[GRASS-SVN] r32620 - grass/branches/develbranch_6/lib/db/dbmi_client
Thu Aug 7 13:07:39 EDT 2008
Author: martinl
Date: 2008-08-07 13:07:39 -0400 (Thu, 07 Aug 2008)
New Revision: 32620
   grass/branches/develbranch_6/lib/db/dbmi_client/c_add_col.c
   grass/branches/develbranch_6/lib/db/dbmi_client/c_bindupdate.c
   grass/branches/develbranch_6/lib/db/dbmi_client/c_close_cur.c
   grass/branches/develbranch_6/lib/db/dbmi_client/c_closedb.c
   grass/branches/develbranch_6/lib/db/dbmi_client/c_create_idx.c
   grass/branches/develbranch_6/lib/db/dbmi_client/c_create_tab.c
   grass/branches/develbranch_6/lib/db/dbmi_client/c_createdb.c
   grass/branches/develbranch_6/lib/db/dbmi_client/c_delete.c
   grass/branches/develbranch_6/lib/db/dbmi_client/c_deletedb.c
   grass/branches/develbranch_6/lib/db/dbmi_client/c_desc_table.c
   grass/branches/develbranch_6/lib/db/dbmi_client/c_drop_col.c
   grass/branches/develbranch_6/lib/db/dbmi_client/c_drop_index.c
   grass/branches/develbranch_6/lib/db/dbmi_client/c_drop_tab.c
   grass/branches/develbranch_6/lib/db/dbmi_client/c_execute.c
   grass/branches/develbranch_6/lib/db/dbmi_client/c_fetch.c
   grass/branches/develbranch_6/lib/db/dbmi_client/c_finddb.c
   grass/branches/develbranch_6/lib/db/dbmi_client/c_insert.c
   grass/branches/develbranch_6/lib/db/dbmi_client/c_list_drivers.c
   grass/branches/develbranch_6/lib/db/dbmi_client/c_list_idx.c
   grass/branches/develbranch_6/lib/db/dbmi_client/c_list_tabs.c
   grass/branches/develbranch_6/lib/db/dbmi_client/c_listdb.c
   grass/branches/develbranch_6/lib/db/dbmi_client/c_opendb.c
   grass/branches/develbranch_6/lib/db/dbmi_client/c_openinsert.c
   grass/branches/develbranch_6/lib/db/dbmi_client/c_openselect.c
   grass/branches/develbranch_6/lib/db/dbmi_client/c_openupdate.c
   grass/branches/develbranch_6/lib/db/dbmi_client/c_priv.c
   grass/branches/develbranch_6/lib/db/dbmi_client/c_rows.c
   grass/branches/develbranch_6/lib/db/dbmi_client/c_update.c
   grass/branches/develbranch_6/lib/db/dbmi_client/c_version.c
   grass/branches/develbranch_6/lib/db/dbmi_client/column.c
   grass/branches/develbranch_6/lib/db/dbmi_client/copy_tab.c
   grass/branches/develbranch_6/lib/db/dbmi_client/db.c
   grass/branches/develbranch_6/lib/db/dbmi_client/delete_tab.c
   grass/branches/develbranch_6/lib/db/dbmi_client/printtab.c
   grass/branches/develbranch_6/lib/db/dbmi_client/select.c
   grass/branches/develbranch_6/lib/db/dbmi_client/shutdown.c
   grass/branches/develbranch_6/lib/db/dbmi_client/start.c
   grass/branches/develbranch_6/lib/db/dbmi_client/table.c
db/dbmi_client: initial doxygenization, message standardization
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/c_add_col.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/c_add_col.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/c_add_col.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_add_col.c
+ * \brief DBMI Library (client) - add column to table
+ * (C) 1999-2008 by the GRASS Development Team
+ * This program is free software under the GNU General Public
+ * License (>=v2). Read the file COPYING that comes with GRASS
+ * for details.
+ * \author Radim Blazek
 #include <grass/dbmi.h>
 #include "macros.h"
@@ -2,7 +16,11 @@
-   \fn int db_add_column (dbDriver *driver, dbString *tableName, dbColumn *column)
-   \brief
-   \return
-   \param
+   \brief Add column to table
+   \param driver db driver
+   \param tableName table name
+   \param column new column description (dbColumn structure)
+   \return DB_OK on success
+   \return DB_FAILED on failure
 int db_add_column(dbDriver * driver, dbString * tableName, dbColumn * column)
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/c_bindupdate.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/c_bindupdate.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/c_bindupdate.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_bindupdate.c
+ * \brief DBMI Library (client) - bind update
+ * for details.
 #include "macros.h"
@@ -2,6 +16,8 @@
-   \fn int db_bind_update (dbCursor *cursor)
-   \brief
-   \return
-   \param
+  \brief ADD
+  \param cursor db cursor
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/c_close_cur.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/c_close_cur.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/c_close_cur.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_close_cur.c
+ * \brief DBMI Library (client) - close cursor
+ * for details.
 #include <stdlib.h>
 #include "macros.h"
@@ -2,9 +16,10 @@
-   \fn int db_close_cursor (dbCursor *cursor)
-   \brief
-   \return
-   \param
+  \brief Close cursor
+  \param cursor cursor to be close
 int db_close_cursor(dbCursor * cursor)
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/c_closedb.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/c_closedb.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/c_closedb.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_closedb.c
+ * \brief DBMI Library (client) - close database connection
+ * for details.
 #include "macros.h"
@@ -2,7 +16,9 @@
-   \fn int db_close_database (dbDriver *driver)
-   \brief
-   \return
-   \param
+  \brief Close database connection
 int db_close_database(dbDriver * driver)
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/c_create_idx.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/c_create_idx.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/c_create_idx.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_create_idx.c
+ * \brief DBMI Library (client) - create index
+ * for details.
 #include <string.h>
 #include "macros.h"
@@ -3,9 +17,12 @@
-   \fn int db_create_index (dbDriver *driver, dbIndex *index)
-   \brief
-   \return
-   \param
+  \brief Create index
+  \param index index info (pointer to dbIndex structure)
 int db_create_index(dbDriver * driver, dbIndex * index)
@@ -32,13 +49,17 @@
-   \brief  Create unique index
-   \return
-   \param
+  \brief Create unique index
+  \param table_name table name
+  \param column_name column name (where to create index)
-int
-db_create_index2(dbDriver * driver, const char *table_name,
-		 const char *column_name)
+int db_create_index2(dbDriver * driver, const char *table_name,
+		     const char *column_name)
     int ret;
     dbIndex index;
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/c_create_tab.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/c_create_tab.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/c_create_tab.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_create_tab.c
+ * \brief DBMI Library (client) - create table
+ * for details.
 #include "macros.h"
@@ -2,6 +16,9 @@
-   \fn int db_create_table (dbDriver *driver, dbTable *table)
-   \brief
-   \return
-   \param
+  \brief Create table
+  \param table table description (pointer to dbTable structure)
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/c_createdb.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/c_createdb.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/c_createdb.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_createdb.c
+ * \brief DBMI Library (client) - create database
+ * for details.
 #include "macros.h"
@@ -2,6 +16,9 @@
-   \fn int db_create_database (dbDriver *driver, dbHandle *handle)
-   \brief create database
-   \return nothing
-   \param driver, handle
+  \brief Create database
+  \param handle handle
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/c_delete.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/c_delete.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/c_delete.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_delete.c
+ * \brief DBMI Library (client) - delete record
+ * for details.
 #include "macros.h"
@@ -2,6 +16,8 @@
-   \fn int db_delete (dbCursor *cursor)
-   \brief
-   \return
-   \param
+  \brief Delete record (?)
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/c_deletedb.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/c_deletedb.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/c_deletedb.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_deletedb.c
+ * \brief DBMI Library (client) - delete database
+ * for details.
 #include "macros.h"
@@ -2,6 +16,9 @@
-   \fn int db_delete_database (dbDriver *driver, dbHandle *handle)
-   \brief
-   \return
-   \param
+  \brief Delete database
+  \param handle handle info
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/c_desc_table.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/c_desc_table.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/c_desc_table.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_desc_table.c
+ * \brief DBMI Library (client) - describe table
+ * for details.
 #include "macros.h"
@@ -2,6 +16,10 @@
-   \fn int db_describe_table (dbDriver *driver, dbString *name, dbTable **table)
-   \brief
-   \return
-   \param
+  \brief Describe table
+  \param name table name
+  \param[out] pointer to dbTable structure
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/c_drop_col.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/c_drop_col.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/c_drop_col.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_drop_col.c
+ * \brief DBMI Library (client) - drop column
+ * for details.
 #include "macros.h"
@@ -2,9 +16,12 @@
-   \fn int db_drop_column (dbDriver *driver, dbString *tableName, dbString *columnName)
-   \brief
-   \return
-   \param
+  \brief driver db driver
+  \param columnName column name to be dropped
-int
-db_drop_column(dbDriver * driver, dbString * tableName, dbString * columnName)
+int db_drop_column(dbDriver * driver, dbString * tableName, dbString * columnName)
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/c_drop_index.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/c_drop_index.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/c_drop_index.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_drop_index.c
+ * \brief DBMI Library (client) - drop index
+ * for details.
 #include "macros.h"
@@ -2,7 +16,10 @@
-   \fn int db_drop_index (dbDriver *driver, dbString *name)
-   \brief
-   \return
-   \param
+  \brief Drop index
+  \param name index name
 int db_drop_index(dbDriver * driver, dbString * name)
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/c_drop_tab.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/c_drop_tab.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/c_drop_tab.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_drop_tab.c
+ * \brief DBMI Library (client) - drop table
+ * for details.
 #include "macros.h"
@@ -2,6 +16,9 @@
-   \fn int db_drop_table (dbDriver *driver, dbString *name)
-   \brief
-   \return
-   \param
+  \brief Drop table
+  \param name table name to be dropped
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/c_execute.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/c_execute.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/c_execute.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_execute.c
+ * \brief DBMI Library (client) - execute SQL statements
+ * for details.
 #include "macros.h"
@@ -2,6 +16,9 @@
-   \fn int db_execute_immediate (dbDriver *driver, dbString *SQLstatement)
-   \brief
-   \return
-   \param
+  \brief Execute SQL statements
+  \param SQLstatement SQL statement (alter, update, ...)
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/c_fetch.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/c_fetch.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/c_fetch.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_fetch.c
+ * \brief DBMI Library (client) - fetch data
+ * for details.
 #include "macros.h"
@@ -2,6 +16,10 @@
-   \fn int db_fetch (dbCursor *cursor, int position, int *more)
-   \brief
-   \return
-   \param
+  \brief Fetch data
+  \param position cursor position
+  \param[out] more get more?
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/c_finddb.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/c_finddb.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/c_finddb.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_finddb.c
+ * \brief DBMI Library (client) - find database
+ * for details.
 #include <stdlib.h>
 #include "macros.h"
@@ -3,8 +17,12 @@
-   \fn int db_find_database (dbDriver *driver, dbHandle *handle, int *found)
-   \brief
-   \return
-   \param
+  \brief Find database
+  \param[out] found if non-zero database found
 int db_find_database(dbDriver * driver, dbHandle * handle, int *found)
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/c_insert.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/c_insert.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/c_insert.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_insert.c
+ * \brief DBMI Library (client) - insert new record
+ * for details.
 #include "macros.h"
@@ -2,7 +16,9 @@
-   \fn int db_insert (dbCursor *cursor)
-   \brief
-   \return
-   \param
+  \brief Insert new record into table
 int db_insert(dbCursor * cursor)
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/c_list_drivers.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/c_list_drivers.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/c_list_drivers.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,10 +1,23 @@
+ * \file db/dbmi_client/c_list_drivers.c
+ * \brief DBMI Library (client) - list drivers
+ * for details.
-   \fn char *db_list_drivers(void)
-   \brief return comma separated list of existing DB drivers, used for driver parameter options
-   \return return char
-   \param void
+  \brief Return comma separated list of existing DB drivers, used for driver parameter options
+  \return list of db drivers
 const char *db_list_drivers(void)
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/c_list_idx.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/c_list_idx.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/c_list_idx.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_list_idx.c
+ * \brief DBMI Library (client) - list indexes
+ * for details.
 #include "macros.h"
@@ -2,6 +16,11 @@
-   \fn int db_list_indexes (dbDriver *driver, dbString *table_name, dbIndex **list, int *count)
-   \brief
-   \return
-   \param
+  \brief List indexes
+  \param[out] list of db indexes
+  \param[out] number of items in the list
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/c_list_tabs.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/c_list_tabs.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/c_list_tabs.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_list_tabs.c
+ * \brief DBMI Library (client) - list tables
+ * for details.
 #include <stdlib.h>
 #include <string.h>
@@ -12,12 +26,15 @@
-   \fn int db_list_tables (dbDriver *driver, dbString **names, int *count, int system)
-   \brief list available tables for given connection
-   \return names of tables, success: DB_OK; DB_FAILED otherwise
-   \param names: names of tables
-   \param
-   \param
+   \brief List available tables for given connection
+   \param[out] names list of table names
+   \param[out] count number of items in the list
+   \param system ?
 int
 db_list_tables(dbDriver * driver, dbString ** names, int *count, int system)
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/c_listdb.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/c_listdb.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/c_listdb.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_listdb.c
+ * \brief DBMI Library (client) - list databases
+ * for details.
 #include "macros.h"
@@ -2,10 +16,15 @@
-   \fn int db_list_databases (dbDriver *driver, dbString *path, int npaths, dbHandle **handles, int *count)
-   \brief
-   \return
-   \param
-int
-db_list_databases(dbDriver * driver, dbString * path, int npaths,
-		  dbHandle ** handles, int *count)
+  \brief List databases
+  \param path db path
+  \param npaths number of given paths
+  \param[out] handles handle infos
+  \param[out] number of handle infos
+int db_list_databases(dbDriver * driver, dbString * path, int npaths,
+		      dbHandle ** handles, int *count)
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/c_opendb.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/c_opendb.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/c_opendb.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_opendb.c
+ * \brief DBMI Library (client) - open database connection
+ * for details.
 #include "macros.h"
@@ -2,6 +16,9 @@
-   \fn
-   \brief
-   \return
-   \param
+  \brief Open database connection
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/c_openinsert.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/c_openinsert.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/c_openinsert.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_openinsert.c
+ * \brief DBMI Library (client) - open insert cursor
+ * for details.
 #include "macros.h"
@@ -2,6 +16,9 @@
-   \fn
-   \brief
-   \return
-   \param
+  \brief Open insert cursor
+  \param cursor cursor to be opened
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/c_openselect.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/c_openselect.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/c_openselect.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_openselect.c
+ * \brief DBMI Library (client) - open select cursor
+ * for details.
 #include "macros.h"
@@ -2,10 +16,14 @@
-   \fn
-   \brief
-   \return
-   \param
+  \brief Open select cursor
+  \param select SQL select statement
+  \param cursor db cursor to be opened
+  \param mode open mode (?)
-int
-db_open_select_cursor(dbDriver * driver, dbString * select, dbCursor * cursor,
-		      int mode)
+int db_open_select_cursor(dbDriver * driver, dbString * select, dbCursor * cursor,
+			  int mode)
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/c_openupdate.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/c_openupdate.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/c_openupdate.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_openupdate.c
+ * \brief DBMI Library (client) - open update cursor
+ * for details.
 #include "macros.h"
@@ -2,10 +16,16 @@
-   \fn
-   \brief
-   \return
-   \param
+  \brief Open update cursor
+  \param select SQL update statement (?)
-int
-db_open_update_cursor(dbDriver * driver, dbString * table_name,
-		      dbString * select, dbCursor * cursor, int mode)
+int db_open_update_cursor(dbDriver * driver, dbString * table_name,
+			  dbString * select, dbCursor * cursor, int mode)
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/c_priv.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/c_priv.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/c_priv.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_priv.c
+ * \brief DBMI Library (client) - privileges management
+ * for details.
 #include "macros.h"
@@ -2,9 +16,13 @@
-   \brief Grant privileges
-   \return
-   \param priv privileges: DB_PRIV_SELECT
-   \param to grant to : DB_GROUP | DB_PUBLIC
-int
-db_grant_on_table(dbDriver * driver, const char *tableName, int priv, int to)
+  \brief Grant privileges
+  \param priv privileges DB_PRIV_SELECT
+  \param to grant to DB_GROUP | DB_PUBLIC
+int db_grant_on_table(dbDriver * driver, const char *tableName, int priv, int to)
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/c_rows.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/c_rows.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/c_rows.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_rows.c
+ * \brief DBMI Library (client) - get number of records
+ * for details.
 #include "macros.h"
@@ -2,6 +16,8 @@
-   \fn int db_get_num_rows ( dbCursor *cursor )
-   \brief get number of selected rows
-   \return
-   \param
+  \brief Get number of selected rows
+  \param cursor db select cursor
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/c_update.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/c_update.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/c_update.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_update.c
+ * \brief DBMI Library (client) - update statemets
+ * for details.
 #include "macros.h"
@@ -2,7 +16,9 @@
-   \fn
-   \brief
-   \return
-   \param
+  \brief ?
 int db_update(dbCursor * cursor)
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/c_version.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/c_version.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/c_version.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,17 +1,35 @@
+ * \file db/dbmi_client/c_version.c
+ * \brief DBMI Library (client) - version info
+ * for details.
 #include "macros.h"
-/* Note: renamed from db_version to db_gversion to avoid name conflict
-   with Berkeley DB etc */
-   \fn
-   \brief
-   \return
-   \param
-int
-db_gversion(dbDriver * driver, dbString * client_version,
-	    dbString * driver_version)
+  \brief Get version info
+  Note: renamed from db_version to db_gversion to avoid name conflict
+  with Berkeley DB etc.
+  \param[out] client_version client version
+  \param[out] driver_version driver version
+int db_gversion(dbDriver * driver, dbString * client_version,
+		dbString * driver_version)
     int ret_code;
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/column.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/column.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/column.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,21 +1,19 @@
+ * \file db/dbmi_client/column.c
+ * \brief DBMI Library (client) - column info
+ * for details.
+ * \author Update by Glynn Clement <glynn gclements.plus.com>
+ * and Martin Landa <landa.martin gmail.com>
-* MODULE:       DBMI Library - dbmi_client column lib
-* AUTHOR(S):    Radim Blazek (original contributor)
-*               Glynn Clement <glynn gclements.plus.com>,
-*               Martin Landa <landa.martin gmail.com>
-* PURPOSE:      Higher level functions for DBMI DataBase Management Interface
-* COPYRIGHT:    (C) 2001-2007 by the GRASS Development Team
-*               This program is free software under the GNU General Public
-*   	    	License (>=v2). Read the file COPYING that comes with GRASS
-*   	    	for details.
 #include <stdlib.h>
 #include <string.h>
 #include <grass/gis.h>
@@ -23,15 +21,17 @@
 #include <grass/glocale.h>
-   \fn int db_column_sqltype (dbDriver *driver, const char *tab, const char *col)
-   \brief Get column sqltype
+  \brief Get column sqltype
-   See db_sqltype_name ()
-   \return column sqltype or -1 on error
-   \param driver DB driver
-   \param tab table name
-   \param col column name
+  See db_sqltype_name().
+  \param driver DB driver
+  \param tab table name
+  \param col column name
+  \return column sqltype
+  \return -1 on error
 int db_column_sqltype(dbDriver * driver, const char *tab, const char *col)
     dbTable *table;
@@ -59,14 +59,16 @@
-   \fn int db_column_Ctype (dbDriver *driver, const char *tab, const char *col)
-   \brief Get column Ctype
+  \brief Get column ctype
-   See db_sqltype_to_Ctype()
-   \return column Ctype or -1 on error
+  See db_sqltype_to_Ctype().
+  \return column Ctype
 int db_column_Ctype(dbDriver * driver, const char *tab, const char *col)
@@ -81,19 +83,20 @@
-   \fn int db_get_column ( dbDriver *Driver, const char *tname, const char *cname, dbColumn **Column )
-   \brief Get column structure by table and column name.
+  \brief Get column structure by table and column name.
-   Column is set to new dbColumn structure or NULL if column was not found
-   \return DB_OK on success, DB_FAILED on error
-   \param Driver DB driver
-   \param tname table name
-   \param cname column name
-   \param Column column structure to store within
-int
-db_get_column(dbDriver * Driver, const char *tname, const char *cname,
-	      dbColumn ** Column)
+  Column is set to new dbColumn structure or NULL if column was not found
+  \param Driver DB driver
+  \param tname table name
+  \param cname column name
+  \param[out] Column column structure to store within
+int db_get_column(dbDriver * Driver, const char *tname, const char *cname,
+		  dbColumn ** Column)
     int i, ncols;
     dbTable *Table;
@@ -104,7 +107,7 @@
     db_set_string(&tabname, tname);
     if (db_describe_table(Driver, &tabname, &Table) != DB_OK) {
-	G_warning(_("Cannot describe table <%s>"), tname);
+      G_warning(_("Unable to describe table <%s>"), tname);
 	return DB_FAILED;
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/copy_tab.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/copy_tab.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/copy_tab.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,6 +1,21 @@
+ * \file db/dbmi_client/copy_tab.c
+ * \brief DBMI Library (client) - copy table
+ * for details.
 #include <stdlib.h>
 #include <string.h>
+#include <grass/glocale.h>
 #include "macros.h"
 static int cmp(const void *pa, const void *pb)
@@ -15,25 +30,36 @@
     return 0;
-/* Copy table, used by various db_copy_table*
+  \brief Copy table, used by various db_copy_table*
+  Use either 'where' or 'select' or 'selcol'+'ivals'+'nvals' but
+  never more than one.
-   Parameters:
-   where: WHERE SQL condition (without where key word) or NULL
-   select: full select statement
-   selcol: name of column used to select records by values in ivals or NULL
-   ivals: pointer to array of integer values or NULL
-   nvals: number of values in ivals
+  Warning: driver opened as second must be closed as first, otherwise
+  it hangs, not sure why.
-   Use either 'where' or 'select' or 'selcol'+'ivals'+'nvals' but never more than one
+  \param from_dvrname name of driver from table is copied
+  \param from_dbname name of database from table is copied
+  \param from_tbl_name name of table to be copied
+  \param to_dvrname name of driver to - where table is copied to
+  \param to_dbname name of database to - where table is copied to
+  \param to_dbname name of copied table
+  \param where WHERE SQL condition (without where key word) or NULL
+  \param select full select statement
+  \param selcol name of column used to select records by values in ivals or NULL
+  \param ivals pointer to array of integer values or NULL
+  \param nvals number of values in ivals
-/* Warning, driver opened as second must be closed as first, otherwise it hangs, not sure why */
-int
-db__copy_table(const char *from_drvname, const char *from_dbname,
-	       const char *from_tblname, const char *to_drvname,
-	       const char *to_dbname, const char *to_tblname,
-	       const char *where, const char *select, const char *selcol,
-	       int *ivals, int nvals)
+int db__copy_table(const char *from_drvname, const char *from_dbname,
+		   const char *from_tblname, const char *to_drvname,
+		   const char *to_dbname, const char *to_tblname,
+		   const char *where, const char *select, const char *selcol,
+		   int *ivals, int nvals)
     int col, ncols, sqltype, ctype, more, selcol_found;
     char buf[1000];
@@ -71,12 +97,13 @@
     /* Open input driver and database */
     from_driver = db_start_driver(from_drvname);
     if (from_driver == NULL) {
-	G_warning("Cannot open driver '%s'", from_drvname);
+	G_warning(_("Unable to start driver <%s>"), from_drvname);
 	return DB_FAILED;
     db_set_handle(&from_handle, from_dbname, NULL);
     if (db_open_database(from_driver, &from_handle) != DB_OK) {
-	G_warning("Cannot open database '%s'", from_dbname);
+	G_warning(_("Unable to open database <%s> by driver <%s>"),
+		  from_drvname, from_dbname);
 	db_close_database_shutdown_driver(from_driver);
 	return DB_FAILED;
@@ -90,13 +117,14 @@
     else {
 	to_driver = db_start_driver(to_drvname);
 	if (to_driver == NULL) {
-	    G_warning("Cannot open driver '%s'", to_drvname);
+	    G_warning(_("Unable to start driver <%s>"), to_drvname);
 	    return DB_FAILED;
 	db_set_handle(&to_handle, to_dbname, NULL);
 	if (db_open_database(to_driver, &to_handle) != DB_OK) {
-	    G_warning("Cannot open database '%s'", to_dbname);
+		      to_drvname, to_dbname);
 	    db_close_database_shutdown_driver(to_driver);
 	    if (from_driver != to_driver) {
@@ -113,7 +141,8 @@
     /* test if the table exists */
     if (db_list_tables(to_driver, &tblnames, &count, 0) != DB_OK) {
-	G_warning("Cannot list tables in database '%s'", to_dbname);
+	G_warning(_("Unable to get list tables in database <%s>"),
+		  to_dbname);
@@ -125,7 +154,8 @@
 	const char *tblname = db_get_string(&tblnames[i]);
 	if (strcmp(to_tblname, tblname) == 0) {
-	    G_warning("Table '%s' already exists", to_dbname);
+	    G_warning(_("Table <%s> already existsin database <%s>"),
+		      to_dbname, to_dbname);
@@ -166,7 +196,8 @@
     G_debug(3, db_get_string(&sql));
     if (db_open_select_cursor(from_driver, &sql, &cursor, DB_SEQUENTIAL) !=
 	DB_OK) {
-	G_warning("Cannot open select cursor: '%s'", db_get_string(&sql));
+	G_warning(_("Unable to open select cursor: '%s'"),
+		  db_get_string(&sql));
@@ -197,7 +228,8 @@
 	if (selcol && G_strcasecmp(colname, selcol) == 0) {
 	    if (ctype != DB_C_TYPE_INT)
-		G_fatal_error("Column '%s' is not integer", colname);
+		G_fatal_error(_("Column <%s> is not integer"),
+			      colname);
 	    selcol_found = 1;
@@ -213,10 +245,11 @@
     db_close_cursor(&cursor);
     if (selcol && !selcol_found)
-	G_fatal_error("Column '%s' not found", selcol);
+	G_fatal_error(_("Column <%s> not found"), selcol);
     if (db_create_table(to_driver, out_table) != DB_OK) {
-	G_warning("Cannot create new table");
+	G_warning(_("Unable to create table <%s>"),
+		  out_table);
@@ -240,7 +273,8 @@
 	DB_OK) {
@@ -258,7 +292,8 @@
 	int select;
 	if (db_fetch(&cursor, DB_NEXT, &more) != DB_OK) {
-	    G_warning("Cannot fetch row");
+	    G_warning(_("Unable to fetch data from table <%s>"),
+		      from_tblname);
@@ -313,7 +348,8 @@
 		break;
 	    default:
-		G_warning("Unknown column type (%s)", colname);
+		G_warning(_("Unknown column type (column <%s>)"),
+			  colname);
@@ -327,7 +363,8 @@
 	db_append_string(&sql, ")");
 	if (db_execute_immediate(to_driver, &sql) != DB_OK) {
-	    G_warning("Cannot insert new record: '%s'", db_get_string(&sql));
+	    G_warning("Unable to insert new record: '%s'",
@@ -351,16 +388,21 @@
-   \fn int db_copy_table (const char *from_drvname, const char *from_dbname, const char *from_tblname,
-   const char *to_drvname, const char *to_dbname, const char *to_tblname )
-   \brief Copy a table
-   \return
-   \param
+  \brief Copy a table
-int
-db_copy_table(const char *from_drvname, const char *from_dbname,
-	      const char *to_dbname, const char *to_tblname)
+int db_copy_table(const char *from_drvname, const char *from_dbname,
+		  const char *to_dbname, const char *to_tblname)
     return db__copy_table(from_drvname, from_dbname, from_tblname,
 			  to_drvname, to_dbname, to_tblname,
@@ -368,17 +410,23 @@
-   \fn int db_copy_table_where (const char *from_drvname, const char *from_dbname, const char *from_tblname,
-   const char *to_drvname, const char *to_dbname, const char *to_tblname, const char *where )
-   \return
-   \param where WHERE SQL condition (without where key word) or NULL
-int
-db_copy_table_where(const char *from_drvname, const char *from_dbname,
-		    const char *where)
+  \brief Copy a table (by where statement)
+int db_copy_table_where(const char *from_drvname, const char *from_dbname,
+			const char *where)
@@ -386,17 +434,23 @@
-   \fn int db_copy_table_select ( const char *from_drvname, const char *from_dbname, const char *from_tblname,
-   const char *to_drvname, const char *to_dbname, const char *to_tblname, const char *select )
-   \return
-   \param select is full select statement or NULL
-int
-db_copy_table_select(const char *from_drvname, const char *from_dbname,
-		     const char *select)
+  \brief Copy a table (by select statement)
+int db_copy_table_select(const char *from_drvname, const char *from_dbname,
+			 const char *select)
@@ -404,21 +458,25 @@
-   \fn int db_copy_table_by_ints ( const char *from_drvname, const char *from_dbname, const char *from_tblname,
-   const char *selcol, int *ivals, int nvals )
-   \brief Copy a table, but only records where value of column 'selcol'
-   is in 'ivals'
-   \return
-   \param selcol name of column used to select records by values in ivals or NULL
-   \param ivals pointer to array of integer values or NULL
-   \param nvals number of values in ivals
-int
-db_copy_table_by_ints(const char *from_drvname, const char *from_dbname,
-		      const char *selcol, int *ivals, int nvals)
+  \brief Copy a table (by keys)
+int db_copy_table_by_ints(const char *from_drvname, const char *from_dbname,
+			  const char *selcol, int *ivals, int nvals)
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/db.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/db.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/db.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,11 +1,29 @@
+ * \file db/dbmi_client/db.c
+ * \brief DBMI Library (client) - open/close driver/database connection
+ * for details.
 #include "macros.h"
-   \fn dbDriver * db_start_driver_open_database ( const char *drvname, const char *dbname )
-   \brief
-   \return
-   \param
+  \brief Open driver/database connection
+  \param drvname driver name
+  \param dbname database name
+  \return poiner to dbDriver structure
+  \return NULL on failure
 dbDriver *db_start_driver_open_database(const char *drvname,
 					const char *dbname)
@@ -13,20 +31,20 @@
     dbHandle handle;
     dbDriver *driver;
-    G_debug(3,
-	    "db_start_driver_open_database():\n  drvname = %s, dbname = %s",
+    G_debug(3, "db_start_driver_open_database():\n  drvname = %s, dbname = %s",
 	    drvname, dbname);
     db_init_handle(&handle);
     driver = db_start_driver(drvname);
     if (driver == NULL) {
-	G_warning("Cannot open driver '%s'", drvname);
+	G_warning(_("Unable to start driver <%s>"), drvname);
 	return NULL;
     db_set_handle(&handle, dbname, NULL);
     if (db_open_database(driver, &handle) != DB_OK) {
-	G_warning("Cannot open database '%s'", dbname);
+		  dbname, drvname);
 	db_shutdown_driver(driver);
 	return NULL;
@@ -35,11 +53,12 @@
-   \fn int db_close_database_shutdown_driver (dbDriver *driver )
-   \brief
-   \return
-   \param
+  \brief Close driver/database connection
+  \return DB_OK
 int db_close_database_shutdown_driver(dbDriver * driver)
     db_close_database(driver);
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/delete_tab.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/delete_tab.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/delete_tab.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,14 +1,32 @@
+ * \file db/dbmi_client/delete_tab.c
+ * \brief DBMI Library (client) - delete table
+ * for details.
 #include "macros.h"
-   \fn int db_delete_table ( const char *drvname, const char *dbname, const char *tblname )
-   \brief
-   \return
-   \param
+  \brief Delete table
+  \param drv driver name
+  \param tblname table name
-int
-db_delete_table(const char *drvname, const char *dbname, const char *tblname)
+int db_delete_table(const char *drvname, const char *dbname, const char *tblname)
     dbDriver *driver;
     dbHandle handle;
@@ -23,12 +41,13 @@
     /* Open driver and database */
+	G_warning(_("Unable to open driver <%s>"), drvname);
 	return DB_FAILED;
+		  dbname, drvname);
 	return DB_FAILED;
@@ -40,7 +59,8 @@
     if (db_execute_immediate(driver, &sql) != DB_OK) {
-	G_warning("Cannot drop table: '%s'", db_get_string(&sql));
+	G_warning(_("Unable to drop table: '%s'"),
 	return DB_FAILED;
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/printtab.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/printtab.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/printtab.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/printtab.c
+ * \brief DBMI Library (client) - print table description info
+ * for details.
 #include <string.h>
@@ -4,11 +18,11 @@
 static void print_priv();
-   \fn
-   \brief
-   \return
-   \param
+  \brief Print table definition info
+  \param fd file descriptor
+  \param table table info
 void db_print_table_definition(FILE * fd, dbTable * table)
     int ncols, col;
@@ -28,6 +42,12 @@
+  \brief Print column definition info
+  \param column column info
 void db_print_column_definition(FILE * fd, dbColumn * column)
     dbString value_string;
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/select.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/select.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/select.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/select.c
+ * \brief DBMI Library (client) - select records from table
+ * for details.
 #include <stdlib.h>
 #include <string.h>
@@ -2,2 +16,3 @@
@@ -74,16 +89,17 @@
-   \fn db_select_int (dbDriver *driver, const char *tab, const char *col, const char *where, int **pval)
-   \brief Select array of ordered integers from table/column
-   \return number of selected values, -1 on error
-   \param where where statement
-   \param pval array of ordered integer values
+  \brief Select array of ordered integers from table/column
+  \param where where statement
+  \param[out] pval array of ordered integer values
+  \return number of selected values
 int db_select_int(dbDriver * driver, const char *tab, const char *col,
@@ -164,15 +180,17 @@
-   \fn db_select_value (dbDriver *driver, const char *tab, const char *key, int id, const char *col, dbValue *val)
-   \brief Select one (first) value from table/column for key/id
-   \param key key column name
-   \param id identifier in key column
-   \param col name of column to select the value from
-   \param val dbValue to store within
+  \brief Select one (first) value from table/column for key/id
+  \param key key column name
+  \param id identifier in key column
+  \param col name of column to select the value from
+  \param[out] val dbValue to store within
 int db_select_value(dbDriver * driver, const char *tab, const char *key,
 		    int id, const char *col, dbValue * val)
@@ -215,14 +233,16 @@
-   \fn int db_select_CatValArray (dbDriver *driver, const char *tab, const char *key, const char *col, const char *where, dbCatValArray *cvarr)
-   \brief Select pairs key/value to array, values are sorted by key (must be integer)
-   \param col value column name
-   \param cvarr dbCatValArray to store within
+  \brief Select pairs key/value to array, values are sorted by key (must be integer)
+  \param col value column name
+  \param[out] cvarr dbCatValArray to store within
 int db_select_CatValArray(dbDriver * driver, const char *tab, const char *key,
@@ -256,7 +276,7 @@
     nrows = db_get_num_rows(&cursor);
     G_debug(3, "  %d rows selected", nrows);
     if (nrows < 0)
-	G_fatal_error("Cannot select rows from database");
+	G_fatal_error(_("Unable select records from table <%s>"), tab);
     db_CatValArray_alloc(cvarr, nrows);
@@ -343,20 +363,21 @@
-   \fn void db_CatValArray_sort (dbCatValArray *arr)
-   \brief Sort key/value array by key
-   \param arr dbCatValArray (key/value array)
+  \brief Sort key/value array by key
+  \param[in,out] arr dbCatValArray (key/value array)
 void db_CatValArray_sort(dbCatValArray * arr)
     qsort((void *)arr->value, arr->n_values, sizeof(dbCatVal), cmpcat);
-   \fn int db_CatValArray_sort_by_value (dbCatValArray *arr)
-   \brief Sort key/value array by value
+  \brief Sort key/value array by value
+  \return DB_FAILED on error
 int db_CatValArray_sort_by_value(dbCatValArray * arr)
@@ -385,12 +406,14 @@
-   \fn int db_CatValArray_get_value (dbCatValArray *arr, int key, dbCatVal **cv)
-   \brief Find value by key
-   \param key key value
-   \param cv dbCatVal structure (key/value) to store within
+  \brief Find value by key
+  \param arr dbCatValArray (key/value array)
+  \param key key value
+  \param[out] cv dbCatVal structure (key/value) to store within
 int db_CatValArray_get_value(dbCatValArray * arr, int key, dbCatVal ** cv)
@@ -409,12 +432,14 @@
-   \fn int db_CatValArray_get_value_int (dbCatValArray *arr, int key, int *val)
-   \brief Find value (integer) by key
-   \param val found value (integer)
+  \brief Find value (integer) by key
+  \param[out] val found value (integer)
 int db_CatValArray_get_value_int(dbCatValArray * arr, int key, int *val)
@@ -433,13 +458,15 @@
-   \fn int db_CatValArray_get_value_double (dbCatValArray *arr, int key, double *val)
-   \brief Find value (double) by key
-   \param val found value (double)
+  \brief Find value (double) by key
+  \param[out] val found value (double)
 int db_CatValArray_get_value_double(dbCatValArray * arr, int key, double *val)
     dbCatVal *catval;
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/shutdown.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/shutdown.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/shutdown.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/shutdown.c
+ * \brief DBMI Library (client) - shutdown database connection
+ * for details.
 #include <stdlib.h>
 #ifdef __MINGW32__
@@ -9,19 +23,19 @@
 #include "macros.h"
-   \fn
-   \brief
-   \return
-   \param
-/* closedown the driver, and free the driver structure */
-/* NOTE: the management of the memory for the driver structure
- * probably should be handled differently.
- * db_start_driver() could take a pointer to driver structure as
- * an argument, instead of returning the pointer to allocated
- * then there would be no hidden free required
+  \brief Closedown the driver, and free the driver structure
+  <b>Note:</b> the management of the memory for the driver structure
+  probably should be handled differently.
+  db_start_driver() could take a pointer to driver structure as
+  an argument, instead of returning the pointer to allocated
+  then there would be no hidden free required
+  \return status (?)
 int db_shutdown_driver(dbDriver * driver)
 #ifndef __MINGW32__
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/start.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/start.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/start.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/start.c
+ * for details.
 #include <string.h>
 #include <stdlib.h>
 #include <unistd.h>
@@ -14,18 +28,17 @@
 #define WRITE 1
- * \fn dbDriver *db_start_driver (const char *name)
- * \brief Initialize a new dbDriver for db transaction.
- * If <b>name</b> is NULL, the db name will be assigned
- * connection.driverName.
- * \param[in] const char * driver name
- * \return NULL on error
+  \brief Initialize a new dbDriver for db transaction.
+  If <i>name</i> is NULL, the db name will be assigned
+  connection.driverName.
+  \param name driver name
+  \return pointer to dbDriver structure
+  \return NULL on error
 dbDriver *db_start_driver(const char *name)
     dbDriver *driver;
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/table.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/table.c	2008-08-07 16:04:00 UTC (rev 32619)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/table.c	2008-08-07 17:07:39 UTC (rev 32620)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/table.c
+ * \brief DBMI Library (client) - table management
+ * for details.
 #include <stdlib.h>
 #include <string.h>
@@ -2,14 +16,16 @@
-   \fn int db_table_exists ( const char *, const char *, const char *)
-   \brief check if table exists
-   \param drvname: driver name
-   \param dbname: database name
-   \param tabname: table name
-   \return: 1 exist, 0 doesn't exist, -1 error
-   \param
-int
-db_table_exists(const char *drvname, const char *dbname, const char *tabname)
+  \brief Check if table exists
+  \param tabname table name
+  \return 1 exist
+  \return 0 doesn't exist
+  \return -1 error
+int db_table_exists(const char *drvname, const char *dbname, const char *tabname)
@@ -27,7 +43,7 @@
     driver = db_start_driver_open_database(drvname, dbname);
-	G_warning("Cannot open database '%s' by driver '%s'", dbname,
+	G_warning(_("Unable open database <%s> by driver <%s>"), dbname,
 		  drvname);
 	return -1;
@@ -77,20 +93,23 @@
-   \fn
-   \brief return number of rows of table
-   \return
-   \param
+  \brief Get number of rows of table
+  \param sql SQL statement
+  \return number of records
+  \return -1
 int db_get_table_number_of_rows(dbDriver * driver, dbString * sql)
     int nrows;
     dbCursor cursor;
     if (db_open_select_cursor(driver, sql, &cursor, DB_SEQUENTIAL) != DB_OK) {
-	G_warning("Cannot open select cursor: '%s'", db_get_string(sql));
+	G_warning(_("Unable to open select cursor: '%s'"), db_get_string(sql));
 	db_close_database_shutdown_driver(driver);
-	return DB_FAILED;
+	return -1;
