[GRASS-SVN] r32574 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Aug 6 09:53:51 EDT 2008
Author: martinl
Date: 2008-08-06 09:53:50 -0400 (Wed, 06 Aug 2008)
New Revision: 32574
grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py
wxGUI/vdidit: allow to hide currently edited map layer (item checkbox), remember map layer even its position in layer tree is changed
various render-related fixes
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py 2008-08-06 11:18:16 UTC (rev 32573)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py 2008-08-06 13:53:50 UTC (rev 32574)
@@ -62,12 +62,13 @@
self.title = title
def __str__(self):
- wx.MessageBox(parent=self.parent,
- caption=self.title,
- message=self.message,
- style=wx.ICON_ERROR | wx.CENTRE)
- # return 'GException: %s' % self.message
+ dlg = wx.MessageDialog(parent=self.parent,
+ caption=self.title,
+ message=self.message,
+ style=wx.ICON_ERROR | wx.CENTRE)
+ dlg.SetIcon(wx.Icon(os.path.join(globalvar.ETCDIR, 'grass_error.ico'), wx.BITMAP_TYPE_ICO))
+ dlg.ShowModal()
return ''
class GStdError(GException):
@@ -429,7 +430,7 @@
content = ""
if type:
- content += line.split(':')[1].strip()
+ content += line.split(':', 1)[1].strip()
else: # stderr
msg.append((None, line.strip()))
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py 2008-08-06 11:18:16 UTC (rev 32573)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py 2008-08-06 13:53:50 UTC (rev 32574)
@@ -681,7 +681,7 @@
digitToolbar = self.parent.toolbars['vdigit']
if renderVector and digitToolbar and \
- digitToolbar.layerSelectedID != None:
+ digitToolbar.GetLayer():
# set region
self.parent.digit.driver.UpdateRegion()
# re-calculate threshold for digitization tool
@@ -689,7 +689,9 @@
# draw map
self.pdcVector.Clear()
self.pdcVector.RemoveAll()
- self.parent.digit.driver.DrawMap()
+ item = self.tree.FindItemByData('maplayer', digitToolbar.GetLayer())
+ if self.tree.IsItemChecked(item):
+ self.parent.digit.driver.DrawMap()
# render overlays
@@ -1075,13 +1077,12 @@
east, north = self.Pixel2Cell(self.mouse['begin'])
try:
- map = digitToolbar.layers[digitToolbar.layerSelectedID].name
+ map = digitToolbar.GetLayer().GetName()
except:
map = None
- dlg = wx.MessageDialog(self, _("No vector map selected for editing."),
- _("Error"), wx.OK | wx.ICON_ERROR)
- dlg.ShowModal()
- dlg.Destroy()
+ wx.MessageBox(parent=self,
+ message=_("No vector map selected for editing."),
+ caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
event.Skip()
return
@@ -1706,14 +1707,13 @@
digitToolbar.type in ["line", "boundary"]:
# -> add new line / boundary
try:
except:
map = None
- dlg.ShowModal()
- dlg.Destroy()
if map:
# mapcoords = []
# xy -> EN
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py 2008-08-06 11:18:16 UTC (rev 32573)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py 2008-08-06 13:53:50 UTC (rev 32574)
@@ -132,7 +132,8 @@
gcmd.Command(['d.mon',
'start=cairo'], stderr=None)
else:
- os.environ["GRASS_PNGFILE"] = self.mapfile
+ if self.mapfile:
+ os.environ["GRASS_PNGFILE"] = self.mapfile
# execute command
@@ -189,10 +190,22 @@
return int (self.opacity * 100)
- def GetName(self):
- """Get map layer name"""
- return self.name
+ def GetName(self, fullyQualified=True):
+ """Get map layer name
+ @param fullyQualified if True return 'name at mapset' otherwise
+ ('name', 'mapset')
+ if fullyQualified:
+ return self.name
+ else:
+ if '@' in self.name:
+ return { 'name' : self.name.split('@')[0],
+ 'mapset' : self.name.split('@')[1] }
+ else:
+ return { 'name' : self.name,
+ 'mapset' : '' }
def IsActive(self):
"""Check if layer is activated for rendering"""
return self.active
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py 2008-08-06 11:18:16 UTC (rev 32573)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py 2008-08-06 13:53:50 UTC (rev 32574)
@@ -358,9 +358,10 @@
self.parent = parent # MapFrame
self.layerTree = layerTree # reference to layer tree associated to map display
- # selected map to digitize
- self.layerSelectedID = None
- self.layers = []
+ # currently selected map layer for editing (reference to MapLayer instance)
+ self.mapLayer = None
+ # list of vector layers from Layer Manager (only in the current mapset)
+ self.layers = []
# default action (digitize new point, line, etc.)
self.action = "addLine"
@@ -536,10 +537,8 @@
def OnExit (self, event=None):
"""Quit digitization tool"""
# stop editing of the currently selected map layer
- try:
- self.StopEditing(self.layers[self.layerSelectedID])
- except:
- pass
+ if self.mapLayer:
+ self.StopEditing()
# close dialogs if still open
if self.settingsDialog:
@@ -765,8 +764,8 @@
selected map layer activated for editing.
if event.GetSelection() == 0: # create new vector map layer
- if self.layerSelectedID is not None:
- openVectorMap = self.layers[self.layerSelectedID].name.split('@')[0]
+ if self.mapLayer:
+ openVectorMap = self.mapLayer.GetName(fullyQualified=False)['name']
else:
openVectorMap = None
mapName = gdialogs.CreateNewVector(self.parent,
@@ -790,115 +789,110 @@
else:
selection = event.GetSelection() - 1 # first option is 'New vector map'
- if self.layerSelectedID == selection:
+ # skip currently selected map
+ if self.layers[selection] == self.mapLayer:
return False
- if self.layerSelectedID != None: # deactive map layer for editing
+ if self.mapLayer:
+ # deactive map layer for editing
# select the given map layer for editing
- self.layerSelectedID = selection
- self.StartEditing(self.layers[self.layerSelectedID])
+ self.StartEditing(self.layers[selection])
event.Skip()
return True
- def StartEditing (self, layerSelected):
+ def StartEditing (self, mapLayer):
- Start editing of selected vector map layer.
+ Start editing selected vector map layer.
- @param layerSelectedId id of layer to be edited
- @return True on success
- @return False on error
+ @param mapLayer reference to MapLayer instance
+ # reload vdigit module
reload(vdigit)
from vdigit import Digit as Digit
self.parent.digit = Digit(mapwindow=self.parent.MapWindow)
+ self.mapLayer = mapLayer
+ # open vector map
try:
- self.layerSelectedID = self.layers.index(layerSelected)
- mapLayer = self.layers[self.layerSelectedID]
- except:
- return False
- try:
- self.parent.digit.SetMapName(mapLayer.name)
+ self.parent.digit.SetMapName(mapLayer.GetName())
except gcmd.DigitError, e:
print >> sys.stderr, e # wxMessageBox
return False
# update toolbar
- self.combo.SetValue (layerSelected.name)
+ self.combo.SetValue(mapLayer.GetName())
self.parent.toolbars['map'].combo.SetValue ('Digitize')
- # set initial category number for new features (layer=1), etc.
- Debug.msg (4, "VDigitToolbar.StartEditing(): layerSelectedID=%d layer=%s" % \
- (self.layerSelectedID, mapLayer.name))
+ Debug.msg (4, "VDigitToolbar.StartEditing(): layer=%s" % mapLayer.GetName())
# deactive layer
self.mapcontent.ChangeLayerActive(mapLayer, False)
# change cursor
if self.parent.MapWindow.mouse['use'] == 'pointer':
self.parent.MapWindow.SetCursor(self.parent.cursors["cross"])
# create pseudoDC for drawing the map
self.parent.MapWindow.pdcVector = wx.PseudoDC()
self.parent.digit.driver.SetDevice(self.parent.MapWindow.pdcVector)
# self.parent.MapWindow.UpdateMap()
if not self.parent.MapWindow.resize:
self.parent.MapWindow.UpdateMap(render=True)
return True
- def StopEditing (self, layerSelected):
- Stop editing of selected vector map layer.
+ def StopEditing (self):
+ """Stop editing of selected vector map layer.
- if self.layers[self.layerSelectedID] == layerSelected:
- Debug.msg (4, "VDigitToolbar.StopEditing(): layer=%s" % \
- (layerSelected.name))
- self.combo.SetValue (_('Select vector map'))
- # save changes (only for vdigit)
- if UserSettings.Get(group='advanced', key='digitInterface', subkey='type') == 'vdigit':
- if UserSettings.Get(group='vdigit', key='saveOnExit', subkey='enabled') is False:
- if self.parent.digit.GetUndoLevel() > 0:
- dlg = wx.MessageDialog(parent=self.parent, message=_("Do you want to save changes "
- "in vector map <%s>?") % layerSelected.name,
- caption=_("Save changes?"),
- style=wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
- if dlg.ShowModal() == wx.ID_NO:
- # revert changes
- self.parent.digit.Undo(0)
- dlg.Destroy()
- self.parent.digit.SetMapName(None) # -> close map
- # re-active layer
- item = self.parent.tree.FindItemByData('maplayer', layerSelected)
- if item and self.parent.tree.IsItemChecked(item):
- self.mapcontent.ChangeLayerActive(layerSelected, True)
- # change cursor
- self.parent.MapWindow.SetCursor(self.parent.cursors["default"])
- # disable pseudodc for vector map layer
- self.parent.MapWindow.pdcVector = None
- self.parent.digit.driver.SetDevice(None)
- self.parent.digit.__del__() # FIXME: destructor is not called here (del)
- self.parent.digit = None
- return True
+ @return True on success
+ @return False on failure
+ if not self.mapLayer:
+ return False
- return False
+ Debug.msg (4, "VDigitToolbar.StopEditing(): layer=%s" % self.mapLayer.GetName())
+ self.combo.SetValue (_('Select vector map'))
+ # save changes (only for vdigit)
+ if UserSettings.Get(group='advanced', key='digitInterface', subkey='type') == 'vdigit':
+ if UserSettings.Get(group='vdigit', key='saveOnExit', subkey='enabled') is False:
+ if self.parent.digit.GetUndoLevel() > 0:
+ dlg = wx.MessageDialog(parent=self.parent, message=_("Do you want to save changes "
+ "in vector map <%s>?") % self.mapLayer.GetName(),
+ caption=_("Save changes?"),
+ style=wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
+ if dlg.ShowModal() == wx.ID_NO:
+ # revert changes
+ self.parent.digit.Undo(0)
+ dlg.Destroy()
+ self.parent.digit.SetMapName(None) # -> close map
+ # re-active layer
+ item = self.parent.tree.FindItemByData('maplayer', self.mapLayer)
+ if item and self.parent.tree.IsItemChecked(item):
+ self.mapcontent.ChangeLayerActive(self.mapLayer, True)
+ # change cursor
+ self.parent.MapWindow.SetCursor(self.parent.cursors["default"])
+ # disable pseudodc for vector map layer
+ self.parent.MapWindow.pdcVector = None
+ self.parent.digit.driver.SetDevice(None)
+ self.parent.digit.__del__() # FIXME: destructor is not called here (del)
+ self.parent.digit = None
+ return True
def UpdateListOfLayers (self, updateTool=False):
Update list of available vector map layers.
@@ -911,8 +905,9 @@
updateTool)
layerNameSelected = None
- if self.layerSelectedID != None: # name of currently selected layer
- layerNameSelected = self.layers[self.layerSelectedID].name
+ # name of currently selected layer
+ if self.mapLayer:
+ layerNameSelected = self.mapLayer.GetName()
# select vector map layer in the current mapset
layerNameList = []
@@ -920,10 +915,10 @@
l_mapset=grassenv.GetGRASSVariable('MAPSET'))
for layer in self.layers:
if not layer.name in layerNameList: # do not duplicate layer
- layerNameList.append (layer.name)
+ layerNameList.append (layer.GetName())
if updateTool: # update toolbar
- if self.layerSelectedID == None:
value = _('Select vector map')
else:
value = layerNameSelected
@@ -937,16 +932,14 @@
else:
self.combo.SetItems([_('New vector map'), ] + layerNameList)
- # update layer index
- try:
- self.layerSelectedID = layerNameList.index(value)
- except ValueError:
self.toolbar[self.numOfRows-1].Realize()
return layerNameList
+ def GetLayer(self):
+ """Get selected layer for editing -- MapLayer instance"""
+ return self.mapLayer
class ProfileToolbar(AbstractToolbar):
Toolbar for profiling raster map
@@ -1018,7 +1011,7 @@
wx.ITEM_NORMAL, Icons["quit"].GetLabel(), Icons["quit"].GetDesc(),
self.parent.OnQuit),
class NvizToolbar(AbstractToolbar):
Nviz toolbar
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py 2008-08-06 11:18:16 UTC (rev 32573)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py 2008-08-06 13:53:50 UTC (rev 32574)
@@ -836,32 +836,32 @@
if len(coords) < 2:
return
if UserSettings.Get(group='vdigit', key="categoryMode", subkey='selection') == 2:
layer = -1 # -> no category
cat = -1
else:
layer = UserSettings.Get(group='vdigit', key="layer", subkey='value')
cat = self.SetCategory()
if line:
type = wxvdigit.GV_LINE
else:
type = wxvdigit.GV_BOUNDARY
listCoords = []
for c in coords:
for x in c:
listCoords.append(x)
snap, thresh = self.__getSnapThreshold()
ret = self.digit.AddLine(type, listCoords, layer, cat,
str(UserSettings.Get(group='vdigit', key="backgroundMap", subkey='value')), snap, thresh)
if ret == -1:
raise gcmd.DigitError, _("Adding new feature to vector map <%s> failed.") % map
self.toolbar.EnableUndo()
def DeleteSelectedLines(self):
@@ -870,7 +870,7 @@
@return number of deleted lines
nlines = self.digit.DeleteLines(UserSettings.Get(group='vdigit', key='delRecord', subkey='enabled'))
if nlines > 0:
@@ -882,13 +882,13 @@
@param move direction (x, y)
nlines = self.digit.MoveLines(move[0], move[1], 0.0, # TODO 3D
if nlines > 0:
return nlines
def MoveSelectedVertex(self, coords, move):
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py 2008-08-06 11:18:16 UTC (rev 32573)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py 2008-08-06 13:53:50 UTC (rev 32574)
@@ -273,14 +273,14 @@
layer = self.GetPyData(self.layer_selected)[0]['maplayer']
# enable editing only for vector map layers available in the current mapset
- digit = self.mapdisplay.toolbars['vdigit']
+ digitToolbar = self.mapdisplay.toolbars['vdigit']
if layer.GetMapset() != grassenv.GetGRASSVariable("MAPSET"):
# only vector map in current mapset can be edited
self.popupMenu.Enable (self.popupID5, False)
self.popupMenu.Enable (self.popupID6, False)
- elif digit and digit.layerSelectedID != None:
+ elif digitToolbar and digitToolbar.GetLayer():
# vector map already edited
- if digit.layers[digit.layerSelectedID] == layer:
+ if digitToolbar.GetLayer() is layer:
self.popupMenu.Enable(self.popupID6, True)
self.popupMenu.Enable(self.popupID1, False)
@@ -535,7 +535,6 @@
self.Bind(wx.EVT_BUTTON, self.OnLayerContextMenu, ctrl)
# add layer to the layer tree
if self.layer_selected and self.layer_selected != self.GetRootItem():
if self.GetPyData(self.layer_selected)[0]['type'] == 'group' \
and self.IsExpanded(self.layer_selected):
# add to group (first child of self.layer_selected) if group expanded
@@ -550,6 +549,8 @@
elif lgroup is True:
# -> last child of group (loading from workspace)
parent = self.GetItemParent(self.layer_selected)
+ if parent is self.root: # first item in group
+ parent=self.layer_selected
layer = self.AppendItem(parentId=parent,
text='', ct_type=1, wnd=ctrl)
elif lgroup is None:
@@ -573,7 +574,7 @@
# select new item
self.SelectItem(layer, select=True)
self.layer_selected = layer
# add text and icons for each layer ltype
if ltype == 'raster':
self.SetItemImage(layer, self.rast_icon)
@@ -673,10 +674,12 @@
# use predefined layer name if given
if lname:
- if ltype != 'command':
- if opacity:
- name = lname + ' (opacity: ' + str(opacity) + '%)'
- self.SetItemText(layer, name )
+ if ltype == 'group':
+ self.SetItemText(layer, lname)
+ elif ltype != 'command':
+ name = lname + ' (opacity: ' + \
+ str(self.GetPyData(layer)[0]['maplayer'].GetOpacity()) + '%)'
+ self.SetItemText(layer, name)
else:
ctrl.SetValue(lname)
@@ -825,17 +828,26 @@
"""Enable/disable data layer"""
item = event.GetItem()
checked = item.IsChecked()
if self.first == False:
# change active parameter for item in layers list in render.Map
if self.GetPyData(item)[0]['type'] == 'group':
child, cookie = self.GetFirstChild(item)
while child:
self.CheckItem(child, checked)
- self.Map.ChangeLayerActive(self.GetPyData(child)[0]['maplayer'], checked)
+ mapLayer = self.GetPyData(child)[0]['maplayer']
+ if not digitToolbar or \
+ (digitToolbar and digitToolbar.GetLayer() != mapLayer):
+ # ignore when map layer is edited
+ self.Map.ChangeLayerActive(mapLayer, checked)
child = self.GetNextSibling(child)
else:
- self.Map.ChangeLayerActive(self.GetPyData(item)[0]['maplayer'], checked)
+ mapLayer = self.GetPyData(item)[0]['maplayer']
# update progress bar range (mapwindow statusbar)
self.mapdisplay.onRenderGauge.SetRange(len(self.Map.GetListOfLayers(l_active=True)))
