[GRASS-SVN] r32621 - in grass/branches/develbranch_6/lib/db: .
dbmi_client
svn_grass at osgeo.org
Thu Aug 7 13:54:47 EDT 2008
Author: martinl
Date: 2008-08-07 13:54:47 -0400 (Thu, 07 Aug 2008)
New Revision: 32621
grass/branches/develbranch_6/lib/db/dbmi_client/c_execute.c
grass/branches/develbranch_6/lib/db/dbmi_client/c_list_idx.c
grass/branches/develbranch_6/lib/db/dbmilib.dox
dbmilib: update dbmilib doxygen page (list of dbmi_client fns), some minor dosygen updates, update r32620
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/c_execute.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/c_execute.c 2008-08-07 17:07:39 UTC (rev 32620)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/c_execute.c 2008-08-07 17:54:47 UTC (rev 32621)
@@ -46,10 +46,12 @@
- \fn int db_begin_transaction (dbDriver *driver)
- \brief
- \return
- \param
+ \brief Begin transaction
+ \return driver db driver
+ \return DB_OK on success
+ \return DB_FAILED on failure
int db_begin_transaction(dbDriver * driver)
@@ -70,10 +72,12 @@
- \fn int db_commit_transaction (dbDriver *driver)
- \brief
- \return
- \param
+ \brief Commit transaction
+ \param driver db driver
int db_commit_transaction(dbDriver * driver)
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/c_list_idx.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/c_list_idx.c 2008-08-07 17:07:39 UTC (rev 32620)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/c_list_idx.c 2008-08-07 17:54:47 UTC (rev 32621)
@@ -26,9 +26,8 @@
-int
-db_list_indexes(dbDriver * driver, dbString * table_name, dbIndex ** list,
- int *count)
+int db_list_indexes(dbDriver * driver, dbString * table_name, dbIndex ** list,
+ int *count)
int ret_code;
Modified: grass/branches/develbranch_6/lib/db/dbmilib.dox
--- grass/branches/develbranch_6/lib/db/dbmilib.dox 2008-08-07 17:07:39 UTC (rev 32620)
+++ grass/branches/develbranch_6/lib/db/dbmilib.dox 2008-08-07 17:54:47 UTC (rev 32621)
@@ -9,16 +9,17 @@
The attribute management was completely changed in GRASS 6 to achieve
multi-attribute capabilities managed within external databases. The former
dig_cats/ files are not used any more and all vector attributes are stored
-in external database. Connection with database is done through DBMI library
+in external database. Connection with database is done through <b>DBMI library</b>
(DataBase Management Interface) with its integrated drivers. At time of this
writing following DBMI drivers for attribute storage are available:
<ul>
<li> DBF: xBase files (default)
-<li> ODBC: to interface from www.unixodbc.org
+<li> ODBC: to interface from http://www.unixodbc.org
<li> PostgreSQL driver (note that PostgreSQL can also be accessed through
- ODBC)
-<li> mySQL
+ ODBC): http://www.postgresql.org
+<li> mySQL: http://mysql.com/
+<li> SQLite: http://www.sqlite.org/
</ul>
These drivers are compiled depending on present DB related libraries and
@@ -35,12 +36,13 @@
vector entity may be linked to attributes in different tables in different
databases connected by different drivers at the same time.
-The DBMI library contains drivers such as DBF, ODBC, MySQL and PostgreSQL.
-The functionality of the database support varies with the
-capabilities of the underlying RDBMS. Main features are multi-attributes
-support for various data types, also multiple tables may optionally be
-linked to one or many vector entity/ies. SQL (Structured Query Language) is
-used for all drivers, but in a limited implementation.
+The DBMI library contains drivers such as DBF, SQLite, ODBC, MySQL and
+PostgreSQL. The functionality of the database support varies with the
+capabilities of the underlying RDBMS. Main features are
+multi-attributes support for various data types, also multiple tables
+may optionally be linked to one or many vector entity/ies. SQL
+(Structured Query Language) is used for all drivers, but in a limited
+implementation.
For DBMI architecture details please read Blazek et al. 2002 (see below).
@@ -63,8 +65,117 @@
\section dbmi_client DBMI CLIENT functions
-[ to be moved here from below list ]
+ - db_add_column()
+ - db_begin_transaction()
+ - db_bind_update()
+ - db_CatValArray_get_value()
+ - db_CatValArray_get_value_double()
+ - db_CatValArray_get_value_int()
+ - db_CatValArray_sort()
+ - db_CatValArray_sort_by_value()
+ - db_close_cursor()
+ - db_close_database()
+ - db_close_database_shutdown_driver()
+ - db_column_Ctype()
+ - db_column_sqltype()
+ - db_commit_transaction()
+ - db_copy_table()
+ - db_copy_table_where()
+ - db_copy_table_select()
+ - db_copy_table_by_ints()
+ - db_create_database()
+ - db_create_index()
+ - db_create_table()
+ - db_delete()
+ - db_delete_database()
+ - db_delete_table()
+ - db_describe_table()
+ - db_drop_column()
+ - db_drop_index()
+ - db_drop_table()
+ - db_execute_immediate()
+ - db_fetch()
+ - db_find_database()
+ - db_get_column()
+ - db_get_num_rows()
+ - db_get_table_number_of_rows()
+ - db_grant_on_table()
+ - db_gversion()
+ - db_insert()
+ - db_list_databases()
+ - db_list_drivers()
+ - db_list_indexes()
+ - db_list_tables()
+ - db_open_database()
+ - db_open_insert_cursor()
+ - db_open_select_cursor()
+ - db_open_update_cursor()
+ - db_print_column_definition()
+ - db_print_table_definition()
+ - db_start_driver_open_database()
+ - db_select_CatValArray()
+ - db_select_int()
+ - db_select_value()
+ - db_shutdown_driver()
+ - db_start_driver()
+ - db_table_exists()
+ - db_update()
+ - db__copy_table()
\section dbmi_driver DBMI DRIVER functions
