[GRASS-SVN] r32622 - in grass/trunk/lib/db: . dbmi_client
svn_grass at osgeo.org
Thu Aug 7 14:08:36 EDT 2008
Author: martinl
Date: 2008-08-07 14:08:36 -0400 (Thu, 07 Aug 2008)
New Revision: 32622
grass/trunk/lib/db/dbmi_client/c_add_col.c
grass/trunk/lib/db/dbmi_client/c_bindupdate.c
grass/trunk/lib/db/dbmi_client/c_close_cur.c
grass/trunk/lib/db/dbmi_client/c_closedb.c
grass/trunk/lib/db/dbmi_client/c_create_idx.c
grass/trunk/lib/db/dbmi_client/c_create_tab.c
grass/trunk/lib/db/dbmi_client/c_createdb.c
grass/trunk/lib/db/dbmi_client/c_delete.c
grass/trunk/lib/db/dbmi_client/c_deletedb.c
grass/trunk/lib/db/dbmi_client/c_desc_table.c
grass/trunk/lib/db/dbmi_client/c_drop_col.c
grass/trunk/lib/db/dbmi_client/c_drop_index.c
grass/trunk/lib/db/dbmi_client/c_drop_tab.c
grass/trunk/lib/db/dbmi_client/c_execute.c
grass/trunk/lib/db/dbmi_client/c_fetch.c
grass/trunk/lib/db/dbmi_client/c_finddb.c
grass/trunk/lib/db/dbmi_client/c_insert.c
grass/trunk/lib/db/dbmi_client/c_list_drivers.c
grass/trunk/lib/db/dbmi_client/c_list_idx.c
grass/trunk/lib/db/dbmi_client/c_list_tabs.c
grass/trunk/lib/db/dbmi_client/c_listdb.c
grass/trunk/lib/db/dbmi_client/c_opendb.c
grass/trunk/lib/db/dbmi_client/c_openinsert.c
grass/trunk/lib/db/dbmi_client/c_openselect.c
grass/trunk/lib/db/dbmi_client/c_openupdate.c
grass/trunk/lib/db/dbmi_client/c_priv.c
grass/trunk/lib/db/dbmi_client/c_rows.c
grass/trunk/lib/db/dbmi_client/c_update.c
grass/trunk/lib/db/dbmi_client/c_version.c
grass/trunk/lib/db/dbmi_client/column.c
grass/trunk/lib/db/dbmi_client/copy_tab.c
grass/trunk/lib/db/dbmi_client/db.c
grass/trunk/lib/db/dbmi_client/delete_tab.c
grass/trunk/lib/db/dbmi_client/printtab.c
grass/trunk/lib/db/dbmi_client/select.c
grass/trunk/lib/db/dbmi_client/shutdown.c
grass/trunk/lib/db/dbmi_client/start.c
grass/trunk/lib/db/dbmi_client/table.c
grass/trunk/lib/db/dbmilib.dox
db/dbmi_client: initial doxygenization, message standardization, update dbmilib doxygen page
(merge from devbr6, r32620 and r32621)
Modified: grass/trunk/lib/db/dbmi_client/c_add_col.c
--- grass/trunk/lib/db/dbmi_client/c_add_col.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/c_add_col.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_add_col.c
+ * \brief DBMI Library (client) - add column to table
+ * (C) 1999-2008 by the GRASS Development Team
+ * This program is free software under the GNU General Public
+ * License (>=v2). Read the file COPYING that comes with GRASS
+ * for details.
+ * \author Radim Blazek
#include <grass/dbmi.h>
#include "macros.h"
@@ -2,7 +16,11 @@
- \fn int db_add_column (dbDriver *driver, dbString *tableName, dbColumn *column)
- \brief
- \return
- \param
+ \brief Add column to table
+ \param driver db driver
+ \param tableName table name
+ \param column new column description (dbColumn structure)
+ \return DB_OK on success
+ \return DB_FAILED on failure
int db_add_column(dbDriver * driver, dbString * tableName, dbColumn * column)
Modified: grass/trunk/lib/db/dbmi_client/c_bindupdate.c
--- grass/trunk/lib/db/dbmi_client/c_bindupdate.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/c_bindupdate.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_bindupdate.c
+ * \brief DBMI Library (client) - bind update
+ * for details.
#include "macros.h"
@@ -2,6 +16,8 @@
- \fn int db_bind_update (dbCursor *cursor)
- \brief
- \return
- \param
+ \brief ADD
+ \param cursor db cursor
Modified: grass/trunk/lib/db/dbmi_client/c_close_cur.c
--- grass/trunk/lib/db/dbmi_client/c_close_cur.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/c_close_cur.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_close_cur.c
+ * \brief DBMI Library (client) - close cursor
+ * for details.
#include <stdlib.h>
#include "macros.h"
@@ -2,9 +16,10 @@
- \fn int db_close_cursor (dbCursor *cursor)
- \brief
- \return
- \param
+ \brief Close cursor
+ \param cursor cursor to be close
int db_close_cursor(dbCursor * cursor)
Modified: grass/trunk/lib/db/dbmi_client/c_closedb.c
--- grass/trunk/lib/db/dbmi_client/c_closedb.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/c_closedb.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_closedb.c
+ * \brief DBMI Library (client) - close database connection
+ * for details.
#include "macros.h"
@@ -2,7 +16,9 @@
- \fn int db_close_database (dbDriver *driver)
- \brief
- \return
- \param
+ \brief Close database connection
int db_close_database(dbDriver * driver)
Modified: grass/trunk/lib/db/dbmi_client/c_create_idx.c
--- grass/trunk/lib/db/dbmi_client/c_create_idx.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/c_create_idx.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_create_idx.c
+ * \brief DBMI Library (client) - create index
+ * for details.
#include <string.h>
#include "macros.h"
@@ -3,9 +17,12 @@
- \fn int db_create_index (dbDriver *driver, dbIndex *index)
- \brief
- \return
- \param
+ \brief Create index
+ \param index index info (pointer to dbIndex structure)
int db_create_index(dbDriver * driver, dbIndex * index)
@@ -32,13 +49,17 @@
- \brief Create unique index
- \return
- \param
+ \brief Create unique index
+ \param table_name table name
+ \param column_name column name (where to create index)
-int
-db_create_index2(dbDriver * driver, const char *table_name,
- const char *column_name)
+int db_create_index2(dbDriver * driver, const char *table_name,
+ const char *column_name)
int ret;
dbIndex index;
Modified: grass/trunk/lib/db/dbmi_client/c_create_tab.c
--- grass/trunk/lib/db/dbmi_client/c_create_tab.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/c_create_tab.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_create_tab.c
+ * \brief DBMI Library (client) - create table
+ * for details.
#include "macros.h"
@@ -2,6 +16,9 @@
- \fn int db_create_table (dbDriver *driver, dbTable *table)
- \brief
- \return
- \param
+ \brief Create table
+ \param table table description (pointer to dbTable structure)
Modified: grass/trunk/lib/db/dbmi_client/c_createdb.c
--- grass/trunk/lib/db/dbmi_client/c_createdb.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/c_createdb.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_createdb.c
+ * \brief DBMI Library (client) - create database
+ * for details.
#include "macros.h"
@@ -2,6 +16,9 @@
- \fn int db_create_database (dbDriver *driver, dbHandle *handle)
- \brief create database
- \return nothing
- \param driver, handle
+ \brief Create database
+ \param handle handle
Modified: grass/trunk/lib/db/dbmi_client/c_delete.c
--- grass/trunk/lib/db/dbmi_client/c_delete.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/c_delete.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_delete.c
+ * \brief DBMI Library (client) - delete record
+ * for details.
#include "macros.h"
@@ -2,6 +16,8 @@
- \fn int db_delete (dbCursor *cursor)
- \brief
- \return
- \param
+ \brief Delete record (?)
Modified: grass/trunk/lib/db/dbmi_client/c_deletedb.c
--- grass/trunk/lib/db/dbmi_client/c_deletedb.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/c_deletedb.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_deletedb.c
+ * \brief DBMI Library (client) - delete database
+ * for details.
#include "macros.h"
@@ -2,6 +16,9 @@
- \fn int db_delete_database (dbDriver *driver, dbHandle *handle)
- \brief
- \return
- \param
+ \brief Delete database
+ \param handle handle info
Modified: grass/trunk/lib/db/dbmi_client/c_desc_table.c
--- grass/trunk/lib/db/dbmi_client/c_desc_table.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/c_desc_table.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_desc_table.c
+ * \brief DBMI Library (client) - describe table
+ * for details.
#include "macros.h"
@@ -2,6 +16,10 @@
- \fn int db_describe_table (dbDriver *driver, dbString *name, dbTable **table)
- \brief
- \return
- \param
+ \brief Describe table
+ \param name table name
+ \param[out] pointer to dbTable structure
Modified: grass/trunk/lib/db/dbmi_client/c_drop_col.c
--- grass/trunk/lib/db/dbmi_client/c_drop_col.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/c_drop_col.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_drop_col.c
+ * \brief DBMI Library (client) - drop column
+ * for details.
#include "macros.h"
@@ -2,9 +16,12 @@
- \fn int db_drop_column (dbDriver *driver, dbString *tableName, dbString *columnName)
- \brief
- \return
- \param
+ \brief driver db driver
+ \param columnName column name to be dropped
-int
-db_drop_column(dbDriver * driver, dbString * tableName, dbString * columnName)
+int db_drop_column(dbDriver * driver, dbString * tableName, dbString * columnName)
Modified: grass/trunk/lib/db/dbmi_client/c_drop_index.c
--- grass/trunk/lib/db/dbmi_client/c_drop_index.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/c_drop_index.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_drop_index.c
+ * \brief DBMI Library (client) - drop index
+ * for details.
#include "macros.h"
@@ -2,7 +16,10 @@
- \fn int db_drop_index (dbDriver *driver, dbString *name)
- \brief
- \return
- \param
+ \brief Drop index
+ \param name index name
int db_drop_index(dbDriver * driver, dbString * name)
Modified: grass/trunk/lib/db/dbmi_client/c_drop_tab.c
--- grass/trunk/lib/db/dbmi_client/c_drop_tab.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/c_drop_tab.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_drop_tab.c
+ * \brief DBMI Library (client) - drop table
+ * for details.
#include "macros.h"
@@ -2,6 +16,9 @@
- \fn int db_drop_table (dbDriver *driver, dbString *name)
- \brief
- \return
- \param
+ \brief Drop table
+ \param name table name to be dropped
Modified: grass/trunk/lib/db/dbmi_client/c_execute.c
--- grass/trunk/lib/db/dbmi_client/c_execute.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/c_execute.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_execute.c
+ * \brief DBMI Library (client) - execute SQL statements
+ * for details.
#include "macros.h"
@@ -2,6 +16,9 @@
- \fn int db_execute_immediate (dbDriver *driver, dbString *SQLstatement)
- \brief
- \return
- \param
+ \brief Execute SQL statements
+ \param SQLstatement SQL statement (alter, update, ...)
@@ -29,10 +46,12 @@
- \fn int db_begin_transaction (dbDriver *driver)
- \brief
- \return
- \param
+ \brief Begin transaction
+ \return driver db driver
int db_begin_transaction(dbDriver * driver)
@@ -53,10 +72,12 @@
- \fn int db_commit_transaction (dbDriver *driver)
- \brief
- \return
- \param
+ \brief Commit transaction
int db_commit_transaction(dbDriver * driver)
Modified: grass/trunk/lib/db/dbmi_client/c_fetch.c
--- grass/trunk/lib/db/dbmi_client/c_fetch.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/c_fetch.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_fetch.c
+ * \brief DBMI Library (client) - fetch data
+ * for details.
#include "macros.h"
@@ -2,6 +16,10 @@
- \fn int db_fetch (dbCursor *cursor, int position, int *more)
- \brief
- \return
- \param
+ \brief Fetch data
+ \param position cursor position
+ \param[out] more get more?
Modified: grass/trunk/lib/db/dbmi_client/c_finddb.c
--- grass/trunk/lib/db/dbmi_client/c_finddb.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/c_finddb.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_finddb.c
+ * \brief DBMI Library (client) - find database
+ * for details.
#include <stdlib.h>
#include "macros.h"
@@ -3,8 +17,12 @@
- \fn int db_find_database (dbDriver *driver, dbHandle *handle, int *found)
- \brief
- \return
- \param
+ \brief Find database
+ \param[out] found if non-zero database found
int db_find_database(dbDriver * driver, dbHandle * handle, int *found)
Modified: grass/trunk/lib/db/dbmi_client/c_insert.c
--- grass/trunk/lib/db/dbmi_client/c_insert.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/c_insert.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_insert.c
+ * \brief DBMI Library (client) - insert new record
+ * for details.
#include "macros.h"
@@ -2,7 +16,9 @@
- \fn int db_insert (dbCursor *cursor)
- \brief
- \return
- \param
+ \brief Insert new record into table
int db_insert(dbCursor * cursor)
Modified: grass/trunk/lib/db/dbmi_client/c_list_drivers.c
--- grass/trunk/lib/db/dbmi_client/c_list_drivers.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/c_list_drivers.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,10 +1,23 @@
+ * \file db/dbmi_client/c_list_drivers.c
+ * \brief DBMI Library (client) - list drivers
+ * for details.
- \fn char *db_list_drivers(void)
- \brief return comma separated list of existing DB drivers, used for driver parameter options
- \return return char
- \param void
+ \brief Return comma separated list of existing DB drivers, used for driver parameter options
+ \return list of db drivers
const char *db_list_drivers(void)
Modified: grass/trunk/lib/db/dbmi_client/c_list_idx.c
--- grass/trunk/lib/db/dbmi_client/c_list_idx.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/c_list_idx.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_list_idx.c
+ * \brief DBMI Library (client) - list indexes
+ * for details.
#include "macros.h"
@@ -2,10 +16,14 @@
- \fn int db_list_indexes (dbDriver *driver, dbString *table_name, dbIndex **list, int *count)
- \brief
- \return
- \param
+ \brief List indexes
+ \param[out] list of db indexes
+ \param[out] number of items in the list
-int
-db_list_indexes(dbDriver * driver, dbString * table_name, dbIndex ** list,
- int *count)
+int db_list_indexes(dbDriver * driver, dbString * table_name, dbIndex ** list,
+ int *count)
Modified: grass/trunk/lib/db/dbmi_client/c_list_tabs.c
--- grass/trunk/lib/db/dbmi_client/c_list_tabs.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/c_list_tabs.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_list_tabs.c
+ * \brief DBMI Library (client) - list tables
+ * for details.
#include <stdlib.h>
#include <string.h>
@@ -12,12 +26,15 @@
- \fn int db_list_tables (dbDriver *driver, dbString **names, int *count, int system)
- \brief list available tables for given connection
- \return names of tables, success: DB_OK; DB_FAILED otherwise
- \param names: names of tables
- \param
- \param
+ \brief List available tables for given connection
+ \param[out] names list of table names
+ \param[out] count number of items in the list
+ \param system ?
int
db_list_tables(dbDriver * driver, dbString ** names, int *count, int system)
Modified: grass/trunk/lib/db/dbmi_client/c_listdb.c
--- grass/trunk/lib/db/dbmi_client/c_listdb.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/c_listdb.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_listdb.c
+ * \brief DBMI Library (client) - list databases
+ * for details.
#include "macros.h"
@@ -2,10 +16,15 @@
- \fn int db_list_databases (dbDriver *driver, dbString *path, int npaths, dbHandle **handles, int *count)
- \brief
- \return
- \param
-int
-db_list_databases(dbDriver * driver, dbString * path, int npaths,
- dbHandle ** handles, int *count)
+ \brief List databases
+ \param path db path
+ \param npaths number of given paths
+ \param[out] handles handle infos
+ \param[out] number of handle infos
+int db_list_databases(dbDriver * driver, dbString * path, int npaths,
+ dbHandle ** handles, int *count)
Modified: grass/trunk/lib/db/dbmi_client/c_opendb.c
--- grass/trunk/lib/db/dbmi_client/c_opendb.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/c_opendb.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_opendb.c
+ * \brief DBMI Library (client) - open database connection
+ * for details.
#include "macros.h"
@@ -2,6 +16,9 @@
- \fn
- \brief
- \return
- \param
+ \brief Open database connection
Modified: grass/trunk/lib/db/dbmi_client/c_openinsert.c
--- grass/trunk/lib/db/dbmi_client/c_openinsert.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/c_openinsert.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_openinsert.c
+ * \brief DBMI Library (client) - open insert cursor
+ * for details.
#include "macros.h"
@@ -2,6 +16,9 @@
- \fn
- \brief
- \return
- \param
+ \brief Open insert cursor
+ \param cursor cursor to be opened
Modified: grass/trunk/lib/db/dbmi_client/c_openselect.c
--- grass/trunk/lib/db/dbmi_client/c_openselect.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/c_openselect.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_openselect.c
+ * \brief DBMI Library (client) - open select cursor
+ * for details.
#include "macros.h"
@@ -2,10 +16,14 @@
- \fn
- \brief
- \return
- \param
+ \brief Open select cursor
+ \param select SQL select statement
+ \param cursor db cursor to be opened
+ \param mode open mode (?)
-int
-db_open_select_cursor(dbDriver * driver, dbString * select, dbCursor * cursor,
- int mode)
+int db_open_select_cursor(dbDriver * driver, dbString * select, dbCursor * cursor,
+ int mode)
Modified: grass/trunk/lib/db/dbmi_client/c_openupdate.c
--- grass/trunk/lib/db/dbmi_client/c_openupdate.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/c_openupdate.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_openupdate.c
+ * \brief DBMI Library (client) - open update cursor
+ * for details.
#include "macros.h"
@@ -2,10 +16,16 @@
- \fn
- \brief
- \return
- \param
+ \brief Open update cursor
+ \param select SQL update statement (?)
-int
-db_open_update_cursor(dbDriver * driver, dbString * table_name,
- dbString * select, dbCursor * cursor, int mode)
+int db_open_update_cursor(dbDriver * driver, dbString * table_name,
+ dbString * select, dbCursor * cursor, int mode)
Modified: grass/trunk/lib/db/dbmi_client/c_priv.c
--- grass/trunk/lib/db/dbmi_client/c_priv.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/c_priv.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_priv.c
+ * \brief DBMI Library (client) - privileges management
+ * for details.
#include "macros.h"
@@ -2,9 +16,13 @@
- \brief Grant privileges
- \return
- \param priv privileges: DB_PRIV_SELECT
- \param to grant to : DB_GROUP | DB_PUBLIC
-int
-db_grant_on_table(dbDriver * driver, const char *tableName, int priv, int to)
+ \brief Grant privileges
+ \param priv privileges DB_PRIV_SELECT
+ \param to grant to DB_GROUP | DB_PUBLIC
+int db_grant_on_table(dbDriver * driver, const char *tableName, int priv, int to)
Modified: grass/trunk/lib/db/dbmi_client/c_rows.c
--- grass/trunk/lib/db/dbmi_client/c_rows.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/c_rows.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_rows.c
+ * \brief DBMI Library (client) - get number of records
+ * for details.
#include "macros.h"
@@ -2,6 +16,8 @@
- \fn int db_get_num_rows ( dbCursor *cursor )
- \brief get number of selected rows
- \return
- \param
+ \brief Get number of selected rows
+ \param cursor db select cursor
Modified: grass/trunk/lib/db/dbmi_client/c_update.c
--- grass/trunk/lib/db/dbmi_client/c_update.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/c_update.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/c_update.c
+ * \brief DBMI Library (client) - update statemets
+ * for details.
#include "macros.h"
@@ -2,7 +16,9 @@
- \fn
- \brief
- \return
- \param
+ \brief ?
int db_update(dbCursor * cursor)
Modified: grass/trunk/lib/db/dbmi_client/c_version.c
--- grass/trunk/lib/db/dbmi_client/c_version.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/c_version.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,17 +1,35 @@
+ * \file db/dbmi_client/c_version.c
+ * \brief DBMI Library (client) - version info
+ * for details.
#include "macros.h"
-/* Note: renamed from db_version to db_gversion to avoid name conflict
- with Berkeley DB etc */
- \fn
- \brief
- \return
- \param
-int
-db_gversion(dbDriver * driver, dbString * client_version,
- dbString * driver_version)
+ \brief Get version info
+ Note: renamed from db_version to db_gversion to avoid name conflict
+ with Berkeley DB etc.
+ \param[out] client_version client version
+ \param[out] driver_version driver version
+int db_gversion(dbDriver * driver, dbString * client_version,
+ dbString * driver_version)
int ret_code;
Modified: grass/trunk/lib/db/dbmi_client/column.c
--- grass/trunk/lib/db/dbmi_client/column.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/column.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,21 +1,19 @@
+ * \file db/dbmi_client/column.c
+ * \brief DBMI Library (client) - column info
+ * for details.
+ * \author Update by Glynn Clement <glynn gclements.plus.com>
+ * and Martin Landa <landa.martin gmail.com>
-* MODULE: DBMI Library - dbmi_client column lib
-* AUTHOR(S): Radim Blazek (original contributor)
-* Glynn Clement <glynn gclements.plus.com>,
-* Martin Landa <landa.martin gmail.com>
-* PURPOSE: Higher level functions for DBMI DataBase Management Interface
-* COPYRIGHT: (C) 2001-2007 by the GRASS Development Team
-* This program is free software under the GNU General Public
-* License (>=v2). Read the file COPYING that comes with GRASS
-* for details.
#include <stdlib.h>
#include <string.h>
#include <grass/gis.h>
@@ -23,15 +21,17 @@
#include <grass/glocale.h>
- \fn int db_column_sqltype (dbDriver *driver, const char *tab, const char *col)
- \brief Get column sqltype
+ \brief Get column sqltype
- See db_sqltype_name ()
- \return column sqltype or -1 on error
- \param driver DB driver
- \param tab table name
- \param col column name
+ See db_sqltype_name().
+ \param driver DB driver
+ \param tab table name
+ \param col column name
+ \return column sqltype
+ \return -1 on error
int db_column_sqltype(dbDriver * driver, const char *tab, const char *col)
dbTable *table;
@@ -59,14 +59,16 @@
- \fn int db_column_Ctype (dbDriver *driver, const char *tab, const char *col)
- \brief Get column Ctype
+ \brief Get column ctype
- See db_sqltype_to_Ctype()
- \return column Ctype or -1 on error
+ See db_sqltype_to_Ctype().
+ \return column Ctype
int db_column_Ctype(dbDriver * driver, const char *tab, const char *col)
@@ -81,19 +83,20 @@
- \fn int db_get_column ( dbDriver *Driver, const char *tname, const char *cname, dbColumn **Column )
- \brief Get column structure by table and column name.
+ \brief Get column structure by table and column name.
- Column is set to new dbColumn structure or NULL if column was not found
- \return DB_OK on success, DB_FAILED on error
- \param Driver DB driver
- \param tname table name
- \param cname column name
- \param Column column structure to store within
-int
-db_get_column(dbDriver * Driver, const char *tname, const char *cname,
- dbColumn ** Column)
+ Column is set to new dbColumn structure or NULL if column was not found
+ \param Driver DB driver
+ \param tname table name
+ \param cname column name
+ \param[out] Column column structure to store within
+int db_get_column(dbDriver * Driver, const char *tname, const char *cname,
+ dbColumn ** Column)
int i, ncols;
dbTable *Table;
@@ -104,7 +107,7 @@
db_set_string(&tabname, tname);
if (db_describe_table(Driver, &tabname, &Table) != DB_OK) {
- G_warning(_("Cannot describe table <%s>"), tname);
+ G_warning(_("Unable to describe table <%s>"), tname);
return DB_FAILED;
Modified: grass/trunk/lib/db/dbmi_client/copy_tab.c
--- grass/trunk/lib/db/dbmi_client/copy_tab.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/copy_tab.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,6 +1,21 @@
+ * \file db/dbmi_client/copy_tab.c
+ * \brief DBMI Library (client) - copy table
+ * for details.
#include <stdlib.h>
#include <string.h>
+#include <grass/glocale.h>
#include "macros.h"
static int cmp(const void *pa, const void *pb)
@@ -15,25 +30,36 @@
return 0;
-/* Copy table, used by various db_copy_table*
+ \brief Copy table, used by various db_copy_table*
+ Use either 'where' or 'select' or 'selcol'+'ivals'+'nvals' but
+ never more than one.
- Parameters:
- where: WHERE SQL condition (without where key word) or NULL
- select: full select statement
- selcol: name of column used to select records by values in ivals or NULL
- ivals: pointer to array of integer values or NULL
- nvals: number of values in ivals
+ Warning: driver opened as second must be closed as first, otherwise
+ it hangs, not sure why.
- Use either 'where' or 'select' or 'selcol'+'ivals'+'nvals' but never more than one
+ \param from_dvrname name of driver from table is copied
+ \param from_dbname name of database from table is copied
+ \param from_tbl_name name of table to be copied
+ \param to_dvrname name of driver to - where table is copied to
+ \param to_dbname name of database to - where table is copied to
+ \param to_dbname name of copied table
+ \param where WHERE SQL condition (without where key word) or NULL
+ \param select full select statement
+ \param selcol name of column used to select records by values in ivals or NULL
+ \param ivals pointer to array of integer values or NULL
+ \param nvals number of values in ivals
-/* Warning, driver opened as second must be closed as first, otherwise it hangs, not sure why */
-int
-db__copy_table(const char *from_drvname, const char *from_dbname,
- const char *from_tblname, const char *to_drvname,
- const char *to_dbname, const char *to_tblname,
- const char *where, const char *select, const char *selcol,
- int *ivals, int nvals)
+int db__copy_table(const char *from_drvname, const char *from_dbname,
+ const char *from_tblname, const char *to_drvname,
+ const char *to_dbname, const char *to_tblname,
+ const char *where, const char *select, const char *selcol,
+ int *ivals, int nvals)
int col, ncols, sqltype, ctype, more, selcol_found;
char buf[1000];
@@ -71,12 +97,13 @@
/* Open input driver and database */
from_driver = db_start_driver(from_drvname);
if (from_driver == NULL) {
- G_warning("Cannot open driver '%s'", from_drvname);
+ G_warning(_("Unable to start driver <%s>"), from_drvname);
return DB_FAILED;
db_set_handle(&from_handle, from_dbname, NULL);
if (db_open_database(from_driver, &from_handle) != DB_OK) {
- G_warning("Cannot open database '%s'", from_dbname);
+ G_warning(_("Unable to open database <%s> by driver <%s>"),
+ from_drvname, from_dbname);
db_close_database_shutdown_driver(from_driver);
return DB_FAILED;
@@ -90,13 +117,14 @@
else {
to_driver = db_start_driver(to_drvname);
if (to_driver == NULL) {
- G_warning("Cannot open driver '%s'", to_drvname);
+ G_warning(_("Unable to start driver <%s>"), to_drvname);
return DB_FAILED;
db_set_handle(&to_handle, to_dbname, NULL);
if (db_open_database(to_driver, &to_handle) != DB_OK) {
- G_warning("Cannot open database '%s'", to_dbname);
+ to_drvname, to_dbname);
db_close_database_shutdown_driver(to_driver);
if (from_driver != to_driver) {
@@ -113,7 +141,8 @@
/* test if the table exists */
if (db_list_tables(to_driver, &tblnames, &count, 0) != DB_OK) {
- G_warning("Cannot list tables in database '%s'", to_dbname);
+ G_warning(_("Unable to get list tables in database <%s>"),
+ to_dbname);
@@ -125,7 +154,8 @@
const char *tblname = db_get_string(&tblnames[i]);
if (strcmp(to_tblname, tblname) == 0) {
- G_warning("Table '%s' already exists", to_dbname);
+ G_warning(_("Table <%s> already existsin database <%s>"),
+ to_dbname, to_dbname);
@@ -166,7 +196,8 @@
G_debug(3, db_get_string(&sql));
if (db_open_select_cursor(from_driver, &sql, &cursor, DB_SEQUENTIAL) !=
DB_OK) {
- G_warning("Cannot open select cursor: '%s'", db_get_string(&sql));
+ G_warning(_("Unable to open select cursor: '%s'"),
+ db_get_string(&sql));
@@ -197,7 +228,8 @@
if (selcol && G_strcasecmp(colname, selcol) == 0) {
if (ctype != DB_C_TYPE_INT)
- G_fatal_error("Column '%s' is not integer", colname);
+ G_fatal_error(_("Column <%s> is not integer"),
+ colname);
selcol_found = 1;
@@ -213,10 +245,11 @@
db_close_cursor(&cursor);
if (selcol && !selcol_found)
- G_fatal_error("Column '%s' not found", selcol);
+ G_fatal_error(_("Column <%s> not found"), selcol);
if (db_create_table(to_driver, out_table) != DB_OK) {
- G_warning("Cannot create new table");
+ G_warning(_("Unable to create table <%s>"),
+ out_table);
@@ -240,7 +273,8 @@
DB_OK) {
@@ -258,7 +292,8 @@
int select;
if (db_fetch(&cursor, DB_NEXT, &more) != DB_OK) {
- G_warning("Cannot fetch row");
+ G_warning(_("Unable to fetch data from table <%s>"),
+ from_tblname);
@@ -313,7 +348,8 @@
break;
default:
- G_warning("Unknown column type (%s)", colname);
+ G_warning(_("Unknown column type (column <%s>)"),
+ colname);
@@ -327,7 +363,8 @@
db_append_string(&sql, ")");
if (db_execute_immediate(to_driver, &sql) != DB_OK) {
- G_warning("Cannot insert new record: '%s'", db_get_string(&sql));
+ G_warning("Unable to insert new record: '%s'",
@@ -351,16 +388,21 @@
- \fn int db_copy_table (const char *from_drvname, const char *from_dbname, const char *from_tblname,
- const char *to_drvname, const char *to_dbname, const char *to_tblname )
- \brief Copy a table
- \return
- \param
+ \brief Copy a table
-int
-db_copy_table(const char *from_drvname, const char *from_dbname,
- const char *to_dbname, const char *to_tblname)
+int db_copy_table(const char *from_drvname, const char *from_dbname,
+ const char *to_dbname, const char *to_tblname)
return db__copy_table(from_drvname, from_dbname, from_tblname,
to_drvname, to_dbname, to_tblname,
@@ -368,17 +410,23 @@
- \fn int db_copy_table_where (const char *from_drvname, const char *from_dbname, const char *from_tblname,
- const char *to_drvname, const char *to_dbname, const char *to_tblname, const char *where )
- \return
- \param where WHERE SQL condition (without where key word) or NULL
-int
-db_copy_table_where(const char *from_drvname, const char *from_dbname,
- const char *where)
+ \brief Copy a table (by where statement)
+int db_copy_table_where(const char *from_drvname, const char *from_dbname,
+ const char *where)
@@ -386,17 +434,23 @@
- \fn int db_copy_table_select ( const char *from_drvname, const char *from_dbname, const char *from_tblname,
- const char *to_drvname, const char *to_dbname, const char *to_tblname, const char *select )
- \return
- \param select is full select statement or NULL
-int
-db_copy_table_select(const char *from_drvname, const char *from_dbname,
- const char *select)
+ \brief Copy a table (by select statement)
+int db_copy_table_select(const char *from_drvname, const char *from_dbname,
+ const char *select)
@@ -404,21 +458,25 @@
- \fn int db_copy_table_by_ints ( const char *from_drvname, const char *from_dbname, const char *from_tblname,
- const char *selcol, int *ivals, int nvals )
- \brief Copy a table, but only records where value of column 'selcol'
- is in 'ivals'
- \return
- \param selcol name of column used to select records by values in ivals or NULL
- \param ivals pointer to array of integer values or NULL
- \param nvals number of values in ivals
-int
-db_copy_table_by_ints(const char *from_drvname, const char *from_dbname,
- const char *selcol, int *ivals, int nvals)
+ \brief Copy a table (by keys)
+int db_copy_table_by_ints(const char *from_drvname, const char *from_dbname,
+ const char *selcol, int *ivals, int nvals)
Modified: grass/trunk/lib/db/dbmi_client/db.c
--- grass/trunk/lib/db/dbmi_client/db.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/db.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,11 +1,29 @@
+ * \file db/dbmi_client/db.c
+ * \brief DBMI Library (client) - open/close driver/database connection
+ * for details.
#include "macros.h"
- \fn dbDriver * db_start_driver_open_database ( const char *drvname, const char *dbname )
- \brief
- \return
- \param
+ \brief Open driver/database connection
+ \param drvname driver name
+ \param dbname database name
+ \return poiner to dbDriver structure
+ \return NULL on failure
dbDriver *db_start_driver_open_database(const char *drvname,
const char *dbname)
@@ -13,20 +31,20 @@
dbHandle handle;
dbDriver *driver;
- G_debug(3,
- "db_start_driver_open_database():\n drvname = %s, dbname = %s",
+ G_debug(3, "db_start_driver_open_database():\n drvname = %s, dbname = %s",
drvname, dbname);
db_init_handle(&handle);
driver = db_start_driver(drvname);
if (driver == NULL) {
- G_warning("Cannot open driver '%s'", drvname);
+ G_warning(_("Unable to start driver <%s>"), drvname);
return NULL;
db_set_handle(&handle, dbname, NULL);
if (db_open_database(driver, &handle) != DB_OK) {
- G_warning("Cannot open database '%s'", dbname);
+ dbname, drvname);
db_shutdown_driver(driver);
return NULL;
@@ -35,11 +53,12 @@
- \fn int db_close_database_shutdown_driver (dbDriver *driver )
- \brief
- \return
- \param
+ \brief Close driver/database connection
+ \return DB_OK
int db_close_database_shutdown_driver(dbDriver * driver)
db_close_database(driver);
Modified: grass/trunk/lib/db/dbmi_client/delete_tab.c
--- grass/trunk/lib/db/dbmi_client/delete_tab.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/delete_tab.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,14 +1,32 @@
+ * \file db/dbmi_client/delete_tab.c
+ * \brief DBMI Library (client) - delete table
+ * for details.
#include "macros.h"
- \fn int db_delete_table ( const char *drvname, const char *dbname, const char *tblname )
- \brief
- \return
- \param
+ \brief Delete table
+ \param drv driver name
+ \param tblname table name
-int
-db_delete_table(const char *drvname, const char *dbname, const char *tblname)
+int db_delete_table(const char *drvname, const char *dbname, const char *tblname)
dbDriver *driver;
dbHandle handle;
@@ -23,12 +41,13 @@
/* Open driver and database */
+ G_warning(_("Unable to open driver <%s>"), drvname);
return DB_FAILED;
+ dbname, drvname);
return DB_FAILED;
@@ -40,7 +59,8 @@
if (db_execute_immediate(driver, &sql) != DB_OK) {
- G_warning("Cannot drop table: '%s'", db_get_string(&sql));
+ G_warning(_("Unable to drop table: '%s'"),
return DB_FAILED;
Modified: grass/trunk/lib/db/dbmi_client/printtab.c
--- grass/trunk/lib/db/dbmi_client/printtab.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/printtab.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/printtab.c
+ * \brief DBMI Library (client) - print table description info
+ * for details.
#include <string.h>
@@ -4,11 +18,11 @@
static void print_priv();
- \fn
- \brief
- \return
- \param
+ \brief Print table definition info
+ \param fd file descriptor
+ \param table table info
void db_print_table_definition(FILE * fd, dbTable * table)
int ncols, col;
@@ -28,6 +42,12 @@
+ \brief Print column definition info
+ \param column column info
void db_print_column_definition(FILE * fd, dbColumn * column)
dbString value_string;
Modified: grass/trunk/lib/db/dbmi_client/select.c
--- grass/trunk/lib/db/dbmi_client/select.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/select.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/select.c
+ * \brief DBMI Library (client) - select records from table
+ * for details.
#include <stdlib.h>
#include <string.h>
@@ -2,2 +16,3 @@
@@ -74,16 +89,17 @@
- \fn db_select_int (dbDriver *driver, const char *tab, const char *col, const char *where, int **pval)
- \brief Select array of ordered integers from table/column
- \return number of selected values, -1 on error
- \param where where statement
- \param pval array of ordered integer values
+ \brief Select array of ordered integers from table/column
+ \param where where statement
+ \param[out] pval array of ordered integer values
+ \return number of selected values
int db_select_int(dbDriver * driver, const char *tab, const char *col,
@@ -164,15 +180,17 @@
- \fn db_select_value (dbDriver *driver, const char *tab, const char *key, int id, const char *col, dbValue *val)
- \brief Select one (first) value from table/column for key/id
- \param key key column name
- \param id identifier in key column
- \param col name of column to select the value from
- \param val dbValue to store within
+ \brief Select one (first) value from table/column for key/id
+ \param key key column name
+ \param id identifier in key column
+ \param col name of column to select the value from
+ \param[out] val dbValue to store within
int db_select_value(dbDriver * driver, const char *tab, const char *key,
int id, const char *col, dbValue * val)
@@ -215,14 +233,16 @@
- \fn int db_select_CatValArray (dbDriver *driver, const char *tab, const char *key, const char *col, const char *where, dbCatValArray *cvarr)
- \brief Select pairs key/value to array, values are sorted by key (must be integer)
- \param col value column name
- \param cvarr dbCatValArray to store within
+ \brief Select pairs key/value to array, values are sorted by key (must be integer)
+ \param col value column name
+ \param[out] cvarr dbCatValArray to store within
int db_select_CatValArray(dbDriver * driver, const char *tab, const char *key,
@@ -256,7 +276,7 @@
nrows = db_get_num_rows(&cursor);
G_debug(3, " %d rows selected", nrows);
if (nrows < 0)
- G_fatal_error("Cannot select rows from database");
+ G_fatal_error(_("Unable select records from table <%s>"), tab);
db_CatValArray_alloc(cvarr, nrows);
@@ -343,20 +363,21 @@
- \fn void db_CatValArray_sort (dbCatValArray *arr)
- \brief Sort key/value array by key
- \param arr dbCatValArray (key/value array)
+ \brief Sort key/value array by key
+ \param[in,out] arr dbCatValArray (key/value array)
void db_CatValArray_sort(dbCatValArray * arr)
qsort((void *)arr->value, arr->n_values, sizeof(dbCatVal), cmpcat);
- \fn int db_CatValArray_sort_by_value (dbCatValArray *arr)
- \brief Sort key/value array by value
+ \brief Sort key/value array by value
+ \return DB_FAILED on error
int db_CatValArray_sort_by_value(dbCatValArray * arr)
@@ -385,12 +406,14 @@
- \fn int db_CatValArray_get_value (dbCatValArray *arr, int key, dbCatVal **cv)
- \brief Find value by key
- \param key key value
- \param cv dbCatVal structure (key/value) to store within
+ \brief Find value by key
+ \param arr dbCatValArray (key/value array)
+ \param key key value
+ \param[out] cv dbCatVal structure (key/value) to store within
int db_CatValArray_get_value(dbCatValArray * arr, int key, dbCatVal ** cv)
@@ -409,12 +432,14 @@
- \fn int db_CatValArray_get_value_int (dbCatValArray *arr, int key, int *val)
- \brief Find value (integer) by key
- \param val found value (integer)
+ \brief Find value (integer) by key
+ \param[out] val found value (integer)
int db_CatValArray_get_value_int(dbCatValArray * arr, int key, int *val)
@@ -433,13 +458,15 @@
- \fn int db_CatValArray_get_value_double (dbCatValArray *arr, int key, double *val)
- \brief Find value (double) by key
- \param val found value (double)
+ \brief Find value (double) by key
+ \param[out] val found value (double)
int db_CatValArray_get_value_double(dbCatValArray * arr, int key, double *val)
dbCatVal *catval;
Modified: grass/trunk/lib/db/dbmi_client/shutdown.c
--- grass/trunk/lib/db/dbmi_client/shutdown.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/shutdown.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/shutdown.c
+ * \brief DBMI Library (client) - shutdown database connection
+ * for details.
#include <stdlib.h>
#ifdef __MINGW32__
@@ -9,19 +23,19 @@
#include "macros.h"
- \fn
- \brief
- \return
- \param
-/* closedown the driver, and free the driver structure */
-/* NOTE: the management of the memory for the driver structure
- * probably should be handled differently.
- * db_start_driver() could take a pointer to driver structure as
- * an argument, instead of returning the pointer to allocated
- * then there would be no hidden free required
+ \brief Closedown the driver, and free the driver structure
+ <b>Note:</b> the management of the memory for the driver structure
+ probably should be handled differently.
+ db_start_driver() could take a pointer to driver structure as
+ an argument, instead of returning the pointer to allocated
+ then there would be no hidden free required
+ \return status (?)
int db_shutdown_driver(dbDriver * driver)
#ifndef __MINGW32__
Modified: grass/trunk/lib/db/dbmi_client/start.c
--- grass/trunk/lib/db/dbmi_client/start.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/start.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/start.c
+ * for details.
#include <string.h>
#include <stdlib.h>
#include <unistd.h>
@@ -14,18 +28,17 @@
#define WRITE 1
- * \fn dbDriver *db_start_driver (const char *name)
- * \brief Initialize a new dbDriver for db transaction.
- * If <b>name</b> is NULL, the db name will be assigned
- * connection.driverName.
- * \param[in] const char * driver name
- * \return NULL on error
+ \brief Initialize a new dbDriver for db transaction.
+ If <i>name</i> is NULL, the db name will be assigned
+ connection.driverName.
+ \param name driver name
+ \return pointer to dbDriver structure
+ \return NULL on error
dbDriver *db_start_driver(const char *name)
dbDriver *driver;
Modified: grass/trunk/lib/db/dbmi_client/table.c
--- grass/trunk/lib/db/dbmi_client/table.c 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmi_client/table.c 2008-08-07 18:08:36 UTC (rev 32622)
@@ -1,3 +1,17 @@
+ * \file db/dbmi_client/table.c
+ * \brief DBMI Library (client) - table management
+ * for details.
#include <stdlib.h>
#include <string.h>
@@ -2,14 +16,16 @@
- \fn int db_table_exists ( const char *, const char *, const char *)
- \brief check if table exists
- \param drvname: driver name
- \param dbname: database name
- \param tabname: table name
- \return: 1 exist, 0 doesn't exist, -1 error
- \param
-int
-db_table_exists(const char *drvname, const char *dbname, const char *tabname)
+ \brief Check if table exists
+ \param tabname table name
+ \return 1 exist
+ \return 0 doesn't exist
+ \return -1 error
+int db_table_exists(const char *drvname, const char *dbname, const char *tabname)
@@ -27,7 +43,7 @@
driver = db_start_driver_open_database(drvname, dbname);
- G_warning("Cannot open database '%s' by driver '%s'", dbname,
+ G_warning(_("Unable open database <%s> by driver <%s>"), dbname,
drvname);
return -1;
@@ -77,20 +93,23 @@
- \fn
- \brief return number of rows of table
- \return
- \param
+ \brief Get number of rows of table
+ \param sql SQL statement
+ \return number of records
+ \return -1
int db_get_table_number_of_rows(dbDriver * driver, dbString * sql)
int nrows;
dbCursor cursor;
if (db_open_select_cursor(driver, sql, &cursor, DB_SEQUENTIAL) != DB_OK) {
- G_warning("Cannot open select cursor: '%s'", db_get_string(sql));
+ G_warning(_("Unable to open select cursor: '%s'"), db_get_string(sql));
db_close_database_shutdown_driver(driver);
- return DB_FAILED;
+ return -1;
Modified: grass/trunk/lib/db/dbmilib.dox
--- grass/trunk/lib/db/dbmilib.dox 2008-08-07 17:54:47 UTC (rev 32621)
+++ grass/trunk/lib/db/dbmilib.dox 2008-08-07 18:08:36 UTC (rev 32622)
@@ -9,16 +9,17 @@
The attribute management was completely changed in GRASS 6 to achieve
multi-attribute capabilities managed within external databases. The former
dig_cats/ files are not used any more and all vector attributes are stored
-in external database. Connection with database is done through DBMI library
+in external database. Connection with database is done through <b>DBMI library</b>
(DataBase Management Interface) with its integrated drivers. At time of this
writing following DBMI drivers for attribute storage are available:
<ul>
<li> DBF: xBase files (default)
-<li> ODBC: to interface from www.unixodbc.org
+<li> ODBC: to interface from http://www.unixodbc.org
<li> PostgreSQL driver (note that PostgreSQL can also be accessed through
- ODBC)
-<li> mySQL
+ ODBC): http://www.postgresql.org
+<li> mySQL: http://mysql.com/
+<li> SQLite: http://www.sqlite.org/
</ul>
These drivers are compiled depending on present DB related libraries and
@@ -35,12 +36,13 @@
vector entity may be linked to attributes in different tables in different
databases connected by different drivers at the same time.
-The DBMI library contains drivers such as DBF, ODBC, MySQL and PostgreSQL.
-The functionality of the database support varies with the
-capabilities of the underlying RDBMS. Main features are multi-attributes
-support for various data types, also multiple tables may optionally be
-linked to one or many vector entity/ies. SQL (Structured Query Language) is
-used for all drivers, but in a limited implementation.
+The DBMI library contains drivers such as DBF, SQLite, ODBC, MySQL and
+PostgreSQL. The functionality of the database support varies with the
+capabilities of the underlying RDBMS. Main features are
+multi-attributes support for various data types, also multiple tables
+may optionally be linked to one or many vector entity/ies. SQL
+(Structured Query Language) is used for all drivers, but in a limited
+implementation.
For DBMI architecture details please read Blazek et al. 2002 (see below).
@@ -63,8 +65,117 @@
\section dbmi_client DBMI CLIENT functions
-[ to be moved here from below list ]
+ - db_add_column()
+ - db_begin_transaction()
+ - db_bind_update()
+ - db_CatValArray_get_value()
+ - db_CatValArray_get_value_double()
+ - db_CatValArray_get_value_int()
+ - db_CatValArray_sort()
+ - db_CatValArray_sort_by_value()
+ - db_close_cursor()
+ - db_close_database()
+ - db_close_database_shutdown_driver()
+ - db_column_Ctype()
+ - db_column_sqltype()
+ - db_commit_transaction()
+ - db_copy_table()
+ - db_copy_table_where()
+ - db_copy_table_select()
+ - db_copy_table_by_ints()
+ - db_create_database()
+ - db_create_index()
+ - db_create_table()
+ - db_delete()
+ - db_delete_database()
+ - db_delete_table()
+ - db_describe_table()
+ - db_drop_column()
+ - db_drop_index()
+ - db_drop_table()
+ - db_execute_immediate()
+ - db_fetch()
+ - db_find_database()
+ - db_get_column()
+ - db_get_num_rows()
+ - db_get_table_number_of_rows()
+ - db_grant_on_table()
+ - db_gversion()
+ - db_insert()
+ - db_list_databases()
+ - db_list_drivers()
+ - db_list_indexes()
+ - db_list_tables()
+ - db_open_database()
+ - db_open_insert_cursor()
+ - db_open_select_cursor()
+ - db_open_update_cursor()
+ - db_print_column_definition()
+ - db_print_table_definition()
+ - db_start_driver_open_database()
+ - db_select_CatValArray()
+ - db_select_int()
+ - db_select_value()
+ - db_shutdown_driver()
+ - db_start_driver()
+ - db_table_exists()
+ - db_update()
+ - db__copy_table()
\section dbmi_driver DBMI DRIVER functions
