Rn)<0)
+ G_fatal_error(_("Could not read from <%s>"),Rn);
+ if(G_get_raster_row(infd_g0,inrast_g0,row,data_type_g0)<0)
+ G_fatal_error(_("Could not read from <%s>"),g0);
if(G_get_raster_row(infd_t0dem,inrast_t0dem,row,data_type_t0dem)<0)
G_fatal_error(_("Could not read from <%s>"),t0dem);
+ switch(data_type_Rn){
+ case CELL_TYPE:
+ d_Rn_dry = (double) ((CELL *) inrast_Rn)[col];
+ break;
+ case FCELL_TYPE:
+ d_Rn_dry = (double) ((FCELL *) inrast_Rn)[col];
+ break;
+ case DCELL_TYPE:
+ d_Rn_dry = (double) ((DCELL *) inrast_Rn)[col];
+ break;
+ switch(data_type_g0){
+ case CELL_TYPE:
+ d_g0_dry = (double) ((CELL *) inrast_g0)[col];
+ break;
+ case FCELL_TYPE:
+ d_g0_dry = (double) ((FCELL *) inrast_g0)[col];
+ break;
+ case DCELL_TYPE:
+ d_g0_dry = (double) ((DCELL *) inrast_g0)[col];
+ break;
switch(data_type_t0dem){
case CELL_TYPE:
d_t0dem_dry = (double) ((CELL *) inrast_t0dem)[col];
@@ -306,6 +358,9 @@
break;
/* END OF MANUAL WET/DRY PIXELS */
+ double h_dry;
+ h_dry=d_Rn_dry-d_g0_dry;
+ G_message("h_dry = %f",h_dry);
G_message("t0dem_dry = %f",d_t0dem_dry);
G_message("t0dem_wet = %f",d_t0dem_wet);
DCELL d_rah_dry;
@@ -390,6 +445,7 @@
b = (sumy - ( a * sumx)) / 2.0;
G_message("d_dT_dry=%f",d_dT_dry);
G_message("dT1=%f * t0dem + (%f)", a, b);
DCELL d_h_dry;
/* ITERATION 1 */
