[GRASS-SVN] r32727 - in grass/branches/develbranch_6/gui/wxpython:
gui_modules nviz
svn_grass at osgeo.org
Tue Aug 12 17:00:07 EDT 2008
Author: martinl
Date: 2008-08-12 17:00:07 -0400 (Tue, 12 Aug 2008)
New Revision: 32727
grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz.py
grass/branches/develbranch_6/gui/wxpython/nviz/nviz.h
grass/branches/develbranch_6/gui/wxpython/nviz/volume.cpp
wxGUI/nviz: volume updates: delete isosurface, dialog layout
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz.py 2008-08-12 13:48:27 UTC (rev 32726)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz.py 2008-08-12 21:00:07 UTC (rev 32727)
@@ -409,7 +409,8 @@
elif type == '3d-raster':
data[nvizType] = {}
- for sec in ('attribute', 'draw', 'position'):
+ for sec in ('attribute', 'draw', 'position',
+ 'isosurface', 'slice'):
data[nvizType][sec] = {}
# reset to default properties
@@ -487,7 +488,7 @@
# set default/workspace layer properties
data = self.SetLayerData(item, id, nvizType)
+ print data
# update properties
self.UpdateLayerProperties(item)
@@ -626,15 +627,13 @@
# attributes
- data['attribute']['shine'] = {}
- data['attribute']['shine']['map'] = \
- UserSettings.Get(group='nviz', key='surface', subkey=['shine', 'map'])
- data['attribute']['shine']['value'] = \
- UserSettings.Get(group='nviz', key='surface', subkey=['shine', 'value'])
- self.update.append('surface:attribute:shine')
+ for attrb in ('shine', ):
+ data['attribute'][attrb] = {}
+ for key, value in UserSettings.Get(group='nviz', key='volume',
+ subkey=attrb).iteritems():
+ data['attribute'][attrb][key] = value
+ self.update.append('surface:attribute:%s' % value)#
# draw
@@ -864,6 +863,16 @@
self.update.append('volume:draw:%s' % control)
data['draw'][control] = { 'value' : value }
+ # isosurface attributes
+ ### self.update.append('volume:attribute:%s' % value)
def Reset(self):
"""Reset (unload data)"""
self.nvizClass.Reset()
@@ -1223,7 +1232,7 @@
range=(0, 1),
bind=(self.OnViewChange, self.OnViewChanged, self.OnViewChangedSpin))
self.CreateControl(panel, dict=self.win['view'], name='z-exag', sliderHor=False,
- range=(1, 1),
+ range=(0, 1),
heightSizer = wx.GridBagSizer(vgap=3, hgap=3)
heightSizer.Add(item=wx.StaticText(panel, id=wx.ID_ANY, label=_("Height:")),
@@ -1332,7 +1341,7 @@
if code != 'mask':
use.Append(item=_('constant'))
self.win['surface'][code]['use'] = use.GetId()
- use.Bind(wx.EVT_CHOICE, self.OnSurfaceUse)
+ use.Bind(wx.EVT_CHOICE, self.OnMapObjUse)
gridSizer.Add(item=use, flag=wx.ALIGN_CENTER_VERTICAL,
pos=(row, 1))
@@ -1859,7 +1868,8 @@
gridSizer = wx.GridBagSizer(vgap=3, hgap=3)
# list
- isolevel = IsoSurfList(parent=panel, size=(300, 150))
+ isolevel = IsoSurfList(parent=panel, win=self.win['volume'],
+ size=(300, 150))
self.win['volume']['isosurfs'] = isolevel.GetId()
gridSizer.Add(item=isolevel, pos=(0, 0), span=(4, 1))
@@ -1930,7 +1940,7 @@
if use:
self.win['volume'][code]['use'] = use.GetId()
pos=(row, 1))
@@ -1938,7 +1948,7 @@
map = gselect.Select(parent=panel, id=wx.ID_ANY,
# size=globalvar.DIALOG_GSELECT_SIZE,
size=(200, -1),
- type="raster")
+ type="grid3")
self.win['volume'][code]['map'] = map.GetId() - 1 # FIXME
map.Bind(wx.EVT_TEXT, self.OnSurfaceMap)
gridSizer.Add(item=map, flag=wx.ALIGN_CENTER_VERTICAL,
@@ -2578,7 +2588,7 @@
self.Hide()
- def OnSurfaceUse(self, event):
+ def OnMapObjUse(self, event):
"""Surface attribute -- use -- map/constant"""
if not self.mapWindow.init:
return
@@ -2588,31 +2598,34 @@
# find attribute row
attrb = self.__GetWindowName(self.win['surface'], event.GetId())
if not attrb:
- return
+ attrb = self.__GetWindowName(self.win['volume'], event.GetId())
+ nvizType = 'volume'
+ else:
+ nvizType = 'surface'
selection = event.GetSelection()
- if self.win['surface'][attrb]['required']: # no 'unset'
+ if self.win[nvizType][attrb]['required']: # no 'unset'
selection += 1
if selection == 0: # unset
useMap = None
value = ''
elif selection == 1: # map
useMap = True
- value = self.FindWindowById(self.win['surface'][attrb]['map']).GetValue()
+ value = self.FindWindowById(self.win[nvizType][attrb]['map']).GetValue()
elif selection == 2: # constant
useMap = False
if attrb == 'color':
- value = self.FindWindowById(self.win['surface'][attrb]['const']).GetColour()
+ value = self.FindWindowById(self.win[nvizType][attrb]['const']).GetColour()
value = str(value[0]) + ':' + str(value[1]) + ':' + str(value[2])
else:
- value = self.FindWindowById(self.win['surface'][attrb]['const']).GetValue()
+ value = self.FindWindowById(self.win[nvizType][attrb]['const']).GetValue()
- self.SetMapObjUseMap(nvizType='surface',
+ self.SetMapObjUseMap(nvizType=nvizType,
attrb=attrb, map=useMap)
self.mapWindow.update.append('surface:attribute:%s' % attrb)
data = self.mapWindow.GetSelectedLayer(type='nviz')
- data['surface']['attribute'][attrb] = { 'map' : useMap,
+ data[nvizType]['attribute'][attrb] = { 'map' : useMap,
'value' : str(value),
self.mapWindow.UpdateLayerProperties()
@@ -3022,6 +3035,7 @@
list.Append("%s %s" % (_("Level"), str(level)))
list.Check(list.GetCount()-1)
+ list.SetSelection(list.GetCount()-1)
# add isosurface
layer = self.mapWindow.GetSelectedLayer()
@@ -3034,6 +3048,10 @@
# disable add button on max
if list.GetCount() >= wxnviz.MAX_ISOSURFS:
self.FindWindowById(event.GetId()).Enable(False)
+ # disable 'move-down'
+ moveDown = self.parent.FindWindowById(self.win['volume']['btnIsosurfMoveDown'])
+ if not moveDown.IsEnabled():
+ moveDown.Enable(False)
# enable delete & move buttons
btnDelete = self.FindWindowById(self.win['volume']['btnIsosurfDelete'])
@@ -3041,11 +3059,12 @@
btnDelete.Enable(True)
if list.GetCount() > 1:
btnMoveUp = self.FindWindowById(self.win['volume']['btnIsosurfMoveUp'])
- btnMoveDown = self.FindWindowById(self.win['volume']['btnIsosurfMoveDown'])
if not btnMoveUp.IsEnabled():
btnMoveUp.Enable(True)
- btnMoveDown.Enable(True)
+ if self.parent.autoRender.IsChecked():
+ self.mapWindow.Refresh(False)
event.Skip()
def OnVolumeIsosurfDelete(self, event):
@@ -3053,12 +3072,32 @@
list = self.FindWindowById(self.win['volume']['isosurfs'])
btn = self.FindWindowById(event.GetId())
+ # remove item from list
+ isosurfId = list.GetSelection()
+ list.Delete(isosurfId)
+ # select last item
+ if list.GetCount() > 0:
+ # delete isosurface
+ layer = self.mapWindow.GetSelectedLayer()
+ data = self.mapWindow.GetSelectedLayer(type='nviz')['volume']
+ id = data['object']['id']
+ self.mapWindow.nvizClass.DeleteIsosurface(id, isosurfId)
+ # update buttons
if list.GetCount() < 1:
btn.Enable(False)
elif list.GetCount() < 2:
self.FindWindowById(self.win['volume']['btnIsosurfMoveUp']).Enable(False)
self.FindWindowById(self.win['volume']['btnIsosurfMoveDown']).Enable(False)
+ event.Skip()
def OnVolumeIsosurfMoveUp(self, event):
"""Move isosurface up in the list"""
pass
@@ -3337,8 +3376,35 @@
else:
win.SetValue(dict['value'])
- self.FindWindowById(self.win['volume']['color']['map']).SetValue("precip3d.500z50 at PERMANENT")
+ for attr in ('color', ): # required
+ if layer and layer.type == '3d-raster':
+ self.FindWindowById(self.win['volume'][attr]['map']).SetValue(layer.name)
+ else:
+ self.FindWindowById(self.win['volume'][attr]['map']).SetValue('')
+ self.SetMapObjUseMap(nvizType='volume',
+ attrb=attr, map=True) # -> map
+ if data['attribute'].has_key('color'):
+ value = data['attribute']['color']['value']
+ if data['attribute']['color']['map']:
+ self.FindWindowById(self.win['volume']['color']['map']).SetValue(value)
+ else: # constant
+ color = map(int, value.split(':'))
+ self.FindWindowById(self.win['volume']['color']['const']).SetColour(color)
+ attrb=attr, map=data['attribute']['color']['map'])
+ attrb='shine', map=data['attribute']['shine']['map'])
+ value = data['attribute']['shine']['value']
+ if data['attribute']['shine']['map']:
+ self.FindWindowById(self.win['volume']['shine']['map']).SetValue(value)
+ else:
+ self.FindWindowById(self.win['volume']['shine']['const']).SetValue(value)
def SetPage(self, name):
"""Get named page"""
self.notebook.SetSelection(self.page[name]['id'])
@@ -3416,6 +3482,35 @@
class IsoSurfList(wx.CheckListBox):
"""List of loaded volume isosurfaces (volume properties page)"""
- def __init__(self, parent, id=wx.ID_ANY, size=wx.DefaultSize):
+ def __init__(self, parent, win, id=wx.ID_ANY, size=wx.DefaultSize):
+ self.parent = parent
+ self.win = win
wx.CheckListBox.__init__(self, parent, id, size=size)
+ self.Bind(wx.EVT_CHECKLISTBOX, self.OnCheck)
+ self.Bind(wx.EVT_LISTBOX, self.OnSelect)
+ def OnCheck(self, event):
+ """Item checked/unchecked -> load/delete surface"""
+ print event.IsChecked()
+ def OnSelect(self, event):
+ """Item selected"""
+ winUp = self.parent.FindWindowById(self.win['btnIsosurfMoveUp'])
+ winDown = self.parent.FindWindowById(self.win['btnIsosurfMoveDown'])
+ selection = event.GetSelection()
+ if selection == 0:
+ winUp.Enable(False)
+ if not winDown.IsEnabled():
+ winDown.Enable()
+ elif selection == self.GetCount() - 1:
+ winDown.Enable(False)
+ if not winUp.IsEnabled():
+ winUp.Enable()
+ else:
+ winDown.Enable()
+ winUp.Enable()
Modified: grass/branches/develbranch_6/gui/wxpython/nviz/nviz.h
--- grass/branches/develbranch_6/gui/wxpython/nviz/nviz.h 2008-08-12 13:48:27 UTC (rev 32726)
+++ grass/branches/develbranch_6/gui/wxpython/nviz/nviz.h 2008-08-12 21:00:07 UTC (rev 32727)
@@ -101,6 +101,7 @@
/* volume */
int AddIsosurface(int, int);
+ int DeleteIsosurface(int, int);
int SetIsosurfaceColor(int, int, bool, const char *);
Modified: grass/branches/develbranch_6/gui/wxpython/nviz/volume.cpp
--- grass/branches/develbranch_6/gui/wxpython/nviz/volume.cpp 2008-08-12 13:48:27 UTC (rev 32726)
+++ grass/branches/develbranch_6/gui/wxpython/nviz/volume.cpp 2008-08-12 21:00:07 UTC (rev 32727)
@@ -45,6 +45,33 @@
ATT_TOPO, level);
+ \brief Delete isosurface
+ \param id volume id
+ \param isosurf_id isosurface id
+ \return 1 on success
+ \return -1 volume not found
+ \return -2 isosurface not found
+ \return -3 on failure
+int Nviz::DeleteIsosurface(int id, int isosurf_id)
+ int ret;
+ if (!GVL_vol_exists(id))
+ return -1;
+ if (isosurf_id > GVL_isosurf_num_isosurfs(id))
+ return -2;
+ ret = GVL_isosurf_del(id, isosurf_id);
+ return ret < 0 ? -3 : 1;
\brief Set surface color
